[GRASS-SVN] r57881 - grass/branches/releasebranch_6_4
Mon Sep 30 11:49:48 PDT 2013
Author: neteler
Date: 2013-09-30 11:49:48 -0700 (Mon, 30 Sep 2013)
New Revision: 57881
   grass/branches/releasebranch_6_4/aclocal.m4
   grass/branches/releasebranch_6_4/configure
configure: update for AIX
Modified: grass/branches/releasebranch_6_4/aclocal.m4
--- grass/branches/releasebranch_6_4/aclocal.m4	2013-09-30 18:25:53 UTC (rev 57880)
+++ grass/branches/releasebranch_6_4/aclocal.m4	2013-09-30 18:49:48 UTC (rev 57881)
@@ -658,7 +658,8 @@
 		fi
 		LD_SEARCH_FLAGS='-R ${LIB_RUNTIME_DIR}'
 	    else
-		SHLIB_LD="${SRCDIR}/ldAix /bin/ld -bhalt:4 -bM:SRE -bE:lib.exp -H512 -T512 -bnoentry ${SHLIB_LD_FLAGS}"
+		#SHLIB_LD="${SRCDIR}/ldAix /bin/ld -bhalt:4 -bM:SRE -bE:lib.exp -H512 -T512 -bnoentry ${SHLIB_LD_FLAGS}"
+		SHLIB_LD="$CC -shared"
 		CC_SEARCH_FLAGS='-L${LIB_RUNTIME_DIR}'
 		LD_SEARCH_FLAGS=${CC_SEARCH_FLAGS}
 		GRASS_NEEDS_EXP_FILE=1
@@ -697,7 +698,8 @@
 		    SHLIB_LD_FLAGS="-b64"
 		fi
 	    fi
 	    # On AIX <=v4 systems, libbsd.a has to be linked in to support
 	    # non-blocking file IO.  This library has to be linked in after
Modified: grass/branches/releasebranch_6_4/configure
--- grass/branches/releasebranch_6_4/configure	2013-09-30 18:25:53 UTC (rev 57880)
+++ grass/branches/releasebranch_6_4/configure	2013-09-30 18:49:48 UTC (rev 57881)
@@ -1799,7 +1799,8 @@
 		fi
 	    else
@@ -1838,7 +1839,8 @@
 		fi
 	    fi
@@ -1853,13 +1855,13 @@
 	    # known GMT value.
 	    echo $ac_n "checking for gettimeofday in -lbsd""... $ac_c" 1>&6
-echo "configure:1857: checking for gettimeofday in -lbsd" >&5
+echo "configure:1859: checking for gettimeofday in -lbsd" >&5
 ac_lib_var=`echo bsd'_'gettimeofday | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lbsd  $LIBS"
 cat > conftest.$ac_ext <<EOF
-#line 1863 "configure"
+#line 1865 "configure"
 #include "confdefs.h"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -1870,7 +1872,7 @@
 gettimeofday()
 ; return 0; }
 EOF
-if { (eval echo configure:1874: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1876: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -1911,13 +1913,13 @@
 	    # is always linked to, for compatibility.
 	    echo $ac_n "checking for inet_ntoa in -lbind""... $ac_c" 1>&6
-echo "configure:1915: checking for inet_ntoa in -lbind" >&5
+echo "configure:1917: checking for inet_ntoa in -lbind" >&5
 ac_lib_var=`echo bind'_'inet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-lbind  $LIBS"
-#line 1921 "configure"
+#line 1923 "configure"
@@ -1928,7 +1930,7 @@
 inet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:1932: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1934: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -1989,13 +1991,13 @@
 	    SHLIB_SUFFIX=".sl"
 	    echo $ac_n "checking for shl_load in -ldld""... $ac_c" 1>&6
-echo "configure:1993: checking for shl_load in -ldld" >&5
+echo "configure:1995: checking for shl_load in -ldld" >&5
 ac_lib_var=`echo dld'_'shl_load | sed 'y%./+-%__p_%'`
 LIBS="-ldld  $LIBS"
-#line 1999 "configure"
+#line 2001 "configure"
@@ -2006,7 +2008,7 @@
 shl_load()
 ; return 0; }
 EOF
-if { (eval echo configure:2010: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2012: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -2071,13 +2073,13 @@
 	HP-UX-*.08.*|HP-UX-*.09.*|HP-UX-*.10.*)
 	    SHLIB_SUFFIX=".sl"
-echo "configure:2075: checking for shl_load in -ldld" >&5
+echo "configure:2077: checking for shl_load in -ldld" >&5
 LIBS="-ldld  $LIBS"
-#line 2081 "configure"
+#line 2083 "configure"
@@ -2088,7 +2090,7 @@
 shl_load()
 ; return 0; }
 EOF
-if { (eval echo configure:2092: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2094: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -2210,15 +2212,15 @@
 	    else
 		ac_safe=`echo "dld.h" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for dld.h""... $ac_c" 1>&6
-echo "configure:2214: checking for dld.h" >&5
+echo "configure:2216: checking for dld.h" >&5
-#line 2217 "configure"
+#line 2219 "configure"
 #include <dld.h>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:2222: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2224: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -2278,15 +2280,15 @@
 	    else
-echo "configure:2282: checking for dld.h" >&5
+echo "configure:2284: checking for dld.h" >&5
-#line 2285 "configure"
+#line 2287 "configure"
 #include <dld.h>
 EOF
-{ (eval echo configure:2290: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2292: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2383,9 +2385,9 @@
 	    CC_SEARCH_FLAGS=""
 	    LD_SEARCH_FLAGS=""
 	    echo $ac_n "checking for ELF""... $ac_c" 1>&6
-echo "configure:2387: checking for ELF" >&5
+echo "configure:2389: checking for ELF" >&5
-#line 2389 "configure"
+#line 2391 "configure"
 #ifdef __ELF__
@@ -2415,15 +2417,15 @@
 	    # Not available on all versions:  check for include file.
 	    ac_safe=`echo "dlfcn.h" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for dlfcn.h""... $ac_c" 1>&6
-echo "configure:2419: checking for dlfcn.h" >&5
+echo "configure:2421: checking for dlfcn.h" >&5
-#line 2422 "configure"
+#line 2424 "configure"
 #include <dlfcn.h>
 EOF
-{ (eval echo configure:2427: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2429: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2447,9 +2449,9 @@
 		CC_SEARCH_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR}'
 		LD_SEARCH_FLAGS='-rpath ${LIB_RUNTIME_DIR}'
-echo "configure:2451: checking for ELF" >&5
+echo "configure:2453: checking for ELF" >&5
-#line 2453 "configure"
+#line 2455 "configure"
 #ifdef __ELF__
@@ -2773,17 +2775,17 @@
 	    # that don't grok the -Bexport option.  Test that it does.
 	    hold_ldflags=$LDFLAGS
 	    echo $ac_n "checking for ld accepts -Bexport flag""... $ac_c" 1>&6
-echo "configure:2777: checking for ld accepts -Bexport flag" >&5
+echo "configure:2779: checking for ld accepts -Bexport flag" >&5
 	    LDFLAGS="${LDFLAGS} -Wl,-Bexport"
-#line 2780 "configure"
+#line 2782 "configure"
 int main() {
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:2787: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2789: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   found=yes
 else
@@ -3581,7 +3583,7 @@
 # Done checking fortran
 echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:3585: checking for additional include dirs" >&5
+echo "configure:3587: checking for additional include dirs" >&5
 case "$with_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -3604,7 +3606,7 @@
 # With libs option
 echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:3608: checking for additional library dirs" >&5
+echo "configure:3610: checking for additional library dirs" >&5
 case "$with_libs" in
 	{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -3638,7 +3640,7 @@
 # SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
 # ./install, which can be erroneously created by make from ./install.sh.
 echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:3642: checking for a BSD compatible install" >&5
+echo "configure:3644: checking for a BSD compatible install" >&5
 if test -z "$INSTALL"; then
   IFS="${IFS= 	}"; ac_save_IFS="$IFS"; IFS=":"
@@ -3691,7 +3693,7 @@
 # Extract the first word of "flex", so it can be a program name with args.
 set dummy flex; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:3695: checking for $ac_word" >&5
+echo "configure:3697: checking for $ac_word" >&5
 if test -n "$LEX"; then
   ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -3722,13 +3724,13 @@
   *) ac_lib=l ;;
   esac
   echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:3726: checking for yywrap in -l$ac_lib" >&5
+echo "configure:3728: checking for yywrap in -l$ac_lib" >&5
 ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
 LIBS="-l$ac_lib  $LIBS"
-#line 3732 "configure"
+#line 3734 "configure"
@@ -3739,7 +3741,7 @@
 yywrap()
 ; return 0; }
 EOF
-if { (eval echo configure:3743: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3745: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3764,7 +3766,7 @@
