[GRASS-SVN] r59837 - in grass-promo/grassposter/2014_EGU_M3_Landscape: . code images
Sun Apr 20 08:50:04 PDT 2014
Author: ychemin
Date: 2014-04-20 08:50:03 -0700 (Sun, 20 Apr 2014)
New Revision: 59837
Added:
   grass-promo/grassposter/2014_EGU_M3_Landscape/code/
   grass-promo/grassposter/2014_EGU_M3_Landscape/code/code1.tex
   grass-promo/grassposter/2014_EGU_M3_Landscape/images/Apollo12_signatures.png
   grass-promo/grassposter/2014_EGU_M3_Landscape/images/M3_A12_craters_signal.eps
Removed:
   grass-promo/grassposter/2014_EGU_M3_Landscape/images/M3FEOlarge.png
   grass-promo/grassposter/2014_EGU_M3_Landscape/Makefile
   grass-promo/grassposter/2014_EGU_M3_Landscape/poster.tex
Update poster
Modified: grass-promo/grassposter/2014_EGU_M3_Landscape/Makefile
--- grass-promo/grassposter/2014_EGU_M3_Landscape/Makefile	2014-04-20 13:28:05 UTC (rev 59836)
+++ grass-promo/grassposter/2014_EGU_M3_Landscape/Makefile	2014-04-20 15:50:03 UTC (rev 59837)
@@ -1,9 +1,13 @@
 FILE=poster
 SVGDIR = svg_images
+CODE = code
 SVGFILES = $(shell ls $(SVGDIR)/*.svg)
 SVGPDF = $(patsubst %.svg, %.pdf, $(SVGFILES))
+CODE = $(shell ls $(CODE)/*.tex)
+CODEPDF = $(patsubst %.tex, %.pdf, $(CODE))
 all: $(FILE).pdf
 $(FILE).pdf: *.tex Makefile
@@ -21,9 +25,12 @@
 $(SVGPDF): %.pdf: %.svg
 	inkscape -z --export-pdf=$@ --export-area-drawing --export-dpi=300 $<
+$(CODEPDF): %.pdf: %.tex
+	pdflatex -shell-escape -output-directory=$(CODE) $<
 clean:
 	rm -f *~ *.aux *.log *.out *.toc *.bbl *.blg *-blx.bib *.ps
-	rm -f $(SVGPDF)
+	rm -f $(SVGPDF) $(CODEPDF)
 distclean:
 	make clean
Added: grass-promo/grassposter/2014_EGU_M3_Landscape/code/code1.tex
--- grass-promo/grassposter/2014_EGU_M3_Landscape/code/code1.tex	                        (rev 0)
+++ grass-promo/grassposter/2014_EGU_M3_Landscape/code/code1.tex	2014-04-20 15:50:03 UTC (rev 59837)
@@ -0,0 +1,33 @@
+\documentclass[preview=true]{standalone}
+\usepackage{minted}
+\begin{document}
+\begin{minted}[frame=single,linenos,mathescape,fontsize=\small]{py}
+#!/bin/env python
+from math import *
+def feolucey2000(uvvis2, uvvis4):
+ return(17.427*(-atan(((uvvis4/uvvis2)-1.19)/(uvvis2-0.08)))-7.565)
+def feolawrence2002(uvvis2, uvvis4):
+ return(5.7*((-0.147+0.372*(-(uvvis4/uvvis2-1.22)/(uvvis2-0.04))+\
+ 	(-0.036)*pow((-(uvvis4/uvvis2-1.22)/(uvvis2-0.04)),2)))+2.15)
+def feowilcox2005(uvvis2, uvvis4):
+  return(-137.97*((uvvis2*0.9834)+(uvvis4/uvvis2*0.1813))+57.46)
+def feozhang2013(uvvis2,uvvis4):
+  return(17.83*(-atan(((uvvis4/uvvis2)-1.26)/0.01)) - 6.87)
+print "@Surveyor"
+#dummy
+uvvis1=0.04
+#M3 at Surveyor crater
+uvvis2=0.05028829
+uvvis4=0.0579434
+print "@Bench"
+#M3 at Bench (north outside)
+uvvis2=0.05045871
+uvvis4=0.05715561
+\end{minted}
+\end{document}
\ No newline at end of file
Added: grass-promo/grassposter/2014_EGU_M3_Landscape/images/Apollo12_signatures.png
(Binary files differ)
Property changes on: grass-promo/grassposter/2014_EGU_M3_Landscape/images/Apollo12_signatures.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Deleted: grass-promo/grassposter/2014_EGU_M3_Landscape/images/M3FEOlarge.png
Added: grass-promo/grassposter/2014_EGU_M3_Landscape/images/M3_A12_craters_signal.eps
--- grass-promo/grassposter/2014_EGU_M3_Landscape/images/M3_A12_craters_signal.eps	                        (rev 0)
+++ grass-promo/grassposter/2014_EGU_M3_Landscape/images/M3_A12_craters_signal.eps	2014-04-20 15:50:03 UTC (rev 59837)
@@ -0,0 +1,1365 @@
+%!PS-Adobe-3.0 EPSF-3.0
+%%BoundingBox: 0 0 454 255
+%%Pages: 0
+%%Creator: LibreOffice 4.1
+%%Title: none
+%%CreationDate: none
+%%LanguageLevel: 2
+%%EndComments
+%%BeginProlog
+%%BeginResource: procset SDRes-Prolog 1.0 0
+/b4_inc_state save def
+/dict_count countdictstack def
+/op_count count 1 sub def
+userdict begin
+0 setgray 0 setlinecap 1 setlinewidth 0 setlinejoin 10 setmiterlimit[] 0 setdash newpath
+/languagelevel where {pop languagelevel 1 ne {false setstrokeadjust false setoverprint} if} if
+/bdef {bind def} bind def
+/c {setrgbcolor} bdef
+/l {neg lineto} bdef
+/rl {neg rlineto} bdef
+/lc {setlinecap} bdef
+/lj {setlinejoin} bdef
+/lw {setlinewidth} bdef
+/ml {setmiterlimit} bdef
+/ld {setdash} bdef
+/m {neg moveto} bdef
+/ct {6 2 roll neg 6 2 roll neg 6 2 roll neg curveto} bdef
+/r {rotate} bdef
+/t {neg translate} bdef
+/s {scale} bdef
+/sw {show} bdef
+/gs {gsave} bdef
+/gr {grestore} bdef
+/f {findfont dup length dict begin
+{1 index /FID ne {def} {pop pop} ifelse} forall /Encoding ISOLatin1Encoding def
+currentdict end /NFont exch definefont pop /NFont findfont} bdef
+/p {closepath} bdef
+/sf {scalefont setfont} bdef
+/ef {eofill}bdef
+/pc {closepath stroke}bdef
+/ps {stroke}bdef
+/pum {matrix currentmatrix}bdef
+/pom {setmatrix}bdef
+/bs {/aString exch def /nXOfs exch def /nWidth exch def currentpoint nXOfs 0 rmoveto pum nWidth aString stringwidth pop div 1 scale aString show pom moveto} bdef
+%%EndResource
+%%EndProlog
+%%BeginSetup
+%%EndSetup
+%%Page: 1 1
+%%BeginPageSetup
+%%EndPageSetup
+pum
+0.02837 0.02833 s
+0 -9000 t
+/tm matrix currentmatrix def
+tm setmatrix
+-11389 -20500 t
+1 1 s
+1.000 1.000 1.000 c 19389 29490 m  11389 29490 l  11389 20491 l  27388 20491 l
+27388 29490 l  19389 29490 l  p ef
+0 lw 1 lj 0.703 0.703 0.703 c 20302 27677 m  13631 27677 l  13631 20834 l
+26973 20834 l  26973 27677 l  20302 27677 l  pc
+[ 51 51 51 51 ] 0 ld
+13631 20833 m  13631 27676 l  ps
+16299 20833 m  16299 27676 l  ps
+18968 20833 m  18968 27676 l  ps
+21635 20833 m  21635 27676 l  ps
+24304 20833 m  24304 27676 l  ps
+26973 20833 m  26973 27676 l  ps
+26973 27676 m  13631 27676 l  ps
+26973 26915 m  13631 26915 l  ps
+26973 26155 m  13631 26155 l  ps
+26973 25394 m  13631 25394 l  ps
+26973 24635 m  13631 24635 l  ps
+26973 23874 m  13631 23874 l  ps
+26973 23114 m  13631 23114 l  ps
+26973 22353 m  13631 22353 l  ps
+26973 21593 m  13631 21593 l  ps
+26973 20833 m  13631 20833 l  ps
+[ ] 0 ld
+13631 27826 m  13631 27676 l  ps
+16299 27826 m  16299 27676 l  ps
+18968 27826 m  18968 27676 l  ps
+21635 27826 m  21635 27676 l  ps
+24304 27826 m  24304 27676 l  ps
+26973 27826 m  26973 27676 l  ps
+13631 27676 m  26973 27676 l  ps
+13481 27676 m  13631 27676 l  ps
+13481 26915 m  13631 26915 l  ps
+13481 26155 m  13631 26155 l  ps
+13481 25394 m  13631 25394 l  ps
+13481 24635 m  13631 24635 l  ps
+13481 23874 m  13631 23874 l  ps
+13481 23114 m  13631 23114 l  ps
+13481 22353 m  13631 22353 l  ps
+13481 21593 m  13631 21593 l  ps
+13481 20833 m  13631 20833 l  ps
+13631 27676 m  13631 20833 l  ps
+24.99843 lw 0.343 0.617 0.113 c 13848 26225 m  14062 26094 l  14275 25996 l
+14488 25888 l  14701 25805 l  14861 25736 l  14967 25690 l  15074 25645 l
+15180 25616 l  15287 25601 l  15393 25590 l  15500 25560 l  15606 25535 l
+15713 25507 l  15819 25463 l  15926 25453 l  16033 25425 l  16139 25382 l
+16246 25324 l  16352 25308 l  16459 25237 l  16565 25190 l  16672 25140 l
+16778 25061 l  16885 25034 l  16991 24967 l  17098 24914 l  17205 24861 l
+17311 24812 l  17418 24754 l  17524 24712 l  17631 24666 l  17737 24609 l
+17844 24559 l  17950 24512 l  18057 24480 l  18163 24430 l  18270 24360 l
+18376 24321 l  18483 24255 l  18590 24222 l  18696 24191 l  18803 24151 l
+18909 24115 l  19016 24077 l  19122 24037 l  19229 24016 l  19389 23981 l
+19601 23927 l  19814 23875 l  20027 23825 l  20240 23764 l  20453 23710 l
+20666 23618 l  20879 23601 l  21092 23543 l  21305 23491 l  21518 23443 l
+21731 23383 l  21945 23312 l  22158 23248 l  22371 23191 l  22584 23106 l
+22797 23048 l  23010 22944 l  23223 22861 l  23436 22777 l  23649 22651 l
+23862 22553 l  24075 22478 l  24288 22343 l  24502 22248 l  24715 22106 l
+24928 22045 l  25141 21927 l  25354 21810 l  25567 21668 l  25780 21529 l
+25993 21485 l  26206 21248 l  26419 21254 l  26632 21382 l  26845 21306 l
+ps
+1.000 0.828 0.128 c 13848 26224 m  14062 26103 l  14275 25995 l  14488 25900 l
+14701 25805 l  14861 25735 l  14967 25678 l  15074 25645 l  15180 25615 l
+15287 25600 l  15393 25589 l  15500 25560 l  15606 25518 l  15713 25491 l
+15819 25463 l  15926 25452 l  16033 25409 l  16139 25382 l  16246 25324 l
+16352 25307 l  16459 25247 l  16565 25189 l  16672 25149 l  16778 25070 l
+16885 25034 l  16991 24974 l  17098 24918 l  17205 24861 l  17311 24812 l
+17418 24753 l  17524 24712 l  17631 24665 l  17737 24618 l  17844 24559 l
+17950 24522 l  18057 24469 l  18163 24418 l  18270 24371 l  18376 24320 l
+18483 24255 l  18590 24235 l  18696 24190 l  18803 24165 l  18909 24129 l
+19016 24091 l  19122 24037 l  19229 24015 l  19389 23981 l  19601 23927 l
+19814 23888 l  20027 23812 l  20240 23763 l  20453 23722 l  20666 23662 l
+20879 23612 l  21092 23555 l  21305 23501 l  21518 23454 l  21731 23394 l
+21945 23313 l  22158 23271 l  22371 23193 l  22584 23109 l  22797 23041 l
+23010 22950 l  23223 22868 l  23436 22787 l  23649 22652 l  23862 22582 l
+24075 22485 l  24288 22355 l  24502 22251 l  24715 22129 l  24928 22045 l
+25141 21936 l  25354 21825 l  25567 21674 l  25780 21544 l  25993 21458 l
+26206 21251 l  26419 21263 l  26632 21392 l  26845 21333 l  ps
+1.000 0.261 0.058 c 13848 26270 m  14062 26164 l  14275 26058 l  14488 25956 l
+14701 25878 l  14861 25801 l  14967 25763 l  15074 25726 l  15180 25685 l
+15287 25668 l  15393 25653 l  15500 25627 l  15606 25600 l  15713 25577 l
+15819 25541 l  15926 25521 l  16033 25472 l  16139 25461 l  16246 25426 l
+16352 25370 l  16459 25318 l  16565 25267 l  16672 25226 l  16778 25172 l
+16885 25116 l  16991 25065 l  17098 25004 l  17205 24946 l  17311 24913 l
+17418 24838 l  17524 24801 l  17631 24759 l  17737 24709 l  17844 24666 l
+17950 24604 l  18057 24566 l  18163 24533 l  18270 24493 l  18376 24431 l
