[GRASS-SVN] r57645 - sandbox/turek/scatter_plot
Thu Sep 12 03:44:50 PDT 2013
Author: turek
Date: 2013-09-12 03:44:50 -0700 (Thu, 12 Sep 2013)
New Revision: 57645
   sandbox/turek/scatter_plot/testing_patch.diff
bugs fixing
Modified: sandbox/turek/scatter_plot/testing_patch.diff
--- sandbox/turek/scatter_plot/testing_patch.diff	2013-09-12 07:27:23 UTC (rev 57644)
+++ sandbox/turek/scatter_plot/testing_patch.diff	2013-09-12 10:44:50 UTC (rev 57645)
@@ -1,428 +1,3 @@
-Index: lib/vector/Vlib/open.c
---- lib/vector/Vlib/open.c	(revision 57633)
-+++ lib/vector/Vlib/open.c	(working copy)
-@@ -240,7 +240,9 @@
-         else {
-             char file_path[GPATH_MAX];
-+            /* reduce to current mapset if search path was set */
-+            if(strcmp(Map->mapset, "") == 0)
-+                Map->mapset = G_store(G_mapset());
-             /* temporary map: reduce to current mapset if search path
-              * was set */
-             if (strcmp(Map->mapset, "") == 0)
-Index: lib/imagery/scatt_sccats.c
---- lib/imagery/scatt_sccats.c	(revision 0)
-+++ lib/imagery/scatt_sccats.c	(working copy)
-@@ -0,0 +1,405 @@
-+   \file lib/imagery/scatt_cat_rast.c
-+   \brief Imagery library - functions for manipulation with scatter plot structs.
-+   Copyright (C) 2013 by the GRASS Development Team
-+   This program is free software under the GNU General Public License
-+   (>=v2).  Read the file COPYING that comes with GRASS for details.
-+   \author Stepan Turek <stepan.turek at seznam.cz> (Mentor: Martin Landa)
-+#include <grass/raster.h>
-+#include <grass/imagery.h>
-+#include <grass/gis.h>
-+#include <stdio.h>
-+#include <stdlib.h>
-+#include <math.h>
-+#include <string.h>
-+   \brief Compute band ids from scatter plot id.
-+    Scatter plot id describes which bands defines the scatter plot.
-+    Let say we have 3 bands, their ids are 0, 1 and 2.
-+    Scatter plot with id 0 consists of band 1 (b_1_id) 0 and  band 2 (b_2_id) 1.
-+    All scatter plots:
-+    scatt_id b_1_id b_2_id
-+    0        0      1
-+    1        0      2
-+    2        1      2
-+   \param scatt_id scatter plot id
-+   \param n_bands number of bands
-+   \param [out] b_1_id id of band1
-+   \param[out] b_2_id id of band2
-+   \return 0
-+int I_id_scatt_to_bands(const int scatt_id, const int n_bands, int * b_1_id, int * b_2_id)
-+    int n_b1 = n_bands - 1;
-+    * b_1_id = (int) ((2 * n_b1 + 1 - sqrt((double)((2 * n_b1 + 1) * (2 * n_b1 + 1) - 8 * scatt_id))) / 2);
-+    * b_2_id = scatt_id - ((* b_1_id) * (2 * n_b1 + 1) - (* b_1_id) * (* b_1_id)) / 2 + (* b_1_id) + 1;
-+    return 0;
-+   \brief Compute scatter plot id from band ids.
-+    See also I_id_scatt_to_bands().
-+   \param b_1_id id of band1
-+   \param b_1_id id of band2
-+   \param [out] scatt_id scatter plot id
-+   \return 0
-+int I_bands_to_id_scatt(const int b_1_id, const int b_2_id, const int n_bands, int * scatt_id)
-+    * scatt_id = (b_1_id * (2 * n_b1 + 1) - b_1_id * b_1_id) / 2 + b_2_id - b_1_id - 1;
-+    return 0;
-+   \brief Initialize structure for storing scatter plots data.
-+   \param cats pointer to scCats struct
-+   \param type SC_SCATT_DATA - stores scatter plots
-+   \param type SC_SCATT_CONDITIONS - stores selected areas in scatter plots
-+void I_sc_init_cats(struct scCats * cats, int n_bands, int type)
-+    int i_cat;
-+    cats->type = type;
-+    cats->n_cats = 100;
-+    cats->n_a_cats = 0;
-+    cats->n_bands = n_bands;
-+    cats->n_scatts = (n_bands - 1) * n_bands / 2;
-+    cats->cats_arr = (struct scScatts **) G_malloc(cats->n_cats * sizeof(struct scScatts *));
-+    memset(cats->cats_arr, 0, cats-> n_cats * sizeof(struct scScatts *));
-+    cats->cats_ids = (int *)  G_malloc(cats->n_cats * sizeof(int));
-+    cats->cats_idxs =(int *)  G_malloc(cats->n_cats * sizeof(int));
-+    for(i_cat = 0; i_cat < cats->n_cats; i_cat++)
-+        cats->cats_idxs[i_cat] = -1;
-+    return;
-+   \brief Free data of struct scCats, the structure itself remains alocated.
-+   \param cats pointer to existing scCats struct
-+void I_sc_free_cats(struct scCats * cats)
-+    int i_cat;
-+    for(i_cat = 0; i_cat < cats->n_a_cats; i_cat++)
-+        if(cats->cats_arr[i_cat])
-+            G_free(cats->cats_arr[i_cat]->scatt_idxs);
-+            G_free(cats->cats_arr[i_cat]->scatts_bands);
-+            G_free(cats->cats_arr[i_cat]->scatts_arr);
-+            G_free(cats->cats_arr[i_cat]);
-+    G_free(cats->cats_ids);
-+    G_free(cats->cats_idxs);
-+    G_free(cats->cats_arr);
-+    cats->n_cats = 0;
-+    cats->n_bands = 0;
-+    cats->n_scatts = 0;
-+    cats->type = -1;
-+    return;
-+#if 0
-+void I_sc_get_active_categories(int * a_cats_ids, int * n_a_cats, struct scCats * cats)
-+    a_cats_ids = cats->cats_ids;
-+    * n_a_cats = cats->n_a_cats;
-+#endif
-+   \brief Add category.
-+    Category represents group of scatter plots.
-+   \return assigned category id (starts with 0)
-+   \return -1 if maximum nuber of categories was reached
-+int I_sc_add_cat(struct scCats * cats)
-+    int i_scatt, i_cat_id, cat_id;
-+    int n_a_cats = cats->n_a_cats;
-+    if(cats->n_a_cats >= cats->n_cats)
-+        return -1;
-+    for(i_cat_id = 0; i_cat_id < cats->n_cats; i_cat_id++)
-+        if(cats->cats_idxs[i_cat_id] < 0) {
-+            cat_id = i_cat_id;
-+            break;
-+    cats->cats_ids[n_a_cats] = cat_id;
-+    cats->cats_idxs[cat_id] = n_a_cats;
-+    cats->cats_arr[n_a_cats] = (struct scScatts *) G_malloc(sizeof(struct scScatts));
-+    cats->cats_arr[n_a_cats]->scatts_arr = (struct scdScattData **) G_malloc(cats->n_scatts * sizeof(struct scdScattData *));
-+    memset((cats->cats_arr[n_a_cats]->scatts_arr), 0, cats->n_scatts * sizeof(struct scdScattData *));
-+    cats->cats_arr[n_a_cats]->n_a_scatts = 0;
-+    cats->cats_arr[n_a_cats]->scatts_bands = (int *) G_malloc(cats->n_scatts * 2 * sizeof(int));
-+    cats->cats_arr[n_a_cats]->scatt_idxs = (int *) G_malloc(cats->n_scatts * sizeof(int));
-+    for(i_scatt = 0; i_scatt < cats->n_scatts; i_scatt++)
-+        cats->cats_arr[n_a_cats]->scatt_idxs[i_scatt] = -1;
-+    ++cats->n_a_cats;
-+    return cat_id;
-+#if 0
-+int I_sc_delete_cat(struct scCats * cats, int cat_id)
-+    int cat_idx, i_cat;
-+    if(cat_id < 0 || cat_id >= cats->n_cats)
-+        return -1;
-+    cat_idx = cats->cats_idxs[cat_id];
-+    if(cat_idx < 0)
-+        return -1;
-+    G_free(cats->cats_arr[cat_idx]->scatt_idxs);
-+    G_free(cats->cats_arr[cat_idx]->scatts_bands);
-+    G_free(cats->cats_arr[cat_idx]->scatts_arr);
-+    G_free(cats->cats_arr[cat_idx]);
-+    for(i_cat = cat_idx; i_cat < cats->n_a_cats - 1; i_cat++)
-+        cats->cats_arr[i_cat] = cats->cats_arr[i_cat + 1];
-+        cats->cats_ids[i_cat] = cats->cats_ids[i_cat + 1];
-+    cats->cats_idxs[cat_id] = -1;
-+    --cats->n_a_cats;
-+    return 0;
-+#endif
-+   \brief Insert scatter plot data .
-+    Inserted scatt_data struct must have same type as cats struct (SC_SCATT_DATA or SC_SCATT_CONDITIONS).
-+   \param cat_id id number of category.
-+   \param scatt_id id number of scatter plot.
-+   \return  0 on success
-+   \return -1 on failure
-+int I_sc_insert_scatt_data(struct scCats * cats, struct scdScattData * scatt_data, int cat_id, int scatt_id)
-+    int band_1, band_2, cat_idx, n_a_scatts;
-+    struct scScatts * scatts;
-+        return -1;
-+    if(cat_idx < 0)
-+        return -1;
-+    if(scatt_id < 0 && scatt_id >= cats->n_scatts)
-+        return -1;
-+    scatts = cats->cats_arr[cat_idx];
-+    if(scatts->scatt_idxs[scatt_id] >= 0)
-+        return -1;
-+    if(!scatt_data->b_conds_arr && cats->type == SC_SCATT_CONDITIONS)
-+        return -1;
-+    if(!scatt_data->scatt_vals_arr && cats->type == SC_SCATT_DATA)
-+        return -1;
-+    n_a_scatts = scatts->n_a_scatts;
-+    scatts->scatt_idxs[scatt_id] = n_a_scatts;
-+    I_id_scatt_to_bands(scatt_id, cats->n_bands, &band_1, &band_2);
-+    scatts->scatts_bands[n_a_scatts * 2] = band_1;
-+    scatts->scatts_bands[n_a_scatts * 2 + 1] = band_2;
-+    scatts->scatts_arr[n_a_scatts] = scatt_data;
-+    ++scatts->n_a_scatts;
-+    return 0;
-+#if 0
-+int I_sc_remove_scatt_data(struct scCats * cats, struct scdScattData * scatt_data, int cat_id, int scatt_id)
-+    int cat_idx, scatt_idx, n_init_scatts, i_scatt;
-+    if(cat_id < 0 && cat_id >= cats->n_cats)
-+        return -1;
-+    if(cat_idx < 0)
-+        return -1;
-+    if(scatt_id < 0 || scatt_id >= cats->n_scatts)
-+        return -1;
-+    if(scatts->scatt_idxs[scatt_id] < 0)
-+        return -1;
-+    scatt_data = scatts->scatts_arr[scatt_idx];
-+    for(i_scatt = scatt_idx; i_scatt < scatts->n_a_scatts - 1; i_scatt++)
-+        scatts->scatts_arr[i_scatt] = scatts->scatts_arr[i_scatt + 1];
-+        scatts->scatts_bands[i_scatt * 2] = scatts->scatts_bands[(i_scatt + 1)* 2];
-+        scatts->scatts_bands[i_scatt * 2 + 1] = scatts->scatts_bands[(i_scatt + 1) * 2 + 1];
-+    scatts->scatts_arr[scatts->n_a_scatts] = NULL;
-+    scatts->scatt_idxs[scatt_id] = -1;
-+    scatt_data = scatts->scatts_arr[scatt_id];
-+    scatts->n_a_scatts--;
-+    return 0;
-+int I_sc_set_value(struct scCats * cats, int cat_id, int scatt_id, int value_idx, int value)
-+    int n_a_scatts = cats->cats_arr[cat_id]->n_a_scatts;
-+    int cat_idx, scatt_idx, ret;
-+    if(cat_idx < 0)
-+        return -1;
-+    if(cats->cats_arr[cat_idx]->scatt_idxs[scatt_id] < 0)
-+        return -1;
-+    scatt_idx = cats->cats_arr[cat_idx]->scatt_idxs[scatt_id];
-+    I_scd_set_value(cats->cats_arr[cat_idx]->scatts_arr[scatt_idx], value_idx, value);
-+    return 0;
-+#endif
-+   \brief Insert scatter plot data.
