[GRASS-SVN] r58106 - in grass-addons/grass7/vector: . v.transects
svn_grass at osgeo.org
Fri Oct 25 10:27:00 PDT 2013
Author: annakrat
Date: 2013-10-25 10:27:00 -0700 (Fri, 25 Oct 2013)
New Revision: 58106
Added:
grass-addons/grass7/vector/v.transects/
grass-addons/grass7/vector/v.transects/v.transects.html
Removed:
grass-addons/grass7/vector/v.transects/description.html
grass-addons/grass7/vector/v.transects/v.transects.py
v.transects ported to GRASS7 (plus whitespace changes for PEP8 compliance)
Deleted: grass-addons/grass7/vector/v.transects/description.html
--- grass-addons/grass6/vector/v.transects/description.html 2013-10-15 23:19:37 UTC (rev 58010)
+++ grass-addons/grass7/vector/v.transects/description.html 2013-10-25 17:27:00 UTC (rev 58106)
@@ -1,69 +0,0 @@
-<h2>DESCRIPTION</h2><em>v.transects</em> creates equally spaced geometries along
-input lines. The geometries can be lines or quadrilateral areas. Lines
-and areas are generated to be perpendicular to the input line.
-<h2>NOTES</h2>Input vector lines that are shorter than <b>transect_spacing</b> are ignored.
-<p>
-<b>transect_spacing</b>, <b>dleft</b>, and <b>dright</b> are interpreted to be in horizontal map units (e.g., degrees in the WGS84 projection).
-<p>
-<em><b>v.transects</b></em> may fail for a network of lines in Windows.
-<h2>EXAMPLES</h2>In these examples, the
-<a href="http://courses.ncsu.edu/mea582/common/media/01/NagsHead_series.zip"><font color="0000FF">Nags Head (19MB)</font></a>
-mapset is used to generate a shoreline and shore-perpendicular geometries. To use the mapset, unpack it into the
-<a href="http://courses.ncsu.edu/mea582/common/media/01/nc_spm_08.zip"><font color="0000FF">nc_spm_08 (150MB)</font></a>
-Location or the
-<a href="http://courses.ncsu.edu/mea792/common/media/gisdemo.zip"><font color="0000FF">gisdemo (47MB)</font></a>
-Location.
-<h3>Example 1) - Generate line transects along shoreline</h3>
-<p>Generate 20 cross-shore transects along 2008 shoreline (1m contour)<br>
-<div class=code><pre>g.region rast=NH_2008_1m
-r.contour input=NH_2008_1m output=NH_2008_1m level=1 cut=100
-v.report map=NH_2008_1m option=length
-# cat|level|length
-# 1|1|1037.86684790028
-# 1038m / 20transects = 52m per transect (value for transect_spacing)
-v.transects input=NH_2008_1m output=NH_2008_transects transect_spacing=52
-v.info NH_2008_transects
-</pre></div>
-<h3>Example 2) - Generate line transects specifying the left and right length</h3>
-<p>Generate longer, more parallel transects by specifying dleft and dright and
-smoothing the input line<br>
-v.generalize input=NH_2008_1m output=NH_2008_1m_smoothed \
- method=sliding_averaging look_ahead=201
-v.transects input=NH_2008_1m_smoothed \
- output=NH_2008_transects_long_smoothed transect_spacing=52 \
- dleft=20 dright=300
-</pre></div>
-<h3>Example 3) - Generate area transects along shoreline</h3>
-v.transects input=NH_2008_1m output=NH_2008_areas \
- transect_spacing=52 dleft=20 dright=300 type=area
-v.db.addtable NH_2008_areas
-v.db.addcolumn map=NH_2008_areas columns='demStats DOUBLE PRECISION'
-v.rast.stats vector=NH_2008_areas raster=NH_2008_1m column_prefix=NH2008
-v.db.select NH_2008_areas
-</pre></div>
-<h2>SEE ALSO</h2><em>
-<a href="http://www4.ncsu.edu/~ejhardi2/v.generalize.html">v.generalize</a>,
-<a href="http://www4.ncsu.edu/~ejhardi2/r.transect.html">r.transect</A> </em>
-<h2>AUTHOR</h2>Eric Hardin, Helena Mitasova, Updates by John Lloyd
-<p>
-<i>Last changed: $Date$</i>
Copied: grass-addons/grass7/vector/v.transects/v.transects.html (from rev 58010, grass-addons/grass6/vector/v.transects/description.html)
--- grass-addons/grass7/vector/v.transects/v.transects.html (rev 0)
+++ grass-addons/grass7/vector/v.transects/v.transects.html 2013-10-25 17:27:00 UTC (rev 58106)
@@ -0,0 +1,69 @@
+<h2>DESCRIPTION</h2><em>v.transects</em> creates equally spaced geometries along
+input lines. The geometries can be lines or quadrilateral areas. Lines
+and areas are generated to be perpendicular to the input line.