+18483 24390 l  18590 24330 l  18696 24304 l  18803 24259 l  18909 24227 l
+19016 24187 l  19122 24146 l  19229 24128 l  19389 24098 l  19601 24044 l
+19814 23985 l  20027 23927 l  20240 23864 l  20453 23829 l  20666 23752 l
+20879 23709 l  21092 23653 l  21305 23591 l  21518 23546 l  21731 23471 l
+21945 23449 l  22158 23349 l  22371 23292 l  22584 23220 l  22797 23146 l
+23010 23047 l  23223 22966 l  23436 22881 l  23649 22781 l  23862 22674 l
+24075 22579 l  24288 22456 l  24502 22362 l  24715 22230 l  24928 22128 l
+25141 22054 l  25354 21908 l  25567 21771 l  25780 21670 l  25993 21604 l
+26206 21398 l  26419 21411 l  26632 21516 l  26845 21477 l  ps
+0.003 0.273 0.527 c 13848 26272 m  14062 26154 l  14275 26060 l  14488 25957 l
+14701 25868 l  14861 25806 l  14967 25757 l  15074 25718 l  15180 25686 l
+15287 25677 l  15393 25672 l  15500 25626 l  15606 25600 l  15713 25577 l
+15819 25540 l  15926 25512 l  16033 25502 l  16139 25481 l  16246 25424 l
+16352 25386 l  16459 25330 l  16565 25280 l  16672 25228 l  16778 25166 l
+16885 25118 l  16991 25070 l  17098 25004 l  17205 24952 l  17311 24914 l
+17418 24851 l  17524 24817 l  17631 24756 l  17737 24705 l  17844 24657 l
+17950 24615 l  18057 24549 l  18163 24510 l  18270 24479 l  18376 24430 l
+18483 24380 l  18590 24353 l  18696 24291 l  18803 24255 l  18909 24235 l
+19016 24180 l  19122 24128 l  19229 24118 l  19389 24097 l  19601 24032 l
+19814 23975 l  20027 23922 l  20240 23858 l  20453 23820 l  20666 23778 l
+20879 23691 l  21092 23652 l  21305 23594 l  21518 23538 l  21731 23482 l
+21945 23413 l  22158 23361 l  22371 23289 l  22584 23207 l  22797 23130 l
+23010 23042 l  23223 22968 l  23436 22889 l  23649 22783 l  23862 22675 l
+24075 22578 l  24288 22454 l  24502 22359 l  24715 22236 l  24928 22108 l
+25141 22046 l  25354 21903 l  25567 21764 l  25780 21663 l  25993 21584 l
+26206 21386 l  26419 21398 l  26632 21528 l  26845 21488 l  ps
+pum
+13353 28244 t
+0.003 0.003 0.003 c 182 -80 m  182 -67 180 -56 176 -46 ct 172 -36 167 -27 160 -20 ct
+152 -13 143 -7 133 -3 ct 122 1 109 3 95 3 ct 83 3 71 1 62 -1 ct 52 -4 44 -9 38 -14 ct
+31 -19 26 -25 22 -32 ct 18 -39 16 -47 14 -55 ct 46 -58 l  47 -54 49 -49 51 -45 ct
+53 -41 56 -37 60 -33 ct 64 -30 69 -27 75 -25 ct 81 -23 88 -22 96 -22 ct 104 -22 111 -24 118 -26 ct
+124 -29 130 -32 135 -37 ct 139 -42 143 -48 145 -55 ct 148 -62 149 -70 149 -79 ct
+149 -86 148 -93 146 -99 ct 143 -106 140 -111 135 -116 ct 131 -120 125 -124 119 -126 ct
+112 -129 105 -130 97 -130 ct 92 -130 87 -130 82 -129 ct 78 -128 74 -126 70 -125 ct
+67 -123 63 -121 60 -119 ct 57 -117 54 -115 52 -113 ct 21 -113 l  29 -243 l  167 -243 l
+167 -217 l  58 -217 l  53 -140 l  58 -144 65 -148 74 -151 ct 82 -154 92 -155 103 -155 ct
+115 -155 126 -154 136 -150 ct 145 -146 154 -141 160 -134 ct 167 -128 172 -120 176 -110 ct
+180 -101 182 -91 182 -80 ct p ef
+368 -122 m  368 -99 365 -79 361 -63 ct 356 -47 350 -34 343 -25 ct 335 -15 326 -8 316 -3 ct
+305 1 294 3 283 3 ct 271 3 260 1 250 -3 ct 239 -8 231 -15 223 -24 ct 215 -34 210 -47 205 -63 ct
+201 -79 199 -99 199 -122 ct 199 -146 201 -167 205 -183 ct 210 -199 216 -212 223 -221 ct
+231 -231 240 -237 250 -241 ct 260 -245 272 -247 284 -247 ct 295 -247 306 -245 316 -241 ct
+327 -237 335 -231 343 -221 ct 351 -212 357 -199 361 -183 ct 365 -167 368 -146 368 -122 ct
+p
+336 -122 m  336 -141 335 -157 333 -170 ct 330 -183 327 -193 322 -201 ct 318 -209 312 -214 306 -217 ct
+299 -220 292 -222 284 -222 ct 275 -222 267 -220 261 -217 ct 254 -214 248 -208 244 -201 ct
+239 -193 236 -183 234 -170 ct 231 -157 230 -141 230 -122 ct 230 -103 231 -88 234 -75 ct
+236 -62 239 -52 244 -44 ct 249 -36 254 -31 261 -27 ct 267 -24 275 -22 283 -22 ct
+291 -22 299 -24 305 -27 ct 312 -31 317 -36 322 -44 ct 326 -52 330 -62 332 -75 ct
+335 -88 336 -103 336 -122 ct p ef
+553 -122 m  553 -99 550 -79 546 -63 ct 541 -47 535 -34 528 -25 ct 520 -15 511 -8 501 -3 ct
+490 1 479 3 468 3 ct 456 3 445 1 435 -3 ct 424 -8 416 -15 408 -24 ct 400 -34 395 -47 390 -63 ct
+386 -79 384 -99 384 -122 ct 384 -146 386 -167 390 -183 ct 395 -199 401 -212 408 -221 ct
+416 -231 425 -237 435 -241 ct 445 -245 457 -247 469 -247 ct 480 -247 491 -245 501 -241 ct
+512 -237 520 -231 528 -221 ct 536 -212 542 -199 546 -183 ct 550 -167 553 -146 553 -122 ct
+p
+521 -122 m  521 -141 520 -157 518 -170 ct 515 -183 512 -193 507 -201 ct 503 -209 497 -214 491 -217 ct
+484 -220 477 -222 469 -222 ct 460 -222 452 -220 446 -217 ct 439 -214 433 -208 429 -201 ct
+424 -193 421 -183 419 -170 ct 416 -157 415 -141 415 -122 ct 415 -103 416 -88 419 -75 ct
+421 -62 424 -52 429 -44 ct 434 -36 439 -31 446 -27 ct 452 -24 460 -22 468 -22 ct
+476 -22 484 -24 490 -27 ct 497 -31 502 -36 507 -44 ct 511 -52 515 -62 517 -75 ct
+520 -88 521 -103 521 -122 ct p ef
+pom
+pum
+15928 28244 t
+27 0 m  27 -26 l  89 -26 l  89 -213 l  34 -174 l  34 -204 l  91 -243 l
+120 -243 l  120 -26 l  179 -26 l  179 0 l  27 0 l  p ef
+p
+p
+739 -122 m  739 -99 736 -79 732 -63 ct 727 -47 721 -34 714 -25 ct 706 -15 697 -8 687 -3 ct
+676 1 665 3 654 3 ct 642 3 631 1 621 -3 ct 610 -8 602 -15 594 -24 ct 586 -34 581 -47 576 -63 ct
+572 -79 570 -99 570 -122 ct 570 -146 572 -167 576 -183 ct 581 -199 587 -212 594 -221 ct
+602 -231 611 -237 621 -241 ct 631 -245 643 -247 655 -247 ct 666 -247 677 -245 687 -241 ct
+698 -237 706 -231 714 -221 ct 722 -212 728 -199 732 -183 ct 736 -167 739 -146 739 -122 ct
+p
+707 -122 m  707 -141 706 -157 704 -170 ct 701 -183 698 -193 693 -201 ct 689 -209 683 -214 677 -217 ct
+670 -220 663 -222 655 -222 ct 646 -222 638 -220 632 -217 ct 625 -214 619 -208 615 -201 ct
+610 -193 607 -183 605 -170 ct 602 -157 601 -141 601 -122 ct 601 -103 602 -88 605 -75 ct
+607 -62 610 -52 615 -44 ct 620 -36 625 -31 632 -27 ct 638 -24 646 -22 654 -22 ct
+662 -22 670 -24 676 -27 ct 683 -31 688 -36 693 -44 ct 697 -52 701 -62 703 -75 ct
+706 -88 707 -103 707 -122 ct p ef
+pom
+pum
+18597 28244 t
+367 -80 m  367 -67 365 -56 361 -46 ct 357 -36 352 -27 345 -20 ct 337 -13 328 -7 318 -3 ct
+307 1 294 3 280 3 ct 268 3 256 1 247 -1 ct 237 -4 229 -9 223 -14 ct 216 -19 211 -25 207 -32 ct
+203 -39 201 -47 199 -55 ct 231 -58 l  232 -54 234 -49 236 -45 ct 238 -41 241 -37 245 -33 ct
+249 -30 254 -27 260 -25 ct 266 -23 273 -22 281 -22 ct 289 -22 296 -24 303 -26 ct
+309 -29 315 -32 320 -37 ct 324 -42 328 -48 330 -55 ct 333 -62 334 -70 334 -79 ct
+334 -86 333 -93 331 -99 ct 328 -106 325 -111 320 -116 ct 316 -120 310 -124 304 -126 ct
+297 -129 290 -130 282 -130 ct 277 -130 272 -130 267 -129 ct 263 -128 259 -126 255 -125 ct
+252 -123 248 -121 245 -119 ct 242 -117 239 -115 237 -113 ct 206 -113 l  214 -243 l
+352 -243 l  352 -217 l  243 -217 l  238 -140 l  243 -144 250 -148 259 -151 ct
+267 -154 277 -155 288 -155 ct 300 -155 311 -154 321 -150 ct 330 -146 339 -141 345 -134 ct
+352 -128 357 -120 361 -110 ct 365 -101 367 -91 367 -80 ct p ef
+p
+p
+pom
+pum
+21265 28244 t
+18 0 m  18 -22 l  24 -35 31 -47 39 -58 ct 48 -68 57 -77 66 -85 ct 75 -94 84 -101 94 -109 ct
+103 -116 111 -123 118 -130 ct 126 -137 132 -145 136 -152 ct 141 -160 143 -169 143 -179 ct
+143 -186 142 -192 140 -197 ct 138 -202 135 -207 131 -210 ct 127 -214 122 -217 117 -218 ct
+111 -220 105 -221 99 -221 ct 92 -221 87 -220 81 -218 ct 76 -217 71 -214 67 -211 ct
+62 -207 59 -203 56 -198 ct 53 -193 52 -187 51 -180 ct 19 -183 l  20 -192 23 -200 26 -208 ct
+30 -215 35 -222 42 -228 ct 49 -234 57 -238 66 -242 ct 75 -245 86 -247 99 -247 ct
+111 -247 121 -245 131 -242 ct 140 -239 148 -235 155 -229 ct 161 -224 166 -217 170 -209 ct
+173 -200 175 -191 175 -180 ct 175 -172 173 -164 170 -157 ct 167 -149 164 -142 159 -136 ct
+154 -129 148 -123 142 -116 ct 135 -110 129 -104 122 -98 ct 115 -92 107 -86 100 -81 ct
+93 -75 87 -69 80 -63 ct 74 -57 68 -51 63 -45 ct 58 -39 55 -33 52 -26 ct 179 -26 l
+179 0 l  18 0 l  p ef
+p
+p
+p
+pom
+pum
+23934 28244 t
+p
+p
+pom
+pum
+26603 28244 t
+181 -68 m  181 -57 179 -47 175 -38 ct 172 -29 166 -22 160 -16 ct 153 -10 144 -5 134 -2 ct
+123 1 112 3 98 3 ct 83 3 71 1 60 -3 ct 50 -6 42 -11 35 -17 ct 28 -24 23 -31 20 -39 ct
+17 -46 14 -55 13 -63 ct 46 -66 l  46 -60 48 -54 51 -48 ct 53 -43 56 -38 61 -35 ct
+65 -31 70 -28 76 -26 ct 83 -24 90 -23 98 -23 ct 114 -23 126 -27 135 -34 ct 144 -42 149 -54 149 -69 ct
+149 -78 147 -85 143 -90 ct 139 -96 134 -100 128 -103 ct 122 -106 115 -108 109 -109 ct
+102 -110 95 -111 89 -111 ct 72 -111 l  72 -138 l  89 -138 l  94 -138 101 -139 107 -140 ct
+113 -141 119 -143 124 -146 ct 129 -149 134 -154 137 -159 ct 141 -164 142 -171 142 -180 ct
+142 -193 138 -203 131 -210 ct 123 -218 112 -221 97 -221 ct 83 -221 72 -218 64 -211 ct
+55 -204 50 -194 49 -182 ct 18 -184 l  19 -195 22 -204 26 -212 ct 31 -220 37 -226 44 -231 ct
+51 -237 59 -241 68 -243 ct 77 -246 87 -247 97 -247 ct 111 -247 122 -245 132 -242 ct
+142 -239 150 -234 156 -228 ct 162 -222 167 -216 170 -208 ct 173 -200 174 -192 174 -183 ct
+174 -176 173 -169 171 -163 ct 169 -157 166 -151 162 -146 ct 158 -141 153 -137 146 -134 ct
+140 -130 132 -127 123 -125 ct 123 -125 l  133 -124 142 -122 149 -118 ct 156 -115 162 -111 167 -105 ct
+171 -100 175 -95 177 -88 ct 180 -82 181 -75 181 -68 ct p ef
+p
+p
+p
+pom
+pum
+13196 27797 t
+183 -122 m  183 -99 180 -79 176 -63 ct 171 -47 165 -34 158 -25 ct 150 -15 141 -8 131 -3 ct
+120 1 109 3 98 3 ct 86 3 75 1 65 -3 ct 54 -8 46 -15 38 -24 ct 30 -34 25 -47 20 -63 ct
+16 -79 14 -99 14 -122 ct 14 -146 16 -167 20 -183 ct 25 -199 31 -212 38 -221 ct
+46 -231 55 -237 65 -241 ct 75 -245 87 -247 99 -247 ct 110 -247 121 -245 131 -241 ct
+142 -237 150 -231 158 -221 ct 166 -212 172 -199 176 -183 ct 180 -167 183 -146 183 -122 ct
+p
+151 -122 m  151 -141 150 -157 148 -170 ct 145 -183 142 -193 137 -201 ct 133 -209 127 -214 121 -217 ct