-+   \param scatt_data pointer to existing struct scdScattData
-+   \param type SC_SCATT_DATA for scatter plots or SC_SCATT_CONDITIONS for selected areas in scatter plot
-+   \param n_vals number of data values
-+   \param data array of values (unsigned char for SC_SCATT_CONDITIONS, unsigned int for SC_SCATT_DATA)
-+void I_scd_init_scatt_data(struct scdScattData * scatt_data, int type, int n_vals, void * data)
-+    scatt_data->n_vals = n_vals;
-+    if(type == SC_SCATT_DATA)
-+        if(data)
-+            scatt_data->scatt_vals_arr = (unsigned int *) data;
-+        else {
-+            scatt_data->scatt_vals_arr = (unsigned int *) G_malloc(n_vals * sizeof(unsigned int));
-+            memset(scatt_data->scatt_vals_arr, 0, n_vals * sizeof(unsigned int));
-+        scatt_data->b_conds_arr = NULL;
-+    else if(type == SC_SCATT_CONDITIONS)
-+        if(data)
-+            scatt_data->b_conds_arr = (unsigned char *) data;
-+        else {
-+            scatt_data->b_conds_arr = (unsigned char *) G_malloc(n_vals * sizeof(unsigned char));
-+            memset(scatt_data->b_conds_arr, 0, n_vals * sizeof(unsigned char));
-+        scatt_data->scatt_vals_arr = NULL;
-+    return;
-+#if 0
-+void I_scd_get_range_min_max(struct scdScattData * scatt_data, CELL * band_1_min, CELL * band_1_max, CELL * band_2_min, CELL * band_2_max)
-+    Rast_get_range_min_max(&(scatt_data->band_1_range), band_1_min, band_2_min);
-+    Rast_get_range_min_max(&(scatt_data->band_2_range), band_2_min, band_2_max);
-+    return;
-+s
-+void * I_scd_get_data_ptr(struct scdScattData * scatt_data)
-+    if(!scatt_data->b_conds_arr)
-+        return scatt_data->b_conds_arr;
-+    else if(!scatt_data->scatt_vals_arr)
-+        return scatt_data->scatt_vals_arr;
-+    return NULL;
-+int I_scd_set_value(struct scdScattData * scatt_data, unsigned int val_idx, unsigned int val)
-+    if(val_idx < 0 && val_idx >  scatt_data->n_vals)
-+        return -1;
-+    if(scatt_data->b_conds_arr)
-+        scatt_data->b_conds_arr[val_idx] = val;
-+    else if(scatt_data->scatt_vals_arr)
-+        scatt_data->scatt_vals_arr[val_idx] = val;
-+    else
-+        return -1;
-+    return 0;
-+#endif
 Index: lib/imagery/scatt.c
 --- lib/imagery/scatt.c	(revision 0)
@@ -1227,70 +802,434 @@
 +    return 0;
-Index: include/imagery.h
+Index: lib/imagery/scatt_sccats.c
---- include/imagery.h	(revision 57633)
-+++ include/imagery.h	(working copy)
-@@ -135,6 +135,56 @@
- } IClass_statistics;
-+/* Scatter Plot backend */
+--- lib/imagery/scatt_sccats.c	(revision 0)
++++ lib/imagery/scatt_sccats.c	(working copy)
+@@ -0,0 +1,405 @@
++   \file lib/imagery/scatt_cat_rast.c
-+#define SC_SCATT_DATA          0
-+#define SC_SCATT_CONDITIONS    1
++   \brief Imagery library - functions for manipulation with scatter plot structs.
++   Copyright (C) 2013 by the GRASS Development Team
-+/*! Holds list of all catagories.
-+    It can contain selected areas for scatter plots (SC_SCATT_CONDITIONS type) or computed scatter plots (SC_SCATT_DATA type).
-+struct scCats
++   This program is free software under the GNU General Public License
++   (>=v2).  Read the file COPYING that comes with GRASS for details.
++   \author Stepan Turek <stepan.turek at seznam.cz> (Mentor: Martin Landa)
++#include <grass/raster.h>
++#include <grass/imagery.h>
++#include <grass/gis.h>
++#include <stdio.h>
++#include <stdlib.h>
++#include <math.h>
++#include <string.h>
++   \brief Compute band ids from scatter plot id.
++    Scatter plot id describes which bands defines the scatter plot.
++    Let say we have 3 bands, their ids are 0, 1 and 2.
++    Scatter plot with id 0 consists of band 1 (b_1_id) 0 and  band 2 (b_2_id) 1.
++    All scatter plots:
++    scatt_id b_1_id b_2_id
++    0        0      1
++    1        0      2
++    2        1      2
++   \param scatt_id scatter plot id
++   \param n_bands number of bands
++   \param [out] b_1_id id of band1
++   \param[out] b_2_id id of band2
++   \return 0
++int I_id_scatt_to_bands(const int scatt_id, const int n_bands, int * b_1_id, int * b_2_id)
++    int n_b1 = n_bands - 1;
++    * b_1_id = (int) ((2 * n_b1 + 1 - sqrt((double)((2 * n_b1 + 1) * (2 * n_b1 + 1) - 8 * scatt_id))) / 2);
++    * b_2_id = scatt_id - ((* b_1_id) * (2 * n_b1 + 1) - (* b_1_id) * (* b_1_id)) / 2 + (* b_1_id) + 1;
++    return 0;
++   \brief Compute scatter plot id from band ids.
++    See also I_id_scatt_to_bands().
++   \param b_1_id id of band1
++   \param b_1_id id of band2
++   \param [out] scatt_id scatter plot id
++   \return 0
++int I_bands_to_id_scatt(const int b_1_id, const int b_2_id, const int n_bands, int * scatt_id)
++    * scatt_id = (b_1_id * (2 * n_b1 + 1) - b_1_id * b_1_id) / 2 + b_2_id - b_1_id - 1;
++    return 0;
++   \brief Initialize structure for storing scatter plots data.
++   \param cats pointer to scCats struct
++   \param type SC_SCATT_DATA - stores scatter plots
++   \param type SC_SCATT_CONDITIONS - stores selected areas in scatter plots
++void I_sc_init_cats(struct scCats * cats, int n_bands, int type)
-+    int type;        /*!< SC_SCATT_DATA -> computed scatter plots, SC_SCATT_CONDITIONS -> set conditions for scatter plots to be computed*/
++    int i_cat;
-+    int n_cats;      /*!< number of alocated categories */
++    cats->type = type;
++    cats->n_cats = 100;
++    cats->n_a_cats = 0;
++    cats->n_bands = n_bands;
++    cats->n_scatts = (n_bands - 1) * n_bands / 2;
++    cats->cats_arr = (struct scScatts **) G_malloc(cats->n_cats * sizeof(struct scScatts *));
++    memset(cats->cats_arr, 0, cats-> n_cats * sizeof(struct scScatts *));
++    cats->cats_ids = (int *)  G_malloc(cats->n_cats * sizeof(int));
++    cats->cats_idxs =(int *)  G_malloc(cats->n_cats * sizeof(int));
++    for(i_cat = 0; i_cat < cats->n_cats; i_cat++)
++        cats->cats_idxs[i_cat] = -1;
++    return;
++   \brief Free data of struct scCats, the structure itself remains alocated.
++   \param cats pointer to existing scCats struct
++void I_sc_free_cats(struct scCats * cats)
++    int i_cat;
++    for(i_cat = 0; i_cat < cats->n_a_cats; i_cat++)
++        if(cats->cats_arr[i_cat])
++            G_free(cats->cats_arr[i_cat]->scatt_idxs);
++            G_free(cats->cats_arr[i_cat]->scatts_bands);
++            G_free(cats->cats_arr[i_cat]->scatts_arr);
++            G_free(cats->cats_arr[i_cat]);
++    G_free(cats->cats_ids);
++    G_free(cats->cats_idxs);
++    G_free(cats->cats_arr);
++    cats->n_cats = 0;
++    cats->n_bands = 0;
++    cats->n_scatts = 0;
++    cats->type = -1;
++    return;
++#if 0
++void I_sc_get_active_categories(int * a_cats_ids, int * n_a_cats, struct scCats * cats)
++    a_cats_ids = cats->cats_ids;
++    * n_a_cats = cats->n_a_cats;
++#endif
++   \brief Add category.
-+    int n_bands;     /*!< number of analyzed bands */
-+    int n_scatts;    /*!< number of possible scattter plot which can be created from bands */
++    Category represents group of scatter plots.
-+    int   n_a_cats;  /*!< number of used/active categories */
-+    int * cats_ids;  /*!< (cat_idx->cat_id) array index is internal idx (position in cats_arr) and id is saved in it's position*/
-+    int * cats_idxs; /*!< (cat_id->cat_idx) array index is id and internal idx is saved in it's position*/
-+    struct scScatts ** cats_arr; /*!< array of pointers to struct scScatts */
++   \return assigned category id (starts with 0)
++   \return -1 if maximum nuber of categories was reached
++int I_sc_add_cat(struct scCats * cats)
++    int i_scatt, i_cat_id, cat_id;
++    int n_a_cats = cats->n_a_cats;
++    if(cats->n_a_cats >= cats->n_cats)
++        return -1;
-+/*! Holds list of all scatter plots, which belongs to category.
