[GRASS-SVN] r57882 - grass/branches/develbranch_6
svn_grass at osgeo.org
Mon Sep 30 11:50:33 PDT 2013
Author: neteler
Date: 2013-09-30 11:50:33 -0700 (Mon, 30 Sep 2013)
New Revision: 57882
grass/branches/develbranch_6/aclocal.m4
grass/branches/develbranch_6/configure
configure: update for AIX
Modified: grass/branches/develbranch_6/aclocal.m4
--- grass/branches/develbranch_6/aclocal.m4 2013-09-30 18:49:48 UTC (rev 57881)
+++ grass/branches/develbranch_6/aclocal.m4 2013-09-30 18:50:33 UTC (rev 57882)
@@ -658,7 +658,8 @@
fi
LD_SEARCH_FLAGS='-R ${LIB_RUNTIME_DIR}'
else
- SHLIB_LD="${SRCDIR}/ldAix /bin/ld -bhalt:4 -bM:SRE -bE:lib.exp -H512 -T512 -bnoentry ${SHLIB_LD_FLAGS}"
+ #SHLIB_LD="${SRCDIR}/ldAix /bin/ld -bhalt:4 -bM:SRE -bE:lib.exp -H512 -T512 -bnoentry ${SHLIB_LD_FLAGS}"
+ SHLIB_LD="$CC -shared"
CC_SEARCH_FLAGS='-L${LIB_RUNTIME_DIR}'
LD_SEARCH_FLAGS=${CC_SEARCH_FLAGS}
GRASS_NEEDS_EXP_FILE=1
@@ -697,7 +698,8 @@
SHLIB_LD_FLAGS="-b64"
fi
fi
# On AIX <=v4 systems, libbsd.a has to be linked in to support
# non-blocking file IO. This library has to be linked in after
Modified: grass/branches/develbranch_6/configure
--- grass/branches/develbranch_6/configure 2013-09-30 18:49:48 UTC (rev 57881)
+++ grass/branches/develbranch_6/configure 2013-09-30 18:50:33 UTC (rev 57882)
@@ -1799,7 +1799,8 @@
fi
else
@@ -1838,7 +1839,8 @@
fi
fi
@@ -1853,13 +1855,13 @@
# known GMT value.
echo $ac_n "checking for gettimeofday in -lbsd""... $ac_c" 1>&6
-echo "configure:1857: checking for gettimeofday in -lbsd" >&5
+echo "configure:1859: checking for gettimeofday in -lbsd" >&5
ac_lib_var=`echo bsd'_'gettimeofday | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lbsd $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 1863 "configure"
+#line 1865 "configure"
#include "confdefs.h"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -1870,7 +1872,7 @@
gettimeofday()
; return 0; }
EOF
-if { (eval echo configure:1874: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1876: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -1911,13 +1913,13 @@
# is always linked to, for compatibility.
echo $ac_n "checking for inet_ntoa in -lbind""... $ac_c" 1>&6
-echo "configure:1915: checking for inet_ntoa in -lbind" >&5
+echo "configure:1917: checking for inet_ntoa in -lbind" >&5
ac_lib_var=`echo bind'_'inet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-lbind $LIBS"
-#line 1921 "configure"
+#line 1923 "configure"
@@ -1928,7 +1930,7 @@
inet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:1932: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:1934: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -1989,13 +1991,13 @@
SHLIB_SUFFIX=".sl"
echo $ac_n "checking for shl_load in -ldld""... $ac_c" 1>&6
-echo "configure:1993: checking for shl_load in -ldld" >&5
+echo "configure:1995: checking for shl_load in -ldld" >&5
ac_lib_var=`echo dld'_'shl_load | sed 'y%./+-%__p_%'`
LIBS="-ldld $LIBS"
-#line 1999 "configure"
+#line 2001 "configure"
@@ -2006,7 +2008,7 @@
shl_load()
; return 0; }
EOF
-if { (eval echo configure:2010: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2012: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -2071,13 +2073,13 @@
HP-UX-*.08.*|HP-UX-*.09.*|HP-UX-*.10.*)
SHLIB_SUFFIX=".sl"
-echo "configure:2075: checking for shl_load in -ldld" >&5
+echo "configure:2077: checking for shl_load in -ldld" >&5
LIBS="-ldld $LIBS"
-#line 2081 "configure"
+#line 2083 "configure"
@@ -2088,7 +2090,7 @@
shl_load()
; return 0; }
EOF
-if { (eval echo configure:2092: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2094: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -2210,15 +2212,15 @@
else
ac_safe=`echo "dld.h" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for dld.h""... $ac_c" 1>&6
-echo "configure:2214: checking for dld.h" >&5
+echo "configure:2216: checking for dld.h" >&5
-#line 2217 "configure"
+#line 2219 "configure"
#include <dld.h>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:2222: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2224: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -2278,15 +2280,15 @@
else
-echo "configure:2282: checking for dld.h" >&5
+echo "configure:2284: checking for dld.h" >&5
-#line 2285 "configure"
+#line 2287 "configure"
#include <dld.h>
EOF
-{ (eval echo configure:2290: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2292: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2383,9 +2385,9 @@
CC_SEARCH_FLAGS=""
LD_SEARCH_FLAGS=""
echo $ac_n "checking for ELF""... $ac_c" 1>&6
-echo "configure:2387: checking for ELF" >&5
+echo "configure:2389: checking for ELF" >&5
-#line 2389 "configure"
+#line 2391 "configure"
#ifdef __ELF__
@@ -2415,15 +2417,15 @@
# Not available on all versions: check for include file.
ac_safe=`echo "dlfcn.h" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for dlfcn.h""... $ac_c" 1>&6
-echo "configure:2419: checking for dlfcn.h" >&5
+echo "configure:2421: checking for dlfcn.h" >&5
-#line 2422 "configure"
+#line 2424 "configure"
#include <dlfcn.h>
EOF
-{ (eval echo configure:2427: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2429: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2447,9 +2449,9 @@
CC_SEARCH_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR}'
LD_SEARCH_FLAGS='-rpath ${LIB_RUNTIME_DIR}'
-echo "configure:2451: checking for ELF" >&5
+echo "configure:2453: checking for ELF" >&5
-#line 2453 "configure"
+#line 2455 "configure"
#ifdef __ELF__
@@ -2773,17 +2775,17 @@
# that don't grok the -Bexport option. Test that it does.
hold_ldflags=$LDFLAGS
echo $ac_n "checking for ld accepts -Bexport flag""... $ac_c" 1>&6
-echo "configure:2777: checking for ld accepts -Bexport flag" >&5
+echo "configure:2779: checking for ld accepts -Bexport flag" >&5
LDFLAGS="${LDFLAGS} -Wl,-Bexport"
-#line 2780 "configure"
+#line 2782 "configure"
int main() {
int i;
; return 0; }
EOF
-if { (eval echo configure:2787: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2789: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
found=yes
else
@@ -3581,7 +3583,7 @@
# Done checking fortran
echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:3585: checking for additional include dirs" >&5
+echo "configure:3587: checking for additional include dirs" >&5
case "$with_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -3604,7 +3606,7 @@
# With libs option
echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:3608: checking for additional library dirs" >&5
+echo "configure:3610: checking for additional library dirs" >&5
case "$with_libs" in
{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -3638,7 +3640,7 @@
# SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
# ./install, which can be erroneously created by make from ./install.sh.
echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:3642: checking for a BSD compatible install" >&5
+echo "configure:3644: checking for a BSD compatible install" >&5
if test -z "$INSTALL"; then
IFS="${IFS= }"; ac_save_IFS="$IFS"; IFS=":"
@@ -3691,7 +3693,7 @@
# Extract the first word of "flex", so it can be a program name with args.
set dummy flex; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:3695: checking for $ac_word" >&5
+echo "configure:3697: checking for $ac_word" >&5
if test -n "$LEX"; then
ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -3722,13 +3724,13 @@
*) ac_lib=l ;;
esac
echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:3726: checking for yywrap in -l$ac_lib" >&5
+echo "configure:3728: checking for yywrap in -l$ac_lib" >&5
ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
LIBS="-l$ac_lib $LIBS"
-#line 3732 "configure"
+#line 3734 "configure"
@@ -3739,7 +3741,7 @@
yywrap()
; return 0; }
EOF
-if { (eval echo configure:3743: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3745: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3764,7 +3766,7 @@
# Extract the first word of "lex", so it can be a program name with args.
set dummy lex; ac_word=$2
-echo "configure:3768: checking for $ac_word" >&5
+echo "configure:3770: checking for $ac_word" >&5
case "$LEXPATH" in
@@ -3804,7 +3806,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:3808: checking for $ac_word" >&5
