[GRASS-SVN] r59716 - grass/branches/releasebranch_6_4/locale/po
svn_grass at osgeo.org
Sun Apr 13 12:13:43 PDT 2014
Author: neteler
Date: 2014-04-13 12:13:43 -0700 (Sun, 13 Apr 2014)
New Revision: 59716
grass/branches/releasebranch_6_4/locale/po/grasslibs_el.po
grass/branches/releasebranch_6_4/locale/po/grassmods_el.po
grass/branches/releasebranch_6_4/locale/po/grasstcl_el.po
Greek .po files converted to UTF8 for transifex
Modified: grass/branches/releasebranch_6_4/locale/po/grasslibs_el.po
--- grass/branches/releasebranch_6_4/locale/po/grasslibs_el.po 2014-04-13 19:01:14 UTC (rev 59715)
+++ grass/branches/releasebranch_6_4/locale/po/grasslibs_el.po 2014-04-13 19:13:43 UTC (rev 59716)
@@ -14,66 +14,66 @@
"Language-Team: Greek <grass-translations at lists.osgeo.org>\n"
"Language: el\n"
"MIME-Version: 1.0\n"
-"Content-Type: text/plain; charset=ISO-8859-7\n"
+"Content-Type: text/plain; charset=UTF-8\n"
"Content-Transfer-Encoding: 8bit\n"
"X-Generator: KBabel 1.11.4\n"
#: ../lib/raster/rem_io.c:40
#, c-format
msgid "ERROR %s from graphics driver.\n"
-msgstr "ÓÖÁËÌÁ %s áðü ôïí ïäçãüò êÜñôáò ãñáöéêþí.\n"
+msgstr "ΣΦÎÎÎÎ %s αÏÏ Ïον οδηγÏÏ ÎºÎ¬ÏÏÎ±Ï Î³ÏαÏικÏν.\n"
#: ../lib/raster/rem_io.c:167
#, c-format
msgid "Unable to allocate memory\n"
-msgstr "Áäõíáìßá êáôáíïìÞò (allocate) ìíÞìçò\n"
+msgstr "ÎδÏ
ναμία καÏÎ±Î½Î¿Î¼Î®Ï (allocate) μνήμηÏ\n"
#: ../lib/raster/rem_io.c:217
#, c-format
msgid "ERROR - eof from graphics monitor.\n"
-msgstr "ÓÖÁËÌÁ - eof áðü ôçí ïèüíç ãñáöéêþí.\n"
+msgstr "ΣΦÎÎÎÎ - eof αÏÏ Ïην οθÏνη γÏαÏικÏν.\n"
#: ../lib/raster/rem_io.c:237
#, c-format
msgid "Warning - no response from graphics monitor <%s>.\n"
-msgstr "Ðñïóï÷Þ - êáìßá áðüêñéóç áðü ôçí ïèüíç ãñáöéêþí <%s>.\n"
+msgstr "Î ÏοÏοÏή - καμία αÏÏκÏιÏη αÏÏ Ïην οθÏνη γÏαÏικÏν <%s>.\n"
#: ../lib/raster/rem_io.c:239
#, c-format
msgid "Check to see if the mouse is still active.\n"
-msgstr "ÄïêéìÜóôå áí ôïí ðïíôßêé (mouse) áðïêñßíåôáé.\n"
+msgstr "ÎοκιμάÏÏε αν Ïον ÏονÏίκι (mouse) αÏοκÏίνεÏαι.\n"
#: ../lib/raster/rem_io.c:244
#, c-format
msgid "ERROR - no response from graphics monitor <%s>.\n"
-msgstr "ÓÖÁËÌÁ - êáìßá áðüêñéóç áðï ôçí ïèüíç ãñáöéêþí <%s>.\n"
+msgstr "ΣΦÎÎÎÎ - καμία αÏÏκÏιÏη αÏο Ïην οθÏνη γÏαÏικÏν <%s>.\n"
#: ../lib/raster/io_sock.c:63
msgid "No graphics monitor has been selected for output."
-msgstr "Äåí Ý÷åé åðéëïãÞ êáìßá ïèüíç ãñáöéêþí ùò Ýîïäïò."
+msgstr "Îεν ÎÏει εÏιλογή καμία οθÏνη γÏαÏικÏν ÏÏ ÎξοδοÏ."
#: ../lib/raster/io_sock.c:64
msgid "Please run \"d.mon\" to select a graphics monitor."
msgstr ""
-"Ðáñáêáëþ åêôåëÝóôå ôçí åíôïëÞ \"d.mon\" ãéá íá åðéëÝîåôå ïèüíç ãñáöéêþí."
+"ΠαÏÎ±ÎºÎ±Î»Ï ÎµÎºÏελÎÏÏε Ïην ενÏολή \"d.mon\" για να εÏιλÎξεÏε οθÏνη γÏαÏικÏν."
#: ../lib/raster/io_sock.c:72
#, c-format
msgid "Failed to get socket name for monitor <%s>."
-msgstr "Áäõíáìßá ëÞøçò ïíüìáôïò áðü ôçí ïèüíç <%s>."
+msgstr "ÎδÏ
ναμία λήÏÎ·Ï Î¿Î½ÏμαÏÎ¿Ï Î±ÏÏ Ïην οθÏνη <%s>."
#: ../lib/raster/io_sock.c:81
#, c-format
msgid "No socket to connect to for monitor <%s>."
-msgstr "Äåí õðÜñ÷åé óýíäåóç ôïõ socket ãéá óýíäåóç óôçí ïèüíç <%s>."
+msgstr "Îεν Ï
ÏάÏÏει ÏÏνδεÏη ÏοÏ
socket για ÏÏνδεÏη ÏÏην οθÏνη <%s>."
#: ../lib/raster/io_sock.c:98
msgid "Socket is already in use or not accepting connections."
-msgstr "Ôï socket ÷ñçóéìïðïéÞôáé Þäç êáé äåí äÝ÷åôáé Üëëåò óõíäÝóåéò."
+msgstr "Το socket ÏÏηÏιμοÏοιήÏαι ήδη και δεν δÎÏεÏαι Î¬Î»Î»ÎµÏ ÏÏ
νδÎÏειÏ."
#: ../lib/raster/io_sock.c:99
msgid "Use d.mon to select a monitor"
-msgstr "×ñçóéìïðïéÞóôå ôçí åíôïëÞ d.mon ãéá íá åðéëÝîåôå ïèüíç"
+msgstr "ΧÏηÏιμοÏοιήÏÏε Ïην ενÏολή d.mon για να εÏιλÎξεÏε οθÏνη"
#: ../lib/raster/io_sock.c:105
msgid "Trying to connect to something not a socket."
@@ -81,81 +81,81 @@
#: ../lib/raster/io_sock.c:106
msgid "Probably program error."
-msgstr "Ðéèáíü ëÜèïò ôïõ ðñïãñÜììáôïò."
+msgstr "Î Î¹Î¸Î±Î½Ï Î»Î¬Î¸Î¿Ï ÏοÏ
ÏÏογÏάμμαÏοÏ."
#: ../lib/raster/io_sock.c:111
msgid "Connect attempt timed out."
-msgstr "Ç ðñïóðÜèåéá óýíäåóçò áðÝôõ÷å (timed out)."
+msgstr "Î ÏÏοÏÏάθεια ÏÏνδεÏÎ·Ï Î±ÏÎÏÏ
Ïε (timed out)."
#: ../lib/raster/io_sock.c:112
msgid "Probably an error with the server."
-msgstr "Ðéèáíü ðñüâëçìá ìå ôïí äéáêïìéóôÞ (server)."
+msgstr "Î Î¹Î¸Î±Î½Ï ÏÏÏβλημα με Ïον διακομιÏÏή (server)."
#: ../lib/raster/io_sock.c:120
msgid "Connection failed."
-msgstr "ÓöÜëìá óýíäåóçò."
+msgstr "ΣÏάλμα ÏÏνδεÏηÏ."
#: ../lib/ogsf/GVL2.c:248
#, c-format
msgid "Loading 3d raster map <%s>..."
-msgstr "Öüñôùóç ôïõ raster ÷Üñôç <%s> ..."
+msgstr "ΦÏÏÏÏÏη ÏοÏ
raster ÏάÏÏη <%s> ..."
#: ../lib/ogsf/gk.c:322
msgid "Need at least 3 keyframes for spline"
-msgstr "×ñåéÜæïíôáé ôïõëÜ÷éóôï 3 keyframes for spline"
+msgstr "ΧÏειάζονÏαι ÏοÏ
λάÏιÏÏο 3 keyframes for spline"
#: ../lib/ogsf/gk.c:624
msgid "Need at least 2 keyframes for interpolation"
-msgstr "×ñåéÜæïíôáé ôïõëÜ÷éóôïí 2 keyframes for interpolation"
λάÏιÏÏον 2 keyframes for interpolation"
#: ../lib/ogsf/Gv3.c:57 ../lib/ogsf/Gp3.c:109 ../lib/vector/Vlib/map.c:327
#: ../lib/vector/Vlib/legal_vname.c:118 ../lib/vector/Vlib/legal_vname.c:121
#: ../lib/vector/Vlib/open.c:168
#, c-format
msgid "Vector map <%s> not found"
-msgstr "Ï äéáíõóìáôéêüò ÷Üñôçò <%s> äåí âñÝèçêå"
+msgstr "ΠδιανÏ
ÏμαÏικÏÏ ÏάÏÏÎ·Ï <%s> δεν βÏÎθηκε"
#: ../lib/ogsf/Gv3.c:63 ../lib/ogsf/Gp3.c:115 ../lib/vector/Vlib/open.c:199
#, c-format
msgid "Unable to open vector map <%s>"
-msgstr "Áäõíáìßá áíïßãìáôïò äéáíõóìáôéêïý ÷Üñôç <%s>"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï Î´Î¹Î±Î½Ï
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη <%s>"
#: ../lib/ogsf/Gv3.c:249
#, c-format
msgid "No features from vector map <%s> fall within current region"
msgstr ""
-"Äåí õðÜñ÷ïõí äåäïìÝíá ãéá ôïí äéáíõóìáôéêü ÷Üñôç <%s> ðïõ íá âñßóêïíôáé óôçí "
-"ôñÝ÷ïõóá ðåñéï÷Þ"
+"Îεν Ï
ÏάÏÏοÏ
ν δεδομÎνα για Ïον διανÏ
ÏμαÏÎ¹ÎºÏ ÏάÏÏη <%s> ÏοÏ
να βÏίÏκονÏαι ÏÏην "
+"ÏÏÎÏοÏ
Ïα ÏεÏιοÏή"
#: ../lib/ogsf/Gv3.c:254
#, c-format
msgid "Vector map <%s> loaded (%d features)"
-msgstr "Ï äéáíõóìáôéêüò ÷Üñôçò <%s> öüñôùóå (%d features)"
+msgstr "ΠδιανÏ
ÏμαÏικÏÏ ÏάÏÏÎ·Ï <%s> ÏÏÏÏÏÏε (%d features)"
#: ../lib/ogsf/gvl_file.c:104
msgid "Maximum number of datafiles exceeded"
-msgstr "ÌÝãéóôïò áñéèìüò áñ÷åßùí"
+msgstr "ÎÎγιÏÏÎ¿Ï Î±ÏιθμÏÏ Î±ÏÏείÏν"
#: ../lib/ogsf/gvl_file.c:428 ../lib/ogsf/Gvl3.c:39
#: ../lib/gpde/N_arrays_io.c:296
#, c-format
msgid "3D raster map <%s> not found"
-msgstr "Ï 3Ä ÷Üñôçò raster <%s> äåí âñÝèçêå"
+msgstr "Î 3Î ÏάÏÏÎ·Ï raster <%s> δεν βÏÎθηκε"
#: ../lib/ogsf/gvl_file.c:437 ../lib/gpde/N_arrays_io.c:304
#, c-format
msgid "Unable to open 3D raster map <%s>"
-msgstr "Áäõíáìßá áíïßãìáôïò ôïõ 3Ä ÷Üñôç ñáóôåñ <%s>"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï ÏοÏ
3Î ÏάÏÏη ÏαÏÏÎµÏ <%s>"
#: ../lib/ogsf/gvl_file.c:443
#, c-format
msgid "Unable to read range of 3D raster map <%s>"
-msgstr "Áäõíáìßá áíÜãíùóçò 3Ä ñáóôåñ ÷Üñôç <%s>"
+msgstr "ÎδÏ
ναμία ανάγνÏÏÎ·Ï 3Î ÏαÏÏÎµÏ ÏάÏÏη <%s>"
#: ../lib/ogsf/gvl_file.c:471
#, c-format
msgid "Unable to close 3D raster map <%s>"
-msgstr "Áäõíáìßá êëåéóßìáôïò ôïõ 3Ä ñáóôåñ ÷Üñôç <%s>"
+msgstr "ÎδÏ
ναμία κλειÏίμαÏÎ¿Ï ÏοÏ
#: ../lib/ogsf/Gp3.c:54 ../lib/ogsf/Gs3.c:126 ../lib/ogsf/Gs3.c:201
#: ../lib/ogsf/Gs3.c:286 ../lib/ogsf/Gs3.c:359 ../lib/ogsf/Gs3.c:475
@@ -165,24 +165,24 @@
#: ../lib/gis/legal_name.c:97 ../lib/gis/opencell.c:1011
#, c-format
msgid "Raster map <%s> not found"
-msgstr "Ï ÷Üñôçò raster <%s> äåí âñÝèçêå"
+msgstr "Î ÏάÏÏÎ·Ï raster <%s> δεν βÏÎθηκε"
#: ../lib/ogsf/Gp3.c:145 ../lib/vector/Vlib/map.c:68
#: ../lib/vector/Vlib/map.c:84
#, c-format
msgid "Unable to read vector map <%s>"
-msgstr "Áäõíáìßá áíÜãíùóçò äéáíõóìáôéêïý ÷Üñôç <%s>"
+msgstr "ÎδÏ
ναμία ανάγνÏÏÎ·Ï Î´Î¹Î±Î½Ï
#: ../lib/ogsf/Gp3.c:206
#, c-format
msgid "No points from vector map <%s> fall within current region"
msgstr ""
-"Äåí õðÜñ÷ïõí óçìåßá óôïí äéáíõóìáôéêü ÷Üñôç <%s> ðïõ íá ðÝöôïõí óôçí ðåñéï÷Þ"
+"Îεν Ï
ÏάÏÏοÏ
ν Ïημεία ÏÏον διανÏ
να ÏÎÏÏοÏ
ν ÏÏην ÏεÏιοÏή"
#: ../lib/ogsf/Gp3.c:211
#, c-format
msgid "Vector map <%s> loaded (%d points)"
-msgstr "Ï äéáíõóìáôéêüò ÷Üñôçò <%s> öüñôùóå (%d óçìåßá)"
+msgstr "ΠδιανÏ
ÏμαÏικÏÏ ÏάÏÏÎ·Ï <%s> ÏÏÏÏÏÏε (%d Ïημεία)"
#: ../lib/ogsf/trans.c:180
msgid "Out of matrix stack space"
@@ -196,62 +196,62 @@
#: ../lib/ogsf/gsd_img_ppm.c:96 ../lib/ogsf/gsd_img_tif.c:64
#, c-format
msgid "Unable to open file <%s> for writing"
-msgstr "Áäõíáìßá áíïßãìáôïò áñ÷åßïõ <%s> ãéá åããñáöÞ"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï Î±ÏÏείοÏ
<%s> για εγγÏαÏή"
#: ../lib/ogsf/GK2.c:275 ../lib/ogsf/GK2.c:288
msgid "Check no. of frames requested and keyframes marked"
-msgstr "ÔóåêÜñåôå ôïí áñéèìü ôùí frames êáé keyframes"
+msgstr "ΤÏεκάÏεÏε Ïον αÏÎ¹Î¸Î¼Ï ÏÏν frames και keyframes"
#: ../lib/ogsf/gsds.c:109
msgid "Maximum number of datasets exceeded"
-msgstr "Ôï ìÝãéóôùí ôùí datasets îåðåñÜóôçêå"
+msgstr "Το μÎγιÏÏÏν ÏÏν datasets ξεÏεÏάÏÏηκε"
#: ../lib/ogsf/gsdrape.c:207
msgid "Unable to process vector map - out of memory"
-msgstr "Áäõíáìßá áíÜãíùóçò äéáíõóìáôéêïý ÷Üñôç - åîôüò ìíÞìçò"
+msgstr "ÎδÏ
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη - εξÏÏÏ Î¼Î½Î®Î¼Î·Ï"
#: ../lib/ogsf/gsd_label.c:58
msgid "Max. number of labels reached!"
-msgstr "ÌÝãéóôïò áñéèìüò ôáìðåëþí!"
+msgstr "ÎÎγιÏÏÎ¿Ï Î±ÏιθμÏÏ ÏαμÏελÏν!"
#: ../lib/ogsf/gsd_img_mpeg.c:73
msgid "Unable to allocate stream"
-msgstr "Áäõíáìßá êáôáíïìÞò (allocate) ìíÞìçò"
+msgstr "ÎδÏ
ναμία καÏÎ±Î½Î¿Î¼Î®Ï (allocate) μνήμηÏ"
#: ../lib/ogsf/gsd_img_mpeg.c:176
msgid "Video codec not found"
-msgstr "Ï êùäéêïðïéçôÞò âßíôåï äåí âñÝèçêå"
+msgstr "ΠκÏδικοÏοιηÏÎ®Ï Î²Î¯Î½Ïεο δεν βÏÎθηκε"
#: ../lib/ogsf/gsd_img_mpeg.c:186
msgid "Unable to open codec"
-msgstr "Ï êùäéêïðïéçôÞò âßíôåï äåí áíïßãåé"
+msgstr "ΠκÏδικοÏοιηÏÎ®Ï Î²Î¯Î½Ïεο δεν ανοίγει"
#: ../lib/ogsf/gsd_img_mpeg.c:205
msgid "Unable to allocate picture"
-msgstr "Áäõíáìßá êáôáíïìÞò (allocate) åéêüíáò"
+msgstr "ÎδÏ
ναμία καÏÎ±Î½Î¿Î¼Î®Ï (allocate) εικÏναÏ"
#: ../lib/ogsf/gsd_img_mpeg.c:216
msgid "Unable to allocate temporary picture"
-msgstr "Áäõíáìßá êáôáíïìÞò (allocate) ðñïóùñéíÞ åéêüíá"
+msgstr "ÎδÏ
ναμία καÏÎ±Î½Î¿Î¼Î®Ï (allocate) ÏÏοÏÏÏινή εικÏνα"
#: ../lib/ogsf/gsd_img_mpeg.c:283
msgid "Error while writing video frame"
-msgstr "ÓöÜëìá êáôÜ ôçí åããñáöÞ ôïõ êáñÝ ôïõ âßíôåï"
+msgstr "ΣÏάλμα καÏά Ïην εγγÏαÏή ÏοÏ
καÏÎ ÏοÏ
βίνÏεο"
#: ../lib/ogsf/gsd_img_mpeg.c:329
#, c-format
msgid "Opening MPEG stream <%s>..."
-msgstr "Áíïßãù MPEG stream <%s>..."
+msgstr "ÎÎ½Î¿Î¯Î³Ï MPEG stream <%s>..."
#: ../lib/ogsf/gsd_img_mpeg.c:341
msgid "Unable to deduce output format from file extension: using MPEG"
msgstr ""
-"Äåí ìðïñþ íá êáôáëÜíù ôïí ôýðï åîáãþìåíïõ áñ÷åßïõ áðü ôçí êáôÜëçîç: "
-"÷ñçóéìïðïéþ MPEG"
+"Îεν μÏοÏÏ Î½Î± καÏÎ±Î»Î¬Î½Ï Ïον ÏÏÏο εξαγÏμενοÏ
αÏÏείοÏ
αÏÏ Ïην καÏάληξη: "
+"ÏÏηÏιμοÏÎ¿Î¹Ï MPEG"
#: ../lib/ogsf/gsd_img_mpeg.c:349
msgid "Unable to find suitable output format"
-msgstr "Áäõíáìßá åýñåóçò ôïõ ðßíáêá êáôÜëëçëïõ öïñìÜô åîáãùãÞò"
+msgstr "ÎδÏ
ναμία εÏÏεÏÎ·Ï ÏοÏ
Ïίνακα καÏάλληλοÏ
ÏοÏÎ¼Î¬Ï ÎµÎ¾Î±Î³ÏγήÏ"
#: ../lib/ogsf/gsd_img_mpeg.c:356 ../lib/rst/interp_float/interp2d.c:119
#: ../lib/rst/interp_float/interp2d.c:125
@@ -274,17 +274,17 @@
#: ../lib/ogsf/gsd_img_mpeg.c:380
msgid "Invalid output format parameters"
-msgstr "ËÜèïò ðáñÜìåôñïé öïñìÜô åîáãùãÞò"
+msgstr "ÎÎ¬Î¸Î¿Ï ÏαÏάμεÏÏοι ÏοÏÎ¼Î¬Ï ÎµÎ¾Î±Î³ÏγήÏ"
#: ../lib/ogsf/gsd_img_mpeg.c:402
#, c-format
msgid "Unable to open <%s>"
-msgstr "Áäõíáìßá áíïßãìáôïò <%s>"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï <%s>"
#: ../lib/ogsf/gsd_img_mpeg.c:415
#, fuzzy
msgid "OGSF library has not been built with MPEG output support"
-msgstr "NVIZ äåí Ý÷åé öôéá÷ôåß ìå MPEG õðïóôÞñéîç"
+msgstr "NVIZ δεν ÎÏει ÏÏιαÏÏεί με MPEG Ï
ÏοÏÏήÏιξη"
#: ../lib/ogsf/gsd_prim.c:146
#, c-format
@@ -297,8 +297,8 @@
"gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please "
"advise GRASS developers of this error"
msgstr ""
-"gsd_rot(): %c åßíáé Ýíáò åóöáëìÝíïò Üîïíáò. Ç óôñÝøç áãíïåßôáé. Ðáñáêáëþ "
-"åíçìåñþóôå ôïõò ðñïãñáììáôéóôÝò ôïõ GRASS ãéá ôï ëÜèïò áõôü"
+"gsd_rot(): %c είναι ÎÎ½Î±Ï ÎµÏÏαλμÎÎ½Î¿Ï Î¬Î¾Î¿Î½Î±Ï. Î ÏÏÏÎÏη αγνοείÏαι. ΠαÏÎ±ÎºÎ±Î»Ï "
+"ενημεÏÏÏÏε ÏοÏ
Ï ÏÏογÏαμμαÏιÏÏÎÏ ÏοÏ
GRASS για Ïο Î»Î¬Î¸Î¿Ï Î±Ï
ÏÏ"
#: ../lib/ogsf/GS2.c:1207
#, c-format
@@ -314,59 +314,59 @@
#, c-format
msgid "Raster map <%s> is outside of current region. Load failed."
msgstr ""
-"Ï ñÜóôåñ ÷Üñôçò <%s> åßíáé Ýîù áðü ôçí ôñÝ÷ïõóá ðåñéï÷Þ. Ç öüñôùóç áðÝôõ÷å."
+"Î ÏάÏÏÎµÏ ÏάÏÏÎ·Ï <%s> είναι ÎÎ¾Ï Î±ÏÏ Ïην ÏÏÎÏοÏ
Ïα ÏεÏιοÏή. Î ÏÏÏÏÏÏη αÏÎÏÏ
Ïε."
#: ../lib/ogsf/GS2.c:1729 ../lib/ogsf/GS2.c:1735 ../lib/ogsf/GS2.c:1743
#: ../lib/ogsf/GS2.c:1752 ../lib/ogsf/GS2.c:1760 ../lib/ogsf/GS2.c:1770
#: ../lib/ogsf/GS2.c:1818
msgid "GS_load_att_map(): Out of memory. Unable to load map"
-msgstr "GS_load_att_map(): Åêôüò ìíÞìçò. Áäõíáìßá öüñôùóçò ÷Üñôç"
+msgstr "GS_load_att_map(): ÎκÏÏÏ Î¼Î½Î®Î¼Î·Ï. ÎδÏ
ναμία ÏÏÏÏÏÏÎ·Ï ÏάÏÏη"
#: ../lib/ogsf/GS2.c:1846
msgid "Loading failed"
-msgstr "Ç öüñôùóç áðÝôõ÷å"
+msgstr "Î ÏÏÏÏÏÏη αÏÎÏÏ
Ïε"
#: ../lib/ogsf/GS2.c:1850
msgid "Error finding range"
-msgstr "ËÜèïò óôçí åýñåóç åýñïõò"
+msgstr "ÎÎ¬Î¸Î¿Ï ÏÏην εÏÏεÏη εÏÏοÏ
Ï"
#: ../lib/ogsf/Gs3.c:133 ../lib/ogsf/Gs3.c:208 ../lib/ogsf/Gs3.c:366
#: ../lib/ogsf/Gs3.c:482 ../lib/ogsf/Gs3.c:587
msgid "Unable to allocate memory for a null buffer"
-msgstr "Áäõíáìßá êáôáíïìÞò (allocate) ìíÞìçò ãéá êåíü buffer"
+msgstr "ÎδÏ
ναμία καÏÎ±Î½Î¿Î¼Î®Ï (allocate) Î¼Î½Î®Î¼Î·Ï Î³Î¹Î± ÎºÎµÎ½Ï buffer"
#: ../lib/ogsf/Gs3.c:137 ../lib/ogsf/Gs3.c:212 ../lib/ogsf/Gs3.c:370
#: ../lib/ogsf/Gs3.c:486 ../lib/ogsf/Gs3.c:577 ../lib/gpde/N_arrays_io.c:68
#, c-format
msgid "Unable to open raster map <%s>"
-msgstr "Áäõíáìßá áíïßãìáôïò ôïõ ÷Üñôç raster <%s>"
+msgstr "ÎδÏ
ÏάÏÏη raster <%s>"
#: ../lib/ogsf/Gs3.c:140 ../lib/ogsf/Gs3.c:215 ../lib/ogsf/Gs3.c:378
#: ../lib/ogsf/Gs3.c:494 ../lib/ogsf/Gs3.c:590
#, c-format
msgid "Loading raster map <%s>..."
-msgstr "Öüñôùóç ôïõ raster ÷Üñôç <%s>..."
raster ÏάÏÏη <%s>..."
#: ../lib/ogsf/Gs3.c:647
#, c-format
msgid "Color table range doesn't match data (mincol=%d, maxcol=%d"
msgstr ""
-"Ôï åýñïò ôïõ ÷ñùìáôéêïý ðßíáêá äåí ôáéñéÜæåé ìå ôá äåäïìÝíá (mincol=%d, "
+"Το εÏÏÎ¿Ï ÏοÏ
ÏÏÏμαÏÎ¹ÎºÎ¿Ï Ïίνακα δεν ÏαιÏιάζει με Ïα δεδομÎνα (mincol=%d, "
"maxcol=%d"
#: ../lib/ogsf/Gs3.c:709 ../lib/ogsf/Gs3.c:781
#, c-format
msgid "Translating colors from raster map <%s>..."
-msgstr "ÌåôáöñÜæïíôáéò ÷ñþìáôá ãéá ôïí ñÜóôåñ ÷Üñôç <%s>..."
+msgstr "ÎεÏαÏÏάζονÏÎ±Î¹Ï ÏÏÏμαÏα για Ïον ÏάÏÏÎµÏ ÏάÏÏη <%s>..."
#: ../lib/ogsf/Gs3.c:1020
msgid "View not saved by this program,there may be some inconsistancies"
msgstr ""
-"Ç üøç äåí Ý÷åé óùèåß áðü ôï ðñüãñáììá, ìÜëëïí õðÜñ÷ïõí êÜðïéåò áóõíÝ÷åéåò"
+"Î ÏÏη δεν ÎÏει ÏÏθεί αÏÏ Ïο ÏÏÏγÏαμμα, μάλλον Ï
ÏάÏÏοÏ
ν κάÏÎ¿Î¹ÎµÏ Î±ÏÏ
νÎÏειεÏ"
#: ../lib/ogsf/gs_bm.c:124
msgid "Bitmap mismatch"
-msgstr "Ôï bitmap äåí ôáéñéÜæåé"
+msgstr "Το bitmap δεν ÏαιÏιάζει"
#: ../lib/ogsf/gsd_surf.c:1742
msgid "Cut-plane points mis-match between surfaces. Check resolution(s)."
@@ -375,91 +375,91 @@
#: ../lib/ogsf/gsd_legend.c:245
#, c-format
msgid "Unable to read color file of raster map <%s>"
-msgstr "Áäõíáìßá áíÜãíùóçò áñ÷åßïõ ÷ñþìáôïò ãéá ôïí ñÜóôåñ ÷Üñôç <%s>"
+msgstr "ÎδÏ
ναμία ανάγνÏÏÎ·Ï Î±ÏÏείοÏ
ÏÏÏμαÏÎ¿Ï Î³Î¹Î± Ïον ÏάÏÏÎµÏ ÏάÏÏη <%s>"
#: ../lib/ogsf/gsd_legend.c:251
#, c-format
msgid "Unable to read category file of raster map <%s>"
-msgstr "Áäõíáìßá äçìéïõñãßáò áñ÷åßïõ êáôçãïñßáò ãéá ôïí ñáóôåñ ÷Üñôç <%s>"
+msgstr "ÎδÏ
ναμία δημιοÏ
ÏÎ³Î¯Î±Ï Î±ÏÏείοÏ
καÏηγοÏÎ¯Î±Ï Î³Î¹Î± Ïον ÏαÏÏÎµÏ ÏάÏÏη <%s>"
#: ../lib/ogsf/gsd_legend.c:268
#, c-format
msgid "Unable to read fp range of raster map <%s>"
-msgstr "Áäõíáìßá äéáâÜóìáôïò åýñïõò fp ãéá ôïí ñáóôåñ ÷Üñôç <%s>"
+msgstr "ÎδÏ
ναμία διαβάÏμαÏÎ¿Ï ÎµÏÏοÏ
Ï fp για Ïον ÏαÏÏÎµÏ ÏάÏÏη <%s>"
#: ../lib/ogsf/gsd_legend.c:280
#, c-format
msgid "Unable to read range of raster map <%s>"
-msgstr "Áäõíáìßá äéáâÜóìáôïò åýñïõò ãéá ôïí ñÜóôåñ ÷Üñôç <%s>"
+msgstr "ÎδÏ
#: ../lib/ogsf/gsd_legend.c:294
msgid "Range request error for legend"
-msgstr "ÓöÜëìá åýñïõò ãéá ôï õðüìíçìá"
+msgstr "ΣÏάλμα εÏÏοÏ
Ï Î³Î¹Î± Ïο Ï
ÏÏμνημα"
#: ../lib/ogsf/gsd_legend.c:384
#, fuzzy
msgid "Unable to show discrete FP range (use list)"
-msgstr "Áäõíáìßá åìöÜíéóçò discrete FP range (use list"
+msgstr "ÎδÏ
ναμία εμÏάνιÏÎ·Ï discrete FP range (use list"
#: ../lib/ogsf/gsd_legend.c:500
msgid "Too many categories to show as discrete!"
-msgstr "ÐÜñá ðïëëÝò êáôçãïñßåò íá äåßîù ùò ìïíáäéêÝò!"
+msgstr "ΠάÏα ÏολλÎÏ ÎºÎ±ÏηγοÏÎ¯ÎµÏ Î½Î± Î´ÎµÎ¯Î¾Ï ÏÏ Î¼Î¿Î½Î±Î´Î¹ÎºÎÏ!"
#: ../lib/ogsf/gsd_legend.c:502
msgid "Try using smaller font!"
-msgstr "×ñçóéìïðïéÞóôå ìéêñüôåñç ãñáììáôïóåéñÜ!"
+msgstr "ΧÏηÏιμοÏοιήÏÏε μικÏÏÏεÏη γÏαμμαÏοÏειÏά!"
#: ../lib/gpde/N_arrays_io.c:97
#, c-format
msgid "Reading raster map <%s> into memory"
-msgstr "Öüñôùóç ôïõ raster ÷Üñôç <%s> óôç ìíÞìç"
raster ÏάÏÏη <%s> ÏÏη μνήμη"
#: ../lib/gpde/N_arrays_io.c:104
msgid "Could not get raster row"
-msgstr "Áäõíáìßá áíÜãíùóçò ôçò ãñáììÞò (row) ôïõ ÷Üñôç"
+msgstr "ÎδÏ
ναμία ανάγνÏÏÎ·Ï ÏÎ·Ï Î³ÏÎ±Î¼Î¼Î®Ï (row) ÏοÏ
ÏάÏÏη"
#: ../lib/gpde/N_arrays_io.c:162 ../lib/gpde/N_arrays_io.c:244
msgid "Unable to close input map"
-msgstr "Áäõíáìßá êëåéóßìáôïò ôïõ ÷Üñôç input"
+msgstr "ÎδÏ
ÏάÏÏη input"
#: ../lib/gpde/N_arrays_io.c:191
msgid "N_array_2d * array is empty"
-msgstr "N_array_2d * ðßíáêáò êåíüò"
+msgstr "N_array_2d * ÏÎ¯Î½Î±ÎºÎ±Ï ÎºÎµÎ½ÏÏ"
#: ../lib/gpde/N_arrays_io.c:203
#, c-format
msgid "Unable to create raster map <%s>"
-msgstr "Áäõíáìßá äçìéïõñãßáò raster ÷Üñôç <%s>"
+msgstr "ÎδÏ
ναμία δημιοÏ
ÏÎ³Î¯Î±Ï raster ÏάÏÏη <%s>"
#: ../lib/gpde/N_arrays_io.c:212
#, c-format
msgid "Write 2d array to raster map <%s>"
-msgstr "ÅããñáöÞ ðßíáêá 2 äéáóôÜóåùí óôïí raster ÷Üñôç <%s>"
+msgstr "ÎγγÏαÏή Ïίνακα 2 διαÏÏάÏεÏν ÏÏον raster ÏάÏÏη <%s>"
#: ../lib/gpde/N_arrays_io.c:228 ../lib/gpde/N_arrays_io.c:233
#: ../lib/gpde/N_arrays_io.c:238
#, c-format
msgid "Unable to write raster row %i"
-msgstr "Áäõíáìßá åããñáöÞò ãñáììÞ raster %i"
+msgstr "ÎδÏ
ναμία εγγÏαÏÎ®Ï Î³Ïαμμή raster %i"
#: ../lib/gpde/N_arrays_io.c:332
#, c-format
msgid "Read g3d map <%s> into the memory"
-msgstr "Öüñôùóç ôïõ g3d ÷Üñôç <%s> óôç ìíÞìç"
g3d ÏάÏÏη <%s> ÏÏη μνήμη"
#: ../lib/gpde/N_arrays_io.c:387 ../lib/gpde/N_arrays_io.c:487
msgid "Error closing g3d file"
-msgstr "ÓöÜëìá êáôÜ ôï êëåßóéìï ôïõ g3d áñ÷åßïõ"
+msgstr "ΣÏάλμα καÏά Ïο κλείÏιμο ÏοÏ
g3d αÏÏείοÏ
#: ../lib/gpde/N_arrays_io.c:446
#, c-format
msgid "Error opening g3d map <%s>"
-msgstr "ÓöÜëìá êáôÜ ôï Üíïéãìá ôïõ g3d ÷Üñôç <%s>"
+msgstr "ΣÏάλμα καÏά Ïο άνοιγμα ÏοÏ
g3d ÏάÏÏη <%s>"
#: ../lib/gpde/N_arrays_io.c:448
#, c-format
msgid "Write 3d array to g3d map <%s>"
-msgstr "ÅããñáöÞ ðßíáêá 3 äéáóôÜóåùí óôïí g3d ÷Üñôç <%s>"
+msgstr "ÎγγÏαÏή Ïίνακα 3 διαÏÏάÏεÏν ÏÏον g3d ÏάÏÏη <%s>"
#: ../lib/gpde/N_solvers_classic_iter.c:57
#: ../lib/gpde/N_solvers_classic_iter.c:94 ../lib/gpde/N_solvers.c:55
@@ -467,7 +467,7 @@
#: ../lib/gpde/N_solvers_krylov.c:78 ../lib/gpde/N_solvers_krylov.c:255
#: ../lib/gpde/N_solvers_krylov.c:423 ../lib/gpde/N_solvers_krylov.c:832
msgid "The linear equation system is not quadratic"
-msgstr "Ç ãñáììéêÞ óõíÜñôçóç äåí åßíáé 2ïõ âáèìïý"
+msgstr "ΠγÏαμμική ÏÏ
νάÏÏηÏη δεν είναι 2οÏ
βαθμοÏ"
#: ../lib/gpde/N_solvers_classic_iter.c:152
#, c-format
@@ -491,31 +491,31 @@
#: ../lib/gpde/test/test_main.c:49
msgid "Choose the unit tests to run"
-msgstr "ÅðéëÝîôå ôéò ìïíÜäåò ðïõ èÝëåôå íá åêôåëÝóåôå"
+msgstr "ÎÏιλÎξÏε ÏÎ¹Ï Î¼Î¿Î½Î¬Î´ÎµÏ ÏοÏ
θÎλεÏε να εκÏελÎÏεÏε"
#: ../lib/gpde/test/test_main.c:56
msgid "Choose the integration tests to run"
-msgstr "ÅðéëÝîôå ôéò ìïíÜäåò åíóùìÜôùóçò ðïõ èÝëåôå íá åêôåëÝóåôå"
+msgstr "ÎÏιλÎξÏε ÏÎ¹Ï Î¼Î¿Î½Î¬Î´ÎµÏ ÎµÎ½ÏÏμάÏÏÏÎ·Ï ÏοÏ
#: ../lib/gpde/test/test_main.c:61
msgid "Run all unit tests"
-msgstr "ÅêôÝëåóç üëùí ôùí äïêéìþí ìïíÜäáò"
+msgstr "ÎκÏÎλεÏη ÏλÏν ÏÏν δοκιμÏν μονάδαÏ"
#: ../lib/gpde/test/test_main.c:65
msgid "Run all integration tests"
-msgstr "ÅêôÝëåóç üëùí ôùí äïêéìþí åíóùìÜôùóçò"
+msgstr "ÎκÏÎλεÏη ÏλÏν ÏÏν δοκιμÏν ενÏÏμάÏÏÏηÏ"
#: ../lib/gpde/test/test_main.c:69
msgid "Run all unit and integration tests"
-msgstr "ÅêôÝëåóç üëùí ôùí äïêéìþí åíóùìÜôùóçò êáé ìïíÜäáò"
+msgstr "ÎκÏÎλεÏη ÏλÏν ÏÏν δοκιμÏν ενÏÏμάÏÏÏÎ·Ï ÎºÎ±Î¹ μονάδαÏ"
#: ../lib/gpde/test/test_main.c:85
msgid "test, gpde"
-msgstr "äïêéìÞ, gpde"
+msgstr "δοκιμή, gpde"
#: ../lib/gpde/test/test_main.c:87
msgid "Performs unit and integration tests for gpde library"
-msgstr "Åêôåëåß äïêéìÝò ìïíÜäáò êáé åíóùìÜôùóçò ãéá ôçí âéâëéïèÞêç gpde"
+msgstr "ÎκÏελεί δοκιμÎÏ Î¼Î¿Î½Î¬Î´Î±Ï ÎºÎ±Î¹ ενÏÏμάÏÏÏÎ·Ï Î³Î¹Î± Ïην βιβλιοθήκη gpde"
#: ../lib/gpde/test/test_gwflow.c:43
msgid ""
@@ -523,15 +523,15 @@
"++ Running gwflow integration tests ++"
msgstr ""
"\n"
-"++ Åêôåëïýíôáé äïêéìÝò åíóùìÜôùóçò gwflow ++"
+"++ ÎκÏελοÏνÏαι δοκιμÎÏ ÎµÎ½ÏÏμάÏÏÏÎ·Ï gwflow ++"
#: ../lib/gpde/test/test_gwflow.c:45
msgid "\t 1. testing 2d gwflow"
-msgstr "\t 1. äïêéìÞ 2 äéáóôÜóåùí gwflow"
+msgstr "\t 1. δοκιμή 2 διαÏÏάÏεÏν gwflow"
#: ../lib/gpde/test/test_gwflow.c:48
msgid "\t 2. testing 3d gwflow"
-msgstr "\t 1. äïêéìÞ 3 äéáóôÜóåùí gwflow"
+msgstr "\t 1. δοκιμή 3 διαÏÏάÏεÏν gwflow"
#: ../lib/gpde/test/test_gwflow.c:52
msgid ""
@@ -539,7 +539,7 @@
"-- gwflow integration tests failure --"
msgstr ""
"\n"
-"-- áðïôõ÷ßá äïêéìÞò åíóùìÜôùóçò gwflow --"
+"-- αÏοÏÏ
Ïία Î´Î¿ÎºÎ¹Î¼Î®Ï ÎµÎ½ÏÏμάÏÏÏÎ·Ï gwflow --"
#: ../lib/gpde/test/test_gwflow.c:54
msgid ""
@@ -547,7 +547,7 @@
"-- gwflow integration tests finished successfully --"
msgstr ""
"\n"
-"-- Åðéôõ÷ßá äïêéìÞò åíóùìÜôùóçò gwflow --"
+"-- ÎÏιÏÏ
#: ../lib/gpde/test/test_arrays.c:48
msgid ""
@@ -555,15 +555,15 @@
"++ Running array unit tests ++"
msgstr ""
"\n"
-"++ ÅêôÝëåóç ôåóô ìïíÜäáò ðßíáêá++"
+"++ ÎκÏÎλεÏη ÏεÏÏ Î¼Î¿Î½Î¬Î´Î±Ï Ïίνακα++"
#: ../lib/gpde/test/test_arrays.c:50
msgid "\t 1. testing 2d arrays"
-msgstr "\t 1. äïêßìç ðßíáêá 2 äéáóôÜóåùí"
+msgstr "\t 1. δοκίμη Ïίνακα 2 διαÏÏάÏεÏν"
#: ../lib/gpde/test/test_arrays.c:53
msgid "\t 2. testing 3d arrays"
-msgstr "\t 1. äïêßìç ðßíáêá 3 äéáóôÜóåùí"
+msgstr "\t 1. δοκίμη Ïίνακα 3 διαÏÏάÏεÏν"
#: ../lib/gpde/test/test_arrays.c:57
msgid ""
@@ -571,7 +571,7 @@
"-- Array unit tests failure --"
msgstr ""
"\n"
-"-- Áðïôõ÷ßá åêôÝëåóçò ìïíÜäáò ðßíáêá --"
+"-- ÎÏοÏÏ
Ïία εκÏÎλεÏÎ·Ï Î¼Î¿Î½Î¬Î´Î±Ï Ïίνακα --"
#: ../lib/gpde/test/test_arrays.c:59
msgid ""
@@ -579,7 +579,7 @@
"-- Array unit tests finished successfully --"
msgstr ""
"\n"
-"-- Åðéôõ÷ßá åêôÝëåóçò ìïíÜäáò ðßíáêá --"
+"-- ÎÏιÏÏ
#: ../lib/gpde/test/test_tools.c:34
msgid ""
@@ -587,7 +587,7 @@
"++ Running math tool unit tests ++"
msgstr ""
"\n"
-"++ ÅêôÝëåóç ôåóô ìáèçìáôéêÞò ìïíÜäáò ++"
+"++ ÎκÏÎλεÏη ÏεÏÏ Î¼Î±Î¸Î·Î¼Î±ÏÎ¹ÎºÎ®Ï Î¼Î¿Î½Î¬Î´Î±Ï ++"
#: ../lib/gpde/test/test_tools.c:39
msgid ""
@@ -595,7 +595,7 @@
"-- math tool unit tests failure --"
msgstr ""
"\n"
-"-- Áðïôõ÷ßá åêôÝëåóçò ôåóô ìáèçìáôéêÞò ìïíÜäáò --"
+"-- ÎÏοÏÏ
Ïία εκÏÎλεÏÎ·Ï ÏεÏÏ Î¼Î±Î¸Î·Î¼Î±ÏÎ¹ÎºÎ®Ï Î¼Î¿Î½Î¬Î´Î±Ï --"
#: ../lib/gpde/test/test_tools.c:41
msgid ""
@@ -603,7 +603,7 @@
"-- math tool unit tests finished successfully --"
msgstr ""
"\n"
-"++ Åðéôõ÷Þò åêôÝëåóç ôåóô ìáèçìáôéêÞò ìïíÜäáò ++"
+"++ ÎÏιÏÏ
ÏÎ®Ï ÎµÎºÏÎλεÏη ÏεÏÏ Î¼Î±Î¸Î·Î¼Î±ÏÎ¹ÎºÎ®Ï Î¼Î¿Î½Î¬Î´Î±Ï ++"
#: ../lib/gpde/test/test_assemble.c:42
msgid ""
@@ -611,15 +611,15 @@
"++ Running assembling unit tests ++"
msgstr ""
"\n"
-"++ ÅêôÝëåóç äïêéìÞò ìïíÜäïò assembling ++"
+"++ ÎκÏÎλεÏη Î´Î¿ÎºÎ¹Î¼Î®Ï Î¼Î¿Î½Î¬Î´Î¿Ï assembling ++"
#: ../lib/gpde/test/test_assemble.c:44
msgid "\t 1. testing 2d assembling"
-msgstr "\t 1. äïêéìÞò assembling 2 äéáóôÜóåùí"
+msgstr "\t 1. Î´Î¿ÎºÎ¹Î¼Î®Ï assembling 2 διαÏÏάÏεÏν"
#: ../lib/gpde/test/test_assemble.c:47
msgid "\t 2. testing 3d assembling"
-msgstr "\t 1. äïêéìÞò assembling 3 äéáóôÜóåùí"
+msgstr "\t 1. Î´Î¿ÎºÎ¹Î¼Î®Ï assembling 3 διαÏÏάÏεÏν"
#: ../lib/gpde/test/test_assemble.c:51
msgid ""
@@ -627,7 +627,7 @@
"-- Assembling unit tests failure --"
msgstr ""
"\n"
-"++ Áðïôõ÷ßá åêôÝëåóçò äïêéìÞò ìïíÜäïò assembling ++"
+"++ ÎÏοÏÏ
Ïία εκÏÎλεÏÎ·Ï Î´Î¿ÎºÎ¹Î¼Î®Ï Î¼Î¿Î½Î¬Î´Î¿Ï assembling ++"
#: ../lib/gpde/test/test_assemble.c:53
msgid ""
@@ -635,7 +635,7 @@
"-- Assembling unit tests finished successfully --"
msgstr ""
"\n"
-"++ Åðéôõ÷ßá åêôÝëåóçò äïêéìÞò ìïíÜäïò assembling ++"
+"++ ÎÏιÏÏ
#: ../lib/gpde/test/test_heat.c:33
msgid ""
@@ -643,15 +643,15 @@
"++ Running heat flow integration tests ++"
msgstr ""
"\n"
-"++ ÅêôÝëåóç äïêéìþí èåñìéêÞò ñïÞò ++"
+"++ ÎκÏÎλεÏη δοκιμÏν θεÏÎ¼Î¹ÎºÎ®Ï ÏÎ¿Î®Ï ++"
#: ../lib/gpde/test/test_heat.c:35
msgid "\t 1. testing 2d heat flow"
-msgstr "\t 1. äïêéìÞ èåñìéêÞò ñïÞò 2 äéáóôÜóåùí"
+msgstr "\t 1. δοκιμή θεÏÎ¼Î¹ÎºÎ®Ï ÏÎ¿Î®Ï 2 διαÏÏάÏεÏν"
#: ../lib/gpde/test/test_heat.c:37
msgid "\t 2. testing 3d heat flow"
-msgstr "\t 1. äïêéìÞ èåñìéêÞò ñïÞò 3 äéáóôÜóåùí"
+msgstr "\t 1. δοκιμή θεÏÎ¼Î¹ÎºÎ®Ï ÏÎ¿Î®Ï 3 διαÏÏάÏεÏν"
#: ../lib/gpde/test/test_heat.c:40
msgid ""
@@ -659,7 +659,7 @@
"-- heat flow integration tests failure --"
msgstr ""
"\n"
-"-- Áðïôõ÷ßá åêôÝëåóçò äïêéìÞò èåñìéêÞò ñïÞò --"
+"-- ÎÏοÏÏ
Ïία εκÏÎλεÏÎ·Ï Î´Î¿ÎºÎ¹Î¼Î®Ï Î¸ÎµÏÎ¼Î¹ÎºÎ®Ï ÏÎ¿Î®Ï --"
#: ../lib/gpde/test/test_heat.c:42
msgid ""
@@ -667,7 +667,7 @@
"-- heat flow integration tests finished successfully --"
msgstr ""
"\n"
-"-- Åðéôõ÷Þò åêôÝëåóçò äïêéìÞò èåñìéêÞò ñïÞò --"
+"-- ÎÏιÏÏ
ÏÎ®Ï ÎµÎºÏÎλεÏÎ·Ï Î´Î¿ÎºÎ¹Î¼Î®Ï Î¸ÎµÏÎ¼Î¹ÎºÎ®Ï ÏÎ¿Î®Ï --"
#: ../lib/gpde/test/test_geom.c:36
msgid ""
@@ -675,7 +675,7 @@
"++ Running geom_data unit tests ++"
msgstr ""
"\n"
-"++ ÅêôÝëåóç äïêéìÞò geom_data ++"
+"++ ÎκÏÎλεÏη Î´Î¿ÎºÎ¹Î¼Î®Ï geom_data ++"
#: ../lib/gpde/test/test_geom.c:41
msgid ""
@@ -683,7 +683,7 @@
"-- geom_data unit tests failure --"
msgstr ""
"\n"
-"++ Áðïôõ÷ßá åêôÝëåóçò äïêéìÞò geom_data ++"
+"++ ÎÏοÏÏ
Ïία εκÏÎλεÏÎ·Ï Î´Î¿ÎºÎ¹Î¼Î®Ï geom_data ++"
#: ../lib/gpde/test/test_geom.c:43
msgid ""
@@ -691,7 +691,7 @@
"-- geom_data unit tests finished successfully --"
msgstr ""
"\n"
-"++ Åðéôõ÷ßá åêôÝëåóçò äïêéìÞò geom_data ++"
+"++ ÎÏιÏÏ
#: ../lib/gpde/test/test_gradient.c:42
msgid ""
@@ -699,15 +699,15 @@
"++ Running gradient unit tests ++"
msgstr ""
"\n"
-"++ ÅêôÝëåóç äïêéìÞò ìïíÜäïò gradient ++"
+"++ ÎκÏÎλεÏη Î´Î¿ÎºÎ¹Î¼Î®Ï Î¼Î¿Î½Î¬Î´Î¿Ï gradient ++"
#: ../lib/gpde/test/test_gradient.c:44
msgid "\t 1. testing 2d gradient"
-msgstr "\t 1. äïêéìÞò gradient 2 äéáóôÜóåùí"
+msgstr "\t 1. Î´Î¿ÎºÎ¹Î¼Î®Ï gradient 2 διαÏÏάÏεÏν"
#: ../lib/gpde/test/test_gradient.c:47
msgid "\t 2. testing 3d gradient"
-msgstr "\t 1. äïêéìÞò gradient 3 äéáóôÜóåùí"
+msgstr "\t 1. Î´Î¿ÎºÎ¹Î¼Î®Ï gradient 3 διαÏÏάÏεÏν"
#: ../lib/gpde/test/test_gradient.c:51
msgid ""
@@ -715,7 +715,7 @@
"-- Gradient unit tests failure --"
msgstr ""
"\n"
-"++ Áðïôõ÷ßá åêôÝëåóçò äïêéìÞò ìïíÜäïò gradient ++"
+"++ ÎÏοÏÏ
Ïία εκÏÎλεÏÎ·Ï Î´Î¿ÎºÎ¹Î¼Î®Ï Î¼Î¿Î½Î¬Î´Î¿Ï gradient ++"
#: ../lib/gpde/test/test_gradient.c:53
msgid ""
@@ -723,7 +723,7 @@
"-- Gradient unit tests finished successfully --"
msgstr ""
"\n"
-"++ Åðéôõ÷ßá åêôÝëåóçò äïêéìÞò ìïíÜäïò gradient ++"
+"++ ÎÏιÏÏ
#: ../lib/gpde/test/test_solvers.c:37
msgid ""
@@ -731,7 +731,7 @@
"++ Running solver unit tests ++"
msgstr ""
"\n"
-"++ ÅêôÝëåóç äïêéìÞò ìïíÜäïò åðßëõóçò (solver) ++"
+"++ ÎκÏÎλεÏη Î´Î¿ÎºÎ¹Î¼Î®Ï Î¼Î¿Î½Î¬Î´Î¿Ï ÎµÏίλÏ
ÏÎ·Ï (solver) ++"
#: ../lib/gpde/test/test_solvers.c:42
msgid ""
@@ -739,7 +739,7 @@
"-- Solver unit tests failure --"
msgstr ""
"\n"
-"++ Áðïôõ÷ßá åêôÝëåóçò äïêéìÞò ìïíÜäïò åðßëõóçò (solver) ++"
+"++ ÎÏοÏÏ
Ïία εκÏÎλεÏÎ·Ï Î´Î¿ÎºÎ¹Î¼Î®Ï Î¼Î¿Î½Î¬Î´Î¿Ï ÎµÏίλÏ
ÏÎ·Ï (solver) ++"
#: ../lib/gpde/test/test_solvers.c:44
msgid ""
@@ -747,7 +747,7 @@
"-- Solver unit tests finished successfully --"
msgstr ""
"\n"
-"++ Åðéôõ÷ßá åêôÝëåóçò äïêéìÞò ìïíÜäïò åðßëõóçò (solver) ++"
+"++ ÎÏιÏÏ
ÏÎ·Ï (solver) ++"
#: ../lib/gpde/test/test_solute_transport.c:43
msgid ""
@@ -755,15 +755,15 @@
"++ Running solute_transport integration tests ++"
msgstr ""
"\n"
-"++ ÅêôÝëåóç äïêéìÞò åíóùìÜôùóçò solute_transport ++"
+"++ ÎκÏÎλεÏη Î´Î¿ÎºÎ¹Î¼Î®Ï ÎµÎ½ÏÏμάÏÏÏÎ·Ï solute_transport ++"
#: ../lib/gpde/test/test_solute_transport.c:45
msgid "\t 1. testing 2d solute_transport"
-msgstr "\t 1. ÄïêéìÞò 2 äéáóôÜóåùí solute_transport"
+msgstr "\t 1. ÎÎ¿ÎºÎ¹Î¼Î®Ï 2 διαÏÏάÏεÏν solute_transport"
#: ../lib/gpde/test/test_solute_transport.c:48
msgid "\t 2. testing 3d solute_transport"
-msgstr "\t 1. ÄïêéìÞò 3 äéáóôÜóåùí solute_transport"
+msgstr "\t 1. ÎÎ¿ÎºÎ¹Î¼Î®Ï 3 διαÏÏάÏεÏν solute_transport"
#: ../lib/gpde/test/test_solute_transport.c:52
msgid ""
@@ -771,7 +771,7 @@
"-- solute_transport integration tests failure --"
msgstr ""
"\n"
-"++ Áðïôõ÷ßá åêôÝëåóçò äïêéìÞò åíóùìÜôùóçò solute_transport ++"
+"++ ÎÏοÏÏ
Ïία εκÏÎλεÏÎ·Ï Î´Î¿ÎºÎ¹Î¼Î®Ï ÎµÎ½ÏÏμάÏÏÏÎ·Ï solute_transport ++"
#: ../lib/gpde/test/test_solute_transport.c:54
msgid ""
@@ -779,7 +779,7 @@
"-- solute_transport integration tests finished successfully --"
msgstr ""
"\n"
-"++ Åðéôõ÷ßá åêôÝëåóçò äïêéìÞò åíóùìÜôùóçò solute_transport ++"
+"++ ÎÏιÏÏ
#: ../lib/gpde/test/test_les.c:34
msgid ""
@@ -787,7 +787,7 @@
"++ Running les creation unit tests ++"
msgstr ""
"\n"
-"++ ÅêôÝëåóçò ìïíÜäáò äçìéïõñãßáò les ++"
+"++ ÎκÏÎλεÏÎ·Ï Î¼Î¿Î½Î¬Î´Î±Ï Î´Î·Î¼Î¹Î¿Ï
ÏÎ³Î¯Î±Ï les ++"
#: ../lib/gpde/test/test_les.c:39
msgid ""
@@ -795,7 +795,7 @@
"-- les creation unit tests failure --"
msgstr ""
"\n"
-"++ Áðïôõ÷ßá åêôÝëåóçò ìïíÜäáò äçìéïõñãßáò les ++"
+"++ ÎÏοÏÏ
Ïία εκÏÎλεÏÎ·Ï Î¼Î¿Î½Î¬Î´Î±Ï Î´Î·Î¼Î¹Î¿Ï
ÏÎ³Î¯Î±Ï les ++"
#: ../lib/gpde/test/test_les.c:41
msgid ""
@@ -803,30 +803,30 @@
"-- les creation unit tests finished successfully --"
msgstr ""
"\n"
-"++ Åðéôõ÷ßá åêôÝëåóçò ìïíÜäáò äçìéïõñãßáò les ++"
+"++ ÎÏιÏÏ
ÏÎ³Î¯Î±Ï les ++"
#: ../lib/gpde/test/test_les.c:95
msgid "\t * testing les creation in parallel\n"
-msgstr "\t * äïêéìÞ äçìéïõñãßáò les ðáñÜëëçëá\n"
+msgstr "\t * δοκιμή δημιοÏ
ÏÎ³Î¯Î±Ï les ÏαÏάλληλα\n"
#: ../lib/gpde/test/test_les.c:126
msgid "\t * testing les creation in serial\n"
-msgstr "\t * äïêéìÞ äçìéïõñãßáò les óåéñéáêÜ\n"
ÏÎ³Î¯Î±Ï les ÏειÏιακά\n"
#: ../lib/gpde/N_parse_options.c:59
msgid ""
"The type of solver which should solve the symmetric linear equation system"
-msgstr "Ï ôýðïò ôïõ åðéëýôç ðïõ ðéèáíÜ ëýíåé ôï óõììåôñéêü ãñáììéêü óýóôçìá"
+msgstr "Î ÏÏÏÎ¿Ï ÏοÏ
εÏιλÏÏη ÏοÏ
Ïιθανά λÏνει Ïο ÏÏ
μμεÏÏÎ¹ÎºÏ Î³ÏÎ±Î¼Î¼Î¹ÎºÏ ÏÏÏÏημα"
#: ../lib/gpde/N_parse_options.c:71
msgid "The type of solver which should solve the linear equation system"
-msgstr "Ï ôýðïò ôïõ åðéëýôç ðïõ ðéèáíÜ ëýíåé ôï ãñáììéêü óýóôçìá"
εÏιλÏÏη ÏοÏ
Ïιθανά λÏνει Ïο γÏÎ±Î¼Î¼Î¹ÎºÏ ÏÏÏÏημα"
#: ../lib/gpde/N_parse_options.c:80
msgid "Maximum number of iteration used to solver the linear equation system"
msgstr ""
-"ÌÝãéóôïò áñéèìüò åðáíáëÞøåùí ðïõ ÷ñçóéìïðïéÞèçêáí óôïí åðéëýôç ãéá ôï "
-"ãñáììéêü óýóôçìá"
+"ÎÎγιÏÏÎ¿Ï Î±ÏιθμÏÏ ÎµÏαναλήÏεÏν ÏοÏ
ÏÏηÏιμοÏοιήθηκαν ÏÏον εÏιλÏÏη για Ïο "
+"γÏÎ±Î¼Î¼Î¹ÎºÏ ÏÏÏÏημα"
#: ../lib/gpde/N_parse_options.c:89
msgid ""
@@ -841,7 +841,7 @@
#: ../lib/gpde/N_parse_options.c:106
msgid "The calculation time in seconds"
-msgstr "Ï ÷ñüíïò õðïëïãßæåôáé óå äåõôåñüëåðôá"
+msgstr "Î ÏÏÏÎ½Î¿Ï Ï
ÏολογίζεÏαι Ïε δεÏ
ÏεÏÏλεÏÏα"
#: ../lib/gpde/N_solvers.c:50
msgid "The gauss elimination solver does not work with sparse matrices"
@@ -866,7 +866,7 @@
#: ../lib/gpde/N_solvers.c:166 ../lib/gpde/N_solvers_krylov.c:84
#: ../lib/gpde/N_solvers_krylov.c:261
msgid "Matrix is not symmetric!"
-msgstr "Ï ðßíáêáò äåí åßíáé óõììåôñéêüò!"
+msgstr "Î ÏÎ¯Î½Î±ÎºÎ±Ï Î´ÎµÎ½ είναι ÏÏ
μμεÏÏικÏÏ!"
#: ../lib/gpde/N_solvers.c:170
msgid "Starting cholesky decomposition solver"
@@ -875,7 +875,7 @@
#: ../lib/gpde/N_solvers.c:173 ../lib/gpde/N_solvers_krylov.c:190
#: ../lib/gpde/N_solvers_krylov.c:357 ../lib/gpde/N_solvers_krylov.c:481
msgid "Unable to solve the linear equation system"
-msgstr "Áäõíáìßá ëýóçò ôïõ ãñáììéêïý óõóôÞìáôïò"
+msgstr "ÎδÏ
ναμία λÏÏÎ·Ï ÏοÏ
γÏÎ±Î¼Î¼Î¹ÎºÎ¿Ï ÏÏ
ÏÏήμαÏοÏ"
#: ../lib/gpde/N_solvers_krylov.c:198
#, c-format
@@ -910,16 +910,16 @@
#: ../lib/proj/get_proj.c:150
#, c-format
msgid "Invalid zone %s specified"
-msgstr "¸÷åé êáèïñéóôåß ëÜèïò æþíç %s"
+msgstr "ÎÏει καθοÏιÏÏεί Î»Î¬Î¸Î¿Ï Î¶Ïνη %s"
#: ../lib/proj/get_proj.c:230
msgid "Unable to initialise PROJ.4 with the following parameter list:"
-msgstr "Äåí åßíáé äõíáôÞ Þ Ýíáñîç PROJ4 ìå ôçí ðáñáêÜôù ëßóôá ðáñáìÝôñùí:"
+msgstr "Îεν είναι δÏ
ναÏή ή ÎναÏξη PROJ4 με Ïην ÏαÏακάÏÏ Î»Î¯ÏÏα ÏαÏαμÎÏÏÏν:"
#: ../lib/proj/get_proj.c:238
#, c-format
msgid "The error message: %s"
-msgstr "Ôï ìÞíõìá ëÜèïõò: %s"
+msgstr "Το μήνÏ
μα λάθοÏ
Ï: %s"
#: ../lib/proj/get_proj.c:296
msgid "Option input overflowed option table"
@@ -928,111 +928,111 @@
#: ../lib/proj/get_proj.c:327
#, c-format
msgid "Unable to initialize pj cause: %s"
-msgstr "Áäýíáìßá Ýíáñîçò pj åîáéôßáò: %s"
+msgstr "ÎδÏναμία ÎναÏÎ¾Î·Ï pj εξαιÏίαÏ: %s"
#: ../lib/proj/get_proj.c:403
msgid "Input Projection Parameters"
-msgstr "ÅéóáãùãÞ ðáñáìÝôñùí ðñïâïëéêïý óõóôÞìáôïò"
+msgstr "ÎιÏαγÏγή ÏαÏαμÎÏÏÏν ÏÏÎ¿Î²Î¿Î»Î¹ÎºÎ¿Ï ÏÏ
ÏÏήμαÏοÏ"
#: ../lib/proj/get_proj.c:406
msgid "Input Unit Factor"
-msgstr "ÅéóáãùãÞ ìïíÜäáò ðáñÜãïíôá"
+msgstr "ÎιÏαγÏγή Î¼Î¿Î½Î¬Î´Î±Ï ÏαÏάγονÏα"
#: ../lib/proj/get_proj.c:416
msgid "Output Projection Parameters"
-msgstr "ÅîáãùãÞ ðáñáìÝôñùí ðñïâïëéêïý óõóôÞìáôïò"
+msgstr "ÎξαγÏγή ÏαÏαμÎÏÏÏν ÏÏÎ¿Î²Î¿Î»Î¹ÎºÎ¿Ï ÏÏ
ÏÏήμαÏοÏ"
#: ../lib/proj/get_proj.c:419
msgid "Output Unit Factor"
-msgstr "ÅîáãùãÞ ìïíÜäáò ðáñÜãïíôá"
+msgstr "ÎξαγÏγή Î¼Î¿Î½Î¬Î´Î±Ï ÏαÏάγονÏα"
#: ../lib/proj/datum.c:250
msgid "Unable to open temporary file"
-msgstr "Áäõíáìßá áíïßãìáôïò ðñïóùñéíïý áñ÷åßïõ"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï ÏÏοÏÏÏÎ¹Î½Î¿Ï Î±ÏÏείοÏ
#: ../lib/proj/datum.c:344 ../lib/gis/get_projname.c:52
#: ../lib/gis/get_datum_name.c:58 ../lib/gis/get_ell_name.c:45
#, c-format
msgid "Hit RETURN to cancel request\n"
-msgstr "ÐáôÞóôå ôï ðëÞêôñï RETURN ãéá íá áêõñþóåôå ôçí åíôïëÞ\n"
+msgstr "ΠαÏήÏÏε Ïο ÏλήκÏÏο RETURN για να ακÏ
ÏÏÏεÏε Ïην ενÏολή\n"
#: ../lib/proj/datum.c:418 ../lib/proj/datum.c:498
#, c-format
msgid "Unable to open datum table file <%s>"
-msgstr "Áäõíáìßá áíïßãìáôïò ôïõ áñ÷åßïõ ðïõ ðåñéÝ÷åé ôïí ðßíáêá datum <%s>"
+msgstr "ÎδÏ
αÏÏείοÏ
ÏοÏ
ÏεÏιÎÏει Ïον Ïίνακα datum <%s>"
#: ../lib/proj/datum.c:431 ../lib/proj/datum.c:512
#, c-format
msgid "Error in datum table file <%s>, line %d"
-msgstr "ÓöÜëìá óôï áñ÷åßï ðïõ ðåñéÝ÷åé ôïí ðßíáêá datum <%s>, ãñáììÞ %d"
+msgstr "ΣÏάλμα ÏÏο αÏÏείο ÏοÏ
ÏεÏιÎÏει Ïον Ïίνακα datum <%s>, γÏαμμή %d"
#: ../lib/proj/ellipse.c:75
#, c-format
msgid "Invalid ellipsoid <%s> in file"
-msgstr "ÅóöáëìÝíï åëëåéøïåéäÝò <%s> óôï áñ÷åßï"
+msgstr "ÎÏÏαλμÎνο ελλειÏοειδÎÏ <%s> ÏÏο αÏÏείο"
#: ../lib/proj/ellipse.c:98
msgid "No secondary ellipsoid descriptor (rf, es or b) in file"
-msgstr "Äåí õðÜñ÷åé äåõôåñç ðáñáìÝôñïò åëëåéøïåéäïýò (rf, es Þ b) óôï áñ÷åßï"
+msgstr "Îεν Ï
ÏάÏÏει δεÏ
ÏεÏη ÏαÏαμÎÏÏÎ¿Ï ÎµÎ»Î»ÎµÎ¹ÏοειδοÏÏ (rf, es ή b) ÏÏο αÏÏείο"
#: ../lib/proj/ellipse.c:102
msgid "Invalid ellipsoid descriptors (a, rf, es or b) in file"
-msgstr "Ìç åðéôñåðôïé ðáñÜìåôñïé åëëåéøïåéäïýò (a, rf, es Þ b) óôï áñ÷åßï"
+msgstr "Îη εÏιÏÏεÏÏοι ÏαÏάμεÏÏοι ελλειÏοειδοÏÏ (a, rf, es ή b) ÏÏο αÏÏείο"
#: ../lib/proj/ellipse.c:115
msgid "No ellipsoid info given in file"
-msgstr "Äåí Ý÷ïõí äùèåß óôïé÷åßá ãéá ôï åëëåéøïåéäÝò óôï áñ÷åßï"
+msgstr "Îεν ÎÏοÏ
ν δÏθεί ÏÏοιÏεία για Ïο ελλειÏοειδÎÏ ÏÏο αÏÏείο"
#: ../lib/proj/ellipse.c:215 ../lib/gis/get_ellipse.c:283
#, c-format
msgid "Unable to open ellipsoid table file <%s>"
-msgstr "Áäõíáìßá áíïßãìáôïò ðßíáêá åëëåéøïåéäïýò áðü áñ÷åßï <%s>"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï Ïίνακα ελλειÏοειδοÏÏ Î±ÏÏ Î±ÏÏείο <%s>"
#: ../lib/proj/ellipse.c:268 ../lib/gis/get_ellipse.c:338
#, c-format
msgid "Line%s of ellipsoid table file <%s> is invalid"
-msgstr "Ç ãñáììÞ%s ôïõ ðßíáêá áñ÷åßïõ ôïõ åëëåéøïåéäïý <%s> åßíáé ëáíèáóìÝíç"
+msgstr "ΠγÏαμμή%s ÏοÏ
Ïίνακα αÏÏείοÏ
ÏοÏ
ελλειÏÎ¿ÎµÎ¹Î´Î¿Ï <%s> είναι λανθαÏμÎνη"
#: ../lib/proj/ellipse.c:269 ../lib/gis/get_ellipse.c:336
#, c-format
msgid "Lines%s of ellipsoid table file <%s> are invalid"
-msgstr "ÃñáììÝò %s ôïõ ðßíáêá áñ÷åßïõ ôïõ åëëåéøïåéäïýò <%s> åßíáé ëáíèáóìÝíåò"
+msgstr "ÎÏαμμÎÏ %s ÏοÏ
Ïίνακα αÏÏείοÏ
ÏοÏ
ελλειÏοειδοÏÏ <%s> είναι λανθαÏμÎνεÏ"
#: ../lib/proj/convert.c:110
msgid "Unable parse GRASS PROJ_INFO file"
-msgstr "Áäõíáìßá áíÜëõóçò GRASS PROJ_INFO áñ÷åßïõ"
+msgstr "ÎδÏ
ναμία ανάλÏ
ÏÎ·Ï GRASS PROJ_INFO αÏÏείοÏ
#: ../lib/proj/convert.c:115
msgid "Unable get PROJ.4-style parameter string"
-msgstr "Áäõíáìßá ëÞøçò PROJ.4-óôõë ðáñáìÝôñïõ"
+msgstr "ÎδÏ
ναμία λήÏÎ·Ï PROJ.4-ÏÏÏ
λ ÏαÏαμÎÏÏοÏ
#: ../lib/proj/convert.c:127
#, c-format
msgid ""
"OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
msgstr ""
-"OGR äåí ìðïñåß íá áíáëýóåé PROJ.4-ôï óôõë ðáñáìÝôñïõ string: %s (OGR êþäéêáò "
-"óöÜëìáôïò Þôáí %d)"
+"OGR δεν μÏοÏεί να αναλÏÏει PROJ.4-Ïο ÏÏÏ
λ ÏαÏαμÎÏÏοÏ
string: %s (OGR κÏÎ´Î¹ÎºÎ±Ï "
+"ÏÏάλμαÏÎ¿Ï Î®Ïαν %d)"
#: ../lib/proj/convert.c:133
#, c-format
msgid "OGR can't get WKT-style parameter string (OGR Error code was %d)"
msgstr ""
-"OGR äåí ìðïñåß íá ðÜñåéò WKT-ôï óôõë ðáñáìÝôñïõ string (OGR êùäéêüò "
+"OGR δεν μÏοÏεί να ÏάÏÎµÎ¹Ï WKT-Ïο ÏÏÏ
λ ÏαÏαμÎÏÏοÏ
string (OGR κÏδικÏÏ "
#: ../lib/proj/convert.c:390
msgid "No projection name! Projection parameters likely to be meaningless."
msgstr ""
-"Äåí õðÜñ÷åé üíïìá ðñïâïëÞò! Ïé ðáñÜìåôñïé ðñïâïëÞò ðñïöáíþò åßíáé Üíåõ "
-"íïÞìáôïò."
+"Îεν Ï
ÏάÏÏει Ïνομα ÏÏοβολήÏ! Îι ÏαÏάμεÏÏοι ÏÏÎ¿Î²Î¿Î»Î®Ï ÏÏοÏανÏÏ ÎµÎ¯Î½Î±Î¹ άνεÏ
+"νοήμαÏοÏ."
#: ../lib/proj/convert.c:426
#, c-format
msgid "Datum <%s> not recognised by GRASS and no parameters found"
msgstr ""
-"Datum <%s> äåí áíáãíùñßæåôáé áðü ôï GRASS êáé ïé ðáñÜìåôñïé äåí ìðïñïýí íá "
-"âñåèïýí."
+"Datum <%s> δεν αναγνÏÏίζεÏαι αÏÏ Ïο GRASS και οι ÏαÏάμεÏÏοι δεν μÏοÏοÏν να "
+"βÏεθοÏν."
#: ../lib/proj/convert.c:442
#, c-format
@@ -1040,8 +1040,8 @@
"Datum <%s> apparently recognised by GRASS but no parameters found. You may "
"want to look into this."
msgstr ""
-"Datum <%s> ðñïöáíþò áíáãíùñßæåôáé áðü ôï GRASS áëëÜ äåí ìðïñïýí íá âñåèïýí "
-"ïé ðáñÜìåôñïé. ÌÜëëïí èá ðñÝðåé íá ôï îáíáäåßôå."
+"Datum <%s> ÏÏοÏανÏÏ Î±Î½Î±Î³Î½ÏÏίζεÏαι αÏÏ Ïο GRASS αλλά δεν μÏοÏοÏν να βÏεθοÏν "
+"οι ÏαÏάμεÏÏοι. Îάλλον θα ÏÏÎÏει να Ïο ξαναδείÏε."
#: ../lib/proj/convert.c:446
#, c-format
@@ -1049,69 +1049,69 @@
"Invalid transformation number %d; valid range is 1 to %d. Leaving datum "
"transform parameters unspecified."
msgstr ""
-"Ìç áðïäåêôüò áñéèìüò ìåôáó÷çìáôéóìïý %d; áðïäåêôü åýñïò 1 ìå %d. Ïé "
-"ðáñÜìåôñïé datum áöÞíïíôáé áðñïóäéüñéóôïé."
+"Îη αÏοδεκÏÏÏ Î±ÏιθμÏÏ Î¼ÎµÏαÏÏημαÏιÏÎ¼Î¿Ï %d; αÏοδεκÏÏ ÎµÏÏÎ¿Ï 1 με %d. Îι "
+"ÏαÏάμεÏÏοι datum αÏήνονÏαι αÏÏοÏδιÏÏιÏÏοι."
#: ../lib/proj/do_proj.c:106 ../lib/proj/do_proj.c:180
#, c-format
msgid "pj_transform() failed: %s"
-msgstr "pj_transform() áðÝôõ÷å: %s"
+msgstr "pj_transform() αÏÎÏÏ
Ïε: %s"
#: ../lib/nviz/position.c:56
msgid "Unable to set focus"
-msgstr "Áäõíáìßá focus"
+msgstr "ÎδÏ
ναμία focus"
#: ../lib/nviz/render.c:105
msgid "Bad server connection"
-msgstr "ÊáêÞ óýíäåóç ìå ôïí åîõðçñåôçôÞ"
+msgstr "Îακή ÏÏνδεÏη με Ïον εξÏ
ÏηÏεÏηÏή"
#: ../lib/nviz/render.c:114
msgid "Unable to create rendering context"
-msgstr "Áäõíáìßá äçìéïõñãßáò rendering"
+msgstr "ÎδÏ
ναμία δημιοÏ
ÏÎ³Î¯Î±Ï rendering"
#: ../lib/nviz/nviz.c:126
#, c-format
msgid "Invalid color (%s), using \"white\" as default"
-msgstr "ÅóöáëìÝíï ÷ñþìá (%s), ÷ñÞóç \"white\" ùò ðñïåðéëïãÞ"
+msgstr "ÎÏÏαλμÎνο ÏÏÏμα (%s), ÏÏήÏη \"white\" ÏÏ ÏÏοεÏιλογή"
#: ../lib/nviz/map_obj.c:59
msgid "Maximum surfaces loaded!"
-msgstr "Öïñôþèçêáí ïé ìÝãéóôåò åðéöÜíåéåò!"
+msgstr "ΦοÏÏÏθηκαν οι μÎγιÏÏÎµÏ ÎµÏιÏάνειεÏ!"
#: ../lib/nviz/map_obj.c:88
msgid "Maximum vector line maps loaded!"
-msgstr "Öïñôþèçêáí ïé ìÝãéóôïé äéáíõóìáôéêïß ÷Üñôåò!"
+msgstr "ΦοÏÏÏθηκαν οι μÎγιÏÏοι διανÏ
ÏμαÏικοί ÏάÏÏεÏ!"
#: ../lib/nviz/map_obj.c:97 ../lib/nviz/map_obj.c:128
#, c-format
msgid "Error loading vector map <%s>"
-msgstr "ÓöÜëìá êáôÜ ôï Üíïéãìá ôïõ äéáíõóìáôéêïý ÷Üñôç <%s>"
διανÏ
#: ../lib/nviz/map_obj.c:116
msgid "Maximum vector point maps loaded!"
-msgstr "Öïñôþèçêáí ï ìÝãéóôïò áñéèìüò ÷áñôþí óçìåßùí!"
+msgstr "ΦοÏÏÏθηκαν ο μÎγιÏÏÎ¿Ï Î±ÏιθμÏÏ ÏαÏÏÏν ÏημείÏν!"
#: ../lib/nviz/map_obj.c:143
msgid "Maximum volumes loaded!"
-msgstr "Öïñôþèçêáí ï ìÝãéóôïò áñéèìüò üãêùí!"
+msgstr "ΦοÏÏÏθηκαν ο μÎγιÏÏÎ¿Ï Î±ÏιθμÏÏ ÏγκÏν!"
#: ../lib/nviz/map_obj.c:152
#, c-format
msgid "Error loading 3d raster map <%s>"
-msgstr "ÓöÜëìá êáôÜ ôï Üíïéãìá ôïõ 3Ä ñáóôåñ ÷Üñôç <%s>"
#: ../lib/nviz/map_obj.c:160
msgid "Nviz_new_map_obj(): unsupported data type"
-msgstr "Nviz_new_map_obj(): ï ôýðïò äåäïìÝíùí äåí õðïóôçñßæåôáé"
+msgstr "Nviz_new_map_obj(): ο ÏÏÏÎ¿Ï Î´ÎµÎ´Î¿Î¼ÎνÏν δεν Ï
ÏοÏÏηÏίζεÏαι"
#: ../lib/nviz/lights.c:171
msgid "Unable to define new light"
-msgstr "Áäõíáìßá åýñåóçò íÝïõ öùôüò"
+msgstr "ÎδÏ
ναμία εÏÏεÏÎ·Ï Î½ÎοÏ
ÏÏÏÏÏ"
#: ../lib/sites/sites.c:97
#, fuzzy, c-format
msgid "Attributes for category %d not found"
-msgstr "Ç åããñáöÞ ôçò âÜóçò äåäïìÝíùí ãéá cat %d äåí âñÝèçêå"
+msgstr "ΠεγγÏαÏή ÏÎ·Ï Î²Î¬ÏÎ·Ï Î´ÎµÎ´Î¿Î¼ÎνÏν για cat %d δεν βÏÎθηκε"
#: ../lib/sites/sites.c:136
msgid "Category must be integer"
@@ -1144,18 +1144,18 @@
#: ../lib/vector/Vlib/net.c:186 ../lib/vector/Vlib/net.c:356
#, c-format
msgid "Unable to open database <%s> by driver <%s>"
-msgstr "Áäõíáìßá áíïßãìáôïò ôçò âÜóçò äåäïìÝíùí <%s> ìå ôïí ïäçãü <%s>"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï ÏÎ·Ï Î²Î¬ÏÎ·Ï Î´ÎµÎ´Î¿Î¼ÎνÏν <%s> με Ïον Î¿Î´Î·Î³Ï <%s>"
#: ../lib/sites/sites.c:381 ../lib/db/dbmi_client/table.c:110
#: ../lib/db/dbmi_client/copy_tab.c:199 ../lib/db/dbmi_client/copy_tab.c:276
#, c-format
msgid "Unable to open select cursor: '%s'"
-msgstr "Áäõíáìßá áíïßãìáôïò êÝñóïñá '%s'"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï ÎºÎÏÏοÏα '%s'"
#: ../lib/sites/sites.c:397
#, fuzzy
msgid "Cannot fetch row"
-msgstr "Äåí ìðïñþ íá ðÜñù ðëçñïöïñßåò ãéá ôï åðßðåäï"
+msgstr "Îεν μÏοÏÏ Î½Î± ÏάÏÏ ÏληÏοÏοÏÎ¯ÎµÏ Î³Î¹Î± Ïο εÏίÏεδο"
#: ../lib/sites/sites.c:579
msgid "G_oldsite_new_struct: invalid # dims or fields"
@@ -1164,7 +1164,7 @@
#: ../lib/sites/sites.c:1249
#, fuzzy, c-format
msgid "Cannot open database %s by driver %s"
+msgstr "ÎδÏ
#: ../lib/sites/sites.c:1257
msgid "Cannot select attributes"
@@ -1174,20 +1174,20 @@
#, c-format
msgid "Illegal table map name <%s>. May not contain '.' or 'NULL'.\n"
msgstr ""
-"Ìç åðéôñåðôÞ ïíïìáóßá ðßíáêá <%s>. Äåí ðñÝðåé íá ðåñéÝ÷åé '.' Þ 'íá åßíáé "
-"êåíüò'.\n"
+"Îη εÏιÏÏεÏÏή ονομαÏία Ïίνακα <%s>. Îεν ÏÏÎÏει να ÏεÏιÎÏει '.' ή 'να είναι "
+"κενÏÏ'.\n"
#: ../lib/db/dbmi_base/legal_dbname.c:33
#, c-format
msgid "Illegal table map name <%s>. Must start with a letter.\n"
-msgstr "Ìç åðéôñåðôÞ ïíïìáóßá ðßíáêá <%s>. ÐñÝðåé íá îåêéíÜ ìå ãñÜììá.\n"
+msgstr "Îη εÏιÏÏεÏÏή ονομαÏία Ïίνακα <%s>. Î ÏÎÏει να ξεκινά με γÏάμμα.\n"
#: ../lib/db/dbmi_base/legal_dbname.c:43
#, c-format
msgid "Illegal table map name <%s>. Character <%c> not allowed.\n"
msgstr ""
-"Ìç åðéôñåðôÞ ïíïìáóßá ðßíáêá <%s>. Ï ÷áñáêôÞñáò <%c> äåí ðñÝðåé íá "
-"÷ñçóéìïðïéçèåß.\n"
+"Îη εÏιÏÏεÏÏή ονομαÏία Ïίνακα <%s>. Î ÏαÏακÏήÏÎ±Ï <%c> δεν ÏÏÎÏει να "
+"ÏÏηÏιμοÏοιηθεί.\n"
#: ../lib/db/dbmi_base/login.c:98
msgid "Login file corrupted"
@@ -1196,28 +1196,28 @@
#: ../lib/db/dbmi_base/default_name.c:127
#, fuzzy
msgid "Programmer error"
ÏÏογÏάμμαÏοÏ."
