[GRASS-SVN] r57834 - grass/trunk/vector/v.clean
Wed Sep 25 01:32:44 PDT 2013
Author: mmetz
Date: 2013-09-25 01:32:44 -0700 (Wed, 25 Sep 2013)
New Revision: 57834
   grass/trunk/vector/v.clean/main.c
v.clean: revert r57832
Modified: grass/trunk/vector/v.clean/main.c
--- grass/trunk/vector/v.clean/main.c	2013-09-25 08:26:54 UTC (rev 57833)
+++ grass/trunk/vector/v.clean/main.c	2013-09-25 08:32:44 UTC (rev 57834)
@@ -303,9 +303,6 @@
     native = Vect_maptype(&Out) == GV_FORMAT_NATIVE;
     if (!native) {
-	/* area cleaning tools might produce unexpected results for
-	 * non-native vectors */
-	G_warning(_("Topological cleaning works best with native GRASS vector format"));
 	/* Copy attributes (OGR format) */
 	Vect_copy_map_dblinks(&In, &Out, TRUE);
@@ -431,8 +428,6 @@
 	    count =
 		Vect_remove_small_areas(&Out, threshs[i], pErr, &size);
 	    if (flag.combine->answer && count > 0) {
-		Vect_build_partial(&Out, GV_BUILD_BASE);
-		G_message(SEP);
 		G_message(_("Tool: Merge boundaries"));
 		Vect_merge_lines(&Out, GV_BOUNDARY, NULL, pErr);