+114 -220 107 -222 99 -222 ct 90 -222 82 -220 76 -217 ct 69 -214 63 -208 59 -201 ct
+54 -193 51 -183 49 -170 ct 46 -157 45 -141 45 -122 ct 45 -103 46 -88 49 -75 ct
+51 -62 54 -52 59 -44 ct 64 -36 69 -31 76 -27 ct 82 -24 90 -22 98 -22 ct 106 -22 114 -24 120 -27 ct
+127 -31 132 -36 137 -44 ct 141 -52 145 -62 147 -75 ct 150 -88 151 -103 151 -122 ct
+p ef
+pom
+pum
+12720 27036 t
+p
+p ef
+217 0 m  217 -38 l  251 -38 l  251 0 l  217 0 l  p ef
+474 -122 m  474 -99 471 -79 467 -63 ct 462 -47 456 -34 449 -25 ct 441 -15 432 -8 422 -3 ct
+411 1 400 3 389 3 ct 377 3 366 1 356 -3 ct 345 -8 337 -15 329 -24 ct 321 -34 316 -47 311 -63 ct
+307 -79 305 -99 305 -122 ct 305 -146 307 -167 311 -183 ct 316 -199 322 -212 329 -221 ct
+337 -231 346 -237 356 -241 ct 366 -245 378 -247 390 -247 ct 401 -247 412 -245 422 -241 ct
+433 -237 441 -231 449 -221 ct 457 -212 463 -199 467 -183 ct 471 -167 474 -146 474 -122 ct
+p
+442 -122 m  442 -141 441 -157 439 -170 ct 436 -183 433 -193 428 -201 ct 424 -209 418 -214 412 -217 ct
+405 -220 398 -222 390 -222 ct 381 -222 373 -220 367 -217 ct 360 -214 354 -208 350 -201 ct
+345 -193 342 -183 340 -170 ct 337 -157 336 -141 336 -122 ct 336 -103 337 -88 340 -75 ct
+342 -62 345 -52 350 -44 ct 355 -36 360 -31 367 -27 ct 373 -24 381 -22 389 -22 ct
+397 -22 405 -24 411 -27 ct 418 -31 423 -36 428 -44 ct 432 -52 436 -62 438 -75 ct
+441 -88 442 -103 442 -122 ct p ef
+494 0 m  494 -22 l  500 -35 507 -47 515 -58 ct 524 -68 533 -77 542 -85 ct 551 -94 560 -101 570 -109 ct
+579 -116 587 -123 594 -130 ct 602 -137 608 -145 612 -152 ct 617 -160 619 -169 619 -179 ct
+619 -186 618 -192 616 -197 ct 614 -202 611 -207 607 -210 ct 603 -214 598 -217 593 -218 ct
+587 -220 581 -221 575 -221 ct 568 -221 563 -220 557 -218 ct 552 -217 547 -214 543 -211 ct
+538 -207 535 -203 532 -198 ct 529 -193 528 -187 527 -180 ct 495 -183 l  496 -192 499 -200 502 -208 ct
+506 -215 511 -222 518 -228 ct 525 -234 533 -238 542 -242 ct 551 -245 562 -247 575 -247 ct
+587 -247 597 -245 607 -242 ct 616 -239 624 -235 631 -229 ct 637 -224 642 -217 646 -209 ct
+649 -200 651 -191 651 -180 ct 651 -172 649 -164 646 -157 ct 643 -149 640 -142 635 -136 ct
+630 -129 624 -123 618 -116 ct 611 -110 605 -104 598 -98 ct 591 -92 583 -86 576 -81 ct
+569 -75 563 -69 556 -63 ct 550 -57 544 -51 539 -45 ct 534 -39 531 -33 528 -26 ct
+655 -26 l  655 0 l  494 0 l  p ef
+pom
+pum
+12720 26276 t
+p
+p ef
+p
+628 -55 m  628 0 l  599 0 l  599 -55 l  484 -55 l  484 -79 l  595 -243 l
+628 -243 l  628 -79 l  662 -79 l  662 -55 l  628 -55 l  p
+599 -208 m  598 -207 598 -206 597 -205 ct 596 -203 595 -201 594 -199 ct 593 -197 591 -195 590 -193 ct
+589 -191 588 -189 587 -187 ct 525 -96 l  524 -95 523 -94 522 -92 ct 521 -91 520 -89 519 -88 ct
+518 -86 517 -84 515 -83 ct 514 -81 513 -80 513 -79 ct 599 -79 l  599 -208 l
+p ef
+pom
+pum
+12720 25515 t
+p
+p ef
+p
+657 -80 m  657 -68 655 -57 652 -47 ct 648 -36 643 -28 637 -20 ct 630 -13 622 -7 612 -3 ct
+602 1 591 3 578 3 ct 564 3 552 0 541 -5 ct 531 -11 522 -18 515 -28 ct 508 -39 503 -51 499 -66 ct
+496 -81 494 -97 494 -116 ct 494 -138 496 -157 500 -173 ct 504 -190 510 -203 517 -214 ct
+524 -225 534 -233 544 -239 ct 555 -244 567 -247 581 -247 ct 589 -247 597 -246 604 -244 ct
+611 -243 618 -240 624 -236 ct 630 -232 635 -227 639 -221 ct 644 -215 647 -207 650 -198 ct
+620 -192 l  617 -203 612 -210 605 -215 ct 598 -220 590 -222 580 -222 ct 572 -222 564 -220 557 -216 ct
+550 -212 545 -206 540 -198 ct 535 -190 531 -180 529 -168 ct 526 -156 525 -142 525 -126 ct
+530 -136 538 -144 549 -150 ct 559 -155 571 -158 584 -158 ct 595 -158 605 -156 614 -153 ct
+623 -149 630 -144 637 -137 ct 643 -130 648 -122 652 -113 ct 655 -103 657 -92 657 -80 ct
+p
+625 -79 m  625 -87 624 -95 622 -102 ct 620 -108 617 -114 613 -119 ct 609 -124 604 -128 598 -130 ct
+591 -133 584 -134 576 -134 ct 571 -134 565 -133 559 -131 ct 554 -130 548 -127 544 -123 ct
+539 -120 535 -115 532 -109 ct 529 -102 528 -95 528 -86 ct 528 -77 529 -69 531 -61 ct
+534 -53 537 -46 541 -41 ct 546 -35 551 -30 557 -27 ct 563 -24 570 -22 577 -22 ct
+585 -22 592 -23 597 -26 ct 603 -29 608 -32 613 -37 ct 617 -42 620 -48 622 -55 ct
+624 -62 625 -70 625 -79 ct p ef
+pom
+pum
+12720 24755 t
+p
+p ef
+p
+657 -68 m  657 -58 655 -48 652 -40 ct 649 -31 644 -24 637 -17 ct 630 -11 622 -6 611 -2 ct
+601 1 589 3 574 3 ct 560 3 548 1 537 -2 ct 527 -6 518 -11 511 -17 ct 505 -23 500 -31 496 -40 ct
+493 -48 491 -58 491 -68 ct 491 -77 493 -85 495 -92 ct 498 -98 502 -104 506 -109 ct
+511 -114 516 -118 522 -121 ct 528 -125 534 -127 540 -128 ct 540 -128 l  533 -130 527 -132 522 -136 ct
+516 -140 512 -144 508 -149 ct 505 -154 502 -159 500 -166 ct 498 -172 497 -178 497 -185 ct
+497 -193 499 -201 502 -209 ct 505 -216 510 -223 517 -229 ct 523 -234 531 -239 540 -242 ct
+550 -245 561 -247 574 -247 ct 587 -247 598 -245 608 -242 ct 618 -239 626 -234 632 -228 ct
+638 -223 643 -216 646 -209 ct 649 -201 651 -193 651 -184 ct 651 -178 650 -171 648 -165 ct
+646 -159 643 -154 640 -149 ct 636 -144 632 -139 626 -136 ct 621 -132 615 -130 608 -129 ct
+608 -128 l  615 -127 621 -125 627 -122 ct 633 -119 638 -115 643 -110 ct 647 -105 651 -99 653 -92 ct
+656 -85 657 -77 657 -68 ct p
+619 -183 m  619 -189 618 -194 616 -199 ct 615 -204 612 -209 609 -212 ct 605 -216 601 -219 595 -221 ct
+589 -223 582 -224 574 -224 ct 565 -224 559 -223 553 -221 ct 547 -219 543 -216 539 -212 ct
+535 -209 533 -204 531 -199 ct 530 -194 529 -189 529 -183 ct 529 -178 529 -173 531 -168 ct
+532 -163 534 -158 538 -154 ct 541 -150 545 -147 551 -144 ct 557 -141 565 -140 574 -140 ct
+584 -140 592 -141 597 -144 ct 603 -147 608 -150 611 -154 ct 614 -158 616 -163 617 -168 ct
+618 -173 619 -178 619 -183 ct p
+625 -71 m  625 -77 624 -83 622 -88 ct 621 -94 618 -98 614 -103 ct 610 -107 605 -110 598 -113 ct
+592 -115 583 -117 574 -117 ct 564 -117 557 -115 550 -113 ct 544 -110 539 -107 535 -103 ct
+531 -98 528 -93 526 -88 ct 524 -82 523 -76 523 -70 ct 523 -63 524 -56 526 -50 ct
+528 -44 531 -39 535 -34 ct 539 -30 544 -26 551 -24 ct 557 -21 565 -20 575 -20 ct
+584 -20 592 -21 598 -24 ct 605 -26 610 -30 614 -34 ct 618 -39 621 -44 622 -50 ct
+624 -56 625 -63 625 -71 ct p ef
+pom
+pum
+12905 23994 t
+p
+p ef
+318 0 m  318 -26 l  380 -26 l  380 -213 l  325 -174 l  325 -204 l  382 -243 l
+411 -243 l  411 -26 l  470 -26 l  470 0 l  318 0 l  p ef
+pom
+pum
+12720 23234 t
+p
+p ef
+pom
+pum
+12720 22473 t
+p
+p ef
+p ef
+pom
+pum
+12720 21713 t
+p
+p ef
+p
+pom
+pum
+12720 20953 t
+p
+p ef
+pom
+0.003 0.273 0.527 c 23212 24931 m  24012 24931 l  ps
+1.000 0.261 0.058 c 23212 25428 m  24012 25428 l  ps
+1.000 0.828 0.128 c 23212 25926 m  24012 25926 l  ps
+0.343 0.617 0.113 c 23212 26424 m  24012 26424 l  ps
+pum
+24112 25050 t
+0.003 0.003 0.003 c 217 -68 m  217 -56 214 -46 210 -37 ct 205 -28 198 -21 190 -16 ct
+182 -10 172 -6 162 -4 ct 151 -1 140 0 128 0 ct 29 0 l  29 -243 l  117 -243 l
+131 -243 143 -242 153 -240 ct 164 -237 173 -234 180 -229 ct 187 -224 193 -218 197 -211 ct
+201 -203 203 -194 203 -184 ct 203 -177 202 -171 200 -165 ct 198 -159 195 -153 191 -149 ct
+187 -144 183 -140 177 -136 ct 171 -132 164 -130 157 -128 ct 166 -127 175 -125 182 -121 ct
+190 -118 196 -114 201 -109 ct 206 -103 210 -97 213 -91 ct 216 -84 217 -76 217 -68 ct
+p
+170 -180 m  170 -193 165 -203 156 -208 ct 147 -214 134 -217 117 -217 ct 62 -217 l
+62 -140 l  117 -140 l  127 -140 135 -141 142 -143 ct 148 -144 154 -147 158 -151 ct
+162 -154 165 -158 167 -163 ct 169 -168 170 -174 170 -180 ct p
+184 -71 m  184 -79 182 -85 179 -91 ct 177 -96 172 -101 167 -104 ct 162 -107 156 -110 148 -112 ct
+141 -113 132 -114 123 -114 ct 62 -114 l  62 -26 l  126 -26 l  134 -26 142 -27 149 -28 ct
+156 -30 162 -32 167 -36 ct 172 -39 176 -44 179 -49 ct 182 -55 184 -62 184 -71 ct
+p ef
+286 -87 m  286 -77 287 -68 289 -60 ct 291 -52 294 -45 298 -39 ct 302 -33 307 -28 314 -25 ct
+321 -22 328 -20 338 -20 ct 351 -20 362 -23 370 -28 ct 378 -34 384 -41 386 -49 ct
+414 -41 l  412 -36 409 -31 405 -26 ct 402 -20 397 -16 391 -11 ct 386 -7 378 -4 369 -1 ct
+361 2 350 3 338 3 ct 310 3 289 -5 275 -22 ct 260 -38 253 -62 253 -95 ct 253 -112 255 -127 260 -139 ct
+264 -151 270 -161 277 -169 ct 285 -176 294 -182 304 -185 ct 314 -188 325 -190 336 -190 ct
+352 -190 365 -187 376 -182 ct 386 -177 395 -170 401 -162 ct 407 -153 412 -142 415 -130 ct
+417 -118 419 -105 419 -91 ct 419 -87 l  286 -87 l  p
+387 -111 m  385 -130 380 -145 372 -154 ct 363 -163 351 -167 336 -167 ct 331 -167 325 -166 320 -165 ct
+314 -163 309 -160 304 -156 ct 299 -152 295 -146 292 -139 ct 288 -131 286 -122 286 -111 ct
+387 -111 l  p ef
+565 0 m  565 -118 l  565 -127 565 -135 563 -141 ct 562 -147 560 -152 557 -156 ct
+554 -160 550 -162 545 -164 ct 540 -165 534 -166 527 -166 ct 519 -166 513 -165 507 -162 ct
+501 -160 496 -156 492 -151 ct 487 -146 484 -140 482 -133 ct 480 -126 479 -117 479 -108 ct
+479 0 l  447 0 l  447 -147 l  447 -151 447 -155 447 -159 ct 447 -163 447 -167 447 -171 ct
+447 -175 447 -178 447 -181 ct 447 -184 447 -186 446 -187 ct 476 -187 l  476 -186 476 -184 476 -182 ct
+476 -179 476 -176 477 -173 ct 477 -170 477 -167 477 -163 ct 477 -160 477 -157 477 -155 ct
+478 -155 l  481 -160 484 -165 487 -169 ct 491 -174 495 -177 500 -180 ct 505 -183 510 -186 516 -188 ct
+522 -189 529 -190 537 -190 ct 548 -190 557 -189 564 -186 ct 571 -184 578 -180 582 -174 ct
+587 -169 591 -162 593 -154 ct 595 -146 596 -136 596 -124 ct 596 0 l  565 0 l
+p ef
+656 -95 m  656 -84 657 -74 659 -65 ct 660 -56 663 -48 667 -42 ct 670 -35 675 -30 681 -27 ct
+687 -23 695 -21 703 -21 ct 714 -21 724 -24 731 -30 ct 739 -36 743 -45 745 -57 ct
+776 -57 l  775 -49 773 -42 769 -34 ct 766 -27 761 -21 755 -15 ct 750 -10 742 -5 734 -2 ct