     # Extract the first word of "lex", so it can be a program name with args.
 set dummy lex; ac_word=$2
-echo "configure:3768: checking for $ac_word" >&5
+echo "configure:3770: checking for $ac_word" >&5
 case "$LEXPATH" in
@@ -3804,7 +3806,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
-echo "configure:3808: checking for $ac_word" >&5
+echo "configure:3810: checking for $ac_word" >&5
 if test -n "$YACC"; then
   ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -3835,7 +3837,7 @@
     # Extract the first word of "yacc", so it can be a program name with args.
 set dummy yacc; ac_word=$2
-echo "configure:3839: checking for $ac_word" >&5
+echo "configure:3841: checking for $ac_word" >&5
 case "$YACCPATH" in
@@ -3873,7 +3875,7 @@
 # Extract the first word of "ranlib", so it can be a program name with args.
 set dummy ranlib; ac_word=$2
-echo "configure:3877: checking for $ac_word" >&5
+echo "configure:3879: checking for $ac_word" >&5
 if test -n "$RANLIB"; then
   ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -3902,7 +3904,7 @@
-echo "configure:3906: checking for $ac_word" >&5
+echo "configure:3908: checking for $ac_word" >&5
 if test -n "$AR"; then
   ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -3933,7 +3935,7 @@
-echo "configure:3937: checking for $ac_word" >&5
+echo "configure:3939: checking for $ac_word" >&5
 if test -n "$ENV"; then
   ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -3962,7 +3964,7 @@
 # Extract the first word of "perl", so it can be a program name with args.
 set dummy perl; ac_word=$2
-echo "configure:3966: checking for $ac_word" >&5
+echo "configure:3968: checking for $ac_word" >&5
 case "$PERL" in
@@ -3993,10 +3995,10 @@
 fi
 echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:3997: checking for ANSI C header files" >&5
+echo "configure:3999: checking for ANSI C header files" >&5
-#line 4000 "configure"
+#line 4002 "configure"
 #include <stdlib.h>
 #include <stdarg.h>
@@ -4004,7 +4006,7 @@
 #include <float.h>
 EOF
-{ (eval echo configure:4008: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4010: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4021,7 +4023,7 @@
 if test $ac_cv_header_stdc = yes; then
   # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 4025 "configure"
+#line 4027 "configure"
 #include <string.h>
 EOF
@@ -4039,7 +4041,7 @@
   # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 4043 "configure"
+#line 4045 "configure"
 #include <stdlib.h>
 EOF
@@ -4060,7 +4062,7 @@
 else
-#line 4064 "configure"
+#line 4066 "configure"
 #include <ctype.h>
 #define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -4071,7 +4073,7 @@
 exit (0); }
 EOF
-if { (eval echo configure:4075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4077: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
 else
@@ -4098,15 +4100,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:4102: checking for $ac_hdr" >&5
+echo "configure:4104: checking for $ac_hdr" >&5
-#line 4105 "configure"
+#line 4107 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4110: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4112: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4135,15 +4137,15 @@
 do
-echo "configure:4139: checking for $ac_hdr" >&5
+echo "configure:4141: checking for $ac_hdr" >&5
-#line 4142 "configure"
+#line 4144 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4147: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4149: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4172,15 +4174,15 @@
 do
-echo "configure:4176: checking for $ac_hdr" >&5
+echo "configure:4178: checking for $ac_hdr" >&5
-#line 4179 "configure"
+#line 4181 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4184: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4186: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4209,15 +4211,15 @@
 do
-echo "configure:4213: checking for $ac_hdr" >&5
+echo "configure:4215: checking for $ac_hdr" >&5
-#line 4216 "configure"
+#line 4218 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4221: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4223: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4246,15 +4248,15 @@
 do
-echo "configure:4250: checking for $ac_hdr" >&5
+echo "configure:4252: checking for $ac_hdr" >&5
-#line 4253 "configure"
+#line 4255 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:4258: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4260: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4280,10 +4282,10 @@
 done
 echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:4284: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:4286: checking whether time.h and sys/time.h may both be included" >&5
-#line 4287 "configure"
+#line 4289 "configure"
 #include <sys/types.h>
 #include <sys/time.h>
@@ -4292,7 +4294,7 @@
 struct tm *tp;
 ; return 0; }
 EOF
-if { (eval echo configure:4296: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4298: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_header_time=yes
 else
@@ -4312,10 +4314,10 @@
 fi
 echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:4316: checking for off_t" >&5
+echo "configure:4318: checking for off_t" >&5
-#line 4319 "configure"
+#line 4321 "configure"
 #if STDC_HEADERS
@@ -4342,10 +4344,10 @@
 fi
 echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:4346: checking for uid_t in sys/types.h" >&5
+echo "configure:4348: checking for uid_t in sys/types.h" >&5
-#line 4349 "configure"
+#line 4351 "configure"
 EOF
@@ -4373,10 +4375,10 @@
 fi
 echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:4377: checking return type of signal handlers" >&5
+echo "configure:4379: checking return type of signal handlers" >&5
-#line 4380 "configure"
+#line 4382 "configure"
 #include <signal.h>
@@ -4393,7 +4395,7 @@
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:4397: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4399: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_type_signal=void
 else
@@ -4411,10 +4413,10 @@
 echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:4415: checking for Cygwin environment" >&5
+echo "configure:4417: checking for Cygwin environment" >&5
-#line 4418 "configure"
+#line 4420 "configure"
 int main() {
@@ -4425,7 +4427,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:4429: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4431: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -4443,10 +4445,10 @@
 for ac_func in ftime gethostname gettimeofday lseek nice time uname
 do
 echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:4447: checking for $ac_func" >&5
+echo "configure:4449: checking for $ac_func" >&5
-#line 4450 "configure"
+#line 4452 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char $ac_func(); below.  */
@@ -4469,7 +4471,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4473: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4475: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_$ac_func=yes"
 else
@@ -4495,10 +4497,10 @@
 for ac_func in seteuid setpriority setreuid setruid
 do
-echo "configure:4499: checking for $ac_func" >&5
+echo "configure:4501: checking for $ac_func" >&5
-#line 4502 "configure"
+#line 4504 "configure"
@@ -4521,7 +4523,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4525: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4527: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4547,10 +4549,10 @@
 for ac_func in drand48
 do
-echo "configure:4551: checking for $ac_func" >&5
+echo "configure:4553: checking for $ac_func" >&5
-#line 4554 "configure"
+#line 4556 "configure"
@@ -4573,7 +4575,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4577: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4579: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4599,10 +4601,10 @@
 for ac_func in putenv setenv
 do
-echo "configure:4603: checking for $ac_func" >&5
+echo "configure:4605: checking for $ac_func" >&5
-#line 4606 "configure"
+#line 4608 "configure"
@@ -4625,7 +4627,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4629: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4631: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4651,10 +4653,10 @@
 for ac_func in nanosleep
 do
-echo "configure:4655: checking for $ac_func" >&5
+echo "configure:4657: checking for $ac_func" >&5
-#line 4658 "configure"
+#line 4660 "configure"
@@ -4677,7 +4679,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4681: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4683: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4702,13 +4704,13 @@
 if test "$cross_compiling" != "yes" ; then
 echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:4706: checking whether setpgrp takes no argument" >&5
+echo "configure:4708: checking whether setpgrp takes no argument" >&5
 if test "$cross_compiling" = yes; then
   { echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
 else
-#line 4712 "configure"
+#line 4714 "configure"
 #ifdef HAVE_UNISTD_H
@@ -4728,7 +4730,7 @@
 EOF
-if { (eval echo configure:4732: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4734: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
   ac_cv_func_setpgrp_void=no
 else
@@ -4756,16 +4758,16 @@
 fi
 echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:4760: checking for long long int" >&5
+echo "configure:4762: checking for long long int" >&5
-#line 4762 "configure"
+#line 4764 "configure"
 int main() {
 long long int x;
 ; return 0; }
 EOF
-if { (eval echo configure:4769: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4771: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
 echo "$ac_t""yes" 1>&6
@@ -4785,7 +4787,7 @@
 rm -f conftest*
 echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:4789: checking for W11" >&5
+echo "configure:4791: checking for W11" >&5
 case "$enable_w11" in
 	yes|no)	echo "$ac_t"""$enable_w11"" 1>&6	;;
 	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
@@ -4813,7 +4815,7 @@
 # Uses ac_ vars as temps to allow command line to override cache and checks.
 # --without-x overrides everything else, but does not touch the cache.
 echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:4817: checking for X" >&5
+echo "configure:4819: checking for X" >&5
 # Check whether --with-x or --without-x was given.
 if test "${with_x+set}" = set; then
@@ -4873,12 +4875,12 @@
   # First, try using that file with no special directory specified.
-#line 4877 "configure"
+#line 4879 "configure"
 #include <$x_direct_test_include>
 EOF
-{ (eval echo configure:4882: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4884: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -4947,14 +4949,14 @@
   LIBS="-l$x_direct_test_library $LIBS"
-#line 4951 "configure"
+#line 4953 "configure"
 int main() {
 ${x_direct_test_function}()
 ; return 0; }
 EOF
-if { (eval echo configure:4958: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4960: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LIBS="$ac_save_LIBS"
 # We can link X programs with no special library path.
@@ -5059,17 +5061,17 @@
     case "`(uname -sr) 2>/dev/null`" in
     "SunOS 5"*)
       echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:5063: checking whether -R must be followed by a space" >&5
+echo "configure:5065: checking whether -R must be followed by a space" >&5
       ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 5066 "configure"
+#line 5068 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:5073: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_nospace=yes
 else
@@ -5085,14 +5087,14 @@
       else
 	LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 5089 "configure"
+#line 5091 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:5096: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5098: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_space=yes
 else
@@ -5124,13 +5126,13 @@
     # libraries were built with DECnet support.  And karl at cs.umb.edu says
     # the Alpha needs dnet_stub (dnet does not exist).
     echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:5128: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:5130: checking for dnet_ntoa in -ldnet" >&5
 ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet  $LIBS"
-#line 5134 "configure"
+#line 5136 "configure"
@@ -5141,7 +5143,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:5145: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5147: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5162,13 +5164,13 @@
     if test $ac_cv_lib_dnet_dnet_ntoa = no; then
       echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:5166: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:5168: checking for dnet_ntoa in -ldnet_stub" >&5
 ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet_stub  $LIBS"
-#line 5172 "configure"
+#line 5174 "configure"
@@ -5179,7 +5181,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:5183: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5185: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5207,10 +5209,10 @@
     # The nsl library prevents programs from opening the X display
     # on Irix 5.2, according to dickey at clark.net.
     echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:5211: checking for gethostbyname" >&5
+echo "configure:5213: checking for gethostbyname" >&5
-#line 5214 "configure"
+#line 5216 "configure"
     which can conflict with char gethostbyname(); below.  */
@@ -5233,7 +5235,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5237: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5239: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gethostbyname=yes"
 else
@@ -5253,13 +5255,13 @@
     if test $ac_cv_func_gethostbyname = no; then
       echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:5257: checking for gethostbyname in -lnsl" >&5
+echo "configure:5259: checking for gethostbyname in -lnsl" >&5
 ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 5263 "configure"
+#line 5265 "configure"
@@ -5270,7 +5272,7 @@
 gethostbyname()
 ; return 0; }
 EOF
-if { (eval echo configure:5274: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5276: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5299,10 +5301,10 @@
     # -lsocket must be given before -lnsl if both are needed.
     # We assume that if connect needs -lnsl, so does gethostbyname.
     echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:5303: checking for connect" >&5
+echo "configure:5305: checking for connect" >&5
-#line 5306 "configure"
+#line 5308 "configure"
     which can conflict with char connect(); below.  */
@@ -5325,7 +5327,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5329: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5331: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_connect=yes"
 else
@@ -5345,13 +5347,13 @@
     if test $ac_cv_func_connect = no; then
       echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:5349: checking for connect in -lsocket" >&5
+echo "configure:5351: checking for connect in -lsocket" >&5
 ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
 LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 5355 "configure"
+#line 5357 "configure"
@@ -5362,7 +5364,7 @@
 connect()
 ; return 0; }
 EOF
-if { (eval echo configure:5366: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5368: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5385,10 +5387,10 @@
     # gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
     echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:5389: checking for remove" >&5
+echo "configure:5391: checking for remove" >&5
-#line 5392 "configure"
+#line 5394 "configure"
     which can conflict with char remove(); below.  */
@@ -5411,7 +5413,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5415: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5417: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_remove=yes"
 else
@@ -5431,13 +5433,13 @@
     if test $ac_cv_func_remove = no; then
       echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:5435: checking for remove in -lposix" >&5
+echo "configure:5437: checking for remove in -lposix" >&5
 ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
 LIBS="-lposix  $LIBS"
-#line 5441 "configure"
+#line 5443 "configure"
@@ -5448,7 +5450,7 @@
 remove()
 ; return 0; }
 EOF
-if { (eval echo configure:5452: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5454: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5471,10 +5473,10 @@
     # BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
     echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:5475: checking for shmat" >&5
+echo "configure:5477: checking for shmat" >&5
-#line 5478 "configure"
+#line 5480 "configure"
     which can conflict with char shmat(); below.  */
@@ -5497,7 +5499,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5501: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5503: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_shmat=yes"
 else
@@ -5517,13 +5519,13 @@
     if test $ac_cv_func_shmat = no; then
       echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:5521: checking for shmat in -lipc" >&5
+echo "configure:5523: checking for shmat in -lipc" >&5
 ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
 LIBS="-lipc  $LIBS"
-#line 5527 "configure"
+#line 5529 "configure"
@@ -5534,7 +5536,7 @@
 shmat()
 ; return 0; }
 EOF
-if { (eval echo configure:5538: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5540: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5566,13 +5568,13 @@