-+struct scScatts
++    for(i_cat_id = 0; i_cat_id < cats->n_cats; i_cat_id++)
++        if(cats->cats_idxs[i_cat_id] < 0) {
++            cat_id = i_cat_id;
++            break;
++    cats->cats_ids[n_a_cats] = cat_id;
++    cats->cats_idxs[cat_id] = n_a_cats;
++    cats->cats_arr[n_a_cats] = (struct scScatts *) G_malloc(sizeof(struct scScatts));
++    cats->cats_arr[n_a_cats]->scatts_arr = (struct scdScattData **) G_malloc(cats->n_scatts * sizeof(struct scdScattData *));
++    memset((cats->cats_arr[n_a_cats]->scatts_arr), 0, cats->n_scatts * sizeof(struct scdScattData *));
++    cats->cats_arr[n_a_cats]->n_a_scatts = 0;
++    cats->cats_arr[n_a_cats]->scatts_bands = (int *) G_malloc(cats->n_scatts * 2 * sizeof(int));
++    cats->cats_arr[n_a_cats]->scatt_idxs = (int *) G_malloc(cats->n_scatts * sizeof(int));
++    for(i_scatt = 0; i_scatt < cats->n_scatts; i_scatt++)
++        cats->cats_arr[n_a_cats]->scatt_idxs[i_scatt] = -1;
++    ++cats->n_a_cats;
++    return cat_id;
++#if 0
++int I_sc_delete_cat(struct scCats * cats, int cat_id)
-+    int n_a_scatts;     /*!< number of used/active scatter plots*/
++    int cat_idx, i_cat;
++    if(cat_id < 0 || cat_id >= cats->n_cats)
++        return -1;
++    cat_idx = cats->cats_idxs[cat_id];
++    if(cat_idx < 0)
++        return -1;
++    G_free(cats->cats_arr[cat_idx]->scatt_idxs);
++    G_free(cats->cats_arr[cat_idx]->scatts_bands);
++    G_free(cats->cats_arr[cat_idx]->scatts_arr);
++    G_free(cats->cats_arr[cat_idx]);
++    for(i_cat = cat_idx; i_cat < cats->n_a_cats - 1; i_cat++)
++        cats->cats_arr[i_cat] = cats->cats_arr[i_cat + 1];
++        cats->cats_ids[i_cat] = cats->cats_ids[i_cat + 1];
++    cats->cats_idxs[cat_id] = -1;
++    --cats->n_a_cats;
-+    int * scatts_bands; /*!< array of bands for which represents the scatter plots,
-+                             every scatter plot has assigned two bads (size of array is n_a_scatts * 2)*/
-+    int * scatt_idxs;   /*!< (scatt_id->scatt_idx) internal idx of the scatter plot (position in scatts_arr)*/
++    return 0;
++#endif
-+    struct scdScattData ** scatts_arr; /*!< array of pointers to scdScattData */
++   \brief Insert scatter plot data .
++    Inserted scatt_data struct must have same type as cats struct (SC_SCATT_DATA or SC_SCATT_CONDITIONS).
-+/*! Holds scatter plot data.
-+struct scdScattData
++   \param cat_id id number of category.
++   \param scatt_id id number of scatter plot.
++   \return  0 on success
++   \return -1 on failure
++int I_sc_insert_scatt_data(struct scCats * cats, struct scdScattData * scatt_data, int cat_id, int scatt_id)
-+    int n_vals; /*!< Number of values in scatter plot. */
++    int band_1, band_2, cat_idx, n_a_scatts;
++    struct scScatts * scatts;
-+    unsigned char  * b_conds_arr; /*!< array of selected areas (used for SC_SCATT_CONDITIONS type) otherwise NULL */
-+    unsigned int  * scatt_vals_arr; /*!< array of computed areas (used for SC_SCATT_DATA type) otherwise NULL */
++        return -1;
++    if(cat_idx < 0)
++        return -1;
- #define SIGNATURE_TYPE_MIXED 1
- #define GROUPFILE "CURGROUP"
++    if(scatt_id < 0 && scatt_id >= cats->n_scatts)
++        return -1;
++    scatts = cats->cats_arr[cat_idx];
++    if(scatts->scatt_idxs[scatt_id] >= 0)
++        return -1;
++    if(!scatt_data->b_conds_arr && cats->type == SC_SCATT_CONDITIONS)
++        return -1;
++    if(!scatt_data->scatt_vals_arr && cats->type == SC_SCATT_DATA)
++        return -1;
++    n_a_scatts = scatts->n_a_scatts;
++    scatts->scatt_idxs[scatt_id] = n_a_scatts;
++    I_id_scatt_to_bands(scatt_id, cats->n_bands, &band_1, &band_2);
++    scatts->scatts_bands[n_a_scatts * 2] = band_1;
++    scatts->scatts_bands[n_a_scatts * 2 + 1] = band_2;
++    scatts->scatts_arr[n_a_scatts] = scatt_data;
++    ++scatts->n_a_scatts;
++    return 0;
++#if 0
++int I_sc_remove_scatt_data(struct scCats * cats, struct scdScattData * scatt_data, int cat_id, int scatt_id)
++    int cat_idx, scatt_idx, n_init_scatts, i_scatt;
++    if(cat_id < 0 && cat_id >= cats->n_cats)
++        return -1;
++    if(cat_idx < 0)
++        return -1;
++    if(scatt_id < 0 || scatt_id >= cats->n_scatts)
++        return -1;
++    if(scatts->scatt_idxs[scatt_id] < 0)
++        return -1;
++    scatt_data = scatts->scatts_arr[scatt_idx];
++    for(i_scatt = scatt_idx; i_scatt < scatts->n_a_scatts - 1; i_scatt++)
++        scatts->scatts_arr[i_scatt] = scatts->scatts_arr[i_scatt + 1];
++        scatts->scatts_bands[i_scatt * 2] = scatts->scatts_bands[(i_scatt + 1)* 2];
++        scatts->scatts_bands[i_scatt * 2 + 1] = scatts->scatts_bands[(i_scatt + 1) * 2 + 1];
++    scatts->scatts_arr[scatts->n_a_scatts] = NULL;
++    scatts->scatt_idxs[scatt_id] = -1;
++    scatt_data = scatts->scatts_arr[scatt_id];
++    scatts->n_a_scatts--;
++    return 0;
++int I_sc_set_value(struct scCats * cats, int cat_id, int scatt_id, int value_idx, int value)
++    int n_a_scatts = cats->cats_arr[cat_id]->n_a_scatts;
++    int cat_idx, scatt_idx, ret;
++    if(cat_idx < 0)
++        return -1;
++    if(cats->cats_arr[cat_idx]->scatt_idxs[scatt_id] < 0)
++        return -1;
++    scatt_idx = cats->cats_arr[cat_idx]->scatt_idxs[scatt_id];
++    I_scd_set_value(cats->cats_arr[cat_idx]->scatts_arr[scatt_idx], value_idx, value);
++    return 0;
++#endif
++   \brief Insert scatter plot data.
++   \param scatt_data pointer to existing struct scdScattData
++   \param type SC_SCATT_DATA for scatter plots or SC_SCATT_CONDITIONS for selected areas in scatter plot
++   \param n_vals number of data values
++   \param data array of values (unsigned char for SC_SCATT_CONDITIONS, unsigned int for SC_SCATT_DATA)
++void I_scd_init_scatt_data(struct scdScattData * scatt_data, int type, int n_vals, void * data)
++    scatt_data->n_vals = n_vals;
++    if(type == SC_SCATT_DATA)
++        if(data)
++            scatt_data->scatt_vals_arr = (unsigned int *) data;
++        else {
++            scatt_data->scatt_vals_arr = (unsigned int *) G_malloc(n_vals * sizeof(unsigned int));
++            memset(scatt_data->scatt_vals_arr, 0, n_vals * sizeof(unsigned int));
++        scatt_data->b_conds_arr = NULL;
++    else if(type == SC_SCATT_CONDITIONS)
++        if(data)
++            scatt_data->b_conds_arr = (unsigned char *) data;
++        else {
++            scatt_data->b_conds_arr = (unsigned char *) G_malloc(n_vals * sizeof(unsigned char));
++            memset(scatt_data->b_conds_arr, 0, n_vals * sizeof(unsigned char));
++        scatt_data->scatt_vals_arr = NULL;
++    return;
++#if 0
++void I_scd_get_range_min_max(struct scdScattData * scatt_data, CELL * band_1_min, CELL * band_1_max, CELL * band_2_min, CELL * band_2_max)
++    Rast_get_range_min_max(&(scatt_data->band_1_range), band_1_min, band_2_min);
++    Rast_get_range_min_max(&(scatt_data->band_2_range), band_2_min, band_2_max);
++    return;
++s
++void * I_scd_get_data_ptr(struct scdScattData * scatt_data)
++    if(!scatt_data->b_conds_arr)
++        return scatt_data->b_conds_arr;
++    else if(!scatt_data->scatt_vals_arr)
++        return scatt_data->scatt_vals_arr;
++    return NULL;
++int I_scd_set_value(struct scdScattData * scatt_data, unsigned int val_idx, unsigned int val)
++    if(val_idx < 0 && val_idx >  scatt_data->n_vals)
++        return -1;
++    if(scatt_data->b_conds_arr)
++        scatt_data->b_conds_arr[val_idx] = val;
++    else if(scatt_data->scatt_vals_arr)
++        scatt_data->scatt_vals_arr[val_idx] = val;
++    else
++        return -1;
++    return 0;
++#endif
+Index: lib/vector/Vlib/open.c
+--- lib/vector/Vlib/open.c	(revision 57644)
++++ lib/vector/Vlib/open.c	(working copy)
+@@ -240,7 +240,9 @@
+         else {
+             char file_path[GPATH_MAX];
++            /* reduce to current mapset if search path was set */
++            if(strcmp(Map->mapset, "") == 0)
++                Map->mapset = G_store(G_mapset());
+             /* temporary map: reduce to current mapset if search path
+              * was set */
+             if (strcmp(Map->mapset, "") == 0)
 Index: include/defs/vedit.h
---- include/defs/vedit.h	(revision 57633)
+--- include/defs/vedit.h	(revision 57644)
 +++ include/defs/vedit.h	(working copy)
 @@ -33,6 +33,8 @@
  int Vedit_merge_lines(struct Map_info *, struct ilist *);
@@ -1303,7 +1242,7 @@
 Index: include/defs/imagery.h
---- include/defs/imagery.h	(revision 57633)
+--- include/defs/imagery.h	(revision 57644)
 +++ include/defs/imagery.h	(working copy)
 @@ -110,6 +110,26 @@
  FILE *I_fopen_subgroup_ref_new(const char *, const char *);
@@ -1332,13 +1271,74 @@
  /* sig.c */
  int I_init_signatures(struct Signature *, int);
  int I_new_signature(struct Signature *);
+Index: include/imagery.h
+--- include/imagery.h	(revision 57644)
++++ include/imagery.h	(working copy)
+@@ -135,6 +135,56 @@
+ } IClass_statistics;
++/* Scatter Plot backend */
++#define SC_SCATT_DATA          0
++#define SC_SCATT_CONDITIONS    1
++/*! Holds list of all catagories.
++    It can contain selected areas for scatter plots (SC_SCATT_CONDITIONS type) or computed scatter plots (SC_SCATT_DATA type).
