[GRASS-SVN] r61569 - grass/trunk/lib/raster3d
Fri Aug 8 14:31:07 PDT 2014
Author: annakrat
Date: 2014-08-08 14:31:07 -0700 (Fri, 08 Aug 2014)
New Revision: 61569
   grass/trunk/lib/raster3d/gradient.c
r3.gradient: set voxels which have neighbors nulls to zero
Modified: grass/trunk/lib/raster3d/gradient.c
--- grass/trunk/lib/raster3d/gradient.c	2014-08-08 18:44:59 UTC (rev 61568)
+++ grass/trunk/lib/raster3d/gradient.c	2014-08-08 21:31:07 UTC (rev 61569)
@@ -18,7 +18,9 @@
    Gradient computation (second order approximation)
    using central differencing scheme (plus forward and backward
-   difference of second order approx.)
+   difference of second order approximation). When one or more of the cells,
+   from which the gradient for a particular cell is computed, is null,
+   gradient for that particular cell is set to 0.
    \param array pointer to RASTER3D_Array with input values
    \param step array of x, y, z steps for gradient (resolution values)
@@ -35,115 +37,142 @@
 			    RASTER3D_Array_double *grad_z)
     int col, row, depth;
-    double val;
+    double val0, val1, val2;
     for (depth = 0; depth < array->sz; depth++) {
 	for (row = 0; row < array->sy; row++) {
 	    /* row start */
-	    val = RASTER3D_ARRAY_ACCESS(array, 0, row, depth);
-	    if (Rast_is_d_null_value(&val))
+	    val0 = RASTER3D_ARRAY_ACCESS(array, 0, row, depth);
+	    val1 = RASTER3D_ARRAY_ACCESS(array, 1, row, depth);
+	    val2 = RASTER3D_ARRAY_ACCESS(array, 2, row, depth);
+	    if (Rast_is_d_null_value(&val0))
 		Rast_set_null_value(&RASTER3D_ARRAY_ACCESS(grad_x, 0, row, depth),
 				    1, DCELL_TYPE);
+	    else if (Rast_is_d_null_value(&val1) || Rast_is_d_null_value(&val2))
+		RASTER3D_ARRAY_ACCESS(grad_x, 0, row, depth) = 0;
 	    else
-			(-3 * val + 4 * RASTER3D_ARRAY_ACCESS(array, 1, row, depth) -
-			 RASTER3D_ARRAY_ACCESS(array, 2, row, depth)) / (2 * step[0]);
+			(-3 * val0 + 4 * val1 - val2) / (2 * step[0]);
 	    /* row end */
-	    val = RASTER3D_ARRAY_ACCESS(array, array->sx - 1, row, depth);
+	    val0 = RASTER3D_ARRAY_ACCESS(array, array->sx - 3, row, depth);
+	    val1 = RASTER3D_ARRAY_ACCESS(array, array->sx - 2, row, depth);
+	    val2 = RASTER3D_ARRAY_ACCESS(array, array->sx - 1, row, depth);
+	    if (Rast_is_d_null_value(&val2))
 			&RASTER3D_ARRAY_ACCESS(grad_x, array->sx - 1, row, depth),
 			1, DCELL_TYPE);
+	    else if (Rast_is_d_null_value(&val0) || Rast_is_d_null_value(&val1))
+		RASTER3D_ARRAY_ACCESS(grad_x, array->sx - 1, row, depth) = 0;
 	    else
-			(3 * val - 4 * RASTER3D_ARRAY_ACCESS(array, array->sx - 2, row, depth) +
-			 RASTER3D_ARRAY_ACCESS(array, array->sx - 3, row, depth)) / (2 * step[0]);
+			(3 * val2 - 4 * val1 + val0) / (2 * step[0]);
 	    /* row */
 	    for (col = 1; col < array->sx - 1; col++) {
-		val = RASTER3D_ARRAY_ACCESS(array, col, row, depth);
+		val0 = RASTER3D_ARRAY_ACCESS(array, col - 1, row, depth);
+		val1 = RASTER3D_ARRAY_ACCESS(array, col, row, depth);
+		val2 = RASTER3D_ARRAY_ACCESS(array, col + 1, row, depth);
+		if (Rast_is_d_null_value(&val1))
 			    &RASTER3D_ARRAY_ACCESS(grad_x, col, row, depth),
 			    1, DCELL_TYPE);
+		else if (Rast_is_d_null_value(&val0) || Rast_is_d_null_value(&val2))
+		    RASTER3D_ARRAY_ACCESS(grad_x, col, row, depth) = 0;
 		else
-			    (RASTER3D_ARRAY_ACCESS(array, col + 1, row, depth) -
-			     RASTER3D_ARRAY_ACCESS(array, col - 1, row, depth)) / (2 * step[0]);
+			    (val2 - val0) / (2 * step[0]);
 	for (col = 0; col < array->sx; col++) {
 	    /* col start */