   # libraries we check for below, so use a different variable.
   #  --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
   echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:5570: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:5572: checking for IceConnectionNumber in -lICE" >&5
 ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
 LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 5576 "configure"
+#line 5578 "configure"
@@ -5583,7 +5585,7 @@
 IceConnectionNumber()
 ; return 0; }
 EOF
-if { (eval echo configure:5587: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5589: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5621,7 +5623,7 @@
 echo $ac_n "checking whether to use Curses""... $ac_c" 1>&6
-echo "configure:5625: checking whether to use Curses" >&5
+echo "configure:5627: checking whether to use Curses" >&5
 echo "$ac_t"""$with_curses"" 1>&6
 case "$with_curses" in
 	"no")	USE_CURSES=	;;
@@ -5640,15 +5642,15 @@
 do
-echo "configure:5644: checking for $ac_hdr" >&5
+echo "configure:5646: checking for $ac_hdr" >&5
-#line 5647 "configure"
+#line 5649 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5652: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5654: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5679,10 +5681,10 @@
 echo $ac_n "checking curses.h WINDOW structure component""... $ac_c" 1>&6
-echo "configure:5683: checking curses.h WINDOW structure component" >&5
+echo "configure:5685: checking curses.h WINDOW structure component" >&5
 CURSES_MAXY=NONE
-#line 5686 "configure"
+#line 5688 "configure"
 #include <curses.h>
@@ -5691,7 +5693,7 @@
 WINDOW w; w.maxy = 0;
 ; return 0; }
 EOF
-if { (eval echo configure:5695: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5697: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   CURSES_MAXY=maxy
 else
@@ -5700,7 +5702,7 @@
 fi
 rm -f conftest*
-#line 5704 "configure"
+#line 5706 "configure"
 #include <curses.h>
@@ -5709,7 +5711,7 @@
 WINDOW w; w._maxy = 0;
 ; return 0; }
 EOF
-if { (eval echo configure:5713: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5715: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   CURSES_MAXY=_maxy
 else
@@ -5725,13 +5727,13 @@
 echo "$ac_t""$CURSES_MAXY" 1>&6
 echo $ac_n "checking for initscr in -lncurses""... $ac_c" 1>&6
-echo "configure:5729: checking for initscr in -lncurses" >&5
+echo "configure:5731: checking for initscr in -lncurses" >&5
 ac_lib_var=`echo ncurses'_'initscr | sed 'y%./+-%__p_%'`
 LIBS="-lncurses  $LIBS"
-#line 5735 "configure"
+#line 5737 "configure"
@@ -5742,7 +5744,7 @@
 initscr()
 ; return 0; }
 EOF
-if { (eval echo configure:5746: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5748: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5761,13 +5763,13 @@
   echo "$ac_t""no" 1>&6
 echo $ac_n "checking for initscr in -lcurses""... $ac_c" 1>&6
-echo "configure:5765: checking for initscr in -lcurses" >&5
+echo "configure:5767: checking for initscr in -lcurses" >&5
 ac_lib_var=`echo curses'_'initscr | sed 'y%./+-%__p_%'`
 LIBS="-lcurses  $LIBS"
-#line 5771 "configure"
+#line 5773 "configure"
@@ -5778,7 +5780,7 @@
 initscr()
 ; return 0; }
 EOF
-if { (eval echo configure:5782: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5784: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5807,13 +5809,13 @@
 echo $ac_n "checking for keypad in -lncurses""... $ac_c" 1>&6
-echo "configure:5811: checking for keypad in -lncurses" >&5
+echo "configure:5813: checking for keypad in -lncurses" >&5
 ac_lib_var=`echo ncurses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5817 "configure"
+#line 5819 "configure"
@@ -5824,7 +5826,7 @@
 keypad()
 ; return 0; }
 EOF
-if { (eval echo configure:5828: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5830: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5846,13 +5848,13 @@
 echo $ac_n "checking for keypad in -lcurses""... $ac_c" 1>&6
-echo "configure:5850: checking for keypad in -lcurses" >&5
+echo "configure:5852: checking for keypad in -lcurses" >&5
 ac_lib_var=`echo curses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5856 "configure"
+#line 5858 "configure"
@@ -5863,7 +5865,7 @@
 keypad()
 ; return 0; }
 EOF
-if { (eval echo configure:5867: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5869: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5893,13 +5895,13 @@
 fi # $USE_CURSES
 echo $ac_n "checking for gtty in -lcompat""... $ac_c" 1>&6
-echo "configure:5897: checking for gtty in -lcompat" >&5
+echo "configure:5899: checking for gtty in -lcompat" >&5
 ac_lib_var=`echo compat'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lcompat  $LIBS"
-#line 5903 "configure"
+#line 5905 "configure"
@@ -5910,7 +5912,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:5914: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5916: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5929,13 +5931,13 @@
 echo $ac_n "checking for gtty in -lbsd-compat""... $ac_c" 1>&6
-echo "configure:5933: checking for gtty in -lbsd-compat" >&5
+echo "configure:5935: checking for gtty in -lbsd-compat" >&5
 ac_lib_var=`echo bsd-compat'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lbsd-compat  $LIBS"
-#line 5939 "configure"
+#line 5941 "configure"
@@ -5946,7 +5948,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:5950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5952: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5965,13 +5967,13 @@
 echo $ac_n "checking for gtty in -lbsd""... $ac_c" 1>&6
-echo "configure:5969: checking for gtty in -lbsd" >&5
+echo "configure:5971: checking for gtty in -lbsd" >&5
 ac_lib_var=`echo bsd'_'gtty | sed 'y%./+-%__p_%'`
 LIBS="-lbsd  $LIBS"
-#line 5975 "configure"
+#line 5977 "configure"
@@ -5982,7 +5984,7 @@
 gtty()
 ; return 0; }
 EOF
-if { (eval echo configure:5986: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5988: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6016,12 +6018,12 @@
 LIBS=""
 echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:6020: checking for library containing cuserid" >&5
+echo "configure:6022: checking for library containing cuserid" >&5
 ac_func_search_save_LIBS="$LIBS"
 ac_cv_search_cuserid="no"
-#line 6025 "configure"
+#line 6027 "configure"
@@ -6032,7 +6034,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:6036: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6038: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="none required"
 else
@@ -6043,7 +6045,7 @@
 test "$ac_cv_search_cuserid" = "no" && for i in compat; do
 LIBS="-l$i  $ac_func_search_save_LIBS"
-#line 6047 "configure"
+#line 6049 "configure"
@@ -6054,7 +6056,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:6058: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6060: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="-l$i"
 break
@@ -6080,10 +6082,10 @@
 # Note: -lxdr -liberty -lws2_32 is for MinGW
 echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:6084: checking for xdrmem_create" >&5
+echo "configure:6086: checking for xdrmem_create" >&5
-#line 6087 "configure"
+#line 6089 "configure"
     which can conflict with char xdrmem_create(); below.  */
@@ -6106,7 +6108,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6110: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6112: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_xdrmem_create=yes"
 else
@@ -6124,13 +6126,13 @@
 echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:6128: checking for xdrmem_create in -lsun" >&5
+echo "configure:6130: checking for xdrmem_create in -lsun" >&5
 ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lsun  $LIBS"
-#line 6134 "configure"
+#line 6136 "configure"
@@ -6141,7 +6143,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6145: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6147: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6160,13 +6162,13 @@
 echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:6164: checking for xdrmem_create in -lnsl" >&5
+echo "configure:6166: checking for xdrmem_create in -lnsl" >&5
 ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 6170 "configure"
+#line 6172 "configure"
@@ -6177,7 +6179,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6181: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6183: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6196,13 +6198,13 @@
 echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:6200: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:6202: checking for xdrmem_create in -lrpclib" >&5
 ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lrpclib  $LIBS"
-#line 6206 "configure"
+#line 6208 "configure"
@@ -6213,7 +6215,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6217: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6219: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6232,13 +6234,13 @@
 echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:6236: checking for xdrmem_create in -lxdr" >&5
+echo "configure:6238: checking for xdrmem_create in -lxdr" >&5
 ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
 LIBS="-lxdr -liberty -lws2_32  $LIBS"
-#line 6242 "configure"
+#line 6244 "configure"
@@ -6249,7 +6251,7 @@
 xdrmem_create()
 ; return 0; }
 EOF
-if { (eval echo configure:6253: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6255: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6283,10 +6285,10 @@
 for ac_func in asprintf
 do
-echo "configure:6287: checking for $ac_func" >&5
+echo "configure:6289: checking for $ac_func" >&5
-#line 6290 "configure"
+#line 6292 "configure"
@@ -6309,7 +6311,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6313: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6315: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6336,10 +6338,10 @@
 # Test if mathlib needs -lm flag or is included with libc
 echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:6340: checking for atan" >&5
+echo "configure:6342: checking for atan" >&5
-#line 6343 "configure"
+#line 6345 "configure"
     which can conflict with char atan(); below.  */
@@ -6362,7 +6364,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6366: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6368: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_atan=yes"
 else
@@ -6380,13 +6382,13 @@
 echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:6384: checking for atan in -lm" >&5
+echo "configure:6386: checking for atan in -lm" >&5
 ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
 LIBS="-lm  $LIBS"
-#line 6390 "configure"
+#line 6392 "configure"
@@ -6397,7 +6399,7 @@
 atan()
 ; return 0; }
 EOF
-if { (eval echo configure:6401: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6403: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6424,10 +6426,10 @@
 echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:6428: checking for dlsym" >&5
+echo "configure:6430: checking for dlsym" >&5
-#line 6431 "configure"
+#line 6433 "configure"
     which can conflict with char dlsym(); below.  */
@@ -6450,7 +6452,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6454: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6456: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dlsym=yes"
 else
@@ -6468,13 +6470,13 @@
 echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:6472: checking for dlsym in -ldl" >&5
+echo "configure:6474: checking for dlsym in -ldl" >&5
 ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
 LIBS="-ldl  $LIBS"
-#line 6478 "configure"
+#line 6480 "configure"
@@ -6485,7 +6487,7 @@
 dlsym()
 ; return 0; }
 EOF
-if { (eval echo configure:6489: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6491: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6512,10 +6514,10 @@
 echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:6516: checking for iconv" >&5
+echo "configure:6518: checking for iconv" >&5
-#line 6519 "configure"
+#line 6521 "configure"
     which can conflict with char iconv(); below.  */
@@ -6538,7 +6540,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6542: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6544: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_iconv=yes"
 else
@@ -6556,13 +6558,13 @@
 echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:6560: checking for iconv in -liconv" >&5
+echo "configure:6562: checking for iconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-liconv  $LIBS"
-#line 6566 "configure"
+#line 6568 "configure"
@@ -6573,7 +6575,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6577: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6579: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6592,13 +6594,13 @@
 echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6596: checking for iconv in -lgiconv" >&5
+echo "configure:6598: checking for iconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-lgiconv  $LIBS"
-#line 6602 "configure"
