[GRASS-SVN] r59594 - in grass/trunk: include/defs lib/vector/Vlib
svn_grass at osgeo.org
Sun Apr 6 01:14:21 PDT 2014
Author: mmetz
Date: 2014-04-06 01:14:21 -0700 (Sun, 06 Apr 2014)
New Revision: 59594
grass/trunk/include/defs/vector.h
grass/trunk/lib/vector/Vlib/area.c
Vlib: fix area perimeter
Modified: grass/trunk/include/defs/vector.h
--- grass/trunk/include/defs/vector.h 2014-04-06 03:08:31 UTC (rev 59593)
+++ grass/trunk/include/defs/vector.h 2014-04-06 08:14:21 UTC (rev 59594)
@@ -277,11 +277,11 @@
int Vect_get_node_line(const struct Map_info *, int, int);
float Vect_get_node_line_angle(const struct Map_info *, int, int);
-double Vect_area_perimeter(const struct line_pnts *);
int Vect_get_area_points(const struct Map_info *, int, struct line_pnts *);
int Vect_get_area_centroid(const struct Map_info *, int);
int Vect_get_area_num_isles(const struct Map_info *, int);
int Vect_get_area_isle(const struct Map_info *, int, int);
+double Vect_get_area_perimeter(const struct Map_info *, int);
double Vect_get_area_area(const struct Map_info *, int);
int Vect_get_area_boundaries(const struct Map_info *, int, struct ilist *);
Modified: grass/trunk/lib/vector/Vlib/area.c
--- grass/trunk/lib/vector/Vlib/area.c 2014-04-06 03:08:31 UTC (rev 59593)
+++ grass/trunk/lib/vector/Vlib/area.c 2014-04-06 08:14:21 UTC (rev 59594)
@@ -279,20 +279,47 @@
return (Isle->area);
- \brief Calculate area perimeter
+ \brief Returns perimeter of area with perimeter of isles
- \param Points list of points defining area boundary
+ \param Map pointer to Map_info structure
+ \param area area id
- \return area perimeter
+ \return perimeter of area with perimeters of isles in meters
-double Vect_area_perimeter(const struct line_pnts *Points)
+double Vect_get_area_perimeter(const struct Map_info *Map, int area)
- return Vect_line_length(Points);
+ const struct Plus_head *Plus;
+ struct P_area *Area;
+ struct line_pnts *Points;
+ double d;
+ int i;
+ G_debug(3, "Vect_get_area_perimeter(): area = %d", area);
+ Points = Vect_new_line_struct();
+ Plus = &(Map->plus);
+ Area = Plus->Area[area];
+ Vect_get_area_points(Map, area, Points);
+ Vect_line_prune(Points);
+ d = Vect_line_geodesic_length(Points);
+ /* adding island perimeters */
+ for (i = 0; i < Area->n_isles; i++) {
+ Vect_get_isle_points(Map, Area->isles[i], Points);
+ d += Vect_line_geodesic_length(Points);
+ Vect_destroy_line_struct(Points);
+ G_debug(3, " perimeter = %f", d);
+ return (d);
\brief Check if point is in area
@@ -363,11 +390,13 @@
size = G_area_of_polygon(Points->x, Points->y, Points->n_points);
- /* substructing island areas */
+ /* substracting island areas */
size -= G_area_of_polygon(Points->x, Points->y, Points->n_points);