+<h2>NOTES</h2>Input vector lines that are shorter than <b>transect_spacing</b> are ignored.
+<p>
+<b>transect_spacing</b>, <b>dleft</b>, and <b>dright</b> are interpreted to be in horizontal map units (e.g., degrees in the WGS84 projection).
+<p>
+<em><b>v.transects</b></em> may fail for a network of lines in Windows.
+<h2>EXAMPLES</h2>In these examples, the
+<a href="http://courses.ncsu.edu/mea582/common/media/01/NagsHead_series.zip"><font color="0000FF">Nags Head (19MB)</font></a>
+mapset is used to generate a shoreline and shore-perpendicular geometries. To use the mapset, unpack it into the
+<a href="http://courses.ncsu.edu/mea582/common/media/01/nc_spm_08.zip"><font color="0000FF">nc_spm_08 (150MB)</font></a>
+Location or the
+<a href="http://courses.ncsu.edu/mea792/common/media/gisdemo.zip"><font color="0000FF">gisdemo (47MB)</font></a>
+Location.
+<h3>Example 1) - Generate line transects along shoreline</h3>
+<p>Generate 20 cross-shore transects along 2008 shoreline (1m contour)<br>
+<div class=code><pre>g.region rast=NH_2008_1m
+r.contour input=NH_2008_1m output=NH_2008_1m level=1 cut=100
+v.report map=NH_2008_1m option=length
+# cat|level|length
+# 1|1|1037.86684790028
+# 1038m / 20transects = 52m per transect (value for transect_spacing)
+v.transects input=NH_2008_1m output=NH_2008_transects transect_spacing=52
+v.info NH_2008_transects
+</pre></div>
+<h3>Example 2) - Generate line transects specifying the left and right length</h3>
+<p>Generate longer, more parallel transects by specifying dleft and dright and
+smoothing the input line<br>
+v.generalize input=NH_2008_1m output=NH_2008_1m_smoothed \
+ method=sliding_averaging look_ahead=201
+v.transects input=NH_2008_1m_smoothed \
+ output=NH_2008_transects_long_smoothed transect_spacing=52 \
+ dleft=20 dright=300
+</pre></div>
+<h3>Example 3) - Generate area transects along shoreline</h3>
+v.transects input=NH_2008_1m output=NH_2008_areas \
+ transect_spacing=52 dleft=20 dright=300 type=area
+v.db.addtable NH_2008_areas
+v.db.addcolumn map=NH_2008_areas columns='demStats DOUBLE PRECISION'
+v.rast.stats vector=NH_2008_areas raster=NH_2008_1m column_prefix=NH2008
+v.db.select NH_2008_areas
+</pre></div>
+<h2>SEE ALSO</h2><em>
+<a href="http://www4.ncsu.edu/~ejhardi2/v.generalize.html">v.generalize</a>,
+<a href="http://www4.ncsu.edu/~ejhardi2/r.transect.html">r.transect</A> </em>
+<h2>AUTHOR</h2>Eric Hardin, Helena Mitasova, Updates by John Lloyd
+<p>
+<i>Last changed: $Date$</i>
Modified: grass-addons/grass7/vector/v.transects/v.transects.py
--- grass-addons/grass6/vector/v.transects/v.transects.py 2013-10-15 23:19:37 UTC (rev 58010)
+++ grass-addons/grass7/vector/v.transects/v.transects.py 2013-10-25 17:27:00 UTC (rev 58106)