+#line 6604 "configure"
@@ -6609,7 +6611,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6613: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6615: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6628,10 +6630,10 @@
 echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:6632: checking for libiconv" >&5
+echo "configure:6634: checking for libiconv" >&5
-#line 6635 "configure"
+#line 6637 "configure"
     which can conflict with char libiconv(); below.  */
@@ -6654,7 +6656,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6658: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6660: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_libiconv=yes"
 else
@@ -6672,13 +6674,13 @@
 echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:6676: checking for libiconv in -liconv" >&5
+echo "configure:6678: checking for libiconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6682 "configure"
+#line 6684 "configure"
@@ -6689,7 +6691,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6693: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6695: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6708,13 +6710,13 @@
 echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6712: checking for libiconv in -lgiconv" >&5
+echo "configure:6714: checking for libiconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6718 "configure"
+#line 6720 "configure"
@@ -6725,7 +6727,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:6729: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6731: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6762,10 +6764,10 @@
 have_socket=1
 echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:6766: checking for socket" >&5
+echo "configure:6768: checking for socket" >&5
-#line 6769 "configure"
+#line 6771 "configure"
     which can conflict with char socket(); below.  */
@@ -6788,7 +6790,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:6792: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6794: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_socket=yes"
 else
@@ -6806,13 +6808,13 @@
 echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:6810: checking for socket in -lsocket" >&5
+echo "configure:6812: checking for socket in -lsocket" >&5
 ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
 LIBS="-lsocket  $LIBS"
-#line 6816 "configure"
+#line 6818 "configure"
@@ -6823,7 +6825,7 @@
 socket()
 ; return 0; }
 EOF
-if { (eval echo configure:6827: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6829: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6871,7 +6873,7 @@
 echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:6875: checking for location of zlib includes" >&5
+echo "configure:6877: checking for location of zlib includes" >&5
 case "$with_zlib_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -6897,15 +6899,15 @@
 do
-echo "configure:6901: checking for $ac_hdr" >&5
+echo "configure:6903: checking for $ac_hdr" >&5
-#line 6904 "configure"
+#line 6906 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6909: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6911: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6939,7 +6941,7 @@
 echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:6943: checking for location of zlib library" >&5
+echo "configure:6945: checking for location of zlib library" >&5
 case "$with_zlib_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -6964,13 +6966,13 @@
 echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:6968: checking for deflate in -lz" >&5
+echo "configure:6970: checking for deflate in -lz" >&5
 ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
 LIBS="-lz  $LIBS"
-#line 6974 "configure"
+#line 6976 "configure"
@@ -6981,7 +6983,7 @@
 deflate()
 ; return 0; }
 EOF
-if { (eval echo configure:6985: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6987: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7029,7 +7031,7 @@
 echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:7033: checking for location of External PROJ.4 includes" >&5
+echo "configure:7035: checking for location of External PROJ.4 includes" >&5
 case "$with_proj_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -7055,15 +7057,15 @@
 do
-echo "configure:7059: checking for $ac_hdr" >&5
+echo "configure:7061: checking for $ac_hdr" >&5
-#line 7062 "configure"
+#line 7064 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7067: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7069: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7100,7 +7102,7 @@
 else
 echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:7104: checking External PROJ.4 version" >&5
+echo "configure:7106: checking External PROJ.4 version" >&5
 ac_save_cppflags="$CPPFLAGS"
 CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -7108,7 +7110,7 @@
         echo "$ac_t""unknown (cross-compiling)" 1>&6
 else
-#line 7112 "configure"
+#line 7114 "configure"
 #include <stdio.h>
@@ -7120,7 +7122,7 @@
 EOF
-if { (eval echo configure:7124: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:7126: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      proj_ver=`cat conftestdata`
         echo "$ac_t""$proj_ver" 1>&6
@@ -7145,7 +7147,7 @@
 echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:7149: checking for location of External PROJ.4 library" >&5
+echo "configure:7151: checking for location of External PROJ.4 library" >&5
 case "$with_proj_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -7170,13 +7172,13 @@
 echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:7174: checking for pj_get_def in -lproj" >&5
+echo "configure:7176: checking for pj_get_def in -lproj" >&5
 ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
 LIBS="-lproj  $LIBS"
-#line 7180 "configure"
+#line 7182 "configure"
@@ -7187,7 +7189,7 @@
 pj_get_def()
 ; return 0; }
 EOF
-if { (eval echo configure:7191: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7193: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7221,7 +7223,7 @@
 echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:7225: checking for location of External PROJ.4 data files" >&5
+echo "configure:7227: checking for location of External PROJ.4 data files" >&5
 case "$with_proj_share" in
         { echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -7245,14 +7247,14 @@
 # LOC_CHECK_SHARE does not work when cross compiling
 if test "$cross_compiling" = "yes" ; then
     echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:7249: checking for epsg" >&5
+echo "configure:7251: checking for epsg" >&5
 else
 ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:7256: checking for $PROJSHARE/epsg" >&5
+echo "configure:7258: checking for $PROJSHARE/epsg" >&5
     { echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -7284,7 +7286,7 @@
 # Extract the first word of "nad2bin", so it can be a program name with args.
 set dummy nad2bin; ac_word=$2
-echo "configure:7288: checking for $ac_word" >&5
+echo "configure:7290: checking for $ac_word" >&5
 case "$NAD2BIN" in
@@ -7324,7 +7326,7 @@
 echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:7328: checking whether to use regex" >&5
+echo "configure:7330: checking whether to use regex" >&5
 echo "$ac_t"""$with_regex"" 1>&6
 case "$with_regex" in
 	"no")	USE_REGEX=	;;
@@ -7344,7 +7346,7 @@
 echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:7348: checking for location of regex includes" >&5
+echo "configure:7350: checking for location of regex includes" >&5
 case "$with_regex_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -7370,15 +7372,15 @@
 do
-echo "configure:7374: checking for $ac_hdr" >&5
+echo "configure:7376: checking for $ac_hdr" >&5
-#line 7377 "configure"
+#line 7379 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7382: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7384: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7412,7 +7414,7 @@
 echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:7416: checking for location of regex library" >&5
+echo "configure:7418: checking for location of regex library" >&5
 case "$with_regex_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -7437,10 +7439,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:7441: checking for regcomp" >&5
+echo "configure:7443: checking for regcomp" >&5
-#line 7444 "configure"
+#line 7446 "configure"
     which can conflict with char regcomp(); below.  */
@@ -7463,7 +7465,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:7467: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7469: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_regcomp=yes"
 else
@@ -7490,13 +7492,13 @@
 echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:7494: checking for regcomp in -lregex" >&5
+echo "configure:7496: checking for regcomp in -lregex" >&5
 ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
 LIBS="-lregex  $LIBS"
-#line 7500 "configure"
+#line 7502 "configure"
@@ -7507,7 +7509,7 @@
 regcomp()
 ; return 0; }
 EOF
-if { (eval echo configure:7511: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7513: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7557,7 +7559,7 @@
 echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:7561: checking whether to use Readline" >&5
+echo "configure:7563: checking whether to use Readline" >&5
 echo "$ac_t"""$with_readline"" 1>&6
 case "$with_readline" in
 	"no")	USE_READLINE=	;;
@@ -7578,7 +7580,7 @@
 echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:7582: checking for location of Readline includes" >&5
+echo "configure:7584: checking for location of Readline includes" >&5
 case "$with_readline_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -7604,15 +7606,15 @@
 do
-echo "configure:7608: checking for $ac_hdr" >&5
+echo "configure:7610: checking for $ac_hdr" >&5
-#line 7611 "configure"
+#line 7613 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7616: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7618: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7648,15 +7650,15 @@
 do
-echo "configure:7652: checking for $ac_hdr" >&5
+echo "configure:7654: checking for $ac_hdr" >&5
-#line 7655 "configure"
+#line 7657 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7660: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7662: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7690,7 +7692,7 @@
 echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:7694: checking for location of Readline library" >&5
+echo "configure:7696: checking for location of Readline library" >&5
 case "$with_readline_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -7715,13 +7717,13 @@
 echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:7719: checking for readline in -lreadline" >&5
+echo "configure:7721: checking for readline in -lreadline" >&5
 ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
 LIBS="-lreadline  $LIBS"
-#line 7725 "configure"
+#line 7727 "configure"
@@ -7732,7 +7734,7 @@
 readline()
 ; return 0; }
 EOF
-if { (eval echo configure:7736: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7767,13 +7769,13 @@
 echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:7771: checking for add_history in -lhistory" >&5
+echo "configure:7773: checking for add_history in -lhistory" >&5
 ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
 LIBS="-lhistory  $LIBS"
-#line 7777 "configure"
+#line 7779 "configure"
@@ -7784,7 +7786,7 @@
 add_history()
 ; return 0; }
 EOF
-if { (eval echo configure:7788: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7790: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7826,7 +7828,7 @@
 # GDAL option
 echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:7830: checking whether to use GDAL" >&5
+echo "configure:7832: checking whether to use GDAL" >&5
 GDAL_LIBS=
 GDAL_CFLAGS=
@@ -7844,7 +7846,7 @@
   # Extract the first word of "gdal-config", so it can be a program name with args.
 set dummy gdal-config; ac_word=$2
-echo "configure:7848: checking for $ac_word" >&5
+echo "configure:7850: checking for $ac_word" >&5
 case "$GDAL_CONFIG" in
@@ -7899,14 +7901,14 @@
   LIBS="$LIBS $GDAL_LIBS"
   CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 7903 "configure"
+#line 7905 "configure"
 #include <gdal.h>
 int main() {
 GDALOpen("foo", GA_ReadOnly);
 ; return 0; }
 EOF
-if { (eval echo configure:7910: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
   echo "configure: failed program was:" >&5
@@ -7915,14 +7917,14 @@
   LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 7919 "configure"
+#line 7921 "configure"
 #include <gdal.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:7926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7928: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
 else
@@ -7954,7 +7956,7 @@
 # GEOS option
 echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:7958: checking whether to use GEOS" >&5
