[GRASS-SVN] r61583 - grass/branches/releasebranch_6_4/locale/po
Mon Aug 11 03:14:22 PDT 2014
Author: neteler
Date: 2014-08-11 03:14:22 -0700 (Mon, 11 Aug 2014)
New Revision: 61583
   grass/branches/releasebranch_6_4/locale/po/grasslibs_de.po
   grass/branches/releasebranch_6_4/locale/po/grassmods_de.po
   grass/branches/releasebranch_6_4/locale/po/grassnviz_de.po
   grass/branches/releasebranch_6_4/locale/po/grasswxpy_de.po
Robert Nuske: DE translation cont'ed)
Modified: grass/branches/releasebranch_6_4/locale/po/grasslibs_de.po
--- grass/branches/releasebranch_6_4/locale/po/grasslibs_de.po	2014-08-11 09:44:09 UTC (rev 61582)
+++ grass/branches/releasebranch_6_4/locale/po/grasslibs_de.po	2014-08-11 10:14:22 UTC (rev 61583)
@@ -1,27 +1,27 @@
 # translation of grasslibs_de.po to Deutsch
 # This file is distributed under the same license as the GRASS package.
-# Copyright (C) 2004-2013 GRASS Development Team
+# Copyright (C) 2004-2014 GRASS Development Team
 # Markus Neteler <neteler itc.it>, 2004.
 # Stephan Holl <holl gdf-hannover.de>, 2004, 2005, 2006.
 # Stephan Holl <stephan.holl intevation.de>, 2007.
 # Markus Neteler <neteler osgeo.org>, 2008.
-# Robert Nuske <robert.nuske nw-fva.de>, 2009, 2010, 2011, 2012, 2013.
+# Robert Nuske <robert.nuske nw-fva.de>, 2009, 2010, 2011, 2012, 2013, 2014.
 # Helmut Kudrnovsky <hellik web.de>, 2011.
 msgid ""
 msgstr ""
 "Project-Id-Version: grasslibs_de\n"
 "Report-Msgid-Bugs-To: \n"
 "POT-Creation-Date: 2014-05-20 18:01+0200\n"
-"PO-Revision-Date: 2014-03-24 13:45+0100\n"
-"Last-Translator: Helmut Kudrnovsky <hellik at web.de>\n"
+"PO-Revision-Date: 2014-08-10 13:37+0200\n"
+"Last-Translator: Robert Nuske <robert.nuske at nw-fva.de>\n"
 "Language-Team: German <grass-translations at lists.osgeo.org>\n"
 "Language: de\n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
 "Plural-Forms: nplurals=2; plural=(n != 1);\n"
-"X-Generator: Poedit 1.6.4\n"
+"X-Generator: Lokalize 1.5\n"
 #: ../lib/driver/command.c:508
 #, c-format
@@ -40,9 +40,7 @@
 #: ../lib/driver/parse_ftcap.c:32
 #, c-format
 msgid "%s: Unable to read font definition file; use the default"
-msgstr ""
-"%s: Kann die Font-Definitionsdatei nicht lesen. Verwende die "
-"Standardeinstellung."
+msgstr "%s: Kann die Font-Definitionsdatei nicht lesen. Verwende die Standardeinstellung."
 #: ../lib/driver/parse_ftcap.c:38
 #, c-format
@@ -65,8 +63,7 @@
 #: ../lib/db/dbmi_base/legal_dbname.c:25
 #, c-format
 msgid "Illegal table map name <%s>. May not contain '.' or 'NULL'.\n"
-msgstr ""
-"Ungültiger Tabellenname <%s>. Er darf weder '.' noch 'NULL' enthalten.\n"
+msgstr "Ungültiger Tabellenname <%s>. Er darf weder '.' noch 'NULL' enthalten.\n"
 #: ../lib/db/dbmi_base/legal_dbname.c:33
 #, c-format
@@ -76,8 +73,7 @@
 #: ../lib/db/dbmi_base/legal_dbname.c:43
 #, c-format
 msgid "Illegal table map name <%s>. Character <%c> not allowed.\n"
-msgstr ""
-"Ungültiger Name für Vektorkarte <%s>. Zeichen <%c> ist nicht erlaubt.\n"
+msgstr "Ungültiger Name für Vektorkarte <%s>. Zeichen <%c> ist nicht erlaubt.\n"
 #: ../lib/db/dbmi_client/copy_tab.c:100 ../lib/db/dbmi_client/copy_tab.c:120
 #: ../lib/db/dbmi_client/db.c:41
@@ -193,12 +189,8 @@
 msgstr "Speicherfehler beim reservieren des Zeitstempel."
 #: ../lib/sites/sites.c:348 ../lib/sites/sites.c:478
-msgid ""
-"Dev note: Adapted sites library used for vector points. (module should be "
-"updated to GRASS 6 vector library)"
-msgstr ""
-"Dev note: Angepasste sites Bibliothek für Vektorpunkte verwendet. (Modul "
-"sollte für die GRASS 6 Vector Library aktualisiert werden)."
+msgid "Dev note: Adapted sites library used for vector points. (module should be updated to GRASS 6 vector library)"
+msgstr "Dev note: Angepasste sites Bibliothek für Vektorpunkte verwendet. (Modul sollte für die GRASS 6 Vector Library aktualisiert werden)."
 #: ../lib/sites/sites.c:397
 msgid "Cannot fetch row"
@@ -383,9 +375,7 @@
 #: ../lib/gis/get_row.c:46 ../lib/gis/get_row.c:1048
 #, c-format
 msgid "Reading raster map <%s@%s> request for row %d is outside region"
-msgstr ""
-"Die Leseanfrage der Rasterkarte <%s@%s> für Zeile %d ist außerhalb der "
-"Region."
+msgstr "Die Leseanfrage der Rasterkarte <%s@%s> für Zeile %d ist außerhalb der Region."
 #: ../lib/gis/get_row.c:324
 #, c-format
@@ -414,7 +404,7 @@
 #: ../lib/gis/get_row.c:1114
 msgid "Unable to realloc buffer"
-msgstr "Kann Buffer nicht wieder reservieren."
+msgstr "Kann Puffer nicht wieder reservieren."
 #: ../lib/gis/get_window.c:67 ../lib/gis/get_window.c:85
 #, c-format
@@ -465,12 +455,8 @@
 #: ../lib/gis/opencell.c:188
 #, c-format
-msgid ""
-"Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@"
-"%s> which does not exist"
-msgstr ""
-"Kann die Rasterkarte <%s@%s> nicht öffnen, weil es eine Reklassifizierung "
-"der Rasterkarte <%s@%s> ist, welche nicht existiert."
+msgid "Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@%s> which does not exist"
+msgstr "Kann die Rasterkarte <%s@%s> nicht öffnen, weil es eine Reklassifizierung der Rasterkarte <%s@%s> ist, welche nicht existiert."
 #: ../lib/gis/opencell.c:212
 #, c-format
@@ -479,19 +465,13 @@
 #: ../lib/gis/opencell.c:219
 #, c-format
-msgid ""
-"Raster map <%s@%s> is in different projection than current region. Found "
-"raster map <%s@%s>, should be <%s>."
-msgstr ""
-"Rasterkarte <%s@%s> ist in einer anderen Projektion als die aktuelle Region. "
-"Habe Rasterkarte <%s@%s> gefunden, sollte <%s> sein."
+msgid "Raster map <%s@%s> is in different projection than current region. Found raster map <%s@%s>, should be <%s>."
+msgstr "Rasterkarte <%s@%s> ist in einer anderen Projektion als die aktuelle Region. Habe Rasterkarte <%s@%s> gefunden, sollte <%s> sein."
 #: ../lib/gis/opencell.c:226
 #, c-format
 msgid "Raster map <%s@%s> is in different zone (%d) than current region (%d)"
-msgstr ""
-"Rasterkarte <%s@%s> ist in einer anderen Zone (%d) als die aktuelle Region "
-"(%d)."
+msgstr "Rasterkarte <%s@%s> ist in einer anderen Zone (%d) als die aktuelle Region (%d)."
 #: ../lib/gis/opencell.c:233
 #, c-format
@@ -501,9 +481,7 @@
 #: ../lib/gis/opencell.c:262
 #, c-format
 msgid "map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
-msgstr ""
-"Karte <%s@%s> ist eine GDAL-Verknüpfung, aber GRASS wurde ohne GDAL-"
-"Unterstützung kompiliert."
+msgstr "Karte <%s@%s> ist eine GDAL-Verknüpfung, aber GRASS wurde ohne GDAL-Unterstützung kompiliert."
 #: ../lib/gis/opencell.c:642
 #, c-format
@@ -521,16 +499,13 @@
 msgstr "<%s>: schlechtes Mapset"
 #: ../lib/gis/opencell.c:666
-#, fuzzy, c-format
+#, c-format
 msgid "No temp files available: %s"
-msgstr "Keine %s Dateien in Mapset <%s> vorhanden.\n"
+msgstr "Keine temp Dateien vorhanden: %s"
 #: ../lib/gis/opencell.c:736
-msgid ""
-"Unable to write embedded null values for raster map open for random access"
-msgstr ""
-"Kann eingebettete NULL-Werte nicht schreiben für Rasterkarten geöffnet für "
-"den direkten Zugriff."
+msgid "Unable to write embedded null values for raster map open for random access"
+msgstr "Kann eingebettete NULL-Werte nicht schreiben für Rasterkarten geöffnet für den direkten Zugriff."
 #: ../lib/gis/opencell.c:767
 msgid "G__open_raster_new(): no temp files available"
@@ -538,8 +513,7 @@
 #: ../lib/gis/opencell.c:941
 msgid "G_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"
-msgstr ""
-"G_set_fp_type(): kann nur mit FCELL_TYPE oder DCELL_TYPE aufgerufen werden."
+msgstr "G_set_fp_type(): kann nur mit FCELL_TYPE oder DCELL_TYPE aufgerufen werden."
 #: ../lib/gis/opencell.c:976 ../lib/gis/opencell.c:1064
 #, c-format
@@ -582,11 +556,8 @@
 msgstr "Rasterkarte <%s> ist nicht xdr: byte_order: %s"
 #: ../lib/gis/opencell.c:1179
-msgid ""
-"G_set_quant_rules() can be called only for raster maps opened for reading"
-msgstr ""
-"G_set_quant_rules() kann nur für zum Lesen geöffnete Rasterkarten aufgerufen "
-"werden."
+msgid "G_set_quant_rules() can be called only for raster maps opened for reading"
+msgstr "G_set_quant_rules() kann nur für zum Lesen geöffnete Rasterkarten aufgerufen werden."
 #: ../lib/gis/proj3.c:64 ../lib/vector/Vlib/header.c:512
 msgid "Unknown projection"
@@ -669,9 +640,7 @@
 #: ../lib/gis/get_cellhd.c:105
 #, c-format
 msgid " It is a reclass of raster map <%s@%s> whose header file is invalid."
-msgstr ""
-" Es ist eine Reklassifikation der Rasterkarte <%s@%s>, deren Header Datei "
-"ungültig ist."
+msgstr " Es ist eine Reklassifikation der Rasterkarte <%s@%s>, deren Header Datei ungültig ist."
 #: ../lib/gis/get_cellhd.c:109
 #, c-format
@@ -755,29 +724,22 @@
 #: ../lib/gis/put_row.c:215
 #, c-format
 msgid "G_put_map_row: %s is not integer! Use G_put_[f/d]_raster_row()!"
-msgstr ""
-"G_put_map_row: %s ist keine Integer-Karte! Benutzen Sie G_put_[f/"
-"d]_raster_row()!"
+msgstr "G_put_map_row: %s ist keine Integer-Karte! Benutzen Sie G_put_[f/d]_raster_row()!"
 #: ../lib/gis/put_row.c:251
 #, c-format
 msgid "%s: map [%s] not open for write - request ignored"
-msgstr ""
-"%s: Karte [%s] ist nicht zum Schreiben geöffnet - Anfrage wird ignoriert."
+msgstr "%s: Karte [%s] ist nicht zum Schreiben geöffnet - Anfrage wird ignoriert."
 #: ../lib/gis/put_row.c:259
 #, c-format
 msgid "%s: map [%s] not open for random write - request ignored"
-msgstr ""
-"%s Karte [%s] ist nicht zum zufälligen Schreiben geöffnet - Anfrage wird "
-"ignoriert."
+msgstr "%s Karte [%s] ist nicht zum zufälligen Schreiben geöffnet - Anfrage wird ignoriert."
 #: ../lib/gis/put_row.c:266
 #, c-format
 msgid "%s: map [%s] not open for sequential write - request ignored"
-msgstr ""
-"%s: Karte [%s] ist nicht für sequentielles Schreiben geöffnet - Anfrage wird "
-"ignoriert."
+msgstr "%s: Karte [%s] ist nicht für sequentielles Schreiben geöffnet - Anfrage wird ignoriert."
 #: ../lib/gis/put_row.c:270
 #, c-format
@@ -855,8 +817,7 @@
 #: ../lib/gis/reclass.c:148
 #, c-format
 msgid "Illegal reclass format in header file for [%s in %s]"
-msgstr ""
-"Ungültiges Reklassifizierungs-Format in der Header-Datei von [%s in %s]."
+msgstr "Ungültiges Reklassifizierungs-Format in der Header-Datei von [%s in %s]."
 #: ../lib/gis/reclass.c:238
 msgid "Illegal reclass request"
@@ -877,13 +838,9 @@
 msgstr "Kann Abhängigkeitsdatei in [%s in %s] nicht anlegen."
 #: ../lib/gis/gisinit.c:54 ../lib/gis/gisinit.c:92
-#, fuzzy, c-format
-msgid ""
-"Module built against version %s but trying to use version %s. You need to "
-"rebuild GRASS GIS or untangle multiple installations."
-msgstr ""
-"Version der Bibliothek ist inkompatible mit Modul. Sie müssen GRASS erneut "
-"bauen oder verschiedene Installationen entwirren."
+#, c-format
+msgid "Module built against version %s but trying to use version %s. You need to rebuild GRASS GIS or untangle multiple installations."
+msgstr "Das Module wurde mit Version %s gebaut, aber versucht Version %s zu verwenden. Sie müssen GRASS erneut bauen oder verschiedene Installationen entwirren."
 #: ../lib/gis/gisinit.c:65
 #, c-format
@@ -897,9 +854,7 @@
 #: ../lib/gis/gisinit.c:113
 msgid "System not initialized. Programmer forgot to call G_gisinit()."
-msgstr ""
-"System ist nicht initialisiert. Der Programmierer hat vergessen G_gisinit() "
-"aufzurufen."
+msgstr "System ist nicht initialisiert. Der Programmierer hat vergessen G_gisinit() aufzurufen."
 #: ../lib/gis/get_projinfo.c:33 ../lib/gis/get_projinfo.c:60
 #, c-format
@@ -924,8 +879,7 @@
 #: ../lib/gis/history.c:132 ../lib/g3d/g3dhistory.c:42
 #, c-format
 msgid "can't get history information for [%s] in mapset [%s]"
-msgstr ""
-"Kann die History-Informationen der Karte [%s] in Mapset [%s] nicht lesen."
+msgstr "Kann die History-Informationen der Karte [%s] in Mapset [%s] nicht lesen."
 #: ../lib/gis/history.c:180
 #, c-format
@@ -934,13 +888,11 @@
 #: ../lib/gis/history.c:263
 msgid "Not enough room in history file to record command line."
-msgstr ""
-"Nicht genügend Platz in der History-Datei, um die Kommandozeile zu speichern."
+msgstr "Nicht genügend Platz in der History-Datei, um die Kommandozeile zu speichern."
 #: ../lib/gis/history.c:285
 msgid "Not enough room in history file for command line (truncated)."
-msgstr ""
-"Nicht genügend Platz in der History-Datei für die Kommandozeile (gekürzt)."
+msgstr "Nicht genügend Platz in der History-Datei für die Kommandozeile (gekürzt)."
 #: ../lib/gis/mapset_msc.c:60
 #, c-format
@@ -1209,12 +1161,8 @@
 #: ../lib/gis/distance.c:160
 #, c-format
-msgid ""
-"G_distance_point_to_line_segment: shouldn't happen: code=%d P=(%f,%f) S=(%f,"
-"%f)(%f,%f)"
-msgstr ""
-"G_distance_point_to_line_segment: sollte nicht vorkommen: Code=%d P=(%f,%f) "
-"S=(%f,%f)(%f,%f)"
+msgid "G_distance_point_to_line_segment: shouldn't happen: code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
+msgstr "G_distance_point_to_line_segment: sollte nicht vorkommen: Code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
 #: ../lib/gis/ask.c:341
 msgid "to cancel request"
@@ -1238,8 +1186,7 @@
 #: ../lib/gis/ask.c:421
 #, c-format
 msgid "Enter 'list' for a list of existing %s files\n"
-msgstr ""
-"Geben Sie 'list' für eine Liste der bereits existierenden %s Dateien ein.\n"
+msgstr "Geben Sie 'list' für eine Liste der bereits existierenden %s Dateien ein.\n"
 #: ../lib/gis/ask.c:424
 #, c-format
@@ -1319,12 +1266,8 @@
 msgstr "Andere Projektion"
 #: ../lib/gis/set_window.c:76
-msgid ""
-"G_set_window(): projection/zone differs from that of currently open raster "
-"maps"
-msgstr ""
-"G_set_window(): Projektion/Zone unterscheidet sich von gerade geöffneten "
-"Rasterkarten."
+msgid "G_set_window(): projection/zone differs from that of currently open raster maps"
+msgstr "G_set_window(): Projektion/Zone unterscheidet sich von gerade geöffneten Rasterkarten."
 #: ../lib/gis/get_ellipse.c:85
 #, c-format
@@ -1610,17 +1553,12 @@
 #: ../lib/gis/view.c:546
 #, c-format
 msgid " Window saved in \"%s\" is completely outside of current GRASS window."
-msgstr ""
-" Das in \"%s\" abgespeicherte Fenster ist komplett außerhalb des derzeitigen "
-"GRASS Fensters."
+msgstr " Das in \"%s\" abgespeicherte Fenster ist komplett außerhalb des derzeitigen GRASS Fensters."
 #: ../lib/gis/view.c:550
 #, c-format
-msgid ""
-" Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
-msgstr ""
-" Nur %d%% des in \"%s\" abgespeicherten Fensters überlappt mit dem "
-"derzeitigen GRASS-Fenster."
+msgid " Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
+msgstr " Nur %d%% des in \"%s\" abgespeicherten Fensters überlappt mit dem derzeitigen GRASS-Fenster."
 #: ../lib/gis/parser.c:340
 msgid "WHERE conditions of SQL statement without 'where' keyword"
@@ -1719,12 +1657,8 @@
 msgstr "Layer-Nummer"
 #: ../lib/gis/parser.c:596
-msgid ""
-"A single vector map can be connected to multiple database tables. This "
-"number determines which table to use."
-msgstr ""
-"Eine einzelne Vektorkarte kann mit mehreren Datenbanktabellen verbunden "
-"sein. Diese Zahl bestimmt welche Tabelle verwendet werden soll."
+msgid "A single vector map can be connected to multiple database tables. This number determines which table to use."
+msgstr "Eine einzelne Vektorkarte kann mit mehreren Datenbanktabellen verbunden sein. Diese Zahl bestimmt welche Tabelle verwendet werden soll."
 #: ../lib/gis/parser.c:605
 msgid "Category value"
@@ -1785,15 +1719,11 @@
 #: ../lib/gis/parser.c:926
 msgid "Use either --quiet or --verbose flag, not both. Assuming --verbose."
-msgstr ""
-"Verwenden Sie entweder --quiet oder --verbose, aber nicht beide. Verwende --"
-"verbose."
+msgstr "Verwenden Sie entweder --quiet oder --verbose, aber nicht beide. Verwende --verbose."
 #: ../lib/gis/parser.c:940
 msgid "Use either --quiet or --verbose flag, not both. Assuming --quiet."
-msgstr ""
-"quiet."
+msgstr "Verwenden Sie entweder --quiet oder --verbose, aber nicht beide. Verwende --quiet."
 #: ../lib/gis/parser.c:971
 #, c-format
@@ -2407,8 +2337,7 @@
 #: ../lib/rst/interp_float/vinput2d.c:328
 #, c-format
 msgid "There are points outside specified 2D/3D region - %d points ignored"
-msgstr ""
-"Es gibt Punkte außerhalb der angegebenen 2D/3D-Region - ignoriere %d Punkte."
+msgstr "Es gibt Punkte außerhalb der angegebenen 2D/3D-Region - ignoriere %d Punkte."
 #: ../lib/rst/interp_float/vinput2d.c:331
 #, c-format
@@ -2417,12 +2346,8 @@
 #: ../lib/rst/interp_float/vinput2d.c:335
 #, c-format
-msgid ""
-"%d points given for interpolation (after thinning) is less than given NPMIN="
-"%d"
-msgstr ""
-"%d Punkte, die (nach Ausdünnung) zur Verfügung stehen, sind weniger als die "
-"angegebenen NPMIN=%d."
+msgid "%d points given for interpolation (after thinning) is less than given NPMIN=%d"
+msgstr "%d Punkte, die (nach Ausdünnung) zur Verfügung stehen, sind weniger als die angegebenen NPMIN=%d."