#: ../lib/db/dbmi_client/table.c:46
#, c-format
msgid "Unable open database <%s> by driver <%s>"
+msgstr "ÎδÏ
#: ../lib/db/dbmi_client/copy_tab.c:100 ../lib/db/dbmi_client/copy_tab.c:120
#: ../lib/db/dbmi_client/db.c:41
#, c-format
msgid "Unable to start driver <%s>"
-msgstr "Áäõíáìßá åêêßíçóçò ôïõ ïäçãïý <%s>"
+msgstr "ÎδÏ
ναμία εκκίνηÏÎ·Ï ÏοÏ
Î¿Î´Î·Î³Î¿Ï <%s>"
#: ../lib/db/dbmi_client/copy_tab.c:144
#, c-format
msgid "Unable to get list tables in database <%s>"
-msgstr "Áäõíáìßá ëÞøçò ëßóôá ðéíÜêùí óôç âÜóç äåäïìÝíùí <%s>"
+msgstr "ÎδÏ
ναμία λήÏÎ·Ï Î»Î¯ÏÏα ÏινάκÏν ÏÏη βάÏη δεδομÎνÏν <%s>"
#: ../lib/db/dbmi_client/copy_tab.c:157
#, c-format
msgid "Table <%s> already exists in database <%s>"
-msgstr "Ðßíáêáò <%s> õðÜñ÷åé Þäç óôçí âÜóç äåäïìÝíùí <%s>"
+msgstr "Î Î¯Î½Î±ÎºÎ±Ï <%s> Ï
ÏάÏÏει ήδη ÏÏην βάÏη δεδομÎνÏν <%s>"
#: ../lib/db/dbmi_client/copy_tab.c:231
#, c-format
@@ -1228,17 +1228,17 @@
#: ../lib/rst/interp_float/vinput2d.c:108
#, c-format
msgid "Column <%s> not found"
-msgstr "Ç óôÞëç <%s> äåí âñÝèçêå"
+msgstr "Î ÏÏήλη <%s> δεν βÏÎθηκε"
#: ../lib/db/dbmi_client/copy_tab.c:251
#, c-format
msgid "Unable to create table <%s>"
-msgstr "Áäõíáìßá äçìéïõñãßáò ðßíáêá <%s>"
+msgstr "ÎδÏ
ναμία δημιοÏ
ÏÎ³Î¯Î±Ï Ïίνακα <%s>"
#: ../lib/db/dbmi_client/copy_tab.c:295
#, c-format
msgid "Unable to fetch data from table <%s>"
-msgstr "Áäõíáìßá öüñôùóçò äåäïìÝíùí ðßíáêá <%s>"
+msgstr "ÎδÏ
ναμία ÏÏÏÏÏÏÎ·Ï Î´ÎµÎ´Î¿Î¼ÎνÏν Ïίνακα <%s>"
#: ../lib/db/dbmi_client/copy_tab.c:351
#, c-format
@@ -1248,7 +1248,7 @@
#: ../lib/db/dbmi_client/column.c:114
#, c-format
msgid "Unable to describe table <%s>"
-msgstr "Áäõíáìßá ðåñéãñáöÞò ðßíáêá <%s>"
+msgstr "ÎδÏ
ναμία ÏεÏιγÏαÏÎ®Ï Ïίνακα <%s>"
#: ../lib/db/dbmi_client/select.c:119 ../lib/db/dbmi_client/select.c:221
#: ../lib/db/dbmi_client/select.c:288
@@ -1262,7 +1262,7 @@
#: ../lib/db/dbmi_client/select.c:317
#, c-format
msgid "Unable select records from table <%s>"
-msgstr "Áäõíáìßá åðéëïãÞò åããñáöþí áðü ðßíáêá <%s>"
+msgstr "ÎδÏ
ναμία εÏÎ¹Î»Î¿Î³Î®Ï ÎµÎ³Î³ÏαÏÏν αÏÏ Ïίνακα <%s>"
#: ../lib/db/dbmi_client/select.c:333
msgid "Key column type is not integer"
@@ -1271,12 +1271,12 @@
#: ../lib/db/dbmi_client/delete_tab.c:44
#, c-format
msgid "Unable to open driver <%s>"
-msgstr "Áäõíáìßá áíïßãìáôïò ïäçãïý <%s>"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï Î¿Î´Î·Î³Î¿Ï <%s>"
#: ../lib/db/dbmi_client/delete_tab.c:62
#, c-format
msgid "Unable to drop table: '%s'"
-msgstr "Áäõíáìßá äéáãñáöÞò ðßíáêá <%s>"
+msgstr "ÎδÏ
ναμία διαγÏαÏÎ®Ï Ïίνακα <%s>"
#: ../lib/cairodriver/Draw_bitmap.c:47
msgid "Cairo_draw_bitmap: Failed to create source"
@@ -1299,53 +1299,53 @@
#: ../lib/display/tran_colr.c:129 ../lib/display/tran_colr.c:131
#, c-format
msgid "[%s]: No such color"
-msgstr "[%s]: Äåí õðÜñ÷åé ôÝôïéï ÷ñþìá"
+msgstr "[%s]: Îεν Ï
ÏάÏÏει ÏÎÏοιο ÏÏÏμα"
#: ../lib/symbol/read.c:211
#, c-format
msgid "Cannot read symbol line coordinates: %s"
-msgstr "Äåí åßíáé äõíáôÞ ç áíÜãíùóç ôùí óõíôåôáãìÝíùí ôùí óõìâüëùí ãñáììÞò: %s"
ναÏή η ανάγνÏÏη ÏÏν ÏÏ
νÏεÏαγμÎνÏν ÏÏν ÏÏ
μβÏλÏν γÏαμμήÏ: %s"
#: ../lib/symbol/read.c:259
#, c-format
msgid ""
"Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
msgstr ""
-"ÅóöáëìÝíï üíïìá óõìâüëïõ: '%s' (èá Ýðñåðå íá åßíáé: group/name or group/"
+"ÎÏÏαλμÎνο Ïνομα ÏÏ
μβÏλοÏ
: '%s' (θα ÎÏÏεÏε να είναι: group/name or group/"
"name at mapset)"
#: ../lib/symbol/read.c:283
#, c-format
msgid "Cannot find/open symbol: '%s'"
-msgstr "Äåí ìðïñþ íá âñù/áíüéîù ôï óýìâïëï: '%s'"
+msgstr "Îεν μÏοÏÏ Î½Î± βÏÏ/ανÏÎ¹Î¾Ï Ïο ÏÏμβολο: '%s'"
#: ../lib/symbol/read.c:388 ../lib/symbol/read.c:406 ../lib/symbol/read.c:416
#: ../lib/symbol/read.c:434
#, c-format
msgid "Incorrect symbol color: '%s', using default."
-msgstr "ÅóöáëìÝíï ÷ñþìá óõìâüëïõ: '%s', ÷ñçóéìïðïéþ ôï ðñïåðéëåãìÝíï."
+msgstr "ÎÏÏαλμÎνο ÏÏÏμα ÏÏ
μβÏλοÏ
: '%s', ÏÏηÏιμοÏÎ¿Î¹Ï Ïο ÏÏοεÏιλεγμÎνο."
#: ../lib/driver/main.c:90
#, c-format
msgid "Graphics driver [%s] started"
-msgstr "Åêêßíçóç ôïõ ïäçãïý êÜñôáò ãñáöéêþí [%s]"
+msgstr "ÎκκίνηÏη ÏοÏ
Î¿Î´Î·Î³Î¿Ï ÎºÎ¬ÏÏÎ±Ï Î³ÏαÏικÏν [%s]"
#: ../lib/driver/parse_ftcap.c:32
#, c-format
msgid "%s: Unable to read font definition file; use the default"
msgstr ""
-"%s: Áäõíáìßá áíÜãíùóçò ôïõ áñ÷åßïõ ãñáììáôïóåéñÜò, ÷ñçóéìïðïéÞóôå ôï "
-"ðñïåðéëåãìÝíï"
+"%s: ÎδÏ
ναμία ανάγνÏÏÎ·Ï ÏοÏ
αÏÏείοÏ
γÏαμμαÏοÏειÏάÏ, ÏÏηÏιμοÏοιήÏÏε Ïο "
+"ÏÏοεÏιλεγμÎνο"
#: ../lib/driver/parse_ftcap.c:38
#, c-format
msgid "%s: No font definition file"
-msgstr "%s: Äåí õðáñ÷åéï áñ÷åßï ãñáììáôïóåéñÜò"
+msgstr "%s: Îεν Ï
ÏαÏÏειο αÏÏείο γÏαμμαÏοÏειÏάÏ"
#: ../lib/driver/command.c:508
#, c-format
msgid "Unknown command: %d last: %d"
-msgstr "¶ãíùóôç åíôïëÞ: %d last: %d"
+msgstr "ÎγνÏÏÏη ενÏολή: %d last: %d"
#: ../lib/driver/command.c:547
msgid "Monitor: get_command: Premature EOF"
@@ -1354,39 +1354,39 @@
#: ../lib/vask/V_support.c:60
#, c-format
msgid "Unable to open file %s"
-msgstr "Áäõíáìßá áíïßãìáôïò áñ÷åßïõ %s"
+msgstr "ÎδÏ
%s"
#: ../lib/gmath/del2g.c:50
msgid " taking FFT of image..."
-msgstr " öôéÜ÷íù FFT ôçò åéêüíáò..."
+msgstr " ÏÏιάÏÎ½Ï FFT ÏÎ·Ï ÎµÎ¹ÎºÏναÏ..."
#: ../lib/gmath/del2g.c:56
msgid " computing del**2 g..."
-msgstr " õðïëïãßæù del**2 g..."
+msgstr " Ï
ÏÎ¿Î»Î¿Î³Î¯Î¶Ï del**2 g..."
#: ../lib/gmath/del2g.c:59
msgid " taking FFT of del**2 g..."
-msgstr " öôéÜ÷íù FFT of del**2 g..."
+msgstr " ÏÏιάÏÎ½Ï FFT of del**2 g..."
#: ../lib/gmath/del2g.c:63
msgid " multiplying transforms..."
-msgstr " ðïëëáðëáóéÜæù ôïõò ìåôáó÷çìáôéóìïýò..."
+msgstr " ÏολλαÏλαÏÎ¹Î¬Î¶Ï ÏοÏ
Ï Î¼ÎµÏαÏÏημαÏιÏμοÏÏ..."
#: ../lib/gmath/del2g.c:66
msgid " taking inverse FFT..."
-msgstr " õðïëïãßæù ôï áíôßóôñïöï FFT..."
+msgstr " Ï
ÏÎ¿Î»Î¿Î³Î¯Î¶Ï Ïο ανÏίÏÏÏοÏο FFT..."
#: ../lib/gmath/la.c:60 ../lib/gmath/la.c:116
msgid "Matrix dimensions out of range"
-msgstr "Ïé äéáóôÜóåéò ôïõ ðßíáêá åßíáé Ýîù áðü ôçí ðåñéï÷Þ"
+msgstr "Îι διαÏÏάÏÎµÎ¹Ï ÏοÏ
Ïίνακα είναι ÎÎ¾Ï Î±ÏÏ Ïην ÏεÏιοÏή"
#: ../lib/gmath/la.c:149
msgid "Matrix is not initialised fully."
-msgstr "Ï ðßíáêáò äåí îåêßíçóå "
+msgstr "Î ÏÎ¯Î½Î±ÎºÎ±Ï Î´ÎµÎ½ ξεκίνηÏε "
#: ../lib/gmath/la.c:154
msgid "Unable to allocate space for matrix copy"
-msgstr "ÁÄõíáìßá ìåôáöïñÜò ìíÞìçò ãéá áíôéãñáöÞ ôïõ ðßíáêá"
+msgstr "ÎÎÏ
ναμία μεÏαÏοÏÎ¬Ï Î¼Î½Î®Î¼Î·Ï Î³Î¹Î± ανÏιγÏαÏή ÏοÏ
Ïίνακα"
#: ../lib/gmath/la.c:243
msgid "First scalar multiplier must be non-zero"
@@ -1394,190 +1394,190 @@
#: ../lib/gmath/la.c:249 ../lib/gmath/la.c:257 ../lib/gmath/la.c:322
msgid "One or both input matrices uninitialised"
-msgstr "'Åíáò áðü ôïõò äýï ðßíáêåò äåí Ý÷åé îåêéíÞóåé"
+msgstr "'ÎÎ½Î±Ï Î±ÏÏ ÏοÏ
Ï Î´Ïο ÏÎ¯Î½Î±ÎºÎµÏ Î´ÎµÎ½ ÎÏει ξεκινήÏει"
#: ../lib/gmath/la.c:262 ../lib/gmath/la.c:327
msgid "Matrix order does not match"
-msgstr "Ç óåéñÜ ôïõ ðßíáêá äåí ôáéñéÜæåé"
+msgstr "Î ÏειÏά ÏοÏ
Ïίνακα δεν ÏαιÏιάζει"
#: ../lib/gmath/la.c:268
msgid "Unable to allocate space for matrix sum"
-msgstr "Áäõíáìßá ìåôáöïñÜò ìíÞìç ãéá ðñüóèåóç ðßíáêá"
+msgstr "ÎδÏ
ναμία μεÏαÏοÏÎ¬Ï Î¼Î½Î®Î¼Î· για ÏÏÏÏθεÏη Ïίνακα"
#: ../lib/gmath/la.c:332
msgid "Unable to allocate space for matrix product"
-msgstr "Áäõíáìßá ìåôáöïñÜò ÷þñïõ ãéá äçìéïõñãßá ðßíáêá"
+msgstr "ÎδÏ
ναμία μεÏαÏοÏÎ¬Ï ÏÏÏοÏ
για δημιοÏ
Ïγία Ïίνακα"
#: ../lib/gmath/la.c:444
msgid "Input: one or both data matrices uninitialised"
-msgstr "ÅéóáãùãÞ: Ýíáò áðü ôïõò äýï ðßíáêåò äåí îåêßíçóå"
+msgstr "ÎιÏαγÏγή: ÎÎ½Î±Ï Î±ÏÏ ÏοÏ
Ï Î´Ïο ÏÎ¯Î½Î±ÎºÎµÏ Î´ÎµÎ½ ξεκίνηÏε"
#: ../lib/gmath/la.c:449
msgid "Principal matrix is not properly dimensioned"
-msgstr "Ï èåìåëéþäçò ðßíáêáò äåí Ý÷åé ôéò óùóôÝò äéáóôÜóåéò"
+msgstr "ΠθεμελιÏÎ´Î·Ï ÏÎ¯Î½Î±ÎºÎ±Ï Î´ÎµÎ½ ÎÏει ÏÎ¹Ï ÏÏÏÏÎÏ Î´Î¹Î±ÏÏάÏειÏ"
#: ../lib/gmath/la.c:454
msgid "Input: you must have at least one array to solve"
-msgstr "Input: ðñÝðåé íá Ý÷åéò ôïõëÜ÷éóôïí Ýíá äéÜíõóìá ðñïò ëýóç"
+msgstr "Input: ÏÏÎÏει να ÎÏÎµÎ¹Ï ÏοÏ
λάÏιÏÏον Îνα διάνÏ
Ïμα ÏÏÎ¿Ï Î»ÏÏη"
#: ../lib/gmath/la.c:460
msgid "Could not allocate space for solution matrix"
-msgstr "Áäõíáìßá ìåôáöïñÜò ÷þñïõ ãéá ëýóç ôïõ ðßíáêá"
+msgstr "ÎδÏ
για λÏÏη ÏοÏ
Ïίνακα"
#: ../lib/gmath/la.c:466 ../lib/gmath/la.c:474
msgid "Could not allocate space for working matrix"
-msgstr "Áäõíáìßá ìåôáöïñÜò ÷þñïõ ãéá åñãáóßá ðßíáêá"
+msgstr "ÎδÏ
για εÏγαÏία Ïίνακα"
#: ../lib/gmath/la.c:527
msgid "Matrix (or submatrix is singular). Solution undetermined"
-msgstr "Ï ðßíáêáò (Þ õðïðßíáêáò åßíáé ìïíáäéáßïò). Áäõíáìßá ëýóçò"
+msgstr "Î ÏÎ¯Î½Î±ÎºÎ±Ï (ή Ï
ÏοÏÎ¯Î½Î±ÎºÎ±Ï ÎµÎ¯Î½Î±Î¹ μοναδιαίοÏ). ÎδÏ
ναμία λÏÏηÏ"
#: ../lib/gmath/la.c:531
msgid "Problem in LA routine."
-msgstr "Ôï ðñüâëçìá åßíáé ìßá LA ñïõôßíá"
+msgstr "Το ÏÏÏβλημα είναι μία LA ÏοÏ
Ïίνα"
#: ../lib/gmath/la.c:538
msgid "Procedure not yet available for selected matrix type"
-msgstr "Ç äéáäéêáóßá äåí åßíáé áêüìç äéáèÝóéìç ãéá ôï åðéëåãìÝíï ôýðï ðßíáêá"
+msgstr "ΠδιαδικαÏία δεν είναι ακÏμη διαθÎÏιμη για Ïο εÏιλεγμÎνο ÏÏÏο Ïίνακα"
#: ../lib/gmath/la.c:572
msgid "Matrix is not square. Cannot determine inverse"
msgstr ""
-"Ï ðßíáêáò äåí åßíáé ôåôñÜãùíéêüò. Äåí ìðïñåß íá êáèïñéóôåß ï áíôßóôñïöïò"
+"Î ÏÎ¯Î½Î±ÎºÎ±Ï Î´ÎµÎ½ είναι ÏεÏÏάγÏνικÏÏ. Îεν μÏοÏεί να καθοÏιÏÏεί ο ανÏίÏÏÏοÏοÏ"
#: ../lib/gmath/la.c:577
msgid "Unable to allocate space for matrix"
-msgstr "Áäõíáìßá åýñåóçò ÷þñïõ ãéá ôïí ðßíáêá"
+msgstr "ÎδÏ
ναμία εÏÏεÏÎ·Ï ÏÏÏοÏ
για Ïον Ïίνακα"
#: ../lib/gmath/la.c:594
msgid "Matrix is singular"
-msgstr "Ï ðßíáêáò åßíáé ìïíáäéáßïò"
+msgstr "Î ÏÎ¯Î½Î±ÎºÎ±Ï ÎµÎ¯Î½Î±Î¹ μοναδιαίοÏ"
#: ../lib/gmath/la.c:599
msgid "Problem in LA procedure."
-msgstr "Ôï ðñüâëçìá åßíáé ìßá LA äéáäéêáóßá"
+msgstr "Το ÏÏÏβλημα είναι μία LA διαδικαÏία"
#: ../lib/gmath/la.c:687
msgid "Element array has not been allocated"
-msgstr "Ôï âáóéêü äéÜíõóìá äåí Ý÷åé ìåôáöåñèåß"
+msgstr "Το βαÏÎ¹ÎºÏ Î´Î¹Î¬Î½Ï
Ïμα δεν ÎÏει μεÏαÏεÏθεί"
#: ../lib/gmath/la.c:692
msgid "Specified element is outside array bounds"
-msgstr "Ôá êáèïñéóìÝíá óôïé÷åßá åßíáé Ýîù áðü ôá äéáíýóìáôá"
+msgstr "Τα καθοÏιÏμÎνα ÏÏοιÏεία είναι ÎÎ¾Ï Î±ÏÏ Ïα διανÏÏμαÏα"
#: ../lib/gmath/la.c:746
msgid "Specified matrix column index is outside range"
-msgstr "Ç óôÞëç ôïõ ðßíáêá åßíáé Ýîù áðü ôá üñéá"
+msgstr "Î ÏÏήλη ÏοÏ
Ïίνακα είναι ÎÎ¾Ï Î±ÏÏ Ïα ÏÏια"
#: ../lib/gmath/la.c:751 ../lib/gmath/la.c:792 ../lib/gmath/la.c:1105
#: ../lib/gmath/la.c:1157 ../lib/gmath/la.c:1232
msgid "Matrix is not initialised"
-msgstr "Ï ðßíáêáò äåí îåêßíçóå"
+msgstr "Î ÏÎ¯Î½Î±ÎºÎ±Ï Î´ÎµÎ½ ξεκίνηÏε"
#: ../lib/gmath/la.c:756 ../lib/gmath/la.c:797
msgid "Could not allocate space for vector structure"
-msgstr "Áäõíáìßá êáèïñéóìïý ÷þñïõ ãéá ôç äïìÞ ôïõ äéáíýóìáôïò"
+msgstr "ÎδÏ
ναμία καθοÏιÏÎ¼Î¿Ï ÏÏÏοÏ
για Ïη δομή ÏοÏ
διανÏÏμαÏοÏ"
#: ../lib/gmath/la.c:787
msgid "Specified matrix row index is outside range"
-msgstr "Ï äåßêôçò ãñáììÞò ôïõ êáèïñéóìÝíïõ ðßíáêá åßíáé Ýîù áðü ôá üñéá"
+msgstr "ΠδείκÏÎ·Ï Î³ÏÎ±Î¼Î¼Î®Ï ÏοÏ
καθοÏιÏμÎνοÏ
#: ../lib/gmath/la.c:827
msgid "Specified row index is outside range"
-msgstr "Ç ãñáììÞ ôïõ êáèïñéóìÝíïõ ðßíáêá åßíáé Ýîù áðü ôá üñéá"
+msgstr "ΠγÏαμμή ÏοÏ
καθοÏιÏμÎνοÏ
#: ../lib/gmath/la.c:832
msgid "Specified column index is outside range"
msgstr ""
-"Ï äåßêôçò ãñáììÞ ôçò óôÞëçò ôïõ êáèïñéóìÝíïõ ðßíáêá åßíáé Ýîù áðü ôá üñéá"
+"ΠδείκÏÎ·Ï Î³Ïαμμή ÏÎ·Ï ÏÏÎ®Î»Î·Ï ÏοÏ
καθοÏιÏμÎνοÏ
#: ../lib/gmath/la.c:852
msgid "Unknown vector type."
-msgstr "¶ãíùóôï ôýðïò äéáíýóìáôïò"
+msgstr "ÎγνÏÏÏο ÏÏÏÎ¿Ï Î´Î¹Î±Î½ÏÏμαÏοÏ"
#: ../lib/gmath/la.c:977
msgid "Output vector is uninitialized"
-msgstr "Ôï åîáãþìåíï äéÜíõóìá äåí Ý÷åé îåêéíÞóåé"
+msgstr "Το εξαγÏμενο διάνÏ
Ïμα δεν ÎÏει ξεκινήÏει"
#: ../lib/gmath/la.c:982
msgid "Vectors are not of the same type"
-msgstr "Ôá äéáíýóìáôá äåí åßíáé ôïõ ßäéïõ ôýðïõ"
+msgstr "Τα διανÏÏμαÏα δεν είναι ÏοÏ
ίδιοÏ
ÏÏÏοÏ
#: ../lib/gmath/la.c:987
msgid "Output vector is of incorrect type"
-msgstr "Ôï åîáãþìåíï äéÜíõóìá äåí Ý÷åé óùóôÞ ôýðï"
Ïμα δεν ÎÏει ÏÏÏÏή ÏÏÏο"
#: ../lib/gmath/la.c:992
msgid "Matrices not allowed"
-msgstr "Ïé ðßíáêåò äåí åðéôñÝðïíôáé"
+msgstr "Îι ÏÎ¯Î½Î±ÎºÎµÏ Î´ÎµÎ½ εÏιÏÏÎÏονÏαι"
#: ../lib/gmath/la.c:998
msgid "Vectors have differing dimensions"
-msgstr "Ôá äéáíýóìáôá Ý÷ïõí äéáöïñåôéêÝò äéáóôÜóåéò"
+msgstr "Τα διανÏÏμαÏα ÎÏοÏ
ν διαÏοÏεÏικÎÏ Î´Î¹Î±ÏÏάÏειÏ"
#: ../lib/gmath/la.c:1004
msgid "Output vector has incorrect dimension"
-msgstr "Ôï åîáãþìåíï äéÜíõóìá Ý÷åé ëÜèïò äéáóôÜóåéò"
Ïμα ÎÏει Î»Î¬Î¸Î¿Ï Î´Î¹Î±ÏÏάÏειÏ"
#: ../lib/gmath/la.c:1050
msgid "Vector dimensions out of range"
-msgstr "Ïé äéáóôÜóåéò ôïõ ðßíáêá åßíáé Ýîù áðü ôá üñéá"
#: ../lib/gmath/la.c:1055
msgid "Row/column out of range"
-msgstr "ÃñáììÞ/óôÞëç Ýîù áðü ôá üñéá"
+msgstr "ÎÏαμμή/ÏÏήλη ÎÎ¾Ï Î±ÏÏ Ïα ÏÏια"
#: ../lib/gmath/la.c:1270
msgid "Vector structure is not initialised"
-msgstr "Ç äïìÞ ôïõ äéáíýóìáôïò äåí Ý÷åé îåêéíÞóåé"
+msgstr "Πδομή ÏοÏ
διανÏÏμαÏÎ¿Ï Î´ÎµÎ½ ÎÏει ξεκινήÏει"
#: ../lib/gmath/la.c:1391 ../lib/gmath/la.c:1399 ../lib/gmath/la.c:1404
msgid "Input format error"
-msgstr "ÓöÜëìá êáôÜ ôçí åéóáãùãÞ óôïé÷åßùí"
+msgstr "ΣÏάλμα καÏά Ïην ειÏαγÏγή ÏÏοιÏείÏν"
#: ../lib/g3d/g3dhistory.c:42 ../lib/gis/history.c:132
#, c-format
msgid "can't get history information for [%s] in mapset [%s]"
msgstr ""
-"äåí ìðïñåß íá ðÜñåé ðëçñïöïñßåò ãéá ôï éóôïñéêü ôïõ [%s] óôá ÷áñôïãñáöéêÜ "
-"äåäïìÝíá[%s]"
+"δεν μÏοÏεί να ÏάÏει ÏληÏοÏοÏÎ¯ÎµÏ Î³Î¹Î± Ïο ιÏÏοÏÎ¹ÎºÏ ÏοÏ
[%s] ÏÏα ÏαÏÏογÏαÏικά "
+"δεδομÎνα[%s]"
#: ../lib/g3d/g3dopen.c:20
msgid "G3d_openCellOldNoHeader: error in G3d_maskOpenOld"
-msgstr "G3d_openCellOldNoHeader: óöÜëìá óôï G3d_maskOpenOld"
+msgstr "G3d_openCellOldNoHeader: ÏÏάλμα ÏÏο G3d_maskOpenOld"
#: ../lib/g3d/g3dopen.c:26
msgid "G3d_openCellOldNoHeader: error in G3d_malloc"
-msgstr "G3d_openCellOldNoHeader: óöÜëìá óôï G3d_malloc"
+msgstr "G3d_openCellOldNoHeader: ÏÏάλμα ÏÏο G3d_malloc"
#: ../lib/g3d/g3dopen.c:45
msgid "G3d_openCellOldNoHeader: error in G_open_old"
-msgstr "G3d_openCellOldNoHeader: óöÜëìá óôï G_open_old"
+msgstr "G3d_openCellOldNoHeader: ÏÏάλμα ÏÏο G_open_old"
#: ../lib/g3d/g3dopen.c:99
msgid "G3d_openCellOld: error in G3d_openCellOldNoHeader"
-msgstr "3d_openCellOld: óöÜëìá óôï G3d_openCellOldNoHeader"
+msgstr "3d_openCellOld: ÏÏάλμα ÏÏο G3d_openCellOldNoHeader"
#: ../lib/g3d/g3dopen.c:104
msgid "G3d_openCellOld: can't rewind file"
-msgstr "G3d_openCellOld: äåí åßíáé äõíáôÞ ç áíáäßðëùóç ôïõ áñ÷åßïõ"
+msgstr "G3d_openCellOld: δεν είναι δÏ
ναÏή η αναδίÏλÏÏη ÏοÏ
αÏÏείοÏ
#: ../lib/g3d/g3dopen.c:116
msgid "G3d_openCellOld: error in G3d_readHeader"
-msgstr "G3d_openCellOld: óöÜëìá óôï G3d_readHeader"
+msgstr "G3d_openCellOld: ÏÏάλμα ÏÏο G3d_readHeader"
#: ../lib/g3d/g3dopen.c:124
msgid "G3d_openCellOld: projection does not match window projection"
-msgstr "G3d_openCellOld: ç ðñïâïëÞ äåí ôáéñéÜæåé ìå ôçí ðñïâïëÞ ôïõ ðáñáèýñïõ"
+msgstr "G3d_openCellOld: η ÏÏοβολή δεν ÏαιÏιάζει με Ïην ÏÏοβολή ÏοÏ
ÏαÏαθÏÏοÏ
#: ../lib/g3d/g3dopen.c:128
msgid "G3d_openCellOld: zone does not match window zone"
-msgstr "G3d_openCellOld: ç æþíç äåí ôáéñéÜæåé ìå ôç æþíç ôïõ ðáñáèýñïõ"
+msgstr "G3d_openCellOld: η ζÏνη δεν ÏαιÏιάζει με Ïη ζÏνη ÏοÏ
ÏαÏαθÏÏοÏ
#: ../lib/g3d/g3dopen.c:140 ../lib/g3d/g3dopen.c:157
msgid "G3d_openCellOld: can't read header"
msgstr ""
-"G3d_openCellOld: äåí åßíáé äõíáôÞ ç áíÜãíùóç ôçò êåöáëßäáò áñ÷åßïõ (header)"
+"G3d_openCellOld: δεν είναι δÏ
ναÏή η ανάγνÏÏη ÏÎ·Ï ÎºÎµÏÎ±Î»Î¯Î´Î±Ï Î±ÏÏείοÏ
(header)"
#: ../lib/g3d/g3dopen.c:146
msgid "G3d_openCellOld: index does not fit into long"
@@ -1585,81 +1585,81 @@
#: ../lib/g3d/g3dopen.c:150
msgid "G3d_openCellOld: error in G3d_malloc"
-msgstr "G3d_openCellOld: óöÜëìá óôï G3d_malloc"
+msgstr "G3d_openCellOld: ÏÏάλμα ÏÏο G3d_malloc"
#: ../lib/g3d/g3dopen.c:176
msgid "G3d_openCellOld: error in G3d_fillHeader"
-msgstr "G3d_openCellOld: óöÜëìá óôï G3d_fillHeader"
+msgstr "G3d_openCellOld: ÏÏάλμα ÏÏο G3d_fillHeader"
#: ../lib/g3d/g3dopen.c:223
msgid "G3d_openCellNew: error in G3d_maskOpenOld"
-msgstr "G3d_openCellNew: óöÜëìá óôï G3d_maskOpenOld"
+msgstr "G3d_openCellNew: ÏÏάλμα ÏÏο G3d_maskOpenOld"
#: ../lib/g3d/g3dopen.c:232
msgid "G3d_openCellNew: error in G3d_malloc"
-msgstr "G3d_openCellNew: óöÜëìá óôï G3d_malloc"
+msgstr "G3d_openCellNew: ÏÏάλμα ÏÏο G3d_malloc"
#: ../lib/g3d/g3dopen.c:245
msgid "G3d_openCellNew: could not open file"
-msgstr "G3d_openCellNew: äåí ìðïñåß íá áíïßîåé ôï áñ÷åßï"
+msgstr "G3d_openCellNew: δεν μÏοÏεί να ανοίξει Ïο αÏÏείο"
#: ../lib/g3d/g3dopen.c:290 ../lib/g3d/g3dopen.c:295
msgid "G3d_openCellNew: can't write header"
-msgstr "G3d_openCellNew: äåí ìðïñåß íá ãñáöôåß ç êåöáëßäá (header)"
+msgstr "G3d_openCellNew: δεν μÏοÏεί να γÏαÏÏεί η κεÏαλίδα (header)"
#: ../lib/g3d/g3dopen.c:318
msgid "G3d_openCellNew: error in G3d_fillHeader"
-msgstr "G3d_openCellNew: óöÜëìá óôï G3d_fillHeader"
+msgstr "G3d_openCellNew: ÏÏάλμα ÏÏο G3d_fillHeader"
#: ../lib/g3d/g3dparam.c:52
msgid "Data type used in the output file"
-msgstr "Ôýðïò äåäïìÝíùí ðïõ ÷ñçóéìïðïéÞèçêå óôï áñ÷åßï åîáãùãÞò"
+msgstr "ΤÏÏÎ¿Ï Î´ÎµÎ´Î¿Î¼ÎνÏν ÏοÏ
ÏÏηÏιμοÏοιήθηκε ÏÏο αÏÏείο εξαγÏγήÏ"
#: ../lib/g3d/g3dparam.c:61
msgid "Precision used in the output file (default, max, or 0 to 52)"
msgstr ""
-"Áêñßâåéá ðïõ ÷ñçóéìïðïéÞèçêå óôï áñ÷åßï åîáãùãÞò (ðñïåðéëåãìÝíï, max, Þ 0 ìå "
+"ÎκÏίβεια ÏοÏ
ÏÏηÏιμοÏοιήθηκε ÏÏο αÏÏείο εξαγÏÎ³Î®Ï (ÏÏοεÏιλεγμÎνο, max, ή 0 με "
"52)"
#: ../lib/g3d/g3dparam.c:71
msgid "The compression method used in the output file"
-msgstr "Ç ìÝèïäïò óõìðßåóçò ðïõ ÷ñçóéìïðïéÞèçêå óôï áñ÷åßï åîáãùãÞò"
+msgstr "ΠμÎÎ¸Î¿Î´Î¿Ï ÏÏ
μÏίεÏÎ·Ï ÏοÏ
#: ../lib/g3d/g3dparam.c:81
msgid "The dimensions of the tiles used in the output file"
-msgstr "Ïé äéáóôÜóåéò ôùí tiles ðïõ ÷ñçóéìïðïéÞèçêáí óôï áñ÷åßï åîáãùãÞò"
+msgstr "Îι διαÏÏάÏÎµÎ¹Ï ÏÏν tiles ÏοÏ
ÏÏηÏιμοÏοιήθηκαν ÏÏο αÏÏείο εξαγÏγήÏ"
#: ../lib/g3d/g3dparam.c:116
msgid "G3d_getStandard3dParams: precision value invalid"
-msgstr "G3d_getStandard3dParams: ç ôéìÞ áêñßâåéáò åßíáé ìç åðéôñåðôÞ"
+msgstr "G3d_getStandard3dParams: η Ïιμή ακÏÎ¯Î²ÎµÎ¹Î±Ï ÎµÎ¯Î½Î±Î¹ μη εÏιÏÏεÏÏή"
#: ../lib/g3d/g3dparam.c:149
msgid "G3d_getStandard3dParams: tile dimension value invalid"
-msgstr "G3d_getStandard3dParams: ç ôéìÞ tile åßíáé ìç åðéôñåðôÞ"
+msgstr "G3d_getStandard3dParams: η Ïιμή tile είναι μη εÏιÏÏεÏÏή"
#: ../lib/g3d/g3dparam.c:173
msgid "Window replacing the default"
-msgstr "Ôï ðáñÜèõñï áíôéêáèéóôÜ ôï ðñïåðéëåãìÝíï"
+msgstr "Το ÏαÏάθÏ
Ïο ανÏικαθιÏÏά Ïο ÏÏοεÏιλεγμÎνο"
#: ../lib/gis/debug.c:74
#, c-format
msgid "Cannot open debug file '%s'"
-msgstr "Äåí Þôáí äõíáôü ôï Üíïéãìá ôïõ áñ÷åßïõ áðïóöáëìÜôùóçò (debug) '%s'"
+msgstr "Îεν ήÏαν δÏ
ναÏÏ Ïο άνοιγμα ÏοÏ
αÏÏείοÏ
αÏοÏÏαλμάÏÏÏÎ·Ï (debug) '%s'"
#: ../lib/gis/get_projname.c:31
#, c-format
msgid "%s not found"
-msgstr "%s äåí âñÝèçêå"
+msgstr "%s δεν βÏÎθηκε"
#: ../lib/gis/get_projname.c:34
#, c-format
msgid "ERROR in reading %s"
-msgstr "ÓÖÁËÌÁ óôï äéÜâáóìá %s"
+msgstr "ΣΦÎÎÎÎ ÏÏο διάβαÏμα %s"
#: ../lib/gis/get_projname.c:38 ../lib/gis/get_datum_name.c:69
#: ../lib/gis/get_ell_name.c:31
msgid "Cannot open temp file"
-msgstr "Äåí ìðïñåß íá áíïßîåé ôï ðñïóùñéíü áñ÷åßï"
+msgstr "Îεν μÏοÏεί να ανοίξει Ïο ÏÏοÏÏÏÎ¹Î½Ï Î±ÏÏείο"
#: ../lib/gis/get_projname.c:49
#, c-format
@@ -1670,12 +1670,12 @@
msgstr ""
"\n"
"\n"
-"Ðáñáêáëþ ðñïóäéïñßóôå üíïìá ðñïâïëÞò\n"
+"ΠαÏÎ±ÎºÎ±Î»Ï ÏÏοÏδιοÏίÏÏε Ïνομα ÏÏοβολήÏ\n"
#: ../lib/gis/get_projname.c:51
#, c-format
msgid "Enter 'list' for the list of available projections\n"
-msgstr "ÐáôÞóôå 'list' ãéá äéáèÝóéìåò ðñïâïëÝò\n"
+msgstr "ΠαÏήÏÏε 'list' για διαθÎÏÎ¹Î¼ÎµÏ ÏÏοβολÎÏ\n"
#: ../lib/gis/get_projname.c:74
#, c-format
@@ -1684,125 +1684,125 @@
"invalid projection\n"
msgstr ""
"\n"
-"ËáíèáóìÝíç ðñïâïëÞ\n"
+"ÎανθαÏμÎνη ÏÏοβολή\n"
#: ../lib/gis/proj2.c:46
msgid "Latitude-Longitude"
-msgstr "Ãåùãñáöéêü ðëÜôïò - Ãåùãñáöéêü ìÞêïò"
+msgstr "ÎεÏγÏαÏÎ¹ÎºÏ ÏλάÏÎ¿Ï - ÎεÏγÏαÏÎ¹ÎºÏ Î¼Î®ÎºÎ¿Ï"
#: ../lib/gis/proj2.c:48
msgid "Other Projection"
-msgstr "¶ëëç ðñïâïëÞ"
+msgstr "Îλλη ÏÏοβολή"
#: ../lib/gis/color_rules.c:110
msgid "syntax error"
-msgstr "Óõíôáêôéêü ëÜèïò"
+msgstr "ΣÏ
νÏακÏÎ¹ÎºÏ Î»Î¬Î¸Î¿Ï"
#: ../lib/gis/color_rules.c:112
msgid "R/G/B not in range 0-255"
-msgstr "R/G/B äåí åßíáé óôï åýñïò 0-255"
+msgstr "R/G/B δεν είναι ÏÏο εÏÏÎ¿Ï 0-255"
#: ../lib/gis/color_rules.c:114
msgid "invalid color name"
-msgstr "ÅóöáëìÝíï üíïìá ÷ñþìáôïò"
+msgstr "ÎÏÏαλμÎνο Ïνομα ÏÏÏμαÏοÏ"
#: ../lib/gis/color_rules.c:116
msgid "percentage not in range 0-100"
-msgstr "Ôï ðïóïóôü äåí åßíáé óôï åýñïò 0-100"
+msgstr "Το ÏοÏοÏÏÏ Î´ÎµÎ½ είναι ÏÏο εÏÏÎ¿Ï 0-100"
#: ../lib/gis/color_rules.c:118
msgid "invalid value"
-msgstr "ÅóöáëìÝíç ôéìÞ"
+msgstr "ÎÏÏαλμÎνη Ïιμή"
#: ../lib/gis/color_rules.c:120
msgid "unknown error"
-msgstr "¶ãíùóôï ëÜèïò"
+msgstr "ÎγνÏÏÏο λάθοÏ"
#: ../lib/gis/color_rules.c:151
#, c-format
msgid "bad rule (%s): [%s]"
-msgstr "ÅóöáëìÝíïò êáíüíáò (%s): [%s]"
+msgstr "ÎÏÏαλμÎÎ½Î¿Ï ÎºÎ±Î½ÏÎ½Î±Ï (%s): [%s]"
#: ../lib/gis/color_rules.c:265
#, fuzzy, c-format
msgid "Unable to load color rules <%s>"
-msgstr "Áäõíáìßá êëåéóßìáôïò ôïõ äéáíýóìáôïò <%s>"
+msgstr "ÎδÏ
διανÏÏμαÏÎ¿Ï <%s>"
#: ../lib/gis/seek.c:52 ../lib/gis/seek.c:58
#, fuzzy
msgid "Unable to seek"
+msgstr "ÎδÏ
ναμία focus"
#: ../lib/gis/seek.c:56
#, fuzzy
msgid "Seek offset out of range"
#: ../lib/gis/color_read.c:116
#, c-format
msgid "color support for [%s] in mapset [%s] %s"
-msgstr "÷ñùìáôéêÞ õðïóôÞñéîç ãéá [%s] óôï mapset [%s] %s"
+msgstr "ÏÏÏμαÏική Ï
ÏοÏÏήÏιξη για [%s] ÏÏο mapset [%s] %s"
#: ../lib/gis/put_title.c:29
#, c-format
msgid "category information for [%s] in [%s] missing or invalid"
-msgstr "Ç ðëçñïöïñßá êáôçãïñßáò ãéá [%s] in [%s] ëåßðåé Þ åßíáé ëáíèáóìÝíç"
+msgstr "Î ÏληÏοÏοÏία καÏηγοÏÎ¯Î±Ï Î³Î¹Î± [%s] in [%s] λείÏει ή είναι λανθαÏμÎνη"
#: ../lib/gis/put_title.c:39
#, c-format
msgid "G_put_title - can't create a temp file"
-msgstr "G_put_title - äåí åßíáé äõíáôÞ ç äçìéïõñãßá åíüò ðñïóùñéíïý áñ÷åßïõ"
+msgstr "G_put_title - δεν είναι δÏ
ναÏή η δημιοÏ
Ïγία ενÏÏ ÏÏοÏÏÏÎ¹Î½Î¿Ï Î±ÏÏείοÏ
#: ../lib/gis/put_title.c:56
#, c-format
msgid "category information for [%s] in [%s] invalid"
-msgstr "Ç ðëçñïöïñßá êáôçãïñßáò ãéá [%s] óôï [%s] åßíáé åóöáëìÝíç"
+msgstr "Î ÏληÏοÏοÏία καÏηγοÏÎ¯Î±Ï Î³Î¹Î± [%s] ÏÏο [%s] είναι εÏÏαλμÎνη"
#: ../lib/gis/put_title.c:64
#, c-format
msgid "G_put_title - can't reopen temp file"
-msgstr "G_put_title - äåí åßíáé äõíáôÞ ôï îáíáÜíïéãìá ôïõ ðñïóùñéíïý áñ÷åßïõ"
ναÏή Ïο ξαναάνοιγμα ÏοÏ
#: ../lib/gis/put_title.c:72
#, c-format
msgid "can't write category information for [%s] in [%s]"
-msgstr "Äåí åßíáé äõíáôÞ ç åããñáäÞ ðëçñïöïñéþí êáôçãïñßáòãéá [%s] óôï [%s]"
ναÏή η εγγÏαδή ÏληÏοÏοÏιÏν καÏηγοÏίαÏγια [%s] ÏÏο [%s]"
#: ../lib/gis/get_row.c:46 ../lib/gis/get_row.c:1049
#, c-format
msgid "Reading raster map <%s@%s> request for row %d is outside region"
msgstr ""
-"Ôï äéÜâáóìá ôïõ ñÜóôåñ ÷Üñôç <%s@%s> êëÞóç ãéá ãñáììÞ %d åßíáé Ýîù áðü ôçí "
-"ðåñéï÷Þ"
+"Το διάβαÏμα ÏοÏ
ÏάÏÏÎµÏ ÏάÏÏη <%s@%s> κλήÏη για γÏαμμή %d είναι ÎÎ¾Ï Î±ÏÏ Ïην "
+"ÏεÏιοÏή"
#: ../lib/gis/get_row.c:324
#, c-format
msgid "cell_values_float: xdr_float failed for index %d"
-msgstr "cell_values_float: xdr_float áðÝôõ÷å ãéá ôïí äåßêôç %d"
+msgstr "cell_values_float: xdr_float αÏÎÏÏ
Ïε για Ïον δείκÏη %d"
#: ../lib/gis/get_row.c:365
#, c-format
msgid "cell_values_double: xdr_double failed for index %d"
-msgstr "cell_values_double: xdr_double áðÝôõ÷å ãéá ôïí äåßêôç %d"
+msgstr "cell_values_double: xdr_double αÏÎÏÏ
#: ../lib/gis/get_row.c:621
#, c-format
msgid "Error reading compressed map <%s@%s>, row %d"
-msgstr "ÓöÜëìá êáôÜ ôçí áíÜãíùóç óõìðéåóìÝíïõ ÷Üñôç <%s@%s>, ãñáììÞ %d"
+msgstr "ΣÏάλμα καÏά Ïην ανάγνÏÏη ÏÏ
μÏιεÏμÎνοÏ
ÏάÏÏη <%s@%s>, γÏαμμή %d"
#: ../lib/gis/get_row.c:624
#, c-format
msgid "Error reading map <%s@%s>, row %d"
-msgstr "ÓöÜëìá áíÜãíùóçò ÷Üñôç <%s@%s>, ãñáììÞ %d"
+msgstr "ΣÏάλμα ανάγνÏÏÎ·Ï ÏάÏÏη <%s@%s>, γÏαμμή %d"
#: ../lib/gis/get_row.c:1031 ../lib/gis/get_row.c:1036
#, c-format
msgid "Error reading null row %d"
-msgstr "ÓöÜëìá áíÜãíùóçò êåíÞò ãñáììÞò %d"
+msgstr "ΣÏάλμα ανάγνÏÏÎ·Ï ÎºÎµÎ½Î®Ï Î³ÏÎ±Î¼Î¼Î®Ï %d"
#: ../lib/gis/get_row.c:1115
msgid "Unable to realloc buffer"
-msgstr "Áäõíáìßá to realloc buffer"
+msgstr "ÎδÏ
ναμία to realloc buffer"
#: ../lib/gis/gisinit.c:54 ../lib/gis/gisinit.c:90
msgid ""
@@ -1813,120 +1813,120 @@
#: ../lib/gis/gisinit.c:63
#, c-format
msgid "MAPSET %s - permission denied"
-msgstr "MAPSET %s - äåí åðéôñÝðåôáé ç ðñüóâáóç"
+msgstr "MAPSET %s - δεν εÏιÏÏÎÏεÏαι η ÏÏÏÏβαÏη"
#: ../lib/gis/gisinit.c:66
#, fuzzy, c-format
msgid "MAPSET %s not found at %s"
-msgstr "MAPSET %s äåí âñÝèçêå"
+msgstr "MAPSET %s δεν βÏÎθηκε"
#: ../lib/gis/gisinit.c:110
msgid "System not initialized. Programmer forgot to call G_gisinit()."
msgstr ""
-"Ôï óýóôçìá äåí Ý÷åé áñ÷éêïðïéçèåß. Ï ðñïãñáììáôéóôÞò îÝ÷áóåé íá êáëÝóåé "
+"Το ÏÏÏÏημα δεν ÎÏει αÏÏικοÏοιηθεί. Î ÏÏογÏαμμαÏιÏÏÎ®Ï Î¾ÎÏαÏει να καλÎÏει "
"G_gisinit()."
#: ../lib/gis/mapset_msc.c:60
#, fuzzy, c-format
msgid "Unable to make mapset element %s (%s): %s"
-msgstr "Áäõíáìßá äçìéïõñãßáò mapset óôïé÷åßïõ %s (%s)"
+msgstr "ÎδÏ
ναμία δημιοÏ
ÏÎ³Î¯Î±Ï mapset ÏÏοιÏείοÏ
%s (%s)"
#: ../lib/gis/mapset_msc.c:64
#, fuzzy, c-format
msgid "Unable to access mapset element %s (%s): %s"
+msgstr "ÎδÏ
ναμία δημιοÏ
%s (%s)"
#: ../lib/gis/reclass.c:145
#, c-format
msgid "Too many reclass categories for [%s in %s]"
-msgstr "ÐÜñá ðïëëÝò êáôçãïñéïðïéÞóåéò ãéá [%s in %s]"
+msgstr "ΠάÏα ÏολλÎÏ ÎºÎ±ÏηγοÏιοÏοιήÏÎµÎ¹Ï Î³Î¹Î± [%s in %s]"
#: ../lib/gis/reclass.c:148
#, c-format
msgid "Illegal reclass format in header file for [%s in %s]"
-msgstr "ìç áðïäåêôü öïñìÜô êáôçãïñéïðïÞóåùí óôï êåöáëéêü áñ÷åßï ãéá [%s in %s]"
+msgstr "μη αÏοδεκÏÏ ÏοÏÎ¼Î¬Ï ÎºÎ±ÏηγοÏιοÏοήÏεÏν ÏÏο κεÏÎ±Î»Î¹ÎºÏ Î±ÏÏείο για [%s in %s]"
#: ../lib/gis/reclass.c:238
msgid "Illegal reclass request"
-msgstr "Ìç áðïäåêôÞ åíôïëÞ êáôçãïñéïðïßçóçò"
+msgstr "Îη αÏοδεκÏή ενÏολή καÏηγοÏιοÏοίηÏηÏ"
#: ../lib/gis/reclass.c:243
msgid "Illegal reclass type"
-msgstr "Ìç áðïäåêôüò ôýðïò êáôçãïñéïðïßçóçò"
+msgstr "Îη αÏοδεκÏÏÏ ÏÏÏÎ¿Ï ÎºÎ±ÏηγοÏιοÏοίηÏηÏ"
#: ../lib/gis/reclass.c:249
#, c-format
msgid "Unable to create header file for [%s in %s]"
-msgstr "Áäõíáìßá äçìéïõñãßáò êåöáëéêïý áñ÷åßïõ ãéá [%s in %s]"
+msgstr "ÎδÏ
ναμία δημιοÏ
ÏÎ³Î¯Î±Ï ÎºÎµÏÎ±Î»Î¹ÎºÎ¿Ï Î±ÏÏείοÏ
για [%s in %s]"
#: ../lib/gis/reclass.c:297
#, c-format
msgid "Unable to create dependency file in [%s in %s]"
-msgstr "Áäõíáìßá äçìéïõñãßáò áñ÷åßïõ åîÜñôçóçò ãéá óôï [%s in %s]"
+msgstr "ÎδÏ
ναμία δημιοÏ
ÏÎ³Î¯Î±Ï Î±ÏÏείοÏ
εξάÏÏηÏÎ·Ï Î³Î¹Î± ÏÏο [%s in %s]"
#: ../lib/gis/put_cellhd.c:26
#, c-format
msgid "Unable to create header file for [%s]"
-msgstr "Áäõíáìßá äçìéïõñãßáò êåöáëéêïý áñ÷åßïõ ãéá [%s]"
+msgstr "ÎδÏ
ναμία δημιοÏ
για [%s]"
#: ../lib/gis/ls.c:96
#, c-format
msgid "Unable to open directory %s"
-msgstr "Áäõíáìßá áíïßãìáôïò öáêÝëëïõ %s"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï ÏακÎλλοÏ
%s"
#: ../lib/gis/datum.c:160
#, c-format
msgid "unable to open datum table file: %s"
-msgstr "Áäõíáìßá áíïßãìáôïò áñ÷åßï ðßíáêá datum: %s"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï Î±ÏÏείο Ïίνακα datum: %s"
#: ../lib/gis/datum.c:181
#, c-format
msgid "error in datum table file, line %d"
-msgstr "ÓöÜëìá óôï áñ÷åßï ðßíáêá datum, ãñáììÞ %d"
+msgstr "ΣÏάλμα ÏÏο αÏÏείο Ïίνακα datum, γÏαμμή %d"
#: ../lib/gis/ask.c:341
msgid "to cancel request"
-msgstr "ãéá áêýñùóç ôçò åíôïëÞò"
+msgstr "για ακÏÏÏÏη ÏÎ·Ï ÎµÎ½ÏολήÏ"
#: ../lib/gis/ask.c:390
#, c-format
msgid "Enter a new %s file name"
-msgstr "Äþóôå Ýíá íÝï %s üíïìá áñ÷åßïõ"
+msgstr "ÎÏÏÏε Îνα νÎο %s Ïνομα αÏÏείοÏ
#: ../lib/gis/ask.c:396
#, c-format
msgid "Enter the name of an existing %s file"
-msgstr "Äþóôå ôï üíïìá åíüò õðÜñ÷ïíôïò %s áñ÷åßïõ"
+msgstr "ÎÏÏÏε Ïο Ïνομα ενÏÏ Ï
ÏάÏÏονÏÎ¿Ï %s αÏÏείοÏ
#: ../lib/gis/ask.c:401
#, c-format
msgid "Enter %s file name"
-msgstr "Äþóôå %s üíïìá áñ÷åßïõ"
+msgstr "ÎÏÏÏε %s Ïνομα αÏÏείοÏ
#: ../lib/gis/ask.c:421
#, c-format
msgid "Enter 'list' for a list of existing %s files\n"
-msgstr "Äþóôå 'list' ãéá ôç ëßóôá ôùí õðáñ÷üíôùí %s áñ÷åßùí\n"
+msgstr "ÎÏÏÏε 'list' για Ïη λίÏÏα ÏÏν Ï
ÏαÏÏÏνÏÏν %s αÏÏείÏν\n"
#: ../lib/gis/ask.c:424
#, c-format
msgid "Enter 'list -f' for "
-msgstr "Äþóôå 'list -f' ãéá "
+msgstr "ÎÏÏÏε 'list -f' για "
#: ../lib/gis/ask.c:426
#, c-format
msgid "a list %s"
-msgstr "ìßá ëßóôá %s"
+msgstr "μία λίÏÏα %s"
#: ../lib/gis/ask.c:428
#, c-format
msgid "an extended list"
-msgstr "ìßá åêôåôáìÝíç ëßóôá"
+msgstr "μία εκÏεÏαμÎνη λίÏÏα"
#: ../lib/gis/ask.c:432
#, c-format
msgid "Hit RETURN %s\n"
-msgstr "ÐáôÞóôå RETURN %s\n"
+msgstr "ΠαÏήÏÏε RETURN %s\n"
#: ../lib/gis/ask.c:452 ../lib/gis/ask.c:557 ../lib/gis/ask.c:577
#, c-format
@@ -1935,7 +1935,7 @@
"** %s - not found **\n"
msgstr ""
"\n"
-"** %s - äåí âñÝèçêå **\n"
+"** %s - δεν βÏÎθηκε **\n"
#: ../lib/gis/ask.c:459 ../lib/gis/ask.c:544
#, c-format
@@ -1944,7 +1944,7 @@
"** %s exists. ok to overwrite? "
msgstr ""
"\n"
-"** %s õðÜñ÷åé, ÏÊ íá ôï áíôéêáôáóôÞóù? "
+"** %s Ï
ÏάÏÏει, ÎΠνα Ïο ανÏικαÏαÏÏήÏÏ? "
#: ../lib/gis/ask.c:506
#, c-format
@@ -1953,7 +1953,7 @@
"**<%s> illegal name **\n"
msgstr ""
"\n"
-"**<%s> ìç åðéôñåðôü üíïìá **\n"
+"**<%s> μη εÏιÏÏεÏÏÏ Ïνομα **\n"
#: ../lib/gis/ask.c:518
#, c-format
@@ -1962,7 +1962,7 @@
"** %s - illegal request **\n"
msgstr ""
"\n"
-"** %s - ìç åðéôñåðôÞ åíôïëÞ **\n"
+"** %s - μη εÏιÏÏεÏÏή ενÏολή **\n"
#: ../lib/gis/ask.c:533
#, c-format
@@ -1971,51 +1971,51 @@
"** %s - exists, select another name **\n"
msgstr ""
"\n"
-"** %s - õðÜñ÷åé, äþóôå Üëëï üíïìá **\n"
+"** %s - Ï
ÏάÏÏει, δÏÏÏε άλλο Ïνομα **\n"
#: ../lib/gis/ask.c:561
msgid "ask: can't happen"
-msgstr "ask: äåí ìðïñåß íá ãßíåé"
+msgstr "ask: δεν μÏοÏεί να γίνει"
#: ../lib/gis/cats.c:381
#, c-format
msgid "category support for [%s] in mapset [%s] %s"
-msgstr "ÕðïóôÞñéîç êáôçãïñéþí ãéá [%s] óôï mapset [%s] %s"
+msgstr "Î¥ÏοÏÏήÏιξη καÏηγοÏιÏν για [%s] ÏÏο mapset [%s] %s"
#: ../lib/gis/cats.c:417
#, c-format
msgid "category support for vector map [%s] in mapset [%s] %s"
-msgstr "ÕðïóôÞñéîç êáôçãïñéþí ãéá äéáíõóìáôéêü ÷Üñôç[%s] óôï mapset [%s] %s"
+msgstr "Î¥ÏοÏÏήÏιξη καÏηγοÏιÏν για διανÏ
ÏμαÏÎ¹ÎºÏ ÏάÏÏη[%s] ÏÏο mapset [%s] %s"
#: ../lib/gis/quant_rw.c:206
#, c-format
msgid "Cannot write quant rules: map %s is integer"
-msgstr "Äåí ìðïñïýí íá åããñáöïýí quant êáíüíåò: Ï ÷Üñôçò %s åßíáé áêÝñáéïò"
+msgstr "Îεν μÏοÏοÏν να εγγÏαÏοÏν quant κανÏνεÏ: Î ÏάÏÏÎ·Ï %s είναι ακÎÏαιοÏ"
#: ../lib/gis/quant_rw.c:215
#, c-format
msgid "Cannot write quant rules for map %s"
-msgstr "Äåí ìðïñïýí íá åããñáöïýí quant êáíüíåò ãéáôïí ÷Üñôç %s"
+msgstr "Îεν μÏοÏοÏν να εγγÏαÏοÏν quant κανÏÎ½ÎµÏ Î³Î¹Î±Ïον ÏάÏÏη %s"
#: ../lib/gis/unix_socks.c:102
msgid "Unable to get GIS_LOCK environment variable value"
-msgstr "Áäõíáìßá ëÞøçò GIS_LOCK ôéìÞò ðåñéâÜëëïíôïò"
+msgstr "ÎδÏ
ναμία λήÏÎ·Ï GIS_LOCK ÏÎ¹Î¼Î®Ï ÏεÏιβάλλονÏοÏ"
#: ../lib/gis/adj_cellhd.c:47 ../lib/gis/adj_cellhd.c:199
msgid "Illegal n-s resolution value"
-msgstr "Ìç åðéôñåðôç n-s ôéìÞ áíÜëõóçò"
+msgstr "Îη εÏιÏÏεÏÏη n-s Ïιμή ανάλÏ
ÏηÏ"
#: ../lib/gis/adj_cellhd.c:51 ../lib/gis/adj_cellhd.c:205
msgid "Illegal row value"
-msgstr "Ìç åðéôñåðôÞ ôéìÞ ãñáììÞò"
+msgstr "Îη εÏιÏÏεÏÏή Ïιμή γÏαμμήÏ"
#: ../lib/gis/adj_cellhd.c:55 ../lib/gis/adj_cellhd.c:211
msgid "Illegal e-w resolution value"
-msgstr "Ìç åðéôñåðôÞ e-w ôéìÞ áíÜëõóçò"
+msgstr "Îη εÏιÏÏεÏÏή e-w Ïιμή ανάλÏ
ÏηÏ"
#: ../lib/gis/adj_cellhd.c:59 ../lib/gis/adj_cellhd.c:217
msgid "Illegal col value"
-msgstr "Ìç åðéôñåðôÞ col ôéìÞ"
+msgstr "Îη εÏιÏÏεÏÏή col Ïιμή"
#: ../lib/gis/adj_cellhd.c:79 ../lib/gis/adj_cellhd.c:247
#, c-format
@@ -2024,7 +2024,7 @@
#: ../lib/gis/adj_cellhd.c:84 ../lib/gis/adj_cellhd.c:252
msgid "Illegal latitude for North"
-msgstr "Ìç åðéôñåðôüò áñéèìüò ãéá ÂïñÜ"
+msgstr "Îη εÏιÏÏεÏÏÏÏ Î±ÏιθμÏÏ Î³Î¹Î± ÎοÏά"
#: ../lib/gis/adj_cellhd.c:90 ../lib/gis/adj_cellhd.c:258
#, c-format
@@ -2033,7 +2033,7 @@
#: ../lib/gis/adj_cellhd.c:95 ../lib/gis/adj_cellhd.c:263
msgid "Illegal latitude for South"
-msgstr "Ìç åðéôñåðôüò áñéèìüò ãéá Íüôï"
+msgstr "Îη εÏιÏÏεÏÏÏÏ Î±ÏιθμÏÏ Î³Î¹Î± ÎÏÏο"
#: ../lib/gis/adj_cellhd.c:107 ../lib/gis/adj_cellhd.c:275
#, c-format
@@ -2047,81 +2047,81 @@
#: ../lib/gis/adj_cellhd.c:131 ../lib/gis/adj_cellhd.c:299
msgid "North must be north of South"
-msgstr "Ï âïñÜò ðñÝðåé íá åßíáé âïñåéüôåñá ôïõ Íüôïõ"
+msgstr "ΠβοÏÎ¬Ï ÏÏÎÏει να είναι βοÏειÏÏεÏα ÏοÏ
ÎÏÏοÏ
#: ../lib/gis/adj_cellhd.c:133 ../lib/gis/adj_cellhd.c:301
msgid "North must be larger than South"
-msgstr "Ï ÂïñÜò ðñÝðåé íá åßíáé ìåãáëýôåñïò áðü ôïí Íüôï"
+msgstr "Î ÎοÏÎ¬Ï ÏÏÎÏει να είναι μεγαλÏÏεÏÎ¿Ï Î±ÏÏ Ïον ÎÏÏο"
#: ../lib/gis/adj_cellhd.c:136 ../lib/gis/adj_cellhd.c:304
msgid "East must be larger than West"
-msgstr "Ç ÁíáôïëÞ ðñÝðåé íá åßíáé ìåãáëýôåñçáðü ôç Äýóç"
+msgstr "Î ÎναÏολή ÏÏÎÏει να είναι μεγαλÏÏεÏηαÏÏ Ïη ÎÏÏη"
#: ../lib/gis/adj_cellhd.c:155 ../lib/gis/adj_cellhd.c:348
msgid "Invalid coordinates"
-msgstr "ËÜèïò óõíôåôáãìÝíåò"
+msgstr "ÎÎ¬Î¸Î¿Ï ÏÏ
νÏεÏαγμÎνεÏ"
#: ../lib/gis/adj_cellhd.c:201
msgid "Illegal n-s3 resolution value"
-msgstr "ìç åðéôñåðôÞ n-s3 ôéìÞ áíÜëõóçò"
+msgstr "μη εÏιÏÏεÏÏή n-s3 Ïιμή ανάλÏ
ÏηÏ"
#: ../lib/gis/adj_cellhd.c:207
msgid "Illegal row3 value"
-msgstr "Ìç åðéôñåðôÞ row3 ôéìÞ"
+msgstr "Îη εÏιÏÏεÏÏή row3 Ïιμή"
#: ../lib/gis/adj_cellhd.c:213
msgid "Illegal e-w3 resolution value"
-msgstr "ìç åðéôñåðôÞ e-w3 ôéìÞ áíÜëõóçò"
+msgstr "μη εÏιÏÏεÏÏή e-w3 Ïιμή ανάλÏ
ÏηÏ"
#: ../lib/gis/adj_cellhd.c:219
msgid "Illegal col3 value"
-msgstr "ìç åðéôñåðôÞ col3 ôéìÞ"
+msgstr "μη εÏιÏÏεÏÏή col3 Ïιμή"
#: ../lib/gis/adj_cellhd.c:223
msgid "Illegal t-b3 resolution value"
-msgstr "ìç åðéôñåðôÞ t-b3 ôéìÞ áíÜëõóçò"
+msgstr "μη εÏιÏÏεÏÏή t-b3 Ïιμή ανάλÏ
ÏηÏ"
#: ../lib/gis/adj_cellhd.c:227
msgid "Illegal depths value"
-msgstr "Ìç åðéôñåðôÝò ôéìÝò âÜèïõò"
+msgstr "Îη εÏιÏÏεÏÏÎÏ ÏιμÎÏ Î²Î¬Î¸Î¿Ï
Ï"
#: ../lib/gis/adj_cellhd.c:306
msgid "Top must be larger than Bottom"
-msgstr "Ôï ðÜíù ðñÝðåé íá åßíáé ìåãáëýôåñï ôïõ êÜôù"
+msgstr "Το ÏÎ¬Î½Ï ÏÏÎÏει να είναι μεγαλÏÏεÏο ÏοÏ
κάÏÏ"
#: ../lib/gis/set_window.c:76
msgid ""
"G_set_window(): projection/zone differs from that of currently open raster "
"maps"
msgstr ""
-"G_set_window(): ç ðñïâïëÞ/æþíç äéáöÝñåéò áðü ôïõò õöéóôÜìåíá áíïé÷ôïõ ñáóôåñ "
-"÷Üñôåò"
+"G_set_window(): η ÏÏοβολή/ζÏνη διαÏÎÏÎµÎ¹Ï Î±ÏÏ ÏοÏ
Ï Ï
ÏιÏÏάμενα ανοιÏÏοÏ
ÏαÏÏÎµÏ "
+"ÏάÏÏεÏ"
#: ../lib/gis/home.c:39
msgid "unable to determine user's home directory"
-msgstr "Äåí åßíáé äõíáôüò ï êáèïñéóìïýò ï áñ÷éêüò öÜêåëëïò ôïõ ÷ñÞóôç"
ναÏÏÏ Î¿ καθοÏιÏμοÏÏ Î¿ αÏÏικÏÏ ÏÎ¬ÎºÎµÎ»Î»Î¿Ï ÏοÏ
ÏÏήÏÏη"
#: ../lib/gis/null_val.c:91
msgid "EmbedGivenNulls: wrong data type!"
-msgstr "EmbedGivenNulls: åóöáëìÝíïò ôýðïò äåäïìÝíùí!"
+msgstr "EmbedGivenNulls: εÏÏαλμÎÎ½Î¿Ï ÏÏÏÎ¿Ï Î´ÎµÎ´Î¿Î¼ÎνÏν!"
#: ../lib/gis/null_val.c:112
msgid "Null values have not been initialized. "
-msgstr "Ç êåíÞ ôéìÞ äåí Ý÷åé áñ÷éêïðïéçèåß."
+msgstr "Πκενή Ïιμή δεν ÎÏει αÏÏικοÏοιηθεί."
#: ../lib/gis/null_val.c:113
msgid "G_gisinit() must be called first. "
-msgstr "G_gisinit() ðñÝðåé íá êëçèåß ðñþôç. "
+msgstr "G_gisinit() ÏÏÎÏει να κληθεί ÏÏÏÏη. "
#: ../lib/gis/null_val.c:114
msgid "Please advise GRASS developers of this error.\n"
msgstr ""
-"Ðáñáêáëþ åíçìåñþóôå ôïõò ðñïãñáììáôéóôÝò ôïõ GRASS ãéá áõôü ôï ìÞíõìá "
-"ëÜèïõò.\n"
+"ΠαÏÎ±ÎºÎ±Î»Ï ÎµÎ½Î·Î¼ÎµÏÏÏÏε ÏοÏ
Ï ÏÏογÏαμμαÏιÏÏÎÏ ÏοÏ
GRASS για αÏ
ÏÏ Ïο μήνÏ
μα "
+"λάθοÏ
Ï.\n"
#: ../lib/gis/null_val.c:223
msgid "G_set_null_value: wrong data type!"
-msgstr "G_set_null_value: åóöáëìÝíïò ôýðïò äåäïìÝíùí!"
+msgstr "G_set_null_value: εÏÏαλμÎÎ½Î¿Ï ÏÏÏÎ¿Ï Î´ÎµÎ´Î¿Î¼ÎνÏν!"
#: ../lib/gis/proj3.c:64 ../lib/vector/Vlib/header.c:512
msgid "Unknown projection"
@@ -2130,74 +2130,74 @@
#: ../lib/gis/view.c:177
#, c-format
msgid "Unable to open %s for writing"
-msgstr "Áäõíáìßá áíïßãìáôïò %s ãéá åããñáöÞ"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï %s για εγγÏαÏή"
#: ../lib/gis/view.c:263 ../lib/gis/view.c:480
#, c-format
msgid "Unable to open %s for reading"
-msgstr "Áäõíáìßá áíïßãìáôïò %s ãéá áíÜãíùóç"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï %s για ανάγνÏÏη"
#: ../lib/gis/view.c:466
#, c-format
msgid "GRASS window when view was saved:\n"
-msgstr "Ôï ðáñÜèõñï ôïõ GRASS üôáí åß÷å óùèåß ç üøç:\n"
+msgstr "Το ÏαÏάθÏ
Ïο ÏοÏ
GRASS ÏÏαν είÏε ÏÏθεί η ÏÏη:\n"
#: ../lib/gis/view.c:546
#, c-format
msgid " Window saved in \"%s\" is completely outside of current GRASS window."
msgstr ""
-"Ôï ðáñÜèõñï ôï ïðïßï óþèçêå \"%s\" åßíáé åíôåëþò Ýîù áðü ôï ôñÝ÷ùí GRASS "
-"ðáñÜèõñï."
+"Το ÏαÏάθÏ
Ïο Ïο οÏοίο ÏÏθηκε \"%s\" είναι ενÏελÏÏ ÎÎ¾Ï Î±ÏÏ Ïο ÏÏÎÏÏν GRASS "
+"ÏαÏάθÏ
Ïο."
#: ../lib/gis/view.c:550
#, c-format
msgid ""
" Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
msgstr ""
-" Ìüíï %d%% ôïõ ðáñáèýñïõ óþèçêò \"%s\" åðéêáëýðôåé ôï ôñÝ÷ïí GRASS ðáñÜèõñï."
+" ÎÏνο %d%% ÏοÏ
ÏαÏαθÏÏοÏ
ÏÏÎ¸Î·ÎºÏ \"%s\" εÏικαλÏÏÏει Ïο ÏÏÎÏον GRASS ÏαÏάθÏ
Ïο."
#: ../lib/gis/error.c:257
msgid "WARNING: "
-msgstr "ÐÑÏÓÏ×Ç:"
+msgstr "ΠΡÎΣÎΧÎ:"
#: ../lib/gis/error.c:258
msgid "ERROR: "
-msgstr "ÓÖÁËÌÁ:"
+msgstr "ΣΦÎÎÎÎ:"
#: ../lib/gis/legal_name.c:39
#, c-format
msgid "Illegal filename. Cannot be '.' or 'NULL'\n"
-msgstr "Ìç åðéôñåðôü üíïìá. äåí ìðïñåß íá åßíáé '.' Þ 'NULL'\n"
+msgstr "Îη εÏιÏÏεÏÏÏ Ïνομα. δεν μÏοÏεί να είναι '.' ή 'NULL'\n"
#: ../lib/gis/legal_name.c:47
#, c-format
msgid "Illegal filename. Character <%c> not allowed.\n"
-msgstr "Ìç åðéôñåðôü üíïìá áñ÷åßïõ. Ï ÷áñáêôÞñáò <%c> äåí åðéôñÝðåôáé.\n"
+msgstr "Îη εÏιÏÏεÏÏÏ Ïνομα αÏÏείοÏ
. Î ÏαÏακÏήÏÎ±Ï <%c> δεν εÏιÏÏÎÏεÏαι.\n"
#: ../lib/gis/legal_name.c:77 ../lib/gis/legal_name.c:81
#, c-format
msgid "Output raster map name <%s> is not valid map name"
-msgstr "Ôï åîáãþìåíï üíïìá ôïõ äéáíõóìáôéêïý ÷Üñôç <%s> äåí åßíáé åðéôñåðôü"
+msgstr "Το εξαγÏμενο Ïνομα ÏοÏ
διανÏ
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη <%s> δεν είναι εÏιÏÏεÏÏÏ"
#: ../lib/gis/legal_name.c:118 ../lib/gis/legal_name.c:122
#, c-format
msgid "Output raster map <%s> is used as input"
msgstr ""
-"Ï åîáãüìåíïò äéáíõóìáôéêüò ÷Üñôçò <%s> ÷ñçóéìïðïéåßôáé ãéá åéóáãùãÞ "
-"äåäïìÝíùí."
+"ΠεξαγÏÎ¼ÎµÎ½Î¿Ï Î´Î¹Î±Î½Ï
ÏμαÏικÏÏ ÏάÏÏÎ·Ï <%s> ÏÏηÏιμοÏοιείÏαι για ειÏαγÏγή "
+"δεδομÎνÏν."
#: ../lib/gis/mask_info.c:40
#, c-format
msgid "<%s> in mapset <%s>"
-msgstr "<%s> óôï mapset <%s>"
+msgstr "<%s> ÏÏο mapset <%s>"
#: ../lib/gis/mask_info.c:43
msgid "none"
-msgstr "êáíÝíá"
+msgstr "κανÎνα"
#: ../lib/gis/mask_info.c:46
msgid "not known"
-msgstr "Üãíùóôï"
+msgstr "άγνÏÏÏο"
#: ../lib/gis/spawn.c:385
#, c-format
@@ -2207,59 +2207,59 @@
#: ../lib/gis/spawn.c:416
#, fuzzy, c-format
msgid "G_spawn: unable to redirect descriptor %d"
-msgstr "G_spawn: áäõíáìßá áíôéãñáöÞò descriptor %d óå %d"
+msgstr "G_spawn: αδÏ
ναμία ανÏιγÏαÏÎ®Ï descriptor %d Ïε %d"
#: ../lib/gis/spawn.c:424 ../lib/gis/spawn.c:609
#, c-format
msgid "G_spawn: unable to open file %s"
-msgstr "G_spawn: áäõíáìßá áíïßãìáôïò áñ÷åßïõ %s"
ναμία ανοίγμαÏÎ¿Ï Î±ÏÏείοÏ
%s"
#: ../lib/gis/spawn.c:493 ../lib/gis/spawn.c:679
msgid "Unable to execute command"
-msgstr "Áäõíáìßá åêôÝëåóçò åíôïëÞò"
+msgstr "ÎδÏ
ναμία εκÏÎλεÏÎ·Ï ÎµÎ½ÏολήÏ"
#: ../lib/gis/spawn.c:518 ../lib/gis/spawn.c:526
#, c-format
msgid "G_spawn: unable to restore signal %d"
-msgstr "G_spawn: áäõíáìßá áðïêáôÜóôáóçò óÞìáôïòl %d"
ναμία αÏοκαÏάÏÏαÏÎ·Ï ÏήμαÏοÏl %d"
#: ../lib/gis/spawn.c:557
#, c-format
msgid "G_spawn: unable to reset signal %d"
-msgstr "G_spawn: áäõíáìßá åðáíáöïñÜò %d"
ναμία εÏαναÏοÏÎ¬Ï %d"
#: ../lib/gis/spawn.c:566
#, c-format
msgid "G_spawn: unable to ignore signal %d"
-msgstr "G_spawn: áäõíáìßá áãíüçóçò óÞìáôïò %d"
ναμία αγνÏηÏÎ·Ï ÏήμαÏÎ¿Ï %d"
#: ../lib/gis/spawn.c:577
#, c-format
msgid "G_spawn: unable to block signal %d"
-msgstr "G_spawn: áäõíáìßá ìðëïêáñßóìáôïò óÞìáôïò %d"
ναμία μÏλοκαÏίÏμαÏÎ¿Ï ÏήμαÏÎ¿Ï %d"
#: ../lib/gis/spawn.c:585
#, c-format
msgid "G_spawn: unable to unblock signal %d"
-msgstr "G_spawn: áäõíáìßá îåìðëïêáñßóìáôïò óÞìáôïò %d"
ναμία ξεμÏλοκαÏίÏμαÏÎ¿Ï ÏήμαÏÎ¿Ï %d"
#: ../lib/gis/spawn.c:614 ../lib/gis/spawn.c:623
#, c-format
msgid "G_spawn: unable to duplicate descriptor %d to %d"
#: ../lib/gis/spawn.c:656
msgid "Unable to create a new process"
-msgstr "Áäõíáìßá äçìéïõñãßáò íÝáò åðåîåñãáóßáò"
+msgstr "ÎδÏ
ναμία δημιοÏ
ÏÎ³Î¯Î±Ï Î½ÎÎ±Ï ÎµÏεξεÏγαÏίαÏ"
#: ../lib/gis/spawn.c:671
#, c-format
msgid "Unable to change directory to %s"
-msgstr "Áäõíáìßá áëëáãÞò öáêÝëïõ óå %s"
+msgstr "ÎδÏ
ναμία Î±Î»Î»Î±Î³Î®Ï ÏακÎλοÏ
Ïε %s"
#: ../lib/gis/system.c:85
msgid "Can not create a new process!"
-msgstr "Áäõíáìßá äçìéïõñãßáò íÝáò åðåîåñãáóßáò - äéáäéêáóßáò!"
+msgstr "ÎδÏ
ναμία δημιοÏ
ÏÎ³Î¯Î±Ï Î½ÎÎ±Ï ÎµÏεξεÏγαÏÎ¯Î±Ï - διαδικαÏίαÏ!"
#: ../lib/gis/alloc.c:42 ../lib/gis/alloc.c:82 ../lib/gis/alloc.c:125
#, c-format
@@ -2283,141 +2283,141 @@
#: ../lib/gis/sample.c:71
msgid "Unknown interpolation type"
-msgstr "¶ãíùóôïò ôýðïò ðáñåìâïëÞò"
+msgstr "ÎγνÏÏÏÎ¿Ï ÏÏÏÎ¿Ï ÏαÏεμβολήÏ"
#: ../lib/gis/sample.c:284
msgid "\"no data\" label found; setting to zero"
-msgstr "\"no data\" åôôéêÝôá âñÝèçêå; ÷ñçóéìïðïéþ ôï ìçäÝí"
+msgstr "\"no data\" εÏÏικÎÏα βÏÎθηκε; ÏÏηÏιμοÏÎ¿Î¹Ï Ïο μηδÎν"
#: ../lib/gis/sample.c:299
msgid "Problem reading raster map"
-msgstr "Ðñüâëçìá ìå ôçí áíÜãíùóç ôïõ ñÜóôåñ ÷Üñôç"
+msgstr "Î ÏÏβλημα με Ïην ανάγνÏÏη ÏοÏ
ÏάÏÏÎµÏ ÏάÏÏη"
#: ../lib/gis/done_msg.c:38
#, c-format
msgid "%s complete. %s"
-msgstr "%s óõìðëçñùìÝíï. %s"
+msgstr "%s ÏÏ
μÏληÏÏμÎνο. %s"
#: ../lib/gis/env.c:242
msgid "GISRC - variable not set"
-msgstr "GISRC - ç ðáñÜìåôñïò äåí Ý÷åé êáèïñéóôåß"
+msgstr "GISRC - η ÏαÏάμεÏÏÎ¿Ï Î´ÎµÎ½ ÎÏει καθοÏιÏÏεί"
#: ../lib/gis/env.c:274
#, c-format
msgid "G_getenv(): Variable %s not set"
-msgstr "G_getenv(): %s ç ðáñÜìåôñïò äåí Ý÷åé êáèïñéóôåß"
+msgstr "G_getenv(): %s η ÏαÏάμεÏÏÎ¿Ï Î´ÎµÎ½ ÎÏει καθοÏιÏÏεί"
#: ../lib/gis/env.c:300
#, c-format
msgid "%s not set"
-msgstr "%s äåí Ý÷åé êáèïñéóôåß"
+msgstr "%s δεν ÎÏει καθοÏιÏÏεί"
#: ../lib/gis/put_row.c:215
#, c-format
msgid "G_put_map_row: %s is not integer! Use G_put_[f/d]_raster_row()!"
msgstr ""
-"G_put_map_row: %s äåí åßíáé áêÝñáéïò! ×ñçóéìïðïéÞóôå G_put_[f/"
+"G_put_map_row: %s δεν είναι ακÎÏαιοÏ! ΧÏηÏιμοÏοιήÏÏε G_put_[f/"
"d]_raster_row()!"
