[GRASS-SVN] r59838 - grass/branches/releasebranch_7_0/raster/r.resamp.rst
Sun Apr 20 10:35:55 PDT 2014
Author: neteler
Date: 2014-04-20 10:35:55 -0700 (Sun, 20 Apr 2014)
New Revision: 59838
   grass/branches/releasebranch_7_0/raster/r.resamp.rst/r.resamp.rst.html
r.resamp.rst manual: example added
Modified: grass/branches/releasebranch_7_0/raster/r.resamp.rst/r.resamp.rst.html
--- grass/branches/releasebranch_7_0/raster/r.resamp.rst/r.resamp.rst.html	2014-04-20 15:50:03 UTC (rev 59837)
+++ grass/branches/releasebranch_7_0/raster/r.resamp.rst/r.resamp.rst.html	2014-04-20 17:35:55 UTC (rev 59838)
@@ -94,6 +94,24 @@
 mask out the data points; if this is desirable, it must be done outside
 <i>r.resamp.rst</i> before processing.
+<h2>EXAMPLE</h2>
+Resampling the Spearfish 30m resolution elevation model to 15m:
+<div class="code"><pre>
+# set computation region to original map (30m)
+g.region rast=elevation.dem -p
+# resample to 15m
+r.resamp.rst input=elevation.dem ew_res=15 ns_res=15 elev=elev15
+# set computation region to resulting map
+g.region rast=elev15 -p
+# verify
+r.univar elev15 -g
+</pre></div>
 <h2>SEE ALSO</h2>
 <a href="g.region.html">g.region</a>,
