[GRASS-SVN] r58329 - in grass/trunk/lib/vector: Vlib diglib
svn_grass at osgeo.org
Fri Nov 29 04:35:30 PST 2013
Author: martinl
Date: 2013-11-29 04:35:30 -0800 (Fri, 29 Nov 2013)
New Revision: 58329
grass/trunk/lib/vector/Vlib/open_pg.c
grass/trunk/lib/vector/diglib/frmt.c
vlib/pg: fix fid_column usage in several SQL statements
Modified: grass/trunk/lib/vector/Vlib/open_pg.c
--- grass/trunk/lib/vector/Vlib/open_pg.c 2013-11-29 12:16:58 UTC (rev 58328)
+++ grass/trunk/lib/vector/Vlib/open_pg.c 2013-11-29 12:35:30 UTC (rev 58329)
@@ -1501,7 +1501,7 @@
"(SELECT node FROM (SELECT start_node AS node FROM \"%s\".edge "
"GROUP BY start_node UNION ALL SELECT end_node AS node FROM "
"\"%s\".edge GROUP BY end_node) AS foo) ORDER BY node_id",
- "fid", pg_info->toposchema_name, pg_info->schema_name, pg_info->table_name,
+ pg_info->fid_column, pg_info->toposchema_name, pg_info->schema_name, pg_info->table_name,
pg_info->topogeom_column, pg_info->topogeom_column, pg_info->toposchema_name,
pg_info->toposchema_name);
else
@@ -1510,7 +1510,7 @@
"FROM \"%s\".node AS tt LEFT JOIN \"%s\".\"%s\" AS ft ON "
"(%s).type = 1 AND (%s).id = node_id WHERE node_id NOT IN "
"(SELECT node_id FROM \"%s\".%s) AND containing_face IS NULL ORDER BY node_id",
pg_info->toposchema_name, TOPO_TABLE_NODE);
G_debug(2, "SQL: %s", stmt);
@@ -1542,19 +1542,19 @@
-> boundaries
if (pg_info->topo_geo_only)
- sprintf(stmt, /* TODO: fix fid column! */
+ sprintf(stmt,
"SELECT edge_id,start_node,end_node,left_face,right_face AS right_area,tt.geom,ft.%s "
"FROM \"%s\".edge AS tt LEFT JOIN \"%s\".\"%s\" AS ft ON (%s).type = 2 AND "
"(%s).id = edge_id ORDER BY edge_id",
pg_info->topogeom_column, pg_info->topogeom_column);
else
+ sprintf(stmt,
"SELECT edge_id,start_node,end_node,left_area,right_area,tt.geom,ft.%s "
"FROM \"%s\".edge AS tt LEFT JOIN \"%s\".\"%s\" ON "
"edge_id = line_id LEFT JOIN \"%s\".\"%s\" AS ft ON (%s).type = 2 AND "
- "fid", pg_info->toposchema_name, pg_info->toposchema_name, TOPO_TABLE_LINE,
+ pg_info->fid_column, pg_info->toposchema_name, pg_info->toposchema_name, TOPO_TABLE_LINE,
pg_info->schema_name, pg_info->table_name, pg_info->topogeom_column,
@@ -1598,7 +1598,7 @@
@@ -1609,7 +1609,7 @@
"(%s).type = 3 AND (%s).id = containing_face WHERE "
"node_id NOT IN (SELECT node_id FROM \"%s\".%s) AND containing_face "
"IS NOT NULL ORDER BY node_id",
Modified: grass/trunk/lib/vector/diglib/frmt.c
--- grass/trunk/lib/vector/diglib/frmt.c 2013-11-29 12:16:58 UTC (rev 58328)
+++ grass/trunk/lib/vector/diglib/frmt.c 2013-11-29 12:35:30 UTC (rev 58329)
@@ -121,6 +121,8 @@
finfo->pg.schema_name = G_store(ptr);
if (G_strcasecmp(buf1, "TABLE") == 0)
finfo->pg.table_name = G_store(ptr);
+ if (G_strcasecmp(buf1, "FID") == 0)
+ finfo->pg.fid_column = G_store(ptr);
#endif
@@ -131,6 +133,12 @@
!finfo->pg.schema_name) {
finfo->pg.schema_name = G_store("public");
+ /* if fid column not defined, use default value */
+ if (frmt == GV_FORMAT_POSTGIS &&
+ !finfo->pg.fid_column) {
+ finfo->pg.fid_column = G_store(GV_PG_FID_COLUMN);
#endif
return frmt;
