[GRASS-SVN] r57857 - grass/trunk/vector/v.net
Fri Sep 27 07:28:32 PDT 2013
Author: mmetz
Date: 2013-09-27 07:28:32 -0700 (Fri, 27 Sep 2013)
New Revision: 57857
   grass/trunk/vector/v.net/connect.c
   grass/trunk/vector/v.net/main.c
   grass/trunk/vector/v.net/proto.h
v.net op=connect: new arcs need unique cat
Modified: grass/trunk/vector/v.net/connect.c
--- grass/trunk/vector/v.net/connect.c	2013-09-27 14:05:18 UTC (rev 57856)
+++ grass/trunk/vector/v.net/connect.c	2013-09-27 14:28:32 UTC (rev 57857)
@@ -18,14 +18,16 @@
  * \return number of new arcs
 int connect_arcs(struct Map_info *In, struct Map_info *Pnts,
-		 struct Map_info *Out, int nfield, double thresh, int snap)
+		 struct Map_info *Out, int afield, int nfield,
+		 double thresh, int snap)
     int narcs;
     int type, line, seg, i, ltype, broken;
     double px, py, pz, spdist, dist;
     struct line_pnts *Points, *Pline, *Pout;
-    struct line_cats *Cats, *Cline;
+    struct line_cats *Cats, *Cline, *Cnew;
+    int maxcat, findex, ncats;
     narcs = 0;
@@ -34,10 +36,16 @@
     Pout = Vect_new_line_struct();
     Cats = Vect_new_cats_struct();
     Cline = Vect_new_cats_struct();
+    Cnew = Vect_new_cats_struct();
     /* rewrite all primitives to output file */
     Vect_copy_map_lines(In, Out);
     Vect_build_partial(Out, GV_BUILD_BASE);
+    findex = Vect_cidx_get_field_index(In, afield);
+    ncats = Vect_cidx_get_num_cats_by_index(In, findex);
+    Vect_cidx_get_cat_by_index(In, findex, ncats - 1, &maxcat, &type, &line);
     /* go thorough all points in point map and write a new arcs if missing */
     while ((type = Vect_read_next_line(Pnts, Points, Cats)) >= 0) {
@@ -103,7 +111,10 @@
 		Vect_reset_line(Pout);
 		Vect_append_point(Pout, px, py, pz);
 		Vect_append_point(Pout, Points->x[0], Points->y[0], Points->z[0]);
-		Vect_write_line(Out, ltype, Pout, Cline);
+		maxcat++;
+		Vect_reset_cats(Cnew);
+		Vect_cat_set(Cnew, afield, maxcat);
+		Vect_write_line(Out, ltype, Pout, Cnew);
 		narcs++;
@@ -122,6 +133,7 @@
     Vect_destroy_line_struct(Pout);
     Vect_destroy_cats_struct(Cats);
     Vect_destroy_cats_struct(Cline);
+    Vect_destroy_cats_struct(Cnew);
     return narcs;
Modified: grass/trunk/vector/v.net/main.c
--- grass/trunk/vector/v.net/main.c	2013-09-27 14:05:18 UTC (rev 57856)
+++ grass/trunk/vector/v.net/main.c	2013-09-27 14:28:32 UTC (rev 57857)
@@ -138,8 +138,8 @@
 	    int narcs;
 	    if (act == TOOL_CONNECT)
-		narcs = connect_arcs(In, Points, Out, nfield, thresh,
-		                     opt.snap_flag->answer);
+		narcs = connect_arcs(In, Points, Out, afield, nfield,
+		                     thresh, opt.snap_flag->answer);
 	    else
 		narcs = create_arcs(file_arcs, Points, Out, afield, nfield);
Modified: grass/trunk/vector/v.net/proto.h
--- grass/trunk/vector/v.net/proto.h	2013-09-27 14:05:18 UTC (rev 57856)
+++ grass/trunk/vector/v.net/proto.h	2013-09-27 14:28:32 UTC (rev 57857)
@@ -24,7 +24,7 @@
 /* connect.c */
 int connect_arcs(struct Map_info *, struct Map_info *,
-		 struct Map_info *, int, double, int);
+		 struct Map_info *, int, int, double, int);
 /* nodes.c */
 int nodes(struct Map_info *, struct Map_info *, int,
