[GRASS-SVN] r58116 - grass/trunk/lib/python/pygrass/gis
svn_grass at osgeo.org
Mon Oct 28 07:10:01 PDT 2013
Author: zarch
Date: 2013-10-28 07:10:01 -0700 (Mon, 28 Oct 2013)
New Revision: 58116
grass/trunk/lib/python/pygrass/gis/__init__.py
Add some more check and options
Modified: grass/trunk/lib/python/pygrass/gis/__init__.py
--- grass/trunk/lib/python/pygrass/gis/__init__.py 2013-10-28 14:08:02 UTC (rev 58115)
+++ grass/trunk/lib/python/pygrass/gis/__init__.py 2013-10-28 14:10:01 UTC (rev 58116)
@@ -1,9 +1,8 @@
# -*- coding: utf-8 -*-
#!/usr/bin/env python2.7
from __future__ import print_function
-#import os
from os import listdir
-from os.path import join
+from os.path import join, exists, isdir
import shutil
import ctypes as ct
import fnmatch
@@ -182,12 +181,9 @@
raise KeyError('Mapset: %s does not exist' % mapset)
def __iter__(self):
- for mapset in libgis.G_available_mapsets():
- mapset_name = ct.cast(mapset, ct.c_char_p).value
- if mapset_name and libgis.G__mapset_permissions(mapset):
- yield mapset_name
- else:
- break
+ lpath = self.path()
+ return (m for m in listdir(lpath)
+ if (isdir(join(lpath, m)) and _check(m, lpath, "MAPSET")))
def __len__(self):
return len(self.mapsets())
@@ -198,7 +194,7 @@
def __repr__(self):
return 'Location(%r)' % self.name
- def mapsets(self, pattern=None):
+ def mapsets(self, pattern=None, permissions=True):
"""Return a list of the available mapsets. ::
>>> location = Location()
@@ -206,6 +202,9 @@
['PERMANENT', 'user1']
mapsets = [mapset for mapset in self]
+ if permissions:
+ mapsets = [mapset for mapset in mapsets
+ if libgis.G__mapset_permissions(mapset)]
if pattern:
return fnmatch.filter(mapsets, pattern)
return mapsets