 #: ../lib/rst/interp_float/vinput2d.c:340
 msgid "Zero points in the given region"
@@ -2430,22 +2355,13 @@
 #: ../lib/rst/interp_float/vinput2d.c:345
 #, c-format
-msgid ""
-"Segmentation parameters set to invalid values: npmin= %d, segmax= %d for "
-"smooth connection of segments, npmin > segmax (see manual)"
-msgstr ""
-"Segmentation-Parameter mit ungültigen Werten: npmin= %d, segmax= %d zum "
-"glatten Aneinandersetzen der Segmente, npmin > segmax (siehe Handbuch)."
+msgid "Segmentation parameters set to invalid values: npmin= %d, segmax= %d for smooth connection of segments, npmin > segmax (see manual)"
+msgstr "Segmentation-Parameter mit ungültigen Werten: npmin= %d, segmax= %d zum glatten Aneinandersetzen der Segmente, npmin > segmax (siehe Handbuch)."
 #: ../lib/rst/interp_float/vinput2d.c:351
 #, c-format
-msgid ""
-"There are less than %d points for interpolation. No segmentation is "
-"necessary, to run the program faster set segmax=%d (see manual)"
-msgstr ""
-"Es gibt weniger als %d Punkte für die Interpolation. Keine Segmentierung "
-"notwendig. Um das Programm schneller laufen zu lassen, setzen Sie segmax = "
-"%d (siehe Handbuch)."
+msgid "There are less than %d points for interpolation. No segmentation is necessary, to run the program faster set segmax=%d (see manual)"
+msgstr "Es gibt weniger als %d Punkte für die Interpolation. Keine Segmentierung notwendig. Um das Programm schneller laufen zu lassen, setzen Sie segmax = %d (siehe Handbuch)."
 #: ../lib/rst/interp_float/vinput2d.c:355
 #, c-format
@@ -2510,21 +2426,12 @@
 #: ../lib/rst/interp_float/interp2d.c:212
 #, c-format
-msgid ""
-"Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) "
-"cell. Z-value %f, zmin %f, zmax %f."
-msgstr ""
-"Overshoot - Erhöhung der Spannung empfohlen. Overshoot bei Zelle (%d,%d). Z-"
-"value %f, zmin %f, zmax %f."
+msgid "Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) cell. Z-value %f, zmin %f, zmax %f."
+msgstr "Overshoot - Erhöhung der Spannung empfohlen. Overshoot bei Zelle (%d,%d). Z-value %f, zmin %f, zmax %f."
 #: ../lib/rst/interp_float/segmen2d.c:111
-msgid ""
-"Taking too long to find points for interpolation - please change the region "
-"to area where your points are. Continuing calculations..."
-msgstr ""
-"Es dauert zu lange Punkte für die Interpolation zu finden. Bitte ändern Sie "
-"die Region auf den Bereich, in der ihre Punkte sind. Fahre mit der "
-"Berechnung fort..."
+msgid "Taking too long to find points for interpolation - please change the region to area where your points are. Continuing calculations..."
+msgstr "Es dauert zu lange Punkte für die Interpolation zu finden. Bitte ändern Sie die Region auf den Bereich, in der ihre Punkte sind. Fahre mit der Berechnung fort..."
 #: ../lib/gpde/N_solvers_krylov.c:78 ../lib/gpde/N_solvers_krylov.c:255
 #: ../lib/gpde/N_solvers_krylov.c:423 ../lib/gpde/N_solvers_krylov.c:832
@@ -2576,9 +2483,7 @@
 #: ../lib/gpde/N_solvers.c:50
 msgid "The gauss elimination solver does not work with sparse matrices"
-msgstr ""
-"Der Gaußsche Eliminierungslöser kann keine dünnbesetzten Matrizen "
-"verarbeiten."
+msgstr "Der Gaußsche Eliminierungslöser kann keine dünnbesetzten Matrizen verarbeiten."
 #: ../lib/gpde/N_solvers.c:60
 msgid "Starting direct gauss elimination solver"
@@ -2601,8 +2506,7 @@
 msgstr "Starte Cholesky Dekompositions-Löser."
 #: ../lib/gpde/N_parse_options.c:59
-msgid ""
-"The type of solver which should solve the symmetric linear equation system"
+msgid "The type of solver which should solve the symmetric linear equation system"
 msgstr "Der Solver, der das symmetrische lineare Gleichungssystem lösen soll"
 #: ../lib/gpde/N_parse_options.c:71
@@ -2614,18 +2518,12 @@
 msgstr "Maximale Anzahl Iterationen, zum Lösen des linearen Gleichungssystems"
 #: ../lib/gpde/N_parse_options.c:89
-msgid ""
-"Error break criteria for iterative solvers (jacobi, sor, cg or bicgstab)"
-msgstr ""
-"Fehlerabbruchkriterien für iterative Löser (jacobi, sor, cg or bicgstab)"
+msgid "Error break criteria for iterative solvers (jacobi, sor, cg or bicgstab)"
+msgstr "Fehlerabbruchkriterien für iterative Löser (jacobi, sor, cg or bicgstab)"
 #: ../lib/gpde/N_parse_options.c:98
-msgid ""
-"The relaxation parameter used by the jacobi and sor solver for speedup or "
-"stabilizing"
-msgstr ""
-"Entspannungsparameter (relaxation parameter) zur Beschleunigung oder "
-"Stabilisierung der Jacobi und SOR Löser"
+msgid "The relaxation parameter used by the jacobi and sor solver for speedup or stabilizing"
+msgstr "Entspannungsparameter (relaxation parameter) zur Beschleunigung oder Stabilisierung der Jacobi und SOR Löser"
 #: ../lib/gpde/N_parse_options.c:106
 msgid "The calculation time in seconds"
@@ -3115,17 +3013,13 @@
 #: ../lib/proj/convert.c:127
 #, c-format
-msgid ""
-"OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
-msgstr ""
-"OGR kann die Zeichenkette im PROJ.4-Stil '%s' nicht interpretieren (OGR "
-"Fehler-Code %d)."
+msgid "OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
+msgstr "OGR kann die Zeichenkette im PROJ.4-Stil '%s' nicht interpretieren (OGR Fehler-Code %d)."
 #: ../lib/proj/convert.c:133
 #, c-format
 msgid "OGR can't get WKT-style parameter string (OGR Error code was %d)"
-msgstr ""
-"OGR kann die Zeichenkette im WKT-Stil nicht bekommen (OGR Fehler-Code %d)."
+msgstr "OGR kann die Zeichenkette im WKT-Stil nicht bekommen (OGR Fehler-Code %d)."
 #: ../lib/proj/convert.c:390
 msgid "No projection name! Projection parameters likely to be meaningless."
@@ -3138,21 +3032,13 @@
 #: ../lib/proj/convert.c:442
 #, c-format
-msgid ""
-"Datum <%s> apparently recognised by GRASS but no parameters found. You may "
-"want to look into this."
-msgstr ""
-"Datum <%s> wurde von GRASS erkannt, doch es wurden keine Parameter gefunden. "
-"Sie sollten dies genauer untersuchen."
+msgid "Datum <%s> apparently recognised by GRASS but no parameters found. You may want to look into this."
+msgstr "Datum <%s> wurde von GRASS erkannt, doch es wurden keine Parameter gefunden. Sie sollten dies genauer untersuchen."
 #: ../lib/proj/convert.c:446
 #, c-format
-msgid ""
-"Invalid transformation number %d; valid range is 1 to %d. Leaving datum "
-"transform parameters unspecified."
-msgstr ""
-"Ungültige Transformationsnummer %d; gültiger Wertebereich 1 bis %d. "
-"Datumstransformationsparameter bleiben unbestimmt."
+msgid "Invalid transformation number %d; valid range is 1 to %d. Leaving datum transform parameters unspecified."
+msgstr "Ungültige Transformationsnummer %d; gültiger Wertebereich 1 bis %d. Datumstransformationsparameter bleiben unbestimmt."
 #: ../lib/proj/datum.c:250
 msgid "Unable to open temporary file"
@@ -3235,12 +3121,8 @@
 #: ../lib/arraystats/class.c:221
 #, c-format
-msgid ""
-"There are classbreaks outside the range min-max. Number of classes reduced "
-"to %i, but using probabilities for %i classes."
-msgstr ""
-"Klassengrenzen außerhalb der min-max Spanne. Anzahl der Klassen auf %i "
-"reduziert. Verwende dennoch die Wahrscheinlichkeiten für %i Klassen. "
+msgid "There are classbreaks outside the range min-max. Number of classes reduced to %i, but using probabilities for %i classes."
+msgstr "Klassengrenzen außerhalb der min-max Spanne. Anzahl der Klassen auf %i reduziert. Verwende dennoch die Wahrscheinlichkeiten für %i Klassen. "
 #: ../lib/g3d/g3dopen.c:20
 msgid "G3d_openCellOldNoHeader: error in G3d_maskOpenOld"
@@ -3346,8 +3228,7 @@
 #: ../lib/imagery/list_subgp.c:48
 #, c-format
 msgid "subgroup <%s> of group <%s> references the following raster maps\n"
-msgstr ""
-"Untergruppe <%s> der Gruppe <%s> referenziert die folgenden Rasterkarten\n"
+msgstr "Untergruppe <%s> der Gruppe <%s> referenziert die folgenden Rasterkarten\n"
 #: ../lib/imagery/points.c:124
 #, c-format
@@ -3392,23 +3273,17 @@
 #: ../lib/imagery/fopen.c:79
 #, c-format
 msgid "Unable to create file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
-"Kann die Datei [%s] für die Untergruppe [%s] der Gruppe [%s in %s] nicht "
-"erstellen."
+msgstr "Kann die Datei [%s] für die Untergruppe [%s] der Gruppe [%s in %s] nicht erstellen."
 #: ../lib/imagery/fopen.c:101 ../lib/imagery/fopen.c:127
 #, c-format
 msgid "Unable to open file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
-"öffnen."
+msgstr "Kann die Datei [%s] für die Untergruppe [%s] der Gruppe [%s in %s] nicht öffnen."
 #: ../lib/imagery/fopen.c:116
 #, c-format
 msgid "Unable to find file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
-"finden."
+msgstr "Kann die Datei [%s] für die Untergruppe [%s] der Gruppe [%s in %s] nicht finden."
 #: ../lib/imagery/target.c:38
 #, c-format
@@ -3417,26 +3292,18 @@
 #: ../lib/imagery/sigsetfile.c:41
 #, c-format
-msgid ""
-"Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> "
-"is not current mapset"
-msgstr ""
-"Kann die Signatur-Datei <%s> für die Untergruppe <%s> der Gruppe <%s> - <%s> "
-"nicht erstellen, da es nicht im aktuellen Mapset ist."
+msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> is not current mapset"
+msgstr "Kann die Signatur-Datei <%s> für die Untergruppe <%s> der Gruppe <%s> - <%s> nicht erstellen, da es nicht im aktuellen Mapset ist."
 #: ../lib/imagery/sigsetfile.c:57
 #, c-format
 msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s>"
-msgstr ""
-"Kann die Signatur-Datei <%s> für die Untergruppe <%s> der Gruppe <%s> nicht "
-"erstellen."
+msgstr "Kann die Signatur-Datei <%s> für die Untergruppe <%s> der Gruppe <%s> nicht erstellen."
 #: ../lib/imagery/sigsetfile.c:86
 #, c-format
 msgid "Unable to open signature file <%s> for subgroup <%s> of group <%s@%s>"
-msgstr ""
-"Kann die Signatur-Datei <%s> für die Untergruppe <%s> der Gruppe <%s@%s> "
-"nicht öffnen."
+msgstr "Kann die Signatur-Datei <%s> für die Untergruppe <%s> der Gruppe <%s@%s> nicht öffnen."
 #: ../lib/cairodriver/Draw_bitmap.c:47
 msgid "Cairo_draw_bitmap: Failed to create source"
@@ -3559,9 +3426,7 @@
 #: ../lib/ogsf/gsd_img_mpeg.c:341
 msgid "Unable to deduce output format from file extension: using MPEG"
-msgstr ""
-"Kann nicht von der Dateiendung auf das Ausgabeformat schließen: verwende "
-"MPEG."
+msgstr "Kann nicht von der Dateiendung auf das Ausgabeformat schließen: verwende MPEG."
 #: ../lib/ogsf/gsd_img_mpeg.c:349
 msgid "Unable to find suitable output format"
@@ -3595,12 +3460,8 @@
 #: ../lib/ogsf/gsd_prim.c:630
 #, c-format
-msgid ""
-"gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please "
-"advise GRASS developers of this error"
-msgstr ""
-"gsd_rot(): %c ist eine ungültige Achsenbestimmung. Rotation ignoriert. "
-"Bitte, unterrichten Sie die GRASS Entwicklern über diesen Fehler."
+msgid "gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please advise GRASS developers of this error"
+msgstr "gsd_rot(): %c ist eine ungültige Achsenbestimmung. Rotation ignoriert. Bitte, unterrichten Sie die GRASS Entwicklern über diesen Fehler."
 #: ../lib/ogsf/GVL2.c:248
 #, c-format
@@ -3620,15 +3481,13 @@
 #: ../lib/ogsf/GS2.c:1651
 #, c-format
 msgid "Raster map <%s> is outside of current region. Load failed."
-msgstr ""
-"Rasterkarte <%s> ist außerhalb der aktuellen Region. Laden fehlgeschlagen."
+msgstr "Rasterkarte <%s> ist außerhalb der aktuellen Region. Laden fehlgeschlagen."
 #: ../lib/ogsf/GS2.c:1729 ../lib/ogsf/GS2.c:1735 ../lib/ogsf/GS2.c:1743
 #: ../lib/ogsf/GS2.c:1752 ../lib/ogsf/GS2.c:1760 ../lib/ogsf/GS2.c:1770
 #: ../lib/ogsf/GS2.c:1818
 msgid "GS_load_att_map(): Out of memory. Unable to load map"
-msgstr ""
-"GS_load_att_map(): Nicht genügend Arbeitsspeicher. Kann Karte nicht laden."
+msgstr "GS_load_att_map(): Nicht genügend Arbeitsspeicher. Kann Karte nicht laden."
 #: ../lib/ogsf/GS2.c:1846
 msgid "Loading failed"
@@ -3719,8 +3578,7 @@
 #: ../lib/ogsf/Gv3.c:249
 #, c-format
 msgid "No features from vector map <%s> fall within current region"
-msgstr ""
-"Keine Objekte der Vektorkarte <%s> befinden sich in der aktuellen Region."
+msgstr "Keine Objekte der Vektorkarte <%s> befinden sich in der aktuellen Region."
 #: ../lib/ogsf/Gv3.c:254
 #, c-format
@@ -3730,7 +3588,7 @@
 #: ../lib/ogsf/Gs3.c:133 ../lib/ogsf/Gs3.c:208 ../lib/ogsf/Gs3.c:366
 #: ../lib/ogsf/Gs3.c:482 ../lib/ogsf/Gs3.c:587
 msgid "Unable to allocate memory for a null buffer"
-msgstr "Kann keinen Speicher reservieren für einen NULL-Buffer."
+msgstr "Kann keinen Speicher reservieren für einen NULL-Puffer."
 #: ../lib/ogsf/Gs3.c:140 ../lib/ogsf/Gs3.c:215 ../lib/ogsf/Gs3.c:378
 #: ../lib/ogsf/Gs3.c:494 ../lib/ogsf/Gs3.c:590
@@ -3741,8 +3599,7 @@
 #: ../lib/ogsf/Gs3.c:647
 #, c-format
 msgid "Color table range doesn't match data (mincol=%d, maxcol=%d"
-msgstr ""
-"Wertebereich der Farbtabelle passt nicht zu den Daten (mincol=%d, maxcol=%d"
+msgstr "Wertebereich der Farbtabelle passt nicht zu den Daten (mincol=%d, maxcol=%d"
 #: ../lib/ogsf/Gs3.c:709 ../lib/ogsf/Gs3.c:781
 #, c-format
@@ -3751,9 +3608,7 @@
 #: ../lib/ogsf/Gs3.c:1020
 msgid "View not saved by this program,there may be some inconsistancies"
-msgstr ""
-"View wurde nicht von diesem Programm gespeichert, es können Inkonsistenzen "
-"auftreten."
+msgstr "View wurde nicht von diesem Programm gespeichert, es können Inkonsistenzen auftreten."
 #: ../lib/ogsf/Gp3.c:145 ../lib/vector/Vlib/map.c:68
 #: ../lib/vector/Vlib/map.c:84
@@ -3764,8 +3619,7 @@
 #: ../lib/ogsf/Gp3.c:206
 #, c-format
 msgid "No points from vector map <%s> fall within current region"
-msgstr ""
-"Keine Punkte der Vektorkarte <%s> befinden sich in der aktuellen Region."
+msgstr "Keine Punkte der Vektorkarte <%s> befinden sich in der aktuellen Region."
 #: ../lib/ogsf/Gp3.c:211
 #, c-format
@@ -3782,9 +3636,7 @@
 #: ../lib/ogsf/gsd_surf.c:1742
 msgid "Cut-plane points mis-match between surfaces. Check resolution(s)."
-msgstr ""
-"Schnittflächenpunkte der Oberflächen passen nicht zusammen. Überprüfen Sie "
-"die Auflösung(en)."
+msgstr "Schnittflächenpunkte der Oberflächen passen nicht zusammen. Überprüfen Sie die Auflösung(en)."
 #: ../lib/symbol/read.c:211
 #, c-format
@@ -3793,10 +3645,8 @@
 #: ../lib/symbol/read.c:259
 #, c-format
-msgid ""
-"Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
-msgstr ""
-"Falscher Symbolname: '%s' (sollte sein: Gruppe/Name oder Gruppe/Name at Mapset)."
+msgid "Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
+msgstr "Falscher Symbolname: '%s' (sollte sein: Gruppe/Name oder Gruppe/Name at Mapset)."
 #: ../lib/symbol/read.c:283
 #, c-format
@@ -3816,9 +3666,7 @@
 #: ../lib/init/lock.c:42
 msgid "Concurrent mapset locking is not supported on Windows"
-msgstr ""
-"Sperren gleichzeitiger Zugriffe auf ein Mapset ist unter Windows nicht "
-"möglich."
+msgstr "Sperren gleichzeitiger Zugriffe auf ein Mapset ist unter Windows nicht möglich."
 #: ../lib/init/lock.c:60
 #, c-format
@@ -3827,12 +3675,8 @@
 #: ../lib/vector/diglib/plus_node.c:217
 #, c-format
-msgid ""
-"Attempt to read line angle for the line which is not connected to the node: "
-"node %d, line %d"
-msgstr ""
-"Versuche den Winkel der Linie, die nicht an den Knoten angebunden ist, zu "
-"lesen: Knoten %d, Linie %d"
+msgid "Attempt to read line angle for the line which is not connected to the node: node %d, line %d"
+msgstr "Versuche den Winkel der Linie, die nicht an den Knoten angebunden ist, zu lesen: Knoten %d, Linie %d"
 #: ../lib/vector/diglib/plus_area.c:207 ../lib/vector/diglib/plus_area.c:675
 #: ../lib/vector/diglib/plus_area.c:683
@@ -3861,8 +3705,7 @@
 #: ../lib/vector/diglib/plus_area.c:394
 #, c-format
 msgid "Dead centroid %d registered for area (bug in the vector library)"
-msgstr ""
-"Toter Zentroid %d für Fläche registriert (Bug in der Vektorbibliothek)."
+msgstr "Toter Zentroid %d für Fläche registriert (Bug in der Vektorbibliothek)."
 #: ../lib/vector/diglib/plus_area.c:418
 #, c-format
@@ -3900,8 +3743,7 @@
 #: ../lib/vector/diglib/file.c:157
 msgid "Writing to file loaded to memory not supported"
-msgstr ""
-"Schreiben in eine in den Speicher geladene Datei wird nicht unterstützt. "
+msgstr "Schreiben in eine in den Speicher geladene Datei wird nicht unterstützt. "
 #: ../lib/vector/diglib/file.c:200
 msgid "Unable to load file to memory, file not open"
@@ -4041,12 +3883,8 @@
 #: ../lib/vector/Vlib/geos.c:56
 #, c-format
-msgid ""
-"Vect_read_line_geos(): feature id %d is not reasonable (max features in "
-"vector map <%s>: %d)"
-msgstr ""
-"Vect_read_line_geos(): Objekt-ID %d ist nicht sinnvoll (max. Objekte in "
-"Vektorkarte <%s>: %d)."
+msgid "Vect_read_line_geos(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
+msgstr "Vect_read_line_geos(): Objekt-ID %d ist nicht sinnvoll (max. Objekte in Vektorkarte <%s>: %d)."
 #: ../lib/vector/Vlib/geos.c:61
 msgid "only native format supported"
@@ -4065,8 +3903,7 @@
 #: ../lib/vector/Vlib/geos.c:105
 #, c-format
 msgid "Vect_read_area_geos(): unable to read isle id %d of area id %d"
-msgstr ""
-"Vect_read_area_geos(): Kann Insel-ID %d der Fläche mit ID %d nicht lesen."
+msgstr "Vect_read_area_geos(): Kann Insel-ID %d der Fläche mit ID %d nicht lesen."
 #: ../lib/vector/Vlib/geos.c:203
 #, c-format
@@ -4158,22 +3995,13 @@
 #: ../lib/vector/Vlib/open_ogr.c:157
 #, c-format
-msgid ""
-"Feature index format version %d.%d is not supported by this release. Try to "
-"rebuild topology or upgrade GRASS."
-msgstr ""
-"Objekt Indexformat Version %d.%d wird von dieser Version nicht unterstützt. "
-"Versuchen Sie die Topologie zu erneuern oder GRASS zu aktualisieren."
