[GRASS-SVN] r59954 - grass-addons/grass6/dst/vector/v.random.sample
Sun Apr 27 16:28:30 PDT 2014
Author: neteler
Date: 2014-04-27 16:28:30 -0700 (Sun, 27 Apr 2014)
New Revision: 59954
Added:
   grass-addons/grass6/dst/vector/v.random.sample/rowcache.c
   grass-addons/grass6/dst/vector/v.random.sample/Makefile
   grass-addons/grass6/dst/vector/v.random.sample/description.html
v.random.sample: svn copy of grass-addons/grass6/dst/lib/gt_raster/rowcache.c fo ease of compilation; HTML cosmetics
Modified: grass-addons/grass6/dst/vector/v.random.sample/Makefile
--- grass-addons/grass6/dst/vector/v.random.sample/Makefile	2014-04-27 23:25:27 UTC (rev 59953)
+++ grass-addons/grass6/dst/vector/v.random.sample/Makefile	2014-04-27 23:28:30 UTC (rev 59954)
@@ -2,7 +2,7 @@
 PGM = v.random.sample
-GT_LIB_RAST = -lgt_raster
+#GT_LIB_RAST = -lgt_raster
 LIBES = $(GISLIB) $(DATETIMELIB) $(VECTLIB) $(GT_LIB_RAST) $(DBMILIB) $(GDALLIBS)
 DEPENDENCIES = $(VECTDEP) $(GPROJDEP) $(DBMIDEP) $(GISDEP)
 EXTRA_CFLAGS = -I../../include $(VECT_CFLAGS)
Modified: grass-addons/grass6/dst/vector/v.random.sample/description.html
--- grass-addons/grass6/dst/vector/v.random.sample/description.html	2014-04-27 23:25:27 UTC (rev 59953)
+++ grass-addons/grass6/dst/vector/v.random.sample/description.html	2014-04-27 23:28:30 UTC (rev 59954)
@@ -1,10 +1,3 @@
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
-<html>
-<TITLE>v.random.sample</TITLE>
-<body bgcolor="white">
 <h2>DESCRIPTION</h2>
 This command creates a random sample of n% of the sites in a GRASS sites map. The current
@@ -51,5 +44,3 @@
 Benjamin Ducke,<br>
 University of Kiel, Germany<br>
 <i>Last changed: 2005/21/07</i>
-</body>
-</html>
Copied: grass-addons/grass6/dst/vector/v.random.sample/rowcache.c (from rev 59953, grass-addons/grass6/dst/lib/gt_raster/rowcache.c)
--- grass-addons/grass6/dst/vector/v.random.sample/rowcache.c	                        (rev 0)
+++ grass-addons/grass6/dst/vector/v.random.sample/rowcache.c	2014-04-27 23:28:30 UTC (rev 59954)
@@ -0,0 +1,462 @@
+/* ROWCACHE.C */
+/* Part of the GRASS Toolkit (GT) functions collection */
+/* Purpose:	provide a raster cache that retrieves rows from memory instead of disk, if possible. */
+/*         	This should speed up operations where the same row has to be read more than once. */
+/* This file is licensed under the GPL (version 2) */
+/* see: http://www.gnu.org/copyleft/gpl.html */
+/* (c) Benjamin Ducke 2004 */
+/* benducke at compuserve.de */
+#include <stdlib.h>
+#include <stdio.h>
+#include <grass/gis.h>
+#include "gt/rowcache.h"
+/* returns the slot number in the lookup table for a cached raster row */
+/* should actually be a hash function instead of this */
+/* return: lookup table index or -1 if row is not in cache */
+long GT_RC_lookup_slot (GT_Row_cache_t *cache, long row) {
+  int i = 0;
+  for (i=0; i <= cache->max; i++) {
+	  if (cache->allocated_lookup[i] == row) {
+		  return (i);
+  /* raster row not currently cached */
+  return (-1);
+void GT_RC_update_worst (GT_Row_cache_t *cache, long hit) {
+	int i = 0;
+	int most_misses = 0;
+	cache->worst=cache->allocated_lookup[0];
+	/* the following loops act on every slot except 'hit' */
+	/* which is the only one that does not get its misses increased */
+	for ( i = 0; i <= cache->max; i++) {
+		if (cache->allocated_lookup[i] != hit) {
+			if (cache->data_type == CELL_TYPE) {
+				if ((cache->c_cache_area[cache->allocated_lookup[i]] != NULL) &&
+					(cache->allocated_lookup[i] > -1))
+			  		cache->misses[cache->allocated_lookup[i]]++;
+			  		if (cache->misses[cache->allocated_lookup[i]] > most_misses) {
+						most_misses = cache->misses[cache->allocated_lookup[i]];
+						cache->worst = cache->allocated_lookup[i];