++struct scCats
++    int type;        /*!< SC_SCATT_DATA -> computed scatter plots, SC_SCATT_CONDITIONS -> set conditions for scatter plots to be computed*/
++    int n_cats;      /*!< number of alocated categories */
++    int n_bands;     /*!< number of analyzed bands */
++    int n_scatts;    /*!< number of possible scattter plot which can be created from bands */
++    int   n_a_cats;  /*!< number of used/active categories */
++    int * cats_ids;  /*!< (cat_idx->cat_id) array index is internal idx (position in cats_arr) and id is saved in it's position*/
++    int * cats_idxs; /*!< (cat_id->cat_idx) array index is id and internal idx is saved in it's position*/
++    struct scScatts ** cats_arr; /*!< array of pointers to struct scScatts */
++/*! Holds list of all scatter plots, which belongs to category.
++struct scScatts
++    int n_a_scatts;     /*!< number of used/active scatter plots*/
++    int * scatts_bands; /*!< array of bands for which represents the scatter plots,
++                             every scatter plot has assigned two bads (size of array is n_a_scatts * 2)*/
++    int * scatt_idxs;   /*!< (scatt_id->scatt_idx) internal idx of the scatter plot (position in scatts_arr)*/
++    struct scdScattData ** scatts_arr; /*!< array of pointers to scdScattData */
++/*! Holds scatter plot data.
++struct scdScattData
++    int n_vals; /*!< Number of values in scatter plot. */
++    unsigned char  * b_conds_arr; /*!< array of selected areas (used for SC_SCATT_CONDITIONS type) otherwise NULL */
++    unsigned int  * scatt_vals_arr; /*!< array of computed areas (used for SC_SCATT_DATA type) otherwise NULL */
+ #define SIGNATURE_TYPE_MIXED 1
+ #define GROUPFILE "CURGROUP"
 Index: gui/icons/grass/polygon.png
 Cannot display: file marked as a binary type.
 svn:mime-type = application/octet-stream
---- gui/icons/grass/polygon.png	(revision 57633)
+--- gui/icons/grass/polygon.png	(revision 57644)
 +++ gui/icons/grass/polygon.png	(working copy)
 Property changes on: gui/icons/grass/polygon.png
@@ -1347,158 +1347,558 @@
 ## -0,0 +1 ##
 +application/octet-stream
 \ No newline at end of property
-Index: gui/wxpython/iclass/plots.py
+Index: gui/wxpython/vdigit/wxdigit.py
---- gui/wxpython/iclass/plots.py	(revision 57633)
-+++ gui/wxpython/iclass/plots.py	(working copy)
-@@ -19,6 +19,7 @@
- import wx.lib.plot as plot
- import wx.lib.scrolledpanel as scrolled
- from core.utils import _
-+from core.gcmd import GError
+--- gui/wxpython/vdigit/wxdigit.py	(revision 57644)
++++ gui/wxpython/vdigit/wxdigit.py	(working copy)
+@@ -17,7 +17,7 @@
+ (and NumPy would be an excellent candidate for acceleration via
+ e.g. OpenCL or CUDA; I'm surprised it hasn't happened already).
- class PlotPanel(scrolled.ScrolledPanel):
-     """!Panel for drawing multiple plots.
-@@ -28,7 +29,7 @@
-     for each band and for one category. Coincidence plots show min max range
-     of classes for each band.
--    def __init__(self, parent, stats_data):
-+    def __init__(self, parent, giface, stats_data):
-         scrolled.ScrolledPanel.__init__(self, parent)
-         self.SetupScrolling(scroll_x = False, scroll_y = True)
-@@ -38,26 +39,71 @@
-         self.stats_data = stats_data
-         self.currentCat = None
-+        self._giface = giface
+-(C) 2007-2011 by the GRASS Development Team
++(C) 2007-2011, 2013 by the GRASS Development Team
+@@ -27,6 +27,8 @@
+ import grass.script.core as grass
++from grass.pydispatch.signal import Signal
-         self.mainSizer = wx.BoxSizer(wx.VERTICAL)
+ from core.gcmd        import GError
+ from core.debug       import Debug
+ from core.settings    import UserSettings
+@@ -176,7 +178,21 @@
+         if self.poMapInfo:
+             self.InitCats()
-         self._createControlPanel()
++        self.emit_signals = False
++        # signals which describes features changes during digitization,
++        # activate them using EmitSignals method
++        #TODO signal for errors?
++        self.featureAdded = Signal('IVDigit.featureAdded')
++        self.areasDeleted = Signal('IVDigit.areasDeleted')
++        self.vertexMoved = Signal('IVDigit.vertexMoved')
++        self.vertexAdded = Signal('IVDigit.vertexAdded')
++        self.vertexRemoved = Signal('IVDigit.vertexRemoved')
++        self.featuresDeleted = Signal('IVDigit.featuresDeleted')
++        self.featuresMoved = Signal('IVDigit.featuresMoved')
++        self.lineEdited = Signal('IVDigit.lineEdited')
+     def __del__(self):
+         Debug.msg(1, "IVDigit.__del__()")
+         Vect_destroy_line_struct(self.poPoints)
+@@ -188,7 +204,12 @@
+             Vect_close(self.poBgMapInfo)
+             self.poBgMapInfo = self.popoBgMapInfo = None
+             del self.bgMapInfo
-+        self._createPlotPanel()
-+        self._createScatterPlotPanel()
++    def EmitSignals(self, emit):
++        """!Activate/deactivate signals which describes features changes during digitization.
++        self.emit_signals = emit
-         self.SetSizer(self.mainSizer)
-         self.mainSizer.Fit(self)
-         self.Layout()
+     def CloseBackgroundMap(self):
+         """!Close background vector map"""
+         if not self.poBgMapInfo:
+@@ -394,7 +415,6 @@
+         @return tuple (number of added features, feature ids)
+         layer = self._getNewFeaturesLayer()
+         cat = self._getNewFeaturesCat()
+@@ -419,10 +439,14 @@
+             return (-1, None)
+         self.toolbar.EnableUndo()
+-        return self._addFeature(vtype, points, layer, cat,
+-                                self._getSnapMode(), self._display.GetThreshold())
-+    def _createPlotPanel(self):
++        ret = self._addFeature(vtype, points, layer, cat,
++                               self._getSnapMode(), self._display.GetThreshold())
++        if ret[0] > -1 and self.emit_signals:
++            self.featureAdded.emit(new_bboxs = [self._createBbox(points)], new_areas_cats = [[{layer : [cat]}, None]])
-+        self.canvasPanel = wx.Panel(parent=self)
-+        self.mainSizer.Add(item = self.canvasPanel, proportion = 1, flag = wx.EXPAND, border = 0)
-+        self.canvasSizer = wx.BoxSizer(wx.VERTICAL)
-+        self.canvasPanel.SetSizer(self.canvasSizer)
++        return ret
-     def _createControlPanel(self):
-         self.plotSwitch = wx.Choice(self, id = wx.ID_ANY,
-                                      choices = [_("Histograms"),
--                                                _("Coincident plots")])
-+                                                _("Coincident plots"),
-+                                                _("Scatter plots")])
-         self.mainSizer.Add(self.plotSwitch, proportion = 0, flag = wx.EXPAND|wx.ALL, border = 5)
-         self.plotSwitch.Bind(wx.EVT_CHOICE, self.OnPlotTypeSelected)
+     def DeleteSelectedLines(self):
+         """!Delete selected features
+@@ -434,16 +458,27 @@
+         # collect categories for deleting if requested
+         deleteRec = UserSettings.Get(group = 'vdigit', key = 'delRecord', subkey = 'enabled')
+         catDict = dict()
++        old_bboxs = []
++        old_areas_cats = []
+         if deleteRec:
+             for i in self._display.selected['ids']:
+                 if Vect_read_line(self.poMapInfo, None, self.poCats, i) < 0:
+                     self._error.ReadLine(i)
+-                cats = self.poCats.contents
+-                for j in range(cats.n_cats):
+-                    if cats.field[j] not in catDict.keys():
+-                        catDict[cats.field[j]] = list()
+-                    catDict[cats.field[j]].append(cats.cat[j])
++                if self.emit_signals:
++                    ret = self._getLineAreaBboxCats(i)
++                    if ret:
++                        old_bboxs += ret[0]
++                        old_areas_cats += ret[1]
++                # catDict was not used -> put into comment
++                #cats = self.poCats.contents
++                #for j in range(cats.n_cats):
++                #    if cats.field[j] not in catDict.keys():
++                #        catDict[cats.field[j]] = list()
++                #    catDict[cats.field[j]].append(cats.cat[j])
+         poList = self._display.GetSelectedIList()
+         nlines = Vedit_delete_lines(self.poMapInfo, poList)
+@@ -456,7 +491,10 @@
+                 self._deleteRecords(catDict)
+             self._addChangeset()
-+    def _createScatterPlotPanel(self):
-+        """!Init interactive scatterplot tools
-+        try:
-+            from scatt_plot.frame import IClassScatterPlotsPanel
-+            self.scatt_plot_panel = IClassScatterPlotsPanel(parent=self,
-+                                                            giface=self._giface,
-+                                                            iclass_mapwin = self.parent.GetFirstWindow())
-+            self.mainSizer.Add(self.scatt_plot_panel, proportion = 1, flag = wx.EXPAND, border = 0)
-+            self.scatt_plot_panel.Hide()
-+        except ImportError as e:#TODO
-+            self.scatt_error = _("Scatter plot functionality is disabled. Reason:\n" \
-+                                 "Unable to import packages needed for scatter plot.\n%s" % e)
-+            GError(self.scatt_error)
-+            self.scatt_plot_panel = None
-     def OnPlotTypeSelected(self, event):
-         """!Plot type selected"""
++                self.featuresDeleted.emit(old_bboxs = old_bboxs, old_areas_cats = old_areas_cats)
-+        if self.plotSwitch.GetSelection() in [0, 1]:
-+            self.SetupScrolling(scroll_x = False, scroll_y = True)
-+            if self.scatt_plot_panel:
-+            self.canvasPanel.Show()
-+            self.Layout()
+         return nlines
+     def _deleteRecords(self, cats):
+@@ -512,22 +550,173 @@
+         @return number of deleted
++        if len(self._display.selected['ids']) < 1:
++            return 0
+         cList  = poList.contents
+         nareas = 0
++        old_bboxs = []
-+        elif self.plotSwitch.GetSelection() == 2:
-+            self.SetupScrolling(scroll_x = False, scroll_y = False)
-+                self.scatt_plot_panel.Show()
+         for i in range(cList.n_values):
+             if Vect_get_line_type(self.poMapInfo, cList.value[i]) != GV_CENTROID:
+                 continue
++                area = Vect_get_centroid_area(self.poMapInfo, cList.value[i]);
++                if area > 0:
++                    bbox, cats = self._getaAreaBboxCats(area)
++                    old_bboxs += bbox
++                    old_areas_cats += cats
+             nareas += Vedit_delete_area_centroid(self.poMapInfo, cList.value[i])
+         if nareas > 0:
++                self.areasDeleted.emit(old_bboxs = old_bboxs, old_areas_cats = old_areas_cats)
++        return nareas
++    def _getLineAreaBboxCats(self, ln_id):
++        ltype = Vect_read_line(self.poMapInfo, None, None, ln_id)
++        if ltype == GV_CENTROID:
++            #TODO centroid opttimization, can be adited also its area -> it will appear two times in new_ lists
++            return self._getCentroidAreaBboxCats(ln_id)
++        else:
++            return [self._getBbox(ln_id)], [self._getLineAreasCategories(ln_id)]
++    def _getCentroidAreaBboxCats(self, centroid):
++        if not Vect_line_alive(self.poMapInfo, centroid):
++            return None
++        area = Vect_get_centroid_area(self.poMapInfo, centroid)
++        if area > 0:
++            return self._getaAreaBboxCats(area)
++        else:
++            return None
++    def _getaAreaBboxCats(self, area):
++        po_b_list = Vect_new_list()
++        Vect_get_area_boundaries(self.poMapInfo, area, po_b_list);
++        b_list = po_b_list.contents
++        geoms = []
++        areas_cats = []
++        if b_list.n_values > 0:
++            for i_line in range(b_list.n_values):
++                line = b_list.value[i_line];
++                geoms.append(self._getBbox(abs(line)))
++                areas_cats.append(self._getLineAreasCategories(abs(line)))
