[GRASS-SVN] r59953 - grass-addons/grass6/dst/vector/v.random.sample
svn_grass at osgeo.org
Sun Apr 27 16:25:27 PDT 2014
Author: neteler
Date: 2014-04-27 16:25:27 -0700 (Sun, 27 Apr 2014)
New Revision: 59953
grass-addons/grass6/dst/vector/v.random.sample/main.c
v.random.sample addon: indentation
Modified: grass-addons/grass6/dst/vector/v.random.sample/main.c
--- grass-addons/grass6/dst/vector/v.random.sample/main.c 2014-04-27 18:27:32 UTC (rev 59952)
+++ grass-addons/grass6/dst/vector/v.random.sample/main.c 2014-04-27 23:25:27 UTC (rev 59953)
@@ -3,8 +3,8 @@
/* TODO
- specifying -a automatically disregards the map as well.
- Is that good behaviour?
+ Is that good behaviour?
#include <stdlib.h>
#include <stdio.h>
@@ -29,363 +29,366 @@
/* checks if user-supplied parameters are valid */
int
-check_parms (char *map_answer, char *input_answer, char *output_answer, int all )
+check_parms(char *map_answer, char *input_answer, char *output_answer,
+ int all)
- if ( map_answer != NULL ) {
- if ((G_find_file ("fcell", map_answer, "") == NULL)
- && (G_find_file ("dcell", map_answer, "") == NULL)
- && (G_find_file ("cell", map_answer, "") == NULL))
- /* no coverage map found */
- G_fatal_error
- ("No raster map exists with the given name.");
- /* specifying all means to disregard the map! */
- if ( all == 1 ) {
- G_warning ("Map was specified, but the -a flag disregards map values!\n Your results might not be what you expect.");
+ if (map_answer != NULL) {
+ if ((G_find_file("fcell", map_answer, "") == NULL)
+ && (G_find_file("dcell", map_answer, "") == NULL)
+ && (G_find_file("cell", map_answer, "") == NULL)) {
+ /* no coverage map found */
+ G_fatal_error("No raster map exists with the given name.");
- /* check if sample sites exist */
- if (G_find_file ("vector", input_answer, "") == NULL)
- G_fatal_error
- ("No sample/sites list exists with the given name!");
+ /* specifying all means to disregard the map! */
+ if (all == 1) {
+ G_warning
+ ("Map was specified, but the -a flag disregards map values!\n Your results might not be what you expect.");
- /* check if a legal file name was given for output map
- this just overwrites existing sites */
- if (G_legal_filename (output_answer) == -1)
- G_fatal_error
- ("Name chosen for result map is not a valid file name!");
- /* return raster mode to caller */
- return (G_raster_map_type (map_answer,""));
- else return (-1);
+ /* check if sample sites exist */
+ if (G_find_file("vector", input_answer, "") == NULL) {
+ G_fatal_error("No sample/sites list exists with the given name!");
+ /* check if a legal file name was given for output map
+ this just overwrites existing sites */
+ if (G_legal_filename(output_answer) == -1) {
+ G_fatal_error("Name chosen for result map is not a valid file name!");
+ /* return raster mode to caller */
+ return (G_raster_map_type(map_answer, ""));
+ else
+ return (-1);
/* creates a vector site file in the user's mapset that contains */
/* 'percentage' objects randomly picked from input map */
/* useful to create randomised samples for statistical tests */
-void do_split_sample ( char *input, char *output, int in_types, double percentage, char *map,
- int all, int processing_mode, int quiet) {
- CELL *cellbuf;
- DCELL *dcellbuf;
- GT_Row_cache_t *cache;
- int fd;
- int i,j,k,l;
- int no_sites;
- int sites_tried = 0;
- struct Cell_head region;
- int error;