+echo "configure:7960: checking whether to use GEOS" >&5
 GEOS_LIBS=
 GGEOS_CFLAGS=
@@ -7972,7 +7974,7 @@
   # Extract the first word of "geos-config", so it can be a program name with args.
 set dummy geos-config; ac_word=$2
-echo "configure:7976: checking for $ac_word" >&5
+echo "configure:7978: checking for $ac_word" >&5
 case "$GEOS_CONFIG" in
@@ -8020,15 +8022,15 @@
 do
-echo "configure:8024: checking for $ac_hdr" >&5
+echo "configure:8026: checking for $ac_hdr" >&5
 cat > conftest.$ac_ext <<EOF
-#line 8027 "configure"
+#line 8029 "configure"
 #include "confdefs.h"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8032: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8034: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8067,13 +8069,13 @@
 echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:8071: checking for initGEOS in -lgeos_c" >&5
+echo "configure:8073: checking for initGEOS in -lgeos_c" >&5
 ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lgeos_c  $LIBS"
-#line 8077 "configure"
+#line 8079 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -8084,7 +8086,7 @@
 initGEOS()
 ; return 0; }
 EOF
-if { (eval echo configure:8088: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8090: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -8129,7 +8131,7 @@
 echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:8133: checking whether to use TIFF" >&5
+echo "configure:8135: checking whether to use TIFF" >&5
 echo "$ac_t"""$with_tiff"" 1>&6
 case "$with_tiff" in
 	"no")	USE_TIFF=	;;
@@ -8149,7 +8151,7 @@
 echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:8153: checking for location of TIFF includes" >&5
+echo "configure:8155: checking for location of TIFF includes" >&5
 case "$with_tiff_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -8175,15 +8177,15 @@
 do
-echo "configure:8179: checking for $ac_hdr" >&5
+echo "configure:8181: checking for $ac_hdr" >&5
-#line 8182 "configure"
+#line 8184 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8187: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8189: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8217,7 +8219,7 @@
 echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:8221: checking for location of TIFF library" >&5
+echo "configure:8223: checking for location of TIFF library" >&5
 case "$with_tiff_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -8248,13 +8250,13 @@
 echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:8252: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8254: checking for TIFFOpen in -ltiff" >&5
 ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
 LIBS="-ltiff  $LIBS"
-#line 8258 "configure"
+#line 8260 "configure"
@@ -8265,7 +8267,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8269: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8271: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8284,13 +8286,13 @@
-echo "configure:8288: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8290: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $MATHLIB $LIBS"
-#line 8294 "configure"
+#line 8296 "configure"
@@ -8301,7 +8303,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8305: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8307: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8320,13 +8322,13 @@
-echo "configure:8324: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8326: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $LIBS"
-#line 8330 "configure"
+#line 8332 "configure"
@@ -8337,7 +8339,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8341: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8343: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8356,13 +8358,13 @@
-echo "configure:8360: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8362: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 8366 "configure"
+#line 8368 "configure"
@@ -8373,7 +8375,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8377: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8379: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8392,13 +8394,13 @@
-echo "configure:8396: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8398: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $LIBS"
-#line 8402 "configure"
+#line 8404 "configure"
@@ -8409,7 +8411,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8413: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8415: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8428,13 +8430,13 @@
-echo "configure:8432: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8434: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $MATHLIB $LIBS"
-#line 8438 "configure"
+#line 8440 "configure"
@@ -8445,7 +8447,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8449: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8451: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8464,13 +8466,13 @@
-echo "configure:8468: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8470: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $ZLIB $LIBS"
-#line 8474 "configure"
+#line 8476 "configure"
@@ -8481,7 +8483,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8485: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8487: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8500,13 +8502,13 @@
-echo "configure:8504: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8506: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $ZLIB $MATHLIB $LIBS"
-#line 8510 "configure"
+#line 8512 "configure"
@@ -8517,7 +8519,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8521: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8523: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8615,7 +8617,7 @@
 echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8619: checking whether to use PNG" >&5
+echo "configure:8621: checking whether to use PNG" >&5
 echo "$ac_t"""$with_png"" 1>&6
 case "$with_png" in
 	"no")	USE_PNG=	;;
@@ -8634,7 +8636,7 @@
 echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8638: checking for location of PNG includes" >&5
+echo "configure:8640: checking for location of PNG includes" >&5
 case "$with_png_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8660,15 +8662,15 @@
 do
-echo "configure:8664: checking for $ac_hdr" >&5
+echo "configure:8666: checking for $ac_hdr" >&5
-#line 8667 "configure"
+#line 8669 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:8672: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8674: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -8702,7 +8704,7 @@
 echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:8706: checking for location of PNG library" >&5
+echo "configure:8708: checking for location of PNG library" >&5
 case "$with_png_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -8727,13 +8729,13 @@
 echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:8731: checking for png_read_image in -lpng" >&5
+echo "configure:8733: checking for png_read_image in -lpng" >&5
 ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
 LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 8737 "configure"
+#line 8739 "configure"
@@ -8744,7 +8746,7 @@
 png_read_image()
 ; return 0; }
 EOF
-if { (eval echo configure:8748: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8750: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8786,7 +8788,7 @@
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:8790: checking whether to use PostgreSQL" >&5
+echo "configure:8792: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -8813,7 +8815,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:8817: checking for location of PostgreSQL includes" >&5
+echo "configure:8819: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -8839,15 +8841,15 @@
 do
-echo "configure:8843: checking for $ac_hdr" >&5
+echo "configure:8845: checking for $ac_hdr" >&5
-#line 8846 "configure"
+#line 8848 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8851: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8853: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8885,7 +8887,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:8889: checking for location of PostgreSQL library" >&5
+echo "configure:8891: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -8914,13 +8916,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:8918: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8920: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 8924 "configure"
+#line 8926 "configure"
@@ -8931,7 +8933,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:8935: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8937: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8950,13 +8952,13 @@
-echo "configure:8954: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8956: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 8960 "configure"
+#line 8962 "configure"
@@ -8967,7 +8969,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:8971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8973: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8986,13 +8988,13 @@
-echo "configure:8990: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8992: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
-#line 8996 "configure"
+#line 8998 "configure"
@@ -9003,7 +9005,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9007: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9009: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9022,13 +9024,13 @@
-echo "configure:9026: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9028: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9032 "configure"
+#line 9034 "configure"
@@ -9039,7 +9041,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9043: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9045: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9096,13 +9098,13 @@
 ac_save_ldflags="$LDFLAGS"
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9100: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9102: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9106 "configure"
+#line 9108 "configure"
@@ -9113,7 +9115,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9117: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9119: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9135,13 +9137,13 @@
-echo "configure:9139: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9141: checking for PQcmdTuples in -lpq" >&5
-#line 9145 "configure"
+#line 9147 "configure"
@@ -9152,7 +9154,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9156: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9158: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9195,7 +9197,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9199: checking whether to use MySQL" >&5
+echo "configure:9201: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -9215,7 +9217,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9219: checking for location of MySQL includes" >&5
+echo "configure:9221: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9241,15 +9243,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:9245: checking for $ac_hdr" >&5
+echo "configure:9247: checking for $ac_hdr" >&5
-#line 9248 "configure"
+#line 9250 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9253: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9255: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9286,7 +9288,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9290: checking for location of MySQL library" >&5
+echo "configure:9292: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9317,13 +9319,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9321: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9323: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 9327 "configure"
+#line 9329 "configure"
@@ -9334,7 +9336,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9338: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9340: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9353,13 +9355,13 @@
-echo "configure:9357: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9359: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9363 "configure"
+#line 9365 "configure"
@@ -9370,7 +9372,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9374: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9376: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9389,13 +9391,13 @@
-echo "configure:9393: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9395: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9399 "configure"
+#line 9401 "configure"
@@ -9406,7 +9408,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9410: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9412: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9425,13 +9427,13 @@
-echo "configure:9429: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9431: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9435 "configure"
+#line 9437 "configure"
@@ -9442,7 +9444,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9446: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9448: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9461,13 +9463,13 @@
-echo "configure:9465: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9467: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9471 "configure"
+#line 9473 "configure"
@@ -9478,7 +9480,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9482: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9484: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9497,13 +9499,13 @@
-echo "configure:9501: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9503: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 9507 "configure"
+#line 9509 "configure"
@@ -9514,7 +9516,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9518: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9520: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9533,13 +9535,13 @@
-echo "configure:9537: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9539: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 9543 "configure"
+#line 9545 "configure"
@@ -9550,7 +9552,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9554: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9556: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9569,13 +9571,13 @@
-echo "configure:9573: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9575: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 9579 "configure"
+#line 9581 "configure"
@@ -9586,7 +9588,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9590: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9592: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9676,7 +9678,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:9680: checking for $ac_word" >&5
+echo "configure:9682: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -9717,10 +9719,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:9721: checking for mysql_server_init" >&5
+echo "configure:9723: checking for mysql_server_init" >&5
-#line 9724 "configure"
+#line 9726 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char mysql_server_init(); below.  */
@@ -9743,7 +9745,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9747: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9749: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -9781,7 +9783,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:9785: checking whether to use SQLite" >&5
+echo "configure:9787: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -9801,7 +9803,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:9805: checking for location of SQLite includes" >&5
+echo "configure:9807: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -9827,15 +9829,15 @@
 do
-echo "configure:9831: checking for $ac_hdr" >&5
+echo "configure:9833: checking for $ac_hdr" >&5
-#line 9834 "configure"
+#line 9836 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9839: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9841: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9878,7 +9880,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:9882: checking for location of SQLite library" >&5
+echo "configure:9884: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -9907,13 +9909,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:9911: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9913: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 9917 "configure"
+#line 9919 "configure"
@@ -9924,7 +9926,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:9928: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9930: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9943,13 +9945,13 @@
-echo "configure:9947: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9949: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 9953 "configure"
+#line 9955 "configure"
@@ -9960,7 +9962,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:9964: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9966: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9979,13 +9981,13 @@
-echo "configure:9983: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9985: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 9989 "configure"
+#line 9991 "configure"
@@ -9996,7 +9998,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10000: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10002: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10015,13 +10017,13 @@
-echo "configure:10019: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10021: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 10025 "configure"
+#line 10027 "configure"
@@ -10032,7 +10034,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10036: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10038: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10101,7 +10103,7 @@
 echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10105: checking whether to use FFMPEG" >&5
+echo "configure:10107: checking whether to use FFMPEG" >&5
 echo "$ac_t"""$with_ffmpeg"" 1>&6
 case "$with_ffmpeg" in
 	"no")	USE_FFMPEG=	;;
@@ -10121,7 +10123,7 @@
 echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10125: checking for location of FFMPEG includes" >&5
+echo "configure:10127: checking for location of FFMPEG includes" >&5
 case "$with_ffmpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10147,15 +10149,15 @@
 do