@@ -5,59 +5,47 @@
# MODULE: v.transects.py
# AUTHOR(S): Eric Hardin
# PURPOSE: Creates lines or quadrilateral areas perpendicular to a polyline
-# COPYRIGHT: (C) 2011
+# COPYRIGHT: (C) 2013
# This program is free software under the GNU General Public
# License (>=v2). Read the file COPYING that comes with GRASS
# for details.
# UPDATES: John Lloyd November 2011
+# Anna Petrasova 2013 (update for GRASS 7)
-#%Module
+#%module
#% description: Creates transect lines or quadrilateral areas at regular intervals perpendicular to a polyline.
-#%End
-#%option
-#% key: input
-#% type: string
-#% description: Name of input vector map
-#% gisprompt: old,vector,vector
-#% required : yes
#%end
-#%option
-#% key: output
-#% type: string
-#% description: Name of output vector map
-#% gisprompt: new,vector,vector
-#% required : yes
+#%option G_OPT_V_INPUT
#%end
+#%option G_OPT_V_OUTPUT
+#%end
#%option
#% key: transect_spacing
#% type: double
#% description: Transect spacing along input polyline
-#% required : yes
+#% required: yes
#%end
#%option
#% key: dleft
#% type: double
#% label: Distance transect extends to the left of input line
#% description: Default is the same as the transect spacing
-#% required : no
+#% required: no
#%end
#%option
#% key: dright
#% type: double
#% label: Distance transect extends to the right of input line
-#% required : no
+#% required: no
#%end
-#%option
-#% key: type
-#% type: string
-#% description: Feature type
-#% required : no
-#% options: line,area,point
-#% answer : line
+#%option G_OPT_V_TYPE
+#% multiple: no
+#% options: point,line,area
+#% answer: line
#%end
from subprocess import Popen, PIPE, STDOUT
@@ -65,32 +53,38 @@
from math import sqrt
import grass.script as grass
import tempfile
-# Returns the name of a vector map not in the current mapset.
-# mapname is of the form temp_xxxxxx where xxxxxx is a random number
+import random
def tempmap():
- import random
- rand_number = [ random.randint(0,9) for i in range(6) ]
- rand_number_str = ''.join( map(str,rand_number) )
+ """!Returns the name of a vector map not in the current mapset.
+ Mapname is of the form temp_xxxxxx where xxxxxx is a random number.
+ rand_number = [random.randint(0, 9) for i in range(6)]
+ rand_number_str = ''.join(map(str, rand_number))
mapname = 'temp_' + rand_number_str
- maplist = grass.read_command('g.list',type='vect',mapset='.').split()
+ maplist = grass.read_command('g.list', type='vect', mapset='.').split()
while mapname in maplist:
return mapname
-# load vector lines into python list
-# returns v
-# len(v) = number of lines in vector map
-# len(v[i]) = number of vertices in ith line
-# v[i][j] = [ xij, yij ] ,i.e., jth vertex in ith line
-def loadVector( vector ):
- expVecCmmd = 'v.out.ascii format=standard input='+vector
+def loadVector(vector):
+ """!Load vector lines into python list.