+echo "configure:3810: checking for $ac_word" >&5
if test -n "$YACC"; then
ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -3835,7 +3837,7 @@
# Extract the first word of "yacc", so it can be a program name with args.
set dummy yacc; ac_word=$2
-echo "configure:3839: checking for $ac_word" >&5
+echo "configure:3841: checking for $ac_word" >&5
case "$YACCPATH" in
@@ -3873,7 +3875,7 @@
# Extract the first word of "ranlib", so it can be a program name with args.
set dummy ranlib; ac_word=$2
-echo "configure:3877: checking for $ac_word" >&5
+echo "configure:3879: checking for $ac_word" >&5
if test -n "$RANLIB"; then
ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -3902,7 +3904,7 @@
-echo "configure:3906: checking for $ac_word" >&5
+echo "configure:3908: checking for $ac_word" >&5
if test -n "$AR"; then
ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -3933,7 +3935,7 @@
-echo "configure:3937: checking for $ac_word" >&5
+echo "configure:3939: checking for $ac_word" >&5
if test -n "$ENV"; then
ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -3962,7 +3964,7 @@
# Extract the first word of "perl", so it can be a program name with args.
set dummy perl; ac_word=$2
-echo "configure:3966: checking for $ac_word" >&5
+echo "configure:3968: checking for $ac_word" >&5
case "$PERL" in
@@ -3993,10 +3995,10 @@
fi
echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:3997: checking for ANSI C header files" >&5
+echo "configure:3999: checking for ANSI C header files" >&5
-#line 4000 "configure"
+#line 4002 "configure"
#include <stdlib.h>
#include <stdarg.h>
@@ -4004,7 +4006,7 @@
#include <float.h>
EOF
-{ (eval echo configure:4008: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4010: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4021,7 +4023,7 @@
if test $ac_cv_header_stdc = yes; then
# SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 4025 "configure"
+#line 4027 "configure"
#include <string.h>
EOF
@@ -4039,7 +4041,7 @@
# ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 4043 "configure"
+#line 4045 "configure"
#include <stdlib.h>
EOF
@@ -4060,7 +4062,7 @@
else
-#line 4064 "configure"
+#line 4066 "configure"
#include <ctype.h>
#define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -4071,7 +4073,7 @@
exit (0); }
EOF
-if { (eval echo configure:4075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4077: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
else
@@ -4098,15 +4100,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:4102: checking for $ac_hdr" >&5
+echo "configure:4104: checking for $ac_hdr" >&5
-#line 4105 "configure"
+#line 4107 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4110: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4112: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4135,15 +4137,15 @@
do
-echo "configure:4139: checking for $ac_hdr" >&5
+echo "configure:4141: checking for $ac_hdr" >&5
-#line 4142 "configure"
+#line 4144 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4147: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4149: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4172,15 +4174,15 @@
do
-echo "configure:4176: checking for $ac_hdr" >&5
+echo "configure:4178: checking for $ac_hdr" >&5
-#line 4179 "configure"
+#line 4181 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4184: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4186: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4209,15 +4211,15 @@
do
-echo "configure:4213: checking for $ac_hdr" >&5
+echo "configure:4215: checking for $ac_hdr" >&5
-#line 4216 "configure"
+#line 4218 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4221: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4223: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4246,15 +4248,15 @@
do
-echo "configure:4250: checking for $ac_hdr" >&5
+echo "configure:4252: checking for $ac_hdr" >&5
-#line 4253 "configure"
+#line 4255 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:4258: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4260: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4280,10 +4282,10 @@
done
echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:4284: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:4286: checking whether time.h and sys/time.h may both be included" >&5
-#line 4287 "configure"
+#line 4289 "configure"
#include <sys/types.h>
#include <sys/time.h>
@@ -4292,7 +4294,7 @@
struct tm *tp;
; return 0; }
EOF
-if { (eval echo configure:4296: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4298: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_header_time=yes
else
@@ -4312,10 +4314,10 @@
fi
echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:4316: checking for off_t" >&5
+echo "configure:4318: checking for off_t" >&5
-#line 4319 "configure"
+#line 4321 "configure"
#if STDC_HEADERS
@@ -4342,10 +4344,10 @@
fi
echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:4346: checking for uid_t in sys/types.h" >&5
+echo "configure:4348: checking for uid_t in sys/types.h" >&5
-#line 4349 "configure"
+#line 4351 "configure"
EOF
@@ -4373,10 +4375,10 @@
fi
echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:4377: checking return type of signal handlers" >&5
+echo "configure:4379: checking return type of signal handlers" >&5
-#line 4380 "configure"
+#line 4382 "configure"
#include <signal.h>
@@ -4393,7 +4395,7 @@
int i;
; return 0; }
EOF
-if { (eval echo configure:4397: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4399: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_type_signal=void
else
@@ -4411,10 +4413,10 @@
echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:4415: checking for Cygwin environment" >&5
+echo "configure:4417: checking for Cygwin environment" >&5
-#line 4418 "configure"
+#line 4420 "configure"
int main() {
@@ -4425,7 +4427,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:4429: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4431: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -4443,10 +4445,10 @@
for ac_func in ftime gethostname gettimeofday lseek nice time uname
do
echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:4447: checking for $ac_func" >&5
+echo "configure:4449: checking for $ac_func" >&5
-#line 4450 "configure"
+#line 4452 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char $ac_func(); below. */
@@ -4469,7 +4471,7 @@
; return 0; }
EOF
-if { (eval echo configure:4473: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4475: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_$ac_func=yes"
else
@@ -4495,10 +4497,10 @@
for ac_func in seteuid setpriority setreuid setruid
do
-echo "configure:4499: checking for $ac_func" >&5
+echo "configure:4501: checking for $ac_func" >&5
-#line 4502 "configure"
+#line 4504 "configure"
@@ -4521,7 +4523,7 @@
; return 0; }
EOF
-if { (eval echo configure:4525: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4527: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4547,10 +4549,10 @@
for ac_func in drand48
do
-echo "configure:4551: checking for $ac_func" >&5
+echo "configure:4553: checking for $ac_func" >&5
-#line 4554 "configure"
+#line 4556 "configure"
@@ -4573,7 +4575,7 @@
; return 0; }
EOF
-if { (eval echo configure:4577: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4579: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4599,10 +4601,10 @@
for ac_func in putenv setenv
do
-echo "configure:4603: checking for $ac_func" >&5
+echo "configure:4605: checking for $ac_func" >&5
-#line 4606 "configure"
+#line 4608 "configure"
@@ -4625,7 +4627,7 @@
; return 0; }
EOF
-if { (eval echo configure:4629: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4631: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4651,10 +4653,10 @@
for ac_func in nanosleep
do
-echo "configure:4655: checking for $ac_func" >&5
+echo "configure:4657: checking for $ac_func" >&5
-#line 4658 "configure"
+#line 4660 "configure"
@@ -4677,7 +4679,7 @@
; return 0; }
EOF
-if { (eval echo configure:4681: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4683: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4702,13 +4704,13 @@
if test "$cross_compiling" != "yes" ; then
echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:4706: checking whether setpgrp takes no argument" >&5
+echo "configure:4708: checking whether setpgrp takes no argument" >&5
if test "$cross_compiling" = yes; then
{ echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
else
-#line 4712 "configure"
+#line 4714 "configure"
#ifdef HAVE_UNISTD_H
@@ -4728,7 +4730,7 @@
EOF
-if { (eval echo configure:4732: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:4734: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
ac_cv_func_setpgrp_void=no
else
@@ -4756,16 +4758,16 @@
fi
echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:4760: checking for long long int" >&5
+echo "configure:4762: checking for long long int" >&5
-#line 4762 "configure"
+#line 4764 "configure"
int main() {
long long int x;
; return 0; }
EOF
-if { (eval echo configure:4769: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:4771: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
echo "$ac_t""yes" 1>&6
@@ -4785,7 +4787,7 @@
rm -f conftest*
echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:4789: checking for W11" >&5
+echo "configure:4791: checking for W11" >&5
case "$enable_w11" in
yes|no) echo "$ac_t"""$enable_w11"" 1>&6 ;;
*) { echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; } ;;
@@ -4813,7 +4815,7 @@
# Uses ac_ vars as temps to allow command line to override cache and checks.
# --without-x overrides everything else, but does not touch the cache.
echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:4817: checking for X" >&5
+echo "configure:4819: checking for X" >&5
# Check whether --with-x or --without-x was given.
if test "${with_x+set}" = set; then
@@ -4873,12 +4875,12 @@
# First, try using that file with no special directory specified.
-#line 4877 "configure"
+#line 4879 "configure"
#include <$x_direct_test_include>
EOF
-{ (eval echo configure:4882: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:4884: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -4947,14 +4949,14 @@
LIBS="-l$x_direct_test_library $LIBS"
-#line 4951 "configure"
+#line 4953 "configure"
int main() {
${x_direct_test_function}()
; return 0; }
EOF
-if { (eval echo configure:4958: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4960: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LIBS="$ac_save_LIBS"
# We can link X programs with no special library path.
@@ -5059,17 +5061,17 @@
case "`(uname -sr) 2>/dev/null`" in
"SunOS 5"*)
echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:5063: checking whether -R must be followed by a space" >&5
+echo "configure:5065: checking whether -R must be followed by a space" >&5
ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 5066 "configure"
+#line 5068 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:5073: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_nospace=yes
else
@@ -5085,14 +5087,14 @@
else
LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 5089 "configure"
+#line 5091 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:5096: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5098: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_space=yes
else
@@ -5124,13 +5126,13 @@
# libraries were built with DECnet support. And karl at cs.umb.edu says
# the Alpha needs dnet_stub (dnet does not exist).
echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:5128: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:5130: checking for dnet_ntoa in -ldnet" >&5
ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet $LIBS"
-#line 5134 "configure"
+#line 5136 "configure"
@@ -5141,7 +5143,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:5145: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5147: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5162,13 +5164,13 @@
if test $ac_cv_lib_dnet_dnet_ntoa = no; then
echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:5166: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:5168: checking for dnet_ntoa in -ldnet_stub" >&5
ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet_stub $LIBS"
-#line 5172 "configure"
+#line 5174 "configure"
@@ -5179,7 +5181,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:5183: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5185: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5207,10 +5209,10 @@
# The nsl library prevents programs from opening the X display
# on Irix 5.2, according to dickey at clark.net.
echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:5211: checking for gethostbyname" >&5
+echo "configure:5213: checking for gethostbyname" >&5
-#line 5214 "configure"
+#line 5216 "configure"
which can conflict with char gethostbyname(); below. */
@@ -5233,7 +5235,7 @@
; return 0; }
EOF
-if { (eval echo configure:5237: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5239: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gethostbyname=yes"
else
@@ -5253,13 +5255,13 @@
if test $ac_cv_func_gethostbyname = no; then
echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:5257: checking for gethostbyname in -lnsl" >&5
+echo "configure:5259: checking for gethostbyname in -lnsl" >&5
ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 5263 "configure"
+#line 5265 "configure"
@@ -5270,7 +5272,7 @@
gethostbyname()
; return 0; }
EOF
-if { (eval echo configure:5274: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5276: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5299,10 +5301,10 @@
# -lsocket must be given before -lnsl if both are needed.
# We assume that if connect needs -lnsl, so does gethostbyname.
echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:5303: checking for connect" >&5
+echo "configure:5305: checking for connect" >&5
-#line 5306 "configure"
+#line 5308 "configure"
which can conflict with char connect(); below. */
@@ -5325,7 +5327,7 @@
; return 0; }
EOF
-if { (eval echo configure:5329: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5331: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_connect=yes"
else
@@ -5345,13 +5347,13 @@
if test $ac_cv_func_connect = no; then
echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:5349: checking for connect in -lsocket" >&5
+echo "configure:5351: checking for connect in -lsocket" >&5
ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 5355 "configure"
+#line 5357 "configure"
@@ -5362,7 +5364,7 @@
connect()
; return 0; }
EOF
-if { (eval echo configure:5366: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5368: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5385,10 +5387,10 @@
# gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:5389: checking for remove" >&5
+echo "configure:5391: checking for remove" >&5
-#line 5392 "configure"
+#line 5394 "configure"
which can conflict with char remove(); below. */
@@ -5411,7 +5413,7 @@
; return 0; }
EOF
-if { (eval echo configure:5415: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5417: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_remove=yes"
else
@@ -5431,13 +5433,13 @@
if test $ac_cv_func_remove = no; then
echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:5435: checking for remove in -lposix" >&5
+echo "configure:5437: checking for remove in -lposix" >&5
ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
LIBS="-lposix $LIBS"
-#line 5441 "configure"
+#line 5443 "configure"
@@ -5448,7 +5450,7 @@
remove()
; return 0; }
EOF
-if { (eval echo configure:5452: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5454: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5471,10 +5473,10 @@
# BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:5475: checking for shmat" >&5
+echo "configure:5477: checking for shmat" >&5
-#line 5478 "configure"
+#line 5480 "configure"
which can conflict with char shmat(); below. */
@@ -5497,7 +5499,7 @@
; return 0; }
EOF
-if { (eval echo configure:5501: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5503: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_shmat=yes"
else
@@ -5517,13 +5519,13 @@
if test $ac_cv_func_shmat = no; then
echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:5521: checking for shmat in -lipc" >&5
+echo "configure:5523: checking for shmat in -lipc" >&5
ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
LIBS="-lipc $LIBS"
-#line 5527 "configure"
+#line 5529 "configure"
@@ -5534,7 +5536,7 @@
shmat()
; return 0; }
EOF
-if { (eval echo configure:5538: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5540: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5566,13 +5568,13 @@