+-        return nareas
++        Vect_destroy_list(po_b_list);
++        return geoms, areas_cats
++    def _getLineAreasCategories(self, ln_id):
++        if not Vect_line_alive (self.poMapInfo, ln_id):
++            return []
++        if ltype != GV_BOUNDARY:
++            return []
++        cats = [None, None]
++        left = c_int()
++        right = c_int()
++        if Vect_get_line_areas(self.poMapInfo, ln_id, pointer(left), pointer(right)) == 1:
++            areas = [left.value, right.value]
++            for i, a in enumerate(areas):
++                if a > 0:
++                    centroid = Vect_get_area_centroid(self.poMapInfo, a)
++                    if centroid <= 0:
++                        continue
++                    c = self._getCategories(centroid)
++                    if c:
++                        cats[i] = c
++        return cats
++    def _getCategories(self, ln_id):
++            return none
++        poCats = Vect_new_cats_struct()
++        if Vect_read_line(self.poMapInfo, None, poCats, ln_id) < 0:
++            Vect_destroy_cats_struct(poCats)
++            return None
++        cCats = poCats.contents
++        cats = {}
++        for j in range(cCats.n_cats):
++            if cats.has_key(cCats.field[j]):
++                cats[cCats.field[j]].append(cCats.cat[j])
 +            else:
-+            self.canvasPanel.Hide()
-+            self.Layout()
++                cats[cCats.field[j]] = [cCats.cat[j]]
++        return cats
-         if self.currentCat is None:
-             return
++    def _getBbox(self, ln_id):
++            return None
-         if self.plotSwitch.GetSelection() == 0:
-             stat = self.stats_data.GetStatistics(self.currentCat)
-             if not stat.IsReady():
-@@ -66,7 +112,10 @@
-             self.DrawHistograms(stat)
-         else:
-             self.DrawCoincidencePlots()
++        poPoints = Vect_new_line_struct()
++        if Vect_read_line(self.poMapInfo, poPoints, None, ln_id) < 0:
++            Vect_destroy_line_struct(poPoints)
++            return []
-+        self.Layout()
++        geom = self._convertGeom(poPoints)
++        bbox = self._createBbox(geom)
++        return bbox
++    def _createBbox(self, points):
-     def StddevChanged(self):
-         """!Standard deviation multiplier changed, redraw histograms"""
-@@ -89,7 +138,7 @@
-             panel.Destroy()
-         self.canvasList = []
++        bbox = {}
++        for pt in points:
++            if not bbox.has_key('maxy'):
++                bbox['maxy'] = pt[1]
++                bbox['miny'] = pt[1]
++                bbox['maxx'] = pt[0]
++                bbox['minx'] = pt[0]
++                continue
++            if   bbox['maxy'] < pt[1]:
++            elif bbox['miny'] > pt[1]:
++            if   bbox['maxx'] < pt[0]:
++            elif bbox['minx'] > pt[0]:
++        return bbox
-     def ClearPlots(self):
-         """!Clears plot canvases"""
-         for bandIdx in range(len(self.bandList)):
-@@ -104,15 +153,15 @@
-     def CreatePlotCanvases(self):
-         """!Create plot canvases according to the number of bands"""
-         for band in self.bandList:
--            canvas = plot.PlotCanvas(self)
-+            canvas = plot.PlotCanvas(self.canvasPanel)
-             canvas.SetMinSize((-1, 140))
-             canvas.SetFontSizeTitle(10)
-             canvas.SetFontSizeAxis(8)
-             self.canvasList.append(canvas)
--            self.mainSizer.Add(item = canvas, proportion = 1, flag = wx.EXPAND, border = 0)
--        self.SetVirtualSize(self.GetBestVirtualSize())
-+            self.canvasSizer.Add(item = canvas, proportion = 1, flag = wx.EXPAND, border = 0)
++    def _convertGeom(self, poPoints):
++        Points = poPoints.contents
++        pts_geom = []
++        for j in range(Points.n_points):
++            pts_geom.append((Points.x[j], Points.y[j]))
++        return pts_geom
+     def MoveSelectedLines(self, move):
+         """!Move selected features
+@@ -536,16 +725,45 @@
+         if not self._checkMap():
+             return -1
++        nsel = len(self._display.selected['ids'])
++        if nsel < 1:
++            return -1
-+        self.SetVirtualSize(self.GetBestVirtualSize())
-         self.Layout()
+         thresh = self._display.GetThreshold()
+         snap   = self._getSnapMode()
-     def UpdatePlots(self, group, currentCat, stats_data):
-@@ -138,7 +187,7 @@
++            old_bboxs = []
++            for sel_id in self._display.selected['ids']:
++                ret = self._getLineAreaBboxCats(sel_id)
++                if ret:
++            Vect_set_updated(self.poMapInfo, 1)
++            n_up_lines_old = Vect_get_num_updated_lines(self.poMapInfo)
+         nlines = Vedit_move_lines(self.poMapInfo, self.popoBgMapInfo, int(self.poBgMapInfo is not None),
+                                   poList,
+                                   move[0], move[1], 0,
+                                   snap, thresh)
+         Vect_destroy_list(poList)
++        if nlines > 0 and self.emit_signals:
++            new_bboxs = []
++            new_areas_cats = []
++            n_up_lines = Vect_get_num_updated_lines(self.poMapInfo)
++            for i in range(n_up_lines_old, n_up_lines):
++                new_id = Vect_get_updated_line(self.poMapInfo, i)
++                ret = self._getLineAreaBboxCats(new_id)
++                if ret:
++                    new_bboxs += ret[0]
++                    new_areas_cats += ret[1]
+         if nlines > 0 and self._settings['breakLines']:
+             for i in range(1, nlines):
+                 self._breakLineAtIntersection(nlines + i, None, changeset)
+@@ -553,7 +771,13 @@
+         if nlines > 0:
++                self.featuresMoved.emit(new_bboxs = new_bboxs,
++                                        old_bboxs = old_bboxs,
++                                        old_areas_cats = old_areas_cats,
++                                        new_areas_cats = new_areas_cats)
+         return nlines
+     def MoveSelectedVertex(self, point, move):
+@@ -571,12 +795,21 @@
-     def UpdateCategory(self, cat):
-         self.currentCat = cat
+         if len(self._display.selected['ids']) != 1:
+             return -1
++        # move only first found vertex in bbox
++        poList = self._display.GetSelectedIList()
++            cList = poList.contents
++            old_bboxs = [self._getBbox(cList.value[0])]
++            old_areas_cats = [self._getLineAreasCategories(cList.value[0])]
+         Vect_reset_line(self.poPoints)
+         Vect_append_point(self.poPoints, point[0], point[1], 0.0)
+-        # move only first found vertex in bbox
+-        poList = self._display.GetSelectedIList()
+         moved = Vedit_move_vertex(self.poMapInfo, self.popoBgMapInfo, int(self.poBgMapInfo is not None),
+                                   poList, self.poPoints,
+                                   self._display.GetThreshold(type = 'selectThresh'),
+@@ -584,7 +817,17 @@
+                                   move[0], move[1], 0.0,
+                                   1, self._getSnapMode())
++        if moved > 0 and self.emit_signals:
++            new_bboxs = []
++                new_bboxs.append(self._getBbox(new_id))
++                new_areas_cats.append(self._getLineAreasCategories(new_id))
+         if moved > 0 and self._settings['breakLines']:
+             self._breakLineAtIntersection(Vect_get_num_lines(self.poMapInfo),
+                                           None)
+@@ -592,7 +835,13 @@
+         if moved > 0:
++                self.vertexMoved.emit(new_bboxs = new_bboxs,
++                                      new_areas_cats = new_areas_cats,
++                                      old_bboxs = old_bboxs)
+         return moved
+     def AddVertex(self, coords):
+@@ -681,6 +930,10 @@
+             self._error.ReadLine(line)
+             return -1
++            old_bboxs = [self._getBbox(line)]
++            old_areas_cats = [self._getLineAreasCategories(line)]
+         # build feature geometry
+         for p in coords:
+@@ -696,6 +949,9 @@
+         newline = Vect_rewrite_line(self.poMapInfo, line, ltype,
+                                     self.poPoints, self.poCats)
++        if newline > 0 and self.emit_signals:
++            new_geom = [self._getBbox(newline)]
++            new_areas_cats = [self._getLineAreasCategories(newline)]
+         if newline > 0 and self._settings['breakLines']:
+             self._breakLineAtIntersection(newline, None)
+@@ -703,7 +959,13 @@
+         if newline > 0:
-     def DrawCoincidencePlots(self):
-         """!Draw coincidence plots"""
++                self.lineEdited.emit(old_bboxs = old_bboxs,
++                                     new_bboxs = new_bboxs,
+         return newline
+     def FlipLine(self):
+@@ -1514,6 +1776,16 @@
+             return 0
+         Vect_append_point(self.poPoints, coords[0], coords[1], 0.0)
+@@ -1525,15 +1797,35 @@
+         else:
+             ret = Vedit_remove_vertex(self.poMapInfo, poList,
+                                       self.poPoints, thresh)
++        if ret > 0 and self.emit_signals:
++            new_bboxs = []
+         if not add and ret > 0 and self._settings['breakLines']:
+                                           None)
+         if ret > 0:
++            if add:
++                self.vertexAdded.emit(old_bboxs = old_bboxs, new_bboxs = new_bboxs)
++            else:
++                self.vertexRemoved.emit(old_bboxs = old_bboxs,
+         return 1
+     def GetLineCats(self, line):
+Index: gui/wxpython/vdigit/toolbars.py
+--- gui/wxpython/vdigit/toolbars.py	(revision 57644)
++++ gui/wxpython/vdigit/toolbars.py	(working copy)
+@@ -17,6 +17,7 @@
+ import wx
+ from grass.script import core as grass
+ from gui_core.toolbars  import BaseToolbar, BaseIcons
+ from gui_core.dialogs   import CreateNewVector
+@@ -42,6 +43,8 @@
+         self.digit         = None
++        self.editingStarted = Signal("VDigitToolbar.editingStarted")
+         # currently selected map layer for editing (reference to MapLayer instance)
+         self.mapLayer = None
+         # list of vector layers from Layer Manager (only in the current mapset)
+@@ -860,6 +863,7 @@
+             alpha = int(opacity * 255)
+             self.digit.GetDisplay().UpdateSettings(alpha = alpha)
++        self.editingStarted.emit(vectMap = mapLayer.GetName(), digit = self.digit)
+         return True
+     def StopEditing(self):
 Index: gui/wxpython/iclass/dialogs.py
---- gui/wxpython/iclass/dialogs.py	(revision 57633)
+--- gui/wxpython/iclass/dialogs.py	(revision 57644)
 +++ gui/wxpython/iclass/dialogs.py	(working copy)
 @@ -333,13 +333,19 @@
          toolbar.SetCategories(catNames = catNames, catIdx = cats)
@@ -1523,7 +1923,7 @@
      def GetSelectedIndices(self, state =  wx.LIST_STATE_SELECTED):
 Index: gui/wxpython/iclass/toolbars.py
---- gui/wxpython/iclass/toolbars.py	(revision 57633)
+--- gui/wxpython/iclass/toolbars.py	(revision 57644)
 +++ gui/wxpython/iclass/toolbars.py	(working copy)
 @@ -46,9 +46,7 @@
          'importAreas' : MetaIcon(img = 'layer-import',
@@ -1559,7 +1959,7 @@
                                        self.parent.OnCategoryManager),
 Index: gui/wxpython/iclass/frame.py
---- gui/wxpython/iclass/frame.py	(revision 57633)
+--- gui/wxpython/iclass/frame.py	(revision 57644)
 +++ gui/wxpython/iclass/frame.py	(working copy)
 @@ -64,6 +64,8 @@
                                 IClassExportAreasDialog, IClassMapDialog
@@ -1815,9 +2215,158 @@
  def test():
      import core.render as render
+Index: gui/wxpython/iclass/plots.py
+--- gui/wxpython/iclass/plots.py	(revision 57644)
++++ gui/wxpython/iclass/plots.py	(working copy)
+@@ -19,6 +19,7 @@
+ import wx.lib.plot as plot
+ import wx.lib.scrolledpanel as scrolled
+ from core.utils import _
++from core.gcmd import GError
+ class PlotPanel(scrolled.ScrolledPanel):
+     """!Panel for drawing multiple plots.
