[GRASS-SVN] r58325 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Fri Nov 29 01:43:40 PST 2013
Author: martinl
Date: 2013-11-29 01:43:40 -0800 (Fri, 29 Nov 2013)
New Revision: 58325
grass/trunk/lib/vector/Vlib/build_pg.c
grass/trunk/lib/vector/Vlib/open_pg.c
grass/trunk/lib/vector/Vlib/pg_local_proto.h
vlib/pg: fix clean-up GRASS DB topology tables in full mode
Modified: grass/trunk/lib/vector/Vlib/build_pg.c
--- grass/trunk/lib/vector/Vlib/build_pg.c 2013-11-29 08:27:30 UTC (rev 58324)
+++ grass/trunk/lib/vector/Vlib/build_pg.c 2013-11-29 09:43:40 UTC (rev 58325)
@@ -132,7 +132,7 @@
int build_topo(struct Map_info *Map, int build)
- int line, type, s;
+ int line, type, s, n_nodes;
int area, nareas, isle, nisles;
int face[2];
char stmt[DB_SQL_MAX];
@@ -162,7 +162,10 @@
/* cache features to speed-up random access (when attaching isles
to areas) */
if (build >= GV_BUILD_BASE) {
- pg_info->cache.ctype = CACHE_MAP;
+ /* clean-up GRASS topology tables in DB */
+ if (!pg_info->topo_geo_only)
+ Vect__clean_grass_db_topo(&(Map->fInfo.pg));
if (Map->mode == GV_MODE_RW &&
pg_info->cache.lines_num > 0) {
@@ -178,16 +181,29 @@
/* reset cache for reading features */
Vect__free_cache(&(pg_info->cache));
- /* force loading nodes from DB to get up-to-date node
- * offsets */
- Vect__free_offset(&(pg_info->offset));
- Map->plus.n_nodes = Vect__load_map_nodes_pg(Map, TRUE);
+ if (plus->built < GV_BUILD_BASE) {
+ /* force loading nodes from DB to get up-to-date node
+ * offsets, see write_nodes() for details */
+ Vect__free_offset(&(pg_info->offset));
+ pg_info->cache.ctype = CACHE_FEATURE; /* do not cache nodes */
+ n_nodes = Map->plus.n_nodes = Vect__load_map_nodes_pg(Map, TRUE);
+ Vect__free_cache(&(pg_info->cache));
+ if (build > GV_BUILD_BASE)
+ pg_info->cache.ctype = CACHE_MAP; /* cache all features */
/* update TopoGeometry based on GRASS-like topology */
Vect_build_nat(Map, build);
+ if (n_nodes != Map->plus.n_nodes)
+ G_warning(_("Inconsistency in topology: number of nodes %d (should be %d)"),
+ Map->plus.n_nodes, n_nodes);
/* store map boundig box in DB */
save_map_bbox(pg_info, &(plus->box));
@@ -888,4 +904,42 @@
*stmt_size = stmt_id_size;
+ \brief Clean-up GRASS Topology tables
+ \param pg_info pointer to Format_info_pg pg_info
+ \return 0 on success
+ \return -1 on error
+int Vect__clean_grass_db_topo(struct Format_info_pg *pg_info)
+ char stmt[DB_SQL_MAX];
+ sprintf(stmt, "DELETE FROM \"%s\".\"%s\"",
+ pg_info->toposchema_name, TOPO_TABLE_NODE);
+ if (-1 == Vect__execute_pg(pg_info->conn, stmt))
+ return -1;
+ pg_info->toposchema_name, TOPO_TABLE_LINE);
+ return -1;
+ pg_info->toposchema_name, TOPO_TABLE_AREA);
+ return -1;
+ pg_info->toposchema_name, TOPO_TABLE_ISLE);
+ return -1;
+ return 0;
#endif
Modified: grass/trunk/lib/vector/Vlib/open_pg.c
--- grass/trunk/lib/vector/Vlib/open_pg.c 2013-11-29 08:27:30 UTC (rev 58324)
+++ grass/trunk/lib/vector/Vlib/open_pg.c 2013-11-29 09:43:40 UTC (rev 58325)
@@ -322,7 +322,7 @@
\param[in,out] Map pointer to Map_info structure
\param head_only TRUE to read only header
- \param update TRUE for update mode (reloading topology)
+ \param update TRUE to clean GRASS topology in update mode
\return 1 topology layer does not exist
@@ -352,28 +352,10 @@
ret = Vect__load_plus_pg(Map, head_only);
- /* clean-up GRASS-like topology tables on update mode */
- if (update && !pg_info->topo_geo_only && ret == 0) {
- char stmt[DB_SQL_MAX];
+ if (update)
+ Vect__clean_grass_db_topo(pg_info);
- sprintf(stmt, "DELETE FROM \"%s\".\"%s\"",
- pg_info->toposchema_name, TOPO_TABLE_NODE);
- Vect__execute_pg(pg_info->conn, stmt);
- pg_info->toposchema_name, TOPO_TABLE_LINE);
- pg_info->toposchema_name, TOPO_TABLE_AREA);
- pg_info->toposchema_name, TOPO_TABLE_ISLE);
- return 0;
+ return ret;
#else
G_fatal_error(_("GRASS is not compiled with PostgreSQL support"));
return -1;
Modified: grass/trunk/lib/vector/Vlib/pg_local_proto.h
--- grass/trunk/lib/vector/Vlib/pg_local_proto.h 2013-11-29 08:27:30 UTC (rev 58324)
+++ grass/trunk/lib/vector/Vlib/pg_local_proto.h 2013-11-29 09:43:40 UTC (rev 58325)
@@ -61,6 +61,9 @@
/* area_pg.c */
int Vect__get_area_points_pg(const struct Map_info *, const plus_t *, int, struct line_pnts *);
+/* build_pg.c */
+int Vect__clean_grass_db_topo(struct Format_info_pg *);
/* read_pg.c */
SF_FeatureType Vect__cache_feature_pg(const char *, int, int,
struct Format_info_cache *,