# libraries we check for below, so use a different variable.
# --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:5570: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:5572: checking for IceConnectionNumber in -lICE" >&5
ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 5576 "configure"
+#line 5578 "configure"
@@ -5583,7 +5585,7 @@
IceConnectionNumber()
; return 0; }
EOF
-if { (eval echo configure:5587: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5589: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5621,7 +5623,7 @@
echo $ac_n "checking whether to use Curses""... $ac_c" 1>&6
-echo "configure:5625: checking whether to use Curses" >&5
+echo "configure:5627: checking whether to use Curses" >&5
echo "$ac_t"""$with_curses"" 1>&6
case "$with_curses" in
"no") USE_CURSES= ;;
@@ -5640,15 +5642,15 @@
do
-echo "configure:5644: checking for $ac_hdr" >&5
+echo "configure:5646: checking for $ac_hdr" >&5
-#line 5647 "configure"
+#line 5649 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5652: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5654: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5679,10 +5681,10 @@
echo $ac_n "checking curses.h WINDOW structure component""... $ac_c" 1>&6
-echo "configure:5683: checking curses.h WINDOW structure component" >&5
+echo "configure:5685: checking curses.h WINDOW structure component" >&5
CURSES_MAXY=NONE
-#line 5686 "configure"
+#line 5688 "configure"
#include <curses.h>
@@ -5691,7 +5693,7 @@
WINDOW w; w.maxy = 0;
; return 0; }
EOF
-if { (eval echo configure:5695: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5697: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
CURSES_MAXY=maxy
else
@@ -5700,7 +5702,7 @@
fi
rm -f conftest*
-#line 5704 "configure"
+#line 5706 "configure"
#include <curses.h>
@@ -5709,7 +5711,7 @@
WINDOW w; w._maxy = 0;
; return 0; }
EOF
-if { (eval echo configure:5713: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:5715: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
CURSES_MAXY=_maxy
else
@@ -5725,13 +5727,13 @@
echo "$ac_t""$CURSES_MAXY" 1>&6
echo $ac_n "checking for initscr in -lncurses""... $ac_c" 1>&6
-echo "configure:5729: checking for initscr in -lncurses" >&5
+echo "configure:5731: checking for initscr in -lncurses" >&5
ac_lib_var=`echo ncurses'_'initscr | sed 'y%./+-%__p_%'`
LIBS="-lncurses $LIBS"
-#line 5735 "configure"
+#line 5737 "configure"
@@ -5742,7 +5744,7 @@
initscr()
; return 0; }
EOF
-if { (eval echo configure:5746: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5748: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5761,13 +5763,13 @@
echo "$ac_t""no" 1>&6
echo $ac_n "checking for initscr in -lcurses""... $ac_c" 1>&6
-echo "configure:5765: checking for initscr in -lcurses" >&5
+echo "configure:5767: checking for initscr in -lcurses" >&5
ac_lib_var=`echo curses'_'initscr | sed 'y%./+-%__p_%'`
LIBS="-lcurses $LIBS"
-#line 5771 "configure"
+#line 5773 "configure"
@@ -5778,7 +5780,7 @@
initscr()
; return 0; }
EOF
-if { (eval echo configure:5782: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5784: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5807,13 +5809,13 @@
echo $ac_n "checking for keypad in -lncurses""... $ac_c" 1>&6
-echo "configure:5811: checking for keypad in -lncurses" >&5
+echo "configure:5813: checking for keypad in -lncurses" >&5
ac_lib_var=`echo ncurses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5817 "configure"
+#line 5819 "configure"
@@ -5824,7 +5826,7 @@
keypad()
; return 0; }
EOF
-if { (eval echo configure:5828: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5830: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5846,13 +5848,13 @@
echo $ac_n "checking for keypad in -lcurses""... $ac_c" 1>&6
-echo "configure:5850: checking for keypad in -lcurses" >&5
+echo "configure:5852: checking for keypad in -lcurses" >&5
ac_lib_var=`echo curses'_'keypad | sed 'y%./+-%__p_%'`
-#line 5856 "configure"
+#line 5858 "configure"
@@ -5863,7 +5865,7 @@
keypad()
; return 0; }
EOF
-if { (eval echo configure:5867: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5869: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5893,13 +5895,13 @@
fi # $USE_CURSES
echo $ac_n "checking for gtty in -lcompat""... $ac_c" 1>&6
-echo "configure:5897: checking for gtty in -lcompat" >&5
+echo "configure:5899: checking for gtty in -lcompat" >&5
ac_lib_var=`echo compat'_'gtty | sed 'y%./+-%__p_%'`
LIBS="-lcompat $LIBS"
-#line 5903 "configure"
+#line 5905 "configure"
@@ -5910,7 +5912,7 @@
gtty()
; return 0; }
EOF
-if { (eval echo configure:5914: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5916: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5929,13 +5931,13 @@
echo $ac_n "checking for gtty in -lbsd-compat""... $ac_c" 1>&6
-echo "configure:5933: checking for gtty in -lbsd-compat" >&5
+echo "configure:5935: checking for gtty in -lbsd-compat" >&5
ac_lib_var=`echo bsd-compat'_'gtty | sed 'y%./+-%__p_%'`
LIBS="-lbsd-compat $LIBS"
-#line 5939 "configure"
+#line 5941 "configure"
@@ -5946,7 +5948,7 @@
gtty()
; return 0; }
EOF
-if { (eval echo configure:5950: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5952: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5965,13 +5967,13 @@
echo $ac_n "checking for gtty in -lbsd""... $ac_c" 1>&6
-echo "configure:5969: checking for gtty in -lbsd" >&5
+echo "configure:5971: checking for gtty in -lbsd" >&5
ac_lib_var=`echo bsd'_'gtty | sed 'y%./+-%__p_%'`
LIBS="-lbsd $LIBS"
-#line 5975 "configure"
+#line 5977 "configure"
@@ -5982,7 +5984,7 @@
gtty()
; return 0; }
EOF
-if { (eval echo configure:5986: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5988: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6016,12 +6018,12 @@
LIBS=""
echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:6020: checking for library containing cuserid" >&5
+echo "configure:6022: checking for library containing cuserid" >&5
ac_func_search_save_LIBS="$LIBS"
ac_cv_search_cuserid="no"
-#line 6025 "configure"
+#line 6027 "configure"
@@ -6032,7 +6034,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:6036: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6038: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="none required"
else
@@ -6043,7 +6045,7 @@
test "$ac_cv_search_cuserid" = "no" && for i in compat; do
LIBS="-l$i $ac_func_search_save_LIBS"
-#line 6047 "configure"
+#line 6049 "configure"
@@ -6054,7 +6056,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:6058: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6060: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="-l$i"
break
@@ -6080,10 +6082,10 @@
# Note: -lxdr -liberty -lws2_32 is for MinGW
echo $ac_n "checking for xdrmem_create""... $ac_c" 1>&6
-echo "configure:6084: checking for xdrmem_create" >&5
+echo "configure:6086: checking for xdrmem_create" >&5
-#line 6087 "configure"
+#line 6089 "configure"
which can conflict with char xdrmem_create(); below. */
@@ -6106,7 +6108,7 @@
; return 0; }
EOF
-if { (eval echo configure:6110: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6112: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_xdrmem_create=yes"
else
@@ -6124,13 +6126,13 @@
echo $ac_n "checking for xdrmem_create in -lsun""... $ac_c" 1>&6
-echo "configure:6128: checking for xdrmem_create in -lsun" >&5
+echo "configure:6130: checking for xdrmem_create in -lsun" >&5
ac_lib_var=`echo sun'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lsun $LIBS"
-#line 6134 "configure"
+#line 6136 "configure"
@@ -6141,7 +6143,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:6145: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6147: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6160,13 +6162,13 @@
echo $ac_n "checking for xdrmem_create in -lnsl""... $ac_c" 1>&6
-echo "configure:6164: checking for xdrmem_create in -lnsl" >&5
+echo "configure:6166: checking for xdrmem_create in -lnsl" >&5
ac_lib_var=`echo nsl'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 6170 "configure"
+#line 6172 "configure"
@@ -6177,7 +6179,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:6181: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6183: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6196,13 +6198,13 @@
echo $ac_n "checking for xdrmem_create in -lrpclib""... $ac_c" 1>&6
-echo "configure:6200: checking for xdrmem_create in -lrpclib" >&5
+echo "configure:6202: checking for xdrmem_create in -lrpclib" >&5
ac_lib_var=`echo rpclib'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lrpclib $LIBS"
-#line 6206 "configure"
+#line 6208 "configure"
@@ -6213,7 +6215,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:6217: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6219: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6232,13 +6234,13 @@
echo $ac_n "checking for xdrmem_create in -lxdr""... $ac_c" 1>&6
-echo "configure:6236: checking for xdrmem_create in -lxdr" >&5
+echo "configure:6238: checking for xdrmem_create in -lxdr" >&5
ac_lib_var=`echo xdr'_'xdrmem_create | sed 'y%./+-%__p_%'`
LIBS="-lxdr -liberty -lws2_32 $LIBS"
-#line 6242 "configure"
+#line 6244 "configure"
@@ -6249,7 +6251,7 @@
xdrmem_create()
; return 0; }
EOF
-if { (eval echo configure:6253: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6255: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6283,10 +6285,10 @@
for ac_func in asprintf
do
-echo "configure:6287: checking for $ac_func" >&5
+echo "configure:6289: checking for $ac_func" >&5
-#line 6290 "configure"
+#line 6292 "configure"
@@ -6309,7 +6311,7 @@
; return 0; }
EOF
-if { (eval echo configure:6313: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6315: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6336,10 +6338,10 @@
# Test if mathlib needs -lm flag or is included with libc
echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:6340: checking for atan" >&5
+echo "configure:6342: checking for atan" >&5
-#line 6343 "configure"
+#line 6345 "configure"
which can conflict with char atan(); below. */
@@ -6362,7 +6364,7 @@
; return 0; }
EOF
-if { (eval echo configure:6366: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6368: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_atan=yes"
else
@@ -6380,13 +6382,13 @@
echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:6384: checking for atan in -lm" >&5
+echo "configure:6386: checking for atan in -lm" >&5
ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
LIBS="-lm $LIBS"
-#line 6390 "configure"
+#line 6392 "configure"
@@ -6397,7 +6399,7 @@
atan()
; return 0; }
EOF
-if { (eval echo configure:6401: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6403: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6424,10 +6426,10 @@
echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:6428: checking for dlsym" >&5
+echo "configure:6430: checking for dlsym" >&5
-#line 6431 "configure"
+#line 6433 "configure"
which can conflict with char dlsym(); below. */
@@ -6450,7 +6452,7 @@
; return 0; }
EOF
-if { (eval echo configure:6454: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6456: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dlsym=yes"
else
@@ -6468,13 +6470,13 @@
echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:6472: checking for dlsym in -ldl" >&5
+echo "configure:6474: checking for dlsym in -ldl" >&5
ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
LIBS="-ldl $LIBS"
-#line 6478 "configure"
+#line 6480 "configure"
@@ -6485,7 +6487,7 @@
dlsym()
; return 0; }
EOF
-if { (eval echo configure:6489: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6491: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6512,10 +6514,10 @@
echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:6516: checking for iconv" >&5
+echo "configure:6518: checking for iconv" >&5
-#line 6519 "configure"
+#line 6521 "configure"
which can conflict with char iconv(); below. */
@@ -6538,7 +6540,7 @@
; return 0; }
EOF
-if { (eval echo configure:6542: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6544: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_iconv=yes"
else
@@ -6556,13 +6558,13 @@
echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:6560: checking for iconv in -liconv" >&5
+echo "configure:6562: checking for iconv in -liconv" >&5
ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-liconv $LIBS"
-#line 6566 "configure"
+#line 6568 "configure"
@@ -6573,7 +6575,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:6577: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6579: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6592,13 +6594,13 @@
echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6596: checking for iconv in -lgiconv" >&5
+echo "configure:6598: checking for iconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-lgiconv $LIBS"
-#line 6602 "configure"