#: ../lib/gis/put_row.c:251
#, c-format
msgid "%s: map [%s] not open for write - request ignored"
-msgstr "%s:÷Üñôçò [%s] äåí åßíáé áíïé÷ôüò ãéá åããñáöÞ - ç åíôïëÞ áãíïåßôáé"
+msgstr "%s:ÏάÏÏÎ·Ï [%s] δεν είναι ανοιÏÏÏÏ Î³Î¹Î± εγγÏαÏή - η ενÏολή αγνοείÏαι"
#: ../lib/gis/put_row.c:259
#, c-format
msgid "%s: map [%s] not open for random write - request ignored"
msgstr ""
-"%s: ÷Üñôçò [%s] äåí åßíáé áíïé÷ôüò ãéá ôõ÷áßá åããñáöÞ - ç åíôïëÞ áãíïåßôáé"
+"%s: ÏάÏÏÎ·Ï [%s] δεν είναι ανοιÏÏÏÏ Î³Î¹Î± ÏÏ
Ïαία εγγÏαÏή - η ενÏολή αγνοείÏαι"
#: ../lib/gis/put_row.c:266
#, c-format
msgid "%s: map [%s] not open for sequential write - request ignored"
msgstr ""
-"%s: ÷Üñôçò [%s] äåí åßíáé áíïé÷ôüò ãéá óõíå÷Þò åããñáöÞ - ç åíôïëÞ áãíïåßôáé"
νεÏÎ®Ï ÎµÎ³Î³ÏαÏή - η ενÏολή αγνοείÏαι"
#: ../lib/gis/put_row.c:270
#, c-format
msgid "%s: unopened file descriptor - request ignored"
-msgstr "%s: ìç áíïéêôÞ ðåñéãñáöÞ áñ÷åßïõ - åíôïëÞ áãíïåßôå"
+msgstr "%s: μη ανοικÏή ÏεÏιγÏαÏή αÏÏείοÏ
- ενÏολή αγνοείÏε"
#: ../lib/gis/put_row.c:310
#, c-format
msgid "map [%s] - unable to write row %d"
-msgstr "÷Üñôçò [%s] - áäõíáìßá åããñáöÞò ãñáììÞò %d"
+msgstr "ÏάÏÏÎ·Ï [%s] - αδÏ
ναμία εγγÏαÏÎ®Ï Î³ÏÎ±Î¼Î¼Î®Ï %d"
#: ../lib/gis/put_row.c:393
#, c-format
msgid "xdr_float failed for index %d of row %d"
-msgstr "xdr_float óöÜëìá ãéá ôï äåßêôç %d ôçò ãñáììÞò %d"
+msgstr "xdr_float ÏÏάλμα για Ïο δείκÏη %d ÏÎ·Ï Î³ÏÎ±Î¼Î¼Î®Ï %d"
#: ../lib/gis/put_row.c:419
#, c-format
msgid "xdr_double failed for index %d of row %d"
-msgstr "xdr_double óöÜëìá ãéá ôï äåßêôç %d ôçò ãñáììÞò %d"
+msgstr "xdr_double ÏÏάλμα για Ïο δείκÏη %d ÏÎ·Ï Î³ÏÎ±Î¼Î¼Î®Ï %d"
#: ../lib/gis/put_row.c:754
#, c-format
msgid "unable to find a temporary null file %s"
-msgstr "Áäõíáìßá åããñáöÞò ðñïóùñéíïý êåíïý áñ÷åßïõ %s"
+msgstr "ÎδÏ
ναμία εγγÏαÏÎ®Ï ÏÏοÏÏÏÎ¹Î½Î¿Ï ÎºÎµÎ½Î¿Ï Î±ÏÏείοÏ
%s"
#: ../lib/gis/put_row.c:776 ../lib/gis/put_row.c:781
#, c-format
msgid "error writing null row %d"
-msgstr "ÓöÜëìá åããñáöÞò êåíÞò ãñáììÞò %d"
+msgstr "ΣÏάλμα εγγÏαÏÎ®Ï ÎºÎµÎ½Î®Ï Î³ÏÎ±Î¼Î¼Î®Ï %d"
#: ../lib/gis/range.c:192
#, c-format
msgid "can't read f_range file for [%s in %s]"
-msgstr "äåí ìðïñåß íá ãßíåé áíÜãíùóç f_range áñ÷åßïõ ãéá [%s in %s]"
+msgstr "δεν μÏοÏεί να γίνει ανάγνÏÏη f_range αÏÏείοÏ
για [%s in %s]"
#: ../lib/gis/range.c:308
#, c-format
msgid "can't read range file for [%s in %s]"
-msgstr "Äåí åßíáé äõíáôÞ ç áíÜãíùóç ôïõ åýñïõò ôïõ áñ÷åßïõ ãéá [%s óå %s]"
ναÏή η ανάγνÏÏη ÏοÏ
εÏÏοÏ
Ï ÏοÏ
αÏÏείοÏ
για [%s Ïε %s]"
#: ../lib/gis/range.c:359 ../lib/gis/range.c:412
#, c-format
msgid "can't write range file for [%s in %s]"
-msgstr "Äåí åßíáé äõíáôÞ ç åããñáöÞ ôïõ åýñïõò ôïõ áñ÷åßïõ ãéá [%s óå %s]"
ναÏή η εγγÏαÏή ÏοÏ
εÏÏοÏ
Ï ÏοÏ
αÏÏείοÏ
για [%s Ïε %s]"
#: ../lib/gis/list.c:114
#, c-format
msgid "no %s files available in current mapset\n"
-msgstr "no %s áñ÷åßá äéáèÝóéìá óôï ôñÝ÷ïí mapset\n"
+msgstr "no %s αÏÏεία διαθÎÏιμα ÏÏο ÏÏÎÏον mapset\n"
#: ../lib/gis/list.c:117
#, c-format
msgid "no %s files available in mapset <%s>\n"
-msgstr "no %s áñ÷åßá äéáèÝóéìá óôï mapset <%s>\n"
+msgstr "no %s αÏÏεία διαθÎÏιμα ÏÏο mapset <%s>\n"
#: ../lib/gis/list.c:132
#, c-format
msgid "hit RETURN to continue -->"
-msgstr "ÐáôÞóôå RETURN ãéá óõíÝ÷åéá -->"
+msgstr "ΠαÏήÏÏε RETURN για ÏÏ
νÎÏεια -->"
#: ../lib/gis/list.c:183
#, c-format
msgid "%s files available in mapset <%s>:\n"
-msgstr "%s áñ÷åßá äéáèÝóéìá óôï mapset <%s>:\n"
+msgstr "%s αÏÏεία διαθÎÏιμα ÏÏο mapset <%s>:\n"
#: ../lib/gis/list.c:254
msgid "G_list: Unknown element type"
-msgstr "G_list: ¶ãíùóôïò ôýðïò óôïé÷åßïõ"
+msgstr "G_list: ÎγνÏÏÏÎ¿Ï ÏÏÏÎ¿Ï ÏÏοιÏείοÏ
#: ../lib/gis/mapset.c:39
msgid "MAPSET is not set"
-msgstr "MAPSET äåí Ý÷åé ïñéóôåß"
+msgstr "MAPSET δεν ÎÏει οÏιÏÏεί"
#: ../lib/gis/mapset.c:57
#, c-format
msgid "MAPSET %s not found"
#: ../lib/gis/make_colr.c:40
#, fuzzy, c-format
msgid "The raster map <%s@%s> is empty"
-msgstr "Ï ñÜóôåñ ÷Üñôçò %s@%s åßíáé Üäåéïò"
+msgstr "Î ÏάÏÏÎµÏ ÏάÏÏÎ·Ï %s@%s είναι άδειοÏ"
#: ../lib/gis/make_colr.c:48
#, c-format
@@ -2428,7 +2428,7 @@
msgstr ""
"\n"
"\n"
-"×ñåéÜæåôáé ðßíáêáò ÷ñùìÜôùí ãéá ôï áñ÷åßï [%s] óôï mapset [%s].\n"
+"ΧÏειάζεÏαι ÏÎ¯Î½Î±ÎºÎ±Ï ÏÏÏμάÏÏν για Ïο αÏÏείο [%s] ÏÏο mapset [%s].\n"
#: ../lib/gis/make_colr.c:51
#, c-format
@@ -2437,52 +2437,52 @@
"Please identify the type desired:\n"
msgstr ""
"\n"
-"Ðáñáêáëþ ðñïóäéïñßóôå ôïí ôýðï ðïõ åðéèõìåßôå:\n"
+"ΠαÏÎ±ÎºÎ±Î»Ï ÏÏοÏδιοÏίÏÏε Ïον ÏÏÏο ÏοÏ
εÏιθÏ
μείÏε:\n"
#: ../lib/gis/make_colr.c:52
#, c-format
msgid " 1: Random colors\n"
-msgstr " 1: Ôõ÷áßá ÷ñþìáôá\n"
+msgstr " 1: ΤÏ
Ïαία ÏÏÏμαÏα\n"
#: ../lib/gis/make_colr.c:53
#, c-format
msgid " 2: Red, green, and blue color ramps\n"
-msgstr " 2: Êüêêéíåò, ðñÜóéíåò êáé ìðëÝ ñÜìðåò ÷ñùìÜôùí\n"
+msgstr " 2: ÎÏκκινεÏ, ÏÏάÏÎ¹Î½ÎµÏ ÎºÎ±Î¹ μÏλΠÏάμÏÎµÏ ÏÏÏμάÏÏν\n"
#: ../lib/gis/make_colr.c:54
#, c-format
msgid " 3: Color wave\n"
-msgstr " 3: ×ñùìáôéêü êýìá\n"
+msgstr " 3: ΧÏÏμαÏÎ¹ÎºÏ ÎºÏμα\n"
#: ../lib/gis/make_colr.c:55
#, c-format
msgid " 4: Gray scale\n"
-msgstr " 4: Áðï÷ñþóåéò ôïõ ãêñé\n"
+msgstr " 4: ÎÏοÏÏÏÏÎµÎ¹Ï ÏοÏ
γκÏι\n"
#: ../lib/gis/make_colr.c:56
#, c-format
msgid " 5: Aspect\n"
-msgstr " 5: ¶ðïøç\n"
+msgstr " 5: ÎÏοÏη\n"
#: ../lib/gis/make_colr.c:57
#, c-format
msgid " 6: Rainbow colors\n"
-msgstr " 6: ×ñþìáôá ïõñÜíéïõ ôüîïõ\n"
+msgstr " 6: ΧÏÏμαÏα οÏ
ÏάνιοÏ
ÏÏξοÏ
\n"
#: ../lib/gis/make_colr.c:58
#, c-format
msgid " 7: Red through yellow to green\n"
-msgstr " 7: Êüêêéíï äéá ìÝóïõ êßôñéíïõ óå ðñÜóéíï\n"
+msgstr " 7: ÎÏκκινο δια μÎÏοÏ
κίÏÏινοÏ
Ïε ÏÏάÏινο\n"
#: ../lib/gis/make_colr.c:59
#, c-format
msgid " 8: Green through yellow to red\n"
-msgstr " 8: ÐñÜóéíï ìÝóù êßôñéíïõ óå êüêêéíï\n"
+msgstr " 8: Î ÏάÏινο μÎÏÏ ÎºÎ¯ÏÏινοÏ
Ïε κÏκκινο\n"
#: ../lib/gis/make_colr.c:60
#, c-format
msgid "RETURN quit\n"
-msgstr "RETURN Ýîïäïò\n"
+msgstr "RETURN ÎξοδοÏ\n"
#: ../lib/gis/make_colr.c:90
#, c-format
@@ -2491,31 +2491,31 @@
"%s invalid; Try again > "
msgstr ""
"\n"
-"%s åóöáëìÝíï; äïêéìÜóôå îáíÜ > "
+"%s εÏÏαλμÎνο; δοκιμάÏÏε ξανά > "
#: ../lib/gis/history.c:180
#, c-format
msgid "can't write history information for [%s]"
-msgstr "äåí åßíáé äõíáôÞ ç åããñáöÞ ôïõ éóôïñéêïý ãéá [%s]"
+msgstr "δεν είναι δÏ
ναÏή η εγγÏαÏή ÏοÏ
ιÏÏοÏÎ¹ÎºÎ¿Ï Î³Î¹Î± [%s]"
#: ../lib/gis/history.c:263
msgid "Not enough room in history file to record command line."
msgstr ""
-"Äåí õðÜñ÷åé áñêåôüò ÷þñïò óôï áñ÷åßï éóôïñéêïý ãéá åããñáöÞ åíôïëÞò ãñáììÞò"
+"Îεν Ï
ÏάÏÏει αÏκεÏÏÏ ÏÏÏÎ¿Ï ÏÏο αÏÏείο ιÏÏοÏÎ¹ÎºÎ¿Ï Î³Î¹Î± εγγÏαÏή ενÏÎ¿Î»Î®Ï Î³ÏαμμήÏ"
#: ../lib/gis/history.c:285
msgid "Not enough room in history file for command line (truncated)."
-msgstr "Not enough room in history file to record command line (ðåñéêïðÞ)."
+msgstr "Not enough room in history file to record command line (ÏεÏικοÏή)."
#: ../lib/gis/opencell.c:105
#, c-format
msgid "Unable to open raster map <%s@%s>"
-msgstr "Áäõíáìßá áíïßãìáôïò ôïõ ÷Üñôç raster <%s@%s>"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï ÏοÏ
ÏάÏÏη raster <%s@%s>"
#: ../lib/gis/opencell.c:171
#, c-format
msgid "Unable to find <%s@%s>"
-msgstr "Áäõíáìßá åýñåóçò <%s@%s>"
+msgstr "ÎδÏ
ναμία εÏÏεÏÎ·Ï <%s@%s>"
#: ../lib/gis/opencell.c:188
#, c-format
@@ -2523,15 +2523,15 @@
"Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@"
"%s> which does not exist"
msgstr ""
-"Áäõíáìßá áíïßãìáôïò ñáóôåñ ÷Üñôç <%s@%s> áöïý åßíáé Ýíá reclass ôïõ ñáóôåñ "
-"÷Üñôç <%s@%s> , ï ïðïßïò äåí õðÜñ÷åé"
+"ÎδÏ
ναμία ανοίγμαÏÎ¿Ï ÏαÏÏÎµÏ ÏάÏÏη <%s@%s> αÏÎ¿Ï ÎµÎ¯Î½Î±Î¹ Îνα reclass ÏοÏ
ÏαÏÏÎµÏ "
+"ÏάÏÏη <%s@%s> , ο οÏÎ¿Î¯Î¿Ï Î´ÎµÎ½ Ï
ÏάÏÏει"
#: ../lib/gis/opencell.c:212
#, c-format
msgid "Raster map <%s@%s>: format field in header file invalid"
msgstr ""
-"Ôï öïñìÜ ôïõ ñÜóôåñ ÷Üñôç <%s@%s>: óôï êåöáëéêü áñ÷åßï (header) åßíáé "
-"ëáíèáóìÝíï"
+"Το ÏοÏμά ÏοÏ
ÏάÏÏÎµÏ ÏάÏÏη <%s@%s>: ÏÏο κεÏÎ±Î»Î¹ÎºÏ Î±ÏÏείο (header) είναι "
+"λανθαÏμÎνο"
#: ../lib/gis/opencell.c:219
#, c-format
@@ -2539,166 +2539,166 @@
"Raster map <%s@%s> is in different projection than current region. Found "
"raster map <%s@%s>, should be <%s>."
msgstr ""
-"Ï ñÜóôåñ ÷Üñôçò <%s@%s> Ý÷åé äéáöïñåôéêÞ ðñïâïëÞ áðü ôçí ôñÝ÷ïõóá ðåñéï÷Þ. Ï "
-"÷Üñôçò <%s@%s>, èá Ýðñåðå íá Þôáí <%s>."
+"Î ÏάÏÏÎµÏ ÏάÏÏÎ·Ï <%s@%s> ÎÏει διαÏοÏεÏική ÏÏοβολή αÏÏ Ïην ÏÏÎÏοÏ
Ïα ÏεÏιοÏή. Î "
+"ÏάÏÏÎ·Ï <%s@%s>, θα ÎÏÏεÏε να ήÏαν <%s>."
#: ../lib/gis/opencell.c:226
#, c-format
msgid "Raster map <%s@%s> is in different zone (%d) than current region (%d)"
msgstr ""
-"Ï ñÜóôåñ ÷Üñôçò <%s@%s> Ý÷åé äéáöïñåôéêÞ æþíç (%d) áðü ôçí ôñÝ÷ïõóá ðåñéï÷Þ "
+"Î ÏάÏÏÎµÏ ÏάÏÏÎ·Ï <%s@%s> ÎÏει διαÏοÏεÏική ζÏνη (%d) αÏÏ Ïην ÏÏÎÏοÏ
Ïα ÏεÏιοÏή "
"(%d)"
#: ../lib/gis/opencell.c:233
#, c-format
msgid "Raster map <%s@%s>: bytes per cell (%d) too large"
-msgstr "Ï ñÜóôåñ ÷Üñôçò <%s@%s>: Ý÷åé bytes per cell (%d) ðïëý ìåãÜëï"
+msgstr "Î ÏάÏÏÎµÏ ÏάÏÏÎ·Ï <%s@%s>: ÎÏει bytes per cell (%d) ÏÎ¿Î»Ï Î¼ÎµÎ³Î¬Î»Î¿"
#: ../lib/gis/opencell.c:262
#, c-format
msgid "map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
msgstr ""
-"Ï ÷Üñôçò <%s@%s> åßíáé Ýíáò óýíäåóìïò GDAL áëëÜ ôï GRASS Ý÷åé ãßíåé "
-"compiled ÷ùñßò GDAL õðïóôÞñéîç"
+"Î ÏάÏÏÎ·Ï <%s@%s> είναι ÎÎ½Î±Ï ÏÏνδεÏÎ¼Î¿Ï GDAL αλλά Ïο GRASS ÎÏει γίνει "
+"compiled ÏÏÏÎ¯Ï GDAL Ï
ÏοÏÏήÏιξη"
#: ../lib/gis/opencell.c:642
#, c-format
msgid "Raster map <%s> is not in the current mapset (%s)"
-msgstr "Ï ñáóôåñ ÷Üñôçò <%s> äåí áíÞêåé óôï ôñÝ÷ïí mapset (%s)"
+msgstr "Î ÏαÏÏÎµÏ ÏάÏÏÎ·Ï <%s> δεν ανήκει ÏÏο ÏÏÎÏον mapset (%s)"
#: ../lib/gis/opencell.c:649
#, c-format
msgid "<%s> is an illegal file name"
-msgstr "<%s> åßíáé ìç åðéôñåðôü üíïìá áñ÷åßïõ"
+msgstr "<%s> είναι μη εÏιÏÏεÏÏÏ Ïνομα αÏÏείοÏ
#: ../lib/gis/opencell.c:655
#, c-format
msgid "<%s>: bad mapset"
-msgstr "<%s>: êáêü mapset"
+msgstr "<%s>: ÎºÎ±ÎºÏ mapset"
#: ../lib/gis/opencell.c:666 ../lib/gis/opencell.c:767
msgid "G__open_raster_new(): no temp files available"
-msgstr "G__open_raster_new(): äåí õðÜñ÷ïõí ðñïóùñéíÜ áñ÷åßá, ìç äéáèÝóéìá"
+msgstr "G__open_raster_new(): δεν Ï
ÏάÏÏοÏ
ν ÏÏοÏÏÏινά αÏÏεία, μη διαθÎÏιμα"
#: ../lib/gis/opencell.c:736
msgid ""
"Unable to write embedded null values for raster map open for random access"
msgstr ""
-"Áäõíáìßá åããñáöÞò ôùí åìðåñéå÷üìåíùí ìçäåíéêþí ôéìþí ãéá ôïí ñáóôåñ ÷Üñôç "
-"ðïõ åßíáé áíïéêôüò ãéá ôõ÷áßá ðñïóðÝëáóç"
+"ÎδÏ
ναμία εγγÏαÏÎ®Ï ÏÏν εμÏεÏιεÏÏμενÏν μηδενικÏν ÏιμÏν για Ïον ÏαÏÏÎµÏ ÏάÏÏη "
+"ÏοÏ
είναι ανοικÏÏÏ Î³Î¹Î± ÏÏ
Ïαία ÏÏοÏÏÎλαÏη"
#: ../lib/gis/opencell.c:941
msgid "G_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"
-msgstr "G_set_fp_type(): ìðïñåß íá êáëåóôåß ìüíï ìå FCELL_TYPE Þ DCELL_TYPE"
+msgstr "G_set_fp_type(): μÏοÏεί να καλεÏÏεί μÏνο με FCELL_TYPE ή DCELL_TYPE"
#: ../lib/gis/opencell.c:976 ../lib/gis/opencell.c:1064
#, c-format
msgid "Unable to find '%s' in '%s'"
-msgstr "Áäõíáìßá åýñåóçò '%s' óå '%s'"
+msgstr "ÎδÏ
ναμία εÏÏεÏÎ·Ï '%s' Ïε '%s'"
#: ../lib/gis/opencell.c:1009
#, c-format
msgid "Raster map <%s> not found in mapset <%s>"
-msgstr "Ï ÷Üñôçò raster <%s> äåí âñÝèçêå óôï mapset <%s>"
+msgstr "Î ÏάÏÏÎ·Ï raster <%s> δεν βÏÎθηκε ÏÏο mapset <%s>"
#: ../lib/gis/opencell.c:1070
#, c-format
msgid "Unable to find '%s'"
-msgstr "Áäõíáìßá åýñåóçò '%s'"
+msgstr "ÎδÏ
ναμία εÏÏεÏÎ·Ï '%s'"
#: ../lib/gis/opencell.c:1075
#, c-format
msgid "Unable to open '%s'"
-msgstr "Áäõíáìßá áíïßãìáôïò '%s'"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï '%s'"
#: ../lib/gis/opencell.c:1085
#, c-format
msgid "Invalid type: field '%s' in file '%s'"
-msgstr "ÅóöáëìÝíïò ôýðïò: ôï ðåäßï '%s' óôï áñ÷åßï '%s'"
+msgstr "ÎÏÏαλμÎÎ½Î¿Ï ÏÏÏοÏ: Ïο Ïεδίο '%s' ÏÏο αÏÏείο '%s'"
#: ../lib/gis/opencell.c:1099
#, c-format
msgid "Raster map <%s> is not xdr: byte_order: %s"
-msgstr "Ï ÷Üñôçò raster <%s> äåí åßíáé xdr: byte_order: %s"
+msgstr "Î ÏάÏÏÎ·Ï raster <%s> δεν είναι xdr: byte_order: %s"
#: ../lib/gis/opencell.c:1179
msgid ""
"G_set_quant_rules() can be called only for raster maps opened for reading"
msgstr ""
-"G_set_quant_rules() ìðïñåß íá êëçèåß ìüíï ãéá ñÜóôåñ ÷Üñôåò áíïéêôïýò ãéá "
-"áíÜãíùóç"
+"G_set_quant_rules() μÏοÏεί να κληθεί μÏνο για ÏάÏÏÎµÏ ÏάÏÏÎµÏ Î±Î½Î¿Î¹ÎºÏοÏÏ Î³Î¹Î± "
+"ανάγνÏÏη"
#: ../lib/gis/auto_mask.c:64
msgid "Unable to open automatic MASK file"
-msgstr "Áäõíáìßá áõôüìáôïõ áíïßãìáôïò ôïõ MASK áñ÷åßïõ"
+msgstr "ÎδÏ
ναμία αÏ
ÏÏμαÏοÏ
ανοίγμαÏÎ¿Ï ÏοÏ
MASK αÏÏείοÏ
#: ../lib/gis/raster_metadata.c:111
#, c-format
msgid "Can't read %s for [%s in %s]"
-msgstr "Áäõíáìßá áíÜãíùóçò %s ãéá [%s óôï %s]"
+msgstr "ÎδÏ
ναμία ανάγνÏÏÎ·Ï %s για [%s ÏÏο %s]"
#: ../lib/gis/raster_metadata.c:144
#, c-format
msgid "Can't create %s metadata file for [%s in %s]"
-msgstr "Áäõíáìßá áíÜãíùóçò %s ôïõ ìåôáñ÷åßïõ ãéá[%s óôï %s]"
+msgstr "ÎδÏ
ναμία ανάγνÏÏÎ·Ï %s ÏοÏ
μεÏαÏÏείοÏ
για[%s ÏÏο %s]"
#: ../lib/gis/find_file.c:74
#, c-format
msgid "'%s/%s' was found in more mapsets (also found in <%s>)"
-msgstr "'%s/%s' âñÝèçêáí óå ðåñéóóüôåñá mapsets (âñÝèçêáí åðßóçò óôï <%s>)"
+msgstr "'%s/%s' βÏÎθηκαν Ïε ÏεÏιÏÏÏÏεÏα mapsets (βÏÎθηκαν εÏίÏÎ·Ï ÏÏο <%s>)"
#: ../lib/gis/find_file.c:82
#, c-format
msgid "Using <%s@%s>"
-msgstr "×ñÞóç: <%s@%s>"
+msgstr "ΧÏήÏη: <%s@%s>"
#: ../lib/gis/get_cellhd.c:71 ../lib/gis/get_cellhd.c:100
#, c-format
msgid "Unable to read header file for raster map <%s@%s>."
-msgstr "Áäõíáìßá áíÜãíùóçò êåöáëéêïý áñ÷åßïõ ãéá ñÜóôåñ ÷Üñôç <%s@%s>."
+msgstr "ÎδÏ
ναμία ανάγνÏÏÎ·Ï ÎºÎµÏÎ±Î»Î¹ÎºÎ¿Ï Î±ÏÏείοÏ
για ÏάÏÏÎµÏ ÏάÏÏη <%s@%s>."
#: ../lib/gis/get_cellhd.c:74
#, c-format
msgid " It is a reclass of raster map <%s@%s> "
-msgstr "Åßíáé ìßá áíáäéÜôáîç ôïõ ñÜóôåñ ÷Üñôç <%s@%s> "
+msgstr "Îίναι μία αναδιάÏαξη ÏοÏ
ÏάÏÏÎµÏ ÏάÏÏη <%s@%s> "
#: ../lib/gis/get_cellhd.c:78
#, c-format
msgid "which is missing."
-msgstr "ôï ïðïßï ëåßðåé"
+msgstr "Ïο οÏοίο λείÏει"
#: ../lib/gis/get_cellhd.c:80
#, c-format
msgid "whose header file can't be opened."
-msgstr "ôïõ ïðïßïõ ôï êåöáëéêü (header) áñ÷åßï äåí ìðïñåß íá áíïßîåé"
+msgstr "ÏοÏ
οÏοίοÏ
Ïο κεÏÎ±Î»Î¹ÎºÏ (header) αÏÏείο δεν μÏοÏεί να ανοίξει"
#: ../lib/gis/get_cellhd.c:88
#, c-format
msgid "Unable to open header file for raster map <%s@%s>"
msgstr ""
-"Áäõíáìßá áíïßãìáôïò êåöáëéêïý (header) áñ÷åßïõ ãéá ôïí ñÜóôåñ ÷Üñôç <%s@%s>"
+"ÎδÏ
ναμία ανοίγμαÏÎ¿Ï ÎºÎµÏÎ±Î»Î¹ÎºÎ¿Ï (header) αÏÏείοÏ
για Ïον ÏάÏÏÎµÏ ÏάÏÏη <%s@%s>"
#: ../lib/gis/get_cellhd.c:105
#, c-format
msgid " It is a reclass of raster map <%s@%s> whose header file is invalid."
msgstr ""
-"Åßíáé ìßá áíáäéÜôáîç ôïõ ñÜóôåñ ÷Üñôç <%s@%s> ôïõ ïðïßïõ ôï êåöáëéêü áñ÷åßï "
-"åßíáé åóöáëìÝíï."
+"Îίναι μία αναδιάÏαξη ÏοÏ
ÏάÏÏÎµÏ ÏάÏÏη <%s@%s> ÏοÏ
οÏοίοÏ
Ïο κεÏÎ±Î»Î¹ÎºÏ Î±ÏÏείο "
+"είναι εÏÏαλμÎνο."
#: ../lib/gis/get_cellhd.c:109
#, c-format
msgid " Invalid format."
-msgstr "ËÜèïò äéÜôáîç (öïñìáô)"
+msgstr "ÎÎ¬Î¸Î¿Ï Î´Î¹Î¬Ïαξη (ÏοÏμαÏ)"
#: ../lib/gis/gishelp.c:45
#, c-format
msgid "one moment...\n"
-msgstr "Ýíá ëåðôÜêé...\n"
+msgstr "Îνα λεÏÏάκι...\n"
#: ../lib/gis/gishelp.c:49
#, c-format
msgid "No help available for command [%s]\n"
-msgstr "Äåí õðÜñ÷åé êåßìåíï âïÞèåéáò ãéá ôçí åíôïëÞ [%s]\n"
+msgstr "Îεν Ï
ÏάÏÏει κείμενο Î²Î¿Î®Î¸ÎµÎ¹Î±Ï Î³Î¹Î± Ïην ενÏολή [%s]\n"
#: ../lib/gis/closecell.c:228
#, c-format
@@ -2706,15 +2706,15 @@
"closecell: can't move %s\n"
"to null file %s"
msgstr ""
-"closecell: äåí ìðïñåß íá ãßíåé ìåôáêßíçóç %s\n"
-"óå êåíü áñ÷åßï %s"
+"closecell: δεν μÏοÏεί να γίνει μεÏακίνηÏη %s\n"
+"Ïε ÎºÎµÎ½Ï Î±ÏÏείο %s"
#: ../lib/gis/closecell.c:250
#, c-format
msgid "Error writing floating point format file for map %s"
msgstr ""
-"ÓöÜëìá êáôÜ ôçí åããñáöÞ óçìåßïõ êéíçôÞò õðïäéáóôïëÞò óôï áñ÷åßï ãéá ôïí "
-"÷Üñôç %s"
+"ΣÏάλμα καÏά Ïην εγγÏαÏή ÏημείοÏ
κινηÏÎ®Ï Ï
ÏοδιαÏÏÎ¿Î»Î®Ï ÏÏο αÏÏείο για Ïον "
+"ÏάÏÏη %s"
#: ../lib/gis/closecell.c:300
#, c-format
@@ -2722,16 +2722,16 @@
"to cell file %s"
msgstr ""
-"closecell: áäõíáìßá ìåôáêßíçóçò %s\n"
-"óôï áñ÷åßï cell %s"
+"closecell: αδÏ
ναμία μεÏακίνηÏÎ·Ï %s\n"
+"ÏÏο αÏÏείο cell %s"
#: ../lib/gis/closecell.c:355
msgid "unable to write quant file!"
-msgstr "áäõíáìßá åããñáöÞò áñ÷åßïõ quant!"
+msgstr "αδÏ
ναμία εγγÏαÏÎ®Ï Î±ÏÏείοÏ
quant!"
#: ../lib/gis/closecell.c:406
msgid "unable to write f_format file for CELL maps"
-msgstr "áäõíáìßá åããñáöÞò f_format áñ÷åßïõ ãéá CELL ÷Üñôåò"
+msgstr "αδÏ
ναμία εγγÏαÏÎ®Ï f_format αÏÏείοÏ
για CELL ÏάÏÏεÏ"
#: ../lib/gis/get_datum_name.c:53
#, c-format
@@ -2740,17 +2740,17 @@
"Please specify datum name\n"
msgstr ""
"\n"
-"Ðáñáêáëþ ðñïóäéïñßóôå üíïìá datum\n"
+"ΠαÏÎ±ÎºÎ±Î»Ï ÏÏοÏδιοÏίÏÏε Ïνομα datum\n"
#: ../lib/gis/get_datum_name.c:55
#, c-format
msgid "Enter 'list' for the list of available datums\n"
-msgstr "ÐëçêôñïëïãÞóôå 'list' ãéá ôá äéáèÝóéìá datums\n"
+msgstr "ΠληκÏÏολογήÏÏε 'list' για Ïα διαθÎÏιμα datums\n"
#: ../lib/gis/get_datum_name.c:57
#, c-format
msgid "or 'custom' if you wish to enter custom parameters\n"
-msgstr "Þ 'custom' ãéá ðñïóáñìïóìÝíåò ðáñáìÝôñïõò\n"
+msgstr "ή 'custom' για ÏÏοÏαÏμοÏμÎÎ½ÎµÏ ÏαÏαμÎÏÏοÏ
Ï\n"
#: ../lib/gis/get_datum_name.c:97
#, c-format
@@ -2759,17 +2759,17 @@
"invalid datum\n"
msgstr ""
"\n"
-"ìç åðéôñåðôü, ëáíèáóìÝíï datum\n"
+"μη εÏιÏÏεÏÏÏ, λανθαÏμÎνο datum\n"
#: ../lib/gis/location.c:44
#, c-format
msgid "LOCATION << %s >> not available"
-msgstr "LOCATION << %s >> äåí åßíáé äéáèÝóéìç"
+msgstr "LOCATION << %s >> δεν είναι διαθÎÏιμη"
#: ../lib/gis/open_misc.c:45
#, c-format
msgid "G__open_misc(read): mapset <%s> doesn't match xmapset <%s>"
-msgstr "G__open_misc(read): mapset <%s> äåí ôáéñéÜæåé xmapset <%s>"
+msgstr "G__open_misc(read): mapset <%s> δεν ÏαιÏιάζει xmapset <%s>"
#: ../lib/gis/open_misc.c:67
#, c-format
@@ -2779,55 +2779,55 @@
#: ../lib/gis/get_ellipse.c:85
#, c-format
msgid "Unable to open file %s in <%s>"
-msgstr "Áäõíáìßá áíïßãìáôïò áñ÷åßïõ %s óôï <%s>"
+msgstr "ÎδÏ
%s ÏÏο <%s>"
#: ../lib/gis/get_ellipse.c:358 ../lib/gis/get_ellipse.c:384
#, c-format
msgid "Invalid a: field '%s' in file %s in <%s>"
-msgstr "ËÜèïò a: ðåäßï '%s' óôï áñ÷åßï %s óôï <%s>"
+msgstr "ÎÎ¬Î¸Î¿Ï a: Ïεδίο '%s' ÏÏο αÏÏείο %s ÏÏο <%s>"
#: ../lib/gis/get_ellipse.c:371
#, c-format
msgid "Invalid ellipsoid '%s' in file %s in <%s>"
-msgstr "ËÜèïò åëëåéøïåéäÝò '%s' óôï áñ÷åßï %s óôï <%s>"
+msgstr "ÎÎ¬Î¸Î¿Ï ÎµÎ»Î»ÎµÎ¹ÏοειδÎÏ '%s' ÏÏο αÏÏείο %s ÏÏο <%s>"
#: ../lib/gis/get_ellipse.c:388
#, c-format
msgid "Invalid es: field '%s' in file %s in <%s>"
-msgstr "ËÜèïò es: ðåäßï '%s' óôï áñ÷åßï %s óôï <%s>"
+msgstr "ÎÎ¬Î¸Î¿Ï es: Ïεδίο '%s' ÏÏο αÏÏείο %s ÏÏο <%s>"
#: ../lib/gis/get_ellipse.c:402
#, c-format
msgid "No ellipsoid info given in file %s in <%s>"
-msgstr "Äåí Ý÷ïõí äùèåß ðëçñïöïñßåò ãéá ôï åëëåéøïåéäÝò óôï áñ÷åßï %s óôï <%s>"
+msgstr "Îεν ÎÏοÏ
ν δÏθεί ÏληÏοÏοÏÎ¯ÎµÏ Î³Î¹Î± Ïο ελλειÏοειδÎÏ ÏÏο αÏÏείο %s ÏÏο <%s>"
#: ../lib/gis/parser.c:340
msgid "WHERE conditions of SQL statement without 'where' keyword"
-msgstr "WHERE óõíèÞêåò ôçò SQL äÞëùóç ÷ùñßò 'where' ëÝîç-êëåéäß"
+msgstr "WHERE ÏÏ
Î½Î¸Î®ÎºÎµÏ ÏÎ·Ï SQL δήλÏÏη ÏÏÏÎ¯Ï 'where' λÎξη-κλειδί"
#: ../lib/gis/parser.c:341
msgid "Example: income < 1000 and inhab >= 10000"
-msgstr "ÐáñÜäåéãìá: income < 1000 and inhab >= 10000"
+msgstr "ΠαÏάδειγμα: income < 1000 and inhab >= 10000"
#: ../lib/gis/parser.c:349
msgid "Table name"
-msgstr "¼íïìá ðßíáêá"
+msgstr "Îνομα Ïίνακα"
#: ../lib/gis/parser.c:358
msgid "Driver name"
-msgstr "¼íïìá ïäçãïý"
+msgstr "Îνομα οδηγοÏ"
#: ../lib/gis/parser.c:367
msgid "Database name"
-msgstr "¼íïìá âÜóçò äåäïìÝíùí"
+msgstr "Îνομα βάÏÎ·Ï Î´ÎµÎ´Î¿Î¼ÎνÏν"
#: ../lib/gis/parser.c:376
msgid "Name of attribute column"
-msgstr "¼íïìá óôÞëçò"
+msgstr "Îνομα ÏÏήληÏ"
#: ../lib/gis/parser.c:385
msgid "Name of attribute column(s)"
-msgstr "¼íïìá óôçëþí"
+msgstr "Îνομα ÏÏηλÏν"
#: ../lib/gis/parser.c:396
msgid "Name of input imagery group"
@@ -2839,108 +2839,108 @@
#: ../lib/gis/parser.c:414 ../lib/gis/parser.c:439
msgid "Name of input raster map"
-msgstr "¼íïìá åéóáãþìåíïõ ñÜóôåñ ÷Üñôç "
+msgstr "Îνομα ειÏαγÏμενοÏ
ÏάÏÏÎµÏ ÏάÏÏη "
#: ../lib/gis/parser.c:423 ../lib/gis/parser.c:448
msgid "Name of input raster map(s)"
-msgstr "¼íïìá åéóáãþìåíùí ñÜóôåñ ÷áñôþí"
+msgstr "Îνομα ειÏαγÏμενÏν ÏάÏÏÎµÏ ÏαÏÏÏν"
#: ../lib/gis/parser.c:431
msgid "Name for output raster map"
-msgstr "¼íïìá åîáãüìåíïõ ñÜóôåñ ÷Üñôç"
+msgstr "Îνομα εξαγÏμενοÏ
ÏάÏÏÎµÏ ÏάÏÏη"
#: ../lib/gis/parser.c:456
msgid "Name of base raster map"
-msgstr "¼íïìá ÷Üñôç õðïâÜèñïõ ñÜóôåñ"
+msgstr "Îνομα ÏάÏÏη Ï
ÏοβάθÏοÏ
ÏάÏÏεÏ"
#: ../lib/gis/parser.c:464
msgid "Name of cover raster map"
#: ../lib/gis/parser.c:472
msgid "Name of elevation raster map"
-msgstr "¼íïìá ñÜóôåñ ÷Üñôç õøïìÝôñïõ"
+msgstr "Îνομα ÏάÏÏÎµÏ ÏάÏÏη Ï
ÏομÎÏÏοÏ
#: ../lib/gis/parser.c:481
msgid "Name of elevation raster map(s)"
-msgstr "¼íïìá ñÜóôåñ ÷áñôþí õøïìÝôñïõ"
+msgstr "Îνομα ÏάÏÏÎµÏ ÏαÏÏÏν Ï
ÏομÎÏÏοÏ
#: ../lib/gis/parser.c:491 ../lib/gis/parser.c:516
msgid "Name of input raster3d map"
-msgstr "¼íïìá åéóáãþìåíùí 3Ä ñÜóôåñ ÷Üñôç"
+msgstr "Îνομα ειÏαγÏμενÏν 3Î ÏάÏÏÎµÏ ÏάÏÏη"
#: ../lib/gis/parser.c:500 ../lib/gis/parser.c:525
msgid "Name of input raster3d map(s)"
-msgstr "¼íïìá åéóáãþìåíùí 3Ä ñÜóôåñ ÷áñôþí"
+msgstr "Îνομα ειÏαγÏμενÏν 3Î ÏάÏÏÎµÏ ÏαÏÏÏν"
#: ../lib/gis/parser.c:508
msgid "Name for output raster3d map"
-msgstr "¼íïìá åîáãüìåíïõ 3Ä ñÜóôåñ ÷Üñôç"
3Î ÏάÏÏÎµÏ ÏάÏÏη"
#: ../lib/gis/parser.c:535 ../lib/gis/parser.c:560
msgid "Name of input vector map"
-msgstr "¼íïìá åéóáãüìåíïõ äéáíõóìáôéêïý ÷Üñôç"
διανÏ
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη"
#: ../lib/gis/parser.c:544 ../lib/gis/parser.c:569
msgid "Name of input vector map(s)"
-msgstr "¼íïìá åéóáãüìåíùí äéáíõóìáôéêùí ÷áñôþí"
+msgstr "Îνομα ειÏαγÏμενÏν διανÏ
ÏμαÏικÏν ÏαÏÏÏν"
#: ../lib/gis/parser.c:552
msgid "Name for output vector map"
-msgstr "¼íïìá åîáãüìåíïõ äéáíõóìáôéêïý ÷Üñôç"
διανÏ
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη"
#: ../lib/gis/parser.c:578 ../lib/gis/parser.c:587
#, fuzzy
msgid "Feature type"
-msgstr "Ôýðïé äåäïìÝíùí"
+msgstr "ΤÏÏοι δεδομÎνÏν"
#: ../lib/gis/parser.c:594
msgid "Layer number"
-msgstr "Íïýìåñï åðéðÝäïõ"
+msgstr "ÎοÏμεÏο εÏιÏÎδοÏ
#: ../lib/gis/parser.c:596
msgid ""
"A single vector map can be connected to multiple database tables. This "
"number determines which table to use."
msgstr ""
-"¸íáò äéáíõóìáôéêüò ÷Üñôçò åßíáé äõíáôüí íá óõíäåèåß ìå ðïëëáðëïýò ðßíáêåò. "
-"Áõôüò áñéèìüò êáèïñßæåé ðïéïò ðßíáêáò èá ÷ñçóéìïðïéçèåß."
+"ÎÎ½Î±Ï Î´Î¹Î±Î½Ï
ÏμαÏικÏÏ ÏάÏÏÎ·Ï ÎµÎ¯Î½Î±Î¹ δÏ
ναÏÏν να ÏÏ
νδεθεί με ÏολλαÏλοÏÏ ÏίνακεÏ. "
+"ÎÏ
ÏÏÏ Î±ÏιθμÏÏ ÎºÎ±Î¸Î¿Ïίζει ÏÎ¿Î¹Î¿Ï ÏÎ¯Î½Î±ÎºÎ±Ï Î¸Î± ÏÏηÏιμοÏοιηθεί."
#: ../lib/gis/parser.c:605
msgid "Category value"
-msgstr "ÔéìÞ êáôçãïñßáò"
+msgstr "Τιμή καÏηγοÏίαÏ"
#: ../lib/gis/parser.c:612
msgid "Category values"
-msgstr "ÔéìÝò êáôçãïñéþí"
+msgstr "ΤιμÎÏ ÎºÎ±ÏηγοÏιÏν"
#: ../lib/gis/parser.c:613 ../lib/gis/parser.c:627
msgid "Example: 1,3,7-9,13"
-msgstr "ÐáñÜäåéãìá: 1,3,7-9,13"
+msgstr "ΠαÏάδειγμα: 1,3,7-9,13"
#: ../lib/gis/parser.c:619
#, fuzzy
msgid "Feature id"
-msgstr "×áñáêôçñéóôéêü: "
+msgstr "ΧαÏακÏηÏιÏÏικÏ: "
#: ../lib/gis/parser.c:626
#, fuzzy
msgid "Feature ids"
#: ../lib/gis/parser.c:637
#, fuzzy
msgid "Name of input file"
-msgstr "¼íïìá áñ÷åßïõ åéóáãùãÞò"
+msgstr "Îνομα αÏÏείοÏ
ειÏαγÏγήÏ"
#: ../lib/gis/parser.c:645
#, fuzzy
msgid "Name for output file"
-msgstr "¼íïìá áñ÷åßïõ åîáãùãÞò"
εξαγÏγήÏ"
#: ../lib/gis/parser.c:653
msgid "Field separator"
-msgstr "Äéá÷ùñéóôÞò ðåäßùí (ð.÷. , . tab)"
+msgstr "ÎιαÏÏÏιÏÏÎ®Ï ÏεδίÏν (Ï.Ï. , . tab)"
#: ../lib/gis/parser.c:654
msgid "Special characters: newline, space, comma, tab"
@@ -2948,39 +2948,39 @@
#: ../lib/gis/parser.c:665
msgid "Color"
-msgstr "×ñþìá"
+msgstr "ΧÏÏμα"
#: ../lib/gis/parser.c:666
msgid "Either a standard color name or R:G:B triplet"
-msgstr "Åßôå Ýíá óôáíôáñ üíïìá ÷ñþìáôïò Þ óõíäõáóìüò R:G:B"
+msgstr "ÎίÏε Îνα ÏÏανÏÎ±Ï Ïνομα ÏÏÏμαÏÎ¿Ï Î® ÏÏ
νδÏ
αÏμÏÏ R:G:B"
#: ../lib/gis/parser.c:675
msgid "Background color"
-msgstr "×ñþìá öüíôïõ"
+msgstr "ΧÏÏμα ÏÏνÏοÏ
#: ../lib/gis/parser.c:677
msgid "Either a standard GRASS color, R:G:B triplet, or \"none\""
-msgstr "Äþóôå Ýíá óôáíôáñ ÷ñþìá GRASS, óõíäõáóìü R:G:B Þ \"none\""
+msgstr "ÎÏÏÏε Îνα ÏÏανÏÎ±Ï ÏÏÏμα GRASS, ÏÏ
νδÏ
αÏÎ¼Ï R:G:B ή \"none\""
#: ../lib/gis/parser.c:818
#, c-format
msgid "BUG in descriptions, option '%s' in <%s> does not exist"
-msgstr "BUG óôéò ðåñéãñáöÝò, åðéëïãÞ '%s' óôï <%s> äåí õðÜñ÷åé"
+msgstr "BUG ÏÏÎ¹Ï ÏεÏιγÏαÏÎÏ, εÏιλογή '%s' ÏÏο <%s> δεν Ï
ÏάÏÏει"
#: ../lib/gis/parser.c:926
msgid "Use either --quiet or --verbose flag, not both. Assuming --verbose."
msgstr ""
-"×ñçóéìïðïéÞóôå --quiet Þ --verbose flag, ü÷é êáé ôá äýï. ÕðïèÝôù --verbose."
+"ΧÏηÏιμοÏοιήÏÏε --quiet ή --verbose flag, ÏÏι και Ïα δÏο. Î¥ÏοθÎÏÏ --verbose."
#: ../lib/gis/parser.c:940
msgid "Use either --quiet or --verbose flag, not both. Assuming --quiet."
msgstr ""
-"×ñçóéìïðïéÞóôå --quiet Þ --verbose flag, ü÷é êáé ôá äýï. ÕðïèÝôù --quiet."
+"ΧÏηÏιμοÏοιήÏÏε --quiet ή --verbose flag, ÏÏι και Ïα δÏο. Î¥ÏοθÎÏÏ --quiet."
#: ../lib/gis/parser.c:971
#, c-format
msgid "Sorry <%s> is not a valid option\n"
-msgstr "Óõãíþìç <%s> äåí åßíáé áðïäåêôÞ åðéëïãÞ\n"
+msgstr "ΣÏ
γνÏμη <%s> δεν είναι αÏοδεκÏή εÏιλογή\n"
#: ../lib/gis/parser.c:1075
#, c-format
@@ -2989,7 +2989,7 @@
"Description:\n"
msgstr ""
"\n"
-"ÐåñéãñáöÞ:\n"
+"ΠεÏιγÏαÏή:\n"
#: ../lib/gis/parser.c:1082
#, c-format
@@ -2998,7 +2998,7 @@
"Keywords:\n"
msgstr ""
"\n"
-"ËÝîåéò êëåéäéÜ:\n"
+"ÎÎÎ¾ÎµÎ¹Ï ÎºÎ»ÎµÎ¹Î´Î¹Î¬:\n"
#: ../lib/gis/parser.c:1086
#, c-format
@@ -3008,7 +3008,7 @@
msgstr ""
"\n"
-"×ñÞóç:\n"
+"ΧÏήÏη:\n"
#: ../lib/gis/parser.c:1154
@@ -3023,15 +3023,15 @@
#: ../lib/gis/parser.c:1177 ../lib/gis/parser.c:1501 ../lib/gis/parser.c:1661
#: ../lib/gis/parser.c:1949
msgid "Allow output files to overwrite existing files"
-msgstr "ÅðéôñÝðåé ôá åîáãüìåíá áñ÷åßá íá åðéêáëýðôïõí ôá õðÜñ÷ïíôá"
+msgstr "ÎÏιÏÏÎÏει Ïα εξαγÏμενα αÏÏεία να εÏικαλÏÏÏοÏ
ν Ïα Ï
ÏάÏÏονÏα"
#: ../lib/gis/parser.c:1179 ../lib/gis/parser.c:1509 ../lib/gis/parser.c:1665
msgid "Verbose module output"
-msgstr "Verbose module åîáãùãÞ"
+msgstr "Verbose module εξαγÏγή"
#: ../lib/gis/parser.c:1180 ../lib/gis/parser.c:1516 ../lib/gis/parser.c:1668
msgid "Quiet module output"
-msgstr "Quiet module åîáãùãÞ"
+msgstr "Quiet module εξαγÏγή"
#: ../lib/gis/parser.c:1185
#, c-format
@@ -3040,24 +3040,24 @@
"Parameters:\n"
msgstr ""
"\n"
-"ÐáñÜìåôñïé:\n"
+"ΠαÏάμεÏÏοι:\n"
#: ../lib/gis/parser.c:1208
#, c-format
msgid " %*s default: %s\n"
-msgstr " %*s ðñïåðéëïãÞ: %s\n"
+msgstr " %*s ÏÏοεÏιλογή: %s\n"
#: ../lib/gis/parser.c:1552
msgid "NAME"
-msgstr "ÏÍÏÌÁ"
+msgstr "ÎÎÎÎÎ"
#: ../lib/gis/parser.c:1565
msgid "KEYWORDS"
-msgstr "ËÅÎÅÉÓ ÊËÅÉÄÉÁ"
+msgstr "ÎÎÎÎÎΣ ÎÎÎÎÎÎÎ"
#: ../lib/gis/parser.c:1570
msgid "SYNOPSIS"
-msgstr "ÓÕÍÏØÇ"
+msgstr "ΣΥÎÎΨÎ"
#: ../lib/gis/parser.c:1638
msgid "Flags"
@@ -3065,27 +3065,27 @@
#: ../lib/gis/parser.c:1676
msgid "Parameters"
-msgstr "ÐáñÜìåôñïé"
+msgstr "ΠαÏάμεÏÏοι"
#: ../lib/gis/parser.c:1716
msgid "Options"
-msgstr "ÅðéëïãÝò"
+msgstr "ÎÏιλογÎÏ"
#: ../lib/gis/parser.c:1722
msgid "Default"
-msgstr "ÐñïåðéëïãÞ"
+msgstr "Î ÏοεÏιλογή"
#: ../lib/gis/parser.c:1951
msgid "Allow overwrite"
-msgstr "ÅðéôñÝðåé åðéêÜëõøç"
+msgstr "ÎÏιÏÏÎÏει εÏικάλÏ
Ïη"
#: ../lib/gis/parser.c:1959
msgid "Run with minimal output messages"
-msgstr "ÔñÝ÷åé ìå ôá ëéãüôåñá åîáãþìåíá ìçíýìáôá"
+msgstr "ΤÏÎÏει με Ïα λιγÏÏεÏα εξαγÏμενα μηνÏμαÏα"
#: ../lib/gis/parser.c:1961
msgid "Run quietly"
-msgstr "ÔñÝ÷åé ÷ùñßò ìçíýìáôá"
+msgstr "ΤÏÎÏει ÏÏÏÎ¯Ï Î¼Î·Î½ÏμαÏα"
#: ../lib/gis/parser.c:1994
msgid "Unable to spawn the 'wish' program"
@@ -3093,12 +3093,12 @@
#: ../lib/gis/parser.c:2013
msgid "Unable to determine program name"
-msgstr "Áäõíáìßá ðñïóäéïñéóìïý ôïõ ïíüìáôïò ôïõ ðñïãñÜììáôïò"
+msgstr "ÎδÏ
ναμία ÏÏοÏδιοÏιÏÎ¼Î¿Ï ÏοÏ
ονÏμαÏÎ¿Ï ÏοÏ
ÏÏογÏάμμαÏοÏ"
#: ../lib/gis/parser.c:2070
#, c-format
msgid " %*s options: "
-msgstr " %*s åðéëïãÝò: "
+msgstr " %*s εÏιλογÎÏ: "
#: ../lib/gis/parser.c:2115 ../lib/gis/parser.c:2130
#, c-format
@@ -3108,12 +3108,12 @@
#: ../lib/gis/parser.c:2196
#, c-format
msgid "Sorry, <%s=> is ambiguous\n"
-msgstr "Óõãíþìç, <%s=> åßíáé áìößóçìï\n"
+msgstr "ΣÏ
γνÏμη, <%s=> είναι αμÏίÏημο\n"
#: ../lib/gis/parser.c:2202
#, c-format
msgid "Sorry, <%s> is not a valid parameter\n"
-msgstr "Óõãíþìç, <%s> äåí åßíáé åðéôñåðôÞ ðáñÜìåôñïò\n"
+msgstr "ΣÏ
γνÏμη, <%s> δεν είναι εÏιÏÏεÏÏή ÏαÏάμεÏÏοÏ\n"
#: ../lib/gis/parser.c:2209
#, c-format
@@ -3127,12 +3127,12 @@
"ERROR: illegal range syntax for parameter <%s>\n"
msgstr ""
"\n"
-"ÓÖÁËÌÁ: ìç åðéôñåðôü óýíôáîç åýñïõò ãéá ôçí ðáñÜìåôñï <%s>\n"
+"ΣΦÎÎÎÎ: μη εÏιÏÏεÏÏÏ ÏÏνÏαξη εÏÏοÏ
Ï Î³Î¹Î± Ïην ÏαÏάμεÏÏο <%s>\n"
#: ../lib/gis/parser.c:2288
#, c-format
msgid " Presented as: %s\n"
-msgstr " ÐáñïõóéÜæåôáé ùò: %s\n"
+msgstr " ΠαÏοÏ
ÏιάζεÏαι ÏÏ: %s\n"
#: ../lib/gis/parser.c:2292
#, c-format
@@ -3141,12 +3141,12 @@
"ERROR: value <%s> out of range for parameter <%s>\n"
msgstr ""
"\n"
-"ÓÖÁËÌÁ: ç ôéìÞ <%s> åßíáé åêôüò ïñßùí <%s>\n"
+"ΣΦÎÎÎÎ: η Ïιμή <%s> είναι εκÏÏÏ Î¿ÏίÏν <%s>\n"
#: ../lib/gis/parser.c:2294
#, c-format
msgid " Legal range: %s\n"
-msgstr " Áðïäåêôü åýñïò ôéìþí: %s\n"
+msgstr " ÎÏοδεκÏÏ ÎµÏÏÎ¿Ï ÏιμÏν: %s\n"
#: ../lib/gis/parser.c:2297
#, c-format
@@ -3155,7 +3155,7 @@
"ERROR: Missing value for parameter <%s>\n"
msgstr ""
"\n"
-"ÓÖÁËÌÁ: Ëåßðåé ôéìÞ ãéá ôçí ðáñÜìåôñï <%s>\n"
+"ΣΦÎÎÎÎ: ÎείÏει Ïιμή για Ïην ÏαÏάμεÏÏο <%s>\n"
#: ../lib/gis/parser.c:2445
#, fuzzy, c-format
@@ -3164,7 +3164,7 @@
"\t(%s)\n"
msgstr ""
"\n"
-"ÓÖÁËÌÁ: Ç áðáéôïýìåíç ðáñÜìåôñïò <%s> äåí Ý÷åé êáèïñéóôåß:\n"
+"ΣΦÎÎÎÎ: ΠαÏαιÏοÏμενη ÏαÏάμεÏÏÎ¿Ï <%s> δεν ÎÏει καθοÏιÏÏεί:\n"
" (%s).\n"
#: ../lib/gis/parser.c:2540
@@ -3174,17 +3174,17 @@
"ERROR: option <%s> must be provided in multiples of %d\n"
msgstr ""
"\n"
-"ÓÖÁËÌÁ: ç åðéëïãÞ <%s> ðñÝðåé íá äùèåß óå ðïëëáðëÜóéá ôïõ %d\n"
+"ΣΦÎÎÎÎ: η εÏιλογή <%s> ÏÏÎÏει να δÏθεί Ïε ÏολλαÏλάÏια ÏοÏ
%d\n"
#: ../lib/gis/parser.c:2542
#, c-format
msgid " You provided %d items:\n"
-msgstr " Äþóáôå %d áíôéêåßìåíá:\n"
+msgstr " ÎÏÏαÏε %d ανÏικείμενα:\n"
#: ../lib/gis/parser.c:2598
#, c-format
msgid "ERROR: option <%s>: <%s> exists.\n"
-msgstr "ÓÖÁËÌÁ: Ç åðéëïãÞ <%s>: <%s> õðÜñ÷åé.\n"
+msgstr "ΣΦÎÎÎÎ: ΠεÏιλογή <%s>: <%s> Ï
ÏάÏÏει.\n"
#: ../lib/gis/parser.c:2653
#, c-format
@@ -3200,51 +3200,51 @@
"OPTION: %s\n"
msgstr ""
"\n"
-"ÅÐÉËÏÃÇ: %s\n"
+"ÎÎ ÎÎÎÎÎ: %s\n"
#: ../lib/gis/parser.c:2668
#, c-format
msgid " key: %s\n"
-msgstr " êëåéäß: %s\n"
+msgstr " κλειδί: %s\n"
#: ../lib/gis/parser.c:2670
#, c-format
msgid " format: %s\n"
-msgstr " öïñìÜô: %s\n"
+msgstr " ÏοÏμάÏ: %s\n"
#: ../lib/gis/parser.c:2672
#, c-format
msgid " default: %s\n"
-msgstr " ðñïåðéëåãìÝíï: %s\n"
+msgstr " ÏÏοεÏιλεγμÎνο: %s\n"
#: ../lib/gis/parser.c:2673
#, c-format
msgid "required: %s\n"
-msgstr "áðáéôïýìåíï: %s\n"
+msgstr "αÏαιÏοÏμενο: %s\n"
#: ../lib/gis/parser.c:2675
#, c-format
msgid "multiple: %s\n"
-msgstr "ðïëëáðëÜóéï: %s\n"
+msgstr "ÏολλαÏλάÏιο: %s\n"
#: ../lib/gis/parser.c:2677
#, c-format
msgid " options: %s\n"
-msgstr " åðéëïãÝò: %s\n"
+msgstr " εÏιλογÎÏ: %s\n"
#: ../lib/gis/parser.c:2690
#, c-format
msgid "enter option > "
-msgstr "äþóôå åðéëïãÞ > "
+msgstr "δÏÏÏε εÏιλογή > "
#: ../lib/gis/parser.c:2707 ../lib/gis/parser.c:2717
msgid " Try again? "
-msgstr " ÐñïóðáèÞóôå îáíÜ? "
+msgstr " Î ÏοÏÏαθήÏÏε ξανά? "
#: ../lib/gis/parser.c:2715
#, c-format
msgid "Sorry, %s is not accepted.\n"
-msgstr "Óõãíþìç, %s äåí åßíáé áðïäåêôü.\n"
+msgstr "ΣÏ
γνÏμη, %s δεν είναι αÏοδεκÏÏ.\n"
#: ../lib/gis/parser.c:2725
#, c-format
@@ -3254,16 +3254,16 @@
" %s\n"
msgstr ""
"\n"
-"¸÷åôå åðéëÝîåé:\n"
+"ÎÏεÏε εÏιλÎξει:\n"
" %s\n"
#: ../lib/gis/parser.c:2726
msgid "Is this correct? "
-msgstr "Åßíáé óùóôü;"
+msgstr "Îίναι ÏÏÏÏÏ;"
#: ../lib/gis/parser.c:2791
msgid "to accept the default"
-msgstr "ãéá íá áðïäåêôåßôå ôï ðñïêáèïñéóìÝíï"
+msgstr "για να αÏοδεκÏείÏε Ïο ÏÏοκαθοÏιÏμÎνο"
#: ../lib/gis/get_ell_name.c:42
#, c-format
@@ -3272,12 +3272,12 @@
"Please specify ellipsoid name\n"
msgstr ""
"\n"
-"Ðáñáêáëþ ðñïóäéïñßóôå ôï üíïìá ôïõ åëëåéøïåéäïýò\n"
+"ΠαÏÎ±ÎºÎ±Î»Ï ÏÏοÏδιοÏίÏÏε Ïο Ïνομα ÏοÏ
ελλειÏοειδοÏÏ\n"
#: ../lib/gis/get_ell_name.c:44
#, c-format
msgid "Enter 'list' for the list of available ellipsoids\n"
-msgstr "Äþóå ôçí åíôïëÞ 'list' ãéá ëßóôá äéáèÝóéìùí åëëåéøïåéäþí\n"
+msgstr "ÎÏÏε Ïην ενÏολή 'list' για λίÏÏα διαθÎÏιμÏν ελλειÏοειδÏν\n"
#: ../lib/gis/get_ell_name.c:67
#, c-format
@@ -3286,17 +3286,17 @@
"invalid ellipsoid\n"
msgstr ""
"\n"
-"ìÞ åðéôñåðôü åëëåéøïåéäÝò\n"
+"μή εÏιÏÏεÏÏÏ ÎµÎ»Î»ÎµÎ¹ÏοειδÎÏ\n"
#: ../lib/gis/quant_io.c:89
#, c-format
msgid "The floating data range for %s@%s is empty"
-msgstr "Ôï ðåäßï õðïäéáóôïëÞò ãéá %s@%s åßíáé Üäåéï"
+msgstr "Το Ïεδίο Ï
ÏοδιαÏÏÎ¿Î»Î®Ï Î³Î¹Î± %s@%s είναι άδειο"
#: ../lib/gis/quant_io.c:99
#, c-format
msgid "The integer data range for %s@%s is empty"
-msgstr "Ôï ðåäßï áêÝñáéïõ áñéèìïý ãéá %s@%s åßíáé Üäåéï"
+msgstr "Το Ïεδίο ακÎÏαιοÏ
αÏÎ¹Î¸Î¼Î¿Ï Î³Î¹Î± %s@%s είναι άδειο"
#: ../lib/gis/quant_io.c:168
#, c-format
@@ -3309,17 +3309,17 @@
"region for current mapset %s\n"
"run \"g.region\""
msgstr ""
-"ðåñéï÷Þ ãéá ôï ôñÝ÷ïí mapset %s\n"
-"äþóôå ôçí åíôïëÞ \"g.region\""
+"ÏεÏιοÏή για Ïο ÏÏÎÏον mapset %s\n"
+"δÏÏÏε Ïην ενÏολή \"g.region\""
#: ../lib/gis/get_window.c:120
#, c-format
msgid "default region %s"
-msgstr "ðñïåðéëåãìÝíç ðåéñéï÷Þ %s"
+msgstr "ÏÏοεÏιλεγμÎνη ÏειÏιοÏή %s"
#: ../lib/gis/get_window.c:141
msgid "is not set"
-msgstr "äåí Ý÷åé êáèïñéóôåß"
+msgstr "δεν ÎÏει καθοÏιÏÏεί"
#: ../lib/gis/get_window.c:150
#, c-format
@@ -3327,81 +3327,81 @@
"is invalid\n"
"%s"
msgstr ""
-"åßíáé ëáíèáóìÝíç\n"
+"είναι λανθαÏμÎνη\n"
"%s"
#: ../lib/gis/format.c:157
#, c-format
msgid "Fail of initial read of compressed file [%s in %s]"
-msgstr "ÓöÜëìá áñ÷éêÞò ðñïóðÝëáóçò ôïõ óõìðéåóìÝíïõ áñ÷åßïõ [%s in %s]"
+msgstr "ΣÏάλμα αÏÏÎ¹ÎºÎ®Ï ÏÏοÏÏÎλαÏÎ·Ï ÏοÏ
ÏÏ
μÏιεÏμÎνοÏ
αÏÏείοÏ
[%s in %s]"
#: ../lib/gis/rd_cellhd.c:143
msgid "duplicate projection field"
-msgstr "äéðëü ðåäßï ðñïâïëÞò"
+msgstr "διÏÎ»Ï Ïεδίο ÏÏοβολήÏ"
#: ../lib/gis/rd_cellhd.c:153
msgid "duplicate zone field"
-msgstr "äéðëü ðåäßï æþíçò"
+msgstr "διÏÎ»Ï Ïεδίο ζÏνηÏ"
#: ../lib/gis/rd_cellhd.c:163
msgid "projection field missing"
-msgstr "ç ðåäßï ðñïâïëÞò ëåßðåé"
+msgstr "η Ïεδίο ÏÏÎ¿Î²Î¿Î»Î®Ï Î»ÎµÎ¯Ïει"
#: ../lib/gis/rd_cellhd.c:165
msgid "zone field missing"
-msgstr "ôï ðåäßï æþíçò ëåßðåé"
+msgstr "Ïο Ïεδίο ζÏÎ½Î·Ï Î»ÎµÎ¯Ïει"
#: ../lib/gis/rd_cellhd.c:187
msgid "duplicate north field"
-msgstr "äéðëü ðåäßï âïñÜ"
+msgstr "διÏÎ»Ï Ïεδίο βοÏά"
#: ../lib/gis/rd_cellhd.c:195
msgid "duplicate south field"
-msgstr "äéðëü ðåäßï íüôïõ"
+msgstr "διÏÎ»Ï Ïεδίο νÏÏοÏ
#: ../lib/gis/rd_cellhd.c:203
msgid "duplicate east field"
-msgstr "äéðëü ðåäßï áíáôïëÞò"
+msgstr "διÏÎ»Ï Ïεδίο αναÏολήÏ"
#: ../lib/gis/rd_cellhd.c:211
msgid "duplicate west field"
-msgstr "äéðëü ðåäßï äýóçò"
+msgstr "διÏÎ»Ï Ïεδίο δÏÏηÏ"
#: ../lib/gis/rd_cellhd.c:219
msgid "duplicate top field"
-msgstr "äéðëü ðåäßï ðÜíù"
+msgstr "διÏÎ»Ï Ïεδίο ÏάνÏ"
#: ../lib/gis/rd_cellhd.c:227
msgid "duplicate bottom field"
-msgstr "äéðëü ðåäßï êÜôù"
+msgstr "διÏÎ»Ï Ïεδίο κάÏÏ"
#: ../lib/gis/rd_cellhd.c:235
msgid "duplicate e-w resolution field"
-msgstr "äéðëü ðåäßï e-w áíÜëõóçò"
+msgstr "διÏÎ»Ï Ïεδίο e-w ανάλÏ
ÏηÏ"
#: ../lib/gis/rd_cellhd.c:245
msgid "duplicate 3D e-w resolution field"
-msgstr "äéðëü ðåäßï 3Ä e-w áíÜëõóçò"
+msgstr "διÏÎ»Ï Ïεδίο 3Î e-w ανάλÏ
ÏηÏ"
#: ../lib/gis/rd_cellhd.c:255
msgid "duplicate n-s resolution field"
-msgstr "äéðëü ðåäßï n-s áíÜëõóçò"
+msgstr "διÏÎ»Ï Ïεδίο n-s ανάλÏ
ÏηÏ"
#: ../lib/gis/rd_cellhd.c:265
msgid "duplicate 3D n-s resolution field"
-msgstr "äéðëü ðåäßï 3Ä n-s áíÜëõóçò"
+msgstr "διÏÎ»Ï Ïεδίο 3Î n-s ανάλÏ
ÏηÏ"
#: ../lib/gis/rd_cellhd.c:275
msgid "duplicate t-b resolution field"
-msgstr "äéðëü ðåäßï t-b áíÜëõóçò"
+msgstr "διÏÎ»Ï Ïεδίο t-b ανάλÏ
ÏηÏ"
#: ../lib/gis/rd_cellhd.c:285
msgid "duplicate rows field"
-msgstr "äéðëü ðåäßï ãñáììþí"
+msgstr "διÏÎ»Ï Ïεδίο γÏαμμÏν"
#: ../lib/gis/rd_cellhd.c:295
msgid "duplicate 3D rows field"
-msgstr "äéðëü ðåäßï 3Ä ãñáììþí"
+msgstr "διÏÎ»Ï Ïεδίο 3ΠγÏαμμÏν"
#: ../lib/gis/rd_cellhd.c:305
msgid "duplicate cols field"
@@ -3409,124 +3409,124 @@
#: ../lib/gis/rd_cellhd.c:315
msgid "duplicate 3D cols field"
-msgstr "äéðëü ðåäßï 3Ä cols"
+msgstr "διÏÎ»Ï Ïεδίο 3Î cols"
#: ../lib/gis/rd_cellhd.c:325
msgid "duplicate depths field"
-msgstr "äéðëü ðåäßï âÜèïõò"
+msgstr "διÏÎ»Ï Ïεδίο βάθοÏ
Ï"
#: ../lib/gis/rd_cellhd.c:335
msgid "duplicate format field"
-msgstr "äéðëü ðåäßï öïñìÜô"
+msgstr "διÏÎ»Ï Ïεδίο ÏοÏμάÏ"
#: ../lib/gis/rd_cellhd.c:343
msgid "duplicate compressed field"
-msgstr "äéðëü ðåäßï óõìðéåóìÝíïõ áñ÷åßïõ"
μÏιεÏμÎνοÏ
αÏÏείοÏ
#: ../lib/gis/rd_cellhd.c:354
msgid "north field missing"
-msgstr "Ôï ðåäßïõ âïñÜ ëåßðåé"
+msgstr "Το ÏεδίοÏ
βοÏά λείÏει"
#: ../lib/gis/rd_cellhd.c:356
msgid "south field missing"
-msgstr "Ôï ðåäßïõ íüôïõ ëåßðåé"
+msgstr "Το ÏεδίοÏ
νÏÏοÏ
λείÏει"
#: ../lib/gis/rd_cellhd.c:358
msgid "west field missing"
-msgstr "Ôï ðåäßïõ äýóçò ëåßðåé"
+msgstr "Το ÏεδίοÏ
δÏÏÎ·Ï Î»ÎµÎ¯Ïει"
#: ../lib/gis/rd_cellhd.c:360
msgid "east field missing"
-msgstr "Ôï ðåäßïõ áíáôïëÞò ëåßðåé"
+msgstr "Το ÏεδίοÏ
αναÏÎ¿Î»Î®Ï Î»ÎµÎ¯Ïει"
#: ../lib/gis/rd_cellhd.c:362
msgid "cols field missing"
-msgstr "Ôï ðåäßïõ colsëåßðåé"
+msgstr "Το ÏεδίοÏ
colsλείÏει"
#: ../lib/gis/rd_cellhd.c:364
msgid "rows field missing"
-msgstr "Ôï ðåäßïõ ãñáììþí ëåßðåé"
+msgstr "Το ÏεδίοÏ
γÏαμμÏν λείÏει"
#: ../lib/gis/rd_cellhd.c:375
msgid "ewres3 field missing"
-msgstr "Ôï ðåäßïõ ewres3 ëåßðåé"
+msgstr "Το ÏεδίοÏ
ewres3 λείÏει"
#: ../lib/gis/rd_cellhd.c:377
msgid "nsres3 field missing"
-msgstr "Ôï ðåäßïõ nsres3 ëåßðåé"
+msgstr "Το ÏεδίοÏ
nsres3 λείÏει"
#: ../lib/gis/rd_cellhd.c:379
msgid "cols3 field missing"
-msgstr "Ôï ðåäßïõ cols3 ëåßðåé"
+msgstr "Το ÏεδίοÏ
cols3 λείÏει"
#: ../lib/gis/rd_cellhd.c:381
msgid "rows3 field missing"
-msgstr "Ôï ðåäßïõ rows3 ëåßðåé"
+msgstr "Το ÏεδίοÏ
rows3 λείÏει"
#: ../lib/gis/rd_cellhd.c:438
#, c-format
msgid "line %d: <%s>"
-msgstr "ãñáììÞ %d: <%s>"
+msgstr "γÏαμμή %d: <%s>"
#: ../lib/gis/timestamp.c:282
#, c-format
msgid "Can't create timestamp file for %s map %s in mapset %s"
msgstr ""
-"Äåí ìðïñåß íá äçìéïõñãçåß timestamp áñ÷åßï ãéá %s ÷Üñôç %s óôï mapset %s"
+"Îεν μÏοÏεί να δημιοÏ
Ïγηεί timestamp αÏÏείο για %s ÏάÏÏη %s ÏÏο mapset %s"
#: ../lib/gis/timestamp.c:291
#, c-format
msgid "Invalid timestamp specified for %s map %s in mapset %s"
-msgstr "ËÜèïò timestamp êáèïñßóôçêå ãéá %s ÷Üñôç %s óôï mapset %s"
+msgstr "ÎÎ¬Î¸Î¿Ï timestamp καθοÏίÏÏηκε για %s ÏάÏÏη %s ÏÏο mapset %s"
#: ../lib/gis/timestamp.c:313
#, c-format
msgid "Can't open timestamp file for %s map %s in mapset %s"
-msgstr "Äåí ìðïñåß íá áíïßîåé timestamp áñ÷åßï ãéá %s ÷Üñôç %s óôï mapset %s"
+msgstr "Îεν μÏοÏεί να ανοίξει timestamp αÏÏείο για %s ÏάÏÏη %s ÏÏο mapset %s"
#: ../lib/gis/timestamp.c:322
#, c-format
msgid "Invalid timestamp file for %s map %s in mapset %s"
-msgstr "ËáíèáóìÝíï timestamp áñ÷åßï ãéá %s ÷Üñôç %s óôï mapset %s"
+msgstr "ÎανθαÏμÎνο timestamp αÏÏείο για %s ÏάÏÏη %s ÏÏο mapset %s"
#: ../lib/gis/get_projinfo.c:33 ../lib/gis/get_projinfo.c:60
#, c-format
msgid "<%s> file not found for location <%s>"
-msgstr "<%s> ôï áñ÷åßï äåí âñÝèçêå óôçí ôïðïèåóßá <%s>"
+msgstr "<%s> Ïο αÏÏείο δεν βÏÎθηκε ÏÏην ÏοÏοθεÏία <%s>"
#: ../lib/gis/get_projinfo.c:39 ../lib/gis/get_projinfo.c:66
#, c-format
msgid "ERROR in reading <%s> file for location <%s>"
-msgstr "ÓÖÁËÌÁ êáôÜ ôçí áíÜãíùóç <%s> áñ÷åßïõ áðü ôçí ôïðïèåóßá <%s>"
+msgstr "ΣΦÎÎÎΠκαÏά Ïην ανάγνÏÏη <%s> αÏÏείοÏ
αÏÏ Ïην ÏοÏοθεÏία <%s>"
#: ../lib/gis/gdal.c:66
#, c-format
msgid "Unable to locate symbol <%s>"
-msgstr "Áäõíáìßá åíôïðéóìïý óõìâüëïõ <%s>"
+msgstr "ÎδÏ
ναμία ενÏοÏιÏÎ¼Î¿Ï ÏÏ
μβÏλοÏ
<%s>"
#: ../lib/gis/gdal.c:114
msgid "Unable to load GDAL library"
-msgstr "Áäõíáìßá öüñôùóçò âéâëéïèÞêçò GDAL "
+msgstr "ÎδÏ
ναμία ÏÏÏÏÏÏÎ·Ï Î²Î¹Î²Î»Î¹Î¿Î¸Î®ÎºÎ·Ï GDAL "
#: ../lib/gis/histogram.c:57
#, c-format
msgid "Histogram for [%s in %s] missing (run r.support)"
-msgstr "Ôï éóôüãñáììá ãéá [%s in %s] ëåßðåé (run r.support)"
+msgstr "Το ιÏÏÏγÏαμμα για [%s in %s] λείÏει (run r.support)"
#: ../lib/gis/histogram.c:65
#, c-format
msgid "Can't read histogram for [%s in %s]"
-msgstr "Äåí ìðïñåß íá áíáãíùóôåß ôï éóôüãñáììá ãéá [%s in %s]"
+msgstr "Îεν μÏοÏεί να αναγνÏÏÏεί Ïο ιÏÏÏγÏαμμα για [%s in %s]"
#: ../lib/gis/histogram.c:74 ../lib/gis/histogram.c:84
#, c-format
msgid "Invalid histogram file for [%s in %s]"
-msgstr "ËÜèïò áñ÷åßï éóôïãñÜììáôïòãéá [%s in %s]"
+msgstr "ÎÎ¬Î¸Î¿Ï Î±ÏÏείο ιÏÏογÏάμμαÏοÏγια [%s in %s]"
#: ../lib/gis/histogram.c:356
#, c-format
msgid "can't create histogram for [%s in %s]"
-msgstr "áäõíáìßá äçìéïõãßáò éóôïãñÜììáôïò ãéá [%s in %s]"
+msgstr "αδÏ
ναμία δημιοÏ
Î³Î¯Î±Ï Î¹ÏÏογÏάμμαÏÎ¿Ï Î³Î¹Î± [%s in %s]"
#: ../lib/gis/myname.c:50
msgid "This location has no description."
@@ -3535,16 +3535,16 @@
#: ../lib/gis/ask_cell.c:54 ../lib/gis/ask_cell.c:72 ../lib/gis/ask_cell.c:91
#: ../lib/gis/ask_cell.c:96
msgid "with titles"
-msgstr "ìå ôßôëïõò"
+msgstr "με ÏίÏλοÏ
Ï"
#: ../lib/gis/ask_cell.c:110
msgid "(no title)"
-msgstr "(÷ùñßò ôßôëï)"
+msgstr "(ÏÏÏÎ¯Ï ÏίÏλο)"
#: ../lib/gis/open.c:62
#, c-format
msgid "G__open(read): mapset <%s> doesn't match xmapset <%s>"
-msgstr "G__open(read): mapset <%s> äåí ôáéñéÜæåé ìå ôï xmapset <%s>"
+msgstr "G__open(read): mapset <%s> δεν ÏαιÏιάζει με Ïο xmapset <%s>"
#: ../lib/gis/open.c:84
#, c-format
@@ -3557,7 +3557,7 @@
"G_distance_point_to_line_segment: shouldn't happen: code=%d P=(%f,%f) S=(%f,"
"%f)(%f,%f)"
msgstr ""
-"G_distance_point_to_line_segment: äåí èá Ýðñåðå íá ãßíåé: code=%d P=(%f,%f) "
+"G_distance_point_to_line_segment: δεν θα ÎÏÏεÏε να γίνει: code=%d P=(%f,%f) "
"S=(%f,%f)(%f,%f)"
#: ../lib/arraystats/class.c:21
@@ -3594,9 +3594,9 @@
"Taking too long to find points for interpolation - please change the region "
"to area where your points are. Continuing calculations..."
msgstr ""
-"Ðáßñíåé ðÜñá ðïëý ÷ñüíï íá âñù ôá óçìåßá ãéá ðáñåìâïëÞ -- ðáñáêáëþ áëëÜîôå "
-"ôçí ðåñéï÷Þ óå ìßá Üëëç ðïõ íá âñßóêïíôáé ôá óçìåßá óáò. Óõíå÷ßæù ôïõò "
-"õðïëïãéóìïýò..."
+"ΠαίÏνει ÏάÏα ÏÎ¿Î»Ï ÏÏÏνο να βÏÏ Ïα Ïημεία για ÏαÏεμβολή -- ÏαÏÎ±ÎºÎ±Î»Ï Î±Î»Î»Î¬Î¾Ïε "
+"Ïην ÏεÏιοÏή Ïε μία άλλη ÏοÏ
να βÏίÏκονÏαι Ïα Ïημεία ÏαÏ. ΣÏ
νεÏÎ¯Î¶Ï ÏοÏ
Ï "
+"Ï
ÏολογιÏμοÏÏ..."
#: ../lib/rst/interp_float/input2d.c:47
#, c-format
@@ -3605,7 +3605,7 @@
#: ../lib/rst/interp_float/input2d.c:69
msgid "Bitmap mask created"
-msgstr "ÄçìéïõñãÞèçêå ìÜóêá bitmap"
+msgstr "ÎημιοÏ
Ïγήθηκε μάÏκα bitmap"
#: ../lib/rst/interp_float/output2d.c:125
#, c-format
@@ -3615,11 +3615,11 @@
#: ../lib/rst/interp_float/vinput2d.c:73
#, fuzzy, c-format
msgid "Vector map <%s> is not 3D"
-msgstr "Ï äéáíõóìáôéêüò ÷Üñôçò <%s> äåí âñÝèçêå"
+msgstr "ΠδιανÏ
ÏμαÏικÏÏ ÏάÏÏÎ·Ï <%s> δεν βÏÎθηκε"
#: ../lib/rst/interp_float/vinput2d.c:76
msgid "Loading data from attribute table ..."
-msgstr "Öïñôþíù äåäïìÝíá áðü ôá ðßíáêá..."
+msgstr "ΦοÏÏÏÎ½Ï Î´ÎµÎ´Î¿Î¼Îνα αÏÏ Ïα Ïίνακα..."
#: ../lib/rst/interp_float/vinput2d.c:79 ../lib/vector/Vlib/map.c:243
#: ../lib/vector/Vlib/map.c:364 ../lib/vector/Vlib/map.c:470
@@ -3629,7 +3629,7 @@
#, c-format
msgid "Database connection not defined for layer %d"
msgstr ""
-"Äåí Ý÷åé êáèïñéóôåß ç óýíäåóç ìå ôç âÜóç äåäïìÝíùí ãéá ôï åðßðåäï (layer) %d"
+"Îεν ÎÏει καθοÏιÏÏεί η ÏÏνδεÏη με Ïη βάÏη δεδομÎνÏν για Ïο εÏίÏεδο (layer) %d"
#: ../lib/rst/interp_float/vinput2d.c:97
#: ../lib/rst/interp_float/vinput2d.c:110
@@ -3640,13 +3640,13 @@
#: ../lib/rst/interp_float/vinput2d.c:121
#, fuzzy
msgid "Reading features from vector map ..."
-msgstr "ÄéáâÜæù ãñáììÝò áðü ôïí äéáíõóìáôéêü ÷Üñôç..."
+msgstr "ÎÎ¹Î±Î²Î¬Î¶Ï Î³ÏαμμÎÏ Î±ÏÏ Ïον διανÏ
ÏμαÏÎ¹ÎºÏ ÏάÏÏη..."
#: ../lib/rst/interp_float/vinput2d.c:153
#: ../lib/rst/interp_float/vinput2d.c:270
#, c-format
msgid "Database record for cat %d not found"
-msgstr "Ç åããñáöÞ ôçò âÜóçò äåäïìÝíùí ãéá cat %d äåí âñÝèçêå"
+msgstr "ΠεγγÏαÏή ÏÎ·Ï Î²Î¬ÏÎ·Ï Î´ÎµÎ´Î¿Î¼ÎνÏν για cat %d δεν βÏÎθηκε"
#: ../lib/rst/interp_float/vinput2d.c:171
#: ../lib/rst/interp_float/vinput2d.c:288
@@ -3656,23 +3656,23 @@
#: ../lib/rst/interp_float/vinput2d.c:233
#, fuzzy
msgid "Reading nodes from vector map ..."
-msgstr "ÄéáâÜæù ôïõò êüìâïõò áðü ôïí äéáíõóìáôéêü ÷Üñôç..."
+msgstr "ÎÎ¹Î±Î²Î¬Î¶Ï ÏοÏ
Ï ÎºÏμβοÏ
Ï Î±ÏÏ Ïον διανÏ
ÏμαÏÎ¹ÎºÏ ÏάÏÏη..."