+msgid "Feature index format version %d.%d is not supported by this release. Try to rebuild topology or upgrade GRASS."
+msgstr "Objekt Indexformat Version %d.%d wird von dieser Version nicht unterstützt. Versuchen Sie die Topologie zu erneuern oder GRASS zu aktualisieren."
 #: ../lib/vector/Vlib/open_ogr.c:162
 #, c-format
-msgid ""
-"Your GRASS version does not fully support feature index format %d.%d of the "
-"vector. Consider to rebuild topology or upgrade GRASS."
-msgstr ""
-"Ihre GRASS Version unterstützt nicht vollständig das Objekt-Indexformat %d."
-"%d der Vektoren. Versuchen Sie die Topologie zu erneuern oder GRASS zu "
-"aktualisieren."
+msgid "Your GRASS version does not fully support feature index format %d.%d of the vector. Consider to rebuild topology or upgrade GRASS."
+msgstr "Ihre GRASS Version unterstützt nicht vollständig das Objekt-Indexformat %d.%d der Vektoren. Versuchen Sie die Topologie zu erneuern oder GRASS zu aktualisieren."
 #: ../lib/vector/Vlib/remove_areas.c:96
 msgid "Area is composed of dead boundary"
@@ -4202,12 +4030,8 @@
 msgstr "Kann Eintrag %d nicht aus dem räumlichen Index löschen."
 #: ../lib/vector/Vlib/sindex.c:127
-msgid ""
-"Unable to build spatial index from topology, vector map is not opened at "
-"topo level 2"
-msgstr ""
-"Kann keinen räumlichen Index aus der Topologie erzeugen. Vektorkarte ist "
-"nicht auf dem topo level 2 geöffnet."
+msgid "Unable to build spatial index from topology, vector map is not opened at topo level 2"
+msgstr "Kann keinen räumlichen Index aus der Topologie erzeugen. Vektorkarte ist nicht auf dem topo level 2 geöffnet."
 #: ../lib/vector/Vlib/sindex.c:168
 msgid "BUG (Vect_build_sidx_from_topo): node does not exist"
@@ -4320,21 +4144,13 @@
 #: ../lib/vector/Vlib/open_nat.c:145
 #, c-format
-msgid ""
-"Coor files of vector map <%s@%s> is larger than it should be (%ld bytes "
-"excess)"
-msgstr ""
-"Coor-Datei der Vektorkarte <%s@%s> ist größer als sie sein sollte (%ld Byte "
-"zuviel)."
+msgid "Coor files of vector map <%s@%s> is larger than it should be (%ld bytes excess)"
+msgstr "Coor-Datei der Vektorkarte <%s@%s> ist größer als sie sein sollte (%ld Byte zuviel)."
 #: ../lib/vector/Vlib/open_nat.c:149
 #, c-format
-msgid ""
-"Coor files of vector <%s@%s> is shorter than it should be (%ld bytes "
-"missing)."
-msgstr ""
-"Coor-Datei der Vektorkarte <%s@%s> ist kleiner als sie sein sollte (%ld Byte "
-"fehlen)."
+msgid "Coor files of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
+msgstr "Coor-Datei der Vektorkarte <%s@%s> ist kleiner als sie sein sollte (%ld Byte fehlen)."
 #: ../lib/vector/Vlib/break_lines.c:374
 #, c-format
@@ -4365,12 +4181,8 @@
 #: ../lib/vector/Vlib/read.c:102
 #, c-format
-msgid ""
-"Vect_read_line(): feature id %d is not reasonable (max features in vector "
-"map <%s>: %d)"
-msgstr ""
-"Vect_read_line(): Objekt-ID %d ist nicht sinnvoll (max. Objekte in "
+msgid "Vect_read_line(): feature id %d is not reasonable (max features in vector map <%s>: %d)"
+msgstr "Vect_read_line(): Objekt-ID %d ist nicht sinnvoll (max. Objekte in Vektorkarte <%s>: %d)."
 #: ../lib/vector/Vlib/net.c:122
 msgid "Building graph..."
@@ -4398,8 +4210,7 @@
 #: ../lib/vector/Vlib/net.c:367
 #, c-format
 msgid "Data type of column <%s> not supported (must be numeric)"
-msgstr ""
-"Spaltentyp der Spalte <%s> wird nicht unterstützt (muss numerisch sein)."
+msgstr "Spaltentyp der Spalte <%s> wird nicht unterstützt (muss numerisch sein)."
 #: ../lib/vector/Vlib/net.c:227
 msgid "Registering arcs..."
@@ -4407,21 +4218,13 @@
 #: ../lib/vector/Vlib/net.c:255
 #, c-format
-msgid ""
-"Database record for line %d (cat = %d, forward/both direction(s)) not found "
-"(forward/both direction(s) of line skipped)"
-msgstr ""
-"Datenbankeintrag für Linie %d (cat = %d, vorwärts/beide Richtung(en)) nicht "
-"gefunden (vorwärts/beide Richtung(en) der Linie übersprungen)."
+msgid "Database record for line %d (cat = %d, forward/both direction(s)) not found (forward/both direction(s) of line skipped)"
+msgstr "Datenbankeintrag für Linie %d (cat = %d, vorwärts/beide Richtung(en)) nicht gefunden (vorwärts/beide Richtung(en) der Linie übersprungen)."
 #: ../lib/vector/Vlib/net.c:274
 #, c-format
-msgid ""
-"Database record for line %d (cat = %d, backword direction) not "
-"found(direction of line skipped)"
-msgstr ""
-"Datenbankeintrag für Linie %d (cat = %d, rückwärts Richtung) nicht gefunden "
-"(Richtung der Linie übersprungen)."
+msgid "Database record for line %d (cat = %d, backword direction) not found(direction of line skipped)"
+msgstr "Datenbankeintrag für Linie %d (cat = %d, rückwärts Richtung) nicht gefunden (Richtung der Linie übersprungen)."
 #: ../lib/vector/Vlib/net.c:323
 msgid "Cannot add network arc"
@@ -4434,9 +4237,7 @@
 #: ../lib/vector/Vlib/net.c:403
 #, c-format
 msgid "Database record for node %d (cat = %d) not found (cost set to 0)"
-msgstr ""
-"Datenbankeintrag für Knoten %d (cat = %d) nicht gefunden (Kosten auf 0 "
-"gesetzt)."
+msgstr "Datenbankeintrag für Knoten %d (cat = %d) nicht gefunden (Kosten auf 0 gesetzt)."
 #: ../lib/vector/Vlib/net.c:430
 msgid "Flattening the graph..."
@@ -4480,20 +4281,17 @@
 #: ../lib/vector/Vlib/array.c:294
 #, c-format
 msgid "Unable to select record from table <%s> (key %s, where %s)"
-msgstr ""
-"Kann den Datensatz in der Tabelle <%s> nicht selektieren (key %s, where %s)."
+msgstr "Kann den Datensatz in der Tabelle <%s> nicht selektieren (key %s, where %s)."
 #: ../lib/vector/Vlib/legal_vname.c:48
 #, c-format
 msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
-msgstr ""
-"Ungültiger Name der Vektorkarte <%s>. Darf nicht '.' oder 'NULL' enthalten."
+msgstr "Ungültiger Name der Vektorkarte <%s>. Darf nicht '.' oder 'NULL' enthalten."
 #: ../lib/vector/Vlib/legal_vname.c:55
 #, c-format
 msgid "Illegal vector map name <%s>. Must start with a letter."
-msgstr ""
-"Ungültiger Name der Vektorkarte <%s>. Muss mit einem Buchstaben beginnen."
+msgstr "Ungültiger Name der Vektorkarte <%s>. Muss mit einem Buchstaben beginnen."
 #: ../lib/vector/Vlib/legal_vname.c:63
 #, c-format
@@ -4502,11 +4300,8 @@
 #: ../lib/vector/Vlib/legal_vname.c:70
 #, c-format
-msgid ""
-"Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
-msgstr ""
-"Ungültiger Name der Vektorkarte <%s>. SQL-Schlüsselwort darf nicht als "
-"Vektorkartenname benutzt werden."
+msgid "Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
+msgstr "Ungültiger Name der Vektorkarte <%s>. SQL-Schlüsselwort darf nicht als Vektorkartenname benutzt werden."
 #: ../lib/vector/Vlib/legal_vname.c:101 ../lib/vector/Vlib/legal_vname.c:105
 #, c-format
@@ -4542,19 +4337,13 @@
 #: ../lib/vector/Vlib/write.c:219
 #, c-format
-msgid ""
-"Unable to delete feature %d, vector map <%s> is not opened on topology level"
-msgstr ""
-"Kann Objekt %d nicht löschen. Vektorkarte <%s> ist nicht auf topologischem "
-"Level geöffnet."
+msgid "Unable to delete feature %d, vector map <%s> is not opened on topology level"
+msgstr "Kann Objekt %d nicht löschen. Vektorkarte <%s> ist nicht auf topologischem Level geöffnet."
 #: ../lib/vector/Vlib/write.c:225
 #, c-format
-msgid ""
-"Unable to delete feature %d, vector map <%s> is not opened in 'write' mode"
-msgstr ""
-"Kann Objekt %d nicht löschen. Vektorkarte <%s> ist nicht im Schreibmodus "
-"geöffnet."
+msgid "Unable to delete feature %d, vector map <%s> is not opened in 'write' mode"
+msgstr "Kann Objekt %d nicht löschen. Vektorkarte <%s> ist nicht im Schreibmodus geöffnet."
 #: ../lib/vector/Vlib/write.c:239
 #, c-format
@@ -4563,19 +4352,13 @@
 #: ../lib/vector/Vlib/write.c:265
 #, c-format
-msgid ""
-"Unable to restore feature %d, vector map <%s> is not opened on topology level"
-msgstr ""
-"Kann Objekt %d nicht wiederherstellen. Vektorkarte <%s> ist nicht auf "
-"topologischem Level geöffnet."
+msgid "Unable to restore feature %d, vector map <%s> is not opened on topology level"
+msgstr "Kann Objekt %d nicht wiederherstellen. Vektorkarte <%s> ist nicht auf topologischem Level geöffnet."
 #: ../lib/vector/Vlib/write.c:271
 #, c-format
-msgid ""
-"Unable to restore feature %d, vector map <%s> is not opened in 'write' mode"
-msgstr ""
-"Kann Objekt %d nicht wiederherstellen. Vektorkarte <%s> ist nicht im "
-"Schreibmodus geöffnet."
+msgid "Unable to restore feature %d, vector map <%s> is not opened in 'write' mode"
+msgstr "Kann Objekt %d nicht wiederherstellen. Vektorkarte <%s> ist nicht im Schreibmodus geöffnet."
 #: ../lib/vector/Vlib/write.c:285
 #, c-format
@@ -4588,8 +4371,7 @@
 #: ../lib/vector/Vlib/buffer2.c:598 ../lib/vector/Vlib/buffer2.c:609
 msgid "Next edge was visited but it is not the first one !!! breaking loop"
-msgstr ""
-"Nächste Kante besucht, aber sie ist nicht die Erste!!! Beende Schleife."
+msgstr "Nächste Kante besucht, aber sie ist nicht die Erste!!! Beende Schleife."
 #: ../lib/vector/Vlib/buffer2.c:657
 msgid "side != 0 feature not implemented"
@@ -4724,9 +4506,7 @@
 #: ../lib/vector/Vlib/cats.c:410
 #, c-format
 msgid "Unable to convert category string '%s' (from '%s') to category range"
-msgstr ""
-"Kann die Kategorie-Zeichenkette '%s' (von '%s') nicht in eine "
-"Kategoriespanne konvertieren."
+msgstr "Kann die Kategorie-Zeichenkette '%s' (von '%s') nicht in eine Kategoriespanne konvertieren."
 #: ../lib/vector/Vlib/snap.c:148
 msgid "Snap vertices Pass 1: select points"
@@ -4760,11 +4540,8 @@
 msgstr "Teilbauten werden für OGR nicht unterstützt."
 #: ../lib/vector/Vlib/build_ogr.c:342
-msgid ""
-"Random read is not supported by OGR for this layer, cannot build support"
-msgstr ""
-"Direktes Lesen wird von OGR für diesen Layer nicht unterstützt, kann Support "
-"nicht erzeugen."
+msgid "Random read is not supported by OGR for this layer, cannot build support"
+msgstr "Direktes Lesen wird von OGR für diesen Layer nicht unterstützt, kann Support nicht erzeugen."
 #: ../lib/vector/Vlib/build_ogr.c:349
 msgid "Feature: "
@@ -4785,9 +4562,7 @@
 #: ../lib/vector/Vlib/field.c:98
 msgid "Unable to add database link, map is not opened in WRITE mode"
-msgstr ""
-"Kann Datenbankverknüpfung nicht hinzufügen. Die Karte ist nicht im "
+msgstr "Kann Datenbankverknüpfung nicht hinzufügen. Die Karte ist nicht im Schreibmodus geöffnet."
 #: ../lib/vector/Vlib/field.c:104
 msgid "Unable to add database link"
@@ -4831,12 +4606,8 @@
 msgstr "Kann den OGR DBMI-Treiber nicht öffnen."
 #: ../lib/vector/Vlib/field.c:551
-msgid ""
-"All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' "
-"available in OGR DB table"
-msgstr ""
-"Alle FID Tests fehlgeschlagen. Weder 'FID' noch 'ogc_fid', 'ogr_fid', 'gid' "
-"sind in der OGR DB Tabelle vorhanden."
+msgid "All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' available in OGR DB table"
+msgstr "Alle FID Tests fehlgeschlagen. Weder 'FID' noch 'ogc_fid', 'ogr_fid', 'gid' sind in der OGR DB Tabelle vorhanden."
 #: ../lib/vector/Vlib/field.c:606
 #, c-format
@@ -4855,8 +4626,7 @@
 #: ../lib/vector/Vlib/field.c:804
 msgid "Bug: attempt to update map which is not in current mapset"
-msgstr ""
-"Bug: Versuch eine Karte zu aktualisieren, die nicht im aktuellen Mapset ist."
+msgstr "Bug: Versuch eine Karte zu aktualisieren, die nicht im aktuellen Mapset ist."
 #: ../lib/vector/Vlib/intersect.c:127
 msgid "3D not supported by Vect_segment_intersection()"
@@ -4868,17 +4638,14 @@
 #: ../lib/vector/Vlib/intersect.c:407
 msgid "Vect_segment_intersection() ERROR (collinear non vertical segments)"
-msgstr ""
-"Vect_segment_intersection() FEHLER (kollineare nicht vertikale Segmente)"
+msgstr "Vect_segment_intersection() FEHLER (kollineare nicht vertikale Segmente)"
 #: ../lib/vector/Vlib/intersect.c:1059 ../lib/vector/Vlib/intersect.c:1065
 #: ../lib/vector/Vlib/intersect.c:1067 ../lib/vector/Vlib/intersect.c:1115
 #: ../lib/vector/Vlib/intersect.c:1124 ../lib/vector/Vlib/intersect.c:1145
 #: ../lib/vector/Vlib/intersect.c:1162
 msgid "Error while adding point to array. Out of memory"
-msgstr ""
-"Fehler beim Hinzufügen eines Punktes zum Array. Nicht genügend "
-"Arbeitsspeicher."
+msgstr "Fehler beim Hinzufügen eines Punktes zum Array. Nicht genügend Arbeitsspeicher."
 #: ../lib/vector/Vlib/overlay.c:74
 msgid "unknown operator"
@@ -4903,21 +4670,14 @@
 msgstr "Programmierer forderte unbekanntes open_level %d an."
 #: ../lib/vector/Vlib/open.c:179
-msgid ""
-"Vector map which is not in the current mapset cannot be opened for update"
-msgstr ""
-"Eine Karte, die sich nicht im aktuellen Mapset befindet, kann nicht zum "
-"Aktualisierung geöffnet werden."
+msgid "Vector map which is not in the current mapset cannot be opened for update"
+msgstr "Eine Karte, die sich nicht im aktuellen Mapset befindet, kann nicht zum Aktualisierung geöffnet werden."
 #: ../lib/vector/Vlib/open.c:211 ../lib/vector/Vlib/open.c:279
 #: ../lib/vector/Vlib/open.c:299
 #, c-format
-msgid ""
-"Unable to open vector map <%s> on level %d. Try to rebuild vector topology "
-"by v.build."
-msgstr ""
-"Kann die Vektorkarte <%s> nicht auf Level %d öffnen. Versuchen Sie die "
-"Topologie mit v.build neu anzulegen."
+msgid "Unable to open vector map <%s> on level %d. Try to rebuild vector topology by v.build."
+msgstr "Kann die Vektorkarte <%s> nicht auf Level %d öffnen. Versuchen Sie die Topologie mit v.build neu anzulegen."
 #: ../lib/vector/Vlib/open.c:214
 msgid "Unable to read head file"
@@ -4955,9 +4715,7 @@
 #: ../lib/vector/Vlib/open.c:731
 msgid "Size of 'coor' file differs from value saved in topology file"
-msgstr ""
-"Größe der 'coor' Datei unterscheidet sich von dem in der Topologie-Datei "
-"gespeicherten Wert."
+msgstr "Größe der 'coor' Datei unterscheidet sich von dem in der Topologie-Datei gespeicherten Wert."
 #: ../lib/vector/Vlib/open.c:742
 #, c-format
@@ -4986,13 +4744,11 @@
 #: ../lib/vector/Vlib/build_nat.c:93
 msgid "Unable to add area (map closed, topo saved)"
-msgstr ""
-"Kann Fläche nicht hinzufügen (Karte geschlossen, Topologie gespeichert)."
+msgstr "Kann Fläche nicht hinzufügen (Karte geschlossen, Topologie gespeichert)."
 #: ../lib/vector/Vlib/build_nat.c:102
 msgid "Unable to add isle (map closed, topo saved)"
-msgstr ""
-"Kann Insel nicht hinzufügen (Karte geschlossen, Topologie gespeichert)."
+msgstr "Kann Insel nicht hinzufügen (Karte geschlossen, Topologie gespeichert)."
 #: ../lib/vector/Vlib/build_nat.c:112
 msgid "Area of size = 0.0 ignored"
@@ -5069,14 +4825,10 @@
 #~ msgstr "Vektor ist nicht 3D."
 #~ msgid "Cannot find z column <%s> (please verify name, e.g. with v.info)"
-#~ msgstr ""
-#~ "Kann die Z-Spalte <%s> nicht finden (Bitte überprüfen Sie den Name, z.B. "
-#~ "mit v.info)."
+#~ msgstr "Kann die Z-Spalte <%s> nicht finden (Bitte überprüfen Sie den Name, z.B. mit v.info)."
 #~ msgid "Column type of z column is not supported (must be integer or double)"
-#~ msgstr ""
-#~ "Spaltentype der Spalte z wird nicht unterstützt (muss integer oder double "
-#~ "sein)."
+#~ msgstr "Spaltentype der Spalte z wird nicht unterstützt (muss integer oder double sein)."
 #~ msgid "Cannot read column type of smooth column"
 #~ msgstr "Kann den Spaltentyp der Smooth-Spalte nicht lesen."
@@ -5085,9 +4837,7 @@
 #~ msgstr "Spaltentyp der Smooth-Spalte (datetime) wird nicht unterstützt."
 #~ msgid "Column type of s column is not supported (must be integer or double)"
-#~ msgstr ""
-#~ "Spaltentyp der s-Spalte wird nicht unterstützt (muss integer oder double "
-#~ "sein)."
+#~ msgstr "Spaltentyp der s-Spalte wird nicht unterstützt (muss integer oder double sein)."
 #~ msgid "Unknown Location"
 #~ msgstr "Unbekannte Location"
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_de.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_de.po	2014-08-11 09:44:09 UTC (rev 61582)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_de.po	2014-08-11 10:14:22 UTC (rev 61583)
@@ -1,36 +1,32 @@
 # translation of grassmods_de.po to Deutsch
-# Robert Nuske <robert.nuske nw-fva.de>, 2006, 2007, 2008, 2009, 2010, 2011, 2012, 2013.
+# Robert Nuske <robert.nuske nw-fva.de>, 2006, 2007, 2008, 2009, 2010, 2011, 2012, 2013, 2014.
 msgid ""
 msgstr ""
 "Project-Id-Version: grassmods_de\n"
-"PO-Revision-Date: 2014-03-24 15:17+0100\n"
+"PO-Revision-Date: 2014-08-10 14:59+0200\n"
 "Language: de\n"
 #: ../display/d.ask/main.c:36
 msgid "display, map management"
 msgstr "Darstellung, Kartenverwaltung"
 #: ../display/d.ask/main.c:38
-msgid ""
-"Prompts the user to select a GRASS data base file from among files displayed "
-"in a menu on the graphics monitor."
-msgstr ""
-"Bittet den Benutzer eine GRASS Datenbankdatei aus den im Menü präsentierten "
-"Dateien im Grafikfenster auszuwählen."
+msgid "Prompts the user to select a GRASS data base file from among files displayed in a menu on the graphics monitor."
+msgstr "Bittet den Benutzer eine GRASS Datenbankdatei aus den im Menü präsentierten Dateien im Grafikfenster auszuwählen."
 #: ../display/d.ask/main.c:46
 msgid "Database element, one word description"
@@ -85,28 +81,19 @@
 #: ../display/d.save/main.c:81
 msgid "Creates a list of commands for recreating screen graphics."
-msgstr ""
-"Erstelle eine Liste von Kommandos zum Wiederherstellen der Bildschirmgrafik."
