[GRASS-SVN] r61570 - grass-addons/grass7/raster3d/r3.gradient/testsuite
svn_grass at osgeo.org
Fri Aug 8 14:32:09 PDT 2014
Author: annakrat
Date: 2014-08-08 14:32:09 -0700 (Fri, 08 Aug 2014)
New Revision: 61570
grass-addons/grass7/raster3d/r3.gradient/testsuite/r3gradient_test.py
r3.gradient: add test for handling nulls
Modified: grass-addons/grass7/raster3d/r3.gradient/testsuite/r3gradient_test.py
--- grass-addons/grass7/raster3d/r3.gradient/testsuite/r3gradient_test.py 2014-08-08 21:31:07 UTC (rev 61569)
+++ grass-addons/grass7/raster3d/r3.gradient/testsuite/r3gradient_test.py 2014-08-08 21:32:09 UTC (rev 61570)
@@ -53,7 +53,52 @@
sum=20.187449647
+r3univar_test_nulls_grad_x = """
+n=107
+null_cells=18
+cells=125
+min=0
+max=10
+range=10
+mean=3.70093457943925
+mean_of_abs=3.70093457943925
+stddev=3.6357902977452
+variance=13.2189710891781
+coeff_var=98.2397883481656
+sum=396
+r3univar_test_nulls_grad_y = """
+n=107
+null_cells=18
+cells=125
+min=-10
+max=0
+range=10
+mean=-3.70093457943925
+coeff_var=-98.2397883481656
+sum=-396
+r3univar_test_nulls_grad_z = """
+n=107
+null_cells=18
+cells=125
+min=0
+max=10
+range=10
+sum=396
class GradientTest(TestCase):
@classmethod
@@ -61,22 +106,27 @@
"""Use temporary region settings"""
cls.use_temp_region()
cls.runModule('g.region', res3=10, n=100, s=0, w=0, e=120, b=0, t=50)
- cls.runModule('r3.in.ascii', input='data/test_map_1', output='test_map_1_ref', overwrite=True)
+ cls.runModule('r3.in.ascii', input='data/test_map_1', output='test_map_1_ref')
+ cls.runModule('g.region', res3=1, n=5, s=0, w=0, e=5, b=0, t=5)
+ cls.runModule('r3.in.ascii', input='data/test_map_2', output='test_map_2_ref')
@classmethod
def tearDownClass(cls):
"""!Remove the temporary region"""
cls.del_temp_region()
- cls.runModule('g.remove', rast3d=['test_map_1_ref', 'test_grad_x',
- 'test_grad_y', 'test_grad_z'])
+ cls.runModule('g.remove', rast3d=['test_map_1_ref', 'test_map_2_ref', 'test_grad_x',
+ 'test_grad_y', 'test_grad_z', 'test_null_grad_x',
+ 'test_null_grad_y', 'test_null_grad_z'])
def test_gradient_runs(self):
+ self.runModule('g.region', res3=10, n=100, s=0, w=0, e=120, b=0, t=50)
self.assertModuleFail('r3.gradient', input='test_map_1_ref',
output=['test_grad_x', 'test_grad_y'], overwrite=True)
self.assertModule('r3.gradient', input='test_map_1_ref',
output=['test_grad_x', 'test_grad_y', 'test_grad_z'], overwrite=True)
def test_gradient(self):
self.runModule('r3.gradient', input='test_map_1_ref',
self.assertRaster3dFitsUnivar(raster='test_grad_x', reference=r3univar_test_grad_x, precision=1e-8)
@@ -84,6 +134,7 @@
self.assertRaster3dFitsUnivar(raster='test_grad_z', reference=r3univar_test_grad_z, precision=1e-8)
def test_gradient_block(self):
self.assertModule('r3.gradient', input='test_map_1_ref', block_size=[200, 2, 50],
@@ -91,12 +142,24 @@
def test_gradient_procs(self):
self.assertModule('r3.gradient', input='test_map_1_ref', block_size=[200, 2, 50], nprocs=3,
self.assertRaster3dFitsUnivar(raster='test_grad_y', reference=r3univar_test_grad_y, precision=1e-8)
+ def test_gradient_nulls(self):
+ self.runModule('g.region', res3=1, n=5, s=0, w=0, e=5, b=0, t=5)
+ self.assertModule('r3.gradient', input='test_map_2_ref', block_size=[200, 2, 50], nprocs=3,
+ output=['test_null_grad_x', 'test_null_grad_y', 'test_null_grad_z'])
+ self.assertRaster3dFitsUnivar(raster='test_null_grad_x',
+ reference=r3univar_test_nulls_grad_x, precision=1e-8)
+ self.assertRaster3dFitsUnivar(raster='test_null_grad_y',
+ reference=r3univar_test_nulls_grad_y, precision=1e-8)
+ self.assertRaster3dFitsUnivar(raster='test_null_grad_z',
+ reference=r3univar_test_nulls_grad_z, precision=1e-8)
if __name__ == '__main__':
test()