-echo "configure:10151: checking for $ac_hdr" >&5
+echo "configure:10153: checking for $ac_hdr" >&5
-#line 10154 "configure"
+#line 10156 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10159: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10161: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10191,15 +10193,15 @@
 do
-echo "configure:10195: checking for $ac_hdr" >&5
+echo "configure:10197: checking for $ac_hdr" >&5
-#line 10198 "configure"
+#line 10200 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10203: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10205: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10235,15 +10237,15 @@
 do
-echo "configure:10239: checking for $ac_hdr" >&5
+echo "configure:10241: checking for $ac_hdr" >&5
-#line 10242 "configure"
+#line 10244 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10247: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10249: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10286,7 +10288,7 @@
 echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10290: checking for location of FFMPEG library" >&5
+echo "configure:10292: checking for location of FFMPEG library" >&5
 case "$with_ffmpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10313,13 +10315,13 @@
 echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10317: checking for av_free in -lavutil" >&5
+echo "configure:10319: checking for av_free in -lavutil" >&5
 ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
 LIBS="-lavutil  $LIBS"
-#line 10323 "configure"
+#line 10325 "configure"
@@ -10330,7 +10332,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10334: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10336: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10349,13 +10351,13 @@
-echo "configure:10353: checking for av_free in -lavutil" >&5
+echo "configure:10355: checking for av_free in -lavutil" >&5
 LIBS="-lavutil $MATHLIB $LIBS"
-#line 10359 "configure"
+#line 10361 "configure"
@@ -10366,7 +10368,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10370: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10372: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10411,13 +10413,13 @@
 echo $ac_n "checking for avcodec_register in -lavcodec""... $ac_c" 1>&6
-echo "configure:10415: checking for avcodec_register in -lavcodec" >&5
+echo "configure:10417: checking for avcodec_register in -lavcodec" >&5
 ac_lib_var=`echo avcodec'_'avcodec_register | sed 'y%./+-%__p_%'`
 LIBS="-lavcodec $FFMPEGLIB  $LIBS"
-#line 10421 "configure"
+#line 10423 "configure"
@@ -10428,7 +10430,7 @@
 avcodec_register()
 ; return 0; }
 EOF
-if { (eval echo configure:10432: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10434: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10447,13 +10449,13 @@
-echo "configure:10451: checking for avcodec_register in -lavcodec" >&5
+echo "configure:10453: checking for avcodec_register in -lavcodec" >&5
 LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 10457 "configure"
+#line 10459 "configure"
@@ -10464,7 +10466,7 @@
 avcodec_register()
 ; return 0; }
 EOF
-if { (eval echo configure:10468: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10470: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10509,13 +10511,13 @@
 echo $ac_n "checking for avformat_alloc_context in -lavformat""... $ac_c" 1>&6
-echo "configure:10513: checking for avformat_alloc_context in -lavformat" >&5
+echo "configure:10515: checking for avformat_alloc_context in -lavformat" >&5
 ac_lib_var=`echo avformat'_'avformat_alloc_context | sed 'y%./+-%__p_%'`
 LIBS="-lavformat $FFMPEGLIB  $LIBS"
-#line 10519 "configure"
+#line 10521 "configure"
@@ -10526,7 +10528,7 @@
 avformat_alloc_context()
 ; return 0; }
 EOF
-if { (eval echo configure:10530: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10532: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10545,13 +10547,13 @@
-echo "configure:10549: checking for avformat_alloc_context in -lavformat" >&5
+echo "configure:10551: checking for avformat_alloc_context in -lavformat" >&5
 LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 10555 "configure"
+#line 10557 "configure"
@@ -10562,7 +10564,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:10566: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10568: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10621,7 +10623,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10625: checking whether to use OpenGL" >&5
+echo "configure:10627: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -10655,7 +10657,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:10659: checking for location of OpenGL includes" >&5
+echo "configure:10661: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -10681,15 +10683,15 @@
 do
-echo "configure:10685: checking for $ac_hdr" >&5
+echo "configure:10687: checking for $ac_hdr" >&5
-#line 10688 "configure"
+#line 10690 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10693: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10695: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10723,7 +10725,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:10727: checking for location of OpenGL library" >&5
+echo "configure:10729: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -10752,13 +10754,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:10756: checking for glBegin in -lGL" >&5
+echo "configure:10758: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 10762 "configure"
+#line 10764 "configure"
@@ -10769,7 +10771,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:10773: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10775: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10788,13 +10790,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:10792: checking for glBegin in -lGL" >&5
+echo "configure:10794: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 10798 "configure"
+#line 10800 "configure"
@@ -10805,7 +10807,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:10809: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10811: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10824,13 +10826,13 @@
-echo "configure:10828: checking for glBegin in -lGL" >&5
+echo "configure:10830: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 10834 "configure"
+#line 10836 "configure"
@@ -10841,7 +10843,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:10845: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10847: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10860,13 +10862,13 @@
-echo "configure:10864: checking for glBegin in -lGL" >&5
+echo "configure:10866: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 10870 "configure"
+#line 10872 "configure"
@@ -10877,7 +10879,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:10881: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10883: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10939,13 +10941,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:10943: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:10945: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 10949 "configure"
+#line 10951 "configure"
@@ -10956,7 +10958,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:10960: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10962: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10975,13 +10977,13 @@
-echo "configure:10979: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:10981: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 10985 "configure"
+#line 10987 "configure"
@@ -10992,7 +10994,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:10996: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10998: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11036,10 +11038,10 @@
 LDFLAGS="$LDFLAGS $OPENGLLIB"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11040: checking for glXCreatePbuffer" >&5
+echo "configure:11042: checking for glXCreatePbuffer" >&5
-#line 11043 "configure"
+#line 11045 "configure"
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -11062,7 +11064,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11066: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11068: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -11084,10 +11086,10 @@
 fi
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11088: checking for glXCreateGLXPixmap" >&5
+echo "configure:11090: checking for glXCreateGLXPixmap" >&5
-#line 11091 "configure"
+#line 11093 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -11110,7 +11112,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11114: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11116: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -11149,7 +11151,7 @@
-echo "configure:11153: checking for location of OpenGL includes" >&5
+echo "configure:11155: checking for location of OpenGL includes" >&5
@@ -11175,15 +11177,15 @@
 do
-echo "configure:11179: checking for $ac_hdr" >&5
+echo "configure:11181: checking for $ac_hdr" >&5
-#line 11182 "configure"
+#line 11184 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11187: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11189: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11218,10 +11220,10 @@
 LDFLAGS="$with_opengl_libs $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11222: checking for glBegin" >&5
+echo "configure:11224: checking for glBegin" >&5
-#line 11225 "configure"
+#line 11227 "configure"
     which can conflict with char glBegin(); below.  */
@@ -11244,7 +11246,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11248: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11250: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -11259,10 +11261,10 @@
   echo "$ac_t""yes" 1>&6
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11263: checking for gluBeginCurve" >&5
+echo "configure:11265: checking for gluBeginCurve" >&5
-#line 11266 "configure"
+#line 11268 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -11285,7 +11287,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11289: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11291: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -11329,7 +11331,7 @@
-echo "configure:11333: checking for location of OpenGL includes" >&5
+echo "configure:11335: checking for location of OpenGL includes" >&5
@@ -11355,15 +11357,15 @@
 do
-echo "configure:11359: checking for $ac_hdr" >&5
+echo "configure:11361: checking for $ac_hdr" >&5
-#line 11362 "configure"
+#line 11364 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11367: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11369: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11397,7 +11399,7 @@
-echo "configure:11401: checking for location of OpenGL library" >&5
+echo "configure:11403: checking for location of OpenGL library" >&5
@@ -11422,18 +11424,18 @@
 ac_save_libs="$LIBS"
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11426: checking for OpenGL library" >&5
+echo "configure:11428: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 11430 "configure"
+#line 11432 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:11437: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11439: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -11457,18 +11459,18 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11461: checking for GLU library" >&5
+echo "configure:11463: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
-#line 11465 "configure"
+#line 11467 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:11472: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11474: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -11517,7 +11519,7 @@
 echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:11521: checking whether to use Tcl/Tk" >&5
+echo "configure:11523: checking whether to use Tcl/Tk" >&5
 echo "$ac_t"""$with_tcltk"" 1>&6
 case "$with_tcltk" in
 	"no")	USE_TCLTK=	;;
@@ -11537,7 +11539,7 @@
 echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:11541: checking for location of Tcl/Tk includes" >&5
+echo "configure:11543: checking for location of Tcl/Tk includes" >&5
 case "$with_tcltk_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -11563,15 +11565,15 @@
 do
-echo "configure:11567: checking for $ac_hdr" >&5
+echo "configure:11569: checking for $ac_hdr" >&5
-#line 11570 "configure"
+#line 11572 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11575: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11577: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11608,15 +11610,15 @@
 do
-echo "configure:11612: checking for $ac_hdr" >&5
+echo "configure:11614: checking for $ac_hdr" >&5
-#line 11615 "configure"
+#line 11617 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11620: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11622: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11649,7 +11651,7 @@
 # Tcl/Tk version checks
 echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:11653: checking Tcl version" >&5
+echo "configure:11655: checking Tcl version" >&5
 CPPFLAGS="$TCLINCDIR $CPPFLAGS"
 if test "$cross_compiling" = yes; then
@@ -11657,7 +11659,7 @@
 else
-#line 11661 "configure"
+#line 11663 "configure"
 #include <stdio.h>
@@ -11669,7 +11671,7 @@
 EOF
-if { (eval echo configure:11673: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11675: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tcl_ver=`cat conftestdata`
     echo "$ac_t""$tcl_ver" 1>&6
@@ -11687,7 +11689,7 @@
 echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:11691: checking Tk version" >&5
+echo "configure:11693: checking Tk version" >&5
 CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -11695,7 +11697,7 @@
 else
-#line 11699 "configure"
+#line 11701 "configure"
 #include <stdio.h>
@@ -11707,7 +11709,7 @@
 EOF
-if { (eval echo configure:11711: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11713: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tk_ver=`cat conftestdata`
     echo "$ac_t""$tk_ver" 1>&6
@@ -11738,7 +11740,7 @@
 echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:11742: checking for location of Tcl/Tk library" >&5
+echo "configure:11744: checking for location of Tcl/Tk library" >&5
 case "$with_tcltk_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -11778,13 +11780,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:11782: checking for Tcl_Init in -ltcl" >&5
+echo "configure:11784: checking for Tcl_Init in -ltcl" >&5
 ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl $MATHLIB $LIBS"
-#line 11788 "configure"
+#line 11790 "configure"
@@ -11795,7 +11797,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11799: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11801: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11814,13 +11816,13 @@
-echo "configure:11818: checking for Tcl_Init in -ltcl" >&5
+echo "configure:11820: checking for Tcl_Init in -ltcl" >&5
 LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 11824 "configure"
+#line 11826 "configure"
@@ -11831,7 +11833,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11835: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11837: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11858,13 +11860,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:11862: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:11864: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 11868 "configure"
+#line 11870 "configure"
@@ -11875,7 +11877,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11879: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11881: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11894,13 +11896,13 @@
-echo "configure:11898: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:11900: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 11904 "configure"
+#line 11906 "configure"
@@ -11911,7 +11913,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11915: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11917: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11938,13 +11940,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:11942: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:11944: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 11948 "configure"
+#line 11950 "configure"
@@ -11955,7 +11957,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11959: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11961: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11974,13 +11976,13 @@
-echo "configure:11978: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:11980: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 11984 "configure"
+#line 11986 "configure"
@@ -11991,7 +11993,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11995: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11997: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12069,13 +12071,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:12073: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:12075: checking for Tk_MainWindow in -ltk" >&5
 ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 12079 "configure"
+#line 12081 "configure"
@@ -12086,7 +12088,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12090: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12092: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12105,13 +12107,13 @@
-echo "configure:12109: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:12111: checking for Tk_MainWindow in -ltk" >&5
 LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12115 "configure"
+#line 12117 "configure"
@@ -12122,7 +12124,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12126: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12128: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12149,13 +12151,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:12153: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:12155: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 12159 "configure"
+#line 12161 "configure"
@@ -12166,7 +12168,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12170: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12172: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12185,13 +12187,13 @@
-echo "configure:12189: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:12191: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12195 "configure"
+#line 12197 "configure"