+msgstr "Erstelle eine Liste von Kommandos zum Wiederherstellen der Bildschirmgrafik."
 #: ../display/d.save/main.c:86
 msgid "Name of frame(s) to save"
 msgstr "Name der Rahmen zum speichern."
 #: ../display/d.save/main.c:126
-msgid ""
-"List of object numbers to remove which are displayed after \"#\". -1 for the "
-"last object."
-msgstr ""
-"Liste der Objektnummer, die entfernt werden sollen, die hinter \"#\" "
-"angezeigt werden. -1 steht für das letzte Objekt."
+msgid "List of object numbers to remove which are displayed after \"#\". -1 for the last object."
+msgstr "Liste der Objektnummer, die entfernt werden sollen, die hinter \"#\" angezeigt werden. -1 steht für das letzte Objekt."
 #: ../display/d.save/main.c:134
-msgid ""
-"List of object numbers to move (\"from\" to \"to\"). remove= option will be "
-"done first, if any."
-msgstr ""
-"Liste der Objektnummern die verschoben werden sollen. (\"von\" nach \"nach"
-"\"). Falls eine Option angegeben wurde, wird remove= als erstes ausgeführt."
+msgid "List of object numbers to move (\"from\" to \"to\"). remove= option will be done first, if any."
+msgstr "Liste der Objektnummern die verschoben werden sollen. (\"von\" nach \"nach\"). Falls eine Option angegeben wurde, wird remove= als erstes ausgeführt."
 #: ../display/d.save/main.c:143
 msgid "Save current frame"
@@ -144,12 +131,8 @@
 msgstr "Darstellung, Farbtransformation"
 #: ../display/d.his/main.c:67
-msgid ""
-"Displays the result obtained by combining hue, intensity, and saturation "
-"(his) values from user-specified input raster map layers."
-msgstr ""
-"Zeigt das Ergebnis der Kombination Kombination von Farbwert-, Intensitäts- "
-"und Sättigungswerten (HIS) aus vom Benutzer gewählten Rasterkarten."
+msgid "Displays the result obtained by combining hue, intensity, and saturation (his) values from user-specified input raster map layers."
+msgstr "Zeigt das Ergebnis der Kombination Kombination von Farbwert-, Intensitäts- und Sättigungswerten (HIS) aus vom Benutzer gewählten Rasterkarten."
 #: ../display/d.his/main.c:76 ../raster/r.his/main.c:74
 msgid "Name of layer to be used for HUE"
@@ -157,13 +140,11 @@
 #: ../display/d.his/main.c:83 ../raster/r.his/main.c:81
 msgid "Name of layer to be used for INTENSITY"
-msgstr ""
-"Name der Karte, die für die Intensität (INTENSITY) verwendet werden soll."
+msgstr "Name der Karte, die für die Intensität (INTENSITY) verwendet werden soll."
 #: ../display/d.his/main.c:90 ../raster/r.his/main.c:88
 msgid "Name of layer to be used for SATURATION"
-msgstr ""
-"Name der Karte, die für die Sättigung (SATURATION) verwendet werden soll"
+msgstr "Name der Karte, die für die Sättigung (SATURATION) verwendet werden soll"
 #: ../display/d.his/main.c:95
 msgid "Percent to brighten intensity channel"
@@ -435,21 +416,13 @@
 #: ../display/d.colortable/main.c:118
 #, c-format
-msgid ""
-"<%s> is a floating point map. Ignoring [lines] and drawing continuous color "
-"ramp"
-msgstr ""
-"<%s> ist eine Fließkommakarte. Ignoriere [lines] und zeichne einen "
-"kontinuierlichen Farbverlauf."
+msgid "<%s> is a floating point map. Ignoring [lines] and drawing continuous color ramp"
+msgstr "<%s> ist eine Fließkommakarte. Ignoriere [lines] und zeichne einen kontinuierlichen Farbverlauf."
 #: ../display/d.colortable/main.c:132
 #, c-format
-msgid ""
-"<%s> is a floating point map. Ignoring [cols] and drawing continuous color "
-"ramp"
-msgstr ""
-"<%s> ist eine Fließkommakarte. Ignoriere [cols] und zeichne einen "
+msgid "<%s> is a floating point map. Ignoring [cols] and drawing continuous color ramp"
+msgstr "<%s> ist eine Fließkommakarte. Ignoriere [cols] und zeichne einen kontinuierlichen Farbverlauf."
 #: ../display/d.colortable/main.c:141
 #, c-format
@@ -485,9 +458,7 @@
 msgstr "Darstellung, Kartographie"
 #: ../display/d.legend/main.c:88
-msgid ""
-"Displays a legend for a raster map in the active frame of the graphics "
-"monitor."
+msgid "Displays a legend for a raster map in the active frame of the graphics monitor."
 msgstr "Zeichnet eine Legende für eine Rasterkarte im aktiven Grafikfenster."
 #: ../display/d.legend/main.c:92 ../display/d.zoom/main.c:90
@@ -526,11 +497,8 @@
 msgstr "Anzahl der Textlabel für eine geglättetete Legende."
 #: ../display/d.legend/main.c:130
-msgid ""
-"Size and placement as percentage of screen coordinates (0,0 is lower left)"
-msgstr ""
-"Größe und Platzierung als Prozentsatz der Bildschirmkoordinaten (0,0 ist "
-"links unten)"
+msgid "Size and placement as percentage of screen coordinates (0,0 is lower left)"
+msgstr "Größe und Platzierung als Prozentsatz der Bildschirmkoordinaten (0,0 ist links unten)"
 #: ../display/d.legend/main.c:140
 msgid "List of discrete category numbers/values for legend"
@@ -538,8 +506,7 @@
 #: ../display/d.legend/main.c:150
 msgid "Use a subset of the map range for the legend (min,max)"
-msgstr ""
-"Benutze einen Teilausschnitt der Wertespanne für eine Legende (min,max)."
+msgstr "Benutze einen Teilausschnitt der Wertespanne für eine Legende (min,max)."
 #: ../display/d.legend/main.c:156
 msgid "Use mouse to size & place legend"
@@ -593,21 +560,16 @@
 #: ../display/d.legend/main.c:331
 msgid "Legend box lies outside of frame. Text may not display properly."
-msgstr ""
-"Legende liegt außerhalb des Rahmens. Text könnte nicht richtig dargestellt "
-"werden."
+msgstr "Legende liegt außerhalb des Rahmens. Text könnte nicht richtig dargestellt werden."
 #: ../display/d.legend/main.c:335
 msgid "Drawing horizontal legend as box width exceeds height"
-msgstr ""
-"Zeichne eine horizontale Legende da die Box-Breite die Höhe überschreitet."
+msgstr "Zeichne eine horizontale Legende da die Box-Breite die Höhe überschreitet."
 #: ../display/d.legend/main.c:346
 #, c-format
 msgid "Range information for <%s> not available (run r.support)"
-msgstr ""
-"Bereich-Information für Karte <%s> nicht vorhanden (Führen Sie r.support "
-"aus)."
+msgstr "Bereich-Information für Karte <%s> nicht vorhanden (Führen Sie r.support aus)."
 #: ../display/d.legend/main.c:351
 msgid "Input map contains no data"
@@ -628,14 +590,11 @@
 #: ../display/d.legend/main.c:468
 msgid "Nothing to draw! (no categories with labels? out of range?)"
-msgstr ""
-"Nichts zu zeichnen! (Keine Kategorien mit Labeln? Außerhalb der Spanne?"
+msgstr "Nichts zu zeichnen! (Keine Kategorien mit Labeln? Außerhalb der Spanne?"
 #: ../display/d.legend/main.c:478
 msgid "Forcing a smooth legend: too many categories for current window height"
-msgstr ""
-"Erzwinge eine geglättete Legende: Zu viele Kategorien für die Höhe des "
-"aktuellen Fensters."
+msgstr "Erzwinge eine geglättete Legende: Zu viele Kategorien für die Höhe des aktuellen Fensters."
 #: ../display/d.legend/main.c:508 ../display/d.histogram/main.c:171
 #, c-format
@@ -652,9 +611,7 @@
 msgstr "Nichts zu zeichnen! Evtl. keine Kategorien mit Labeln?"
 #: ../display/d.text.new/main.c:144 ../display/d.text/main.c:68
-msgid ""
-"Draws text in the active display frame on the graphics monitor using the "
-"current font."
+msgid "Draws text in the active display frame on the graphics monitor using the current font."
 msgstr "Zeichnet Text im aktiven Graphik-Fenster mit der aktuellen Schrift."
 #: ../display/d.text.new/main.c:150 ../display/d.text.freetype/main.c:146
@@ -672,21 +629,15 @@
 #: ../display/d.text.new/main.c:175
 msgid "Text background color, either a standard GRASS color or R:G:B triplet"
-msgstr ""
-"Texthintergrundfarbe, entweder eine GRASS Standardfarbe oder ein R:G:B "
-"Tripel."
+msgstr "Texthintergrundfarbe, entweder eine GRASS Standardfarbe oder ein R:G:B Tripel."
 #: ../display/d.text.new/main.c:184 ../display/d.text/main.c:94
 msgid "The screen line number on which text will begin to be drawn"
 msgstr "Die Zeile des Grafikfensters, in der der Text beginnt."
 #: ../display/d.text.new/main.c:192 ../display/d.text/main.c:103
-msgid ""
-"Screen position at which text will begin to be drawn (percentage, [0,0] is "
-"lower left)"
-msgstr ""
-"Bildschirmposition, an der der Text angefangen wird, zu zeichnen (in "
-"Prozent, [0,0] ist die untere linke Ecke)."
+msgid "Screen position at which text will begin to be drawn (percentage, [0,0] is lower left)"
+msgstr "Bildschirmposition, an der der Text angefangen wird, zu zeichnen (in Prozent, [0,0] ist die untere linke Ecke)."
 #: ../display/d.text.new/main.c:200 ../display/d.text.freetype/main.c:209
 msgid "Text alignment"
@@ -758,8 +709,7 @@
 "Please enter text instructions.  Enter EOF (ctrl-d) on last line to quit\n"
 msgstr ""
 "\n"
-"Bitte geben Sie Anweisungen ein.  Um dies zu beenden geben Sie in der "
-"letzten Zeile EOF (Strg-d) ein.\n"
+"Bitte geben Sie Anweisungen ein.  Um dies zu beenden geben Sie in der letzten Zeile EOF (Strg-d) ein.\n"
 #: ../display/d.text.new/main.c:417 ../display/d.text/main.c:193
 #: ../display/d.title/main.c:119 ../general/g.setproj/get_stp.c:162
@@ -891,11 +841,8 @@
 msgstr "Grafikfenster: Interaktives Kommando zum erneuten Zeichnen."
 #: ../display/d.linegraph/linegraph.c:115
-msgid ""
-"Generates and displays simple line graphs in the active graphics monitor "
-"display frame."
-msgstr ""
-"Erzeugt und stellt einfache Liniengrafiken im aktiven Grafikfenster dar."
+msgid "Generates and displays simple line graphs in the active graphics monitor display frame."
+msgstr "Erzeugt und stellt einfache Liniengrafiken im aktiven Grafikfenster dar."
 #: ../display/d.linegraph/linegraph.c:119
 msgid "Name of data file for X axis of graph"
@@ -1029,8 +976,7 @@
 #: ../display/d.nviz/main.c:147
 msgid "Either -i flag and/or route parameter must be used"
-msgstr ""
-"Entweder der Parameter '-i' und/oder Routen-Parameter muss gesetzt werden."
+msgstr "Entweder der Parameter '-i' und/oder Routen-Parameter muss gesetzt werden."
 #: ../display/d.nviz/main.c:171
 msgid "Off-screen only available with full render mode"
@@ -1065,13 +1011,8 @@
 msgstr "Habe NVIZ-Skript <%s> erzeugt."
 #: ../display/d.nviz/main.c:537
-msgid ""
-"Skipping this point, selected point is outside region. Perhaps the camera "
-"setback distance puts it beyond the edge?"
-msgstr ""
-"Lasse diesen Punkt aus, der selektierte Punkt liegt außerhalb der Region. "
-"Vielleicht ist der Kameraabstand zu weit, sodass der Punkt hinter die Kante "
-"gerutscht ist?"
+msgid "Skipping this point, selected point is outside region. Perhaps the camera setback distance puts it beyond the edge?"
+msgstr "Lasse diesen Punkt aus, der selektierte Punkt liegt außerhalb der Region. Vielleicht ist der Kameraabstand zu weit, sodass der Punkt hinter die Kante gerutscht ist?"
 #: ../display/d.rast/main.c:52
 msgid "Displays user-specified raster map in the active graphics frame."
@@ -1139,19 +1080,15 @@
 #: ../display/d.rast/main.c:99
 msgid "Don't add to list of rasters and commands in monitor"
-msgstr ""
-"Nicht zu der Liste der Rasterkarten und Kommandos im Monitor hinzufügen."
+msgstr "Nicht zu der Liste der Rasterkarten und Kommandos im Monitor hinzufügen."
 #: ../display/d.rast/main.c:119
 msgid "Ignoring catlist: map is floating point (please use 'val=')"
-msgstr ""
-"Igniriere Kategorieliste: Karte ist ein Fließkommakarte (Bitte benutzen Sie "
-"'val=')."
+msgstr "Igniriere Kategorieliste: Karte ist ein Fließkommakarte (Bitte benutzen Sie 'val=')."
 #: ../display/d.rast/main.c:125
 msgid "Ignoring vallist: map is integer (please use 'cat=')"
-msgstr ""
-"Ignoriere Vallist: Karte ist eine Integerkarte (Bitte benutzen Sie 'cat=')."
+msgstr "Ignoriere Vallist: Karte ist eine Integerkarte (Bitte benutzen Sie 'cat=')."
 #: ../display/d.rast/display.c:32 ../display/d.paint.labels/color.c:66
 #: ../display/d.text.freetype/main.c:842 ../display/d.graph/do_graph.c:112
@@ -1188,8 +1125,7 @@
 #: ../display/d.info/main.c:58
 msgid "Display geographic coordinates and resolution of entire screen"
-msgstr ""
-"Zeigt geographische Koordinaten und die Auflösung des gesamten Bildschirms."
+msgstr "Zeigt geographische Koordinaten und die Auflösung des gesamten Bildschirms."
 #: ../display/d.info/main.c:62
 msgid "Display number of colors"
@@ -1287,8 +1223,7 @@
 msgstr "Kann den Select-Cursor '%s' nicht öffnen."
 #: ../display/d.vect.chart/main.c:65
-msgid ""
-"Displays charts of vector data in the active frame on the graphics monitor."
+msgid "Displays charts of vector data in the active frame on the graphics monitor."
 msgstr "Stellt Diagramme von Vektordaten im aktiven Grafikfenster dar."
 #: ../display/d.vect.chart/main.c:82
@@ -1312,9 +1247,7 @@
 #: ../display/d.vect.chart/main.c:104
 msgid "Size of chart (diameter for pie, total width for bar)"
-msgstr ""
-"Größe des Diagramms (Durchmesser für Tortendiagramm, Gesamtbreite für "
-"Balkendiagrramm)."
+msgstr "Größe des Diagramms (Durchmesser für Tortendiagramm, Gesamtbreite für Balkendiagrramm)."
 #: ../display/d.vect.chart/main.c:111
 msgid "Scale for size (to get size in pixels)"
@@ -1345,12 +1278,8 @@
 msgstr "Darstellung, Distanz"
 #: ../display/d.rhumbline/main.c:47
-msgid ""
-"Displays the rhumbline joining two user-specified points, in the active "
-"frame on the user's graphics monitor."
-msgstr ""
-"Stellt im aktiven Grafikfenster die Kompasslinie dar, die zwei vom Benutzer "
-"angegebene Punkte verbindet."
+msgid "Displays the rhumbline joining two user-specified points, in the active frame on the user's graphics monitor."
+msgstr "Stellt im aktiven Grafikfenster die Kompasslinie dar, die zwei vom Benutzer angegebene Punkte verbindet."
 #: ../display/d.rhumbline/main.c:55 ../display/d.path/main.c:66
 #: ../display/d.geodesic/main.c:56
@@ -1389,9 +1318,7 @@
 msgstr "Darstellung, Zeichen Label"
 #: ../display/d.paint.labels/main.c:48
-msgid ""
-"Displays text labels (created with v.label) to the active frame on the "
-"graphics monitor."
+msgid "Displays text labels (created with v.label) to the active frame on the graphics monitor."
 msgstr "Zeigt Text-Label (mit v.label erstellt) im aktiven Grafikfenster."
 #: ../display/d.paint.labels/main.c:54
@@ -1417,13 +1344,11 @@
 #: ../display/d.paint.labels/main.c:102 ../display/d.vect/main.c:387
 msgid "Region size is lower than minreg, nothing displayed."
-msgstr ""
-"Region-Größe ist kleiner als die Minimal-Region; es wird nichts angezeigt."
+msgstr "Region-Größe ist kleiner als die Minimal-Region; es wird nichts angezeigt."
 #: ../display/d.paint.labels/main.c:111 ../display/d.vect/main.c:396
 msgid "Region size is greater than maxreg, nothing displayed."
-msgstr ""
-"Region-Größe ist größer als die Maximal-Region; es wird nichts angezeigt."
+msgstr "Region-Größe ist größer als die Maximal-Region; es wird nichts angezeigt."
 #: ../display/d.paint.labels/main.c:121 ../vector/v.lrs/v.lrs.label/main.c:299
 #, c-format
@@ -1446,14 +1371,11 @@
 #: ../display/d.extract/extract.c:46
 msgid " - M: draw box with middle mouse button to remove from display"
-msgstr ""
-"- M: Zeichne Boxe mit der mittleren Maustaste, die von der Darstellung "
-"entfernt werden soll."
+msgstr "- M: Zeichne Boxe mit der mittleren Maustaste, die von der Darstellung entfernt werden soll."
 #: ../display/d.extract/extract.c:47
 msgid " - R: quit and save selected vectors to new map\n"
-msgstr ""
-" - R: Beende und speichere die ausgewählten Vektoren in eine neuen Karte.\n"
+msgstr " - R: Beende und speichere die ausgewählten Vektoren in eine neuen Karte.\n"
 #: ../display/d.extract/extract.c:49
 msgid "L: add  M: remove  R: quit and save\n"
@@ -1466,9 +1388,7 @@
 #: ../display/d.extract/main.c:52
 msgid "Selects and extracts vectors with mouse into new vector map."
-msgstr ""
-"Interaktives Auswählen und Extrahieren von Vektoren mit der Maus in eine "
-"neue Karte."
+msgstr "Interaktives Auswählen und Extrahieren von Vektoren mit der Maus in eine neue Karte."
 #: ../display/d.extract/main.c:65 ../display/d.path/main.c:100
 msgid "Original line color"
@@ -1484,9 +1404,7 @@
 #: ../display/d.extract/main.c:125
 msgid "Cannot get db link info -> cannot copy table."
-msgstr ""
-"Kann die Informationen zu Datenbankverbindung nicht lesen -> Kann Tabelle "
-"nicht kopieren."
+msgstr "Kann die Informationen zu Datenbankverbindung nicht lesen -> Kann Tabelle nicht kopieren."
 #: ../display/d.thematic.area/plot1.c:210 ../display/d.vect/plot1.c:222
 msgid "Color definition column not specified"
@@ -1494,13 +1412,8 @@
 #: ../display/d.thematic.area/plot1.c:220
 #, c-format
-msgid ""
-"Color definition column (%s) not a string. Column must be of form RRR:GGG:"
-"BBB where RGB values range 0-255."
-msgstr ""
-"Farbdefinitionsspalte (%s) ist keine Zeichenkette. Die Spalte muss die "
-"folgende Form haben: RRR:GGG:BBB. Die RGB-Werte müssen zwischen 0 und 255 "
-"liegen."
+msgid "Color definition column (%s) not a string. Column must be of form RRR:GGG:BBB where RGB values range 0-255."
+msgstr "Farbdefinitionsspalte (%s) ist keine Zeichenkette. Die Spalte muss die folgende Form haben: RRR:GGG:BBB. Die RGB-Werte müssen zwischen 0 und 255 liegen."
 #: ../display/d.thematic.area/plot1.c:225
 #: ../display/d.thematic.area/plot1.c:253
@@ -1533,12 +1446,8 @@
 #: ../display/d.thematic.area/plot1.c:369
 #, c-format
-msgid ""
-"Error in color definition column (%s), element %d with cat %d: colorstring "
-"[%s]"
-msgstr ""
-"Fehler in der Farbdefinitionsspalte (%s), Element %d mit Kategorie %d: "
-"Farbwert [%s]."
+msgid "Error in color definition column (%s), element %d with cat %d: colorstring [%s]"
+msgstr "Fehler in der Farbdefinitionsspalte (%s), Element %d mit Kategorie %d: Farbwert [%s]."
 #: ../display/d.thematic.area/plot1.c:376
 #, c-format
@@ -1548,16 +1457,11 @@
 #: ../display/d.thematic.area/plot1.c:444 ../display/d.vect/plot1.c:587
 #: ../display/d.vect/area.c:369
 #, c-format
-msgid ""
-"Error in line width column (%s), element %d with cat %d: line width [%d]"
-msgstr ""
-"Fehler in der Spalte mit den Linienbreiten (%s), Element %d mit cat %d: "
-"Linienbreite [%d]."
+msgid "Error in line width column (%s), element %d with cat %d: line width [%d]"
+msgstr "Fehler in der Spalte mit den Linienbreiten (%s), Element %d mit cat %d: Linienbreite [%d]."