+			if (cache->data_type == DCELL_TYPE) {
+				if ((cache->d_cache_area[cache->allocated_lookup[i]] != NULL) &&
+			if (cache->data_type == FCELL_TYPE) {
+				if ((cache->f_cache_area[cache->allocated_lookup[i]] != NULL) &&
+long GT_RC_find_worst (GT_Row_cache_t *cache) {
+	return (cache->worst);
+/* tries to allocate a block of n cache rows */
+/* no memory is actually allocated! This function */
+/* frees all allocated memory before exiting */
+/* returns n (same value), if enough mem is present, -1 otherwise */
+int GT_RC_try_alloc (long n, RASTER_MAP_TYPE data_type ) {
+	void *try;
+	if ( data_type == CELL_TYPE ) {
+		try = calloc ((unsigned long) n, sizeof (CELL*));
+		if (try == NULL) {
+			return (-1);
+		} else {
+			free (try);
+	if ( data_type == FCELL_TYPE ) {
+		try = calloc ((unsigned long) n, sizeof (FCELL*));
+			return (-1);
+		} else {
+			free (try);
+	if ( data_type == DCELL_TYPE ) {
+		try = calloc ((unsigned long)n, sizeof (DCELL*));
+			return (-1);
+		} else {
+			free (try);
+	return (0);
+/* open a new row cache on a GRASS rast map */
+/* n = number of raster rows to store in cache */
+/* fd = file descriptor to associate with cache */
+/* NOTE: fd must NOT be closed by caller, it will be closed automatically */
+/*		  by GT_RC_close() */
+/* RASTER_MAP_TYPE may be CELL, DCELL or FCELL */
+int GT_RC_open (GT_Row_cache_t *cache, long n, int fd, RASTER_MAP_TYPE data_type) {
+	long i;
+	long rows;
+	/* turn cache on by defult */
+	cache->off = 0;
+	/* 1: see if user requested a certain size and if we have that much mem */
+	if ( n == 0 ) {
+		G_warning ("Cache has been turned off by user request.\n");
+		cache->off = 1;
+		n = 1; /* even a cache that was turned off needs to store one row */
+	if ( n > 0 ) {
+		if ( GT_RC_try_alloc (n, data_type) == -1) {
+			G_warning ("Requested cache size cannot be allocated.\n");
+			/* set to auto mode */
+			n = -1;
+	/* 2: else: fall back to auto mode, try 20% of total rows, than 10%, than 5% */
+	if ( n == -1 ) {
+		/* try 20 percent first */
+		n = (G_window_rows()/100) * 20;
+			n = (G_window_rows() / 100) * 10;
+				n = (G_window_rows() / 100) * 5;
+					/* it's no longer any use: just turn off the cache! */
+					G_warning ("Insufficient memory for cache: turned off.\n");
+					cache->off = 1;
+					n = 1;
+	cache->max = n-1;
+	cache->allocated = 0;
+	cache->fd = fd;
+	cache->worst = 0;
+	cache->region_rows = G_window_rows(); /* store these values for faster access */
+	cache->region_cols = G_window_cols(); /* store these values for faster access */
+	cache->data_type = data_type;
+	rows = G_window_rows ();
+	cache->misses = G_calloc (rows, sizeof(long));
+	for (i=0; i<rows;i++) {
+		cache->misses[i] = 0;
+	/* allocate pointers according to type of raster */
+	if (data_type == CELL_TYPE) {
+		cache->c_cache_area = G_calloc (rows,sizeof (CELL*));
+    	for (i = 0; i<n; i++) {
+	  	cache->c_cache_area[i] = NULL;
+	if (data_type == DCELL_TYPE) {
+		cache->d_cache_area = G_calloc (rows,sizeof (DCELL*));
+	  	cache->d_cache_area[i] = NULL;
+	if (data_type == FCELL_TYPE) {
+		cache->f_cache_area = G_calloc (rows,sizeof (FCELL*));
+       	cache->f_cache_area[i] = NULL;
+	/* if cache turned off, we cannot dynamically allocate, so do it now! */
+	if ( cache->off == 1 ) {
+			cache->c_cache_area[0] = G_allocate_raster_buf(CELL_TYPE);
+			cache->d_cache_area[0] = G_allocate_raster_buf(DCELL_TYPE);
+			cache->f_cache_area[0] = G_allocate_raster_buf(FCELL_TYPE);
+	cache->allocated_lookup = G_calloc (n, sizeof(long));
+   	for (i=0;i<n;i++) {
+		cache->allocated_lookup[i] = -1; /* -1 marks free entry */
+    return (0);
+/* retreives row 'i' from the cache */