+ Returns v:
+ len(v) = number of lines in vector map
+ len(v[i]) = number of vertices in ith line
+ v[i][j] = [ xij, yij ] ,i.e., jth vertex in ith line
+ expVecCmmd = 'v.out.ascii format=standard input=' + vector
# JL p = Popen(expVecCmmd, shell=True, stdin=PIPE, stdout=PIPE, stderr=STDOUT, close_fds=True)
- p = Popen(expVecCmmd, shell=True, stdin=PIPE, stdout=PIPE, stderr=STDOUT, close_fds=False)
+ p = Popen(expVecCmmd, shell=True, stdin=PIPE, stdout=PIPE,
+ stderr=STDOUT, close_fds=False)
vectorAscii = p.stdout.read().strip('\n').split('\n')
l = 0
while 'ORGANIZATION' not in vectorAscii[l]:
@@ -100,17 +94,17 @@
v = []
while l < len(vectorAscii):
line = vectorAscii[l].split()
- if line[0] in ['L','B','A']:
- skip = len(line)-2
+ if line[0] in ['L', 'B', 'A']:
+ skip = len(line) - 2
vertices = int(line[1])
l += 1
v.append([])
for i in range(vertices):
- v[-1].append( map(float,vectorAscii[l].split()[:2]) )
+ v[-1].append(map(float, vectorAscii[l].split()[:2]))
l += 1
l += skip
- elif line[0] in ['P','C','F','K']:
+ elif line[0] in ['P', 'C', 'F', 'K']:
l += 1
@@ -122,114 +116,124 @@
grass.fatal(_("Zero lines found in vector map <%s>") % vector)
return v
-# get transects locations along input vector lines
-def get_transects_locs( vector, transect_spacing ):
- transect_locs = [] # holds locations where transects should intersect input vector lines
- for line in vector:
+def get_transects_locs(vector, transect_spacing):
+ """!Get transects locations along input vector lines."""
+ # holds locations where transects should intersect input vector lines
+ transect_locs = []
+ for line in vector:
transect_locs.append([line[0]])
# i starts at the beginning of the line.
# j walks along the line until j and i are separated by a distance of transect_spacing.
# then, a transect is placed at j, i is moved to j, and this is iterated until the end of the line is reached
i = 0
- j = i+1
+ j = i + 1
while j < len(line):
- d = dist( line[i],line[j] )
+ d = dist(line[i], line[j])
if d > transect_spacing:
- r = (transect_spacing - dist(line[i],line[j-1]) )/( dist(line[i],line[j]) - dist(line[i],line[j-1]) )
- transect_locs[-1].append( (r*array( line[j] ) + (1-r)*array( line[j-1] )).tolist() )
- i = j-1
+ r = ((transect_spacing - dist(line[i], line[j - 1])) /
+ (dist(line[i], line[j]) - dist(line[i], line[j - 1])))
+ transect_locs[-1].append((r * array(line[j]) +
+ (1 - r) * array(line[j - 1])).tolist())
+ i = j - 1
line[i] = transect_locs[-1][-1]
else:
j += 1
return transect_locs
-# from transects locations along input vector lines, get transect ends
-def get_transect_ends( transect_locs, dleft, dright ):
+def get_transect_ends(transect_locs, dleft, dright):
+ """!From transects locations along input vector lines, get transect ends."""
