[GRASS-SVN] r57646 - grass/trunk/mswindows
svn_grass at osgeo.org
Thu Sep 12 05:46:29 PDT 2013
Author: martinl
Date: 2013-09-12 05:46:29 -0700 (Thu, 12 Sep 2013)
New Revision: 57646
grass/trunk/mswindows/GRASS-Installer.nsi.tmpl
grass/trunk/mswindows/env.bat
wingrass: remove references to extralib
Modified: grass/trunk/mswindows/GRASS-Installer.nsi.tmpl
--- grass/trunk/mswindows/GRASS-Installer.nsi.tmpl 2013-09-12 10:44:50 UTC (rev 57645)
+++ grass/trunk/mswindows/GRASS-Installer.nsi.tmpl 2013-09-12 12:46:29 UTC (rev 57646)
@@ -543,7 +543,7 @@
FileWrite $0 'set GISBASE=$INSTALL_DIR$\r$\n'
FileWrite $0 '$\r$\n'
FileWrite $0 'rem set path to freetype dll$\r$\n'
- FileWrite $0 'set FREETYPEBASE=$INSTALL_DIR\extralib;$INSTALL_DIR\msys\bin;$INSTALL_DIR\lib$\r$\n'
+ FileWrite $0 'set FREETYPEBASE=$INSTALL_DIR\extrabin;$INSTALL_DIR\msys\bin;$INSTALL_DIR\lib$\r$\n'
FileWrite $0 'rem set dependecies path$\r$\n'
FileWrite $0 'set PATH=%FREETYPEBASE%;%PATH%$\r$\n'
@@ -821,7 +821,7 @@
FileWrite $0 'export GISBASE$\r$\n'
FileWrite $0 '# Set the PATH variable$\r$\n'
- FileWrite $0 'PATH="$$GISBASE/extrabin:$$GISBASE/extralib:$$PATH"$\r$\n'
+ FileWrite $0 'PATH="$$GISBASE/extrabin:$$PATH"$\r$\n'
FileWrite $0 'export PATH$\r$\n'
FileWrite $0 '# Set the PYTHONPATH variable$\r$\n'
FileWrite $0 'PYTHONPATH="$$GISBASE/etc/python:$$GISBASE/Python27:$$PYTHONPATH"$\r$\n'
@@ -946,7 +946,7 @@
ExecWait "$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\vcredist_2005_x86.exe /q"
ExecWait "$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\vcredist_2008_x86.exe /q"
ExecWait "$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\vcredist_2010_x86.exe /q"
- CopyFiles "$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\*.dll" "$INSTDIR\extralib"
+ CopyFiles "$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\*.dll" "$INSTDIR\extrabin"
Delete "$TEMP\$ARCHIVE_NAME"
RMDir /r "$TEMP\$ORIGINAL_UNTAR_FOLDER"
;the following doesn't work. Maybe because the installer is still running?
Modified: grass/trunk/mswindows/env.bat
--- grass/trunk/mswindows/env.bat 2013-09-12 10:44:50 UTC (rev 57645)
+++ grass/trunk/mswindows/env.bat 2013-09-12 12:46:29 UTC (rev 57646)
@@ -14,5 +14,5 @@
set GEOTIFF_CSV=%GISBASE%\share\epsg_csv
set PATH=%GISBASE%\msys\bin;%PATH%
-set PATH=%GISBASE%\extrabin;%GISBASE%\extralib;%PATH%
+set PATH=%GISBASE%\extrabin;%PATH%
set PATH=%GISBASE%\bin;%PATH%