+#line 6604 "configure"
@@ -6609,7 +6611,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:6613: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6615: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6628,10 +6630,10 @@
echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:6632: checking for libiconv" >&5
+echo "configure:6634: checking for libiconv" >&5
-#line 6635 "configure"
+#line 6637 "configure"
which can conflict with char libiconv(); below. */
@@ -6654,7 +6656,7 @@
; return 0; }
EOF
-if { (eval echo configure:6658: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6660: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_libiconv=yes"
else
@@ -6672,13 +6674,13 @@
echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:6676: checking for libiconv in -liconv" >&5
+echo "configure:6678: checking for libiconv in -liconv" >&5
ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6682 "configure"
+#line 6684 "configure"
@@ -6689,7 +6691,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:6693: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6695: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6708,13 +6710,13 @@
echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:6712: checking for libiconv in -lgiconv" >&5
+echo "configure:6714: checking for libiconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 6718 "configure"
+#line 6720 "configure"
@@ -6725,7 +6727,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:6729: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6731: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6762,10 +6764,10 @@
have_socket=1
echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:6766: checking for socket" >&5
+echo "configure:6768: checking for socket" >&5
-#line 6769 "configure"
+#line 6771 "configure"
which can conflict with char socket(); below. */
@@ -6788,7 +6790,7 @@
; return 0; }
EOF
-if { (eval echo configure:6792: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6794: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_socket=yes"
else
@@ -6806,13 +6808,13 @@
echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:6810: checking for socket in -lsocket" >&5
+echo "configure:6812: checking for socket in -lsocket" >&5
ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
LIBS="-lsocket $LIBS"
-#line 6816 "configure"
+#line 6818 "configure"
@@ -6823,7 +6825,7 @@
socket()
; return 0; }
EOF
-if { (eval echo configure:6827: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6829: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6871,7 +6873,7 @@
echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:6875: checking for location of zlib includes" >&5
+echo "configure:6877: checking for location of zlib includes" >&5
case "$with_zlib_includes" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -6897,15 +6899,15 @@
do
-echo "configure:6901: checking for $ac_hdr" >&5
+echo "configure:6903: checking for $ac_hdr" >&5
-#line 6904 "configure"
+#line 6906 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6909: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6911: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6939,7 +6941,7 @@
echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:6943: checking for location of zlib library" >&5
+echo "configure:6945: checking for location of zlib library" >&5
case "$with_zlib_libs" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -6964,13 +6966,13 @@
echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:6968: checking for deflate in -lz" >&5
+echo "configure:6970: checking for deflate in -lz" >&5
ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
LIBS="-lz $LIBS"
-#line 6974 "configure"
+#line 6976 "configure"
@@ -6981,7 +6983,7 @@
deflate()
; return 0; }
EOF
-if { (eval echo configure:6985: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6987: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7029,7 +7031,7 @@
echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:7033: checking for location of External PROJ.4 includes" >&5
+echo "configure:7035: checking for location of External PROJ.4 includes" >&5
case "$with_proj_includes" in
{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -7055,15 +7057,15 @@
do
-echo "configure:7059: checking for $ac_hdr" >&5
+echo "configure:7061: checking for $ac_hdr" >&5
-#line 7062 "configure"
+#line 7064 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7067: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7069: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7100,7 +7102,7 @@
else
echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:7104: checking External PROJ.4 version" >&5
+echo "configure:7106: checking External PROJ.4 version" >&5
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -7108,7 +7110,7 @@
echo "$ac_t""unknown (cross-compiling)" 1>&6
else
-#line 7112 "configure"
+#line 7114 "configure"
#include <stdio.h>
@@ -7120,7 +7122,7 @@
EOF
-if { (eval echo configure:7124: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:7126: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
proj_ver=`cat conftestdata`
echo "$ac_t""$proj_ver" 1>&6
@@ -7145,7 +7147,7 @@
echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:7149: checking for location of External PROJ.4 library" >&5
+echo "configure:7151: checking for location of External PROJ.4 library" >&5
case "$with_proj_libs" in
{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -7170,13 +7172,13 @@
echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:7174: checking for pj_get_def in -lproj" >&5
+echo "configure:7176: checking for pj_get_def in -lproj" >&5
ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
LIBS="-lproj $LIBS"
-#line 7180 "configure"
+#line 7182 "configure"
@@ -7187,7 +7189,7 @@
pj_get_def()
; return 0; }
EOF
-if { (eval echo configure:7191: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7193: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7221,7 +7223,7 @@
echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:7225: checking for location of External PROJ.4 data files" >&5
+echo "configure:7227: checking for location of External PROJ.4 data files" >&5
case "$with_proj_share" in
{ echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -7245,14 +7247,14 @@
# LOC_CHECK_SHARE does not work when cross compiling
if test "$cross_compiling" = "yes" ; then
echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:7249: checking for epsg" >&5
+echo "configure:7251: checking for epsg" >&5
else
ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:7256: checking for $PROJSHARE/epsg" >&5
+echo "configure:7258: checking for $PROJSHARE/epsg" >&5
{ echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -7284,7 +7286,7 @@
# Extract the first word of "nad2bin", so it can be a program name with args.
set dummy nad2bin; ac_word=$2
-echo "configure:7288: checking for $ac_word" >&5
+echo "configure:7290: checking for $ac_word" >&5
case "$NAD2BIN" in
@@ -7324,7 +7326,7 @@
echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:7328: checking whether to use regex" >&5
+echo "configure:7330: checking whether to use regex" >&5
echo "$ac_t"""$with_regex"" 1>&6
case "$with_regex" in
"no") USE_REGEX= ;;
@@ -7344,7 +7346,7 @@
echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:7348: checking for location of regex includes" >&5
+echo "configure:7350: checking for location of regex includes" >&5
case "$with_regex_includes" in
{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -7370,15 +7372,15 @@
do
-echo "configure:7374: checking for $ac_hdr" >&5
+echo "configure:7376: checking for $ac_hdr" >&5
-#line 7377 "configure"
+#line 7379 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7382: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7384: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7412,7 +7414,7 @@
echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:7416: checking for location of regex library" >&5
+echo "configure:7418: checking for location of regex library" >&5
case "$with_regex_libs" in
{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -7437,10 +7439,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:7441: checking for regcomp" >&5
+echo "configure:7443: checking for regcomp" >&5
-#line 7444 "configure"
+#line 7446 "configure"
which can conflict with char regcomp(); below. */
@@ -7463,7 +7465,7 @@
; return 0; }
EOF
-if { (eval echo configure:7467: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7469: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_regcomp=yes"
else
@@ -7490,13 +7492,13 @@
echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:7494: checking for regcomp in -lregex" >&5
+echo "configure:7496: checking for regcomp in -lregex" >&5
ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
LIBS="-lregex $LIBS"
-#line 7500 "configure"
+#line 7502 "configure"
@@ -7507,7 +7509,7 @@
regcomp()
; return 0; }
EOF
-if { (eval echo configure:7511: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7513: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7557,7 +7559,7 @@
echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:7561: checking whether to use Readline" >&5
+echo "configure:7563: checking whether to use Readline" >&5
echo "$ac_t"""$with_readline"" 1>&6
case "$with_readline" in
"no") USE_READLINE= ;;
@@ -7578,7 +7580,7 @@
echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:7582: checking for location of Readline includes" >&5
+echo "configure:7584: checking for location of Readline includes" >&5
case "$with_readline_includes" in
{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -7604,15 +7606,15 @@
do
-echo "configure:7608: checking for $ac_hdr" >&5
+echo "configure:7610: checking for $ac_hdr" >&5
-#line 7611 "configure"
+#line 7613 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7616: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7618: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7648,15 +7650,15 @@
do
-echo "configure:7652: checking for $ac_hdr" >&5
+echo "configure:7654: checking for $ac_hdr" >&5
-#line 7655 "configure"
+#line 7657 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7660: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7662: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7690,7 +7692,7 @@
echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:7694: checking for location of Readline library" >&5
+echo "configure:7696: checking for location of Readline library" >&5
case "$with_readline_libs" in
{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -7715,13 +7717,13 @@
echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:7719: checking for readline in -lreadline" >&5
+echo "configure:7721: checking for readline in -lreadline" >&5
ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
LIBS="-lreadline $LIBS"
-#line 7725 "configure"
+#line 7727 "configure"
@@ -7732,7 +7734,7 @@
readline()
; return 0; }
EOF
-if { (eval echo configure:7736: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7767,13 +7769,13 @@
echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:7771: checking for add_history in -lhistory" >&5
+echo "configure:7773: checking for add_history in -lhistory" >&5
ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
LIBS="-lhistory $LIBS"
-#line 7777 "configure"
+#line 7779 "configure"
@@ -7784,7 +7786,7 @@
add_history()
; return 0; }
EOF
-if { (eval echo configure:7788: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7790: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7826,7 +7828,7 @@
# GDAL option
echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:7830: checking whether to use GDAL" >&5
+echo "configure:7832: checking whether to use GDAL" >&5
GDAL_LIBS=
GDAL_CFLAGS=
@@ -7844,7 +7846,7 @@
# Extract the first word of "gdal-config", so it can be a program name with args.
set dummy gdal-config; ac_word=$2
-echo "configure:7848: checking for $ac_word" >&5
+echo "configure:7850: checking for $ac_word" >&5
case "$GDAL_CONFIG" in
@@ -7899,14 +7901,14 @@
LIBS="$LIBS $GDAL_LIBS"
CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 7903 "configure"
+#line 7905 "configure"
#include <gdal.h>
int main() {
GDALOpen("foo", GA_ReadOnly);
; return 0; }
EOF
-if { (eval echo configure:7910: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
echo "configure: failed program was:" >&5
@@ -7915,14 +7917,14 @@
LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 7919 "configure"
+#line 7921 "configure"
#include <gdal.h>
int main() {
; return 0; }
EOF
-if { (eval echo configure:7926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7928: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
else
@@ -7954,7 +7956,7 @@
# GEOS option
echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:7958: checking whether to use GEOS" >&5
