[GRASS-SVN] r57832 - in grass/trunk/vector: . v.clean
svn_grass at osgeo.org
Wed Sep 25 01:26:27 PDT 2013
Author: mmetz
Date: 2013-09-25 01:26:27 -0700 (Wed, 25 Sep 2013)
New Revision: 57832
grass/trunk/vector/Makefile
grass/trunk/vector/v.clean/main.c
v.centerpoint: geometric mean -> arithmetic mean
Modified: grass/trunk/vector/Makefile
--- grass/trunk/vector/Makefile 2013-09-25 04:01:01 UTC (rev 57831)
+++ grass/trunk/vector/Makefile 2013-09-25 08:26:27 UTC (rev 57832)
@@ -27,6 +27,7 @@
v.in.ascii \
v.in.db \
v.in.dxf \
+ v.in.ply \
v.in.region \
v.in.sites \
v.kcv \
@@ -58,6 +59,7 @@
v.normal \
v.out.ascii \
v.out.dxf \
+ v.out.ply \
v.out.postgis \
v.out.pov \
v.out.svg \
Modified: grass/trunk/vector/v.clean/main.c
--- grass/trunk/vector/v.clean/main.c 2013-09-25 04:01:01 UTC (rev 57831)
+++ grass/trunk/vector/v.clean/main.c 2013-09-25 08:26:27 UTC (rev 57832)
@@ -303,6 +303,9 @@
native = Vect_maptype(&Out) == GV_FORMAT_NATIVE;
if (!native) {
+ /* area cleaning tools might produce unexpected results for
+ * non-native vectors */
+ G_warning(_("Topological cleaning works best with native GRASS vector format"));
/* Copy attributes (OGR format) */
Vect_copy_map_dblinks(&In, &Out, TRUE);
@@ -428,6 +431,8 @@
count =
Vect_remove_small_areas(&Out, threshs[i], pErr, &size);
if (flag.combine->answer && count > 0) {
+ Vect_build_partial(&Out, GV_BUILD_BASE);
+ G_message(SEP);
G_message(_("Tool: Merge boundaries"));
Vect_merge_lines(&Out, GV_BOUNDARY, NULL, pErr);