#: ../lib/rst/interp_float/vinput2d.c:314
#, fuzzy
msgid "Strip exists with insufficient data"
-msgstr "strip õðÜñ÷åé ìå áíåðáñêÞ äåäïìÝíá"
+msgstr "strip Ï
ÏάÏÏει με ανεÏαÏκή δεδομÎνα"
#: ../lib/rst/interp_float/vinput2d.c:328
#, fuzzy, c-format
msgid "There are points outside specified 2D/3D region - %d points ignored"
msgstr ""
-"õðÜñ÷ïõí óçìåßá Ýîù áðü ôçí êáèïñéóìÝíç 2Ä/3Ä ðåñéï÷Þ --áãíïïýíôáé %d óçìåßá"
+"Ï
ÏάÏÏοÏ
ν Ïημεία ÎÎ¾Ï Î±ÏÏ Ïην καθοÏιÏμÎνη 2Î/3Î ÏεÏιοÏή --αγνοοÏνÏαι %d Ïημεία"
#: ../lib/rst/interp_float/vinput2d.c:331
#, fuzzy, c-format
msgid "Ignoring %d points (too dense)"
-msgstr "áãíïïýíôáé %d óçìåßá -- ðïëý ðõêíÜ"
+msgstr "αγνοοÏνÏαι %d Ïημεία -- ÏÎ¿Î»Ï ÏÏ
κνά"
#: ../lib/rst/interp_float/vinput2d.c:335
#, c-format
@@ -3680,8 +3680,8 @@
"%d points given for interpolation (after thinning) is less than given NPMIN="
"%d"
msgstr ""
-"%d ôá óçìåßá ðïõ äþèçêáí ãéá ðáñåìâïëÞ (after thinning) åßíáé ìéêñüôåñá áðü "
-"ôï äùóìÝíï NPMIN=%d"
+"%d Ïα Ïημεία ÏοÏ
δÏθηκαν για ÏαÏεμβολή (after thinning) είναι μικÏÏÏεÏα αÏÏ "
+"Ïο δÏÏμÎνο NPMIN=%d"
#: ../lib/rst/interp_float/vinput2d.c:340
msgid "Zero points in the given region"
@@ -3700,75 +3700,75 @@
"There are less than %d points for interpolation. No segmentation is "
"necessary, to run the program faster set segmax=%d (see manual)"
msgstr ""
-"ÕðÜñ÷ïõí ëéãüôåñá áðü %d óçìåßá ãéá ðáñåìâïëÞ. Äåí åßíáé áðáñáßôçôïò ï "
-"äéáìåëéóìüò , ãéá íá ôñÝîåôå ôï ðñüãñáììá ãñçãïñüôåñá äþóôå segmax=%d (äåßôå "
-"ïäçãßåò)"
+"Î¥ÏάÏÏοÏ
ν λιγÏÏεÏα αÏÏ %d Ïημεία για ÏαÏεμβολή. Îεν είναι αÏαÏαίÏηÏÎ¿Ï Î¿ "
+"διαμελιÏμÏÏ , για να ÏÏÎξεÏε Ïο ÏÏÏγÏαμμα γÏηγοÏÏÏεÏα δÏÏÏε segmax=%d (δείÏε "
+"οδηγίεÏ)"
#: ../lib/rst/interp_float/vinput2d.c:355
#, fuzzy, c-format
msgid "Number of points from vector map %d"
διανÏ
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη"
#: ../lib/rst/interp_float/vinput2d.c:356
#, fuzzy, c-format
msgid "Number of points outside of 2D/3D region %d"
-msgstr "Áñéèìüò êÝíôñùí ðïëõãþíùí Ýîù áðü ôçí ðåñéï÷Þ : %d\n"
+msgstr "ÎÏιθμÏÏ ÎºÎνÏÏÏν ÏολÏ
γÏνÏν ÎÎ¾Ï Î±ÏÏ Ïην ÏεÏιοÏή : %d\n"
#: ../lib/rst/interp_float/vinput2d.c:358
#, fuzzy, c-format
msgid "Number of points being used %d"
-msgstr "Áñéèìüò óçìåßùí : %d\n"
+msgstr "ÎÏιθμÏÏ ÏημείÏν : %d\n"
#: ../lib/rst/interp_float/vinput2d.c:391
#, fuzzy
msgid "Some points outside of region (ignored)"
-msgstr "êÜðïéá óçìåßá Ýîù áðü ôçí ðåñéï÷Þ -- èá áãíïçèïýí..."
+msgstr "κάÏοια Ïημεία ÎÎ¾Ï Î±ÏÏ Ïην ÏεÏιοÏή -- θα αγνοηθοÏν..."
#: ../lib/rst/interp_float/vinput2d.c:397
#, fuzzy
msgid "Unable to allocate memory"
-msgstr "Áäõíáìßá êáôáíïìÞò (allocate) ìíÞìçò\n"
+msgstr "ÎδÏ
ναμία καÏÎ±Î½Î¿Î¼Î®Ï (allocate) μνήμηÏ\n"
#: ../lib/rst/interp_float/vinput2d.c:405
#, fuzzy, c-format
msgid "Unable to insert %f,%f,%f a = %d"
-msgstr "Áäõíáìßá åðáíåããñáöÞò feature %d"
+msgstr "ÎδÏ
ναμία εÏανεγγÏαÏÎ®Ï feature %d"
#: ../lib/imagery/fopen.c:23
#, c-format
msgid "Unable to create file [%s] of group [%s in %s]"
-msgstr "Áäõíáìßá äçìéïõñãßáò áñ÷åßïõ [%s] ôïõ ãêñïõð [%s in %s]"
+msgstr "ÎδÏ
ναμία δημιοÏ
ÏÎ³Î¯Î±Ï Î±ÏÏείοÏ
[%s] ÏοÏ
γκÏοÏ
Ï [%s in %s]"
#: ../lib/imagery/fopen.c:36 ../lib/imagery/fopen.c:57
#, c-format
msgid "Unable to open file [%s] of group [%s in %s]"
-msgstr "Áäõíáìßá áíïßãìáôïò áñ÷åßïõ [%s] ôïõ ãêñïõð [%s in %s]"
+msgstr "ÎδÏ
[%s] ÏοÏ
γκÏοÏ
Ï [%s in %s]"
#: ../lib/imagery/fopen.c:49
#, c-format
msgid "Unable to find file [%s] of group [%s in %s]"
-msgstr "Áäõíáìßá åýñåóçò áñ÷åßùí [%s] ôïõ ãñïõð [%s in %s]"
+msgstr "ÎδÏ
ναμία εÏÏεÏÎ·Ï Î±ÏÏείÏν [%s] ÏοÏ
γÏοÏ
Ï [%s in %s]"
#: ../lib/imagery/fopen.c:79
#, c-format
msgid "Unable to create file [%s] for subgroup [%s] of group [%s in %s]"
msgstr ""
-"Áäõíáìßá äçìéïõñãßáò áñ÷åßïõ [%s] ãéá ôï subgroup [%s] ôïõ group [%s in %s]"
+"ÎδÏ
ναμία δημιοÏ
ÏÎ³Î¯Î±Ï Î±ÏÏείοÏ
[%s] για Ïο subgroup [%s] ÏοÏ
group [%s in %s]"
#: ../lib/imagery/fopen.c:101 ../lib/imagery/fopen.c:127
#, c-format
msgid "Unable to open file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr "Áäõíáìßá áíïßãìáôïò [%s] ãéá subgroup [%s] ôïõ group [%s óôï %s]"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï [%s] για subgroup [%s] ÏοÏ
group [%s ÏÏο %s]"
#: ../lib/imagery/fopen.c:116
#, c-format
msgid "Unable to find file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr "Áäõíáìßá åýñåóçò [%s] ãéá subgroup [%s] ôïõ group [%s óôï %s]"
+msgstr "ÎδÏ
ναμία εÏÏεÏÎ·Ï [%s] για subgroup [%s] ÏοÏ
group [%s ÏÏο %s]"
#: ../lib/imagery/target.c:38
#, c-format
msgid "Unable to read target file for group [%s]"
-msgstr "Áäõíáìßá áíÜãíùóçò ôïõ áñ÷åßïõ ãéá ôï ãêñïõð [%s]"
+msgstr "ÎδÏ
ναμία ανάγνÏÏÎ·Ï ÏοÏ
αÏÏείοÏ
για Ïο γκÏοÏ
Ï [%s]"
#: ../lib/imagery/list_subgp.c:36
#, c-format
@@ -3786,33 +3786,33 @@
"Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> "
"is not current mapset"
msgstr ""
+"ÎδÏ
ναμία δημιοÏ
ÏÎ³Î¯Î±Ï Î±ÏÏείοÏ
group [%s in %s]"
#: ../lib/imagery/sigsetfile.c:57
#, fuzzy, c-format
msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s>"
msgstr ""
+"ÎδÏ
ναμία δημιοÏ
ÏÎ³Î¯Î±Ï Î±ÏÏείοÏ
group [%s in %s]"
#: ../lib/imagery/sigsetfile.c:86
#, fuzzy, c-format
msgid "Unable to open signature file <%s> for subgroup <%s> of group <%s@%s>"
+msgstr "ÎδÏ
group [%s ÏÏο %s]"
#: ../lib/imagery/points.c:124
#, fuzzy, c-format
msgid "Unable to open control point file for group [%s in %s]"
+msgstr "ÎδÏ
[%s] ÏοÏ
γκÏοÏ
Ï [%s in %s]"
#: ../lib/imagery/points.c:132
#, fuzzy, c-format
msgid "Bad format in control point file for group [%s in %s]"
+msgstr "ÎδÏ
[%s] ÏοÏ
γκÏοÏ
Ï [%s in %s]"
#: ../lib/imagery/points.c:159
#, fuzzy, c-format
msgid "Unable to create control point file for group [%s in %s]"
+msgstr "ÎδÏ
ναμία δημιοÏ
ÏÎ³Î¯Î±Ï Î±ÏÏείοÏ
[%s] ÏοÏ
γκÏοÏ
Ï [%s in %s]"
#: ../lib/imagery/list_gp.c:34
#, c-format
@@ -3833,83 +3833,83 @@
#: ../lib/vector/diglib/plus.c:288
msgid "Unable read topology for nodes"
-msgstr "Áäõíáìßá áíÜãíùóçò ôùí ôïðïãñáöéêþí êüìâùí (nodes)"
+msgstr "ÎδÏ
ναμία ανάγνÏÏÎ·Ï ÏÏν ÏοÏογÏαÏικÏν κÏμβÏν (nodes)"
#: ../lib/vector/diglib/plus.c:293
#, c-format
msgid "Unable to read topology for node %d"
-msgstr "Áäõíáìßá áíÜãíùóçò ôïõ ôïðïãñáöéêïý êüìâïõ (node) %d"
+msgstr "ÎδÏ
ÏοÏογÏαÏÎ¹ÎºÎ¿Ï ÎºÏμβοÏ
(node) %d"
#: ../lib/vector/diglib/plus.c:298
msgid "Unable read topology for lines"
-msgstr "Áäõíáìßá áíÜãíùóçò ôïðïãßáò ãéá ãñáììÝò"
+msgstr "ÎδÏ
ναμία ανάγνÏÏÎ·Ï ÏοÏÎ¿Î³Î¯Î±Ï Î³Î¹Î± γÏαμμÎÏ"
#: ../lib/vector/diglib/plus.c:303
#, c-format
msgid "Unable to read topology for line %d"
-msgstr "Áäõíáìßá áíÜãíùóçò ôïðïëïãßá ãéá ãñáììÞ %d"
+msgstr "ÎδÏ
ναμία ανάγνÏÏÎ·Ï ÏοÏολογία για γÏαμμή %d"
#: ../lib/vector/diglib/plus.c:308
msgid "Unable to read topo for areas"
-msgstr "Áäõíáìßá áíÜãíùóçò topo ôùí ðåñéï÷þí"
+msgstr "ÎδÏ
ναμία ανάγνÏÏÎ·Ï topo ÏÏν ÏεÏιοÏÏν"
#: ../lib/vector/diglib/plus.c:313
#, c-format
msgid "Unable read topology for area %d"
-msgstr "Áäõíáìßá áíÜãíùóçò ôïðïëïãßáò ôçò ðåñéï÷Þò %d"
+msgstr "ÎδÏ
ναμία ανάγνÏÏÎ·Ï ÏοÏÎ¿Î»Î¿Î³Î¯Î±Ï ÏÎ·Ï ÏεÏιοÏÎ®Ï %d"
#: ../lib/vector/diglib/plus.c:318
msgid "Unable to read topology for isles"
-msgstr "Áäõíáìßá áíÜãíùóçò ôïðïëïãßáò ãéá íçóßäåò"
+msgstr "ÎδÏ
ναμία ανάγνÏÏÎ·Ï ÏοÏÎ¿Î»Î¿Î³Î¯Î±Ï Î³Î¹Î± νηÏίδεÏ"
#: ../lib/vector/diglib/plus.c:323
#, c-format
msgid "Unable to read topology for isle %d"
-msgstr "Áäõíáìßá áíÜãíùóçò ôïðïëïãßá ãéá íçóßäá %d"
+msgstr "ÎδÏ
ναμία ανάγνÏÏÎ·Ï ÏοÏολογία για νηÏίδα %d"
#: ../lib/vector/diglib/plus.c:345 ../lib/vector/diglib/plus.c:371
msgid "Unable to write head to plus file"
-msgstr "Áäõíáìßá åããñáöÞò êåöáëéêïý ôïõ plus áñ÷åßïõ"
+msgstr "ÎδÏ
ναμία εγγÏαÏÎ®Ï ÎºÎµÏÎ±Î»Î¹ÎºÎ¿Ï ÏοÏ
plus αÏÏείοÏ
#: ../lib/vector/diglib/plus.c:350
msgid "Unable to write nodes to plus file"
-msgstr "Áäõíáìßá åããñáöÞò êüìâùí óôï plus áñ÷åßï"
+msgstr "ÎδÏ
ναμία εγγÏαÏÎ®Ï ÎºÏμβÏν ÏÏο plus αÏÏείο"
#: ../lib/vector/diglib/plus.c:355
msgid "Unable to write lines to plus file"
-msgstr "Áäõíáìßá åããñáöÞò ãñáììÝò óôï plus áñ÷åßï"
+msgstr "ÎδÏ
ναμία εγγÏαÏÎ®Ï Î³ÏαμμÎÏ ÏÏο plus αÏÏείο"
#: ../lib/vector/diglib/plus.c:360
msgid "Unable to write areas to plus file"
-msgstr "Áäõíáìßá åããñáöÞò åðéöáíåéþí óôï plus áñ÷åßï"
+msgstr "ÎδÏ
ναμία εγγÏαÏÎ®Ï ÎµÏιÏανειÏν ÏÏο plus αÏÏείο"
#: ../lib/vector/diglib/plus.c:365
msgid "Unable to write isles to plus file"
-msgstr "Áäõíáìßá åããñáöÞò íçóßäùí óôï plus áñ÷åßï"
+msgstr "ÎδÏ
ναμία εγγÏαÏÎ®Ï Î½Î·ÏίδÏν ÏÏο plus αÏÏείο"
#: ../lib/vector/diglib/spindex.c:248
#, c-format
msgid "Unable to delete node %d from spatial index"
-msgstr "Äåí ãßíåôáé ç äéáãñáöÞ ôïõ êüìâïõ %d áðü ôï ÷ùñéêü ðßíáêá"
+msgstr "Îεν γίνεÏαι η διαγÏαÏή ÏοÏ
κÏμβοÏ
%d αÏÏ Ïο ÏÏÏÎ¹ÎºÏ Ïίνακα"
#: ../lib/vector/diglib/spindex.c:288
#, c-format
msgid "Unable to delete line %d from spatial index"
-msgstr "Äåí ãßíåôáé ç äéáãñáöÞ ôçò ãñáììÞò %d áðü ôï ÷ùñéêü ðßíáêá"
+msgstr "Îεν γίνεÏαι η διαγÏαÏή ÏÎ·Ï Î³ÏÎ±Î¼Î¼Î®Ï %d αÏÏ Ïο ÏÏÏÎ¹ÎºÏ Ïίνακα"
#: ../lib/vector/diglib/spindex.c:314
msgid "Attempt to delete sidx for dead area"
-msgstr "ÐñïóðÜèåéá äéáãñáöÞò sidx Üêõñçò ãñáììÞò"
+msgstr "Î ÏοÏÏάθεια διαγÏαÏÎ®Ï sidx άκÏ
ÏÎ·Ï Î³ÏαμμήÏ"
#: ../lib/vector/diglib/spindex.c:327
#, c-format
msgid "Unable to delete area %d from spatial index"
-msgstr "Äåí ãßíåôáé ç äéáãñáöÞ ðåñéï÷Þò %d áðü ôï ÷ùñéêü ðßíáêá"
+msgstr "Îεν γίνεÏαι η διαγÏαÏή ÏεÏιοÏÎ®Ï %d αÏÏ Ïο ÏÏÏÎ¹ÎºÏ Ïίνακα"
#: ../lib/vector/diglib/spindex.c:362
#, c-format
msgid "Unable to delete isle %d from spatial index"
-msgstr "Äåí ãßíåôáé ç äéáãñáöÞ ôçò íçóßäáò %d áðü ôï ÷ùñéêü ðßíáêá"
+msgstr "Îεν γίνεÏαι η διαγÏαÏή ÏÎ·Ï Î½Î·ÏÎ¯Î´Î±Ï %d αÏÏ Ïο ÏÏÏÎ¹ÎºÏ Ïίνακα"
#: ../lib/vector/diglib/file.c:157
msgid "Writing to file loaded to memory not supported"
@@ -3918,7 +3918,7 @@
#: ../lib/vector/diglib/file.c:200
#, fuzzy
msgid "Unable to load file to memory, file not open"
-msgstr "Áäõíáìßá áíïßãìáôïò ðñïóùñéíïý áñ÷åßïõ"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï ÏÏοÏÏÏÎ¹Î½Î¿Ï Î±ÏÏείοÏ
#: ../lib/vector/diglib/file.c:215
msgid "Vector memory mode not supported, using 'AUTO'"
@@ -3956,12 +3956,12 @@
#: ../lib/vector/diglib/plus_area.c:418
#, c-format
msgid "Attempt to delete area %d info from dead isle %d"
-msgstr "ÐñïóðÜèåéá äéáãñáöÞò åðéöÜíåéáò %d áðü êåíÞ íçóßäá (%d)"
+msgstr "Î ÏοÏÏάθεια διαγÏαÏÎ®Ï ÎµÏιÏÎ¬Î½ÎµÎ¹Î±Ï %d αÏÏ ÎºÎµÎ½Î® νηÏίδα (%d)"
#: ../lib/vector/diglib/plus_area.c:773
#, c-format
msgid "Attempt to delete isle %d info from dead area %d"
-msgstr "ÐñïóðÜèåéá äéáãñáöÞò íçóßäáò %d áðü êåíÞ (dead) åðéöÜíåéá %d"
+msgstr "Î ÏοÏÏάθεια διαγÏαÏÎ®Ï Î½Î·ÏÎ¯Î´Î±Ï %d αÏÏ ÎºÎµÎ½Î® (dead) εÏιÏάνεια %d"
#: ../lib/vector/neta/spanningtree.c:104
msgid "Computing minimum spanning tree..."
@@ -3970,13 +3970,13 @@
#: ../lib/vector/neta/flow.c:309 ../lib/vector/Vlib/net.c:433
#: ../lib/vector/Vlib/graph.c:110
msgid "GngFlatten error"
-msgstr "GngFlatten óöÜëìá"
+msgstr "GngFlatten ÏÏάλμα"
#: ../lib/vector/neta/timetables.c:46 ../lib/vector/neta/timetables.c:203
#: ../lib/vector/neta/timetables.c:244 ../lib/vector/neta/timetables.c:286
#, fuzzy, c-format
msgid "Unable to open select cursor: %s"
-msgstr "Áäõíáìßá áíïßãìáôïò êÝñóïñá '%s'"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï ÎºÎÏÏοÏα '%s'"
#: ../lib/vector/neta/utils.c:219 ../lib/vector/neta/utils.c:232
#, c-format
@@ -3990,12 +3990,12 @@
#: ../lib/vector/neta/utils.c:225
#, fuzzy
msgid "Unable to load data from database"
-msgstr "Áäõíáìßá óýíäåóçò âÜóçò äåäïìÝíùí"
+msgstr "ÎδÏ
ναμία ÏÏνδεÏÎ·Ï Î²Î¬ÏÎ·Ï Î´ÎµÎ´Î¿Î¼ÎνÏν"
#: ../lib/vector/neta/utils.c:236
#, fuzzy
msgid "Problem loading category values"
ÏάÏÏÎµÏ ÏάÏÏη"
#: ../lib/vector/neta/allpairs.c:53
msgid "Computing all pairs shortest paths..."
@@ -4021,12 +4021,12 @@
#: ../lib/vector/Vlib/snap.c:452
#, fuzzy, c-format
msgid "New vertices: %d"
-msgstr "¼ëá ôá óçìåßá (vertices)"
+msgstr "Îλα Ïα Ïημεία (vertices)"
#: ../lib/vector/Vlib/intersect.c:127
msgid "3D not supported by Vect_segment_intersection()"
msgstr ""
-"Ç 3äéÜóôáôç áðåéêüíéóç äåí õðïóôçñßæåôáé áðü ôï Vect_segment_intersection()"
+"Î 3διάÏÏαÏη αÏεικÏνιÏη δεν Ï
ÏοÏÏηÏίζεÏαι αÏÏ Ïο Vect_segment_intersection()"
#: ../lib/vector/Vlib/intersect.c:313
msgid "Vect_segment_intersection() ERROR (collinear vertical segments)"
@@ -4045,102 +4045,102 @@
#: ../lib/vector/Vlib/map.c:55
msgid "input vector map is not open"
-msgstr "Ï äéáíõóìáôéêüò ÷Üñôçò åéóáãùãÞò äåí åßíáé áíïéêôüò"
+msgstr "ΠδιανÏ
ÏμαÏικÏÏ ÏάÏÏÎ·Ï ÎµÎ¹ÏαγÏÎ³Î®Ï Î´ÎµÎ½ είναι ανοικÏÏÏ"
#: ../lib/vector/Vlib/map.c:178 ../lib/vector/Vlib/map.c:314
#: ../lib/vector/Vlib/open.c:540
#, c-format
msgid "Vector map name is not SQL compliant"
-msgstr "Ï äéáíõóìáôéêüò ÷Üñôçò äåí åßíáé óõìâáôüò ìå SQL"
+msgstr "ΠδιανÏ
ÏμαÏικÏÏ ÏάÏÏÎ·Ï Î´ÎµÎ½ είναι ÏÏ
μβαÏÏÏ Î¼Îµ SQL"
#: ../lib/vector/Vlib/map.c:182
#, c-format
msgid "Unable to find vector map <%s> in <%s>"
-msgstr "Áäõíáìßá áíôéãñáöÞò äéáíõóìáôéêïý ÷Üñôç <%s> óå <%s>"
+msgstr "ÎδÏ
ναμία ανÏιγÏαÏÎ®Ï Î´Î¹Î±Î½Ï
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη <%s> Ïε <%s>"
#: ../lib/vector/Vlib/map.c:189 ../lib/vector/Vlib/map.c:318
#: ../lib/vector/Vlib/open.c:547
#, c-format
msgid "Vector map <%s> already exists and will be overwritten"
msgstr ""
-"Ï äéáíõóìáôéêüò ÷Üñôçò <%s> õðÜñ÷åé Þäç êáé èá áíôéêáôáóôáèåß (overwritten)"
+"ΠδιανÏ
ÏμαÏικÏÏ ÏάÏÏÎ·Ï <%s> Ï
ÏάÏÏει ήδη και θα ανÏικαÏαÏÏαθεί (overwritten)"
#: ../lib/vector/Vlib/map.c:193 ../lib/vector/Vlib/open.c:552
#, c-format
msgid "Unable to delete vector map <%s>"
-msgstr "Áäõíáìßá äéáãñáöÞò äéáíõóìáôéêïý ÷Üñôç <%s>"
+msgstr "ÎδÏ
ναμία διαγÏαÏÎ®Ï Î´Î¹Î±Î½Ï
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη <%s>"
#: ../lib/vector/Vlib/map.c:213 ../lib/vector/Vlib/map.c:331
#, c-format
msgid "Unable to copy vector map <%s> to <%s>"
+msgstr "ÎδÏ
#: ../lib/vector/Vlib/map.c:260 ../lib/vector/Vlib/map.c:381
#: ../lib/vector/Vlib/map.c:613 ../lib/vector/Vlib/map.c:720
#, c-format
msgid "Unable to copy table <%s>"
-msgstr "Áäõíáìßá áíôéãñáöÞò ðßíáêá <%s>"
+msgstr "ÎδÏ
ναμία ανÏιγÏαÏÎ®Ï Ïίνακα <%s>"
#: ../lib/vector/Vlib/map.c:276 ../lib/vector/Vlib/map.c:410
#: ../lib/vector/Vlib/map.c:626
#, c-format
msgid "Unable to create index for table <%s>, key <%s>"
-msgstr "Áäõíáìßá äçìéïõñãßáò êáôáëüãïõ ãéá ôïí ðßíáêá <%s>, êëåéäß <%s>"
+msgstr "ÎδÏ
ναμία δημιοÏ
ÏÎ³Î¯Î±Ï ÎºÎ±ÏαλÏγοÏ
για Ïον Ïίνακα <%s>, κλειδί <%s>"
#: ../lib/vector/Vlib/map.c:395 ../lib/vector/Vlib/map.c:490
#, c-format
msgid "Unable to delete table <%s>"
-msgstr "Áäõíáìßá äéáãñáöÞò ðßíáêá <%s>"
+msgstr "ÎδÏ
ναμία διαγÏαÏÎ®Ï Ïίνακα <%s>"
#: ../lib/vector/Vlib/map.c:444
#, c-format
msgid "Invalid vector map name <%s>"
-msgstr "ËÜèïò üíïìá äéáíõóìáôéêïý ÷Üñôç <%s>"
+msgstr "ÎÎ¬Î¸Î¿Ï Ïνομα διανÏ
#: ../lib/vector/Vlib/map.c:458
#, c-format
msgid "Unable to open header file for vector map <%s>"
-msgstr "Áäõíáìßá áíïßãìáôïò header áñ÷åßïõ äéáíõóìáôéêïý ÷Üñôç <%s>"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï header αÏÏείοÏ
διανÏ
#: ../lib/vector/Vlib/map.c:480
#, c-format
msgid "Unable to find table <%s> linked to vector map <%s>"
msgstr ""
-"Áäõíáìßá åýñåóçò ôïõ ðßíáêá <%s> ðïõ åßíáé óõíäåäåìÝíïò ìå ôïí äéáíõóìáôéêü "
-"÷Üñôç <%s>"
+"ÎδÏ
ναμία εÏÏεÏÎ·Ï ÏοÏ
Ïίνακα <%s> ÏοÏ
είναι ÏÏ
νδεδεμÎÎ½Î¿Ï Î¼Îµ Ïον διανÏ
ÏμαÏÎ¹ÎºÏ "
+"ÏάÏÏη <%s>"
#: ../lib/vector/Vlib/map.c:497
#, c-format
msgid "Table <%s> linked to vector map <%s> does not exist"
msgstr ""
-"Ï ðßíáêáò <%s> ðïõ åßíáé óõíäåäåìÝíïò ìå ôïí äéáíõóìáôéêü ÷Üñôç <%s> äåí "
-"õðÜñ÷åé"
+"Î ÏÎ¯Î½Î±ÎºÎ±Ï <%s> ÏοÏ
είναι ÏÏ
ÏμαÏÎ¹ÎºÏ ÏάÏÏη <%s> δεν "
+"Ï
ÏάÏÏει"
#: ../lib/vector/Vlib/map.c:511
#, c-format
msgid "Unable to open directory '%s'"
-msgstr "Áäõíáìßá áíïßãìáôïò êáôáëüãïõ óõóôÞìáôïò '%s'"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï ÎºÎ±ÏαλÏγοÏ
ÏÏ
ÏÏήμαÏÎ¿Ï '%s'"
#: ../lib/vector/Vlib/map.c:525
#, c-format
msgid "Unable to delete file '%s'"
-msgstr "Áäõíáìßá äéáãñáöÞò áñ÷åßïõ '%s'"
+msgstr "ÎδÏ
ναμία διαγÏαÏÎ®Ï Î±ÏÏείοÏ
'%s'"
#: ../lib/vector/Vlib/map.c:542
#, c-format
msgid "Unable to rename directory '%s' to '%s'"
-msgstr "Áäõíáìßá ìåôïíïìáóßáò êáôáëüãïõ óõóôÞìáôïò '%s' óå '%s'"
+msgstr "ÎδÏ
ναμία μεÏονομαÏÎ¯Î±Ï ÎºÎ±ÏαλÏγοÏ
ÏÏ
ÏÏήμαÏÎ¿Ï '%s' Ïε '%s'"
#: ../lib/vector/Vlib/map.c:550
#, c-format
msgid "Unable to remove directory '%s'"
-msgstr "Áäõíáìßá ìåôáöïñÜò êáôáëüãïõ óõóôÞìáôïò '%s'"
+msgstr "ÎδÏ
ναμία μεÏαÏοÏÎ¬Ï ÎºÎ±ÏαλÏγοÏ
ÏÏ
ÏÏήμαÏÎ¿Ï '%s'"
#: ../lib/vector/Vlib/map.c:604 ../lib/vector/Vlib/map.c:705
#, c-format
msgid "Unable to add database link for vector map <%s>"
msgstr ""
-"Áäõíáìßá ðñïóèÞêçò óýíäåóçò ìå âÜóç äåäïìÝíùí ãéá ôïí äéáíõóìáôéêü ÷Üñôç <%s>"
+"ÎδÏ
ναμία ÏÏοÏÎ¸Î®ÎºÎ·Ï ÏÏνδεÏÎ·Ï Î¼Îµ βάÏη δεδομÎνÏν για Ïον διανÏ
ÏμαÏÎ¹ÎºÏ ÏάÏÏη <%s>"
#: ../lib/vector/Vlib/read_nat.c:136 ../lib/vector/Vlib/geos.c:66
#: ../lib/vector/Vlib/geos.c:256
@@ -4164,60 +4164,60 @@
#: ../lib/vector/Vlib/array.c:294
#, c-format
msgid "Unable to select record from table <%s> (key %s, where %s)"
-msgstr "Áäõíáìßá åðéëïãÞò ôçò åããñáöÞò <%s> (êëåéäß %s, üðïõ %s)"
+msgstr "ÎδÏ
ναμία εÏÎ¹Î»Î¿Î³Î®Ï ÏÎ·Ï ÎµÎ³Î³ÏαÏÎ®Ï <%s> (κλειδί %s, ÏÏοÏ
%s)"
#: ../lib/vector/Vlib/legal_vname.c:48
#, c-format
msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
msgstr ""
-"Ìç åðéôñåðôü üíïìá äéáíõóìáôéêüõ ÷Üñôç <%s>. äåí ðñÝðåé íá ðåñéÝ÷åé '.' Þ "
+"Îη εÏιÏÏεÏÏÏ Ïνομα διανÏ
ÏμαÏικÏÏ
ÏάÏÏη <%s>. δεν ÏÏÎÏει να ÏεÏιÎÏει '.' ή "
"'NULL'."
#: ../lib/vector/Vlib/legal_vname.c:55
#, c-format
msgid "Illegal vector map name <%s>. Must start with a letter."
msgstr ""
-"Ìç åðéôñåðôü üíïìá äéáíõóìáôéêüõ ÷Üñôç <%s>. ÐñÝðåé íá îåêéíÜ ìå ãñÜììá."
ÏμαÏικÏÏ
ÏάÏÏη <%s>. Î ÏÎÏει να ξεκινά με γÏάμμα."
#: ../lib/vector/Vlib/legal_vname.c:63
#, c-format
msgid "Illegal vector map name <%s>. Character '%c' not allowed."
msgstr ""
-"Ìç åðéôñåðôü üíïìá äéáíõóìáôéêüõ ÷Üñôç <%s>. Ï ÷áñáêôÞñáò '%c' äåí "
-"åðéôñÝðåôáé."
ÏμαÏικÏÏ
ÏάÏÏη <%s>. Î ÏαÏακÏήÏÎ±Ï '%c' δεν "
+"εÏιÏÏÎÏεÏαι."
#: ../lib/vector/Vlib/legal_vname.c:70
#, c-format
msgid ""
"Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
msgstr ""
-"Ìç åðéôñåðôü üíïìá äéáíõóìáôéêüõ ÷Üñôç <%s>. Ç ëÝîç êëåéäß SQL äåí ìðïñåß "
-"íá ÷ñçóéìïðïéçèåß þò üíïìá ôïõ ÷Üñôç."
ÏμαÏικÏÏ
ÏάÏÏη <%s>. ΠλÎξη κλειδί SQL δεν μÏοÏεί "
+"να ÏÏηÏιμοÏοιηθεί ÏÏ Ïνομα ÏοÏ
ÏάÏÏη."
#: ../lib/vector/Vlib/legal_vname.c:101 ../lib/vector/Vlib/legal_vname.c:105
#, c-format
msgid "Output vector map name <%s> is not valid map name"
-msgstr "Ôï åîáãþìåíï üíïìá ôïõ äéáíõóìáôéêïý ÷Üñôç <%s> äåí åßíáé åðéôñåðôü"
+msgstr "Το εξαγÏμενο Ïνομα ÏοÏ
διανÏ
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη <%s> δεν είναι εÏιÏÏεÏÏÏ"
#: ../lib/vector/Vlib/legal_vname.c:142 ../lib/vector/Vlib/legal_vname.c:146
#, c-format
msgid "Output vector map <%s> is used as input"
msgstr ""
-"Ï åîáãüìåíïò äéáíõóìáôéêüò ÷Üñôçò <%s> ÷ñçóéìïðïéåßôáé ãéá åéóáãùãÞ "
-"äåäïìÝíùí."
+"ΠεξαγÏÎ¼ÎµÎ½Î¿Ï Î´Î¹Î±Î½Ï
ÏμαÏικÏÏ ÏάÏÏÎ·Ï <%s> ÏÏηÏιμοÏοιείÏαι για ειÏαγÏγή "
+"δεδομÎνÏν."
#: ../lib/vector/Vlib/write_nat.c:50 ../lib/vector/Vlib/write_nat.c:83
#, c-format
msgid "%s: Area %d does not exist"
-msgstr "%s: ÅðéäÜíåéá %d äåí õðÜñ÷åé"
+msgstr "%s: ÎÏιδάνεια %d δεν Ï
ÏάÏÏει"
#: ../lib/vector/Vlib/write_nat.c:640
msgid "Attempt to delete dead feature"
-msgstr "ÐñïóðÜèåéá äéáãñáöÞò ëÜèïò óôïé÷åßùí"
+msgstr "Î ÏοÏÏάθεια διαγÏαÏÎ®Ï Î»Î¬Î¸Î¿Ï ÏÏοιÏείÏν"
#: ../lib/vector/Vlib/write_nat.c:885
msgid "Attempt to restore alive feature"
-msgstr "ÐñïóðÜèåéá áðïêáôÜóôáóçò óùóôþí óôïé÷åßùí"
+msgstr "Î ÏοÏÏάθεια αÏοκαÏάÏÏαÏÎ·Ï ÏÏÏÏÏν ÏÏοιÏείÏν"
#: ../lib/vector/Vlib/merge_lines.c:233
#, c-format
@@ -4299,7 +4299,7 @@
#: ../lib/vector/Vlib/net.c:522 ../lib/vector/Vlib/graph.c:231
#, c-format
msgid "dglShortestPath error: %s"
-msgstr "dglShortestPath óöÜëìá: %s"
+msgstr "dglShortestPath ÏÏάλμα: %s"
#: ../lib/vector/Vlib/net.c:603
msgid "Wrong line direction in Vect_net_get_line_cost()"
@@ -4307,26 +4307,26 @@
#: ../lib/vector/Vlib/field.c:93
msgid "Layer number must be 1 or greater"
-msgstr "Ôï íïýìåñï ôïõ åðéðÝäïõ ðñÝðåé íá åßíáé ìåãáëýôåñï Þ ßóï ìå 1"
+msgstr "Το νοÏμεÏο ÏοÏ
εÏιÏÎδοÏ
ÏÏÎÏει να είναι μεγαλÏÏεÏο ή ίÏο με 1"
#: ../lib/vector/Vlib/field.c:98
msgid "Unable to add database link, map is not opened in WRITE mode"
msgstr ""
-"Áäõíáìßá óýíäåóçò âÜóçò äåäïìÝíùí, ï ÷Üñôçò äåí åßíáé áíïéêôüò óå êáôÜóôáóç "
-"åããñáöÞò (WRITE mode)"
+"ÎδÏ
ναμία ÏÏνδεÏÎ·Ï Î²Î¬ÏÎ·Ï Î´ÎµÎ´Î¿Î¼ÎνÏν, ο ÏάÏÏÎ·Ï Î´ÎµÎ½ είναι ανοικÏÏÏ Ïε καÏάÏÏαÏη "
+"εγγÏαÏÎ®Ï (WRITE mode)"
#: ../lib/vector/Vlib/field.c:104
msgid "Unable to add database link"
+msgstr "ÎδÏ
#: ../lib/vector/Vlib/field.c:110 ../lib/vector/Vlib/field.c:155
msgid "Unable to write database links"
+msgstr "ÎδÏ
#: ../lib/vector/Vlib/field.c:223
#, c-format
msgid "Layer number %d or name <%s> already exists"
-msgstr "Ôï åðßðåäï ìå áñéèìü %d Þ üíïìá <%s> õðÜñ÷åé Þäç"
+msgstr "Το εÏίÏεδο με αÏÎ¹Î¸Î¼Ï %d ή Ïνομα <%s> Ï
ÏάÏÏει ήδη"
#: ../lib/vector/Vlib/field.c:302
#, c-format
@@ -4335,17 +4335,17 @@
"driver: %s\n"
"database: %s"
msgstr ""
-"ÐñïåðéëåãìÝíïò ïäçãüò / ç âÜóç äåäïìÝíùí Ý÷åé:\n"
+"Î ÏοεÏιλεγμÎÎ½Î¿Ï Î¿Î´Î·Î³ÏÏ / η βάÏη δεδομÎνÏν ÎÏει:\n"
"driver: %s\n"
"database: %s"
#: ../lib/vector/Vlib/field.c:309
msgid "Default driver is not set"
-msgstr "Ï ðñïåðéëåãìÝíïò ïäçãüò äåí Ý÷åé êáèïñéóôåß"
+msgstr "Î ÏÏοεÏιλεγμÎÎ½Î¿Ï Î¿Î´Î·Î³ÏÏ Î´ÎµÎ½ ÎÏει καθοÏιÏÏεί"
#: ../lib/vector/Vlib/field.c:312
msgid "Default database is not set"
-msgstr "Ç ðñïåðéëåãìÝíç âÜóç äåäïìÝíùí äåí Ý÷åé êáèïñéóôåß"
+msgstr "Î ÏÏοεÏιλεγμÎνη βάÏη δεδομÎνÏν δεν ÎÏει καθοÏιÏÏεί"
#: ../lib/vector/Vlib/field.c:371
#, c-format
@@ -4387,15 +4387,15 @@
#: ../lib/vector/Vlib/build_nat.c:93
msgid "Unable to add area (map closed, topo saved)"
-msgstr "Áäõíáìßá ðñïóèÞêçò åðéöÜíåéáò (÷Üñôçò êëåéóôüò, ôïðïãñáößá óùóìÝíç)"
+msgstr "ÎδÏ
ναμία ÏÏοÏÎ¸Î®ÎºÎ·Ï ÎµÏιÏÎ¬Î½ÎµÎ¹Î±Ï (ÏάÏÏÎ·Ï ÎºÎ»ÎµÎ¹ÏÏÏÏ, ÏοÏογÏαÏία ÏÏÏμÎνη)"
#: ../lib/vector/Vlib/build_nat.c:102
msgid "Unable to add isle (map closed, topo saved)"
-msgstr "Unable to add isle (÷Üñôçò êëåéóôüò, ôïðïãñáößá óùóìÝíç)"
+msgstr "Unable to add isle (ÏάÏÏÎ·Ï ÎºÎ»ÎµÎ¹ÏÏÏÏ, ÏοÏογÏαÏία ÏÏÏμÎνη)"
#: ../lib/vector/Vlib/build_nat.c:112
msgid "Area of size = 0.0 ignored"
-msgstr "ÅðéöÜíåéá ìåãÝèïõò = 0.0 áãíïåßôáé"
+msgstr "ÎÏιÏάνεια μεγÎθοÏ
Ï = 0.0 αγνοείÏαι"
#: ../lib/vector/Vlib/build_nat.c:148
msgid "Request to find area outside nonexistent isle"
@@ -4404,11 +4404,11 @@
#: ../lib/vector/Vlib/build_nat.c:516
#, fuzzy
msgid "Registering primitives..."
-msgstr "ÅããñáöÞ áñ÷éêÜ: "
+msgstr "ÎγγÏαÏή αÏÏικά: "
#: ../lib/vector/Vlib/build_nat.c:525
msgid "Unable to read vector map"
-msgstr "Áäõíáìßá áíÜãíùóçò äéáíõóìáôéêïý ÷Üñôç"
+msgstr "ÎδÏ
ναμία ανάγνÏÏÎ·Ï Î´Î¹Î±Î½Ï
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη"
#: ../lib/vector/Vlib/build_nat.c:569
#, c-format
@@ -4423,17 +4423,17 @@
#: ../lib/vector/Vlib/build_nat.c:581
#, fuzzy
msgid "Building areas..."
-msgstr "Äçìéïõñãßá åðéöáíåéþí"
+msgstr "ÎημιοÏ
Ïγία εÏιÏανειÏν"
#: ../lib/vector/Vlib/build_nat.c:604
#, fuzzy, c-format
msgid "%d areas built"
-msgstr "ÅðéöÜíåéåò äçìéïõñãÞèçêáí"
+msgstr "ÎÏιÏÎ¬Î½ÎµÎ¹ÎµÏ Î´Î·Î¼Î¹Î¿Ï
Ïγήθηκαν"
#: ../lib/vector/Vlib/build_nat.c:605
#, fuzzy, c-format
msgid "%d isles built"
-msgstr "Íçóßäåò äçìéïõñãÞèçêáí"
+msgstr "ÎηÏÎ¯Î´ÎµÏ Î´Î·Î¼Î¹Î¿Ï
Ïγήθηκαν"
#: ../lib/vector/Vlib/build_nat.c:614
msgid "Attaching islands..."
@@ -4449,8 +4449,8 @@
"Coor files of vector map <%s@%s> is larger than it should be (%ld bytes "
"excess)"
msgstr ""
-"Ôá áñ÷åßá óõíôåôáãìÝíùí (coor) ôùí äéáíõóìáôéêþí ÷áñôþí <%s@%s> åßíáé "
-"ìåãáëýôåñá áðü üóï èá Ýðñåðå (%ld bytes excess)"
+"Τα αÏÏεία ÏÏ
νÏεÏαγμÎνÏν (coor) ÏÏν διανÏ
ÏμαÏικÏν ÏαÏÏÏν <%s@%s> είναι "
+"μεγαλÏÏεÏα αÏÏ ÏÏο θα ÎÏÏεÏε (%ld bytes excess)"
#: ../lib/vector/Vlib/open_nat.c:149
#, c-format
@@ -4458,17 +4458,17 @@
"Coor files of vector <%s@%s> is shorter than it should be (%ld bytes "
"missing)."
msgstr ""
-"ìéêñüôåñá áðü üóï èá Ýðñåðå (%ld bytes missing)."
+"Τα αÏÏεία ÏÏ
+"μικÏÏÏεÏα αÏÏ ÏÏο θα ÎÏÏεÏε (%ld bytes missing)."
#: ../lib/vector/Vlib/cats.c:47
msgid "Vect_new_cats_struct(): Out of memory"
-msgstr "Vect_new_cats_struct(): ç ìíÞìç ãÝìéóå"
+msgstr "Vect_new_cats_struct(): η μνήμη γÎμιÏε"
#: ../lib/vector/Vlib/cats.c:131
#, c-format
msgid "Too many categories (%d), unable to set cat %d (layer %d)"
-msgstr "ÐÜñá ðïëëÝò êáôçãïñßåò (%d), äåí ìðïñåß íá cat %d (åðßðåäï %d)"
+msgstr "ΠάÏα ÏολλÎÏ ÎºÎ±ÏηγοÏÎ¯ÎµÏ (%d), δεν μÏοÏεί να cat %d (εÏίÏεδο %d)"
#: ../lib/vector/Vlib/cats.c:410
#, c-format
@@ -4481,32 +4481,32 @@
#: ../lib/vector/Vlib/sindex.c:97
msgid "not implemented"
-msgstr "Äåí Ý÷åé åöáñìïóôåß"
+msgstr "Îεν ÎÏει εÏαÏμοÏÏεί"
#: ../lib/vector/Vlib/sindex.c:109
#, c-format
msgid "Unable to delete item %d from spatial index"
-msgstr "Äåí ãßíåôáé ç äéáãñáöÞ ôïõ áíôéêåéìÝíïõ %d áðü ôï ÷ùñéêü ðßíáêá"
ανÏικειμÎνοÏ
#: ../lib/vector/Vlib/sindex.c:127
msgid ""
"Unable to build spatial index from topology, vector map is not opened at "
"topo level 2"
msgstr ""
-"Áäõíáìßá äçìéïñãßáò ÷ùñéêïý ðßíáêá áðü ôçí ôïðïëïãßá, ï äéáíõóìáôéêüò ÷Üñôçò "
-"äåí åßíáé áíïéêôüò óôï topo level 2"
+"ÎδÏ
ναμία δημιοÏÎ³Î¯Î±Ï ÏÏÏÎ¹ÎºÎ¿Ï Ïίνακα αÏÏ Ïην ÏοÏολογία, ο διανÏ
ÏμαÏικÏÏ ÏάÏÏÎ·Ï "
+"δεν είναι ανοικÏÏÏ ÏÏο topo level 2"
#: ../lib/vector/Vlib/sindex.c:168
msgid "BUG (Vect_build_sidx_from_topo): node does not exist"
-msgstr "BUG (Vect_build_sidx_from_topo): êüìâïò äåí õðÜñ÷åé"
+msgstr "BUG (Vect_build_sidx_from_topo): κÏÎ¼Î²Î¿Ï Î´ÎµÎ½ Ï
ÏάÏÏει"
#: ../lib/vector/Vlib/sindex.c:180
msgid "BUG (Vect_build_sidx_from_topo): line does not exist"
-msgstr "BUG (Vect_build_sidx_from_topo): ç ãñáììÞ äåí õðÜñ÷åé"
+msgstr "BUG (Vect_build_sidx_from_topo): η γÏαμμή δεν Ï
ÏάÏÏει"
#: ../lib/vector/Vlib/sindex.c:199
msgid "BUG (Vect_build_sidx_from_topo): area does not exist"
-msgstr "BUG (Vect_build_sidx_from_topo): ç åðéöÜíåéá äåí õðÜñ÷åé"
+msgstr "BUG (Vect_build_sidx_from_topo): η εÏιÏάνεια δεν Ï
ÏάÏÏει"
#: ../lib/vector/Vlib/sindex.c:218
msgid "BUG (Vect_build_sidx_from_topo): isle does not exist"
@@ -4540,11 +4540,11 @@
#: ../lib/vector/Vlib/write.c:59 ../lib/vector/Vlib/open.c:40
#: ../lib/vector/Vlib/build.c:31
msgid "Requested format is not compiled in this version"
-msgstr "Ôï óõãêåêñéìÝíï format äåí ãßíåé compiled ãéá ôçí Ýêäïóç áõôÞ"
+msgstr "Το ÏÏ
γκεκÏιμÎνο format δεν γίνει compiled για Ïην ÎκδοÏη αÏ
Ïή"
#: ../lib/vector/Vlib/read.c:99 ../lib/vector/Vlib/geos.c:53
msgid "vector map is not opened"
-msgstr "Ï äéáíõóìáôéêüò ÷Üñôçò äåí åßíáé áíïéêôüò"
+msgstr "ΠδιανÏ
ÏμαÏικÏÏ ÏάÏÏÎ·Ï Î´ÎµÎ½ είναι ανοικÏÏÏ"
#: ../lib/vector/Vlib/read.c:102
#, c-format
@@ -4552,23 +4552,23 @@
"Vect_read_line(): feature id %d is not reasonable (max features in vector "
"map <%s>: %d)"
msgstr ""
-"Vect_read_line():ãñáììÞ %d äåí Ý÷åé ëïãéêÞ (max ãñáììÞ óôïí äéáíõóìáôéêü "
-"÷Üñôç: <%s>: %d)"
+"Vect_read_line():γÏαμμή %d δεν ÎÏει λογική (max γÏαμμή ÏÏον διανÏ
ÏμαÏÎ¹ÎºÏ "
+"ÏάÏÏη: <%s>: %d)"
#: ../lib/vector/Vlib/area.c:53
msgid "Attempt to read points of nonexistent area"
-msgstr "ÐñïóðÜèåéá ðñïóðåëáóçò óçìåßùí óå åðéöÜíåéá ðïõ äåí õðÜñ÷åé"
+msgstr "Î ÏοÏÏάθεια ÏÏοÏÏελαÏÎ·Ï ÏημείÏν Ïε εÏιÏάνεια ÏοÏ
δεν Ï
ÏάÏÏει"
#: ../lib/vector/Vlib/area.c:125
#, c-format
msgid "Unable to read line %d"
-msgstr "Áäõíáìßá áíÜãíùóçò ãñáììÞò %d"
+msgstr "ÎδÏ
ναμία ανάγνÏÏÎ·Ï Î³ÏÎ±Î¼Î¼Î®Ï %d"
#: ../lib/vector/Vlib/area.c:164 ../lib/vector/Vlib/area.c:193
#: ../lib/vector/Vlib/area.c:257 ../lib/vector/Vlib/area.c:286
#, c-format
msgid "Attempt to read topo for dead area (%d)"
-msgstr "ÐñïóðÜèåéá áíÜãíùóçò ôïðïãñáößáò ãéá êåíÞ (dead) åðéöÜíåéá (%d)"
+msgstr "Î ÏοÏÏάθεια ανάγνÏÏÎ·Ï ÏοÏογÏαÏÎ¯Î±Ï Î³Î¹Î± κενή (dead) εÏιÏάνεια (%d)"
#: ../lib/vector/Vlib/area.c:313
#, c-format
@@ -4581,8 +4581,8 @@
"Vect_read_line_geos(): feature id %d is not reasonable (max features in "
"vector map <%s>: %d)"
msgstr ""
-"÷Üñôç: <%s>: %d)"
ÏμαÏÎ¹ÎºÏ "
+"ÏάÏÏη: <%s>: %d)"
#: ../lib/vector/Vlib/geos.c:61
msgid "only native format supported"
@@ -4601,29 +4601,29 @@
#: ../lib/vector/Vlib/geos.c:203
#, fuzzy, c-format
msgid "Unable to read line offset %ld"
+msgstr "ÎδÏ
#: ../lib/vector/Vlib/geos.c:410
#, fuzzy, c-format
msgid "Attempt to read points of nonexistent area id %d"
δεν Ï
ÏάÏÏει"
#: ../lib/vector/Vlib/geos.c:470
#, fuzzy, c-format
msgid "Unable to read feature id %d"
+msgstr "ÎδÏ
#: ../lib/vector/Vlib/level_two.c:234 ../lib/vector/Vlib/level_two.c:259
#: ../lib/vector/Vlib/level_two.c:283 ../lib/vector/Vlib/level_two.c:302
#: ../lib/vector/Vlib/level_two.c:320 ../lib/vector/Vlib/level_two.c:339
#, c-format
msgid "Vector map <%s> is not open on level >= 2"
-msgstr "Ï äéáíõóìáôéêüò ÷Üñôçò <%s> äåí åßíáé áíïéêôüò óå åðßðåäï >= 2"
+msgstr "ΠδιανÏ
ÏμαÏικÏÏ ÏάÏÏÎ·Ï <%s> δεν είναι ανοικÏÏÏ Ïε εÏίÏεδο >= 2"
#: ../lib/vector/Vlib/build_ogr.c:272
#, c-format
msgid "Unable to calculate centroid for area %d"
-msgstr "Áäõíáìßá õðïëïãéóìïý êÝíôñùí ðïëõãþíïõ ãéá ôçí åðéöÜíåéá %d"
+msgstr "ÎδÏ
ναμία Ï
ÏολογιÏÎ¼Î¿Ï ÎºÎνÏÏÏν ÏολÏ
γÏνοÏ
για Ïην εÏιÏάνεια %d"
#: ../lib/vector/Vlib/build_ogr.c:333
msgid "Partial build for OGR is not supported"
@@ -4636,20 +4636,20 @@
#: ../lib/vector/Vlib/build_ogr.c:349
msgid "Feature: "
#: ../lib/vector/Vlib/build_ogr.c:361
#, c-format
msgid "Feature %d without geometry ignored"
-msgstr "×áñáêôçñéóôéêü %d ÷ùñßò ãåùìåôñßá áãíïåßôáé"
+msgstr "ΧαÏακÏηÏιÏÏÎ¹ÎºÏ %d ÏÏÏÎ¯Ï Î³ÎµÏμεÏÏία αγνοείÏαι"
#: ../lib/vector/Vlib/build_ogr.c:368
msgid "OGR feature without ID ignored"
-msgstr "OGR ÷áñáêôçñéóôéêü ÷ùñßò ID áãíïåßôáé"
+msgstr "OGR ÏαÏακÏηÏιÏÏÎ¹ÎºÏ ÏÏÏÎ¯Ï ID αγνοείÏαι"
#: ../lib/vector/Vlib/cindex.c:31
msgid "Category index is not up to date"
-msgstr "Ï êáôÜëïãïò ôùí êáôçãïñéþí äåí åßíáé åíçìåñùìÝíïò"
+msgstr "ΠκαÏÎ¬Î»Î¿Î³Î¿Ï ÏÏν καÏηγοÏιÏν δεν είναι ενημεÏÏμÎνοÏ"
#: ../lib/vector/Vlib/cindex.c:61 ../lib/vector/Vlib/cindex.c:125
#: ../lib/vector/Vlib/cindex.c:143 ../lib/vector/Vlib/cindex.c:166
@@ -4686,39 +4686,39 @@
#: ../lib/vector/Vlib/close.c:134
#, c-format
msgid "Unable to close vector <%s>"
-msgstr "Áäõíáìßá êëåéóßìáôïò ôïõ äéáíýóìáôïò <%s>"
+msgstr "ÎδÏ
ναμία κλειÏίμαÏÎ¿Ï ÏοÏ
διανÏÏμαÏÎ¿Ï <%s>"
#: ../lib/vector/Vlib/overlay.c:74
msgid "unknown operator"
-msgstr "¶ãíùóôïò ôåëåóôÞò"
+msgstr "ÎγνÏÏÏÎ¿Ï ÏελεÏÏήÏ"
#: ../lib/vector/Vlib/overlay.c:123
msgid "Overlay: line/boundary types not supported by AND operator"
-msgstr "Overlay: ãñáììÝò/üñéá ôýðïé äåí õðïóôçñßæïíôáé áðü AND ôåëåóôÞ"
+msgstr "Overlay: γÏαμμÎÏ/ÏÏια ÏÏÏοι δεν Ï
ÏοÏÏηÏίζονÏαι αÏÏ AND ÏελεÏÏή"
#: ../lib/vector/Vlib/overlay.c:126
msgid "Overlay: area x area types not supported by AND operator"
msgstr ""
-"Overlay: åðéöÜíåéá x åðéöÜíåéá ôýðïé äåí õðïóôçñßæïíôáé áðü AND ôåëåóôÞ"
+"Overlay: εÏιÏάνεια x εÏιÏάνεια ÏÏÏοι δεν Ï
#: ../lib/vector/Vlib/open_ogr.c:54
msgid "OGR format cannot be updated"
-msgstr "OGR format äåí ìðïñåß íá áíáíåùèåß"
+msgstr "OGR format δεν μÏοÏεί να ανανεÏθεί"
#: ../lib/vector/Vlib/open_ogr.c:66
#, c-format
msgid "Unable to open OGR data source '%s'"
-msgstr "Áäõíáìßá áíïßãìáôïò OGR ðçãÞ äåäïìÝíùí '%s'"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï OGR Ïηγή δεδομÎνÏν '%s'"
#: ../lib/vector/Vlib/open_ogr.c:86
#, c-format
msgid "Unable to open layer <%s>"
-msgstr "Áäõíáìßá áíïßãìáôïò åðéðÝäïõ <%s>"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï ÎµÏιÏÎδοÏ
<%s>"
#: ../lib/vector/Vlib/open_ogr.c:139
#, c-format
msgid "Unable to open fidx file for vector map <%s@%s>"
-msgstr "Áäõíáìßá áíïßãìáôïò áñ÷åßïõ fidx ãéá ôïí äéáíõóìáôéêü ÷Üñôç <%s@%s>"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï Î±ÏÏείοÏ
fidx για Ïον διανÏ
ÏμαÏÎ¹ÎºÏ ÏάÏÏη <%s@%s>"
#: ../lib/vector/Vlib/open_ogr.c:157
#, c-format
@@ -4740,17 +4740,17 @@
#: ../lib/vector/Vlib/level.c:40
msgid "Map structure has been closed"
-msgstr "Ç äïìÞ ôïõ ÷Üñôç Ý÷åé êëåßóåé"
+msgstr "Πδομή ÏοÏ
ÏάÏÏη ÎÏει κλείÏει"
#: ../lib/vector/Vlib/break_lines.c:374
#, fuzzy, c-format
msgid "Intersections: %5d"
-msgstr "¶ëëç ðñïâïëÞ"
+msgstr "Îλλη ÏÏοβολή"
#: ../lib/vector/Vlib/buffer2.c:364
#, fuzzy
msgid "Line is not looped"
-msgstr "Ïé ðßíáêåò äåí åðéôñÝðïíôáé"
+msgstr "Îι ÏÎ¯Î½Î±ÎºÎµÏ Î´ÎµÎ½ εÏιÏÏÎÏονÏαι"
#: ../lib/vector/Vlib/buffer2.c:598 ../lib/vector/Vlib/buffer2.c:609
msgid "Next edge was visited but it is not the first one !!! breaking loop"
@@ -4759,7 +4759,7 @@
#: ../lib/vector/Vlib/buffer2.c:657
#, fuzzy
msgid "side != 0 feature not implemented"
#: ../lib/vector/Vlib/buffer2.c:899 ../lib/vector/Vlib/buffer2.c:946
msgid "zero area size"
@@ -4768,7 +4768,7 @@
#: ../lib/vector/Vlib/buffer2.c:905 ../lib/vector/Vlib/buffer2.c:952
#, fuzzy
msgid "Line was not closed"
#: ../lib/vector/Vlib/buffer2.c:918 ../lib/vector/Vlib/buffer2.c:969
msgid "Vect_get_point_in_poly() failed"
@@ -4782,37 +4782,37 @@
#: ../lib/vector/Vlib/write.c:135
msgid "Unable to write feature, vector map is not opened"
msgstr ""
-"Áäõíáìßá äçìéïõñãßáò óôïé÷åßïõ, ï äéáíõóìáôéêüò ÷Üñôçò äåí åßíáé áíïéêôüò"
+"ÎδÏ
ναμία δημιοÏ
ÏÎ³Î¯Î±Ï ÏÏοιÏείοÏ
, ο διανÏ
#: ../lib/vector/Vlib/write.c:148
msgid "Unable to write feature (negative offset)"
-msgstr "Áäõíáìßá åããñáöÞ feature (áñíçôéêü offset)"
+msgstr "ÎδÏ
ναμία εγγÏαÏή feature (αÏνηÏÎ¹ÎºÏ offset)"
#: ../lib/vector/Vlib/write.c:181
msgid "Unable to rewrite feature, vector map is not opened"
msgstr ""
-"Áäõíáìßá åðáíåããñáöÞò feature, ï äéáíõóìáôéêüò ÷Üñôçò äåí åßíáé áíïéêôüò"
+"ÎδÏ
ναμία εÏανεγγÏαÏÎ®Ï feature, ο διανÏ
#: ../lib/vector/Vlib/write.c:194
#, c-format
msgid "Unable to rewrite feature %d"
+msgstr "ÎδÏ
#: ../lib/vector/Vlib/write.c:219
#, c-format
msgid ""
"Unable to delete feature %d, vector map <%s> is not opened on topology level"
msgstr ""
-"Áäõíáìßá äéáãñáöÞò feature %d, ï äéáíõóìáôéêüò ÷Üñôçò <%s> äåí åßíáé "
-"áíïéêôüò óå ôïðïëïãéêü åðßðåäï"
+"ÎδÏ
ναμία διαγÏαÏÎ®Ï feature %d, ο διανÏ
ÏμαÏικÏÏ ÏάÏÏÎ·Ï <%s> δεν είναι "
+"ανοικÏÏÏ Ïε ÏοÏÎ¿Î»Î¿Î³Î¹ÎºÏ ÎµÏίÏεδο"
#: ../lib/vector/Vlib/write.c:225
#, c-format
msgid ""
"Unable to delete feature %d, vector map <%s> is not opened in 'write' mode"
msgstr ""
-"áíïéêôüò óå 'write' mode"
+"ÎδÏ
+"ανοικÏÏÏ Ïε 'write' mode"
#: ../lib/vector/Vlib/write.c:239
#, fuzzy, c-format
@@ -4824,16 +4824,16 @@
msgid ""
"Unable to restore feature %d, vector map <%s> is not opened on topology level"
msgstr ""
-"Áäõíáìßá áðüêáôÜóôáóçò feature %d, äéáíõóìáôéêüò ÷Üñôçò <%s> äåí åßíáé "
+"ÎδÏ
ναμία αÏÏκαÏάÏÏαÏÎ·Ï feature %d, διανÏ
#: ../lib/vector/Vlib/write.c:271
#, c-format
msgid ""
"Unable to restore feature %d, vector map <%s> is not opened in 'write' mode"
msgstr ""
-"Áäõíáìßá áðïêáôÜóôáóçò feature %d, äéáíõóìáôéêüò ÷Üñôçò <%s> äåí åßíáé "
+"ÎδÏ
ναμία αÏοκαÏάÏÏαÏÎ·Ï feature %d, διανÏ
#: ../lib/vector/Vlib/write.c:285
#, c-format
@@ -4857,11 +4857,11 @@
#: ../lib/vector/Vlib/poly.c:235
msgid "Unable to find point in polygon"
-msgstr "Áäõíáìßá åýñåóçò óçìåßïõ óôï ðïëýãùíï"
+msgstr "ÎδÏ
ναμία εÏÏεÏÎ·Ï ÏημείοÏ
ÏÏο ÏολÏγÏνο"
#: ../lib/vector/Vlib/poly.c:649
msgid "conditions failed"
-msgstr "Ïé óõíèÞêåò áðÝôõ÷áí"
+msgstr "Îι ÏÏ
Î½Î¸Î®ÎºÎµÏ Î±ÏÎÏÏ
Ïαν"
#: ../lib/vector/Vlib/open.c:100
#, c-format
@@ -4872,8 +4872,8 @@
msgid ""
"Vector map which is not in the current mapset cannot be opened for update"
msgstr ""
-"Ï äéáíõóìáôéêüò ÷Üñôçò ðïõ äåí áíÞêåé óôï ôñÝ÷ïí mapset äåí ìðïñåß íá "
-"áíïßîåé ãéá åíçìÝñùóç"
+"ΠδιανÏ
ÏμαÏικÏÏ ÏάÏÏÎ·Ï ÏοÏ
δεν ανήκει ÏÏο ÏÏÎÏον mapset δεν μÏοÏεί να "
+"ανοίξει για ενημÎÏÏÏη"
#: ../lib/vector/Vlib/open.c:211 ../lib/vector/Vlib/open.c:279
#: ../lib/vector/Vlib/open.c:299
@@ -4882,28 +4882,28 @@
"Unable to open vector map <%s> on level %d. Try to rebuild vector topology "
"by v.build."
msgstr ""
-"Áäõíáìßá áíïßãìáôïò äéáíõóìáôéêïý ÷Üñôç <%s> óôï ôïðïëïãéêü åðßðåäï %d. "
-"ÄïêéìÜóôå íá îáíáöôéÜîåôå ôçí ôïðïëïãßá ìå v.build."
+"ÎδÏ
ναμία ανοίγμαÏÎ¿Ï Î´Î¹Î±Î½Ï
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη <%s> ÏÏο ÏοÏÎ¿Î»Î¿Î³Î¹ÎºÏ ÎµÏίÏεδο %d. "
+"ÎοκιμάÏÏε να ξαναÏÏιάξεÏε Ïην ÏοÏολογία με v.build."
#: ../lib/vector/Vlib/open.c:214
msgid "Unable to read head file"
-msgstr "Áäõíáìßá áíÜãíùóçò head áñ÷åßïõ"
+msgstr "ÎδÏ
ναμία ανάγνÏÏÎ·Ï head αÏÏείοÏ
#: ../lib/vector/Vlib/open.c:236
#, c-format
msgid "Unable to open topology file for vector map <%s>"
msgstr ""
-"Áäõíáìßá áíïßãìáôïò ôïðïëïãéêïý áñ÷åßïõ ãéá ôïí äéáíõóìáôéêü ÷Üñôç <%s>"
+"ÎδÏ
ναμία ανοίγμαÏÎ¿Ï ÏοÏÎ¿Î»Î¿Î³Î¹ÎºÎ¿Ï Î±ÏÏείοÏ
για Ïον διανÏ
#: ../lib/vector/Vlib/open.c:262
#, c-format
msgid "Unable to open category index file for vector map <%s>"
-msgstr "Áäõíáìßá áíïßãìáôïò ôïõ õðïìíÞìáôïò ãéá ôïí äéáíõóìáôéêü ÷Üñôç <%s>"
+msgstr "ÎδÏ
Ï
ÏομνήμαÏÎ¿Ï Î³Î¹Î± Ïον διανÏ
#: ../lib/vector/Vlib/open.c:353 ../lib/vector/Vlib/open.c:576
#, c-format
msgid "Unable to open history file for vector map <%s>"
-msgstr "Áäõíáìßá áíïßãìáôïò ôïõ éóôïñéêïý ôïõ äéáíõóìáôéêïý ÷Üñôç <%s>"
+msgstr "ÎδÏ
ιÏÏοÏÎ¹ÎºÎ¿Ï ÏοÏ
διανÏ
#: ../lib/vector/Vlib/open.c:531
#, c-format
@@ -4913,7 +4913,7 @@
#: ../lib/vector/Vlib/open.c:566
#, c-format
msgid "Unable to create vector map <%s>"
-msgstr "Áäõíáìßá äçìéïõñãßáò äéáíõóìáôéêïý ÷Üñôç <%s>"
+msgstr "ÎδÏ
ναμία δημιοÏ
ÏÎ³Î¯Î±Ï Î´Î¹Î±Î½Ï
#: ../lib/vector/Vlib/open.c:622
#, c-format
@@ -4927,218 +4927,218 @@
#: ../lib/vector/Vlib/open.c:742
#, c-format
msgid "Please rebuild topology for vector map <%s@%s>"
-msgstr "Ðáñáêáëþ îáíáöôéÜîôå ôçí ôïðïëïãßá ãéá ôïí äéáíõóìáôéêü ÷Üñôç <%s@%s>"
+msgstr "ΠαÏÎ±ÎºÎ±Î»Ï Î¾Î±Î½Î±ÏÏιάξÏε Ïην ÏοÏολογία για Ïον διανÏ
#: ../lib/vector/Vlib/build.c:123
#, fuzzy, c-format
msgid "Building topology for vector map <%s>..."
-msgstr "Äçìéïõñãßá ôïðïëïãßáò ãéá ôïí äéáíõóìáôéêü ÷Üñôç <%s>...\n"
+msgstr "ÎημιοÏ
Ïγία ÏοÏÎ¿Î»Î¿Î³Î¯Î±Ï Î³Î¹Î± Ïον διανÏ
ÏμαÏÎ¹ÎºÏ ÏάÏÏη <%s>...\n"
#: ../lib/vector/Vlib/build.c:141
#, fuzzy
msgid "Topology was built"
-msgstr "Ç ôïðïëïãßá äçìéïõñãÞèçêå\n"
+msgstr "Î ÏοÏολογία δημιοÏ
Ïγήθηκε\n"
#: ../lib/vector/Vlib/build.c:153
#, fuzzy, c-format
msgid "Number of nodes: %d"
-msgstr "Áñéèìüò êüìâùí : %d\n"
+msgstr "ÎÏιθμÏÏ ÎºÏμβÏν : %d\n"
#: ../lib/vector/Vlib/build.c:154
#, fuzzy, c-format
msgid "Number of primitives: %d"
#: ../lib/vector/Vlib/build.c:155
#, fuzzy, c-format
msgid "Number of points: %d"
#: ../lib/vector/Vlib/build.c:156
#, fuzzy, c-format
msgid "Number of lines: %d"
-msgstr "Áñéèìüò ãñáììþí : %d\n"
+msgstr "ÎÏιθμÏÏ Î³ÏαμμÏν : %d\n"
#: ../lib/vector/Vlib/build.c:157
#, fuzzy, c-format
msgid "Number of boundaries: %d"
-msgstr "Áñéèìüò óõíïñéáêþí ãñáììþí: %d\n"
+msgstr "ÎÏιθμÏÏ ÏÏ
νοÏιακÏν γÏαμμÏν: %d\n"
#: ../lib/vector/Vlib/build.c:158
#, fuzzy, c-format
msgid "Number of centroids: %d"
-msgstr "Áñéèìüò êÝíôñùí ðïëõãþíïõ : %d\n"
γÏνοÏ
: %d\n"
#: ../lib/vector/Vlib/build.c:161
#, fuzzy, c-format
msgid "Number of faces: %d"
+msgstr "ÎÏιθμÏÏ ÏÏ
#: ../lib/vector/Vlib/build.c:164
#, fuzzy, c-format
msgid "Number of kernels: %d"
-msgstr "Áñéèìüò ðõñÞíùí : %d\n"
+msgstr "ÎÏιθμÏÏ ÏÏ
ÏήνÏν : %d\n"
#: ../lib/vector/Vlib/build.c:205
#, fuzzy, c-format
msgid "Number of areas: %d"
-msgstr "Áñéèìüò ðåñéï÷þí : %d\n"
+msgstr "ÎÏιθμÏÏ ÏεÏιοÏÏν : %d\n"
#: ../lib/vector/Vlib/build.c:206
#, fuzzy, c-format
msgid "Number of isles: %d"
#: ../lib/vector/Vlib/build.c:209
#, fuzzy, c-format
msgid "Number of incorrect boundaries: %d"
-msgstr "Áñéèìüò ëáíèáóìÝíùí óõíïñéáêþí ãñáììþí (boundaries) : %d\n"
+msgstr "ÎÏιθμÏÏ Î»Î±Î½Î¸Î±ÏμÎνÏν ÏÏ
νοÏιακÏν γÏαμμÏν (boundaries) : %d\n"
#: ../lib/vector/Vlib/build.c:213
#, fuzzy, c-format
msgid "Number of centroids outside area: %d"
#: ../lib/vector/Vlib/build.c:217
#, fuzzy, c-format
msgid "Number of duplicate centroids: %d"
-msgstr "Áñéèìüò äéðëþí êÝíôñùí ðïëõãþíùí : %d\n"
+msgstr "ÎÏιθμÏÏ Î´Î¹ÏλÏν κÎνÏÏÏν ÏολÏ
γÏνÏν : %d\n"
#: ../lib/vector/Vlib/build.c:221
#, fuzzy, c-format
msgid "Number of areas without centroid: %d"
-msgstr "Áñéèìüò ðåñéï÷þí ÷ùñßò êÝíôñá : %d\n"
+msgstr "ÎÏιθμÏÏ ÏεÏιοÏÏν ÏÏÏÎ¯Ï ÎºÎνÏÏα : %d\n"
#: ../lib/vector/Vlib/build.c:226
#, fuzzy
msgid "Number of areas: -"
-msgstr "Áñéèìüò ðåñéï÷þí : -\n"
+msgstr "ÎÏιθμÏÏ ÏεÏιοÏÏν : -\n"
#: ../lib/vector/Vlib/build.c:227
#, fuzzy
msgid "Number of isles: -"
#: ../lib/vector/Vlib/build.c:256
#, c-format
msgid "Unable to open topo file for write <%s>"
-msgstr "Áäõíáìßá áíïßãìáôïò áñ÷åßïõ ãéá åããñáöÞ <%s>"
+msgstr "ÎδÏ
για εγγÏαÏή <%s>"
#: ../lib/vector/Vlib/build.c:264
msgid "Error writing out topo file"
-msgstr "ÓöÜëìá êáôÜ ôçí åããñáöÞ ôïõ ÷Üñôç"
+msgstr "ΣÏάλμα καÏά Ïην εγγÏαÏή ÏοÏ
ÏάÏÏη"
#: ../lib/vector/Vlib/build.c:407
#, c-format
msgid "Unable open spatial index file for write <%s>"
-msgstr "Áäõíáìßá áíïßãìáôïò ðßíáêá ÷ùñéêþí äåäïìÝíùí ãéá åããñáöÞ <%s>"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï Ïίνακα ÏÏÏικÏν δεδομÎνÏν για εγγÏαÏή <%s>"
#: ../lib/vector/Vlib/build.c:415
msgid "Error writing out spatial index file"
-msgstr "ÓöÜëìá åããñáöÞò ÷ùñéêþí äåäïìÝíùí óôï áñ÷åßï"
+msgstr "ΣÏάλμα εγγÏαÏÎ®Ï ÏÏÏικÏν δεδομÎνÏν ÏÏο αÏÏείο"
#: ../lib/vector/vedit/cats.c:63
#, fuzzy, c-format
msgid "Unable to set category %d for (feature id %d)"
-msgstr "Áäõíáìßá êáèïñéóìïý êáôçãïñßáò %d ãéá ôç ãñáììÞ %d"
+msgstr "ÎδÏ
ναμία καθοÏιÏÎ¼Î¿Ï ÎºÎ±ÏηγοÏÎ¯Î±Ï %d για Ïη γÏαμμή %d"
#: ../lib/vector/vedit/select.c:232
msgid "Unknown query tool"
-msgstr "¶ãíùóôïò query åñãáëåßï"
+msgstr "ÎγνÏÏÏÎ¿Ï query εÏγαλείο"
#~ msgid "Requested g3d map <%s> not found"
-#~ msgstr "Ï ÷Üñôçò g3d <%s> äåí âñÞèçêå"
+#~ msgstr "Î ÏάÏÏÎ·Ï g3d <%s> δεν βÏήθηκε"
#~ msgid "Unable to feature %d from vector map <%s>"
-#~ msgstr "Áäõíáìßá óå feature %d áðü ôïí äéáíõóìáôéêü ÷Üñôç <%s>"
+#~ msgstr "ÎδÏ
ναμία Ïε feature %d αÏÏ Ïον διανÏ
#~ msgid "Invalid view position coordinates, using %f,%f"
-#~ msgstr "ËÜèïò óõíôåôáãìÝíåò üøçò, ÷ñÞóç %f,%f"
+#~ msgstr "ÎÎ¬Î¸Î¿Ï ÏÏ
νÏεÏαγμÎÎ½ÎµÏ ÏÏηÏ, ÏÏήÏη %f,%f"
#~ msgid "Vector is not 3D"
-#~ msgstr "Ôï äéÜíõóìá äåí åßíáé 3Ä"
+#~ msgstr "Το διάνÏ
Ïμα δεν είναι 3Î"
#~ msgid "Cannot find z column <%s> (please verify name, e.g. with v.info)"
#~ msgstr ""
-#~ "Äåí ìðïñþ íá âñþ ôçí óôÞëç z <%s> (ðáñáêáëþ åðéâåâáéþóôå ôï üíïìá, e.g. "
+#~ "Îεν μÏοÏÏ Î½Î± βÏÏ Ïην ÏÏήλη z <%s> (ÏαÏÎ±ÎºÎ±Î»Ï ÎµÏιβεβαιÏÏÏε Ïο Ïνομα, e.g. "
#~ "with v.info)"
#~ msgid "Column type of z column is not supported (must be integer or double)"
#~ msgstr ""
-#~ "Ï ôýðïò óôÞëçò z äåí õðïóôçñßæåôáé (ðñÝðåé íá åßíáé áêÝñáéïò Þ äéðëüò)"
+#~ "Î ÏÏÏÎ¿Ï ÏÏÎ®Î»Î·Ï z δεν Ï
ÏοÏÏηÏίζεÏαι (ÏÏÎÏει να είναι ακÎÏÎ±Î¹Î¿Ï Î® διÏλÏÏ)"
#~ msgid "Cannot read column type of smooth column"
-#~ msgstr "Äåí åßíáé äõíáôÞ ç áíÜãíùóç ôïõ ôýðïõ óôÞëçò ôçò smooth óôÞëçò"
+#~ msgstr "Îεν είναι δÏ
ναÏή η ανάγνÏÏη ÏοÏ
ÏÏÏοÏ
ÏÏÎ®Î»Î·Ï ÏÎ·Ï smooth ÏÏήληÏ"
#~ msgid "Column type of smooth column (datetime) is not supported"
-#~ msgstr "Ï ôýðïò óôÞëçò Þ smooth óôÞëç (datetime) äåí õðïóôçñßæåôáé"
+#~ msgstr "Î ÏÏÏÎ¿Ï ÏÏÎ®Î»Î·Ï Î® smooth ÏÏήλη (datetime) δεν Ï
ÏοÏÏηÏίζεÏαι"
#~ msgid "Column type of s column is not supported (must be integer or double)"
#~ msgstr ""
-#~ "Ï ôýðïò óôÞëçò ôçò s óôÞëçò äåí õðïóôçñßæåôáé (ðñÝðåé íá åßíáé áêÝñáéïò Þ "
-#~ "äéðëüò)"
+#~ "Î ÏÏÏÎ¿Ï ÏÏÎ®Î»Î·Ï ÏÎ·Ï s ÏÏÎ®Î»Î·Ï Î´ÎµÎ½ Ï
ÏοÏÏηÏίζεÏαι (ÏÏÎÏει να είναι ακÎÏÎ±Î¹Î¿Ï Î® "
+#~ "διÏλÏÏ)"
#~ msgid "Unknown Location"
-#~ msgstr "¶ãíùóôç ðåñéï÷Þ"
+#~ msgstr "ÎγνÏÏÏη ÏεÏιοÏή"
#~ msgid "Too many arguments"
-#~ msgstr "ÐÜñá ðïëëÝò ðáñÜìåôñïé(;)"
+#~ msgstr "ΠάÏα ÏολλÎÏ ÏαÏάμεÏÏοι(;)"
#~ msgid "Incompatible library version for module"
-#~ msgstr "Áóýìâáôç Ýêäïóç âéâëéïèÞêçò ãéá ôï module"
+#~ msgstr "ÎÏÏμβαÏη ÎκδοÏη Î²Î¹Î²Î»Î¹Î¿Î¸Î®ÎºÎ·Ï Î³Î¹Î± Ïο module"
#~ msgid "Unable to delete layer/category %d/%d line %d"
-#~ msgstr "Áäõíáìßá äéáãñáöÞò óôñþìá/êáôçãïñßá %d/%d ãñáììÞ %d"
+#~ msgstr "ÎδÏ
ναμία διαγÏαÏÎ®Ï ÏÏÏÏμα/καÏηγοÏία %d/%d γÏαμμή %d"
#~ msgid "Removed dangles:"
-#~ msgstr "Ðåñéï÷Ýò ðïõ áöáéñÝèçêáí:"
+#~ msgstr "ΠεÏιοÏÎÏ ÏοÏ
αÏαιÏÎθηκαν:"
#~ msgid "Registering points"
-#~ msgstr "ÅããñáöÞ óçìåßùí"
+#~ msgstr "ÎγγÏαÏή ÏημείÏν"
#~ msgid "Registered points"
-#~ msgstr "ÅããåãñáìÝíá óçìåßá"
+#~ msgstr "ÎγγεγÏαμÎνα Ïημεία"
#, fuzzy
#~ msgid "Nodes marked to be snapped"
-#~ msgstr "Óçìåßá \"óçìáäåìÝíá\" ãéá óðÜóéìï (break)"
+#~ msgstr "Σημεία \"ÏημαδεμÎνα\" για ÏÏάÏιμο (break)"
#~ msgid "Modifications"
-#~ msgstr "ÌåôáôñïðÝò"
+#~ msgstr "ÎεÏαÏÏοÏÎÏ"
#, fuzzy
#~ msgid "Removed bridges"
-#~ msgstr "Ðåñéï÷Ýò ðïõ áöáéñÝèçêáí"
αÏαιÏÎθηκαν"
#~ msgid "Duplicates"
-#~ msgstr "ÄéðëÝò åããñáöÝò"
+#~ msgstr "ÎιÏλÎÏ ÎµÎ³Î³ÏαÏÎÏ"
#~ msgid "All points (vertices)"
-#~ msgstr "¼ëá ôá óçìåßá (vertices)"
+#~ msgstr "Îλα Ïα Ïημεία (vertices)"
#~ msgid "Registered points (unique coordinates)"
-#~ msgstr "ÅããåãñáìÝíá óçìåßá (ìïíáäéêÝò óõíôåôáãìÝíåò)"
+#~ msgstr "ÎγγεγÏαμÎνα Ïημεία (μοναδικÎÏ ÏÏ
νÏεÏαγμÎνεÏ)"
#~ msgid "Points marked for break"
#~ msgid "Breaks"
-#~ msgstr "\"Óðáóßìáôá\" (breaks)"
+#~ msgstr "\"ΣÏαÏίμαÏα\" (breaks)"
#~ msgid "Removed areas"
αÏαιÏÎθηκαν"
#~ msgid "Type"
-#~ msgstr "Ôýðïò"
+#~ msgstr "ΤÏÏοÏ"
#~ msgid "G_malloc: out of memory"
-#~ msgstr "G_malloc: åêôüò ìíÞìçò"
+#~ msgstr "G_malloc: εκÏÏÏ Î¼Î½Î®Î¼Î·Ï"
#~ msgid "G_calloc: out of memory"
-#~ msgstr "G_calloc: åêôüò ìíÞìçò"
+#~ msgstr "G_calloc: εκÏÏÏ Î¼Î½Î®Î¼Î·Ï"
#~ msgid "G_realloc: out of memory"
-#~ msgstr "G_realloc: åêôüò ìíÞìçò"
+#~ msgstr "G_realloc: εκÏÏÏ Î¼Î½Î®Î¼Î·Ï"
#~ msgid "Cannot open database %s"
-#~ msgstr "Äåí ìðïñþ íá áíïßîù ôçí âÜóç äåäïìÝíùí %s"
+#~ msgstr "Îεν μÏοÏÏ Î½Î± Î±Î½Î¿Î¯Î¾Ï Ïην βάÏη δεδομÎνÏν %s"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_el.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_el.po 2014-04-13 19:01:14 UTC (rev 59715)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_el.po 2014-04-13 19:13:43 UTC (rev 59716)
@@ -16,7 +16,7 @@
"Language-Team: Greek <grass-translations at lists.osgeo.org>\n"
"Language: el\n"
"MIME-Version: 1.0\n"
-"Content-Type: text/plain; charset=ISO-8859-7\n"
+"Content-Type: text/plain; charset=UTF-8\n"
"Content-Transfer-Encoding: 8bit\n"
"X-Generator: KBabel 1.11.4\n"
@@ -164,7 +164,7 @@
#: ../vector/v.what.rast/main.c:139
#, c-format
msgid "Raster map <%s> not found"
-msgstr "Ï ÷Üñôçò raster <%s> äåí âñÝèçêå."
+msgstr "Î ÏάÏÏÎ·Ï raster <%s> δεν βÏÎθηκε."