 #: ../display/d.thematic.area/main.c:80
-msgid ""
-"Displays a thematic vector area map in the active frame on the graphics "
-"monitor."
+msgid "Displays a thematic vector area map in the active frame on the graphics monitor."
 msgstr "Stellt eine thematische Vektorkarte im aktiven Grafikfenster dar."
 #: ../display/d.thematic.area/main.c:90
@@ -1573,12 +1477,8 @@
 msgstr "Algorithmus, der zur Klassifikation verwendet werden sollen."
 #: ../display/d.thematic.area/main.c:106 ../vector/v.class/main.c:69
-msgid ""
-"int;simple intervals;std;standard deviations;qua;quantiles;equ;equiprobable "
-"(normal distribution);"
-msgstr ""
-"int;einfache Intervalle;std;Standardabweichungen;qua;Quantile;equ;"
-"gleichwahrscheinlich(Normalverteilung);"
+msgid "int;simple intervals;std;standard deviations;qua;quantiles;equ;equiprobable (normal distribution);"
+msgstr "int;einfache Intervalle;std;Standardabweichungen;qua;Quantile;equ;gleichwahrscheinlich(Normalverteilung);"
 #: ../display/d.thematic.area/main.c:117 ../vector/v.class/main.c:80
 msgid "Number of classes to define"
@@ -1609,29 +1509,16 @@
 msgstr "Render-Methode für gefüllte Polygone."
 #: ../display/d.thematic.area/main.c:159
-msgid ""
-"d;use the display library basic functions (features: polylines);c;use the "
-"display library clipping functions (features: clipping);l;use the display "
-"library culling functions (features: culling, polylines)"
-msgstr ""
-"d;Verwende grundlegende Funktion der Displaybibliothek (Objekte: Polylinien);"
-"c;Verwende Clipping-Funktion der Displaybibliothek (Objekte: abschneiden);l;"
-"Verwende Culling-Funktion der Displaybibliothek (Objekte: Beschneiden, "
-"Polylinien)"
+msgid "d;use the display library basic functions (features: polylines);c;use the display library clipping functions (features: clipping);l;use the display library culling functions (features: culling, polylines)"
+msgstr "d;Verwende grundlegende Funktion der Displaybibliothek (Objekte: Polylinien);c;Verwende Clipping-Funktion der Displaybibliothek (Objekte: abschneiden);l;Verwende Culling-Funktion der Displaybibliothek (Objekte: Beschneiden, Polylinien)"
 #: ../display/d.thematic.area/main.c:167
 msgid "File in which to save d.graph instructions for legend display"
-msgstr ""
-"Datei in der die d.grap-Anweisungen für die Darstellung der Legende "
-"gespeichert werden."
+msgstr "Datei in der die d.grap-Anweisungen für die Darstellung der Legende gespeichert werden."
 #: ../display/d.thematic.area/main.c:178
-msgid ""
-"When printing legend info , include extended statistical info from "
-"classification algorithm"
-msgstr ""
-"Beim ausgeben der Legenden-Info auch die erweiterte Statistik des "
-"Klassifikationsalgorithmus ausgeben."
+msgid "When printing legend info , include extended statistical info from classification algorithm"
+msgstr "Beim ausgeben der Legenden-Info auch die erweiterte Statistik des Klassifikationsalgorithmus ausgeben."
 #: ../display/d.thematic.area/main.c:182
 msgid "Do not draw map, only output the legend"
@@ -1645,9 +1532,7 @@
 #: ../display/d.thematic.area/main.c:217
 #, c-format
 msgid "%s: You must build topology on vector map. Run v.build."
-msgstr ""
-"%s: Sie müssen die Topologie für die Vektorkarte erstellen. Führen Sie v."
-"build aus."
+msgstr "%s: Sie müssen die Topologie für die Vektorkarte erstellen. Führen Sie v.build aus."
 #: ../display/d.thematic.area/main.c:224
 msgid "'layer' must be > 0"
@@ -1691,19 +1576,12 @@
 msgstr "Unbekannte Farbe: [%s]."
 #: ../display/d.thematic.area/main.c:328
-msgid ""
-"You gave both manual breaks and a classification algorithm or a number of "
-"classes. The manual breaks have precedence and will thus be used."
-msgstr ""
-"Sie haben manuelle Klassengrenzen und ein Klassifikationsalgorithmus/"
-"Klassenanzahl angegeben. Die manuellen Klassengrenzen haben Vorrang und "
-"werden daher verwendet."
+msgid "You gave both manual breaks and a classification algorithm or a number of classes. The manual breaks have precedence and will thus be used."
+msgstr "Sie haben manuelle Klassengrenzen und ein Klassifikationsalgorithmus/Klassenanzahl angegeben. Die manuellen Klassengrenzen haben Vorrang und werden daher verwendet."
 #: ../display/d.thematic.area/main.c:365
 msgid "You must either give classbreaks or a classification algorithm"
-msgstr ""
-"Sie müssen entweder Klassengrenzen oder einen Klassfikationsalgorithmus "
-"angeben."
+msgstr "Sie müssen entweder Klassengrenzen oder einen Klassfikationsalgorithmus angeben."
 #: ../display/d.thematic.area/main.c:378
 #, c-format
@@ -1724,11 +1602,8 @@
 msgstr "Zeichne..."
 #: ../display/d.thematic.area/main.c:408 ../display/d.vect/main.c:591
-msgid ""
-"The bounding box of the map is outside the current region, nothing drawn."
-msgstr ""
-"Die BoundingBox der Karte liegt außerhalb der derzeitigen Region, es wird "
-"nichts gezeichnet."
+msgid "The bounding box of the map is outside the current region, nothing drawn."
+msgstr "Die BoundingBox der Karte liegt außerhalb der derzeitigen Region, es wird nichts gezeichnet."
 #: ../display/d.thematic.area/main.c:457
 #, c-format
@@ -1769,12 +1644,8 @@
 msgstr "Darstellung, Raster, RGB"
 #: ../display/d.rgb/main.c:56
-msgid ""
-"Displays three user-specified raster maps as red, green, and blue overlays "
-"in the active graphics frame."
-msgstr ""
-"Stellt drei Rasterkarten als rot, grün und blau Überlagerung im aktuellen "
-"Kartenfenster dar."
+msgid "Displays three user-specified raster maps as red, green, and blue overlays in the active graphics frame."
+msgstr "Stellt drei Rasterkarten als rot, grün und blau Überlagerung im aktuellen Kartenfenster dar."
 #: ../display/d.rgb/main.c:66 ../display/d.erase/main.c:52
 msgid "Don't add to list of commands in monitor"
@@ -1790,12 +1661,8 @@
 msgstr "Fehler beim Lesen eine Datenzeile."
 #: ../display/d.rast.num/number.c:86
-msgid ""
-"Overlays cell category values on a raster map layer displayed to the "
-msgstr ""
-"Überlagert Zell-Kategoriewerte über eine Rasterkarte im aktiven Grafik-"
-"Fenster."
+msgid "Overlays cell category values on a raster map layer displayed to the graphics monitor."
+msgstr "Überlagert Zell-Kategoriewerte über eine Rasterkarte im aktiven Grafik-Fenster."
 #: ../display/d.rast.num/number.c:91 ../raster/r.out.gdal/main.c:148
 #: ../raster/r.out.gdal/main.c:184 ../raster/r.external/main.c:527
@@ -1858,26 +1725,18 @@
 #, c-format
 msgid ""
 "Current region size: %d rows X %d cols\n"
-"Your current region setting may be too large. Cells displayed on your "
-"graphics window may be too small for cell category number to be visible."
+"Your current region setting may be too large. Cells displayed on your graphics window may be too small for cell category number to be visible."
 msgstr ""
 "Aktuelle Region: %d rows X %d cols\n"
-"Ihre aktuelle Fenstereinstellung könnte zu groß sein. Die im Grafikfenster "
-"dargestellten Zellen könnten zu klein sein, um die Kategorien lesen zu "
-"können."
+"Ihre aktuelle Fenstereinstellung könnte zu groß sein. Die im Grafikfenster dargestellten Zellen könnten zu klein sein, um die Kategorien lesen zu können."
 #: ../display/d.rast.num/number.c:216
 msgid "Aborting (region larger then 200 rows X 200 cols is not allowed)"
-msgstr ""
-"Abbruch (Region größer als 200 Zeilen x 200 Spalten sind nicht erlaubt)"
+msgstr "Abbruch (Region größer als 200 Zeilen x 200 Spalten sind nicht erlaubt)"
 #: ../display/d.rast.arrow/arrow.c:112
-msgid ""
-"Draws arrows representing cell aspect direction for a raster map containing "
-"aspect data."
-msgstr ""
-"Zeichnet Pfeile, die die Exposition der Zellen repräsentieren, basierend auf "
-"einer Rasterkarte mit Expositionsdaten."
+msgid "Draws arrows representing cell aspect direction for a raster map containing aspect data."
+msgstr "Zeichnet Pfeile, die die Exposition der Zellen repräsentieren, basierend auf einer Rasterkarte mit Expositionsdaten."
 #: ../display/d.rast.arrow/arrow.c:121
 msgid "Name of raster aspect map to be displayed"
@@ -1925,8 +1784,7 @@
 #: ../display/d.rast.arrow/arrow.c:233
 msgid "Magnitude is only supported for GRASS and compass aspect maps."
-msgstr ""
-"Magnitude wird nur für GRASS sowie Kompass-Expositionskarten unterstützt."
+msgstr "Magnitude wird nur für GRASS sowie Kompass-Expositionskarten unterstützt."
 #: ../display/d.rast.arrow/arrow.c:240
 msgid "Scale option requires magnitude_map"
@@ -1969,15 +1827,12 @@
 msgstr "Zeichne nur eine Maßstabsleiste."
 #: ../display/d.barscale/main.c:96
-#, fuzzy
 msgid "Screen coordinates of the rectangle's top-left corner"
-msgstr ""
-"Die Bildschirmkoordinaten für die linke obere Ecke des Labels ([0,0] ist "
-"oben links)."
+msgstr "Bildschirmkoordinaten der linken oberen Ecke des Rechtecks"
 #: ../display/d.barscale/main.c:97
 msgid "(0,0) is top-left of the display frame"
-msgstr ""
+msgstr "(0,0) ist links oben im Fenster"
 #: ../display/d.barscale/main.c:105
 msgid "Font size"
@@ -1997,8 +1852,7 @@
 msgstr "Darstellung, Menue"
 #: ../display/d.menu/main.c:68
-msgid ""
-"Creates and displays a menu within the active frame on the graphics monitor."
+msgid "Creates and displays a menu within the active frame on the graphics monitor."
 msgstr "Erzeugt und stellt ein Menü im aktiven Frame des Grafikfensters dar."
 #: ../display/d.menu/main.c:77
@@ -2028,12 +1882,8 @@
 msgstr "Das Menü muss mindestens einen Titel und eine Option enthalten."
 #: ../display/d.text.freetype/main.c:140
-msgid ""
-"Draws text in the graphics monitor's active display frame using TrueType "
-"fonts."
-msgstr ""
-"Verwende TrueType-Schriften, um Text im aktiven Rahmen des Graphik-Fensters "
-"zu zeichnen."
+msgid "Draws text in the graphics monitor's active display frame using TrueType fonts."
+msgstr "Verwende TrueType-Schriften, um Text im aktiven Rahmen des Graphik-Fensters zu zeichnen."
 #: ../display/d.text.freetype/main.c:154
 msgid "Screen position (percentage, [0,0] is bottom left)"
@@ -2106,8 +1956,7 @@
 #: ../display/d.text.freetype/main.c:645
 #, c-format
 msgid "%s: Unable to read FreeType definition file; use the default"
-msgstr ""
-"%s: Kann die FreeType Definitionsdatei nicht lesen; nehme den Standard."
+msgstr "%s: Kann die FreeType Definitionsdatei nicht lesen; nehme den Standard."
 #: ../display/d.text.freetype/main.c:651
 #, c-format
@@ -2120,12 +1969,8 @@
 msgstr "%s: Kann die FreeType Definitionsdatei nicht lesen."
 #: ../display/d.what.vect/main.c:56
-msgid ""
-"Allows the user to interactively query a vector map layer at user-selected "
-"locations within the current geographic region."
-msgstr ""
-"Erlaubt dem Benutzer das interaktive Abfragen einer Vektorkarte in der "
-"aktuellen Region."
+msgid "Allows the user to interactively query a vector map layer at user-selected locations within the current geographic region."
+msgstr "Erlaubt dem Benutzer das interaktive Abfragen einer Vektorkarte in der aktuellen Region."
 #: ../display/d.what.vect/main.c:74 ../display/d.what.rast/main.c:94
 msgid "Identify just one location"
@@ -2317,9 +2162,7 @@
 #: ../display/d.what.vect/what.c:531
 #, c-format
 msgid " Middle: toggle flash color\n"
-msgstr ""
-" Mitte: wechselt zwischen den Farben, die auf dem Bildschirm aufleuchten "
-"sollen.\n"
+msgstr " Mitte: wechselt zwischen den Farben, die auf dem Bildschirm aufleuchten sollen.\n"
 #: ../display/d.what.vect/what.c:536
 #, c-format
@@ -2468,12 +2311,8 @@
 msgstr "Darstellung, Histogramm, Statistik"
 #: ../display/d.histogram/main.c:73
-msgid ""
-"Displays a histogram in the form of a pie or bar chart for a user-specified "
-"raster map."
-msgstr ""
-"Stellt ein Histogramm in Torten- oder Balkenform für eine angegebene "
-"Rasterkarte dar."
+msgid "Displays a histogram in the form of a pie or bar chart for a user-specified raster map."
+msgstr "Stellt ein Histogramm in Torten- oder Balkenform für eine angegebene Rasterkarte dar."
 #: ../display/d.histogram/main.c:77
 msgid "Raster map for which histogram will be displayed"
@@ -2489,14 +2328,11 @@
 #: ../display/d.histogram/main.c:98
 msgid "Indicate if cell counts or map areas should be displayed"
-msgstr ""
-"Gibt an, ob die Zellenanzahl oder Karteneinheiten angezeigt werden sollen."
+msgstr "Gibt an, ob die Zellenanzahl oder Karteneinheiten angezeigt werden sollen."
 #: ../display/d.histogram/main.c:108
 msgid "Number of steps to divide the data range into (fp maps only)"
-msgstr ""
-"Anzahl der Klassen, in die der Wertebereich geteilt werden soll (nur "
-"Fließkommakarten)"
+msgstr "Anzahl der Klassen, in die der Wertebereich geteilt werden soll (nur Fließkommakarten)"
 #: ../display/d.histogram/main.c:115
 msgid "Display information for null cells"
@@ -2520,12 +2356,8 @@
 msgstr "Wenn der Schalter -C gesetzt ist, wird das Argument nsteps ignoriert."
 #: ../display/d.font/main.c:48 ../display/d.font.freetype/main.c:61
-msgid ""
-"Selects the font in which text will be displayed on the user's graphics "
-"monitor."
-msgstr ""
-"Selektiert die Schriftart, in welcher der Text im Grafikfenster angezeigt "
-"wird."
+msgid "Selects the font in which text will be displayed on the user's graphics monitor."
+msgstr "Selektiert die Schriftart, in welcher der Text im Grafikfenster angezeigt wird."
 #: ../display/d.font/main.c:56
 msgid "Choose new current font"
@@ -2559,11 +2391,8 @@
 #: ../display/d.font/main.c:126
 #, c-format
-msgid ""
-"Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
-msgstr ""
-"Der Name des Fonts <%s> ist nicht gültig. Überprüfe Sie den Namen oder "
-"überlegen Sie 'g.mkfontcap' auszuführen."
+msgid "Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
+msgstr "Der Name des Fonts <%s> ist nicht gültig. Überprüfe Sie den Namen oder überlegen Sie 'g.mkfontcap' auszuführen."
 #: ../display/d.font.freetype/main.c:68
 msgid "Font name or pathname of TTF file"
@@ -2574,27 +2403,16 @@
 msgstr "Einstellunge des FreeType-Releases"
 #: ../display/d.mapgraph/main.c:50
-msgid ""
-"Generates and displays simple graphics on map layers drawn in the active "
-"graphics monitor display frame."
-msgstr ""
-"Erzeugt und stellt einfache Grafiken auf Karten im aktiven Grafikfenster dar."
+msgid "Generates and displays simple graphics on map layers drawn in the active graphics monitor display frame."
+msgstr "Erzeugt und stellt einfache Grafiken auf Karten im aktiven Grafikfenster dar."
 #: ../display/d.mapgraph/main.c:57
-msgid ""
-"Unix file containg graphing instructions, if not given reads from standard "
-"input"
-msgstr ""
-"Unix-Datei, die Graphik-Instruktionen enthält. Falls diese nicht angegeben "
-"ist, wird von der Standardeingabe gelesen."
+msgid "Unix file containg graphing instructions, if not given reads from standard input"
+msgstr "Unix-Datei, die Graphik-Instruktionen enthält. Falls diese nicht angegeben ist, wird von der Standardeingabe gelesen."
 #: ../display/d.mapgraph/main.c:67
-msgid ""
-"Color to draw with, either a standard GRASS color or R:G:B triplet "
-"(separated by colons)"
-msgstr ""
-"Farbe, die benutzt werden soll. Entweder GRASS Standardfarben oder R:G:B "
-"Tripel (durch Doppelpunkte getrennt)."
+msgid "Color to draw with, either a standard GRASS color or R:G:B triplet (separated by colons)"
+msgstr "Farbe, die benutzt werden soll. Entweder GRASS Standardfarben oder R:G:B Tripel (durch Doppelpunkte getrennt)."
 #: ../display/d.grid/plot.c:203 ../display/d.grid/plot.c:209
 #: ../display/d.grid/plot.c:259 ../display/d.grid/plot.c:265
@@ -2633,8 +2451,7 @@
 "datum transformation parameters. Try running g.setproj."
 msgstr ""
 "Ausgabe in WGS84 ist unmöglich, da diese Location keine Datums-\n"
-"Transformationsparameter enthält. Versuchen Sie vorher 'g.setproj' zu "
-"benutzen."
+"Transformationsparameter enthält. Versuchen Sie vorher 'g.setproj' zu benutzen."
 #: ../display/d.grid/plot.c:512
 msgid "Error in pj_do_proj1"
@@ -2657,9 +2474,7 @@
 msgstr "Fehler in pj_do_proj6"
 #: ../display/d.grid/main.c:53
-msgid ""
-"Overlays a user-specified grid in the active display frame on the graphics "
-"monitor."
+msgid "Overlays a user-specified grid in the active display frame on the graphics monitor."
 msgstr "Überlagert ein benutzerdefiniertes Gitter im aktiven Grafikfenster."
 #: ../display/d.grid/main.c:61
@@ -2668,9 +2483,7 @@
 #: ../display/d.grid/main.c:62
 msgid "In map units or DDD:MM:SS format. Example: \"1000\" or \"0:10\""
-msgstr ""
-"In Karteneinheiten oder im DDD:MM:SS Format.  Beispiel: \"1000\" oder "
-"\"0:10\""
+msgstr "In Karteneinheiten oder im DDD:MM:SS Format.  Beispiel: \"1000\" oder \"0:10\""
 #: ../display/d.grid/main.c:71
 msgid "Lines of the grid pass through this coordinate"
@@ -2820,21 +2633,15 @@
 #: ../display/d.zoom/zoom.c:42
 #, c-format
 msgid "Note: run 'd.erase' for the new region to affect the graphics.\n"
-msgstr ""
-"Hinweis: Bitte benutzen Sie 'd.erase', um das Grafikfenster auf die neue "
-"Region einzustellen.\n"
+msgstr "Hinweis: Bitte benutzen Sie 'd.erase', um das Grafikfenster auf die neue Region einzustellen.\n"
 #: ../display/d.zoom/main.c:57
 msgid "display, zoom"
 msgstr "Darstellung, Zoom"
 #: ../display/d.zoom/main.c:59
-msgid ""
-"Allows the user to change the current geographic region settings "
-"interactively, with a mouse."
-msgstr ""
-"Erlaubt dem Benutzer die altuelle geographische Region interaktiv mit der "
-"Maus zu ändern."
+msgid "Allows the user to change the current geographic region settings interactively, with a mouse."
+msgstr "Erlaubt dem Benutzer die altuelle geographische Region interaktiv mit der Maus zu ändern."
 #: ../display/d.zoom/main.c:100
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:4
@@ -2913,12 +2720,8 @@
 msgstr "Darstellung, Geometrie"
 #: ../display/d.measure/main.c:51
-msgid ""
-"Measures the lengths and areas of features drawn by the user in the active "
-"display frame on the graphics monitor."
-msgstr ""
-"Misst die Länge und Fläche von Objekten, gezeichnet vom Benutzer, im aktiven "
-"Grafikfenster."
+msgid "Measures the lengths and areas of features drawn by the user in the active display frame on the graphics monitor."
+msgstr "Misst die Länge und Fläche von Objekten, gezeichnet vom Benutzer, im aktiven Grafikfenster."
 #: ../display/d.measure/main.c:57
 msgid "Line color 1"
@@ -2962,24 +2765,16 @@
 msgstr "Kann Symbol nicht lesen; stelle daher die Punkte nicht dar."
 #: ../display/d.graph/main.c:56
-msgid ""
-"Program for generating and displaying simple graphics on the display monitor."
-msgstr ""
-"Programm zum Erstellen und Anzeigen von einfachen Grafiken im Grafikfenster."