+echo "configure:7960: checking whether to use GEOS" >&5
GEOS_LIBS=
GGEOS_CFLAGS=
@@ -7972,7 +7974,7 @@
# Extract the first word of "geos-config", so it can be a program name with args.
set dummy geos-config; ac_word=$2
-echo "configure:7976: checking for $ac_word" >&5
+echo "configure:7978: checking for $ac_word" >&5
case "$GEOS_CONFIG" in
@@ -8020,15 +8022,15 @@
do
-echo "configure:8024: checking for $ac_hdr" >&5
+echo "configure:8026: checking for $ac_hdr" >&5
cat > conftest.$ac_ext <<EOF
-#line 8027 "configure"
+#line 8029 "configure"
#include "confdefs.h"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8032: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8034: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8067,13 +8069,13 @@
echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:8071: checking for initGEOS in -lgeos_c" >&5
+echo "configure:8073: checking for initGEOS in -lgeos_c" >&5
ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lgeos_c $LIBS"
-#line 8077 "configure"
+#line 8079 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -8084,7 +8086,7 @@
initGEOS()
; return 0; }
EOF
-if { (eval echo configure:8088: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8090: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -8128,7 +8130,7 @@
echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:8132: checking whether to use TIFF" >&5
+echo "configure:8134: checking whether to use TIFF" >&5
echo "$ac_t"""$with_tiff"" 1>&6
case "$with_tiff" in
"no") USE_TIFF= ;;
@@ -8148,7 +8150,7 @@
echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:8152: checking for location of TIFF includes" >&5
+echo "configure:8154: checking for location of TIFF includes" >&5
case "$with_tiff_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -8174,15 +8176,15 @@
do
-echo "configure:8178: checking for $ac_hdr" >&5
+echo "configure:8180: checking for $ac_hdr" >&5
-#line 8181 "configure"
+#line 8183 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8186: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8188: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8216,7 +8218,7 @@
echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:8220: checking for location of TIFF library" >&5
+echo "configure:8222: checking for location of TIFF library" >&5
case "$with_tiff_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -8247,13 +8249,13 @@
echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:8251: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8253: checking for TIFFOpen in -ltiff" >&5
ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
LIBS="-ltiff $LIBS"
-#line 8257 "configure"
+#line 8259 "configure"
@@ -8264,7 +8266,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8268: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8270: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8283,13 +8285,13 @@
-echo "configure:8287: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8289: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $MATHLIB $LIBS"
-#line 8293 "configure"
+#line 8295 "configure"
@@ -8300,7 +8302,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8304: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8306: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8319,13 +8321,13 @@
-echo "configure:8323: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8325: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $LIBS"
-#line 8329 "configure"
+#line 8331 "configure"
@@ -8336,7 +8338,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8340: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8342: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8355,13 +8357,13 @@
-echo "configure:8359: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8361: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 8365 "configure"
+#line 8367 "configure"
@@ -8372,7 +8374,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8376: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8378: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8391,13 +8393,13 @@
-echo "configure:8395: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8397: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $LIBS"
-#line 8401 "configure"
+#line 8403 "configure"
@@ -8408,7 +8410,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8412: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8414: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8427,13 +8429,13 @@
-echo "configure:8431: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8433: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $MATHLIB $LIBS"
-#line 8437 "configure"
+#line 8439 "configure"
@@ -8444,7 +8446,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8448: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8450: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8463,13 +8465,13 @@
-echo "configure:8467: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8469: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $ZLIB $LIBS"
-#line 8473 "configure"
+#line 8475 "configure"
@@ -8480,7 +8482,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8484: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8486: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8499,13 +8501,13 @@
-echo "configure:8503: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8505: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $ZLIB $MATHLIB $LIBS"
-#line 8509 "configure"
+#line 8511 "configure"
@@ -8516,7 +8518,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:8520: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8522: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8614,7 +8616,7 @@
echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8618: checking whether to use PNG" >&5
+echo "configure:8620: checking whether to use PNG" >&5
echo "$ac_t"""$with_png"" 1>&6
case "$with_png" in
"no") USE_PNG= ;;
@@ -8633,7 +8635,7 @@
echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8637: checking for location of PNG includes" >&5
+echo "configure:8639: checking for location of PNG includes" >&5
case "$with_png_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8659,15 +8661,15 @@
do
-echo "configure:8663: checking for $ac_hdr" >&5
+echo "configure:8665: checking for $ac_hdr" >&5
-#line 8666 "configure"
+#line 8668 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:8671: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8673: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -8701,7 +8703,7 @@
echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:8705: checking for location of PNG library" >&5
+echo "configure:8707: checking for location of PNG library" >&5
case "$with_png_libs" in
{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -8726,13 +8728,13 @@
echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:8730: checking for png_read_image in -lpng" >&5
+echo "configure:8732: checking for png_read_image in -lpng" >&5
ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 8736 "configure"
+#line 8738 "configure"
@@ -8743,7 +8745,7 @@
png_read_image()
; return 0; }
EOF
-if { (eval echo configure:8747: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8749: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8785,7 +8787,7 @@
echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:8789: checking whether to use PostgreSQL" >&5
+echo "configure:8791: checking whether to use PostgreSQL" >&5
echo "$ac_t"""$with_postgres"" 1>&6
case "$with_postgres" in
"no") USE_POSTGRES= ;;
@@ -8812,7 +8814,7 @@
echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:8816: checking for location of PostgreSQL includes" >&5
+echo "configure:8818: checking for location of PostgreSQL includes" >&5
case "$with_postgres_includes" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -8838,15 +8840,15 @@
do
-echo "configure:8842: checking for $ac_hdr" >&5
+echo "configure:8844: checking for $ac_hdr" >&5
-#line 8845 "configure"
+#line 8847 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8850: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8852: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8884,7 +8886,7 @@
echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:8888: checking for location of PostgreSQL library" >&5
+echo "configure:8890: checking for location of PostgreSQL library" >&5
case "$with_postgres_libs" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -8913,13 +8915,13 @@
echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:8917: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8919: checking for PQsetdbLogin in -lpq" >&5
ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 8923 "configure"
+#line 8925 "configure"
@@ -8930,7 +8932,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:8934: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8936: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8949,13 +8951,13 @@
-echo "configure:8953: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8955: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 8959 "configure"
+#line 8961 "configure"
@@ -8966,7 +8968,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:8970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8972: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8985,13 +8987,13 @@
-echo "configure:8989: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:8991: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt $LIBS"
-#line 8995 "configure"
+#line 8997 "configure"
@@ -9002,7 +9004,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9006: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9008: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9021,13 +9023,13 @@
-echo "configure:9025: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9027: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9031 "configure"
+#line 9033 "configure"
@@ -9038,7 +9040,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:9042: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9044: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9095,13 +9097,13 @@
ac_save_ldflags="$LDFLAGS"
LDFLAGS="$LDFLAGS $PQLIBPATH"
echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9099: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9101: checking for PQcmdTuples in -lpq" >&5
ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 9105 "configure"
+#line 9107 "configure"
@@ -9112,7 +9114,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9116: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9118: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9134,13 +9136,13 @@
-echo "configure:9138: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9140: checking for PQcmdTuples in -lpq" >&5
-#line 9144 "configure"
+#line 9146 "configure"
@@ -9151,7 +9153,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:9155: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9157: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9194,7 +9196,7 @@
echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9198: checking whether to use MySQL" >&5
+echo "configure:9200: checking whether to use MySQL" >&5
echo "$ac_t"""$with_mysql"" 1>&6
case "$with_mysql" in
"no") USE_MYSQL= ;;
@@ -9214,7 +9216,7 @@
echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9218: checking for location of MySQL includes" >&5
+echo "configure:9220: checking for location of MySQL includes" >&5
case "$with_mysql_includes" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9240,15 +9242,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:9244: checking for $ac_hdr" >&5
+echo "configure:9246: checking for $ac_hdr" >&5
-#line 9247 "configure"
+#line 9249 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9252: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9254: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9285,7 +9287,7 @@
echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9289: checking for location of MySQL library" >&5
+echo "configure:9291: checking for location of MySQL library" >&5
case "$with_mysql_libs" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9316,13 +9318,13 @@
echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9320: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9322: checking for mysql_query in -lmysqlclient" >&5
ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
LIBS="-lmysqlclient $LIBS"
-#line 9326 "configure"
+#line 9328 "configure"
@@ -9333,7 +9335,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9337: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9339: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9352,13 +9354,13 @@
-echo "configure:9356: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9358: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9362 "configure"
+#line 9364 "configure"
@@ -9369,7 +9371,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9373: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9375: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9388,13 +9390,13 @@
-echo "configure:9392: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9394: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9398 "configure"
+#line 9400 "configure"
@@ -9405,7 +9407,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9409: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9411: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9424,13 +9426,13 @@
-echo "configure:9428: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9430: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9434 "configure"
+#line 9436 "configure"
@@ -9441,7 +9443,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9445: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9447: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9460,13 +9462,13 @@
-echo "configure:9464: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9466: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9470 "configure"
+#line 9472 "configure"
@@ -9477,7 +9479,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9481: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9483: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9496,13 +9498,13 @@
-echo "configure:9500: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9502: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 9506 "configure"
+#line 9508 "configure"
@@ -9513,7 +9515,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9517: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9519: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9532,13 +9534,13 @@
-echo "configure:9536: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9538: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 9542 "configure"
+#line 9544 "configure"
@@ -9549,7 +9551,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9553: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9555: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9568,13 +9570,13 @@
-echo "configure:9572: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9574: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 9578 "configure"
+#line 9580 "configure"
@@ -9585,7 +9587,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:9589: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9591: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9675,7 +9677,7 @@
# Extract the first word of "mysql_config", so it can be a program name with args.
set dummy mysql_config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:9679: checking for $ac_word" >&5
+echo "configure:9681: checking for $ac_word" >&5
case "$MYSQLD_CONFIG" in
@@ -9716,10 +9718,10 @@
LIBS="$MYSQLDLIB $LIBS"
echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:9720: checking for mysql_server_init" >&5
+echo "configure:9722: checking for mysql_server_init" >&5
-#line 9723 "configure"
+#line 9725 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char mysql_server_init(); below. */
@@ -9742,7 +9744,7 @@
; return 0; }
EOF
-if { (eval echo configure:9746: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9748: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_mysql_server_init=yes"
else
@@ -9780,7 +9782,7 @@
echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:9784: checking whether to use SQLite" >&5
+echo "configure:9786: checking whether to use SQLite" >&5
echo "$ac_t"""$with_sqlite"" 1>&6
case "$with_sqlite" in
"no") USE_SQLITE= ;;
@@ -9800,7 +9802,7 @@
echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:9804: checking for location of SQLite includes" >&5
+echo "configure:9806: checking for location of SQLite includes" >&5
case "$with_sqlite_includes" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -9826,15 +9828,15 @@
do
-echo "configure:9830: checking for $ac_hdr" >&5
+echo "configure:9832: checking for $ac_hdr" >&5
-#line 9833 "configure"
+#line 9835 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9838: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9840: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9877,7 +9879,7 @@
echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:9881: checking for location of SQLite library" >&5
+echo "configure:9883: checking for location of SQLite library" >&5
case "$with_sqlite_libs" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -9906,13 +9908,13 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:9910: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9912: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
LIBS="-lsqlite3 $LIBS"
-#line 9916 "configure"
+#line 9918 "configure"
@@ -9923,7 +9925,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:9927: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9929: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9942,13 +9944,13 @@
-echo "configure:9946: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9948: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 9952 "configure"
+#line 9954 "configure"
@@ -9959,7 +9961,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:9963: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9965: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9978,13 +9980,13 @@
-echo "configure:9982: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:9984: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 9988 "configure"
+#line 9990 "configure"
@@ -9995,7 +9997,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:9999: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10001: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10014,13 +10016,13 @@
-echo "configure:10018: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10020: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 10024 "configure"
+#line 10026 "configure"
@@ -10031,7 +10033,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:10035: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10037: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10100,7 +10102,7 @@
echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10104: checking whether to use FFMPEG" >&5
+echo "configure:10106: checking whether to use FFMPEG" >&5
echo "$ac_t"""$with_ffmpeg"" 1>&6
case "$with_ffmpeg" in
"no") USE_FFMPEG= ;;
@@ -10120,7 +10122,7 @@
echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10124: checking for location of FFMPEG includes" >&5
+echo "configure:10126: checking for location of FFMPEG includes" >&5
case "$with_ffmpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10146,15 +10148,15 @@
do
-echo "configure:10150: checking for $ac_hdr" >&5
+echo "configure:10152: checking for $ac_hdr" >&5
-#line 10153 "configure"
+#line 10155 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10158: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10160: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10190,15 +10192,15 @@
do
-echo "configure:10194: checking for $ac_hdr" >&5
+echo "configure:10196: checking for $ac_hdr" >&5
-#line 10197 "configure"
+#line 10199 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10202: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10204: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10234,15 +10236,15 @@
do
-echo "configure:10238: checking for $ac_hdr" >&5
+echo "configure:10240: checking for $ac_hdr" >&5
-#line 10241 "configure"
+#line 10243 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10246: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10248: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10285,7 +10287,7 @@
echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10289: checking for location of FFMPEG library" >&5
+echo "configure:10291: checking for location of FFMPEG library" >&5
case "$with_ffmpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10312,13 +10314,13 @@
echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10316: checking for av_free in -lavutil" >&5
+echo "configure:10318: checking for av_free in -lavutil" >&5
ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
LIBS="-lavutil $LIBS"
-#line 10322 "configure"
+#line 10324 "configure"
@@ -10329,7 +10331,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:10333: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10335: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10348,13 +10350,13 @@
-echo "configure:10352: checking for av_free in -lavutil" >&5
+echo "configure:10354: checking for av_free in -lavutil" >&5
LIBS="-lavutil $MATHLIB $LIBS"
-#line 10358 "configure"
+#line 10360 "configure"
@@ -10365,7 +10367,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:10369: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10371: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10410,13 +10412,13 @@
echo $ac_n "checking for avcodec_register in -lavcodec""... $ac_c" 1>&6
-echo "configure:10414: checking for avcodec_register in -lavcodec" >&5
+echo "configure:10416: checking for avcodec_register in -lavcodec" >&5
ac_lib_var=`echo avcodec'_'avcodec_register | sed 'y%./+-%__p_%'`
LIBS="-lavcodec $FFMPEGLIB $LIBS"
-#line 10420 "configure"
+#line 10422 "configure"
@@ -10427,7 +10429,7 @@
avcodec_register()
; return 0; }
EOF
-if { (eval echo configure:10431: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10433: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10446,13 +10448,13 @@
-echo "configure:10450: checking for avcodec_register in -lavcodec" >&5
+echo "configure:10452: checking for avcodec_register in -lavcodec" >&5
LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 10456 "configure"
+#line 10458 "configure"
@@ -10463,7 +10465,7 @@
avcodec_register()
; return 0; }
EOF
-if { (eval echo configure:10467: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10469: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10508,13 +10510,13 @@
echo $ac_n "checking for avformat_alloc_context in -lavformat""... $ac_c" 1>&6
-echo "configure:10512: checking for avformat_alloc_context in -lavformat" >&5
+echo "configure:10514: checking for avformat_alloc_context in -lavformat" >&5
ac_lib_var=`echo avformat'_'avformat_alloc_context | sed 'y%./+-%__p_%'`
LIBS="-lavformat $FFMPEGLIB $LIBS"
-#line 10518 "configure"
+#line 10520 "configure"
@@ -10525,7 +10527,7 @@
avformat_alloc_context()
; return 0; }
EOF
-if { (eval echo configure:10529: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10531: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10544,13 +10546,13 @@
-echo "configure:10548: checking for avformat_alloc_context in -lavformat" >&5
+echo "configure:10550: checking for avformat_alloc_context in -lavformat" >&5
LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 10554 "configure"
+#line 10556 "configure"
@@ -10561,7 +10563,7 @@
; return 0; }
EOF
-if { (eval echo configure:10565: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10567: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10620,7 +10622,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10624: checking whether to use OpenGL" >&5
+echo "configure:10626: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -10654,7 +10656,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:10658: checking for location of OpenGL includes" >&5
+echo "configure:10660: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -10680,15 +10682,15 @@
do
-echo "configure:10684: checking for $ac_hdr" >&5
+echo "configure:10686: checking for $ac_hdr" >&5
-#line 10687 "configure"
+#line 10689 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10692: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10694: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10725,15 +10727,15 @@
do
-echo "configure:10729: checking for $ac_hdr" >&5
+echo "configure:10731: checking for $ac_hdr" >&5
-#line 10732 "configure"
+#line 10734 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10737: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10739: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10767,7 +10769,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:10771: checking for location of OpenGL library" >&5
+echo "configure:10773: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -10788,7 +10790,7 @@
echo $ac_n "checking for location of Xmu library""... $ac_c" 1>&6
-echo "configure:10792: checking for location of Xmu library" >&5
+echo "configure:10794: checking for location of Xmu library" >&5
case "$with_Xmu_libs" in
{ echo "configure: error: *** You must supply a directory to --with-Xmu-libs." 1>&2; exit 1; }
@@ -10817,13 +10819,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:10821: checking for glBegin in -lGL" >&5
+echo "configure:10823: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 10827 "configure"
+#line 10829 "configure"
@@ -10834,7 +10836,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10838: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10840: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10853,13 +10855,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:10857: checking for glBegin in -lGL" >&5
+echo "configure:10859: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 10863 "configure"
+#line 10865 "configure"
@@ -10870,7 +10872,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10874: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10876: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10889,13 +10891,13 @@
-echo "configure:10893: checking for glBegin in -lGL" >&5
+echo "configure:10895: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 10899 "configure"
+#line 10901 "configure"
@@ -10906,7 +10908,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10910: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10925,13 +10927,13 @@
-echo "configure:10929: checking for glBegin in -lGL" >&5
+echo "configure:10931: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 10935 "configure"
+#line 10937 "configure"
@@ -10942,7 +10944,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:10946: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10948: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11004,13 +11006,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:11008: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11010: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 11014 "configure"
+#line 11016 "configure"
@@ -11021,7 +11023,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11025: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11027: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11040,13 +11042,13 @@
-echo "configure:11044: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:11046: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 11050 "configure"
+#line 11052 "configure"
@@ -11057,7 +11059,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:11061: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11063: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11101,10 +11103,10 @@
LDFLAGS="$LDFLAGS $OPENGLLIB"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:11105: checking for glXCreatePbuffer" >&5
+echo "configure:11107: checking for glXCreatePbuffer" >&5
-#line 11108 "configure"
+#line 11110 "configure"
which can conflict with char glXCreatePbuffer(); below. */
@@ -11127,7 +11129,7 @@
; return 0; }
EOF
-if { (eval echo configure:11131: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11133: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -11149,10 +11151,10 @@
fi
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11153: checking for glXCreateGLXPixmap" >&5
+echo "configure:11155: checking for glXCreateGLXPixmap" >&5
-#line 11156 "configure"
+#line 11158 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -11175,7 +11177,7 @@
; return 0; }
EOF
-if { (eval echo configure:11179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11181: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -11214,7 +11216,7 @@
-echo "configure:11218: checking for location of OpenGL includes" >&5
+echo "configure:11220: checking for location of OpenGL includes" >&5
@@ -11240,15 +11242,15 @@
do
-echo "configure:11244: checking for $ac_hdr" >&5
+echo "configure:11246: checking for $ac_hdr" >&5
-#line 11247 "configure"
+#line 11249 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11252: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11254: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11283,10 +11285,10 @@
LDFLAGS="$with_opengl_libs $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11287: checking for glBegin" >&5
+echo "configure:11289: checking for glBegin" >&5
-#line 11290 "configure"
+#line 11292 "configure"
which can conflict with char glBegin(); below. */
@@ -11309,7 +11311,7 @@
; return 0; }
EOF
-if { (eval echo configure:11313: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11315: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -11324,10 +11326,10 @@
echo "$ac_t""yes" 1>&6
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11328: checking for gluBeginCurve" >&5
+echo "configure:11330: checking for gluBeginCurve" >&5
-#line 11331 "configure"
+#line 11333 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -11350,7 +11352,7 @@
; return 0; }
EOF
-if { (eval echo configure:11354: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11356: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -11394,7 +11396,7 @@
-echo "configure:11398: checking for location of OpenGL includes" >&5
+echo "configure:11400: checking for location of OpenGL includes" >&5
@@ -11420,15 +11422,15 @@
do
-echo "configure:11424: checking for $ac_hdr" >&5
+echo "configure:11426: checking for $ac_hdr" >&5
-#line 11427 "configure"
+#line 11429 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11432: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11434: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11462,7 +11464,7 @@
-echo "configure:11466: checking for location of OpenGL library" >&5
+echo "configure:11468: checking for location of OpenGL library" >&5
@@ -11487,18 +11489,18 @@
ac_save_libs="$LIBS"
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11491: checking for OpenGL library" >&5
+echo "configure:11493: checking for OpenGL library" >&5
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
LIBS="-lopengl32 "
-#line 11495 "configure"
+#line 11497 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:11502: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11504: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
@@ -11522,18 +11524,18 @@
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11526: checking for GLU library" >&5
+echo "configure:11528: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB "
-#line 11530 "configure"
+#line 11532 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:11537: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11539: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -11582,7 +11584,7 @@
echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:11586: checking whether to use Tcl/Tk" >&5
+echo "configure:11588: checking whether to use Tcl/Tk" >&5
echo "$ac_t"""$with_tcltk"" 1>&6
case "$with_tcltk" in
"no") USE_TCLTK= ;;
@@ -11602,7 +11604,7 @@
echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:11606: checking for location of Tcl/Tk includes" >&5
+echo "configure:11608: checking for location of Tcl/Tk includes" >&5
case "$with_tcltk_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -11628,15 +11630,15 @@
do
-echo "configure:11632: checking for $ac_hdr" >&5
+echo "configure:11634: checking for $ac_hdr" >&5
-#line 11635 "configure"
+#line 11637 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11640: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11642: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11673,15 +11675,15 @@
do
-echo "configure:11677: checking for $ac_hdr" >&5
+echo "configure:11679: checking for $ac_hdr" >&5
-#line 11680 "configure"
+#line 11682 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11685: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11687: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11714,7 +11716,7 @@
# Tcl/Tk version checks
echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:11718: checking Tcl version" >&5
+echo "configure:11720: checking Tcl version" >&5
CPPFLAGS="$TCLINCDIR $CPPFLAGS"
if test "$cross_compiling" = yes; then
@@ -11722,7 +11724,7 @@
else
-#line 11726 "configure"
+#line 11728 "configure"
#include <stdio.h>
@@ -11734,7 +11736,7 @@
EOF
-if { (eval echo configure:11738: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11740: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tcl_ver=`cat conftestdata`
echo "$ac_t""$tcl_ver" 1>&6
@@ -11752,7 +11754,7 @@
echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:11756: checking Tk version" >&5
+echo "configure:11758: checking Tk version" >&5
CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -11760,7 +11762,7 @@
else
-#line 11764 "configure"
+#line 11766 "configure"
#include <stdio.h>
@@ -11772,7 +11774,7 @@
EOF
-if { (eval echo configure:11776: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11778: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
tk_ver=`cat conftestdata`
echo "$ac_t""$tk_ver" 1>&6
@@ -11803,7 +11805,7 @@
echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:11807: checking for location of Tcl/Tk library" >&5
+echo "configure:11809: checking for location of Tcl/Tk library" >&5
case "$with_tcltk_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -11843,13 +11845,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:11847: checking for Tcl_Init in -ltcl" >&5
+echo "configure:11849: checking for Tcl_Init in -ltcl" >&5
ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl $MATHLIB $LIBS"
-#line 11853 "configure"
+#line 11855 "configure"
@@ -11860,7 +11862,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11864: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11866: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11879,13 +11881,13 @@
-echo "configure:11883: checking for Tcl_Init in -ltcl" >&5
+echo "configure:11885: checking for Tcl_Init in -ltcl" >&5
LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 11889 "configure"
+#line 11891 "configure"
@@ -11896,7 +11898,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11900: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11902: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11923,13 +11925,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:11927: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:11929: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 11933 "configure"
+#line 11935 "configure"
@@ -11940,7 +11942,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11944: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11946: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11959,13 +11961,13 @@
-echo "configure:11963: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:11965: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 11969 "configure"
+#line 11971 "configure"
@@ -11976,7 +11978,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:11980: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11982: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12003,13 +12005,13 @@
echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:12007: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:12009: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 12013 "configure"
+#line 12015 "configure"
@@ -12020,7 +12022,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12024: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12026: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12039,13 +12041,13 @@
-echo "configure:12043: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:12045: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 12049 "configure"
+#line 12051 "configure"
@@ -12056,7 +12058,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12060: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12062: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12134,13 +12136,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:12138: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:12140: checking for Tk_MainWindow in -ltk" >&5
ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 12144 "configure"
+#line 12146 "configure"
@@ -12151,7 +12153,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12155: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12157: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12170,13 +12172,13 @@
-echo "configure:12174: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:12176: checking for Tk_MainWindow in -ltk" >&5
LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12180 "configure"
+#line 12182 "configure"