#: ../raster/r.out.pov/main.c:178 ../raster/r.clump/main.c:94
#: ../raster/r.cost/main.c:370 ../raster/r.cost/main.c:675
@@ -235,7 +235,7 @@
#: ../vector/v.to.rast/support.c:265 ../vector/v.to.rast/support.c:511
#, fuzzy, c-format
msgid "Unable to open raster map <%s>"
-msgstr "Áäõíáìßá áíïßãìáôïò ôïõ ÷Üñôç raster <%s>"
+msgstr "ÎδÏ
ÏάÏÏη raster <%s>"
#: ../raster/r.out.pov/main.c:183
#, c-format
@@ -297,7 +297,7 @@
#: ../raster/r.clump/main.c:49
#, fuzzy
msgid "raster, statistics, reclass"
-msgstr "ñÜóôåñ 3Ä, óôáôéóôéêÜ"
+msgstr "ÏάÏÏÎµÏ 3Î, ÏÏαÏιÏÏικά"
#: ../raster/r.clump/main.c:51
msgid ""
@@ -308,7 +308,7 @@
#: ../raster/r.clump/main.c:63 ../raster/r.recode/main.c:60
#, fuzzy
msgid "Title for output raster map"
-msgstr "¼íïìá åîáãüìåíïõ ñÜóôåñ ÷Üñôç"
+msgstr "Îνομα εξαγÏμενοÏ
ÏάÏÏÎµÏ ÏάÏÏη"
#: ../raster/r.clump/main.c:68 ../raster/r.series/main.c:170
#: ../raster/r.out.ppm3/main.c:90 ../raster/r.colors/main.c:249
@@ -321,7 +321,7 @@
#: ../imagery/i.smap/shapiro/parse.c:43
#, fuzzy
msgid "Run quietly"
-msgstr "ÔñÝ÷åé ÷ùñßò ìçíýìáôá"
+msgstr "ΤÏÎÏει ÏÏÏÎ¯Ï Î¼Î·Î½ÏμαÏα"
#: ../raster/r.clump/main.c:77 ../raster/r.series/main.c:188
#: ../raster/r.out.ppm3/main.c:102 ../raster/r.colors/main.c:258
@@ -369,7 +369,7 @@
#: ../vector/v.in.ogr/main.c:337
#, fuzzy, c-format
msgid "<%s> is an illegal file name"
-msgstr "<%s> åßíáé ìç åðéôñåðôü üíïìá áñ÷åßïõ"
+msgstr "<%s> είναι μη εÏιÏÏεÏÏÏ Ïνομα αÏÏείοÏ
#: ../raster/r.clump/main.c:98 ../raster/r.in.arc/main.c:154
#: ../raster/r.composite/main.c:192 ../raster/r.in.xyz/main.c:498
@@ -409,7 +409,7 @@
#: ../vector/v.neighbors/main.c:96
#, c-format
msgid "Unable to create raster map <%s>"
-msgstr "Áäõíáìßá äçìéïõñãßáò raster ÷Üñôç <%s>."
+msgstr "ÎδÏ
ναμία δημιοÏ
ÏÎ³Î¯Î±Ï raster ÏάÏÏη <%s>."
#: ../raster/r.clump/main.c:120
#, c-format
@@ -424,12 +424,12 @@
#: ../raster/r.clump/clump.c:101
#, fuzzy, c-format
msgid "Unable to read raster map row %d "
-msgstr "Áäõíáìßá äçìéïõñãßáò ñÜóôåñ ÷Üñôç"
+msgstr "ÎδÏ
ναμία δημιοÏ
ÏÎ³Î¯Î±Ï ÏάÏÏÎµÏ ÏάÏÏη"
#: ../raster/r.clump/clump.c:238
#, fuzzy, c-format
msgid "Failed writing raster map row %d"
-msgstr "Äåí Þôáí äõíáôÞ ç åããñáöÞ ãñáììÞò ñÜóôåñ"
+msgstr "Îεν ήÏαν δÏ
ναÏή η εγγÏαÏή γÏÎ±Î¼Î¼Î®Ï ÏάÏÏεÏ"
#: ../raster/r.in.arc/main.c:59 ../raster/r.in.gridatb/main.c:41
#: ../raster/r.in.poly/main.c:29 ../raster/r.in.gdal/main.c:79
@@ -610,12 +610,12 @@
#: ../raster/r.cost/main.c:147 ../raster/r.walk/main.c:214
#, fuzzy
msgid "Name of output raster map to contain movement directions"
-msgstr "¼íïìá åîáãüìåíïõ ñÜóôåñ ÷Üñôç (saturation)"
ÏάÏÏÎµÏ ÏάÏÏη (saturation)"
#: ../raster/r.cost/main.c:152
#, fuzzy
msgid "Name of starting vector points map"
-msgstr "¼íïìá åéóáãþìåíïõ ñÜóôåñ ÷Üñôç "
+msgstr "Îνομα ειÏαγÏμενοÏ
ÏάÏÏÎµÏ ÏάÏÏη "
#: ../raster/r.cost/main.c:153 ../raster/r.cost/main.c:165
#: ../raster/r.cost/main.c:174 ../raster/r.cost/main.c:224
@@ -626,7 +626,7 @@
#: ../raster/r.cost/main.c:158
#, fuzzy
msgid "Name of stop vector points map"
-msgstr "¼íïìá åéóáãþìåíùí ñÜóôåñ ÷áñôþí"
+msgstr "Îνομα ειÏαγÏμενÏν ÏάÏÏÎµÏ ÏαÏÏÏν"
#: ../raster/r.cost/main.c:159 ../raster/r.cost/main.c:183
msgid "Stop"
@@ -635,7 +635,7 @@
#: ../raster/r.cost/main.c:164
#, fuzzy
msgid "Name of starting raster points map"
-msgstr "¼íïìá ñÜóôåñ ÷Üñôç õøïìÝôñïõ"
+msgstr "Îνομα ÏάÏÏÎµÏ ÏάÏÏη Ï
ÏομÎÏÏοÏ
#: ../raster/r.cost/main.c:173
msgid "Map grid coordinates of a starting point (E,N)"
@@ -665,7 +665,7 @@
#: ../raster/r.cost/main.c:219
#, fuzzy
msgid "Keep null values in output raster map"
ÏάÏÏÎµÏ ÏάÏÏη "
#: ../raster/r.cost/main.c:223 ../raster/r.walk/main.c:318
msgid "Start with values in raster map"
@@ -759,7 +759,7 @@
#: ../vector/v.perturb/main.c:154 ../vector/v.generalize/main.c:290
#, fuzzy, c-format
msgid "Vector map <%s> not found"
+msgstr "ΠδιανÏ
#: ../raster/r.cost/main.c:324
msgid "Assigning negative cost to null cell. Null cells excluded."
@@ -820,12 +820,12 @@
#: ../raster/r.cost/main.c:517
#, fuzzy
msgid "Initializing output..."
-msgstr "ÅããñáöÞ %s áðü %s..."
+msgstr "ÎγγÏαÏή %s αÏÏ %s..."
#: ../raster/r.cost/main.c:540 ../raster/r.walk/main.c:880
#, fuzzy
msgid "Initializing directional output "
#: ../raster/r.cost/main.c:581 ../raster/r.drain/main.c:290
msgid "Failed to guess site file format"
@@ -897,7 +897,7 @@
#: ../raster/r.cost/btree.c:146
#, fuzzy, c-format
msgid "Unable to find row %d, col %d: %f"
+msgstr "ÎδÏ
ναμία δημιοÏ
#: ../raster/r.cost/btree.c:185
msgid "Illegal delete request"
@@ -945,7 +945,7 @@
#: ../raster/r.cats/main.c:51
#, fuzzy
msgid "raster, category"
-msgstr "ñÜóôåñ 3D, voxel, åîáãùãÞ"
+msgstr "ÏάÏÏÎµÏ 3D, voxel, εξαγÏγή"
#: ../raster/r.cats/main.c:53
msgid ""
@@ -966,7 +966,7 @@
#: ../locale/scriptstrings/r.tileset_to_translate.c:13
#: ../vector/v.db.select/main.c:64 ../vector/v.vect.stats/main.c:201
msgid "Output field separator"
-msgstr "Äéá÷ùñéóôÞò ðåäßùí åîüäïõ"
+msgstr "ÎιαÏÏÏιÏÏÎ®Ï ÏεδίÏν εξÏδοÏ
#: ../raster/r.cats/main.c:78 ../raster/r.support/front/front.c:114
msgid "Raster map from which to copy category table"
@@ -979,7 +979,7 @@
#: ../raster/r.cats/main.c:91
#, fuzzy
msgid "Default label or format string for dynamic labeling"
-msgstr "ÐñïåðéëïãÞ"
+msgstr "Î ÏοεÏιλογή"
#: ../raster/r.cats/main.c:93
msgid "Used when no explicit label exists for the category"
@@ -1042,7 +1042,7 @@
#: ../raster/r.transect/main.c:54
#, fuzzy
msgid "raster, transect"
#: ../raster/r.transect/main.c:56
msgid ""
@@ -1060,7 +1060,7 @@
#: ../raster/r.transect/main.c:85 ../raster/r.what/main.c:117
#: ../raster3d/r3.out.ascii/main.c:98
msgid "Char string to represent no data cell"
-msgstr "Ôï óôïé÷åßï char áíôéðñïóùðåýåé êåëü ÷ùñßò äåäïìÝíá"
+msgstr "Το ÏÏοιÏείο char ανÏιÏÏοÏÏÏεÏει ÎºÎµÎ»Ï ÏÏÏÎ¯Ï Î´ÎµÎ´Î¿Î¼Îνα"
#: ../raster/r.transect/main.c:97 ../raster/r.profile/main.c:97
msgid "Output easting and northing in first two columns of four column output"
@@ -1565,7 +1565,7 @@
#: ../raster/r.support/modcolr/modcolr.c:54
#, fuzzy, c-format
msgid "Color table for <%s> updated"
-msgstr "×ñþìá"
+msgstr "ΧÏÏμα"
#: ../raster/r.watershed/seg/main.c:84 ../raster/r.watershed/seg/main.c:95
#: ../raster/r.watershed/ram/main.c:79 ../raster/r.watershed/ram/main.c:95
@@ -1664,7 +1664,7 @@
#: ../raster/r.watershed/seg/close_maps.c:52
#, fuzzy
msgid "unable to open flow accumulation map layer"
-msgstr "Áäõíáìßá áíïßãìáôïò ÷Üñôç õøïìÝôñùí"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï ÏάÏÏη Ï
ÏομÎÏÏÏν"
#: ../raster/r.watershed/seg/do_cum.c:17 ../raster/r.watershed/ram/do_cum.c:16
msgid "SECTION 3: Accumulating Surface Flow with SFD."
@@ -1707,7 +1707,7 @@
#: ../raster/r.watershed/ram/close_maps.c:201
#, fuzzy
msgid "unable to open new LS factor map layer."
-msgstr "Áäõíáìßá áíïßãìáôïò äéáíõóìáôéêïý ÷Üñôç <%s>"
+msgstr "ÎδÏ
#: ../raster/r.watershed/ram/close_maps.c:219
msgid "unable to open new slope length map layer."
@@ -1716,7 +1716,7 @@
#: ../raster/r.watershed/ram/close_maps.c:241
#, fuzzy
msgid "unable to open new S factor map layer."
+msgstr "ÎδÏ
#: ../raster/r.watershed/shed/intro.c:8
#, c-format
@@ -2147,7 +2147,7 @@
#: ../raster/r.watershed/shed/com_line.c:352
#, fuzzy
msgid "Type <return> if you do not have a disturbed land map layer."
-msgstr "Ôýðïò<return>."
+msgstr "ΤÏÏοÏ<return>."
#: ../raster/r.watershed/shed/com_line.c:364
msgid ""
@@ -2219,7 +2219,7 @@
#: ../raster/r.flow/calc.c:411
#, fuzzy
msgid "raster, hydrology"
#: ../raster/r.watershed/front/main.c:57
msgid "Watershed basin analysis program."
@@ -2431,7 +2431,7 @@
#: ../raster/r.composite/main.c:167 ../raster/r.lake/main.c:407
#, fuzzy, c-format
msgid "Unable to read color file of raster map <%s>"
-msgstr "Áäõíáìßá áíÜãíùóçò áñ÷åßïõ ÷ñþìáôïò ãéá ôïí ñÜóôåñ ÷Üñôç <%s>"
+msgstr "ÎδÏ
ναμία ανάγνÏÏÎ·Ï Î±ÏÏείοÏ
ÏÏÏμαÏÎ¿Ï Î³Î¹Î± Ïον ÏάÏÏÎµÏ ÏάÏÏη <%s>"
#: ../raster/r.composite/main.c:210
#, c-format
@@ -2448,7 +2448,7 @@
#: ../raster/r.surf.fractal/main.c:39
#, fuzzy, c-format
msgid "Raster map <%s> created."
-msgstr "Ï ÷Üñôçò raster <%s> äåí âñÝèçêå"
+msgstr "Î ÏάÏÏÎ·Ï raster <%s> δεν βÏÎθηκε"
#: ../raster/r.composite/main.c:297
msgid "Creating color table for output raster map..."
@@ -2697,7 +2697,7 @@
#: ../raster/r.in.xyz/main.c:302
#, fuzzy
msgid "Invalid zrange"
-msgstr "ËÜèïò óõíôåôáãìÝíåò"
+msgstr "ÎÎ¬Î¸Î¿Ï ÏÏ
νÏεÏαγμÎνεÏ"
#: ../raster/r.in.xyz/main.c:389
msgid "Unable to calculate percentile without the pth option specified!"
@@ -2719,7 +2719,7 @@
#: ../raster/r.in.xyz/main.c:521
#, fuzzy
msgid "Reading data ..."
-msgstr "×Üñôçò åðáíáöüñôéóçò óå m^3/s"
+msgstr "ΧάÏÏÎ·Ï ÎµÏαναÏÏÏÏιÏÎ·Ï Ïε m^3/s"
#: ../raster/r.in.xyz/main.c:528 ../raster/r.in.poly/poly2rast.c:56
#, c-format
@@ -2836,22 +2836,22 @@
#: ../raster/r.patch/main.c:53
#, fuzzy
msgid "raster, geometry"
-msgstr "ñÜóôåñ 3Ä, voxel"
+msgstr "ÏάÏÏÎµÏ 3Î, voxel"
#: ../raster/r.grow.distance/main.c:150
#, fuzzy
msgid "Generates a raster map containing distances to nearest raster features."
-msgstr "ÌåôáôñÝðåé Ýíá 3Ä åðßðåäï ñÜóôåñ ÷Üñôç óå Ýíá ASCII áñ÷åßï êåéìÝíïõ"
+msgstr "ÎεÏαÏÏÎÏει Îνα 3ΠεÏίÏεδο ÏάÏÏÎµÏ ÏάÏÏη Ïε Îνα ASCII αÏÏείο κειμÎνοÏ
#: ../raster/r.grow.distance/main.c:157
#, fuzzy
msgid "Name for distance output map"
ÏάÏÏÎµÏ ÏάÏÏη"
#: ../raster/r.grow.distance/main.c:162
#, fuzzy
msgid "Name for value output map"
ÏάÏÏÎµÏ ÏάÏÏη"
#: ../raster/r.grow.distance/main.c:168 ../raster/r.grow2/main.c:148
msgid "Metric"
@@ -2877,28 +2877,28 @@
#: ../raster/r.grow.distance/main.c:220
#, fuzzy, c-format
msgid "Unable to create distance map <%s>"
-msgstr "Áäõíáìßá äçìéïõñãßáò raster ÷Üñôç <%s>"
+msgstr "ÎδÏ
ναμία δημιοÏ
ÏÎ³Î¯Î±Ï raster ÏάÏÏη <%s>"
#: ../raster/r.grow.distance/main.c:226
#, fuzzy, c-format
msgid "Unable to create value map <%s>"
+msgstr "ÎδÏ
ναμία δημιοÏ
#: ../raster/r.grow.distance/main.c:232
#, fuzzy, c-format
msgid "Unable to create temporary file <%s>"
-msgstr "Áäõíáìßá äçìéïõñãßáò ðßíáêá <%s>"
+msgstr "ÎδÏ
ναμία δημιοÏ
ÏÎ³Î¯Î±Ï Ïίνακα <%s>"
#: ../raster/r.grow.distance/main.c:307
#, fuzzy
msgid "Writing output raster maps..."
#: ../raster/r.grow.distance/main.c:364 ../raster/r.colors/main.c:390
#: ../raster/r.colors.out/main.c:91 ../display/d.colors/get_info.c:26
#, fuzzy, c-format
msgid "Unable to read color table for raster map <%s>"
+msgstr "ÎδÏ
#: ../raster/r.out.ppm3/main.c:59
msgid ""
@@ -2928,7 +2928,7 @@
#: ../display/d.rast/display.c:21
#, fuzzy, c-format
msgid "Color file for <%s> not available"
-msgstr "×ñþìá"
+msgstr "ΧÏÏμα"
#: ../raster/r.out.ppm3/main.c:176
msgid "Converting ... "
@@ -2941,12 +2941,12 @@
#: ../raster/r.null/null.c:59
#, fuzzy
msgid "Manages NULL-values of given raster map."
ÏάÏÏÎµÏ ÏάÏÏη "
#: ../raster/r.null/null.c:62
#, fuzzy
msgid "Name of raster map for which to edit null file"
-msgstr "âÜóç äåäïìÝíùí, ðßíáêáò éäéïôÞôùí"
+msgstr "βάÏη δεδομÎνÏν, ÏÎ¯Î½Î±ÎºÎ±Ï Î¹Î´Î¹Î¿ÏήÏÏν"
#: ../raster/r.null/null.c:70 ../raster3d/base/r3.null.main.c:66
msgid "List of cell values to be set to NULL"
@@ -3001,18 +3001,18 @@
#: ../raster/r.null/null.c:129
#, fuzzy, c-format
msgid "Raster map <%s> is not in your mapset <%s>"
#: ../raster/r.null/null.c:136
#, fuzzy, c-format
msgid "%s is illegal entry for null"
#: ../raster/r.null/null.c:143
#, fuzzy, c-format
msgid "Raster map <%s> already has a null bitmap file"
msgstr ""
+"ΠδιανÏ
#: ../raster/r.null/null.c:147
#, c-format
@@ -3027,7 +3027,7 @@
#: ../raster/r.null/null.c:157
#, fuzzy, c-format
msgid "<%s> is floating pointing raster map"
-msgstr "¼íïìá õðÜñ÷ïíôùò 3Ä ñÜóôåñ ÷Üñôç"
+msgstr "Îνομα Ï
ÏάÏÏονÏÏÏ 3Î ÏάÏÏÎµÏ ÏάÏÏη"
#: ../raster/r.null/null.c:163 ../raster/r.topidx/file_io.c:21
#: ../raster/r.texture/main.c:240 ../raster/r.out.tiff/r.out.tiff.c:169
@@ -3041,27 +3041,27 @@
#: ../raster/r.null/null.c:175
#, fuzzy, c-format
msgid "Writing new null file for raster map <%s>..."
+msgstr "ÎδÏ
#: ../raster/r.null/null.c:181
#, fuzzy, c-format
msgid "Error writing null row %d"
-msgstr "ÓöÜëìá êáôÜ ôçí áíÜãíùóç ôïõ åýñïõò ãéá [%s]"
+msgstr "ΣÏάλμα καÏά Ïην ανάγνÏÏη ÏοÏ
εÏÏοÏ
Ï Î³Î¹Î± [%s]"
#: ../raster/r.null/null.c:186 ../raster/r.null/null.c:199
#, fuzzy, c-format
msgid "Raster map <%s> modified."
#: ../raster/r.null/null.c:193
#, fuzzy, c-format
msgid "Removing null file for raster map <%s>..."
+msgstr "ÎδÏ
#: ../raster/r.null/null.c:263
#, fuzzy, c-format
msgid "%s: %s: illegal value spec"
#: ../raster/r.null/null.c:265 ../raster3d/base/mask_functions.c:100
#, c-format
@@ -3071,7 +3071,7 @@
#: ../raster/r.null/null.c:332
#, fuzzy, c-format
msgid "Writing new data for raster map <%s>..."
+msgstr "ÎδÏ
ÏάÏÏη raster <%s>"
#: ../raster/r.null/null.c:347 ../raster/r.buffer/write_map.c:78
#: ../raster/r.texture/main.c:356 ../raster/r.texture/main.c:360
@@ -3086,7 +3086,7 @@
#: ../raster/r.sunmask/main.c:115 ../raster/r.horizon/main.c:178
#, fuzzy
msgid "raster, sun position"
#: ../raster/r.sunmask/main.c:116
msgid ""
@@ -3279,12 +3279,12 @@
#: ../raster/r.sunmask/main.c:442
#, fuzzy, c-format
msgid "Option <%s> required"
ÏάÏÏÎµÏ ÏάÏÏη"
#: ../raster/r.sunmask/main.c:459
#, fuzzy, c-format
msgid "Unable to open range file for raster map <%s>"
-msgstr "Áäõíáìßá äéáâÜóìáôïò åýñïõò fp ãéá ôïí ñáóôåñ ÷Üñôç <%s>"
+msgstr "ÎδÏ
ναμία διαβάÏμαÏÎ¿Ï ÎµÏÏοÏ
Ï fp για Ïον ÏαÏÏÎµÏ ÏάÏÏη <%s>"
#: ../raster/r.sunmask/main.c:475
msgid "Calculating shadows from DEM..."
@@ -3306,7 +3306,7 @@
#: ../raster/r.sunmask/g_solposition.c:98
#, fuzzy
msgid "Unable to get projection info of current location"
+msgstr "ÎδÏ
ναμία Ï
γÏνοÏ
#: ../raster/r.sunmask/g_solposition.c:101
msgid "Unable to get projection units of current location"
@@ -3421,7 +3421,7 @@
#: ../raster/wildfire/r.spreadpath/main.c:72
#, fuzzy
msgid "raster, fire"
#: ../raster/wildfire/r.ros/main.c:214
msgid ""
@@ -3646,7 +3646,7 @@
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:4
#: ../imagery/i.ifft/ifftmain.c:83
msgid "Name for output raster map"
ÏάÏÏÎµÏ ÏάÏÏη"
#: ../raster/r.in.gridatb/main.c:67
#, c-format
@@ -3709,7 +3709,7 @@
#: ../raster/r.what.color/main.c:88 ../raster/r.what/main.c:91
#, fuzzy
msgid "raster, querying"
#: ../raster/r.what.color/main.c:89
msgid "Queries colors for a raster map layer."
@@ -3765,7 +3765,7 @@
#: ../raster/r.out.arc/main.c:69
#, fuzzy
msgid "Name for output ARC-GRID map (use out=- for stdout)"
-msgstr "¼íïìá åîáãüìåíïõ äéáíõóìáôéêïý ÷Üñôç"
διανÏ
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη"
#: ../raster/r.out.arc/main.c:76
msgid "Number of decimal places"
@@ -3774,7 +3774,7 @@
#: ../raster/r.out.arc/main.c:80 ../raster/r.out.ascii/main.c:104
#: ../raster3d/r3.out.ascii/main.c:103
msgid "Suppress printing of header information"
-msgstr "Áðïóéþðçóç åêôýðùóçò ðëçñïöïñéþí header"
+msgstr "ÎÏοÏιÏÏηÏη εκÏÏÏÏÏÎ·Ï ÏληÏοÏοÏιÏν header"
#: ../raster/r.out.arc/main.c:86
msgid "List one entry per line instead of full row"
@@ -3849,7 +3849,7 @@
#: ../raster/r.colors/rules.c:136
#, fuzzy, c-format
msgid "bad rule (%s): [%s]"
-msgstr "ÅóöáëìÝíïò êáíüíáò (%s): [%s]"
+msgstr "ÎÏÏαλμÎÎ½Î¿Ï ÎºÎ±Î½ÏÎ½Î±Ï (%s): [%s]"
#: ../raster/r.colors/stats.c:79
msgid "Unable to use logarithmic scaling if range includes zero"
@@ -3879,7 +3879,7 @@
#: ../locale/scriptstrings/v.colors_to_translate.c:9
#, fuzzy
msgid "Type of color table"
-msgstr "Ôýðïò"
+msgstr "ΤÏÏοÏ"
#: ../raster/r.colors/main.c:193 ../raster/r.colors/main.c:207
#: ../raster/r.colors/main.c:225 ../raster/r.colors/main.c:230
@@ -3973,12 +3973,12 @@
#: ../raster/r.colors/main.c:312
#, fuzzy, c-format
msgid "Unable to remove color table of raster map <%s>"
+msgstr "ÎδÏ
#: ../raster/r.colors/main.c:314
#, fuzzy, c-format
msgid "Color table of raster map <%s> not found"
-msgstr "Ï 3Ä ñÜóôåñ ÷Üñôçò <%s> äåí âñÝèçêå"
+msgstr "Î 3Î ÏάÏÏÎµÏ ÏάÏÏÎ·Ï <%s> δεν βÏÎθηκε"
#: ../raster/r.colors/main.c:324
msgid "Color table exists. Exiting."
@@ -4004,12 +4004,12 @@
#: ../raster/r.colors/main.c:380
#, fuzzy, c-format
msgid "Unable to load rules file <%s>"
-msgstr "Áäõíáìßá ðåñéãñáöÞò ðßíáêá <%s>"
+msgstr "ÎδÏ
ναμία ÏεÏιγÏαÏÎ®Ï Ïίνακα <%s>"
#: ../raster/r.colors/main.c:427
#, fuzzy, c-format
msgid "Color table for raster map <%s> set to '%s'"
-msgstr "×ñþìá"
+msgstr "ΧÏÏμα"
#: ../raster/r.in.ascii/main.c:68
msgid "raster, import, conversion"
@@ -4151,7 +4151,7 @@
#: ../raster/r.random.cells/main.c:35
#, fuzzy
msgid "raster, random, cell"
#: ../raster/r.random.cells/main.c:37
msgid "Generates random cell values with spatial dependence."
@@ -4172,13 +4172,13 @@
#: ../raster/r.random.cells/init.c:115 ../raster/r.random.surface/main.c:57
#, fuzzy, c-format
msgid "Generating raster map <%s>..."
-msgstr "ÓöÜëìá áíïßãìáôïò 3Ä ñÜóôåñ ÷Üñôç <%s>"
+msgstr "ΣÏάλμα ανοίγμαÏÎ¿Ï 3Î ÏάÏÏÎµÏ ÏάÏÏη <%s>"
#: ../raster/r.random.cells/init.c:156 ../raster/r.random.surface/init.c:425
#: ../imagery/i.topo.corr/main.c:52
#, fuzzy, c-format
msgid "<%s> is an illegal name"
#: ../raster/r.stats/main.c:105
msgid "Generates area statistics for raster map layers."
@@ -4257,7 +4257,7 @@
#: ../vector/v.db.select/main.c:111
#, fuzzy, c-format
msgid "Unable to open file <%s> for writing"
-msgstr "Áäõíáìßá áíïßãìáôïò áñ÷åßïõ <%s> ãéá åããñáöÞ"
+msgstr "ÎδÏ
<%s> για εγγÏαÏή"
#: ../raster/r.stats/main.c:214
#, c-format
@@ -4293,7 +4293,7 @@
#: ../raster/r.recode/read_rules.c:19
#, fuzzy, c-format
msgid "Unable to read fp range of raster map <%s>"
+msgstr "ÎδÏ
#: ../raster/r.stats/main.c:342
#, c-format
@@ -4303,7 +4303,7 @@
#: ../raster/r.stats/cell_stats.c:51
#, fuzzy, c-format
msgid "Unable to read raster <map %d of %d> row %d"
+msgstr "ÎδÏ
ναμία δημιοÏ
#: ../raster/r.statistics/o_skew.c:97
msgid "o_skew: No data in array"
@@ -4400,7 +4400,7 @@
#: ../raster/r.drain/main.c:145
#, fuzzy
msgid "Name of vector map(s) containing starting point(s)"
-msgstr "¼íïìá ôïõ áñ÷åßïõ ðïõ ðåñéÝ÷åé SQL åíôïëÝò"
+msgstr "Îνομα ÏοÏ
αÏÏείοÏ
ÏοÏ
ÏεÏιÎÏει SQL ενÏολÎÏ"
#: ../raster/r.drain/main.c:150
msgid "Copy input cell values on output"
@@ -4437,7 +4437,7 @@
#: ../raster/r.drain/main.c:191
#, fuzzy, c-format
msgid "Direction raster found <%s>"
#: ../raster/r.drain/main.c:198
#, c-format
@@ -4447,7 +4447,7 @@
#: ../raster/r.drain/main.c:204
#, fuzzy
msgid "Outputting a vector path"
-msgstr "ÊÜèåôïò äéá÷ùñéóôÞò åããñáöþí åîüäïõ"
+msgstr "ÎάθεÏÎ¿Ï Î´Î¹Î±ÏÏÏιÏÏÎ®Ï ÎµÎ³Î³ÏαÏÏν εξÏδοÏ
#: ../raster/r.drain/main.c:209 ../raster/r.flow/io.c:176
#: ../doc/vector/v.example/main.c:96 ../vector/v.in.dxf/main.c:169
@@ -4471,7 +4471,7 @@
#: ../vector/v.generalize/main.c:302
#, fuzzy, c-format
+msgstr "ÎδÏ
ναμία δημιοÏ
ÏÎ³Î¯Î±Ï Î´Î¹Î±Î½Ï
#: ../raster/r.drain/main.c:227
msgid "Specify just one of the -c, -a and -n flags"
@@ -4514,7 +4514,7 @@
#: ../raster/r.info/main.c:77 ../raster3d/base/r3.info.main.c:91
msgid "Print range only"
-msgstr "Åêôýðùóç ìüíï ôïõ åýñïõò"
+msgstr "ÎκÏÏÏÏÏη μÏνο ÏοÏ
εÏÏοÏ
Ï"
#: ../raster/r.info/main.c:82
msgid "Print raster map resolution (NS-res, EW-res) only"
@@ -4707,7 +4707,7 @@
#: ../raster/r.mfilter/main.c:63
#, fuzzy
msgid "Path to filter file"
+msgstr "ÎδÏ
ÏάÏÏη raster <%s>"
#: ../raster/r.mfilter/main.c:72 ../raster/r.mfilter/main.c:96
msgid "Filter"
@@ -4720,7 +4720,7 @@
#: ../raster/r.volume/main.c:57
#, fuzzy
msgid "raster, volume"
#: ../raster/r.volume/main.c:59
msgid ""
@@ -4935,7 +4935,7 @@
#: ../raster/r.gwflow/main.c:55
msgid "The initial piezometric head in [m]"
-msgstr "Ç áñ÷éêÞ ðéåæïìåôñéêÞ óôÞëç óå [m]"
+msgstr "ΠαÏÏική ÏιεζομεÏÏική ÏÏήλη Ïε [m]"
#: ../raster/r.gwflow/main.c:60
msgid "Boundary condition status, 0-inactive, 1-active, 2-dirichlet"
@@ -5074,7 +5074,7 @@
#: ../vector/v.generalize/network.c:94 ../vector/v.generalize/network.c:129
#: ../vector/v.generalize/point.c:121
msgid "Out of memory"
-msgstr "Åêôüò ìíÞìçò"
+msgstr "ÎκÏÏÏ Î¼Î½Î®Î¼Î·Ï"
#: ../raster/r.gwflow/main.c:360
#, c-format
@@ -5088,7 +5088,7 @@
#: ../raster/r.gwflow/main.c:529 ../raster3d/r3.gwflow/main.c:294
msgid "Unable to create and solve the linear equation system"
-msgstr "Áäõíáìßá äçìéïõñãßáò êáé ëýóçò ôïõ ãñáììéêïý óõóôÞìáôïò"
+msgstr "ÎδÏ
ναμία δημιοÏ
ÏÎ³Î¯Î±Ï ÎºÎ±Î¹ λÏÏÎ·Ï ÏοÏ
γÏÎ±Î¼Î¼Î¹ÎºÎ¿Ï ÏÏ
ÏÏήμαÏοÏ"
#: ../raster/r.quant/read_rules.c:49
msgid "Old data range is empty"
@@ -5111,7 +5111,7 @@
#: ../raster/r.quant/main.c:41
#, fuzzy
msgid "raster, quantization"
#: ../raster/r.quant/main.c:43
msgid "Produces the quantization file for a floating-point map."
@@ -5233,7 +5233,7 @@
#: ../raster/simwe/r.sim.water/main.c:216
#, fuzzy
msgid "Output"
-msgstr "ÁðïôÝëåóìá:"
+msgstr "ÎÏοÏÎλεÏμα:"
#: ../raster/simwe/r.sim.sediment/main.c:187
msgid "Output transp.limited erosion-deposition raster map [kg/m2s]"
@@ -5275,7 +5275,7 @@
#: ../vector/v.surf.rst/main.c:383
#, fuzzy
msgid "Parameters"
-msgstr "ÐáñÜìåôñïé"
+msgstr "ΠαÏάμεÏÏοι"
#: ../raster/simwe/r.sim.sediment/main.c:222
#: ../raster/simwe/r.sim.water/main.c:240
@@ -5389,7 +5389,7 @@
#: ../raster/simwe/r.sim.water/main.c:477
#, fuzzy
msgid "You are not outputting any raster maps"
ÏάÏÏÎµÏ ÏάÏÏη"
#: ../raster/simwe/simlib/hydro.c:211
#, c-format
@@ -5466,7 +5466,7 @@
#: ../raster/simwe/simlib/output.c:313 ../raster/simwe/simlib/output.c:321
#, fuzzy, c-format
msgid "FP raster map <%s> not found"
-msgstr "Ï 3Ä ÷Üñôçò raster <%s> äåí âñÝèçêå"
+msgstr "Î 3Î ÏάÏÏÎ·Ï raster <%s> δεν βÏÎθηκε"
#: ../raster/r.region/main.c:56
msgid "Sets the boundary definitions for a raster map."
@@ -5574,12 +5574,12 @@
#: ../raster/r.timestamp/main.c:35
#, fuzzy
msgid "raster, metadata, timestamp"
-msgstr "raster3d, voxel, åéóÜãåôáé"
+msgstr "raster3d, voxel, ειÏάγεÏαι"
#: ../raster/r.timestamp/main.c:36
#, fuzzy
msgid "Modifies a timestamp for a raster map."
-msgstr "ÐáñÜãåé óôáôéóôéêÜ üãêïõ ãéá 3Ä ñÜóôåñ ÷Üñôåò."
+msgstr "ΠαÏάγει ÏÏαÏιÏÏικά ÏγκοÏ
για 3Î ÏάÏÏÎµÏ ÏάÏÏεÏ."
#: ../raster/r.timestamp/main.c:37
msgid "Print/add/remove a timestamp for a raster map."
@@ -5588,7 +5588,7 @@
#: ../raster/r.timestamp/main.c:46
#, fuzzy
msgid "Datetime, datetime1/datetime2, or 'none' to remove"
-msgstr "Datetime, datetime1/datetime2 Þ êáíÝíá"
+msgstr "Datetime, datetime1/datetime2 ή κανÎνα"
#: ../raster/r.timestamp/main.c:47
msgid "Format: '15 jan 1994' (absolute) or '2 years' (relative)"
@@ -5650,7 +5650,7 @@
#: ../raster/r.mapcalc/map.c:442 ../imagery/i.topo.corr/main.c:38
#, fuzzy, c-format
msgid "Unable to open raster map <%s@%s>"
-msgstr "Áäõíáìßá áíïßãìáôïò ôïõ ÷Üñôç raster <%s@%s>"
+msgstr "ÎδÏ
ÏάÏÏη raster <%s@%s>"
#: ../raster/r.mapcalc/map.c:515
msgid "Failed writing raster map row"
@@ -5786,7 +5786,7 @@
#: ../raster/r.sun2/main.c:227 ../raster/r.sun/main.c:173
#, fuzzy
msgid "raster, sun energy"
#: ../raster/r.sun2/main.c:228 ../raster/r.sun/main.c:174
msgid "Solar irradiance and irradiation model."
@@ -5848,12 +5848,12 @@
#: ../raster/r.sun2/main.c:328
#, fuzzy
msgid "Name of input raster map containing latitudes [decimal degrees]"
ÏάÏÏÎµÏ ÏάÏÏη "
#: ../raster/r.sun2/main.c:337
#, fuzzy
msgid "Name of input raster map containing longitudes [decimal degrees]"
ÏάÏÏÎµÏ ÏάÏÏη "
#: ../raster/r.sun2/main.c:346
msgid ""
@@ -5960,12 +5960,12 @@
#: ../raster/r.sun2/main.c:564
#, fuzzy
msgid "Error reading civil time zone value"
εÏÏοÏ
Ï Î³Î¹Î± [%s]"
#: ../raster/r.sun2/main.c:567
#, fuzzy
msgid "Invalid civil time zone value"
-msgstr "ËÜèïò ðáñÜìåôñïé"
+msgstr "ÎÎ¬Î¸Î¿Ï ÏαÏάμεÏÏοι"
#: ../raster/r.sun2/main.c:592 ../raster/r.sun/main.c:408
msgid "insol_time and incidout are incompatible options"
@@ -5974,17 +5974,17 @@
#: ../raster/r.sun2/main.c:597
#, fuzzy
msgid "Error reading time step size"
εÏÏοÏ
Ï Î³Î¹Î± [%s]"
#: ../raster/r.sun2/main.c:599
#, fuzzy
msgid "Invalid time step size"
εÏÏοÏ
Ï Î³Î¹Î± [%s]"
#: ../raster/r.sun2/main.c:603
#, fuzzy
msgid "Error reading horizon step size"
εÏÏοÏ
Ï Î³Î¹Î± [%s]"
#: ../raster/r.sun2/main.c:607
msgid "The horizon step size must be greater than 0."
@@ -6062,7 +6062,7 @@
#: ../raster/r.sun2/main.c:949
#, fuzzy, c-format
msgid "Horizon file no. %d <%s> not found"
-msgstr "Ç óôÞëç <%s> äåí âñÝèçêå"
+msgstr "Î ÏÏήλη <%s> δεν βÏÎθηκε"
#: ../raster/r.out.ascii/main.c:61
msgid "Converts a raster map layer into an ASCII text file."
@@ -6127,12 +6127,12 @@
#: ../raster/r.random.surface/save.c:219 ../imagery/i.pca/support.c:27
#, fuzzy, c-format
msgid "Unable to write color table for raster map <%s>"
+msgstr "ÎδÏ
#: ../raster/r.random.surface/main.c:43
#, fuzzy
msgid "raster, random, surface"
#: ../raster/r.random.surface/main.c:45
msgid "Generates random surface(s) with spatial dependence."
@@ -6141,7 +6141,7 @@
#: ../raster/r.random.surface/init.c:40
#, fuzzy
msgid "Name for output raster map(s)"
ÏάÏÏÎµÏ ÏάÏÏη"
#: ../raster/r.random.surface/init.c:58
msgid "Maximum distance of spatial correlation (value >= 0.0)"
@@ -6180,12 +6180,12 @@
#, fuzzy, c-format
msgid "Rastar map <%s> repeated, maps must be unique"
msgstr ""
+"ΠδιανÏ
#: ../raster/r.random.surface/init.c:183
#, fuzzy
msgid "Output raster map required"
ÏάÏÏÎµÏ ÏάÏÏη"
#: ../raster/r.random.surface/init.c:205
#, c-format
@@ -6293,7 +6293,7 @@
#: ../raster/r.lake/main.c:277
#, fuzzy
-msgstr "G_malloc: åêôüò ìíÞìçò"
+msgstr "G_malloc: εκÏÏÏ Î¼Î½Î®Î¼Î·Ï"
#: ../raster/r.lake/main.c:303
msgid ""
@@ -6405,7 +6405,7 @@
#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:5
#: ../imagery/i.zc/main.c:69
msgid "Name of input raster map"
ÏάÏÏÎµÏ ÏάÏÏη "
#: ../raster/r.water.outlet/main.c:62 ../raster/r.walk/main.c:206
msgid "Name of raster map to contain results"
@@ -6609,7 +6609,7 @@
#: ../raster/r.distance/main.c:38
#, fuzzy
msgid "raster, distance"
#: ../raster/r.distance/main.c:40
msgid "Locates the closest points between objects in two raster maps."
@@ -6730,7 +6730,7 @@
#: ../raster/r.out.gdal/export_band.c:585
#, fuzzy, c-format
msgid "Raster map <%s> range: %g - %g"
#: ../raster/r.out.gdal/export_band.c:555 ../raster/r.out.gdal/main.c:682
#, c-format
@@ -6820,7 +6820,7 @@
#: ../vector/v.in.ogr/main.c:277 ../vector/v.in.ogr/main.c:333
#, c-format
msgid "Required parameter <%s> not set"
-msgstr "Ïé áðáéôïýìåíåò ðáñÜìåôñïé <%s> äåí Ý÷ïõí äïèåß"
+msgstr "Îι αÏαιÏοÏÎ¼ÎµÎ½ÎµÏ ÏαÏάμεÏÏοι <%s> δεν ÎÏοÏ
ν δοθεί"
#: ../raster/r.out.gdal/main.c:243
#, c-format
@@ -6856,7 +6856,7 @@
#: ../raster/r.out.gdal/main.c:352
#, fuzzy, c-format
msgid "Could not read data range of raster <%s>"
+msgstr "ÎδÏ
#: ../raster/r.out.gdal/main.c:409
#, c-format
@@ -6892,7 +6892,7 @@
#: ../raster/r.out.gdal/main.c:515
#, fuzzy
msgid "Raster export aborted."
#: ../raster/r.out.gdal/main.c:492
msgid "Checking GDAL data type and nodata value"
@@ -6901,12 +6901,12 @@
#: ../raster/r.out.gdal/main.c:495
#, fuzzy, c-format
msgid "Checking options for raster map <%s> (band %d)..."
+msgstr "ÎδÏ
#: ../raster/r.out.gdal/main.c:509
#, fuzzy
msgid "Forcing raster export."
-msgstr "ÓöÜëìá êáôÜ ôï êëåßóéìï 3Ä ñÜóôåñ áñ÷åßïõ"
+msgstr "ΣÏάλμα καÏά Ïο κλείÏιμο 3Î ÏάÏÏÎµÏ Î±ÏÏείοÏ
#: ../raster/r.out.gdal/main.c:536
msgid "Output file name not specified"
@@ -7053,7 +7053,7 @@
#: ../vector/v.net.centrality/main.c:220 ../vector/v.random/main.c:168
#, fuzzy, c-format
msgid "Unable to open database <%s> by driver <%s>"
-msgstr "Áäõíáìßá áíïßãìáôïò ôçò âÜóçò äåäïìÝíùí <%s> ìå ôïí ïäçãü <%s>"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï ÏÎ·Ï Î²Î¬ÏÎ·Ï Î´ÎµÎ´Î¿Î¼ÎνÏν <%s> με Ïον Î¿Î´Î·Î³Ï <%s>"
#: ../raster/r.random/random.c:100
msgid "Cannot create new table"
@@ -7101,7 +7101,7 @@
#: ../raster/r.random/main.c:51 ../raster/r.surf.random/main.c:44
#, fuzzy
msgid "raster, random"
#: ../raster/r.random/main.c:53
msgid ""
@@ -7112,7 +7112,7 @@
#: ../raster/r.random/main.c:62 ../raster/r.median/main.c:58
#, fuzzy
msgid "Name of cover raster map"
#: ../raster/r.random/main.c:69
msgid "The number of points to allocate"
@@ -7180,7 +7180,7 @@
#: ../raster/r.topidx/main.c:39
#, fuzzy
msgid "Creates topographic index map from elevation raster map."
ÏομÎÏÏοÏ
#: ../raster/r.topidx/main.c:42
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:3
@@ -7210,17 +7210,17 @@
#: ../raster/r.basins.fill/main.c:55
#, fuzzy
msgid "Generates watershed subbasins raster map."
#: ../raster/r.basins.fill/main.c:59
#, fuzzy
msgid "Name of input coded stream network raster map"
ÏάÏÏÎµÏ ÏάÏÏη "
#: ../raster/r.basins.fill/main.c:63
#, fuzzy
msgid "Name of input thinned ridge network raster map"
ÏάÏÏÎµÏ ÏάÏÏη "
#: ../raster/r.basins.fill/main.c:72
msgid "Number of passes through the dataset"
@@ -7480,14 +7480,14 @@
#: ../imagery/i.ortho.photo/i.photo.rectify/target.c:32
#: ../imagery/i.rectify/target.c:33
msgid "permission denied"
-msgstr "Äåí åðéôñÝðåôáé ç ðñüóâáóç"
+msgstr "Îεν εÏιÏÏÎÏεÏαι η ÏÏÏÏβαÏη"
#: ../raster/r.in.gdal/main.c:690 ../raster/r.proj/main.c:246
#: ../raster/r.proj.seg/main.c:281
msgid "not found"
-msgstr "äåí âñÝèçêå"
+msgstr "δεν βÏÎθηκε"
#: ../raster/r.in.gdal/main.c:989
#, c-format
@@ -7543,12 +7543,12 @@
#: ../raster/r.to.vect/main.c:51
#, fuzzy
msgid "raster, conversion, vectorization"
#: ../raster/r.to.vect/main.c:52
#, fuzzy
msgid "Converts a raster map into a vector map."
#: ../raster/r.to.vect/main.c:65
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:6
@@ -7689,7 +7689,7 @@
#: ../raster/r.topmodel/main.c:122
#, fuzzy
msgid "(i) TOPMODEL Parameters file"
#: ../raster/r.topmodel/main.c:129
msgid "(i) Rainfall and potential evapotranspiration data file"
@@ -7750,7 +7750,7 @@
#: ../raster/r.rescale.eq/main.c:52 ../raster/r.rescale/main.c:50
#, fuzzy
msgid "raster, rescale"
#: ../raster/r.rescale.eq/main.c:54
msgid ""
@@ -8374,7 +8374,7 @@
#: ../raster/r.his/main.c:63
#, fuzzy
msgid "raster, color transformation"
#: ../raster/r.his/main.c:65
msgid ""
@@ -8456,7 +8456,7 @@
#: ../raster/r.thin/main.c:55
#, fuzzy
msgid "raster, thin"
#: ../raster/r.thin/main.c:57
msgid "Thins non-zero cells that denote linear features in a raster map."
@@ -8505,12 +8505,12 @@
#: ../raster/r.to.rast3/main.c:83
#, fuzzy
msgid "Use 3D raster mask (if exists) with output map"
-msgstr "×ñçóéìïðïéÞóôå G3D mask (áí õðÜñ÷åé) ìå åéóáãþìåíï ÷Üñôç"
+msgstr "ΧÏηÏιμοÏοιήÏÏε G3D mask (αν Ï
ÏάÏÏει) με ειÏαγÏμενο ÏάÏÏη"
#: ../raster/r.to.rast3/main.c:117
#, fuzzy
msgid "Could not get raster row"
-msgstr "Áäõíáìßá áíÜãíùóçò ôçò ãñáììÞò (row) ôïõ ÷Üñôç"
+msgstr "ÎδÏ
ναμία ανάγνÏÏÎ·Ï ÏÎ·Ï Î³ÏÎ±Î¼Î¼Î®Ï (row) ÏοÏ
ÏάÏÏη"
#: ../raster/r.to.rast3/main.c:194
msgid "raster, volume, conversion"
@@ -8530,13 +8530,13 @@
"The 2D and 3D region settings are different. I will use the 3D region "
"settings to adjust the 2D region."
msgstr ""
-"Ç 2Ä êáé 3Ä ñõèìßóåéò ðåñéï÷çò åßíáé äéáöïñåôéêÞ, èá ÷ñçóéìïðïéÞóù ôçí 3Ä "
-"ãéá íá ñõèìßóù ôçí 2Ä"
+"Î 2Πκαι 3Î ÏÏ
θμίÏÎµÎ¹Ï ÏεÏιοÏÎ·Ï ÎµÎ¯Î½Î±Î¹ διαÏοÏεÏική, θα ÏÏηÏιμοÏοιήÏÏ Ïην 3Î "
+"για να ÏÏ
θμίÏÏ Ïην 2Î"
#: ../raster/r.to.rast3/main.c:239 ../raster3d/r3.cross.rast/main.c:349
#: ../raster3d/r3.to.rast/main.c:302
msgid "Illegal output file name"
-msgstr "Ìç åðéôñåðôü üíïìá åîáãþìåíïõ ÷Üñôç"
+msgstr "Îη εÏιÏÏεÏÏÏ Ïνομα εξαγÏμενοÏ
ÏάÏÏη"
#: ../raster/r.to.rast3/main.c:260
msgid "Cell file not found"
@@ -8557,16 +8557,16 @@
#: ../raster/r.to.rast3/main.c:309 ../raster/r.to.rast3elev/main.c:483
msgid "Error opening 3d raster map"
-msgstr "ÓöÜëìá êáôÜ ôï Üíïéìá 3Ä ñÜóôåñ ÷Üñôç"
+msgstr "ΣÏάλμα καÏά Ïο άνοιμα 3Î ÏάÏÏÎµÏ ÏάÏÏη"
#: ../raster/r.to.rast3/main.c:341 ../raster/r.to.rast3elev/main.c:546
msgid "Error closing 3d raster map"
#: ../raster/r.to.rast3/main.c:378 ../raster/r.to.rast3elev/main.c:171
#, fuzzy
msgid "Unable to close input map"
-msgstr "Áäõíáìßá êëåéóßìáôïò ôïõ ÷Üñôç input"
+msgstr "ÎδÏ
ÏάÏÏη input"
#: ../raster/r.surf.idw2/main.c:61
msgid "Surface generation program."
@@ -8874,7 +8874,7 @@
#: ../raster/r.carve/main.c:89
#, fuzzy
msgid "Name of input vector map containing stream(s)"
+msgstr "Îνομα ÏοÏ
αÏÏείοÏ
ÏοÏ
#: ../raster/r.carve/main.c:97
msgid "Name for output vector map for adjusted stream points"
@@ -8883,12 +8883,12 @@
#: ../raster/r.carve/main.c:102
#, fuzzy
msgid "Stream width (in meters)"
#: ../raster/r.carve/main.c:103
#, fuzzy
msgid "Default is raster cell width"
#: ../raster/r.carve/main.c:108
msgid "Additional stream depth (in meters)"
@@ -9151,7 +9151,7 @@
#: ../raster/r.li/r.li.renyi/renyi.c:44
#, fuzzy
msgid "Calculates Renyi's diversity index on a raster map"
#: ../raster/r.li/r.li.renyi/renyi.c:46 ../raster/r.li/r.li.pielou/pielou.c:61
#: ../raster/r.li/r.li.shannon/shannon.c:45
@@ -9189,7 +9189,7 @@
#: ../raster/r.li/r.li.daemon/daemon.c:60
#, fuzzy, c-format
msgid "Invalid number of workers: [%s]"
νÏεÏαγμÎνεÏ"
#: ../raster/r.li/r.li.daemon/daemon.c:92
msgid "Error in pipe creation"
@@ -9258,7 +9258,7 @@
#: ../raster/r.li/r.li.daemon/daemon.c:340
#, fuzzy, c-format
msgid "Cannot find configuration file <%s>"
-msgstr "Áäõíáìßá áíïßãìáôïò âÜóçò äåäïìåíùí <%s>"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï Î²Î¬ÏÎ·Ï Î´ÎµÎ´Î¿Î¼ÎµÎ½Ïν <%s>"
#: ../raster/r.li/r.li.daemon/daemon.c:347
#: ../raster/r.li/r.li.daemon/daemon.c:351
@@ -9268,7 +9268,7 @@
#: ../raster/r.li/r.li.daemon/daemon.c:355
#, fuzzy
msgid "Unable to parse configuration file (sampling frame)"
-msgstr "Áäõíáìßá áíïßãìáôïò ðñïóùñéíïý áñ÷åßïõ"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï ÏÏοÏÏÏÎ¹Î½Î¿Ï Î±ÏÏείοÏ
#: ../raster/r.li/r.li.daemon/daemon.c:367
msgid "Cannot read raster header file"
@@ -9281,7 +9281,7 @@
#: ../raster/r.li/r.li.daemon/daemon.c:540
#, fuzzy
msgid "Unable to parse configuration file (sample area)"
+msgstr "ÎδÏ
#: ../raster/r.li/r.li.daemon/daemon.c:575
msgid "Too many units to place"
@@ -9290,7 +9290,7 @@
#: ../raster/r.li/r.li.daemon/daemon.c:644
#, fuzzy
msgid "Too many stratified random sample for raster map"
#: ../raster/r.li/r.li.daemon/daemon.c:678
msgid "Illegal areas disposition"
@@ -9392,7 +9392,7 @@
#: ../raster/r.li/r.li.pielou/pielou.c:59
#, fuzzy
msgid "Calculates Pielou's diversity index on a raster map"
#: ../raster/r.li/r.li.padcv/padcv.c:43
msgid "Calculates coefficient of variation of patch area on a raster map"
@@ -9454,7 +9454,7 @@
#: ../raster/r.what/main.c:131
#, fuzzy
msgid "Output header row"
ÏάÏÏÎµÏ ÏάÏÏη"
#: ../raster/r.what/main.c:135
msgid "Show the category labels of the grid cell(s)"
@@ -9501,7 +9501,7 @@
#: ../raster3d/r3.out.ascii/main.c:107 ../raster3d/r3.to.rast/main.c:90
#, fuzzy
msgid "Use 3D raster mask (if exists) with input map"
#: ../raster/r.to.rast3elev/main.c:276
msgid "Could not get raster row from input map"
@@ -9514,7 +9514,7 @@
#: ../raster/r.to.rast3elev/main.c:326 ../raster/r.to.rast3elev/main.c:360
#, fuzzy
msgid "Error writing 3D raster double data"
εÏÏοÏ
Ï Î³Î¹Î± [%s]"
#: ../raster/r.to.rast3elev/main.c:400
msgid "raster, raster3d, voxel, conversion"
@@ -9667,7 +9667,7 @@
#: ../raster/r.horizon/main.c:1133
#, fuzzy, c-format
msgid "Calculating map %01d of %01d (angle %lf, raster map <%s>)"
+msgstr "ÎδÏ
#: ../raster/r.median/main.c:48
msgid ""
@@ -9678,7 +9678,7 @@
#: ../raster/r.median/main.c:54
#, fuzzy
msgid "Name of base raster map"
-msgstr "¼íïìá ÷Üñôç õðïâÜèñïõ ñÜóôåñ"
+msgstr "Îνομα ÏάÏÏη Ï
ÏοβάθÏοÏ
ÏάÏÏεÏ"
#: ../raster/r.median/main.c:71
#, c-format
@@ -9698,7 +9698,7 @@
#: ../raster/r.compress/main.c:64
#, fuzzy
msgid "raster, map management"
#: ../raster/r.compress/main.c:65
msgid "Compresses and decompresses raster maps."
@@ -9772,17 +9772,17 @@
#: ../raster/r.colors.out/main.c:63
#, fuzzy
msgid "raster, export, color table"
-msgstr "äéÜíõóìá, ðßíáêáò ÷ñùìÜôùí"
+msgstr "διάνÏ
Ïμα, ÏÎ¯Î½Î±ÎºÎ±Ï ÏÏÏμάÏÏν"
#: ../raster/r.colors.out/main.c:65
#, fuzzy
msgid "Exports the color table associated with a raster map layer."
+msgstr "ÎδÏ
#: ../raster/r.colors.out/main.c:71
#, fuzzy
msgid "Path to output rules file"
+msgstr "ÎδÏ
ÏάÏÏη raster <%s>"
#: ../raster/r.colors.out/main.c:72
msgid "\"-\" to write to stdout"
@@ -9791,7 +9791,7 @@
#: ../raster/r.colors.out/main.c:77
#, fuzzy
msgid "Output values as percentages"
-msgstr "ÅîáãùãÞ ïíüìáôïò ðßíáêá"
+msgstr "ÎξαγÏγή ονÏμαÏÎ¿Ï Ïίνακα"
#: ../raster/r.proj/bordwalk.c:182 ../raster/r.proj.seg/bordwalk.c:182
msgid "Input raster map is outside current region"
@@ -9800,7 +9800,7 @@
#: ../raster/r.proj/main.c:130 ../raster/r.proj.seg/main.c:139
#, fuzzy
msgid "raster, projection, transformation"
#: ../raster/r.proj/main.c:132 ../raster/r.proj.seg/main.c:141
msgid "Re-projects a raster map from one location to the current location."
@@ -9822,12 +9822,12 @@
#: ../raster/r.proj/main.c:143 ../raster/r.proj.seg/main.c:152
#, fuzzy
msgid "Location containing input raster map"
-msgstr "Áäõíáìßá êëåéóßìáôïò ôïõ ÷Üñôç åéóáãùãÞò"
+msgstr "ÎδÏ
ÏάÏÏη ειÏαγÏγήÏ"
#: ../raster/r.proj/main.c:151 ../raster/r.proj.seg/main.c:160
#, fuzzy
msgid "Mapset containing input raster map"
ÏάÏÏÎµÏ ÏάÏÏη "
#: ../raster/r.proj/main.c:160 ../raster/r.proj.seg/main.c:169
#: ../vector/v.proj/main.c:93
@@ -9933,47 +9933,47 @@
#: ../raster/r.proj.seg/main.c:440 ../raster/r.proj.seg/main.c:451
#, c-format
msgid "Rows: %d (%d)"
-msgstr "ÃñáììÝò: %d (%d)"
+msgstr "ÎÏαμμÎÏ: %d (%d)"
#: ../raster/r.proj/main.c:373 ../raster/r.proj/main.c:384
#: ../raster/r.proj.seg/main.c:441 ../raster/r.proj.seg/main.c:452
#, c-format
msgid "North: %f (%f)"
-msgstr "Âüñåéá: %f (%f)"
+msgstr "ÎÏÏεια: %f (%f)"
#: ../raster/r.proj/main.c:374 ../raster/r.proj/main.c:385
#: ../raster/r.proj.seg/main.c:442 ../raster/r.proj.seg/main.c:453
#, c-format
msgid "South: %f (%f)"
-msgstr "Íüôéá: %f (%f)"
+msgstr "ÎÏÏια: %f (%f)"
#: ../raster/r.proj/main.c:375 ../raster/r.proj/main.c:386
#: ../raster/r.proj.seg/main.c:443 ../raster/r.proj.seg/main.c:454
#, c-format
msgid "West: %f (%f)"
-msgstr "ÄõôéêÜ: %f (%f)"
+msgstr "ÎÏ
Ïικά: %f (%f)"
#: ../raster/r.proj/main.c:376 ../raster/r.proj/main.c:387
#: ../raster/r.proj.seg/main.c:444 ../raster/r.proj.seg/main.c:455
#, c-format
msgid "East: %f (%f)"
-msgstr "ÁíáôïëéêÜ: %f (%f)"
+msgstr "ÎναÏολικά: %f (%f)"
#: ../raster/r.proj/main.c:377 ../raster/r.proj/main.c:388
#: ../raster/r.proj.seg/main.c:445 ../raster/r.proj.seg/main.c:456
#, c-format
msgid "EW-res: %f"
-msgstr "ÁÄ-res: %f"
+msgstr "ÎÎ-res: %f"
#: ../raster/r.proj/main.c:378 ../raster/r.proj/main.c:389
#: ../raster/r.proj.seg/main.c:446 ../raster/r.proj.seg/main.c:457
#, c-format
msgid "NS-res: %f"
-msgstr "ÂÍ-res: %f"
#: ../raster/r.proj/main.c:381 ../raster/r.proj.seg/main.c:449
msgid "Output:"
#: ../raster/r.proj/main.c:417 ../raster/r.proj.seg/main.c:485
msgid "Projecting..."
@@ -10070,7 +10070,7 @@
#: ../raster/r.profile/main.c:53
#, fuzzy
msgid "raster, profile"
#: ../raster/r.profile/main.c:55
msgid "Outputs the raster map layer values lying on user-defined line(s)."
@@ -10127,7 +10127,7 @@
#: ../raster/r.profile/main.c:183
#, fuzzy
msgid " [RGB Color]"
-msgstr "×ñþìá"
+msgstr "ΧÏÏμα"
#: ../raster/r.profile/main.c:193
#, c-format
@@ -10185,7 +10185,7 @@
#: ../raster/r.slope.aspect/main.c:155
#, fuzzy
msgid "raster, terrain"
#: ../raster/r.slope.aspect/main.c:156
msgid ""
@@ -10213,7 +10213,7 @@
#: ../vector/v.surf.rst/main.c:280 ../vector/v.surf.rst/main.c:287
#, fuzzy
msgid "Outputs"
#: ../raster/r.slope.aspect/main.c:171
msgid "Name for output aspect raster map"
@@ -10226,7 +10226,7 @@
#: ../raster/r.slope.aspect/main.c:190
#, fuzzy
msgid "Type of output aspect and slope maps"
-msgstr "Ôýðïò"
+msgstr "ΤÏÏοÏ"
#: ../raster/r.slope.aspect/main.c:197
msgid "Name for output profile curvature raster map"
@@ -10433,7 +10433,7 @@
#: ../vector/v.in.ogr/main.c:801
#, fuzzy, c-format
msgid "Unable to create index for table <%s>, key <%s>"
-msgstr "Áäõíáìßá äçìéïõñãßáò êáôáëüãïõ ãéá ôïí ðßíáêá <%s>, êëåéäß <%s>"
+msgstr "ÎδÏ
ναμία δημιοÏ
ÏÎ³Î¯Î±Ï ÎºÎ±ÏαλÏγοÏ
για Ïον Ïίνακα <%s>, κλειδί <%s>"
#: ../raster/r.contour/main.c:215 ../vector/v.extract/main.c:428
#: ../vector/v.select/main.c:480 ../vector/v.generalize/misc.c:127
@@ -10672,7 +10672,7 @@
#: ../raster/r.external/main.c:496
#, fuzzy, c-format
msgid "Link to raster map <%s> created"
#: ../raster/r.external/main.c:522
msgid "Link GDAL supported raster file to a binary raster map layer."
@@ -10689,7 +10689,7 @@
#: ../raster/r.external/main.c:543
#, fuzzy
msgid "Band to select (default: all)"
-msgstr "Áäýíáôç ç åðéëïãÞ äåäïìÝíùí: \n"
+msgstr "ÎδÏναÏη η εÏιλογή δεδομÎνÏν: \n"
#: ../raster/r.external/main.c:566
msgid "Require exact range"
@@ -10711,17 +10711,17 @@
#, fuzzy, c-format
msgid "Imagery group <%s> already exists and will be overwritten."
msgstr ""
-"Ï äéáíõóìáôéêüò ÷Üñôçò <%s> õðÜñ÷åé Þäç êáé èá áíôéêáôáóôáèåß (overwritten)"
+"ΠδιανÏ
ÏμαÏικÏÏ ÏάÏÏÎ·Ï <%s> Ï
ÏάÏÏει ήδη και θα ανÏικαÏαÏÏαθεί (overwritten)"
#: ../raster/r.external/main.c:677
#, fuzzy, c-format
msgid "Imagery group <%s> created"
#: ../raster/r.out.png/r.out.png.c:110
#, fuzzy
msgid "raster, export, png"
#: ../raster/r.out.png/r.out.png.c:112
msgid "Export GRASS raster as non-georeferenced PNG image."
@@ -10734,7 +10734,7 @@
#: ../raster/r.out.png/r.out.png.c:127
#, fuzzy
msgid "Compression level of PNG file"
-msgstr "¼íïìá áñ÷åßïõ PNG."
+msgstr "Îνομα αÏÏείοÏ
PNG."
#: ../raster/r.out.png/r.out.png.c:128
msgid "(0 = none, 1 = fastest, 9 = best)"
@@ -10755,12 +10755,12 @@
#: ../display/d.rast/display.c:32
#, c-format
msgid "[%s]: No such color"
-msgstr "[%s]: Äåí õðÜñ÷åé ôÝôïéï ÷ñþìá"
+msgstr "[%s]: Îεν Ï
ÏάÏÏει ÏÎÏοιο ÏÏÏμα"
#: ../raster/r.out.png/r.out.png.c:285
#, fuzzy, c-format
msgid "Converting <%s>..."
#: ../raster/r.out.png/r.out.png.c:300 ../raster/r.univar2/r.univar_main.c:183
#, c-format
@@ -10782,7 +10782,7 @@
#: ../raster/r.out.png/r.out.png.c:459
#, fuzzy
msgid "Unable to open world file for writing"
+msgstr "ÎδÏ
<%s> για εγγÏαÏή"
#: ../raster/r.out.tiff/r.out.tiff.c:101
msgid ""
@@ -10822,7 +10822,7 @@
msgid ""
"Color map for palette must have less than 256 colors for the available range "
"of data"
-msgstr "×ñþìá"
+msgstr "ΧÏÏμα"
#: ../raster/r.out.tiff/r.out.tiff.c:198
#, c-format
@@ -10857,12 +10857,12 @@
#: ../raster/r.in.bin/main.c:510
#, fuzzy
msgid "Error reading data"
εÏÏοÏ
Ï Î³Î¹Î± [%s]"
#: ../raster/r.in.bin/main.c:236
#, fuzzy
msgid "Import a binary raster file into a GRASS raster map."
-msgstr "Áäõíáìßá áíÜãíùóçò äéáíõóìáôéêïý ÷Üñôç"
+msgstr "ÎδÏ
ναμία ανάγνÏÏÎ·Ï Î´Î¹Î±Î½Ï
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη"
#: ../raster/r.in.bin/main.c:241
msgid "Import as floating-point data (default: integer)"
@@ -10902,12 +10902,12 @@
#: ../raster/r.in.bin/main.c:284 ../raster/r.out.bin/main.c:310
#, fuzzy
msgid "Number of bytes per cell"
-msgstr "Íïýìåñï ôùí õðïðåñéï÷þí ãéá óõëëïãÞ óôáôéóôéêþí áðü áõôÜ"
+msgstr "ÎοÏμεÏο ÏÏν Ï
ÏοÏεÏιοÏÏν για ÏÏ
λλογή ÏÏαÏιÏÏικÏν αÏÏ Î±Ï
Ïά"
#: ../raster/r.in.bin/main.c:292 ../raster/r.out.bin/main.c:317
#, fuzzy
msgid "Output byte order"
ÏάÏÏÎµÏ ÏάÏÏη"
#: ../raster/r.in.bin/main.c:300
msgid "Northern limit of geographic region (outer edge)"
@@ -10998,7 +10998,7 @@
#: ../raster/r.in.bin/main.c:445
#, fuzzy, c-format
msgid "Unable to open <%s>"
-msgstr "Áäõíáìßá áíôéãñáöÞò ðßíáêá <%s>"
+msgstr "ÎδÏ
ναμία ανÏιγÏαÏÎ®Ï Ïίνακα <%s>"
#: ../raster/r.in.bin/main.c:464
#, c-format
@@ -11098,7 +11098,7 @@
#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:8
#, fuzzy
msgid "Name for output file"
-msgstr "¼íïìá áñ÷åßïõ åîáãùãÞò"
εξαγÏγήÏ"
#: ../raster/r.out.mpeg/main.c:416
msgid "Quality factor (1 = highest quality, lowest compression)"
@@ -11129,7 +11129,7 @@
#: ../raster/r.recode/read_rules.c:24
#, fuzzy, c-format
msgid "Data range of raster map <%s> is empty"
+msgstr "ÎδÏ
#: ../raster/r.recode/read_rules.c:31
#, c-format
@@ -11139,17 +11139,17 @@
#: ../raster/r.recode/read_rules.c:36
#, fuzzy, c-format
msgid "Unable to read range of raster map <%s>"
+msgstr "ÎδÏ
#: ../raster/r.recode/read_rules.c:41
#, fuzzy, c-format
msgid "Integer data range of raster map <%s> is empty"
+msgstr "ÎδÏ
#: ../raster/r.recode/read_rules.c:44
#, fuzzy, c-format
msgid "Integer data range of raster mao <%s> is %d to %d"
+msgstr "ÎδÏ
#: ../raster/r.recode/read_rules.c:63
msgid "Enter the rule or 'help' for the format description"
@@ -11187,7 +11187,7 @@
#: ../raster/r.recode/main.c:41
#, fuzzy
msgid "raster, recode category"
#: ../raster/r.recode/main.c:42
msgid "Recodes categorical raster maps."
@@ -11196,7 +11196,7 @@
#: ../raster/r.recode/main.c:45
#, fuzzy
msgid "Name of raster map to be recoded"
-msgstr "Ascii ñÜóôåñ ÷Üñôçò ðïõ èá åéóá÷èåß"
+msgstr "Ascii ÏάÏÏÎµÏ ÏάÏÏÎ·Ï ÏοÏ
θα ειÏαÏθεί"
#: ../raster/r.recode/main.c:52
msgid "File containing recode rules"
@@ -11209,7 +11209,7 @@
#: ../raster/r.recode/main.c:64
#, fuzzy
msgid "Align the current region to the input raster map"
+msgstr "ÎδÏ
ÏάÏÏη ειÏαγÏγήÏ"
#: ../raster/r.recode/main.c:68
msgid "Force output to 'double' raster map type (DCELL)"
@@ -11367,7 +11367,7 @@
#: ../raster/r.univar2/r3.univar_main.c:100 ../raster3d/r3.stats/main.c:568
#, fuzzy
msgid "raster3d, voxel, statistics"
#: ../raster/r.univar2/r3.univar_main.c:102
msgid ""
@@ -11385,7 +11385,7 @@
#: ../raster3d/r3.to.rast/main.c:228
#, fuzzy, c-format
msgid "3D raster map <%s> not found"
#: ../raster/r.univar2/r3.univar_main.c:154
#: ../raster/r.univar2/r3.univar_main.c:193 ../raster3d/base/r3.mask.main.c:84
@@ -11396,12 +11396,12 @@
#: ../raster3d/r3.out.ascii/main.c:268
#, fuzzy, c-format
msgid "Unable to open 3D raster map <%s>"
+msgstr "ÎδÏ
ÏάÏÏη raster <%s>"
#: ../raster/r.univar2/r3.univar_main.c:163
#, fuzzy
msgid "Unable to load 3D raster range"
+msgstr "ÎδÏ
ναμία δημιοÏ
#: ../raster/r.univar2/r.univar_main.c:37
msgid "Raster map used for zoning, must be of type CELL"
@@ -11437,7 +11437,7 @@
#: ../raster/r.out.bin/main.c:280
#, fuzzy
msgid "Exports a GRASS raster map to a binary array."
-msgstr "ÅîáãùãÞ ôïõ GRASS 3Ä ñÜóôåñ ÷Üñôç óå 3 äéÜóôáôï Vis5D áñ÷åßï"
+msgstr "ÎξαγÏγή ÏοÏ
GRASS 3Î ÏάÏÏÎµÏ ÏάÏÏη Ïε 3 διάÏÏαÏο Vis5D αÏÏείο"
#: ../raster/r.out.bin/main.c:296
msgid "Name for output binary map (use output=- for stdout)"
@@ -11450,7 +11450,7 @@
#: ../raster/r.out.bin/main.c:322
#, fuzzy
msgid "Generate integer output"
#: ../raster/r.out.bin/main.c:326
msgid "Generate floating-point output"
@@ -11571,7 +11571,7 @@
#: ../imagery/i.rectify/readcell.c:55
#, fuzzy
msgid "Unable to open temporary file"
+msgstr "ÎδÏ
#: ../raster/r.proj.seg/readcell.c:81
msgid "Error reading input"
@@ -11668,7 +11668,7 @@
#: ../raster/r.reclass/main.c:49
#, fuzzy
msgid "raster, reclassification"
#: ../raster/r.reclass/main.c:50
msgid "Reclassify raster map based on category values."
@@ -11705,17 +11705,17 @@
#: ../raster/r.reclass/main.c:108
#, fuzzy, c-format
msgid "FCELL: Data range is %.7g to %.7g\n"
+msgstr "ÎδÏ
#: ../raster/r.reclass/main.c:111
#, fuzzy, c-format
msgid "DCELL: Data range is %.15g to %.15g\n"
+msgstr "ÎδÏ
#: ../raster/r.reclass/main.c:114
#, fuzzy, c-format
msgid "CELL: Data range is %ld to %ld\n"
+msgstr "ÎδÏ
#: ../raster/r.reclass/main.c:122
#, c-format
@@ -11774,12 +11774,12 @@
#: ../raster/r.surf.random/main.c:65
#, fuzzy
msgid "Create an integer raster map"
ÏάÏÏÎµÏ ÏάÏÏη "
#: ../raster/r.surf.random/main.c:79
#, fuzzy, c-format
msgid "Raster map <%s> generated."
#: ../raster/r.surf.area/main.c:87
msgid "Surface area estimation for rasters."
@@ -11993,7 +11993,7 @@
#: ../raster/r.los/main.c:82
#, fuzzy
msgid "raster, viewshed"
#: ../raster/r.los/main.c:83
msgid "Line-of-sight raster analysis program."
@@ -12278,7 +12278,7 @@
#: ../general/g.message/main.c:51 ../general/g.message/main.c:56
#, fuzzy
msgid "Type"
-msgstr "¶ãíùóôïò ôýðïò"
+msgstr "ÎγνÏÏÏÎ¿Ï ÏÏÏοÏ"
#: ../general/g.message/main.c:42
msgid "Print message as warning"
@@ -12324,7 +12324,7 @@
#: ../general/g.message/main.c:104
#, fuzzy
msgid "Unable to parse input message"
+msgstr "ÎδÏ
ναμία κλειÏίμαÏÎ¿Ï ÏοÏ
ÏάÏÏη input"
#: ../general/g.access/main.c:37 ../general/g.mlist/main.c:65
#: ../general/g.ask/main.c:40 ../general/g.findetc/main.c:28
@@ -12362,7 +12362,7 @@
#: ../general/g.access/set_perms.c:26
#, fuzzy
msgid "Unable to change mapset permissions"
+msgstr "ÎδÏ
ναμία δημιοÏ
#: ../general/g.access/exp_perms.c:11 ../general/g.access/exp_perms.c:29
msgid "have"
@@ -12408,7 +12408,7 @@
#: ../general/g.proj/datumtrans.c:47
#, fuzzy, c-format
msgid "Invalid datum code <%s>"
νÏεÏαγμÎνεÏ"
#: ../general/g.proj/datumtrans.c:77
#, c-format
@@ -12475,12 +12475,12 @@
#: ../general/g.proj/main.c:136
#, fuzzy
msgid "Name of ASCII file containing a WKT projection description"
-msgstr "¼íïìá ôïõ áñ÷åßïõ ðïõ ðåñéÝ÷åé õðïãñáöÝò (signatures)"
+msgstr "Îνομα ÏοÏ
αÏÏείοÏ
ÏοÏ
ÏεÏιÎÏει Ï
ÏογÏαÏÎÏ (signatures)"
#: ../general/g.proj/main.c:138 ../general/g.proj/main.c:147
#, fuzzy
msgid "'-' for standard input"
-msgstr "¼íïìá åéóáãþìåíïõ äéáíõóìáôéêïý ÷Üñôç "
διανÏ
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη "
#: ../general/g.proj/main.c:146
msgid "PROJ.4 projection description"
@@ -12520,7 +12520,7 @@
#: ../general/g.proj/main.c:191
#, fuzzy
msgid "Create new projection files (modifies current location)"
-msgstr "Áäõíáìßá õðïëïãéóìïý êÝíôñùí ðïëõãþíïõ ãéá ôçí åðéöÜíåéá %d"
+msgstr "ÎδÏ
ναμία Ï
ÏολογιÏÎ¼Î¿Ï ÎºÎνÏÏÏν ÏολÏ
γÏνοÏ
για Ïην εÏιÏάνεια %d"
#: ../general/g.proj/main.c:199 ../general/g.mapset/main.c:82
#: ../locale/scriptstrings/r.mask_to_translate.c:4
@@ -12560,7 +12560,7 @@
#: ../general/g.proj/create.c:17
#, fuzzy, c-format
msgid "Unable to create location <%s>: %s"
+msgstr "ÎδÏ
ναμία δημιοÏ
ÏÎ³Î¯Î±Ï Î´Î¹Î±Î½Ï
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη <%s>"
#: ../general/g.proj/create.c:20
#, c-format
@@ -12595,7 +12595,7 @@
#: ../general/g.proj/create.c:67
#, fuzzy
msgid "Projection information updated"
#: ../general/g.proj/input.c:91
msgid "Error reading WKT projection description"
@@ -12604,7 +12604,7 @@
#: ../general/g.proj/input.c:98
#, fuzzy, c-format
msgid "Unable to open file '%s' for reading"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï Î±ÏÏείοÏ
<%s> για εγγÏαÏή"
#: ../general/g.proj/input.c:143
msgid "Can't parse PROJ.4-style parameter string"
@@ -12727,7 +12727,7 @@
#: ../general/g.gui/main.c:44
#, fuzzy
msgid "Default value: GRASS_GUI if defined, otherwise wxpython"
#: ../general/g.gui/main.c:45
msgid ""
@@ -12950,19 +12950,19 @@
#: ../general/g.mapsets/main.c:78
#, fuzzy
msgid "Name(s) of existing mapset(s) to add to search path"
+msgstr "Îνομα Ï
#: ../general/g.mapsets/main.c:87
#, fuzzy
msgid "Name(s) of existing mapset(s) to remove from search path"
+msgstr "Îνομα Ï
#: ../general/g.mapsets/main.c:91
#: ../locale/scriptstrings/m.proj_to_translate.c:7
#: ../locale/scriptstrings/v.in.lines_to_translate.c:6
#: ../locale/scriptstrings/r.out.xyz_to_translate.c:5
msgid "Field separator"
-msgstr "Äéá÷ùñéóôÞò ðåäßùí"
+msgstr "ÎιαÏÏÏιÏÏÎ®Ï ÏεδίÏν"
#: ../general/g.mapsets/main.c:92
msgid "Special characters: newline, space, comma, tab"
@@ -13449,7 +13449,7 @@
#: ../vector/v.lrs/v.lrs.label/main.c:228
#, fuzzy
msgid "Background color"
-msgstr "×ñþìá öüíôïõ"
+msgstr "ΧÏÏμα ÏÏνÏοÏ
#: ../general/g.gisenv/main.c:40
msgid "Outputs and modifies the user's current GRASS variable settings."
@@ -13487,7 +13487,7 @@
#: ../general/g.transform/main.c:101
#, fuzzy, c-format
msgid "Error conducting transform (%d)"
εÏÏοÏ
Ï Î³Î¹Î± [%s]"
#: ../general/g.transform/main.c:199
msgid "Poorly placed control points"
@@ -13508,7 +13508,7 @@
#: ../general/g.transform/main.c:300
#, fuzzy, c-format
msgid "Invalid coordinates: [%s]"
νÏεÏαγμÎνεÏ"
#: ../general/g.transform/main.c:320
msgid "general, transformation, GCP"
@@ -13574,61 +13574,61 @@
#: ../vector/v.db.connect/main.c:278
#, c-format
msgid "Unable to start driver <%s>"
-msgstr "Áäõíáìßá åêêßíçóçò ôïõ ïäçãïý <%s>"
+msgstr "ÎδÏ
ναμία εκκίνηÏÎ·Ï ÏοÏ
Î¿Î´Î·Î³Î¿Ï <%s>"
#: ../db/base/databases.c:56
msgid "Unable to list databases"
-msgstr "Áäõíáìßá ëßóôáò âÜóåùí äåäïìÝíùí"
+msgstr "ÎδÏ
ναμία λίÏÏÎ±Ï Î²Î¬ÏεÏν δεδομÎνÏν"
#: ../db/base/databases.c:85
msgid "Location name"
-msgstr "¼íïìá ôïðïèåóßá"
+msgstr "Îνομα ÏοÏοθεÏία"
#: ../db/base/databases.c:90 ../db/base/dropdb.c:71 ../db/base/droptable.c:78
#: ../db/base/createdb.c:71
msgid "database, SQL"
-msgstr "ÂÜóç äåäïìÝíùí, SQL"
+msgstr "ÎάÏη δεδομÎνÏν, SQL"
#: ../db/base/databases.c:92
msgid "List all databases for a given driver and location."
msgstr ""
-"Äßíåé ôç ëßóôá üëùí ôùí âÜóåùí äåäïìÝíùí ãéá Ýíá äùóìÝíï ïäçãü êáé ôïðïèåóßá"
+"Îίνει Ïη λίÏÏα ÏλÏν ÏÏν βάÏεÏν δεδομÎνÏν για Îνα δÏÏμÎνο Î¿Î´Î·Î³Ï ÎºÎ±Î¹ ÏοÏοθεÏία"
#: ../db/base/dropdb.c:72
msgid "Removes a database."
-msgstr "Áöáéñåß ìßá âÜóç äåäïìÝíùí"
+msgstr "ÎÏαιÏεί μία βάÏη δεδομÎνÏν"
#: ../db/base/droptable.c:79
msgid "Removes a table from database."
-msgstr "Áöáéñåß Ýíá ðßíáêá áðü ôçí âÜóç äåäïìÝíùí"
+msgstr "ÎÏαιÏεί Îνα Ïίνακα αÏÏ Ïην βάÏη δεδομÎνÏν"
#: ../db/base/createdb.c:72
msgid "Creates an empty database."
-msgstr "Äçìéïõñãåß ìßá êåíÞ âÜóç äåäïìÝíùí"
+msgstr "ÎημιοÏ
Ïγεί μία κενή βάÏη δεδομÎνÏν"
#: ../db/base/execute.c:68 ../db/base/tables.c:51 ../db/base/select.c:81
#: ../db/base/describe.c:62 ../display/d.thematic.area/main.c:235
#: ../display/d.vect/main.c:475 ../vector/v.convert/att.c:73
#, c-format
msgid "Unable to open database <%s>"
+msgstr "ÎδÏ
#: ../db/base/execute.c:78 ../db/base/execute.c:86
#, c-format
msgid "Error while executing: '%s'"
-msgstr "ÓöÜëìá êáôÜ ôçí åêôÝëåóç: '%s'"
+msgstr "ΣÏάλμα καÏά Ïην εκÏÎλεÏη: '%s'"
#: ../db/base/execute.c:112 ../db/base/copy.c:37 ../db/base/select.c:263
msgid "database, attribute table, SQL"
-msgstr "ÂÜóç äåäïìÝíùí, ðßíáêáò éäéïôÞôùí, SQL"
+msgstr "ÎάÏη δεδομÎνÏν, ÏÎ¯Î½Î±ÎºÎ±Ï Î¹Î´Î¹Î¿ÏήÏÏν, SQL"
#: ../db/base/execute.c:113
msgid "Executes any SQL statement."
-msgstr "Åêôåëåß ïðïéáäÞðïôå SQL åíôïëÞ"
+msgstr "ÎκÏελεί οÏοιαδήÏοÏε SQL ενÏολή"
#: ../db/base/execute.c:117
msgid "Name of file containing SQL statements"
+msgstr "Îνομα ÏοÏ
αÏÏείοÏ
ÏοÏ
#: ../db/base/execute.c:118 ../vector/v.to.db/parse.c:47
#: ../vector/v.to.db/parse.c:99
@@ -13638,7 +13638,7 @@
#: ../db/base/execute.c:119
#, fuzzy
msgid "If not given or '-' read from standard input"
διανÏ
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη "
#: ../db/base/execute.c:123 ../db/base/execute.c:128
#: ../vector/v.in.db/main.c:63 ../vector/v.in.db/main.c:67
@@ -13647,15 +13647,15 @@
#: ../db/base/execute.c:134
msgid "Ignore SQL errors and continue"
-msgstr "Áãíïåß ôá SQL ëÜèç êáé óõíå÷ßæåé"
+msgstr "Îγνοεί Ïα SQL λάθη και ÏÏ
νεÏίζει"
#: ../db/base/tables.c:87
msgid "Print tables and exit"
-msgstr "Ôõðþíåé ôïí ðßíáêá êáé êëåéíåé (Ýîïäïò)"
+msgstr "ΤÏ
ÏÏνει Ïον Ïίνακα και κλεινει (ÎξοδοÏ)"
#: ../db/base/tables.c:91
msgid "System tables instead of user tables"
-msgstr "Ðßíáêåò óõóôÞìáôïò áíôß ðßíáêåò ÷ñçóôþí"
+msgstr "Î Î¯Î½Î±ÎºÎµÏ ÏÏ
ÏÏήμαÏÎ¿Ï Î±Î½Ïί ÏÎ¯Î½Î±ÎºÎµÏ ÏÏηÏÏÏν"
#: ../db/base/tables.c:95 ../db/base/columns.c:98 ../db/base/drivers.c:73
#: ../db/base/describe.c:130 ../locale/scriptstrings/db.test_to_translate.c:2
@@ -13664,51 +13664,51 @@
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:2
#: ../locale/scriptstrings/db.droptable_to_translate.c:2
msgid "database, attribute table"
#: ../db/base/tables.c:96
msgid "Lists all tables for a given database."