+725 1 715 3 704 3 ct 690 3 677 1 667 -4 ct 657 -9 649 -16 642 -25 ct 636 -34 631 -44 628 -56 ct
+625 -67 624 -80 624 -94 ct 624 -106 625 -117 627 -127 ct 629 -137 632 -145 636 -152 ct
+640 -159 644 -165 649 -170 ct 654 -175 660 -179 665 -182 ct 671 -185 678 -187 684 -188 ct
+691 -190 697 -190 704 -190 ct 714 -190 724 -189 732 -186 ct 740 -183 747 -179 753 -174 ct
+759 -169 764 -163 767 -157 ct 771 -150 774 -142 775 -135 ct 743 -132 l  742 -143 738 -151 731 -157 ct
+724 -163 715 -166 703 -166 ct 694 -166 687 -165 681 -162 ct 675 -159 670 -154 667 -148 ct
+663 -142 660 -135 659 -126 ct 657 -117 656 -107 656 -95 ct p ef
+849 -155 m  852 -161 856 -166 860 -171 ct 864 -175 868 -179 873 -182 ct 878 -185 883 -187 889 -188 ct
+895 -189 901 -190 908 -190 ct 920 -190 930 -188 938 -185 ct 945 -182 951 -177 956 -172 ct
+960 -166 963 -159 965 -151 ct 967 -143 967 -134 967 -124 ct 967 0 l  936 0 l
+936 -118 l  936 -126 936 -133 935 -139 ct 934 -145 932 -150 929 -154 ct 926 -158 922 -161 917 -163 ct
+912 -165 906 -166 898 -166 ct 890 -166 884 -165 878 -162 ct 872 -159 867 -156 863 -151 ct
+858 -146 855 -140 853 -133 ct 851 -126 850 -119 850 -110 ct 850 0 l  818 0 l
+818 -256 l  850 -256 l  850 -189 l  850 -186 849 -182 849 -178 ct 849 -174 849 -171 849 -167 ct
+849 -164 849 -162 848 -159 ct 848 -157 848 -155 848 -155 ct 849 -155 l  p ef
+pom
+pum
+24112 25548 t
+219 -68 m  219 -57 217 -48 213 -39 ct 209 -31 203 -23 195 -17 ct 187 -11 176 -6 164 -2 ct
+151 1 136 3 119 3 ct 89 3 65 -2 48 -13 ct 31 -23 21 -39 16 -59 ct 48 -65 l  50 -59 52 -53 55 -48 ct
+59 -43 63 -38 69 -35 ct 75 -31 82 -28 90 -26 ct 98 -24 108 -23 120 -23 ct 130 -23 139 -24 147 -25 ct
+155 -27 162 -29 168 -33 ct 174 -36 178 -41 182 -46 ct 185 -52 187 -58 187 -66 ct
+187 -74 185 -80 181 -85 ct 178 -90 173 -94 166 -97 ct 159 -101 152 -103 143 -105 ct
+133 -108 123 -110 112 -113 ct 106 -114 99 -116 92 -117 ct 85 -119 79 -121 72 -124 ct
+66 -126 60 -129 55 -133 ct 49 -136 44 -140 40 -145 ct 36 -149 33 -155 31 -161 ct
+29 -167 27 -174 27 -182 ct 27 -193 30 -203 34 -212 ct 39 -220 46 -227 54 -232 ct
+62 -237 72 -241 83 -243 ct 94 -246 107 -247 120 -247 ct 135 -247 148 -246 158 -243 ct
+169 -241 178 -238 185 -233 ct 193 -228 199 -222 203 -215 ct 207 -208 211 -200 214 -191 ct
+181 -185 l  180 -191 177 -197 174 -201 ct 171 -206 167 -210 162 -213 ct 157 -216 151 -218 144 -220 ct
+137 -221 129 -222 119 -222 ct 108 -222 99 -221 91 -219 ct 83 -217 77 -214 72 -211 ct
+68 -208 65 -203 62 -199 ct 60 -194 59 -189 59 -184 ct 59 -176 61 -171 65 -166 ct
+69 -161 73 -157 80 -154 ct 86 -151 93 -149 101 -146 ct 109 -144 118 -142 127 -140 ct
+135 -139 142 -137 150 -135 ct 157 -133 164 -131 171 -129 ct 178 -126 184 -123 190 -120 ct
+196 -117 201 -113 205 -108 ct 210 -103 213 -97 216 -91 ct 218 -84 219 -76 219 -68 ct
+p ef
+292 -187 m  292 -69 l  292 -60 293 -52 294 -46 ct 295 -40 298 -35 301 -31 ct
+304 -27 307 -25 312 -23 ct 317 -22 323 -21 331 -21 ct 338 -21 345 -22 350 -25 ct
+356 -27 361 -31 366 -36 ct 370 -41 373 -47 375 -54 ct 378 -61 379 -70 379 -79 ct
+379 -187 l  410 -187 l  410 -40 l  410 -36 410 -32 410 -28 ct 410 -24 410 -20 410 -16 ct
+410 -12 410 -9 411 -6 ct 411 -3 411 -1 411 0 ct 382 0 l  381 -1 381 -3 381 -5 ct
+381 -8 381 -11 381 -14 ct 381 -17 380 -20 380 -24 ct 380 -27 380 -30 380 -32 ct
+380 -32 l  377 -27 373 -22 370 -18 ct 366 -13 362 -10 357 -7 ct 353 -4 347 -1 341 1 ct
+335 2 328 3 320 3 ct 310 3 301 2 293 -1 ct 286 -3 280 -7 275 -13 ct 270 -18 267 -25 264 -33 ct
+262 -41 261 -51 261 -63 ct 261 -187 l  292 -187 l  p ef
+447 0 m  447 -143 l  447 -147 447 -151 447 -155 ct 447 -159 447 -163 447 -167 ct
+447 -171 447 -174 447 -178 ct 447 -181 447 -184 446 -187 ct 476 -187 l  476 -184 476 -181 476 -178 ct
+476 -174 477 -171 477 -167 ct 477 -164 477 -160 477 -157 ct 477 -154 477 -151 477 -148 ct
+478 -148 l  480 -156 482 -162 485 -167 ct 487 -172 490 -177 494 -180 ct 497 -183 501 -186 505 -188 ct
+510 -189 516 -190 522 -190 ct 525 -190 527 -190 529 -189 ct 532 -189 533 -189 535 -188 ct
+535 -160 l  533 -160 530 -161 527 -161 ct 525 -161 522 -162 518 -162 ct 511 -162 505 -160 500 -157 ct
+495 -154 491 -149 488 -143 ct 485 -138 482 -131 481 -123 ct 479 -115 479 -107 479 -97 ct
+479 0 l  447 0 l  p ef
+635 0 m  598 0 l  530 -187 l  563 -187 l  604 -65 l  605 -63 606 -60 607 -56 ct
+608 -52 609 -49 611 -45 ct 612 -41 613 -37 614 -33 ct 615 -30 616 -27 616 -24 ct
+617 -27 618 -30 619 -33 ct 620 -37 621 -41 622 -44 ct 623 -48 625 -52 626 -56 ct
+627 -59 628 -62 629 -65 ct 671 -187 l  704 -187 l  635 0 l  p ef
+762 -87 m  762 -77 763 -68 765 -60 ct 767 -52 770 -45 774 -39 ct 778 -33 783 -28 790 -25 ct
+797 -22 804 -20 814 -20 ct 827 -20 838 -23 846 -28 ct 854 -34 860 -41 862 -49 ct
+890 -41 l  888 -36 885 -31 881 -26 ct 878 -20 873 -16 867 -11 ct 862 -7 854 -4 845 -1 ct
+837 2 826 3 814 3 ct 786 3 765 -5 751 -22 ct 736 -38 729 -62 729 -95 ct 729 -112 731 -127 736 -139 ct
+740 -151 746 -161 753 -169 ct 761 -176 770 -182 780 -185 ct 790 -188 801 -190 812 -190 ct
+828 -190 841 -187 852 -182 ct 862 -177 871 -170 877 -162 ct 883 -153 888 -142 891 -130 ct
+893 -118 895 -105 895 -91 ct 895 -87 l  762 -87 l  p
+863 -111 m  861 -130 856 -145 848 -154 ct 839 -163 827 -167 812 -167 ct 807 -167 801 -166 796 -165 ct
+790 -163 785 -160 780 -156 ct 775 -152 771 -146 768 -139 ct 764 -131 762 -122 762 -111 ct
+863 -111 l  p ef
+1004 0 m  1000 11 995 21 991 30 ct 986 39 981 47 975 53 ct 970 60 964 65 957 68 ct
+950 71 942 73 933 73 ct 929 73 925 73 922 73 ct 919 73 915 72 912 71 ct 912 48 l
+914 49 916 49 919 49 ct 922 49 924 49 926 49 ct 935 49 944 46 951 39 ct 959 32 966 21 972 6 ct
+975 -1 l  901 -187 l  934 -187 l  973 -83 l  974 -80 976 -76 978 -71 ct 979 -66 981 -61 983 -55 ct
+985 -50 986 -46 988 -41 ct 989 -37 990 -35 990 -34 ct 990 -35 991 -37 993 -41 ct
+994 -45 995 -49 997 -54 ct 999 -58 1000 -63 1002 -68 ct 1004 -72 1005 -76 1007 -80 ct
+1043 -187 l  1076 -187 l  1004 0 l  p ef
+1267 -94 m  1267 -61 1259 -37 1245 -21 ct 1231 -5 1210 3 1182 3 ct 1169 3 1158 1 1148 -3 ct
+1137 -7 1129 -13 1122 -21 ct 1115 -29 1109 -39 1105 -51 ct 1102 -63 1100 -77 1100 -94 ct
+1100 -158 1128 -190 1183 -190 ct 1198 -190 1210 -188 1221 -184 ct 1231 -180 1240 -174 1247 -166 ct
+1253 -158 1258 -148 1262 -136 ct 1265 -124 1267 -110 1267 -94 ct p
+1234 -94 m  1234 -108 1233 -120 1231 -129 ct 1228 -139 1225 -146 1221 -152 ct
+1216 -158 1211 -161 1205 -164 ct 1199 -166 1192 -167 1184 -167 ct 1176 -167 1169 -166 1162 -164 ct
+1156 -161 1151 -157 1146 -152 ct 1142 -146 1138 -138 1136 -129 ct 1134 -120 1132 -108 1132 -94 ct
+1132 -79 1134 -67 1136 -58 ct 1139 -48 1142 -41 1147 -35 ct 1151 -30 1156 -26 1162 -23 ct
+1168 -21 1175 -20 1182 -20 ct 1190 -20 1197 -21 1204 -23 ct 1210 -26 1215 -29 1220 -35 ct
+1224 -41 1228 -48 1230 -58 ct 1233 -67 1234 -79 1234 -94 ct p ef
+1294 0 m  1294 -143 l  1294 -147 1294 -151 1294 -155 ct 1294 -159 1294 -163 1294 -167 ct
+1294 -171 1294 -174 1294 -178 ct 1294 -181 1294 -184 1293 -187 ct 1323 -187 l
+1323 -184 1323 -181 1323 -178 ct 1323 -174 1324 -171 1324 -167 ct 1324 -164 1324 -160 1324 -157 ct
+1324 -154 1324 -151 1324 -148 ct 1325 -148 l  1327 -156 1329 -162 1332 -167 ct
+1334 -172 1337 -177 1341 -180 ct 1344 -183 1348 -186 1352 -188 ct 1357 -189 1363 -190 1369 -190 ct
+1372 -190 1374 -190 1376 -189 ct 1379 -189 1380 -189 1382 -188 ct 1382 -160 l
+1380 -160 1377 -161 1374 -161 ct 1372 -161 1369 -162 1365 -162 ct 1358 -162 1352 -160 1347 -157 ct
+1342 -154 1338 -149 1335 -143 ct 1332 -138 1329 -131 1328 -123 ct 1326 -115 1326 -107 1326 -97 ct
+1326 0 l  1294 0 l  p ef
+pom
+pum
+24112 26046 t
+p ef
+293 -155 m  296 -161 300 -166 304 -171 ct 308 -175 312 -179 317 -182 ct 322 -185 327 -187 333 -188 ct
+339 -189 345 -190 352 -190 ct 364 -190 374 -188 382 -185 ct 389 -182 395 -177 400 -172 ct
+404 -166 407 -159 409 -151 ct 411 -143 411 -134 411 -124 ct 411 0 l  380 0 l
+380 -118 l  380 -126 380 -133 379 -139 ct 378 -145 376 -150 373 -154 ct 370 -158 366 -161 361 -163 ct
+356 -165 350 -166 342 -166 ct 334 -166 328 -165 322 -162 ct 316 -159 311 -156 307 -151 ct
+302 -146 299 -140 297 -133 ct 295 -126 294 -119 294 -110 ct 294 0 l  262 0 l
+262 -256 l  294 -256 l  294 -189 l  294 -186 293 -182 293 -178 ct 293 -174 293 -171 293 -167 ct
+293 -164 293 -162 292 -159 ct 292 -157 292 -155 292 -155 ct 293 -155 l  p ef
+494 3 m  476 3 462 -2 452 -12 ct 443 -22 438 -35 438 -53 ct 438 -65 440 -75 445 -83 ct
+450 -91 456 -97 463 -102 ct 471 -106 479 -109 489 -111 ct 499 -113 509 -114 518 -114 ct
+560 -114 l  560 -124 l  560 -132 560 -138 558 -144 ct 556 -149 554 -154 551 -157 ct
+547 -161 543 -163 538 -165 ct 533 -166 527 -167 520 -167 ct 514 -167 509 -167 504 -166 ct
+499 -165 495 -163 492 -161 ct 488 -159 485 -156 483 -152 ct 481 -148 479 -143 479 -137 ct
+446 -140 l  447 -148 450 -154 453 -160 ct 456 -167 461 -172 467 -176 ct 472 -181 480 -184 489 -187 ct
+498 -189 508 -191 521 -191 ct 545 -191 562 -185 574 -175 ct 586 -164 592 -148 592 -128 ct
+592 -48 l  592 -38 593 -31 595 -27 ct 598 -22 602 -20 609 -20 ct 611 -20 613 -20 614 -20 ct
+616 -20 618 -21 619 -21 ct 619 -2 l  615 -1 612 0 608 0 ct 604 1 600 1 595 1 ct
+590 1 584 0 580 -1 ct 576 -3 573 -5 570 -8 ct 567 -11 565 -15 564 -20 ct 563 -25 562 -30 561 -36 ct
+560 -36 l  557 -30 553 -25 549 -20 ct 545 -15 541 -11 536 -8 ct 530 -4 524 -2 518 0 ct
+511 2 503 3 494 3 ct p
+501 -20 m  511 -20 520 -22 527 -26 ct 535 -29 541 -34 546 -39 ct 551 -45 554 -51 557 -58 ct
+559 -64 560 -71 560 -77 ct 560 -92 l  526 -92 l  519 -92 512 -92 505 -91 ct
+498 -90 492 -88 487 -85 ct 482 -82 478 -78 474 -73 ct 471 -67 470 -61 470 -52 ct
