[GRASS-SVN] r57856 - grass/branches/releasebranch_6_4/lib/vector/diglib
svn_grass at osgeo.org
Fri Sep 27 07:05:20 PDT 2013
Author: mmetz
Date: 2013-09-27 07:05:18 -0700 (Fri, 27 Sep 2013)
New Revision: 57856
grass/branches/releasebranch_6_4/lib/vector/diglib/portable.c
diglib: fix support for BIG ENDIAN (backport r47992, r56890)
Modified: grass/branches/releasebranch_6_4/lib/vector/diglib/portable.c
--- grass/branches/releasebranch_6_4/lib/vector/diglib/portable.c 2013-09-27 14:04:55 UTC (rev 57855)
+++ grass/branches/releasebranch_6_4/lib/vector/diglib/portable.c 2013-09-27 14:05:18 UTC (rev 57856)
@@ -155,21 +155,19 @@
memset(buf, 0, cnt * sizeof(long));
/* read from buffer in changed order */
c1 = (unsigned char *)buffer;
- if (lng_order == ENDIAN_LITTLE)
- c2 = (unsigned char *)buf;
- else
- c2 = (unsigned char *)buf + nat_lng - PORT_LONG;
+ c2 = (unsigned char *)buf;
for (i = 0; i < cnt; i++) {
/* set to FF if the value is negative */
if (lng_order == ENDIAN_LITTLE) {
if (c1[PORT_LONG - 1] & 0x80)
memset(c2, 0xff, sizeof(long));
+ memcpy(c2, c1, PORT_LONG);
else {
if (c1[0] & 0x80)
+ memcpy(c2 + nat_lng - PORT_LONG, c1, PORT_LONG);
- memcpy(c2, c1, PORT_LONG);
c1 += PORT_LONG;
c2 += sizeof(long);
@@ -227,21 +225,19 @@
memset(buf, 0, cnt * sizeof(int));
- if (int_order == ENDIAN_LITTLE)
- else
- c2 = (unsigned char *)buf + nat_int - PORT_INT;
if (int_order == ENDIAN_LITTLE) {
if (c1[PORT_INT - 1] & 0x80)
memset(c2, 0xff, sizeof(int));
+ memcpy(c2, c1, PORT_INT);
else {
if (c1[0] & 0x80)
+ memcpy(c2 + nat_int - PORT_INT, c1, PORT_INT);
- memcpy(c2, c1, PORT_INT);
c1 += PORT_INT;
c2 += sizeof(int);
@@ -299,21 +295,19 @@
memset(buf, 0, cnt * sizeof(short));
- if (shrt_order == ENDIAN_LITTLE)
- else
- c2 = (unsigned char *)buf + nat_shrt - PORT_SHORT;
if (shrt_order == ENDIAN_LITTLE) {
if (c1[PORT_SHORT - 1] & 0x80)
memset(c2, 0xff, sizeof(short));
+ memcpy(c2, c1, PORT_SHORT);
else {
if (c1[0] & 0x80)
+ memcpy(c2 + nat_shrt - PORT_SHORT, c1, PORT_SHORT);
- memcpy(c2, c1, PORT_SHORT);
c1 += PORT_SHORT;
c2 += sizeof(short);
@@ -438,15 +432,15 @@
else {
buf_alloc(cnt * PORT_LONG);
- c1 = (unsigned char *)buf;
- else
- c1 = (unsigned char *)buf + nat_lng - PORT_LONG;
+ c1 = (unsigned char *)buf;
c2 = (unsigned char *)buffer;
- c1 += PORT_LONG;
- c2 += sizeof(long);
+ if (lng_order == ENDIAN_LITTLE)
+ else
+ memcpy(c2, c1 + nat_lng - PORT_LONG, PORT_LONG);
+ c1 += sizeof(long);
+ c2 += PORT_LONG;
if (dig_fwrite(buffer, PORT_LONG, cnt, fp) == cnt)
return 1;
@@ -481,15 +475,15 @@
else {
buf_alloc(cnt * PORT_INT);
- else
- c1 = (unsigned char *)buf + nat_int - PORT_INT;
- c1 += PORT_INT;
- c2 += sizeof(int);
+ if (int_order == ENDIAN_LITTLE)
+ else
+ memcpy(c2, c1 + nat_int - PORT_INT, PORT_INT);
+ c1 += sizeof(int);
+ c2 += PORT_INT;
if (dig_fwrite(buffer, PORT_INT, cnt, fp) == cnt)
return 1;
@@ -524,15 +518,15 @@
else {
buf_alloc(cnt * PORT_SHORT);
- else
- c1 = (unsigned char *)buf + nat_shrt - PORT_SHORT;
- c1 += PORT_SHORT;
- c2 += sizeof(short);
+ if (shrt_order == ENDIAN_LITTLE)
+ else
+ memcpy(c2, c1 + nat_shrt - PORT_SHORT, PORT_SHORT);
+ c1 += sizeof(short);
+ c2 += PORT_SHORT;
if (dig_fwrite(buffer, PORT_SHORT, cnt, fp) == cnt)
return 1;