@@ -12187,7 +12189,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12191: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12193: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12214,13 +12216,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:12218: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:12220: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 12224 "configure"
+#line 12226 "configure"
@@ -12231,7 +12233,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12235: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12237: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12250,13 +12252,13 @@
-echo "configure:12254: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:12256: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12260 "configure"
+#line 12262 "configure"
@@ -12267,7 +12269,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12271: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12273: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12294,13 +12296,13 @@
echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:12298: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12300: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 12304 "configure"
+#line 12306 "configure"
@@ -12311,7 +12313,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12315: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12317: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12330,13 +12332,13 @@
-echo "configure:12334: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12336: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12340 "configure"
+#line 12342 "configure"
@@ -12347,7 +12349,7 @@
Tk_MainWindow()
; return 0; }
EOF
-if { (eval echo configure:12351: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12353: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12437,13 +12439,13 @@
do
# add only if in MACOSX_ARCHS
echo $ac_n "checking for Tcl_Init in -l$tlib""... $ac_c" 1>&6
-echo "configure:12441: checking for Tcl_Init in -l$tlib" >&5
+echo "configure:12443: checking for Tcl_Init in -l$tlib" >&5
ac_lib_var=`echo $tlib'_'Tcl_Init | sed 'y%./+-%__p_%'`
LIBS="-l$tlib -arch $a $MACOSX_SDK $TCLTKLIBPATH $LIBS"
-#line 12447 "configure"
+#line 12449 "configure"
@@ -12454,7 +12456,7 @@
Tcl_Init()
; return 0; }
EOF
-if { (eval echo configure:12458: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12460: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12503,7 +12505,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:12507: checking whether to use ODBC" >&5
+echo "configure:12509: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -12522,7 +12524,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:12526: checking for location of ODBC includes" >&5
+echo "configure:12528: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -12548,15 +12550,15 @@
do
-echo "configure:12552: checking for $ac_hdr" >&5
+echo "configure:12554: checking for $ac_hdr" >&5
-#line 12555 "configure"
+#line 12557 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12560: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12562: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12590,7 +12592,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:12594: checking for location of ODBC library" >&5
+echo "configure:12596: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -12615,13 +12617,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:12619: checking for SQLConnect in -lodbc" >&5
+echo "configure:12621: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 12625 "configure"
+#line 12627 "configure"
@@ -12632,7 +12634,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:12636: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12638: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12657,13 +12659,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12661: checking for SQLConnect in -liodbc" >&5
+echo "configure:12663: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 12667 "configure"
+#line 12669 "configure"
@@ -12674,7 +12676,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:12678: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12680: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12699,11 +12701,11 @@
echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12703: checking for ODBC library" >&5
+echo "configure:12705: checking for ODBC library" >&5
LDFLAGS="$ODBCLIB $LDFLAGS"
LIBS="-lodbc32 "
-#line 12707 "configure"
+#line 12709 "configure"
#include <windows.h>
#include <sql.h>
@@ -12711,7 +12713,7 @@
SQLAllocEnv((SQLHENV *)0);
; return 0; }
EOF
-if { (eval echo configure:12715: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12717: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -12760,7 +12762,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12764: checking whether to use FFTW" >&5
+echo "configure:12766: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -12779,7 +12781,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12783: checking for location of FFTW includes" >&5
+echo "configure:12785: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12805,15 +12807,15 @@
do
-echo "configure:12809: checking for $ac_hdr" >&5
+echo "configure:12811: checking for $ac_hdr" >&5
-#line 12812 "configure"
+#line 12814 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12817: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12819: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12841,15 +12843,15 @@
do
-echo "configure:12845: checking for $ac_hdr" >&5
+echo "configure:12847: checking for $ac_hdr" >&5
-#line 12848 "configure"
+#line 12850 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12853: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12855: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12877,15 +12879,15 @@
do
-echo "configure:12881: checking for $ac_hdr" >&5
+echo "configure:12883: checking for $ac_hdr" >&5
-#line 12884 "configure"
+#line 12886 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12889: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12891: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12931,7 +12933,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12935: checking for location of FFTW library" >&5
+echo "configure:12937: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12956,13 +12958,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12960: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12962: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12966 "configure"
+#line 12968 "configure"
@@ -12973,7 +12975,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:12977: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12979: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12998,13 +13000,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:13002: checking for fftwnd_one in -lfftw" >&5
+echo "configure:13004: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
-#line 13008 "configure"
+#line 13010 "configure"
@@ -13015,7 +13017,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:13019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13021: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13040,13 +13042,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:13044: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:13046: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 13050 "configure"
+#line 13052 "configure"
@@ -13057,7 +13059,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:13061: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13063: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13114,7 +13116,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:13118: checking whether to use BLAS" >&5
+echo "configure:13120: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -13135,7 +13137,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:13139: checking for location of BLAS includes" >&5
+echo "configure:13141: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -13155,7 +13157,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:13159: checking for location of BLAS library" >&5
+echo "configure:13161: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -13181,15 +13183,15 @@
do
-echo "configure:13185: checking for $ac_hdr" >&5
+echo "configure:13187: checking for $ac_hdr" >&5
cat > conftest.$ac_ext <<EOF
-#line 13188 "configure"
+#line 13190 "configure"
#include "confdefs.h"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13193: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13195: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -13224,13 +13226,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:13228: checking for dnrm2_ in -lblas" >&5
+echo "configure:13230: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lblas $MATHLIB $LIBS"
-#line 13234 "configure"
+#line 13236 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -13241,7 +13243,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:13245: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13247: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -13260,13 +13262,13 @@
-echo "configure:13264: checking for dnrm2_ in -lblas" >&5
+echo "configure:13266: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 13270 "configure"
+#line 13272 "configure"
@@ -13277,7 +13279,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:13281: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13283: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13321,13 +13323,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:13325: checking for ATL_xerbla in -latlas" >&5
+echo "configure:13327: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 13331 "configure"
+#line 13333 "configure"
@@ -13338,7 +13340,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:13342: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13344: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13353,13 +13355,13 @@
if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:13357: checking for sgemm_ in -lf77blas" >&5
+echo "configure:13359: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 13363 "configure"
+#line 13365 "configure"
@@ -13370,7 +13372,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13374: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13376: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13385,13 +13387,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:13389: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:13391: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 13395 "configure"
+#line 13397 "configure"
@@ -13402,7 +13404,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:13406: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13408: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13448,16 +13450,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:13452: checking for sgemm in $vlib_flags" >&5
+echo "configure:13454: checking for sgemm in $vlib_flags" >&5
-#line 13454 "configure"
+#line 13456 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:13461: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13463: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -13475,13 +13477,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:13479: checking for sgemm_ in -lblas" >&5
+echo "configure:13481: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $LIBS"
-#line 13485 "configure"
+#line 13487 "configure"
@@ -13492,7 +13494,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13496: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13498: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13507,13 +13509,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:13511: checking for dgemm_ in -ldgemm" >&5
+echo "configure:13513: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 13517 "configure"
+#line 13519 "configure"
@@ -13524,7 +13526,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:13528: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13530: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13539,13 +13541,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:13543: checking for sgemm_ in -lsgemm" >&5
+echo "configure:13545: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 13549 "configure"
+#line 13551 "configure"
@@ -13556,7 +13558,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13560: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13562: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13590,13 +13592,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:13594: checking for acosp in -lsunmath" >&5
+echo "configure:13596: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
LIBS="-lsunmath $LIBS"
-#line 13600 "configure"
+#line 13602 "configure"
@@ -13607,7 +13609,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:13611: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13613: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13622,13 +13624,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:13626: checking for sgemm_ in -lsunperf" >&5
+echo "configure:13628: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 13632 "configure"
+#line 13634 "configure"
@@ -13639,7 +13641,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13643: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13645: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13669,13 +13671,13 @@
# Generic BLAS library
-echo "configure:13673: checking for sgemm_ in -lblas" >&5
+echo "configure:13675: checking for sgemm_ in -lblas" >&5
LIBS="-lblas $LIBS"
-#line 13679 "configure"
+#line 13681 "configure"
@@ -13686,7 +13688,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:13690: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13692: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13725,7 +13727,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13729: checking whether to use LAPACK" >&5
+echo "configure:13731: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -13750,7 +13752,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13754: checking for location of LAPACK includes" >&5
+echo "configure:13756: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13770,7 +13772,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13774: checking for location of LAPACK library" >&5
+echo "configure:13776: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13796,15 +13798,15 @@
do
-echo "configure:13800: checking for $ac_hdr" >&5
+echo "configure:13802: checking for $ac_hdr" >&5
-#line 13803 "configure"
+#line 13805 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13808: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13810: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -13836,10 +13838,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13840: checking for dsegv_" >&5
+echo "configure:13842: checking for dsegv_" >&5
-#line 13843 "configure"
+#line 13845 "configure"
which can conflict with char dsegv_(); below. */
@@ -13862,7 +13864,7 @@
; return 0; }
EOF
-if { (eval echo configure:13866: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13868: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -13889,13 +13891,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13893: checking for desgv_ in -llapack" >&5
+echo "configure:13895: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $FLIBS $LIBS"
-#line 13899 "configure"
+#line 13901 "configure"
@@ -13906,7 +13908,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:13910: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13912: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13938,13 +13940,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13942: checking for dgesv_ in -llapack" >&5
+echo "configure:13944: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 13948 "configure"
+#line 13950 "configure"
@@ -13955,7 +13957,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:13959: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13961: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -13974,13 +13976,13 @@
-echo "configure:13978: checking for dgesv_ in -llapack" >&5
+echo "configure:13980: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13984 "configure"
+#line 13986 "configure"
@@ -13991,7 +13993,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:13995: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13997: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14047,7 +14049,7 @@
echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:14051: checking whether to use Motif" >&5
+echo "configure:14053: checking whether to use Motif" >&5
echo "$ac_t"""$with_motif"" 1>&6
case "$with_motif" in
"no") USE_MOTIF= ;;
@@ -14066,7 +14068,7 @@
echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:14070: checking for location of Motif includes" >&5
+echo "configure:14072: checking for location of Motif includes" >&5
case "$with_motif_includes" in
{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -14092,15 +14094,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:14096: checking for $ac_hdr" >&5
+echo "configure:14098: checking for $ac_hdr" >&5
-#line 14099 "configure"
+#line 14101 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14104: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14106: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14134,7 +14136,7 @@
echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:14138: checking for location of Motif library" >&5
+echo "configure:14140: checking for location of Motif library" >&5
case "$with_motif_libs" in
{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -14159,13 +14161,13 @@
echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:14163: checking for XmStringCreate in -lXm" >&5
+echo "configure:14165: checking for XmStringCreate in -lXm" >&5
ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 14169 "configure"
+#line 14171 "configure"
@@ -14176,7 +14178,7 @@
XmStringCreate()
; return 0; }
EOF
-if { (eval echo configure:14180: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14182: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14217,7 +14219,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:14221: checking whether to use Cairo" >&5
+echo "configure:14223: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -14249,7 +14251,7 @@
echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:14253: checking for location of cairo includes" >&5
+echo "configure:14255: checking for location of cairo includes" >&5
case "$with_cairo_includes" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -14275,15 +14277,15 @@
do
-echo "configure:14279: checking for $ac_hdr" >&5
+echo "configure:14281: checking for $ac_hdr" >&5
-#line 14282 "configure"
+#line 14284 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14287: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14289: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14319,7 +14321,7 @@
echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:14323: checking for location of cairo library" >&5
+echo "configure:14325: checking for location of cairo library" >&5
case "$with_cairo_libs" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -14339,7 +14341,7 @@
echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:14343: checking for cairo linking flags" >&5
+echo "configure:14345: checking for cairo linking flags" >&5
case "$with_cairo_ldflags" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -14355,10 +14357,10 @@
LIBS=" $CAIROLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:14359: checking for cairo_create" >&5
+echo "configure:14361: checking for cairo_create" >&5
-#line 14362 "configure"
+#line 14364 "configure"
which can conflict with char cairo_create(); below. */
@@ -14381,7 +14383,7 @@
; return 0; }
EOF
-if { (eval echo configure:14385: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14387: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -14415,10 +14417,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:14419: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:14421: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 14422 "configure"
+#line 14424 "configure"
which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below. */
@@ -14441,7 +14443,7 @@
; return 0; }
EOF
-if { (eval echo configure:14445: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14447: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
else
@@ -14474,10 +14476,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:14478: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:14480: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 14481 "configure"
+#line 14483 "configure"
which can conflict with char cairo_xlib_surface_get_xrender_format(); below. */
@@ -14500,7 +14502,7 @@
; return 0; }
EOF
-if { (eval echo configure:14504: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14506: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
else
@@ -14542,7 +14544,7 @@
echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:14546: checking whether to use GLw" >&5
+echo "configure:14548: checking whether to use GLw" >&5
echo "$ac_t"""$with_glw"" 1>&6
case "$with_glw" in
"no") USE_GLW= ;;
@@ -14561,7 +14563,7 @@
echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:14565: checking for location of GLw includes" >&5
+echo "configure:14567: checking for location of GLw includes" >&5
case "$with_glw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -14587,15 +14589,15 @@
do
-echo "configure:14591: checking for $ac_hdr" >&5
+echo "configure:14593: checking for $ac_hdr" >&5
-#line 14594 "configure"
+#line 14596 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14599: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14601: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14623,15 +14625,15 @@
do
-echo "configure:14627: checking for $ac_hdr" >&5
+echo "configure:14629: checking for $ac_hdr" >&5
-#line 14630 "configure"
+#line 14632 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:14635: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14637: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -14671,7 +14673,7 @@
echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:14675: checking for location of GLw library" >&5
+echo "configure:14677: checking for location of GLw library" >&5
case "$with_glw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -14696,13 +14698,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14700: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:14702: checking for GLwCreateMDrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14706 "configure"
+#line 14708 "configure"
@@ -14713,7 +14715,7 @@
GLwCreateMDrawingArea()
; return 0; }
EOF
-if { (eval echo configure:14717: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14719: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14738,13 +14740,13 @@
echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14742: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:14744: checking for GLwCreateM1DrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14748 "configure"
+#line 14750 "configure"
@@ -14755,7 +14757,7 @@
GLwCreateM1DrawingArea()
; return 0; }
EOF
-if { (eval echo configure:14759: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14761: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14780,13 +14782,13 @@
echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14784: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:14786: checking for GLwCreateM2DrawingArea in -lGLw" >&5
ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14790 "configure"
+#line 14792 "configure"
@@ -14797,7 +14799,7 @@
GLwCreateM2DrawingArea()
; return 0; }
EOF
-if { (eval echo configure:14801: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14803: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14822,13 +14824,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14826: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:14828: checking for GLwCreateMDrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14832 "configure"
+#line 14834 "configure"
@@ -14839,7 +14841,7 @@
; return 0; }
EOF
-if { (eval echo configure:14843: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14845: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14864,13 +14866,13 @@
echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14868: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:14870: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14874 "configure"
+#line 14876 "configure"
@@ -14881,7 +14883,7 @@
; return 0; }
EOF
-if { (eval echo configure:14885: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14887: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14906,13 +14908,13 @@
echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14910: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:14912: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14916 "configure"
+#line 14918 "configure"
@@ -14923,7 +14925,7 @@
; return 0; }
EOF
-if { (eval echo configure:14927: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14929: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14950,13 +14952,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:14954: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14956: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 14960 "configure"
+#line 14962 "configure"
@@ -14967,7 +14969,7 @@
; return 0; }
EOF
-if { (eval echo configure:14971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14973: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -14986,13 +14988,13 @@
-echo "configure:14990: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14992: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14996 "configure"
+#line 14998 "configure"
@@ -15003,7 +15005,7 @@
; return 0; }
EOF
-if { (eval echo configure:15007: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15009: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15030,13 +15032,13 @@
echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:15034: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:15036: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 15040 "configure"
+#line 15042 "configure"
@@ -15047,7 +15049,7 @@
; return 0; }
EOF
-if { (eval echo configure:15051: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15053: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15066,13 +15068,13 @@
-echo "configure:15070: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:15072: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 15076 "configure"
+#line 15078 "configure"
@@ -15083,7 +15085,7 @@
; return 0; }
EOF
-if { (eval echo configure:15087: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15089: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15196,7 +15198,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:15200: checking whether to use FreeType" >&5
+echo "configure:15202: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -15215,7 +15217,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:15219: checking for location of FreeType includes" >&5
+echo "configure:15221: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -15241,15 +15243,15 @@
do
-echo "configure:15245: checking for $ac_hdr" >&5
+echo "configure:15247: checking for $ac_hdr" >&5
-#line 15248 "configure"
+#line 15250 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15253: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15255: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15283,7 +15285,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:15287: checking for location of FreeType library" >&5
+echo "configure:15289: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -15308,13 +15310,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:15312: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:15314: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 15318 "configure"
+#line 15320 "configure"
@@ -15325,7 +15327,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:15329: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15331: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15366,7 +15368,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:15370: checking whether to use NLS" >&5
+echo "configure:15372: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -15386,10 +15388,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:15390: checking for gettext" >&5
+echo "configure:15392: checking for gettext" >&5
-#line 15393 "configure"
+#line 15395 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char gettext(); below. */
@@ -15412,7 +15414,7 @@
; return 0; }
EOF
-if { (eval echo configure:15416: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15418: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -15430,13 +15432,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:15434: checking for gettext in -lintl" >&5
+echo "configure:15436: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 15440 "configure"
+#line 15442 "configure"
@@ -15447,7 +15449,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:15451: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15453: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -15482,7 +15484,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:15486: checking whether to use C++" >&5
+echo "configure:15488: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -15498,7 +15500,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:15502: checking for $ac_word" >&5
+echo "configure:15504: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -15527,7 +15529,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:15531: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:15533: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -15538,12 +15540,12 @@
cat > conftest.$ac_ext << EOF
-#line 15542 "configure"
+#line 15544 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:15547: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15549: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -15569,19 +15571,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:15573: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:15575: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:15578: checking whether we are using GNU C++" >&5
+echo "configure:15580: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15585: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15587: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -15599,7 +15601,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:15603: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:15605: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -15627,7 +15629,58 @@
fi
fi
+for ac_declaration in \
+ '#include <stdlib.h>' \
+ 'extern "C" void std::exit (int) throw (); using std::exit;' \
+ 'extern "C" void std::exit (int); using std::exit;' \
+ 'extern "C" void exit (int) throw ();' \
+ 'extern "C" void exit (int);' \
+ 'void exit (int);'
+do
+ cat > conftest.$ac_ext <<EOF
+#line 15643 "configure"
+#include "confdefs.h"
+#include <stdlib.h>
+$ac_declaration
+int main() {
+exit (42);
+; return 0; }
+EOF
+if { (eval echo configure:15651: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
+ echo "configure: failed program was:" >&5
+ cat conftest.$ac_ext >&5
+ rm -rf conftest*
+ continue
+fi
+rm -f conftest*
+#line 15661 "configure"
+$ac_declaration
+int main() {
+exit (42);
+; return 0; }
+EOF
+if { (eval echo configure:15668: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+ rm -rf conftest*
+ break
+else
+fi
+rm -f conftest*
+done
+if test -n "$ac_declaration"; then
+ echo '#ifdef __cplusplus' >>confdefs.h
+ echo $ac_declaration >>confdefs.h
+ echo '#endif' >>confdefs.h
+fi
+else
CXX=
CXXFLAGS=
@@ -15640,7 +15693,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:15644: checking whether to use openDWG" >&5
+echo "configure:15697: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -15660,7 +15713,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:15664: checking for location of openDGW includes" >&5
+echo "configure:15717: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -15686,15 +15739,15 @@
do
-echo "configure:15690: checking for $ac_hdr" >&5
+echo "configure:15743: checking for $ac_hdr" >&5
-#line 15693 "configure"
+#line 15746 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:15698: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15751: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -15728,7 +15781,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:15732: checking for location of openDWG library" >&5
+echo "configure:15785: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -15775,7 +15828,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:15779: checking for special C compiler options needed for large files" >&5
+echo "configure:15832: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -15783,7 +15836,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 15787 "configure"
+#line 15840 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -15799,7 +15852,7 @@
; return 0; }
EOF
-if { (eval echo configure:15803: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15856: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
@@ -15808,7 +15861,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 15812 "configure"
+#line 15865 "configure"
@@ -15824,7 +15877,7 @@
; return 0; }
EOF
-if { (eval echo configure:15828: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15881: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -15844,11 +15897,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:15848: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:15901: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 15852 "configure"
+#line 15905 "configure"
@@ -15864,14 +15917,14 @@
; return 0; }
EOF
-if { (eval echo configure:15868: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15921: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 15875 "configure"
+#line 15928 "configure"
#define _FILE_OFFSET_BITS 64
@@ -15889,7 +15942,7 @@
; return 0; }
EOF
-if { (eval echo configure:15893: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15946: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -15908,11 +15961,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:15912: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:15965: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 15916 "configure"
+#line 15969 "configure"
@@ -15928,14 +15981,14 @@
; return 0; }
EOF
-if { (eval echo configure:15932: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15985: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 15939 "configure"
+#line 15992 "configure"
#define _LARGE_FILES 1
@@ -15953,7 +16006,7 @@
; return 0; }
EOF
-if { (eval echo configure:15957: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16010: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -15972,25 +16025,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:15976: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:16029: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 15980 "configure"
+#line 16033 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:15987: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16040: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 15994 "configure"
+#line 16047 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -15999,7 +16052,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:16003: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16056: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -16020,10 +16073,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:16024: checking if system supports Large Files at all" >&5
+echo "configure:16077: checking if system supports Large Files at all" >&5
-#line 16027 "configure"
+#line 16080 "configure"
#include <stdio.h>
@@ -16055,7 +16108,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:16059: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:16112: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -16084,7 +16137,7 @@
# Python check
echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:16088: checking whether to use Python" >&5
+echo "configure:16141: checking whether to use Python" >&5
PYTHONINC=
PYTHONCFLAGS=
@@ -16104,7 +16157,7 @@
# Extract the first word of "python-config", so it can be a program name with args.
set dummy python-config; ac_word=$2
-echo "configure:16108: checking for $ac_word" >&5
+echo "configure:16161: checking for $ac_word" >&5
case "$PY_CONFIG" in
@@ -16146,15 +16199,15 @@
do
-echo "configure:16150: checking for $ac_hdr" >&5
+echo "configure:16203: checking for $ac_hdr" >&5
-#line 16153 "configure"
+#line 16206 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:16158: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16211: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -16224,7 +16277,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:16228: checking whether to use wxWidgets" >&5
+echo "configure:16281: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -16245,7 +16298,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
-echo "configure:16249: checking for $ac_word" >&5
+echo "configure:16302: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -16293,7 +16346,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:16297: checking wxWidgets version" >&5
+echo "configure:16350: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -16316,15 +16369,15 @@
do
-echo "configure:16320: checking for $ac_hdr" >&5
+echo "configure:16373: checking for $ac_hdr" >&5
-#line 16323 "configure"
+#line 16376 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:16328: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16381: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