+@@ -28,7 +29,7 @@
+     for each band and for one category. Coincidence plots show min max range
+     of classes for each band.
+-    def __init__(self, parent, stats_data):
++    def __init__(self, parent, giface, stats_data):
+         scrolled.ScrolledPanel.__init__(self, parent)
+@@ -38,26 +39,71 @@
+         self.stats_data = stats_data
+         self.currentCat = None
++        self._giface = giface
+         self.mainSizer = wx.BoxSizer(wx.VERTICAL)
+         self._createControlPanel()
++        self._createPlotPanel()
++        self._createScatterPlotPanel()
+         self.SetSizer(self.mainSizer)
+         self.mainSizer.Fit(self)
+         self.Layout()
++    def _createPlotPanel(self):
++        self.canvasPanel = wx.Panel(parent=self)
++        self.mainSizer.Add(item = self.canvasPanel, proportion = 1, flag = wx.EXPAND, border = 0)
++        self.canvasSizer = wx.BoxSizer(wx.VERTICAL)
++        self.canvasPanel.SetSizer(self.canvasSizer)
+     def _createControlPanel(self):
+         self.plotSwitch = wx.Choice(self, id = wx.ID_ANY,
+                                      choices = [_("Histograms"),
+-                                                _("Coincident plots")])
++                                                _("Coincident plots"),
++                                                _("Scatter plots")])
+         self.mainSizer.Add(self.plotSwitch, proportion = 0, flag = wx.EXPAND|wx.ALL, border = 5)
+         self.plotSwitch.Bind(wx.EVT_CHOICE, self.OnPlotTypeSelected)
++    def _createScatterPlotPanel(self):
++        """!Init interactive scatterplot tools
++        try:
++            from scatt_plot.frame import IClassScatterPlotsPanel
++            self.scatt_plot_panel = IClassScatterPlotsPanel(parent=self,
++                                                            giface=self._giface,
++                                                            iclass_mapwin = self.parent.GetFirstWindow())
++            self.mainSizer.Add(self.scatt_plot_panel, proportion = 1, flag = wx.EXPAND, border = 0)
++            self.scatt_plot_panel.Hide()
++        except ImportError as e:#TODO
++            self.scatt_error = _("Scatter plot functionality is disabled. Reason:\n" \
++                                 "Unable to import packages needed for scatter plot.\n%s" % e)
++            GError(self.scatt_error)
++            self.scatt_plot_panel = None
+     def OnPlotTypeSelected(self, event):
+         """!Plot type selected"""
++        if self.plotSwitch.GetSelection() in [0, 1]:
++            self.SetupScrolling(scroll_x = False, scroll_y = True)
++            if self.scatt_plot_panel:
++            self.canvasPanel.Show()
++            self.Layout()
++        elif self.plotSwitch.GetSelection() == 2:
++            self.SetupScrolling(scroll_x = False, scroll_y = False)
++                self.scatt_plot_panel.Show()
++            else:
++            self.canvasPanel.Hide()
++            self.Layout()
+         if self.currentCat is None:
+             return
+         if self.plotSwitch.GetSelection() == 0:
+             stat = self.stats_data.GetStatistics(self.currentCat)
+             if not stat.IsReady():
+@@ -66,7 +112,10 @@
+             self.DrawHistograms(stat)
+         else:
+             self.DrawCoincidencePlots()
++        self.Layout()
+     def StddevChanged(self):
+         """!Standard deviation multiplier changed, redraw histograms"""
+@@ -89,7 +138,7 @@
+             panel.Destroy()
+         self.canvasList = []
+     def ClearPlots(self):
+         """!Clears plot canvases"""
+         for bandIdx in range(len(self.bandList)):
+@@ -104,15 +153,15 @@
+     def CreatePlotCanvases(self):
+         """!Create plot canvases according to the number of bands"""
+         for band in self.bandList:
+-            canvas = plot.PlotCanvas(self)
++            canvas = plot.PlotCanvas(self.canvasPanel)
+             canvas.SetMinSize((-1, 140))
+             canvas.SetFontSizeTitle(10)
+             canvas.SetFontSizeAxis(8)
+             self.canvasList.append(canvas)
+-            self.mainSizer.Add(item = canvas, proportion = 1, flag = wx.EXPAND, border = 0)
+-        self.SetVirtualSize(self.GetBestVirtualSize())
++            self.canvasSizer.Add(item = canvas, proportion = 1, flag = wx.EXPAND, border = 0)
++        self.SetVirtualSize(self.GetBestVirtualSize())
+         self.Layout()
+     def UpdatePlots(self, group, currentCat, stats_data):
+@@ -138,7 +187,7 @@
+     def UpdateCategory(self, cat):
+         self.currentCat = cat
+     def DrawCoincidencePlots(self):
+         """!Draw coincidence plots"""
 Index: gui/wxpython/mapdisp/toolbars.py
---- gui/wxpython/mapdisp/toolbars.py	(revision 57633)
+--- gui/wxpython/mapdisp/toolbars.py	(revision 57644)
 +++ gui/wxpython/mapdisp/toolbars.py	(working copy)
 @@ -239,7 +239,8 @@
                        (MapIcons["scatter"],     self.parent.OnScatterplot),
@@ -1831,7 +2380,7 @@
          """!Decorations overlay menu
 Index: gui/wxpython/mapdisp/frame.py
---- gui/wxpython/mapdisp/frame.py	(revision 57633)
+--- gui/wxpython/mapdisp/frame.py	(revision 57644)
 +++ gui/wxpython/mapdisp/frame.py	(working copy)
 @@ -225,6 +225,7 @@
@@ -1861,11 +2410,27 @@
      def OnVNet(self, event):
          """!Dialog for v.net* modules
+Index: gui/wxpython/scatt_plot/__init__.py
+--- gui/wxpython/scatt_plot/__init__.py	(revision 0)
++++ gui/wxpython/scatt_plot/__init__.py	(working copy)
+@@ -0,0 +1,11 @@
++all = [
++    'dialogs',
++    'controllers',
++    'frame',
++    'gthreading',
++    'plots',
++    'scatt_core',
++    'toolbars',
++    'scatt_core',
++    'core_c',
 Index: gui/wxpython/scatt_plot/plots.py
 --- gui/wxpython/scatt_plot/plots.py	(revision 0)
 +++ gui/wxpython/scatt_plot/plots.py	(working copy)
-@@ -0,0 +1,950 @@
+@@ -0,0 +1,944 @@
 + at package scatt_plot.dialogs
@@ -1882,13 +2447,11 @@
 +import wx
 +import numpy as np
++from math import ceil
 +#TODO testing
 +import time
 +from multiprocessing import Process, Queue
-+#TODO
-+#from numpy.lib.stride_tricks import as_strided
 +from copy import deepcopy
 +from scatt_plot.core_c import MergeArrays, ApplyColormap
 +from core.settings import UserSettings
@@ -1967,7 +2530,7 @@
 +        self.canvas = FigCanvas(self, -1, self.fig)
-+        self.axes = self.fig.add_axes([0,0,1,1])
++        self.axes = self.fig.add_axes([0.0,0.0,1,1])
 +        pol = Polygon(list(zip([0], [0])), animated=True)
 +        self.axes.add_patch(pol)
@@ -2075,7 +2638,6 @@
 +        else:
 +            c = None
 +        #q = Queue()
 +        #p = Process(target=MergeImg, args=(cats_order, scatts, styles, self.transpose, q))
 +        #p.start()
@@ -2089,10 +2651,8 @@
 +        if self.transpose:
 +            merged_img = np.transpose(merged_img, (1, 0, 2))
-+        #print self.full_extend
 +        img = imshow(self.axes, merged_img,
-+                     extent=self.full_extend,
++                     extent= [int(ceil(x)) for x in self.full_extend],
 +                     origin='lower',
 +                     interpolation='nearest',
 +                     aspect="equal")
@@ -2210,8 +2770,9 @@
 +        if x1 == x2 or y1 == y2:
 +            return
-+        self.axes.set_xlim(x1, x2)#, auto = True)
-+        self.axes.set_ylim(y1, y2)#, auto = True)
++        self.axes.axis((x1, x2, y1, y2))
++        #self.axes.set_xlim(x1, x2)#, auto = True)
++        #self.axes.set_ylim(y1, y2)#, auto = True)
 +        self.canvas.draw()
 +    def Motion(self, event):
@@ -2237,10 +2798,10 @@
 +        x,y = event.xdata, event.ydata
-+        mx = (x - self.zoom_wheel_coords['x']) * 0.5
