[GRASS-SVN] r57833 - grass-addons/grass7/vector/v.centerpoint
Wed Sep 25 01:26:55 PDT 2013
Author: mmetz
Date: 2013-09-25 01:26:54 -0700 (Wed, 25 Sep 2013)
New Revision: 57833
   grass-addons/grass7/vector/v.centerpoint/areas.c
   grass-addons/grass7/vector/v.centerpoint/lines.c
   grass-addons/grass7/vector/v.centerpoint/local_proto.h
   grass-addons/grass7/vector/v.centerpoint/main.c
   grass-addons/grass7/vector/v.centerpoint/points.c
   grass-addons/grass7/vector/v.centerpoint/v.centerpoint.html
v.centerpoint: geometric mean -> arithmetic mean
Modified: grass-addons/grass7/vector/v.centerpoint/areas.c
--- grass-addons/grass7/vector/v.centerpoint/areas.c	2013-09-25 08:26:27 UTC (rev 57832)
+++ grass-addons/grass7/vector/v.centerpoint/areas.c	2013-09-25 08:26:54 UTC (rev 57833)
@@ -6,20 +6,6 @@
 #include <grass/glocale.h>
 #include "local_proto.h"
-static double d_ulp(double d)
-    int exp;
-    if (d == 0)
-	return GRASS_EPSILON;
-    d = frexp(d, &exp);
-    exp -= 51;
-    d = ldexp(d, exp);
-    return d;
 int areas_center(struct Map_info *In, struct Map_info *Out, int layer,
                  struct cat_list *cat_list, int mode)
@@ -46,7 +32,7 @@
     nareas = Vect_get_num_areas(In);
-    /* geometric mean = center of gravity */
+    /* arithmetic mean = center of gravity */
     if (mode & A_MEAN) {
 	G_message(_("Calculating centers of gravity for areas..."));
@@ -127,7 +113,7 @@
-    /* approximate geometric median with Weiszfeld's algorithm:
+    /* approximate point of minimum distance (geometric median) with Weiszfeld's algorithm:
      * iterative least squares reduction */
     if (mode & A_MEDIAN) {
 	struct line_pnts *CPoints;
@@ -412,7 +398,7 @@
 	double dist, distsum, dist2all, lastdist2all;
 	int j, iter, maxiter = 1000;
-	G_message(_("Calculating geometric medians for areas..."));
+	G_message(_("Calculating geometric medians for area boundaries..."));
 	CPoints = Vect_new_line_struct();
Modified: grass-addons/grass7/vector/v.centerpoint/lines.c
--- grass-addons/grass7/vector/v.centerpoint/lines.c	2013-09-25 08:26:27 UTC (rev 57832)
+++ grass-addons/grass7/vector/v.centerpoint/lines.c	2013-09-25 08:26:54 UTC (rev 57833)
@@ -6,20 +6,6 @@
-    int exp;
-    if (d == 0)
-    exp -= 51;
-    return d;
 int lines_center(struct Map_info *In, struct Map_info *Out, int layer,
                  struct cat_list *cat_list, int n_primitives, int mode)
@@ -37,6 +23,7 @@
     if (mode & L_MID) {
 	double len;
+	G_message(_("Calculating mid point coordinates..."));
 	counter = 0;
 	Vect_rewind(In);
@@ -73,6 +60,7 @@
 	double dx, dy, dz;
 	int i;
+	G_message(_("Calculating centers of gravity for lines..."));
 	counter = 0;
 	Vect_rewind(In);
@@ -133,6 +121,7 @@
 	SPoints = Vect_new_line_struct();
+	G_message(_("Approximating geometric medians..."));
 	counter = 0;
 	Vect_rewind(In);
@@ -185,7 +174,7 @@
 	    lastdist2all = -1;
-	    G_debug(3, "Approximating geometric median...");
+	    G_debug(3, "Approximating geometric median...", );
 	    for (iter = 0; iter < maxiter; iter++) {
Modified: grass-addons/grass7/vector/v.centerpoint/local_proto.h
--- grass-addons/grass7/vector/v.centerpoint/local_proto.h	2013-09-25 08:26:27 UTC (rev 57832)
+++ grass-addons/grass7/vector/v.centerpoint/local_proto.h	2013-09-25 08:26:54 UTC (rev 57833)
@@ -10,6 +10,7 @@