+msgid "Program for generating and displaying simple graphics on the display monitor."
+msgstr "Programm zum Erstellen und Anzeigen von einfachen Grafiken im Grafikfenster."
 #: ../display/d.graph/main.c:63
-msgid ""
-"Name of file containing graphics commands, if not given reads from standard "
-"input"
-msgstr ""
-"Name der Datei, die Graph>ikkommandos enthält. Falls nicht angegeben, wird "
-"von der Standardeingabe gelesen."
+msgid "Name of file containing graphics commands, if not given reads from standard input"
+msgstr "Name der Datei, die Graph>ikkommandos enthält. Falls nicht angegeben, wird von der Standardeingabe gelesen."
 #: ../display/d.graph/main.c:71
 msgid "Color to draw with, either a standard GRASS color or R:G:B triplet"
-msgstr ""
-"Farbe zum Zeichnen, entweder eine GRASS Standard-Farbe oder eine R:G:B-"
-"Tripel."
+msgstr "Farbe zum Zeichnen, entweder eine GRASS Standard-Farbe oder eine R:G:B-Tripel."
 #: ../display/d.graph/main.c:78
 msgid "Coordinates are given in map units"
@@ -3000,13 +2795,8 @@
 msgstr "Editiere interaktiv Zellwerte einer Rasterkarte."
 #: ../display/d.geodesic/main.c:47
-msgid ""
-"Displays a geodesic line, tracing the shortest distance between two "
-"geographic points along a great circle, in a longitude/latitude data set."
-msgstr ""
-"Stellt eine geodätische Linie, die kürzeste Distanz zwischen zwei "
-"geographischen Punkten auf dem Großkreis, in einem longitude/latitude "
-"Datensatz dar"
+msgid "Displays a geodesic line, tracing the shortest distance between two geographic points along a great circle, in a longitude/latitude data set."
+msgstr "Stellt eine geodätische Linie, die kürzeste Distanz zwischen zwei geographischen Punkten auf dem Großkreis, in einem longitude/latitude Datensatz dar"
 #: ../display/d.geodesic/main.c:70
 msgid "Text color or \"none\""
@@ -3017,12 +2807,8 @@
 msgstr "Darstellung, Position, Abfrage"
 #: ../display/d.where/main.c:44
-msgid ""
-"Identifies the geographic coordinates associated with point locations in the "
-"active frame on the graphics monitor."
-msgstr ""
-"Identifiziert geographische Koordinaten an einem gegebenen Punkt im Grafik-"
-"Fenster."
+msgid "Identifies the geographic coordinates associated with point locations in the active frame on the graphics monitor."
+msgstr "Identifiziert geographische Koordinaten an einem gegebenen Punkt im Grafik-Fenster."
 #: ../display/d.where/main.c:49
 msgid "One mouse click only"
@@ -3037,13 +2823,8 @@
 msgstr "Ausgabe auf den aktuellen Ellipsoid referenziert."
 #: ../display/d.where/main.c:63
-msgid ""
-"Output lat/long referenced to WGS84 ellipsoid using datum transformation "
-"parameters defined in current location (if available)"
-msgstr ""
-"Gibt Lat/long Ausgabe auf einen WGS84-Ellipsoiden mit den definierten "
-"Datumstransformationsparametern der aktuellen Location (sofern vorhanden) "
-"aus."
+msgid "Output lat/long referenced to WGS84 ellipsoid using datum transformation parameters defined in current location (if available)"
+msgstr "Gibt Lat/long Ausgabe auf einen WGS84-Ellipsoiden mit den definierten Datumstransformationsparametern der aktuellen Location (sofern vorhanden) aus."
 #: ../display/d.where/main.c:69
 msgid "Output frame coordinates of current display monitor (percentage)"
@@ -3055,15 +2836,13 @@
 #: ../display/d.where/main.c:80
 msgid "Please specify a lat/long ellipsoid with -l or -w"
-msgstr ""
-"Bitte geben Sie einen Lat/Long-Ellipsoiden mit den Optionen -l oder -w an."
+msgstr "Bitte geben Sie einen Lat/Long-Ellipsoiden mit den Optionen -l oder -w an."
 #: ../display/d.where/main.c:93 ../general/g.region/printwindow.c:247
 #: ../general/g.region/printwindow.c:503 ../general/g.region/printwindow.c:622
 #: ../raster/r.horizon/main.c:477 ../raster/r.sun2/main.c:728
 msgid "Can't get projection info of current location"
-msgstr ""
-"Kann die Projektionsinformation der aktuellen Location nicht ermitteln."
+msgstr "Kann die Projektionsinformation der aktuellen Location nicht ermitteln."
 #: ../display/d.where/main.c:96 ../general/g.region/printwindow.c:250
 #: ../general/g.region/printwindow.c:506 ../general/g.region/printwindow.c:625
@@ -3076,10 +2855,7 @@
 msgid ""
 "WGS84 output not possible as this location does not contain\n"
-msgstr ""
-"Ausgabe in WGS84A ist unmöglich, da diese Location keine Datums-"
-"benutzen."
+msgstr "Ausgabe in WGS84A ist unmöglich, da diese Location keine Datums-Transformationsparameter enthält. Versuchen Sie vorher 'g.setproj' zu benutzen."
 #: ../display/d.frame/select.c:41
 #, c-format
@@ -3156,8 +2932,7 @@
 #: ../display/d.frame/frame.c:107
 msgid "Where to place the frame, values in percent (implies -c)"
-msgstr ""
-"Wo soll das Fenster platziert werden? Werte in Prozent (impliziert -c)."
+msgstr "Wo soll das Fenster platziert werden? Werte in Prozent (impliziert -c)."
 #: ../display/d.vect/label.c:28 ../display/d.vect/attr.c:53
 #: ../display/d.vect/dir.c:31
@@ -3175,15 +2950,8 @@
 #: ../display/d.vect/plot1.c:233 ../display/d.vect/area.c:83
 #, c-format
-msgid ""
-"Color definition column ('%s') not a string. Column must be of form 'RRR:GGG:"
-"BBB' where RGB values range 0-255. You can use '%s' module to define color "
-"rules. Unable to colorize features."
-msgstr ""
-"Farbdefinitionsspalte ('%s') ist keine Zeichenkette. Die Spalte muss die "
-"Form 'RRR:GGG:BBB' haben. Die RGB-Werte müssen zwischen 0 und 255 liegen. "
-"Sie können das Modul '%s' verwenden um Farbregeln zu definieren. Kann die "
-"Objekte nicht einfärben."
+msgid "Color definition column ('%s') not a string. Column must be of form 'RRR:GGG:BBB' where RGB values range 0-255. You can use '%s' module to define color rules. Unable to colorize features."
+msgstr "Farbdefinitionsspalte ('%s') ist keine Zeichenkette. Die Spalte muss die Form 'RRR:GGG:BBB' haben. Die RGB-Werte müssen zwischen 0 und 255 liegen. Sie können das Modul '%s' verwenden um Farbregeln zu definieren. Kann die Objekte nicht einfärben."
 #: ../display/d.vect/plot1.c:276
 #, c-format
@@ -3220,12 +2988,8 @@
 #: ../display/d.vect/plot1.c:511
 #, c-format
-msgid ""
-"Error in color definition column '%s', feature id %d with cat %d: "
-"colorstring '%s'"
-msgstr ""
-"Fehler in der Spalte mit den Farbwerten '%s', Objekt ID %d mit cat %d: "
-"Farbwert '%s'."
+msgid "Error in color definition column '%s', feature id %d with cat %d: colorstring '%s'"
+msgstr "Fehler in der Spalte mit den Farbwerten '%s', Objekt ID %d mit cat %d: Farbwert '%s'."
 #: ../display/d.vect/plot1.c:519
 #, c-format
@@ -3234,11 +2998,8 @@
 #: ../display/d.vect/plot1.c:641
 #, c-format
-msgid ""
-"Error in symbol size column (%s), element %d with cat %d: symbol size [%f]"
-msgstr ""
-"Fehler in der Symbolgrößen-Spalte (%s), Element %d mit cat %d: Symbolgröße "
-"[%f]."
+msgid "Error in symbol size column (%s), element %d with cat %d: symbol size [%f]"
+msgstr "Fehler in der Symbolgrößen-Spalte (%s), Element %d mit cat %d: Symbolgröße [%f]."
 #: ../display/d.vect/plot1.c:729
 #, c-format
@@ -3254,17 +3015,8 @@
 msgstr "Darstellung"
 #: ../display/d.vect/main.c:92
-msgid ""
-"shape;Display geometry of features;cat;Display category numbers of features;"
-"topo;Display topology information (nodes, edges);dir;Display direction of "
-"linear features;attr;Display selected attribute based on 'attrcol';zcoor;"
-"Display z-coordinate of features (only for 3D vector maps)"
-msgstr ""
-"shape;Anzeige der Geometrie der Objekte;cat;Anzeige der Kategorienummern der "
-"Objekte;topo;Anzeige der Topologieinformationen (nodes, edges);dir;Anzeige "
-"der Richtung von linearen Objekten;attr;Anzeige der ausgewählten Attribute "
-"basierend auf 'attrcol';zcoor;Anzeige der z-Kooridinate der Objekte (nur für "
-"3D Vektorkarten)"
+msgid "shape;Display geometry of features;cat;Display category numbers of features;topo;Display topology information (nodes, edges);dir;Display direction of linear features;attr;Display selected attribute based on 'attrcol';zcoor;Display z-coordinate of features (only for 3D vector maps)"
+msgstr "shape;Anzeige der Geometrie der Objekte;cat;Anzeige der Kategorienummern der Objekte;topo;Anzeige der Topologieinformationen (nodes, edges);dir;Anzeige der Richtung von linearen Objekten;attr;Anzeige der ausgewählten Attribute basierend auf 'attrcol';zcoor;Anzeige der z-Kooridinate der Objekte (nur für 3D Vektorkarten)"
 #: ../display/d.vect/main.c:107
 msgid "Layer number (if -1, all layers are displayed)"
@@ -3302,8 +3054,7 @@
 #: ../display/d.vect/main.c:165
 msgid "Name of column for line widths (these values will be scaled by wscale)"
-msgstr ""
-"Name der Spalte für die Linienbreite (Werte werden über wscale skaliert)."
+msgstr "Name der Spalte für die Linienbreite (Werte werden über wscale skaliert)."
 #: ../display/d.vect/main.c:172
 msgid "Scale factor for wcolumn"
@@ -3324,9 +3075,7 @@
 #: ../display/d.vect/main.c:193
 msgid "When used with the size_column option this becomes the scale factor"
-msgstr ""
-"Dies wird der Skalierungsfaktor, wenn es zusammen mit der Option size_column "
-"verwendet wird."
+msgstr "Dies wird der Skalierungsfaktor, wenn es zusammen mit der Option size_column verwendet wird."
 #: ../display/d.vect/main.c:199
 msgid "Name of numeric column containing symbol size"
@@ -3350,9 +3099,7 @@
 #: ../display/d.vect/main.c:214
 msgid "Layer number for labels (default: the given layer number)"
-msgstr ""
-"Layernummer für die Beschriftungen (Standard: die bereits gegebene "
-"Layernummer)."
+msgstr "Layernummer für die Beschriftungen (Standard: die bereits gegebene Layernummer)."
 #: ../display/d.vect/main.c:220
 msgid "Name of column to be displayed"
@@ -3387,33 +3134,16 @@
 msgstr "Vertikale Labelausrichtung"
 #: ../display/d.vect/main.c:285
-msgid ""
-"Minimum region size (average from height and width) when map is displayed"
-msgstr ""
-"Minimale Größe der Region (Durchschnitt von Höhe und Breite) beim Zeichnen "
-"der Karte."
+msgid "Minimum region size (average from height and width) when map is displayed"
+msgstr "Minimale Größe der Region (Durchschnitt von Höhe und Breite) beim Zeichnen der Karte."
 #: ../display/d.vect/main.c:293
-msgid ""
-"Maximum region size (average from height and width) when map is displayed"
-msgstr ""
-"Maximale Größe der Region (Durchschnitt von Höhe und Breite) beim Zeichnen "
-"der Karte."
+msgid "Maximum region size (average from height and width) when map is displayed"
+msgstr "Maximale Größe der Region (Durchschnitt von Höhe und Breite) beim Zeichnen der Karte."
 #: ../display/d.vect/main.c:305
-msgid ""
-"g;use the libgis render functions (features: clipping);r;use the raster "
-"graphics library functions (features: polylines);d;use the display library "
-"basic functions (features: polylines);c;use the display library clipping "
-"functions (features: clipping);l;use the display library culling functions "
-"(features: culling, polylines)"
-msgstr ""
-"g;Verwende Render-Funktion von libgis (Objekte: clippen);r;verwende Render-"
-"Funktion der Rastergrafik-Bibliothek (Objekte: Polylinien);d;Verwende "
-"grundlegende Funktionen der Displaybibliothek (Objekte: Polylinien);c;"
-"Verwende Clipping-Funktion der Displaybibliothek (Objekte: clippen);l;"
-"Verwende Culling-Funktion der der Displaybibliothek (Objekte: Beschneiden, "
-"Polylinien)"
+msgid "g;use the libgis render functions (features: clipping);r;use the raster graphics library functions (features: polylines);d;use the display library basic functions (features: polylines);c;use the display library clipping functions (features: clipping);l;use the display library culling functions (features: culling, polylines)"
+msgstr "g;Verwende Render-Funktion von libgis (Objekte: clippen);r;verwende Render-Funktion der Rastergrafik-Bibliothek (Objekte: Polylinien);d;Verwende grundlegende Funktionen der Displaybibliothek (Objekte: Polylinien);c;Verwende Clipping-Funktion der Displaybibliothek (Objekte: clippen);l;Verwende Culling-Funktion der der Displaybibliothek (Objekte: Beschneiden, Polylinien)"
 #: ../display/d.vect/main.c:314 ../raster/r.cost/main.c:229
 #: ../raster/wildfire/r.ros/main.c:301
@@ -3426,24 +3156,16 @@
 msgstr "Hole die Farbe aus der Tabellenspalte (RRR:GGG:BBB)."
 #: ../display/d.vect/main.c:327
-msgid ""
-"Random colors according to category number (or layer number if 'layer=-1' is "
-"given)"
-msgstr ""
-"Füllt die Flächen mit zufälligen Farben entsprechend den Kategorienummern "
-"(oder der Layernummer, wenn 'layer=-1' angegeben wurde)."
+msgid "Random colors according to category number (or layer number if 'layer=-1' is given)"
+msgstr "Füllt die Flächen mit zufälligen Farben entsprechend den Kategorienummern (oder der Layernummer, wenn 'layer=-1' angegeben wurde)."
 #: ../display/d.vect/main.c:334
 msgid "Use values from 'cats' option as feature id"
 msgstr "Verwende Werte der Option 'cats' Option als Fature-ID."
 #: ../display/d.vect/main.c:339
-msgid ""
-"Don't add to list of vectors and commands in monitor (it won't be drawn if "
-"the monitor is refreshed)"
-msgstr ""
-"Nicht zu der Liste der Vektorkarten und Kommandos im Monitor hinzufügen (Die "
-"Vektorkarte wird nicht gezeichnet, wenn das Grafikfenster aktualisiert wird)."
+msgid "Don't add to list of vectors and commands in monitor (it won't be drawn if the monitor is refreshed)"
+msgstr "Nicht zu der Liste der Vektorkarten und Kommandos im Monitor hinzufügen (Die Vektorkarte wird nicht gezeichnet, wenn das Grafikfenster aktualisiert wird)."
 #: ../display/d.vect/main.c:344
 msgid "Colorize polygons according to z height"
@@ -3454,20 +3176,12 @@
 #: ../raster/wildfire/r.ros/main.c:314 ../raster/wildfire/r.spread/main.c:255
 #: ../raster/r.out.mat/main.c:90 ../raster/r.in.mat/main.c:125
 #: ../raster/r.out.tiff/r.out.tiff.c:144
-msgid ""
-"The '-v' flag is superseded and will be removed in future. Please use '--"
-"verbose' instead."
-msgstr ""
-"Der Schalter '-v' wurde ersetzt und in Zukunft entfernt. Bitte verwenden Sie "
-"stattdessen '--verbose'."
+msgid "The '-v' flag is superseded and will be removed in future. Please use '--verbose' instead."
+msgstr "Der Schalter '-v' wurde ersetzt und in Zukunft entfernt. Bitte verwenden Sie stattdessen '--verbose'."
 #: ../display/d.vect/main.c:411
-msgid ""
-"The '-c' and '-a' flags cannot be used together, the '-c' flag will be "
-"ignored!"
-msgstr ""
-"Die Schalter '-c' und '-a' können nicht gemeinsam verwendet werden. Der "
-"Schalter '-c' wird ignoriert!"
+msgid "The '-c' and '-a' flags cannot be used together, the '-c' flag will be ignored!"
+msgstr "Die Schalter '-c' und '-a' können nicht gemeinsam verwendet werden. Der Schalter '-c' wird ignoriert!"
 #: ../display/d.vect/main.c:442
 #, c-format
@@ -3477,8 +3191,7 @@
 #: ../display/d.vect/main.c:463 ../vector/v.univar/main.c:205
 #: ../vector/v.surf.rst/main.c:450 ../vector/v.extract/main.c:274
 msgid "'layer' must be > 0 for 'where'."
-msgstr ""
-"Parameter 'layer' muss > 0 sein, wenn der Parameter 'where' angegeben ist."
+msgstr "Parameter 'layer' muss > 0 sein, wenn der Parameter 'where' angegeben ist."
 #: ../display/d.vect/main.c:490
 msgid "'layer' must be > 0 for 'cats'."
@@ -3495,9 +3208,7 @@
 #: ../display/d.vect/main.c:630
 msgid "Unable to display lines by id, topology not available"
-msgstr ""
-"Kann die Linien nicht mittels ihrer ID darstellen, da die Topologie nicht "
-"vorhanden ist."
+msgstr "Kann die Linien nicht mittels ihrer ID darstellen, da die Topologie nicht vorhanden ist."
 #: ../display/d.vect/main.c:673
 msgid "Unable to display topology, not available"
@@ -3509,11 +3220,8 @@
 #: ../display/d.vect/area.c:302
 #, c-format
-msgid ""
-"Error in color definition column (%s), area %d with cat %d: colorstring [%s]"
-msgstr ""
-"Fehler in der Spalten mit den Frabwerten (%s), Fläche %d mit cat %d: "
-"Farbwert [%s]."
+msgid "Error in color definition column (%s), area %d with cat %d: colorstring [%s]"
+msgstr "Fehler in der Spalten mit den Frabwerten (%s), Fläche %d mit cat %d: Farbwert [%s]."
 #: ../display/d.vect/area.c:308
 #, c-format
@@ -3637,24 +3345,15 @@
 #: ../display/d.erase/main.c:34
 msgid "Erase the contents of the active display frame with user defined color"
-msgstr ""
-"Löscht den Inhalte des aktiven Grafikfensters mit einer benutzerdefinierten "
-"Farbe."
+msgstr "Löscht den Inhalte des aktiven Grafikfensters mit einer benutzerdefinierten Farbe."
 #: ../display/d.erase/main.c:42
-msgid ""
-"Color to erase with, either a standard GRASS color or R:G:B triplet "
-msgstr ""
-"Farbe zum Löschen, entweder als GRASS Standard-Farbe oder als R:G:B-Tripel "
-"(Semicolon als Trennzeichen)."
+msgid "Color to erase with, either a standard GRASS color or R:G:B triplet (separated by colons)"
+msgstr "Farbe zum Löschen, entweder als GRASS Standard-Farbe oder als R:G:B-Tripel (Semicolon als Trennzeichen)."
 #: ../display/d.title/main.c:47
-msgid ""
-"Create a TITLE for a raster map in a form suitable for display with d.text."
-msgstr ""
-"Erzeugt einen Titel für eine Rasterkarte in einer geeigneten Form für die "
-"Darstellung mit d.text."
+msgid "Create a TITLE for a raster map in a form suitable for display with d.text."
+msgstr "Erzeugt einen Titel für eine Rasterkarte in einer geeigneten Form für die Darstellung mit d.text."
 #: ../display/d.title/main.c:58
 msgid "Sets the text color"
@@ -3700,13 +3399,8 @@
 msgstr "Kann die Kategorie-Datei der Rasterkarte <%s@%s> nicht lesen."
 #: ../display/d.what.rast/main.c:54
-msgid ""
-"Allows the user to interactively query the category contents of multiple "
-"raster map layers at user specified locations within the current geographic "
-"region."
-msgstr ""
-"Erlaubt dem Nutzer interaktiv mehrere Rasterkartenkategorien übereinander an "
-"einem angeklickten Punkt in der aktuellen Region abzufragen."
+msgid "Allows the user to interactively query the category contents of multiple raster map layers at user specified locations within the current geographic region."
+msgstr "Erlaubt dem Nutzer interaktiv mehrere Rasterkartenkategorien übereinander an einem angeklickten Punkt in der aktuellen Region abzufragen."
 #: ../display/d.what.rast/main.c:81 ../raster/r.compress/main.c:73
 msgid "Name of existing raster map(s)"
@@ -3718,9 +3412,7 @@
 #: ../display/d.what.rast/main.c:103
 msgid "Print out col/row for the entire map in grid resolution of the region"
-msgstr ""
-"Gebe Zeile/Spalte für die gesamte Karte in der aktuellen Auflösung der "
-"Region aus."
