[GRASS-SVN] r58318 - grass-addons/grass7/raster/r.popgrowth
svn_grass at osgeo.org
Wed Nov 27 02:46:56 PST 2013
Author: jradinger
Date: 2013-11-27 02:46:55 -0800 (Wed, 27 Nov 2013)
New Revision: 58318
grass-addons/grass7/raster/r.popgrowth/r.popgrowth.py
Introduction of patch specific growth models beside single-cell populations.
Average growth rate and cumulative N0 and carrying capacity are used for each patch.
Modified: grass-addons/grass7/raster/r.popgrowth/r.popgrowth.py
--- grass-addons/grass7/raster/r.popgrowth/r.popgrowth.py 2013-11-27 03:58:52 UTC (rev 58317)
+++ grass-addons/grass7/raster/r.popgrowth/r.popgrowth.py 2013-11-27 10:46:55 UTC (rev 58318)
@@ -8,7 +8,7 @@
# VERSION:
-# DATE: 2013-08-28
+# DATE: 2013-11-27
#%Module
@@ -19,7 +19,7 @@
#% key: n_initial
#% type: string
#% gisprompt: old,cell,raster
-#% description: Map with number of individuals per cell at time t0 (initial population size)
+#% description: Map of number of individuals per cell at time t0 (initial population size)
#% required: yes
#%end
#%option
@@ -42,7 +42,7 @@
#%option
#% key: r_exp_fix
#% type: double
-#% description: Fixed value of intrinsic rate of increase, log(finite rate of increase, lambda)
+#% description: Cell-specific fixed value of intrinsic rate of increase, log(finite rate of increase, lambda)
#% required: no
#% multiple: no
#% guisection: Exponential
@@ -51,7 +51,7 @@
#% key: r_exp_map
#% type: string
-#% description: Map with intrinsic rate of increase, log(finite rate of increase, lambda)
+#% description: Map of cell-specific intrinsic rate of increase, log(finite rate of increase, lambda)
#% required: no
#% multiple: no
@@ -69,7 +69,7 @@
#%option
#% key: k_fix
#% type: integer
-#% description: Fixed value of carrying capacity of the environment
+#% description: Fixed value of carrying capacity of the environment (per cell)
#% required: no
#% guisection: Ricker
#%end
@@ -77,14 +77,14 @@
#% key: k_map
#% type: string
-#% description: Map with carrying capacity of the environment
+#% description: Map of carrying capacity of the environment (per cell)
#% required: no
#%end
#%option
#% key: r_rick_fix
#% type: double
-#% description: Fixed value of intrinsic rate of increase (Ricker)
+#% description: Cell-specific fixed value of intrinsic rate of increase (Ricker)
#% required: no
#% multiple: no
@@ -92,11 +92,19 @@
#%option
#% key: r_rick_map
-#% description: Map with intrinsic rate of increase (Ricker)
+#% description: Map of cell-specific intrinsic rate of increase (Ricker)
#% required: no
#% multiple: no
#%end
+#%option
+#% key: population_patches
+#% type: string
+#% gisprompt: old,cell,raster
+#% description: Optional raster map of patches of single populations. If provided, growth models are calculated based on these patches (patch-averaged r and cumulated k).
+#% required: no
+#% guisection: Optional
+#%end
#%Option
#% key: seed
#% type: integer
@@ -131,6 +139,11 @@
def cleanup():
grass.debug(_("This is the cleanup part"))
+ if (tmp_map_rast or tmp_map_vect):
+ grass.run_command("g.remove",
+ #rast = [f + str(os.getpid()) for f in tmp_map_rast],
+ vect = [f + str(os.getpid()) for f in tmp_map_vect],
+ quiet = True)
def main():
@@ -151,6 +164,21 @@
#Model parameters input
t = int(options['timesteps'])
+ # If populations patches are provided, otherwise single cell populations are used
+ if options['population_patches']:
+ grass.run_command("r.statistics2",
+ base=options['population_patches'],
+ cover=options['n_initial'],
+ method="sum",
+ output="n0_tmp_%d" % os.getpid())
+ else:
+ grass.run_command("g.copy",
+ rast=options['n_initial']+","+"n0_tmp_%d" % os.getpid())
+ tmp_map_rast.append("n0_tmp_")
# Customized rounding function. Round based on a probability (p=digits after decimal point) to avoid "local stable states"
@@ -183,7 +211,7 @@
if flags['i']:
n = vprob_round(n)
return n
- vricker_mod = numpy.vectorize(ricker_mod)
+ #vricker_mod = numpy.vectorize(ricker_mod) ##### ???????????