+470 -42 473 -34 478 -29 ct 484 -23 491 -20 501 -20 ct p ef
+633 0 m  633 -143 l  633 -147 633 -151 633 -155 ct 633 -159 633 -163 633 -167 ct
+633 -171 633 -174 633 -178 ct 633 -181 633 -184 632 -187 ct 662 -187 l  662 -184 662 -181 662 -178 ct
+662 -174 663 -171 663 -167 ct 663 -164 663 -160 663 -157 ct 663 -154 663 -151 663 -148 ct
+664 -148 l  666 -156 668 -162 671 -167 ct 673 -172 676 -177 680 -180 ct 683 -183 687 -186 691 -188 ct
+696 -189 702 -190 708 -190 ct 711 -190 713 -190 715 -189 ct 718 -189 719 -189 721 -188 ct
+721 -160 l  719 -160 716 -161 713 -161 ct 711 -161 708 -162 704 -162 ct 697 -162 691 -160 686 -157 ct
+681 -154 677 -149 674 -143 ct 671 -138 668 -131 667 -123 ct 665 -115 665 -107 665 -97 ct
+665 0 l  633 0 l  p ef
+896 -94 m  896 -80 894 -67 892 -55 ct 890 -43 886 -33 881 -25 ct 875 -16 868 -9 859 -4 ct
+851 1 840 3 827 3 ct 814 3 802 0 792 -5 ct 782 -10 774 -18 769 -29 ct 768 -29 l
+768 -29 768 -28 768 -26 ct 768 -24 769 -22 769 -19 ct 769 -17 769 -14 769 -10 ct
+769 -7 769 -3 769 0 ct 769 73 l  738 73 l  738 -149 l  738 -153 738 -158 738 -162 ct
+738 -166 738 -170 737 -173 ct 737 -176 737 -179 737 -182 ct 737 -184 737 -186 737 -187 ct
+767 -187 l  767 -187 767 -185 767 -183 ct 767 -181 768 -179 768 -176 ct 768 -173 768 -170 768 -166 ct
+768 -163 768 -160 768 -157 ct 769 -157 l  772 -163 775 -168 779 -172 ct 783 -176 787 -180 792 -182 ct
+796 -185 802 -187 807 -188 ct 813 -189 820 -190 827 -190 ct 840 -190 851 -188 859 -183 ct
+868 -179 875 -172 881 -164 ct 886 -155 890 -145 892 -134 ct 894 -122 896 -109 896 -94 ct
+p
+863 -94 m  863 -105 862 -115 861 -124 ct 859 -133 857 -141 854 -147 ct 850 -153 846 -158 840 -161 ct
+835 -164 827 -166 819 -166 ct 812 -166 806 -165 799 -163 ct 793 -161 788 -157 784 -152 ct
+779 -146 775 -139 773 -129 ct 770 -119 769 -107 769 -91 ct 769 -78 770 -67 772 -58 ct
+774 -49 777 -41 782 -36 ct 786 -30 791 -26 797 -24 ct 803 -21 811 -20 819 -20 ct
+827 -20 834 -22 840 -25 ct 846 -28 850 -33 854 -39 ct 857 -46 859 -53 861 -63 ct
+862 -72 863 -82 863 -94 ct p ef
+pom
+pum
+24112 26544 t
+235 0 m  235 -162 l  235 -168 236 -174 236 -180 ct 236 -186 236 -192 236 -197 ct
+236 -203 237 -208 237 -214 ct 235 -208 234 -202 232 -196 ct 231 -191 229 -186 227 -181 ct
+225 -175 224 -170 222 -166 ct 159 0 l  136 0 l  72 -166 l  72 -167 71 -169 70 -172 ct
+70 -174 69 -176 68 -179 ct 67 -181 66 -184 65 -187 ct 64 -190 64 -192 63 -195 ct
+61 -201 59 -207 57 -214 ct 57 -207 57 -201 58 -195 ct 58 -189 58 -184 58 -178 ct
+58 -172 58 -167 58 -162 ct 58 0 l  29 0 l  29 -243 l  72 -243 l  137 -74 l
+138 -72 139 -69 140 -66 ct 141 -62 142 -58 143 -54 ct 144 -51 145 -47 146 -44 ct
+147 -40 147 -38 148 -36 ct 148 -38 149 -40 150 -44 ct 151 -47 152 -51 153 -55 ct
+154 -58 155 -62 156 -66 ct 157 -69 159 -72 159 -74 ct 223 -243 l  265 -243 l
+265 0 l  235 0 l  p ef
+315 -226 m  315 -256 l  346 -256 l  346 -226 l  315 -226 l  p
+315 0 m  315 -187 l  346 -187 l  346 0 l  315 0 l  p ef
+512 -30 m  506 -18 498 -10 489 -5 ct 479 0 467 3 453 3 ct 430 3 413 -5 401 -21 ct
+390 -37 385 -61 385 -93 ct 385 -158 408 -190 453 -190 ct 468 -190 479 -187 489 -182 ct
+498 -177 506 -169 512 -158 ct 512 -158 l  512 -159 512 -161 512 -163 ct 512 -166 512 -168 512 -171 ct
+512 -174 512 -176 512 -179 ct 512 -181 512 -183 512 -184 ct 512 -256 l  543 -256 l
+543 -39 l  543 -34 543 -30 543 -26 ct 543 -22 543 -18 543 -14 ct 543 -11 543 -8 543 -5 ct
+543 -3 543 -1 544 0 ct 514 0 l  514 -1 513 -3 513 -5 ct 513 -7 513 -10 513 -12 ct
+513 -15 512 -18 512 -21 ct 512 -24 512 -27 512 -30 ct 512 -30 l  p
+417 -94 m  417 -81 418 -70 420 -61 ct 421 -52 424 -44 428 -38 ct 431 -32 436 -28 441 -25 ct
+447 -22 453 -21 461 -21 ct 470 -21 477 -22 483 -25 ct 489 -28 494 -32 499 -38 ct
+503 -44 506 -51 508 -61 ct 510 -70 512 -82 512 -96 ct 512 -109 510 -120 508 -129 ct
+506 -138 503 -146 499 -151 ct 494 -157 489 -161 483 -163 ct 477 -166 470 -167 462 -167 ct
+454 -167 448 -166 442 -163 ct 437 -160 432 -156 428 -150 ct 425 -145 422 -137 420 -128 ct
+418 -118 417 -107 417 -94 ct p ef
+693 -220 m  679 -220 667 -218 656 -213 ct 645 -209 636 -202 629 -194 ct 622 -185 617 -175 613 -163 ct
+609 -151 607 -138 607 -123 ct 607 -108 609 -95 613 -83 ct 617 -71 623 -60 630 -52 ct
+638 -43 647 -36 658 -31 ct 668 -26 680 -24 694 -24 ct 703 -24 712 -25 720 -28 ct
+727 -30 734 -34 741 -38 ct 747 -43 753 -48 757 -54 ct 762 -60 767 -67 771 -75 ct
+797 -61 l  793 -52 788 -44 781 -36 ct 775 -28 767 -21 759 -15 ct 750 -10 740 -5 729 -2 ct
+718 1 706 3 692 3 ct 673 3 655 0 641 -6 ct 626 -13 614 -21 604 -33 ct 594 -44 586 -57 581 -73 ct
+576 -88 574 -105 574 -123 ct 574 -142 577 -159 582 -174 ct 587 -190 595 -203 605 -213 ct
+615 -224 627 -232 642 -238 ct 657 -244 673 -247 692 -247 ct 718 -247 740 -242 757 -232 ct
+774 -222 787 -207 795 -187 ct 764 -176 l  762 -182 759 -188 755 -193 ct 751 -198 746 -203 740 -207 ct
+734 -211 727 -214 719 -216 ct 712 -219 703 -220 693 -220 ct p ef
+818 0 m  818 -143 l  818 -147 818 -151 818 -155 ct 818 -159 818 -163 818 -167 ct
+818 -171 818 -174 818 -178 ct 818 -181 818 -184 817 -187 ct 847 -187 l  847 -184 847 -181 847 -178 ct
+847 -174 848 -171 848 -167 ct 848 -164 848 -160 848 -157 ct 848 -154 848 -151 848 -148 ct
+849 -148 l  851 -156 853 -162 856 -167 ct 858 -172 861 -177 865 -180 ct 868 -183 872 -186 876 -188 ct
+881 -189 887 -190 893 -190 ct 896 -190 898 -190 900 -189 ct 903 -189 904 -189 906 -188 ct
+906 -160 l  904 -160 901 -161 898 -161 ct 896 -161 893 -162 889 -162 ct 882 -162 876 -160 871 -157 ct
+866 -154 862 -149 859 -143 ct 856 -138 853 -131 852 -123 ct 850 -115 850 -107 850 -97 ct
+850 0 l  818 0 l  p ef
+948 -87 m  948 -77 949 -68 951 -60 ct 953 -52 956 -45 960 -39 ct 964 -33 969 -28 976 -25 ct
+983 -22 990 -20 1000 -20 ct 1013 -20 1024 -23 1032 -28 ct 1040 -34 1046 -41 1048 -49 ct
+1076 -41 l  1074 -36 1071 -31 1067 -26 ct 1064 -20 1059 -16 1053 -11 ct 1048 -7 1040 -4 1031 -1 ct
+1023 2 1012 3 1000 3 ct 972 3 951 -5 937 -22 ct 922 -38 915 -62 915 -95 ct 915 -112 917 -127 922 -139 ct
+926 -151 932 -161 939 -169 ct 947 -176 956 -182 966 -185 ct 976 -188 987 -190 998 -190 ct
+1014 -190 1027 -187 1038 -182 ct 1048 -177 1057 -170 1063 -162 ct 1069 -153 1074 -142 1077 -130 ct
+1079 -118 1081 -105 1081 -91 ct 1081 -87 l  948 -87 l  p
+1049 -111 m  1047 -130 1042 -145 1034 -154 ct 1025 -163 1013 -167 998 -167 ct
+993 -167 987 -166 982 -165 ct 976 -163 971 -160 966 -156 ct 961 -152 957 -146 954 -139 ct
+950 -131 948 -122 948 -111 ct 1049 -111 l  p ef
+1249 -52 m  1249 -43 1247 -36 1244 -29 ct 1240 -22 1235 -16 1229 -11 ct 1222 -7 1215 -3 1205 -1 ct
+1196 2 1185 3 1173 3 ct 1162 3 1153 2 1144 1 ct 1135 -1 1128 -4 1121 -8 ct 1114 -11 1109 -16 1105 -22 ct
+1100 -28 1097 -36 1095 -44 ct 1122 -50 l  1125 -40 1130 -32 1139 -28 ct 1147 -23 1158 -21 1173 -21 ct
+1180 -21 1186 -21 1191 -22 ct 1197 -23 1202 -25 1206 -27 ct 1210 -29 1213 -32 1215 -36 ct
+1217 -39 1219 -44 1219 -50 ct 1219 -55 1217 -60 1215 -63 ct 1212 -67 1208 -70 1204 -73 ct
+1199 -75 1193 -77 1186 -79 ct 1180 -81 1172 -83 1164 -85 ct 1157 -87 1149 -89 1142 -91 ct
+1135 -94 1128 -97 1122 -101 ct 1116 -105 1111 -110 1108 -116 ct 1104 -122 1102 -129 1102 -138 ct
+1102 -155 1108 -168 1120 -177 ct 1133 -186 1150 -190 1173 -190 ct 1194 -190 1210 -186 1222 -179 ct
+1235 -172 1242 -160 1245 -144 ct 1218 -141 l  1217 -146 1215 -150 1212 -153 ct
+1209 -156 1206 -159 1202 -161 ct 1198 -163 1194 -164 1189 -165 ct 1184 -166 1179 -167 1173 -167 ct
+1159 -167 1149 -164 1142 -160 ct 1136 -156 1132 -149 1132 -141 ct 1132 -136 1134 -132 1136 -128 ct
+1139 -125 1142 -122 1146 -120 ct 1151 -118 1156 -116 1162 -114 ct 1169 -113 1175 -111 1183 -109 ct
+1188 -108 1193 -106 1198 -105 ct 1203 -103 1208 -102 1213 -100 ct 1218 -98 1223 -95 1227 -93 ct
+1231 -90 1235 -87 1238 -83 ct 1241 -79 1244 -75 1246 -70 ct 1248 -65 1249 -59 1249 -52 ct
+p ef
+1317 -95 m  1317 -84 1318 -74 1320 -65 ct 1321 -56 1324 -48 1328 -42 ct 1331 -35 1336 -30 1342 -27 ct
+1348 -23 1356 -21 1364 -21 ct 1375 -21 1385 -24 1392 -30 ct 1400 -36 1404 -45 1406 -57 ct
+1437 -57 l  1436 -49 1434 -42 1430 -34 ct 1427 -27 1422 -21 1416 -15 ct 1411 -10 1403 -5 1395 -2 ct
+1386 1 1376 3 1365 3 ct 1351 3 1338 1 1328 -4 ct 1318 -9 1310 -16 1303 -25 ct 1297 -34 1292 -44 1289 -56 ct
+1286 -67 1285 -80 1285 -94 ct 1285 -106 1286 -117 1288 -127 ct 1290 -137 1293 -145 1297 -152 ct
+1301 -159 1305 -165 1310 -170 ct 1315 -175 1321 -179 1326 -182 ct 1332 -185 1339 -187 1345 -188 ct
+1352 -190 1358 -190 1365 -190 ct 1375 -190 1385 -189 1393 -186 ct 1401 -183 1408 -179 1414 -174 ct
+1420 -169 1425 -163 1428 -157 ct 1432 -150 1435 -142 1436 -135 ct 1404 -132 l
+1403 -143 1399 -151 1392 -157 ct 1385 -163 1376 -166 1364 -166 ct 1355 -166 1348 -165 1342 -162 ct
+1336 -159 1331 -154 1328 -148 ct 1324 -142 1321 -135 1320 -126 ct 1318 -117 1317 -107 1317 -95 ct
+p ef
+1503 -87 m  1503 -77 1504 -68 1506 -60 ct 1508 -52 1511 -45 1515 -39 ct 1519 -33 1524 -28 1531 -25 ct
+1538 -22 1545 -20 1555 -20 ct 1568 -20 1579 -23 1587 -28 ct 1595 -34 1601 -41 1603 -49 ct
+1631 -41 l  1629 -36 1626 -31 1622 -26 ct 1619 -20 1614 -16 1608 -11 ct 1603 -7 1595 -4 1586 -1 ct
+1578 2 1567 3 1555 3 ct 1527 3 1506 -5 1492 -22 ct 1477 -38 1470 -62 1470 -95 ct
+1470 -112 1472 -127 1477 -139 ct 1481 -151 1487 -161 1494 -169 ct 1502 -176 1511 -182 1521 -185 ct
+1531 -188 1542 -190 1553 -190 ct 1569 -190 1582 -187 1593 -182 ct 1603 -177 1612 -170 1618 -162 ct
+1624 -153 1629 -142 1632 -130 ct 1634 -118 1636 -105 1636 -91 ct 1636 -87 l
+1503 -87 l  p
+1604 -111 m  1602 -130 1597 -145 1589 -154 ct 1580 -163 1568 -167 1553 -167 ct
+1548 -167 1542 -166 1537 -165 ct 1531 -163 1526 -160 1521 -156 ct 1516 -152 1512 -146 1509 -139 ct