@@ -12202,7 +12204,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12206: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12208: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12229,13 +12231,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:12233: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12235: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 12239 "configure"
+#line 12241 "configure"
@@ -12246,7 +12248,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12250: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12252: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12265,13 +12267,13 @@
-echo "configure:12269: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12271: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12275 "configure"
+#line 12277 "configure"
@@ -12282,7 +12284,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12286: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12288: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12372,13 +12374,13 @@
   do
     # add only if in MACOSX_ARCHS
     echo $ac_n "checking for Tcl_Init in -l$tlib""... $ac_c" 1>&6
-echo "configure:12376: checking for Tcl_Init in -l$tlib" >&5
+echo "configure:12378: checking for Tcl_Init in -l$tlib" >&5
 ac_lib_var=`echo $tlib'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-l$tlib -arch $a $MACOSX_SDK $TCLTKLIBPATH $LIBS"
-#line 12382 "configure"
+#line 12384 "configure"
@@ -12389,7 +12391,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:12393: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12395: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12438,7 +12440,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:12442: checking whether to use ODBC" >&5
+echo "configure:12444: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -12457,7 +12459,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:12461: checking for location of ODBC includes" >&5
+echo "configure:12463: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -12483,15 +12485,15 @@
 do
-echo "configure:12487: checking for $ac_hdr" >&5
+echo "configure:12489: checking for $ac_hdr" >&5
-#line 12490 "configure"
+#line 12492 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12495: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12497: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12525,7 +12527,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:12529: checking for location of ODBC library" >&5
+echo "configure:12531: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -12550,13 +12552,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:12554: checking for SQLConnect in -lodbc" >&5
+echo "configure:12556: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 12560 "configure"
+#line 12562 "configure"
@@ -12567,7 +12569,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12571: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12573: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12592,13 +12594,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12596: checking for SQLConnect in -liodbc" >&5
+echo "configure:12598: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 12602 "configure"
+#line 12604 "configure"
@@ -12609,7 +12611,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12613: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12615: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12634,11 +12636,11 @@
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12638: checking for ODBC library" >&5
+echo "configure:12640: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 12642 "configure"
+#line 12644 "configure"
 #include <windows.h>
 #include <sql.h>
@@ -12646,7 +12648,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:12650: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12652: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -12695,7 +12697,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12699: checking whether to use FFTW" >&5
+echo "configure:12701: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -12714,7 +12716,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12718: checking for location of FFTW includes" >&5
+echo "configure:12720: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12740,15 +12742,15 @@
 do
-echo "configure:12744: checking for $ac_hdr" >&5
+echo "configure:12746: checking for $ac_hdr" >&5
-#line 12747 "configure"
+#line 12749 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12752: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12754: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12776,15 +12778,15 @@
 do
-echo "configure:12780: checking for $ac_hdr" >&5
+echo "configure:12782: checking for $ac_hdr" >&5
-#line 12783 "configure"
+#line 12785 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12788: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12790: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12812,15 +12814,15 @@
 do
-echo "configure:12816: checking for $ac_hdr" >&5
+echo "configure:12818: checking for $ac_hdr" >&5
-#line 12819 "configure"
+#line 12821 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12824: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12826: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12866,7 +12868,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12870: checking for location of FFTW library" >&5
+echo "configure:12872: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12891,13 +12893,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12895: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12897: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12901 "configure"
+#line 12903 "configure"
@@ -12908,7 +12910,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:12912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12914: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12933,13 +12935,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12937: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12939: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 12943 "configure"
+#line 12945 "configure"
@@ -12950,7 +12952,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12954: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12956: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12975,13 +12977,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:12979: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:12981: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 12985 "configure"
+#line 12987 "configure"
@@ -12992,7 +12994,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12996: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12998: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13049,7 +13051,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:13053: checking whether to use BLAS" >&5
+echo "configure:13055: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -13070,7 +13072,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:13074: checking for location of BLAS includes" >&5
+echo "configure:13076: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -13090,7 +13092,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:13094: checking for location of BLAS library" >&5
+echo "configure:13096: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -13116,15 +13118,15 @@
 do
-echo "configure:13120: checking for $ac_hdr" >&5
+echo "configure:13122: checking for $ac_hdr" >&5
 cat > conftest.$ac_ext <<EOF
-#line 13123 "configure"
+#line 13125 "configure"
 #include "confdefs.h"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13128: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13130: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13159,13 +13161,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:13163: checking for dnrm2_ in -lblas" >&5
+echo "configure:13165: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 13169 "configure"
+#line 13171 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -13176,7 +13178,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:13180: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13182: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -13195,13 +13197,13 @@
-echo "configure:13199: checking for dnrm2_ in -lblas" >&5
+echo "configure:13201: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 13205 "configure"
+#line 13207 "configure"
@@ -13212,7 +13214,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:13216: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13218: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13256,13 +13258,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:13260: checking for ATL_xerbla in -latlas" >&5
+echo "configure:13262: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 13266 "configure"
+#line 13268 "configure"
@@ -13273,7 +13275,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:13277: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13279: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13288,13 +13290,13 @@
 if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:13292: checking for sgemm_ in -lf77blas" >&5
+echo "configure:13294: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 13298 "configure"
+#line 13300 "configure"
@@ -13305,7 +13307,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13309: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13311: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13320,13 +13322,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:13324: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:13326: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 13330 "configure"
+#line 13332 "configure"
@@ -13337,7 +13339,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:13341: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13343: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13383,16 +13385,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:13387: checking for sgemm in $vlib_flags" >&5
+echo "configure:13389: checking for sgemm in $vlib_flags" >&5
-#line 13389 "configure"
+#line 13391 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:13396: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13398: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -13410,13 +13412,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:13414: checking for sgemm_ in -lblas" >&5
+echo "configure:13416: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas  $LIBS"
-#line 13420 "configure"
+#line 13422 "configure"
@@ -13427,7 +13429,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13431: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13433: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13442,13 +13444,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:13446: checking for dgemm_ in -ldgemm" >&5
+echo "configure:13448: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 13452 "configure"
+#line 13454 "configure"
@@ -13459,7 +13461,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13463: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13465: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13474,13 +13476,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:13478: checking for sgemm_ in -lsgemm" >&5
+echo "configure:13480: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 13484 "configure"
+#line 13486 "configure"
@@ -13491,7 +13493,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13495: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13497: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13525,13 +13527,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:13529: checking for acosp in -lsunmath" >&5
+echo "configure:13531: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 13535 "configure"
+#line 13537 "configure"
@@ -13542,7 +13544,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:13546: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13548: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13557,13 +13559,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:13561: checking for sgemm_ in -lsunperf" >&5
+echo "configure:13563: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 13567 "configure"
+#line 13569 "configure"
@@ -13574,7 +13576,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13578: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13580: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13604,13 +13606,13 @@
 # Generic BLAS library
-echo "configure:13608: checking for sgemm_ in -lblas" >&5
+echo "configure:13610: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 13614 "configure"
+#line 13616 "configure"
@@ -13621,7 +13623,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13625: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13627: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13660,7 +13662,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13664: checking whether to use LAPACK" >&5
+echo "configure:13666: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -13685,7 +13687,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13689: checking for location of LAPACK includes" >&5
+echo "configure:13691: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13705,7 +13707,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13709: checking for location of LAPACK library" >&5
+echo "configure:13711: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13731,15 +13733,15 @@
 do
-echo "configure:13735: checking for $ac_hdr" >&5
+echo "configure:13737: checking for $ac_hdr" >&5
-#line 13738 "configure"
+#line 13740 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13743: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13745: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -13771,10 +13773,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13775: checking for dsegv_" >&5
+echo "configure:13777: checking for dsegv_" >&5
-#line 13778 "configure"
+#line 13780 "configure"
     which can conflict with char dsegv_(); below.  */
@@ -13797,7 +13799,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13801: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13803: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -13824,13 +13826,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13828: checking for desgv_ in -llapack" >&5
+echo "configure:13830: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 13834 "configure"
+#line 13836 "configure"
@@ -13841,7 +13843,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13845: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13847: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13873,13 +13875,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13877: checking for dgesv_ in -llapack" >&5
+echo "configure:13879: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 13883 "configure"
+#line 13885 "configure"
@@ -13890,7 +13892,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13894: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13896: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13909,13 +13911,13 @@
-echo "configure:13913: checking for dgesv_ in -llapack" >&5
+echo "configure:13915: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13919 "configure"
+#line 13921 "configure"
@@ -13926,7 +13928,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13930: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13932: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13982,7 +13984,7 @@
 echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:13986: checking whether to use Motif" >&5
+echo "configure:13988: checking whether to use Motif" >&5
 echo "$ac_t"""$with_motif"" 1>&6
 case "$with_motif" in
 	"no")	USE_MOTIF=	;;
@@ -14001,7 +14003,7 @@
 echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:14005: checking for location of Motif includes" >&5
+echo "configure:14007: checking for location of Motif includes" >&5
 case "$with_motif_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -14027,15 +14029,15 @@
 do
-echo "configure:14031: checking for $ac_hdr" >&5
+echo "configure:14033: checking for $ac_hdr" >&5
-#line 14034 "configure"
+#line 14036 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14039: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14041: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14069,7 +14071,7 @@
 echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:14073: checking for location of Motif library" >&5
+echo "configure:14075: checking for location of Motif library" >&5
 case "$with_motif_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -14094,13 +14096,13 @@
 echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:14098: checking for XmStringCreate in -lXm" >&5
+echo "configure:14100: checking for XmStringCreate in -lXm" >&5
 ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
 LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS  $LIBS"
-#line 14104 "configure"
+#line 14106 "configure"
@@ -14111,7 +14113,7 @@
 XmStringCreate()
 ; return 0; }
 EOF
-if { (eval echo configure:14115: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14117: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14152,7 +14154,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:14156: checking whether to use Cairo" >&5
+echo "configure:14158: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -14184,7 +14186,7 @@
 echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:14188: checking for location of cairo includes" >&5
+echo "configure:14190: checking for location of cairo includes" >&5
 case "$with_cairo_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -14210,15 +14212,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:14214: checking for $ac_hdr" >&5
+echo "configure:14216: checking for $ac_hdr" >&5
-#line 14217 "configure"
+#line 14219 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14222: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14224: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14254,7 +14256,7 @@
 echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:14258: checking for location of cairo library" >&5
+echo "configure:14260: checking for location of cairo library" >&5
 case "$with_cairo_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -14274,7 +14276,7 @@
 echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:14278: checking for cairo linking flags" >&5