+msgstr "Gebe Zeile/Spalte für die gesamte Karte in der aktuellen Auflösung der Region aus."
 #: ../display/d.what.rast/main.c:128
 msgid "Setting graphics window"
@@ -3748,8 +3440,7 @@
 #: ../display/d.profile/main.c:63
 msgid "Interactive profile plotting utility with optional output."
-msgstr ""
-"Interaktives Werkzeug zum Zeichnen von Profilen mit optionales Ausgabe."
+msgstr "Interaktives Werkzeug zum Zeichnen von Profilen mit optionales Ausgabe."
 #: ../display/d.profile/main.c:71
 msgid "Raster map to be profiled"
@@ -3780,8 +3471,7 @@
 #: ../display/d.profile/main.c:199 ../display/d.profile/main.c:393
 msgid "Use 'd.frame -e' to remove left over frames"
-msgstr ""
-"Benutzen Sie bitte 'd.frame -e' um übrig gebliebene Rahmen zu entfernen."
+msgstr "Benutzen Sie bitte 'd.frame -e' um übrig gebliebene Rahmen zu entfernen."
 #: ../display/d.profile/main.c:283
 msgid "Error opening cell-file"
@@ -3895,12 +3585,8 @@
 #: ../db/drivers/mysql/describe.c:126
 #, c-format
-msgid ""
-"column '%s' : type BIGINT is stored as integer (4 bytes) some data may be "
-"damaged"
-msgstr ""
-"Spalte '%s' : Typ BIGINT wird als integer (4 Byte) abgespeichert. Einige "
-"Datensätze könnten beschädigt sein."
+msgid "column '%s' : type BIGINT is stored as integer (4 bytes) some data may be damaged"
+msgstr "Spalte '%s' : Typ BIGINT wird als integer (4 Byte) abgespeichert. Einige Datensätze könnten beschädigt sein."
 #: ../db/drivers/mysql/parse.c:60
 msgid "Wrong port number in MySQL database definition: "
@@ -3908,15 +3594,11 @@
 #: ../db/drivers/mysql/parse.c:71 ../db/drivers/postgres/parse.c:55
 msgid "'user' in database definition is not supported, use db.login"
-msgstr ""
-"'user' in der Datenbankdefinition wird nicht unterstützt. Bitte 'db.login' "
-"verwenden."
+msgstr "'user' in der Datenbankdefinition wird nicht unterstützt. Bitte 'db.login' verwenden."
 #: ../db/drivers/mysql/parse.c:75 ../db/drivers/postgres/parse.c:59
 msgid "'password' in database definition is not supported, use db.login"
-msgstr ""
-"'Password' in der Datenbankdefinition wird nicht unterstützt. Bitte 'db."
-"login' verwenden."
+msgstr "'Password' in der Datenbankdefinition wird nicht unterstützt. Bitte 'db.login' verwenden."
 #: ../db/drivers/mysql/parse.c:79
 msgid "Unknown option in database definition for "
@@ -3929,8 +3611,7 @@
 #: ../db/drivers/postgres/describe.c:103
 #, c-format
 msgid "pg driver: PostGIS column '%s', type 'geometry'  will not be converted"
-msgstr ""
-"PG-Treiber: PostGIS Spalte '%s', vom Typ 'geometry'  wird nicht konvertiert."
+msgstr "PG-Treiber: PostGIS Spalte '%s', vom Typ 'geometry'  wird nicht konvertiert."
 #: ../db/drivers/postgres/describe.c:109
 #, c-format
@@ -3939,30 +3620,18 @@
 #: ../db/drivers/postgres/describe.c:116
 #, c-format
-msgid ""
-"column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data "
-"may be damaged"
-msgstr ""
-"Spalte '%s' : Typ int8 (bigint) wird als integer (4 Byte) abgespeichert. "
-"Einige Datensätze könnten beschädigt sein."
+msgid "column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data may be damaged"
+msgstr "Spalte '%s' : Typ int8 (bigint) wird als integer (4 Byte) abgespeichert. Einige Datensätze könnten beschädigt sein."
 #: ../db/drivers/postgres/describe.c:120
 #, c-format
-msgid ""
-"column '%s' : type character varying is stored as varchar(250) some data may "
-"be lost"
-msgstr ""
-"Spalte '%s' : Typ 'character' wird als Typ varchar(250) abgespeichert. "
-"Einige Daten könnten verloren gehen."
+msgid "column '%s' : type character varying is stored as varchar(250) some data may be lost"
+msgstr "Spalte '%s' : Typ 'character' wird als Typ varchar(250) abgespeichert. Einige Daten könnten verloren gehen."
 #: ../db/drivers/postgres/describe.c:126
 #, c-format
-msgid ""
-"column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 "
-"(true)"
-msgstr ""
-"Spalte '%s' : Typ bool (boolean) wird als Typ char(1) mit den Werten 0 "
-"(falsch), 1 (wahr) abgespeichert."
+msgid "column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 (true)"
+msgstr "Spalte '%s' : Typ bool (boolean) wird als Typ char(1) mit den Werten 0 (falsch), 1 (wahr) abgespeichert."
 #: ../db/drivers/postgres/parse.c:63
 msgid "Unknown option in database definition for PostgreSQL: "
@@ -3979,12 +3648,8 @@
 #: ../db/drivers/ogr/describe.c:157
 #, c-format
-msgid ""
-"column '%s', type 'string': unknown width -> stored as varchar(250) some "
-"data may be lost"
-msgstr ""
-"Spalte '%s', Typ 'string': unbekannte Breite -> als Datentyp varchar(250) "
-"abgespeichert. Einige Daten könnten verloren gehen."
+msgid "column '%s', type 'string': unknown width -> stored as varchar(250) some data may be lost"
+msgstr "Spalte '%s', Typ 'string': unbekannte Breite -> als Datentyp varchar(250) abgespeichert. Einige Daten könnten verloren gehen."
 #: ../db/drivers/sqlite/db.c:85
 msgid "Unable to open database: "
@@ -4087,9 +3752,9 @@
 msgstr "Kann Benutzer/Passwort nicht setzen."
 #: ../db/db.login/main.c:114
-#, fuzzy, c-format
+#, c-format
 msgid "The password was stored in file (%s/.grasslogin64)"
-msgstr "Das Passwort wurde in einer Datei gespeichert."
+msgstr "Das Passwort wurde in der Datei  (%s/.grasslogin64) gespeichert."
 #: ../db/base/connect.c:45
 msgid "database, attribute table, connection settings"
@@ -4097,9 +3762,7 @@
 #: ../db/base/connect.c:47
 msgid "Prints/sets general DB connection for current mapset and exits."
-msgstr ""
-"Gibt oder setzt generelle Datenbankverbindung für das aktuelle Mapset und "
-"beendet sich."
+msgstr "Gibt oder setzt generelle Datenbankverbindung für das aktuelle Mapset und beendet sich."
 #: ../db/base/connect.c:51
 msgid "Print current connection parameters and exit"
@@ -4138,20 +3801,15 @@
 #: ../db/base/connect.c:57
 msgid "Check connection parameters, set if uninitialized, and exit"
-msgstr ""
-"Prüfe die Verbindungsparameter, setzt sie wenn nicht vorhanden und beendet "
-"sich."
+msgstr "Prüfe die Verbindungsparameter, setzt sie wenn nicht vorhanden und beendet sich."
 #: ../db/base/connect.c:74
 msgid "Database schema"
 msgstr "Datenbank-Schema"
 #: ../db/base/connect.c:75
-msgid ""
-"Do not use this option if schemas are not supported by driver/database server"
-msgstr ""
-"Bitte benutzen Sie diese Option nicht, wenn Schemas nicht durch ihre "
-"Datenbank / Server unterstützt werden."
+msgid "Do not use this option if schemas are not supported by driver/database server"
+msgstr "Bitte benutzen Sie diese Option nicht, wenn Schemas nicht durch ihre Datenbank / Server unterstützt werden."
 #: ../db/base/connect.c:85
 msgid "Default group of database users to which select privilege is granted"
@@ -4217,9 +3875,9 @@
 #: ../db/base/columns.c:44 ../db/base/select.c:53 ../db/base/copy.c:100
 #: ../db/base/describe.c:51
-#, fuzzy, c-format
+#, c-format
 msgid "Table <%s> not found in database <%s> using driver <%s>"
-msgstr "Kann Datenbank <%s> nicht mit dem Treiber <%s> öffnen."
+msgstr "Tabelle <%s>  in der Datenbank <%s> mit dem Treiber <%s> nicht gefunden."
 #: ../db/base/columns.c:99
 msgid "List all columns for a given table."
@@ -4287,9 +3945,7 @@
 #: ../raster/r.univar2/r.univar_main.c:42 ../raster/r.stats/main.c:114
 #: ../vector/v.db.select/main.c:84
 msgid "Name for output file (if omitted or \"-\" output to stdout)"
-msgstr ""
-"Name der Ausgabekarte (wenn keiner oder \"-\"  angegeben wurdeerfolgt die "
-"Ausgabe nach stdout)."
+msgstr "Name der Ausgabekarte (wenn keiner oder \"-\"  angegeben wurdeerfolgt die Ausgabe nach stdout)."
 #: ../db/base/select.c:245 ../vector/v.db.select/main.c:93
 msgid "Do not include column names in output"
@@ -4313,22 +3969,15 @@
 #: ../db/base/select.c:264
 msgid "Selects data from attribute table (performs SQL query statement(s))."
-msgstr ""
-"Wählt Daten von der Attributtabelle aus (führt SQL-Abfrage-Anweisung(en) "
-"aus)."
+msgstr "Wählt Daten von der Attributtabelle aus (führt SQL-Abfrage-Anweisung(en) aus)."
 #: ../db/base/copy.c:38
 msgid "Copy a table."
 msgstr "Kopiere eine Tabelle."
 #: ../db/base/copy.c:40
-msgid ""
-"Either 'from_table' (optionally with 'where') can be used or 'select' "
-"option, but not 'from_table' and 'select' at the same time."
-msgstr ""
-"Es kann entweder die Option 'from_table' (auch mit 'WHERE') oder die "
-"'select'-Option verwendet werden, aber nicht 'from_table' und 'select' "
-"können zur selben Zeit."
+msgid "Either 'from_table' (optionally with 'where') can be used or 'select' option, but not 'from_table' and 'select' at the same time."
+msgstr "Es kann entweder die Option 'from_table' (auch mit 'WHERE') oder die 'select'-Option verwendet werden, aber nicht 'from_table' und 'select' können zur selben Zeit."
 #: ../db/base/copy.c:46
 msgid "Input driver name"
@@ -4340,8 +3989,7 @@
 #: ../db/base/copy.c:59
 msgid "Input table name (only, if 'select' is not used)"
-msgstr ""
-"Name der Eingabe-Tabelle (nur wenn 'SELECT'-Statement nicht benutzt wird)."
+msgstr "Name der Eingabe-Tabelle (nur wenn 'SELECT'-Statement nicht benutzt wird)."
 #: ../db/base/copy.c:65
 msgid "Output driver name"
@@ -4357,9 +4005,7 @@
 #: ../db/base/copy.c:87
 msgid "Full select statement (only, if 'from_table' and 'where' is not used)"
-msgstr ""
-"Vollständiger Select-Ausdruck (nur wenn 'from_table' und 'where' nicht "
-"verwendet werden)."
+msgstr "Vollständiger Select-Ausdruck (nur wenn 'from_table' und 'where' nicht verwendet werden)."
 #: ../db/base/copy.c:88
 msgid "E.g.: SELECT dedek FROM starobince WHERE obec = 'Frimburg'"
@@ -4476,12 +4122,8 @@
 msgstr "Verschiedenes, Distanz"
 #: ../misc/m.cogo/main.c:228
-msgid ""
-"A simple utility for converting bearing and distance measurements to "
-"coordinates and vice versa."
-msgstr ""
-"Ein einfaches Hilfsprogramm, dass Kurs- und Distanzwert in Koordinaten "
-"umrechnet und umgekehrt."
+msgid "A simple utility for converting bearing and distance measurements to coordinates and vice versa."
+msgstr "Ein einfaches Hilfsprogramm, dass Kurs- und Distanzwert in Koordinaten umrechnet und umgekehrt."
 #: ../misc/m.cogo/main.c:230
 msgid "It assumes a cartesian coordinate system"
@@ -4501,7 +4143,7 @@
 #: ../misc/m.cogo/main.c:248
 msgid "Repeat the starting coordinate at the end to close a loop"
-msgstr ""
+msgstr "Anfangs-Koordinaten am Ende wiederholen, um den Ring zu schließen."
 #: ../misc/m.cogo/main.c:263
 msgid "Starting coordinate pair"
@@ -4807,8 +4449,7 @@
 #: ../misc/m.nviz.image/args.c:503
 msgid "Focus to point on surface (from SW corner in map units)"
-msgstr ""
-"Fokussiere auf Punkt auf der Oberfläche (von SW Ecke in Karteneinheiten)"
+msgstr "Fokussiere auf Punkt auf der Oberfläche (von SW Ecke in Karteneinheiten)"
 #: ../misc/m.nviz.image/args.c:513 ../misc/m.nviz.image/args.c:548
 #: ../misc/m.nviz.image/args.c:560 ../misc/m.nviz.image/args.c:570
@@ -4924,11 +4565,8 @@
 msgstr "Lichtwärme"
 #: ../misc/m.nviz.image/args.c:764
-msgid ""
-"nw;North-West edge;ne;North-East edge;sw;South-West edge;se;South-East edge"
-msgstr ""
-"nw;Nord-West Begrenzung;ne;Nord-Ost-Begrenzung;sw;Süd-West-Begrenzung;se;Süd-"
-"Ost-Begrenzung"
+msgid "nw;North-West edge;ne;North-East edge;sw;South-West edge;se;South-East edge"
+msgstr "nw;Nord-West Begrenzung;ne;Nord-Ost-Begrenzung;sw;Süd-West-Begrenzung;se;Süd-Ost-Begrenzung"
 #: ../misc/m.nviz.image/args.c:768
 msgid "Fringe edges"
@@ -4948,12 +4586,8 @@
 msgstr "Höhe der Randzone"
 #: ../misc/m.nviz.image/args.c:796
-msgid ""
-"Place north arrow at given position \t(in screen coordinates from bottom "
-"left corner)"
-msgstr ""
-"Platziere den Nordpfeil an der angegeben Position \t(in "
-"Bildschirmkoordinaten von der unteren linken Ecke)"
+msgid "Place north arrow at given position \t(in screen coordinates from bottom left corner)"
+msgstr "Platziere den Nordpfeil an der angegeben Position \t(in Bildschirmkoordinaten von der unteren linken Ecke)"
 #: ../misc/m.nviz.image/args.c:798 ../misc/m.nviz.image/args.c:807
 #: ../misc/m.nviz.image/args.c:814
@@ -5018,25 +4652,18 @@
 msgstr "Erzeugt eine 3D Darstellung aus GIS Daten."
 #: ../misc/m.nviz.image/main.c:51
-msgid ""
-"Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster "
-"data) in 3D."
-msgstr ""
-"Darstellung von Oberflächen (Rasterdaten), 2D/3D Vektordaten und Volumen (3D "
-"Rasterdaten) in 3D."
+msgid "Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster data) in 3D."
+msgstr "Darstellung von Oberflächen (Rasterdaten), 2D/3D Vektordaten und Volumen (3D Rasterdaten) in 3D."
 #: ../misc/m.nviz.image/main.c:134
 #, c-format
 msgid "Vertical exaggeration not given, using calculated value %.0f"
-msgstr ""
-"Vertikale Überhöhung wurde nicht spezifiziert, verwende den berechneten Wert "
-"%.0f."
+msgstr "Vertikale Überhöhung wurde nicht spezifiziert, verwende den berechneten Wert %.0f."
 #: ../misc/m.nviz.image/main.c:146
 #, c-format
 msgid "Viewpoint height not given, using calculated value %.0f"
-msgstr ""
-"Höhe des Betrachters nicht spezifiziert, verwende den berechneten Wert %.0f."
+msgstr "Höhe des Betrachters nicht spezifiziert, verwende den berechneten Wert %.0f."
 #: ../misc/m.nviz.image/main.c:229
 msgid "Unsupported output format"
@@ -5094,10 +4721,7 @@
 msgstr "Benenne reclass-Karten um."
 #: ../general/manage/cmd/copy.c:41
-msgid ""
-"Copies available data files in the user's current mapset search path and "
-"location to the appropriate element directories under the user's current "
-"mapset."
+msgid "Copies available data files in the user's current mapset search path and location to the appropriate element directories under the user's current mapset."
 msgstr "Kopiert die vorhandenen Daten in die aktuelle Mapset/Location."
 #: ../general/manage/cmd/copy.c:58
@@ -5122,9 +4746,7 @@
 #: ../general/manage/cmd/list.c:43
 msgid "Lists available GRASS data base files of the user-specified data type."
-msgstr ""
-"Liste vorhandene GRASS Datenbank-Dateien eines vom Nutzer bestimmten "
-"Datentyps."
+msgstr "Liste vorhandene GRASS Datenbank-Dateien eines vom Nutzer bestimmten Datentyps."
 #: ../general/manage/cmd/list.c:72 ../general/g.mlist/main.c:123
 msgid "Mapset to list (default: current search path)"
@@ -5142,17 +4764,14 @@
 #: ../general/manage/cmd/remove.c:41 ../general/g.mremove/check_reclass.c:18
 #, c-format
 msgid "[%s@%s] is a base map. Remove reclassed map first: %s"
-msgstr ""
-"[%s@%s] ist eine Ausgangskarte. Lösche zuerst die reklassifizierte Karte: %s"
+msgstr "[%s@%s] ist eine Ausgangskarte. Lösche zuerst die reklassifizierte Karte: %s"
 #: ../general/manage/cmd/remove.c:63 ../general/manage/cmd/remove.c:76
 #: ../general/g.mremove/check_reclass.c:41
 #: ../general/g.mremove/check_reclass.c:55
 #, c-format
 msgid "Removing information about reclassed map from [%s@%s] failed"
-msgstr ""
-"Das Löschen der Information über die reklassifizierte Karte von [%s@%s] ist "
-"fehlgeschlagen."
+msgstr "Das Löschen der Information über die reklassifizierte Karte von [%s@%s] ist fehlgeschlagen."
 #: ../general/manage/cmd/remove.c:101 ../general/g.mremove/main.c:60
 msgid "Removes data base element files from the user's current mapset."
@@ -5204,24 +4823,15 @@
 #: ../general/g.transform/main.c:322
 msgid "Computes a coordinate transformation based on the control points."
-msgstr ""
-"Berechnet eine Koordinatentransformation basierend auf Kontrollpunkten."
+msgstr "Berechnet eine Koordinatentransformation basierend auf Kontrollpunkten."
 #: ../general/g.transform/main.c:331
 msgid "Rectification polynomial order"
 msgstr "Polynomgrad der Entzerrung."
 #: ../general/g.transform/main.c:339
-msgid ""
-"idx;point index;src;source coordinates;dst;destination coordinates;fwd;"
-"forward coordinates (destination);rev;reverse coordinates (source);fxy;"
-"forward coordinates difference (destination);rxy;reverse coordinates "
-"difference (source);fd;forward error (destination);rd;reverse error (source)"
-msgstr ""
-"idx;Punkt Index;src;Quell-Koordinaten;dst;Ziel-Koordinaten;fwd;Vorwärts-"
-"Koordinaten (Ziel);rev;Rückwärts-Koordinaten (Quelle);fxy;Vorwärts-"
-"Koordinaten-Differenz (Ziel);rxy;Rückwärts-Koordinaten-Differenz (Quelle);fd;"
-"Vorwärts-Fehler (Ziel);rd;Rückwärts-Fehler (Quelle)"
+msgid "idx;point index;src;source coordinates;dst;destination coordinates;fwd;forward coordinates (destination);rev;reverse coordinates (source);fxy;forward coordinates difference (destination);rxy;reverse coordinates difference (source);fd;forward error (destination);rd;reverse error (source)"
+msgstr "idx;Punkt Index;src;Quell-Koordinaten;dst;Ziel-Koordinaten;fwd;Vorwärts-Koordinaten (Ziel);rev;Rückwärts-Koordinaten (Quelle);fxy;Vorwärts-Koordinaten-Differenz (Ziel);rxy;Rückwärts-Koordinaten-Differenz (Quelle);fd;Vorwärts-Fehler (Ziel);rd;Rückwärts-Fehler (Quelle)"
 #: ../general/g.transform/main.c:349 ../vector/v.out.ascii/out.c:63
 msgid "Output format"
@@ -5233,9 +4843,7 @@
 #: ../general/g.transform/main.c:359
 msgid "File containing coordinates to transform (\"-\" to read from stdin)"
-msgstr ""
-"Datei mit zu transformierenden Koordinaten (oder \"-\" um von stdin zu "
-"lesen)."
+msgstr "Datei mit zu transformierenden Koordinaten (oder \"-\" um von stdin zu lesen)."
 #: ../general/g.transform/main.c:360
 msgid "Local x,y coordinates to target east,north"
@@ -5286,24 +4894,15 @@
 #: ../general/g.region/printwindow.c:410
 msgid "You are already in Lat/Long. Use the -p flag instead."
-msgstr ""
-"Sie sind bereits in Lat/Long. Verwenden Sie den Schalter -p statt dessen."
+msgstr "Sie sind bereits in Lat/Long. Verwenden Sie den Schalter -p statt dessen."