################# Exponential Model #################
if options['exponential_output']:
@@ -193,20 +221,49 @@
# Define r
if options['r_exp_map']:
- grass.message(_("r_exp_map provided"))
+ grass.debug(_("r_exp_map provided"))
+ cover=options['r_exp_map'],
+ method="average",
+ output="r_exp_tmp_%d" % os.getpid())
+ else:
+ rast=options['r_exp_map']+","+"r_exp_tmp_%d" % os.getpid())
+ tmp_map_rast.append("r_exp_tmp_")
r = garray.array()
- r.read(options['r_exp_map'])
+ r.read("r_exp_tmp_%d" % os.getpid())
elif options['r_exp_fix']:
r = float(options['r_exp_fix'])
else:
grass.fatal(_("No r value/map provided for exponential model"))
+ # run model
n0_map = garray.array()
- n0_map.read(options['n_initial'])
+ n0_map.read("n0_tmp_%d" % os.getpid())
exponential_map = garray.array()
exponential_map[...] = exponential_mod(n0_map,r,t)
- exponential_map.write(options['exponential_output'])
+ ricker_map.write("exponential_output_tmp_%d" % os.getpid())
+ tmp_map_rast.append("exponential_output_tmp_")
+ # Retransform in case of patches
+ grass.mapcalc("$exponential_output = round(($n0*1.0/$n0_tmp)*$exponential_output_tmp)",
+ ricker_output=options['exponential_output'],
+ n0=options['n_initial'],
+ n0_tmp="n0_tmp_%d" % os.getpid(),
+ ricker_output_tmp="exponential_output_tmp_%d" % os.getpid())
+ else:
+ rast="exponential_output_tmp_%d" % os.getpid() + ","+options['exponential_output'])
################# Ricker Model #################
if options['ricker_output']:
# Check for correct input
@@ -217,8 +274,22 @@
# Define r
if options['r_rick_map']:
+ cover=options['r_rick_map'],
+ method="average",
+ output="r_rick_tmp_%d" % os.getpid())
+ else:
+ rast=options['r_rick_map']+","+"r_rick_tmp_%d" % os.getpid())
+ tmp_map_rast.append("r_rick_tmp_")
r = garray.array()
- r.read(options['r_rick_map'])
+ r.read("r_rick_tmp_%d" % os.getpid())
elif options['r_rick_fix']:
r = float(options['r_rick_fix'])
else:
@@ -226,20 +297,51 @@
# Define k
if options['k_map']:
+ cover=options['k_map'],
+ method="sum",
+ output="k_tmp_%d" % os.getpid())
+ else:
+ rast=options['k_map']+","+"k_tmp_%d" % os.getpid())
+ tmp_map_rast.append("k_tmp_")
k = garray.array()
- k.read(options['k_map'])
+ k.read("k_tmp_%d" % os.getpid())
elif options['k_fix']:
k = float(options['k_fix'])
else:
grass.fatal(_("No value/map for carrying capacity (k) provided"))
+ # run model
ricker_map = garray.array()
ricker_map[...] = ricker_mod(n0_map,r,k,t)
- ricker_map.write(options['ricker_output'])
+ ricker_map.write("ricker_output_tmp_%d" % os.getpid())
+ tmp_map_rast.append("ricker_output_tmp_")
+ grass.mapcalc("$ricker_output = round(($n0*1.0/$n0_tmp)*$ricker_output_tmp)",
+ ricker_output=options['ricker_output'],
+ ricker_output_tmp="ricker_output_tmp_%d" % os.getpid())
+ else:
+ rast="ricker_output_tmp_%d" % os.getpid() +","+options['ricker_output'])
return 0