transect_ends = []
for transect in transect_locs:
- if len(transect) < 2: # if a line in input vec was shorter than transect_spacing
- continue # then don't put a transect on it
+ # if a line in input vec was shorter than transect_spacing
+ if len(transect) < 2:
+ continue # then don't put a transect on it
transect_ends.append([])
- transect = array( transect )
- v = NR( transect[0], transect[1] ) # vector pointing parallel to transect
- transect_ends[-1].append( [ transect[0]+dleft*v, transect[0]-dright*v ] )
- for i in range(1,len( transect )-1,1):
- v = NR( transect[i-1], transect[i+1] )
- transect_ends[-1].append( [ transect[i]+dleft*v, transect[i]-dright*v ] )
- v = NR( transect[-2], transect[-1] )
- transect_ends[-1].append( [ transect[-1]+dleft*v, transect[-1]-dright*v ] )
+ transect = array(transect)
+ v = NR(transect[0], transect[1]) # vector pointing parallel to transect
+ transect_ends[-1].append([transect[0] + dleft * v, transect[0] - dright * v])
+ for i in range(1, len(transect) - 1, 1):
+ v = NR(transect[i - 1], transect[i + 1])
+ transect_ends[-1].append([transect[i] + dleft * v, transect[i] - dright * v])
+ v = NR(transect[-2], transect[-1])
+ transect_ends[-1].append([transect[-1] + dleft * v, transect[-1] - dright * v])
return transect_ends
-# calculate distance between two points
-def dist( ip, fp ):
- return sqrt( (ip[0]-fp[0])**2 + (ip[1]-fp[1])**2 )
-# take a vector, normalize and rotate it 90 degrees
-def NR( ip, fp ):
+def dist(ip, fp):
+ """!Calculates distance between two points"""
+ return sqrt((ip[0] - fp[0]) ** 2 + (ip[1] - fp[1]) ** 2)
+def NR(ip, fp):
+ """!Take a vector, normalize and rotate it 90 degrees."""
x = fp[0] - ip[0]
y = fp[1] - ip[1]
- r = sqrt( x**2 + y**2 )
- return array([ -y/r, x/r ])
+ r = sqrt(x ** 2 + y ** 2)
+ return array([-y / r, x / r])
-# write transects
-def writeTransects( transects, output ):
+def writeTransects(transects, output):
+ """!Writes transects."""
transects_str = ''
for transect in transects:
- transects_str += '\n'.join( [ 'L 2\n'+' '.join(map(str,end_points[0]))+'\n'+' '.join(map(str,end_points[1]))+'\n' for end_points in transect ] )
+ transects_str += '\n'.join(['L 2\n' + ' '.join(map(str, end_points[0])) + '\n' +
+ ' '.join(map(str, end_points[1])) +
+ '\n' for end_points in transect])
# JL Rewrote Temporary File Logic for Windows
_, temp_path = tempfile.mkstemp()
a = open(temp_path, 'w')
- a.write( transects_str )
+ a.write(transects_str)
a.seek(0)
a.close()
- grass.run_command('v.in.ascii', flags='n', input=temp_path, output=output, format='standard')
+ grass.run_command('v.in.ascii', flags='n', input=temp_path, output=output,
+ format='standard')
-# writes areas
-def writeQuads( transects, output ):
+def writeQuads(transects, output):
+ """!Writes areas."""
quad_str = ''
cnt = 1
for line in transects:
- for tran in range( len(line)-1 ):
- pt1 = ' '.join( map(str,line[tran][0]) )
- pt2 = ' '.join( map(str,line[tran][1]) )
- pt3 = ' '.join( map(str,line[tran+1][1]) )
- pt4 = ' '.join( map(str,line[tran+1][0]) )
+ for tran in range(len(line) - 1):
+ pt1 = ' '.join(map(str, line[tran][0]))
+ pt2 = ' '.join(map(str, line[tran][1]))
+ pt3 = ' '.join(map(str, line[tran + 1][1]))
+ pt4 = ' '.join(map(str, line[tran + 1][0]))
pt5 = pt1
# centroid is the average of the four corners
- c = ' '.join( map(str,[ 0.25*(line[tran][0][0]+line[tran][1][0]+line[tran+1][0][0]+line[tran+1][1][0]), 0.25*(line[tran][0][1]+line[tran][1][1]+line[tran+1][0][1]+line[tran+1][1][1]) ]) )
- quad_str += 'B 5\n' + '\n'.join([pt1,pt2,pt3,pt4,pt5]) + '\n'
+ c = ' '.join(map(str, [0.25 * (line[tran][0][0] + line[tran][1][0] +
+ line[tran + 1][0][0] + line[tran + 1][1][0]),
+ 0.25 * (line[tran][0][1] + line[tran][1][1] +
+ line[tran + 1][0][1] + line[tran + 1][1][1])]))
+ quad_str += 'B 5\n' + '\n'.join([pt1, pt2, pt3, pt4, pt5]) + '\n'
quad_str += 'C 1 1\n' + c + '\n1 ' + str(cnt) + '\n'
cnt += 1
- a.write( quad_str )
+ a.write(quad_str)
a.seek(0)
a.close()
- grass.run_command('v.in.ascii', flags='n', input=a.name, output=output, format='standard')
+ grass.run_command('v.in.ascii', flags='n', input=a.name,
+ output=output, format='standard')
-# writes areas
-def writePoints( transect_locs, output ):
+def writePoints(transect_locs, output):
+ """!Writes points."""
