[GRASS-SVN] r58260 - grass/trunk/vector/v.category
svn_grass at osgeo.org
Wed Nov 20 12:22:14 PST 2013
Author: mmetz
Date: 2013-11-20 12:22:14 -0800 (Wed, 20 Nov 2013)
New Revision: 58260
grass/trunk/vector/v.category/main.c
v.category: improve r58202
Modified: grass/trunk/vector/v.category/main.c
--- grass/trunk/vector/v.category/main.c 2013-11-20 20:08:00 UTC (rev 58259)
+++ grass/trunk/vector/v.category/main.c 2013-11-20 20:22:14 UTC (rev 58260)
@@ -66,7 +66,7 @@
struct GModule *module;
struct Option *in_opt, *out_opt, *option_opt, *type_opt;
struct Option *cat_opt, *field_opt, *step_opt, *id_opt;
- struct Flag *shell, *nodb;
+ struct Flag *shell, *notab;
FREPORT **freps;
int nfreps, rtype, fld;
char *desc;
@@ -138,10 +138,8 @@
shell->label = _("Shell script style, currently only for report");
shell->description = _("Format: layer type count min max");
- nodb = G_define_flag();
- nodb->key = 'n';
- nodb->label = _("Avoid to copy the attribute table");
- nodb->description = _("Avoid to copy the attribute table in the database");
+ notab = G_define_standard_flag(G_FLG_V_TABLE);
+ notab->description = _("Do not copy attribute table(s)");
G_gisinit(argv[0]);
@@ -763,7 +761,7 @@
if (option == O_ADD || option == O_DEL || option == O_CHFIELD ||
option == O_SUM || option == O_TRANS){
- if (!nodb->answer){
+ if (!notab->answer){
G_message(_("Copying attribute table(s)..."));
if (Vect_copy_tables(&In, &Out, 0))
G_warning(_("Failed to copy attribute table to output map"));