+1505 -131 1503 -122 1503 -111 ct 1604 -111 l  p ef
+1782 0 m  1782 -118 l  1782 -127 1782 -135 1780 -141 ct 1779 -147 1777 -152 1774 -156 ct
+1771 -160 1767 -162 1762 -164 ct 1757 -165 1751 -166 1744 -166 ct 1736 -166 1730 -165 1724 -162 ct
+1718 -160 1713 -156 1709 -151 ct 1704 -146 1701 -140 1699 -133 ct 1697 -126 1696 -117 1696 -108 ct
+1696 0 l  1664 0 l  1664 -147 l  1664 -151 1664 -155 1664 -159 ct 1664 -163 1664 -167 1664 -171 ct
+1664 -175 1664 -178 1664 -181 ct 1664 -184 1664 -186 1663 -187 ct 1693 -187 l
+1693 -186 1693 -184 1693 -182 ct 1693 -179 1693 -176 1694 -173 ct 1694 -170 1694 -167 1694 -163 ct
+1694 -160 1694 -157 1694 -155 ct 1695 -155 l  1698 -160 1701 -165 1704 -169 ct
+1708 -174 1712 -177 1717 -180 ct 1722 -183 1727 -186 1733 -188 ct 1739 -189 1746 -190 1754 -190 ct
+1765 -190 1774 -189 1781 -186 ct 1788 -184 1795 -180 1799 -174 ct 1804 -169 1808 -162 1810 -154 ct
+1812 -146 1813 -136 1813 -124 ct 1813 0 l  1782 0 l  p ef
+1921 -1 m  1917 0 1912 1 1907 2 ct 1902 3 1897 3 1890 3 ct 1865 3 1853 -11 1853 -39 ct
+1853 -164 l  1831 -164 l  1831 -187 l  1854 -187 l  1863 -228 l  1884 -228 l
+1884 -187 l  1918 -187 l  1918 -164 l  1884 -164 l  1884 -46 l  1884 -37 1885 -31 1888 -27 ct
+1891 -23 1896 -22 1904 -22 ct 1907 -22 1909 -22 1912 -22 ct 1915 -23 1918 -23 1921 -24 ct
+1921 -1 l  p ef
+pom
+pum
+18471 28891 t
+235 0 m  199 0 l  161 -139 l  160 -143 159 -147 158 -153 ct 156 -158 155 -163 154 -168 ct
+153 -174 152 -180 150 -185 ct 149 -179 148 -174 147 -168 ct 145 -163 144 -158 143 -153 ct
+142 -147 141 -143 139 -139 ct 101 0 l  66 0 l  1 -219 l  32 -219 l  72 -80 l
+73 -73 75 -67 77 -60 ct 78 -54 80 -48 81 -43 ct 82 -37 83 -31 84 -26 ct 86 -33 88 -40 89 -47 ct
+90 -50 91 -53 91 -56 ct 92 -59 93 -63 94 -66 ct 94 -69 95 -72 96 -75 ct 97 -77 98 -80 98 -82 ct
+136 -219 l  165 -219 l  203 -82 l  203 -80 204 -77 205 -75 ct 206 -72 206 -69 207 -66 ct
+208 -63 209 -60 209 -56 ct 210 -53 211 -50 211 -47 ct 213 -40 215 -33 216 -26 ct
+216 -26 217 -28 218 -31 ct 219 -35 220 -39 221 -45 ct 222 -50 223 -56 225 -62 ct
+226 -68 228 -74 230 -80 ct 268 -219 l  299 -219 l  235 0 l  p ef
+329 3 m  312 3 300 -1 291 -10 ct 283 -19 279 -32 279 -47 ct 279 -58 281 -67 285 -75 ct
+289 -82 294 -87 301 -91 ct 308 -95 316 -98 324 -100 ct 333 -101 342 -102 351 -102 ct
+389 -102 l  389 -111 l  389 -118 388 -124 387 -129 ct 385 -134 383 -138 380 -141 ct
+377 -144 373 -146 369 -148 ct 364 -149 359 -150 353 -150 ct 347 -150 342 -149 338 -149 ct
+334 -148 330 -146 327 -144 ct 324 -142 321 -140 319 -136 ct 317 -133 316 -128 315 -123 ct
+286 -126 l  287 -132 289 -138 292 -144 ct 295 -149 299 -154 304 -158 ct 310 -162 316 -165 324 -168 ct
+332 -170 342 -171 353 -171 ct 374 -171 390 -166 401 -156 ct 412 -147 417 -133 417 -114 ct
+417 -42 l  417 -34 418 -28 420 -23 ct 422 -19 427 -17 433 -17 ct 434 -17 436 -17 437 -17 ct
+439 -18 440 -18 442 -18 ct 442 -1 l  438 0 435 1 431 1 ct 428 2 424 2 420 2 ct
+415 2 410 1 407 0 ct 403 -2 400 -4 397 -7 ct 395 -10 393 -13 392 -17 ct 391 -22 390 -27 390 -32 ct
+389 -32 l  386 -27 382 -22 379 -18 ct 375 -13 371 -10 366 -7 ct 362 -4 356 -1 350 1 ct
+344 2 337 3 329 3 ct p
+336 -18 m  345 -18 352 -20 359 -23 ct 366 -26 371 -30 376 -35 ct 380 -40 383 -46 385 -52 ct
+388 -58 389 -63 389 -69 ct 389 -82 l  358 -82 l  351 -82 345 -82 339 -81 ct
+333 -80 327 -78 322 -76 ct 318 -73 314 -70 311 -65 ct 309 -60 307 -54 307 -47 ct
+307 -37 310 -30 315 -25 ct 320 -20 327 -18 336 -18 ct p ef
+545 0 m  512 0 l  451 -168 l  481 -168 l  518 -59 l  519 -56 519 -54 520 -50 ct
+521 -47 522 -44 523 -40 ct 524 -37 525 -33 526 -30 ct 527 -27 528 -24 529 -22 ct
+529 -24 530 -27 531 -30 ct 532 -33 533 -37 534 -40 ct 535 -43 536 -47 537 -50 ct
+538 -53 539 -56 540 -58 ct 578 -168 l  608 -168 l  545 0 l  p ef
+652 -78 m  652 -69 653 -61 655 -54 ct 656 -46 659 -40 663 -35 ct 667 -29 672 -25 677 -22 ct
+683 -19 690 -18 699 -18 ct 711 -18 721 -20 728 -25 ct 735 -30 740 -36 743 -44 ct
+767 -37 l  765 -32 763 -27 760 -23 ct 757 -18 752 -14 747 -10 ct 742 -6 735 -3 727 -1 ct
+719 2 710 3 699 3 ct 674 3 655 -4 642 -19 ct 629 -34 623 -56 623 -85 ct 623 -101 624 -114 628 -125 ct
+632 -136 638 -145 645 -152 ct 651 -158 659 -163 668 -166 ct 678 -169 687 -171 698 -171 ct
+712 -171 724 -169 733 -164 ct 742 -160 750 -153 756 -145 ct 762 -137 766 -128 768 -117 ct
+771 -106 772 -94 772 -82 ct 772 -78 l  652 -78 l  p
+743 -99 m  741 -117 737 -130 729 -138 ct 722 -146 711 -150 697 -150 ct 693 -150 688 -150 683 -148 ct
+677 -147 673 -144 668 -140 ct 664 -136 660 -131 657 -125 ct 654 -118 653 -110 652 -99 ct
+743 -99 l  p ef
+815 0 m  815 -230 l  843 -230 l  843 0 l  815 0 l  p ef
+916 -78 m  916 -69 917 -61 919 -54 ct 920 -46 923 -40 927 -35 ct 931 -29 936 -25 941 -22 ct
+947 -19 954 -18 963 -18 ct 975 -18 985 -20 992 -25 ct 999 -30 1004 -36 1007 -44 ct
+1031 -37 l  1029 -32 1027 -27 1024 -23 ct 1021 -18 1016 -14 1011 -10 ct 1006 -6 999 -3 991 -1 ct
+983 2 974 3 963 3 ct 938 3 919 -4 906 -19 ct 893 -34 887 -56 887 -85 ct 887 -101 888 -114 892 -125 ct
+896 -136 902 -145 909 -152 ct 915 -158 923 -163 932 -166 ct 942 -169 951 -171 962 -171 ct
+976 -171 988 -169 997 -164 ct 1006 -160 1014 -153 1020 -145 ct 1026 -137 1030 -128 1032 -117 ct
+1035 -106 1036 -94 1036 -82 ct 1036 -78 l  916 -78 l  p
+1007 -99 m  1005 -117 1001 -130 993 -138 ct 986 -146 975 -150 961 -150 ct 957 -150 952 -150 947 -148 ct
+941 -147 937 -144 932 -140 ct 928 -136 924 -131 921 -125 ct 918 -118 917 -110 916 -99 ct
+1007 -99 l  p ef
+1186 0 m  1186 -106 l  1186 -115 1186 -121 1184 -127 ct 1183 -132 1181 -137 1178 -140 ct
+1176 -144 1172 -146 1168 -147 ct 1163 -149 1158 -149 1151 -149 ct 1145 -149 1139 -148 1134 -146 ct
+1128 -144 1124 -140 1120 -136 ct 1116 -131 1113 -126 1111 -120 ct 1109 -113 1108 -106 1108 -97 ct
+1108 0 l  1080 0 l  1080 -132 l  1080 -136 1080 -139 1080 -143 ct 1080 -147 1080 -151 1080 -154 ct
+1080 -158 1080 -161 1079 -163 ct 1079 -166 1079 -167 1079 -168 ct 1106 -168 l
+1106 -167 1106 -166 1106 -164 ct 1106 -161 1106 -159 1106 -156 ct 1106 -153 1107 -150 1107 -147 ct
+1107 -144 1107 -141 1107 -139 ct 1107 -139 l  1110 -144 1113 -148 1116 -152 ct
+1119 -156 1123 -160 1127 -162 ct 1132 -165 1136 -167 1142 -169 ct 1147 -170 1154 -171 1161 -171 ct
+1170 -171 1178 -170 1185 -168 ct 1192 -165 1197 -162 1202 -157 ct 1206 -152 1209 -146 1211 -139 ct
+1213 -131 1214 -122 1214 -112 ct 1214 0 l  1186 0 l  p ef
+1329 66 m  1319 66 1311 65 1303 63 ct 1296 61 1290 58 1284 55 ct 1279 51 1275 46 1271 41 ct
+1268 36 1266 31 1264 24 ct 1292 20 l  1294 28 1298 34 1305 38 ct 1311 43 1320 45 1330 45 ct
+1336 45 1342 44 1347 42 ct 1352 40 1357 37 1360 34 ct 1364 30 1367 25 1369 18 ct
+1371 12 1372 5 1372 -4 ct 1372 -31 l  1371 -31 l  1369 -27 1367 -23 1364 -19 ct
+1361 -15 1357 -12 1352 -9 ct 1348 -6 1343 -4 1337 -2 ct 1331 0 1325 1 1317 1 ct
+1307 1 1297 -1 1290 -4 ct 1282 -8 1276 -13 1271 -20 ct 1266 -28 1263 -36 1261 -47 ct
+1258 -58 1257 -70 1257 -84 ct 1257 -97 1258 -109 1261 -120 ct 1263 -131 1267 -140 1272 -148 ct
+1277 -155 1283 -161 1291 -165 ct 1299 -169 1309 -171 1320 -171 ct 1332 -171 1343 -168 1351 -163 ct
+1360 -157 1367 -149 1372 -139 ct 1372 -139 l  1372 -142 1372 -145 1372 -148 ct
+1372 -151 1372 -154 1373 -157 ct 1373 -160 1373 -163 1373 -165 ct 1373 -167 1374 -168 1374 -168 ct
+1400 -168 l  1400 -167 1400 -166 1400 -163 ct 1400 -161 1400 -159 1400 -155 ct
+1400 -152 1400 -149 1400 -145 ct 1399 -141 1399 -137 1399 -133 ct 1399 -5 l
+1399 19 1394 36 1382 48 ct 1371 60 1353 66 1329 66 ct p
+1372 -84 m  1372 -96 1370 -106 1368 -114 ct 1365 -123 1362 -129 1358 -135 ct
+1354 -140 1349 -144 1344 -146 ct 1338 -149 1333 -150 1327 -150 ct 1320 -150 1314 -149 1309 -146 ct
+1304 -144 1299 -140 1296 -135 ct 1293 -129 1290 -122 1289 -114 ct 1287 -106 1286 -96 1286 -84 ct
+1286 -72 1287 -62 1289 -54 ct 1290 -45 1293 -39 1296 -34 ct 1299 -29 1304 -25 1309 -23 ct
+1314 -21 1320 -20 1327 -20 ct 1332 -20 1338 -21 1343 -23 ct 1348 -26 1353 -29 1358 -35 ct
+1362 -40 1365 -46 1368 -55 ct 1370 -63 1372 -73 1372 -84 ct p ef
+1515 -2 m  1511 -1 1506 0 1502 1 ct 1498 2 1493 2 1487 2 ct 1464 2 1453 -11 1453 -36 ct
+1453 -148 l  1434 -148 l  1434 -168 l  1454 -168 l  1463 -206 l  1481 -206 l
+1481 -168 l  1512 -168 l  1512 -148 l  1481 -148 l  1481 -42 l  1481 -34 1482 -28 1485 -25 ct
+1488 -22 1492 -20 1499 -20 ct 1502 -20 1504 -20 1507 -21 ct 1509 -21 1512 -22 1515 -22 ct
+1515 -2 l  p ef
+1557 -139 m  1560 -144 1564 -149 1567 -153 ct 1571 -157 1575 -161 1579 -163 ct
+1584 -166 1588 -168 1594 -169 ct 1599 -170 1605 -171 1611 -171 ct 1622 -171 1631 -169 1637 -166 ct
+1644 -163 1650 -159 1654 -154 ct 1658 -149 1660 -143 1662 -135 ct 1663 -128 1664 -120 1664 -111 ct
+1664 0 l  1636 0 l  1636 -106 l  1636 -113 1636 -119 1635 -125 ct 1634 -130 1632 -135 1630 -138 ct
+1627 -142 1624 -144 1619 -146 ct 1615 -148 1609 -149 1601 -149 ct 1595 -149 1589 -148 1584 -145 ct
+1578 -143 1574 -140 1570 -135 ct 1566 -131 1563 -126 1561 -120 ct 1559 -113 1558 -106 1558 -99 ct
+1558 0 l  1530 0 l  1530 -230 l  1558 -230 l  1558 -170 l  1558 -167 1558 -163 1558 -160 ct
+1558 -156 1558 -153 1557 -150 ct 1557 -147 1557 -145 1557 -143 ct 1557 -141 1557 -140 1557 -139 ct
+1557 -139 l  p ef
+1985 0 m  1985 -146 l  1985 -151 1985 -157 1985 -162 ct 1985 -167 1986 -173 1986 -177 ct
+1986 -182 1986 -187 1987 -192 ct 1985 -187 1984 -182 1982 -177 ct 1981 -172 1979 -168 1978 -163 ct
+1976 -158 1974 -153 1973 -149 ct 1916 0 l  1896 0 l  1838 -149 l  1838 -151 1837 -152 1836 -154 ct
+1836 -156 1835 -159 1834 -161 ct 1833 -163 1833 -166 1832 -168 ct 1831 -171 1830 -173 1830 -175 ct
+1828 -181 1826 -187 1824 -192 ct 1825 -187 1825 -181 1825 -175 ct 1825 -170 1825 -165 1825 -160 ct