pt_str = ''
for pts in transect_locs:
- pt_str += '\n'.join( [ ','.join(map(str,pt)) for pt in pts ] ) + '\n'
+ pt_str += '\n'.join([','.join(map(str, pt)) for pt in pts]) + '\n'
- a.write( pt_str )
+ a.write(pt_str)
a.seek(0)
a.close()
- grass.run_command('v.in.ascii', input=a.name, output=output, format='point', fs=',', x=1, y=2)
+ grass.run_command('v.in.ascii', input=a.name, output=output,
+ format='point', separator=',', x=1, y=2)
-# Main method
def main():
vector = options['input']
output = options['output']
@@ -243,8 +247,8 @@
dleft = options['dleft']
dright = options['dright']
shape = options['type']
- print dleft, transect_spacing
- if not dleft:
+ if not dleft:
dleft = transect_spacing
else:
# JL Handling Invalid dleft parameter
@@ -252,7 +256,7 @@
dleft = float(dleft)
except:
grass.fatal(_("Invalid dleft value."))
- if not dright:
+ if not dright:
dright = transect_spacing
else:
# JL Handling Invalid dright parameter
@@ -261,36 +265,35 @@
except:
grass.fatal(_("Invalid dright value."))
# check if input file does not exists
- if not grass.find_file(vector, element='vector')['file']:
+ if not grass.find_file(vector, element='vector')['file']:
grass.fatal(_("<%s> does not exist.") % vector)
# check if output file exists
- if grass.find_file(output, element='vector')['mapset'] == grass.gisenv()['MAPSET']:
+ if grass.find_file(output, element='vector')['mapset'] == grass.gisenv()['MAPSET']:
if not grass.overwrite():
grass.fatal(_("output map <%s> exists") % output)
#JL Is the vector a line and does if have at least one feature?
- info = grass.parse_command('v.info', flags = 't', map = vector)
+ info = grass.parse_command('v.info', flags='t', map=vector)
if info['lines'] == '0':
- grass.fatal(_("vector <%s> does not contain lines") % vector)
+ grass.fatal(_("vector <%s> does not contain lines") % vector)
- v = loadVector( vector )
- transect_locs = get_transects_locs( v, transect_spacing )
+ v = loadVector(vector)
+ transect_locs = get_transects_locs(v, transect_spacing)
temp_map = tempmap()
- if shape == 'line' or not shape:
- transect_ends = get_transect_ends( transect_locs, dleft, dright )
- writeTransects( transect_ends, temp_map )
+ if shape == 'line' or not shape:
+ transect_ends = get_transect_ends(transect_locs, dleft, dright)
+ writeTransects(transect_ends, temp_map)
elif shape == 'area':
- writeQuads( transect_ends, temp_map )
+ writeQuads(transect_ends, temp_map)
else:
- writePoints( transect_locs, temp_map )
- grass.run_command( 'v.category', input=temp_map, output=output, type=shape )
- grass.run_command( 'g.remove', vect=temp_map )
+ writePoints(transect_locs, temp_map)
+ grass.run_command('v.category', input=temp_map, output=output,
+ option='add', type=shape)
+ grass.run_command('g.remove', vect=temp_map)
if __name__ == "__main__":
- options, flags = grass.parser()
- main()
+ options, flags = grass.parser()
+ main()