-msgstr "Äßíåé ôç ëßóôá üëùí ôùí ðéíÜêùí ãéá ìßá äåäïìÝíç âÜóç äåäïìÝíùí."
+msgstr "Îίνει Ïη λίÏÏα ÏλÏν ÏÏν ÏινάκÏν για μία δεδομÎνη βάÏη δεδομÎνÏν."
#: ../db/base/connect.c:45
#, fuzzy
msgid "database, attribute table, connection settings"
#: ../db/base/connect.c:47
msgid "Prints/sets general DB connection for current mapset and exits."
-msgstr "Åêôõðþíåé/óåôÜñåé ãåíéêÞ DB óýíäåóç ãéá ôï ôñÝ÷ùí maps êáé êëåßíåé"
+msgstr "ÎκÏÏ
ÏÏνει/ÏεÏάÏει γενική DB ÏÏνδεÏη για Ïο ÏÏÎÏÏν maps και κλείνει"
#: ../db/base/connect.c:51
msgid "Print current connection parameters and exit"
-msgstr "Åêôõðþíåé ôéò ôñÝ÷ïõóåò ðáñáìÝôñïõò óýíäåóçò êáé êëåßíåé"
+msgstr "ÎκÏÏ
ÏÏνει ÏÎ¹Ï ÏÏÎÏοÏ
ÏÎµÏ ÏαÏαμÎÏÏοÏ
Ï ÏÏνδεÏÎ·Ï ÎºÎ±Î¹ κλείνει"
#: ../db/base/connect.c:57
msgid "Check connection parameters, set if uninitialized, and exit"
msgstr ""
-"ÅëÝã÷åéò ôéò ôñÝ÷ïõóåò ðáñáìÝôñïõò óýíäåóçò, óåôÜñåéò Üí äåí Ý÷ïõí "
-"îåêéíÞóåéò êáé êëåßíåé"
+"ÎλÎγÏÎµÎ¹Ï ÏÎ¹Ï ÏÏÎÏοÏ
ÏÎµÏ ÏαÏαμÎÏÏοÏ
Ï ÏÏνδεÏηÏ, ÏεÏάÏÎµÎ¹Ï Î¬Î½ δεν ÎÏοÏ
ν "
+"ξεκινήÏÎµÎ¹Ï ÎºÎ±Î¹ κλείνει"
#: ../db/base/connect.c:74
msgid "Database schema"
-msgstr "Ç äéÜôáîç ôçò âÜóçò äåäïìÝíùí"
+msgstr "ΠδιάÏαξη ÏÎ·Ï Î²Î¬ÏÎ·Ï Î´ÎµÎ´Î¿Î¼ÎνÏν"
#: ../db/base/connect.c:75
msgid ""
"Do not use this option if schemas are not supported by driver/database server"
msgstr ""
-"Ìçí ÷ñçóéìïðïéÞóåôå áõôÞ ôçí åðéëïãÞ Üí ç äéÜôáîç äåí õðïóôçñßæåôáé áðü ôïí "
-"åîõðçñåôçôÞ ïäçãü/âÜóç äåäïìÝíùí"
+"Îην ÏÏηÏιμοÏοιήÏεÏε αÏ
Ïή Ïην εÏιλογή άν η διάÏαξη δεν Ï
ÏοÏÏηÏίζεÏαι αÏÏ Ïον "
+"εξÏ
ÏηÏεÏηÏή οδηγÏ/βάÏη δεδομÎνÏν"
#: ../db/base/connect.c:85
msgid "Default group of database users to which select privilege is granted"
msgstr ""
-"ÐñïåðéëåãìÝíï ãêñïõð ÷ñçóôþí âÜóçò äåäïìÝíùí óôï ïðïßï Ý÷ïõí ôá äéêáéþìáôá"
+"Î ÏοεÏιλεγμÎνο γκÏοÏ
Ï ÏÏηÏÏÏν βάÏÎ·Ï Î´ÎµÎ´Î¿Î¼ÎνÏν ÏÏο οÏοίο ÎÏοÏ
ν Ïα δικαιÏμαÏα"
#: ../db/base/connect.c:121
msgid "Database connection not defined. Run db.connect."
msgstr ""
-"Äåí Ý÷åé êáèïñéóèåß ç óýíäåóç ìå ôç âÜóç äåäïìÝíùí. ÔñÝîôå ôï db.connect."
+"Îεν ÎÏει καθοÏιÏθεί η ÏÏνδεÏη με Ïη βάÏη δεδομÎνÏν. ΤÏÎξÏε Ïο db.connect."
#: ../db/base/connect.c:141
#, c-format
@@ -13717,113 +13717,113 @@
"driver: %s\n"
"database: %s"
msgstr ""
-"ÐñïåðéëåãìÝíïò ïäçãüò / ç âÜóç äåäïìÝíùí Ý÷åé:\n"
+"Î ÏοεÏιλεγμÎÎ½Î¿Ï Î¿Î´Î·Î³ÏÏ / η βάÏη δεδομÎνÏν ÎÏει:\n"
"driver: %s\n"
"database: %s"
#: ../db/base/connect.c:148
msgid "Default driver is not set"
-msgstr "Ï ðñïåðéëåãìÝíïò ïäçãüò äåí Ý÷åé êáèïñéóôåß"
+msgstr "Î ÏÏοεÏιλεγμÎÎ½Î¿Ï Î¿Î´Î·Î³ÏÏ Î´ÎµÎ½ ÎÏει καθοÏιÏÏεί"
#: ../db/base/connect.c:151
msgid "Default database is not set"
-msgstr "Ç ðñïåðéëåãìÝíç âÜóç äåäïìÝíùí äåí Ý÷åé êáèïñéóôåß"
+msgstr "Î ÏÏοεÏιλεγμÎνη βάÏη δεδομÎνÏν δεν ÎÏει καθοÏιÏÏεί"
#: ../db/base/columns.c:44 ../db/base/copy.c:100 ../db/base/select.c:53
#: ../db/base/describe.c:51
#, fuzzy, c-format
msgid "Table <%s> not found in database <%s> using driver <%s>"
+msgstr "ÎδÏ
#: ../db/base/columns.c:99
msgid "List all columns for a given table."
-msgstr "Äßíåé ëßóôá üëùí ôùí óôçëþí ãéá Ýíá äåäïìÝíï ðßíáêá."
+msgstr "Îίνει λίÏÏα ÏλÏν ÏÏν ÏÏηλÏν για Îνα δεδομÎνο Ïίνακα."
#: ../db/base/copy.c:38
msgid "Copy a table."
-msgstr "ÁíôéãñÜöåé Ýíá ðßíáêá"
+msgstr "ÎνÏιγÏάÏει Îνα Ïίνακα"
#: ../db/base/copy.c:40
msgid ""
"Either 'from_table' (optionally with 'where') can be used or 'select' "
"option, but not 'from_table' and 'select' at the same time."
msgstr ""
-"Åßôå 'from_table' (êáô' åðéëïãÞ ìå 'where') ìðïñåß íá ÷ñçóéìïðïéçèåß Þ "
-"'select' åðéëïãÞ, áëëÜ ü÷é 'from_table' êáé 'select' ôçí ßäéá óôéãìÞ."
+"ÎίÏε 'from_table' (καÏ' εÏιλογή με 'where') μÏοÏεί να ÏÏηÏιμοÏοιηθεί ή "
+"'select' εÏιλογή, αλλά ÏÏι 'from_table' και 'select' Ïην ίδια ÏÏιγμή."
#: ../db/base/copy.c:46
msgid "Input driver name"
-msgstr "ÅéóáãùãÞ üíïìá ïäçãïý"
+msgstr "ÎιÏαγÏγή Ïνομα οδηγοÏ"
#: ../db/base/copy.c:52
msgid "Input database name"
-msgstr "ÅéóáãùãÞ üíïìá âÜóçò äåäïìÝíùí"
+msgstr "ÎιÏαγÏγή Ïνομα βάÏÎ·Ï Î´ÎµÎ´Î¿Î¼ÎνÏν"
#: ../db/base/copy.c:59
msgid "Input table name (only, if 'select' is not used)"
-msgstr "ÅéóáãùãÞò âÜóçò äåäïìÝíùí (ìüíï åÜí 'select' äåí ÷ñçóéìïðïéåßôáé)"
+msgstr "ÎιÏαγÏÎ³Î®Ï Î²Î¬ÏÎ·Ï Î´ÎµÎ´Î¿Î¼ÎνÏν (μÏνο εάν 'select' δεν ÏÏηÏιμοÏοιείÏαι)"
#: ../db/base/copy.c:65
msgid "Output driver name"
-msgstr "ÅîáãùãÞ üíïìá ïäçãïý"
+msgstr "ÎξαγÏγή Ïνομα οδηγοÏ"
#: ../db/base/copy.c:71
msgid "Output database name"
-msgstr "ÅîáãùãÞ üíïìá âÜóçò äåäïìÝíùí"
+msgstr "ÎξαγÏγή Ïνομα βάÏÎ·Ï Î´ÎµÎ´Î¿Î¼ÎνÏν"
#: ../db/base/copy.c:78
msgid "Output table name"
#: ../db/base/copy.c:87
msgid "Full select statement (only, if 'from_table' and 'where' is not used)"
msgstr ""
-"ÐëÞñçò select äÞëùóç (ìüíï, åÜí 'from_table' êáé 'where' is äåí "
-"÷ñçóéìïðïéïýíôáé)"
+"ΠλήÏÎ·Ï select δήλÏÏη (μÏνο, εάν 'from_table' και 'where' is δεν "
+"ÏÏηÏιμοÏοιοÏνÏαι)"
#: ../db/base/copy.c:88
msgid "E.g.: SELECT dedek FROM starobince WHERE obec = 'Frimburg'"
-msgstr "ÐáñÜäåéãìá.: SELECT dedek FROM starobince WHERE obec = 'Frimburg'"
+msgstr "ΠαÏάδειγμα.: SELECT dedek FROM starobince WHERE obec = 'Frimburg'"
#: ../db/base/copy.c:96
msgid "Cannot combine 'from_table' and 'select' options"
-msgstr "Äåí ìðïñåß íá óõíäõáóôåß 'from_table' êáé 'select' åðéëïãÝò"
+msgstr "Îεν μÏοÏεί να ÏÏ
νδÏ
αÏÏεί 'from_table' και 'select' εÏιλογÎÏ"
#: ../db/base/copy.c:122
msgid "Either 'from_table' or 'select' option must be given."
-msgstr "Åßôå 'from_table' Þ 'select' åðéëïãÞ ðñÝðåé íá äùèåß."
+msgstr "ÎίÏε 'from_table' ή 'select' εÏιλογή ÏÏÎÏει να δÏθεί."
#: ../db/base/copy.c:125
msgid "Cannot combine 'select' and 'where' options"
-msgstr "Äåí óõíäõÜæïíôáé 'select' êáé 'where' åðéëïãÝò"
+msgstr "Îεν ÏÏ
νδÏ
άζονÏαι 'select' και 'where' εÏιλογÎÏ"
#: ../db/base/copy.c:135
msgid "Copy table failed"
-msgstr "ÁíôéãñáöÞ ðßíáêá áðÝôõ÷å"
+msgstr "ÎνÏιγÏαÏή Ïίνακα αÏÎÏÏ
Ïε"
#: ../db/base/drivers.c:41
#, fuzzy
msgid "Error trying to read dbmscap file"
-msgstr "ÓöÜëìá êáôÜ ôçí ðñïóðÜèåéá áíÜãíùóçò ôïõ áñ÷åßïõ dbmscap\n"
+msgstr "ΣÏάλμα καÏά Ïην ÏÏοÏÏάθεια ανάγνÏÏÎ·Ï ÏοÏ
αÏÏείοÏ
dbmscap\n"
#: ../db/base/drivers.c:65
msgid "Full output"
-msgstr "ÐëÞñåò output"
+msgstr "ΠλήÏÎµÏ output"
#: ../db/base/drivers.c:69
#, fuzzy
msgid "Print drivers and exit"
-msgstr "ôõðþíåé ôïõò ïäçãïýò êáé Ýîïäïò"
+msgstr "ÏÏ
ÏÏνει ÏοÏ
Ï Î¿Î´Î·Î³Î¿ÏÏ ÎºÎ±Î¹ ÎξοδοÏ"
#: ../db/base/drivers.c:74
#, fuzzy
msgid "Lists all database drivers."
-msgstr "Äßíåé ôç ëßóôá ãéá üëïõò ôïõò ïäçãïýò âÜóåùí äåäïìÝíùí"
+msgstr "Îίνει Ïη λίÏÏα για ÏλοÏ
Ï ÏοÏ
Ï Î¿Î´Î·Î³Î¿ÏÏ Î²Î¬ÏεÏν δεδομÎνÏν"
#: ../db/base/select.c:101
#, fuzzy, c-format
msgid "Test %s."
-msgstr "Ôýðïò"
+msgstr "ΤÏÏοÏ"
#: ../imagery/i.ortho.photo/i.photo.rectify/report.c:10
@@ -13837,15 +13837,15 @@
#: ../db/base/select.c:213
msgid "SQL select statement"
-msgstr "SQL select åíôïëÞ"
+msgstr "SQL select ενÏολή"
#: ../db/base/select.c:215
msgid "For example: 'select * from rybniky where kapri = 'hodne'"
-msgstr "Ãéá ðáñÜäåéãìá: 'select * from rybniky where kapri = 'hodne'"
+msgstr "Îια ÏαÏάδειγμα: 'select * from rybniky where kapri = 'hodne'"
#: ../db/base/select.c:219
msgid "Name of file with sql statement"
-msgstr "¼íïìá áñ÷åßïõ ìå sql åíôïëÞ"
με sql ενÏολή"
#: ../db/base/select.c:223 ../db/base/select.c:229 ../db/base/select.c:236
#: ../db/base/select.c:246 ../db/base/select.c:255
@@ -13853,31 +13853,31 @@
#: ../vector/v.db.select/main.c:78 ../vector/v.db.select/main.c:94
#: ../vector/v.db.select/main.c:99
msgid "Format"
-msgstr "Äéáìüñöùóç"
+msgstr "ÎιαμÏÏÏÏÏη"
#: ../db/base/select.c:227 ../vector/v.db.select/main.c:69
msgid "Output vertical record separator"
#: ../db/base/select.c:235 ../vector/v.db.select/main.c:77
msgid "Null value indicator"
-msgstr "Äåßêôçò êåíÞò ôéìÞò"
+msgstr "ÎείκÏÎ·Ï ÎºÎµÎ½Î®Ï ÏιμήÏ"
#: ../db/base/select.c:245 ../vector/v.db.select/main.c:93
msgid "Do not include column names in output"
-msgstr "Ìçí óõìðåñéëÜâåôáé ôá ïíüìáôá ôùí óôçëþí óôçí Ýîïäï"
+msgstr "Îην ÏÏ
μÏεÏιλάβεÏαι Ïα ονÏμαÏα ÏÏν ÏÏηλÏν ÏÏην Îξοδο"
#: ../db/base/select.c:250
msgid "Describe query only (don't run it)"
-msgstr "ÐåñéãñÜöç ìüíï ôï åñþôçìá (äåí ôï ôñÝ÷åé)"
+msgstr "ΠεÏιγÏάÏη μÏνο Ïο εÏÏÏημα (δεν Ïο ÏÏÎÏει)"
#: ../db/base/select.c:254 ../vector/v.db.select/main.c:98
msgid "Vertical output (instead of horizontal)"
-msgstr "Ïñéæüíôéá Ýîïäïò (áíôß ãéá êáôáêüñõöç)"
+msgstr "ÎÏιζÏνÏια ÎÎ¾Î¿Î´Î¿Ï (ανÏί για καÏακÏÏÏ
Ïη)"
#: ../db/base/select.c:259
msgid "Only test query, do not execute"
-msgstr "Åñþôçìá ìüíï ãéá ôåóô, ìçí ôï åêôåëÝóåôå"
+msgstr "ÎÏÏÏημα μÏνο για ÏεÏÏ, μην Ïο εκÏελÎÏεÏε"
#: ../db/base/select.c:264
msgid "Selects data from attribute table (performs SQL query statement(s))."
@@ -13892,37 +13892,37 @@
#: ../vector/v.random/main.c:214
#, c-format
msgid "Unable to describe table <%s>"
+msgstr "ÎδÏ
#: ../db/base/describe.c:109
msgid "Print column names only instead of full column descriptions"
-msgstr "Åêôýðùóç ìüíï ôùí ïíïìÜôùí óôçëþí áíôß ôùí áíáëõôéêþí ðåñéãñáöþí"
+msgstr "ÎκÏÏÏÏÏη μÏνο ÏÏν ονομάÏÏν ÏÏηλÏν ανÏί ÏÏν αναλÏ
ÏικÏν ÏεÏιγÏαÏÏν"
#: ../db/base/describe.c:114
msgid "Print table structure"
-msgstr "Ôýðùìá ôçò äïìÞ ôïõ ðßíáêá"
+msgstr "ΤÏÏÏμα ÏÎ·Ï Î´Î¿Î¼Î® ÏοÏ
Ïίνακα"
#: ../db/base/describe.c:131
msgid "Describes a table in detail."
-msgstr "ËåðôïìåñÞò ðåñéãñáöÞ ðßíáêá"
+msgstr "ÎεÏÏομεÏÎ®Ï ÏεÏιγÏαÏή Ïίνακα"
#: ../db/db.login/main.c:44
#, fuzzy
msgid "database, connection settings"
msgstr ""
-"Äåí Ý÷åé êáèïñéóôåß ç óýíäåóç ìå ôç âÜóç äåäïìÝíùí ãéá ôï åðßðåäï (layer) %d"
+"Îεν ÎÏει καθοÏιÏÏεί η ÏÏνδεÏη με Ïη βάÏη δεδομÎνÏν για Ïο εÏίÏεδο (layer) %d"
#: ../db/db.login/main.c:45
msgid "Sets user/password for driver/database."
-msgstr "Êáèïñßæåé ôï üíïìá ÷ñÞóôç/êùäéêü ãéá ôïí ïäçãü/ âÜóç äåäïìÝíùí"
+msgstr "ÎαθοÏίζει Ïο Ïνομα ÏÏήÏÏη/κÏÎ´Î¹ÎºÏ Î³Î¹Î± Ïον οδηγÏ/ βάÏη δεδομÎνÏν"
#: ../db/db.login/main.c:61
msgid "Username"
-msgstr "¼íïìá ÷ñÞóôç"
+msgstr "Îνομα ÏÏήÏÏη"
#: ../db/db.login/main.c:69
msgid "Password"
-msgstr "Êùäéêüò"
+msgstr "ÎÏδικÏÏ"
#: ../db/db.login/main.c:86
#, c-format
@@ -13932,39 +13932,39 @@
"<%s:%s:user=%s>\n"
msgstr ""
"\n"
-"Äþóôå ôïí êùäéêü ôçò âÜóçò äåäïìÝíùí ãéá ôç óýíäåóç\n"
+"ÎÏÏÏε Ïον κÏÎ´Î¹ÎºÏ ÏÎ·Ï Î²Î¬ÏÎ·Ï Î´ÎµÎ´Î¿Î¼ÎνÏν για Ïη ÏÏνδεÏη\n"
"<%s:%s:user=%s>\n"
#: ../db/db.login/main.c:88
#, c-format
msgid "Hit RETURN to cancel request\n"
-msgstr "ÐáôÞóôå ôï ðëÞêôñï RETURN ãéá íá áêõñþóåôå ôçí åíôïëÞ\n"
+msgstr "ΠαÏήÏÏε Ïο ÏλήκÏÏο RETURN για να ακÏ
ÏÏÏεÏε Ïην ενÏολή\n"
#: ../db/db.login/main.c:96
msgid "Exiting. Not changing current settings"
-msgstr "Êëåßóéìï åöáñìïãÞò, ÷ùñßò íá áëëÜîïõí ïé ôñÝ÷ïõóåò åðéëïãÝò"
+msgstr "ÎλείÏιμο εÏαÏμογήÏ, ÏÏÏÎ¯Ï Î½Î± αλλάξοÏ
ν οι ÏÏÎÏοÏ
ÏÎµÏ ÎµÏιλογÎÏ"
#: ../db/db.login/main.c:100
msgid "New password set"
-msgstr "Ï íÝïò êùäéêüò äçìéïõñãÞèçêå"
+msgstr "ΠνÎÎ¿Ï ÎºÏδικÏÏ Î´Î·Î¼Î¹Î¿Ï
Ïγήθηκε"
#: ../db/db.login/main.c:109
msgid "Unable to set user/password"
-msgstr "Äåí åßíáé äõíáôÞ ç áëëáãÞ ÷ñÞóôç/êùäéêïý"
+msgstr "Îεν είναι δÏ
ναÏή η αλλαγή ÏÏήÏÏη/κÏδικοÏ"
#: ../db/db.login/main.c:114
#, fuzzy, c-format
msgid "The password was stored in file (%s/.grasslogin64)"
-msgstr "Ï êùäéêüò áðïèçêåýôçêå óôï áñ÷åßï"
+msgstr "ΠκÏδικÏÏ Î±ÏοθηκεÏÏηκε ÏÏο αÏÏείο"
#: ../db/drivers/ogr/fetch.c:132 ../db/drivers/ogr/describe.c:165
msgid "Unknown type"
#: ../db/drivers/ogr/describe.c:94
#, c-format
msgid "OGR driver: column '%s', OGR type %d is not supported"
-msgstr "OGR driver: óôÞëç '%s', OGR ôýðïò %d äåí õðïóôçñßæåôáé"
+msgstr "OGR driver: ÏÏήλη '%s', OGR ÏÏÏÎ¿Ï %d δεν Ï
ÏοÏÏηÏίζεÏαι"
#: ../db/drivers/ogr/describe.c:157
#, c-format
@@ -13972,8 +13972,8 @@
"column '%s', type 'string': unknown width -> stored as varchar(250) some "
"data may be lost"
msgstr ""
-"óôÞëç '%s', ôýðïò 'string': Üãíùóôï åýñïò -> óùóìÝíï ùò varchar(250) "
-"ïñéóìÝíá äåäïìÝíá ìðïñåß íá ÷áèïýí"
+"ÏÏήλη '%s', ÏÏÏÎ¿Ï 'string': άγνÏÏÏο εÏÏÎ¿Ï -> ÏÏÏμÎνο ÏÏ varchar(250) "
+"οÏιÏμÎνα δεδομÎνα μÏοÏεί να ÏαθοÏν"
#: ../db/drivers/sqlite/main.c:47
#, c-format
@@ -13982,104 +13982,104 @@
#: ../db/drivers/sqlite/db.c:85
msgid "Unable to open database: "
-msgstr "Áäõíáìßá áíïßãìáôïò âÜóçò äåäïìåíùí"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï Î²Î¬ÏÎ·Ï Î´ÎµÎ´Î¿Î¼ÎµÎ½Ïν"
#: ../db/drivers/sqlite/db.c:110
#, fuzzy
msgid "SQLite database connection is still busy"
msgstr ""
#: ../db/drivers/sqlite/describe.c:191
#, c-format
msgid "SQLite driver: column '%s', SQLite type %d is not supported"
-msgstr "SQLite driver: óôÞëç '%s', SQLite ôýðïò %d äåí õðïóôçñßæåôáé"
+msgstr "SQLite driver: ÏÏήλη '%s', SQLite ÏÏÏÎ¿Ï %d δεν Ï
ÏοÏÏηÏίζεÏαι"
#: ../db/drivers/mysql/cursor.c:46
msgid "Cannot allocate cursor."
-msgstr "Äåí ãßíåôáé ç ìåôáêßíçóç ôïõ êÝñóïñá."
+msgstr "Îεν γίνεÏαι η μεÏακίνηÏη ÏοÏ
κÎÏÏοÏα."
#: ../db/drivers/mysql/cursor.c:55
msgid "Cannot ad new token."
-msgstr "Áäýíáôç ç ðñïóèÞêç new token"
+msgstr "ÎδÏναÏη η ÏÏοÏθήκη new token"
#: ../db/drivers/mysql/error.c:29
msgid "DBMI-MySQL driver error:\n"
-msgstr "DBMI-MySQL óöÜëìá ïäçãïý:\n"
+msgstr "DBMI-MySQL ÏÏάλμα οδηγοÏ:\n"
#: ../db/drivers/mysql/fetch.c:34
msgid "Cursor not found"
-msgstr "Ï êÝñóïñáò äåí âñÝèçêå"
+msgstr "ΠκÎÏÏοÏÎ±Ï Î´ÎµÎ½ βÏÎθηκε"
#: ../db/drivers/mysql/fetch.c:52
msgid "Cursor position is not supported by MySQL driver"
-msgstr "Ç èÝóç ôïõ êÝñóïåá äåí õðïóôçñßæåôáé áðü ôïí ïäçãü MySQL"
+msgstr "ΠθÎÏη ÏοÏ
κÎÏÏοεα δεν Ï
ÏοÏÏηÏίζεÏαι αÏÏ Ïον Î¿Î´Î·Î³Ï MySQL"
#: ../db/drivers/mysql/fetch.c:190
msgid "Cannot scan timestamp: "
-msgstr "Áäõíáìßá óêáíáñßóìáôïò timestamp: "
+msgstr "ÎδÏ
ναμία ÏκαναÏίÏμαÏÎ¿Ï timestamp: "
#: ../db/drivers/mysql/fetch.c:198
msgid "Unknown timestamp format: "
-msgstr "¶ãíùóôç ìïñöÞ timestamp: "
+msgstr "ÎγνÏÏÏη μοÏÏή timestamp: "
#: ../db/drivers/mysql/fetch.c:212
msgid "Cannot scan date: "
-msgstr "Áäõíáìßá óêáíáñßóìáôïò çìåñïìçíßáò:"
+msgstr "ÎδÏ
ναμία ÏκαναÏίÏμαÏÎ¿Ï Î·Î¼ÎµÏομηνίαÏ:"
#: ../db/drivers/mysql/fetch.c:225
msgid "Cannot scan time: "
-msgstr "Áäõíáìßá óêáíáñßóìáôïò ÷ñüíïõ: "
+msgstr "ÎδÏ
ναμία ÏκαναÏίÏμαÏÎ¿Ï ÏÏÏνοÏ
#: ../db/drivers/mysql/fetch.c:240
msgid "Cannot scan datetime: "
-msgstr "Áäõíáìßá óêáíáñßóìáôïò çìåñïìçíßáò-÷ñüíïõ: "
+msgstr "ÎδÏ
ναμία ÏκαναÏίÏμαÏÎ¿Ï Î·Î¼ÎµÏομηνίαÏ-ÏÏÏνοÏ
#: ../db/drivers/mysql/listtab.c:36
msgid "Cannot get list of tables:\n"
-msgstr "Äåí ìðïñþ íá äù ëßóôá ôùí ðéíÜêùí:\n"
+msgstr "Îεν μÏοÏÏ Î½Î± Î´Ï Î»Î¯ÏÏα ÏÏν ÏινάκÏν:\n"
#: ../db/drivers/mysql/db.c:67
msgid "Cannot connect to MySQL: "
-msgstr "Áäõíáìßá óýíäåóçò óôçí MySQL: "
+msgstr "ÎδÏ
ναμία ÏÏνδεÏÎ·Ï ÏÏην MySQL: "
#: ../db/drivers/mysql/db.c:83
msgid "Cannot parse MySQL embedded database name"
-msgstr "Áäõíáìßá ðåñÜóìáôïò' MySQL ïíüìáôïò âÜóçò"
+msgstr "ÎδÏ
ναμία ÏεÏάÏμαÏοÏ' MySQL ονÏμαÏÎ¿Ï Î²Î¬ÏηÏ"
#: ../db/drivers/mysql/db.c:99
msgid "Cannot initialize MySQL embedded server"
-msgstr "Äåí åéíáé äõíáôÞ ç áñ÷éêïðïßçóç ìå ôïí åíóùìáôùìÝíï MySQL åîõðçñåôçôÞ"
+msgstr "Îεν ειναι δÏ
ναÏή η αÏÏικοÏοίηÏη με Ïον ενÏÏμαÏÏμÎνο MySQL εξÏ
ÏηÏεÏηÏή"
#: ../db/drivers/mysql/db.c:118
msgid "Cannot connect to MySQL embedded server: "
-msgstr "Äåí åéíáé äõíáôÞ ç óýíäåóç ìå ôïí åíóùìáôùìÝíï MySQL åîõðçñåôçôÞ"
ναÏή η ÏÏνδεÏη με Ïον ενÏÏμαÏÏμÎνο MySQL εξÏ
ÏηÏεÏηÏή"
#: ../db/drivers/mysql/parse.c:60
msgid "Wrong port number in MySQL database definition: "
-msgstr "ËÜèïò íïýìåñï ðüñôáò óôçí MySQL ðåñéãñáöÞ ôçò âÜóçò: "
+msgstr "ÎÎ¬Î¸Î¿Ï Î½Î¿ÏμεÏο ÏÏÏÏÎ±Ï ÏÏην MySQL ÏεÏιγÏαÏή ÏÎ·Ï Î²Î¬ÏηÏ: "
#: ../db/drivers/mysql/parse.c:71 ../db/drivers/postgres/parse.c:55
msgid "'user' in database definition is not supported, use db.login"
-msgstr "'user' óôç âÜóç äåäïìÝíùí äåí õðïóôçñßæåôáé, ÷ñçóéìïðïéÞóôå db."
+msgstr "'user' ÏÏη βάÏη δεδομÎνÏν δεν Ï
ÏοÏÏηÏίζεÏαι, ÏÏηÏιμοÏοιήÏÏε db."
#: ../db/drivers/mysql/parse.c:75 ../db/drivers/postgres/parse.c:59
msgid "'password' in database definition is not supported, use db.login"
msgstr ""
-"'password' óôç âÜóç äåäïìÝíùí äåí õðïóôçñßæåôáé, ÷ñçóéìïðïéÞóôå db.login"
+"'password' ÏÏη βάÏη δεδομÎνÏν δεν Ï
ÏοÏÏηÏίζεÏαι, ÏÏηÏιμοÏοιήÏÏε db.login"
#: ../db/drivers/mysql/parse.c:79
msgid "Unknown option in database definition for "
-msgstr "¶ãíùóôç åðéëïãÞ óôïí ïñéóìüò ôçò âÜóçò äåäïìÝíùí ãéá "
+msgstr "ÎγνÏÏÏη εÏιλογή ÏÏον οÏιÏμÏÏ ÏÎ·Ï Î²Î¬ÏÎ·Ï Î´ÎµÎ´Î¿Î¼ÎνÏν για "
#: ../db/drivers/mysql/select.c:43
msgid "Cannot select data: \n"
#: ../db/drivers/mysql/describe.c:120
#, c-format
msgid "MySQL driver: column '%s', type %d is not supported"
-msgstr "MySQL ïäçãüò: óôÞëç '%s', ôýðïò %d äåí õðïóôçñßæåôáé"
+msgstr "MySQL οδηγÏÏ: ÏÏήλη '%s', ÏÏÏÎ¿Ï %d δεν Ï
ÏοÏÏηÏίζεÏαι"
#: ../db/drivers/mysql/describe.c:126
#, c-format
@@ -14087,26 +14087,26 @@
"column '%s' : type BIGINT is stored as integer (4 bytes) some data may be "
"damaged"
msgstr ""
-"óôÞëç '%s' : ôýðïò BIGINT Ý÷åé áðïèçêåõôåß ùò áêÝñáéïò (4 bytes) ïñéóìÝíá "
-"äåäïìÝíá ìðïñåß íá Ý÷ïõí êáôáóôñáöåß"
+"ÏÏήλη '%s' : ÏÏÏÎ¿Ï BIGINT ÎÏει αÏοθηκεÏ
Ïεί ÏÏ Î±ÎºÎÏÎ±Î¹Î¿Ï (4 bytes) οÏιÏμÎνα "
+"δεδομÎνα μÏοÏεί να ÎÏοÏ
ν καÏαÏÏÏαÏεί"
#: ../db/drivers/postgres/fetch.c:172
msgid "Cannot recognize boolean value"
-msgstr "Äåí ìðïñåß íá áíáãíùñéóôÞ ç ôéìÞ boolean"
+msgstr "Îεν μÏοÏεί να αναγνÏÏιÏÏή η Ïιμή boolean"
#: ../db/drivers/postgres/parse.c:63
msgid "Unknown option in database definition for PostgreSQL: "
-msgstr "¶ãíùóôç åðéëïãÞ óôçí ðåñéãñáöÞ âÜóçò äåäïìÝíùí ãéá PostgreSQL: "
+msgstr "ÎγνÏÏÏη εÏιλογή ÏÏην ÏεÏιγÏαÏή βάÏÎ·Ï Î´ÎµÎ´Î¿Î¼ÎνÏν για PostgreSQL: "
#: ../db/drivers/postgres/describe.c:103
#, c-format
msgid "pg driver: PostGIS column '%s', type 'geometry' will not be converted"
-msgstr "pg driver: PostGIS óôÞëç '%s', ôýðïò 'geometry' äåí èá ìåôáôñáðåß"
+msgstr "pg driver: PostGIS ÏÏήλη '%s', ÏÏÏÎ¿Ï 'geometry' δεν θα μεÏαÏÏαÏεί"
#: ../db/drivers/postgres/describe.c:109
#, c-format
msgid "pg driver: column '%s', type %d is not supported"
-msgstr "pg driver: óôÞëç '%s', ôýðïò %d äåí õðïóôçñßæåôáé"
+msgstr "pg driver: ÏÏήλη '%s', ÏÏÏÎ¿Ï %d δεν Ï
ÏοÏÏηÏίζεÏαι"
#: ../db/drivers/postgres/describe.c:116
#, c-format
@@ -14114,8 +14114,8 @@
"column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data "
"may be damaged"
msgstr ""
-"óôÞëç '%s' : ôýðïò int8 (bigint) Ý÷åé áðïèçêåõôåß ùò áêÝñáéïò (4 bytes) "
-"ïñéóìÝíá äåäïìÝíá ìðïñåß íá Ý÷ïõí êáôáóôñáöåß"
+"ÏÏήλη '%s' : ÏÏÏÎ¿Ï int8 (bigint) ÎÏει αÏοθηκεÏ
Ïεί ÏÏ Î±ÎºÎÏÎ±Î¹Î¿Ï (4 bytes) "
+"οÏιÏμÎνα δεδομÎνα μÏοÏεί να ÎÏοÏ
ν καÏαÏÏÏαÏεί"
#: ../db/drivers/postgres/describe.c:120
#, c-format
@@ -14123,8 +14123,8 @@
"column '%s' : type character varying is stored as varchar(250) some data may "
"be lost"
msgstr ""
-"óôÞëç '%s' : ï ôýðïò ÷áñáêôÞñá ìåôáâÜëëåôáé Ý÷åé áðïèçêåõôåß ùò varchar(250) "
-"ïñéóìÝíá äåäïìÝíá èá ÷áèïýí"
+"ÏÏήλη '%s' : ο ÏÏÏÎ¿Ï ÏαÏακÏήÏα μεÏαβάλλεÏαι ÎÏει αÏοθηκεÏ
Ïεί ÏÏ varchar(250) "
+"οÏιÏμÎνα δεδομÎνα θα ÏαθοÏν"
#: ../db/drivers/postgres/describe.c:126
#, c-format
@@ -14132,7 +14132,7 @@
"column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 "
"(true)"
msgstr ""
-"óôÞëç '%s' : ôýðïò bool (boolean) Ý÷åé áðïèçêåõôÝé ùò char(1), ôéìÝò: 0 "
+"ÏÏήλη '%s' : ÏÏÏÎ¿Ï bool (boolean) ÎÏει αÏοθηκεÏ
ÏÎι ÏÏ char(1), ÏιμÎÏ: 0 "
"(false), 1 (true)"
#: ../doc/raster/r.example/main.c:85
@@ -14179,7 +14179,7 @@
#: ../vector/v.net.centrality/main.c:188 ../vector/v.generalize/main.c:295
#, fuzzy, c-format
msgid "Unable to open vector map <%s>"
-msgstr "Áäõíáìßá áíïßãìáôïò äéáíõóìáôéêïý ÷Üñôç <%s>"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï Î´Î¹Î±Î½Ï
#: ../doc/vector/v.example/main.c:103 ../display/d.thematic.area/plot1.c:196
#: ../display/d.vect/area.c:54 ../display/d.vect/plot1.c:205
@@ -14201,7 +14201,7 @@
#, fuzzy, c-format
msgid "Database connection not defined for layer %d"
msgstr ""
#: ../doc/vector/v.example/main.c:167
#, c-format
@@ -14270,7 +14270,7 @@
#: ../misc/m.nviz.image/cplane.c:40
#, fuzzy, c-format
msgid "Cutting plane number <%d> not found"
#: ../misc/m.nviz.image/main.c:49 ../visualization/nviz/src/nviz_init.c:53
msgid "visualization, raster, vector, raster3d"
@@ -14313,7 +14313,7 @@
#: ../misc/m.nviz.image/surface.c:129 ../misc/m.nviz.image/volume.c:144
#, fuzzy, c-format
msgid "Color attribute not defined, using default <%s>"
-msgstr "×ñþìá"
+msgstr "ΧÏÏμα"
#: ../misc/m.nviz.image/surface.c:134
#, c-format
@@ -14333,7 +14333,7 @@
#: ../misc/m.nviz.image/volume.c:42 ../misc/m.nviz.image/volume.c:125
#, c-format
msgid "3d raster map <%s> not found"
#: ../misc/m.nviz.image/volume.c:92 ../misc/m.nviz.image/volume.c:231
#, c-format
@@ -14366,12 +14366,12 @@
#: ../misc/m.nviz.image/volume.c:253
#, fuzzy, c-format
msgid "Unable to add slice (volume set %d)"
-msgstr "Áäõíáìßá äçìéïõñãßáò ñÜóôåñ ÷Üñôç"
+msgstr "ÎδÏ
ναμία δημιοÏ
ÏÎ³Î¯Î±Ï ÏάÏÏÎµÏ ÏάÏÏη"
#: ../misc/m.nviz.image/volume.c:266
#, fuzzy, c-format
msgid "Unable to set slice (%d) position of volume %d"
+msgstr "ÎδÏ
#: ../misc/m.nviz.image/volume.c:271
#, c-format
@@ -14394,7 +14394,7 @@
#: ../misc/m.nviz.image/args.c:89
#, fuzzy
msgid "Name for output image file (without extension)"
-msgstr "¼íïìá áñ÷åßïõ åîáãùãÞò (ÌÇÍ ðñïóèÝóåôå åðÝêôáóç áñ÷åßïõ)"
εξαγÏÎ³Î®Ï (ÎÎÎ ÏÏοÏθÎÏεÏε εÏÎκÏαÏη αÏÏείοÏ
#: ../misc/m.nviz.image/args.c:90 ../misc/m.nviz.image/args.c:104
#: ../misc/m.nviz.image/args.c:114
@@ -14425,7 +14425,7 @@
#: ../misc/m.nviz.image/args.c:151
#, fuzzy
msgid "Color value(s)"
-msgstr "×ñþìá"
+msgstr "ΧÏÏμα"
#: ../misc/m.nviz.image/args.c:159
msgid "Name of raster map(s) for mask"
@@ -14490,7 +14490,7 @@
#: ../misc/m.nviz.image/args.c:295
#, fuzzy
msgid "Surface position"
-msgstr "ñÜóôåñ 3Ä, voxel"
+msgstr "ÏάÏÏÎµÏ 3Î, voxel"
#: ../misc/m.nviz.image/args.c:307
msgid "Name of line vector overlay map(s)"
@@ -14521,7 +14521,7 @@
#: ../misc/m.nviz.image/args.c:363
#, fuzzy
msgid "Vector lines position"
-msgstr "Ôï äéÜíõóìá äåí åßíáé 3Ä"
+msgstr "Το διάνÏ
Ïμα δεν είναι 3Î"
#: ../misc/m.nviz.image/args.c:375
msgid "Name of point vector overlay map(s)"
@@ -14552,7 +14552,7 @@
#: ../misc/m.nviz.image/args.c:432
#, fuzzy
msgid "Vector points position"
+msgstr "Το διάνÏ
Ïμα δεν είναι 3Î"
#: ../misc/m.nviz.image/args.c:449
msgid "Viewpoint position (x,y model coordinates)"
@@ -14589,7 +14589,7 @@
#: ../misc/m.nviz.image/args.c:656
#, fuzzy
msgid "Volumes"
-msgstr "×ñþìá"
+msgstr "ΧÏÏμα"
#: ../misc/m.nviz.image/args.c:523
msgid "Volume draw mode"
@@ -14614,17 +14614,17 @@
#: ../misc/m.nviz.image/args.c:577
#, fuzzy
msgid "Name of volume for isosurface color"
-msgstr "Ëßóôá ôùí thresholds ãéá éóïåðéöÜíåéåò"
+msgstr "ÎίÏÏα ÏÏν thresholds για ιÏοεÏιÏάνειεÏ"
#: ../misc/m.nviz.image/args.c:585
#, fuzzy
msgid "Isosurface color"
#: ../misc/m.nviz.image/args.c:594
#, fuzzy
msgid "Name of 3D raster map(s) for isosurface transparency"
-msgstr "×ñþìá"
+msgstr "ΧÏÏμα"
#: ../misc/m.nviz.image/args.c:604
msgid "Transparency value(s)for isosurfaces"
@@ -14633,12 +14633,12 @@
#: ../misc/m.nviz.image/args.c:612
#, fuzzy
msgid "Name of 3D raster map(s) for shininess"
-msgstr "×ñþìá"
+msgstr "ΧÏÏμα"
#: ../misc/m.nviz.image/args.c:622
#, fuzzy
msgid "Shininess value(s) for isosurfaces"
#: ../misc/m.nviz.image/args.c:634
msgid "Volume slice parallel to given axis (x, y, z)"
@@ -14647,7 +14647,7 @@
#: ../misc/m.nviz.image/args.c:644
#, fuzzy
msgid "Volume slice position"
+msgstr "Το διάνÏ
Ïμα δεν είναι 3Î"
#: ../misc/m.nviz.image/args.c:655
msgid "Volume slice transparency"
@@ -14708,7 +14708,7 @@
#: ../misc/m.nviz.image/args.c:768
#, fuzzy
msgid "Fringe edges"
-msgstr "ÅããñáöÞ %s áðü %s..."
+msgstr "ÎγγÏαÏή %s αÏÏ %s..."
#: ../misc/m.nviz.image/args.c:769 ../misc/m.nviz.image/args.c:775
#: ../misc/m.nviz.image/args.c:784
@@ -14722,7 +14722,7 @@
#: ../misc/m.nviz.image/args.c:783
#, fuzzy
msgid "Fringe elevation"
#: ../misc/m.nviz.image/args.c:796
msgid ""
@@ -14804,7 +14804,7 @@
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:3
#, fuzzy
msgid "Input map is in Matlab format"
+msgstr "Îνομα ειÏαγÏμενοÏ
διανÏ
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη "
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:4
msgid "Create a 3D vector points map from 3 column Matlab data"
@@ -14813,14 +14813,14 @@
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:5
#, fuzzy
msgid "Name of input file in Mapgen/Matlab format"
διανÏ
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη "
#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:6
#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:10
#: ../locale/scriptstrings/v.in.garmin_to_translate.c:11
#, fuzzy
msgid "Name for output vector map (omit for display to stdout)"
-msgstr "¼íïìá åîáãüìåíïõ äéáíõóìáôéêïý ÷Üñôç"
+msgstr "Îνομα εξαγÏμενοÏ
διανÏ
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη"
#: ../locale/scriptstrings/d.split.frame_to_translate.c:1
msgid "Split the display into subframes."
@@ -14829,7 +14829,7 @@
#: ../locale/scriptstrings/d.split.frame_to_translate.c:2
#, fuzzy
msgid "Number of subframes"
ÏοÏεÏιοÏÏν για ÏÏ
Ïά"
#: ../locale/scriptstrings/d.split.frame_to_translate.c:3
msgid "Split horizontally not vertically"
@@ -14933,7 +14933,7 @@
#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:9
#, fuzzy
msgid "Name for output grid3D volume"
εξαγÏγήÏ"
#: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:10
#: ../locale/scriptstrings/r.mapcalculator_to_translate.c:10
@@ -14954,13 +14954,13 @@
msgid ""
"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
"points map."
+msgstr "ÎδÏ
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη"
#: ../locale/scriptstrings/v.in.gns_to_translate.c:2
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:2
#, fuzzy
msgid "vector, import, gazetteer"
-msgstr "ñÜóôåñ 3Ä, óôáôéóôéêÜ"
+msgstr "ÏάÏÏÎµÏ 3Î, ÏÏαÏιÏÏικά"
#: ../locale/scriptstrings/v.in.gns_to_translate.c:3
msgid "Uncompressed GNS file from NGA (with .txt extension)"
@@ -14974,7 +14974,7 @@
#: ../locale/scriptstrings/v.in.lines_to_translate.c:5
#: ../locale/scriptstrings/v.in.wfs_to_translate.c:4
msgid "Name for output vector map"
διανÏ
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη"
#: ../locale/scriptstrings/v.colors_to_translate.c:1
msgid ""
@@ -14983,7 +14983,7 @@
#: ../locale/scriptstrings/v.colors_to_translate.c:2
msgid "vector, color table"
+msgstr "διάνÏ
#: ../locale/scriptstrings/v.colors_to_translate.c:3
#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:6
@@ -14992,22 +14992,22 @@
#: ../locale/scriptstrings/v.centroids_to_translate.c:3
#: ../vector/v.hull/main.c:278
msgid "Name of input vector map"
διανÏ
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη "
#: ../locale/scriptstrings/v.colors_to_translate.c:4
#, fuzzy
msgid "Name of column containing numeric data"
+msgstr "Îνομα ÏοÏ
αÏÏείοÏ
ÏοÏ
ÏεÏιÎÏει Ï
#: ../locale/scriptstrings/v.colors_to_translate.c:5
#, fuzzy
msgid "Layer number of data column"
-msgstr "Íïýìåñï åðéðÝäïõ"
+msgstr "ÎοÏμεÏο εÏιÏÎδοÏ
#: ../locale/scriptstrings/v.colors_to_translate.c:6
#, fuzzy
msgid "Name of color column to populate"
εξαγÏγήÏ"
#: ../locale/scriptstrings/v.colors_to_translate.c:8
msgid "Manually set range (min,max)"
@@ -15016,7 +15016,7 @@
#: ../locale/scriptstrings/v.colors_to_translate.c:13
#, fuzzy
msgid "Path to rules file"
-msgstr "Áäõíáìßá áíïßãìáôïò ôïõ ÷Üñôç raster <%s>"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï ÏοÏ
ÏάÏÏη raster <%s>"
#: ../locale/scriptstrings/v.colors_to_translate.c:15
msgid "Dummy raster map name containing color rules for use with d.legend"
@@ -15029,12 +15029,12 @@
#: ../locale/scriptstrings/v.colors_to_translate.c:18
#, fuzzy
msgid "Save placeholder raster map for use with d.legend"
-msgstr "×ñþìá"
+msgstr "ΧÏÏμα"
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:1
#, fuzzy
msgid "Removes existing attribute table of a vector map."
+msgstr "ÎδÏ
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη"
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:2
#: ../locale/scriptstrings/v.db.join_to_translate.c:2
@@ -15058,17 +15058,17 @@
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:4
#, fuzzy
msgid "Vector map from which to remove attribute table"
-msgstr "âÜóç äåäïìÝíùí, ðßíáêáò éäéïôÞôùí"
+msgstr "βάÏη δεδομÎνÏν, ÏÎ¯Î½Î±ÎºÎ±Ï Î¹Î´Î¹Î¿ÏήÏÏν"
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:5
#, fuzzy
msgid "Name of existing attribute table (default: vector map name)"
-msgstr "¼íïìá õðÜñ÷ïíôùò 3Ä ñÜóôåñ ÷Üñôç"
+msgstr "Îνομα Ï
ÏάÏÏονÏÏÏ 3Î ÏάÏÏÎµÏ ÏάÏÏη"
#: ../locale/scriptstrings/v.db.droptable_to_translate.c:6
#, fuzzy
msgid "Layer from which to drop linked attribute table"
#: ../locale/scriptstrings/d.shadedmap_to_translate.c:1
msgid "Drapes a color raster over a shaded relief map using d.his."
@@ -15077,12 +15077,12 @@
#: ../locale/scriptstrings/d.shadedmap_to_translate.c:2
#, fuzzy
msgid "Name of shaded relief or aspect map"
ÏοβάθÏοÏ
ÏάÏÏεÏ"
#: ../locale/scriptstrings/d.shadedmap_to_translate.c:3
#, fuzzy
msgid "Name of raster to drape over relief map"
ÏοβάθÏοÏ
ÏάÏÏεÏ"
#: ../locale/scriptstrings/d.shadedmap_to_translate.c:4
msgid "Percent to brighten"
@@ -15098,7 +15098,7 @@
msgid ""
"Calculates univariate statistics on selected table column for a GRASS vector "
"map."
-msgstr "ÐáñÜãåé óôáôéóôéêÜ üãêïõ ãéá 3Ä ñÜóôåñ ÷Üñôåò."
+msgstr "ΠαÏάγει ÏÏαÏιÏÏικά ÏγκοÏ
για 3Î ÏάÏÏÎµÏ ÏάÏÏεÏ."
#: ../locale/scriptstrings/v.db.univar_to_translate.c:2
#: ../locale/scriptstrings/v.univar.sh_to_translate.c:2
@@ -15118,7 +15118,7 @@
#: ../locale/scriptstrings/v.univar.sh_to_translate.c:4
#, fuzzy
msgid "Name of data table"
+msgstr "ÎδÏ
#: ../locale/scriptstrings/v.db.univar_to_translate.c:5
#: ../locale/scriptstrings/v.univar.sh_to_translate.c:5
@@ -15134,7 +15134,7 @@
#: ../locale/scriptstrings/v.univar.sh_to_translate.c:7
#, fuzzy
msgid "Database driver"
Ï ÏοÏ
#: ../locale/scriptstrings/v.db.univar_to_translate.c:8
#: ../locale/scriptstrings/v.univar.sh_to_translate.c:8
@@ -15146,17 +15146,17 @@
#: ../locale/scriptstrings/v.db.join_to_translate.c:1
#, fuzzy
msgid "Joins a database table to a vector map table."
+msgstr "ÎδÏ
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη"
#: ../locale/scriptstrings/v.db.join_to_translate.c:3
#, fuzzy
msgid "Vector map to which to join other table"
#: ../locale/scriptstrings/v.db.join_to_translate.c:4
#, fuzzy
msgid "Layer where to join"
#: ../locale/scriptstrings/v.db.join_to_translate.c:5
msgid "Join column in map table"
@@ -15165,12 +15165,12 @@
#: ../locale/scriptstrings/v.db.join_to_translate.c:6
#, fuzzy
msgid "Other table name"
#: ../locale/scriptstrings/v.db.join_to_translate.c:7
#, fuzzy
msgid "Join column in other table"
-msgstr "Áñéèìüò ãñáììþí ðïõ èá åìöáíßæïíôáé óôï õðüìíçìá."
+msgstr "ÎÏιθμÏÏ Î³ÏαμμÏν ÏοÏ
θα εμÏανίζονÏαι ÏÏο Ï
ÏÏμνημα."
#: ../locale/scriptstrings/v.convert.all_to_translate.c:1
msgid ""
@@ -15192,7 +15192,7 @@
#: ../locale/scriptstrings/v.in.garmin_to_translate.c:2
#, fuzzy
msgid "vector, import, GPS"
-msgstr "raster3d, voxel, åéóÜãåôáé"
+msgstr "raster3d, voxel, ειÏάγεÏαι"
#: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:4
msgid "Import waypoints"
@@ -15247,7 +15247,7 @@
#: ../locale/scriptstrings/r.in.srtm_to_translate.c:4
#, fuzzy
msgid "Output raster map (default: input tile)"
-msgstr "¼íïìá åîáãüìåíïõ ñÜóôåñ ÷Üñôç"
ÏάÏÏÎµÏ ÏάÏÏη"
#: ../locale/scriptstrings/r.in.srtm_to_translate.c:5
msgid "Input is a 1-arcsec tile (default: 3-arcsec)"
@@ -15269,7 +15269,7 @@
#: ../locale/scriptstrings/i.spectral_to_translate.c:4
#, fuzzy
msgid "Raster input maps"
+msgstr "ÎδÏ
ÏάÏÏη input"
#: ../locale/scriptstrings/i.spectral_to_translate.c:5
msgid "Write output to PNG image"
@@ -15286,7 +15286,7 @@
#: ../locale/scriptstrings/i.spectral_to_translate.c:8
#, fuzzy
msgid "Show pick coordinates instead of numbering in the legend"
-msgstr "×ñçóéìïðïéÞóôå óõíôåôáãìÝíåò ÷Üñôç áíôß ÷øæ óõíôåôáãìÝíåò"
+msgstr "ΧÏηÏιμοÏοιήÏÏε ÏÏ
νÏεÏαγμÎÎ½ÎµÏ ÏάÏÏη ανÏί ÏÏζ ÏÏ
νÏεÏαγμÎνεÏ"
#: ../locale/scriptstrings/d.redraw_to_translate.c:1
msgid "Redraws the current display frame in the GRASS monitor"
@@ -15329,7 +15329,7 @@
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:1
#, fuzzy
msgid "Imports geonames.org country files into a GRASS vector points map."
+msgstr "ÎδÏ
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη"
#: ../locale/scriptstrings/v.in.geonames_to_translate.c:3
msgid "Uncompressed geonames file from (with .txt extension)"
@@ -15342,7 +15342,7 @@
#: ../locale/scriptstrings/db.out.ogr_to_translate.c:3
#, fuzzy
msgid "GRASS table name"
#: ../locale/scriptstrings/db.out.ogr_to_translate.c:4
msgid "Table file to be exported or DB connection string"
@@ -15351,23 +15351,23 @@
#: ../locale/scriptstrings/db.out.ogr_to_translate.c:5
#, fuzzy
msgid "Table format"
+msgstr "ÎδÏ
#: ../locale/scriptstrings/db.out.ogr_to_translate.c:6
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:5
msgid "Name for output table"
-msgstr "¼íïìá ðßíáêá åîáãùãÞò"
+msgstr "Îνομα Ïίνακα εξαγÏγήÏ"
#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:1
#, fuzzy
msgid "Import of SPOT VGT NDVI file into a raster map"
+msgstr "ÎδÏ
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη"
#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:2
#: ../locale/scriptstrings/r.in.aster_to_translate.c:2
#, fuzzy
msgid "raster, imagery, import"
#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:3
msgid "Also import quality map (SM status map layer) and filter NDVI map"
@@ -15384,17 +15384,17 @@
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:2
#, fuzzy
msgid "raster, elevation, interpolation"
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:3
#, fuzzy
msgid "Name of input raster map in which to fill nulls"
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:4
#, fuzzy
msgid "Name for output raster map with nulls filled by interpolation"
-msgstr "¼íïìá åîáãüìåíïõ ñÜóôåñ ÷Üñôç (saturation)"
ÏάÏÏÎµÏ ÏάÏÏη (saturation)"
#: ../locale/scriptstrings/r.fillnulls_to_translate.c:5
msgid "Spline tension parameter"
@@ -15412,7 +15412,7 @@
#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:2
#, fuzzy
msgid "sites, vector, import"
#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:3
msgid "Run non-interactively"
@@ -15425,7 +15425,7 @@
#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:2
#, fuzzy
msgid "raster, imagery, colors"
#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:3
msgid "LANDSAT red channel"
@@ -15463,7 +15463,7 @@
#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:2
#, fuzzy
msgid "vector, export, GPS"
#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:3
msgid "Export as waypoints"
@@ -15480,12 +15480,12 @@
#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:7
#, fuzzy
msgid "Feature type(s)"
+msgstr "ÎδÏ
#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:8
#, fuzzy
msgid "Name for output file or GPS device"
εξαγÏγήÏ"
#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:9
msgid "GpsBabel supported output format"
@@ -15497,7 +15497,7 @@
#: ../locale/scriptstrings/v.centroids_to_translate.c:6
#: ../vector/v.out.vtk/main.c:83
msgid "Layer number"
#: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:11
#: ../locale/scriptstrings/v.db.addcol_to_translate.c:5
@@ -15526,7 +15526,7 @@
#: ../locale/scriptstrings/d.polar_to_translate.c:3
msgid "Name of raster angle map"
-msgstr "¼íïìá ÷Üñôç ñÜóôåñ ãùíßáò"
+msgstr "Îνομα ÏάÏÏη ÏάÏÏÎµÏ Î³ÏνίαÏ"
#: ../locale/scriptstrings/d.polar_to_translate.c:4
msgid "Pixel value to be interpreted as undefined (different from NULL)"
@@ -15534,7 +15534,7 @@
#: ../locale/scriptstrings/d.polar_to_translate.c:5
msgid "Name of optional EPS output file"
-msgstr "¼íïìá áñ÷åßïõ åîáãùãÞò EPS"
εξαγÏÎ³Î®Ï EPS"
#: ../locale/scriptstrings/d.polar_to_translate.c:6
msgid "Plot using Xgraph"
@@ -15545,17 +15545,17 @@
msgid ""
"Adds one or more columns to the attribute table connected to a given vector "
"map."
+msgstr "ÎδÏ
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη"
#: ../locale/scriptstrings/v.db.addcol_to_translate.c:3
#, fuzzy
msgid "Name of vector map for which to edit attribute table"
#: ../locale/scriptstrings/v.db.addcol_to_translate.c:4
#, fuzzy
msgid "Layer number where to add column(s)"
#: ../locale/scriptstrings/v.db.addcol_to_translate.c:6
msgid "Name and type of the new column(s) ('name type [,name type, ...]')"
@@ -15570,17 +15570,17 @@
#: ../locale/scriptstrings/db.dropcol_to_translate.c:1
#, fuzzy
msgid "Drops a column from selected attribute table"
-msgstr "äéáãñáöÞ åíüò ðßíáêá éäéïôÞôùí."
+msgstr "διαγÏαÏή ενÏÏ Ïίνακα ιδιοÏήÏÏν."
#: ../locale/scriptstrings/db.dropcol_to_translate.c:4
#, fuzzy
msgid "Table from which to drop attribute column"
+msgstr "ÎδÏ
#: ../locale/scriptstrings/db.dropcol_to_translate.c:5
#, fuzzy
msgid "Name of the column"
#: ../locale/scriptstrings/i.tasscap_to_translate.c:1
msgid "Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data"
@@ -15589,7 +15589,7 @@
#: ../locale/scriptstrings/i.tasscap_to_translate.c:2
#, fuzzy
msgid "raster, imagery"
#: ../locale/scriptstrings/i.tasscap_to_translate.c:3
msgid "use transformation rules for LANDSAT-4"
@@ -15606,37 +15606,37 @@
#: ../locale/scriptstrings/i.tasscap_to_translate.c:6
#, fuzzy
msgid "raster input map (LANDSAT channel 1)"
-msgstr "Áäõíáìßá êëåéóßìáôïò ôïõ ÷Üñôç input."
+msgstr "ÎδÏ
ÏάÏÏη input."
#: ../locale/scriptstrings/i.tasscap_to_translate.c:7
#, fuzzy
msgid "raster input map (LANDSAT channel 2)"
+msgstr "ÎδÏ
ÏάÏÏη input."
#: ../locale/scriptstrings/i.tasscap_to_translate.c:8
#, fuzzy
msgid "raster input map (LANDSAT channel 3)"
+msgstr "ÎδÏ
ÏάÏÏη input."
#: ../locale/scriptstrings/i.tasscap_to_translate.c:9
#, fuzzy
msgid "raster input map (LANDSAT channel 4)"
+msgstr "ÎδÏ
ÏάÏÏη input."
#: ../locale/scriptstrings/i.tasscap_to_translate.c:10
#, fuzzy
msgid "raster input map (LANDSAT channel 5)"
+msgstr "ÎδÏ
ÏάÏÏη input."
#: ../locale/scriptstrings/i.tasscap_to_translate.c:11
#, fuzzy
msgid "raster input map (LANDSAT channel 7)"
+msgstr "ÎδÏ
ÏάÏÏη input."
#: ../locale/scriptstrings/i.tasscap_to_translate.c:12
#, fuzzy
msgid "raster output TC maps prefix"
+msgstr "ÎδÏ
ÏάÏÏη input."
#: ../locale/scriptstrings/r.pack_to_translate.c:1
msgid "Packs up a raster map and support files for copying."
@@ -15646,22 +15646,22 @@
#: ../locale/scriptstrings/r.unpack_to_translate.c:2
#, fuzzy
msgid "raster, copying"
#: ../locale/scriptstrings/r.pack_to_translate.c:3
#, fuzzy
msgid "Name of raster map to pack up"
-msgstr "×ñþìá"
+msgstr "ΧÏÏμα"
#: ../locale/scriptstrings/r.pack_to_translate.c:4
#, fuzzy
msgid "Name for output file (default is input-map.pack)"
διανÏ
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη"
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:1
#, fuzzy
msgid "Imports attribute tables in various formats."
+msgstr "ÎδÏ
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη"
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:3
msgid "Table file to be imported or DB connection string"
@@ -15674,7 +15674,7 @@
#: ../locale/scriptstrings/db.in.ogr_to_translate.c:6
#, fuzzy
msgid "Name for auto-generated unique key column"
-msgstr "×ñþìá"
+msgstr "ΧÏÏμα"
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:1
msgid ""
@@ -15685,17 +15685,17 @@
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:3
#, fuzzy
msgid "Vector map for which to add new attribute table"
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:4
#, fuzzy
msgid "Name of new attribute table (default: vector map name)"
+msgstr "Îνομα Ï
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:5
#, fuzzy
msgid "Layer where to add new attribute table"
#: ../locale/scriptstrings/v.db.addtable_to_translate.c:6
msgid ""
@@ -15706,7 +15706,7 @@
#: ../locale/scriptstrings/v.in.e00_to_translate.c:1
#, fuzzy
msgid "Import E00 file into a vector map."
+msgstr "ÎδÏ
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη"
#: ../locale/scriptstrings/v.in.e00_to_translate.c:4
msgid "E00 file"
@@ -15799,7 +15799,7 @@
#: ../locale/scriptstrings/r.tileset_to_translate.c:2
#, fuzzy
msgid "raster, tiling"
#: ../locale/scriptstrings/r.tileset_to_translate.c:3
msgid "Produces shell script output"
@@ -15830,7 +15830,7 @@
#: ../locale/scriptstrings/r.tileset_to_translate.c:10
#, fuzzy
msgid "Maximum number of columns for a tile in the source projection"
#: ../locale/scriptstrings/r.tileset_to_translate.c:11
msgid "Maximum number of rows for a tile in the source projection"
@@ -15848,12 +15848,12 @@
#: ../locale/scriptstrings/v.report_to_translate.c:1
#, fuzzy
msgid "Reports geometry statistics for vectors."
#: ../locale/scriptstrings/v.report_to_translate.c:2
#, fuzzy
msgid "vector, report, statistics"
#: ../locale/scriptstrings/v.report_to_translate.c:3
msgid "Reverse sort the result"
@@ -15880,7 +15880,7 @@
#: ../locale/scriptstrings/v.dissolve_to_translate.c:2
#, fuzzy
msgid "vector, area, dissolve"
#: ../locale/scriptstrings/v.dissolve_to_translate.c:5
msgid "Layer number. If -1, all layers are extracted."
@@ -15889,7 +15889,7 @@
#: ../locale/scriptstrings/v.dissolve_to_translate.c:7
#, fuzzy
msgid "Name of column used to dissolve common boundaries"
-msgstr "¼íïìá ôïõ äåýôåñïõ ñÜóôåñ ÷Üñôç ãéá blending"
+msgstr "Îνομα ÏοÏ
δεÏÏεÏοÏ
ÏάÏÏÎµÏ ÏάÏÏη για blending"
#: ../locale/scriptstrings/r.mask_to_translate.c:1
msgid "Creates a MASK for limiting raster operation."
@@ -15898,7 +15898,7 @@
#: ../locale/scriptstrings/r.mask_to_translate.c:2
#, fuzzy
msgid "raster, mask"
#: ../locale/scriptstrings/r.mask_to_translate.c:3
msgid "Raster map to use as MASK"
@@ -15923,7 +15923,7 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:1
#, fuzzy
msgid "Displays thematic vector map"
+msgstr "ÎδÏ
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:2
msgid "display, vector, thematic, legend"
@@ -15956,12 +15956,12 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:8
#, fuzzy
msgid "Name of attribute column to use for thematic display (must be numeric)"
+msgstr "Îνομα ÏοÏ
δεÏÏεÏοÏ
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:10
#, fuzzy
msgid "Type of thematic display"
-msgstr "Ôýðïò"
+msgstr "ΤÏÏοÏ"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:12
msgid "Thematic divisions of data for display"
@@ -15994,7 +15994,7 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:26
#, fuzzy
msgid "Number of classes for interval theme (integer)"
ÏÏμνημα."
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:27
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:30
@@ -16006,22 +16006,22 @@
#: ../display/d.grid/main.c:82 ../display/d.grid/main.c:87
#: ../display/d.grid/main.c:93
msgid "Color"
-msgstr "×ñþìá"
+msgstr "ΧÏÏμα"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:28
#, fuzzy
msgid "Color scheme for graduated color mapping"
-msgstr "×ñþìá"
+msgstr "ΧÏÏμα"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:29
#, fuzzy
msgid "Select 'single_color' for graduated point/line display"
-msgstr "×ñþìá"
+msgstr "ΧÏÏμα"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:31
#, fuzzy
msgid "Color for graduated points map"
-msgstr "×ñþìá"
+msgstr "ΧÏÏμα"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:32
msgid "GRASS named color or R:G:B triplet. Set color scheme to single color"
@@ -16030,7 +16030,7 @@
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:34
#, fuzzy
msgid "Color for graduated lines or point/area outlines"
-msgstr "×ñþìá"
+msgstr "ΧÏÏμα"
#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:35
msgid "GRASS named color or R:G:B triplet. Set color scheme to single color."
@@ -16114,7 +16114,7 @@
#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:2
#, fuzzy
msgid "raster, imagery, mosaicking"
#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:3
msgid "1st map for mosaic (top of image stack)."
@@ -16267,12 +16267,12 @@
#: ../locale/scriptstrings/v.db.update_to_translate.c:1
#, fuzzy
msgid "Updates a column in the attribute table connected to a vector map."
+msgstr "ÎδÏ
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη"
#: ../locale/scriptstrings/v.db.update_to_translate.c:3
#, fuzzy
msgid "Vector map to edit the attribute table for"
#: ../locale/scriptstrings/v.db.update_to_translate.c:4
msgid "Layer to which the table to be changed is connected"
@@ -16281,7 +16281,7 @@
#: ../locale/scriptstrings/v.db.update_to_translate.c:5
#, fuzzy
msgid "Column to update"
θα ειÏαÏθεί"
#: ../locale/scriptstrings/v.db.update_to_translate.c:6
msgid "Literal value to update the column with"
@@ -16294,7 +16294,7 @@
#: ../locale/scriptstrings/v.db.update_to_translate.c:8
#, fuzzy
msgid "Name of attribute column to query"
#: ../locale/scriptstrings/v.db.update_to_translate.c:9
msgid "Can be a combination of columns, e.g. col1+col2"
@@ -16308,12 +16308,12 @@
#: ../locale/scriptstrings/db.droptable_to_translate.c:1
msgid "Drops an attribute table."
#: ../locale/scriptstrings/db.droptable_to_translate.c:4
#, fuzzy
msgid "Table to drop"
-msgstr "Áäõíáìßá áíïßãìáôïò âÜóçò äåäïìåíùí <%s>"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï Î²Î¬ÏÎ·Ï Î´ÎµÎ´Î¿Î¼ÎµÎ½Ïν <%s>"
#: ../locale/scriptstrings/m.proj_to_translate.c:1
msgid "Convert coordinates from one projection to another (cs2cs frontend)."
@@ -16334,12 +16334,12 @@
#: ../locale/scriptstrings/m.proj_to_translate.c:20
#, fuzzy
msgid "Files & format"
+msgstr "ÎδÏ
#: ../locale/scriptstrings/m.proj_to_translate.c:5
#, fuzzy
msgid "Output coordinate file (omit to send to stdout)"
διανÏ
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη"
#: ../locale/scriptstrings/m.proj_to_translate.c:9
msgid "Input projection parameters (PROJ.4 style)"
@@ -16383,22 +16383,22 @@
#, fuzzy
msgid ""
"Drops a column from the attribute table connected to a given vector map."
+msgstr "ÎδÏ
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη"
#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:3
#, fuzzy
msgid "Vector map for which to drop attribute column"
#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:4
#, fuzzy
msgid "Layer where to drop column"
#: ../locale/scriptstrings/v.db.dropcol_to_translate.c:5
#, fuzzy
msgid "Name of the column to drop"
#: ../locale/scriptstrings/d.m_to_translate.c:1
msgid "Display manager for GRASS"
@@ -16406,7 +16406,7 @@
#: ../locale/scriptstrings/d.m_to_translate.c:2
msgid "Name of .dmrc settings file"
-msgstr "¼íïìá áñ÷åßïõ .dmrc"
.dmrc"
#: ../locale/scriptstrings/r.in.aster_to_translate.c:1
msgid ""
@@ -16449,21 +16449,21 @@
#: ../locale/scriptstrings/d.rast.leg_to_translate.c:6
#, fuzzy
msgid "Name of raster map to display"
-msgstr "×ñþìá"
+msgstr "ΧÏÏμα"
#: ../locale/scriptstrings/d.rast.leg_to_translate.c:7
msgid "Number of lines to appear in the legend"
ÏÏμνημα."
#: ../locale/scriptstrings/d.rast.leg_to_translate.c:8
#, fuzzy
msgid "Name of raster map to generate legend from"
-msgstr "×ñþìá"
+msgstr "ΧÏÏμα"
#: ../locale/scriptstrings/d.rast.leg_to_translate.c:9
#, fuzzy
msgid "Name of raster map to print in legend"
-msgstr "×ñþìá"
+msgstr "ΧÏÏμα"
#: ../locale/scriptstrings/d.rast.leg_to_translate.c:10
msgid "Position of vertical map-legend separator (in percent)"
@@ -16478,7 +16478,7 @@
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:2
#, fuzzy
msgid "vector, raster, statistics"
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:3
msgid "Continue if upload column(s) already exist"
@@ -16487,7 +16487,7 @@
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:5
#, fuzzy
msgid "Name of vector polygon map"
-msgstr "¼íïìá åéóáãþìåíùí ñÜóôåñ ÷áñôþí"
+msgstr "Îνομα ειÏαγÏμενÏν ÏάÏÏÎµÏ ÏαÏÏÏν"
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:6
msgid ""
@@ -16498,12 +16498,12 @@
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:7
#, fuzzy
msgid "Name of raster map to calculate statistics from"
ÏοÏεÏιοÏÏν για ÏÏ
Ïά"
#: ../locale/scriptstrings/v.rast.stats_to_translate.c:8
#, fuzzy
msgid "Column prefix for new attribute columns"
+msgstr "ÎδÏ
#: ../locale/scriptstrings/d.split_to_translate.c:1
msgid ""
@@ -16540,7 +16540,7 @@
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:2
#, fuzzy
msgid "raster, statistics, aggregation"
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:5
msgid "Lesser value option that sets the <= area size limit [hectares]"
@@ -16562,7 +16562,7 @@
#: ../locale/scriptstrings/v.what.vect_to_translate.c:3
#, fuzzy
msgid "Vector map to modify"
θα ειÏαÏθεί"
#: ../locale/scriptstrings/v.what.vect_to_translate.c:4
msgid "Layer in the vector to be modified"
@@ -16575,17 +16575,17 @@
#: ../locale/scriptstrings/v.what.vect_to_translate.c:6
#, fuzzy
msgid "Vector map to be queried"
θα ειÏαÏθεί"
#: ../locale/scriptstrings/v.what.vect_to_translate.c:7
#, fuzzy
msgid "Layer of the query vector containing data"
ÏάÏÏÎµÏ ÏάÏÏη"
#: ../locale/scriptstrings/v.what.vect_to_translate.c:8
#, fuzzy
msgid "Column to be queried"
θα ειÏαÏθεί"
#: ../locale/scriptstrings/v.what.vect_to_translate.c:9
msgid "Maximum query distance in map units"
@@ -16598,7 +16598,7 @@
#: ../locale/scriptstrings/gis.m_to_translate.c:2
#, fuzzy
msgid "Name of GIS manager settings file (.grc)"
+msgstr "Îνομα αÏÏείοÏ
.dmrc"
#: ../locale/scriptstrings/d.out.gpsdrive_to_translate.c:1
msgid "Export display monitor to a GpsDrive compatible backdrop image"
@@ -16607,7 +16607,7 @@
#: ../locale/scriptstrings/d.out.gpsdrive_to_translate.c:2
#, fuzzy
msgid "display, export, GPS"
#: ../locale/scriptstrings/d.out.gpsdrive_to_translate.c:3
msgid "name for new map image (lives in ~/.gpsdrive/maps/)"
@@ -16648,7 +16648,7 @@
#: ../locale/scriptstrings/d.slide.show_to_translate.c:8
#, fuzzy
msgid "Number of seconds to pause between slides"
ÏÏμνημα."
#: ../locale/scriptstrings/v.build.all_to_translate.c:1
msgid "Rebuilds topology on all vector maps in the current mapset."
@@ -16666,7 +16666,7 @@
#: ../locale/scriptstrings/v.centroids_to_translate.c:2
#, fuzzy
msgid "vector, centroid, area"
-msgstr "äéÜíõóìá, ðßíáêáò ÷ñùìÜôùí"
+msgstr "διάνÏ
Ïμα, ÏÎ¯Î½Î±ÎºÎ±Ï ÏÏÏμάÏÏν"
#: ../locale/scriptstrings/v.centroids_to_translate.c:5
msgid "Action to be taken"
@@ -16692,7 +16692,7 @@
#: ../locale/scriptstrings/v.in.lines_to_translate.c:4
#, fuzzy
msgid "Name of input file (or \"-\" to read from stdin)"
διανÏ
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη "
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:1
msgid ""
@@ -16724,23 +16724,23 @@
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:9
#, fuzzy
msgid "Name of input raster map (green: tm2 | qbird_green | spot1)"
-msgstr "¼íïìá åéóáãþìåíïõ ñÜóôåñ ÷Üñôç (NIR: tm4 | qbird_nir | spot2"
ÏάÏÏÎµÏ ÏάÏÏη (NIR: tm4 | qbird_nir | spot2"
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:10
msgid "Name of input raster map (NIR: tm4 | qbird_nir | spot2)"
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:11
msgid "Name of input raster map (MIR; tm5 | qbird_red | spot3)"
-msgstr "¼íïìá åéóáãþìåíïõ ñÜóôåñ ÷Üñôç (MIR; tm5 | qbird_red | spot3)"
ÏάÏÏÎµÏ ÏάÏÏη (MIR; tm5 | qbird_red | spot3)"
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:12
msgid "Name of input raster map (etmpan | qbird_pan | spotpan)"
-msgstr "¼íïìá åéóáãþìåíïõ ñÜóôåñ ÷Üñôç (etmpan | qbird_pan | spotpan)"
ÏάÏÏÎµÏ ÏάÏÏη (etmpan | qbird_pan | spotpan)"
#: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:13
msgid "Name for output raster map prefix (e.g. 'brov')"
-msgstr "¼íïìá åîáãüìåíïõ ñÜóôåñ ÷Üñôç prefix (e.g. 'brov')"
ÏάÏÏÎµÏ ÏάÏÏη prefix (e.g. 'brov')"
#: ../locale/scriptstrings/i.oif_to_translate.c:1
msgid "Calculates Optimum-Index-Factor table for LANDSAT TM bands 1-5, & 7"
@@ -16749,7 +16749,7 @@
#: ../locale/scriptstrings/i.oif_to_translate.c:2
#, fuzzy
msgid "raster, imagery, statistics"
#: ../locale/scriptstrings/i.oif_to_translate.c:3
msgid "LANDSAT TM band 1."
@@ -16782,14 +16782,14 @@
#: ../locale/scriptstrings/d.correlate_to_translate.c:2
#, fuzzy
msgid "display, correlation, scatterplot"
#: ../locale/scriptstrings/d.correlate_to_translate.c:3
#: ../locale/scriptstrings/d.correlate_to_translate.c:4
#: ../locale/scriptstrings/d.correlate_to_translate.c:5
#: ../locale/scriptstrings/d.correlate_to_translate.c:6
msgid "raster input map"
+msgstr "ÎδÏ
ÏάÏÏη input."
#: ../locale/scriptstrings/d.correlate_to_translate.c:7
msgid "Draw a trend line and calculate linear regression formula"
@@ -16846,7 +16846,7 @@
#: ../locale/scriptstrings/r.univar.sh_to_translate.c:1
#, fuzzy
msgid "calculates univariate statistics from a GRASS raster map"
#: ../locale/scriptstrings/r.univar.sh_to_translate.c:3
msgid "extended statistics (quartiles and percentile)"
@@ -16868,7 +16868,7 @@
#: ../locale/scriptstrings/v.in.wfs_to_translate.c:2
#, fuzzy
msgid "vector, import, wfs"
#: ../locale/scriptstrings/v.in.wfs_to_translate.c:3
msgid "GetFeature URL starting with 'http'"
@@ -16885,7 +16885,7 @@
#: ../locale/scriptstrings/d.out.png_to_translate.c:3
msgid "Name of PNG file"
-msgstr "¼íïìá áñ÷åßïõ PNG."
PNG."
#: ../locale/scriptstrings/d.out.png_to_translate.c:4
msgid "Resolution of output file (single=1, double=2, quad=4)"
@@ -16895,17 +16895,17 @@
#, fuzzy
msgid ""
"Renames a column in the attribute table connected to a given vector map."
-msgstr "Áäõíáìßá áíÜãíùóçò äéáíõóìáôéêïý ÷Üñôç"
+msgstr "ÎδÏ
ναμία ανάγνÏÏÎ·Ï Î´Î¹Î±Î½Ï
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη"
#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:3
#, fuzzy
msgid "Vector map for which to rename attribute column"
#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:4
#, fuzzy
msgid "Layer where to rename column"
#: ../locale/scriptstrings/v.db.renamecol_to_translate.c:5
msgid "Old and new name of the column (old,new)"
@@ -16921,11 +16921,11 @@
#: ../locale/scriptstrings/r.blend_to_translate.c:3
msgid "Name of first raster map for blending"
-msgstr "¼íïìá ôïõ ðñþôïõ ñÜóôåñ ÷Üñôç ãéá blending"
+msgstr "Îνομα ÏοÏ
ÏÏÏÏοÏ
#: ../locale/scriptstrings/r.blend_to_translate.c:4
msgid "Name of second raster map for blending"
+msgstr "Îνομα ÏοÏ
δεÏÏεÏοÏ
#: ../locale/scriptstrings/r.blend_to_translate.c:5
msgid "Base name for red, green and blue output maps containing the blend"
@@ -16934,7 +16934,7 @@
#: ../locale/scriptstrings/r.blend_to_translate.c:6
#, fuzzy
msgid "Percentage weight of first map for color blending"
+msgstr "Îνομα ÏοÏ
ÏÏÏÏοÏ
#: ../locale/scriptstrings/d.out.file_to_translate.c:1
msgid "Saves the contents of the active display monitor to a graphics file."
@@ -16942,7 +16942,7 @@
#: ../locale/scriptstrings/d.out.file_to_translate.c:3
msgid "Name for output file (do NOT add extension)"
#: ../locale/scriptstrings/d.out.file_to_translate.c:5
msgid "Dimensions of output file versus current window size"
@@ -16968,7 +16968,7 @@
#: ../locale/scriptstrings/d.out.file_to_translate.c:10
#, fuzzy
msgid "Compression for PNG files"
PNG."
#: ../locale/scriptstrings/d.out.file_to_translate.c:11
msgid "(0=none, 1=fastest, 9=most; lossless, only time vs. filesize)"
@@ -17034,7 +17034,7 @@
#: ../locale/scriptstrings/d.out.file_to_translate.c:33
#, fuzzy
msgid "Do not crop away margins"
-msgstr "Áäõíáìßá áíôéãñáöÞò ðßíáêá <%s>"
+msgstr "ÎδÏ
ναμία ανÏιγÏαÏÎ®Ï Ïίνακα <%s>"
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:1
msgid "Creates shaded relief map from an elevation map (DEM)."
@@ -17044,12 +17044,12 @@
#: ../locale/scriptstrings/r.plane_to_translate.c:2
#, fuzzy
msgid "raster, elevation"
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:4
#, fuzzy
msgid "Output shaded relief map name"
#: ../locale/scriptstrings/r.shaded.relief_to_translate.c:5
msgid "Altitude of the sun in degrees above the horizon"
@@ -17075,12 +17075,12 @@
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:1
#, fuzzy
msgid "Reconnects vectors to a new database."
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:3
#, fuzzy
msgid "Name of old database"
+msgstr "ÎδÏ
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:4
msgid ""
@@ -17091,17 +17091,17 @@
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:5
#, fuzzy
msgid "Name of new database"
+msgstr "ÎδÏ
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:6
#, fuzzy
msgid "Old schema"
#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:7
#, fuzzy
msgid "New schema"
#: ../locale/scriptstrings/r.plane_to_translate.c:1
msgid ""
@@ -17112,7 +17112,7 @@
#: ../locale/scriptstrings/r.plane_to_translate.c:3
#, fuzzy
msgid "Name of raster plane to be created"
-msgstr "Ascii ñÜóôåñ ÷Üñôçò ðïõ èá åéóá÷èåß"
+msgstr "Ascii ÏάÏÏÎµÏ ÏάÏÏÎ·Ï ÏοÏ
θα ειÏαÏθεί"
#: ../locale/scriptstrings/r.plane_to_translate.c:4
msgid "Dip of plane. Value must be between -90 and 90 degrees"
@@ -17137,7 +17137,7 @@
#: ../locale/scriptstrings/r.plane_to_translate.c:9
#, fuzzy
msgid "Type of the raster map to be created"
θα ειÏαÏθεί"
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:1
#: ../display/d.rast.edit/main.c:61
@@ -17154,7 +17154,7 @@
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:5
msgid "Name of aspect raster map"
-msgstr "¼íïìá ÷Üñôç "
+msgstr "Îνομα ÏάÏÏη "
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:6
msgid "Width of display canvas"
@@ -17166,17 +17166,17 @@
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:8
msgid "Minimum size of each cell"
-msgstr "ÅëÜ÷éóôï ìÝãåèïò êÜèå êåëéïý"
+msgstr "ÎλάÏιÏÏο μÎÎ³ÎµÎ¸Î¿Ï ÎºÎ¬Î¸Îµ κελιοÏ"
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:9
#, fuzzy
msgid "Maximum number of rows to load"
#: ../locale/scriptstrings/d.rast.edit_to_translate.c:10
#, fuzzy
msgid "Maximum number of columns to load"
#: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:1
msgid "Exports GRASS raster into GDAL supported formats."
