[GRASS-SVN] r58105 - grass/trunk/raster/r.proj
svn_grass at osgeo.org
Fri Oct 25 04:07:14 PDT 2013
Author: neteler
Date: 2013-10-25 04:07:13 -0700 (Fri, 25 Oct 2013)
New Revision: 58105
grass/trunk/raster/r.proj/r.proj.html
r.proj example: use -d densify for v.in.region
Modified: grass/trunk/raster/r.proj/r.proj.html
--- grass/trunk/raster/r.proj/r.proj.html 2013-10-25 11:04:21 UTC (rev 58104)
+++ grass/trunk/raster/r.proj/r.proj.html 2013-10-25 11:07:13 UTC (rev 58105)
@@ -250,7 +250,7 @@
# In the source location, use v.in.region to generate a bounding box around the
# region of interest:
-v.in.region output=bounds type=area
+v.in.region -d output=bounds type=area
# Now switch to the target location and import the vector bounding box
# (you can run v.proj -l to get a list of vector maps in the source location):