+echo "configure:14280: checking for cairo linking flags" >&5
 case "$with_cairo_ldflags" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -14290,10 +14292,10 @@
 LIBS=" $CAIROLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:14294: checking for cairo_create" >&5
+echo "configure:14296: checking for cairo_create" >&5
-#line 14297 "configure"
+#line 14299 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -14316,7 +14318,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14320: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14322: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -14350,10 +14352,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:14354: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:14356: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 14357 "configure"
+#line 14359 "configure"
     which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below.  */
@@ -14376,7 +14378,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14380: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14382: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
 else
@@ -14409,10 +14411,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:14413: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:14415: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 14416 "configure"
+#line 14418 "configure"
     which can conflict with char cairo_xlib_surface_get_xrender_format(); below.  */
@@ -14435,7 +14437,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14439: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14441: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
 else
@@ -14477,7 +14479,7 @@
 echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:14481: checking whether to use GLw" >&5
+echo "configure:14483: checking whether to use GLw" >&5
 echo "$ac_t"""$with_glw"" 1>&6
 case "$with_glw" in
 	"no")	USE_GLW=	;;
@@ -14496,7 +14498,7 @@
 echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:14500: checking for location of GLw includes" >&5
+echo "configure:14502: checking for location of GLw includes" >&5
 case "$with_glw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -14522,15 +14524,15 @@
 do
-echo "configure:14526: checking for $ac_hdr" >&5
+echo "configure:14528: checking for $ac_hdr" >&5
-#line 14529 "configure"
+#line 14531 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14534: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14536: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14558,15 +14560,15 @@
 do
-echo "configure:14562: checking for $ac_hdr" >&5
+echo "configure:14564: checking for $ac_hdr" >&5
-#line 14565 "configure"
+#line 14567 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14570: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14572: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14606,7 +14608,7 @@
 echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:14610: checking for location of GLw library" >&5
+echo "configure:14612: checking for location of GLw library" >&5
 case "$with_glw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -14631,13 +14633,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14635: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:14637: checking for GLwCreateMDrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14641 "configure"
+#line 14643 "configure"
@@ -14648,7 +14650,7 @@
 GLwCreateMDrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14652: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14654: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14673,13 +14675,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14677: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:14679: checking for GLwCreateM1DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14683 "configure"
+#line 14685 "configure"
@@ -14690,7 +14692,7 @@
 GLwCreateM1DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14694: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14696: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14715,13 +14717,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14719: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:14721: checking for GLwCreateM2DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14725 "configure"
+#line 14727 "configure"
@@ -14732,7 +14734,7 @@
 GLwCreateM2DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14736: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14757,13 +14759,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14761: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:14763: checking for GLwCreateMDrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14767 "configure"
+#line 14769 "configure"
@@ -14774,7 +14776,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14778: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14780: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14799,13 +14801,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14803: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:14805: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14809 "configure"
+#line 14811 "configure"
@@ -14816,7 +14818,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14820: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14841,13 +14843,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14845: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:14847: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14851 "configure"
+#line 14853 "configure"
@@ -14858,7 +14860,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14862: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14864: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14885,13 +14887,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:14889: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14891: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14895 "configure"
+#line 14897 "configure"
@@ -14902,7 +14904,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14906: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14908: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14921,13 +14923,13 @@
-echo "configure:14925: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14927: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14931 "configure"
+#line 14933 "configure"
@@ -14938,7 +14940,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14942: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14944: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14965,13 +14967,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:14969: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:14971: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14975 "configure"
+#line 14977 "configure"
@@ -14982,7 +14984,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14986: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14988: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15001,13 +15003,13 @@
-echo "configure:15005: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:15007: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 15011 "configure"
+#line 15013 "configure"
@@ -15018,7 +15020,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15022: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15024: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15131,7 +15133,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:15135: checking whether to use FreeType" >&5
+echo "configure:15137: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -15150,7 +15152,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:15154: checking for location of FreeType includes" >&5
+echo "configure:15156: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -15176,15 +15178,15 @@
 do
-echo "configure:15180: checking for $ac_hdr" >&5
+echo "configure:15182: checking for $ac_hdr" >&5
-#line 15183 "configure"
+#line 15185 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15188: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15190: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15218,7 +15220,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:15222: checking for location of FreeType library" >&5
+echo "configure:15224: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -15243,13 +15245,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:15247: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:15249: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 15253 "configure"
+#line 15255 "configure"
@@ -15260,7 +15262,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:15264: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15266: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15301,7 +15303,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:15305: checking whether to use NLS" >&5
+echo "configure:15307: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -15321,10 +15323,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:15325: checking for gettext" >&5
+echo "configure:15327: checking for gettext" >&5
-#line 15328 "configure"
+#line 15330 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char gettext(); below.  */
@@ -15347,7 +15349,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15351: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15353: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -15365,13 +15367,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:15369: checking for gettext in -lintl" >&5
+echo "configure:15371: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 15375 "configure"
+#line 15377 "configure"
@@ -15382,7 +15384,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:15386: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15388: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15417,7 +15419,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:15421: checking whether to use C++" >&5
+echo "configure:15423: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -15433,7 +15435,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:15437: checking for $ac_word" >&5
+echo "configure:15439: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -15462,7 +15464,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:15466: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:15468: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -15473,12 +15475,12 @@
 cat > conftest.$ac_ext << EOF
-#line 15477 "configure"
+#line 15479 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:15482: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15484: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -15504,19 +15506,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:15508: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:15510: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:15513: checking whether we are using GNU C++" >&5
+echo "configure:15515: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15520: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15522: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -15534,7 +15536,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:15538: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:15540: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -15562,7 +15564,58 @@
   fi
 fi
+for ac_declaration in \
+   '#include <stdlib.h>' \
+   'extern "C" void std::exit (int) throw (); using std::exit;' \
+   'extern "C" void std::exit (int); using std::exit;' \
+   'extern "C" void exit (int) throw ();' \
+   'extern "C" void exit (int);' \
+   'void exit (int);'
+do
+  cat > conftest.$ac_ext <<EOF
+#line 15578 "configure"
+#include "confdefs.h"
+#include <stdlib.h>
+$ac_declaration
+int main() {
+exit (42);
+; return 0; }
+EOF
+if { (eval echo configure:15586: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
+  echo "configure: failed program was:" >&5
+  cat conftest.$ac_ext >&5
+  rm -rf conftest*
+  continue
+fi
+rm -f conftest*
+#line 15596 "configure"
+$ac_declaration
+int main() {
+exit (42);
+; return 0; }
+EOF
+if { (eval echo configure:15603: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+  rm -rf conftest*
+  break
+else
+fi
+rm -f conftest*
+done
+if test -n "$ac_declaration"; then
+  echo '#ifdef __cplusplus' >>confdefs.h
+  echo $ac_declaration      >>confdefs.h
+  echo '#endif'             >>confdefs.h
+fi
+else
 	CXX=
 	CXXFLAGS=
@@ -15575,7 +15628,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:15579: checking whether to use openDWG" >&5
+echo "configure:15632: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -15595,7 +15648,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:15599: checking for location of openDGW includes" >&5
+echo "configure:15652: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -15621,15 +15674,15 @@
 do
-echo "configure:15625: checking for $ac_hdr" >&5
+echo "configure:15678: checking for $ac_hdr" >&5
-#line 15628 "configure"
+#line 15681 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15633: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15686: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15663,7 +15716,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:15667: checking for location of openDWG library" >&5
+echo "configure:15720: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -15710,7 +15763,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:15714: checking for special C compiler options needed for large files" >&5
+echo "configure:15767: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -15718,7 +15771,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 15722 "configure"
+#line 15775 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -15734,7 +15787,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15738: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15791: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
@@ -15743,7 +15796,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 15747 "configure"
+#line 15800 "configure"
@@ -15759,7 +15812,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15763: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15816: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -15779,11 +15832,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:15783: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:15836: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 15787 "configure"
+#line 15840 "configure"
@@ -15799,14 +15852,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15803: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15856: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15810 "configure"
+#line 15863 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -15824,7 +15877,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15828: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15881: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -15843,11 +15896,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:15847: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:15900: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 15851 "configure"
+#line 15904 "configure"
@@ -15863,14 +15916,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15867: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15920: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15874 "configure"
+#line 15927 "configure"
 #define _LARGE_FILES 1
@@ -15888,7 +15941,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15892: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15945: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -15907,25 +15960,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:15911: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:15964: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 15915 "configure"
+#line 15968 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:15922: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15975: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15929 "configure"
+#line 15982 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -15934,7 +15987,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:15938: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15991: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -15955,10 +16008,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:15959: checking if system supports Large Files at all" >&5
+echo "configure:16012: checking if system supports Large Files at all" >&5
-#line 15962 "configure"
+#line 16015 "configure"
 #include <stdio.h>
@@ -15990,7 +16043,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:15994: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16047: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -16019,7 +16072,7 @@
 # Python check
 echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:16023: checking whether to use Python" >&5
+echo "configure:16076: checking whether to use Python" >&5
 PYTHONINC=
 PYTHONCFLAGS=
@@ -16039,7 +16092,7 @@
   # Extract the first word of "python-config", so it can be a program name with args.
 set dummy python-config; ac_word=$2
-echo "configure:16043: checking for $ac_word" >&5
+echo "configure:16096: checking for $ac_word" >&5
 case "$PY_CONFIG" in
@@ -16081,15 +16134,15 @@
 do
-echo "configure:16085: checking for $ac_hdr" >&5
+echo "configure:16138: checking for $ac_hdr" >&5
-#line 16088 "configure"
+#line 16141 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:16093: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16146: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -16159,7 +16212,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:16163: checking whether to use wxWidgets" >&5
+echo "configure:16216: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -16180,7 +16233,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
-echo "configure:16184: checking for $ac_word" >&5
+echo "configure:16237: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -16228,7 +16281,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:16232: checking wxWidgets version" >&5
+echo "configure:16285: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -16251,15 +16304,15 @@
 do
-echo "configure:16255: checking for $ac_hdr" >&5
+echo "configure:16308: checking for $ac_hdr" >&5
-#line 16258 "configure"
+#line 16311 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:16263: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16316: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