- char *mapset, errmsg [200];
- unsigned int *taken; /* this is an array of 0/1 which signals, if
- a certain site has already been 'drawn' */
- long row_idx, col_idx;
- struct Map_info in_vect_map;
- struct Map_info out_vect_map;
- struct line_pnts *vect_points;
- struct line_cats *vect_cats;
- double x,y,z;
- int n_points = 1;
- int cur_type;
- cellbuf = NULL;
- dcellbuf = NULL;
- cache = NULL;
- /* get current region */
- G_get_window (®ion);
- /* attempt to create new file for output */
- Vect_set_open_level (2);
- if (0 > Vect_open_new (&out_vect_map, output, 0) ) {
- G_fatal_error ("Could not open output vector map.\n");
+void do_split_sample(char *input, char *output, int in_types,
+ double percentage, char *map, int all,
+ int processing_mode, int quiet)
+ CELL *cellbuf;
+ DCELL *dcellbuf;
+ GT_Row_cache_t *cache;
+ int fd;
+ int i, j, k, l;
+ int no_sites;
+ int sites_tried = 0;
+ struct Cell_head region;
+ int error;
+ char *mapset, errmsg[200];
+ unsigned int *taken; /* this is an array of 0/1 which signals, if
+ a certain site has already been 'drawn' */
+ long row_idx, col_idx;
+ struct Map_info in_vect_map;
+ struct Map_info out_vect_map;
+ struct line_pnts *vect_points;
+ struct line_cats *vect_cats;
+ double x, y, z;
+ int n_points = 1;
+ int cur_type;
- /* open input vector map */
- if ((mapset = G_find_vector2 (input, "")) == NULL) {
- sprintf (errmsg, "Could not find input %s\n", input);
- G_fatal_error ("%s",errmsg);
- if (1 > Vect_open_old (&in_vect_map, input, "")) {
- sprintf (errmsg, "Could not open input map %s.\n", input);
+ cellbuf = NULL;
+ dcellbuf = NULL;
+ cache = NULL;
- vect_points = Vect_new_line_struct ();
- vect_cats = Vect_new_cats_struct ();
+ /* get current region */
+ G_get_window(®ion);
- /* set constraints specified */
- if (in_types != 0) {
- Vect_set_constraint_type (&in_vect_map, in_types);
+ /* attempt to create new file for output */
+ Vect_set_open_level(2);
+ if (0 > Vect_open_new(&out_vect_map, output, 0)) {
+ G_fatal_error("Could not open output vector map.\n");
+ /* open input vector map */
+ if ((mapset = G_find_vector2(input, "")) == NULL) {
+ sprintf(errmsg, "Could not find input %s\n", input);
+ G_fatal_error("%s", errmsg);
+ if (1 > Vect_open_old(&in_vect_map, input, "")) {
+ sprintf(errmsg, "Could not open input map %s.\n", input);
+ vect_points = Vect_new_line_struct();
+ vect_cats = Vect_new_cats_struct();
+ /* set constraints specified */
+ if (in_types != 0) {
+ Vect_set_constraint_type(&in_vect_map, in_types);
+ if (all != 1) {
+ Vect_set_constraint_region(&in_vect_map, region.north, region.south,
+ region.east, region.west, 0.0, 0.0);
+ /* get total number of objects with constraints */
+ i = 0;
+ while ((cur_type =
+ Vect_read_next_line(&in_vect_map, vect_points, vect_cats) > 0)) {
+ i++;
+ k = (((float)i / 100)) * percentage; /* k now has the number of objects wanted */
+ if (quiet != 1) {
+ fprintf(stderr, "Creating randomised sample of size n = %i.\n", k);
+ /* now, we need to acquire exactly 'k' random objects that fall in NON-NULL */
+ /* coverage raster cells. */
+ taken = G_calloc(i, sizeof(unsigned int));
+ for (l = 0; l < k; l++) {
+ taken[l] = 0;
+ no_sites = i; /* store this for later use */
+ /* does user want to filter objects through a raster map? */
+ if (map != NULL) {
+ /* open raster map */
+ fd = G_open_cell_old(map, G_find_cell(map, ""));
+ if (fd < 0) {
