[GRASS-SVN] r58259 - grass-addons/grass7/raster/r.sun.daily
svn_grass at osgeo.org
Wed Nov 20 12:08:00 PST 2013
Author: wenzeslaus
Date: 2013-11-20 12:08:00 -0800 (Wed, 20 Nov 2013)
New Revision: 58259
grass-addons/grass7/raster/r.sun.daily/r.sun.daily.py
grass-addons/grass7/raster/r.sun.daily/test.r.sun.daily.sh
r.sun.daily: report error when cumulative maps are requested together with day step higher then 1
Modified: grass-addons/grass7/raster/r.sun.daily/r.sun.daily.py
--- grass-addons/grass7/raster/r.sun.daily/r.sun.daily.py 2013-11-20 11:46:05 UTC (rev 58258)
+++ grass-addons/grass7/raster/r.sun.daily/r.sun.daily.py 2013-11-20 20:08:00 UTC (rev 58259)
@@ -74,28 +74,28 @@
#% type: string
#% gisprompt: new,cell,raster
#% key: beam_rad
-#% description: Output beam irradiation raster map [Wh.m-2.day-1]
+#% description: Output beam irradiation raster map cumulated for the whole period of time [Wh.m-2.day-1]
#% required: no
#%end
#%option
#% type: string
#% key: diff_rad
-#% description: Output diffuse irradiation raster map [Wh.m-2.day-1]
+#% description: Output diffuse irradiation raster map cumulated for the whole period of time [Wh.m-2.day-1]
#% required: no
#%end
#%option
#% type: string
#% key: refl_rad
-#% description: Output ground reflected irradiation raster map [Wh.m-2.day-1]
+#% description: Output ground reflected irradiation raster map cumulated for the whole period of time [Wh.m-2.day-1]
#% required: no
#%end
#%option
#% type: string
#% key: glob_rad
-#% description: Output global (total) irradiance/irradiation raster map [Wh.m-2.day-1]
+#% description: Output global (total) irradiance/irradiation raster map cumulated for the whole period of time [Wh.m-2.day-1]
#% required: no
#%end
#%option
@@ -250,6 +250,28 @@
refl_rad_basename, glob_rad_basename]):
grass.fatal(_("No output specified."))
+ start_day = int(options['start_day'])
+ end_day = int(options['end_day'])
+ day_step = int(options['day_step'])
+ if day_step > 1 and (beam_rad or diff_rad or refl_rad or glob_rad):
+ grass.fatal(_("Day step higher then 1 would produce"
+ " meaningless cumulative maps."))
+ # check: start < end
+ if start_day > end_day:
+ grass.fatal(_("Start day is after end day."))
+ if day_step >= end_day - start_day:
+ grass.fatal(_("Day step is too big."))
+ step = float(options['step'])
+ nprocs = int(options['nprocs'])
+ temporal = flags['t']
+ if not is_grass_7() and temporal:
+ grass.warning(_("Flag t has effect only in GRASS 7"))
if beam_rad and not beam_rad_basename:
beam_rad_basename = create_tmp_map_name('beam_rad')
MREMOVE.append(beam_rad_basename)
@@ -263,24 +285,6 @@
glob_rad_basename = create_tmp_map_name('glob_rad')
MREMOVE.append(glob_rad_basename)
- start_day = int(options['start_day'])
- end_day = int(options['end_day'])
- day_step = int(options['day_step'])
- step = float(options['step'])
- nprocs = int(options['nprocs'])
- temporal = flags['t']
- if not is_grass_7() and temporal:
- grass.warning(_("Flag t has effect only in GRASS 7"))
- # check: start < end
- if start_day > end_day:
- grass.fatal(_("Start day is after end day."))
- if day_step >= end_day - start_day:
- grass.fatal(_("Day step is too big."))
# here we check all the days
if not grass.overwrite():
check_daily_map_names(beam_rad_basename, grass.gisenv()['MAPSET'],
Modified: grass-addons/grass7/raster/r.sun.daily/test.r.sun.daily.sh
--- grass-addons/grass7/raster/r.sun.daily/test.r.sun.daily.sh 2013-11-20 11:46:05 UTC (rev 58258)
+++ grass-addons/grass7/raster/r.sun.daily/test.r.sun.daily.sh 2013-11-20 20:08:00 UTC (rev 58259)
@@ -29,6 +29,7 @@
map_names_file=`g.tempfile pid=$$`
created_map_names_file=`g.tempfile pid=$$`
+should_not_be_created_map="test_r_sun_should_not_be_created_map"
cat > "${map_names_file}" << EOF
${map_basename}_026
@@ -44,13 +45,17 @@
echo "$NAME: r.sun.daily returned: $? (expecting 1)"
NAME="Wrong start and end day parameter values test (module should fail)"
-r.sun.daily elev_in=terrain start_day=82 end_day=37 day_step=3 reflrad_basename=${map_basename}
+r.sun.daily elev_in=terrain start_day=82 end_day=37 day_step=3 reflrad_basename=${should_not_be_created_map}
NAME="Wrong day step parameter values test (module should fail)"
-r.sun.daily elev_in=terrain start_day=82 end_day=85 day_step=9 reflrad_basename=${map_basename}
+r.sun.daily elev_in=terrain start_day=82 end_day=85 day_step=9 reflrad_basename=${should_not_be_created_map}
+NAME="Wrong day step parameter and cumulative parameters values test (module should fail)"
+r.sun.daily elev_in=terrain start_day=1 end_day=85 day_step=9 refl_rad=${should_not_be_created_map}
+echo "$NAME: r.sun.daily returned: $? (expecting 1)"
NAME="Map creation test"
r.sun.daily elev_in=terrain start_day=26 end_day=37 day_step=3 reflrad_basename=${map_basename}
