[GRASS-SVN] r58319 - grass/branches/releasebranch_6_4/general/g.parser
svn_grass at osgeo.org
Wed Nov 27 12:59:34 PST 2013
Author: neteler
Date: 2013-11-27 12:59:34 -0800 (Wed, 27 Nov 2013)
New Revision: 58319
Added:
grass/branches/releasebranch_6_4/general/g.parser/g_parser_test.png
grass/branches/releasebranch_6_4/general/g.parser/Makefile
grass/branches/releasebranch_6_4/general/g.parser/description.html
g.parser manual: GUI window screenshot added to example
Property changes on: grass/branches/releasebranch_6_4/general/g.parser
___________________________________________________________________
Modified: svn:ignore
- *.tmp.html
*OBJ*
+ OBJ.*
*.tmp.html
Modified: grass/branches/releasebranch_6_4/general/g.parser/Makefile
--- grass/branches/releasebranch_6_4/general/g.parser/Makefile 2013-11-27 10:46:55 UTC (rev 58318)
+++ grass/branches/releasebranch_6_4/general/g.parser/Makefile 2013-11-27 20:59:34 UTC (rev 58319)
@@ -8,9 +8,15 @@
include $(MODULE_TOPDIR)/include/Make/Module.make
default: cmd
+ $(INSTALL_DATA) g_parser_test.png $(HTMLDIR)/g_parser_test.png
-#hardcoded here, this is an exeption due to the g.parser specialities:
+#FIXME: please comment or file bug reports instead of just quietly
+# bypassing portability problems with a ifneq(). otherwise underlying
+# problems never get fixed. thanks
ifneq ($(MSYSTEM),MINGW32)
+# hardcoded here, this is an exeption due to the g.parser specialities:
htmlcmd:
$(MAKE) $(HTMLDIR)/$(PGM).html HTMLSRC=
endif
Modified: grass/branches/releasebranch_6_4/general/g.parser/description.html
--- grass/branches/releasebranch_6_4/general/g.parser/description.html 2013-11-27 10:46:55 UTC (rev 58318)
+++ grass/branches/releasebranch_6_4/general/g.parser/description.html 2013-11-27 20:59:34 UTC (rev 58319)
@@ -12,6 +12,18 @@
<h2>NAME</h2>
<em><b>g.parser</b></em>
+<h2>SYNOPSIS</h2>
+<b>g.parser help</b><br>
+<b>g.parser</b> [-<b>s</b>] [-<b>t</b>] <em>filename</em> [<em>argument</em>,...]
+<h3>Flags:</h3>
+<dl>
+<dt><b>-t</b></dt>
+<dd>Print strings for translation</dd>
+<dt><b>-s</b></dt>
+<dd>Write option values to stdout instead of reinvoking script</dd>
+</dl>
<h2>DESCRIPTION</h2>
The <em>g.parser</em> module provides full parser support for GRASS
@@ -48,33 +60,21 @@
<div class="code"><pre>
#%module
-#% description: g.parser test script
+#% description: g.parser test script
#%end
#%flag
-#% key: f
-#% description: A flag
+#% key: f
+#% description: A flag
#%end
#%option
-#% key: raster
-#% type: string
-#% gisprompt: old,cell,raster
-#% description: Raster input map
-#% required : yes
+#% key: raster
+#% type: string
+#% gisprompt: old,cell,raster
+#% description: Raster input map
+#% required : yes
#%end
</pre></div>
-<h2>SYNOPSIS</h2>
-<b>g.parser help</b><br>
-<b>g.parser</b> [-<b>s</b>] [-<b>t</b>] <em>filename</em> [<em>argument</em>,...]
-<h3>Flags:</h3>
-<dl>
-<dt><b>-t</b></DT>
-<dd>Print strings for translation</DD>
-<dt><b>-s</b></DT>
-<dd>Write option values to stdout instead of reinvoking script</DD>
-</dl>
<h2>NOTES</h2>
An option can be instructed to allow multiple inputs by adding the
@@ -176,6 +176,12 @@
<h2>EXAMPLES</h2>
+All examples below autogenerate the graphical user interface when invoked
+without parameters of flags:
+<p>
+<img src="g_parser_test.png" alt="Autogenerated GUI window">
<h3>Example code for SHELL</h3>
@@ -239,7 +245,32 @@
</pre></div>
+To run properly, the script needs to be copied into $GISBASE/scripts/
+with the executable flag being set. The script will provide a GUI
+(as above) and the following usage help text:
+<div class="code"><pre>
+test.sh --help
+Description:
+ g.parser test script (python)
+Usage:
+ test.sh [-f] raster=string vector=string [option1=string]
+ [--verbose] [--quiet]
+Flags:
+ -f A flag
+ --v Verbose module output
+ --q Quiet module output
+Parameters:
+ raster Raster input map
+ vector Vector input map
+ option1 An option
+</pre></div>
<h3>Example code for Python</h3>
@@ -308,7 +339,8 @@
main()
</pre></div>
-The <tt>test.py</tt> script will provide following help text:
+The <tt>test.py</tt> script will provide a GUI (as above) and the
+following usage help text:
./test.py --help
@@ -413,7 +445,7 @@
<a href="g.ask.html">g.ask</a>,
<a href="g.filename.html">g.filename</a>,
<a href="g.findfile.html">g.findfile</a>,
- <a href="g.tempfile.html">g.tempfile</a>,
+ <a href="g.tempfile.html">g.tempfile</a>
</em>
and the <tt>SUBMITTING_SCRIPTS</tt> file in the GRASS source code.
Added: grass/branches/releasebranch_6_4/general/g.parser/g_parser_test.png
(Binary files differ)
Property changes on: grass/branches/releasebranch_6_4/general/g.parser/g_parser_test.png
Added: svn:mime-type
+ image/png