@@ -17202,12 +17202,12 @@
#: ../locale/scriptstrings/r.unpack_to_translate.c:3
#, fuzzy
msgid "Name of input pack file"
-msgstr "¼íïìá åîáãþìåíïõ áñ÷åßïõ ðáñïõóßáóçò"
αÏÏείοÏ
ÏαÏοÏ
ÏίαÏηÏ"
#: ../locale/scriptstrings/r.unpack_to_translate.c:4
#, fuzzy
msgid "Name for output raster map (default: taken from input file internals)"
διανÏ
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη"
#: ../locale/scriptstrings/r.unpack_to_translate.c:5
msgid "Override projection check (use current location's projection)"
@@ -17425,7 +17425,7 @@
#: ../display/d.graph/main.c:71
#, fuzzy
msgid "Color to draw with, either a standard GRASS color or R:G:B triplet"
-msgstr "×ñþìá"
+msgstr "ΧÏÏμα"
#: ../display/d.graph/main.c:78
msgid "Coordinates are given in map units"
@@ -17539,7 +17539,7 @@
#: ../display/d.rhumbline/main.c:45 ../display/d.geodesic/main.c:45
#, fuzzy
msgid "display, distance"
#: ../display/d.rhumbline/main.c:47
msgid ""
@@ -17644,12 +17644,12 @@
#: ../display/d.legend/main.c:364 ../display/d.legend/main.c:522
#, fuzzy
msgid "Color range exceeds lower limit of actual data"
-msgstr "×ñþìá"
+msgstr "ΧÏÏμα"
#: ../display/d.legend/main.c:370 ../display/d.legend/main.c:526
#, fuzzy
msgid "Color range exceeds upper limit of actual data"
-msgstr "×ñþìá"
+msgstr "ΧÏÏμα"
#: ../display/d.legend/main.c:427
#, c-format
@@ -17681,7 +17681,7 @@
#: ../display/d.rgb/main.c:54
#, fuzzy
msgid "display, raster, RGB"
#: ../display/d.rgb/main.c:56
msgid ""
@@ -17705,7 +17705,7 @@
#: ../display/d.rgb/main.c:71
#, fuzzy, c-format
msgid "Name of raster map to be used for '%s'"
θα ειÏαÏθεί"
#: ../display/d.rgb/main.c:120
msgid "Error reading row of data"
@@ -17859,12 +17859,12 @@
#: ../display/d.linegraph/linegraph.c:139
msgid "Color for Y data"
-msgstr "×ñþìá ãéá äåäïìÝíá Õ"
+msgstr "ΧÏÏμα για δεδομÎνα Î¥"
#: ../display/d.linegraph/linegraph.c:148
#, fuzzy
msgid "Color for axis, tics, numbers, and title"
-msgstr "×ñþìá"
+msgstr "ΧÏÏμα"
#: ../display/d.linegraph/linegraph.c:156
msgid "Title for X data"
@@ -18120,14 +18120,14 @@
#: ../display/d.thematic.area/plot1.c:210 ../display/d.vect/plot1.c:222
#, fuzzy
msgid "Color definition column not specified"
-msgstr "×ñþìá"
+msgstr "ΧÏÏμα"
#: ../display/d.thematic.area/plot1.c:220
#, fuzzy, c-format
msgid ""
"Color definition column (%s) not a string. Column must be of form RRR:GGG:"
"BBB where RGB values range 0-255."
-msgstr "×ñþìá."
+msgstr "ΧÏÏμα."
#: ../display/d.thematic.area/plot1.c:238 ../display/d.vect/area.c:113
#: ../display/d.vect/plot1.c:261
@@ -18174,7 +18174,7 @@
msgid ""
"Color to erase with, either a standard GRASS color or R:G:B triplet "
"(separated by colons)"
-msgstr "×ñþìá"
+msgstr "ΧÏÏμα"
#: ../display/d.erase/main.c:62 ../display/d.colortable/main.c:147
#: ../display/d.measure/main.c:90
@@ -18223,7 +18223,7 @@
#: ../display/d.vect/main.c:126 ../display/d.vect/main.c:136
#: ../display/d.vect/main.c:239 ../display/d.vect/main.c:249
msgid "Either a standard GRASS color, R:G:B triplet, or \"none\""
-msgstr "Äþóôå Ýíá óôáíôáñ ÷ñþìá GRASS, óõíäõáóìü R:G:B Þ \"none\""
+msgstr "ÎÏÏÏε Îνα ÏÏανÏÎ±Ï ÏÏÏμα GRASS, ÏÏ
νδÏ
αÏÎ¼Ï R:G:B ή \"none\""
#: ../display/d.vect/main.c:132
msgid "Area fill color"
@@ -18236,7 +18236,7 @@
#: ../display/d.vect/main.c:149
#, fuzzy
msgid "Type of color table (for use with -z flag)"
-msgstr "Ôýðïò"
+msgstr "ΤÏÏοÏ"
#: ../display/d.vect/main.c:158 ../display/d.vect/main.c:163
#: ../display/d.vect/main.c:171
@@ -18275,12 +18275,12 @@
#: ../display/d.vect/main.c:199
#, fuzzy
msgid "Name of numeric column containing symbol size"
-msgstr "¼íïìá ôïõ áñ÷åßïõ ðïõ ðåñéÝ÷åé õðïãñáöÝò (signatures)"
+msgstr "Îνομα ÏοÏ
αÏÏείοÏ
ÏοÏ
ÏεÏιÎÏει Ï
ÏογÏαÏÎÏ (signatures)"
#: ../display/d.vect/main.c:205
#, fuzzy
msgid "Name of numeric column containing symbol rotation angle"
+msgstr "Îνομα ÏοÏ
αÏÏείοÏ
ÏοÏ
ÏεÏιÎÏει Ï
#: ../display/d.vect/main.c:207
msgid "Measured in degrees CCW from east"
@@ -18309,7 +18309,7 @@
#: ../display/d.vect/main.c:229
#, fuzzy
msgid "Either a standard color name or R:G:B triplet"
-msgstr "Åßôå Ýíá óôáíôáñ üíïìá ÷ñþìáôïò Þ óõíäõáóìüò R:G:B"
+msgstr "ÎίÏε Îνα ÏÏανÏÎ±Ï Ïνομα ÏÏÏμαÏÎ¿Ï Î® ÏÏ
νδÏ
αÏμÏÏ R:G:B"
#: ../display/d.vect/main.c:236
msgid "Label background color"
@@ -18427,7 +18427,7 @@
#: ../display/d.vect/area.c:72
#, fuzzy
msgid "Color definition column not specified."
-msgstr "×ñþìá."
+msgstr "ΧÏÏμα."
#: ../display/d.vect/area.c:83 ../display/d.vect/plot1.c:233
#, fuzzy, c-format
@@ -18435,7 +18435,7 @@
"Color definition column ('%s') not a string. Column must be of form 'RRR:GGG:"
"BBB' where RGB values range 0-255. You can use '%s' module to define color "
"rules. Unable to colorize features."
-msgstr "×ñþìá."
+msgstr "ΧÏÏμα."
#: ../display/d.vect/area.c:302
#, c-format
@@ -18456,7 +18456,7 @@
#: ../display/d.vect/plot1.c:304
#, fuzzy
msgid "Symbol size column not specified."
-msgstr "×ñþìá."
+msgstr "ΧÏÏμα."
#: ../display/d.vect/plot1.c:319
#, c-format
@@ -18466,7 +18466,7 @@
#: ../display/d.vect/plot1.c:347
#, fuzzy
msgid "Symbol rotation column not specified."
-msgstr "×ñþìá."
+msgstr "ΧÏÏμα."
#: ../display/d.vect/plot1.c:362
#, c-format
@@ -18476,14 +18476,14 @@
#: ../display/d.vect/plot1.c:388 ../display/d.vect/plot1.c:689
#, fuzzy
msgid "Unable to read symbol, unable to display points"
-msgstr "Áäõíáìßá áíÜãíùóçò áñ÷åßïõ ÷ñþìáôïò ãéá ôïí ñÜóôåñ ÷Üñôç <%s>"
+msgstr "ÎδÏ
ναμία ανάγνÏÏÎ·Ï Î±ÏÏείοÏ
ÏÏÏμαÏÎ¿Ï Î³Î¹Î± Ïον ÏάÏÏÎµÏ ÏάÏÏη <%s>"
#: ../display/d.vect/plot1.c:419 ../vector/v.label/main.c:297
#: ../vector/v.info/main.c:388 ../vector/v.label.sa/labels.c:147
#: ../vector/v.to.3d/trans3.c:82 ../vector/v.to.3d/trans2.c:81
#, fuzzy
msgid "Unable to read vector map"
+msgstr "ÎδÏ
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη"
#: ../display/d.vect/plot1.c:511
#, c-format
@@ -18516,7 +18516,7 @@
#: ../vector/v.in.db/main.c:163
#, fuzzy, c-format
msgid "Unable to open select cursor: '%s'"
-msgstr "Áäõíáìßá áíïßãìáôïò êÝñóïñá '%s'"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï ÎºÎÏÏοÏα '%s'"
#: ../display/d.vect/attr.c:129
#, c-format
@@ -18532,7 +18532,7 @@
#: ../display/d.geodesic/main.c:70
#, fuzzy
msgid "Text color or \"none\""
-msgstr "êáíÝíá"
+msgstr "κανÎνα"
#: ../display/d.where/main.c:42
msgid "display, position, querying"
@@ -18631,7 +18631,7 @@
#: ../display/d.colortable/main.c:68
#, fuzzy
msgid "Name of raster map whose color table is to be displayed"
θα ειÏαÏθεί"
#: ../display/d.colortable/main.c:76
msgid "Color of lines separating the colors of the color table"
@@ -18640,12 +18640,12 @@
#: ../display/d.colortable/main.c:82
#, fuzzy
msgid "Number of lines to appear in the color table"
ÏÏμνημα."
#: ../display/d.colortable/main.c:88
#, fuzzy
msgid "Number of columns to appear in the color table"
ÏÏμνημα."
#: ../display/d.colortable/main.c:93
msgid "Don't draw a collar showing the NULL color in FP maps"
@@ -18668,17 +18668,17 @@
#: ../display/d.colortable/main.c:141
#, fuzzy, c-format
msgid "R_color file for [%s] not available"
-msgstr "×ñþìá"
+msgstr "ΧÏÏμα"
#: ../display/d.colortable/main.c:143
#, fuzzy, c-format
msgid "Range file for [%s] not available"
-msgstr "×ñþìá"
+msgstr "ΧÏÏμα"
#: ../display/d.colortable/main.c:156
#, fuzzy
msgid "Data range is empty"
-msgstr "Áäõíáìßá äéáâÜóìáôïò åýñïõò fp ãéá ôïí ñáóôåñ ÷Üñôç <%s>"
+msgstr "ÎδÏ
ναμία διαβάÏμαÏÎ¿Ï ÎµÏÏοÏ
Ï fp για Ïον ÏαÏÏÎµÏ ÏάÏÏη <%s>"
#: ../display/d.mapgraph/main.c:50
msgid ""
@@ -18697,7 +18697,7 @@
msgid ""
"Color to draw with, either a standard GRASS color or R:G:B triplet "
-msgstr "×ñþìá"
+msgstr "ΧÏÏμα"
#: ../display/d.info/main.c:34 ../display/d.save/main.c:79
msgid "display, metadata"
@@ -18756,7 +18756,7 @@
#: ../display/d.profile/main.c:61
#, fuzzy
msgid "display, raster, profile"
#: ../display/d.profile/main.c:63
msgid "Interactive profile plotting utility with optional output."
@@ -18887,23 +18887,23 @@
#: ../display/d.rast.arrow/arrow.c:129
#, fuzzy
msgid "Type of existing raster aspect map"
-msgstr "Ôýðïò"
+msgstr "ΤÏÏοÏ"
#: ../display/d.rast.arrow/arrow.c:137
msgid "Color for drawing arrows"
-msgstr "×ñþìá ãéá ôïí ó÷åäéáóìü âåëþí"
+msgstr "ΧÏÏμα για Ïον ÏÏεδιαÏÎ¼Ï Î²ÎµÎ»Ïν"
#: ../display/d.rast.arrow/arrow.c:145
msgid "Color for drawing grid or \"none\""
-msgstr "×ñþìá "
+msgstr "ΧÏÏμα "
#: ../display/d.rast.arrow/arrow.c:153
msgid "Color for drawing X's (Null values)"
-msgstr "×ñþìá ãéá ôïí ó÷åäéáóìü ×'s (Null values)"
+msgstr "ΧÏÏμα για Ïον ÏÏεδιαÏÎ¼Ï Î§'s (Null values)"
#: ../display/d.rast.arrow/arrow.c:161
msgid "Color for showing unknown information"
-msgstr "×ñþìá ãéá ôçí áðåéêüíéóç Üãíùóôçò ðëçñïöïñßáò"
+msgstr "ΧÏÏμα για Ïην αÏεικÏνιÏη άγνÏÏÏÎ·Ï ÏληÏοÏοÏίαÏ"
#: ../display/d.rast.arrow/arrow.c:168
msgid "Draw arrow every Nth grid cell"
@@ -18958,7 +18958,7 @@
#: ../display/d.text.new/main.c:175
#, fuzzy
msgid "Text background color, either a standard GRASS color or R:G:B triplet"
-msgstr "êáíÝíá"
+msgstr "κανÎνα"
#: ../display/d.text.new/main.c:200 ../display/d.text.freetype/main.c:209
msgid "Text alignment"
@@ -19002,7 +19002,7 @@
#: ../display/d.text.new/main.c:345
msgid "Invalid coordinates"
-msgstr "ËÜèïò óõíôåôáãìÝíåò"
+msgstr "ÎÎ¬Î¸Î¿Ï ÏÏ
νÏεÏαγμÎνεÏ"
#: ../display/d.text.new/main.c:413
#, c-format
@@ -19040,7 +19040,7 @@
#: ../display/d.what.vect/what.c:237
#, fuzzy, c-format
msgid "Line: %d Type: %s Left: %d Right: %d "
-msgstr "Ôýðïò "
+msgstr "ΤÏÏÎ¿Ï "
#: ../display/d.what.vect/what.c:241 ../vector/v.what/what.c:169
#: ../vector/v.what/what.c:224
@@ -19319,7 +19319,7 @@
#: ../display/d.histogram/main.c:71
#, fuzzy
msgid "display, histogram, statistics"
#: ../display/d.histogram/main.c:73
msgid ""
@@ -19338,7 +19338,7 @@
#: ../display/d.histogram/main.c:90
#, fuzzy
msgid "Color for text and axes"
-msgstr "×ñþìá"
+msgstr "ΧÏÏμα"
#: ../display/d.histogram/main.c:98
msgid "Indicate if cell counts or map areas should be displayed"
@@ -19378,11 +19378,11 @@
#: ../display/d.rast.num/number.c:100
#, fuzzy
msgid "Color for drawing grid, or \"none\""
-msgstr "×ñþìá êáíÝíá"
+msgstr "ΧÏÏμα κανÎνα"
#: ../display/d.rast.num/number.c:110
msgid "Color for drawing text"
-msgstr "×ñþìá ãéá ôï êåßìåíï"
+msgstr "ΧÏÏμα για Ïο κείμενο"
#: ../display/d.rast.num/number.c:124
msgid "Get text color from cell color value"
@@ -19640,7 +19640,7 @@
#: ../display/d.menu/main.c:66
#, fuzzy
msgid "display, menu"
#: ../display/d.menu/main.c:68
msgid ""
@@ -19676,7 +19676,7 @@
#: ../display/d.his/main.c:65
#, fuzzy
msgid "display, color transformation"
#: ../display/d.his/main.c:67
msgid ""
@@ -19964,7 +19964,7 @@
#: ../display/d.measure/main.c:49
#, fuzzy
msgid "display, geometry"
#: ../display/d.measure/main.c:51
msgid ""
@@ -20028,7 +20028,7 @@
#: ../display/d.zoom/main.c:57
#, fuzzy
msgid "display, zoom"
#: ../display/d.zoom/main.c:59
msgid ""
@@ -20187,7 +20187,7 @@
#: ../raster3d/r3.cross.rast/main.c:270 ../raster3d/r3.mkdspf/main.c:75
#: ../raster3d/r3.to.rast/main.c:215 ../raster3d/r3.gwflow/main.c:169
msgid "raster3d, voxel"
#: ../raster3d/base/r3.timestamp.main.c:45
msgid "Print/add/remove a timestamp for a 3D raster map"
@@ -20199,7 +20199,7 @@
#: ../raster3d/base/r3.timestamp.main.c:59
msgid "Datetime, datetime1/datetime2, or none"
-msgstr "Datetime, datetime1/datetime2 Þ êáíÝíá"
+msgstr "Datetime, datetime1/datetime2 ή κανÎνα"
#: ../raster3d/base/r3.timestamp.main.c:74
#, c-format
@@ -20209,7 +20209,7 @@
#: ../raster3d/base/mask_functions.c:82
#, c-format
msgid "Adding rule: %lf - %lf"
-msgstr "Ðñüóèåóç êáíüíá: %lf - %lf"
+msgstr "Î ÏÏÏθεÏη κανÏνα: %lf - %lf"
#: ../raster3d/base/r3.mask.main.c:44
msgid "3D raster map with reference values"
@@ -20222,7 +20222,7 @@
#: ../raster3d/base/r3.mask.main.c:95
#, fuzzy
msgid "Unable to open 3D raster mask file"
+msgstr "ÎδÏ
ÏάÏÏη raster <%s>"
#: ../raster3d/base/r3.mask.main.c:124
msgid "makeMask: error flushing tiles in cube"
@@ -20235,12 +20235,12 @@
#: ../raster3d/base/r3.mask.main.c:137
#, fuzzy
msgid "Unable to close 3D raster mask file"
-msgstr "Áäõíáìßá êëåéóßìáôïò ôïõ ÷Üñôç åéóáãùãÞò"
+msgstr "ÎδÏ
ναμία κλειÏίμαÏÎ¿Ï ÏοÏ
ÏάÏÏη ειÏαγÏγήÏ"
#: ../raster3d/base/r3.mask.main.c:139
#, fuzzy, c-format
msgid "Unable to close raster map <%s>"
+msgstr "ÎδÏ
ÏάÏÏη raster <%s>"
#: ../raster3d/base/r3.mask.main.c:155
msgid "Establishes the current working 3D raster mask."
@@ -20283,22 +20283,22 @@
#: ../raster3d/base/r3.info.main.c:121
#, fuzzy, c-format
msgid "3D Raster map <%s> not found"
-msgstr "Ï 3Ä ÷Üñôçò raster <%s> äåí âñÝèçêå"
+msgstr "Î 3Î ÏάÏÏÎ·Ï raster <%s> δεν βÏÎθηκε"
#: ../raster3d/base/r3.info.main.c:287 ../raster3d/base/r3.info.main.c:349
#, fuzzy, c-format
msgid "Unable to read range of 3D raster map <%s>"
+msgstr "ÎδÏ
#: ../raster3d/base/r3.info.main.c:404
msgid "Error while reading history file"
-msgstr "ÓöÜëìá êáôÜ ôçí áíÜãíùóç ôïõ áñ÷åßïõ éóôïñéêïý"
+msgstr "ΣÏάλμα καÏά Ïην ανάγνÏÏη ÏοÏ
αÏÏείοÏ
ιÏÏοÏικοÏ"
#: ../raster3d/base/r3.info.main.c:425 ../raster3d/r3.cross.rast/main.c:404
#: ../raster3d/r3.out.vtk/errorHandling.c:67 ../raster3d/r3.gwflow/main.c:415
#, fuzzy, c-format
msgid "Unable to close 3D raster map <%s>"
+msgstr "ÎδÏ
ÏάÏÏη raster <%s>"
#: ../raster3d/base/r3.null.main.c:58
msgid "3d raster map for which to modify null values"
@@ -20310,7 +20310,7 @@
#: ../raster3d/base/r3.null.main.c:125
msgid "modifyNull: error opening tmp file"
-msgstr "modifyNull: óöÜëìá êáôÜ ôï Üíïéãìá ðñïóùñéíïý áñ÷åßïõ"
+msgstr "modifyNull: ÏÏάλμα καÏά Ïο άνοιγμα ÏÏοÏÏÏÎ¹Î½Î¿Ï Î±ÏÏείοÏ
#: ../raster3d/base/r3.null.main.c:174
msgid "modifyNull: error flushing tiles in cube"
@@ -20323,7 +20323,7 @@
#: ../raster3d/base/r3.null.main.c:190
#, fuzzy
msgid "modifyNull: Unable to close tmp file"
#: ../raster3d/base/r3.null.main.c:207
msgid "Explicitly create the 3D NULL-value bitmap file."
@@ -20337,28 +20337,28 @@
#: ../raster3d/r3.in.v5d/main.c:218
#, fuzzy
msgid "Unable to close 3D raster map"
+msgstr "ÎδÏ
ÏάÏÏη ειÏαγÏγήÏ"
#: ../raster3d/r3.cross.rast/main.c:77 ../raster3d/r3.cross.rast/main.c:392
#: ../raster3d/r3.to.rast/main.c:194
msgid "Unable to close output map"
-msgstr "Áäõíáìßá êëåéóßìáôïò ôïõ åîáãüìåíïõ ÷Üñôç"
+msgstr "ÎδÏ
εξαγÏμενοÏ
ÏάÏÏη"
#: ../raster3d/r3.cross.rast/main.c:91
msgid "Input 3D raster map for cross section."
-msgstr "Ï 3Ä åéóáãþìåíïò ÷Üñôçò ãéá ôïìÞ"
+msgstr "Î 3ΠειÏαγÏÎ¼ÎµÎ½Î¿Ï ÏάÏÏÎ·Ï Î³Î¹Î± Ïομή"
#: ../raster3d/r3.cross.rast/main.c:98
msgid "2D elevation map used to create the cross section map"
-msgstr "2Ä õøïìåôñéêüò ÷Üñôçò ðïõ ÷ñçóéìïðïéÞèçêå ãéá ôçí ôïìÞ"
+msgstr "2Î Ï
ÏομεÏÏικÏÏ ÏάÏÏÎ·Ï ÏοÏ
ÏÏηÏιμοÏοιήθηκε για Ïην Ïομή"
#: ../raster3d/r3.cross.rast/main.c:105
msgid "Resulting cross section 2D raster map"
-msgstr "Ôï áðïôÝëåóìá ôïìÞò 2Ä ñÜóôåñ ÷Üñôç"
+msgstr "Το αÏοÏÎλεÏμα ÏÎ¿Î¼Î®Ï 2Î ÏάÏÏÎµÏ ÏάÏÏη"
#: ../raster3d/r3.cross.rast/main.c:162
msgid "Unable to get elevation raster row"
-msgstr "Áäõíáìßá ëÞøçò ãñáììÞò õøïìÝôñùí áðü ñÜóôåñ"
+msgstr "ÎδÏ
ναμία λήÏÎ·Ï Î³ÏÎ±Î¼Î¼Î®Ï Ï
ÏομÎÏÏÏν αÏÏ ÏάÏÏεÏ"
#: ../raster3d/r3.cross.rast/main.c:230 ../raster3d/r3.cross.rast/main.c:237
#: ../raster3d/r3.to.rast/main.c:152 ../raster3d/r3.to.rast/main.c:159
@@ -20371,8 +20371,8 @@
"Creates cross section 2D raster map from 3D raster map based on 2D elevation "
"map."
msgstr ""
-"Äçìéïõñãåß ôïìÞ 2Ä ñÜóôåñ ÷Üñôç áðü 3Ä ñÜóôåñ ÷Üñôç âáóéóìÝíï óôïí 2Ä ÷Üñôç "
-"õøïìÝôñùí"
+"ÎημιοÏ
Ïγεί Ïομή 2Î ÏάÏÏÎµÏ ÏάÏÏη αÏÏ 3Î ÏάÏÏÎµÏ ÏάÏÏη βαÏιÏμÎνο ÏÏον 2Î ÏάÏÏη "
+"Ï
ÏομÎÏÏÏν"
#: ../raster3d/r3.cross.rast/main.c:298
#, fuzzy
@@ -20380,75 +20380,75 @@
"The 2D and 3D region settings are different. Using the 3D raster map "
"settings to adjust the 2D region."
msgstr ""
-"Ç 2Ä êáé 3Ä ñõèìßóåéò ðåñéï÷çò åßíáé äéáöïñåôéêÞ, èá ÷ñçóéìïðïéÞóù ôçí 3Ä "
-"ãéá íá ñõèìßóù ôçí 2Ä"
+"Î 2Πκαι 3Î ÏÏ
θμίÏÎµÎ¹Ï ÏεÏιοÏÎ·Ï ÎµÎ¯Î½Î±Î¹ διαÏοÏεÏική, θα ÏÏηÏιμοÏοιήÏÏ Ïην 3Î "
+"για να ÏÏ
θμίÏÏ Ïην 2Î"
#: ../raster3d/r3.cross.rast/main.c:333
msgid "Elevation map not found"
-msgstr "Ï ÷Üñôçò õøïìÝôñùí äåí âñÝèçêå"
+msgstr "Î ÏάÏÏÎ·Ï Ï
ÏομÎÏÏÏν δεν βÏÎθηκε"
#: ../raster3d/r3.cross.rast/main.c:338
msgid "Unable to open elevation map"
-msgstr "Áäõíáìßá áíïßãìáôïò ÷Üñôç õøïìÝôñùí"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï ÏάÏÏη Ï
ÏομÎÏÏÏν"
#: ../raster3d/r3.cross.rast/main.c:352
msgid "Output map already exists. Will be overwritten!"
-msgstr "Ï åîáãþìåíïò ÷Üñôçò Þäç õðÜñ÷åé. Èá áíôéêáôáóôáèåß!"
+msgstr "ΠεξαγÏÎ¼ÎµÎ½Î¿Ï ÏάÏÏÎ·Ï Î®Î´Î· Ï
ÏάÏÏει. Îα ανÏικαÏαÏÏαθεί!"
#: ../raster3d/r3.cross.rast/main.c:358 ../raster3d/r3.cross.rast/main.c:364
msgid "Unable to create raster map"
+msgstr "ÎδÏ
ναμία δημιοÏ
#: ../raster3d/r3.cross.rast/main.c:394
msgid "Unable to close elevation map"
-msgstr "Áäõíáìßá êëåéóßìáôïò ÷Üñôç õøïìÝôñùí"
+msgstr "ÎδÏ
ναμία κλειÏίμαÏÎ¿Ï ÏάÏÏη Ï
ÏομÎÏÏÏν"
#: ../raster3d/r3.cross.rast/main.c:399
#, fuzzy
msgid "Wrong 3D raster map datatype! Unable to create raster map."
-msgstr "ËÜèïò G3D ôýðïò! Äåí ìðïñåß íá äçìéïõñãçèåß ñÜóôåñ ÷Üñôçò."
+msgstr "ÎÎ¬Î¸Î¿Ï G3D ÏÏÏοÏ! Îεν μÏοÏεί να δημιοÏ
Ïγηθεί ÏάÏÏÎµÏ ÏάÏÏηÏ."
#: ../raster3d/r3.stats/main.c:569
#, fuzzy
msgid "Generates volume statistics for 3D raster maps."
#: ../raster3d/r3.stats/main.c:580
#, fuzzy
msgid "Number of subranges to collect stats from"
-msgstr "Íïýìåñï ôùí õðïðåñéï÷þí ãéá óõëëïãÞ óôáôéóôéêþí áðü áõôÜ"
+msgstr "ÎοÏμεÏο ÏÏν Ï
ÏοÏεÏιοÏÏν για ÏÏ
λλογή ÏÏαÏιÏÏικÏν αÏÏ Î±Ï
Ïά"
#: ../raster3d/r3.stats/main.c:586
msgid "Calculate statistics based on equal value groups"
-msgstr "Õðïëïãßæåé óôáôéóôéêÜ âáóéóìÝíá óå ßóçò ôéìÞò ãêñïõð"
+msgstr "Î¥Ïολογίζει ÏÏαÏιÏÏικά βαÏιÏμÎνα Ïε ίÏÎ·Ï ÏÎ¹Î¼Î®Ï Î³ÎºÏοÏ
Ï"
#: ../raster3d/r3.stats/main.c:606
msgid "The number of subranges has to be equal or greater than 1"
-msgstr "Ï áñéèìüò ôùí õðïðåñéï÷þí ðñÝðåé íá åßíáé ìåãáëýôåñïò Þ ßóïò ôïõ 1"
+msgstr "ΠαÏιθμÏÏ ÏÏν Ï
ÏοÏεÏιοÏÏν ÏÏÎÏει να είναι μεγαλÏÏεÏÎ¿Ï Î® ίÏÎ¿Ï ÏοÏ
1"
#: ../raster3d/r3.stats/main.c:665
msgid "Sort non-null values"
-msgstr "ÓïñôÜñéóìá ìç êåíþí ôéìþí"
+msgstr "ΣοÏÏάÏιÏμα μη κενÏν ÏιμÏν"
#: ../raster3d/r3.in.ascii/main.c:79
#, fuzzy
msgid "ASCII raster map to be imported"
θα ειÏαÏθεί"
#: ../raster3d/r3.in.ascii/main.c:90
msgid "String representing NULL value data cell (use 'none' if no such value)"
msgstr ""
-"Ï ÷áñáêôÞñáò áíôéðñïóùðåýåé NULL ôéìÞ äåäïìÝíùí êåëéïý (÷ñçóéìïðïéÞóôå "
-"'none' áí äåí õðÜñ÷åé ôÝôïéá ôéìÞ)"
+"Î ÏαÏακÏήÏÎ±Ï Î±Î½ÏιÏÏοÏÏÏεÏει NULL Ïιμή δεδομÎνÏν ÎºÎµÎ»Î¹Î¿Ï (ÏÏηÏιμοÏοιήÏÏε "
+"'none' αν δεν Ï
ÏάÏÏει ÏÎÏοια Ïιμή)"
#: ../raster3d/r3.in.ascii/main.c:175
#, c-format
msgid "Loading data ... (%dx%dx%d)"
-msgstr "Öüñôùóç äåäïìÝíùí... (%dx%dx%d)"
+msgstr "ΦÏÏÏÏÏη δεδομÎνÏν... (%dx%dx%d)"
#: ../raster3d/r3.in.ascii/main.c:192
msgid "End of file reached while still loading data."
-msgstr "¸öôáóå ôï ôÝëïò áñ÷åßïõ åíþ áêüìá öïñôþíïíôáé äåäïìÝíá"
+msgstr "ÎÏÏαÏε Ïο ÏÎÎ»Î¿Ï Î±ÏÏείοÏ
ÎµÎ½Ï Î±ÎºÏμα ÏοÏÏÏνονÏαι δεδομÎνα"
#: ../raster3d/r3.in.ascii/main.c:205
msgid "Invalid value detected"
@@ -20459,28 +20459,28 @@
msgid ""
"Data exists in input file after fully importing expected data. [%.4f ...]"
msgstr ""
-"Ôá äåäïìÝíá õðÜñ÷ïõí óôï áñ÷åßï åéóáãùãÞò ìåôÜ ôçí ðëÞñç åéóáãùãÞ ôùí "
-"áíáìåíþìåíùí áñ÷åßùí [%.4f ...]"
+"Τα δεδομÎνα Ï
ÏάÏÏοÏ
ν ÏÏο αÏÏείο ειÏαγÏÎ³Î®Ï Î¼ÎµÏά Ïην ÏλήÏη ειÏαγÏγή ÏÏν "
+"αναμενÏμενÏν αÏÏείÏν [%.4f ...]"
#: ../raster3d/r3.in.ascii/main.c:253 ../raster3d/r3.in.v5d/main.c:191
msgid "raster3d, voxel, import"
#: ../raster3d/r3.in.ascii/main.c:255
#, fuzzy
msgid ""
"Converts a 3D ASCII raster text file into a (binary) 3D raster map layer."
-msgstr "ÌåôáôñïðÞ åíüò 3Ä ASCII ñÜóôåñ áñ÷åßïõ óå (binary) 3Ä ñÜóôåñ åðßðåäï"
+msgstr "ÎεÏαÏÏοÏή ενÏÏ 3Î ASCII ÏάÏÏÎµÏ Î±ÏÏείοÏ
Ïε (binary) 3Î ÏάÏÏÎµÏ ÎµÏίÏεδο"
#: ../raster3d/r3.in.ascii/main.c:281 ../raster3d/r3.in.v5d/main.c:213
#, fuzzy
msgid "Unable to open 3D raster map"
+msgstr "ÎδÏ
ÏάÏÏη raster <%s>"
#: ../raster3d/r3.in.ascii/main.c:297
#, fuzzy
msgid "Unable to close ASCII file"
-msgstr "Áäõíáìßá áíïßãìáôïò ðñïóùñéíïý áñ÷åßïõ"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï ÏÏοÏÏÏÎ¹Î½Î¿Ï Î±ÏÏείοÏ
#: ../raster3d/r3.out.vtk/main.c:99
#, c-format
@@ -20508,7 +20508,7 @@
#: ../raster3d/r3.out.vtk/main.c:167
#, fuzzy, c-format
msgid "3D vector map <%s> not found"
-msgstr "Ï äéáíõóìáôéêüò ÷Üñôçò <%s> äåí âñÝèçêå"
+msgstr "ΠδιανÏ
ÏμαÏικÏÏ ÏάÏÏÎ·Ï <%s> δεν βÏÎθηκε"
#: ../raster3d/r3.out.vtk/main.c:171
msgid "Please provide three 3D raster maps for the xyz-vector maps [x,y,z]"
@@ -20531,12 +20531,12 @@
#: ../raster3d/r3.out.vtk/main.c:376 ../raster3d/r3.out.v5d/main.c:286
#: ../raster3d/r3.out.ascii/main.c:244
msgid "raster3d, voxel, export"
-msgstr "ñÜóôåñ 3D, voxel, åîáãùãÞ"
+msgstr "ÏάÏÏÎµÏ 3D, voxel, εξαγÏγή"
#: ../raster3d/r3.out.vtk/main.c:378
#, fuzzy
msgid "Converts 3D raster maps into the VTK-ASCII format."
-msgstr "ÌåôáôñÝðåé Ýíá 3Ä åðßðåäï ñÜóôåñ ÷Üñôç óå Ýíá ASCII áñ÷åßï êåéìÝíïõ"
+msgstr "ÎεÏαÏÏÎÏει Îνα 3ΠεÏίÏεδο ÏάÏÏÎµÏ ÏάÏÏη Ïε Îνα ASCII αÏÏείο κειμÎνοÏ
#: ../raster3d/r3.out.vtk/main.c:389
msgid "failed to interpret dp as an integer"
@@ -20548,18 +20548,18 @@
"The 2D and 3D region settings are different. Using the 2D window settings to "
"adjust the 2D part of the 3D region."
msgstr ""
+"Î 2Πκαι 3Î ÏÏ
+"για να ÏÏ
θμίÏÏ Ïην 2Î"
#: ../raster3d/r3.out.vtk/main.c:489
#, fuzzy
msgid "Unable to close top raster map"
+msgstr "ÎδÏ
ÏάÏÏη ειÏαγÏγήÏ"
#: ../raster3d/r3.out.vtk/main.c:494
#, fuzzy
msgid "Unable to close bottom raster map"
+msgstr "ÎδÏ
ÏάÏÏη ειÏαγÏγήÏ"
#: ../raster3d/r3.out.vtk/main.c:546
msgid "Unable to close 3D raster map, the VTK file may be incomplete"
@@ -20568,17 +20568,17 @@
#: ../raster3d/r3.out.vtk/main.c:561
#, fuzzy
msgid "Unable to close VTK-ASCII file"
+msgstr "ÎδÏ
#: ../raster3d/r3.out.vtk/errorHandling.c:52
#, fuzzy
msgid "Unable to close input raster map"
+msgstr "ÎδÏ
ÏάÏÏη ειÏαγÏγήÏ"
#: ../raster3d/r3.out.vtk/errorHandling.c:107
#, fuzzy
msgid "Unable to close input raster maps"
+msgstr "ÎδÏ
ÏάÏÏη ειÏαγÏγήÏ"
#: ../raster3d/r3.out.vtk/writeVTKData.c:122
msgid "write_vtk_points: Writing point coordinates"
@@ -20587,12 +20587,12 @@
#: ../raster3d/r3.out.vtk/writeVTKData.c:131
#, fuzzy
msgid "Unable to read top raster row \n"
+msgstr "ÎδÏ
ναμία δημιοÏ
#: ../raster3d/r3.out.vtk/writeVTKData.c:135
#, fuzzy
msgid "Unable to read bottom raster row \n"
+msgstr "ÎδÏ
ναμία δημιοÏ
#: ../raster3d/r3.out.vtk/writeVTKData.c:256
msgid "write_vtk_unstructured_grid_cells: Writing the cells"
@@ -20641,7 +20641,7 @@
#: ../raster3d/r3.out.vtk/parameters.c:117 ../raster3d/r3.gwflow/main.c:136
#, fuzzy
msgid "Use 3D raster mask (if exists) with input maps"
-msgstr "×ñçóéìïðïéÞóôå G3D mask (áí õðÜñ÷åé) ìå åéóáãþìåíï ÷Üñôç"
+msgstr "ΧÏηÏιμοÏοιήÏÏε G3D mask (αν Ï
ÏάÏÏει) με ειÏαγÏμενο ÏάÏÏη"
#: ../raster3d/r3.out.vtk/parameters.c:122
msgid "Scale factor effects the origin"
@@ -20662,82 +20662,82 @@
#: ../raster3d/r3.out.v5d/main.c:72
#, fuzzy
msgid "3D raster map to be converted to Vis5D (V5D) file"
-msgstr "3Ä ñÜóôåñ ÷Üñôçò èá ìåôáôñáðåß óå áñ÷åßï Vis5d (v5d)"
+msgstr "3Î ÏάÏÏÎµÏ ÏάÏÏÎ·Ï Î¸Î± μεÏαÏÏαÏεί Ïε αÏÏείο Vis5d (v5d)"
#: ../raster3d/r3.out.v5d/main.c:79
#, fuzzy
msgid "Name for V5D output file"
-msgstr "¼íïìá ãéá ôï åîáãþìåíï v5d áñ÷åßï"
+msgstr "Îνομα για Ïο εξαγÏμενο v5d αÏÏείο"
#: ../raster3d/r3.out.v5d/main.c:149
#, fuzzy, c-format
msgid "Vis5D allows %d columns, %d columns found"
-msgstr "Viz5D åðéôñÝðåé %d cols, Ý÷åôå %d cols"
+msgstr "Viz5D εÏιÏÏÎÏει %d cols, ÎÏεÏε %d cols"
#: ../raster3d/r3.out.v5d/main.c:152
#, fuzzy, c-format
msgid "Vis5D allows %d rows, %d rows found"
-msgstr "Viz5D allows %d ãñáììÝò, Ý÷åôå %d ãñáììÝò"
+msgstr "Viz5D allows %d γÏαμμÎÏ, ÎÏεÏε %d γÏαμμÎÏ"
#: ../raster3d/r3.out.v5d/main.c:259
#, fuzzy, c-format
msgid "Unable to create V5D file <%s>"
-msgstr "Áäõíáìßá äçìéïõñãßáò ðßíáêá <%s>"
+msgstr "ÎδÏ
ναμία δημιοÏ
ÏÎ³Î¯Î±Ï Ïίνακα <%s>"
#: ../raster3d/r3.out.v5d/main.c:264
#, fuzzy
msgid "Failed writing V5D file"
-msgstr "ÓöÜëìá êáôÜ ôçí åããñáöÞ ôïõ grid. Äßóêïò ãåìÜôïò;"
+msgstr "ΣÏάλμα καÏά Ïην εγγÏαÏή ÏοÏ
grid. ÎίÏÎºÎ¿Ï Î³ÎµÎ¼Î¬ÏοÏ;"
#: ../raster3d/r3.out.v5d/main.c:288
#, fuzzy
msgid "Exports GRASS 3D raster map to 3-dimensional Vis5D file."
-msgstr "ÅîáãùãÞ ôïõ GRASS 3Ä ñÜóôåñ ÷Üñôç óå 3 äéÜóôáôï Vis5D áñ÷åßï"
+msgstr "ÎξαγÏγή ÏοÏ
GRASS 3Î ÏάÏÏÎµÏ ÏάÏÏη Ïε 3 διάÏÏαÏο Vis5D αÏÏείο"
#: ../raster3d/r3.out.v5d/main.c:295
msgid "Use map coordinates instead of xyz coordinates"
νÏεÏαγμÎνεÏ"
#: ../raster3d/r3.mkdspf/main.c:77
msgid ""
"Creates a display file from an existing grid3 file according to specified "
"threshold levels."
msgstr ""
-"Äçìéïõñãåß Ýíá áñ÷åßï ðáñïõóßáóçò áðü Ýíá õöéóôÜìåíï grid3 áñ÷åßï óýìöùíá ìå "
-"ôá äåäïìÝíá threshold levels."
+"ÎημιοÏ
Ïγεί Îνα αÏÏείο ÏαÏοÏ
ÏίαÏÎ·Ï Î±ÏÏ Îνα Ï
ÏιÏÏάμενο grid3 αÏÏείο ÏÏμÏÏνα με "
+"Ïα δεδομÎνα threshold levels."
#: ../raster3d/r3.mkdspf/main.c:85
msgid "Name of an existing 3d raster map"
+msgstr "Îνομα Ï
#: ../raster3d/r3.mkdspf/main.c:91
msgid "Name of output display file"
αÏÏείοÏ
ÏαÏοÏ
ÏίαÏηÏ"
#: ../raster3d/r3.mkdspf/main.c:98
msgid "List of thresholds for isosurfaces"
#: ../raster3d/r3.mkdspf/main.c:104
msgid "Minimum isosurface level"
-msgstr "ÅëÜ÷éóôï åðßðåäï éóïåðéöáíåéþí"
+msgstr "ÎλάÏιÏÏο εÏίÏεδο ιÏοεÏιÏανειÏν"
#: ../raster3d/r3.mkdspf/main.c:110
msgid "Maximum isosurface level"
-msgstr "ÌÝãéóôï åðßðåäï éóïåðéöáíåéþí"
+msgstr "ÎÎγιÏÏο εÏίÏεδο ιÏοεÏιÏανειÏν"
#: ../raster3d/r3.mkdspf/main.c:116
msgid "Positive increment between isosurface levels"
-msgstr "Èåôéêü âÞìá ìåôáîý éóïåðéöáíåéþí"
+msgstr "ÎεÏÎ¹ÎºÏ Î²Î®Î¼Î± μεÏÎ±Î¾Ï Î¹ÏοεÏιÏανειÏν"
#: ../raster3d/r3.mkdspf/main.c:123
msgid "Number of isosurface threshold levels"
-msgstr "Áñéèìüò åðéðÝäùí threshold éóïåðéöáíåéþí"
+msgstr "ÎÏιθμÏÏ ÎµÏιÏÎδÏν threshold ιÏοεÏιÏανειÏν"
#: ../raster3d/r3.mkdspf/main.c:127
msgid "Suppress progress report & min/max information"
msgstr ""
-"Åëá÷éóôïðïßçóç ôçò ðñïüäïõ áðïôåëåóìÜôùí & ìÝãéóôï/åëÜ÷éóôï ðëçñïöïñéþí"
+"ÎλαÏιÏÏοÏοίηÏη ÏÎ·Ï ÏÏοÏδοÏ
αÏοÏελεÏμάÏÏν & μÎγιÏÏο/ελάÏιÏÏο ÏληÏοÏοÏιÏν"
#: ../raster3d/r3.mkdspf/main.c:131
msgid "Use flat shading rather than gradient"
@@ -20746,60 +20746,60 @@
#: ../raster3d/r3.mkdspf/main.c:139
#, c-format
msgid "Region from getWindow: %d %d %d"
-msgstr "Ðåñéï÷Þ áðü getWindow: %d %d %d"
+msgstr "ΠεÏιοÏή αÏÏ getWindow: %d %d %d"
#: ../raster3d/r3.mkdspf/main.c:151
#, c-format
msgid "Not able to find grid3 file for [%s]"
-msgstr "Äåí Þôáí äõíáôÞ ç åýñåóç grid3 áñ÷åßïõ ãéá [%s]"
+msgstr "Îεν ήÏαν δÏ
ναÏή η εÏÏεÏη grid3 αÏÏείοÏ
για [%s]"
#: ../raster3d/r3.mkdspf/main.c:163
#, c-format
msgid "Error opening grid3 file [%s]"
-msgstr "ÓöÜëìá êáôÜ ôï Üíïéãìá ôïõ áñ÷åßïõ grid3 [%s]"
+msgstr "ΣÏάλμα καÏά Ïο άνοιγμα ÏοÏ
αÏÏείοÏ
grid3 [%s]"
#: ../raster3d/r3.mkdspf/main.c:166
#, c-format
msgid "Error reading range for [%s]"
-msgstr "ÓöÜëìá êáôÜ ôçí áíÜãíùóç ôïõ åýñïõò ãéá [%s]"
εÏÏοÏ
Ï Î³Î¹Î± [%s]"
#: ../raster3d/r3.mkdspf/main.c:195
#, c-format
msgid "Error opening display file [%s]"
-msgstr "ÓöÜëìá êáôÜ ôï Üíïéãìá ôïõ áñ÷åßïõ ðáñïõóßáóçò [%s]"
αÏÏείοÏ
ÏαÏοÏ
ÏίαÏÎ·Ï [%s]"
#: ../raster3d/r3.mkdspf/main.c:216
#, c-format
msgid "Writing %s from %s..."
#: ../raster3d/r3.out.ascii/main.c:76
#, fuzzy
msgid "3D raster map to be converted to ASCII"
-msgstr "Ôï 3Ä ñÜóôåñ áñ÷åßï èá ìåôáôñáðåß óå ASCII"
+msgstr "Το 3Î ÏάÏÏÎµÏ Î±ÏÏείο θα μεÏαÏÏαÏεί Ïε ASCII"
#: ../raster3d/r3.out.ascii/main.c:83
msgid "Name for ASCII output file"
-msgstr "¼íïìá ôïõ ASCII åîáãþìåíïõ áñ÷åßïõ"
+msgstr "Îνομα ÏοÏ
ASCII εξαγÏμενοÏ
αÏÏείοÏ
#: ../raster3d/r3.out.ascii/main.c:92
msgid "Number of decimal places for floats"
-msgstr "Áñéèìüò ôùí äåäáäéêþí øçößùí ãéá ôïõò áñéèìïýò õðïäéáóôïëÞò"
+msgstr "ÎÏιθμÏÏ ÏÏν δεδαδικÏν ÏηÏίÏν για ÏοÏ
Ï Î±ÏιθμοÏÏ Ï
ÏοδιαÏÏολήÏ"
#: ../raster3d/r3.out.ascii/main.c:246
#, fuzzy
msgid "Converts a 3D raster map layer into an ASCII text file."
#: ../raster3d/r3.out.ascii/main.c:305
#, fuzzy
msgid "Unable to close new ASCII file"
-msgstr "ÓöÜëìá êáôÜ ôï êëåßóéìïõ íÝïõ ASCII áñ÷åßïõ"
+msgstr "ΣÏάλμα καÏά Ïο κλείÏιμοÏ
νÎοÏ
ASCII αÏÏείοÏ
#: ../raster3d/r3.to.rast/main.c:79
#, fuzzy
msgid "3D raster map(s) to be converted to 2D raster slices"
#: ../raster3d/r3.to.rast/main.c:85
msgid "Basename for resultant raster slice maps"
@@ -20818,12 +20818,12 @@
#: ../raster3d/r3.to.rast/main.c:225
#, fuzzy, c-format
msgid "Open 3D raster map <%s>"
-msgstr "ÓöÜëìá áíïßãìáôïò 3Ä ñÜóôåñ ÷Üñôç <%s>"
+msgstr "ΣÏάλμα ανοίγμαÏÎ¿Ï 3Î ÏάÏÏÎµÏ ÏάÏÏη <%s>"
#: ../raster3d/r3.to.rast/main.c:243 ../raster3d/r3.to.rast/main.c:284
#, fuzzy, c-format
msgid "Error opening 3D raster map <%s>"
#: ../raster3d/r3.to.rast/main.c:304
#, c-format
@@ -20843,23 +20843,23 @@
#: ../raster3d/r3.gwflow/main.c:55
#, fuzzy
msgid "Input 3D raster map with initial piezometric heads in [m]"
-msgstr "Ç áñ÷éêÞ ðéåæïìåôñéêÞ óôÞëç óå [m]"
+msgstr "ΠαÏÏική ÏιεζομεÏÏική ÏÏήλη Ïε [m]"
#: ../raster3d/r3.gwflow/main.c:63
msgid "The status for each cell, = 0 - inactive, 1 - active, 2 - dirichlet"
-msgstr "Ç êáôÜóôáóç êÜèå êåëéïý, = 0 - inactive, 1 - active, 2 - dirichlet"
+msgstr "ΠκαÏάÏÏαÏη κάθε κελιοÏ, = 0 - inactive, 1 - active, 2 - dirichlet"
#: ../raster3d/r3.gwflow/main.c:71
msgid "The x-part of the hydraulic conductivity tensor in [m/s]"
-msgstr "Ôï x-ìÝñïò ôçò õäñáõëéêÞò áãùãéìüôçôáò óå [m/s]"
+msgstr "Το x-μÎÏÎ¿Ï ÏÎ·Ï Ï
δÏαÏ
Î»Î¹ÎºÎ®Ï Î±Î³ÏγιμÏÏηÏÎ±Ï Ïε [m/s]"
#: ../raster3d/r3.gwflow/main.c:79
msgid "The y-part of the hydraulic conductivity tensor in [m/s]"
-msgstr "Ôï y-ìÝñïò ôçò õäñáõëéêÞò áãùãéìüôçôáò óå [m/s]"
+msgstr "Το y-μÎÏÎ¿Ï ÏÎ·Ï Ï
δÏαÏ
#: ../raster3d/r3.gwflow/main.c:87
msgid "The z-part of the hydraulic conductivity tensor in [m/s]"
-msgstr "Ôï z-ìÝñïò ôçò õäñáõëéêÞò áãùãéìüôçôáò óå [m/s]"
+msgstr "Το z-μÎÏÎ¿Ï ÏÎ·Ï Ï
δÏαÏ
#: ../raster3d/r3.gwflow/main.c:94
msgid "Sources and sinks in [m^3/s]"
@@ -20871,15 +20871,15 @@
#: ../raster3d/r3.gwflow/main.c:108
msgid "Recharge raster map in m^3/s"
-msgstr "×Üñôçò åðáíáöüñôéóçò óå m^3/s"
+msgstr "ΧάÏÏÎ·Ï ÎµÏαναÏÏÏÏιÏÎ·Ï Ïε m^3/s"
#: ../raster3d/r3.gwflow/main.c:116
msgid ""
"The piezometric head result of the numerical calculation will be written to "
"this map"
msgstr ""
-"Ç ðéåæïìåôñéêÞ óôÞëç, áðïôÝëåóìá ôùí áñéèìçôéêþí õðïëïãéóìþí èá ãñáöôåß óå "
-"áõôü ôï ÷Üñôç"
+"Î ÏιεζομεÏÏική ÏÏήλη, αÏοÏÎλεÏμα ÏÏν αÏιθμηÏικÏν Ï
ÏολογιÏμÏν θα γÏαÏÏεί Ïε "
+"αÏ
ÏÏ Ïο ÏάÏÏη"
#: ../raster3d/r3.gwflow/main.c:123
#, fuzzy
@@ -20888,9 +20888,9 @@
"and write the x, y, and z components to maps named name_[xyz].\n"
"Name is basename for the new 3D raster maps."
msgstr ""
-"Õðïëïãßóôå ôçí ôá÷ýôçôá ôïõ õðïãåéïõ íåñïý (äéáíõóìáôéêü ìåñïò) êáé ãñÜøôå "
-"ôá ÷ , ø êáé æ óôïé÷åßá óôï ÷Üñôç ìå üíïìá name_[xyz]. Ôï üíïìá åßíáé ôï "
-"âáóéêü üíïìá ãéá ôïõò íÝïõò ñÜóôåñ 3Ä ÷Üñôåò"
+"Î¥ÏολογίÏÏε Ïην ÏαÏÏÏηÏα ÏοÏ
Ï
ÏογειοÏ
νεÏÎ¿Ï (διανÏ
ÏμαÏÎ¹ÎºÏ Î¼ÎµÏοÏ) και γÏάÏÏε "
+"Ïα Ï , Ï ÎºÎ±Î¹ ζ ÏÏοιÏεία ÏÏο ÏάÏÏη με Ïνομα name_[xyz]. Το Ïνομα είναι Ïο "
+"βαÏÎ¹ÎºÏ Ïνομα για ÏοÏ
Ï Î½ÎοÏ
Ï ÏάÏÏÎµÏ 3Î ÏάÏÏεÏ"
#: ../raster3d/r3.gwflow/main.c:141
msgid ""
@@ -20910,7 +20910,7 @@
#: ../raster3d/r3.gwflow/main.c:371
#, fuzzy, c-format
msgid "Unable to create 3D raster map <%s>"
-msgstr "Áäõíáìßá äçìéïõñãßáò raster ÷Üñôç <%s>."
+msgstr "ÎδÏ
ναμία δημιοÏ
ÏÎ³Î¯Î±Ï raster ÏάÏÏη <%s>."
#: ../raster3d/r3.in.v5d/main.c:193
msgid ""
@@ -21002,12 +21002,12 @@
#: ../ps/ps.map/eps.c:19
#, fuzzy, c-format
msgid "Can't open eps file <%s>"
-msgstr "Áäõíáìßá áíïßãìáôïò ôïõ ÷Üñôç raster <%s>"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï ÏοÏ
ÏάÏÏη raster <%s>"
#: ../ps/ps.map/eps.c:38
#, fuzzy, c-format
msgid "Bounding box in eps file <%s> was not found"
-msgstr "Ç óôÞëç <%s> äåí âñÝèçêå"
+msgstr "Î ÏÏήλη <%s> δεν βÏÎθηκε"
#: ../ps/ps.map/r_header.c:77
msgid "illegal header sub-request"
@@ -21086,7 +21086,7 @@
#: ../ps/ps.map/main.c:156
#, fuzzy
msgid "Output settings"
-msgstr "ÁðïôÝëåóìá:"
+msgstr "ÎÏοÏÎλεÏμα:"
#: ../ps/ps.map/main.c:111
msgid "List paper formats ( name width height left right top bottom(margin) )"
@@ -21109,7 +21109,7 @@
#: ../ps/ps.map/main.c:129
#, fuzzy
msgid "File containing mapping instructions"
-msgstr "¼íïìá ôïõ áñ÷åßïõ ðïõ ðåñéÝ÷åé SQL åíôïëÝò"
+msgstr "Îνομα ÏοÏ
αÏÏείοÏ
ÏοÏ
ÏεÏιÎÏει SQL ενÏολÎÏ"
#: ../ps/ps.map/main.c:130
msgid "Use '-' to enter instructions from keyboard"
@@ -21150,7 +21150,7 @@
"\t(%s)\n"
msgstr ""
"\n"
-"ÓÖÁËÌÁ: Ç áðáéôïýìåíç ðáñÜìåôñïò <%s> äåí Ý÷åé êáèïñéóôåß:\n"
+"ΣΦÎÎÎÎ: ΠαÏαιÏοÏμενη ÏαÏάμεÏÏÎ¿Ï <%s> δεν ÎÏει καθοÏιÏÏεί:\n"
" (%s).\n"
#: ../ps/ps.map/main.c:288
@@ -21175,12 +21175,12 @@
#: ../ps/ps.map/main.c:394
#, fuzzy
msgid "no raster map selected yet"
-msgstr "Ï ÷Üñôçò raster <%s> äåí âñÝèçêå"
+msgstr "Î ÏάÏÏÎ·Ï raster <%s> δεν βÏÎθηκε"
#: ../ps/ps.map/main.c:410
#, fuzzy
msgid "illegal value list"
-msgstr "<%s> åßíáé ìç åðéôñåðôü üíïìá áñ÷åßïõ"
+msgstr "<%s> είναι μη εÏιÏÏεÏÏÏ Ïνομα αÏÏείοÏ
#: ../ps/ps.map/main.c:738
#, c-format
@@ -21255,7 +21255,7 @@
#: ../ps/ps.map/r_colortable.c:169
#, fuzzy
msgid "No raster selected for colortable!"
+msgstr "διάνÏ
#: ../ps/ps.map/ps_vpoints.c:181
#, c-format
@@ -21299,7 +21299,7 @@
#: ../ps/ps.map/r_plt.c:158
#, fuzzy
msgid "Can't open eps file"
+msgstr "ÎδÏ
#: ../ps/ps.map/do_vectors.c:34
#, c-format
@@ -21378,7 +21378,7 @@
#: ../imagery/i.ortho.photo/i.photo.init/main.c:64
#, fuzzy, c-format
msgid "Group [%s] not found"
#: ../imagery/i.ortho.photo/i.photo.2target/main.c:114
#: ../imagery/i.ortho.photo/i.photo.2image/main.c:98
@@ -21420,7 +21420,7 @@
#: ../imagery/i.ortho.photo/i.photo.2target/main.c:233
#, fuzzy, c-format
msgid "Unable to read raster header of <%s>"
-msgstr "Áäõíáìßá äçìéïõñãßáò raster ÷Üñôç <%s>"
+msgstr "ÎδÏ
ναμία δημιοÏ
ÏÎ³Î¯Î±Ï raster ÏάÏÏη <%s>"
#: ../imagery/i.ortho.photo/i.photo.2target/main.c:302
#: ../imagery/i.ortho.photo/i.photo.2image/main.c:195
@@ -21439,7 +21439,7 @@
#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:44
#, fuzzy, c-format
msgid "Could not read REF file for group [%s]"
-msgstr "Áäõíáìßá äçìéïõñãßáò êáôáëüãïõ ãéá ôïí ðßíáêá <%s>, êëåéäß <%s>"
+msgstr "ÎδÏ
ναμία δημιοÏ
ÏÎ³Î¯Î±Ï ÎºÎ±ÏαλÏγοÏ
για Ïον Ïίνακα <%s>, κλειδί <%s>"
#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:45
#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:50
@@ -21481,7 +21481,7 @@
#: ../imagery/i.rectify/main.c:266
#, fuzzy, c-format
msgid "Extension <%s> is illegal"
#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:110
msgid ""
@@ -21507,12 +21507,12 @@
#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:132
#, fuzzy
msgid "Enter a name for the camera angle map:"
#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:141
#, fuzzy, c-format
msgid "Map name <%s> is illegal"
#: ../imagery/i.ortho.photo/menu/i.photo.rectify.c:142
msgid ""
@@ -21587,7 +21587,7 @@
#: ../imagery/i.ortho.photo/menu/menu.c:62
#, fuzzy, c-format
msgid "Pre-selected group <%s> not found"
-msgstr "Ï ÷Üñôçò g3d <%s> äåí âñÞèçêå"
+msgstr "Î ÏάÏÏÎ·Ï g3d <%s> δεν βÏήθηκε"
#: ../imagery/i.ortho.photo/menu/menu.c:68
msgid "Enter imagery group for ortho-rectification"
@@ -21610,7 +21610,7 @@
#: ../imagery/i.ortho.photo/i.photo.elev/main.c:98
#, fuzzy, c-format
msgid "Target location [%s] not found\n"
#: ../imagery/i.ortho.photo/i.photo.elev/main.c:127
#, c-format
@@ -21624,7 +21624,7 @@
#: ../imagery/i.ortho.photo/i.photo.elev/main.c:128
#, fuzzy
msgid "not found\n"
-msgstr "Ï êÝñóïñáò äåí âñÝèçêå"
+msgstr "ΠκÎÏÏοÏÎ±Ï Î´ÎµÎ½ βÏÎθηκε"
#: ../imagery/i.ortho.photo/i.photo.elev/main.c:131
msgid "Please select a target for group"
@@ -21635,7 +21635,7 @@
msgid ""
"Control Z Point file for group [%s] in [%s] \n"
" \n"
+msgstr "ÎδÏ
ναμία δημιοÏ
#: ../imagery/i.ortho.photo/i.photo.rectify/cp.c:16
msgid "Computing equations..."
@@ -21669,7 +21669,7 @@
msgid ""
"Reference Point file for group [%s] in [%s] \n"
" \n"
+msgstr "ÎδÏ
ναμία δημιοÏ
#: ../imagery/i.ortho.photo/i.photo.rectify/cp.c:51
msgid "Poorly placed Reference Points!\n"
@@ -21789,7 +21789,7 @@
#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:181
#, fuzzy, c-format
msgid "Could not read REF file for group <%s>"
+msgstr "ÎδÏ
ναμία δημιοÏ
#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:184
#: ../imagery/i.rectify/main.c:191
@@ -21845,7 +21845,7 @@
#: ../imagery/i.rectify/main.c:321
#, fuzzy, c-format
msgid "Input raster map <%s> does not exist in group <%s>."
#: ../imagery/i.ortho.photo/i.photo.rectify/main.c:385
#: ../imagery/i.rectify/main.c:323
@@ -21867,23 +21867,23 @@
#: ../imagery/i.rectify/target.c:20
#, fuzzy, c-format
msgid "Target location <%s> not found"
#: ../imagery/i.ortho.photo/i.photo.rectify/angle.c:36
#, fuzzy
msgid "Calculating camera angle to local surface..."
-msgstr "Áäõíáìßá õðïëïãéóìïý êÝíôñùí ðïëõãþíïõ ãéá ôçí åðéöÜíåéá %d"
+msgstr "ÎδÏ
ναμία Ï
ÏολογιÏÎ¼Î¿Ï ÎºÎνÏÏÏν ÏολÏ
γÏνοÏ
για Ïην εÏιÏάνεια %d"
#: ../imagery/i.ortho.photo/i.photo.rectify/angle.c:51
#: ../imagery/i.ortho.photo/i.photo.rectify/exec.c:43
#, fuzzy
msgid "Could not open elevation raster"
-msgstr "Áäõíáìßá áíÜãíùóçò ôçò ãñáììÞò (row) ôïõ ÷Üñôç"
+msgstr "ÎδÏ
ναμία ανάγνÏÏÎ·Ï ÏÎ·Ï Î³ÏÎ±Î¼Î¼Î®Ï (row) ÏοÏ
ÏάÏÏη"
#: ../imagery/i.ortho.photo/i.photo.rectify/readcell.c:140
#, fuzzy
msgid "Error reading segment file"
εÏÏοÏ
Ï Î³Î¹Î± [%s]"
#: ../imagery/i.ortho.photo/i.photo.target/main.c:48
msgid "Interactively select or modify the imagery group target."
@@ -21925,7 +21925,7 @@
#: ../imagery/i.ortho.photo/i.photo.2image/main.c:86
#, fuzzy, c-format
msgid "Image Group [%s] not found"
#: ../imagery/i.landsat.acca/main.c:74
#, c-format
@@ -21941,12 +21941,12 @@
#: ../imagery/i.landsat.acca/main.c:107
#, fuzzy
msgid "imagery, landsat, acca"
-msgstr "ñÜóôåñ 3Ä, óôáôéóôéêÜ"
+msgstr "ÏάÏÏÎµÏ 3Î, ÏÏαÏιÏÏικά"
#: ../imagery/i.landsat.acca/main.c:111 ../imagery/i.landsat.toar/main.c:74
#, fuzzy
msgid "Base name of input raster bands"
-msgstr "¼íïìá åîáãüìåíïõ ñÜóôåñ ÷Üñôç"
+msgstr "Îνομα εξαγÏμενοÏ
ÏάÏÏÎµÏ ÏάÏÏη"
#: ../imagery/i.landsat.acca/main.c:112 ../imagery/i.landsat.toar/main.c:75
msgid "Example: 'B.' for B.1, B.2, ..."
@@ -21963,7 +21963,7 @@
#: ../imagery/i.landsat.acca/main.c:137
#, fuzzy
msgid "Number of classes in the cloud temperature histogram"
-msgstr "Áñéèìüò ãñáììþí ðïõ èá åìöáíßæïíôáé óôï õðüìíçìá."
+msgstr "ÎÏιθμÏÏ Î³ÏαμμÏν ÏοÏ
θα εμÏανίζονÏαι ÏÏο Ï
ÏÏμνημα."
#: ../imagery/i.landsat.acca/main.c:139 ../imagery/i.landsat.acca/main.c:154
#: ../imagery/i.landsat.acca/main.c:160 ../imagery/i.landsat.acca/main.c:165
@@ -22101,7 +22101,7 @@
#: ../imagery/i.landsat.acca/algorithm.c:238
#, fuzzy
msgid "Processing first pass..."
#: ../imagery/i.landsat.acca/algorithm.c:400
msgid "Removing ambiguous pixels..."
@@ -22114,7 +22114,7 @@
#: ../imagery/i.landsat.acca/algorithm.c:448
#, fuzzy, c-format
msgid "Cannot write to raster map <%s>"
-msgstr "Äåí Þôáí äõíáôÞ ç åããñáöÞ ãñáììÞò ñÜóôåñ"
ναÏή η εγγÏαÏή γÏÎ±Î¼Î¼Î®Ï ÏάÏÏεÏ"
#: ../imagery/i.vpoints/main.c:94 ../imagery/i.points/main.c:96
msgid "imagery, geometry"
@@ -22207,7 +22207,7 @@
#: ../imagery/i.gensig/parse.c:26
#, fuzzy
msgid "Name for output file containing result signatures"
+msgstr "Îνομα ÏοÏ
αÏÏείοÏ
ÏοÏ
#: ../imagery/i.cluster/main.c:105
msgid "Initial number of classes"
@@ -22216,7 +22216,7 @@
#: ../imagery/i.cluster/main.c:113
#, fuzzy
msgid "Name of file containing initial signatures"
+msgstr "Îνομα ÏοÏ
αÏÏείοÏ
ÏοÏ
#: ../imagery/i.cluster/main.c:121
msgid "Sampling intervals (by row and col); default: ~10,000 pixels"
@@ -22241,7 +22241,7 @@
#: ../imagery/i.cluster/main.c:160
#, fuzzy
msgid "Name for output file containing final report"
+msgstr "Îνομα ÏοÏ
αÏÏείοÏ
ÏοÏ
#: ../imagery/i.cluster/main.c:183
#, c-format
@@ -22276,7 +22276,7 @@
#: ../imagery/i.cluster/main.c:235
#, fuzzy, c-format
msgid "Unable to create report file <%s>"
+msgstr "ÎδÏ
ναμία δημιοÏ
#: ../imagery/i.cluster/main.c:243
#, c-format
@@ -22394,7 +22394,7 @@
#: ../imagery/i.ifft/ifftmain.c:144
#, fuzzy
msgid "Reading raster maps..."
#: ../imagery/i.cluster/main.c:298
msgid "Out of Memory. Please run again and choose a smaller sample size."
@@ -22430,7 +22430,7 @@
#: ../imagery/i.cluster/main.c:336
#, fuzzy, c-format
msgid "Unable to create signature file <%s> for group <%s>, subsgroup <%s>"
+msgstr "ÎδÏ
ναμία δημιοÏ
#: ../imagery/i.cluster/main.c:341
#, c-format
@@ -22489,14 +22489,14 @@
#: ../imagery/i.gensig/parse.c:41
#, fuzzy, c-format
msgid "Group <%s> not found in current mapset"
#: ../imagery/i.cluster/open_files.c:21 ../imagery/i.maxlik/open.c:19
#: ../imagery/i.smap/shapiro/parse.c:61 ../imagery/i.gensigset/parse.c:50
#: ../imagery/i.gensig/parse.c:44
#, fuzzy, c-format
msgid "Subgroup <%s> in group <%s> not found"
#: ../imagery/i.cluster/open_files.c:33
#, c-format
@@ -22506,7 +22506,7 @@
#: ../imagery/i.cluster/open_files.c:38
#, fuzzy
msgid "No raster maps found"
-msgstr "Ï 3Ä ñÜóôåñ ÷Üñôçò <%s> äåí âñÝèçêå"
+msgstr "Î 3Î ÏάÏÏÎµÏ ÏάÏÏÎ·Ï <%s> δεν βÏÎθηκε"
#: ../imagery/i.cluster/open_files.c:42
#, c-format
@@ -22525,13 +22525,13 @@
#: ../imagery/i.cluster/open_files.c:64
#, fuzzy, c-format
msgid "Unable to open seed signature file <%s>"
+msgstr "ÎδÏ
#: ../imagery/i.cluster/open_files.c:70 ../imagery/i.maxlik/open.c:54
#: ../imagery/i.smap/shapiro/read_sig.c:23
#, c-format
msgid "Unable to read signature file <%s>"
-msgstr "Áäõíáìßá áíÜãíùóçò áñ÷åßïõ õðïãñáöÞò <%s>"
+msgstr "ÎδÏ
Ï
ÏογÏαÏÎ®Ï <%s>"
#: ../imagery/i.cluster/open_files.c:74 ../imagery/i.maxlik/open.c:58
#, c-format
@@ -22767,12 +22767,12 @@
#: ../imagery/i.modis.qc/main.c:98
#, fuzzy
msgid "Name of input surface reflectance QC layer [bit array]"
-msgstr "¼íïìá ÷Üñôç õðïâÜèñïõ ñÜóôåñ"
+msgstr "Îνομα ÏάÏÏη Ï
ÏοβάθÏοÏ
ÏάÏÏεÏ"
#: ../imagery/i.modis.qc/main.c:103
#, fuzzy
msgid "Name for output QC type classification layer"
-msgstr "¼íïìá åîáãüìåíïõ äéáíõóìáôéêïý ÷Üñôç"
διανÏ
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη"
#: ../imagery/i.modis.qc/main.c:109
msgid "Name of MODIS product type"
@@ -22788,7 +22788,7 @@
#: ../imagery/i.modis.qc/main.c:122
#, fuzzy
msgid "Name of QC type to extract"
θα ειÏαÏθεί"
#: ../imagery/i.modis.qc/main.c:123
msgid ""
@@ -22899,7 +22899,7 @@
#: ../imagery/i.maxlik/main.c:79 ../imagery/i.smap/shapiro/parse.c:21
msgid "Name of file containing signatures"
+msgstr "Îνομα ÏοÏ
αÏÏείοÏ
ÏοÏ
ÏεÏιÎÏει Ï
#: ../imagery/i.maxlik/main.c:80
msgid "Generated by either i.cluster, i.class, or i.gensig"
@@ -22930,7 +22930,7 @@
#: ../imagery/i.maxlik/open.c:48
#, fuzzy, c-format
msgid "Unable to open signature file <%s>"
+msgstr "ÎδÏ
ÏάÏÏη raster <%s>"
#: ../imagery/i.his.rgb/h2rmain.c:45 ../imagery/i.rgb.his/r2hmain.c:45
msgid "imagery, color transformation, RGB, HIS"
@@ -22944,37 +22944,37 @@
#: ../imagery/i.his.rgb/h2rmain.c:53
msgid "Name of input raster map (hue)"
-msgstr "¼íïìá åéóáãþìåíïõ ñÜóôåñ ÷Üñôç (hue)"
+msgstr "Îνομα ειÏαγÏμενοÏ
ÏάÏÏÎµÏ ÏάÏÏη (hue)"
#: ../imagery/i.his.rgb/h2rmain.c:57
msgid "Name of input raster map (intensity)"
-msgstr "¼íïìá åéóáãþìåíïõ ñÜóôåñ ÷Üñôç (intensity)"
ÏάÏÏÎµÏ ÏάÏÏη (intensity)"
#: ../imagery/i.his.rgb/h2rmain.c:61
msgid "Name of input raster map (saturation)"
-msgstr "¼íïìá åéóáãþìåíïõ ñÜóôåñ ÷Üñôç (saturation)"
ÏάÏÏÎµÏ ÏάÏÏη (saturation)"
#: ../imagery/i.his.rgb/h2rmain.c:65
msgid "Name for output raster map (red)"
-msgstr "¼íïìá åîáãüìåíïõ ñÜóôåñ ÷Üñôç (red)"
ÏάÏÏÎµÏ ÏάÏÏη (red)"
#: ../imagery/i.his.rgb/h2rmain.c:69
msgid "Name for output raster map (green)"
-msgstr "¼íïìá åîáãüìåíïõ ñÜóôåñ ÷Üñôç (green)"
ÏάÏÏÎµÏ ÏάÏÏη (green)"
#: ../imagery/i.his.rgb/h2rmain.c:73
msgid "Name for output raster map (blue)"
-msgstr "¼íïìá åîáãüìåíïõ ñÜóôåñ ÷Üñôç (blue)"
ÏάÏÏÎµÏ ÏάÏÏη (blue)"
#: ../imagery/i.his.rgb/h2rmain.c:95 ../imagery/i.rgb.his/r2hmain.c:93
#, fuzzy, c-format
msgid "Unable to read raster map row %ld"
-msgstr "Áäõíáìßá äçìéïõñãßáò ñÜóôåñ ÷Üñôç"
+msgstr "ÎδÏ
ναμία δημιοÏ
ÏÎ³Î¯Î±Ï ÏάÏÏÎµÏ ÏάÏÏη"
#: ../imagery/i.his.rgb/h2rmain.c:104 ../imagery/i.rgb.his/r2hmain.c:102
#, fuzzy, c-format
msgid "Failed writing raster map row %ld"
#: ../imagery/i.his.rgb/openfiles.c:23 ../imagery/i.his.rgb/openfiles.c:25
#: ../imagery/i.his.rgb/openfiles.c:27 ../imagery/i.rgb.his/openfiles.c:37
@@ -22988,7 +22988,7 @@
#: ../imagery/i.smap/bouman/interp.c:237
msgid "Invalid parameter values"
-msgstr "ËÜèïò ðáñÜìåôñïé"
+msgstr "ÎÎ¬Î¸Î¿Ï ÏαÏάμεÏÏοι"
#: ../imagery/i.smap/bouman/segment.c:70
msgid "Number of classes must be < 256"
@@ -23024,7 +23024,7 @@
#: ../imagery/i.gensigset/openfiles.c:15 ../imagery/i.gensig/openfiles.c:16
#, fuzzy, c-format
msgid "Unable to read REF file for subgroup <%s> in group <%s>"
+msgstr "ÎδÏ
ναμία δημιοÏ
#: ../imagery/i.smap/shapiro/openfiles.c:19
#: ../imagery/i.smap/shapiro/read_sig.c:17
@@ -23052,7 +23052,7 @@
#: ../imagery/i.smap/shapiro/read_sig.c:30
#, fuzzy, c-format
msgid "Signature file <%s> is empty"
+msgstr "ÎδÏ
#: ../imagery/i.gensigset/subcluster.c:75
#, c-format
@@ -23067,7 +23067,7 @@
#: ../imagery/i.gensigset/subcluster.c:87
#, fuzzy, c-format
msgid "Number of subclasses set to %d"
ÏοÏεÏιοÏÏν για ÏÏ
Ïά"
#: ../imagery/i.gensigset/subcluster.c:102
#, c-format
@@ -23113,7 +23113,7 @@
#: ../imagery/i.gensigset/main.c:42
#, fuzzy
msgid "Generates statistics for i.smap from raster map."
-msgstr "ÐáñÜãåé óôáôéóôéêÜ üãêïõ ãéá 3Ä ñÜóôåñ ÷Üñôåò."
+msgstr "ΠαÏάγει ÏÏαÏιÏÏικά ÏγκοÏ
για 3Î ÏάÏÏÎµÏ ÏάÏÏεÏ."
#: ../imagery/i.gensigset/main.c:52
#, c-format
@@ -23133,12 +23133,12 @@
#: ../imagery/i.gensigset/write_sig.c:13 ../imagery/i.gensig/write_sig.c:15
#, fuzzy, c-format
msgid "Unable to create signature file <%s>"
+msgstr "ÎδÏ
ναμία δημιοÏ
#: ../imagery/i.gensigset/write_sig.c:16 ../imagery/i.gensig/write_sig.c:18
#, fuzzy
msgid "Writing signatures..."
-msgstr "ÅããñáöÞ %s áðü %s..."
+msgstr "ÎγγÏαÏή %s αÏÏ %s..."
#: ../imagery/i.gensigset/parse.c:13 ../imagery/i.gensig/parse.c:14
msgid "Ground truth training map"
@@ -23156,7 +23156,7 @@
#: ../imagery/i.zc/main.c:57
#, fuzzy
msgid "imagery, edges"
#: ../imagery/i.zc/main.c:59
msgid "Zero-crossing \"edge detection\" raster function for image processing."
@@ -23317,12 +23317,12 @@
#: ../imagery/i.fft/fftmain.c:84
#, fuzzy
msgid "Name for output real part arrays stored as raster map"
ÏάÏÏÎµÏ ÏάÏÏη"
#: ../imagery/i.fft/fftmain.c:88
#, fuzzy
msgid "Name for output imaginary part arrays stored as raster map"
ÏάÏÏÎµÏ ÏάÏÏη"
#: ../imagery/i.fft/fftmain.c:96
msgid "Range of values in output display files"
@@ -23339,7 +23339,7 @@
#: ../imagery/i.fft/fftmain.c:166
#, fuzzy, c-format
msgid "Reading the raster map <%s>..."
#: ../imagery/i.fft/fftmain.c:182
msgid "Starting FFT..."
@@ -23352,7 +23352,7 @@
#: ../imagery/i.fft/fftmain.c:225
#, fuzzy
msgid "Writing transformed data..."
#: ../imagery/i.fft/fftmain.c:231
msgid "Writing viewable versions of transformed data..."
@@ -23377,7 +23377,7 @@
#: ../imagery/i.gensig/main.c:41
#, fuzzy
msgid "Generates statistics for i.maxlik from raster map."
#: ../imagery/i.gensig/check.c:21
#, c-format
@@ -23418,12 +23418,12 @@
#: ../imagery/i.pca/main.c:72
#, fuzzy
msgid "Name of two or more input raster maps"
-msgstr "¼íïìá åéóáãþìåíïõ ñÜóôåñ ÷Üñôç "
ÏάÏÏÎµÏ ÏάÏÏη "
#: ../imagery/i.pca/main.c:75
#, fuzzy
msgid "Base name for output raster maps"
ÏάÏÏÎµÏ ÏάÏÏη"
#: ../imagery/i.pca/main.c:77
msgid "A numerical suffix will be added for each component map"
@@ -23432,7 +23432,7 @@
#: ../imagery/i.pca/main.c:90
#, fuzzy
msgid "Rescaling range for output maps"
ÏάÏÏÎµÏ ÏάÏÏη"
#: ../imagery/i.pca/main.c:92
msgid "For no rescaling use 0,0"
@@ -23461,12 +23461,12 @@
#: ../imagery/i.pca/main.c:373
#, fuzzy, c-format
msgid "Rescaling to range %d,%d..."
#: ../imagery/i.pca/main.c:381
#, fuzzy
msgid "Calculating principal components..."
+msgstr "ÎδÏ
ναμία Ï
γÏνοÏ
#: ../imagery/i.pca/support.c:44
msgid "Eigen values, (vectors), and [percent importance]:"
@@ -23507,7 +23507,7 @@
#: ../imagery/i.rectify/cp.c:32
#, fuzzy
msgid "Invalid order"
νÏεÏαγμÎνεÏ"
#: ../imagery/i.rectify/main.c:90
msgid "imagery, rectify"
@@ -23548,17 +23548,17 @@
#: ../imagery/i.topo.corr/main.c:94
#, fuzzy
msgid "Name of reflectance raster maps to be corrected topographically"
θα ειÏαÏθεί"
#: ../imagery/i.topo.corr/main.c:98
#, fuzzy
msgid "Name (flag -i) or prefix for output raster maps"
ÏάÏÏÎµÏ ÏάÏÏη"
#: ../imagery/i.topo.corr/main.c:102
#, fuzzy
msgid "Name of input base raster map (elevation or illumination)"
#: ../imagery/i.topo.corr/main.c:108
msgid "Solar zenith in degrees"
@@ -23575,7 +23575,7 @@
#: ../imagery/i.topo.corr/main.c:126
#, fuzzy
msgid "Output sun illumination terrain model"
ÏάÏÏÎµÏ ÏάÏÏη"
#: ../imagery/i.topo.corr/main.c:132
msgid "Solar azimuth is necessary to calculate illumination terrain model"
@@ -23588,7 +23588,7 @@
#: ../imagery/i.topo.corr/main.c:167
#, fuzzy
msgid "Elevation raster map of unknown type"
#: ../imagery/i.topo.corr/main.c:201
msgid "Illumination model is of CELL type"
@@ -23597,7 +23597,7 @@
#: ../imagery/i.topo.corr/main.c:208
#, fuzzy, c-format
msgid "Reflectance of raster map <%s> is not of DCELL type - ignored"
#: ../imagery/i.topo.corr/correction.c:100
#, c-format
@@ -23617,27 +23617,27 @@
#: ../imagery/i.rgb.his/r2hmain.c:53
msgid "Name of input raster map (red)"
-msgstr "¼íïìá åéóáãþìåíïõ ñÜóôåñ ÷Üñôç (red)"
#: ../imagery/i.rgb.his/r2hmain.c:57
msgid "Name of input raster map (green)"
-msgstr "¼íïìá åéóáãþìåíïõ ñÜóôåñ ÷Üñôç (green)"
#: ../imagery/i.rgb.his/r2hmain.c:61
msgid "Name of input raster map (blue)"
-msgstr "¼íïìá åéóáãþìåíïõ ñÜóôåñ ÷Üñôç (blue)"
#: ../imagery/i.rgb.his/r2hmain.c:65
msgid "Name for output raster map (hue)"
-msgstr "¼íïìá åîáãüìåíïõ ñÜóôåñ ÷Üñôç (hue)"
#: ../imagery/i.rgb.his/r2hmain.c:69
msgid "Name for output raster map (intensity)"
-msgstr "¼íïìá åîáãüìåíïõ ñÜóôåñ ÷Üñôç (intensity)"
#: ../imagery/i.rgb.his/r2hmain.c:73
msgid "Name for output raster map (saturation)"
-msgstr "¼íïìá åîáãüìåíïõ ñÜóôåñ ÷Üñôç (saturation)"
#: ../imagery/i.landsat.toar/main.c:67
msgid ""
@@ -23654,7 +23654,7 @@
#: ../imagery/i.landsat.toar/main.c:81
#, fuzzy
msgid "Prefix for output raster maps"
ÏάÏÏÎµÏ ÏάÏÏη"
#: ../imagery/i.landsat.toar/main.c:83
msgid "Example: 'B.toar.' generates B.toar.1, B.toar.2, ..."
@@ -23763,7 +23763,7 @@
#: ../imagery/i.landsat.toar/main.c:354 ../imagery/i.landsat.toar/main.c:500
#, fuzzy, c-format
msgid "Unable to read data type of raster map <%s>"
+msgstr "ÎδÏ
#: ../imagery/i.landsat.toar/main.c:479
msgid "Calculating..."