+ G_fatal_error("Could not open raster map for reading!\n");
- if (all != 1) {
- Vect_set_constraint_region (&in_vect_map, region.north, region.south,
- region.east, region.west, 0.0, 0.0);
+ /* allocate cache and buffer, according to type of coverage */
+ if (processing_mode == CELL_TYPE) {
+ /* INT coverage */
+ cache = (GT_Row_cache_t *) G_malloc(sizeof(GT_Row_cache_t));
+ /* TODO: check error value */
+ error = GT_RC_open(cache, cachesize, fd, CELL_TYPE);
+ cellbuf = G_allocate_raster_buf(CELL_TYPE);
+ if ((processing_mode == FCELL_TYPE) ||
+ (processing_mode == DCELL_TYPE)) {
+ /* FP coverage */
+ error = GT_RC_open(cache, cachesize, fd, DCELL_TYPE);
+ dcellbuf = G_allocate_raster_buf(DCELL_TYPE);
- /* get total number of objects with constraints */
- i = 0;
- while ((cur_type = Vect_read_next_line (&in_vect_map, vect_points, vect_cats) > 0)) {
- i ++;
+ srand(((unsigned int)time(NULL)) + getpid()); /* set seed for random number generator from system time and process ID */
+ i = 0;
+ /* MAIN LOOP */
+ while (i < k) {
+ /* get a random index, but one that was not taken already */
+ l = 0;
+ while (l == 0) {
+ j = rand() % (no_sites - 1 + 1) + 1; /* j now has the random position to try */
+ if (taken[j - 1] == 0) {
+ l = 1; /* exit loop */
- k = ( ((float) i/100)) * percentage; /* k now has the number of objects wanted */
- if ( quiet != 1 ) {
- fprintf (stderr,"Creating randomised sample of size n = %i.\n",k);
+ taken[j - 1] = 1; /* mark this index as 'taken' */
+ sites_tried++; /* keep track of this so we do not enter an infinite loop */
+ if (sites_tried > no_sites) {
+ /* could not create a large enough sample */
+ G_fatal_error
+ ("Could not find enough objects for split sampling.\nDecrease split sample size.\n");
- /* now, we need to acquire exactly 'k' random objects that fall in NON-NULL */
- /* coverage raster cells. */
- taken = G_calloc (i, sizeof (unsigned int));
- for ( l = 0; l < k; l ++ ) {
- taken[l] = 0;
+ /* get next vector object */
+ cur_type = Vect_read_line(&in_vect_map, vect_points, vect_cats, j);
+ if (cur_type < 0) {
+ G_fatal_error("Error reading vector map: premature EOF.\n");
- no_sites = i; /* store this for later use */
- /* does user want to filter objects through a raster map? */
- if ( map != NULL) {
- /* open raster map */
- fd = G_open_cell_old (map, G_find_cell (map, ""));
- if (fd < 0)
- G_fatal_error ("Could not open raster map for reading!\n");
+ /* now, check if coverage under site is NON-NULL and within region */
+ /* convert site northing to row! */
+ /* for this check, we use only the first pair of coordinates! */
+ Vect_copy_pnts_to_xyz(vect_points, &x, &y, &z, &n_points);
+ row_idx = (long)G_northing_to_row(y, ®ion);
+ col_idx = (long)G_easting_to_col(x, ®ion);
+ /* do region check, first... OBSOLETE */
+ /* read row from cache and check for NULL */
+ /* if required */
+ cellbuf = GT_RC_get(cache, row_idx);
+ if (!G_is_c_null_value(&cellbuf[col_idx])) {
+ i++;
+ Vect_write_line(&out_vect_map, cur_type,
+ vect_points, vect_cats);
+ fflush(stdout);
- /* allocate cache and buffer, according to type of coverage */
- if ( processing_mode == CELL_TYPE) {
- /* INT coverage */
- cache = (GT_Row_cache_t *) G_malloc (sizeof (GT_Row_cache_t));
- /* TODO: check error value */
- error = GT_RC_open (cache, cachesize, fd, CELL_TYPE);
- cellbuf = G_allocate_raster_buf (CELL_TYPE);
+ dcellbuf = GT_RC_get(cache, row_idx);
