[GRASS-SVN] r59952 - grass/branches/releasebranch_7_0/lib/python/pygrass/docs
svn_grass at osgeo.org
Sun Apr 27 11:27:32 PDT 2014
Author: neteler
Date: 2014-04-27 11:27:32 -0700 (Sun, 27 Apr 2014)
New Revision: 59952
grass/branches/releasebranch_7_0/lib/python/pygrass/docs/attributes.rst
grass/branches/releasebranch_7_0/lib/python/pygrass/docs/conf.py
grass/branches/releasebranch_7_0/lib/python/pygrass/docs/index.rst
grass/branches/releasebranch_7_0/lib/python/pygrass/docs/intro.rst
grass/branches/releasebranch_7_0/lib/python/pygrass/docs/modules.rst
grass/branches/releasebranch_7_0/lib/python/pygrass/docs/raster.rst
pyGRASS docs: English fixes
Modified: grass/branches/releasebranch_7_0/lib/python/pygrass/docs/attributes.rst
--- grass/branches/releasebranch_7_0/lib/python/pygrass/docs/attributes.rst 2014-04-27 18:25:27 UTC (rev 59951)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/docs/attributes.rst 2014-04-27 18:27:32 UTC (rev 59952)
@@ -1,7 +1,7 @@
Attributes
-It is possible to access to the vector attributes with: ::
+It is possible to access the vector attributes with: ::
>>> from pygrass.vector import Vector
>>> municip = Vector('boundary_municp_sqlite')
@@ -135,4 +135,4 @@
.. autoclass:: pygrass.vector.table.Table
- :members:
\ No newline at end of file
+ :members:
Modified: grass/branches/releasebranch_7_0/lib/python/pygrass/docs/conf.py
--- grass/branches/releasebranch_7_0/lib/python/pygrass/docs/conf.py 2014-04-27 18:25:27 UTC (rev 59951)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/docs/conf.py 2014-04-27 18:27:32 UTC (rev 59952)
@@ -52,7 +52,7 @@
# The short X.Y version.
version = '0.2'
# The full version, including alpha/beta/rc tags.
-release = 'alpha'
+release = 'beta'
# The language for content autogenerated by Sphinx. Refer to documentation
# for a list of supported languages.
Modified: grass/branches/releasebranch_7_0/lib/python/pygrass/docs/index.rst
--- grass/branches/releasebranch_7_0/lib/python/pygrass/docs/index.rst 2014-04-27 18:25:27 UTC (rev 59951)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/docs/index.rst 2014-04-27 18:27:32 UTC (rev 59952)
@@ -3,19 +3,18 @@
You can adapt this file completely to your liking, but it should at least
contain the root `toctree` directive.
-Welcome to PyGrass's documentation!
+Welcome to PyGrass documentation!
-Since in the 2006 GRASS developers start to adopt python for the new GUI,
-python becoming more and more important and developers plan to convert all
-the bash scripts in to python for the next major release GRASS 7.
+In 2006, GRASS GIS developers started to adopt Python for the new GUI. Due
+to this Python became more and more important and developers converted all
+shell scripts from GRASS GIS 6 to Python for GRASS GIS 7.
-``pygrass`` want to improve integration between GRASS and python, make the
-use of python under GRASS more consistent with the language itself and make
-the GRASS scripting and programming activity easier and more natural
-to the final users.
+``pygrass`` improves the integration between GRASS GIS and Python, making
+the use of Python under GRASS more consistent with the language itself. Furthermore,
+it simplifies GRASS scripting and programming and more natural for the user.
-This project has been funded with support from the google Summer of Code 2012.
+This project has been funded with support from the Google Summer of Code 2012.
Contents:
Modified: grass/branches/releasebranch_7_0/lib/python/pygrass/docs/intro.rst
--- grass/branches/releasebranch_7_0/lib/python/pygrass/docs/intro.rst 2014-04-27 18:25:27 UTC (rev 59951)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/docs/intro.rst 2014-04-27 18:27:32 UTC (rev 59952)
@@ -1,30 +1,14 @@
Introduction
-To work with ``pygrass`` you need a up-to-date version of GRASS 7.
-You can obtain a recent version following the information on the
-`main web site <http://grass.osgeo.org/download/software.php#g70x>`_
+To work with ``pygrass`` you need a up-to-date version of GRASS GIS 7.
+You can obtain a recent version following the information provided on the
+`main Web site <http://grass.osgeo.org/download/software/>`_
of GRASS, and you can read more about compilation on the
-`GRASS wiki <http://grass.osgeo.org/wiki/Compile_and_Install>`_
+`GRASS GIS Wiki <http://grasswiki.osgeo.org/wiki/Compile_and_Install>`_
-Now you can download the ``pygrass`` source using ``git``
+The only action before starting to work with ``pygrass`` is to launch
+GRASS GIS 7 and from the console launch ``python`` or ``ipython``
+(the second one is the recommended way)
- git clone https://lucadeluge@code.google.com/p/pygrass/
-If you have not ``git`` you can install it from the `git website <http://git-scm.com/downloads>`_
-or download the source code of ``pygrass`` from `<http://code.google.com/p/pygrass/downloads/list>`_
-At this point you have to install ``pygrass``, so enter in the right
-folder and launch with administration permission
- python setup.py install
-The last action before start to work with ``pygrass`` is to run
-GRASS 7 and from the console launch ``python`` or ``ipython``
-(the second one is the the suggested)
-Read more about how to work with :doc:`raster`, :doc:`vector`, :doc:`modules`.
+Read more about how to work with :doc:`raster`, :doc:`vector`, :doc:`attributes`, :doc:`modules`.
Modified: grass/branches/releasebranch_7_0/lib/python/pygrass/docs/modules.rst
--- grass/branches/releasebranch_7_0/lib/python/pygrass/docs/modules.rst 2014-04-27 18:25:27 UTC (rev 59951)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/docs/modules.rst 2014-04-27 18:27:32 UTC (rev 59952)
@@ -61,7 +61,7 @@
-It is possible to access to the module info, with:
+It is possible to access the module info with:
>>> slope_aspect.name
'r.slope.aspect'
Modified: grass/branches/releasebranch_7_0/lib/python/pygrass/docs/raster.rst
--- grass/branches/releasebranch_7_0/lib/python/pygrass/docs/raster.rst 2014-04-27 18:25:27 UTC (rev 59951)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/docs/raster.rst 2014-04-27 18:27:32 UTC (rev 59952)
@@ -3,16 +3,16 @@
Raster
-PyGrass use 4 different Raster classes, that respect the 4 different approaches
-of C grass API.
+PyGRASS uses 4 different Raster classes, that respect the 4 different approaches
+of GRASS-C API.
The read access is row wise for :ref:`RasterRow-label` and
:ref:`RasterRowIO-label` and additionally
-cached in the RowIO class. Booth classes write sequentially.
+cached in the RowIO class. Both classes write sequentially.
RowIO is row cached, :ref:`RasterSegment-label` and :ref:`RasterNumpy-label`
are tile cached for reading and writing therefore a randomly access is possible.
Hence RasterRow and RasterRowIO should be used in case for fast (cached)
row read access and RasterRow for fast sequential writing.
-Segment and Numpy should be used for random access, but numpy only for files
+Segment and Numpy should be used for random access, but Numpy only for files
not larger than 2GB.
@@ -110,7 +110,7 @@
('bare ground path', 10, None),
('grass', 11, None)]
-Access to single category, using Rast_get_ith_cat(), with: ::
+Access a single category, using Rast_get_ith_cat(), with: ::
>>> land.cats[0]
('pond', 1, None)