 int points_center(struct Map_info *, struct Map_info *, int,
                   struct cat_list *, int, int);
+double d_ulp(double);
 int lines_center(struct Map_info *, struct Map_info *, int,
Modified: grass-addons/grass7/vector/v.centerpoint/main.c
--- grass-addons/grass7/vector/v.centerpoint/main.c	2013-09-25 08:26:27 UTC (rev 57832)
+++ grass-addons/grass7/vector/v.centerpoint/main.c	2013-09-25 08:26:54 UTC (rev 57833)
@@ -3,12 +3,11 @@
  * MODULE:     v.centerpoint
- * AUTHOR(S):  GRASS Development Team, Radim Blazek, Maris Nartiss
+ * AUTHOR(S):  Markus Metz
- * PURPOSE:    copies vector data from source map to destination map
- *             prints out all point coordinates and atributes
+ * PURPOSE:    Calculates center points
- * COPYRIGHT:  (C) 2002-2009 by the GRASS Development Team
+ * COPYRIGHT:  (C) 2013 by the GRASS Development Team
  *             This program is free software under the
  *             GNU General Public License (>=v2).
@@ -84,8 +83,8 @@
 	       "mean;%s;"
 	       "median;%s;"
 	       "pmedian;%s;",
-	       _("Geometric mean (center of gravity)"),
-	       _("Geometric median"),
+	       _("Center of gravity"),
+	       _("Geometric median (point of minimum distance)"),
 	       _("Point closest to geometric median"));
     pmode->descriptions = pdesc;
@@ -102,8 +101,8 @@
 	       "mean;%s;"
 	       "median;%s;",
 	       _("Line mid point"),
-	       _("Geometric median using line segments"));
+	       _("Geometric median (point of minimum distance) using line segments"));
     lmode->descriptions = ldesc;
     amode = G_define_option();
@@ -118,9 +117,9 @@
 	       "mean;%s;"
 	       "median;%s;"
 	       "bmedian;%s;",
-	       _("Geometric median using area sizes"),
-	       _("Geometric median using boundary segments"));
+	       _("Geometric median (point of minimum distance) using area sizes"),
+	       _("Geometric median (point of minimum distance) using boundary segments"));
     amode->descriptions = adesc;
     topo_flag = G_define_standard_flag(G_FLG_V_TOPO);
Modified: grass-addons/grass7/vector/v.centerpoint/points.c
--- grass-addons/grass7/vector/v.centerpoint/points.c	2013-09-25 08:26:27 UTC (rev 57832)
+++ grass-addons/grass7/vector/v.centerpoint/points.c	2013-09-25 08:26:54 UTC (rev 57833)
@@ -6,7 +6,7 @@
+double d_ulp(double d)
     int exp;
@@ -41,7 +41,7 @@
     /* coordinates' mean */
     counter = n = 0;
     xsum = ysum = zsum = 0.;
-    G_message(_("Calculating mean point coordinates (center of gravity)..."));
+    G_message(_("Calculating center of gravity..."));
     while ((type = Vect_read_next_line(In, Points, Cats)) > 0) {
 	G_percent(counter, n_primitives, 4);
 	counter++;
Modified: grass-addons/grass7/vector/v.centerpoint/v.centerpoint.html
--- grass-addons/grass7/vector/v.centerpoint/v.centerpoint.html	2013-09-25 08:26:27 UTC (rev 57832)
+++ grass-addons/grass7/vector/v.centerpoint/v.centerpoint.html	2013-09-25 08:26:54 UTC (rev 57833)
@@ -1,7 +1,7 @@
 <h2>DESCRIPTION</h2>
 <em>v.centerpoint</em> calculates center points for point clouds, lines
-and areas. Center points can be geometric means (centers of gravity) or
+and areas. Center points can be centers of gravity (coordinates' mean) or
 geometric medians, which is more robust in case of outliers.
 <p>
 For points, center points are calculated considering all points. For