+ if (!G_is_d_null_value(&dcellbuf[col_idx])) {
+ i++;
+ fflush(stdout);
- if ( (processing_mode == FCELL_TYPE) || (processing_mode == DCELL_TYPE) ) {
- /* FP coverage */
- error = GT_RC_open (cache, cachesize, fd, DCELL_TYPE);
- dcellbuf = G_allocate_raster_buf (DCELL_TYPE);
- srand ( ((unsigned int) time (NULL)) + getpid()); /* set seed for random number generator from system time and process ID*/
- i = 0;
- /* MAIN LOOP */
- while ( i < k ) {
- /* get a random index, but one that was not taken already */
- l = 0;
- while ( l == 0 ) {
- j = rand () % ( no_sites - 1 + 1) + 1; /* j now has the random position to try */
- if ( taken[j-1] == 0 ) {
- l = 1; /* exit loop */
- taken [j-1] = 1; /* mark this index as 'taken' */
- sites_tried ++; /* keep track of this so we do not enter an infinite loop */
- if ( sites_tried > no_sites ) {
- /* could not create a large enough sample */
- G_fatal_error ("Could not find enough objects for split sampling.\nDecrease split sample size.\n");
- /* get next vector object */
- cur_type = Vect_read_line (&in_vect_map, vect_points, vect_cats, j);
- if (cur_type < 0 ) {
- G_fatal_error ("Error reading vector map: premature EOF.\n");
- /* now, check if coverage under site is NON-NULL and within region */
- /* convert site northing to row! */
- /* for this check, we use only the first pair of coordinates! */
- Vect_copy_pnts_to_xyz (vect_points, &x, &y, &z, &n_points);
- row_idx =
- (long) G_northing_to_row (y,
- ®ion);
- col_idx =
- (long) G_easting_to_col (x,
- ®ion);
- /* do region check, first... OBSOLETE */
- /* read row from cache and check for NULL */
- /* if required */
- if ( map != NULL ) {
- if ( processing_mode == CELL_TYPE ) {
- cellbuf = GT_RC_get (cache, row_idx);
- if (!G_is_c_null_value(&cellbuf[col_idx])) {
- i ++;
- Vect_write_line (&out_vect_map, cur_type,
- vect_points, vect_cats );
- fflush (stdout);
- dcellbuf = GT_RC_get (cache, row_idx);
- if (!G_is_d_null_value(&dcellbuf[col_idx])) {
- i ++;
- fflush (stdout);
- } else {
- i ++;
- Vect_write_line (&out_vect_map, GV_POINT,
- fflush (stdout);
- /* disregard region setting and map, if -a flag is given */
- if ( all == 1 ) {
- i ++;
- fflush (stdout);
- G_percent(i,k,1);
+ else {
+ i++;
+ Vect_write_line(&out_vect_map, GV_POINT, vect_points, vect_cats);
+ fflush(stdout);
- /* END OF MAIN LOOP */
- Vect_copy_head_data (&in_vect_map, &out_vect_map);
- fprintf (stdout, "Building topology information for output map.\n");
- Vect_build (&out_vect_map);
- Vect_close (&in_vect_map);
- Vect_close (&out_vect_map);
- /* close cache, free buffers! */
- GT_RC_close (cache);
- G_free (cellbuf);
- G_free (dcellbuf);
- G_free (cache);
+ /* disregard region setting and map, if -a flag is given */
+ if (all == 1) {
+ i++;
+ Vect_write_line(&out_vect_map, cur_type, vect_points, vect_cats);
+ fflush(stdout);
+ if (quiet != 1) {
+ G_percent(i, k, 1);
+ /* END OF MAIN LOOP */
+ Vect_copy_head_data(&in_vect_map, &out_vect_map);
+ fprintf(stdout, "Building topology information for output map.\n");
+ Vect_build(&out_vect_map);
+ Vect_close(&in_vect_map);
+ Vect_close(&out_vect_map);
-int
-main (int argc, char *argv[])
- struct GModule *module;
- struct
- struct Option *input; /* name of input site map */
- struct Option *output; /* name of output site map */
- struct Option *type;
- struct Option *where;
- struct Option *size; /* size of sample (%input) */
