[GRASS-SVN] r57664 - grass/branches/develbranch_6/raster/simwe/r.sim.water
svn_grass at osgeo.org
Fri Sep 13 19:30:00 PDT 2013
Author: hamish
Date: 2013-09-13 19:30:00 -0700 (Fri, 13 Sep 2013)
New Revision: 57664
grass/branches/develbranch_6/raster/simwe/r.sim.water/main.c
named for Robert Manning c.1890, see http://en.wikipedia.org/wiki/Manning_formula (merge from trunk)
Modified: grass/branches/develbranch_6/raster/simwe/r.sim.water/main.c
--- grass/branches/develbranch_6/raster/simwe/r.sim.water/main.c 2013-09-14 02:28:54 UTC (rev 57663)
+++ grass/branches/develbranch_6/raster/simwe/r.sim.water/main.c 2013-09-14 02:30:00 UTC (rev 57664)
@@ -166,7 +166,7 @@
parm.manin = G_define_standard_option(G_OPT_R_INPUT);
parm.manin->key = "manin";
parm.manin->required = NO;
- parm.manin->description = _("Name of mannings n raster map");
+ parm.manin->description = _("Name of the Manning's n raster map");
parm.manin->guisection = _("Input");
parm.maninval = G_define_option();
@@ -174,7 +174,7 @@
parm.maninval->type = TYPE_DOUBLE;
parm.maninval->answer = MANINVAL;
parm.maninval->required = NO;
- parm.maninval->description = _("Mannings n unique value");
+ parm.maninval->description = _("Manning's n unique value");
parm.maninval->guisection = _("Input");
parm.traps = G_define_standard_option(G_OPT_R_INPUT);
@@ -381,7 +381,7 @@
if (parm.maninval->answer == NULL) {
/*No Mannings input so use default */
sscanf(MANINVAL, "%lf", &manin_val);
- /* if mannings unique input value exists, load it */
+ /* if Mannings unique input value exists, load it */
else {
/*Unique value input only */