-+        my = (y - self.zoom_wheel_coords['y']) * 0.5
++        mx = (x - self.zoom_wheel_coords['x']) * 0.6
++        my = (y - self.zoom_wheel_coords['y']) * 0.6
-+        extend = (cur_xlim[0] + mx, cur_xlim[1] + mx, cur_ylim[0] + my, cur_ylim[1] + my)
++        extend = (cur_xlim[0] - mx, cur_xlim[1] - mx, cur_ylim[0] - my, cur_ylim[1] - my)
 +        self.zoom_wheel_coords['x'] = x
 +        self.zoom_wheel_coords['y'] = y
@@ -2632,7 +3193,7 @@
 +        self._A = self._full_res[y0 - self.miny:y1 - self.miny:sy,
 +                                 x0 - self.minx:x1 - self.minx:sx]
-+        self._A = cbook.safe_masked_invalid(self._A)
 +        x1 = x0 + self._A.shape[1] * sx
 +        y1 = y0 + self._A.shape[0] * sy
@@ -2743,7 +3304,6 @@
 +                cmap._lut[:, 1] = int(colors[1])/255.0
 +                cmap._lut[:, 2] = int(colors[2])/255.0
 +            #if init:
 +            tmp = time.clock()
@@ -2758,7 +3318,6 @@
 +            masked_cat = np.uint8(masked_cat * (255.0 / float(vmax)))
 +            norm_time += time.clock() - tmp
-+            #print "ahoj"
 +            #print masked_cat
 +            #print masked_cat.shape
 +            #print masked_cat.mask.dtype
@@ -3206,8 +3765,8 @@
 +        if not sel_cat_id:
 +            return
-+        for scatt in self.plots.itervalues():
-+            scatt.SetEmpty()
++        #for scatt in self.plots.itervalues():
++        #    scatt.SetEmpty()
 +        self.computingStarted.emit()
@@ -4437,7 +4996,7 @@
 --- gui/wxpython/scatt_plot/scatt_core.py	(revision 0)
 +++ gui/wxpython/scatt_plot/scatt_core.py	(working copy)
-@@ -0,0 +1,813 @@
+@@ -0,0 +1,794 @@
 + at package scatt_plot.scatt_plot
@@ -4584,14 +5143,12 @@
 +            if self.scatt_conds_dt.AddScattPlot(cat_id, scatt_id) < 0:
 +                return False
-+            b1, b2 = idScattToidBands(scatt_id, len(self.an_data.GetBands()))
++            b1, b2 = idScattToidBands(scatt_id, len(self.an_data.GetBands()))
++            b = self.scatts_dt.GetBandsInfo(scatt_id)
-+            b1_info = self.an_data.GetBandInfo(b1)
-+            b2_info = self.an_data.GetBandInfo(b2)
++            raster_pol = RasterizePolygon(coords, b['b1']['range'], b['b1']['min'],
++                                                  b['b2']['range'], b['b2']['min'])
-+            raster_pol = RasterizePolygon(coords, b1_info['range'], b1_info['min'],
-+                                                  b2_info['range'], b2_info['min'])
 +            raster_ind = np.where(raster_pol > 0)
 +            arr = self.scatt_conds_dt.GetValuesArr(cat_id, scatt_id)
@@ -5091,6 +5648,7 @@
 +        data = np.copy(self.cats[cat_id][scatt_id]['np_vals'])
++        b = self.GetBandsInfo(scatt_id)
 +        sel_pts = np.where(data > 0)
 +        x = sel_pts[1]
@@ -5104,7 +5662,7 @@
 +        x_avg = np.average(x, weights=weights)
 +        y_avg = np.average(y, weights=weights)
-+        pos = np.array([x_avg, y_avg])
++        pos = np.array([x_avg + b['b1']['min'], y_avg + b['b2']['min']])
 +        x_diff = (x - x_avg)
 +        y_diff = (y - y_avg)
@@ -5192,39 +5750,21 @@
 +    nx = width
 +    ny = height
-+    for p in pol:
-+        p[0] = p[0] - min_w
-+        p[1] = p[1] - min_h
-+    x, y =  np.meshgrid(np.arange(-0.5, nx+0.5, dtype=float), np.arange(-0.5, ny+0.5, dtype=float))
++    x, y =  np.meshgrid(np.arange(-0.5 + min_w, nx + 0.5 + min_w, dtype=float),
++                        np.arange(-0.5 + min_h, ny + 0.5 + min_h, dtype=float))
 +    x, y = x.flatten(), y.flatten()
 +    points = np.vstack((x,y)).T
 +    p = Path(pol)
 +    grid = p.contains_points(points)
-+    grid = grid.reshape((ny + 1,nx + 1))
++    grid = grid.reshape((ny + 1, nx + 1))
 +    raster = np.zeros((height, width), dtype=np.uint8)#TODO bool
 +    #TODO shift by 0.5
 +    B = np.ones((2,2))/4
 +    raster = convolve2d(grid, B, 'valid')
-+    #TODO this part is very inefficient, replace it with better solution
-+    #for (y, x), value in np.ndenumerate(grid):
-+    #    if x >= width - 1: continue
-+    #    if y >= height - 1: continue
-+    #    if grid[y, x]:
-+    #        raster[y, x] = 1
-+    #        raster[y + 1, x] = 1
-+    #        raster[y, x + 1] = 1
-+    #        raster[y + 1, x + 1] = 1
 +    return raster
 +#TODO move to utils?
@@ -6088,25 +6628,9 @@
 +    def GetScattId(self):
 +        return self.scatt_id
-Index: gui/wxpython/scatt_plot/__init__.py
---- gui/wxpython/scatt_plot/__init__.py	(revision 0)
-+++ gui/wxpython/scatt_plot/__init__.py	(working copy)
-@@ -0,0 +1,11 @@
-+all = [
-+    'dialogs',
-+    'controllers',
-+    'frame',
-+    'gthreading',
-+    'plots',
-+    'scatt_core',
-+    'toolbars',
-+    'scatt_core',
-+    'core_c',
 Index: gui/wxpython/vnet/dialogs.py
---- gui/wxpython/vnet/dialogs.py	(revision 57633)
+--- gui/wxpython/vnet/dialogs.py	(revision 57644)
 +++ gui/wxpython/vnet/dialogs.py	(working copy)
 @@ -1218,7 +1218,7 @@
                        pos = (row, 1))
@@ -6119,7 +6643,7 @@
          styleBoxSizer.Add(item = gridSizer, flag = wx.EXPAND)
 Index: gui/wxpython/vnet/toolbars.py
---- gui/wxpython/vnet/toolbars.py	(revision 57633)
+--- gui/wxpython/vnet/toolbars.py	(revision 57644)
 +++ gui/wxpython/vnet/toolbars.py	(working copy)
 @@ -19,9 +19,9 @@
@@ -6135,7 +6659,7 @@
  class PointListToolbar(BaseToolbar):
 Index: gui/wxpython/Makefile
---- gui/wxpython/Makefile	(revision 57633)
+--- gui/wxpython/Makefile	(revision 57644)
 +++ gui/wxpython/Makefile	(working copy)
 @@ -13,7 +13,7 @@
  	$(wildcard animation/* core/*.py dbmgr/* gcp/*.py gmodeler/* \
@@ -6157,552 +6681,3 @@
  DSTDIRS := $(patsubst %,$(ETCDIR)/%,icons scripts xml)
  default: $(DSTFILES)
-Index: gui/wxpython/vdigit/wxdigit.py
---- gui/wxpython/vdigit/wxdigit.py	(revision 57633)
-+++ gui/wxpython/vdigit/wxdigit.py	(working copy)
-@@ -17,7 +17,7 @@
- (and NumPy would be an excellent candidate for acceleration via
- e.g. OpenCL or CUDA; I'm surprised it hasn't happened already).
--(C) 2007-2011 by the GRASS Development Team
-+(C) 2007-2011, 2013 by the GRASS Development Team
- This program is free software under the GNU General Public License
- (>=v2). Read the file COPYING that comes with GRASS for details.
-@@ -27,6 +27,8 @@
- import grass.script.core as grass
-+from grass.pydispatch.signal import Signal
- from core.gcmd        import GError
- from core.debug       import Debug
- from core.settings    import UserSettings
-@@ -176,7 +178,21 @@
-         if self.poMapInfo:
-             self.InitCats()
-+        self.emit_signals = False
-+        # signals which describes features changes during digitization,
-+        # activate them using EmitSignals method
-+        #TODO signal for errors?
-+        self.featureAdded = Signal('IVDigit.featureAdded')
-+        self.areasDeleted = Signal('IVDigit.areasDeleted')
-+        self.vertexMoved = Signal('IVDigit.vertexMoved')
-+        self.vertexAdded = Signal('IVDigit.vertexAdded')
-+        self.vertexRemoved = Signal('IVDigit.vertexRemoved')
-+        self.featuresDeleted = Signal('IVDigit.featuresDeleted')
-+        self.featuresMoved = Signal('IVDigit.featuresMoved')
-+        self.lineEdited = Signal('IVDigit.lineEdited')
-     def __del__(self):
-         Debug.msg(1, "IVDigit.__del__()")
-         Vect_destroy_line_struct(self.poPoints)
-@@ -188,7 +204,12 @@
-             Vect_close(self.poBgMapInfo)
-             self.poBgMapInfo = self.popoBgMapInfo = None
-             del self.bgMapInfo
-+    def EmitSignals(self, emit):
-+        """!Activate/deactivate signals which describes features changes during digitization.