- struct Option *map; /* optional raster to check for NULL */
- struct Option *cachesize;
+ /* close cache, free buffers! */
+ GT_RC_close(cache);
+ G_free(cellbuf);
- parm;
- struct
- struct Flag *quiet;
- struct Flag *all; /* disregard region settings */
+ G_free(dcellbuf);
- flag;
- int processing_mode = 0;
- int vect_types;
+ G_free(cache);
- /* setup some basic GIS stuff */
- G_gisinit (argv[0]);
- module = G_define_module ();
- module->description = "Generates a random sample from a map of vector objects";
- /* do not pause after a warning message was displayed */
- G_sleep_on_error (0);
- /* Module Parameters: */
- parm.input = G_define_standard_option (G_OPT_V_INPUT);
- parm.input->key = "input";
- parm.input->type = TYPE_STRING;
- parm.input->required = YES;
- parm.input->description = "Vector map to draw sample from";
- /* name of output map */
- parm.output = G_define_standard_option (G_OPT_V_OUTPUT);
- parm.output->key = "output";
- parm.output->type = TYPE_STRING;
- parm.output->required = YES;
- parm.output->description = "Vector map to store random sample in";
- /* type of objects */
- parm.type = G_define_standard_option (G_OPT_V_TYPE);
- /* filter objects by sql statement */
- parm.where = G_define_standard_option (G_OPT_WHERE);
+int main(int argc, char *argv[])
+ struct GModule *module;
+ struct
+ struct Option *input; /* name of input site map */
+ struct Option *output; /* name of output site map */
+ struct Option *type;
+ struct Option *where;
+ struct Option *size; /* size of sample (%input) */
+ struct Option *map; /* optional raster to check for NULL */
+ struct Option *cachesize;
+ parm;
+ struct
+ struct Flag *quiet;
+ struct Flag *all; /* disregard region settings */
+ flag;
+ int processing_mode = 0;
+ int vect_types;
- /* percentage of input objects to include for random sample */
- parm.size = G_define_option ();
- parm.size->key = "size";
- parm.size->type = TYPE_DOUBLE;
- parm.size->required = YES;
- parm.size->description = "Size of the sample (% of input vector objects)";
- parm.size->options = "0-100";
+ /* setup some basic GIS stuff */
+ G_gisinit(argv[0]);
+ module = G_define_module();
+ module->description =
+ "Generates a random sample from a map of vector objects";
+ /* do not pause after a warning message was displayed */
+ G_sleep_on_error(0);
- /* map = an optional raster map. Samples will not be generated */
- /* in cells where this map fprintf (stderr, "HI\n");is NULL */
- parm.map = G_define_standard_option (G_OPT_R_INPUT);
- parm.map->key = "raster";
- parm.map->type = TYPE_STRING;
- parm.map->required = NO;
- parm.map->description = "Sampling cannot be done on NULL cells in this raster map";
- /* number of lines to store in cache */
- parm.cachesize = G_define_option ();
- parm.cachesize->key = "cachesize";
- parm.cachesize->type = TYPE_INTEGER;
- parm.cachesize->answer = "-1";
- parm.cachesize->required = NO;
- parm.cachesize->description = "Number of raster rows to store in cache (-1 for auto)";
- flag.all = G_define_flag ();
- flag.all->key = 'a';
- flag.all->description = "Sample outside the current region's limits";
- flag.quiet = G_define_flag ();
- flag.quiet->key = 'q';
- flag.quiet->description = "Quiet operation: no progress display";
- /* parse command line */
- if (G_parser (argc, argv))
- exit (-1);
+ /* Module Parameters: */
