[GRASS-SVN] r57883 - grass/branches/develbranch_6/ps/ps.map
svn_grass at osgeo.org
Mon Sep 30 12:00:32 PDT 2013
Author: neteler
Date: 2013-09-30 12:00:32 -0700 (Mon, 30 Sep 2013)
New Revision: 57883
grass/branches/develbranch_6/ps/ps.map/vect.c
ps.map: avoid namespace pollution on AIX (backport from trunk); comments sync
Modified: grass/branches/develbranch_6/ps/ps.map/vect.c
--- grass/branches/develbranch_6/ps/ps.map/vect.c 2013-09-30 18:50:33 UTC (rev 57882)
+++ grass/branches/develbranch_6/ps/ps.map/vect.c 2013-09-30 19:00:32 UTC (rev 57883)
@@ -1,9 +1,9 @@
/* Functions: adjust_line
- ** Author: Radim Blazek Feb 2000
+ * Author: Radim Blazek Feb 2000
#include <stdlib.h>
#include <math.h>
#include <grass/Vect.h>
@@ -13,7 +13,7 @@
#define LENGTH(DX, DY) ( sqrt( (DX*DX)+(DY*DY) ) )
/* nearest returns nearest longitude coordinate, copy from src/libes */
-static double nearest(double e0, double e1)
+static double nearest_longitude(double e0, double e1)
while (e0 - e1 > 180)
e1 += 360.0;
@@ -23,7 +23,8 @@
/* if projection is PROJECTION_LL adjust_line will change
- ** longitudes to nearest form previous point */
+ * longitudes to nearest form previous point
void adjust_line(struct line_pnts *Points)
int i, np;
@@ -31,7 +32,7 @@
if (G_projection() == PROJECTION_LL) {
np = Points->n_points;
for (i = 1; i < np; i++) {
- Points->x[i] = nearest(Points->x[i - 1], Points->x[i]);
+ Points->x[i] = nearest_longitude(Points->x[i - 1], Points->x[i]);
