[GRASS-SVN] r58326 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Fri Nov 29 03:29:40 PST 2013
Author: martinl
Date: 2013-11-29 03:29:39 -0800 (Fri, 29 Nov 2013)
New Revision: 58326
grass/trunk/lib/vector/Vlib/read_pg.c
grass/trunk/lib/vector/Vlib/write_pg.c
vlib/pg: fix issues in SQL statements related to the schema name
Modified: grass/trunk/lib/vector/Vlib/read_pg.c
--- grass/trunk/lib/vector/Vlib/read_pg.c 2013-11-29 09:43:40 UTC (rev 58325)
+++ grass/trunk/lib/vector/Vlib/read_pg.c 2013-11-29 11:29:39 UTC (rev 58326)
@@ -1249,29 +1249,31 @@
sprintf(stmt,
"DECLARE %s CURSOR FOR "
"SELECT geom,id,type,fid FROM ("
- "SELECT tt.node_id AS id,tt.geom, %d AS type, ft.fid AS fid FROM \"%s\".node AS tt "
- "LEFT JOIN \"%s\" AS ft ON (%s).type = 1 AND (%s).id = node_id "
+ "SELECT tt.node_id AS id,tt.geom, %d AS type, ft.%s AS fid FROM \"%s\".node AS tt "
+ "LEFT JOIN \"%s\".\"%s\" AS ft ON (%s).type = 1 AND (%s).id = node_id "
"WHERE containing_face IS NULL AND node_id NOT IN "
"(SELECT node FROM (SELECT start_node AS node FROM \"%s\".edge GROUP BY start_node UNION ALL "
"SELECT end_node AS node FROM \"%s\".edge GROUP BY end_node) AS foo) UNION ALL "
- "LEFT JOIN \"%s\" AS ft ON (%s).type = 3 AND (%s).id = containing_face "
+ "LEFT JOIN \"%s\".\"%s\" AS ft ON (%s).type = 3 AND (%s).id = containing_face "
"WHERE containing_face IS NOT NULL AND node_id NOT IN "
- "SELECT tt.edge_id AS id, tt.geom, %d AS type, ft.fid AS fid FROM \"%s\".edge AS tt "
- "LEFT JOIN \"%s\" AS ft ON (%s).type = 2 AND (%s).id = edge_id "
+ "SELECT tt.edge_id AS id, tt.geom, %d AS type, ft.%s AS fid FROM \"%s\".edge AS tt "
+ "LEFT JOIN \"%s\".\"%s\" AS ft ON (%s).type = 2 AND (%s).id = edge_id "
"WHERE left_face = 0 AND right_face = 0 UNION ALL "
"WHERE left_face != 0 OR right_face != 0 ) AS foo ORDER BY type,id",
pg_info->cursor_name,
- GV_POINT, pg_info->toposchema_name, pg_info->table_name, pg_info->topogeom_column, pg_info->topogeom_column,
- pg_info->toposchema_name, pg_info->toposchema_name,
- GV_CENTROID, pg_info->toposchema_name, pg_info->table_name, pg_info->topogeom_column, pg_info->topogeom_column,
- GV_LINE, pg_info->toposchema_name, pg_info->table_name, pg_info->topogeom_column, pg_info->topogeom_column,
- GV_BOUNDARY, pg_info->toposchema_name, pg_info->table_name, pg_info->topogeom_column, pg_info->topogeom_column);
+ GV_POINT, pg_info->fid_column, pg_info->toposchema_name, pg_info->schema_name, pg_info->table_name,
+ pg_info->topogeom_column, pg_info->topogeom_column, pg_info->toposchema_name, pg_info->toposchema_name,
+ GV_CENTROID, pg_info->fid_column, pg_info->toposchema_name, pg_info->schema_name, pg_info->table_name,
+ GV_LINE, pg_info->fid_column, pg_info->toposchema_name, pg_info->schema_name, pg_info->table_name,
+ GV_BOUNDARY, pg_info->fid_column, pg_info->toposchema_name, pg_info->schema_name, pg_info->table_name,
+ pg_info->topogeom_column, pg_info->topogeom_column);
if (Vect__execute_pg(pg_info->conn, stmt) == -1) {
Vect__execute_pg(pg_info->conn, "ROLLBACK");
@@ -1445,19 +1447,19 @@
sprintf(stmt,
"SELECT tt.geom,tt.containing_face,ft.%s FROM \"%s\".node AS tt "
- "LEFT JOIN \"%s\" AS ft ON (%s).type = %d and (%s).id = %s "
+ "LEFT JOIN \"%s\".\"%s\" AS ft ON (%s).type = %d and (%s).id = %s "
"WHERE node_id = %d",
- pg_info->table_name, pg_info->topogeom_column,
+ pg_info->schema_name, pg_info->table_name, pg_info->topogeom_column,
topotype, pg_info->topogeom_column, nodeid, fid);
else {
sprintf(stmt,
"SELECT tt.geom,tt.left_face,tt.right_face,ft.%s FROM \"%s\".edge AS tt "
- "LEFT JOIN \"%s\" AS ft ON (%s).type = 2 and (%s).id = edge_id "
+ "LEFT JOIN \"%s\".\"%s\" AS ft ON (%s).type = 2 and (%s).id = edge_id "
"WHERE edge_id = %d",
pg_info->topogeom_column, fid);
Modified: grass/trunk/lib/vector/Vlib/write_pg.c
--- grass/trunk/lib/vector/Vlib/write_pg.c 2013-11-29 09:43:40 UTC (rev 58325)
+++ grass/trunk/lib/vector/Vlib/write_pg.c 2013-11-29 11:29:39 UTC (rev 58326)
@@ -868,9 +868,9 @@
/* create index on topo column */
- sprintf(stmt, "CREATE INDEX \"%s_%s_idx\" ON %s (((%s).id))",
- pg_info->table_name, pg_info->topogeom_column);
+ sprintf(stmt, "CREATE INDEX \"%s_%s_%s_idx\" ON \"%s\".\"%s\" (((%s).id))",
+ pg_info->schema_name, pg_info->table_name, pg_info->topogeom_column);
if (-1 == Vect__execute_pg(pg_info->conn, stmt)) {
return -1;