-+        self.emit_signals = emit
-     def CloseBackgroundMap(self):
-         """!Close background vector map"""
-         if not self.poBgMapInfo:
-@@ -394,7 +415,6 @@
-         @return tuple (number of added features, feature ids)
-         layer = self._getNewFeaturesLayer()
-         cat = self._getNewFeaturesCat()
-@@ -419,10 +439,14 @@
-             return (-1, None)
-         self.toolbar.EnableUndo()
--        return self._addFeature(vtype, points, layer, cat,
--                                self._getSnapMode(), self._display.GetThreshold())
-+        ret = self._addFeature(vtype, points, layer, cat,
-+                               self._getSnapMode(), self._display.GetThreshold())
-+        if ret[0] > -1 and self.emit_signals:
-+            self.featureAdded.emit(new_bboxs = [self._createBbox(points)], new_areas_cats = [[{layer : [cat]}, None]])
-+        return ret
-     def DeleteSelectedLines(self):
-         """!Delete selected features
-@@ -434,16 +458,27 @@
-         # collect categories for deleting if requested
-         deleteRec = UserSettings.Get(group = 'vdigit', key = 'delRecord', subkey = 'enabled')
-         catDict = dict()
-+        old_bboxs = []
-+        old_areas_cats = []
-         if deleteRec:
-             for i in self._display.selected['ids']:
-                 if Vect_read_line(self.poMapInfo, None, self.poCats, i) < 0:
-                     self._error.ReadLine(i)
--                cats = self.poCats.contents
--                for j in range(cats.n_cats):
--                    if cats.field[j] not in catDict.keys():
--                        catDict[cats.field[j]] = list()
--                    catDict[cats.field[j]].append(cats.cat[j])
-+                if self.emit_signals:
-+                    ret = self._getLineAreaBboxCats(i)
-+                    if ret:
-+                        old_bboxs += ret[0]
-+                        old_areas_cats += ret[1]
-+                # catDict was not used -> put into comment
-+                #cats = self.poCats.contents
-+                #for j in range(cats.n_cats):
-+                #    if cats.field[j] not in catDict.keys():
-+                #        catDict[cats.field[j]] = list()
-+                #    catDict[cats.field[j]].append(cats.cat[j])
-         nlines = Vedit_delete_lines(self.poMapInfo, poList)
-@@ -456,7 +491,10 @@
-                 self._deleteRecords(catDict)
-             self._addChangeset()
-+                self.featuresDeleted.emit(old_bboxs = old_bboxs, old_areas_cats = old_areas_cats)
-         return nlines
-     def _deleteRecords(self, cats):
-@@ -512,22 +550,173 @@
-         @return number of deleted
-+        if len(self._display.selected['ids']) < 1:
-+            return 0
-         cList  = poList.contents
-         nareas = 0
-+        old_bboxs = []
-         for i in range(cList.n_values):
-             if Vect_get_line_type(self.poMapInfo, cList.value[i]) != GV_CENTROID:
-                 continue
-+                area = Vect_get_centroid_area(self.poMapInfo, cList.value[i]);
-+                if area > 0:
-+                    bbox, cats = self._getaAreaBboxCats(area)
-+                    old_bboxs += bbox
-+                    old_areas_cats += cats
-             nareas += Vedit_delete_area_centroid(self.poMapInfo, cList.value[i])
-         if nareas > 0:
-+                self.areasDeleted.emit(old_bboxs = old_bboxs, old_areas_cats = old_areas_cats)
-+        return nareas
-+    def _getLineAreaBboxCats(self, ln_id):
-+        ltype = Vect_read_line(self.poMapInfo, None, None, ln_id)
-+        if ltype == GV_CENTROID:
-+            #TODO centroid opttimization, can be adited also its area -> it will appear two times in new_ lists
-+            return self._getCentroidAreaBboxCats(ln_id)
-+        else:
-+            return [self._getBbox(ln_id)], [self._getLineAreasCategories(ln_id)]
-+    def _getCentroidAreaBboxCats(self, centroid):
-+        if not Vect_line_alive(self.poMapInfo, centroid):
-+            return None
-+        area = Vect_get_centroid_area(self.poMapInfo, centroid)
-+        if area > 0:
-+            return self._getaAreaBboxCats(area)
-+        else:
-+            return None
-+    def _getaAreaBboxCats(self, area):
-+        po_b_list = Vect_new_list()
-+        Vect_get_area_boundaries(self.poMapInfo, area, po_b_list);
-+        b_list = po_b_list.contents
-+        geoms = []
-+        areas_cats = []
-+        if b_list.n_values > 0:
-+            for i_line in range(b_list.n_values):
-+                line = b_list.value[i_line];
-+                geoms.append(self._getBbox(abs(line)))
-+                areas_cats.append(self._getLineAreasCategories(abs(line)))
--        return nareas
-+        Vect_destroy_list(po_b_list);
-+        return geoms, areas_cats
-+    def _getLineAreasCategories(self, ln_id):
-+        if not Vect_line_alive (self.poMapInfo, ln_id):
-+            return []
-+        if ltype != GV_BOUNDARY:
-+            return []
-+        cats = [None, None]
-+        left = c_int()
-+        right = c_int()
-+        if Vect_get_line_areas(self.poMapInfo, ln_id, pointer(left), pointer(right)) == 1:
-+            areas = [left.value, right.value]
-+            for i, a in enumerate(areas):
-+                if a > 0:
-+                    centroid = Vect_get_area_centroid(self.poMapInfo, a)
-+                    if centroid <= 0:
-+                        continue
-+                    c = self._getCategories(centroid)
-+                    if c:
-+                        cats[i] = c
-+        return cats
-+    def _getCategories(self, ln_id):
-+            return none
-+        poCats = Vect_new_cats_struct()
-+        if Vect_read_line(self.poMapInfo, None, poCats, ln_id) < 0:
-+            Vect_destroy_cats_struct(poCats)
-+            return None
-+        cCats = poCats.contents
-+        cats = {}
-+        for j in range(cCats.n_cats):
-+            if cats.has_key(cCats.field[j]):
-+                cats[cCats.field[j]].append(cCats.cat[j])
-+            else:
-+                cats[cCats.field[j]] = [cCats.cat[j]]
-+        return cats
-+    def _getBbox(self, ln_id):
-+            return None
-+        poPoints = Vect_new_line_struct()
-+        if Vect_read_line(self.poMapInfo, poPoints, None, ln_id) < 0:
-+            Vect_destroy_line_struct(poPoints)
-+            return []
-+        geom = self._convertGeom(poPoints)
-+        bbox = self._createBbox(geom)
-+        return bbox
-+    def _createBbox(self, points):
-+        bbox = {}
-+        for pt in points:
-+            if not bbox.has_key('maxy'):
-+                bbox['maxy'] = pt[1]
-+                bbox['miny'] = pt[1]
-+                bbox['maxx'] = pt[0]
-+                bbox['minx'] = pt[0]
-+                continue
-+            if   bbox['maxy'] < pt[1]:
-+            elif bbox['miny'] > pt[1]:
-+            if   bbox['maxx'] < pt[0]:
-+            elif bbox['minx'] > pt[0]:
-+        return bbox
-+    def _convertGeom(self, poPoints):
-+        Points = poPoints.contents
-+        pts_geom = []
-+        for j in range(Points.n_points):
-+            pts_geom.append((Points.x[j], Points.y[j]))
-+        return pts_geom
-     def MoveSelectedLines(self, move):
-         """!Move selected features
-@@ -536,16 +725,45 @@
-         if not self._checkMap():
-             return -1
-+        nsel = len(self._display.selected['ids'])
-+        if nsel < 1:
-+            return -1
-         thresh = self._display.GetThreshold()
-         snap   = self._getSnapMode()
-+            old_bboxs = []
-+            for sel_id in self._display.selected['ids']:
-+                ret = self._getLineAreaBboxCats(sel_id)
-+                if ret:
-+            Vect_set_updated(self.poMapInfo, 1)
-+            n_up_lines_old = Vect_get_num_updated_lines(self.poMapInfo)
-         nlines = Vedit_move_lines(self.poMapInfo, self.popoBgMapInfo, int(self.poBgMapInfo is not None),
-                                   poList,
-                                   move[0], move[1], 0,
-                                   snap, thresh)
-         Vect_destroy_list(poList)
-+        if nlines > 0 and self.emit_signals:
-+            new_bboxs = []
-+            new_areas_cats = []
-+            n_up_lines = Vect_get_num_updated_lines(self.poMapInfo)
-+            for i in range(n_up_lines_old, n_up_lines):
-+                new_id = Vect_get_updated_line(self.poMapInfo, i)
-+                ret = self._getLineAreaBboxCats(new_id)
-+                if ret:
-+                    new_bboxs += ret[0]
-+                    new_areas_cats += ret[1]
-         if nlines > 0 and self._settings['breakLines']:
-             for i in range(1, nlines):
-                 self._breakLineAtIntersection(nlines + i, None, changeset)
-@@ -553,7 +771,13 @@
-         if nlines > 0:
-+                self.featuresMoved.emit(new_bboxs = new_bboxs,
-+                                        old_bboxs = old_bboxs,
-+                                        old_areas_cats = old_areas_cats,
-+                                        new_areas_cats = new_areas_cats)
-         return nlines
-     def MoveSelectedVertex(self, point, move):
-@@ -571,12 +795,21 @@
-         if len(self._display.selected['ids']) != 1:
-             return -1
-+        # move only first found vertex in bbox
-+        poList = self._display.GetSelectedIList()
-+            cList = poList.contents
-+            old_bboxs = [self._getBbox(cList.value[0])]
-+            old_areas_cats = [self._getLineAreasCategories(cList.value[0])]
-         Vect_reset_line(self.poPoints)
-         Vect_append_point(self.poPoints, point[0], point[1], 0.0)
--        # move only first found vertex in bbox
--        poList = self._display.GetSelectedIList()
-         moved = Vedit_move_vertex(self.poMapInfo, self.popoBgMapInfo, int(self.poBgMapInfo is not None),
-                                   poList, self.poPoints,
-                                   self._display.GetThreshold(type = 'selectThresh'),
-@@ -584,7 +817,17 @@
-                                   move[0], move[1], 0.0,
-                                   1, self._getSnapMode())
-+        if moved > 0 and self.emit_signals:
-+            new_bboxs = []
-+                new_bboxs.append(self._getBbox(new_id))
-+                new_areas_cats.append(self._getLineAreasCategories(new_id))
-         if moved > 0 and self._settings['breakLines']:
-             self._breakLineAtIntersection(Vect_get_num_lines(self.poMapInfo),
-                                           None)
-@@ -592,7 +835,13 @@
-         if moved > 0:
-+                self.vertexMoved.emit(new_bboxs = new_bboxs,
-+                                      new_areas_cats = new_areas_cats,
-+                                      old_bboxs = old_bboxs)
-         return moved
-     def AddVertex(self, coords):
-@@ -681,6 +930,10 @@
-             self._error.ReadLine(line)
-             return -1
-+            old_bboxs = [self._getBbox(line)]
-+            old_areas_cats = [self._getLineAreasCategories(line)]
-         # build feature geometry
-         for p in coords:
-@@ -696,6 +949,9 @@
-         newline = Vect_rewrite_line(self.poMapInfo, line, ltype,
-                                     self.poPoints, self.poCats)
-+        if newline > 0 and self.emit_signals:
-+            new_geom = [self._getBbox(newline)]
-+            new_areas_cats = [self._getLineAreasCategories(newline)]
-         if newline > 0 and self._settings['breakLines']:
-             self._breakLineAtIntersection(newline, None)
-@@ -703,7 +959,13 @@
-         if newline > 0:
-+                self.lineEdited.emit(old_bboxs = old_bboxs,
-+                                     new_bboxs = new_bboxs,
-         return newline
-     def FlipLine(self):
-@@ -1514,6 +1776,16 @@
-             return 0
-         Vect_append_point(self.poPoints, coords[0], coords[1], 0.0)
-@@ -1525,15 +1797,35 @@
-         else:
-             ret = Vedit_remove_vertex(self.poMapInfo, poList,
-                                       self.poPoints, thresh)
-+        if ret > 0 and self.emit_signals:
-+            new_bboxs = []
-         if not add and ret > 0 and self._settings['breakLines']:
-                                           None)
-         if ret > 0:
-+            if add:
-+                self.vertexAdded.emit(old_bboxs = old_bboxs, new_bboxs = new_bboxs)
-+            else:
-+                self.vertexRemoved.emit(old_bboxs = old_bboxs,
-         return 1
-     def GetLineCats(self, line):
-Index: gui/wxpython/vdigit/toolbars.py
---- gui/wxpython/vdigit/toolbars.py	(revision 57633)
-+++ gui/wxpython/vdigit/toolbars.py	(working copy)
-@@ -17,6 +17,7 @@
- import wx
- from grass.script import core as grass
- from gui_core.toolbars  import BaseToolbar, BaseIcons
- from gui_core.dialogs   import CreateNewVector
-@@ -42,6 +43,8 @@
-         self.digit         = None
-         self._giface       = giface
-+        self.editingStarted = Signal("VDigitToolbar.editingStarted")
-         # currently selected map layer for editing (reference to MapLayer instance)
-         self.mapLayer = None
-         # list of vector layers from Layer Manager (only in the current mapset)
-@@ -860,6 +863,7 @@
-             alpha = int(opacity * 255)
-             self.digit.GetDisplay().UpdateSettings(alpha = alpha)
-+        self.editingStarted.emit(vectMap = mapLayer.GetName(), digit = self.digit)
-         return True
-     def StopEditing(self):