+1825 -155 1825 -150 1825 -146 ct 1825 0 l  1799 0 l  1799 -219 l  1838 -219 l
+1896 -67 l  1897 -65 1898 -62 1899 -59 ct 1900 -56 1901 -52 1902 -49 ct 1903 -46 1904 -42 1904 -39 ct
+1905 -36 1906 -34 1906 -32 ct 1906 -34 1907 -36 1908 -39 ct 1909 -43 1910 -46 1911 -49 ct
+1912 -53 1913 -56 1914 -59 ct 1915 -62 1916 -65 1917 -67 ct 1974 -219 l  2012 -219 l
+2012 0 l  1985 0 l  p ef
+2159 -104 m  2111 -202 l  2064 -104 l  2039 -104 l  2096 -218 l  2127 -218 l
+2185 -104 l  2159 -104 l  p ef
+2359 -60 m  2359 -50 2357 -41 2354 -34 ct 2351 -26 2346 -19 2340 -14 ct 2333 -8 2326 -4 2316 -1 ct
+2307 2 2297 3 2285 3 ct 2271 3 2260 1 2250 -2 ct 2241 -5 2234 -10 2228 -15 ct 2222 -21 2217 -27 2214 -34 ct
+2211 -41 2209 -49 2208 -56 ct 2237 -59 l  2238 -53 2239 -48 2242 -43 ct 2244 -38 2247 -34 2251 -31 ct
+2254 -27 2259 -25 2265 -23 ct 2270 -21 2277 -20 2285 -20 ct 2299 -20 2310 -24 2318 -30 ct
+2326 -37 2330 -48 2330 -61 ct 2330 -69 2328 -76 2324 -81 ct 2321 -86 2316 -89 2311 -92 ct
+2306 -95 2300 -97 2294 -98 ct 2287 -99 2282 -99 2276 -99 ct 2261 -99 l  2261 -123 l
+2276 -123 l  2281 -123 2287 -124 2292 -125 ct 2298 -126 2303 -128 2308 -131 ct
+2313 -134 2316 -137 2320 -142 ct 2323 -147 2324 -153 2324 -161 ct 2324 -173 2321 -182 2314 -189 ct
+2307 -196 2297 -199 2283 -199 ct 2271 -199 2261 -196 2253 -190 ct 2246 -183 2241 -174 2240 -163 ct
+2212 -165 l  2213 -175 2216 -183 2220 -190 ct 2224 -197 2229 -203 2236 -208 ct
+2242 -213 2249 -216 2257 -219 ct 2266 -221 2274 -222 2283 -222 ct 2296 -222 2306 -220 2315 -217 ct
+2324 -214 2331 -210 2337 -205 ct 2342 -200 2346 -194 2349 -187 ct 2352 -179 2353 -172 2353 -164 ct
+2353 -158 2352 -152 2350 -146 ct 2348 -140 2346 -135 2342 -131 ct 2338 -126 2334 -123 2328 -119 ct
+2322 -116 2315 -114 2307 -112 ct 2307 -111 l  2316 -110 2323 -109 2330 -105 ct
+2337 -102 2342 -99 2346 -94 ct 2350 -90 2354 -84 2356 -79 ct 2358 -73 2359 -67 2359 -60 ct
+p ef
+2481 -82 m  2481 -97 2482 -110 2484 -124 ct 2486 -137 2490 -149 2494 -161 ct
+2499 -174 2505 -185 2512 -197 ct 2519 -208 2528 -219 2538 -230 ct 2565 -230 l
+2555 -219 2547 -208 2540 -197 ct 2533 -185 2527 -173 2522 -161 ct 2518 -149 2514 -136 2512 -123 ct
+2510 -110 2509 -96 2509 -82 ct 2509 -68 2510 -54 2512 -41 ct 2514 -28 2518 -15 2522 -3 ct
+2527 9 2533 21 2540 33 ct 2547 44 2555 55 2565 66 ct 2538 66 l  2528 55 2519 44 2512 33 ct
+2505 21 2499 10 2494 -3 ct 2490 -15 2486 -27 2484 -40 ct 2482 -53 2481 -67 2481 -82 ct
+2481 -82 l  p ef
+2694 0 m  2694 -106 l  2694 -115 2694 -121 2692 -127 ct 2691 -132 2689 -137 2686 -140 ct
+2684 -144 2680 -146 2676 -147 ct 2671 -149 2666 -149 2659 -149 ct 2653 -149 2647 -148 2642 -146 ct
+2636 -144 2632 -140 2628 -136 ct 2624 -131 2621 -126 2619 -120 ct 2617 -113 2616 -106 2616 -97 ct
+2616 0 l  2588 0 l  2588 -132 l  2588 -136 2588 -139 2588 -143 ct 2588 -147 2588 -151 2588 -154 ct
+2588 -158 2588 -161 2587 -163 ct 2587 -166 2587 -167 2587 -168 ct 2614 -168 l
+2614 -167 2614 -166 2614 -164 ct 2614 -161 2614 -159 2614 -156 ct 2614 -153 2615 -150 2615 -147 ct
+2615 -144 2615 -141 2615 -139 ct 2615 -139 l  2618 -144 2621 -148 2624 -152 ct
+2627 -156 2631 -160 2635 -162 ct 2640 -165 2644 -167 2650 -169 ct 2655 -170 2662 -171 2669 -171 ct
+2678 -171 2686 -170 2693 -168 ct 2700 -165 2705 -162 2710 -157 ct 2714 -152 2717 -146 2719 -139 ct
+2721 -131 2722 -122 2722 -112 ct 2722 0 l  2694 0 l  p ef
+2871 0 m  2871 -106 l  2871 -115 2871 -121 2870 -127 ct 2869 -132 2867 -137 2864 -140 ct
+2862 -144 2859 -146 2855 -147 ct 2851 -149 2846 -149 2841 -149 ct 2835 -149 2829 -148 2825 -146 ct
+2820 -144 2816 -140 2812 -136 ct 2809 -131 2806 -126 2805 -120 ct 2803 -113 2802 -106 2802 -97 ct
+2802 0 l  2774 0 l  2774 -132 l  2774 -136 2774 -139 2774 -143 ct 2774 -147 2774 -151 2774 -154 ct
+2774 -158 2774 -161 2773 -163 ct 2773 -166 2773 -167 2773 -168 ct 2800 -168 l
+2800 -167 2800 -166 2800 -164 ct 2800 -161 2800 -159 2800 -156 ct 2800 -153 2801 -150 2801 -147 ct
+2801 -144 2801 -141 2801 -139 ct 2801 -139 l  2804 -144 2806 -148 2809 -152 ct
+2812 -156 2816 -160 2819 -162 ct 2823 -165 2828 -167 2833 -169 ct 2838 -170 2844 -171 2850 -171 ct
+2863 -171 2873 -168 2880 -163 ct 2888 -158 2893 -150 2896 -139 ct 2896 -139 l
+2899 -144 2902 -148 2905 -152 ct 2908 -156 2912 -160 2916 -162 ct 2920 -165 2924 -167 2930 -169 ct
+2935 -170 2941 -171 2947 -171 ct 2956 -171 2963 -170 2969 -168 ct 2975 -165 2981 -162 2984 -157 ct
+2988 -152 2991 -146 2993 -139 ct 2995 -131 2996 -122 2996 -112 ct 2996 0 l  2968 0 l
+2968 -106 l  2968 -115 2968 -121 2967 -127 ct 2966 -132 2964 -137 2962 -140 ct
+2959 -144 2956 -146 2952 -147 ct 2948 -149 2943 -149 2938 -149 ct 2932 -149 2926 -148 2922 -146 ct
+2917 -144 2913 -141 2909 -136 ct 2906 -132 2903 -126 2902 -120 ct 2900 -113 2899 -106 2899 -97 ct
+2899 0 l  2871 0 l  p ef
+3102 -82 m  3102 -67 3101 -53 3099 -40 ct 3097 -27 3093 -15 3089 -3 ct 3084 10 3078 21 3071 33 ct
+3064 44 3055 55 3045 66 ct 3018 66 l  3028 55 3036 44 3043 33 ct 3050 21 3056 9 3061 -3 ct
+3065 -15 3069 -28 3071 -41 ct 3073 -54 3074 -68 3074 -82 ct 3074 -96 3073 -110 3071 -123 ct
+3069 -136 3065 -149 3061 -161 ct 3056 -173 3050 -185 3043 -197 ct 3036 -208 3028 -219 3018 -230 ct
+3045 -230 l  3055 -219 3064 -208 3071 -197 ct 3078 -185 3084 -174 3089 -161 ct
+3093 -149 3097 -137 3099 -124 ct 3101 -110 3102 -97 3102 -82 ct 3102 -82 l  p ef
+pom
+pum
+12225 25339 t
+90.0 r 181 0 m  124 -91 l  56 -91 l  56 0 l  26 0 l  26 -219 l  129 -219 l
+141 -219 152 -217 162 -214 ct 172 -212 180 -208 186 -202 ct 193 -197 198 -190 201 -182 ct
+205 -175 206 -166 206 -156 ct 206 -149 205 -143 203 -136 ct 201 -129 198 -123 194 -117 ct
+189 -112 184 -107 177 -103 ct 170 -99 162 -96 153 -94 ct 215 0 l  181 0 l  p
+176 -156 m  176 -163 175 -168 173 -173 ct 171 -178 167 -182 163 -185 ct 159 -189 153 -191 147 -193 ct
+141 -194 134 -195 126 -195 ct 56 -195 l  56 -114 l  127 -114 l  136 -114 143 -115 149 -118 ct
+156 -120 161 -123 165 -126 ct 169 -130 172 -134 174 -140 ct 175 -145 176 -150 176 -156 ct
+p ef
+281 -78 m  281 -69 282 -61 284 -54 ct 285 -46 288 -40 292 -35 ct 296 -29 301 -25 306 -22 ct
+312 -19 319 -18 328 -18 ct 340 -18 350 -20 357 -25 ct 364 -30 369 -36 372 -44 ct
+396 -37 l  394 -32 392 -27 389 -23 ct 386 -18 381 -14 376 -10 ct 371 -6 364 -3 356 -1 ct
+348 2 339 3 328 3 ct 303 3 284 -4 271 -19 ct 258 -34 252 -56 252 -85 ct 252 -101 253 -114 257 -125 ct
+261 -136 267 -145 274 -152 ct 280 -158 288 -163 297 -166 ct 307 -169 316 -171 327 -171 ct
+341 -171 353 -169 362 -164 ct 371 -160 379 -153 385 -145 ct 391 -137 395 -128 397 -117 ct
+400 -106 401 -94 401 -82 ct 401 -78 l  281 -78 l  p
+372 -99 m  370 -117 366 -130 358 -138 ct 351 -146 340 -150 326 -150 ct 322 -150 317 -150 312 -148 ct
+306 -147 302 -144 297 -140 ct 293 -136 289 -131 286 -125 ct 283 -118 282 -110 281 -99 ct
+372 -99 l  p ef
+479 -148 m  479 0 l  451 0 l  451 -148 l  428 -148 l  428 -168 l  451 -168 l
+451 -187 l  451 -193 452 -199 453 -204 ct 454 -209 456 -214 459 -218 ct 462 -221 466 -224 472 -227 ct
+477 -229 484 -230 492 -230 ct 495 -230 499 -230 502 -230 ct 506 -229 509 -229 512 -228 ct
+512 -207 l  510 -207 508 -207 506 -208 ct 503 -208 501 -208 499 -208 ct 495 -208 492 -208 489 -206 ct
+487 -205 485 -204 483 -202 ct 482 -199 480 -197 480 -194 ct 479 -191 479 -187 479 -183 ct
+479 -168 l  512 -168 l  512 -148 l  479 -148 l  p ef
+524 0 m  524 -230 l  552 -230 l  552 0 l  524 0 l  p ef
+625 -78 m  625 -69 626 -61 628 -54 ct 629 -46 632 -40 636 -35 ct 640 -29 645 -25 650 -22 ct
+656 -19 663 -18 672 -18 ct 684 -18 694 -20 701 -25 ct 708 -30 713 -36 716 -44 ct
+740 -37 l  738 -32 736 -27 733 -23 ct 730 -18 725 -14 720 -10 ct 715 -6 708 -3 700 -1 ct
+692 2 683 3 672 3 ct 647 3 628 -4 615 -19 ct 602 -34 596 -56 596 -85 ct 596 -101 597 -114 601 -125 ct
+605 -136 611 -145 618 -152 ct 624 -158 632 -163 641 -166 ct 651 -169 660 -171 671 -171 ct
+685 -171 697 -169 706 -164 ct 715 -160 723 -153 729 -145 ct 735 -137 739 -128 741 -117 ct
+744 -106 745 -94 745 -82 ct 745 -78 l  625 -78 l  p
+716 -99 m  714 -117 710 -130 702 -138 ct 695 -146 684 -150 670 -150 ct 666 -150 661 -150 656 -148 ct
+650 -147 646 -144 641 -140 ct 637 -136 633 -131 630 -125 ct 627 -118 626 -110 625 -99 ct
+716 -99 l  p ef
+810 -85 m  810 -75 810 -66 812 -58 ct 813 -50 816 -43 819 -37 ct 822 -32 827 -27 832 -24 ct
+837 -21 844 -19 852 -19 ct 862 -19 870 -22 877 -27 ct 884 -32 888 -40 889 -51 ct
+918 -51 l  917 -44 915 -37 912 -31 ct 908 -24 904 -18 899 -13 ct 894 -8 887 -4 879 -1 ct
+872 1 863 3 853 3 ct 840 3 829 1 819 -4 ct 810 -8 803 -14 797 -22 ct 791 -30 787 -39 784 -50 ct
+782 -60 781 -72 781 -84 ct 781 -95 781 -105 783 -114 ct 785 -123 788 -130 791 -137 ct
+795 -143 798 -149 803 -153 ct 808 -157 813 -161 818 -163 ct 823 -166 829 -168 835 -169 ct
+841 -170 847 -171 853 -171 ct 862 -171 870 -170 878 -167 ct 885 -165 891 -161 897 -157 ct
+902 -152 906 -147 910 -141 ct 913 -135 915 -128 917 -121 ct 888 -119 l  887 -128 883 -135 877 -141 ct
+871 -146 863 -149 852 -149 ct 844 -149 837 -148 832 -145 ct 827 -143 822 -139 819 -133 ct
+816 -128 813 -121 812 -113 ct 810 -105 810 -96 810 -85 ct p ef
+1012 -2 m  1008 -1 1003 0 999 1 ct 995 2 990 2 984 2 ct 961 2 950 -11 950 -36 ct
+950 -148 l  931 -148 l  931 -168 l  951 -168 l  960 -206 l  978 -206 l
+978 -168 l  1009 -168 l  1009 -148 l  978 -148 l  978 -42 l  978 -34 979 -28 982 -25 ct
+985 -22 989 -20 996 -20 ct 999 -20 1001 -20 1004 -21 ct 1006 -21 1009 -22 1012 -22 ct
+1012 -2 l  p ef
+1069 3 m  1052 3 1040 -1 1031 -10 ct 1023 -19 1019 -32 1019 -47 ct 1019 -58 1021 -67 1025 -75 ct
+1029 -82 1034 -87 1041 -91 ct 1048 -95 1056 -98 1064 -100 ct 1073 -101 1082 -102 1091 -102 ct
