[GRASS-SVN] r57665 - grass/branches/releasebranch_6_4/raster/simwe/r.sim.water
Fri Sep 13 19:31:04 PDT 2013
Author: hamish
Date: 2013-09-13 19:31:04 -0700 (Fri, 13 Sep 2013)
New Revision: 57665
   grass/branches/releasebranch_6_4/raster/simwe/r.sim.water/main.c
named for Robert Manning c.1890, see http://en.wikipedia.org/wiki/Manning_formula (partial merge from trunk)
Modified: grass/branches/releasebranch_6_4/raster/simwe/r.sim.water/main.c
--- grass/branches/releasebranch_6_4/raster/simwe/r.sim.water/main.c	2013-09-14 02:30:00 UTC (rev 57664)
+++ grass/branches/releasebranch_6_4/raster/simwe/r.sim.water/main.c	2013-09-14 02:31:04 UTC (rev 57665)
@@ -170,7 +170,7 @@
     parm.manin = G_define_standard_option(G_OPT_R_INPUT);
     parm.manin->key = "manin";
     parm.manin->required = NO;
-    parm.manin->description = _("Name of the Mannings n raster map");
+    parm.manin->description = _("Name of the Manning's n raster map");
     parm.manin->guisection = _("Input");
     parm.maninval = G_define_option();
@@ -178,7 +178,7 @@
     parm.maninval->type = TYPE_DOUBLE;
     parm.maninval->answer = MANINVAL;
     parm.maninval->required = NO;
-    parm.maninval->description = _("Mannings n unique value");
+    parm.maninval->description = _("Manning's n unique value");
     parm.maninval->guisection = _("Input");
     parm.traps = G_define_standard_option(G_OPT_R_INPUT);
@@ -385,7 +385,7 @@
 	if (parm.maninval->answer == NULL) {
 	    /*No Mannings input so use default */
 	    sscanf(MANINVAL, "%lf", &manin_val);
-	    /* if mannings unique input value exists, load it */
+	    /* if Mannings unique input value exists, load it */
 	else {
 	    /*Unique value input only */
