[GRASS-SVN] r57601 - grass-addons/grass7/raster/r.fidimo
svn_grass at osgeo.org
Fri Sep 6 00:29:10 PDT 2013
Author: jradinger
Date: 2013-09-06 00:29:10 -0700 (Fri, 06 Sep 2013)
New Revision: 57601
grass-addons/grass7/raster/r.fidimo/r.fidimo.py
Implementation: Habitat attraction, a raster map is used as weighting factor. The probability based on the distance is multiplied by an attractivity-factor of a habitat relativ to the source point habitat.
Modified: grass-addons/grass7/raster/r.fidimo/r.fidimo.py
--- grass-addons/grass7/raster/r.fidimo/r.fidimo.py 2013-09-05 15:30:53 UTC (rev 57600)
+++ grass-addons/grass7/raster/r.fidimo/r.fidimo.py 2013-09-06 07:29:10 UTC (rev 57601)
@@ -61,7 +61,7 @@
#% key: source_populations
#% type: string
#% gisprompt: old,cell,raster
-#% description: Or: Source population raster, e.g output from SDM
+#% description: Or: Source population raster (relative or absolute occurence)
#% required: no
#% guisection: Source populations
#%end
@@ -110,6 +110,22 @@
#% answer:0.67
#% guisection: Dispersal parameters
#%End
+#%option
+#% key: habitat_attract
+#% type: string
+#% gisprompt: old,cell,raster
+#% description: Or: Attractiveness of habitat used as weighting factor (sink efffect, habitat-dependent dispersal)
+#% required: no
+#% guisection: Habitat dependency
+#%end
+#%option
+#% key: habitat_p
+#% type: string
+#% description: Or: Spatially varying and habitat-dependent p factor (float: 0-1, source effect, habitat-dependent dispersal)
+#% required: no
+#%end
#%Flag
#% key: b
#% description: Don't keep basic vector maps (source_points, barriers)
@@ -230,12 +246,22 @@
- #Source population input
+ # Source population input
if (options['source_populations'] and options['n_source']) or (str(options['source_populations']) == '' and str(options['n_source']) == ''):
grass.fatal(_("Provide either fixed or random source population"))
+ if options['n_source'] and flags['r']:
+ grass.fatal(_("Realisation (flag: 'r') in combination with random source populations (n_source) not possible. Please choose either random source populations or provide source populations to calculate realisation"))
n_source = options['n_source'] #number of random source points
source_populations = options['source_populations']
+ # Habitat maps
+ if options['habitat_attract']:
+ habitat_attract = options['habitat_attract']
+ if options['habitat_p']:
+ habitat_p = options['habitat_p']
+ # check if min max is 0-1
# multiplication value as workaround for very small FLOAT values
@@ -544,10 +570,11 @@
columns = "n_fish INT, prob_scalar DOUBLE")
#populate n_fish and sample prob from input sourcepopulations raster (multiplied by scalar)
- grass.run_command("v.what.rast",
- map = "source_points_%d" % os.getpid(),
- raster = source_populations,
- column = "n_fish")
+ if flags['r']:
+ grass.run_command("v.what.rast",
+ map = "source_points_%d" % os.getpid(),
+ raster = source_populations,
+ column = "n_fish")
@@ -557,7 +584,7 @@
#Adding columns and coordinates to source points
grass.run_command("v.db.addcolumn",
- columns = "X DOUBLE, Y DOUBLE, segment INT, Strahler INT")
+ columns = "X DOUBLE, Y DOUBLE, segment INT, Strahler INT, habitat_attract DOUBLE")
grass.run_command("v.to.db",
type = "point",
@@ -583,7 +610,16 @@
raster = "strahler_tmp_%d" % os.getpid(),
- column = "Strahler")
+ column = "Strahler")
+ #Adding information of habitat attractivenss to source points
+ raster = habitat_attract,
+ column = "habitat_attract")
# Make source points permanent
grass.run_command("g.copy",
vect = "source_points_%d" % os.getpid() + "," + output_fidimo + "_source_points")
@@ -621,7 +657,7 @@
mapcalc_list_Ab = []
# Loop over Source points
- source_points_list = grass.read_command("db.select", flags="c", sql= "SELECT cat, X, Y, n_fish, prob_scalar, Strahler FROM source_points_%d WHERE segment=%d" % (os.getpid(),int(j))).split("\n")[:-1] # remove last (empty line)
+ source_points_list = grass.read_command("db.select", flags="c", sql= "SELECT cat, X, Y, n_fish, prob_scalar, Strahler, habitat_attract FROM source_points_%d WHERE segment=%d" % (os.getpid(),int(j))).split("\n")[:-1] # remove last (empty line)
source_points_list = list(csv.reader(source_points_list,delimiter="|"))
@@ -636,6 +672,8 @@
coors = str(X)+","+str(Y)
if flags['r']:
n_fish = int(k[3])
+ source_habitat_attract = float(k[6])
# Progress bar
# add here progressbar
@@ -700,12 +738,8 @@
# MAIN PART: leptokurtic probability density kernel based on fishmove
grass.debug(_("Begin with core of fidimo, application of fishmove on garray"))
- if flags['r']:
- def cdf(x):
- return (p * stats.norm.cdf(x, loc=m, scale=sigma_stat) + (1-p) * stats.norm.cdf(x, loc=m, scale=sigma_mob))
- else:
- def cdf(x):
- return (p * stats.norm.cdf(x, loc=m, scale=sigma_stat) + (1-p) * stats.norm.cdf(x, loc=m, scale=sigma_mob)) * prob_scalar
+ def cdf(x):
+ return (p * stats.norm.cdf(x, loc=m, scale=sigma_stat) + (1-p) * stats.norm.cdf(x, loc=m, scale=sigma_mob)) * prob_scalar
#Calculation Kernel Density from Distance Raster
@@ -902,8 +936,22 @@
# Get a list of all densities processed so far within this segement
mapcalc_list_Aa.append("density_"+str(cat))
+ # Multiply (Weight) density point with relative attractiveness. realative attractive in relation to habitat attractivness at source
+ grass.mapcalc("$density_point_attract = $density_point*($habitat_attract/$source_habitat_attract)",
+ density_point_attract = "density_attract_"+str(cat),
+ density_point = "density_"+str(cat),
+ habitat_attract = habitat_attract,
+ source_habitat_attract = source_habitat_attract,
+ overwrite = True)
+ grass.run_command("g.rename",
+ rast = "density_attract_"+str(cat) + "," + "density_"+str(cat),
+ overwrite=True)
if flags['r']:
- # Realisation of Probablity raster, Backtransformation from probability into fish counts per cell
+ # Realisation of Probablity raster, Multinomial backtransformation from probability into fish counts per cell
grass.debug(_("Write Realisation (fish counts) from point to garray. This is point cat: "+str(cat)))
CorrectedDensity = garray.array()
CorrectedDensity.read("density_"+str(cat))
@@ -911,9 +959,7 @@
RealisedDensity = garray.array()
RealisedDensity[...] = numpy.random.multinomial(n_fish, (CorrectedDensity/numpy.sum(CorrectedDensity)).flat, size=1).reshape(CorrectedDensity.shape)
- #RealisedDensity[...] = numpy.bincount(numpy.searchsorted(numpy.cumsum(CorrectedDensity), numpy.random.random(n_fish)),minlength=CorrectedDensity.size).reshape(CorrectedDensity.shape)
RealisedDensity.write("realised_density_"+str(cat))
grass.run_command("r.null", map="realised_density_"+str(cat), null="0")