+1129 -102 l  1129 -111 l  1129 -118 1128 -124 1127 -129 ct 1125 -134 1123 -138 1120 -141 ct
+1117 -144 1113 -146 1109 -148 ct 1104 -149 1099 -150 1093 -150 ct 1087 -150 1082 -149 1078 -149 ct
+1074 -148 1070 -146 1067 -144 ct 1064 -142 1061 -140 1059 -136 ct 1057 -133 1056 -128 1055 -123 ct
+1026 -126 l  1027 -132 1029 -138 1032 -144 ct 1035 -149 1039 -154 1044 -158 ct
+1050 -162 1056 -165 1064 -168 ct 1072 -170 1082 -171 1093 -171 ct 1114 -171 1130 -166 1141 -156 ct
+1152 -147 1157 -133 1157 -114 ct 1157 -42 l  1157 -34 1158 -28 1160 -23 ct 1162 -19 1167 -17 1173 -17 ct
+1174 -17 1176 -17 1177 -17 ct 1179 -18 1180 -18 1182 -18 ct 1182 -1 l  1178 0 1175 1 1171 1 ct
+1168 2 1164 2 1160 2 ct 1155 2 1150 1 1147 0 ct 1143 -2 1140 -4 1137 -7 ct 1135 -10 1133 -13 1132 -17 ct
+1131 -22 1130 -27 1130 -32 ct 1129 -32 l  1126 -27 1122 -22 1119 -18 ct 1115 -13 1111 -10 1106 -7 ct
+1102 -4 1096 -1 1090 1 ct 1084 2 1077 3 1069 3 ct p
+1076 -18 m  1085 -18 1092 -20 1099 -23 ct 1106 -26 1111 -30 1116 -35 ct 1120 -40 1123 -46 1125 -52 ct
+1128 -58 1129 -63 1129 -69 ct 1129 -82 l  1098 -82 l  1091 -82 1085 -82 1079 -81 ct
+1073 -80 1067 -78 1062 -76 ct 1058 -73 1054 -70 1051 -65 ct 1049 -60 1047 -54 1047 -47 ct
+1047 -37 1050 -30 1055 -25 ct 1060 -20 1067 -18 1076 -18 ct p ef
+1319 0 m  1319 -106 l  1319 -115 1319 -121 1317 -127 ct 1316 -132 1314 -137 1311 -140 ct
+1309 -144 1305 -146 1301 -147 ct 1296 -149 1291 -149 1284 -149 ct 1278 -149 1272 -148 1267 -146 ct
+1261 -144 1257 -140 1253 -136 ct 1249 -131 1246 -126 1244 -120 ct 1242 -113 1241 -106 1241 -97 ct
+1241 0 l  1213 0 l  1213 -132 l  1213 -136 1213 -139 1213 -143 ct 1213 -147 1213 -151 1213 -154 ct
+1213 -158 1213 -161 1212 -163 ct 1212 -166 1212 -167 1212 -168 ct 1239 -168 l
+1239 -167 1239 -166 1239 -164 ct 1239 -161 1239 -159 1239 -156 ct 1239 -153 1240 -150 1240 -147 ct
+1240 -144 1240 -141 1240 -139 ct 1240 -139 l  1243 -144 1246 -148 1249 -152 ct
+1252 -156 1256 -160 1260 -162 ct 1265 -165 1269 -167 1275 -169 ct 1280 -170 1287 -171 1294 -171 ct
+1303 -171 1311 -170 1318 -168 ct 1325 -165 1330 -162 1335 -157 ct 1339 -152 1342 -146 1344 -139 ct
+1346 -131 1347 -122 1347 -112 ct 1347 0 l  1319 0 l  p ef
+1419 -85 m  1419 -75 1419 -66 1421 -58 ct 1422 -50 1425 -43 1428 -37 ct 1431 -32 1436 -27 1441 -24 ct
+1446 -21 1453 -19 1461 -19 ct 1471 -19 1479 -22 1486 -27 ct 1493 -32 1497 -40 1498 -51 ct
+1527 -51 l  1526 -44 1524 -37 1521 -31 ct 1517 -24 1513 -18 1508 -13 ct 1503 -8 1496 -4 1488 -1 ct
+1481 1 1472 3 1462 3 ct 1449 3 1438 1 1428 -4 ct 1419 -8 1412 -14 1406 -22 ct 1400 -30 1396 -39 1393 -50 ct
+1391 -60 1390 -72 1390 -84 ct 1390 -95 1390 -105 1392 -114 ct 1394 -123 1397 -130 1400 -137 ct
+1404 -143 1407 -149 1412 -153 ct 1417 -157 1422 -161 1427 -163 ct 1432 -166 1438 -168 1444 -169 ct
+1450 -170 1456 -171 1462 -171 ct 1471 -171 1479 -170 1487 -167 ct 1494 -165 1500 -161 1506 -157 ct
+1511 -152 1515 -147 1519 -141 ct 1522 -135 1524 -128 1526 -121 ct 1497 -119 l
+1496 -128 1492 -135 1486 -141 ct 1480 -146 1472 -149 1461 -149 ct 1453 -149 1446 -148 1441 -145 ct
+1436 -143 1431 -139 1428 -133 ct 1425 -128 1422 -121 1421 -113 ct 1419 -105 1419 -96 1419 -85 ct
+p ef
+1578 -78 m  1578 -69 1579 -61 1581 -54 ct 1582 -46 1585 -40 1589 -35 ct 1593 -29 1598 -25 1603 -22 ct
+1609 -19 1616 -18 1625 -18 ct 1637 -18 1647 -20 1654 -25 ct 1661 -30 1666 -36 1669 -44 ct
+1693 -37 l  1691 -32 1689 -27 1686 -23 ct 1683 -18 1678 -14 1673 -10 ct 1668 -6 1661 -3 1653 -1 ct
+1645 2 1636 3 1625 3 ct 1600 3 1581 -4 1568 -19 ct 1555 -34 1549 -56 1549 -85 ct
+1549 -101 1550 -114 1554 -125 ct 1558 -136 1564 -145 1571 -152 ct 1577 -158 1585 -163 1594 -166 ct
+1604 -169 1613 -171 1624 -171 ct 1638 -171 1650 -169 1659 -164 ct 1668 -160 1676 -153 1682 -145 ct
+1688 -137 1692 -128 1694 -117 ct 1697 -106 1698 -94 1698 -82 ct 1698 -78 l  1578 -78 l
+p
+1669 -99 m  1667 -117 1663 -130 1655 -138 ct 1648 -146 1637 -150 1623 -150 ct
+1619 -150 1614 -150 1609 -148 ct 1603 -147 1599 -144 1594 -140 ct 1590 -136 1586 -131 1583 -125 ct
+1580 -118 1579 -110 1578 -99 ct 1669 -99 l  p ef
+pom
+0 9000 t
+pom
+count op_count sub {pop} repeat countdictstack dict_count sub {end} repeat b4_inc_state restore
+%%PageTrailer
+%%Trailer
+%%EOF
Modified: grass-promo/grassposter/2014_EGU_M3_Landscape/poster.tex
--- grass-promo/grassposter/2014_EGU_M3_Landscape/poster.tex	2014-04-20 13:28:05 UTC (rev 59836)
+++ grass-promo/grassposter/2014_EGU_M3_Landscape/poster.tex	2014-04-20 15:50:03 UTC (rev 59837)
@@ -84,6 +84,7 @@
 Snape et al. (2013) & LPSC Abstracts 44:1044.\\{}
 Weider et al. (2010) & Icarus, 209, 323-336.\\{}
 Wilcox et al. (2005) & J. Geophys. Res. 110(E11):2156-2202.\\{}
+Zhang et al. (2013) & LPSC Abstracts 44:374.\\{}
 \end{tabular}
 \end{flushleft}
 \smallskip
@@ -129,61 +130,69 @@
 \begin{center}
  \includegraphics[width=0.75\textwidth]{./images/Clementine}
  \newline
- Figure 1: Clementine RGB153, segmentation and FeO (wt\%) per segmentation class.
+ Figure 1: Clementine RGB153 (top), segmentation (middle) and FeO (wt\%) per segmentation class (bottom).
 \end{center}
 \startthirdcolumn
-\blocknode{$M^3$ data analysis}{
-nn
-\newline
+\blocknode{M$^3$ Signal at Apollo 12 landing site}{
+\smallskip
 \begin{center}
- \includegraphics[width=0.5\textwidth]{./images/M3FEOlarge}
- \newline
- Figure 3: FeO
-\end{center}
+\begin{tabular}{ c p{0.45\textwidth}}
+ \raisebox{-1.2\totalheight}{\includegraphics[width=0.5\textwidth]{./images/M3_A12_craters_signal}}\newline
+ %\caption{Spectral signature of $M^3$ from four craters}
+ \label{fig:specsignature4craters}
+ \noindent Chandrayaan $M^3$ data was  downloaded from PDS \url{http://pds-imaging.jpl.nasa.gov/}{pds-imaging.jpl.nasa.gov}. The tile \textit{M3G20090111T013904\_V01\_RFL.IMG} was imported in GRASS GIS, resulting in 85 bands. The spectrum for four craters where extracted in the Figure \ref{fig:specsignature4craters}. Bench and Surveyor are both together in the lower reflectance curves. On the higher side, Sharp and Middle Crescent are consistently above the two others. This higher broadband Albedo is increasing towards the West, where one of the ray is clearly drawn (Oblique white strip in the middle of The Clementine upper map. Compared to the spectral data from Figure ~\ref{fig:specsignatureASTERlib} the reflectance is overall lower and the obvious shape differences are there.
+ \end{tabular}
+ \end{center}
+ \begin{flushleft}
+ \hspace{22mm}
+ \includegraphics[width=0.45\textwidth]{./images/Apollo12_signatures}
+ %\caption{Spectral signature from Apollo 12 (ASTER library)}
+ \label{fig:specsignatureASTERlib}
+ \end{flushleft}
 \startfourthcolumn
-\blocknode{Segmentation of PCA elements}{
-GRASS GIS segmentation of the PCA of the full temporal archive of MODIS EVI.
-\newline
+\blocknode{M$^3$ derived FeO from standard equations}{
+\noindent The wt\%FeO equations have a large range of results when used with $M^3$ data:
+\begin{center}
+\begin{tabular}{ l r r}
+\hline
+Authors & Bench & Surveyor\\
+\hline
+Lucey et al. (2000) & -26.64 & -23.32 \\
+Lawrence et al. (2002) & 4.72 & 6.38 \\
+Wilcox et al. (2005) & 22.28 & 21.82 \\
+Zhang et al. (2013) & 19.74 & 19.49 \\
+\hline
+\end{tabular}
+\end{center}
+\bigskip
-A summary of the code needed to reach this point of analysis is here.\newline
-\hrule
-{\footnotesize \fontfamily{pcr}\selectfont i.group \textcolor{blue}{group}=pca\_group \textcolor{blue}{input}=\$(g.mlist \textcolor{blue}{type}=rast \textcolor{blue}{pattern}=*h28v07*EVI)\newline
-i.pca \textcolor{blue}{input}=pca\_group \textcolor{blue}{output\_prefix}=pca\_ \textcolor{blue}{percent}=99 --o\newline
-\#Here, run {\it i.group} interactively to add the PCA output files you want to use for segmentation\newline
-i.segment \textcolor{blue}{group}=seg\_group \textcolor{blue}{output}=seg \textcolor{blue}{threshold}=0.9 \textcolor{blue}{memory}=3000 \textcolor{blue}{iterations}=100 --o\newline}
-\hrule
-\blocknode{Temporal PCA-based classification}{
-Classes found to follow one crop per year
-\newline
 \begin{center}
- \includegraphics[width=0.55\textwidth]{./images/startup_banner_isis}\newline
- \newline
- Figure 4: Single-crop classes from PCA.
+ \raisebox{-0.8\totalheight}{\includegraphics[width=0.5\textwidth]{./code/code1}}
+ %\caption{Testing FeO algorithms.}
+ \label{fig:FeOtesting}
+ \noindent It is known that the local range of FeO is below 10wt\% from UVVIS data (see Figure on the lower left), only the Lawrence et al. (2002) equation is giving an appropriate range. Lucey et al. (2000) equation fails because of the offset of uvvis4/uvvis2(=1.15 vs offset = 1.19) and the one for uvvis2(=0.05 vs offset = 0.08), as both of the parts are negative thus giving a positive division output, their interplay should bring a negative number for the arctangent negative sign to compensate. This clearly does not happen with $M^3$ data in the Bench and Surveyor craters, the results from the arctangent being positive, and the sign change brings the main part of the equation to a negative, further reduced by the negative final offset.\newline
+\end{tabular}
 \end{center}
+\noindent Upon using the  Lawrence et al. (2002) equation, it turned out that though the wt\%FeO range was satisfactory for few crater points, the rate of change was actually reverse to the expected one, reducing to null towards the South of the landing site and increasing towards the North.\newline
+\noindent The equation from Zhang et al. (2013) is giving an appropriate rate of change, however, the local values are too large compared to the Clementine derived FeO values.\newline
 \end{tikzpicture}
 \end{document}