+ parm.input = G_define_standard_option(G_OPT_V_INPUT);
+ parm.input->key = "input";
+ parm.input->type = TYPE_STRING;
+ parm.input->required = YES;
+ parm.input->description = "Vector map to draw sample from";
+ /* name of output map */
+ parm.output = G_define_standard_option(G_OPT_V_OUTPUT);
+ parm.output->key = "output";
+ parm.output->type = TYPE_STRING;
+ parm.output->required = YES;
+ parm.output->description = "Vector map to store random sample in";
+ /* type of objects */
+ parm.type = G_define_standard_option(G_OPT_V_TYPE);
+ /* filter objects by sql statement */
+ parm.where = G_define_standard_option(G_OPT_WHERE);
+ /* percentage of input objects to include for random sample */
+ parm.size = G_define_option();
+ parm.size->key = "size";
+ parm.size->type = TYPE_DOUBLE;
+ parm.size->required = YES;
+ parm.size->description = "Size of the sample (% of input vector objects)";
+ parm.size->options = "0-100";
+ /* map = an optional raster map. Samples will not be generated */
+ /* in cells where this map fprintf (stderr, "HI\n");is NULL */
+ parm.map = G_define_standard_option(G_OPT_R_INPUT);
+ parm.map->key = "raster";
+ parm.map->type = TYPE_STRING;
+ parm.map->required = NO;
+ parm.map->description =
+ "Sampling cannot be done on NULL cells in this raster map";
+ /* number of lines to store in cache */
+ parm.cachesize = G_define_option();
+ parm.cachesize->key = "cachesize";
+ parm.cachesize->type = TYPE_INTEGER;
+ parm.cachesize->answer = "-1";
+ parm.cachesize->required = NO;
+ parm.cachesize->description =
+ "Number of raster rows to store in cache (-1 for auto)";
+ flag.all = G_define_flag();
+ flag.all->key = 'a';
+ flag.all->description = "Sample outside the current region's limits";
+ flag.quiet = G_define_flag();
+ flag.quiet->key = 'q';
+ flag.quiet->description = "Quiet operation: no progress display";
+ /* parse command line */
+ if (G_parser(argc, argv)) {
+ exit(-1);
+ vect_types = Vect_option_to_types(parm.type);
+ /* check if given parameters are valid */
+ processing_mode =
+ check_parms(parm.map->answer, parm.input->answer, parm.output->answer,
+ flag.all->answer);
+ if (parm.map->answer != NULL) {
+ /* set cachesize */
+ cachesize = atoi(parm.cachesize->answer);
+ if ((cachesize < -1) || (cachesize > G_window_rows())) {
+ /* if cache size is invalid, just set to auto-mode (-1) */
+ G_warning
+ ("Invalid cache size requested (must be between 0 and %i or -1).\n",
+ G_window_rows());
+ cachesize = -1;
- vect_types = Vect_option_to_types (parm.type);
+ do_split_sample(parm.input->answer, parm.output->answer, vect_types,
+ atof(parm.size->answer), parm.map->answer,
+ flag.all->answer, processing_mode, flag.quiet->answer);
- /* check if given parameters are valid */
- processing_mode =
- check_parms (parm.map->answer, parm.input->answer, parm.output->answer, flag.all->answer);
- if ( parm.map->answer != NULL ) {
- /* set cachesize */
- cachesize = atoi (parm.cachesize->answer);
- if ( (cachesize<-1) || (cachesize > G_window_rows ()) ) {
- /* if cache size is invalid, just set to auto-mode (-1) */
- G_warning ("Invalid cache size requested (must be between 0 and %i or -1).\n", G_window_rows());
- cachesize = -1;
- do_split_sample ( parm.input->answer, parm.output->answer, vect_types, atof (parm.size->answer),
- parm.map->answer, flag.all->answer, processing_mode, flag.quiet->answer );
- return (EXIT_SUCCESS);
+ return (EXIT_SUCCESS);
