[GRASS-SVN] r57835 - grass/trunk/vector/v.clean
Wed Sep 25 01:34:17 PDT 2013
Author: mmetz
Date: 2013-09-25 01:34:17 -0700 (Wed, 25 Sep 2013)
New Revision: 57835
   grass/trunk/vector/v.clean/main.c
v.clean: improve topo handling, warning for non-native formats
Modified: grass/trunk/vector/v.clean/main.c
--- grass/trunk/vector/v.clean/main.c	2013-09-25 08:32:44 UTC (rev 57834)
+++ grass/trunk/vector/v.clean/main.c	2013-09-25 08:34:17 UTC (rev 57835)
@@ -303,6 +303,9 @@
     native = Vect_maptype(&Out) == GV_FORMAT_NATIVE;
     if (!native) {
+	/* area cleaning tools might produce unexpected results for
+	 * non-native vectors */
+	G_warning(_("Topological cleaning works best with native GRASS vector format"));
 	/* Copy attributes (OGR format) */
 	Vect_copy_map_dblinks(&In, &Out, TRUE);
@@ -428,6 +431,8 @@
 	    count =
 		Vect_remove_small_areas(&Out, threshs[i], pErr, &size);
 	    if (flag.combine->answer && count > 0) {
+		Vect_build_partial(&Out, GV_BUILD_BASE);
+		G_message(SEP);
 		G_message(_("Tool: Merge boundaries"));
 		Vect_merge_lines(&Out, GV_BOUNDARY, NULL, pErr);