@@ -23772,12 +23772,12 @@
#: ../imagery/i.landsat.toar/main.c:518
#, fuzzy, c-format
msgid "Writing %s of <%s> to <%s>..."
#: ../imagery/i.landsat.toar/main.c:519
#, fuzzy
msgid "radiance"
#: ../imagery/i.landsat.toar/main.c:520
msgid "temperature"
@@ -23790,7 +23790,7 @@
#: ../imagery/i.landsat.toar/landsat_met.c:117
#, fuzzy, c-format
msgid "Metadata file <%s> not found"
#: ../imagery/i.ifft/ifftmain.c:70
msgid "Inverse Fast Fourier Transform (IFFT) for image processing."
@@ -23799,12 +23799,12 @@
#: ../imagery/i.ifft/ifftmain.c:75
#, fuzzy
msgid "Name of input raster map (image fft, real part)"
ÏάÏÏÎµÏ ÏάÏÏη "
#: ../imagery/i.ifft/ifftmain.c:79
#, fuzzy
msgid "Name of input raster map (image fft, imaginary part"
ÏάÏÏÎµÏ ÏάÏÏη "
#: ../imagery/i.ifft/ifftmain.c:101
msgid ""
@@ -23826,7 +23826,7 @@
#: ../imagery/i.ifft/ifftmain.c:151
#, fuzzy
msgid "Masking raster maps..."
-msgstr "ÓöÜëìá êáôÜ ôï êëåßóéìï 3Ä ñÜóôåñ áñ÷åßïõ"
+msgstr "ΣÏάλμα καÏά Ïο κλείÏιμο 3Î ÏάÏÏÎµÏ Î±ÏÏείοÏ
#: ../imagery/i.ifft/ifftmain.c:211
msgid "Starting Inverse FFT..."
@@ -23835,7 +23835,7 @@
#: ../imagery/i.ifft/ifftmain.c:225
#, fuzzy
msgid "Writing data..."
#: ../imagery/i.ifft/orig_wind.c:27
msgid "The real and imaginary original windows did not match"
@@ -23860,7 +23860,7 @@
#: ../imagery/i.cca/main.c:84
#, fuzzy
msgid "imagery, statistics"
#: ../imagery/i.cca/main.c:86
msgid "Canonical components analysis (cca) program for image processing."
@@ -23869,7 +23869,7 @@
#: ../imagery/i.cca/main.c:99
#, fuzzy
msgid "File containing spectral signatures"
+msgstr "Îνομα ÏοÏ
αÏÏείοÏ
ÏοÏ
#: ../imagery/i.cca/main.c:102
msgid "Output raster map prefix name"
@@ -23978,7 +23978,7 @@
#: ../visualization/nviz/src/nviz_init.c:69
#, fuzzy
msgid "Name of raster map(s) for Color"
-msgstr "×ñþìá"
+msgstr "ΧÏÏμα"
#: ../visualization/nviz/src/nviz_init.c:78
msgid "Name of vector lines/areas overlay map(s)"
@@ -24217,7 +24217,7 @@
#, fuzzy, c-format
msgid "Unable to add database link for vector map <%s>"
msgstr ""
-"Áäõíáìßá ðñïóèÞêçò óýíäåóçò ìå âÜóç äåäïìÝíùí ãéá ôïí äéáíõóìáôéêü ÷Üñôç <%s>"
+"ÎδÏ
ναμία ÏÏοÏÎ¸Î®ÎºÎ·Ï ÏÏνδεÏÎ·Ï Î¼Îµ βάÏη δεδομÎνÏν για Ïον διανÏ
ÏμαÏÎ¹ÎºÏ ÏάÏÏη <%s>"
#: ../vector/v.kernel/main.c:67
#, c-format
@@ -24307,12 +24307,12 @@
#: ../vector/v.kernel/main.c:225
#, fuzzy
msgid "Unknown node method"
-msgstr "¶ãíùóôïò ôýðïò"
+msgstr "ÎγνÏÏÏÎ¿Ï ÏÏÏοÏ"
#: ../vector/v.kernel/main.c:243
#, fuzzy
msgid "Unknown kernel function"
#: ../vector/v.kernel/main.c:249
msgid ""
@@ -24412,28 +24412,28 @@
#: ../vector/v.digit/var.c:122
#, fuzzy, c-format
msgid "Cannot set variable code = %d"
-msgstr "Äåí ìðïñþ íá äù ëßóôá ôùí ðéíÜêùí:\n"
+msgstr "Îεν μÏοÏÏ Î½Î± Î´Ï Î»Î¯ÏÏα ÏÏν ÏινάκÏν:\n"
#: ../vector/v.digit/var.c:143
#, fuzzy, c-format
msgid "Cannot get type of variable %s"
#: ../vector/v.digit/var.c:164
#, fuzzy, c-format
msgid "Cannot get code of variable %s"
#: ../vector/v.digit/var.c:184
#, fuzzy, c-format
msgid "Cannot get name of variable %d"
#: ../vector/v.digit/var.c:199 ../vector/v.digit/var.c:215
#: ../vector/v.digit/var.c:231
#, fuzzy, c-format
msgid "Cannot get value of variable code = %d"
#: ../vector/v.digit/vertex.c:35
msgid "Split line:"
@@ -24505,7 +24505,7 @@
#: ../vector/v.digit/line.c:55
#, fuzzy
msgid "Form"
-msgstr "Äéáìüñöùóç"
+msgstr "ÎιαμÏÏÏÏÏη"
#: ../vector/v.digit/line.c:64
msgid "New record was created.<BR>"
@@ -24554,7 +24554,7 @@
#: ../vector/v.digit/line.c:407
#, fuzzy
msgid "Delete line and exit"
-msgstr "Ôõðþíåé ôïí ðßíáêá êáé êëåéíåé (Ýîïäïò)"
+msgstr "ΤÏ
ÏÏνει Ïον Ïίνακα και κλεινει (ÎξοδοÏ)"
#: ../vector/v.digit/line.c:480
msgid "Delete point, line, boundary, or centroid:"
@@ -24571,22 +24571,22 @@
#: ../vector/v.digit/form.c:108 ../vector/v.digit/generate.c:77
#, fuzzy
msgid "Cannot open driver"
-msgstr "Äåí ìðïñþ íá áíïßîù ôçí âÜóç äåäïìÝíùí %s"
+msgstr "Îεν μÏοÏÏ Î½Î± Î±Î½Î¿Î¯Î¾Ï Ïην βάÏη δεδομÎνÏν %s"
#: ../vector/v.digit/form.c:120 ../vector/v.digit/generate.c:89
#, fuzzy
msgid "Cannot open database"
-msgstr "Áäõíáìßá áíïßãìáôïò âÜóçò äåäïìåíùí <%s>"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï Î²Î¬ÏÎ·Ï Î´ÎµÎ´Î¿Î¼ÎµÎ½Ïν <%s>"
#: ../vector/v.digit/form.c:133
#, fuzzy
msgid "Cannot describe table"
-msgstr "Áäõíáìßá ðåñéãñáöÞò ðßíáêá <%s>"
+msgstr "ÎδÏ
ναμία ÏεÏιγÏαÏÎ®Ï Ïίνακα <%s>"
#: ../vector/v.digit/form.c:162
#, fuzzy
msgid "Cannot find column type"
+msgstr "ÎδÏ
#: ../vector/v.digit/form.c:199
#, c-format
@@ -24600,28 +24600,28 @@
#: ../vector/v.digit/form.c:256
#, fuzzy
msgid "Cannot update table"
+msgstr "ÎδÏ
#: ../vector/v.digit/c_face.c:183 ../vector/v.digit/c_face.c:241
#, fuzzy, c-format
msgid "Cannot open driver %s"
+msgstr "ÎδÏ
#: ../vector/v.digit/c_face.c:189 ../vector/v.digit/c_face.c:251
#, fuzzy, c-format
msgid "Cannot open database %s"
+msgstr "ÎδÏ
#: ../vector/v.digit/c_face.c:242
#, fuzzy
msgid "Cannot open driver "
+msgstr "ÎδÏ
#: ../vector/v.digit/c_face.c:252 ../vector/v.digit/attr.c:137
#: ../vector/v.digit/attr.c:650
#, fuzzy, c-format
msgid "Cannot open database %s by driver %s"
-msgstr "Áäõíáìßá áíïßãìáôïò ôçò âÜóçò äåäïìÝíùí <%s> ìå ôïí ïäçãü <%s>"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï ÏÎ·Ï Î²Î¬ÏÎ·Ï Î´ÎµÎ´Î¿Î¼ÎνÏν <%s> με Ïον Î¿Î´Î·Î³Ï <%s>"
#: ../vector/v.digit/c_face.c:269 ../vector/v.vol.rst/main.c:596
#, c-format
@@ -24631,7 +24631,7 @@
#: ../vector/v.digit/c_face.c:270
#, fuzzy
msgid "Cannot create table: "
-msgstr "Áäõíáìßá óêáíáñßóìáôïò çìåñïìçíßáò:"
+msgstr "ÎδÏ
ναμία ÏκαναÏίÏμαÏÎ¿Ï Î·Î¼ÎµÏομηνίαÏ:"
#: ../vector/v.digit/c_face.c:282 ../vector/v.sample/main.c:219
#: ../vector/v.net.distance/main.c:212 ../vector/v.net.path/path.c:113
@@ -24644,7 +24644,7 @@
#: ../vector/v.digit/c_face.c:283
#, fuzzy
msgid "Cannot create index:\n"
+msgstr "ÎδÏ
#: ../vector/v.digit/c_face.c:294 ../vector/v.db.connect/main.c:336
#, c-format
@@ -24654,7 +24654,7 @@
#: ../vector/v.digit/c_face.c:295
#, fuzzy
msgid "Cannot grant privileges on table:\n"
#: ../vector/v.digit/c_face.c:312
msgid ""
@@ -24687,33 +24687,33 @@
#: ../vector/v.digit/generate.c:78
#, fuzzy, c-format
msgid "Cannot open driver '%s'<BR>"
+msgstr "ÎδÏ
#: ../vector/v.digit/generate.c:91
#, fuzzy, c-format
msgid "Cannot open database '%s' by driver '%s'<BR>"
+msgstr "ÎδÏ
#: ../vector/v.digit/generate.c:106
#, fuzzy
msgid "Cannot open select cursor"
+msgstr "ÎδÏ
#: ../vector/v.digit/generate.c:110
#, fuzzy, c-format
msgid ""
"Cannot open select cursor:<BR>'%s'<BR>on database '%s' by driver '%s'<BR>"
+msgstr "ÎδÏ
#: ../vector/v.digit/generate.c:121
#, fuzzy
msgid "Cannot fetch next record"
-msgstr "Áäýíáôç ç åðéëïãÞ äåäïìÝíùí: \n"
+msgstr "ÎδÏναÏη η εÏιλογή δεδομÎνÏν: \n"
#: ../vector/v.digit/generate.c:130
#, fuzzy
msgid "No database record"
-msgstr "Äßíåé ôç ëßóôá ãéá üëïõò ôïõò ïäçãïýò âÜóåùí äåäïìÝíùí"
+msgstr "Îίνει Ïη λίÏÏα για ÏλοÏ
Ï ÏοÏ
Ï Î¿Î´Î·Î³Î¿ÏÏ Î²Î¬ÏεÏν δεδομÎνÏν"
#: ../vector/v.digit/generate.c:223
#, c-format
@@ -24745,17 +24745,17 @@
#: ../vector/v.digit/zoom.c:158
#, fuzzy
msgid "New center"
-msgstr "Ç äéÜôáîç ôçò âÜóçò äåäïìÝíùí"
+msgstr "ΠδιάÏαξη ÏÎ·Ï Î²Î¬ÏÎ·Ï Î´ÎµÎ´Î¿Î¼ÎνÏν"
#: ../vector/v.digit/zoom.c:247
#, fuzzy, c-format
msgid "Cannot find window '%s'"
#: ../vector/v.digit/attr.c:94
#, fuzzy
msgid "Cannot create new record."
-msgstr "Äåí ãßíåôáé ç ìåôáêßíçóç ôïõ êÝñóïñá."
+msgstr "Îεν γίνεÏαι η μεÏακίνηÏη ÏοÏ
κÎÏÏοÏα."
#: ../vector/v.digit/attr.c:127
msgid "Database table for this layer is not defined"
@@ -24764,12 +24764,12 @@
#: ../vector/v.digit/attr.c:145 ../vector/v.digit/attr.c:659
#, fuzzy, c-format
msgid "Cannot select record from table %s"
#: ../vector/v.digit/attr.c:191
#, fuzzy
msgid "Display categories:"
#: ../vector/v.digit/attr.c:192 ../vector/v.digit/attr.c:463
msgid "Select line"
@@ -24778,7 +24778,7 @@
#: ../vector/v.digit/attr.c:301 ../vector/v.digit/attr.c:406
#, fuzzy
msgid "Copy attributes:"
+msgstr "ÎδÏ
#: ../vector/v.digit/attr.c:302 ../vector/v.digit/attr.c:407
msgid "Select source object"
@@ -24819,7 +24819,7 @@
#, fuzzy
msgid "Database connection not defined<BR>"
msgstr ""
-"Äåí Ý÷åé êáèïñéóôåß ç óýíäåóç ìå ôç âÜóç äåäïìÝíùí ãéá ôï åðßðåäï (layer) %d"
+"Îεν ÎÏει καθοÏιÏÏεί η ÏÏνδεÏη με Ïη βάÏη δεδομÎνÏν για Ïο εÏίÏεδο (layer) %d"
#: ../vector/v.digit/attr.c:553
#, c-format
@@ -24834,7 +24834,7 @@
#: ../vector/v.digit/attr.c:577
#, fuzzy
msgid "No categories"
-msgstr "×ñþìá"
+msgstr "ΧÏÏμα"
#: ../vector/v.digit/attr.c:668
#, c-format
@@ -24846,7 +24846,7 @@
#: ../vector/v.digit/attr.c:680
#, fuzzy, c-format
msgid "Cannot delete record: %s"
#: ../vector/v.extrude/main.c:69
msgid "vector, geometry, 3D"
@@ -25043,12 +25043,12 @@
#: ../vector/v.net.connectivity/main.c:66
#, fuzzy
msgid "Name of node capacity column"
-msgstr "Íïýìåñï åðéðÝäïõ"
+msgstr "ÎοÏμεÏο εÏιÏÎδοÏ
#: ../vector/v.net.connectivity/main.c:70
#, fuzzy
msgid "Set1 layer number or name"
#: ../vector/v.net.connectivity/main.c:71
#: ../vector/v.net.connectivity/main.c:76
@@ -25067,7 +25067,7 @@
#: ../vector/v.net.connectivity/main.c:86
#, fuzzy
msgid "Set2 layer number or name"
#: ../vector/v.net.connectivity/main.c:87
#: ../vector/v.net.connectivity/main.c:92
@@ -25094,7 +25094,7 @@
#: ../vector/v.net.connectivity/main.c:151
#, fuzzy, c-format
msgid "%s is empty"
+msgstr "ÎδÏ
#: ../vector/v.delaunay2/memory.c:64 ../vector/v.delaunay2/memory.c:70
#: ../vector/v.delaunay2/memory.c:74 ../vector/v.delaunay2/memory.c:84
@@ -25102,7 +25102,7 @@
#: ../vector/v.delaunay2/memory.c:108
#, fuzzy
msgid "Not enough memory."
-msgstr "Åêôüò ìíÞìçò"
+msgstr "ÎκÏÏÏ Î¼Î½Î®Î¼Î·Ï"
#: ../vector/v.delaunay2/memory.c:124
msgid "All allocated edges have been used."
@@ -25112,7 +25112,7 @@
#: ../vector/v.voronoi/dt_main.c:46
#, fuzzy
msgid "vector, geometry, triangulation"
#: ../vector/v.delaunay2/main.c:87 ../vector/v.voronoi/dt_main.c:47
msgid ""
@@ -25139,12 +25139,12 @@
#: ../vector/v.delaunay2/main.c:152
#, fuzzy
msgid "Writing edges..."
#: ../vector/v.delaunay2/main.c:162
#, fuzzy
msgid "Calculate area centroids..."
+msgstr "ÎδÏ
ναμία Ï
γÏνοÏ
#: ../vector/v.delaunay2/main.c:172 ../vector/v.category/main.c:290
msgid "Unable to calculate area centroid"
@@ -25153,7 +25153,7 @@
#: ../vector/v.delaunay2/main.c:178
#, fuzzy
msgid "Unable to calculate area centroid z coordinate"
+msgstr "ÎδÏ
ναμία Ï
γÏνοÏ
#: ../vector/v.out.dxf/write_dxf.c:21
#, c-format
@@ -25322,7 +25322,7 @@
#: ../vector/v.transform/main.c:295
#, fuzzy, c-format
msgid "Unable to tokenize column string: [%s]"
+msgstr "ÎδÏ
ÏάÏÏη raster <%s>"
#: ../vector/v.transform/main.c:367 ../vector/v.category/main.c:556
#: ../vector/v.proj/main.c:296 ../vector/v.type/main.c:234
@@ -25330,7 +25330,7 @@
#: ../vector/v.clean/main.c:281 ../vector/v.kcv/main.c:161
#, fuzzy
msgid "Failed to copy attribute table to output map"
+msgstr "ÎδÏ
εξαγÏμενοÏ
ÏάÏÏη"
#: ../vector/v.transform/main.c:373
#, c-format
@@ -25460,12 +25460,12 @@
#: ../vector/v.in.ascii/in.c:114
#, fuzzy
msgid "Number of column used as y coordinate (points mode)"
ÏÏμνημα."
#: ../vector/v.in.ascii/in.c:124
#, fuzzy
msgid "Number of column used as z coordinate (points mode)"
ÏÏμνημα."
#: ../vector/v.in.ascii/in.c:125
msgid "First column is 1. If 0, z coordinate is not used"
@@ -25474,7 +25474,7 @@
#: ../vector/v.in.ascii/in.c:135
#, fuzzy
msgid "Number of column used as category (points mode)"
ÏÏμνημα."
#: ../vector/v.in.ascii/in.c:137
msgid ""
@@ -25676,12 +25676,12 @@
#: ../vector/v.in.ascii/a2b.c:118
#, fuzzy, c-format
msgid "Unparsable longitude value: [%s]"
+msgstr "ÎδÏ
ναμία δημιοÏ
#: ../vector/v.in.ascii/a2b.c:121
#, fuzzy, c-format
msgid "Unparsable latitude value: [%s]"
+msgstr "ÎδÏ
ναμία δημιοÏ
#: ../vector/v.in.ascii/a2b.c:154
msgid "End of ASCII file reached before end of categories"
@@ -25913,7 +25913,7 @@
#: ../vector/v.info/main.c:212 ../vector/v.convert/att.c:67
#, fuzzy, c-format
msgid "Unable to open driver <%s>"
-msgstr "Áäõíáìßá åêêßíçóçò ôïõ ïäçãïý <%s>"
+msgstr "ÎδÏ
ναμία εκκίνηÏÎ·Ï ÏοÏ
Î¿Î´Î·Î³Î¿Ï <%s>"
#: ../vector/v.info/main.c:240
#, c-format
@@ -25968,7 +25968,7 @@
#: ../vector/v.info/main.c:264
#, fuzzy, c-format
msgid " Type of Map: %s (level: %i) "
-msgstr "Ôýðïò "
+msgstr "ΤÏÏÎ¿Ï "
#: ../vector/v.info/main.c:272
#, c-format
@@ -26023,7 +26023,7 @@
#: ../vector/v.net.bridge/main.c:45
#, fuzzy
msgid "vector, network, articulation points"
#: ../vector/v.net.bridge/main.c:47
msgid "Computes bridges and articulation points in the network."
@@ -26150,7 +26150,7 @@
#: ../vector/v.category/main.c:554
#, fuzzy
msgid "Copying attribute table(s)..."
-msgstr "ÁíôéãñÜöåé Ýíá ðßíáêá"
+msgstr "ÎνÏιγÏάÏει Îνα Ïίνακα"
#: ../vector/v.category/main.c:560
#, c-format
@@ -26195,12 +26195,12 @@
#: ../vector/v.out.ogr/main.c:147
#, fuzzy
msgid "OGR dataset creation option (format specific, NAME=VALUE)"
-msgstr "ÏÍÏÌÁ"
+msgstr "ÎÎÎÎÎ"
#: ../vector/v.out.ogr/main.c:157
#, fuzzy
msgid "OGR layer creation option (format specific, NAME=VALUE)"
-msgstr "ÏÍÏÌÁ"
+msgstr "ÎÎÎÎÎ"
#: ../vector/v.out.ogr/main.c:162
msgid "Open an existing datasource for update"
@@ -26346,7 +26346,7 @@
#: ../vector/v.out.ogr/main.c:450
#, fuzzy
msgid "Nothing to export"
#: ../vector/v.out.ogr/main.c:483
#, c-format
@@ -26356,18 +26356,18 @@
#: ../vector/v.out.ogr/main.c:508
#, fuzzy, c-format
msgid "Unable to open OGR data source '%s'"
-msgstr "Áäõíáìßá áíïßãìáôïò OGR ðçãÞ äåäïìÝíùí '%s'"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï OGR Ïηγή δεδομÎνÏν '%s'"
#: ../vector/v.out.ogr/main.c:522
#, fuzzy, c-format
msgid "Layer <%s> already exists in OGR data source '%s'"
+msgstr "ÎδÏ
#: ../vector/v.out.ogr/main.c:526
#, fuzzy, c-format
msgid "OGR layer <%s> already exists and will be overwritten"
msgstr ""
-"Ï äéáíõóìáôéêüò ÷Üñôçò <%s> õðÜñ÷åé Þäç êáé èá áíôéêáôáóôáèåß (overwritten)"
+"ΠδιανÏ
ÏμαÏικÏÏ ÏάÏÏÎ·Ï <%s> Ï
ÏάÏÏει ήδη και θα ανÏικαÏαÏÏαθεί (overwritten)"
#: ../vector/v.out.ogr/main.c:567
msgid "Overriding existing user-defined 'SHPT=' LCO."
@@ -26407,7 +26407,7 @@
#: ../vector/v.out.ogr/main.c:713
#, fuzzy, c-format
msgid "Exporting %i geometries..."
#: ../vector/v.out.ogr/main.c:795
#, c-format
@@ -26422,12 +26422,12 @@
#: ../vector/v.out.ogr/main.c:933
#, fuzzy, c-format
msgid "Exporting %i kernels..."
#: ../vector/v.out.ogr/main.c:992
#, fuzzy, c-format
msgid "Exporting %i volumes..."
#: ../vector/v.out.ogr/main.c:993
msgid "Export of volumes not implemented yet. Skipping."
@@ -26451,7 +26451,7 @@
#: ../vector/v.out.ogr/main.c:1025
#, fuzzy, c-format
msgid "%d features written to <%s> (%s)."
-msgstr "Áäõíáìßá áíÜãíùóçò äéáíõóìáôéêïý ÷Üñôç"
+msgstr "ÎδÏ
ναμία ανάγνÏÏÎ·Ï Î´Î¹Î±Î½Ï
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη"
#: ../vector/v.out.ogr/main.c:1067 ../vector/v.out.vtk/writeVTK.c:576
#, c-format
@@ -26482,7 +26482,7 @@
#: ../vector/v.out.ascii/b2a.c:212
#, fuzzy, c-format
msgid "Unable to select record from table <%s> (key %s, column %s)"
+msgstr "ÎδÏ
ναμία δημιοÏ
#: ../vector/v.out.ascii/b2a.c:237 ../vector/v.vect.stats/main.c:394
#: ../vector/v.distance/main.c:377 ../vector/v.distance/main.c:419
@@ -26495,7 +26495,7 @@
#: ../vector/v.out.ascii/b2a.c:239
#, fuzzy, c-format
msgid "Column <%s>: unsupported data type"
#: ../vector/v.out.ascii/out.c:47
msgid "Converts a GRASS binary vector map to a GRASS ASCII vector map."
@@ -26552,7 +26552,7 @@
#: ../vector/v.out.ascii/out.c:188
#, fuzzy, c-format
msgid "Unable to open dig_att file <%s>"
+msgstr "ÎδÏ
#: ../vector/v.support/main.c:40
msgid "vector, metadata"
@@ -26616,12 +26616,12 @@
#: ../vector/v.support/main.c:188
#, fuzzy, c-format
msgid "Unable to open history file for vector map <%s>"
-msgstr "Áäõíáìßá áíïßãìáôïò ôïõ éóôïñéêïý ôïõ äéáíõóìáôéêïý ÷Üñôç <%s>"
+msgstr "ÎδÏ
ιÏÏοÏÎ¹ÎºÎ¿Ï ÏοÏ
διανÏ
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη <%s>"
#: ../vector/v.proj/main.c:63
#, fuzzy
msgid "vector, projection, transformation"
#: ../vector/v.proj/main.c:64
msgid "Re-projects a vector map from one location to the current location."
@@ -26638,7 +26638,7 @@
#: ../vector/v.proj/main.c:100
#, fuzzy
msgid "Name for output vector map (default: input)"
διανÏ
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη"
#: ../vector/v.proj/main.c:105
msgid "List vector maps in input location and exit"
@@ -26754,7 +26754,7 @@
#: ../vector/v.sample/main.c:86
#, fuzzy
msgid "vector, raster, resample"
#: ../vector/v.sample/main.c:88
msgid "Samples a raster map at vector point locations."
@@ -26808,7 +26808,7 @@
#: ../vector/v.sample/main.c:216 ../vector/v.patch/main.c:285
#, fuzzy, c-format
msgid "Unable to create table <%s>"
+msgstr "ÎδÏ
ναμία δημιοÏ
#: ../vector/v.sample/main.c:227
msgid "Checking vector points..."
@@ -26832,7 +26832,7 @@
#: ../vector/v.net.allpairs/main.c:58 ../vector/v.net.timetable/main.c:254
#, fuzzy
msgid "vector, network, shortest path"
-msgstr "äéÜíõóìá, ðßíáêáò ÷ñùìÜôùí"
+msgstr "διάνÏ
Ïμα, ÏÎ¯Î½Î±ÎºÎ±Ï ÏÏÏμάÏÏν"
#: ../vector/v.net.distance/main.c:61
msgid ""
@@ -26849,7 +26849,7 @@
#: ../vector/v.net.distance/main.c:73
#, fuzzy
msgid "From layer number or name"
#: ../vector/v.net.distance/main.c:74 ../vector/v.net.distance/main.c:79
#: ../vector/v.net.distance/main.c:85 ../vector/v.distance/main.c:121
@@ -26868,7 +26868,7 @@
#: ../vector/v.net.distance/main.c:89
#, fuzzy
msgid "To layer number or name"
#: ../vector/v.net.distance/main.c:90 ../vector/v.net.distance/main.c:95
#: ../vector/v.net.distance/main.c:101 ../vector/v.net.distance/main.c:108
@@ -26880,7 +26880,7 @@
#: ../vector/v.net.distance/main.c:94
#, fuzzy
msgid "To category values"
-msgstr "×ñþìá"
+msgstr "ΧÏÏμα"
#: ../vector/v.net.distance/main.c:100
msgid "To WHERE conditions of SQL statement without 'where' keyword"
@@ -26889,7 +26889,7 @@
#: ../vector/v.net.distance/main.c:107
#, fuzzy
msgid "To feature type"
-msgstr "Áäõíáìßá áíïßãìáôïò äéáíõóìáôéêïý ÷Üñôç <%s>"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï Î´Î¹Î±Î½Ï
#: ../vector/v.net.distance/main.c:216 ../vector/v.net.path/path.c:117
#: ../vector/v.net.allpairs/main.c:161 ../vector/v.net.flow/main.c:176
@@ -27002,7 +27002,7 @@
#: ../vector/v.vol.rst/main.c:327
#, fuzzy
msgid "Maximum number of points for approximation in a segment (>npmin)"
#: ../vector/v.vol.rst/main.c:345
msgid "Conversion factor for w-values used for interpolation"
@@ -27063,7 +27063,7 @@
#: ../vector/v.vol.rst/main.c:557
#, fuzzy
msgid "Vector is not 3D"
-msgstr "Ôï äéÜíõóìá äåí åßíáé 3Ä"
+msgstr "Το διάνÏ
Ïμα δεν είναι 3Î"
#: ../vector/v.vol.rst/main.c:612
#, c-format
@@ -27097,7 +27097,7 @@
#: ../vector/v.net/main.c:47
#, fuzzy
msgid "vector, networking, maintenance"
+msgstr "διάνÏ
#: ../vector/v.net/main.c:48
msgid "Performs network maintenance."
@@ -27226,7 +27226,7 @@
#: ../vector/v.convert/att.c:41
#, fuzzy
msgid "Unable to open dig_cats file"
+msgstr "ÎδÏ
#: ../vector/v.convert/read.c:41
msgid "Reading dig file..."
@@ -27394,7 +27394,7 @@
#: ../vector/v.buffer2/main.c:192
#, fuzzy
msgid "Name of column to use for buffer distances"
-msgstr "¼íïìá ôïõ äåýôåñïõ ñÜóôåñ ÷Üñôç ãéá blending"
+msgstr "Îνομα ÏοÏ
δεÏÏεÏοÏ
ÏάÏÏÎµÏ ÏάÏÏη για blending"
#: ../vector/v.buffer2/main.c:200 ../vector/v.buffer/main.c:286
msgid "Scaling factor for attribute column values"
@@ -27466,7 +27466,7 @@
#: ../vector/v.buffer2/main.c:344
#, fuzzy, c-format
msgid "Unable to select data from table <%s>"
-msgstr "Áäõíáìßá öüñôùóçò äåäïìÝíùí ðßíáêá <%s>"
+msgstr "ÎδÏ
ναμία ÏÏÏÏÏÏÎ·Ï Î´ÎµÎ´Î¿Î¼ÎνÏν Ïίνακα <%s>"
#: ../vector/v.buffer2/main.c:380
msgid ""
@@ -27498,7 +27498,7 @@
#: ../vector/v.buffer2/main.c:524
#, fuzzy
msgid "Writing buffers..."
#: ../vector/v.buffer2/main.c:540 ../vector/v.buffer/main.c:607
msgid "Building parts of topology..."
@@ -27524,7 +27524,7 @@
#: ../vector/v.buffer2/main.c:559
#, fuzzy
msgid "Cleaning boundaries at nodes"
#: ../vector/v.buffer2/main.c:574 ../vector/v.buffer/main.c:637
#: ../vector/v.overlay/area_area.c:157
@@ -27535,7 +27535,7 @@
#: ../vector/v.buffer/main.c:644 ../vector/v.buffer/main.c:734
#, fuzzy
msgid "Calculating centroids for areas..."
+msgstr "ÎδÏ
ναμία Ï
γÏνοÏ
#: ../vector/v.buffer2/main.c:594 ../vector/v.buffer2/main.c:686
#: ../vector/v.voronoi/dt_main.c:142 ../vector/v.buffer/main.c:663
@@ -27551,7 +27551,7 @@
#: ../vector/v.buffer2/main.c:644 ../vector/v.buffer/main.c:718
#, fuzzy
msgid "Deleting boundaries..."
#: ../vector/v.patch/main.c:69
msgid "Create a new vector map layer by combining other vector map layers."
@@ -27709,7 +27709,7 @@
#: ../vector/v.net.salesman/main.c:97
#, fuzzy
msgid "vector, network, salesman"
#: ../vector/v.net.salesman/main.c:99
msgid "Creates a cycle connecting given nodes (Traveling salesman problem)."
@@ -27889,7 +27889,7 @@
#: ../vector/v.to.points/main.c:273 ../vector/v.generalize/misc.c:177
#, fuzzy, c-format
msgid "Unable to copy table <%s>"
-msgstr "Áäõíáìßá áíôéãñáöÞò ðßíáêá <%s>"
+msgstr "ÎδÏ
ναμία ανÏιγÏαÏÎ®Ï Ïίνακα <%s>"
#: ../vector/v.to.points/main.c:384
#, c-format
@@ -27900,13 +27900,13 @@
#, fuzzy, c-format
msgid "%s: Unable to read font definition file; use the default"
msgstr ""
-"%s: Áäõíáìßá áíÜãíùóçò ôïõ áñ÷åßïõ ãñáììáôïóåéñÜò, ÷ñçóéìïðïéÞóôå ôï "
-"ðñïåðéëåãìÝíï"
+"%s: ÎδÏ
ναμία ανάγνÏÏÎ·Ï ÏοÏ
αÏÏείοÏ
γÏαμμαÏοÏειÏάÏ, ÏÏηÏιμοÏοιήÏÏε Ïο "
+"ÏÏοεÏιλεγμÎνο"
#: ../vector/v.label.sa/font.c:61
#, fuzzy, c-format
msgid "%s: No font definition file"
-msgstr "%s: Äåí õðáñ÷åéï áñ÷åßï ãñáììáôïóåéñÜò"
+msgstr "%s: Îεν Ï
ÏαÏÏειο αÏÏείο γÏαμμαÏοÏειÏάÏ"
#: ../vector/v.label.sa/main.c:56
msgid "Create optimally placed labels for vector map(s)"
@@ -27933,7 +27933,7 @@
#: ../vector/v.label.sa/labels.c:74
#, fuzzy, c-format
msgid "Cannot allocate %lu bytes of memory"
κÎÏÏοÏα."
#: ../vector/v.label.sa/labels.c:96
#, c-format
@@ -27975,7 +27975,7 @@
#: ../vector/v.clean/rmdac.c:61
#, fuzzy, c-format
msgid "Duplicate area centroids: %d"
+msgstr "ÎδÏ
ναμία Ï
γÏνοÏ
#: ../vector/v.clean/rmline.c:62
#, c-format
@@ -28210,7 +28210,7 @@
#: ../vector/v.db.select/main.c:208 ../vector/v.reclass/main.c:247
#, fuzzy, c-format
msgid "Unable to fetch data from table <%s>"
+msgstr "ÎδÏ
#: ../vector/v.db.select/main.c:253
#, c-format
@@ -28235,7 +28235,7 @@
#: ../vector/v.voronoi/vo_main.c:182
#, fuzzy
msgid "Reading sites..."
#: ../vector/v.voronoi/vo_main.c:192
msgid "Voronoi triangulation..."
@@ -28244,7 +28244,7 @@
#: ../vector/v.voronoi/vo_main.c:277
#, fuzzy
msgid "Writing sites to output..."
#: ../vector/v.voronoi/vo_main.c:350 ../vector/v.extract/main.c:466
msgid "No table"
@@ -28278,32 +28278,32 @@
#: ../vector/v.vect.stats/main.c:133
#, fuzzy
msgid "Name of existing vector map with points"
-msgstr "¼íïìá õðÜñ÷ïíôùò 3Ä ñÜóôåñ ÷Üñôç"
+msgstr "Îνομα Ï
ÏάÏÏονÏÏÏ 3Î ÏάÏÏÎµÏ ÏάÏÏη"
#: ../vector/v.vect.stats/main.c:138
#, fuzzy
msgid "Name of existing vector map with areas"
+msgstr "Îνομα Ï
#: ../vector/v.vect.stats/main.c:150
#, fuzzy
msgid "Layer number for points map"
#: ../vector/v.vect.stats/main.c:154
#, fuzzy
msgid "Layer number for area map"
#: ../vector/v.vect.stats/main.c:170
#, fuzzy
msgid "Method for aggregate statistics"
#: ../vector/v.vect.stats/main.c:177
#, fuzzy
msgid "Column name of points map to use for statistics"
ÏοÏεÏιοÏÏν για ÏÏ
Ïά"
#: ../vector/v.vect.stats/main.c:178
msgid "Column of points map must be numeric"
@@ -28322,7 +28322,7 @@
#: ../vector/v.vect.stats/main.c:194
#, fuzzy
msgid "Column name to upload statistics"
-msgstr "Ascii ñÜóôåñ ÷Üñôçò ðïõ èá åéóá÷èåß"
+msgstr "Ascii ÏάÏÏÎµÏ ÏάÏÏÎ·Ï ÏοÏ
θα ειÏαÏθεί"
#: ../vector/v.vect.stats/main.c:196
msgid ""
@@ -28346,7 +28346,7 @@
#: ../vector/v.vect.stats/main.c:308 ../vector/v.vect.stats/main.c:384
#, fuzzy, c-format
msgid "Unable to open database <%s> with driver <%s>"
+msgstr "ÎδÏ
#: ../vector/v.vect.stats/main.c:312
msgid "ccolumn is required to upload point counts"
@@ -28359,7 +28359,7 @@
#: ../vector/v.vect.stats/main.c:334 ../vector/v.vect.stats/main.c:364
#, fuzzy, c-format
msgid "Unable to add column <%s>"
+msgstr "ÎδÏ
#: ../vector/v.vect.stats/main.c:340
msgid "scolumn is required to upload point stats"
@@ -28376,7 +28376,7 @@
#: ../vector/v.vect.stats/main.c:407
#, fuzzy
msgid "column for points vector must be numeric"
+msgstr "Îνομα ÏοÏ
δεÏÏεÏοÏ
#: ../vector/v.vect.stats/main.c:481
msgid "creating spatial index"
@@ -28385,7 +28385,7 @@
#: ../vector/v.vect.stats/main.c:484
#, fuzzy
msgid "Selecting points for each area..."
+msgstr "ÎδÏ
ναμία Ï
γÏνοÏ
#: ../vector/v.vect.stats/main.c:581
#, c-format
@@ -28428,7 +28428,7 @@
msgid ""
"Required parameter <%s> not set:\n"
"\t(%s)"
-msgstr "Ïé áðáéôïýìåíåò ðáñÜìåôñïé <%s> äåí Ý÷ïõí äïèåß"
+msgstr "Îι αÏαιÏοÏÎ¼ÎµÎ½ÎµÏ ÏαÏάμεÏÏοι <%s> δεν ÎÏοÏ
ν δοθεί"
#: ../vector/v.univar/main.c:175
msgid ""
@@ -28443,13 +28443,13 @@
#: ../vector/v.univar/main.c:220
#, fuzzy, c-format
msgid "Unable select categories from table <%s>"
+msgstr "ÎδÏ
#: ../vector/v.univar/main.c:311
#, fuzzy, c-format
msgid " Database connection not defined for layer <%s>"
msgstr ""
#: ../vector/v.univar/main.c:605
msgid "Cannot sort the key/value array"
@@ -28468,7 +28468,7 @@
#: ../vector/v.surf.idw/main.c:98 ../vector/v.surf.idw/main.c:106
#, fuzzy
msgid "Values"
-msgstr "×ñþìá"
+msgstr "ΧÏÏμα"
#: ../vector/v.surf.idw/main.c:104
msgid "Attribute table column with values to interpolate"
@@ -28657,7 +28657,7 @@
#: ../vector/v.net.allpairs/main.c:219 ../vector/v.net.centrality/main.c:311
#, fuzzy
msgid "Writing data into the table..."
#: ../vector/v.drape/main.c:166
msgid "vector, geometry, sampling"
@@ -28682,7 +28682,7 @@
#: ../vector/v.drape/main.c:206
#, fuzzy
msgid "Layer is only used for WHERE SQL statement"
-msgstr "×ñçóéìïðïéÞóôå sb.select ãéá SELECT SQL åíôïëÝò"
+msgstr "ΧÏηÏιμοÏοιήÏÏε sb.select για SELECT SQL ενÏολÎÏ"
#: ../vector/v.drape/main.c:211
msgid "Vector Z value for unknown height"
@@ -28716,7 +28716,7 @@
#: ../vector/v.buffer/main.c:254
#, fuzzy
msgid "vector, geometry, buffer"
#: ../vector/v.buffer/main.c:278
msgid "Attribute column to use for buffer distances"
@@ -28905,7 +28905,7 @@
#: ../vector/v.extract/main.c:297
#, fuzzy, c-format
msgid "Unable select records from table <%s>"
+msgstr "ÎδÏ
#: ../vector/v.extract/main.c:298
#, c-format
@@ -29094,7 +29094,7 @@
#: ../vector/v.hull/main.c:314
#, fuzzy, c-format
msgid "Error loading vector points from <%s>"
ÏάÏÏÎµÏ ÏάÏÏη "
#: ../vector/v.hull/main.c:318
msgid "Convex hull calculation requires at least three points. Exiting."
@@ -29103,7 +29103,7 @@
#: ../vector/v.hull/main.c:320
#, fuzzy, c-format
msgid "%d points read from vector map <%s>"
+msgstr "ÎδÏ
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη"
#: ../vector/v.to.rast3/main.c:45
msgid "vector, volume, conversion"
@@ -29152,7 +29152,7 @@
#: ../vector/v.split/main.c:61
#, fuzzy
msgid "Maximum number of vertices in segment"
#: ../vector/v.distance/main.c:116
msgid ""
@@ -29163,12 +29163,12 @@
#: ../vector/v.distance/main.c:120
#, fuzzy
msgid "Name of existing vector map (from)"
+msgstr "Îνομα Ï
#: ../vector/v.distance/main.c:125
#, fuzzy
msgid "Name of existing vector map (to)"
+msgstr "Îνομα Ï
#: ../vector/v.distance/main.c:132
msgid "Feature type (from)"
@@ -29181,12 +29181,12 @@
#: ../vector/v.distance/main.c:144
#, fuzzy
msgid "Layer number (from)"
#: ../vector/v.distance/main.c:149
#, fuzzy
msgid "Layer number (to)"
#: ../vector/v.distance/main.c:155
msgid "Name for output vector map containing lines connecting nearest elements"
@@ -29446,12 +29446,12 @@
#: ../vector/v.to.db/parse.c:38
#, fuzzy
msgid "For coor valid point/centroid, for length valid line/boundary"
-msgstr "Ôýðïò"
+msgstr "ΤÏÏοÏ"
#: ../vector/v.to.db/parse.c:42
#, fuzzy
msgid "Layer number (write to)"
#: ../vector/v.to.db/parse.c:46
msgid "Query layer number (read from)"
@@ -29481,7 +29481,7 @@
#: ../vector/v.to.db/parse.c:108
#, fuzzy
msgid "Only print SQL statements"
-msgstr "Åêôåëåß ïðïéáäÞðïôå SQL åíôïëÞ"
+msgstr "ÎκÏελεί οÏοιαδήÏοÏε SQL ενÏολή"
#: ../vector/v.to.db/parse.c:114
msgid "In print mode prints totals for options: length,area,count"
@@ -29548,7 +29548,7 @@
#, fuzzy, c-format
msgid "Record (cat %d) already exists (not inserted)"
msgstr ""
+"ΠδιανÏ
#: ../vector/v.to.db/update.c:221 ../vector/v.to.3d/trans3.c:129
#, c-format
@@ -29562,7 +29562,7 @@
#: ../vector/v.in.dwg/main.c:69
#, fuzzy
msgid "Name of DWG or DXF file"
-msgstr "¼íïìá áñ÷åßïõ åîáãùãÞò"
+msgstr "Îνομα αÏÏείοÏ
εξαγÏγήÏ"
#: ../vector/v.in.dwg/main.c:92
msgid "Write circles as points (centre)"
@@ -29580,12 +29580,12 @@
#: ../vector/v.in.dwg/main.c:123
#, fuzzy, c-format
msgid "%s Cannot open %s"
#: ../vector/v.in.dwg/main.c:131
#, fuzzy, c-format
msgid "Unable to open input file <%s>. Error %d: %s"
-msgstr "Áäõíáìßá áíïßãìáôïò áñ÷åßïõ <%s> ãéá åããñáöÞ"
+msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï Î±ÏÏείοÏ
<%s> για εγγÏαÏή"
#: ../vector/v.in.dwg/main.c:266
#, c-format
@@ -29613,22 +29613,22 @@
#: ../vector/v.to.3d/main.c:58
#, fuzzy, c-format
msgid "Parameters '%s' ignored"
-msgstr "ÐáñÜìåôñïé"
+msgstr "ΠαÏάμεÏÏοι"
#: ../vector/v.to.3d/main.c:63
#, fuzzy
msgid "Attribute table required"
-msgstr "Ôýðùìá ôçò äïìÞ ôïõ ðßíáêá"
+msgstr "ΤÏÏÏμα ÏÎ·Ï Î´Î¿Î¼Î® ÏοÏ
Ïίνακα"
#: ../vector/v.to.3d/main.c:76
#, fuzzy, c-format
msgid "Vector map <%s> is 2D"
+msgstr "ΠδιανÏ
#: ../vector/v.to.3d/main.c:81
#, fuzzy, c-format
msgid "Vector map <%s> is 3D"
+msgstr "ΠδιανÏ
#: ../vector/v.to.3d/main.c:97 ../vector/v.to.3d/main.c:127
#: ../vector/v.in.db/main.c:212
@@ -29638,7 +29638,7 @@
#: ../vector/v.to.3d/main.c:99 ../vector/v.to.3d/main.c:129
#, fuzzy
msgid "Unable to copy attributes"
+msgstr "ÎδÏ
#: ../vector/v.to.3d/main.c:103
msgid "Transforming features..."
@@ -29675,7 +29675,7 @@
#: ../vector/v.to.3d/trans2.c:113
#, fuzzy, c-format
msgid "Unable to get height for feature category %d"
+msgstr "ÎδÏ
ναμία Ï
γÏνοÏ
#: ../vector/v.to.3d/args.c:11
msgid "Reverse transformation; 3D vector features to 2D"
@@ -29684,7 +29684,7 @@
#: ../vector/v.to.3d/args.c:15
#, fuzzy
msgid "Do not copy table"
+msgstr "ÎδÏ
#: ../vector/v.to.3d/args.c:30
msgid "Fixed height for 3D vector features"
@@ -29710,12 +29710,12 @@
#: ../vector/v.overlay/line_area.c:71 ../vector/v.overlay/area_area.c:153
#, fuzzy
msgid "Merging lines..."
#: ../vector/v.overlay/line_area.c:83
#, fuzzy
msgid "Selecting lines..."
#: ../vector/v.overlay/line_area.c:162 ../vector/v.overlay/line_area.c:190
#: ../vector/v.overlay/area_area.c:208 ../vector/v.overlay/area_area.c:290
@@ -29730,32 +29730,32 @@
#: ../vector/v.overlay/main.c:64 ../vector/v.select/args.c:10
#, fuzzy
msgid "Name of input vector map (A)"
ÏάÏÏÎµÏ ÏάÏÏη "
#: ../vector/v.overlay/main.c:68 ../vector/v.select/args.c:14
#, fuzzy
msgid "Feature type (vector map A)"
+msgstr "ÎδÏ
#: ../vector/v.overlay/main.c:74 ../vector/v.select/args.c:19
#, fuzzy
msgid "Layer number (vector map A)"
#: ../vector/v.overlay/main.c:78 ../vector/v.select/args.c:24
#, fuzzy
msgid "Name of input vector map (B)"
ÏάÏÏÎµÏ ÏάÏÏη "
#: ../vector/v.overlay/main.c:82 ../vector/v.select/args.c:28
#, fuzzy
msgid "Feature type (vector map B)"
+msgstr "ÎδÏ
#: ../vector/v.overlay/main.c:88 ../vector/v.select/args.c:33
#, fuzzy
msgid "Layer number (vector map B)"
#: ../vector/v.overlay/main.c:100
msgid "Operator defines features written to output vector map"
@@ -29795,7 +29795,7 @@
#: ../vector/v.overlay/main.c:160
#, fuzzy, c-format
msgid "Unknown operator '%s'"
#: ../vector/v.overlay/main.c:165
#, c-format
@@ -29829,7 +29829,7 @@
#: ../vector/v.overlay/area_area.c:54
#, fuzzy, c-format
msgid "Snapping boundaries with %g ..."
#: ../vector/v.overlay/area_area.c:102
#, c-format
@@ -29886,7 +29886,7 @@
#: ../vector/v.net.flow/main.c:58
#, fuzzy
msgid "vector, network, flow"
#: ../vector/v.net.flow/main.c:60
msgid "Computes the maximum flow between two sets of nodes in the network."
@@ -29895,7 +29895,7 @@
#: ../vector/v.net.flow/main.c:71
#, fuzzy
msgid "Name for output vector map containing a minimum cut"
διανÏ
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη"
#: ../vector/v.net.flow/main.c:77
msgid "Name of arc forward/both direction(s) capacity column"
@@ -29908,7 +29908,7 @@
#: ../vector/v.net.flow/main.c:86
#, fuzzy
msgid "Source layer number or name"
#: ../vector/v.net.flow/main.c:91
msgid "Source category values"
@@ -29921,7 +29921,7 @@
#: ../vector/v.net.flow/main.c:102
#, fuzzy
msgid "Sink layer number or name"
#: ../vector/v.net.flow/main.c:103 ../vector/v.net.flow/main.c:108
#: ../vector/v.net.flow/main.c:114
@@ -29947,7 +29947,7 @@
#: ../vector/v.net.flow/main.c:224
#, fuzzy
msgid "Writing the output..."
#: ../vector/v.what/what.c:164
#, c-format
@@ -29984,7 +29984,7 @@
#: ../vector/v.what/what.c:221
#, fuzzy, c-format
msgid "Type: %s"
-msgstr "Ôýðïò"
+msgstr "ΤÏÏοÏ"
#: ../vector/v.what/what.c:222
#, c-format
@@ -30003,12 +30003,12 @@
msgid ""
"Type: Area\n"
"Area height: %f\n"
-msgstr "Ôýðïò"
+msgstr "ΤÏÏοÏ"
#: ../vector/v.what/what.c:288
#, fuzzy, c-format
msgid "Type: Area\n"
-msgstr "Ôýðïò"
+msgstr "ΤÏÏοÏ"
#: ../vector/v.what/what.c:310
#, c-format
@@ -30091,7 +30091,7 @@
#: ../vector/v.external/main.c:58
#, fuzzy
msgid "vector, external, import"
#: ../vector/v.external/main.c:60
msgid "Creates a new vector as a read-only link to OGR layer."
@@ -30456,7 +30456,7 @@
#: ../vector/v.net.alloc/main.c:61
#, fuzzy
msgid "vector, network, allocation"
#: ../vector/v.net.alloc/main.c:63
msgid "Allocate subnets for nearest centres (direction from centre)."
@@ -30507,7 +30507,7 @@
#: ../vector/v.net.spanningtree/main.c:46
#, fuzzy
msgid "vector, network, spanning tree"
+msgstr "διάνÏ
#: ../vector/v.net.spanningtree/main.c:48
msgid "Computes minimum spanning tree for the network."
@@ -30516,7 +30516,7 @@
#: ../vector/v.net.spanningtree/main.c:59
#, fuzzy
msgid "Name of Arc cost column"
#: ../vector/v.net.steiner/main.c:58
#, c-format
@@ -30526,7 +30526,7 @@
#: ../vector/v.net.steiner/main.c:345
#, fuzzy
msgid "vector, network, steiner tree"
+msgstr "διάνÏ
#: ../vector/v.net.steiner/main.c:347
msgid "Create Steiner tree for the network and given terminals"
@@ -30595,7 +30595,7 @@
#: ../vector/v.net.iso/main.c:73
#, fuzzy
msgid "vector, network, isolines"
#: ../vector/v.net.iso/main.c:75
msgid ""
@@ -30671,7 +30671,7 @@
#: ../vector/v.to.rast/support.c:315 ../vector/v.to.rast/support.c:467
#, fuzzy, c-format
msgid "Column <%s> not found"
#: ../vector/v.what.rast/main.c:166
msgid "Raster type is integer and column type is float"
@@ -30745,7 +30745,7 @@
#: ../vector/v.in.db/main.c:52
#, fuzzy
msgid "vector, import, database, points"
#: ../vector/v.in.db/main.c:54
msgid ""
@@ -30789,7 +30789,7 @@
#: ../vector/v.in.db/main.c:173
#, fuzzy
msgid "Writing features..."
#: ../vector/v.in.db/main.c:180
msgid "Key column must be integer"
@@ -30802,12 +30802,12 @@
#: ../vector/v.in.db/main.c:235
#, fuzzy, c-format
msgid "%d points written to vector map."
+msgstr "ÎδÏ
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη"
#: ../vector/v.select/main.c:52
#, fuzzy
msgid "vector, spatial query"
+msgstr "διάνÏ
#: ../vector/v.select/main.c:54
msgid ""
@@ -30817,7 +30817,7 @@
#: ../vector/v.select/main.c:87
#, fuzzy
msgid "Unknown operator"
#: ../vector/v.select/main.c:124
msgid "Output from v.select"
@@ -30826,7 +30826,7 @@
#: ../vector/v.select/main.c:172
#, fuzzy, c-format
msgid "Unable to read line id %d from vector map <%s>"
-msgstr "Áäõíáìßá äçìéïõñãßáò äéáíõóìáôéêïý ÷Üñôç <%s>"
+msgstr "ÎδÏ
ναμία δημιοÏ
ÏÎ³Î¯Î±Ï Î´Î¹Î±Î½Ï
#: ../vector/v.select/main.c:278
msgid "Processing areas..."
@@ -30836,12 +30836,12 @@
#, fuzzy, c-format
msgid "Unable to read area id %d from vector map <%s>"
msgstr ""
+"ÎδÏ
#: ../vector/v.select/main.c:446
#, fuzzy
msgid "Writing selected features..."
#: ../vector/v.select/main.c:512
#, c-format
@@ -30851,7 +30851,7 @@
#: ../vector/v.select/main.c:527
#, fuzzy, c-format
msgid "Layer %d - unable to copy table"
+msgstr "ÎδÏ
#: ../vector/v.select/main.c:542
#, c-format
@@ -30861,7 +30861,7 @@
#: ../vector/v.select/main.c:545
#, fuzzy, c-format
msgid "%d features written to output."
+msgstr "ÎδÏ
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη"
#: ../vector/v.select/args.c:45
msgid "Operator defines required relation between features"
@@ -30941,7 +30941,7 @@
#: ../vector/lidar/v.lidar.growing/main.c:179
#, fuzzy, c-format
msgid "Unable to open table <%s>"
+msgstr "ÎδÏ
#: ../vector/lidar/v.lidar.growing/main.c:204
msgid "Setting regions and boxes"
@@ -30969,7 +30969,7 @@
#: ../vector/lidar/v.lidar.growing/main.c:291
#, fuzzy
msgid "read points in input vector"
+msgstr "ÎδÏ
ÏμαÏÎ¹ÎºÎ¿Ï ÏάÏÏη"
#: ../vector/lidar/v.lidar.growing/main.c:440
msgid "Region Growing"
@@ -30999,7 +30999,7 @@
#: ../vector/lidar/lidarlib/raster.c:168 ../vector/lidar/lidarlib/raster.c:181
#, fuzzy, c-format
msgid "Unable to access table <%s>"
-msgstr "Áäõíáìßá äçìéïõñãßáò ðßíáêá <%s>"
+msgstr "ÎδÏ
ναμία δημιοÏ
ÏÎ³Î¯Î±Ï Ïίνακα <%s>"
#: ../vector/lidar/v.surf.bspline/main.c:85
msgid "Bicubic or bilinear spline interpolation with Tykhonov regularization."
@@ -31116,7 +31116,7 @@
#, fuzzy, c-format
msgid "Vector map <%s> of sparse points will be interpolated"
msgstr ""
+"ΠδιανÏ
#: ../vector/lidar/v.surf.bspline/main.c:285
#, c-format
@@ -31129,13 +31129,13 @@
#, fuzzy, c-format
msgid "Points in input vector map <%s> will be interpolated"
msgstr ""
+"ΠδιανÏ
#: ../vector/lidar/v.surf.bspline/main.c:320
#, fuzzy, c-format
msgid "Cells for raster map <%s> will be interpolated"
msgstr ""
+"ΠδιανÏ
#: ../vector/lidar/v.surf.bspline/main.c:329
msgid "Cannot read field info"
@@ -31185,7 +31185,7 @@
#: ../vector/lidar/v.surf.bspline/main.c:715
#, fuzzy
msgid "Writing output..."
#: ../vector/lidar/v.surf.bspline/main.c:731
#: ../vector/lidar/v.lidar.edgedetection/main.c:470
@@ -31218,7 +31218,7 @@
#: ../vector/lidar/v.surf.bspline/crosscorr.c:141
#, fuzzy, c-format
msgid "No records selected from table <%s> "
+msgstr "ÎδÏ
#: ../vector/lidar/v.surf.bspline/crosscorr.c:156
#, c-format
@@ -31256,7 +31256,7 @@
#: ../vector/lidar/v.surf.bspline/crosscorr.c:328
#, fuzzy
msgid "Table of results:"
+msgstr "ÎδÏ
#: ../vector/lidar/v.surf.bspline/crosscorr.c:329
#, c-format
@@ -31279,7 +31279,7 @@
#: ../vector/lidar/v.lidar.edgedetection/edgedetection.c:313
#, fuzzy
msgid "Impossible to update aux table"
-msgstr "Áäõíáìßá ëßóôáò âÜóåùí äåäïìÝíùí"
+msgstr "ÎδÏ
ναμία λίÏÏÎ±Ï Î²Î¬ÏεÏν δεδομÎνÏν"
#: ../vector/lidar/v.lidar.edgedetection/edgedetection.c:250
#: ../vector/lidar/v.lidar.edgedetection/edgedetection.c:262
@@ -31332,7 +31332,7 @@
#: ../vector/lidar/v.outlier/main.c:186
#, fuzzy, c-format
msgid "Input vector map <%s> is not 3D!"
-msgstr "Ï äéáíõóìáôéêüò ÷Üñôçò <%s> äåí âñÝèçêå"
+msgstr "ΠδιανÏ
ÏμαÏικÏÏ ÏάÏÏÎ·Ï <%s> δεν βÏÎθηκε"
#: ../vector/lidar/v.lidar.edgedetection/main.c:260
#, c-format
@@ -31491,7 +31491,7 @@
#: ../vector/lidar/v.outlier/main.c:243
#, fuzzy, c-format
msgid "It was impossible to create <%s> table."
+msgstr "ÎδÏ
ναμία δημιοÏ
#: ../vector/lidar/v.outlier/main.c:405
msgid "Outlier detection"
@@ -32019,7 +32019,7 @@
#: ../vector/v.to.rast/main.c:40
#, fuzzy
msgid "Converts (rasterize) a vector map into a raster map."
#: ../vector/v.to.rast/main.c:61
msgid "Source of raster values"
@@ -32035,7 +32035,7 @@
#: ../vector/v.to.rast/main.c:71
#, fuzzy
msgid "Name of column for 'attr' parameter (data type must be numeric)"
+msgstr "Îνομα ÏοÏ
δεÏÏεÏοÏ
#: ../vector/v.to.rast/main.c:77
msgid "Name of color definition column (with RRR:GGG:BBB entries)"
@@ -32073,7 +32073,7 @@
#: ../vector/v.to.rast/vect2rast.c:39
#, fuzzy
msgid "Loading data..."
-msgstr "Öüñôùóç äåäïìÝíùí... (%dx%dx%d)"
+msgstr "ΦÏÏÏÏÏη δεδομÎνÏν... (%dx%dx%d)"
#: ../vector/v.to.rast/vect2rast.c:44
#, c-format
@@ -32122,12 +32122,12 @@
#: ../vector/v.to.rast/vect2rast.c:200
#, fuzzy
msgid "Creating support files for raster map..."
-msgstr "Áäõíáìßá áíÜãíùóçò áñ÷åßïõ ÷ñþìáôïò ãéá ôïí ñÜóôåñ ÷Üñôç <%s>"
+msgstr "ÎδÏ
ναμία ανάγνÏÏÎ·Ï Î±ÏÏείοÏ
ÏÏÏμαÏÎ¿Ï Î³Î¹Î± Ïον ÏάÏÏÎµÏ ÏάÏÏη <%s>"
#: ../vector/v.to.rast/vect2rast.c:207
#, fuzzy
msgid "Color can be updated from database only if use=attr"
-msgstr "×ñþìá"
+msgstr "ΧÏÏμα"
#: ../vector/v.to.rast/vect2rast.c:227
#, c-format
@@ -32175,7 +32175,7 @@
#: ../vector/v.to.rast/support.c:176
#, fuzzy
msgid "Color set to [200:200:200]"
-msgstr "×ñþìá"
+msgstr "ΧÏÏμα"
#: ../vector/v.to.rast/support.c:181
#, c-format
@@ -32306,27 +32306,27 @@
#: ../vector/v.net.timetable/main.c:272
#, fuzzy
msgid "Layer number or name with route paths or -1"
#: ../vector/v.net.timetable/main.c:278
#, fuzzy
msgid "Name of column name with route ids"
-msgstr "¼íïìá ôïõ áñ÷åßïõ ðïõ ðåñéÝ÷åé õðïãñáöÝò (signatures)"
+msgstr "Îνομα ÏοÏ
αÏÏείοÏ
ÏοÏ
ÏεÏιÎÏει Ï
ÏογÏαÏÎÏ (signatures)"
#: ../vector/v.net.timetable/main.c:285
#, fuzzy
msgid "Name of column name with stop timestamps"
-msgstr "¼íïìá áñ÷åßïõ ìå sql åíôïëÞ"
με sql ενÏολή"
#: ../vector/v.net.timetable/main.c:291
#, fuzzy
msgid "Name of column name with stop ids"
+msgstr "Îνομα ÏοÏ
αÏÏείοÏ
ÏοÏ
ÏεÏιÎÏει Ï
#: ../vector/v.net.timetable/main.c:297
#, fuzzy
msgid "Name of column name with walk lengths"
με sql ενÏολή"
#: ../vector/v.net.timetable/main.c:345
msgid "Could not initialize the timetables"
@@ -32458,7 +32458,7 @@
#, fuzzy, c-format
msgid "Vector map <%s> already exists and will be overwritten"
msgstr ""
+"ΠδιανÏ
#: ../vector/v.in.ogr/main.c:386
msgid "Select either the current region flag or the spatial option, not both"
@@ -32500,7 +32500,7 @@
#: ../vector/v.in.ogr/main.c:619
#, fuzzy, c-format
msgid "Using temporary vector <%s>"
+msgstr "ÎδÏ
ναμία δημιοÏ
ÏÎ³Î¯Î±Ï Î´Î¹Î±Î½Ï
#: ../vector/v.in.ogr/main.c:640
#, c-format
@@ -32537,12 +32537,12 @@
#: ../vector/v.in.ogr/main.c:789
#, fuzzy, c-format
msgid "Unable open database <%s> by driver <%s>"
+msgstr "ÎδÏ
#: ../vector/v.in.ogr/main.c:826
#, fuzzy, c-format
msgid "Counting polygons for %d features..."
+msgstr "ÎδÏ
ναμία Ï
γÏνοÏ
#: ../vector/v.in.ogr/main.c:848
#, c-format
@@ -32587,7 +32587,7 @@
#: ../vector/v.in.ogr/main.c:1027
#, fuzzy
msgid "Merge boundaries:"
#: ../vector/v.in.ogr/main.c:1032
msgid "Change boundary dangles to lines:"
@@ -32608,7 +32608,7 @@
#: ../vector/v.in.ogr/main.c:1081
#, fuzzy, c-format
msgid "Find centroids for layer: %s"
+msgstr "ÎδÏ
ναμία Ï
γÏνοÏ
#: ../vector/v.in.ogr/main.c:1102
msgid "Write centroids:"
@@ -32680,7 +32680,7 @@
#: ../vector/v.in.ogr/geom.c:195
#, fuzzy
msgid "Cannot read part of geometry"
-msgstr "Áäõíáìßá äéáâÜóìáôïò åýñïõò fp ãéá ôïí ñáóôåñ ÷Üñôç <%s>"
+msgstr "ÎδÏ
ναμία διαβάÏμαÏÎ¿Ï ÎµÏÏοÏ
Ï fp για Ïον ÏαÏÏÎµÏ ÏάÏÏη <%s>"
#: ../vector/v.in.ogr/geom.c:234 ../vector/v.in.ogr/geom.c:247
#: ../vector/v.in.ogr/geom.c:275 ../vector/v.in.ogr/geom.c:321
@@ -32728,7 +32728,7 @@
#: ../vector/v.net.components/main.c:87
#, fuzzy
msgid "Type of components"
-msgstr "Ôýðïò"
+msgstr "ΤÏÏοÏ"
#: ../vector/v.net.components/main.c:91 ../vector/v.net.centrality/main.c:171
msgid "Add points on nodes"
@@ -32741,7 +32741,7 @@
#: ../vector/v.perturb/main.c:73
#, fuzzy
msgid "vector, geometry, statistics"
#: ../vector/v.perturb/main.c:75
msgid "Random location perturbations of GRASS vector points"
@@ -32793,7 +32793,7 @@
#: ../vector/v.net.centrality/main.c:95
#, fuzzy
msgid "vector, network, centrality measures"
+msgstr "διάνÏ
#: ../vector/v.net.centrality/main.c:97
msgid ""
@@ -32804,28 +32804,28 @@
#: ../vector/v.net.centrality/main.c:127
#, fuzzy
msgid "Name of degree centrality column"
#: ../vector/v.net.centrality/main.c:128 ../vector/v.net.centrality/main.c:134
#: ../vector/v.net.centrality/main.c:140 ../vector/v.net.centrality/main.c:146
#, fuzzy
msgid "Columns"
-msgstr "×ñþìá"
+msgstr "ΧÏÏμα"
#: ../vector/v.net.centrality/main.c:133
#, fuzzy
msgid "Name of closeness centrality column"
#: ../vector/v.net.centrality/main.c:139
#, fuzzy
msgid "Name of betweenness centrality column"
#: ../vector/v.net.centrality/main.c:145
#, fuzzy
msgid "Name of eigenvector centrality column"
+msgstr "Îνομα Ï
#: ../vector/v.net.centrality/main.c:154
msgid "Maximum number of iterations to compute eigenvector centrality"
@@ -33039,7 +33039,7 @@
#: ../vector/v.random/main.c:123 ../vector/v.random/main.c:128
#, fuzzy
msgid "3D output"
-msgstr "ÐëÞñåò output"
+msgstr "ΠλήÏÎµÏ output"
#: ../vector/v.random/main.c:109
msgid "Maximum z height (needs -z flag or column name)"
@@ -33093,235 +33093,235 @@
#, fuzzy
#~ msgid "Subgroup <%s> not found in current mapset"
-#~ msgstr "Ç óôÞëç <%s> äåí âñÝèçêå"
+#~ msgstr "Î ÏÏήλη <%s> δεν βÏÎθηκε"
#, fuzzy
#~ msgid "Column to query"
-#~ msgstr "Ascii ñÜóôåñ ÷Üñôçò ðïõ èá åéóá÷èåß"
+#~ msgstr "Ascii ÏάÏÏÎµÏ ÏάÏÏÎ·Ï ÏοÏ
θα ειÏαÏθεί"
#, fuzzy
#~ msgid "Unknown production date (defined by '%s')"
-#~ msgstr "¶ãíùóôç åðéëïãÞ óôïí ïñéóìüò ôçò âÜóçò äåäïìÝíùí ãéá "
+#~ msgstr "ÎγνÏÏÏη εÏιλογή ÏÏον οÏιÏμÏÏ ÏÎ·Ï Î²Î¬ÏÎ·Ï Î´ÎµÎ´Î¿Î¼ÎνÏν για "
#~ msgid "Use G3D mask (if exists) with input map"
-#~ msgstr "×ñçóéìïðïéÞóôå G3D mask (áí õðÜñ÷åé) ìå åéóáãþìåíï ÷Üñôç"
+#~ msgstr "ΧÏηÏιμοÏοιήÏÏε G3D mask (αν Ï
ÏάÏÏει) με ειÏαγÏμενο ÏάÏÏη"
#, fuzzy
#~ msgid "Unable to allocate memory for row buffer"
-#~ msgstr "Áäõíáìßá õðïëïãéóìïý êÝíôñùí ðïëõãþíïõ ãéá ôçí åðéöÜíåéá %d"
+#~ msgstr "ÎδÏ
ναμία Ï
γÏνοÏ
#, fuzzy
#~ msgid "Unable to allocate memory for raster row"
-#~ msgstr "Áäõíáìßá ëÞøçò ãñáììÞò õøïìÝôñùí áðü ñÜóôåñ"
+#~ msgstr "ÎδÏ
ναμία λήÏÎ·Ï Î³ÏÎ±Î¼Î¼Î®Ï Ï
ÏομÎÏÏÏν αÏÏ ÏάÏÏεÏ"
#, fuzzy
#~ msgid "Cannot open driver\n"
-#~ msgstr "Äåí ìðïñþ íá áíïßîù ôçí âÜóç äåäïìÝíùí %s"
+#~ msgstr "Îεν μÏοÏÏ Î½Î± Î±Î½Î¿Î¯Î¾Ï Ïην βάÏη δεδομÎνÏν %s"
#, fuzzy
#~ msgid "Cannot open database\n"
-#~ msgstr "Áäõíáìßá áíïßãìáôïò âÜóçò äåäïìåíùí <%s>"
+#~ msgstr "ÎδÏ
#~ msgid "Requested 3d raster map not found"
-#~ msgstr "Ï æçôïýìåíïò 3Ä ñÜóôåñ ÷Üñôçò äåí âñÝèçêå"
+#~ msgstr "ΠζηÏοÏÎ¼ÎµÎ½Î¿Ï 3Î ÏάÏÏÎµÏ ÏάÏÏÎ·Ï Î´ÎµÎ½ βÏÎθηκε"
#~ msgid "Error closing new 3d raster map"
-#~ msgstr "ÓöÜëìá êáôÜ ôï êëåßóåéìï 3Ä ñÜóôåñ ÷Üñôç"
+#~ msgstr "ΣÏάλμα καÏά Ïο κλείÏειμο 3Î ÏάÏÏÎµÏ ÏάÏÏη"
#~ msgid "Error closing ascii file"
-#~ msgstr "ÓöÜëìá êáôÜ ôï êëåßóïìï ascii áñ÷åßïõ"
+#~ msgstr "ΣÏάλμα καÏά Ïο κλείÏομο ascii αÏÏείοÏ
#~ msgid "Could not close G3D map"
-#~ msgstr "Äåí ãßíåôáé íá êëåßóåé ï G3Ä ÷Üñôçò"
+#~ msgstr "Îεν γίνεÏαι να κλείÏει ο G3Î ÏάÏÏηÏ"
#~ msgid "Use g3d mask (if exists) with input map"
-#~ msgstr "×ñçóéìïðïéÞóôå g3d ìÜóêá (áí õðÜñ÷åé) ìå ôïí ÷Üñôç"
+#~ msgstr "ΧÏηÏιμοÏοιήÏÏε g3d μάÏκα (αν Ï
ÏάÏÏει) με Ïον ÏάÏÏη"
#~ msgid "Could not write raster row"
-#~ msgstr "Äåí Þôáí äõíáôÞ ç åããñáöÞ ãñáììÞò ñÜóôåñ"
+#~ msgstr "Îεν ήÏαν δÏ
#~ msgid "Could not close G3D map <%s>"
-#~ msgstr "Äåí ìðïñåß íá êëåßóåé ï G3D ÷Üñôçò <%s>"
+#~ msgstr "Îεν μÏοÏεί να κλείÏει ο G3D ÏάÏÏÎ·Ï <%s>"
#~ msgid "Use G3D mask (if exists)"
-#~ msgstr "×ñçóéìïðïéÞóôå G3D ìÜóêá (åÜí õðÜñ÷åé)"
+#~ msgstr "ΧÏηÏιμοÏοιήÏÏε G3D μάÏκα (εάν Ï
ÏάÏÏει)"
#~ msgid "Error opening g3d map <%s>"
-#~ msgstr "ÓöÜëìá êáôÜ ôï Üíïéãìá ôïõ g3d ÷Üñôç <%s>"
+#~ msgstr "ΣÏάλμα καÏά Ïο άνοιγμα ÏοÏ
g3d ÏάÏÏη <%s>"
#~ msgid "Error closing g3d file"
-#~ msgstr "ÓöÜëìá êáôÜ ôï êëåßóéìï ôïõ g3d áñ÷åßïõ."
+#~ msgstr "ΣÏάλμα καÏά Ïο κλείÏιμο ÏοÏ
g3d αÏÏείοÏ
#~ msgid "Requested g3d map <%s> not found"
-#~ msgstr "Ï ÷Üñôçò g3d <%s> äåí âñÝèçêå"
+#~ msgstr "Î ÏάÏÏÎ·Ï g3d <%s> δεν βÏÎθηκε"
#~ msgid "modifyNull: error opening map"
-#~ msgstr "modifyNull: óöÜëìá êáôÜ ôï Üíïéãìá ôïõ ÷Üñôç"
+#~ msgstr "modifyNull: ÏÏάλμα καÏά Ïο άνοιγμα ÏοÏ
ÏάÏÏη"
#~ msgid "Error: couldn't create %s"
-#~ msgstr "ÓöÜëìá: äåí Þôáí äõíáôÞ ç äçìéïõñãßá %s"
+#~ msgstr "ΣÏάλμα: δεν ήÏαν δÏ
ναÏή η δημιοÏ
Ïγία %s"
#~ msgid "Error while writing grid. Disk full?"
-#~ msgstr "ÓöÜëìá êáôÜ ôçí åããñáöÞ ôïõ grid. Äßóêïò ãåìÜôïò;"
+#~ msgstr "ΣÏάλμα καÏά Ïην εγγÏαÏή ÏοÏ
grid. ÎίÏÎºÎ¿Ï Î³ÎµÎ¼Î¬ÏοÏ;"
#, fuzzy
#~ msgid "Unable to calculate centroid for area %d"
+#~ msgstr "ÎδÏ
ναμία Ï
ÏολογιÏÎ¼Î¿Ï ÎºÎνÏÏÏν ÏολÏ
γÏνοÏ
για Ïην εÏιÏάνεια %d"
#, fuzzy
#~ msgid "Target location <%s> not found\n"
-#~ msgstr "Ï ÷Üñôçò raster <%s> äåí âñÝèçêå"
+#~ msgstr "Î ÏάÏÏÎ·Ï raster <%s> δεν βÏÎθηκε"
#, fuzzy
#~ msgid "Cannot open file [%s] in mapset [%s]"
-#~ msgstr "Áäõíáìßá áíïßãìáôïò ôïõ ÷Üñôç raster <%s>"
+#~ msgstr "ÎδÏ
ναμία ανοίγμαÏÎ¿Ï ÏοÏ
ÏάÏÏη raster <%s>"
#, fuzzy
#~ msgid "Cannot create file <%s> in mapset <%s>"
-#~ msgstr "¸ëåã÷ïò location <%s>, mapset <%s>..."
+#~ msgstr "ÎλεγÏÎ¿Ï location <%s>, mapset <%s>..."
#, fuzzy
#~ msgid "output"
-#~ msgstr "ÁðïôÝëåóìá:"
+#~ msgstr "ÎÏοÏÎλεÏμα:"
#~ msgid "Selects data from table."
-#~ msgstr "ÅðéëÝãåé äåäïìÝíá áðü ôïí ðßíáêá/"
+#~ msgstr "ÎÏιλÎγει δεδομÎνα αÏÏ Ïον Ïίνακα/"
#, fuzzy
#~ msgid "%s@%s: projection doesn't match current settings"
-#~ msgstr "Êëåßóéìï åöáñìïãÞò, ÷ùñßò íá áëëÜîïõí ïé ôñÝ÷ïõóåò åðéëïãÝò"
+#~ msgstr "ÎλείÏιμο εÏαÏμογήÏ, ÏÏÏÎ¯Ï Î½Î± αλλάξοÏ
ν οι ÏÏÎÏοÏ
ÏÎµÏ ÎµÏιλογÎÏ"
#, fuzzy
#~ msgid "%s@%s: zone doesn't match current settings"
ν οι ÏÏÎÏοÏ
ÏÎµÏ ÎµÏιλογÎÏ"
#, fuzzy
#~ msgid "Vector output map"
-#~ msgstr "Áäõíáìßá êëåéóßìáôïò ôïõ åîáãüìåíïõ ÷Üñôç"
+#~ msgstr "ÎδÏ
ναμία κλειÏίμαÏÎ¿Ï ÏοÏ
εξαγÏμενοÏ
ÏάÏÏη"
#, fuzzy
#~ msgid "Unable to open table <%s_edge_Interpolation>"
-#~ msgstr "Áäõíáìßá áíôéãñáöÞò ðßíáêá <%s>"
+#~ msgstr "ÎδÏ
#~ msgid "Use db.select for SELECT SQL statements"
-#~ msgstr "×ñçóéìïðïéÞóôå sb.select ãéá SELECT SQL åíôïëÝò"
+#~ msgstr "ΧÏηÏιμοÏοιήÏÏε sb.select για SELECT SQL ενÏολÎÏ"
#, fuzzy
#~ msgid "Density of output walkers"
-#~ msgstr "¼íïìá áñ÷åßïõ åîáãùãÞò"
+#~ msgstr "Îνομα αÏÏείοÏ
εξαγÏγήÏ"
#, fuzzy
#~ msgid "File [%s] not found"
#, fuzzy
#~ msgid "Reading sites map (%s) ..."
-#~ msgstr "×Üñôçò åðáíáöüñôéóçò óå m^3/s"
+#~ msgstr "ΧάÏÏÎ·Ï ÎµÏαναÏÏÏÏιÏÎ·Ï Ïε m^3/s"
#, fuzzy
#~ msgid "Unable to read current region parameters"
-#~ msgstr "Áäõíáìßá äéáâÜóìáôïò åýñïõò fp ãéá ôïí ñáóôåñ ÷Üñôç <%s>"
+#~ msgstr "ÎδÏ
#, fuzzy
#~ msgid "Cannot open database <%s> by driver <%s>"
-#~ msgstr "Áäõíáìßá áíïßãìáôïò ôçò âÜóçò äåäïìÝíùí <%s> ìå ôïí ïäçãü <%s>"
+#~ msgstr "ÎδÏ
#, fuzzy
#~ msgid "%s - color table not found"
-#~ msgstr "Ï êÝñóïñáò äåí âñÝèçêå"
+#~ msgstr "ΠκÎÏÏοÏÎ±Ï Î´ÎµÎ½ βÏÎθηκε"
#, fuzzy
#~ msgid "Unable to properly read input raster map"
-#~ msgstr "Áäõíáìßá äçìéïõñãßáò ñÜóôåñ ÷Üñôç"
+#~ msgstr "ÎδÏ
ναμία δημιοÏ
#, fuzzy
#~ msgid "Unable to properly write output raster map"
+#~ msgstr "ÎδÏ
ναμία δημιοÏ
#, fuzzy
#~ msgid "Unable to read f_range for map %s"
+#~ msgstr "ÎδÏ
#, fuzzy
#~ msgid "CrossCorrelation: Cannot open database %s by driver %s"
+#~ msgstr "ÎδÏ
#, fuzzy
#~ msgid "CrossCorrelation: Column type not supported"
-#~ msgstr "pg driver: óôÞëç '%s', ôýðïò %d äåí õðïóôçñßæåôáé"
+#~ msgstr "pg driver: ÏÏήλη '%s', ÏÏÏÎ¿Ï %d δεν Ï
ÏοÏÏηÏίζεÏαι"
#, fuzzy
#~ msgid "CrossCorrelation: Cannot select data from table"
-#~ msgstr "Áäõíáìßá öüñôùóçò äåäïìÝíùí ðßíáêá <%s>"
+#~ msgstr "ÎδÏ
#, fuzzy
#~ msgid "Input vector was not found."
-#~ msgstr "Ï äéáíõóìáôéêüò ÷Üñôçò <%s> äåí âñÝèçêå"
+#~ msgstr "ΠδιανÏ
#, fuzzy
#~ msgid "Reading data from the map..."
#, fuzzy
#~ msgid "Output inverse raster map after IFFT"
-#~ msgstr "¼íïìá åîáãüìåíïõ ñÜóôåñ ÷Üñôç"
+#~ msgstr "Îνομα εξαγÏμενοÏ
ÏάÏÏÎµÏ ÏάÏÏη"
#, fuzzy
#~ msgid "Rotating data arrays..."
-#~ msgstr "ÅããñáöÞ %s áðü %s..."
+#~ msgstr "ÎγγÏαÏή %s αÏÏ %s..."
#, fuzzy
#~ msgid "Saturation map name"
-#~ msgstr "¼íïìá ôïðïèåóßá"
+#~ msgstr "Îνομα ÏοÏοθεÏία"
#, fuzzy
#~ msgid "Red input raster map"
-#~ msgstr "¼íïìá åéóáãþìåíïõ ñÜóôåñ ÷Üñôç "
+#~ msgstr "Îνομα ειÏαγÏμενοÏ
ÏάÏÏÎµÏ ÏάÏÏη "
#, fuzzy
#~ msgid "Output intensity raster map"
ÏάÏÏÎµÏ ÏάÏÏη"
#, fuzzy
#~ msgid "Class transition statistics."
-#~ msgstr "ñÜóôåñ 3Ä, óôáôéóôéêÜ"
+#~ msgstr "ÏάÏÏÎµÏ 3Î, ÏÏαÏιÏÏικά"
#, fuzzy
#~ msgid "get_img: out of memory."
-#~ msgstr "G_malloc: åêôüò ìíÞìçò"
+#~ msgstr "G_malloc: εκÏÏÏ Î¼Î½Î®Î¼Î·Ï"
#, fuzzy
#~ msgid "Name of imagery signaturefile"
-#~ msgstr "¼íïìá ôïõ áñ÷åßïõ ðïõ ðåñéÝ÷åé SQL åíôïëÝò"
αÏÏείοÏ
ÏοÏ
ÏεÏιÎÏει SQL ενÏολÎÏ"
#, fuzzy
#~ msgid "Subgroup [%s] not found."
#, fuzzy
#~ msgid "Resultant signature file"
-#~ msgstr "Áäõíáìßá äçìéïõñãßáò ðßíáêá <%s>"
+#~ msgstr "ÎδÏ
ναμία δημιοÏ
#, fuzzy
#~ msgid "Input raster map being fft"
ÏάÏÏÎµÏ ÏάÏÏη"
#, fuzzy
#~ msgid "Output file to contain final report"
αÏÏείοÏ
ÏοÏ
#, fuzzy
#~ msgid "Can't creat reportfile: "
+#~ msgstr "ÎδÏ
ναμία δημιοÏ
#, fuzzy
#~ msgid "group=[%s] - not found."
#, fuzzy
#~ msgid "Can't read signature file [%s]."
+#~ msgstr "ÎδÏ
ναμία δημιοÏ
#, fuzzy
#~ msgid "Unable to create reject layer [%s]."
+#~ msgstr "ÎδÏ
ναμία δημιοÏ
Modified: grass/branches/releasebranch_6_4/locale/po/grasstcl_el.po
--- grass/branches/releasebranch_6_4/locale/po/grasstcl_el.po 2014-04-13 19:01:14 UTC (rev 59715)
+++ grass/branches/releasebranch_6_4/locale/po/grasstcl_el.po 2014-04-13 19:13:43 UTC (rev 59716)
@@ -14,7 +14,7 @@
"Language-Team: Greek <grass-translations at lists.osgeo.org>\n"
"Language: el\n"
"MIME-Version: 1.0\n"
-"Content-Type: text/plain; charset=ISO-8859-7\n"
+"Content-Type: text/plain; charset=UTF-8\n"
"Content-Transfer-Encoding: 8bit\n"
#: ../lib/init/file_option.tcl:72
