[GRASS-SVN] r58328 - grass/trunk/lib/vector/Vlib
Fri Nov 29 04:16:58 PST 2013
Author: martinl
Date: 2013-11-29 04:16:58 -0800 (Fri, 29 Nov 2013)
New Revision: 58328
   grass/trunk/lib/vector/Vlib/open_pg.c
vlib/pg: fix remaining issues in SQL statements related to the schema name
Modified: grass/trunk/lib/vector/Vlib/open_pg.c
--- grass/trunk/lib/vector/Vlib/open_pg.c	2013-11-29 11:34:42 UTC (rev 58327)
+++ grass/trunk/lib/vector/Vlib/open_pg.c	2013-11-29 12:16:58 UTC (rev 58328)
@@ -1495,22 +1495,22 @@
     if (pg_info->topo_geo_only)
         sprintf(stmt,
                 "SELECT tt.node_id,tt.geom,ft.%s FROM \"%s\".node AS tt "
-                "LEFT JOIN \"%s\" AS ft ON "
+                "LEFT JOIN \"%s\".\"%s\" AS ft ON "
                 "(%s).type = 1 AND (%s).id = node_id WHERE containing_face "
                 "IS NULL AND node_id NOT IN "
                 "(SELECT node FROM (SELECT start_node AS node FROM \"%s\".edge "
                 "GROUP BY start_node UNION ALL SELECT end_node AS node FROM "
                 "\"%s\".edge GROUP BY end_node) AS foo) ORDER BY node_id",
-                "fid", pg_info->toposchema_name, pg_info->table_name,
+                "fid", pg_info->toposchema_name, pg_info->schema_name, pg_info->table_name,
                 pg_info->topogeom_column, pg_info->topogeom_column, pg_info->toposchema_name,
                 pg_info->toposchema_name);
     else
         sprintf(stmt,
                 "SELECT tt.node_id,tt.geom,ft.%s "
-                "FROM \"%s\".node AS tt LEFT JOIN \"%s\" AS ft ON "
+                "FROM \"%s\".node AS tt LEFT JOIN \"%s\".\"%s\" AS ft ON "
                 "(%s).type = 1 AND (%s).id = node_id WHERE node_id NOT IN "
                 "(SELECT node_id FROM \"%s\".%s) AND containing_face IS NULL ORDER BY node_id",
                 pg_info->toposchema_name, TOPO_TABLE_NODE);
     G_debug(2, "SQL: %s", stmt);
@@ -1544,18 +1544,19 @@
         sprintf(stmt, /* TODO: fix fid column! */
                 "SELECT edge_id,start_node,end_node,left_face,right_face AS right_area,tt.geom,ft.%s "
-                "FROM \"%s\".edge AS tt LEFT JOIN \"%s\" AS ft ON (%s).type = 2 AND "
+                "FROM \"%s\".edge AS tt LEFT JOIN \"%s\".\"%s\" AS ft ON (%s).type = 2 AND "
                 "(%s).id = edge_id ORDER BY edge_id",
                 pg_info->topogeom_column, pg_info->topogeom_column);
     else
                 "SELECT edge_id,start_node,end_node,left_area,right_area,tt.geom,ft.%s "
-                "FROM \"%s\".edge AS tt LEFT JOIN \"%s\".%s ON "
-                "edge_id = line_id LEFT JOIN \"%s\" AS ft ON (%s).type = 2 AND "
+                "FROM \"%s\".edge AS tt LEFT JOIN \"%s\".\"%s\" ON "
+                "edge_id = line_id LEFT JOIN \"%s\".\"%s\" AS ft ON (%s).type = 2 AND "
                 "fid", pg_info->toposchema_name, pg_info->toposchema_name, TOPO_TABLE_LINE,
-                pg_info->table_name, pg_info->topogeom_column, pg_info->topogeom_column);
+                pg_info->schema_name, pg_info->table_name, pg_info->topogeom_column,
+                pg_info->topogeom_column);
     res = PQexec(pg_info->conn, stmt);
@@ -1591,24 +1592,24 @@
         sprintf(stmt,
                 "SELECT node_id,tt.geom,containing_face,ft.%s FROM "
-                "\"%s\".node AS tt LEFT JOIN \"%s\" AS ft ON "
+                "\"%s\".node AS tt LEFT JOIN \"%s\".\"%s\" AS ft ON "
                 "(%s).type = 3 AND (%s).id = containing_face WHERE containing_face "
                 "IS NOT NULL AND node_id NOT IN "
     else
         sprintf(stmt,
                 "SELECT tt.node_id,tt.geom,containing_face,ft.%s FROM "
                 "(%s).type = 3 AND (%s).id = containing_face WHERE "
                 "node_id NOT IN (SELECT node_id FROM \"%s\".%s) AND containing_face "
                 "IS NOT NULL ORDER BY node_id",
