[GRASS-SVN] r59595 - grass/trunk/vector/v.to.db
svn_grass at osgeo.org
Sun Apr 6 01:14:59 PDT 2014
Author: mmetz
Date: 2014-04-06 01:14:59 -0700 (Sun, 06 Apr 2014)
New Revision: 59595
grass/trunk/vector/v.to.db/areas.c
v.to.db: fix area perimeter
Modified: grass/trunk/vector/v.to.db/areas.c
--- grass/trunk/vector/v.to.db/areas.c 2014-04-06 08:14:21 UTC (rev 59594)
+++ grass/trunk/vector/v.to.db/areas.c 2014-04-06 08:14:59 UTC (rev 59595)
@@ -39,8 +39,7 @@
if ((options.option == O_COMPACT) || (options.option == O_FD) ||
(options.option == O_PERIMETER)) {
- Vect_get_area_points(Map, area_num, Ppoints);
- perimeter = Vect_line_geodesic_length(Ppoints);
+ perimeter = Vect_get_area_perimeter(Map, area_num);
found = 0;
