[GRASS-SVN] r59878 - grass-addons/grass7/raster/r.basin
    svn_grass at osgeo.org
    Mon Apr 21 06:40:59 PDT 2014
Author: madi
Date: 2014-04-21 06:40:59 -0700 (Mon, 21 Apr 2014)
New Revision: 59878
   grass-addons/grass7/raster/r.basin/r.basin.py
fixed error about characters not allowed in columns table
Modified: grass-addons/grass7/raster/r.basin/r.basin.py
--- grass-addons/grass7/raster/r.basin/r.basin.py	2014-04-21 12:36:50 UTC (rev 59877)
+++ grass-addons/grass7/raster/r.basin/r.basin.py	2014-04-21 13:40:59 UTC (rev 59878)
@@ -719,38 +719,38 @@
     	    writer = csv.writer(f)
             writer.writerow(['x'] +
                             ['y'] +
-                            ['Easting Centroid of basin'] +
-                            ['Northing Centroid of basin'] +
-                            ['Rectangle containing basin N-W'] +
-                            ['Rectangle containing basin S-E'] +
-                            ['Area of basin [km^2]'] +
-                            ['Perimeter of basin [km]'] +
-                            ['Max Elevation [m s.l.m.]'] +
-                            ['Min Elevation [m s.l.m.]'] +
-                            ['Elevation Difference [m]'] +
-                            ['Mean Elevation'] +
-                            ['Mean Slope'] +
-                            ['Length of Directing Vector [km]'] +
-                            ['Prevalent Orientation [deg from north, ccw]'] +
-                            ['Compactness Coefficient'] +
-                            ['Circularity Ratio'] +
-                            ['Topological Diameter'] +
-                            ['Elongation Ratio'] +
-                            ['Shape Factor'] +
-                            ['Concentration Time [hr]'] +
-                            ['Length of Mainchannel [km]'] +
-                            ['Mean slope of mainchannel [percent]'] +
-                            ['Mean hillslope length [m]'] +
+                            ['Easting_Centroid_basin'] +
+                            ['Northing_Centroid_basin'] +
+                            ['Rectangle_containing_basin_N_W'] +
+                            ['Rectangle_containing_basin_S_E'] +
+                            ['Area_of_basin_km2'] +
+                            ['Perimeter_of_basin_km'] +
+                            ['Max_Elevation'] +
+                            ['Min_Elevation'] +
+                            ['Elevation_Difference'] +
+                            ['Mean_Elevation'] +
+                            ['Mean_Slope'] +
+                            ['Length_of_Directing_Vector_km'] +
+                            ['Prevalent_Orientation_deg_from_north_ccw]'] +
+                            ['Compactness_Coefficient'] +
+                            ['Circularity_Ratio'] +
+                            ['Topological_Diameter'] +
+                            ['Elongation_Ratio'] +
+                            ['Shape_Factor'] +
+                            ['Concentration_Time_'] +
+                            ['Length_of_Mainchannel_km'] +
+                            ['Mean_slope_of_mainchanne_percent'] +
+                            ['Mean_hillslope_length_m'] +
                             ['Magnitudo'] +
-                            ['Max order (Strahler)'] +
-                            ['Number of streams'] +
-                            ['Total Stream Length [km]'] +
-                            ['First order stream frequency'] +
-                            ['Drainage Density [km over km^2]'] +
-                            ['Bifurcation Ratio (Horton)'] +
-                            ['Length Ratio (Horton)'] +
-                            ['Area ratio (Horton)'] +
-                            ['Slope ratio (Horton)'] )
+                            ['Max_order_Strahler'] +
+                            ['Number_of_streams'] +
+                            ['Total_Stream_Length_km'] +
+                            ['First_order_stream_frequency'] +
+                            ['Drainage_Density_km_over_km2]'] +
+                            ['Bifurcation_Ratio_Horton'] +
+                            ['Length_Ratio_Horton'] +
+                            ['Area_ratio_Horton'] +
+                            ['Slope_ratio_Horton'] )
             writer.writerow([east_o]
                           + [north_o]
                           + [basin_east]
@@ -787,16 +787,18 @@
                           + [Slope_ratio])
+# Import table "summary", attaches it to "outlet_snap", then drops it
         grass.run_command("db.in.ogr", dsn = csvfileT,
-                                       output = "summary",
-                                       overwrite = True)
+                                       output = "summary")
         grass.run_command("v.db.join", map = v_outlet_snap,
                                        otable = "summary",
                                        column = "y",
-                                       ocolumn = "y")
+                                       ocolumn = "y")
+        grass.run_command("db.droptable", table = "summary",
+                                          flags = 'f')