-	    val = RASTER3D_ARRAY_ACCESS(array, col, 0, depth);
+	    val0 = RASTER3D_ARRAY_ACCESS(array, col, 0, depth);
+	    val1 = RASTER3D_ARRAY_ACCESS(array, col, 1, depth);
+	    val2 = RASTER3D_ARRAY_ACCESS(array, col, 2, depth);
 		Rast_set_null_value(&RASTER3D_ARRAY_ACCESS(grad_y, col, 0, depth),
 				    1, DCELL_TYPE);
+		RASTER3D_ARRAY_ACCESS(grad_y, col, 0, depth) = 0;
 	    else
-			-(-3 * val + 4 * RASTER3D_ARRAY_ACCESS(array, col, 1, depth) -
-			  RASTER3D_ARRAY_ACCESS(array, col, 2, depth)) / (2 * step[1]);
+			-(-3 * val0 + 4 * val1 - val2) / (2 * step[1]);
 	    /* col end */
-	    val = RASTER3D_ARRAY_ACCESS(array, col, array->sy - 1, depth);
+	    val0 = RASTER3D_ARRAY_ACCESS(array, col, array->sy - 3, depth);
+	    val1 = RASTER3D_ARRAY_ACCESS(array, col, array->sy - 2, depth);
+	    val2 = RASTER3D_ARRAY_ACCESS(array, col, array->sy - 1, depth);
 			&RASTER3D_ARRAY_ACCESS(grad_y, col, array->sy - 1, depth),
 			1, DCELL_TYPE);
+		RASTER3D_ARRAY_ACCESS(grad_y, col, array->sy - 1, depth) = 0;
 	    else
-			-(3 * val - 4 * RASTER3D_ARRAY_ACCESS(array, col, array->sy - 2, depth) +
-			  RASTER3D_ARRAY_ACCESS(array, col, array->sy - 3, depth)) / (2 * step[1]);
+			-(3 * val2 - 4 * val1 + val0) / (2 * step[1]);
 	    /* col */
 	    for (row = 1; row < array->sy - 1; row++) {
+		val0 = RASTER3D_ARRAY_ACCESS(array, col, row - 1, depth);
+		val2 = RASTER3D_ARRAY_ACCESS(array, col, row + 1, depth);
 			    &RASTER3D_ARRAY_ACCESS(grad_y, col, row, depth),
 			    1, DCELL_TYPE);
+		    RASTER3D_ARRAY_ACCESS(grad_y, col, row, depth) = 0;
 		else
-			    -(RASTER3D_ARRAY_ACCESS(array, col, row + 1, depth) -
-			      RASTER3D_ARRAY_ACCESS(array, col, row - 1, depth)) / (2 * step[1]);
+			    -(val2 - val0) / (2 * step[1]);
 	    /* vertical col start */
-	    val = RASTER3D_ARRAY_ACCESS(array, col, row, 0);
+	    val0 = RASTER3D_ARRAY_ACCESS(array, col, row, 0);
+	    val1 = RASTER3D_ARRAY_ACCESS(array, col, row, 1);
+	    val2 = RASTER3D_ARRAY_ACCESS(array, col, row, 2);
 		Rast_set_null_value(&RASTER3D_ARRAY_ACCESS(grad_z, col, row, 0),
 				    1, DCELL_TYPE);
+		RASTER3D_ARRAY_ACCESS(grad_z, col, row, 0) = 0;
 	    else
-			(-3 * val + 4 * RASTER3D_ARRAY_ACCESS(array, col, row, 1) -
-			 RASTER3D_ARRAY_ACCESS(array, col, row, 2)) / (2 * step[2]);
+			(-3 * val0 + 4 * val1 - val2) / (2 * step[2]);
 	    /* vertical col end */
-	    val = RASTER3D_ARRAY_ACCESS(array, col, row, array->sz - 1);
+	    val0 = RASTER3D_ARRAY_ACCESS(array, col, row, array->sz - 3);
+	    val1 = RASTER3D_ARRAY_ACCESS(array, col, row, array->sz - 2);
+	    val2 = RASTER3D_ARRAY_ACCESS(array, col, row, array->sz - 1);
 			&RASTER3D_ARRAY_ACCESS(grad_z, col, row, array->sz - 1),
 			1, DCELL_TYPE);
+		RASTER3D_ARRAY_ACCESS(grad_z, col, row, array->sz - 1) = 0;
 	    else
-			(3 * val - 4 * RASTER3D_ARRAY_ACCESS(array, col, row, array->sz - 2) +
-			 RASTER3D_ARRAY_ACCESS(array, col, row, array->sz - 3)) / (2 * step[2]);
+			(3 * val2 - 4 * val1 + val0) / (2 * step[2]);
 	    /* vertical col */
 	    for (depth = 1; depth < array->sz - 1; depth++) {
+		val0 = RASTER3D_ARRAY_ACCESS(array, col, row, depth - 1);
+		val2 = RASTER3D_ARRAY_ACCESS(array, col, row, depth + 1);
 			    &RASTER3D_ARRAY_ACCESS(grad_z, col, row, depth),
 			    1, DCELL_TYPE);
+		    RASTER3D_ARRAY_ACCESS(grad_z, col, row, depth) = 0;
 		else
-			    (RASTER3D_ARRAY_ACCESS(array, col, row, depth + 1) -
-			     RASTER3D_ARRAY_ACCESS(array, col, row, depth - 1)) / (2 * step[2]);
+			    (val2 - val0) / (2 * step[2]);