+void* GT_RC_get (GT_Row_cache_t *cache, long i) {
+    	int error;
+	char tmp[255];
+	struct Cell_head region;
+	/* if cache was turned off: just read row from disk and return it */
+		if ( cache->data_type == CELL_TYPE ) {
+			error = G_get_c_raster_row (cache->fd,cache->c_cache_area[0],i);
+		  	if ( error == -1 ) {
+				G_get_window (&region);
+			 	G_fatal_error ("Cache failure: could not read CELL raster row at %.2f.\n",
+			  					G_row_to_northing((float) i,&region));
+			return (CELL*) (cache->c_cache_area[0]);
+		if ( cache->data_type == DCELL_TYPE ) {
+			error = G_get_d_raster_row (cache->fd,cache->d_cache_area[0],i);
+			return (DCELL*) (cache->d_cache_area[0]);
+		if ( cache->data_type == FCELL_TYPE ) {
+			error = G_get_f_raster_row (cache->fd,cache->f_cache_area[0],i);
+			return (FCELL*) (cache->f_cache_area[0]);
+	if ((i < 0) || (i >= cache->region_rows)) {
+		sprintf (tmp,"Illegal cache request: row %i at Northing %.2f.\n",(int)i,
+			G_row_to_northing((float)i,&region));
+		G_fatal_error ( "%s", (char*) tmp);
+	  if (cache->c_cache_area[i] == NULL) {
+		/* case one: cache miss */
+		if (cache->allocated < (cache->max+1)) { /* still got spare slots in cache */
+		  cache->c_cache_area[i] = G_allocate_raster_buf(CELL_TYPE);
+		  /* put row into cache */
+		  error = G_get_c_raster_row (cache->fd,cache->c_cache_area[i],i);
+		  cache->allocated_lookup[cache->allocated] = i;
+		  cache->allocated ++;
+		  /* increase cache miss count on all other rows */
+		  GT_RC_update_worst (cache, i);
+		  return (CELL*) (cache->c_cache_area[i]);
+        } else {
+		  /* if max cache allocated, we have to throw out one row */
+		  /* find row with most misses and de-allocate it*/
+		  G_free (cache->c_cache_area[GT_RC_find_worst(cache)]);
+		  cache->c_cache_area[GT_RC_find_worst(cache)] = NULL;
+		  cache->allocated_lookup[GT_RC_lookup_slot(cache, GT_RC_find_worst (cache))] = i;
+	  } else {
+		/* case two: row in cache */
+		/* that's good: we have to do nothing but return a pointer to the row */
+	  if (cache->d_cache_area[i] == NULL) {
+		  cache->d_cache_area[i] = G_allocate_raster_buf(DCELL_TYPE);
+		  error = G_get_d_raster_row (cache->fd,cache->d_cache_area[i],i);
+			  G_fatal_error ("Cache failure: could not read DCELL raster row at %.2f.\n",
+		  return (DCELL*) (cache->d_cache_area[i]);
+        } else {
+		  G_free (cache->d_cache_area[GT_RC_find_worst(cache)]);
+		  cache->d_cache_area[GT_RC_find_worst(cache)] = NULL;
+	  } else {
+	  if (cache->f_cache_area[i] == NULL) {
+		  cache->f_cache_area[i] = G_allocate_raster_buf(FCELL_TYPE);
+		  error = G_get_f_raster_row (cache->fd,cache->f_cache_area[i],i);
+			  G_fatal_error ("Cache failure: could not read FCELL raster row at %.2f.\n",
+		  return (FCELL*) (cache->f_cache_area[i]);
+        } else {
+		  G_free (cache->f_cache_area[GT_RC_find_worst(cache)]);
+		  cache->f_cache_area[GT_RC_find_worst(cache)] = NULL;
+	  } else {
+	return (NULL);
+/* closes cache, frees allocated memory */
+void GT_RC_close (GT_Row_cache_t *cache) {
+	/* release all memory used to cache rows */
+	int i;
+	if (cache->off == 1) {
+		for (i = 0; i < cache->region_rows;i++) {
+				if (cache->c_cache_area[i] != NULL) {
+					G_free (cache->c_cache_area[i]);
+				if (cache->d_cache_area[i] != NULL) {
+					G_free (cache->d_cache_area[i]);
+				if (cache->f_cache_area[i] != NULL) {
+					G_free (cache->f_cache_area[i]);
+			G_free (cache->c_cache_area);
+			G_free (cache->d_cache_area);
+			G_free (cache->f_cache_area);
+	} else {
+			G_free (cache->c_cache_area[0]);
+			G_free (cache->d_cache_area[0]);
+			G_free (cache->f_cache_area[0]);
+	G_free (cache->misses);
+	G_free (cache->allocated_lookup);
+	G_close_cell (cache->fd);
