[GRASS-SVN] r58117 - grass/trunk/lib/python/pygrass/modules/grid
svn_grass at osgeo.org
Mon Oct 28 07:29:54 PDT 2013
Author: zarch
Date: 2013-10-28 07:29:54 -0700 (Mon, 28 Oct 2013)
New Revision: 58117
grass/trunk/lib/python/pygrass/modules/grid/grid.py
Avoid to copy raster maps if not necessary
Modified: grass/trunk/lib/python/pygrass/modules/grid/grid.py
--- grass/trunk/lib/python/pygrass/modules/grid/grid.py 2013-10-28 14:10:01 UTC (rev 58116)
+++ grass/trunk/lib/python/pygrass/modules/grid/grid.py 2013-10-28 14:29:54 UTC (rev 58117)
@@ -14,7 +14,7 @@
from grass.pygrass.gis import Mapset, Location
from grass.pygrass.gis.region import Region
from grass.pygrass.modules import Module
-from grass.pygrass.functions import get_mapset_raster
+from grass.pygrass.functions import get_mapset_raster, findmaps
from grass.pygrass.modules.grid.split import split_region_tiles
from grass.pygrass.modules.grid.patch import rpatch_map
@@ -177,7 +177,7 @@
return src, dst
-def copy_groups(groups, gisrc_src, gisrc_dst, region=None, cp_rasts=False):
+def copy_groups(groups, gisrc_src, gisrc_dst, region=None):
"""Copy group from one mapset to another, crop the raster to the region.
Parameters
@@ -202,23 +202,29 @@
env = os.environ.copy()
# instantiate modules
get_grp = Module('i.group', flags='lg', stdout_=sub.PIPE, run_=False)
set_grp = Module('i.group')
get_grp.run_ = True
+ rmloc = lambda r: r.split('@')[0] if '@' in r else r
+ src = read_gisrc(gisrc_src)
+ dst = read_gisrc(gisrc_dst)
+ rm = True if src[2] != dst[2] else False
+ all_rasts = [r[0]
+ for r in findmaps('rast', location=dst[1], gisdbase=dst[2])]
for grp in groups:
# change gisdbase to src
env['GISRC'] = gisrc_src
get_grp(group=grp, env_=env)
- rasts = get_grp.outputs.stdout.split()
- if cp_rasts:
- copy_rasters(rasts, gisrc_src, gisrc_dst, region=region)
+ rasts = [r for r in get_grp.outputs.stdout.split()]
# change gisdbase to dst
env['GISRC'] = gisrc_dst
+ rast2cp = [r for r in rasts if rmloc(r) not in all_rasts]
+ if rast2cp:
+ copy_rasters(rast2cp, gisrc_src, gisrc_dst, region=region)
set_grp(group=grp,
- input=[r.split('@')[0] if '@' in r else r for r in rasts],
+ input=[rmloc(r) for r in rasts] if rast2cp or rm else rasts,
env_=env)
@@ -281,7 +287,7 @@
if region:
set_region(region, gisrc_src, gisrc_dst, env)
- path_dst = os.path.join(*read_gisrc(gisrc_dst))
+ path_dst = os.path.join(*read_gisrc(gisrc_dst)[::-1])
nam = "copy%d__%s" % (id(gisrc_dst), '%s')
@@ -431,8 +437,7 @@
lcmd.extend(["%s=%s" % (k, v) for k, v in bbox.iteritems()])
sub.Popen(lcmd, env=env).wait()
if groups:
- cp_rasts = src.gisdbase != dst.gisdbase or src.location != dst.location
- copy_groups(groups, gisrc_src, gisrc_dst, cp_rasts=cp_rasts)
+ copy_groups(groups, gisrc_src, gisrc_dst)
# run the grass command
sub.Popen(get_cmd(cmd), env=env).wait()
# remove temp GISRC
@@ -509,7 +514,6 @@
if groups:
copy_groups(groups, self.gisrc_src, self.gisrc_dst,
region=self.region)
self.bboxes = split_region_tiles(region=region,
width=width, height=height,
overlap=overlap)
@@ -526,10 +530,16 @@
def clean_location(self, location=None):
"""Remove all created mapsets."""
- location = location if location else Location()
+ if location is None:
+ if self.n_mset:
+ self.n_mset.current()
+ location = Location()
mapsets = location.mapsets(self.msetstr.split('_')[0] + '_*')
for mset in mapsets:
Mapset(mset).delete()
+ if self.n_mset and self.n_mset.is_current():
+ self.mset.current()
def split(self):
"""Split all the raster inputs using r.tile"""
@@ -644,6 +654,9 @@
def patch(self):
"""Patch the final results."""
bboxes = split_region_tiles(width=self.width, height=self.height)
+ loc = Location()
+ mset = loc[self.mset.name]
+ mset.visible.extend(loc.mapsets())
for otmap in self.module.outputs:
otm = self.module.outputs[otmap]
if otm.typedesc == 'raster' and otm.value:
