[GRASS-SVN] r57644 - sandbox/turek/scatter_plot
svn_grass at osgeo.org
Thu Sep 12 00:27:23 PDT 2013
Author: turek
Date: 2013-09-12 00:27:23 -0700 (Thu, 12 Sep 2013)
New Revision: 57644
sandbox/turek/scatter_plot/testing_patch.diff
scatter plot: rasterization fixes
Modified: sandbox/turek/scatter_plot/testing_patch.diff
--- sandbox/turek/scatter_plot/testing_patch.diff 2013-09-12 05:14:09 UTC (rev 57643)
+++ sandbox/turek/scatter_plot/testing_patch.diff 2013-09-12 07:27:23 UTC (rev 57644)
@@ -1,3 +1,1232 @@
+Index: lib/vector/Vlib/open.c
+--- lib/vector/Vlib/open.c (revision 57633)
++++ lib/vector/Vlib/open.c (working copy)
+@@ -240,7 +240,9 @@
+ else {
+ char file_path[GPATH_MAX];
++ /* reduce to current mapset if search path was set */
++ if(strcmp(Map->mapset, "") == 0)
++ Map->mapset = G_store(G_mapset());
+ /* temporary map: reduce to current mapset if search path
+ * was set */
+ if (strcmp(Map->mapset, "") == 0)
+Index: lib/imagery/scatt_sccats.c
+--- lib/imagery/scatt_sccats.c (revision 0)
++++ lib/imagery/scatt_sccats.c (working copy)
+@@ -0,0 +1,405 @@
++ \file lib/imagery/scatt_cat_rast.c
++ \brief Imagery library - functions for manipulation with scatter plot structs.
++ Copyright (C) 2013 by the GRASS Development Team
++ This program is free software under the GNU General Public License
++ (>=v2). Read the file COPYING that comes with GRASS for details.
++ \author Stepan Turek <stepan.turek at seznam.cz> (Mentor: Martin Landa)
++#include <grass/raster.h>
++#include <grass/imagery.h>
++#include <grass/gis.h>
++#include <stdio.h>
++#include <stdlib.h>
++#include <math.h>
++#include <string.h>
++ \brief Compute band ids from scatter plot id.
++ Scatter plot id describes which bands defines the scatter plot.
++ Let say we have 3 bands, their ids are 0, 1 and 2.
++ Scatter plot with id 0 consists of band 1 (b_1_id) 0 and band 2 (b_2_id) 1.
++ All scatter plots:
++ scatt_id b_1_id b_2_id
++ 0 0 1
++ 1 0 2
++ 2 1 2
++ \param scatt_id scatter plot id
++ \param n_bands number of bands
++ \param [out] b_1_id id of band1
++ \param[out] b_2_id id of band2
++ \return 0
++int I_id_scatt_to_bands(const int scatt_id, const int n_bands, int * b_1_id, int * b_2_id)
++ int n_b1 = n_bands - 1;
++ * b_1_id = (int) ((2 * n_b1 + 1 - sqrt((double)((2 * n_b1 + 1) * (2 * n_b1 + 1) - 8 * scatt_id))) / 2);
++ * b_2_id = scatt_id - ((* b_1_id) * (2 * n_b1 + 1) - (* b_1_id) * (* b_1_id)) / 2 + (* b_1_id) + 1;
++ return 0;
++ \brief Compute scatter plot id from band ids.
++ See also I_id_scatt_to_bands().
++ \param b_1_id id of band1
++ \param b_1_id id of band2
++ \param [out] scatt_id scatter plot id
++ \return 0
++int I_bands_to_id_scatt(const int b_1_id, const int b_2_id, const int n_bands, int * scatt_id)
++ * scatt_id = (b_1_id * (2 * n_b1 + 1) - b_1_id * b_1_id) / 2 + b_2_id - b_1_id - 1;
++ return 0;
++ \brief Initialize structure for storing scatter plots data.
++ \param cats pointer to scCats struct
++ \param type SC_SCATT_DATA - stores scatter plots
++ \param type SC_SCATT_CONDITIONS - stores selected areas in scatter plots
++void I_sc_init_cats(struct scCats * cats, int n_bands, int type)
++ int i_cat;
++ cats->type = type;
++ cats->n_cats = 100;
++ cats->n_a_cats = 0;
++ cats->n_bands = n_bands;
++ cats->n_scatts = (n_bands - 1) * n_bands / 2;
++ cats->cats_arr = (struct scScatts **) G_malloc(cats->n_cats * sizeof(struct scScatts *));
++ memset(cats->cats_arr, 0, cats-> n_cats * sizeof(struct scScatts *));
++ cats->cats_ids = (int *) G_malloc(cats->n_cats * sizeof(int));
++ cats->cats_idxs =(int *) G_malloc(cats->n_cats * sizeof(int));
++ for(i_cat = 0; i_cat < cats->n_cats; i_cat++)
++ cats->cats_idxs[i_cat] = -1;
++ return;
++ \brief Free data of struct scCats, the structure itself remains alocated.
++ \param cats pointer to existing scCats struct
++void I_sc_free_cats(struct scCats * cats)
++ int i_cat;
++ for(i_cat = 0; i_cat < cats->n_a_cats; i_cat++)
++ if(cats->cats_arr[i_cat])
++ G_free(cats->cats_arr[i_cat]->scatt_idxs);
++ G_free(cats->cats_arr[i_cat]->scatts_bands);
++ G_free(cats->cats_arr[i_cat]->scatts_arr);
++ G_free(cats->cats_arr[i_cat]);
++ G_free(cats->cats_ids);
++ G_free(cats->cats_idxs);
++ G_free(cats->cats_arr);
++ cats->n_cats = 0;
++ cats->n_bands = 0;
++ cats->n_scatts = 0;
++ cats->type = -1;
++ return;
++#if 0
++void I_sc_get_active_categories(int * a_cats_ids, int * n_a_cats, struct scCats * cats)
++ a_cats_ids = cats->cats_ids;
++ * n_a_cats = cats->n_a_cats;
++#endif
++ \brief Add category.
++ Category represents group of scatter plots.
++ \return assigned category id (starts with 0)
++ \return -1 if maximum nuber of categories was reached
++int I_sc_add_cat(struct scCats * cats)
++ int i_scatt, i_cat_id, cat_id;
++ int n_a_cats = cats->n_a_cats;
++ if(cats->n_a_cats >= cats->n_cats)
++ return -1;
++ for(i_cat_id = 0; i_cat_id < cats->n_cats; i_cat_id++)
++ if(cats->cats_idxs[i_cat_id] < 0) {
++ cat_id = i_cat_id;
++ break;
++ cats->cats_ids[n_a_cats] = cat_id;
++ cats->cats_idxs[cat_id] = n_a_cats;
++ cats->cats_arr[n_a_cats] = (struct scScatts *) G_malloc(sizeof(struct scScatts));
++ cats->cats_arr[n_a_cats]->scatts_arr = (struct scdScattData **) G_malloc(cats->n_scatts * sizeof(struct scdScattData *));
++ memset((cats->cats_arr[n_a_cats]->scatts_arr), 0, cats->n_scatts * sizeof(struct scdScattData *));
++ cats->cats_arr[n_a_cats]->n_a_scatts = 0;
++ cats->cats_arr[n_a_cats]->scatts_bands = (int *) G_malloc(cats->n_scatts * 2 * sizeof(int));
++ cats->cats_arr[n_a_cats]->scatt_idxs = (int *) G_malloc(cats->n_scatts * sizeof(int));
++ for(i_scatt = 0; i_scatt < cats->n_scatts; i_scatt++)
++ cats->cats_arr[n_a_cats]->scatt_idxs[i_scatt] = -1;
++ ++cats->n_a_cats;
++ return cat_id;
++#if 0
++int I_sc_delete_cat(struct scCats * cats, int cat_id)
++ int cat_idx, i_cat;
++ if(cat_id < 0 || cat_id >= cats->n_cats)
++ return -1;
++ cat_idx = cats->cats_idxs[cat_id];
++ if(cat_idx < 0)
++ return -1;
++ G_free(cats->cats_arr[cat_idx]->scatt_idxs);
++ G_free(cats->cats_arr[cat_idx]->scatts_bands);
++ G_free(cats->cats_arr[cat_idx]->scatts_arr);
++ G_free(cats->cats_arr[cat_idx]);
++ for(i_cat = cat_idx; i_cat < cats->n_a_cats - 1; i_cat++)
++ cats->cats_arr[i_cat] = cats->cats_arr[i_cat + 1];
++ cats->cats_ids[i_cat] = cats->cats_ids[i_cat + 1];
++ cats->cats_idxs[cat_id] = -1;
++ --cats->n_a_cats;
++ return 0;
++#endif
++ \brief Insert scatter plot data .
++ Inserted scatt_data struct must have same type as cats struct (SC_SCATT_DATA or SC_SCATT_CONDITIONS).
++ \param cat_id id number of category.
++ \param scatt_id id number of scatter plot.
++ \return 0 on success
++ \return -1 on failure
++int I_sc_insert_scatt_data(struct scCats * cats, struct scdScattData * scatt_data, int cat_id, int scatt_id)
++ int band_1, band_2, cat_idx, n_a_scatts;
++ struct scScatts * scatts;
++ return -1;
++ if(cat_idx < 0)
++ return -1;
++ if(scatt_id < 0 && scatt_id >= cats->n_scatts)
++ return -1;
++ scatts = cats->cats_arr[cat_idx];
++ if(scatts->scatt_idxs[scatt_id] >= 0)
++ return -1;
++ if(!scatt_data->b_conds_arr && cats->type == SC_SCATT_CONDITIONS)
++ return -1;
++ if(!scatt_data->scatt_vals_arr && cats->type == SC_SCATT_DATA)
++ return -1;
++ n_a_scatts = scatts->n_a_scatts;
++ scatts->scatt_idxs[scatt_id] = n_a_scatts;
++ I_id_scatt_to_bands(scatt_id, cats->n_bands, &band_1, &band_2);
++ scatts->scatts_bands[n_a_scatts * 2] = band_1;
++ scatts->scatts_bands[n_a_scatts * 2 + 1] = band_2;
++ scatts->scatts_arr[n_a_scatts] = scatt_data;
++ ++scatts->n_a_scatts;
++ return 0;
++#if 0
++int I_sc_remove_scatt_data(struct scCats * cats, struct scdScattData * scatt_data, int cat_id, int scatt_id)
++ int cat_idx, scatt_idx, n_init_scatts, i_scatt;
++ if(cat_id < 0 && cat_id >= cats->n_cats)
++ return -1;
++ if(cat_idx < 0)
++ return -1;
++ if(scatt_id < 0 || scatt_id >= cats->n_scatts)
++ return -1;
++ if(scatts->scatt_idxs[scatt_id] < 0)
++ return -1;
++ scatt_data = scatts->scatts_arr[scatt_idx];
++ for(i_scatt = scatt_idx; i_scatt < scatts->n_a_scatts - 1; i_scatt++)
++ scatts->scatts_arr[i_scatt] = scatts->scatts_arr[i_scatt + 1];
++ scatts->scatts_bands[i_scatt * 2] = scatts->scatts_bands[(i_scatt + 1)* 2];
++ scatts->scatts_bands[i_scatt * 2 + 1] = scatts->scatts_bands[(i_scatt + 1) * 2 + 1];
++ scatts->scatts_arr[scatts->n_a_scatts] = NULL;
++ scatts->scatt_idxs[scatt_id] = -1;
++ scatt_data = scatts->scatts_arr[scatt_id];
++ scatts->n_a_scatts--;
++ return 0;
++int I_sc_set_value(struct scCats * cats, int cat_id, int scatt_id, int value_idx, int value)
++ int n_a_scatts = cats->cats_arr[cat_id]->n_a_scatts;
++ int cat_idx, scatt_idx, ret;
++ if(cat_idx < 0)
++ return -1;
++ if(cats->cats_arr[cat_idx]->scatt_idxs[scatt_id] < 0)
++ return -1;
++ scatt_idx = cats->cats_arr[cat_idx]->scatt_idxs[scatt_id];
++ I_scd_set_value(cats->cats_arr[cat_idx]->scatts_arr[scatt_idx], value_idx, value);
++ return 0;
++#endif
++ \brief Insert scatter plot data.
++ \param scatt_data pointer to existing struct scdScattData
++ \param type SC_SCATT_DATA for scatter plots or SC_SCATT_CONDITIONS for selected areas in scatter plot
++ \param n_vals number of data values
++ \param data array of values (unsigned char for SC_SCATT_CONDITIONS, unsigned int for SC_SCATT_DATA)
++void I_scd_init_scatt_data(struct scdScattData * scatt_data, int type, int n_vals, void * data)
++ scatt_data->n_vals = n_vals;
++ if(type == SC_SCATT_DATA)
++ if(data)
++ scatt_data->scatt_vals_arr = (unsigned int *) data;
++ else {
++ scatt_data->scatt_vals_arr = (unsigned int *) G_malloc(n_vals * sizeof(unsigned int));
++ memset(scatt_data->scatt_vals_arr, 0, n_vals * sizeof(unsigned int));
++ scatt_data->b_conds_arr = NULL;
++ else if(type == SC_SCATT_CONDITIONS)
++ if(data)
++ scatt_data->b_conds_arr = (unsigned char *) data;
++ else {
++ scatt_data->b_conds_arr = (unsigned char *) G_malloc(n_vals * sizeof(unsigned char));
++ memset(scatt_data->b_conds_arr, 0, n_vals * sizeof(unsigned char));
++ scatt_data->scatt_vals_arr = NULL;
++ return;
++#if 0
++void I_scd_get_range_min_max(struct scdScattData * scatt_data, CELL * band_1_min, CELL * band_1_max, CELL * band_2_min, CELL * band_2_max)
++ Rast_get_range_min_max(&(scatt_data->band_1_range), band_1_min, band_2_min);
++ Rast_get_range_min_max(&(scatt_data->band_2_range), band_2_min, band_2_max);
++ return;
++s
++void * I_scd_get_data_ptr(struct scdScattData * scatt_data)
++ if(!scatt_data->b_conds_arr)
++ return scatt_data->b_conds_arr;
++ else if(!scatt_data->scatt_vals_arr)
++ return scatt_data->scatt_vals_arr;
++ return NULL;
++int I_scd_set_value(struct scdScattData * scatt_data, unsigned int val_idx, unsigned int val)
++ if(val_idx < 0 && val_idx > scatt_data->n_vals)
++ return -1;
++ if(scatt_data->b_conds_arr)
++ scatt_data->b_conds_arr[val_idx] = val;
++ else if(scatt_data->scatt_vals_arr)
++ scatt_data->scatt_vals_arr[val_idx] = val;
++ else
++ return -1;
++ return 0;
++#endif
+Index: lib/imagery/scatt.c
+--- lib/imagery/scatt.c (revision 0)
++++ lib/imagery/scatt.c (working copy)
+@@ -0,0 +1,799 @@
++ \file lib/imagery/scatt.c
++ \brief Imagery library - functions for wx Scatter Plot Tool.
++ Low level functions used by wx Scatter Plot Tool.
++#include <grass/glocale.h>
++#include <math.h>
++struct rast_row
++ CELL * row;
++ char * null_row;
++ struct Range rast_range; /*Range of whole raster.*/
++ \brief Create pgm header.
++ Scatter plot internally generates pgm files. These pgms have header in format created by this function.
++ \param region region to be pgm header generated for
++ \param [out] header header of pgm file
++static int get_cat_rast_header(struct Cell_head * region, char * header){
++ return sprintf(header, "P5\n%d\n%d\n1\n", region->cols, region->rows);
++ \brief Create category raster conditions file.
++ \param cat_rast_region region to be file generated for
++ \param cat_rast path of generated category raster file
++int I_create_cat_rast(struct Cell_head * cat_rast_region, const char * cat_rast)
++ FILE * f_cat_rast;
++ char cat_rast_header[1024];//TODO magic number
++ int i_row, i_col;
++ int head_nchars;
++ unsigned char * row_data;
++ f_cat_rast = fopen(cat_rast, "wb");
++ if(!f_cat_rast) {
++ G_warning("Unable to create category raster condition file <%s>.", cat_rast);
++ return -1;
++ head_nchars = get_cat_rast_header(cat_rast_region, cat_rast_header);
++ fwrite(cat_rast_header, sizeof(char), head_nchars/sizeof(char), f_cat_rast);
++ if (ferror(f_cat_rast)){
++ fclose(f_cat_rast);
++ G_warning(_("Unable to write header into category raster condition file <%s>."), cat_rast);
++ return -1;
++ row_data = (unsigned char *) G_malloc(cat_rast_region->cols * sizeof(unsigned char));
++ for(i_col = 0; i_col < cat_rast_region->cols; i_col++)
++ row_data[i_col] = 0 & 255;
++ for(i_row = 0; i_row < cat_rast_region->rows; i_row++) {
++ fwrite(row_data, sizeof(unsigned char), (cat_rast_region->cols)/sizeof(unsigned char), f_cat_rast);
++ G_warning(_("Unable to write into category raster condition file <%s>."), cat_rast);
++ return -1;
++ return 0;
++static int print_reg(struct Cell_head * intersec, const char * pref, int dbg_level)
++ G_debug(dbg_level, "%s:\n n:%f\ns:%f\ne:%f\nw:%f\nns_res:%f\new_res:%f", pref, intersec->north, intersec->south,
++ intersec->east, intersec->west, intersec->ns_res, intersec->ew_res);
++ \brief Find intersection region of two regions.
++ \param A pointer to intersected region
++ \param B pointer to intersected region
++ \param [out] intersec pointer to intersection region of regions A B (relevant params of the region are: south, north, east, west)
++ \return 0 if interection exists
++ \return -1 if regions does not intersect
++static int regions_intersecion(struct Cell_head * A, struct Cell_head * B, struct Cell_head * intersec)
++ if(B->north < A->south) return -1;
++ else if(B->north > A->north) intersec->north = A->north;
++ else intersec->north = B->north;
++ if(B->south > A->north) return -1;
++ else if(B->south < A->south) intersec->south = A->south;
++ else intersec->south = B->south;
++ if(B->east < A->west) return -1;
++ else if(B->east > A->east) intersec->east = A->east;
++ else intersec->east = B->east;
++ if(B->west > A->east) return -1;
++ else if(B->west < A->west) intersec->west = A->west;
++ else intersec->west = B->west;
++ if(intersec->north == intersec->south) return -1;
++ if(intersec->east == intersec->west) return -1;
++ return 0;
++ \brief Get rows and cols numbers, which defines intersection of the regions.
++ \param B pointer to intersected region (A and B must have same resolution)
++ \param [out] A_bounds rows and cols numbers of A stored in south, north, east, west, which defines intersection of A and B
++ \param [out] B_bounds rows and cols numbers of B stored in south, north, east, west, which defines intersection of A and B
++ \return -1 if regions do not intersect
++ \return -2 resolution of regions is not same
++static int get_rows_and_cols_bounds(struct Cell_head * A, struct Cell_head * B, struct Cell_head * A_bounds, struct Cell_head * B_bounds)
++ float ns_res, ew_res;
++ struct Cell_head intersec;
++ /* TODO is it right check? */
++ if(abs(A->ns_res - B->ns_res) > GRASS_EPSILON) {
++ G_debug(0, "'get_rows_and_cols_bounds' ns_res does not fit, A->ns_res: %f B->ns_res: %f", A->ns_res, B->ns_res);
++ return -2;
++ if(abs(A->ew_res - B->ew_res) > GRASS_EPSILON) {
++ G_debug(0, "'get_rows_and_cols_bounds' ew_res does not fit, A->ew_res: %f B->ew_res: %f", A->ew_res, B->ew_res);
++ return -2;
++ ns_res = A->ns_res;
++ ew_res = A->ew_res;
++ if(regions_intersecion(A, B, &intersec) == -1)
++ return -1;
++ A_bounds->north = ceil((A->north - intersec.north - ns_res * 0.5) / ns_res);
++ A_bounds->south = ceil((A->north - intersec.south - ns_res * 0.5) / ns_res);
++ A_bounds->east = ceil((intersec.east - A->west - ew_res * 0.5) / ew_res);
++ A_bounds->west = ceil((intersec.west - A->west - ew_res * 0.5) / ew_res);
++ B_bounds->north = ceil((B->north - intersec.north - ns_res * 0.5) / ns_res);
++ B_bounds->south = ceil((B->north - intersec.south - ns_res * 0.5) / ns_res);
++ B_bounds->east = ceil((intersec.east - B->west - ew_res * 0.5) / ew_res);
++ B_bounds->west = ceil((intersec.west - B->west - ew_res * 0.5) / ew_res);
++ return 0;
++ \brief Insert raster map patch into pgm file.
++ \param patch_rast name of raster map
++ \param cat_rast_region region of category raster file
++ \param cat_rast path to category raster file
++int I_insert_patch_to_cat_rast(const char * patch_rast, struct Cell_head * cat_rast_region, const char * cat_rast)
++ struct Cell_head patch_region, patch_bounds, cat_rast_bounds;
++ int i_row, i_col, ncols, nrows, cat_rast_col, patch_col, val;
++ int head_nchars, ret;
++ int fd_patch_rast, init_shift, step_shift;
++ unsigned char * patch_data;
++ char * null_chunk_row;
++ const char *mapset;
++ struct Cell_head patch_lines, cat_rast_lines;
++ f_cat_rast = fopen(cat_rast, "rb+");
++ G_warning(_("Unable to open category raster condtions file <%s>."), cat_rast);
++ return -1;
++ if ((mapset = G_find_raster(patch_rast,"")) == NULL) {
++ G_warning(_("Unable to find patch raster <%s>."), patch_rast);
++ return -1;
++ Rast_get_cellhd(patch_rast, mapset, &patch_region);
++ Rast_set_window(&patch_region);
++ if ((fd_patch_rast = Rast_open_old(patch_rast, mapset)) < 0) {
++ return -1;
++ ret = get_rows_and_cols_bounds(cat_rast_region, &patch_region, &cat_rast_bounds, &patch_bounds);
++ if(ret == -2) {
++ G_warning(_("Resolutions of patch <%s> and patched file <%s> are not same."), patch_rast, cat_rast);
++ Rast_close(fd_patch_rast);
++ return -1;
++ else if (ret == -1){
++ return 0;
++ ncols = cat_rast_bounds.east - cat_rast_bounds.west;
++ nrows = cat_rast_bounds.south - cat_rast_bounds.north;
++ patch_data = (unsigned char *) G_malloc(ncols * sizeof(unsigned char));
++ init_shift = head_nchars + cat_rast_region->cols * cat_rast_bounds.north + cat_rast_bounds.west;
++ if(fseek(f_cat_rast, init_shift, SEEK_SET) != 0) {
++ G_warning(_("Corrupted category raster conditions file <%s> (fseek failed)"), cat_rast);
++ G_free(null_chunk_row);
++ return -1;
++ step_shift = cat_rast_region->cols - ncols;
++ null_chunk_row = Rast_allocate_null_buf();
++ for(i_row = 0; i_row < nrows; i_row++) {
++ Rast_get_null_value_row (fd_patch_rast, null_chunk_row, i_row + patch_bounds.north);
++ for(i_col = 0; i_col < ncols; i_col++) {
++ patch_col = patch_bounds.west + i_col;
++ if(null_chunk_row[patch_col] != 1)
++ patch_data[i_col] = 1 & 255;
++ else {
++ patch_data[i_col] = 0 & 255;
++ fwrite(patch_data, sizeof(unsigned char), (ncols)/sizeof(unsigned char), f_cat_rast);
++ G_warning(_("Unable to write into category raster conditions file <%s>"), cat_rast);
++ return -1;
++ if(fseek(f_cat_rast, step_shift, SEEK_CUR) != 0) {
++ return -1;
++ return 0;
++ \brief Updates scatter plots data in category by pixels which meets category conditions.
++ \param bands_rows data represents data describig one row from raster band
++ \param belongs_pix array which defines which pixels belongs to category (1 value) and which not (0 value)
++ \param [out] scatts pointer to scScatts struct of type SC_SCATT_DATA, which are modified according to values in belongs_pix
++static inline void update_cat_scatt_plts(struct rast_row * bands_rows, unsigned short * belongs_pix, struct scScatts * scatts)
++ int band_axis_1, band_axis_2, i_scatt, array_idx, cat_idx, i_chunk_rows_pix, max_arr_idx;
++ CELL * b_1_row;
++ CELL * b_2_row;
++ char * b_1_null_row,* b_2_null_row;
++ struct rast_row b_1_rast_row, b_2_rast_row;
++ struct Range b_1_range, b_2_range;
++ int b_1_range_size;
++ int row_size = Rast_window_cols();
++ int * scatts_bands = scatts->scatts_bands;
++ for(i_scatt = 0; i_scatt < scatts->n_a_scatts; i_scatt++)
++ b_1_rast_row = bands_rows[scatts_bands[i_scatt * 2]];
++ b_2_rast_row = bands_rows[scatts_bands[i_scatt * 2 + 1]];
++ b_1_row = b_1_rast_row.row;
++ b_2_row = b_2_rast_row.row;
++ b_1_null_row = b_1_rast_row.null_row;
++ b_2_null_row = b_2_rast_row.null_row;
++ b_1_range = b_1_rast_row.rast_range;
++ b_2_range = b_2_rast_row.rast_range;
++ b_1_range_size = b_1_range.max - b_1_range.min + 1;
++ max_arr_idx = (b_1_range.max - b_1_range.min + 1) * (b_2_range.max - b_2_range.min + 1);
++ for(i_chunk_rows_pix = 0; i_chunk_rows_pix < row_size; i_chunk_rows_pix++)
++ /* pixel does not belongs to scatter plot or has null value in one of the bands */
++ if(!belongs_pix[i_chunk_rows_pix] ||
++ b_1_null_row[i_chunk_rows_pix] == 1 ||
++ b_2_null_row[i_chunk_rows_pix] == 1)
++ continue;
++ /* index in scatter plot array */
++ array_idx = b_1_row[i_chunk_rows_pix] - b_1_range.min + (b_2_row[i_chunk_rows_pix] - b_2_range.min) * b_1_range_size;
++ if(array_idx < 0 || array_idx >= max_arr_idx) {
++ G_warning ("Data inconsistent. Value computed for scatter plot is out of initialized range.");
++ continue;
++ /* increment scatter plot value */
++ ++scatts->scatts_arr[i_scatt]->scatt_vals_arr[array_idx];
++ \brief Computes scatter plots data from chunk_rows.
++ \param scatts pointer to scScatts struct of type SC_SCATT_DATA, where are computed scatter plots stored
++ \param scatt_conds pointer to scScatts struct of type SC_SCATT_CONDITIONS, where are selected areas (condtitions)stored
++ \param chunk_rows data arrays of chunk_rows from analyzed raster bands (all data in chunk_rows, null_chunk_rows and belongs_pix arrays represents same region)
++ \param null_chunk_rows null data arrays of chunk_rows from analyzed raster bands
++ \param row_size size of data in chunk_rows, null_chunk_rows and belongs_pix arrays
++ \param f_cats_rasts_conds file which stores selected areas (conditions) from mapwindow see I_create_cat_rast() and I_pa
++ \param fd_cats_rasts array of openedraster maps which represents all selected pixels for category
++ \param region analysis region
++static inline int compute_scatts_from_chunk_row(struct Cell_head *region, struct scCats * scatt_conds,
++ FILE ** f_cats_rasts_conds, struct rast_row * bands_rows,
++ struct scCats * scatts, int * fd_cats_rasts)
++ int i_rows_pix, i_cat, i_scatt, n_a_scatts, n_pixs;
++ int cat_id, scatt_plts_cat_idx, array_idx, max_arr_idx;
++ CELL * cat_rast_row;
++ struct scScatts * scatts_conds;
++ struct scScatts * scatts_scatt_plts;
++ struct scdScattData * conds;
++ int * scatts_bands;
++ struct scdScattData ** scatts_arr;
++ CELL * b_1_row;
++ CELL * b_2_row;
++ unsigned char * i_scatt_conds;
++ unsigned short * belongs_pix = (unsigned short *) G_malloc(row_size * sizeof(unsigned short));
++ unsigned char * rast_pixs = (unsigned char *) G_malloc(row_size * sizeof(unsigned char));
++ cat_rast_row = Rast_allocate_c_buf();
++ for(i_cat = 0; i_cat < scatt_conds->n_a_cats; i_cat++)
++ scatts_conds = scatt_conds->cats_arr[i_cat];
++ cat_id = scatt_conds->cats_ids[i_cat];
++ scatt_plts_cat_idx = scatts->cats_idxs[cat_id];
++ if(scatt_plts_cat_idx < 0)
++ continue;
++ scatts_scatt_plts = scatts->cats_arr[scatt_plts_cat_idx];
++ G_zero(belongs_pix, row_size * sizeof(unsigned short));
++ /* if category has no conditions defined, scatter plots without any constraint are computed (default scatter plots) */
++ if(!scatts_conds->n_a_scatts && !f_cats_rasts_conds[i_cat]) {
++ for(i_scatt = 0; i_scatt < scatts_scatt_plts->n_a_scatts; i_scatt++)
++ /* all pixels belongs */
++ for(i_rows_pix = 0; i_rows_pix < row_size; i_rows_pix++)
++ belongs_pix[i_rows_pix] = 1;
++ /* compute belonging pixels for defined conditions */
++ else
++ scatts_bands = scatts_conds->scatts_bands;
++ /* check conditions from category raster condtitions file */
++ if(f_cats_rasts_conds[i_cat]) {
++ n_pixs = fread(rast_pixs, sizeof(unsigned char), (row_size)/sizeof(unsigned char), f_cats_rasts_conds[i_cat]);
++ if (ferror(f_cats_rasts_conds[i_cat]))
++ G_free(rast_pixs);
++ G_free(belongs_pix);
++ G_warning(_("Unable to read from category raster condtition file."));
++ return -1;
++ if (n_pixs != n_pixs) {
++ G_warning(_("Invalid size of category raster conditions file."));
++ return -1;
++ if(rast_pixs[i_rows_pix] != 0 & 255)
++ /* check condtions defined in scatter plots*/
++ for(i_scatt = 0; i_scatt < scatts_conds->n_a_scatts; i_scatt++)
++ i_scatt_conds = scatts_conds->scatts_arr[i_scatt]->b_conds_arr;
++ /* pixels already belongs to category from category raster conditions file or contains null value in one of the bands */
++ if(belongs_pix[i_rows_pix] ||
++ b_1_null_row[i_rows_pix] == 1 ||
++ b_2_null_row[i_rows_pix] == 1)
++ continue;
++ array_idx = b_1_row[i_rows_pix] - b_1_range.min + (b_2_row[i_rows_pix] - b_2_range.min) * b_1_range_size;
++ continue;
++ /* pixels meets condtion defined in scatter plot */
++ if(i_scatt_conds[array_idx])
++ /* update category raster with belonging pixels */
++ if(fd_cats_rasts[i_cat] >= 0) {
++ Rast_set_null_value(cat_rast_row, Rast_window_cols(), CELL_TYPE);
++ if(belongs_pix[i_rows_pix])
++ cat_rast_row[i_rows_pix] = belongs_pix[i_rows_pix];
++ Rast_put_c_row (fd_cats_rasts[i_cat], cat_rast_row);
++ /* update scatter plots with belonging pixels */
++ update_cat_scatt_plts(bands_rows, belongs_pix, scatts_scatt_plts);
++ G_free(cat_rast_row);
++ return 0;
++ \brief Get list if bands needed to be opened for analysis from scCats struct.
++static void get_needed_bands(struct scCats * cats, int * b_needed_bands)
++ // results in b_needed_bands - array of bools - if item has value 1, band (defined by item index) is needed to be opened
++ int i_cat, i_scatt, cat_id;
++ for(i_scatt = 0; i_scatt < cats->cats_arr[i_cat]->n_a_scatts; i_scatt++)
++ G_debug(3, "Active scatt %d in catt %d", i_scatt, i_cat);
++ b_needed_bands[cats->cats_arr[i_cat]->scatts_bands[i_scatt * 2]] = 1;
++ b_needed_bands[cats->cats_arr[i_cat]->scatts_bands[i_scatt * 2 + 1]] = 1;
++ return;
++ \brief Helper function for clean up.
++static void free_compute_scatts_data(int * fd_bands, struct rast_row * bands_rows, int n_a_bands, int * bands_ids,
++ int * fd_cats_rasts, FILE ** f_cats_rasts_conds, int n_a_cats)
++ int i, band_id;
++ for(i = 0; i < n_a_bands; i++)
++ band_id = bands_ids[i];
++ if(band_id >= 0) {
++ Rast_close(fd_bands[i]);
++ G_free(bands_rows[band_id].row);
++ G_free(bands_rows[band_id].null_row);
++ if(f_cats_rasts_conds)
++ for(i = 0; i < n_a_cats; i++)
++ if(f_cats_rasts_conds[i])
++ fclose(f_cats_rasts_conds[i]);
++ if(fd_cats_rasts)
++ if(fd_cats_rasts[i] >= 0)
++ Rast_close(fd_cats_rasts[i]);
++ \brief Compute scatter plots data.
++ If category has not defined no category raster condition file and no scatter plot with consdtion,
++ default scatter plot is computed.
++ \param region analysis region, beaware that all input data must be prepared for this region (bands (their ranges), cats_rasts_conds rasters...)
++ \param region function calls Rast_set_window for this region
++ \param scatt_conds pointer to scScatts struct of type SC_SCATT_CONDITIONS, where are stored selected areas (conditions) in scatter plots
++ \param cats_rasts_conds paths to category raster conditions files representing selected areas (conditions) in rasters for every category
++ \param cats_rasts_conds index in array represents corresponding category id
++ \param cats_rasts_conds for manupulation with category raster conditions file see also I_id_scatt_to_bands() and I_insert_patch_to_cat_rast()
++ \param bands names of analyzed bands, order of bands is defined by their id
++ \param [out] scatts pointer to scScatts struct of type SC_SCATT_DATA, where are computed scatter plots stored
++ \param [out] cats_rasts array of raster maps names where will be stored all selected pixels for every category
++int I_compute_scatts(struct Cell_head *region, struct scCats * scatt_conds, const char ** cats_rasts_conds,
++ const char ** bands, int n_bands, struct scCats * scatts, const char ** cats_rasts)
++ char header[1024];
++ int fd_cats_rasts[scatt_conds->n_a_cats];
++ FILE * f_cats_rasts_conds[scatt_conds->n_a_cats];
++ struct rast_row bands_rows[n_bands];
++ RASTER_MAP_TYPE data_type;
++ int nrows, i_band, n_a_bands, band_id,
++ i, i_row, head_nchars, i_cat, id_cat;
++ int fd_bands[n_bands];
++ int bands_ids[n_bands];
++ int b_needed_bands[n_bands];
++ Rast_set_window(region);
++ for(i_band = 0; i_band < n_bands; i_band++)
++ fd_bands[i_band] = -1;
++ bands_ids[i_band] = -1;
++ if (n_bands != scatts->n_bands ||
++ n_bands != scatt_conds->n_bands)
++ return -1;
++ memset(b_needed_bands, 0, (size_t)n_bands * sizeof(int));
++ get_needed_bands(scatt_conds, &b_needed_bands[0]);
++ get_needed_bands(scatts, &b_needed_bands[0]);
++ n_a_bands = 0;
++ /* open band rasters, which are needed for computation */
++ for(band_id = 0; band_id < n_bands; band_id++)
++ if(b_needed_bands[band_id])
++ G_debug(3, "Opening raster no. %d with name: %s", band_id, bands[band_id]);
++ if ((mapset = G_find_raster2(bands[band_id],"")) == NULL) {
++ free_compute_scatts_data(fd_bands, bands_rows, n_a_bands,
++ bands_ids, NULL, NULL, scatt_conds->n_a_cats);
++ G_warning(_("Unbale to read find raster <%s>"), bands[band_id]);
++ return -1;
++ if ((fd_bands[n_a_bands] = Rast_open_old(bands[band_id], mapset)) < 0) {
++ G_warning(_("Unbale to open raster <%s>"), bands[band_id]);
++ return -1;
++ data_type = Rast_get_map_type(fd_bands[n_a_bands]);
++ if(data_type != CELL_TYPE) {
++ G_warning(_("Raster <%s> type is not <%s>"), bands[band_id], "CELL");
++ return -1;
++ bands_rows[band_id].row = Rast_allocate_c_buf();
++ bands_rows[band_id].null_row = Rast_allocate_null_buf();
++ if(Rast_read_range(bands[band_id], mapset, &bands_rows[band_id].rast_range) != 1){
++ G_warning(_("Unable to read range of raster <%s>"), bands[band_id]);
++ return -1;
++ bands_ids[n_a_bands] = band_id;
++ ++n_a_bands;
++ /* open category rasters condition files and category rasters */
++ for(i_cat = 0; i_cat < scatts->n_a_cats; i_cat++)
++ id_cat = scatts->cats_ids[i_cat];
++ if(cats_rasts[id_cat]) {
++ fd_cats_rasts[i_cat] = Rast_open_new(cats_rasts[id_cat], CELL_TYPE);
++ else
++ fd_cats_rasts[i_cat] = -1;
++ if(cats_rasts_conds[id_cat]) {
++ f_cats_rasts_conds[i_cat] = fopen(cats_rasts_conds[id_cat], "r");
++ if(!f_cats_rasts_conds[i_cat]) {
++ free_compute_scatts_data(fd_bands, bands_rows, n_a_bands, bands_ids,
++ f_cats_rasts_conds, f_cats_rasts_conds, scatt_conds->n_a_cats);
++ G_warning(_("Unable to open category raster condtition file <%s>"), bands[band_id]);
++ return -1;
++ else
++ f_cats_rasts_conds[i_cat] = NULL;
++ head_nchars = get_cat_rast_header(region, header);
++ if( fseek(f_cats_rasts_conds[i_cat] , head_nchars, SEEK_SET) != 0) {
++ G_warning(_("Corrupted category raster conditions file (fseek failed)"));
++ return -1;
++ nrows = Rast_window_rows();
++ /* analyze bands by rows */
++ for (i_row = 0; i_row < nrows; i_row++)
++ for(i_band = 0; i_band < n_a_bands; i_band++)
++ band_id = bands_ids[i_band];
++ Rast_get_c_row(fd_bands[i_band], bands_rows[band_id].row, i_row);
++ Rast_get_null_value_row (fd_bands[i_band], bands_rows[band_id].null_row, i_row);
++ if(compute_scatts_from_chunk_row(region, scatt_conds, f_cats_rasts_conds, bands_rows, scatts, fd_cats_rasts) == -1)
++ free_compute_scatts_data(fd_bands, bands_rows, n_a_bands, bands_ids, fd_cats_rasts,
++ f_cats_rasts_conds, scatt_conds->n_a_cats);
++ return -1;
++ fd_cats_rasts, f_cats_rasts_conds, scatt_conds->n_a_cats);
++ return 0;
++int I_merge_arrays(unsigned char * merged_arr, unsigned char * overlay_arr, unsigned rows, unsigned cols, double alpha)
++ unsigned int i_row, i_col, i_b;
++ unsigned int row_idx, col_idx, idx;
++ unsigned int c_a_i, c_a;
++ for(i_row = 0; i_row < rows; i_row++)
++ row_idx = i_row * cols;
++ for(i_col = 0; i_col < cols; i_col++)
++ col_idx = 4 * (row_idx + i_col);
++ idx = col_idx + 3;
++ c_a = overlay_arr[idx] * alpha;
++ c_a_i = 255 - c_a;
++ merged_arr[idx] = (c_a_i * (int)merged_arr[idx] + c_a * 255) / 255;
++ for(i_b = 0; i_b < 3; i_b++)
++ idx = col_idx + i_b;
++ merged_arr[idx] = (c_a_i * (int)merged_arr[idx] + c_a * (int)overlay_arr[idx]) / 255;
++ return 0;
++int I_apply_colormap(unsigned char * vals, unsigned char * vals_mask, unsigned vals_size, unsigned char * colmap, unsigned char * col_vals){
++ unsigned int i_val;
++ int v, i, i_cm;
++ for(i_val = 0; i_val < vals_size; i_val++){
++ i_cm = 4 * i_val;
++ v = vals[i_val];
++ if(vals_mask[i_val])
++ for(i = 0; i < 4; i++) col_vals[i_cm + i] = colmap[258 * 4 + i];
++ else if(v > 255)
++ for(i = 0; i < 4; i++) col_vals[i_cm + i] = colmap[257 * 4 + i];
++ else if(v < 0)
++ for(i = 0; i < 4; i++) col_vals[i_cm + i] = colmap[256 * 4 + i];
++ else
++ for(i = 0; i < 4; i++){ col_vals[i_cm + i] = colmap[v * 4 + i];
++ return 0;
Index: include/imagery.h
--- include/imagery.h (revision 57633)
@@ -103,52 +1332,170 @@
/* sig.c */
int I_init_signatures(struct Signature *, int);
int I_new_signature(struct Signature *);
-Index: gui/wxpython/mapdisp/frame.py
+Index: gui/icons/grass/polygon.png
---- gui/wxpython/mapdisp/frame.py (revision 57633)
-+++ gui/wxpython/mapdisp/frame.py (working copy)
-@@ -225,6 +225,7 @@
- self.dialogs = {}
- self.dialogs['attributes'] = None
-+ self.dialogs['scatt_plot'] = None
- self.dialogs['category'] = None
- self.dialogs['barscale'] = None
- self.dialogs['legend'] = None
-@@ -1168,6 +1169,19 @@
- """!Returns toolbar with zooming tools"""
- return self.toolbars['map']
+Cannot display: file marked as a binary type.
+svn:mime-type = application/octet-stream
+--- gui/icons/grass/polygon.png (revision 57633)
++++ gui/icons/grass/polygon.png (working copy)
+Property changes on: gui/icons/grass/polygon.png
+___________________________________________________________________
+Added: svn:mime-type
+## -0,0 +1 ##
++application/octet-stream
+\ No newline at end of property
+Index: gui/wxpython/iclass/plots.py
+--- gui/wxpython/iclass/plots.py (revision 57633)
++++ gui/wxpython/iclass/plots.py (working copy)
+@@ -19,6 +19,7 @@
+ import wx.lib.plot as plot
+ import wx.lib.scrolledpanel as scrolled
+ from core.utils import _
++from core.gcmd import GError
-+ def OnScatterplot2(self, event):
+ class PlotPanel(scrolled.ScrolledPanel):
+ """!Panel for drawing multiple plots.
+@@ -28,7 +29,7 @@
+ for each band and for one category. Coincidence plots show min max range
+ of classes for each band.
+- def __init__(self, parent, stats_data):
++ def __init__(self, parent, giface, stats_data):
+ scrolled.ScrolledPanel.__init__(self, parent)
+ self.SetupScrolling(scroll_x = False, scroll_y = True)
+@@ -38,26 +39,71 @@
+ self.stats_data = stats_data
+ self.currentCat = None
++ self._giface = giface
+ self.mainSizer = wx.BoxSizer(wx.VERTICAL)
+ self._createControlPanel()
++ self._createPlotPanel()
++ self._createScatterPlotPanel()
+ self.SetSizer(self.mainSizer)
+ self.mainSizer.Fit(self)
+ self.Layout()
++ def _createPlotPanel(self):
++ self.canvasPanel = wx.Panel(parent=self)
++ self.mainSizer.Add(item = self.canvasPanel, proportion = 1, flag = wx.EXPAND, border = 0)
++ self.canvasSizer = wx.BoxSizer(wx.VERTICAL)
++ self.canvasPanel.SetSizer(self.canvasSizer)
+ def _createControlPanel(self):
+ self.plotSwitch = wx.Choice(self, id = wx.ID_ANY,
+ choices = [_("Histograms"),
+- _("Coincident plots")])
++ _("Coincident plots"),
++ _("Scatter plots")])
+ self.mainSizer.Add(self.plotSwitch, proportion = 0, flag = wx.EXPAND|wx.ALL, border = 5)
+ self.plotSwitch.Bind(wx.EVT_CHOICE, self.OnPlotTypeSelected)
++ def _createScatterPlotPanel(self):
+ """!Init interactive scatterplot tools
-+ if self.dialogs['scatt_plot']:
-+ self.dialogs['scatt_plot'].Raise()
-+ return
++ try:
++ from scatt_plot.frame import IClassScatterPlotsPanel
++ self.scatt_plot_panel = IClassScatterPlotsPanel(parent=self,
++ giface=self._giface,
++ iclass_mapwin = self.parent.GetFirstWindow())
++ self.mainSizer.Add(self.scatt_plot_panel, proportion = 1, flag = wx.EXPAND, border = 0)
++ self.scatt_plot_panel.Hide()
++ except ImportError as e:#TODO
++ self.scatt_error = _("Scatter plot functionality is disabled. Reason:\n" \
++ "Unable to import packages needed for scatter plot.\n%s" % e)
++ GError(self.scatt_error)
++ self.scatt_plot_panel = None
-+ from scatt_plot.dialogs import ScattPlotMainDialog
-+ self.dialogs['scatt_plot'] = ScattPlotMainDialog(parent=self, giface=self._giface)
+ def OnPlotTypeSelected(self, event):
+ """!Plot type selected"""
++ if self.plotSwitch.GetSelection() in [0, 1]:
++ self.SetupScrolling(scroll_x = False, scroll_y = True)
++ if self.scatt_plot_panel:
++ self.canvasPanel.Show()
++ self.Layout()
++ elif self.plotSwitch.GetSelection() == 2:
++ self.SetupScrolling(scroll_x = False, scroll_y = False)
++ self.scatt_plot_panel.Show()
++ else:
++ self.canvasPanel.Hide()
++ self.Layout()
+ if self.currentCat is None:
+ return
+ if self.plotSwitch.GetSelection() == 0:
+ stat = self.stats_data.GetStatistics(self.currentCat)
+ if not stat.IsReady():
+@@ -66,7 +112,10 @@
+ self.DrawHistograms(stat)
+ else:
+ self.DrawCoincidencePlots()
++ self.Layout()
+ def StddevChanged(self):
+ """!Standard deviation multiplier changed, redraw histograms"""
+@@ -89,7 +138,7 @@
+ panel.Destroy()
+ self.canvasList = []
+ def ClearPlots(self):
+ """!Clears plot canvases"""
+ for bandIdx in range(len(self.bandList)):
+@@ -104,15 +153,15 @@
+ def CreatePlotCanvases(self):
+ """!Create plot canvases according to the number of bands"""
+ for band in self.bandList:
+- canvas = plot.PlotCanvas(self)
++ canvas = plot.PlotCanvas(self.canvasPanel)
+ canvas.SetMinSize((-1, 140))
+ canvas.SetFontSizeTitle(10)
+ canvas.SetFontSizeAxis(8)
+ self.canvasList.append(canvas)
+- self.mainSizer.Add(item = canvas, proportion = 1, flag = wx.EXPAND, border = 0)
+- self.SetVirtualSize(self.GetBestVirtualSize())
++ self.canvasSizer.Add(item = canvas, proportion = 1, flag = wx.EXPAND, border = 0)
-+ self.dialogs['scatt_plot'].CenterOnScreen()
-+ self.dialogs['scatt_plot'].Show()
- def OnVNet(self, event):
- """!Dialog for v.net* modules
-Index: gui/wxpython/mapdisp/toolbars.py
---- gui/wxpython/mapdisp/toolbars.py (revision 57633)
-+++ gui/wxpython/mapdisp/toolbars.py (working copy)
-@@ -239,7 +239,8 @@
- (MapIcons["scatter"], self.parent.OnScatterplot),
- (MapIcons["histogram"], self.parent.OnHistogramPyPlot),
- (BaseIcons["histogramD"], self.parent.OnHistogram),
-- (MapIcons["vnet"], self.parent.OnVNet)))
-+ (MapIcons["vnet"], self.parent.OnVNet),
-+ (MapIcons["scatter"], self.parent.OnScatterplot2)))
++ self.SetVirtualSize(self.GetBestVirtualSize())
+ self.Layout()
- def OnDecoration(self, event):
- """!Decorations overlay menu
+ def UpdatePlots(self, group, currentCat, stats_data):
+@@ -138,7 +187,7 @@
+ def UpdateCategory(self, cat):
+ self.currentCat = cat
+ def DrawCoincidencePlots(self):
+ """!Draw coincidence plots"""
Index: gui/wxpython/iclass/dialogs.py
--- gui/wxpython/iclass/dialogs.py (revision 57633)
@@ -468,155 +1815,1830 @@
def test():
import core.render as render
-Index: gui/wxpython/iclass/plots.py
+Index: gui/wxpython/mapdisp/toolbars.py
---- gui/wxpython/iclass/plots.py (revision 57633)
-+++ gui/wxpython/iclass/plots.py (working copy)
-@@ -19,6 +19,7 @@
- import wx.lib.plot as plot
- import wx.lib.scrolledpanel as scrolled
- from core.utils import _
-+from core.gcmd import GError
+--- gui/wxpython/mapdisp/toolbars.py (revision 57633)
++++ gui/wxpython/mapdisp/toolbars.py (working copy)
+@@ -239,7 +239,8 @@
+ (MapIcons["scatter"], self.parent.OnScatterplot),
+ (MapIcons["histogram"], self.parent.OnHistogramPyPlot),
+ (BaseIcons["histogramD"], self.parent.OnHistogram),
+- (MapIcons["vnet"], self.parent.OnVNet)))
++ (MapIcons["vnet"], self.parent.OnVNet),
++ (MapIcons["scatter"], self.parent.OnScatterplot2)))
+ def OnDecoration(self, event):
+ """!Decorations overlay menu
+Index: gui/wxpython/mapdisp/frame.py
+--- gui/wxpython/mapdisp/frame.py (revision 57633)
++++ gui/wxpython/mapdisp/frame.py (working copy)
+@@ -225,6 +225,7 @@
+ self.dialogs = {}
+ self.dialogs['attributes'] = None
++ self.dialogs['scatt_plot'] = None
+ self.dialogs['category'] = None
+ self.dialogs['barscale'] = None
+ self.dialogs['legend'] = None
+@@ -1168,6 +1169,19 @@
+ """!Returns toolbar with zooming tools"""
+ return self.toolbars['map']
- class PlotPanel(scrolled.ScrolledPanel):
- """!Panel for drawing multiple plots.
-@@ -28,7 +29,7 @@
- for each band and for one category. Coincidence plots show min max range
- of classes for each band.
-- def __init__(self, parent, stats_data):
-+ def __init__(self, parent, giface, stats_data):
- scrolled.ScrolledPanel.__init__(self, parent)
- self.SetupScrolling(scroll_x = False, scroll_y = True)
-@@ -38,26 +39,71 @@
- self.stats_data = stats_data
- self.currentCat = None
-+ self._giface = giface
++ def OnScatterplot2(self, event):
++ """!Init interactive scatterplot tools
++ if self.dialogs['scatt_plot']:
++ self.dialogs['scatt_plot'].Raise()
++ return
- self.mainSizer = wx.BoxSizer(wx.VERTICAL)
++ from scatt_plot.dialogs import ScattPlotMainDialog
++ self.dialogs['scatt_plot'] = ScattPlotMainDialog(parent=self, giface=self._giface)
++ self.dialogs['scatt_plot'].CenterOnScreen()
++ self.dialogs['scatt_plot'].Show()
- self._createControlPanel()
-+ self._createPlotPanel()
-+ self._createScatterPlotPanel()
+ def OnVNet(self, event):
+ """!Dialog for v.net* modules
+Index: gui/wxpython/scatt_plot/plots.py
+--- gui/wxpython/scatt_plot/plots.py (revision 0)
++++ gui/wxpython/scatt_plot/plots.py (working copy)
+@@ -0,0 +1,950 @@
++ at package scatt_plot.dialogs
- self.SetSizer(self.mainSizer)
- self.mainSizer.Fit(self)
- self.Layout()
++ at brief Ploting widgets.
-+ def _createPlotPanel(self):
++Classes:
-+ self.canvasPanel = wx.Panel(parent=self)
-+ self.mainSizer.Add(item = self.canvasPanel, proportion = 1, flag = wx.EXPAND, border = 0)
-+ self.canvasSizer = wx.BoxSizer(wx.VERTICAL)
-+ self.canvasPanel.SetSizer(self.canvasSizer)
++(C) 2013 by the GRASS Development Team
- def _createControlPanel(self):
- self.plotSwitch = wx.Choice(self, id = wx.ID_ANY,
- choices = [_("Histograms"),
-- _("Coincident plots")])
-+ _("Coincident plots"),
-+ _("Scatter plots")])
- self.mainSizer.Add(self.plotSwitch, proportion = 0, flag = wx.EXPAND|wx.ALL, border = 5)
- self.plotSwitch.Bind(wx.EVT_CHOICE, self.OnPlotTypeSelected)
++This program is free software under the GNU General Public License
++(>=v2). Read the file COPYING that comes with GRASS for details.
++ at author Stepan Turek <stepan.turek seznam.cz> (mentor: Martin Landa)
++import wx
++import numpy as np
++#TODO testing
++import time
++from multiprocessing import Process, Queue
++#TODO
++#from numpy.lib.stride_tricks import as_strided
++from copy import deepcopy
++from scatt_plot.core_c import MergeArrays, ApplyColormap
++from core.settings import UserSettings
++try:
++ import matplotlib
++ matplotlib.use('WXAgg')
++ from matplotlib.figure import Figure
++ from matplotlib.backends.backend_wxagg import \
++ FigureCanvasWxAgg as FigCanvas
++ from matplotlib.lines import Line2D
++ from matplotlib.artist import Artist
++ from matplotlib.mlab import dist_point_to_segment
++ from matplotlib.patches import Polygon, Ellipse, Rectangle
++ import matplotlib.image as mi
++ import matplotlib.colors as mcolors
++ import matplotlib.cbook as cbook
++except ImportError as e:
++ raise ImportError(_("Unable to import matplotlib (try to install it).\n%s") % e)
++import grass.script as grass
++from grass.pydispatch.signal import Signal
++class ScatterPlotWidget(wx.Panel):
++ def __init__(self, parent, scatt_id, scatt_mgr, transpose,
++ id = wx.ID_ANY):
++ wx.Panel.__init__(self, parent, id)
++ self.parent = parent
++ self.full_extend = None
++ self.mode = None
++ self._createWidgets()
++ self._doLayout()
++ self.scatt_id = scatt_id
++ self.scatt_mgr = scatt_mgr
++ self.cidpress = None
++ self.cidrelease = None
++ self.transpose = transpose
++ self.inverse = False
++ self.SetSize((200, 100))
++ self.Layout()
++ self.base_scale = 1.2
++ self.Bind(wx.EVT_CLOSE,lambda event : self.CleanUp())
++ self.plotClosed = Signal("ScatterPlotWidget.plotClosed")
++ self.cursorMove = Signal("ScatterPlotWidget.cursorMove")
++ self.contex_menu = ScatterPlotContextMenu(plot = self)
++ self.ciddscroll = None
++ self.canvas.mpl_connect('motion_notify_event', self.Motion)
++ self.canvas.mpl_connect('button_press_event', self.OnPress)
++ self.canvas.mpl_connect('button_release_event', self.OnRelease)
++ self.canvas.mpl_connect('draw_event', self.draw_callback)
++ def draw_callback(self, event):
++ self.polygon_drawer.draw_callback(event)
++ self.axes.draw_artist(self.zoom_rect)
++ def _createWidgets(self):
++ # Create the mpl Figure and FigCanvas objects.
++ # 5x4 inches, 100 dots-per-inch
++ self.dpi = 100
++ self.fig = Figure((1.0, 1.0), dpi=self.dpi)
++ self.fig.autolayout = True
++ self.canvas = FigCanvas(self, -1, self.fig)
++ self.axes = self.fig.add_axes([0,0,1,1])
++ pol = Polygon(list(zip([0], [0])), animated=True)
++ self.axes.add_patch(pol)
++ self.polygon_drawer = PolygonDrawer(self.axes, pol = pol, empty_pol = True)
++ self.zoom_wheel_coords = None
++ self.zoom_rect_coords = None
++ self.zoom_rect = Polygon(list(zip([0], [0])), facecolor = 'none')
++ self.zoom_rect.set_visible(False)
++ self.axes.add_patch(self.zoom_rect)
++ def ZoomToExtend(self):
++ if self.full_extend:
++ self.axes.axis(self.full_extend)
++ self.canvas.draw()
++ def SetMode(self, mode):
++ self._deactivateMode()
++ if mode == 'zoom':
++ self.ciddscroll = self.canvas.mpl_connect('scroll_event', self.ZoomWheel)
++ self.mode = 'zoom'
++ elif mode == 'zoom_extend':
++ self.mode = 'zoom_extend'
++ elif mode == 'pan':
++ self.mode = 'pan'
++ elif mode:
++ self.polygon_drawer.SetMode(mode)
++ def SetSelectionPolygonMode(self, activate):
++ self.polygon_drawer.SetSelectionPolygonMode(activate)
++ def _deactivateMode(self):
++ self.mode = None
++ self.polygon_drawer.SetMode(None)
++ if self.ciddscroll:
++ self.canvas.mpl_disconnect(self.ciddscroll)
++ self._stopCategoryEdit()
++ def GetCoords(self):
++ coords = self.polygon_drawer.GetCoords()
++ if coords is None:
++ return
++ if self.transpose:
++ for c in coords:
++ tmp = c[0]
++ c[0] = c[1]
++ c[1] = tmp
++ return coords
++ def SetEmpty(self):
++ return self.polygon_drawer.SetEmpty()
++ def OnRelease(self, event):
++ if not self.mode == "zoom": return
++ self.ZoomRectangle(event)
-+ def _createScatterPlotPanel(self):
-+ """!Init interactive scatterplot tools
++ def OnPress(self, event):
++ 'on button press we will see if the mouse is over us and store some data'
++ if not event.inaxes:
++ return
++ if self.mode == "zoom_extend":
++ self.ZoomToExtend()
++ if event.xdata and event.ydata:
++ self.zoom_wheel_coords = { 'x' : event.xdata, 'y' : event.ydata}
++ self.zoom_rect_coords = { 'x' : event.xdata, 'y' : event.ydata}
++ else:
++ def _stopCategoryEdit(self):
++ 'disconnect all the stored connection ids'
++ if self.cidpress:
++ self.canvas.mpl_disconnect(self.cidpress)
++ if self.cidrelease:
++ self.canvas.mpl_disconnect(self.cidrelease)
++ #self.canvas.mpl_disconnect(self.cidmotion)
++ def _doLayout(self):
++ self.main_sizer = wx.BoxSizer(wx.VERTICAL)
++ self.main_sizer.Add(self.canvas, 1, wx.LEFT | wx.TOP | wx.GROW)
++ self.SetSizer(self.main_sizer)
++ self.main_sizer.Fit(self)
++ def Plot(self, cats_order, scatts, ellipses, styles):
++ """ Redraws the figure
++ callafter_list = []
++ cx = self.axes.get_xlim()
++ cy = self.axes.get_ylim()
++ c = cx + cy
++ else:
++ c = None
++ #q = Queue()
++ #p = Process(target=MergeImg, args=(cats_order, scatts, styles, self.transpose, q))
++ #p.start()
++ #merged_img, self.full_extend = q.get()
++ #p.join()
++ merged_img, self.full_extend = MergeImg(cats_order, scatts, styles, None)
++ self.axes.clear()
++ self.axes.axis('equal')
++ merged_img = np.transpose(merged_img, (1, 0, 2))
++ #print self.full_extend
++ img = imshow(self.axes, merged_img,
++ extent=self.full_extend,
++ origin='lower',
++ interpolation='nearest',
++ aspect="equal")
++ callafter_list.append([self.axes.draw_artist, [img]])
++ callafter_list.append([grass.try_remove, [merged_img.filename]])
++ for cat_id in cats_order:
++ if cat_id == 0:
++ continue
++ if not ellipses.has_key(cat_id):
++ continue
++ e = ellipses[cat_id]
++ if not e:
++ continue
++ colors = styles[cat_id]['color'].split(":")
++ e['theta'] = 360 - e['theta'] + 90
++ if e['theta'] >= 360:
++ e['theta'] = abs(360 - e['theta'])
++ e['pos'] = [e['pos'][1], e['pos'][0]]
++ ellip = Ellipse(xy=e['pos'],
++ width=e['width'],
++ height=e['height'],
++ angle=e['theta'],
++ edgecolor="w",
++ linewidth=1.5,
++ facecolor='None')
++ self.axes.add_artist(ellip)
++ callafter_list.append([self.axes.draw_artist, [ellip]])
++ color = map(lambda v : int(v)/255.0, styles[cat_id]['color'].split(":"))
++ edgecolor=color,
++ linewidth=1,
++ center = Line2D([e['pos'][0]], [e['pos'][1]],
++ marker='x',
++ markeredgecolor='w',
++ #markerfacecolor=color,
++ markersize=2)
++ self.axes.add_artist(center)
++ callafter_list.append([self.axes.draw_artist, [center]])
++ callafter_list.append([self.fig.canvas.blit, []])
++ if c:
++ self.axes.axis(c)
++ wx.CallAfter(lambda : self.CallAfter(callafter_list))
++ def CallAfter(self, funcs_list):
++ while funcs_list:
++ fcn, args = funcs_list.pop(0)
++ fcn(*args)
++ def CleanUp(self):
++ self.plotClosed.emit(scatt_id = self.scatt_id)
++ self.Destroy()
++ def ZoomWheel(self, event):
++ # get the current x and y limits
++ return
++ # tcaswell
++ # http://stackoverflow.com/questions/11551049/matplotlib-plot-zooming-with-scroll-wheel
++ cur_xlim = self.axes.get_xlim()
++ cur_ylim = self.axes.get_ylim()
++ xdata = event.xdata
++ ydata = event.ydata
++ if event.button == 'up':
++ scale_factor = 1/self.base_scale
++ elif event.button == 'down':
++ scale_factor = self.base_scale
++ else:
++ scale_factor = 1
++ extend = (xdata - (xdata - cur_xlim[0]) * scale_factor,
++ xdata + (cur_xlim[1] - xdata) * scale_factor,
++ ydata - (ydata - cur_ylim[0]) * scale_factor,
++ ydata + (cur_ylim[1] - ydata) * scale_factor)
++ self.axes.axis(extend)
++ def ZoomRectangle(self, event):
++ if event.inaxes is None: return
++ if event.button != 1: return
++ x1, y1 = event.xdata, event.ydata
++ x2 = deepcopy(self.zoom_rect_coords['x'])
++ y2 = deepcopy(self.zoom_rect_coords['y'])
++ if x1 == x2 or y1 == y2:
++ return
++ self.axes.set_xlim(x1, x2)#, auto = True)
++ self.axes.set_ylim(y1, y2)#, auto = True)
++ def Motion(self, event):
++ self.PanMotion(event)
++ self.ZoomRectMotion(event)
++ return
++ self.cursorMove.emit(x=event.xdata, y=event.ydata)
++ def PanMotion(self, event):
++ 'on mouse movement'
++ if not self.mode == "pan":
++ return
++ return
++ return
++ x,y = event.xdata, event.ydata
++ mx = (x - self.zoom_wheel_coords['x']) * 0.5
++ my = (y - self.zoom_wheel_coords['y']) * 0.5
++ extend = (cur_xlim[0] + mx, cur_xlim[1] + mx, cur_ylim[0] + my, cur_ylim[1] + my)
++ self.zoom_wheel_coords['x'] = x
++ self.zoom_wheel_coords['y'] = y
++ #self.canvas.copy_from_bbox(self.axes.bbox)
++ #self.canvas.restore_region(self.background)
++ def ZoomRectMotion(self, event):
++ self.zoom_rect.set_visible(True)
++ x2 = self.zoom_rect_coords['x']
++ y2 = self.zoom_rect_coords['y']
++ self.zoom_rect.xy = ((x1, y1), (x1, y2), (x2, y2), (x2, y1), (x1, y1))
++ #self.axes.draw_artist(self.zoom_rect)
++class ScatterPlotContextMenu:
++ def __init__(self, plot):
++ self.plot = plot
++ self.canvas = plot.canvas
++ self.cidpress = self.canvas.mpl_connect(
++ 'button_press_event', self.ContexMenu)
++ def ContexMenu(self, event):
++ return
++ if event.button == 3:
++ menu = wx.Menu()
++ menu_items = [["zoom_to_extend", _("Zoom to scatter plot extend"), lambda event : self.plot.ZoomToExtend()]]
++ for item in menu_items:
++ item_id = wx.ID_ANY
++ menu.Append(item_id, text = item[1])
++ menu.Bind(wx.EVT_MENU, item[2], id = item_id)
++ wx.CallAfter(self.ShowMenu, menu)
++ def ShowMenu(self, menu):
++ self.plot.PopupMenu(menu)
++ menu.Destroy()
++ self.plot.ReleaseMouse()
++class PolygonDrawer:
++ An polygon editor.
++ def __init__(self, ax, pol, empty_pol):
++ if pol.figure is None:
++ raise RuntimeError('You must first add the polygon to a figure or canvas before defining the interactor')
++ self.ax = ax
++ self.canvas = pol.figure.canvas
++ self.showverts = True
++ self.pol = pol
++ self.empty_pol = empty_pol
++ x, y = zip(*self.pol.xy)
++ style = self._getPolygonStyle()
++ self.line = Line2D(x, y, marker='o', markerfacecolor='r', animated=True)
++ self.ax.add_line(self.line)
++ #self._update_line(pol)
++ cid = self.pol.add_callback(self.poly_changed)
++ self.moving_ver_idx = None # the active vert
++ self.mode = None
++ if self.empty_pol:
++ self._show(False)
++ #self.canvas.mpl_connect('draw_event', self.draw_callback)
++ self.canvas.mpl_connect('button_press_event', self.OnButtonPressed)
++ self.canvas.mpl_connect('button_release_event', self.button_release_callback)
++ self.canvas.mpl_connect('motion_notify_event', self.motion_notify_callback)
++ self.it = 0
++ def _getPolygonStyle(self):
++ style = {}
++ style['sel_pol'] = UserSettings.Get(group='scatt',
++ key='selection',
++ subkey='sel_pol')
++ style['sel_pol_vertex'] = UserSettings.Get(group='scatt',
++ key='selection',
++ subkey='sel_pol_vertex')
++ style['sel_pol'] = [i / 255.0 for i in style['sel_pol']]
++ style['sel_pol_vertex'] = [i / 255.0 for i in style['sel_pol_vertex']]
++ return style
++ def _getSnapTresh(self):
++ return UserSettings.Get(group='scatt',
++ key='selection',
++ subkey='snap_tresh')
++ self.mode = mode
++ self.Show(activate)
++ if not activate and self.mode:
++ self.SetMode(None)
++ def Show(self, show):
++ if show:
++ if not self.empty_pol:
++ self._show(True)
++ else:
++ return None
++ coords = deepcopy(self.pol.xy)
++ return coords
++ self._setEmptyPol(True)
++ def _setEmptyPol(self, empty_pol):
++ self._show(not empty_pol)
++ def _show(self, show):
++ self.show = show
++ self.line.set_visible(self.show)
++ self.pol.set_visible(self.show)
++ self.Redraw()
++ def Redraw(self):
++ if self.show:
++ self.ax.draw_artist(self.pol)
++ self.ax.draw_artist(self.line)
++ self.canvas.blit(self.ax.bbox)
++ style=self._getPolygonStyle()
++ self.pol.set_facecolor(style['sel_pol'])
++ self.line.set_markerfacecolor(style['sel_pol_vertex'])
++ self.background = self.canvas.copy_from_bbox(self.ax.bbox)
++ def poly_changed(self, pol):
++ 'this method is called whenever the polygon object is called'
++ # only copy the artist props to the line (except visibility)
++ vis = self.line.get_visible()
++ Artist.update_from(self.line, pol)
++ self.line.set_visible(vis) # don't use the pol visibility state
++ def get_ind_under_point(self, event):
++ 'get the index of the vertex under point if within treshold'
++ # display coords
++ xy = np.asarray(self.pol.xy)
++ xyt = self.pol.get_transform().transform(xy)
++ xt, yt = xyt[:, 0], xyt[:, 1]
++ d = np.sqrt((xt-event.x)**2 + (yt-event.y)**2)
++ indseq = np.nonzero(np.equal(d, np.amin(d)))[0]
++ ind = indseq[0]
++ if d[ind]>=self._getSnapTresh():
++ ind = None
++ return ind
++ def OnButtonPressed(self, event):
++ return
++ if event.button in [2, 3]:
++ return
++ if self.mode == "delete_vertex":
++ self._deleteVertex(event)
++ elif self.mode == "add_boundary_vertex":
++ self._addVertexOnBoundary(event)
++ elif self.mode == "add_vertex":
++ self._addVertex(event)
++ elif self.mode == "remove_polygon":
++ self.SetEmpty()
++ self.moving_ver_idx = self.get_ind_under_point(event)
++ def button_release_callback(self, event):
++ 'whenever a mouse button is released'
++ if not self.showverts: return
++ def ShowVertices(self, show):
++ self.showverts = show
++ self.line.set_visible(self.showverts)
++ if not self.showverts: self.moving_ver_idx = None
++ def _deleteVertex(self, event):
++ ind = self.get_ind_under_point(event)
++ if ind is None or self.empty_pol:
++ return
++ if len(self.pol.xy) <= 2:
++ self.empty_pol = True
++ return
++ coords = []
++ for i,tup in enumerate(self.pol.xy):
++ if i == ind:
++ continue
++ elif i == 0 and ind == len(self.pol.xy) - 1:
++ continue
++ elif i == len(self.pol.xy) - 1 and ind == 0:
++ continue
++ coords.append(tup)
++ self.pol.xy = coords
++ self.line.set_data(zip(*self.pol.xy))
++ self.Redraw()
++ def _addVertexOnBoundary(self, event):
++ return
++ xys = self.pol.get_transform().transform(self.pol.xy)
++ p = event.x, event.y # display coords
++ for i in range(len(xys)-1):
++ s0 = xys[i]
++ s1 = xys[i+1]
++ d = dist_point_to_segment(p, s0, s1)
++ if d<=self._getSnapTresh():
++ self.pol.xy = np.array(
++ list(self.pol.xy[:i + 1]) +
++ [(event.xdata, event.ydata)] +
++ list(self.pol.xy[i + 1:]))
++ break
++ self.Redraw()
++ def _addVertex(self, event):
++ pt = (event.xdata, event.ydata)
++ self.pol.xy = np.array([pt, pt])
++ self._show(True)
++ self.empty_pol = False
++ else:
++ list(self.pol.xy[1:]) +
++ [(event.xdata, event.ydata)])
++ self.Redraw()
++ def motion_notify_callback(self, event):
++ if not self.mode == "move_vertex": return
++ if self.empty_pol: return
++ if self.moving_ver_idx is None: return
++ self.it += 1
++ self.pol.xy[self.moving_ver_idx] = x,y
++ if self.moving_ver_idx == 0:
++ self.pol.xy[len(self.pol.xy) - 1] = x,y
++ elif self.moving_ver_idx == len(self.pol.xy) - 1:
++ self.pol.xy[0] = x,y
++ self.canvas.restore_region(self.background)
++ self.Redraw()
++class ModestImage(mi.AxesImage):
++ Computationally modest image class.
++ ModestImage is an extension of the Matplotlib AxesImage class
++ better suited for the interactive display of larger images. Before
++ drawing, ModestImage resamples the data array based on the screen
++ resolution and view window. This has very little affect on the
++ appearance of the image, but can substantially cut down on
++ computation since calculations of unresolved or clipped pixels
++ are skipped.
++ The interface of ModestImage is the same as AxesImage. However, it
++ does not currently support setting the 'extent' property. There
++ may also be weird coordinate warping operations for images that
++ I'm not aware of. Don't expect those to work either.
++ Author: Chris Beaumont <beaumont at hawaii.edu>
++ def __init__(self, minx=0.0, miny=0.0, *args, **kwargs):
++ if 'extent' in kwargs and kwargs['extent'] is not None:
++ raise NotImplementedError("ModestImage does not support extents")
++ self._full_res = None
++ self._sx, self._sy = None, None
++ self._bounds = (None, None, None, None)
++ self.minx = minx
++ self.miny = miny
++ super(ModestImage, self).__init__(*args, **kwargs)
++ def set_data(self, A):
++ Set the image array
++ ACCEPTS: numpy/PIL Image A
++ self._full_res = A
++ self._A = A
++ if self._A.dtype != np.uint8 and not np.can_cast(self._A.dtype,
++ np.float):
++ raise TypeError("Image data can not convert to float")
++ if (self._A.ndim not in (2, 3) or
++ (self._A.ndim == 3 and self._A.shape[-1] not in (3, 4))):
++ raise TypeError("Invalid dimensions for image data")
++ self._imcache =None
++ self._rgbacache = None
++ self._oldxslice = None
++ self._oldyslice = None
++ def get_array(self):
++ """Override to return the full-resolution array"""
++ return self._full_res
++ def _scale_to_res(self):
++ """ Change self._A and _extent to render an image whose
++ resolution is matched to the eventual rendering."""
++ ax = self.axes
++ ext = ax.transAxes.transform([1, 1]) - ax.transAxes.transform([0, 0])
++ xlim, ylim = ax.get_xlim(), ax.get_ylim()
++ dx, dy = xlim[1] - xlim[0], ylim[1] - ylim[0]
++ y0 = max(self.miny, ylim[0] - 5)
++ y1 = min(self._full_res.shape[0] + self.miny, ylim[1] + 5)
++ x0 = max(self.minx, xlim[0] - 5)
++ x1 = min(self._full_res.shape[1] + self.minx, xlim[1] + 5)
++ y0, y1, x0, x1 = map(int, [y0, y1, x0, x1])
++ sy = int(max(1, min((y1 - y0) / 5., np.ceil(dy / ext[1]))))
++ sx = int(max(1, min((x1 - x0) / 5., np.ceil(dx / ext[0]))))
++ # have we already calculated what we need?
++ if sx == self._sx and sy == self._sy and \
++ x0 == self._bounds[0] and x1 == self._bounds[1] and \
++ y0 == self._bounds[2] and y1 == self._bounds[3]:
++ return
++ self._A = self._full_res[y0 - self.miny:y1 - self.miny:sy,
++ x0 - self.minx:x1 - self.minx:sx]
++ self._A = cbook.safe_masked_invalid(self._A)
++ x1 = x0 + self._A.shape[1] * sx
++ y1 = y0 + self._A.shape[0] * sy
++ self.set_extent([x0 - .5, x1 - .5, y0 - .5, y1 - .5])
++ self._sx = sx
++ self._sy = sy
++ self._bounds = (x0, x1, y0, y1)
++ self.changed()
++ def draw(self, renderer, *args, **kwargs):
++ self._scale_to_res()
++ super(ModestImage, self).draw(renderer, *args, **kwargs)
++def imshow(axes, X, cmap=None, norm=None, aspect=None,
++ interpolation=None, alpha=None, vmin=None, vmax=None,
++ origin=None, extent=None, shape=None, filternorm=1,
++ filterrad=4.0, imlim=None, resample=None, url=None, **kwargs):
++ """Similar to matplotlib's imshow command, but produces a ModestImage
++ Unlike matplotlib version, must explicitly specify axes
++ if not axes._hold:
++ axes.cla()
++ if norm is not None:
++ assert(isinstance(norm, mcolors.Normalize))
++ if aspect is None:
++ aspect = rcParams['image.aspect']
++ axes.set_aspect(aspect)
++ if extent:
++ minx=extent[0]
++ miny=extent[2]
++ else:
++ minx=0.0
++ miny=0.0
++ im = ModestImage(minx, miny, axes, cmap, norm, interpolation, origin, extent,
++ filternorm=filternorm,
++ filterrad=filterrad, resample=resample, **kwargs)
++ im.set_data(X)
++ im.set_alpha(alpha)
++ axes._set_artist_props(im)
++ if im.get_clip_path() is None:
++ # image does not already have clipping set, clip to axes patch
++ im.set_clip_path(axes.patch)
++ #if norm is None and shape is None:
++ # im.set_clim(vmin, vmax)
++ if vmin is not None or vmax is not None:
++ im.set_clim(vmin, vmax)
++ else:
++ im.autoscale_None()
++ im.set_url(url)
++ # update ax.dataLim, and, if autoscaling, set viewLim
++ # to tightly fit the image, regardless of dataLim.
++ im.set_extent(im.get_extent())
++ axes.images.append(im)
++ im._remove_method = lambda h: axes.images.remove(h)
++ return im
++def MergeImg(cats_order, scatts, styles, output_queue):
++ start_time = time.clock()
++ cmap_time = 0
++ merge_time = 0
++ mask_time = 0
++ norm_time = 0
++ max_time = 0
++ init = True
++ merge_tmp = grass.tempfile()
++ if not scatts.has_key(cat_id):
++ continue
++ scatt = scatts[cat_id]
++ #print "color map %d" % cat_id
++ #TODO make more general
++ if cat_id != 0 and (styles[cat_id]['opacity'] == 0.0 or \
++ not styles[cat_id]['show']):
++ continue
++ if init:
++ b2_i = scatt['bands_info']['b1']
++ b1_i = scatt['bands_info']['b2']
++ full_extend = (b1_i['min'] - 0.5, b1_i['max'] + 0.5, b2_i['min'] - 0.5, b2_i['max'] + 0.5)
++ if cat_id == 0:
++ cmap = matplotlib.cm.jet
++ cmap.set_bad('w',1.)
++ cmap._init()
++ cmap._lut[len(cmap._lut) - 1, -1] = 0
++ else:
++ cmap._init()
++ cmap._lut[:, 0] = int(colors[0])/255.0
++ cmap._lut[:, 1] = int(colors[1])/255.0
++ cmap._lut[:, 2] = int(colors[2])/255.0
++ #if init:
++ tmp = time.clock()
++ masked_cat = np.ma.masked_less_equal(scatt['np_vals'], 0)
++ mask_time += time.clock() - tmp
++ vmax = np.amax(masked_cat)
++ max_time += time.clock() - tmp
++ masked_cat = np.uint8(masked_cat * (255.0 / float(vmax)))
++ norm_time += time.clock() - tmp
++ #print "ahoj"
++ #print masked_cat
++ #print masked_cat.shape
++ #print masked_cat.mask.dtype
++ #print "colored_cat.shape"
++ #print colored_cat.shape
++ #merged_img = np.memmap(merge_tmp, dtype='uint8',, shape=colored_cat.shape)
++ cmap = np.uint8(cmap._lut * 255)
++ sh =masked_cat.shape
++ colored_cat = np.zeros(dtype='uint8', shape=(sh[0], sh[1], 4))
++ ApplyColormap(masked_cat, masked_cat.mask, cmap, colored_cat)
++ #colored_cat = np.uint8(cmap(masked_cat) * 255)
++ cmap_time += time.clock() - tmp
++ del masked_cat
++ del cmap
++ #colored_cat[...,3] = np.choose(masked_cat.mask, (255, 0))
++ if init:
++ merged_img = np.memmap(merge_tmp, dtype='uint8', mode='w+', shape=colored_cat.shape)
++ merged_img[:] = colored_cat[:]
++ init = False
++ else:
++ MergeArrays(merged_img, colored_cat, styles[cat_id]['opacity'])
++ #c_img_a = np.memmap(grass.tempfile(), dtype="uint16", mode='w+', shape = shape)
++ c_img_a = colored_cat.astype('uint16')[:,:,3] * styles[cat_id]['opacity']
++ #TODO apply strides and there will be no need for loop
++ #b = as_strided(a, strides=(0, a.strides[3], a.strides[3], a.strides[3]), shape=(3, a.shape[0], a.shape[1]))
++ for i in range(3):
++ merged_img[:,:,i] = (merged_img[:,:,i] * (255 - c_img_a) + colored_cat[:,:,i] * c_img_a) / 255;
++ merged_img[:,:,3] = (merged_img[:,:,3] * (255 - c_img_a) + 255 * c_img_a) / 255;
++ del c_img_a
++ merge_time += time.clock() - tmp
++ del colored_cat
++ end_time = time.clock() - start_time
++ #print "all time:%f" % (end_time)
++ #print "cmap_time:%f" % (cmap_time / end_time * 100.0 )
++ #print "merge_time:%f" % (merge_time / end_time * 100.0 )
++ #print "mask_time:%f" % (mask_time / end_time * 100.0 )
++ #print "nax_time:%f" % (max_time / end_time * 100.0 )
++ #print "norm_time:%f" % (norm_time / end_time * 100.0 )
++ #output_queue.put((merged_img, full_extend))
++ return merged_img, full_extend
+\ No newline at end of file
+Index: gui/wxpython/scatt_plot/controllers.py
+--- gui/wxpython/scatt_plot/controllers.py (revision 0)
++++ gui/wxpython/scatt_plot/controllers.py (working copy)
+@@ -0,0 +1,816 @@
++ at package scatt_plot.controllers
++ at brief Controller layer for scatter plot tool.
++Classes:
++import os
++import sys
++#TODO just for testing
++import time
++#TODO
++import wx
++from core.gcmd import GException, GError, GMessage, RunCommand
++from scatt_plot.scatt_core import Core, idBandsToidScatt
++from scatt_plot.dialogs import AddScattPlotDialog, ExportCategoryRaster
++from scatt_plot.gthreading import gThread
++from core.gconsole import EVT_CMD_DONE
++class ScattsManager(wx.EvtHandler):
++ def __init__(self, guiparent, giface, iclass_mapwin):
++ #TODO remove iclass parameter
++ wx.EvtHandler.__init__(self)
++ self.giface = giface
++ self.mapDisp = giface.GetMapDisplay()
++ if iclass_mapwin:
++ self.mapWin = iclass_mapwin
++ else:
++ self.mapWin = giface.GetMapWindow()
++ self.guiparent = guiparent
++ self.show_add_scatt_plot = False
++ self.core = Core()
++ self.scatts_dt, self.scatt_conds_dt = self.core.GetScattsData()
++ self.cats_mgr = CategoriesManager(self, self.core)
++ self.thread = gThread(self);
++ self.plots = {}
++ self.added_cats_rasts = []
++ self.cats_to_update = []
++ self.plot_mode = None
++ self.pol_sel_mode = [False, None]
++ self.data_set = False
++ self.cursorPlotMove = Signal("ScattsManager.cursorPlotMove")
++ self.renderingStarted = Signal("ScattsManager.renderingStarted")
++ self.renderingFinished = Signal("ScattsManager.renderingFinished")
++ self.computingStarted = Signal("ScattsManager.computingStarted")
++ self.mapWin_conn = MapWinConnection(self, self.mapWin, self.core.CatRastUpdater())
++ self.iclass_conn = IClassConnection(self, iclass_mapwin.parent, self.cats_mgr)
++ else:
++ self.mapWin_conn = None
++ self.iclass_conn = None
++ self.tasks_pids = {
++ 'add_scatt' : [],
++ 'set_data' : -1,
++ 'set_data_add' : -1,
++ 'set_edit_cat_data' : -1,
++ 'mapwin_conn' : [],
++ 'render_plots' : -1,
++ 'render' : [],
++ 'export_cat_rast' : []
++ self._initSettings()
++ self.Bind(EVT_CMD_DONE, self.OnThreadDone)
++ self.modeSet = Signal("ScattsManager.mondeSet")
++ self.core.CleanUp()
++ self.cats_mgr.CleanUp()
++ for scatt_id, scatt in self.plots.items():
++ scatt.CleanUp()
++ def _initSettings(self):
++ """!Initialization of settings (if not already defined)"""
++ # initializes default settings
++ initSettings = [
++ ['selection', 'sel_pol', (255,255,0)],
++ ['selection', 'sel_pol_vertex', (255,0,0)],
++ ['selection', 'sel_area', (0,255,19)],
++ ['selection', "snap_tresh", 10],
++ ['selection', 'sel_area_opacty', 50],
++ ['ellipses', 'show_ellips', True],
++ for init in initSettings:
++ UserSettings.ReadSettingsFile()
++ UserSettings.Append(dict = UserSettings.userSettings,
++ group ='scatt',
++ key = init[0],
++ subkey =init[1],
++ value = init[2],
++ overwrite = False)
++ def OnThreadDone(self, event):
++ if event.exception:
++ GError(str(event.exception))
++ return
++ if event.pid in self.tasks_pids['mapwin_conn']:
++ self.tasks_pids['mapwin_conn'].remove(event.pid)
++ updated_cats = event.ret
++ for cat in updated_cats:
++ if cat not in self.cats_to_update:
++ self.cats_to_update.append(cat)
++ if not self.tasks_pids['mapwin_conn']:
++ self.tasks_pids['render_plots'] = self.thread.GetId()
++ self.thread.Run(callable = self.core.ComputeCatsScatts,
++ cats_ids = self.cats_to_update[:])
++ del self.cats_to_update[:]
++ return
++ if self.tasks_pids['render_plots'] == event.pid:
++ self.RenderScattPlts()
++ return
++ if event.pid in self.tasks_pids['render']:
++ self.tasks_pids['render'].remove(event.pid)
++ if not self.tasks_pids['render']:
++ self.renderingFinished.emit()
++ return
++ if event.pid in self.tasks_pids['add_scatt']:
++ self.tasks_pids['add_scatt'].remove(event.pid)
++ self.AddScattPlotDone(event)
++ return
++ if self.tasks_pids['set_data'] == event.pid:
++ self.SetDataDone(event)
++ return
++ if self.tasks_pids['set_data_add'] == event.pid:
++ self.AddScattPlot()
++ return
++ if self.tasks_pids['set_edit_cat_data'] == event.pid:
++ self.SetEditCatDataDone(event)
++ return
++ if event.pid in self.tasks_pids['export_cat_rast']:
++ self.cats_mgr.OnExportCatRastDone(event)
++ return
++ def SetData(self, bands):
++ "setting datas"
++ self.CleanUp()
++ if self.show_add_scatt_plot:
++ self.tasks_pids['set_data_add'] = self.thread.GetId()
++ else:
++ self.tasks_pids['set_data'] = self.thread.GetId()
++ self.thread.Run(callable=self.core.SetData, bands=bands)
++ def SetDataDone(self, event):
++ self.data_set = True
++ self.iclass_conn.SyncCats()
++ def SettingsUpdated(self, event):
++ #TODO optimization
++ def OnOutput(self, event):
++ """!Print thread output according to debug level.
++ print event.text
++ def GetBands(self):
++ return self.core.GetBands()
++ def AddScattPlot(self):
++ if not self.data_set and self.iclass_conn:
++ self.show_add_scatt_plot = True
++ self.iclass_conn.SetData()
++ return
++ if not self.data_set:
++ GError(_('No data set.'))
++ return
++ self.computingStarted.emit()
++ bands = self.core.GetBands()
++ dlg = AddScattPlotDialog(parent = self.guiparent, bands = bands)
++ if dlg.ShowModal() == wx.ID_OK:
++ b_1, b_2 = dlg.GetBands()
++ #TODO axes selection
++ transpose = False
++ if b_1 > b_2:
++ transpose = True
++ tmp_band = b_2
++ b_2 = b_1
++ b_1 = tmp_band
++ self.scatt_id = idBandsToidScatt(b_1, b_2, len(bands))
++ self._addScattPlot(self.scatt_id, transpose)
++ dlg.Destroy()
++ self.mapWin_conn.Update()
++ def _addScattPlot(self, scatt_id, transpose):
++ if self.plots.has_key(scatt_id):
++ GMessage(_("Scatter plot has been already added."))
++ return
++ self.tasks_pids['add_scatt'].append(self.thread.GetId())
++ self.thread.Run(callable = self.core.AddScattPlot, scatt_id = scatt_id, userdata = {'transpose' : transpose})
++ def RenderScattPlts(self, scatt_ids = None):
++ if len(self.tasks_pids['render']) > 1:
++ return
++ self.renderingStarted.emit()
++ self.tasks_pids['render'].append(self.thread.GetId())
++ self.thread.Run(callable = self._renderscattplts, scatt_ids = scatt_ids)
++ def _renderscattplts(self, scatt_ids):
++ cats_attrs = self.cats_mgr.GetCategoriesAttrs()
++ cats = self.cats_mgr.GetCategories()[:]
++ cats.reverse()
++ cats.insert(0, 0)
++ for i_scatt_id, scatt in self.plots.items():
++ if scatt_ids is not None and i_scatt_id not in scatt_ids:
++ continue
++ scatt_dt = self.scatts_dt.GetScatt(i_scatt_id)
++ if self._showConfEllipses():
++ ellipses_dt = self.scatts_dt.GetEllipses(i_scatt_id, cats_attrs)
++ else:
++ ellipses_dt = {}
++ if self.pol_sel_mode[0]:
++ self._getSelectedAreas(cats, i_scatt_id, scatt_dt, cats_attrs)
++ scatt.Plot(cats_order = cats, scatts = scatt_dt, ellipses = ellipses_dt, styles = cats_attrs)
++ def _showConfEllipses(self):
++ key="ellipses",
++ subkey="show_ellips")
++ def _getSelectedAreas(self, cats_order, scatt_id, scatt_dt, cats_attrs):
++ cat_id = self.cats_mgr.GetSelectedCat()
++ if not cat_id:
++ return
++ sel_a_cat_id = max(cats_attrs.keys()) + 1
++ s = self.scatt_conds_dt.GetScatt(scatt_id, [cat_id])
++ if not s:
++ return
++ cats_order.append(sel_a_cat_id)
++ col = UserSettings.Get(group='scatt',
++ key='selection',
++ subkey='sel_area')
++ col = ":".join(map(str, col))
++ opac = UserSettings.Get(group='scatt',
++ key='selection',
++ subkey='sel_area_opacty') / 100.0
++ cats_attrs[sel_a_cat_id] = {'color' : col,
++ 'opacity' : opac,
++ 'show' : True}
++ scatt_dt[sel_a_cat_id] = s[cat_id]
++ def AddScattPlotDone(self, event):
++ transpose = event.userdata['transpose']
++ scatt_id = event.kwds['scatt_id']
++ #TODO guiparent - not very good
++ self.plots[scatt_id] = self.guiparent.NewScatterPlot(scatt_id = scatt_id, transpose = transpose)
++ self.plots[scatt_id].plotClosed.connect(self.PlotClosed)
++ self.plots[scatt_id].cursorMove.connect(lambda x, y: self.cursorPlotMove.emit(x = x, y = y))
++ if self.plot_mode:
++ self.plots[scatt_id].SetMode(self.plot_mode)
++ self.plots[scatt_id].ZoomToExtend()
++ self.RenderScattPlts(scatt_ids = [scatt_id])
++ def PlotClosed(self, scatt_id):
++ del self.plots[scatt_id]
++ def SetPlotsMode(self, mode):
++ self.plot_mode = mode
++ for scatt in self.plots.itervalues():
++ scatt.SetMode(mode)
++ self.modeSet.emit(mode = mode)
++ def ActivateSelectionPolygonMode(self, activate):
++ self.pol_sel_mode[0] = activate
++ scatt.SetSelectionPolygonMode(activate)
++ if not activate and self.plot_mode not in ['zoom', 'pan', 'zoom_extend']:
++ self.SetPlotsMode(None)
++ return activate
++ def ProcessSelectionPolygons(self, process_mode):
++ scatts_polygons = {}
++ for scatt_id, scatt in self.plots.iteritems():
++ coords = scatt.GetCoords()
++ if coords is not None:
++ scatts_polygons[scatt_id] = coords
++ if not scatts_polygons:
++ return
++ value = 1
++ if process_mode == 'remove':
++ value = 0
++ sel_cat_id = self.cats_mgr.GetSelectedCat()
++ if not sel_cat_id:
++ dlg = wx.MessageDialog(parent = self.guiparent,
++ message = _("In order to select arrea in scatter plot, "
++ "you have to select class first.\n\n"
++ "There is no class yet, "
++ "do you want to create one?"),
++ caption = _("No class selected"),
++ style = wx.YES_NO)
++ if dlg.ShowModal() == wx.ID_YES:
++ self.iclass_conn.EmptyCategories()
++ return
++ scatt.SetEmpty()
++ self.tasks_pids['set_edit_cat_data'] = self.thread.GetId()
++ self.thread.Run(callable = self.core.UpdateCategoryWithPolygons,
++ cat_id = sel_cat_id,
++ scatts_pols = scatts_polygons,
++ value = value)
++ def SetEditCatDataDone(self, event):
++ GError(_("Error occured during computation of scatter plot category:\n%s"),
++ parent = self.guiparent, showTraceback = False)
++ cat_id = event.ret
++ cat_id = event.kwds["cat_id"]
++ train_mgr, preview_mgr = self.iclass_conn.iclass_frame.GetMapManagers()
++ if not cat_id in self.added_cats_rasts:
++ cat_rast = self.core.GetCatRast(cat_id)
++ cat_name = self.cats_mgr.GetCategoryAttrs(cat_id)['name']
++ self.UpdateCategoryRaster(cat_id, ['color'], render = False)
++ train_mgr.AddLayer(cat_rast, alias = cat_name)
++ self.added_cats_rasts.append(cat_id)
++ else: #TODO settings
++ train_mgr.Render()
++ def UpdateCategoryRaster(self, cat_id, attrs, render = True):
++ if not grass.find_file(cat_rast, element = 'cell', mapset = '.')['file']:
++ return
++ cats_attrs = self.cats_mgr.GetCategoryAttrs(cat_id)
++ if "color" in attrs:
++ ret, err_msg = RunCommand('r.colors',
++ map=cat_rast,
++ rules="-",
++ stdin="1 %s" % cats_attrs["color"],
++ getErrorMsg=True)
++ if ret != 0:
++ GError("r.colors failed\n%s" % err_msg)
++ if render:
++ if "name" in attrs:
++ train_mgr.SetAlias(original=cat_rast, alias=cats_attrs['name'])
++ cats_attrs["name"]
++ def DigitDataChanged(self, vectMap, digit):
++ if self.mapWin_conn:
++ self.mapWin_conn.DigitDataChanged(vectMap, digit)
++ return 1
++ else:
++ return 0
++ def GetCategoriesManager(self):
++ return self.cats_mgr
++class CategoriesManager:
++ def __init__(self, scatt_mgr, core):
++ self.core = core
++ self.cats = {}
++ self.cats_ids = []
++ self.sel_cat_id = None
++ self.exportRaster = None
++ self.initialized = Signal('CategoriesManager.initialized')
++ self.setCategoryAttrs = Signal('CategoriesManager.setCategoryAttrs')
++ self.deletedCategory = Signal('CategoriesManager.deletedCategory')
++ self.addedCategory = Signal('CategoriesManager.addedCategory')
++ self.cats.clear()
++ del self.cats_ids[:]
++ def InitCoreCats(self):
++ if self.scatt_mgr.data_set:
++ for cat_id in self.cats_ids:
++ self._addCategory(cat_id)
++ self.scatt_mgr.mapWin_conn.Update()
++ def ChangePosition(self, cat_id, new_pos):
++ if new_pos >= len(self.cats_ids):
++ return False
+ try:
-+ from scatt_plot.frame import IClassScatterPlotsPanel
-+ self.scatt_plot_panel = IClassScatterPlotsPanel(parent=self,
-+ giface=self._giface,
-+ iclass_mapwin = self.parent.GetFirstWindow())
-+ self.mainSizer.Add(self.scatt_plot_panel, proportion = 1, flag = wx.EXPAND, border = 0)
-+ self.scatt_plot_panel.Hide()
-+ except ImportError as e:#TODO
-+ self.scatt_error = _("Scatter plot functionality is disabled. Reason:\n" \
-+ "Unable to import packages needed for scatter plot.\n%s" % e)
-+ GError(self.scatt_error)
-+ self.scatt_plot_panel = None
++ pos = self.cats_ids.index(cat_id)
++ except:
++ return False
- def OnPlotTypeSelected(self, event):
- """!Plot type selected"""
++ if pos > new_pos:
++ pos -= 1
-+ if self.plotSwitch.GetSelection() in [0, 1]:
-+ self.SetupScrolling(scroll_x = False, scroll_y = True)
-+ if self.scatt_plot_panel:
-+ self.canvasPanel.Show()
-+ self.Layout()
++ self.cats_ids.remove(cat_id)
-+ elif self.plotSwitch.GetSelection() == 2:
-+ self.SetupScrolling(scroll_x = False, scroll_y = False)
-+ self.scatt_plot_panel.Show()
++ self.cats_ids.insert(new_pos, cat_id)
++ self.scatt_mgr.RenderScattPlts()
++ return True
++ def _addCategory(self, cat_id):
++ self.scatt_mgr.thread.Run(callable = self.core.AddCategory,
++ cat_id = cat_id)
++ def AddCategory(self, cat_id = None, name = None, color = None, nstd = None):
++ if cat_id is None:
++ if self.cats_ids:
++ cat_id = max(self.cats_ids) + 1
+ else:
-+ self.canvasPanel.Hide()
-+ self.Layout()
++ cat_id = 1
- if self.currentCat is None:
- return
++ cat_id = cat_id)
++ #TODO check number of cats
++ #if ret < 0: #TODO
++ # return -1;
- if self.plotSwitch.GetSelection() == 0:
- stat = self.stats_data.GetStatistics(self.currentCat)
- if not stat.IsReady():
-@@ -66,7 +112,10 @@
- self.DrawHistograms(stat)
- else:
- self.DrawCoincidencePlots()
++ self.cats[cat_id] = {
++ 'name' : _('Category %s' % cat_id ),
++ 'color' : "0:0:0",
++ 'opacity' : 1.0,
++ 'show' : True,
++ 'nstd' : 1.0,
-+ self.Layout()
++ self.cats_ids.insert(0, cat_id)
++ if name is not None:
++ self.cats[cat_id]["name"] = name
++ if color is not None:
++ self.cats[cat_id]["color"] = color
- def StddevChanged(self):
- """!Standard deviation multiplier changed, redraw histograms"""
-@@ -89,7 +138,7 @@
- panel.Destroy()
- self.canvasList = []
++ if nstd is not None:
++ self.cats[cat_id]["nstd"] = nstd
- def ClearPlots(self):
- """!Clears plot canvases"""
- for bandIdx in range(len(self.bandList)):
-@@ -104,15 +153,15 @@
- def CreatePlotCanvases(self):
- """!Create plot canvases according to the number of bands"""
- for band in self.bandList:
-- canvas = plot.PlotCanvas(self)
-+ canvas = plot.PlotCanvas(self.canvasPanel)
- canvas.SetMinSize((-1, 140))
- canvas.SetFontSizeTitle(10)
- canvas.SetFontSizeAxis(8)
- self.canvasList.append(canvas)
-- self.mainSizer.Add(item = canvas, proportion = 1, flag = wx.EXPAND, border = 0)
-- self.SetVirtualSize(self.GetBestVirtualSize())
-+ self.canvasSizer.Add(item = canvas, proportion = 1, flag = wx.EXPAND, border = 0)
++ self.addedCategory.emit(cat_id = cat_id,
++ name = self.cats[cat_id]["name"],
++ color = self.cats[cat_id]["color"] )
++ return cat_id
++ def SetCategoryAttrs(self, cat_id, attrs_dict):
++ render = False
++ update_cat_rast = []
++ for k, v in attrs_dict.iteritems():
++ if not render and k in ['color', 'opacity', 'show', 'nstd']:
++ render = True
++ if k in ['color', 'name']:
++ update_cat_rast.append(k)
++ self.cats[cat_id][k] = v
++ if render:
-+ self.SetVirtualSize(self.GetBestVirtualSize())
- self.Layout()
- def UpdatePlots(self, group, currentCat, stats_data):
-@@ -138,7 +187,7 @@
- def UpdateCategory(self, cat):
- self.currentCat = cat
- def DrawCoincidencePlots(self):
- """!Draw coincidence plots"""
++ if update_cat_rast:
++ self.scatt_mgr.UpdateCategoryRaster(cat_id, update_cat_rast)
++ self.setCategoryAttrs.emit(cat_id = cat_id, attrs_dict = attrs_dict)
++ def DeleteCategory(self, cat_id):
++ self.scatt_mgr.thread.Run(callable = self.core.DeleteCategory,
++ cat_id = cat_id)
++ del self.cats[cat_id]
++ self.deletedCategory.emit(cat_id = cat_id)
++ #TODO emit event?
++ def SetSelectedCat(self, cat_id):
++ self.sel_cat_id = cat_id
++ if self.scatt_mgr.pol_sel_mode[0]:
++ def GetSelectedCat(self):
++ return self.sel_cat_id
++ def GetCategoryAttrs(self, cat_id):
++ #TODO is mutable
++ return self.cats[cat_id]
++ def GetCategoriesAttrs(self):
++ #TODO is mutable
++ return self.cats
++ def GetCategories(self):
++ return self.cats_ids[:]
++ def SetCategoryPosition(self):
++ if newindex > oldindex:
++ newindex -= 1
++ self.cats_ids.insert(newindex, self.cats_ids.pop(oldindex))
++ def ExportCatRast(self, cat_id):
++ cat_attrs = self.GetCategoryAttrs(cat_id)
++ dlg = ExportCategoryRaster(parent=self.scatt_mgr.guiparent,
++ rasterName=self.exportRaster,
++ title=_("Export scatter plot raster of class <%s>") % cat_attrs['name'])
++ self.exportCatRast = dlg.GetRasterName()
++ dlg.Destroy()
++ self.scatt_mgr.tasks_pids['export_cat_rast'].append(self.scatt_mgr.thread.GetId())
++ self.scatt_mgr.thread.Run(callable=self.core.ExportCatRast,
++ userdata={'name' : cat_attrs['name']},
++ cat_id=cat_id,
++ rast_name=self.exportCatRast)
++ def OnExportCatRastDone(self, event):
++ ret, err = event.ret
++ if ret == 0:
++ cat_attrs = self.GetCategoryAttrs(event.kwds['cat_id'])
++ GMessage(_("Scatter plot raster of class <%s> exported to raster map <%s>.") %
++ (event.userdata['name'], event.kwds['rast_name']))
++ else:
++ GMessage(_("Export of scatter plot raster of class <%s> to map <%s> failed.\n%s") %
++ (event.userdata['name'], event.kwds['rast_name'], err))
++class MapWinConnection:
++ def __init__(self, scatt_mgr, mapWin, scatt_rast_updater):
++ self.mapWin = mapWin
++ self.vectMap = None
++ self.scatt_rast_updater = scatt_rast_updater
++ self.cats_mgr = scatt_mgr.cats_mgr
++ self.thread = self.scatt_mgr.thread
++ #TODO
++ self.mapWin.parent.toolbars["vdigit"].editingStarted.connect(self.DigitDataChanged)
++ #def ChangeMap(self, vectMap, layers_cats):
++ # self.vectMap = vectMap
++ # self.layers_cats = layers_cats
++ #ret, region, msg = RunCommand("v.to.rast",
++ # flags = "gp",
++ # getErrorMsg = True,
++ # read = True)
++ def Update(self):
++ self.thread.Run(callable=self.scatt_rast_updater.SynchWithMap)
++ def _connectSignals(self):
++ self.digit.featureAdded.connect(self.AddFeature)
++ self.digit.areasDeleted.connect(self.DeleteAreas)
++ self.digit.featuresDeleted.connect(self.DeleteAreas)
++ self.digit.vertexMoved.connect(self.EditedFeature)
++ self.digit.vertexRemoved.connect(self.EditedFeature)
++ self.digit.lineEdited.connect(self.EditedFeature)
++ self.digit.featuresMoved.connect(self.EditedFeature)
++ def AddFeature(self, new_bboxs, new_areas_cats):
++ if not self.scatt_mgr.data_set:
++ return
++ self.scatt_mgr.computingStarted.emit()
++ self.scatt_mgr.tasks_pids['mapwin_conn'].append(self.thread.GetId())
++ self.thread.Run(callable = self.scatt_rast_updater.EditedFeature,
++ new_bboxs = new_bboxs,
++ old_bboxs = [],
++ old_areas_cats = [],
++ new_areas_cats = new_areas_cats)
++ def DeleteAreas(self, old_bboxs, old_areas_cats):
++ return
++ new_bboxs = [],
++ old_bboxs = old_bboxs,
++ old_areas_cats = old_areas_cats,
++ new_areas_cats = [])
++ def EditedFeature(self, new_bboxs, new_areas_cats, old_bboxs, old_areas_cats):
++ return
++ self.digit = digit
++ self.vectMap = vectMap
++ self.digit.EmitSignals(emit = True)
++ self.scatt_rast_updater.SetVectMap(vectMap)
++ self._connectSignals()
++class IClassConnection:
++ def __init__(self, scatt_mgr, iclass_frame, cats_mgr):
++ self.iclass_frame = iclass_frame
++ self.stats_data = self.iclass_frame.stats_data
++ self.cats_mgr = cats_mgr
++ self.scatt_mgr= scatt_mgr
++ self.stats_data.statisticsAdded.connect(self.AddCategory)
++ self.stats_data.statisticsDeleted.connect(self.DeleteCategory)
++ self.stats_data.allStatisticsDeleted.connect(self.DeletAllCategories)
++ self.stats_data.statisticsSet.connect(self.SetCategory)
++ self.iclass_frame.groupSet.connect(self.GroupSet)
++ self.cats_mgr.setCategoryAttrs.connect(self.SetStatistics)
++ self.cats_mgr.deletedCategory.connect(self.DeleteStatistics)
++ self.cats_mgr.addedCategory.connect(self.AddStatistics)
++ self.iclass_frame.categoryChanged.connect(self.CategoryChanged)
++ self.SyncCats()
++ def SetData(self):
++ self.iclass_frame.AddBands()
++ def EmptyCategories(self):
++ self.iclass_frame.OnCategoryManager(None)
++ def SyncCats(self, cats_ids = None):
++ self.cats_mgr.addedCategory.disconnect(self.AddStatistics)
++ cats = self.stats_data.GetCategories()
++ for c in cats:
++ if cats_ids and c not in cats_ids:
++ continue
++ stats = self.stats_data.GetStatistics(c)
++ self.cats_mgr.AddCategory(c, stats.name, stats.color, stats.nstd)
++ def CategoryChanged(self, cat):
++ self.cats_mgr.SetSelectedCat(cat)
++ def AddCategory(self, cat, name, color):
++ stats = self.stats_data.GetStatistics(cat)
++ self.cats_mgr.AddCategory(cat_id = cat, name = name, color = color, nstd = stats.nstd)
++ def DeleteCategory(self, cat):
++ self.cats_mgr.deletedCategory.disconnect(self.DeleteStatistics)
++ self.cats_mgr.DeleteCategory(cat)
++ def DeletAllCategories(self):
++ for c in cats:
++ self.cats_mgr.DeleteCategory(c)
++ def SetCategory(self, cat, stats):
++ self.cats_mgr.setCategoryAttrs.disconnect(self.SetStatistics)
++ cats_attr = {}
++ for attr in ['name', 'color', 'nstd']:
++ if stats.has_key(attr):
++ cats_attr[attr] = stats[attr]
++ if cats_attr:
++ self.cats_mgr.SetCategoryAttrs(cat, cats_attr)
++ def SetStatistics(self, cat_id, attrs_dict):
++ self.stats_data.statisticsSet.disconnect(self.SetCategory)
++ self.stats_data.GetStatistics(cat_id).SetStatistics(attrs_dict)
++ def AddStatistics(self, cat_id, name, color):
++ self.stats_data.statisticsAdded.disconnect(self.AddCategory)
++ self.stats_data.AddStatistics(cat_id, name, color)
++ def DeleteStatistics(self, cat_id):
++ self.stats_data.statisticsDeleted.disconnect(self.DeleteCategory)
++ self.stats_data.DeleteStatistics(cat_id)
++ def GroupSet(self, group):
++ res = RunCommand('i.group',
++ flags = 'g',
++ group = group, subgroup = group,
++ read = True).strip()
++ if res.split('\n')[0]:
++ bands = res.split('\n')
++ self.scatt_mgr.SetData(bands)
Index: gui/wxpython/scatt_plot/gthreading.py
--- gui/wxpython/scatt_plot/gthreading.py (revision 0)
@@ -1227,7 +4249,7 @@
+ def _toolbarData(self):
+ icons = {
-+ 'settings' : BaseIcons['settings'].SetLabel( _('Ssettings')),
++ 'settings' : BaseIcons['settings'].SetLabel( _('Settings')),
+ 'help' : MetaIcon(img = 'help',
+ label = _('Show manual')),
+ 'add_scatt_pl' : MetaIcon(img = 'layer-raster-analyze',
@@ -1415,7 +4437,7 @@
--- gui/wxpython/scatt_plot/scatt_core.py (revision 0)
+++ gui/wxpython/scatt_plot/scatt_core.py (working copy)
-@@ -0,0 +1,808 @@
+@@ -0,0 +1,813 @@
+ at package scatt_plot.scatt_plot
@@ -1567,7 +4589,8 @@
+ b1_info = self.an_data.GetBandInfo(b1)
+ b2_info = self.an_data.GetBandInfo(b2)
-+ raster_pol = RasterizePolygon(coords, b1_info['range'], b2_info['range'])
++ raster_pol = RasterizePolygon(coords, b1_info['range'], b1_info['min'],
++ b2_info['range'], b2_info['min'])
+ raster_ind = np.where(raster_pol > 0)
+ arr = self.scatt_conds_dt.GetValuesArr(cat_id, scatt_id)
@@ -2159,25 +5182,29 @@
+ return cats_rasts
++def RasterizePolygon(pol, height, min_h, width, min_w):
-+def RasterizePolygon(pol, height, width):
+ # Joe Kington
+ # http://stackoverflow.com/questions/3654289/scipy-create-2d-polygon-mask
+ #poly_verts = [(1,1), (1,4), (4,4),(4,1), (1,1)]
-+ nx = width + 1
-+ ny = height + 1
++ nx = width
++ ny = height
-+ x, y = np.meshgrid(np.arange(nx), np.arange(ny))
++ for p in pol:
++ p[0] = p[0] - min_w
++ p[1] = p[1] - min_h
++ x, y = np.meshgrid(np.arange(-0.5, nx+0.5, dtype=float), np.arange(-0.5, ny+0.5, dtype=float))
+ x, y = x.flatten(), y.flatten()
+ points = np.vstack((x,y)).T
+ p = Path(pol)
+ grid = p.contains_points(points)
-+ grid = grid.reshape((ny,nx))
++ grid = grid.reshape((ny + 1,nx + 1))
+ raster = np.zeros((height, width), dtype=np.uint8)#TODO bool
@@ -3077,1770 +6104,6 @@
+ 'scatt_core',
+ 'core_c',
-Index: gui/wxpython/scatt_plot/plots.py
---- gui/wxpython/scatt_plot/plots.py (revision 0)
-+++ gui/wxpython/scatt_plot/plots.py (working copy)
-@@ -0,0 +1,936 @@
-+ at package scatt_plot.dialogs
-+ at brief Ploting widgets.
-+Classes:
-+(C) 2013 by the GRASS Development Team
-+This program is free software under the GNU General Public License
-+(>=v2). Read the file COPYING that comes with GRASS for details.
-+ at author Stepan Turek <stepan.turek seznam.cz> (mentor: Martin Landa)
-+import wx
-+import numpy as np
-+#TODO testing
-+import time
-+from multiprocessing import Process, Queue
-+#TODO
-+#from numpy.lib.stride_tricks import as_strided
-+from copy import deepcopy
-+from scatt_plot.core_c import MergeArrays, ApplyColormap
-+from core.settings import UserSettings
-+try:
-+ import matplotlib
-+ matplotlib.use('WXAgg')
-+ from matplotlib.figure import Figure
-+ from matplotlib.backends.backend_wxagg import \
-+ FigureCanvasWxAgg as FigCanvas
-+ from matplotlib.lines import Line2D
-+ from matplotlib.artist import Artist
-+ from matplotlib.mlab import dist_point_to_segment
-+ from matplotlib.patches import Polygon, Ellipse, Rectangle
-+ import matplotlib.image as mi
-+ import matplotlib.colors as mcolors
-+ import matplotlib.cbook as cbook
-+except ImportError as e:
-+ raise ImportError(_("Unable to import matplotlib (try to install it).\n%s") % e)
-+import grass.script as grass
-+from grass.pydispatch.signal import Signal
-+class ScatterPlotWidget(wx.Panel):
-+ def __init__(self, parent, scatt_id, scatt_mgr, transpose,
-+ id = wx.ID_ANY):
-+ wx.Panel.__init__(self, parent, id)
-+ self.parent = parent
-+ self.full_extend = None
-+ self.mode = None
-+ self._createWidgets()
-+ self._doLayout()
-+ self.scatt_id = scatt_id
-+ self.scatt_mgr = scatt_mgr
-+ self.cidpress = None
-+ self.cidrelease = None
-+ self.transpose = transpose
-+ self.inverse = False
-+ self.SetSize((200, 100))
-+ self.Layout()
-+ self.base_scale = 1.2
-+ self.Bind(wx.EVT_CLOSE,lambda event : self.CleanUp())
-+ self.plotClosed = Signal("ScatterPlotWidget.plotClosed")
-+ self.cursorMove = Signal("ScatterPlotWidget.cursorMove")
-+ self.contex_menu = ScatterPlotContextMenu(plot = self)
-+ self.ciddscroll = None
-+ self.canvas.mpl_connect('motion_notify_event', self.Motion)
-+ self.canvas.mpl_connect('button_press_event', self.OnPress)
-+ self.canvas.mpl_connect('button_release_event', self.OnRelease)
-+ self.canvas.mpl_connect('draw_event', self.draw_callback)
-+ def draw_callback(self, event):
-+ self.polygon_drawer.draw_callback(event)
-+ self.axes.draw_artist(self.zoom_rect)
-+ def _createWidgets(self):
-+ # Create the mpl Figure and FigCanvas objects.
-+ # 5x4 inches, 100 dots-per-inch
-+ self.dpi = 100
-+ self.fig = Figure((1.0, 1.0), dpi=self.dpi)
-+ self.fig.autolayout = True
-+ self.canvas = FigCanvas(self, -1, self.fig)
-+ self.axes = self.fig.add_axes([0,0,1,1])
-+ pol = Polygon(list(zip([0], [0])), animated=True)
-+ self.axes.add_patch(pol)
-+ self.polygon_drawer = PolygonDrawer(self.axes, pol = pol, empty_pol = True)
-+ self.zoom_wheel_coords = None
-+ self.zoom_rect_coords = None
-+ self.zoom_rect = Polygon(list(zip([0], [0])), facecolor = 'none')
-+ self.zoom_rect.set_visible(False)
-+ self.axes.add_patch(self.zoom_rect)
-+ def ZoomToExtend(self):
-+ if self.full_extend:
-+ self.axes.axis(self.full_extend)
-+ self.canvas.draw()
-+ def SetMode(self, mode):
-+ self._deactivateMode()
-+ if mode == 'zoom':
-+ self.ciddscroll = self.canvas.mpl_connect('scroll_event', self.ZoomWheel)
-+ self.mode = 'zoom'
-+ elif mode == 'zoom_extend':
-+ self.mode = 'zoom_extend'
-+ elif mode == 'pan':
-+ self.mode = 'pan'
-+ elif mode:
-+ self.polygon_drawer.SetMode(mode)
-+ def SetSelectionPolygonMode(self, activate):
-+ self.polygon_drawer.SetSelectionPolygonMode(activate)
-+ def _deactivateMode(self):
-+ self.mode = None
-+ self.polygon_drawer.SetMode(None)
-+ if self.ciddscroll:
-+ self.canvas.mpl_disconnect(self.ciddscroll)
-+ self._stopCategoryEdit()
-+ def GetCoords(self):
-+ coords = self.polygon_drawer.GetCoords()
-+ if coords is None:
-+ return
-+ if self.transpose:
-+ for c in coords:
-+ tmp = c[0]
-+ c[0] = c[1]
-+ c[1] = tmp
-+ return coords
-+ def SetEmpty(self):
-+ return self.polygon_drawer.SetEmpty()
-+ def OnRelease(self, event):
-+ if not self.mode == "zoom": return
-+ self.ZoomRectangle(event)
-+ def OnPress(self, event):
-+ 'on button press we will see if the mouse is over us and store some data'
-+ if not event.inaxes:
-+ return
-+ if self.mode == "zoom_extend":
-+ self.ZoomToExtend()
-+ if event.xdata and event.ydata:
-+ self.zoom_wheel_coords = { 'x' : event.xdata, 'y' : event.ydata}
-+ self.zoom_rect_coords = { 'x' : event.xdata, 'y' : event.ydata}
-+ else:
-+ def _stopCategoryEdit(self):
-+ 'disconnect all the stored connection ids'
-+ if self.cidpress:
-+ self.canvas.mpl_disconnect(self.cidpress)
-+ if self.cidrelease:
-+ self.canvas.mpl_disconnect(self.cidrelease)
-+ #self.canvas.mpl_disconnect(self.cidmotion)
-+ def _doLayout(self):
-+ self.main_sizer = wx.BoxSizer(wx.VERTICAL)
-+ self.main_sizer.Add(self.canvas, 1, wx.LEFT | wx.TOP | wx.GROW)
-+ self.SetSizer(self.main_sizer)
-+ self.main_sizer.Fit(self)
-+ def Plot(self, cats_order, scatts, ellipses, styles):
-+ """ Redraws the figure
-+ callafter_list = []
-+ cx = self.axes.get_xlim()
-+ cy = self.axes.get_ylim()
-+ c = cx + cy
-+ else:
-+ c = None
-+ #q = Queue()
-+ #p = Process(target=MergeImg, args=(cats_order, scatts, styles, self.transpose, q))
-+ #p.start()
-+ #merged_img, self.full_extend = q.get()
-+ #p.join()
-+ merged_img, self.full_extend = MergeImg(cats_order, scatts, styles, None)
-+ self.axes.clear()
-+ self.axes.axis('equal')
-+ merged_img = np.transpose(merged_img, (1, 0, 2))
-+ img = imshow(self.axes, merged_img,
-+ origin = 'lower',
-+ interpolation='nearest',
-+ aspect = "equal")
-+ callafter_list.append([self.axes.draw_artist, [img]])
-+ callafter_list.append([grass.try_remove, [merged_img.filename]])
-+ for cat_id in cats_order:
-+ if cat_id == 0:
-+ continue
-+ if not ellipses.has_key(cat_id):
-+ continue
-+ e = ellipses[cat_id]
-+ if not e:
-+ continue
-+ colors = styles[cat_id]['color'].split(":")
-+ e['theta'] = 360 - e['theta'] + 90
-+ if e['theta'] >= 360:
-+ e['theta'] = abs(360 - e['theta'])
-+ e['pos'] = [e['pos'][1], e['pos'][0]]
-+ ellip = Ellipse(xy=e['pos'],
-+ width=e['width'],
-+ height=e['height'],
-+ angle=e['theta'],
-+ edgecolor="w",
-+ linewidth=1.5,
-+ facecolor = 'None')
-+ self.axes.add_artist(ellip)
-+ callafter_list.append([self.axes.draw_artist, [ellip]])
-+ color = map(lambda v : int(v)/255.0, styles[cat_id]['color'].split(":"))
-+ edgecolor=color,
-+ linewidth=1,
-+ center = Line2D([e['pos'][0]], [e['pos'][1]],
-+ marker='x',
-+ markeredgecolor='w',
-+ #markerfacecolor=color,
-+ markersize=2)
-+ self.axes.add_artist(center)
-+ callafter_list.append([self.axes.draw_artist, [center]])
-+ callafter_list.append([self.fig.canvas.blit, []])
-+ if c:
-+ self.axes.axis(c)
-+ wx.CallAfter(lambda : self.CallAfter(callafter_list))
-+ def CallAfter(self, funcs_list):
-+ while funcs_list:
-+ fcn, args = funcs_list.pop(0)
-+ fcn(*args)
-+ def CleanUp(self):
-+ self.plotClosed.emit(scatt_id = self.scatt_id)
-+ self.Destroy()
-+ def ZoomWheel(self, event):
-+ # get the current x and y limits
-+ return
-+ # tcaswell
-+ # http://stackoverflow.com/questions/11551049/matplotlib-plot-zooming-with-scroll-wheel
-+ cur_xlim = self.axes.get_xlim()
-+ cur_ylim = self.axes.get_ylim()
-+ xdata = event.xdata
-+ ydata = event.ydata
-+ if event.button == 'up':
-+ scale_factor = 1/self.base_scale
-+ elif event.button == 'down':
-+ scale_factor = self.base_scale
-+ else:
-+ scale_factor = 1
-+ extend = (xdata - (xdata - cur_xlim[0]) * scale_factor,
-+ xdata + (cur_xlim[1] - xdata) * scale_factor,
-+ ydata - (ydata - cur_ylim[0]) * scale_factor,
-+ ydata + (cur_ylim[1] - ydata) * scale_factor)
-+ self.axes.axis(extend)
-+ def ZoomRectangle(self, event):
-+ if event.inaxes is None: return
-+ if event.button != 1: return
-+ x1, y1 = event.xdata, event.ydata
-+ x2 = deepcopy(self.zoom_rect_coords['x'])
-+ y2 = deepcopy(self.zoom_rect_coords['y'])
-+ if x1 == x2 or y1 == y2:
-+ return
-+ self.axes.set_xlim(x1, x2)#, auto = True)
-+ self.axes.set_ylim(y1, y2)#, auto = True)
-+ def Motion(self, event):
-+ self.PanMotion(event)
-+ self.ZoomRectMotion(event)
-+ return
-+ self.cursorMove.emit(x=event.xdata, y=event.ydata)
-+ def PanMotion(self, event):
-+ 'on mouse movement'
-+ if not self.mode == "pan":
-+ return
-+ return
-+ return
-+ x,y = event.xdata, event.ydata
-+ mx = (x - self.zoom_wheel_coords['x']) * 0.5
-+ my = (y - self.zoom_wheel_coords['y']) * 0.5
-+ extend = (cur_xlim[0] + mx, cur_xlim[1] + mx, cur_ylim[0] + my, cur_ylim[1] + my)
-+ self.zoom_wheel_coords['x'] = x
-+ self.zoom_wheel_coords['y'] = y
-+ #self.canvas.copy_from_bbox(self.axes.bbox)
-+ #self.canvas.restore_region(self.background)
-+ def ZoomRectMotion(self, event):
-+ self.zoom_rect.set_visible(True)
-+ x2 = self.zoom_rect_coords['x']
-+ y2 = self.zoom_rect_coords['y']
-+ self.zoom_rect.xy = ((x1, y1), (x1, y2), (x2, y2), (x2, y1), (x1, y1))
-+ #self.axes.draw_artist(self.zoom_rect)
-+class ScatterPlotContextMenu:
-+ def __init__(self, plot):
-+ self.plot = plot
-+ self.canvas = plot.canvas
-+ self.cidpress = self.canvas.mpl_connect(
-+ 'button_press_event', self.ContexMenu)
-+ def ContexMenu(self, event):
-+ return
-+ if event.button == 3:
-+ menu = wx.Menu()
-+ menu_items = [["zoom_to_extend", _("Zoom to scatter plot extend"), lambda event : self.plot.ZoomToExtend()]]
-+ for item in menu_items:
-+ item_id = wx.ID_ANY
-+ menu.Append(item_id, text = item[1])
-+ menu.Bind(wx.EVT_MENU, item[2], id = item_id)
-+ wx.CallAfter(self.ShowMenu, menu)
-+ def ShowMenu(self, menu):
-+ self.plot.PopupMenu(menu)
-+ menu.Destroy()
-+ self.plot.ReleaseMouse()
-+class PolygonDrawer:
-+ An polygon editor.
-+ def __init__(self, ax, pol, empty_pol):
-+ if pol.figure is None:
-+ raise RuntimeError('You must first add the polygon to a figure or canvas before defining the interactor')
-+ self.ax = ax
-+ self.canvas = pol.figure.canvas
-+ self.showverts = True
-+ self.pol = pol
-+ self.empty_pol = empty_pol
-+ x, y = zip(*self.pol.xy)
-+ style = self._getPolygonStyle()
-+ self.line = Line2D(x, y, marker='o', markerfacecolor='r', animated=True)
-+ self.ax.add_line(self.line)
-+ #self._update_line(pol)
-+ cid = self.pol.add_callback(self.poly_changed)
-+ self.moving_ver_idx = None # the active vert
-+ self.mode = None
-+ if self.empty_pol:
-+ self._show(False)
-+ #self.canvas.mpl_connect('draw_event', self.draw_callback)
-+ self.canvas.mpl_connect('button_press_event', self.OnButtonPressed)
-+ self.canvas.mpl_connect('button_release_event', self.button_release_callback)
-+ self.canvas.mpl_connect('motion_notify_event', self.motion_notify_callback)
-+ self.it = 0
-+ def _getPolygonStyle(self):
-+ style = {}
-+ style['sel_pol'] = UserSettings.Get(group='scatt',
-+ key='selection',
-+ subkey='sel_pol')
-+ style['sel_pol_vertex'] = UserSettings.Get(group='scatt',
-+ key='selection',
-+ subkey='sel_pol_vertex')
-+ style['sel_pol'] = [i / 255.0 for i in style['sel_pol']]
-+ style['sel_pol_vertex'] = [i / 255.0 for i in style['sel_pol_vertex']]
-+ return style
-+ def _getSnapTresh(self):
-+ return UserSettings.Get(group='scatt',
-+ key='selection',
-+ subkey='snap_tresh')
-+ self.mode = mode
-+ self.Show(activate)
-+ if not activate and self.mode:
-+ self.SetMode(None)
-+ def Show(self, show):
-+ if show:
-+ if not self.empty_pol:
-+ self._show(True)
-+ else:
-+ return None
-+ coords = deepcopy(self.pol.xy)
-+ return coords
-+ self._setEmptyPol(True)
-+ def _setEmptyPol(self, empty_pol):
-+ self._show(not empty_pol)
-+ def _show(self, show):
-+ self.show = show
-+ self.line.set_visible(self.show)
-+ self.pol.set_visible(self.show)
-+ self.Redraw()
-+ def Redraw(self):
-+ if self.show:
-+ self.ax.draw_artist(self.pol)
-+ self.ax.draw_artist(self.line)
-+ self.canvas.blit(self.ax.bbox)
-+ style=self._getPolygonStyle()
-+ self.pol.set_facecolor(style['sel_pol'])
-+ self.line.set_markerfacecolor(style['sel_pol_vertex'])
-+ self.background = self.canvas.copy_from_bbox(self.ax.bbox)
-+ def poly_changed(self, pol):
-+ 'this method is called whenever the polygon object is called'
-+ # only copy the artist props to the line (except visibility)
-+ vis = self.line.get_visible()
-+ Artist.update_from(self.line, pol)
-+ self.line.set_visible(vis) # don't use the pol visibility state
-+ def get_ind_under_point(self, event):
-+ 'get the index of the vertex under point if within treshold'
-+ # display coords
-+ xy = np.asarray(self.pol.xy)
-+ xyt = self.pol.get_transform().transform(xy)
-+ xt, yt = xyt[:, 0], xyt[:, 1]
-+ d = np.sqrt((xt-event.x)**2 + (yt-event.y)**2)
-+ indseq = np.nonzero(np.equal(d, np.amin(d)))[0]
-+ ind = indseq[0]
-+ if d[ind]>=self._getSnapTresh():
-+ ind = None
-+ return ind
-+ def OnButtonPressed(self, event):
-+ return
-+ if event.button in [2, 3]:
-+ return
-+ if self.mode == "delete_vertex":
-+ self._deleteVertex(event)
-+ elif self.mode == "add_boundary_vertex":
-+ self._addVertexOnBoundary(event)
-+ elif self.mode == "add_vertex":
-+ self._addVertex(event)
-+ elif self.mode == "remove_polygon":
-+ self.SetEmpty()
-+ self.moving_ver_idx = self.get_ind_under_point(event)
-+ def button_release_callback(self, event):
-+ 'whenever a mouse button is released'
-+ if not self.showverts: return
-+ def ShowVertices(self, show):
-+ self.showverts = show
-+ self.line.set_visible(self.showverts)
-+ if not self.showverts: self.moving_ver_idx = None
-+ def _deleteVertex(self, event):
-+ ind = self.get_ind_under_point(event)
-+ if ind is None or self.empty_pol:
-+ return
-+ if len(self.pol.xy) <= 2:
-+ self.empty_pol = True
-+ return
-+ coords = []
-+ for i,tup in enumerate(self.pol.xy):
-+ if i == ind:
-+ continue
-+ elif i == 0 and ind == len(self.pol.xy) - 1:
-+ continue
-+ elif i == len(self.pol.xy) - 1 and ind == 0:
-+ continue
-+ coords.append(tup)
-+ self.pol.xy = coords
-+ self.line.set_data(zip(*self.pol.xy))
-+ self.Redraw()
-+ def _addVertexOnBoundary(self, event):
-+ return
-+ xys = self.pol.get_transform().transform(self.pol.xy)
-+ p = event.x, event.y # display coords
-+ for i in range(len(xys)-1):
-+ s0 = xys[i]
-+ s1 = xys[i+1]
-+ d = dist_point_to_segment(p, s0, s1)
-+ if d<=self._getSnapTresh():
-+ self.pol.xy = np.array(
-+ list(self.pol.xy[:i + 1]) +
-+ [(event.xdata, event.ydata)] +
-+ list(self.pol.xy[i + 1:]))
-+ break
-+ self.Redraw()
-+ def _addVertex(self, event):
-+ pt = (event.xdata, event.ydata)
-+ self.pol.xy = np.array([pt, pt])
-+ self._show(True)
-+ self.empty_pol = False
-+ else:
-+ list(self.pol.xy[1:]) +
-+ [(event.xdata, event.ydata)])
-+ self.Redraw()
-+ def motion_notify_callback(self, event):
-+ if not self.mode == "move_vertex": return
-+ if self.empty_pol: return
-+ if self.moving_ver_idx is None: return
-+ self.it += 1
-+ self.pol.xy[self.moving_ver_idx] = x,y
-+ if self.moving_ver_idx == 0:
-+ self.pol.xy[len(self.pol.xy) - 1] = x,y
-+ elif self.moving_ver_idx == len(self.pol.xy) - 1:
-+ self.pol.xy[0] = x,y
-+ self.canvas.restore_region(self.background)
-+ self.Redraw()
-+class ModestImage(mi.AxesImage):
-+ Computationally modest image class.
-+ ModestImage is an extension of the Matplotlib AxesImage class
-+ better suited for the interactive display of larger images. Before
-+ drawing, ModestImage resamples the data array based on the screen
-+ resolution and view window. This has very little affect on the
-+ appearance of the image, but can substantially cut down on
-+ computation since calculations of unresolved or clipped pixels
-+ are skipped.
-+ The interface of ModestImage is the same as AxesImage. However, it
-+ does not currently support setting the 'extent' property. There
-+ may also be weird coordinate warping operations for images that
-+ I'm not aware of. Don't expect those to work either.
-+ Author: Chris Beaumont <beaumont at hawaii.edu>
-+ def __init__(self, *args, **kwargs):
-+ if 'extent' in kwargs and kwargs['extent'] is not None:
-+ raise NotImplementedError("ModestImage does not support extents")
-+ self._full_res = None
-+ self._sx, self._sy = None, None
-+ self._bounds = (None, None, None, None)
-+ super(ModestImage, self).__init__(*args, **kwargs)
-+ def set_data(self, A):
-+ Set the image array
-+ ACCEPTS: numpy/PIL Image A
-+ self._full_res = A
-+ self._A = A
-+ if self._A.dtype != np.uint8 and not np.can_cast(self._A.dtype,
-+ np.float):
-+ raise TypeError("Image data can not convert to float")
-+ if (self._A.ndim not in (2, 3) or
-+ (self._A.ndim == 3 and self._A.shape[-1] not in (3, 4))):
-+ raise TypeError("Invalid dimensions for image data")
-+ self._imcache =None
-+ self._rgbacache = None
-+ self._oldxslice = None
-+ self._oldyslice = None
-+ def get_array(self):
-+ """Override to return the full-resolution array"""
-+ return self._full_res
-+ def _scale_to_res(self):
-+ """ Change self._A and _extent to render an image whose
-+ resolution is matched to the eventual rendering."""
-+ ax = self.axes
-+ ext = ax.transAxes.transform([1, 1]) - ax.transAxes.transform([0, 0])
-+ xlim, ylim = ax.get_xlim(), ax.get_ylim()
-+ dx, dy = xlim[1] - xlim[0], ylim[1] - ylim[0]
-+ y0 = max(0, ylim[0] - 5)
-+ y1 = min(self._full_res.shape[0], ylim[1] + 5)
-+ x0 = max(0, xlim[0] - 5)
-+ x1 = min(self._full_res.shape[1], xlim[1] + 5)
-+ y0, y1, x0, x1 = map(int, [y0, y1, x0, x1])
-+ sy = int(max(1, min((y1 - y0) / 5., np.ceil(dy / ext[1]))))
-+ sx = int(max(1, min((x1 - x0) / 5., np.ceil(dx / ext[0]))))
-+ # have we already calculated what we need?
-+ if sx == self._sx and sy == self._sy and \
-+ x0 == self._bounds[0] and x1 == self._bounds[1] and \
-+ y0 == self._bounds[2] and y1 == self._bounds[3]:
-+ return
-+ self._A = self._full_res[y0:y1:sy, x0:x1:sx]
-+ self._A = cbook.safe_masked_invalid(self._A)
-+ x1 = x0 + self._A.shape[1] * sx
-+ y1 = y0 + self._A.shape[0] * sy
-+ self.set_extent([x0 - .5, x1 - .5, y0 - .5, y1 - .5])
-+ self._sx = sx
-+ self._sy = sy
-+ self._bounds = (x0, x1, y0, y1)
-+ self.changed()
-+ def draw(self, renderer, *args, **kwargs):
-+ self._scale_to_res()
-+ super(ModestImage, self).draw(renderer, *args, **kwargs)
-+def imshow(axes, X, cmap=None, norm=None, aspect=None,
-+ interpolation=None, alpha=None, vmin=None, vmax=None,
-+ origin=None, extent=None, shape=None, filternorm=1,
-+ filterrad=4.0, imlim=None, resample=None, url=None, **kwargs):
-+ """Similar to matplotlib's imshow command, but produces a ModestImage
-+ Unlike matplotlib version, must explicitly specify axes
-+ if not axes._hold:
-+ axes.cla()
-+ if norm is not None:
-+ assert(isinstance(norm, mcolors.Normalize))
-+ if aspect is None:
-+ aspect = rcParams['image.aspect']
-+ axes.set_aspect(aspect)
-+ im = ModestImage(axes, cmap, norm, interpolation, origin, extent,
-+ filternorm=filternorm,
-+ filterrad=filterrad, resample=resample, **kwargs)
-+ im.set_data(X)
-+ im.set_alpha(alpha)
-+ axes._set_artist_props(im)
-+ if im.get_clip_path() is None:
-+ # image does not already have clipping set, clip to axes patch
-+ im.set_clip_path(axes.patch)
-+ #if norm is None and shape is None:
-+ # im.set_clim(vmin, vmax)
-+ if vmin is not None or vmax is not None:
-+ im.set_clim(vmin, vmax)
-+ else:
-+ im.autoscale_None()
-+ im.set_url(url)
-+ # update ax.dataLim, and, if autoscaling, set viewLim
-+ # to tightly fit the image, regardless of dataLim.
-+ im.set_extent(im.get_extent())
-+ axes.images.append(im)
-+ im._remove_method = lambda h: axes.images.remove(h)
-+ return im
-+def MergeImg(cats_order, scatts, styles, output_queue):
-+ start_time = time.clock()
-+ cmap_time = 0
-+ merge_time = 0
-+ mask_time = 0
-+ norm_time = 0
-+ max_time = 0
-+ init = True
-+ merge_tmp = grass.tempfile()
-+ if not scatts.has_key(cat_id):
-+ continue
-+ scatt = scatts[cat_id]
-+ #print "color map %d" % cat_id
-+ #TODO make more general
-+ if cat_id != 0 and (styles[cat_id]['opacity'] == 0.0 or \
-+ not styles[cat_id]['show']):
-+ continue
-+ if init:
-+ b2_i = scatt['bands_info']['b1']
-+ b1_i = scatt['bands_info']['b2']
-+ full_extend = (b1_i['min'] - 0.5, b1_i['max'] + 0.5, b2_i['min'] - 0.5, b2_i['max'] + 0.5)
-+ if cat_id == 0:
-+ cmap = matplotlib.cm.jet
-+ cmap.set_bad('w',1.)
-+ cmap._init()
-+ cmap._lut[len(cmap._lut) - 1, -1] = 0
-+ else:
-+ cmap._init()
-+ cmap._lut[:, 0] = int(colors[0])/255.0
-+ cmap._lut[:, 1] = int(colors[1])/255.0
-+ cmap._lut[:, 2] = int(colors[2])/255.0
-+ #if init:
-+ tmp = time.clock()
-+ masked_cat = np.ma.masked_less_equal(scatt['np_vals'], 0)
-+ mask_time += time.clock() - tmp
-+ vmax = np.amax(masked_cat)
-+ max_time += time.clock() - tmp
-+ masked_cat = np.uint8(masked_cat * (255.0 / float(vmax)))
-+ norm_time += time.clock() - tmp
-+ #print "ahoj"
-+ #print masked_cat
-+ #print masked_cat.shape
-+ #print masked_cat.mask.dtype
-+ #print "colored_cat.shape"
-+ #print colored_cat.shape
-+ #merged_img = np.memmap(merge_tmp, dtype='uint8',, shape=colored_cat.shape)
-+ cmap = np.uint8(cmap._lut * 255)
-+ sh =masked_cat.shape
-+ colored_cat = np.zeros(dtype='uint8', shape=(sh[0], sh[1], 4))
-+ ApplyColormap(masked_cat, masked_cat.mask, cmap, colored_cat)
-+ #colored_cat = np.uint8(cmap(masked_cat) * 255)
-+ cmap_time += time.clock() - tmp
-+ del masked_cat
-+ del cmap
-+ #colored_cat[...,3] = np.choose(masked_cat.mask, (255, 0))
-+ if init:
-+ merged_img = np.memmap(merge_tmp, dtype='uint8', mode='w+', shape=colored_cat.shape)
-+ merged_img[:] = colored_cat[:]
-+ init = False
-+ else:
-+ MergeArrays(merged_img, colored_cat, styles[cat_id]['opacity'])
-+ #c_img_a = np.memmap(grass.tempfile(), dtype="uint16", mode='w+', shape = shape)
-+ c_img_a = colored_cat.astype('uint16')[:,:,3] * styles[cat_id]['opacity']
-+ #TODO apply strides and there will be no need for loop
-+ #b = as_strided(a, strides=(0, a.strides[3], a.strides[3], a.strides[3]), shape=(3, a.shape[0], a.shape[1]))
-+ for i in range(3):
-+ merged_img[:,:,i] = (merged_img[:,:,i] * (255 - c_img_a) + colored_cat[:,:,i] * c_img_a) / 255;
-+ merged_img[:,:,3] = (merged_img[:,:,3] * (255 - c_img_a) + 255 * c_img_a) / 255;
-+ del c_img_a
-+ merge_time += time.clock() - tmp
-+ del colored_cat
-+ end_time = time.clock() - start_time
-+ #print "all time:%f" % (end_time)
-+ #print "cmap_time:%f" % (cmap_time / end_time * 100.0 )
-+ #print "merge_time:%f" % (merge_time / end_time * 100.0 )
-+ #print "mask_time:%f" % (mask_time / end_time * 100.0 )
-+ #print "nax_time:%f" % (max_time / end_time * 100.0 )
-+ #print "norm_time:%f" % (norm_time / end_time * 100.0 )
-+ #output_queue.put((merged_img, full_extend))
-+ return merged_img, full_extend
-\ No newline at end of file
-Index: gui/wxpython/scatt_plot/controllers.py
---- gui/wxpython/scatt_plot/controllers.py (revision 0)
-+++ gui/wxpython/scatt_plot/controllers.py (working copy)
-@@ -0,0 +1,816 @@
-+ at package scatt_plot.controllers
-+ at brief Controller layer for scatter plot tool.
-+Classes:
-+import os
-+import sys
-+#TODO just for testing
-+import time
-+#TODO
-+import wx
-+from core.gcmd import GException, GError, GMessage, RunCommand
-+from scatt_plot.scatt_core import Core, idBandsToidScatt
-+from scatt_plot.dialogs import AddScattPlotDialog, ExportCategoryRaster
-+from scatt_plot.gthreading import gThread
-+from core.gconsole import EVT_CMD_DONE
-+class ScattsManager(wx.EvtHandler):
-+ def __init__(self, guiparent, giface, iclass_mapwin):
-+ #TODO remove iclass parameter
-+ wx.EvtHandler.__init__(self)
-+ self.giface = giface
-+ self.mapDisp = giface.GetMapDisplay()
-+ if iclass_mapwin:
-+ self.mapWin = iclass_mapwin
-+ else:
-+ self.mapWin = giface.GetMapWindow()
-+ self.guiparent = guiparent
-+ self.show_add_scatt_plot = False
-+ self.core = Core()
-+ self.scatts_dt, self.scatt_conds_dt = self.core.GetScattsData()
-+ self.cats_mgr = CategoriesManager(self, self.core)
-+ self.thread = gThread(self);
-+ self.plots = {}
-+ self.added_cats_rasts = []
-+ self.cats_to_update = []
-+ self.plot_mode = None
-+ self.pol_sel_mode = [False, None]
-+ self.data_set = False
-+ self.cursorPlotMove = Signal("ScattsManager.cursorPlotMove")
-+ self.renderingStarted = Signal("ScattsManager.renderingStarted")
-+ self.renderingFinished = Signal("ScattsManager.renderingFinished")
-+ self.computingStarted = Signal("ScattsManager.computingStarted")
-+ self.mapWin_conn = MapWinConnection(self, self.mapWin, self.core.CatRastUpdater())
-+ self.iclass_conn = IClassConnection(self, iclass_mapwin.parent, self.cats_mgr)
-+ else:
-+ self.mapWin_conn = None
-+ self.iclass_conn = None
-+ self.tasks_pids = {
-+ 'add_scatt' : [],
-+ 'set_data' : -1,
-+ 'set_data_add' : -1,
-+ 'set_edit_cat_data' : -1,
-+ 'mapwin_conn' : [],
-+ 'render_plots' : -1,
-+ 'render' : [],
-+ 'export_cat_rast' : []
-+ self._initSettings()
-+ self.Bind(EVT_CMD_DONE, self.OnThreadDone)
-+ self.modeSet = Signal("ScattsManager.mondeSet")
-+ self.core.CleanUp()
-+ self.cats_mgr.CleanUp()
-+ for scatt_id, scatt in self.plots.items():
-+ scatt.CleanUp()
-+ def _initSettings(self):
-+ """!Initialization of settings (if not already defined)"""
-+ # initializes default settings
-+ initSettings = [
-+ ['selection', 'sel_pol', (255,255,0)],
-+ ['selection', 'sel_pol_vertex', (255,0,0)],
-+ ['selection', 'sel_area', (0,255,19)],
-+ ['selection', "snap_tresh", 10],
-+ ['selection', 'sel_area_opacty', 50],
-+ ['ellipses', 'show_ellips', True],
-+ for init in initSettings:
-+ UserSettings.ReadSettingsFile()
-+ UserSettings.Append(dict = UserSettings.userSettings,
-+ group ='scatt',
-+ key = init[0],
-+ subkey =init[1],
-+ value = init[2],
-+ overwrite = False)
-+ def OnThreadDone(self, event):
-+ if event.exception:
-+ GError(str(event.exception))
-+ return
-+ if event.pid in self.tasks_pids['mapwin_conn']:
-+ self.tasks_pids['mapwin_conn'].remove(event.pid)
-+ updated_cats = event.ret
-+ for cat in updated_cats:
-+ if cat not in self.cats_to_update:
-+ self.cats_to_update.append(cat)
-+ if not self.tasks_pids['mapwin_conn']:
-+ self.tasks_pids['render_plots'] = self.thread.GetId()
-+ self.thread.Run(callable = self.core.ComputeCatsScatts,
-+ cats_ids = self.cats_to_update[:])
-+ del self.cats_to_update[:]
-+ return
-+ if self.tasks_pids['render_plots'] == event.pid:
-+ self.RenderScattPlts()
-+ return
-+ if event.pid in self.tasks_pids['render']:
-+ self.tasks_pids['render'].remove(event.pid)
-+ if not self.tasks_pids['render']:
-+ self.renderingFinished.emit()
-+ return
-+ if event.pid in self.tasks_pids['add_scatt']:
-+ self.tasks_pids['add_scatt'].remove(event.pid)
-+ self.AddScattPlotDone(event)
-+ return
-+ if self.tasks_pids['set_data'] == event.pid:
-+ self.SetDataDone(event)
-+ return
-+ if self.tasks_pids['set_data_add'] == event.pid:
-+ self.AddScattPlot()
-+ return
-+ if self.tasks_pids['set_edit_cat_data'] == event.pid:
-+ self.SetEditCatDataDone(event)
-+ return
-+ if event.pid in self.tasks_pids['export_cat_rast']:
-+ self.cats_mgr.OnExportCatRastDone(event)
-+ return
-+ def SetData(self, bands):
-+ "setting datas"
-+ self.CleanUp()
-+ if self.show_add_scatt_plot:
-+ self.tasks_pids['set_data_add'] = self.thread.GetId()
-+ else:
-+ self.tasks_pids['set_data'] = self.thread.GetId()
-+ self.thread.Run(callable=self.core.SetData, bands=bands)
-+ def SetDataDone(self, event):
-+ self.data_set = True
-+ self.iclass_conn.SyncCats()
-+ def SettingsUpdated(self, event):
-+ #TODO optimization
-+ def OnOutput(self, event):
-+ """!Print thread output according to debug level.
-+ print event.text
-+ def GetBands(self):
-+ return self.core.GetBands()
-+ def AddScattPlot(self):
-+ if not self.data_set and self.iclass_conn:
-+ self.show_add_scatt_plot = True
-+ self.iclass_conn.SetData()
-+ return
-+ if not self.data_set:
-+ GError(_('No data set.'))
-+ return
-+ self.computingStarted.emit()
-+ bands = self.core.GetBands()
-+ dlg = AddScattPlotDialog(parent = self.guiparent, bands = bands)
-+ if dlg.ShowModal() == wx.ID_OK:
-+ b_1, b_2 = dlg.GetBands()
-+ #TODO axes selection
-+ transpose = False
-+ if b_1 > b_2:
-+ transpose = True
-+ tmp_band = b_2
-+ b_2 = b_1
-+ b_1 = tmp_band
-+ self.scatt_id = idBandsToidScatt(b_1, b_2, len(bands))
-+ self._addScattPlot(self.scatt_id, transpose)
-+ dlg.Destroy()
-+ self.mapWin_conn.Update()
-+ def _addScattPlot(self, scatt_id, transpose):
-+ if self.plots.has_key(scatt_id):
-+ GMessage(_("Scatter plot has been already added."))
-+ return
-+ self.tasks_pids['add_scatt'].append(self.thread.GetId())
-+ self.thread.Run(callable = self.core.AddScattPlot, scatt_id = scatt_id, userdata = {'transpose' : transpose})
-+ def RenderScattPlts(self, scatt_ids = None):
-+ if len(self.tasks_pids['render']) > 1:
-+ return
-+ self.renderingStarted.emit()
-+ self.tasks_pids['render'].append(self.thread.GetId())
-+ self.thread.Run(callable = self._renderscattplts, scatt_ids = scatt_ids)
-+ def _renderscattplts(self, scatt_ids):
-+ cats_attrs = self.cats_mgr.GetCategoriesAttrs()
-+ cats = self.cats_mgr.GetCategories()[:]
-+ cats.reverse()
-+ cats.insert(0, 0)
-+ for i_scatt_id, scatt in self.plots.items():
-+ if scatt_ids is not None and i_scatt_id not in scatt_ids:
-+ continue
-+ scatt_dt = self.scatts_dt.GetScatt(i_scatt_id)
-+ if self._showConfEllipses():
-+ ellipses_dt = self.scatts_dt.GetEllipses(i_scatt_id, cats_attrs)
-+ else:
-+ ellipses_dt = {}
-+ if self.pol_sel_mode[0]:
-+ self._getSelectedAreas(cats, i_scatt_id, scatt_dt, cats_attrs)
-+ scatt.Plot(cats_order = cats, scatts = scatt_dt, ellipses = ellipses_dt, styles = cats_attrs)
-+ def _showConfEllipses(self):
-+ key="ellipses",
-+ subkey="show_ellips")
-+ def _getSelectedAreas(self, cats_order, scatt_id, scatt_dt, cats_attrs):
-+ cat_id = self.cats_mgr.GetSelectedCat()
-+ if not cat_id:
-+ return
-+ sel_a_cat_id = max(cats_attrs.keys()) + 1
-+ s = self.scatt_conds_dt.GetScatt(scatt_id, [cat_id])
-+ if not s:
-+ return
-+ cats_order.append(sel_a_cat_id)
-+ col = UserSettings.Get(group='scatt',
-+ key='selection',
-+ subkey='sel_area')
-+ col = ":".join(map(str, col))
-+ opac = UserSettings.Get(group='scatt',
-+ key='selection',
-+ subkey='sel_area_opacty') / 100.0
-+ cats_attrs[sel_a_cat_id] = {'color' : col,
-+ 'opacity' : opac,
-+ 'show' : True}
-+ scatt_dt[sel_a_cat_id] = s[cat_id]
-+ def AddScattPlotDone(self, event):
-+ transpose = event.userdata['transpose']
-+ scatt_id = event.kwds['scatt_id']
-+ #TODO guiparent - not very good
-+ self.plots[scatt_id] = self.guiparent.NewScatterPlot(scatt_id = scatt_id, transpose = transpose)
-+ self.plots[scatt_id].plotClosed.connect(self.PlotClosed)
-+ self.plots[scatt_id].cursorMove.connect(lambda x, y: self.cursorPlotMove.emit(x = x, y = y))
-+ if self.plot_mode:
-+ self.plots[scatt_id].SetMode(self.plot_mode)
-+ self.plots[scatt_id].ZoomToExtend()
-+ self.RenderScattPlts(scatt_ids = [scatt_id])
-+ def PlotClosed(self, scatt_id):
-+ del self.plots[scatt_id]
-+ def SetPlotsMode(self, mode):
-+ self.plot_mode = mode
-+ for scatt in self.plots.itervalues():
-+ scatt.SetMode(mode)
-+ self.modeSet.emit(mode = mode)
-+ def ActivateSelectionPolygonMode(self, activate):
-+ self.pol_sel_mode[0] = activate
-+ scatt.SetSelectionPolygonMode(activate)
-+ if not activate and self.plot_mode not in ['zoom', 'pan', 'zoom_extend']:
-+ self.SetPlotsMode(None)
-+ return activate
-+ def ProcessSelectionPolygons(self, process_mode):
-+ scatts_polygons = {}
-+ for scatt_id, scatt in self.plots.iteritems():
-+ coords = scatt.GetCoords()
-+ if coords is not None:
-+ scatts_polygons[scatt_id] = coords
-+ if not scatts_polygons:
-+ return
-+ value = 1
-+ if process_mode == 'remove':
-+ value = 0
-+ sel_cat_id = self.cats_mgr.GetSelectedCat()
-+ if not sel_cat_id:
-+ dlg = wx.MessageDialog(parent = self.guiparent,
-+ message = _("In order to select arrea in scatter plot, "
-+ "you have to select class first.\n\n"
-+ "There is no class yet, "
-+ "do you want to create one?"),
-+ caption = _("No class selected"),
-+ style = wx.YES_NO)
-+ if dlg.ShowModal() == wx.ID_YES:
-+ self.iclass_conn.EmptyCategories()
-+ return
-+ scatt.SetEmpty()
-+ self.tasks_pids['set_edit_cat_data'] = self.thread.GetId()
-+ self.thread.Run(callable = self.core.UpdateCategoryWithPolygons,
-+ cat_id = sel_cat_id,
-+ scatts_pols = scatts_polygons,
-+ value = value)
-+ def SetEditCatDataDone(self, event):
-+ GError(_("Error occured during computation of scatter plot category:\n%s"),
-+ parent = self.guiparent, showTraceback = False)
-+ cat_id = event.ret
-+ cat_id = event.kwds["cat_id"]
-+ train_mgr, preview_mgr = self.iclass_conn.iclass_frame.GetMapManagers()
-+ if not cat_id in self.added_cats_rasts:
-+ cat_rast = self.core.GetCatRast(cat_id)
-+ cat_name = self.cats_mgr.GetCategoryAttrs(cat_id)['name']
-+ self.UpdateCategoryRaster(cat_id, ['color'], render = False)
-+ train_mgr.AddLayer(cat_rast, alias = cat_name)
-+ self.added_cats_rasts.append(cat_id)
-+ else: #TODO settings
-+ train_mgr.Render()
-+ def UpdateCategoryRaster(self, cat_id, attrs, render = True):
-+ if not grass.find_file(cat_rast, element = 'cell', mapset = '.')['file']:
-+ return
-+ cats_attrs = self.cats_mgr.GetCategoryAttrs(cat_id)
-+ if "color" in attrs:
-+ ret, err_msg = RunCommand('r.colors',
-+ map=cat_rast,
-+ rules="-",
-+ stdin="1 %s" % cats_attrs["color"],
-+ getErrorMsg=True)
-+ if ret != 0:
-+ GError("r.colors failed\n%s" % err_msg)
-+ if render:
-+ if "name" in attrs:
-+ train_mgr.SetAlias(original=cat_rast, alias=cats_attrs['name'])
-+ cats_attrs["name"]
-+ def DigitDataChanged(self, vectMap, digit):
-+ if self.mapWin_conn:
-+ self.mapWin_conn.DigitDataChanged(vectMap, digit)
-+ return 1
-+ else:
-+ return 0
-+ def GetCategoriesManager(self):
-+ return self.cats_mgr
-+class CategoriesManager:
-+ def __init__(self, scatt_mgr, core):
-+ self.core = core
-+ self.cats = {}
-+ self.cats_ids = []
-+ self.sel_cat_id = None
-+ self.exportRaster = None
-+ self.initialized = Signal('CategoriesManager.initialized')
-+ self.setCategoryAttrs = Signal('CategoriesManager.setCategoryAttrs')
-+ self.deletedCategory = Signal('CategoriesManager.deletedCategory')
-+ self.addedCategory = Signal('CategoriesManager.addedCategory')
-+ self.cats.clear()
-+ del self.cats_ids[:]
-+ def InitCoreCats(self):
-+ if self.scatt_mgr.data_set:
-+ for cat_id in self.cats_ids:
-+ self._addCategory(cat_id)
-+ self.scatt_mgr.mapWin_conn.Update()
-+ def ChangePosition(self, cat_id, new_pos):
-+ if new_pos >= len(self.cats_ids):
-+ return False
-+ try:
-+ pos = self.cats_ids.index(cat_id)
-+ except:
-+ return False
-+ if pos > new_pos:
-+ pos -= 1
-+ self.cats_ids.remove(cat_id)
-+ self.cats_ids.insert(new_pos, cat_id)
-+ self.scatt_mgr.RenderScattPlts()
-+ return True
-+ def _addCategory(self, cat_id):
-+ self.scatt_mgr.thread.Run(callable = self.core.AddCategory,
-+ cat_id = cat_id)
-+ def AddCategory(self, cat_id = None, name = None, color = None, nstd = None):
-+ if cat_id is None:
-+ if self.cats_ids:
-+ cat_id = max(self.cats_ids) + 1
-+ else:
-+ cat_id = 1
-+ cat_id = cat_id)
-+ #TODO check number of cats
-+ #if ret < 0: #TODO
-+ # return -1;
-+ self.cats[cat_id] = {
-+ 'name' : _('Category %s' % cat_id ),
-+ 'color' : "0:0:0",
-+ 'opacity' : 1.0,
-+ 'show' : True,
-+ 'nstd' : 1.0,
-+ self.cats_ids.insert(0, cat_id)
-+ if name is not None:
-+ self.cats[cat_id]["name"] = name
-+ if color is not None:
-+ self.cats[cat_id]["color"] = color
-+ if nstd is not None:
-+ self.cats[cat_id]["nstd"] = nstd
-+ self.addedCategory.emit(cat_id = cat_id,
-+ name = self.cats[cat_id]["name"],
-+ color = self.cats[cat_id]["color"] )
-+ return cat_id
-+ def SetCategoryAttrs(self, cat_id, attrs_dict):
-+ render = False
-+ update_cat_rast = []
-+ for k, v in attrs_dict.iteritems():
-+ if not render and k in ['color', 'opacity', 'show', 'nstd']:
-+ render = True
-+ if k in ['color', 'name']:
-+ update_cat_rast.append(k)
-+ self.cats[cat_id][k] = v
-+ if render:
-+ if update_cat_rast:
-+ self.scatt_mgr.UpdateCategoryRaster(cat_id, update_cat_rast)
-+ self.setCategoryAttrs.emit(cat_id = cat_id, attrs_dict = attrs_dict)
-+ def DeleteCategory(self, cat_id):
-+ self.scatt_mgr.thread.Run(callable = self.core.DeleteCategory,
-+ cat_id = cat_id)
-+ del self.cats[cat_id]
-+ self.deletedCategory.emit(cat_id = cat_id)
-+ #TODO emit event?
-+ def SetSelectedCat(self, cat_id):
-+ self.sel_cat_id = cat_id
-+ if self.scatt_mgr.pol_sel_mode[0]:
-+ def GetSelectedCat(self):
-+ return self.sel_cat_id
-+ def GetCategoryAttrs(self, cat_id):
-+ #TODO is mutable
-+ return self.cats[cat_id]
-+ def GetCategoriesAttrs(self):
-+ #TODO is mutable
-+ return self.cats
-+ def GetCategories(self):
-+ return self.cats_ids[:]
-+ def SetCategoryPosition(self):
-+ if newindex > oldindex:
-+ newindex -= 1
-+ self.cats_ids.insert(newindex, self.cats_ids.pop(oldindex))
-+ def ExportCatRast(self, cat_id):
-+ cat_attrs = self.GetCategoryAttrs(cat_id)
-+ dlg = ExportCategoryRaster(parent=self.scatt_mgr.guiparent,
-+ rasterName=self.exportRaster,
-+ title=_("Export scatter plot raster of class <%s>") % cat_attrs['name'])
-+ self.exportCatRast = dlg.GetRasterName()
-+ dlg.Destroy()
-+ self.scatt_mgr.tasks_pids['export_cat_rast'].append(self.scatt_mgr.thread.GetId())
-+ self.scatt_mgr.thread.Run(callable=self.core.ExportCatRast,
-+ userdata={'name' : cat_attrs['name']},
-+ cat_id=cat_id,
-+ rast_name=self.exportCatRast)
-+ def OnExportCatRastDone(self, event):
-+ ret, err = event.ret
-+ if ret == 0:
-+ cat_attrs = self.GetCategoryAttrs(event.kwds['cat_id'])
-+ GMessage(_("Scatter plot raster of class <%s> exported to raster map <%s>.") %
-+ (event.userdata['name'], event.kwds['rast_name']))
-+ else:
-+ GMessage(_("Export of scatter plot raster of class <%s> to map <%s> failed.\n%s") %
-+ (event.userdata['name'], event.kwds['rast_name'], err))
-+class MapWinConnection:
-+ def __init__(self, scatt_mgr, mapWin, scatt_rast_updater):
-+ self.mapWin = mapWin
-+ self.vectMap = None
-+ self.scatt_rast_updater = scatt_rast_updater
-+ self.cats_mgr = scatt_mgr.cats_mgr
-+ self.thread = self.scatt_mgr.thread
-+ #TODO
-+ self.mapWin.parent.toolbars["vdigit"].editingStarted.connect(self.DigitDataChanged)
-+ #def ChangeMap(self, vectMap, layers_cats):
-+ # self.vectMap = vectMap
-+ # self.layers_cats = layers_cats
-+ #ret, region, msg = RunCommand("v.to.rast",
-+ # flags = "gp",
-+ # getErrorMsg = True,
-+ # read = True)
-+ def Update(self):
-+ self.thread.Run(callable=self.scatt_rast_updater.SynchWithMap)
-+ def _connectSignals(self):
-+ self.digit.featureAdded.connect(self.AddFeature)
-+ self.digit.areasDeleted.connect(self.DeleteAreas)
-+ self.digit.featuresDeleted.connect(self.DeleteAreas)
-+ self.digit.vertexMoved.connect(self.EditedFeature)
-+ self.digit.vertexRemoved.connect(self.EditedFeature)
-+ self.digit.lineEdited.connect(self.EditedFeature)
-+ self.digit.featuresMoved.connect(self.EditedFeature)
-+ def AddFeature(self, new_bboxs, new_areas_cats):
-+ if not self.scatt_mgr.data_set:
-+ return
-+ self.scatt_mgr.computingStarted.emit()
-+ self.scatt_mgr.tasks_pids['mapwin_conn'].append(self.thread.GetId())
-+ self.thread.Run(callable = self.scatt_rast_updater.EditedFeature,
-+ new_bboxs = new_bboxs,
-+ old_bboxs = [],
-+ old_areas_cats = [],
-+ new_areas_cats = new_areas_cats)
-+ def DeleteAreas(self, old_bboxs, old_areas_cats):
-+ return
-+ new_bboxs = [],
-+ old_bboxs = old_bboxs,
-+ old_areas_cats = old_areas_cats,
-+ new_areas_cats = [])
-+ def EditedFeature(self, new_bboxs, new_areas_cats, old_bboxs, old_areas_cats):
-+ return
-+ self.digit = digit
-+ self.vectMap = vectMap
-+ self.digit.EmitSignals(emit = True)
-+ self.scatt_rast_updater.SetVectMap(vectMap)
-+ self._connectSignals()
-+class IClassConnection:
-+ def __init__(self, scatt_mgr, iclass_frame, cats_mgr):
-+ self.iclass_frame = iclass_frame
-+ self.stats_data = self.iclass_frame.stats_data
-+ self.cats_mgr = cats_mgr
-+ self.scatt_mgr= scatt_mgr
-+ self.stats_data.statisticsAdded.connect(self.AddCategory)
-+ self.stats_data.statisticsDeleted.connect(self.DeleteCategory)
-+ self.stats_data.allStatisticsDeleted.connect(self.DeletAllCategories)
-+ self.stats_data.statisticsSet.connect(self.SetCategory)
-+ self.iclass_frame.groupSet.connect(self.GroupSet)
-+ self.cats_mgr.setCategoryAttrs.connect(self.SetStatistics)
-+ self.cats_mgr.deletedCategory.connect(self.DeleteStatistics)
-+ self.cats_mgr.addedCategory.connect(self.AddStatistics)
-+ self.iclass_frame.categoryChanged.connect(self.CategoryChanged)
-+ self.SyncCats()
-+ def SetData(self):
-+ self.iclass_frame.AddBands()
-+ def EmptyCategories(self):
-+ self.iclass_frame.OnCategoryManager(None)
-+ def SyncCats(self, cats_ids = None):
-+ self.cats_mgr.addedCategory.disconnect(self.AddStatistics)
-+ cats = self.stats_data.GetCategories()
-+ for c in cats:
-+ if cats_ids and c not in cats_ids:
-+ continue
-+ stats = self.stats_data.GetStatistics(c)
-+ self.cats_mgr.AddCategory(c, stats.name, stats.color, stats.nstd)
-+ def CategoryChanged(self, cat):
-+ self.cats_mgr.SetSelectedCat(cat)
-+ def AddCategory(self, cat, name, color):
-+ stats = self.stats_data.GetStatistics(cat)
-+ self.cats_mgr.AddCategory(cat_id = cat, name = name, color = color, nstd = stats.nstd)
-+ def DeleteCategory(self, cat):
-+ self.cats_mgr.deletedCategory.disconnect(self.DeleteStatistics)
-+ self.cats_mgr.DeleteCategory(cat)
-+ def DeletAllCategories(self):
-+ for c in cats:
-+ self.cats_mgr.DeleteCategory(c)
-+ def SetCategory(self, cat, stats):
-+ self.cats_mgr.setCategoryAttrs.disconnect(self.SetStatistics)
-+ cats_attr = {}
-+ for attr in ['name', 'color', 'nstd']:
-+ if stats.has_key(attr):
-+ cats_attr[attr] = stats[attr]
-+ if cats_attr:
-+ self.cats_mgr.SetCategoryAttrs(cat, cats_attr)
-+ def SetStatistics(self, cat_id, attrs_dict):
-+ self.stats_data.statisticsSet.disconnect(self.SetCategory)
-+ self.stats_data.GetStatistics(cat_id).SetStatistics(attrs_dict)
-+ def AddStatistics(self, cat_id, name, color):
-+ self.stats_data.statisticsAdded.disconnect(self.AddCategory)
-+ self.stats_data.AddStatistics(cat_id, name, color)
-+ def DeleteStatistics(self, cat_id):
-+ self.stats_data.statisticsDeleted.disconnect(self.DeleteCategory)
-+ self.stats_data.DeleteStatistics(cat_id)
-+ def GroupSet(self, group):
-+ res = RunCommand('i.group',
-+ flags = 'g',
-+ group = group, subgroup = group,
-+ read = True).strip()
-+ if res.split('\n')[0]:
-+ bands = res.split('\n')
-+ self.scatt_mgr.SetData(bands)
Index: gui/wxpython/vnet/dialogs.py
--- gui/wxpython/vnet/dialogs.py (revision 57633)
@@ -5443,1247 +6706,3 @@
return True
def StopEditing(self):
-Index: gui/icons/grass/polygon.png
-Cannot display: file marked as a binary type.
-svn:mime-type = application/octet-stream
---- gui/icons/grass/polygon.png (revision 57633)
-+++ gui/icons/grass/polygon.png (working copy)
-Property changes on: gui/icons/grass/polygon.png
-___________________________________________________________________
-Added: svn:mime-type
-## -0,0 +1 ##
-+application/octet-stream
-\ No newline at end of property
-Index: lib/imagery/scatt_sccats.c
---- lib/imagery/scatt_sccats.c (revision 0)
-+++ lib/imagery/scatt_sccats.c (working copy)
-@@ -0,0 +1,405 @@
-+ \file lib/imagery/scatt_cat_rast.c
-+ \brief Imagery library - functions for manipulation with scatter plot structs.
-+ Copyright (C) 2013 by the GRASS Development Team
-+ This program is free software under the GNU General Public License
-+ (>=v2). Read the file COPYING that comes with GRASS for details.
-+ \author Stepan Turek <stepan.turek at seznam.cz> (Mentor: Martin Landa)
-+#include <grass/raster.h>
-+#include <grass/imagery.h>
-+#include <grass/gis.h>
-+#include <stdio.h>
-+#include <stdlib.h>
-+#include <math.h>
-+#include <string.h>
-+ \brief Compute band ids from scatter plot id.
-+ Scatter plot id describes which bands defines the scatter plot.
-+ Let say we have 3 bands, their ids are 0, 1 and 2.
-+ Scatter plot with id 0 consists of band 1 (b_1_id) 0 and band 2 (b_2_id) 1.
-+ All scatter plots:
-+ scatt_id b_1_id b_2_id
-+ 0 0 1
-+ 1 0 2
-+ 2 1 2
-+ \param scatt_id scatter plot id
-+ \param n_bands number of bands
-+ \param [out] b_1_id id of band1
-+ \param[out] b_2_id id of band2
-+ \return 0
-+int I_id_scatt_to_bands(const int scatt_id, const int n_bands, int * b_1_id, int * b_2_id)
-+ int n_b1 = n_bands - 1;
-+ * b_1_id = (int) ((2 * n_b1 + 1 - sqrt((double)((2 * n_b1 + 1) * (2 * n_b1 + 1) - 8 * scatt_id))) / 2);
-+ * b_2_id = scatt_id - ((* b_1_id) * (2 * n_b1 + 1) - (* b_1_id) * (* b_1_id)) / 2 + (* b_1_id) + 1;
-+ return 0;
-+ \brief Compute scatter plot id from band ids.
-+ See also I_id_scatt_to_bands().
-+ \param b_1_id id of band1
-+ \param b_1_id id of band2
-+ \param [out] scatt_id scatter plot id
-+ \return 0
-+int I_bands_to_id_scatt(const int b_1_id, const int b_2_id, const int n_bands, int * scatt_id)
-+ * scatt_id = (b_1_id * (2 * n_b1 + 1) - b_1_id * b_1_id) / 2 + b_2_id - b_1_id - 1;
-+ return 0;
-+ \brief Initialize structure for storing scatter plots data.
-+ \param cats pointer to scCats struct
-+ \param type SC_SCATT_DATA - stores scatter plots
-+ \param type SC_SCATT_CONDITIONS - stores selected areas in scatter plots
-+void I_sc_init_cats(struct scCats * cats, int n_bands, int type)
-+ int i_cat;
-+ cats->type = type;
-+ cats->n_cats = 100;
-+ cats->n_a_cats = 0;
-+ cats->n_bands = n_bands;
-+ cats->n_scatts = (n_bands - 1) * n_bands / 2;
-+ cats->cats_arr = (struct scScatts **) G_malloc(cats->n_cats * sizeof(struct scScatts *));
-+ memset(cats->cats_arr, 0, cats-> n_cats * sizeof(struct scScatts *));
-+ cats->cats_ids = (int *) G_malloc(cats->n_cats * sizeof(int));
-+ cats->cats_idxs =(int *) G_malloc(cats->n_cats * sizeof(int));
-+ for(i_cat = 0; i_cat < cats->n_cats; i_cat++)
-+ cats->cats_idxs[i_cat] = -1;
-+ return;
-+ \brief Free data of struct scCats, the structure itself remains alocated.
-+ \param cats pointer to existing scCats struct
-+void I_sc_free_cats(struct scCats * cats)
-+ int i_cat;
-+ for(i_cat = 0; i_cat < cats->n_a_cats; i_cat++)
-+ if(cats->cats_arr[i_cat])
-+ G_free(cats->cats_arr[i_cat]->scatt_idxs);
-+ G_free(cats->cats_arr[i_cat]->scatts_bands);
-+ G_free(cats->cats_arr[i_cat]->scatts_arr);
-+ G_free(cats->cats_arr[i_cat]);
-+ G_free(cats->cats_ids);
-+ G_free(cats->cats_idxs);
-+ G_free(cats->cats_arr);
-+ cats->n_cats = 0;
-+ cats->n_bands = 0;
-+ cats->n_scatts = 0;
-+ cats->type = -1;
-+ return;
-+#if 0
-+void I_sc_get_active_categories(int * a_cats_ids, int * n_a_cats, struct scCats * cats)
-+ a_cats_ids = cats->cats_ids;
-+ * n_a_cats = cats->n_a_cats;
-+#endif
-+ \brief Add category.
-+ Category represents group of scatter plots.
-+ \return assigned category id (starts with 0)
-+ \return -1 if maximum nuber of categories was reached
-+int I_sc_add_cat(struct scCats * cats)
-+ int i_scatt, i_cat_id, cat_id;
-+ int n_a_cats = cats->n_a_cats;
-+ if(cats->n_a_cats >= cats->n_cats)
-+ return -1;
-+ for(i_cat_id = 0; i_cat_id < cats->n_cats; i_cat_id++)
-+ if(cats->cats_idxs[i_cat_id] < 0) {
-+ cat_id = i_cat_id;
-+ break;
-+ cats->cats_ids[n_a_cats] = cat_id;
-+ cats->cats_idxs[cat_id] = n_a_cats;
-+ cats->cats_arr[n_a_cats] = (struct scScatts *) G_malloc(sizeof(struct scScatts));
-+ cats->cats_arr[n_a_cats]->scatts_arr = (struct scdScattData **) G_malloc(cats->n_scatts * sizeof(struct scdScattData *));
-+ memset((cats->cats_arr[n_a_cats]->scatts_arr), 0, cats->n_scatts * sizeof(struct scdScattData *));
-+ cats->cats_arr[n_a_cats]->n_a_scatts = 0;
-+ cats->cats_arr[n_a_cats]->scatts_bands = (int *) G_malloc(cats->n_scatts * 2 * sizeof(int));
-+ cats->cats_arr[n_a_cats]->scatt_idxs = (int *) G_malloc(cats->n_scatts * sizeof(int));
-+ for(i_scatt = 0; i_scatt < cats->n_scatts; i_scatt++)
-+ cats->cats_arr[n_a_cats]->scatt_idxs[i_scatt] = -1;
-+ ++cats->n_a_cats;
-+ return cat_id;
-+#if 0
-+int I_sc_delete_cat(struct scCats * cats, int cat_id)
-+ int cat_idx, i_cat;
-+ if(cat_id < 0 || cat_id >= cats->n_cats)
-+ return -1;
-+ cat_idx = cats->cats_idxs[cat_id];
-+ if(cat_idx < 0)
-+ return -1;
-+ G_free(cats->cats_arr[cat_idx]->scatt_idxs);
-+ G_free(cats->cats_arr[cat_idx]->scatts_bands);
-+ G_free(cats->cats_arr[cat_idx]->scatts_arr);
-+ G_free(cats->cats_arr[cat_idx]);
-+ for(i_cat = cat_idx; i_cat < cats->n_a_cats - 1; i_cat++)
-+ cats->cats_arr[i_cat] = cats->cats_arr[i_cat + 1];
-+ cats->cats_ids[i_cat] = cats->cats_ids[i_cat + 1];
-+ cats->cats_idxs[cat_id] = -1;
-+ --cats->n_a_cats;
-+ return 0;
-+#endif
-+ \brief Insert scatter plot data .
-+ Inserted scatt_data struct must have same type as cats struct (SC_SCATT_DATA or SC_SCATT_CONDITIONS).
-+ \param cat_id id number of category.
-+ \param scatt_id id number of scatter plot.
-+ \return 0 on success
-+ \return -1 on failure
-+int I_sc_insert_scatt_data(struct scCats * cats, struct scdScattData * scatt_data, int cat_id, int scatt_id)
-+ int band_1, band_2, cat_idx, n_a_scatts;
-+ struct scScatts * scatts;
-+ return -1;
-+ if(cat_idx < 0)
-+ return -1;
-+ if(scatt_id < 0 && scatt_id >= cats->n_scatts)
-+ return -1;
-+ scatts = cats->cats_arr[cat_idx];
-+ if(scatts->scatt_idxs[scatt_id] >= 0)
-+ return -1;
-+ if(!scatt_data->b_conds_arr && cats->type == SC_SCATT_CONDITIONS)
-+ return -1;
-+ if(!scatt_data->scatt_vals_arr && cats->type == SC_SCATT_DATA)
-+ return -1;
-+ n_a_scatts = scatts->n_a_scatts;
-+ scatts->scatt_idxs[scatt_id] = n_a_scatts;
-+ I_id_scatt_to_bands(scatt_id, cats->n_bands, &band_1, &band_2);
-+ scatts->scatts_bands[n_a_scatts * 2] = band_1;
-+ scatts->scatts_bands[n_a_scatts * 2 + 1] = band_2;
-+ scatts->scatts_arr[n_a_scatts] = scatt_data;
-+ ++scatts->n_a_scatts;
-+ return 0;
-+#if 0
-+int I_sc_remove_scatt_data(struct scCats * cats, struct scdScattData * scatt_data, int cat_id, int scatt_id)
-+ int cat_idx, scatt_idx, n_init_scatts, i_scatt;
-+ if(cat_id < 0 && cat_id >= cats->n_cats)
-+ return -1;
-+ if(cat_idx < 0)
-+ return -1;
-+ if(scatt_id < 0 || scatt_id >= cats->n_scatts)
-+ return -1;
-+ if(scatts->scatt_idxs[scatt_id] < 0)
-+ return -1;
-+ scatt_data = scatts->scatts_arr[scatt_idx];
-+ for(i_scatt = scatt_idx; i_scatt < scatts->n_a_scatts - 1; i_scatt++)
-+ scatts->scatts_arr[i_scatt] = scatts->scatts_arr[i_scatt + 1];
-+ scatts->scatts_bands[i_scatt * 2] = scatts->scatts_bands[(i_scatt + 1)* 2];
-+ scatts->scatts_bands[i_scatt * 2 + 1] = scatts->scatts_bands[(i_scatt + 1) * 2 + 1];
-+ scatts->scatts_arr[scatts->n_a_scatts] = NULL;
-+ scatts->scatt_idxs[scatt_id] = -1;
-+ scatt_data = scatts->scatts_arr[scatt_id];
-+ scatts->n_a_scatts--;
-+ return 0;
-+int I_sc_set_value(struct scCats * cats, int cat_id, int scatt_id, int value_idx, int value)
-+ int n_a_scatts = cats->cats_arr[cat_id]->n_a_scatts;
-+ int cat_idx, scatt_idx, ret;
-+ if(cat_idx < 0)
-+ return -1;
-+ if(cats->cats_arr[cat_idx]->scatt_idxs[scatt_id] < 0)
-+ return -1;
-+ scatt_idx = cats->cats_arr[cat_idx]->scatt_idxs[scatt_id];
-+ I_scd_set_value(cats->cats_arr[cat_idx]->scatts_arr[scatt_idx], value_idx, value);
-+ return 0;
-+#endif
-+ \brief Insert scatter plot data.
-+ \param scatt_data pointer to existing struct scdScattData
-+ \param type SC_SCATT_DATA for scatter plots or SC_SCATT_CONDITIONS for selected areas in scatter plot
-+ \param n_vals number of data values
-+ \param data array of values (unsigned char for SC_SCATT_CONDITIONS, unsigned int for SC_SCATT_DATA)
-+void I_scd_init_scatt_data(struct scdScattData * scatt_data, int type, int n_vals, void * data)
-+ scatt_data->n_vals = n_vals;
-+ if(type == SC_SCATT_DATA)
-+ if(data)
-+ scatt_data->scatt_vals_arr = (unsigned int *) data;
-+ else {
-+ scatt_data->scatt_vals_arr = (unsigned int *) G_malloc(n_vals * sizeof(unsigned int));
-+ memset(scatt_data->scatt_vals_arr, 0, n_vals * sizeof(unsigned int));
-+ scatt_data->b_conds_arr = NULL;
-+ else if(type == SC_SCATT_CONDITIONS)
-+ if(data)
-+ scatt_data->b_conds_arr = (unsigned char *) data;
-+ else {
-+ scatt_data->b_conds_arr = (unsigned char *) G_malloc(n_vals * sizeof(unsigned char));
-+ memset(scatt_data->b_conds_arr, 0, n_vals * sizeof(unsigned char));
-+ scatt_data->scatt_vals_arr = NULL;
-+ return;
-+#if 0
-+void I_scd_get_range_min_max(struct scdScattData * scatt_data, CELL * band_1_min, CELL * band_1_max, CELL * band_2_min, CELL * band_2_max)
-+ Rast_get_range_min_max(&(scatt_data->band_1_range), band_1_min, band_2_min);
-+ Rast_get_range_min_max(&(scatt_data->band_2_range), band_2_min, band_2_max);
-+ return;
-+s
-+void * I_scd_get_data_ptr(struct scdScattData * scatt_data)
-+ if(!scatt_data->b_conds_arr)
-+ return scatt_data->b_conds_arr;
-+ else if(!scatt_data->scatt_vals_arr)
-+ return scatt_data->scatt_vals_arr;
-+ return NULL;
-+int I_scd_set_value(struct scdScattData * scatt_data, unsigned int val_idx, unsigned int val)
-+ if(val_idx < 0 && val_idx > scatt_data->n_vals)
-+ return -1;
-+ if(scatt_data->b_conds_arr)
-+ scatt_data->b_conds_arr[val_idx] = val;
-+ else if(scatt_data->scatt_vals_arr)
-+ scatt_data->scatt_vals_arr[val_idx] = val;
-+ else
-+ return -1;
-+ return 0;
-+#endif
-Index: lib/imagery/scatt.c
---- lib/imagery/scatt.c (revision 0)
-+++ lib/imagery/scatt.c (working copy)
-@@ -0,0 +1,799 @@
-+ \file lib/imagery/scatt.c
-+ \brief Imagery library - functions for wx Scatter Plot Tool.
-+ Low level functions used by wx Scatter Plot Tool.
-+#include <grass/glocale.h>
-+#include <math.h>
-+struct rast_row
-+ CELL * row;
-+ char * null_row;
-+ struct Range rast_range; /*Range of whole raster.*/
-+ \brief Create pgm header.
-+ Scatter plot internally generates pgm files. These pgms have header in format created by this function.
-+ \param region region to be pgm header generated for
-+ \param [out] header header of pgm file
-+static int get_cat_rast_header(struct Cell_head * region, char * header){
-+ return sprintf(header, "P5\n%d\n%d\n1\n", region->cols, region->rows);
-+ \brief Create category raster conditions file.
-+ \param cat_rast_region region to be file generated for
-+ \param cat_rast path of generated category raster file
-+int I_create_cat_rast(struct Cell_head * cat_rast_region, const char * cat_rast)
-+ FILE * f_cat_rast;
-+ char cat_rast_header[1024];//TODO magic number
-+ int i_row, i_col;
-+ int head_nchars;
-+ unsigned char * row_data;
-+ f_cat_rast = fopen(cat_rast, "wb");
-+ if(!f_cat_rast) {
-+ G_warning("Unable to create category raster condition file <%s>.", cat_rast);
-+ return -1;
-+ head_nchars = get_cat_rast_header(cat_rast_region, cat_rast_header);
-+ fwrite(cat_rast_header, sizeof(char), head_nchars/sizeof(char), f_cat_rast);
-+ if (ferror(f_cat_rast)){
-+ fclose(f_cat_rast);
-+ G_warning(_("Unable to write header into category raster condition file <%s>."), cat_rast);
-+ return -1;
-+ row_data = (unsigned char *) G_malloc(cat_rast_region->cols * sizeof(unsigned char));
-+ for(i_col = 0; i_col < cat_rast_region->cols; i_col++)
-+ row_data[i_col] = 0 & 255;
-+ for(i_row = 0; i_row < cat_rast_region->rows; i_row++) {
-+ fwrite(row_data, sizeof(unsigned char), (cat_rast_region->cols)/sizeof(unsigned char), f_cat_rast);
-+ G_warning(_("Unable to write into category raster condition file <%s>."), cat_rast);
-+ return -1;
-+ return 0;
-+static int print_reg(struct Cell_head * intersec, const char * pref, int dbg_level)
-+ G_debug(dbg_level, "%s:\n n:%f\ns:%f\ne:%f\nw:%f\nns_res:%f\new_res:%f", pref, intersec->north, intersec->south,
-+ intersec->east, intersec->west, intersec->ns_res, intersec->ew_res);
-+ \brief Find intersection region of two regions.
-+ \param A pointer to intersected region
-+ \param B pointer to intersected region
-+ \param [out] intersec pointer to intersection region of regions A B (relevant params of the region are: south, north, east, west)
-+ \return 0 if interection exists
-+ \return -1 if regions does not intersect
-+static int regions_intersecion(struct Cell_head * A, struct Cell_head * B, struct Cell_head * intersec)
-+ if(B->north < A->south) return -1;
-+ else if(B->north > A->north) intersec->north = A->north;
-+ else intersec->north = B->north;
-+ if(B->south > A->north) return -1;
-+ else if(B->south < A->south) intersec->south = A->south;
-+ else intersec->south = B->south;
-+ if(B->east < A->west) return -1;
-+ else if(B->east > A->east) intersec->east = A->east;
-+ else intersec->east = B->east;
-+ if(B->west > A->east) return -1;
-+ else if(B->west < A->west) intersec->west = A->west;
-+ else intersec->west = B->west;
-+ if(intersec->north == intersec->south) return -1;
-+ if(intersec->east == intersec->west) return -1;
-+ return 0;
-+ \brief Get rows and cols numbers, which defines intersection of the regions.
-+ \param B pointer to intersected region (A and B must have same resolution)
-+ \param [out] A_bounds rows and cols numbers of A stored in south, north, east, west, which defines intersection of A and B
-+ \param [out] B_bounds rows and cols numbers of B stored in south, north, east, west, which defines intersection of A and B
-+ \return -1 if regions do not intersect
-+ \return -2 resolution of regions is not same
-+static int get_rows_and_cols_bounds(struct Cell_head * A, struct Cell_head * B, struct Cell_head * A_bounds, struct Cell_head * B_bounds)
-+ float ns_res, ew_res;
-+ struct Cell_head intersec;
-+ /* TODO is it right check? */
-+ if(abs(A->ns_res - B->ns_res) > GRASS_EPSILON) {
-+ G_debug(0, "'get_rows_and_cols_bounds' ns_res does not fit, A->ns_res: %f B->ns_res: %f", A->ns_res, B->ns_res);
-+ return -2;
-+ if(abs(A->ew_res - B->ew_res) > GRASS_EPSILON) {
-+ G_debug(0, "'get_rows_and_cols_bounds' ew_res does not fit, A->ew_res: %f B->ew_res: %f", A->ew_res, B->ew_res);
-+ return -2;
-+ ns_res = A->ns_res;
-+ ew_res = A->ew_res;
-+ if(regions_intersecion(A, B, &intersec) == -1)
-+ return -1;
-+ A_bounds->north = ceil((A->north - intersec.north - ns_res * 0.5) / ns_res);
-+ A_bounds->south = ceil((A->north - intersec.south - ns_res * 0.5) / ns_res);
-+ A_bounds->east = ceil((intersec.east - A->west - ew_res * 0.5) / ew_res);
-+ A_bounds->west = ceil((intersec.west - A->west - ew_res * 0.5) / ew_res);
-+ B_bounds->north = ceil((B->north - intersec.north - ns_res * 0.5) / ns_res);
-+ B_bounds->south = ceil((B->north - intersec.south - ns_res * 0.5) / ns_res);
-+ B_bounds->east = ceil((intersec.east - B->west - ew_res * 0.5) / ew_res);
-+ B_bounds->west = ceil((intersec.west - B->west - ew_res * 0.5) / ew_res);
-+ return 0;
-+ \brief Insert raster map patch into pgm file.
-+ \param patch_rast name of raster map
-+ \param cat_rast_region region of category raster file
-+ \param cat_rast path to category raster file
-+int I_insert_patch_to_cat_rast(const char * patch_rast, struct Cell_head * cat_rast_region, const char * cat_rast)
-+ struct Cell_head patch_region, patch_bounds, cat_rast_bounds;
-+ int i_row, i_col, ncols, nrows, cat_rast_col, patch_col, val;
-+ int head_nchars, ret;
-+ int fd_patch_rast, init_shift, step_shift;
-+ unsigned char * patch_data;
-+ char * null_chunk_row;
-+ const char *mapset;
-+ struct Cell_head patch_lines, cat_rast_lines;
-+ f_cat_rast = fopen(cat_rast, "rb+");
-+ G_warning(_("Unable to open category raster condtions file <%s>."), cat_rast);
-+ return -1;
-+ if ((mapset = G_find_raster(patch_rast,"")) == NULL) {
-+ G_warning(_("Unable to find patch raster <%s>."), patch_rast);
-+ return -1;
-+ Rast_get_cellhd(patch_rast, mapset, &patch_region);
-+ Rast_set_window(&patch_region);
-+ if ((fd_patch_rast = Rast_open_old(patch_rast, mapset)) < 0) {
-+ return -1;
-+ ret = get_rows_and_cols_bounds(cat_rast_region, &patch_region, &cat_rast_bounds, &patch_bounds);
-+ if(ret == -2) {
-+ G_warning(_("Resolutions of patch <%s> and patched file <%s> are not same."), patch_rast, cat_rast);
-+ Rast_close(fd_patch_rast);
-+ return -1;
-+ else if (ret == -1){
-+ return 0;
-+ ncols = cat_rast_bounds.east - cat_rast_bounds.west;
-+ nrows = cat_rast_bounds.south - cat_rast_bounds.north;
-+ patch_data = (unsigned char *) G_malloc(ncols * sizeof(unsigned char));
-+ init_shift = head_nchars + cat_rast_region->cols * cat_rast_bounds.north + cat_rast_bounds.west;
-+ if(fseek(f_cat_rast, init_shift, SEEK_SET) != 0) {
-+ G_warning(_("Corrupted category raster conditions file <%s> (fseek failed)"), cat_rast);
-+ G_free(null_chunk_row);
-+ return -1;
-+ step_shift = cat_rast_region->cols - ncols;
-+ null_chunk_row = Rast_allocate_null_buf();
-+ for(i_row = 0; i_row < nrows; i_row++) {
-+ Rast_get_null_value_row (fd_patch_rast, null_chunk_row, i_row + patch_bounds.north);
-+ for(i_col = 0; i_col < ncols; i_col++) {
-+ patch_col = patch_bounds.west + i_col;
-+ if(null_chunk_row[patch_col] != 1)
-+ patch_data[i_col] = 1 & 255;
-+ else {
-+ patch_data[i_col] = 0 & 255;
-+ fwrite(patch_data, sizeof(unsigned char), (ncols)/sizeof(unsigned char), f_cat_rast);
-+ G_warning(_("Unable to write into category raster conditions file <%s>"), cat_rast);
-+ return -1;
-+ if(fseek(f_cat_rast, step_shift, SEEK_CUR) != 0) {
-+ return -1;
-+ return 0;
-+ \brief Updates scatter plots data in category by pixels which meets category conditions.
-+ \param bands_rows data represents data describig one row from raster band
-+ \param belongs_pix array which defines which pixels belongs to category (1 value) and which not (0 value)
-+ \param [out] scatts pointer to scScatts struct of type SC_SCATT_DATA, which are modified according to values in belongs_pix
-+static inline void update_cat_scatt_plts(struct rast_row * bands_rows, unsigned short * belongs_pix, struct scScatts * scatts)
-+ int band_axis_1, band_axis_2, i_scatt, array_idx, cat_idx, i_chunk_rows_pix, max_arr_idx;
-+ CELL * b_1_row;
-+ CELL * b_2_row;
-+ char * b_1_null_row,* b_2_null_row;
-+ struct rast_row b_1_rast_row, b_2_rast_row;
-+ struct Range b_1_range, b_2_range;
-+ int b_1_range_size;
-+ int row_size = Rast_window_cols();
-+ int * scatts_bands = scatts->scatts_bands;
-+ for(i_scatt = 0; i_scatt < scatts->n_a_scatts; i_scatt++)
-+ b_1_rast_row = bands_rows[scatts_bands[i_scatt * 2]];
-+ b_2_rast_row = bands_rows[scatts_bands[i_scatt * 2 + 1]];
-+ b_1_row = b_1_rast_row.row;
-+ b_2_row = b_2_rast_row.row;
-+ b_1_null_row = b_1_rast_row.null_row;
-+ b_2_null_row = b_2_rast_row.null_row;
-+ b_1_range = b_1_rast_row.rast_range;
-+ b_2_range = b_2_rast_row.rast_range;
-+ b_1_range_size = b_1_range.max - b_1_range.min + 1;
-+ max_arr_idx = (b_1_range.max - b_1_range.min + 1) * (b_2_range.max - b_2_range.min + 1);
-+ for(i_chunk_rows_pix = 0; i_chunk_rows_pix < row_size; i_chunk_rows_pix++)
-+ /* pixel does not belongs to scatter plot or has null value in one of the bands */
-+ if(!belongs_pix[i_chunk_rows_pix] ||
-+ b_1_null_row[i_chunk_rows_pix] == 1 ||
-+ b_2_null_row[i_chunk_rows_pix] == 1)
-+ continue;
-+ /* index in scatter plot array */
-+ array_idx = b_1_row[i_chunk_rows_pix] - b_1_range.min + (b_2_row[i_chunk_rows_pix] - b_2_range.min) * b_1_range_size;
-+ if(array_idx < 0 || array_idx >= max_arr_idx) {
-+ G_warning ("Data inconsistent. Value computed for scatter plot is out of initialized range.");
-+ continue;
-+ /* increment scatter plot value */
-+ ++scatts->scatts_arr[i_scatt]->scatt_vals_arr[array_idx];
-+ \brief Computes scatter plots data from chunk_rows.
-+ \param scatts pointer to scScatts struct of type SC_SCATT_DATA, where are computed scatter plots stored
-+ \param scatt_conds pointer to scScatts struct of type SC_SCATT_CONDITIONS, where are selected areas (condtitions)stored
-+ \param chunk_rows data arrays of chunk_rows from analyzed raster bands (all data in chunk_rows, null_chunk_rows and belongs_pix arrays represents same region)
-+ \param null_chunk_rows null data arrays of chunk_rows from analyzed raster bands
-+ \param row_size size of data in chunk_rows, null_chunk_rows and belongs_pix arrays
-+ \param f_cats_rasts_conds file which stores selected areas (conditions) from mapwindow see I_create_cat_rast() and I_pa
-+ \param fd_cats_rasts array of openedraster maps which represents all selected pixels for category
-+ \param region analysis region
-+static inline int compute_scatts_from_chunk_row(struct Cell_head *region, struct scCats * scatt_conds,
-+ FILE ** f_cats_rasts_conds, struct rast_row * bands_rows,
-+ struct scCats * scatts, int * fd_cats_rasts)
-+ int i_rows_pix, i_cat, i_scatt, n_a_scatts, n_pixs;
-+ int cat_id, scatt_plts_cat_idx, array_idx, max_arr_idx;
-+ CELL * cat_rast_row;
-+ struct scScatts * scatts_conds;
-+ struct scScatts * scatts_scatt_plts;
-+ struct scdScattData * conds;
-+ int * scatts_bands;
-+ struct scdScattData ** scatts_arr;
-+ CELL * b_1_row;
-+ CELL * b_2_row;
-+ unsigned char * i_scatt_conds;
-+ unsigned short * belongs_pix = (unsigned short *) G_malloc(row_size * sizeof(unsigned short));
-+ unsigned char * rast_pixs = (unsigned char *) G_malloc(row_size * sizeof(unsigned char));
-+ cat_rast_row = Rast_allocate_c_buf();
-+ for(i_cat = 0; i_cat < scatt_conds->n_a_cats; i_cat++)
-+ scatts_conds = scatt_conds->cats_arr[i_cat];
-+ cat_id = scatt_conds->cats_ids[i_cat];
-+ scatt_plts_cat_idx = scatts->cats_idxs[cat_id];
-+ if(scatt_plts_cat_idx < 0)
-+ continue;
-+ scatts_scatt_plts = scatts->cats_arr[scatt_plts_cat_idx];
-+ G_zero(belongs_pix, row_size * sizeof(unsigned short));
-+ /* if category has no conditions defined, scatter plots without any constraint are computed (default scatter plots) */
-+ if(!scatts_conds->n_a_scatts && !f_cats_rasts_conds[i_cat]) {
-+ for(i_scatt = 0; i_scatt < scatts_scatt_plts->n_a_scatts; i_scatt++)
-+ /* all pixels belongs */
-+ for(i_rows_pix = 0; i_rows_pix < row_size; i_rows_pix++)
-+ belongs_pix[i_rows_pix] = 1;
-+ /* compute belonging pixels for defined conditions */
-+ else
-+ scatts_bands = scatts_conds->scatts_bands;
-+ /* check conditions from category raster condtitions file */
-+ if(f_cats_rasts_conds[i_cat]) {
-+ n_pixs = fread(rast_pixs, sizeof(unsigned char), (row_size)/sizeof(unsigned char), f_cats_rasts_conds[i_cat]);
-+ if (ferror(f_cats_rasts_conds[i_cat]))
-+ G_free(rast_pixs);
-+ G_free(belongs_pix);
-+ G_warning(_("Unable to read from category raster condtition file."));
-+ return -1;
-+ if (n_pixs != n_pixs) {
-+ G_warning(_("Invalid size of category raster conditions file."));
-+ return -1;
-+ if(rast_pixs[i_rows_pix] != 0 & 255)
-+ /* check condtions defined in scatter plots*/
-+ for(i_scatt = 0; i_scatt < scatts_conds->n_a_scatts; i_scatt++)
-+ i_scatt_conds = scatts_conds->scatts_arr[i_scatt]->b_conds_arr;
-+ /* pixels already belongs to category from category raster conditions file or contains null value in one of the bands */
-+ if(belongs_pix[i_rows_pix] ||
-+ b_1_null_row[i_rows_pix] == 1 ||
-+ b_2_null_row[i_rows_pix] == 1)
-+ continue;
-+ array_idx = b_1_row[i_rows_pix] - b_1_range.min + (b_2_row[i_rows_pix] - b_2_range.min) * b_1_range_size;
-+ continue;
-+ /* pixels meets condtion defined in scatter plot */
-+ if(i_scatt_conds[array_idx])
-+ /* update category raster with belonging pixels */
-+ if(fd_cats_rasts[i_cat] >= 0) {
-+ Rast_set_null_value(cat_rast_row, Rast_window_cols(), CELL_TYPE);
-+ if(belongs_pix[i_rows_pix])
-+ cat_rast_row[i_rows_pix] = belongs_pix[i_rows_pix];
-+ Rast_put_c_row (fd_cats_rasts[i_cat], cat_rast_row);
-+ /* update scatter plots with belonging pixels */
-+ update_cat_scatt_plts(bands_rows, belongs_pix, scatts_scatt_plts);
-+ G_free(cat_rast_row);
-+ return 0;
-+ \brief Get list if bands needed to be opened for analysis from scCats struct.
-+static void get_needed_bands(struct scCats * cats, int * b_needed_bands)
-+ // results in b_needed_bands - array of bools - if item has value 1, band (defined by item index) is needed to be opened
-+ int i_cat, i_scatt, cat_id;
-+ for(i_scatt = 0; i_scatt < cats->cats_arr[i_cat]->n_a_scatts; i_scatt++)
-+ G_debug(3, "Active scatt %d in catt %d", i_scatt, i_cat);
-+ b_needed_bands[cats->cats_arr[i_cat]->scatts_bands[i_scatt * 2]] = 1;
-+ b_needed_bands[cats->cats_arr[i_cat]->scatts_bands[i_scatt * 2 + 1]] = 1;
-+ return;
-+ \brief Helper function for clean up.
-+static void free_compute_scatts_data(int * fd_bands, struct rast_row * bands_rows, int n_a_bands, int * bands_ids,
-+ int * fd_cats_rasts, FILE ** f_cats_rasts_conds, int n_a_cats)
-+ int i, band_id;
-+ for(i = 0; i < n_a_bands; i++)
-+ band_id = bands_ids[i];
-+ if(band_id >= 0) {
-+ Rast_close(fd_bands[i]);
-+ G_free(bands_rows[band_id].row);
-+ G_free(bands_rows[band_id].null_row);
-+ if(f_cats_rasts_conds)
-+ for(i = 0; i < n_a_cats; i++)
-+ if(f_cats_rasts_conds[i])
-+ fclose(f_cats_rasts_conds[i]);
-+ if(fd_cats_rasts)
-+ if(fd_cats_rasts[i] >= 0)
-+ Rast_close(fd_cats_rasts[i]);
-+ \brief Compute scatter plots data.
-+ If category has not defined no category raster condition file and no scatter plot with consdtion,
-+ default scatter plot is computed.
-+ \param region analysis region, beaware that all input data must be prepared for this region (bands (their ranges), cats_rasts_conds rasters...)
-+ \param region function calls Rast_set_window for this region
-+ \param scatt_conds pointer to scScatts struct of type SC_SCATT_CONDITIONS, where are stored selected areas (conditions) in scatter plots
-+ \param cats_rasts_conds paths to category raster conditions files representing selected areas (conditions) in rasters for every category
-+ \param cats_rasts_conds index in array represents corresponding category id
-+ \param cats_rasts_conds for manupulation with category raster conditions file see also I_id_scatt_to_bands() and I_insert_patch_to_cat_rast()
-+ \param bands names of analyzed bands, order of bands is defined by their id
-+ \param [out] scatts pointer to scScatts struct of type SC_SCATT_DATA, where are computed scatter plots stored
-+ \param [out] cats_rasts array of raster maps names where will be stored all selected pixels for every category
-+int I_compute_scatts(struct Cell_head *region, struct scCats * scatt_conds, const char ** cats_rasts_conds,
-+ const char ** bands, int n_bands, struct scCats * scatts, const char ** cats_rasts)
-+ char header[1024];
-+ int fd_cats_rasts[scatt_conds->n_a_cats];
-+ FILE * f_cats_rasts_conds[scatt_conds->n_a_cats];
-+ struct rast_row bands_rows[n_bands];
-+ RASTER_MAP_TYPE data_type;
-+ int nrows, i_band, n_a_bands, band_id,
-+ i, i_row, head_nchars, i_cat, id_cat;
-+ int fd_bands[n_bands];
-+ int bands_ids[n_bands];
-+ int b_needed_bands[n_bands];
-+ Rast_set_window(region);
-+ for(i_band = 0; i_band < n_bands; i_band++)
-+ fd_bands[i_band] = -1;
-+ bands_ids[i_band] = -1;
-+ if (n_bands != scatts->n_bands ||
-+ n_bands != scatt_conds->n_bands)
-+ return -1;
-+ memset(b_needed_bands, 0, (size_t)n_bands * sizeof(int));
-+ get_needed_bands(scatt_conds, &b_needed_bands[0]);
-+ get_needed_bands(scatts, &b_needed_bands[0]);
-+ n_a_bands = 0;
-+ /* open band rasters, which are needed for computation */
-+ for(band_id = 0; band_id < n_bands; band_id++)
-+ if(b_needed_bands[band_id])
-+ G_debug(3, "Opening raster no. %d with name: %s", band_id, bands[band_id]);
-+ if ((mapset = G_find_raster2(bands[band_id],"")) == NULL) {
-+ free_compute_scatts_data(fd_bands, bands_rows, n_a_bands,
-+ bands_ids, NULL, NULL, scatt_conds->n_a_cats);
-+ G_warning(_("Unbale to read find raster <%s>"), bands[band_id]);
-+ return -1;
-+ if ((fd_bands[n_a_bands] = Rast_open_old(bands[band_id], mapset)) < 0) {
-+ G_warning(_("Unbale to open raster <%s>"), bands[band_id]);
-+ return -1;
-+ data_type = Rast_get_map_type(fd_bands[n_a_bands]);
-+ if(data_type != CELL_TYPE) {
-+ G_warning(_("Raster <%s> type is not <%s>"), bands[band_id], "CELL");
-+ return -1;
-+ bands_rows[band_id].row = Rast_allocate_c_buf();
-+ bands_rows[band_id].null_row = Rast_allocate_null_buf();
-+ if(Rast_read_range(bands[band_id], mapset, &bands_rows[band_id].rast_range) != 1){
-+ G_warning(_("Unable to read range of raster <%s>"), bands[band_id]);
-+ return -1;
-+ bands_ids[n_a_bands] = band_id;
-+ ++n_a_bands;
-+ /* open category rasters condition files and category rasters */
-+ for(i_cat = 0; i_cat < scatts->n_a_cats; i_cat++)
-+ id_cat = scatts->cats_ids[i_cat];
-+ if(cats_rasts[id_cat]) {
-+ fd_cats_rasts[i_cat] = Rast_open_new(cats_rasts[id_cat], CELL_TYPE);
-+ else
-+ fd_cats_rasts[i_cat] = -1;
-+ if(cats_rasts_conds[id_cat]) {
-+ f_cats_rasts_conds[i_cat] = fopen(cats_rasts_conds[id_cat], "r");
-+ if(!f_cats_rasts_conds[i_cat]) {
-+ free_compute_scatts_data(fd_bands, bands_rows, n_a_bands, bands_ids,
-+ f_cats_rasts_conds, f_cats_rasts_conds, scatt_conds->n_a_cats);
-+ G_warning(_("Unable to open category raster condtition file <%s>"), bands[band_id]);
-+ return -1;
-+ else
-+ f_cats_rasts_conds[i_cat] = NULL;
-+ head_nchars = get_cat_rast_header(region, header);
-+ if( fseek(f_cats_rasts_conds[i_cat] , head_nchars, SEEK_SET) != 0) {
-+ G_warning(_("Corrupted category raster conditions file (fseek failed)"));
-+ return -1;
-+ nrows = Rast_window_rows();
-+ /* analyze bands by rows */
-+ for (i_row = 0; i_row < nrows; i_row++)
-+ for(i_band = 0; i_band < n_a_bands; i_band++)
-+ band_id = bands_ids[i_band];
-+ Rast_get_c_row(fd_bands[i_band], bands_rows[band_id].row, i_row);
-+ Rast_get_null_value_row (fd_bands[i_band], bands_rows[band_id].null_row, i_row);
-+ if(compute_scatts_from_chunk_row(region, scatt_conds, f_cats_rasts_conds, bands_rows, scatts, fd_cats_rasts) == -1)
-+ free_compute_scatts_data(fd_bands, bands_rows, n_a_bands, bands_ids, fd_cats_rasts,
-+ f_cats_rasts_conds, scatt_conds->n_a_cats);
-+ return -1;
-+ fd_cats_rasts, f_cats_rasts_conds, scatt_conds->n_a_cats);
-+ return 0;
-+int I_merge_arrays(unsigned char * merged_arr, unsigned char * overlay_arr, unsigned rows, unsigned cols, double alpha)
-+ unsigned int i_row, i_col, i_b;
-+ unsigned int row_idx, col_idx, idx;
-+ unsigned int c_a_i, c_a;
-+ for(i_row = 0; i_row < rows; i_row++)
-+ row_idx = i_row * cols;
-+ for(i_col = 0; i_col < cols; i_col++)
-+ col_idx = 4 * (row_idx + i_col);
-+ idx = col_idx + 3;
-+ c_a = overlay_arr[idx] * alpha;
-+ c_a_i = 255 - c_a;
-+ merged_arr[idx] = (c_a_i * (int)merged_arr[idx] + c_a * 255) / 255;
-+ for(i_b = 0; i_b < 3; i_b++)
-+ idx = col_idx + i_b;
-+ merged_arr[idx] = (c_a_i * (int)merged_arr[idx] + c_a * (int)overlay_arr[idx]) / 255;
-+ return 0;
-+int I_apply_colormap(unsigned char * vals, unsigned char * vals_mask, unsigned vals_size, unsigned char * colmap, unsigned char * col_vals){
-+ unsigned int i_val;
-+ int v, i, i_cm;
-+ for(i_val = 0; i_val < vals_size; i_val++){
-+ i_cm = 4 * i_val;
-+ v = vals[i_val];
-+ if(vals_mask[i_val])
-+ for(i = 0; i < 4; i++) col_vals[i_cm + i] = colmap[258 * 4 + i];
-+ else if(v > 255)
-+ for(i = 0; i < 4; i++) col_vals[i_cm + i] = colmap[257 * 4 + i];
-+ else if(v < 0)
-+ for(i = 0; i < 4; i++) col_vals[i_cm + i] = colmap[256 * 4 + i];
-+ else
-+ for(i = 0; i < 4; i++){ col_vals[i_cm + i] = colmap[v * 4 + i];
-+ return 0;
-Index: lib/vector/Vlib/open.c
---- lib/vector/Vlib/open.c (revision 57633)
-+++ lib/vector/Vlib/open.c (working copy)
-@@ -240,7 +240,9 @@
- else {
- char file_path[GPATH_MAX];
-+ /* reduce to current mapset if search path was set */
-+ if(strcmp(Map->mapset, "") == 0)
-+ Map->mapset = G_store(G_mapset());
- /* temporary map: reduce to current mapset if search path
- * was set */
- if (strcmp(Map->mapset, "") == 0)