 #: ../general/g.region/printwindow.c:412
-msgid ""
-"You are in a simple XY location, projection to Lat/Lon is not possible. Use "
-"the -p flag instead."
-msgstr ""
-"Sie befinden sich in einer einfachen XY-Location. Umprojezieren nach Lat/Lon "
-"ist nicht möglich.Verwenden Sie statt dessen den Schalter -p)."
+msgid "You are in a simple XY location, projection to Lat/Lon is not possible. Use the -p flag instead."
+msgstr "Sie befinden sich in einer einfachen XY-Location. Umprojezieren nach Lat/Lon ist nicht möglich.Verwenden Sie statt dessen den Schalter -p)."
 #: ../general/g.region/printwindow.c:637
-msgid ""
-"WGS84 output not possible as this location does not contain datum "
-"transformation parameters. Try running g.setproj."
-msgstr ""
-"WGS84 Ausgabe nicht möglich, da diese Location keine "
-"Datumstransformationsparameter enthält. Versuchen Sie g.setproj."
+msgid "WGS84 output not possible as this location does not contain datum transformation parameters. Try running g.setproj."
+msgstr "WGS84 Ausgabe nicht möglich, da diese Location keine Datumstransformationsparameter enthält. Versuchen Sie g.setproj."
 #: ../general/g.region/printwindow.c:783
 msgid "Lat/Long calculations are not possible from a simple XY system"
@@ -5343,9 +4942,7 @@
 #: ../general/g.region/main.c:96
 msgid "Print the current region in lat/long using the current ellipsoid/datum"
-msgstr ""
-"Gebe die aktuelle Region in Lat/Long unter Verwendung des aktuellen "
-"Ellipsoid/Datum aus."
+msgstr "Gebe die aktuelle Region in Lat/Long unter Verwendung des aktuellen Ellipsoid/Datum aus."
 #: ../general/g.region/main.c:102
 msgid "Print the current region extent"
@@ -5372,12 +4969,8 @@
 msgstr "Gebe den Konvergenzwinkel aus (Grad CCW)."
 #: ../general/g.region/main.c:133
-msgid ""
-"The difference between the projection's grid north and true north, measured "
-"at the center coordinates of the current region."
-msgstr ""
-"Die Differenz zwischen dem Gitternord der Projektion und der wahren "
-"Nordrichtung gemessen im Zentrum der aktuellen Region."
+msgid "The difference between the projection's grid north and true north, measured at the center coordinates of the current region."
+msgstr "Die Differenz zwischen dem Gitternord der Projektion und der wahren Nordrichtung gemessen im Zentrum der aktuellen Region."
 #: ../general/g.region/main.c:139
 msgid "Print also 3D settings"
@@ -5394,12 +4987,8 @@
 msgstr "Gebe im Shell-Skript-Style aus."
 #: ../general/g.region/main.c:156
-msgid ""
-"Align region to resolution (default = align to bounds, works only for 2D "
-"resolution)"
-msgstr ""
-"Passe Region an die Auflösung an (Standard = passe an die Grenzen an; "
-"funktioniert nur für 2D-Auflösung)."
+msgid "Align region to resolution (default = align to bounds, works only for 2D resolution)"
+msgstr "Passe Region an die Auflösung an (Standard = passe an die Grenzen an; funktioniert nur für 2D-Auflösung)."
 #: ../general/g.region/main.c:158 ../general/g.region/main.c:218
 #: ../general/g.region/main.c:228 ../general/g.region/main.c:238
@@ -5432,9 +5021,7 @@
 #: ../general/g.region/main.c:189
 msgid "Set region to match this 3D raster map (both 2D and 3D values)"
-msgstr ""
-"Setze Region auf die Werte dieser 3D-Rasterkarte (sowohl 2D- als auch 3D-"
-"Parameter)"
+msgstr "Setze Region auf die Werte dieser 3D-Rasterkarte (sowohl 2D- als auch 3D-Parameter)"
 #: ../general/g.region/main.c:197 ../raster/r.region/main.c:102
 msgid "Set region to match this vector map"
@@ -5505,9 +5092,7 @@
 #: ../general/g.region/main.c:342
 msgid "Shrink region until it meets non-NULL data from this raster map"
-msgstr ""
-"Schrumpfe die Region so lange, bis sie auf nicht-NULL Zellen dieser "
-"Rasterkarte stösst."
+msgstr "Schrumpfe die Region so lange, bis sie auf nicht-NULL Zellen dieser Rasterkarte stösst."
 #: ../general/g.region/main.c:353
 msgid "Adjust region cells to cleanly align with this raster map"
@@ -5515,9 +5100,7 @@
 #: ../general/g.region/main.c:364
 msgid "Save current region settings in named region file"
-msgstr ""
-"Speichere die Einstellungen der aktuellen Region in eine benannte Regions-"
-"Datei."
+msgstr "Speichere die Einstellungen der aktuellen Region in eine benannte Regions-Datei."
 #: ../general/g.region/main.c:423 ../raster/r.region/main.c:182
 #, c-format
@@ -5586,9 +5169,7 @@
 #: ../general/g.region/main.c:858
 msgid "Unable to change default region. The current mapset is not <PERMANENT>."
-msgstr ""
-"Kann die Standard-Region nicht ändern. Das aktuelle Mapset ist nicht "
-"<PERMANENT>."
+msgstr "Kann die Standard-Region nicht ändern. Das aktuelle Mapset ist nicht <PERMANENT>."
 #: ../general/g.region/main.c:875
 #, c-format
@@ -5611,12 +5192,8 @@
 "%s"
 #: ../general/g.mlist/main.c:67
-msgid ""
-"Lists available GRASS data base files of the user-specified data type "
-"optionally using the search pattern."
-msgstr ""
-"Datentyps und verwende optional ein Suchmuster."
+msgid "Lists available GRASS data base files of the user-specified data type optionally using the search pattern."
+msgstr "Liste vorhandene GRASS Datenbank-Dateien eines vom Nutzer bestimmten Datentyps und verwende optional ein Suchmuster."
 #: ../general/g.mlist/main.c:97
 msgid "Map name search pattern (default: all)"
@@ -5633,9 +5210,7 @@
 #: ../general/g.mlist/main.c:115
 msgid "One-character output separator, newline, comma, space, or tab"
-msgstr ""
-"Trennzeichen für die Ausgabe, Zeilenumbruch, Komma, Leerzeichen oder "
-"Tabulator."
+msgstr "Trennzeichen für die Ausgabe, Zeilenumbruch, Komma, Leerzeichen oder Tabulator."
 #: ../general/g.mlist/main.c:128 ../general/g.mremove/main.c:66
 msgid "Use basic regular expressions instead of wildcards"
@@ -5672,11 +5247,8 @@
 msgstr "Ändere aktuelles Mapset."
 #: ../general/g.mapset/main.c:50
-msgid ""
-"Optionally create new mapset or list available mapsets in given location."
-msgstr ""
-"Erzeuge optional ein neues Mapset oder liste die verfügbaren Mapsets in der "
-"Location auf."
+msgid "Optionally create new mapset or list available mapsets in given location."
+msgstr "Erzeuge optional ein neues Mapset oder liste die verfügbaren Mapsets in der Location auf."
 #: ../general/g.mapset/main.c:57
 msgid "Name of mapset where to switch"
@@ -5687,11 +5259,8 @@
 msgstr "Name der Location (nicht Pfad)."
 #: ../general/g.mapset/main.c:75
-msgid ""
-"GIS data directory (full path to the directory where the new location is)"
-msgstr ""
-"Neue GISDBASE (vollständiger Pfad zu dem Verzeichnis, in dem sich die neue "
-"Location befindet)."
+msgid "GIS data directory (full path to the directory where the new location is)"
+msgstr "Neue GISDBASE (vollständiger Pfad zu dem Verzeichnis, in dem sich die neue Location befindet)."
 #: ../general/g.mapset/main.c:80
 msgid "Create mapset if it doesn't exist"
@@ -5723,8 +5292,7 @@
 #: ../general/g.mapset/main.c:156
 msgid "The mapset does not exist. Use -c flag to create it."
-msgstr ""
-"Das Mapset existiert nicht.Verwenden Sie den Schalter -c um es zu erzeugen."
+msgstr "Das Mapset existiert nicht.Verwenden Sie den Schalter -c um es zu erzeugen."
 #: ../general/g.mapset/main.c:165
 msgid "Unable to read GIS_LOCK environment variable"
@@ -5732,12 +5300,8 @@
 #: ../general/g.mapset/main.c:179
 #, c-format
-msgid ""
-"%s is currently running GRASS in selected mapset or lock file cannot be "
-"checked"
-msgstr ""
-"%s führt zur Zeit GRASS in dem gewählten Mapset aus oder die Lock-Datei kann "
-"nicht überprüft werden."
+msgid "%s is currently running GRASS in selected mapset or lock file cannot be checked"
+msgstr "%s führt zur Zeit GRASS in dem gewählten Mapset aus oder die Lock-Datei kann nicht überprüft werden."
 #: ../general/g.mapset/main.c:183
 msgid "Erasing monitors..."
@@ -5824,12 +5388,8 @@
 #: ../general/g.findfile/main.c:79
 #, c-format
-msgid ""
-"Parameter 'file' contains reference to <%s> mapset, but mapset parameter <"
-"%s> does not correspond"
-msgstr ""
-"Der Parameter 'file' enthält einen Verweis auf das Mapset <%s>, aber der "
-"Parameter Mapset <%s> stimmt damit nicht überein."
+msgid "Parameter 'file' contains reference to <%s> mapset, but mapset parameter <%s> does not correspond"
+msgstr "Der Parameter 'file' enthält einen Verweis auf das Mapset <%s>, aber der Parameter Mapset <%s> stimmt damit nicht überein."
 #: ../general/g.mapsets/dsply_path.c:30
 #, c-format
@@ -5860,12 +5420,8 @@
 msgstr "Ändere den aktuellen Mapset-Suchpfad aus."
 #: ../general/g.mapsets/main.c:61
-msgid ""
-"Affects the user's access to data existing under the other mapsets in the "
-"current location."
-msgstr ""
-"Beeinflusst beeinflusst den Zugriff des Benutzers auf Daten in anderen "
-"Mapsets in der aktuellen Location."
+msgid "Affects the user's access to data existing under the other mapsets in the current location."
+msgstr "Beeinflusst beeinflusst den Zugriff des Benutzers auf Daten in anderen Mapsets in der aktuellen Location."
 #: ../general/g.mapsets/main.c:69
 msgid "Name(s) of existing mapset(s)"
@@ -5878,13 +5434,11 @@
 #: ../general/g.mapsets/main.c:78
 msgid "Name(s) of existing mapset(s) to add to search path"
-msgstr ""
-"Name(n) existierender Mapset(s), die zum Suchpfad hinzugefügt werden sollen."
+msgstr "Name(n) existierender Mapset(s), die zum Suchpfad hinzugefügt werden sollen."
 #: ../general/g.mapsets/main.c:87
 msgid "Name(s) of existing mapset(s) to remove from search path"
-msgstr ""
-"Name(n) existierender Mapset(s), die aus dem Suchpfad entfernt werden sollen."
+msgstr "Name(n) existierender Mapset(s), die aus dem Suchpfad entfernt werden sollen."
 #: ../general/g.mapsets/main.c:91
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:5
@@ -5895,9 +5449,7 @@
 #: ../general/g.mapsets/main.c:92
 msgid "Special characters: newline, space, comma, tab"
-msgstr ""
-"Trennzeichen für die Ausgabe: Zeilenumbruch, Komma, Leerzeichen oder "
-"Tabulator."
+msgstr "Trennzeichen für die Ausgabe: Zeilenumbruch, Komma, Leerzeichen oder Tabulator."
 #: ../general/g.mapsets/main.c:97
 msgid "List all available mapsets in alphabetical order"
@@ -6059,8 +5611,7 @@
 #: ../general/g.setproj/get_stp.c:43
 msgid "This should not happen see your system admin"
-msgstr ""
-"Dies sollte nicht passieren, suchen Sie ihren System-Administrator auf."
+msgstr "Dies sollte nicht passieren, suchen Sie ihren System-Administrator auf."
 #: ../general/g.setproj/get_stp.c:99
 msgid "Unable to open FIPS code file"
@@ -6105,8 +5656,7 @@
 #: ../general/g.setproj/main.c:108
 msgid "You must be in the PERMANENT mapset to run g.setproj"
-msgstr ""
-"Sie müssen sich in dem Mapset PERMANENT befinden um g.setproj auszuführen."
+msgstr "Sie müssen sich in dem Mapset PERMANENT befinden um g.setproj auszuführen."
 #: ../general/g.setproj/main.c:113
 #, c-format
@@ -6216,14 +5766,8 @@
 msgstr "Die Information zu der UTM Zone wurde nicht aktualisiert."
 #: ../general/g.setproj/main.c:488
-msgid ""
-"But if you change zone, all the existing data will be interpreted by "
-"projection software. GRASS will not automatically re-project or even change "
-"the headers for existing maps."
-msgstr ""
-"Wenn Sie aber die Zone ändern, werden alle existierenden Daten von der "
-"Projektionssoftware interpretiert. GRASS wird die Daten nicht automatisch "
-"umprojezieren oder die Header existierender Karten ändern."
+msgid "But if you change zone, all the existing data will be interpreted by projection software. GRASS will not automatically re-project or even change the headers for existing maps."
+msgstr "Wenn Sie aber die Zone ändern, werden alle existierenden Daten von der Projektionssoftware interpretiert. GRASS wird die Daten nicht automatisch umprojezieren oder die Header existierender Karten ändern."
 #: ../general/g.setproj/main.c:493
 msgid "Would you still like to change the UTM zone?"
@@ -6293,9 +5837,7 @@
 #: ../general/g.mremove/main.c:158
 msgid "You must use the force flag to actually remove them. Exiting."
-msgstr ""
-"Sie müssen den Zwangs-Schalter verwenden, um tatsächlich zu Löschen. Beende "
-"mich."
+msgstr "Sie müssen den Zwangs-Schalter verwenden, um tatsächlich zu Löschen. Beende mich."
 #: ../general/g.mremove/do_remove.c:21
 #, c-format
@@ -6331,15 +5873,12 @@
 msgstr "Allgemein, Skripte"
 #: ../general/g.message/main.c:35
-msgid ""
-"Prints a message, warning, progress info, or fatal error in the GRASS way."
+msgid "Prints a message, warning, progress info, or fatal error in the GRASS way."
 msgstr "Gibt eine Nachricht, Warnung oder fatalen Fehler im GRASS-Stil aus."
 #: ../general/g.message/main.c:37
 msgid "This module should be used in scripts for messages served to user."
-msgstr ""
-"Dieses Modul sollte in Skripten verwendet werden um Nachrichten an den "
-"Benutzer auszugeben."
+msgstr "Dieses Modul sollte in Skripten verwendet werden um Nachrichten an den Benutzer auszugeben."
 #: ../general/g.message/main.c:41 ../general/g.message/main.c:46
 #: ../general/g.message/main.c:51 ../general/g.message/main.c:56
@@ -6404,14 +5943,8 @@
 msgstr "Standardwert: GRASS_GUI wenn definiert, ansonsten wxpython"
 #: ../general/g.gui/main.c:45
-msgid ""
-"wxpython;wxPython based GUI - wxGUI;tcltk;Tcl/Tk based GUI - GIS Manager "
-"(gis.m);oldtcltk;Old Tcl/Tk based GUI - Display Manager (d.m);text;command "
-"line interface only"
-msgstr ""
-"wxpython;wxPython basiertes GUI - wxGUI;tcltk;Tcl/Tk basiertes GUI - GIS "
-"Manager (gis.m);oldtcltk;Altes Tcl/Tkbasiertes GUI - Display Manager (d.m);"
-"text;Nur Kommandozeile"
+msgid "wxpython;wxPython based GUI - wxGUI;tcltk;Tcl/Tk based GUI - GIS Manager (gis.m);oldtcltk;Old Tcl/Tk based GUI - Display Manager (d.m);text;command line interface only"
+msgstr "wxpython;wxPython basiertes GUI - wxGUI;tcltk;Tcl/Tk basiertes GUI - GIS Manager (gis.m);oldtcltk;Altes Tcl/Tkbasiertes GUI - Display Manager (d.m);text;Nur Kommandozeile"
 #: ../general/g.gui/main.c:54
 msgid "Name of workspace file"
@@ -6423,9 +5956,7 @@
 #: ../general/g.gui/main.c:63
 msgid "Do not launch GUI after updating the default GUI setting"
-msgstr ""
-"Starten Sie das GUI nicht nachdem Sie die standard GUI-Einstellungen "
-"geändert haben."
+msgstr "Starten Sie das GUI nicht nachdem Sie die standard GUI-Einstellungen geändert haben."
 #: ../general/g.gui/main.c:90
 #, c-format
@@ -6500,14 +6031,11 @@
 #: ../general/g.access/main.c:59
 msgid "UNIX filesystem access controls are not supported by MS-Windows"
-msgstr ""
-"Die Rechteverwaltung des UNIX Dateisystems wird von MS-Windows nicht "
-"unterstützt."
+msgstr "Die Rechteverwaltung des UNIX Dateisystems wird von MS-Windows nicht unterstützt."
 #: ../general/g.access/main.c:67
 msgid "Access to the PERMANENT mapset must be open, nothing changed"
-msgstr ""
-"Zugang zum Mapset PERMANENT muss möglich sein. Es wurde nichts verändert."
+msgstr "Zugang zum Mapset PERMANENT muss möglich sein. Es wurde nichts verändert."
 #: ../general/g.access/main.c:71
 msgid "Unable to determine mapset permissions"
@@ -6534,12 +6062,8 @@
 msgstr "%s: Kann nicht in WKT konvertieren."
 #: ../general/g.proj/main.c:66
-msgid ""
-"Prints and manipulates GRASS projection information files (in various co-"
-"ordinate system descriptions)."
-msgstr ""
-"Ausgabe und Manipulation von GRASS Projektionsinformationsdateien (in "
-"verschieden Koordinatensystembeschreibungen)."
+msgid "Prints and manipulates GRASS projection information files (in various co-ordinate system descriptions)."
+msgstr "Ausgabe und Manipulation von GRASS Projektionsinformationsdateien (in verschieden Koordinatensystembeschreibungen)."
 #: ../general/g.proj/main.c:69
 msgid "Can also be used to create new GRASS locations."
@@ -6559,16 +6083,14 @@
 #: ../general/g.proj/main.c:91
 msgid "Verify datum information and print transformation parameters"
-msgstr ""
-"Überprüfe Datum-Informationen und gebe die Transformationsparameter aus."
+msgstr "Überprüfe Datum-Informationen und gebe die Transformationsparameter aus."
 #: ../general/g.proj/main.c:97
 msgid "Print projection information in PROJ.4 format"
 msgstr "Gebe die Projektionsinformationen im PROJ.4-Format aus."
 #: ../general/g.proj/main.c:103
-msgid ""
-"Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
+msgid "Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
 msgstr "Ausgabe ohne Zeilenumbrüche (nur bei WKT- und PROJ.4-Ausgaben)"
 #: ../general/g.proj/main.c:113
@@ -6586,9 +6108,7 @@
 #: ../general/g.proj/main.c:127
 msgid "Name of georeferenced data file to read projection information from"
-msgstr ""
-"Name der Datei georeferenzierten Daten, von der Projektionsinformationen "
-"gelesen werden sollen"
+msgstr "Name der Datei georeferenzierten Daten, von der Projektionsinformationen gelesen werden sollen"
 #: ../general/g.proj/main.c:136
 msgid "Name of ASCII file containing a WKT projection description"
@@ -6617,9 +6137,7 @@
 #: ../general/g.proj/main.c:168
 msgid "Accepts standard GRASS datum codes, or \"list\" to list and exit"
-msgstr ""
-"Akzeptiert Standard GRASS Datumcodes oder \"list\" zum Anzeigen der Liste "
-"und beenden"
+msgstr "Akzeptiert Standard GRASS Datumcodes oder \"list\" zum Anzeigen der Liste und beenden"
 #: ../general/g.proj/main.c:178
 msgid "Index number of datum transform parameters"
@@ -6627,17 +6145,11 @@
 #: ../general/g.proj/main.c:179
 msgid "\"0\" for unspecified or \"-1\" to list and exit"
-msgstr ""
-"\"0\" für nicht spezifiziert oder \"-1\" um alle aufzulisten und sich zu "
-"beenden"
+msgstr "\"0\" für nicht spezifiziert oder \"-1\" um alle aufzulisten und sich zu beenden"
 #: ../general/g.proj/main.c:185
-msgid ""
-"Force override of datum transformation information in input co-ordinate "
-"system"
-msgstr ""
-"Erzwinge das Übersteuern der Datumtransformationsinformation des Eingabe "
-"Koordinatensystems."
+msgid "Force override of datum transformation information in input co-ordinate system"
+msgstr "Erzwinge das Übersteuern der Datumtransformationsinformation des Eingabe Koordinatensystems."
 #: ../general/g.proj/main.c:190 ../raster/r.null/null.c:71
 #: ../raster/r.null/null.c:79
@@ -6655,8 +6167,7 @@
 #: ../general/g.proj/main.c:216
 #, c-format
 msgid "Only one of '%s', '%s', '%s' or '%s' options may be specified"
-msgstr ""
-"Nur eine der Optionen '%s', '%s', '%s' oder '%s' kann angegeben werden."
+msgstr "Nur eine der Optionen '%s', '%s', '%s' oder '%s' kann angegeben werden."
 #: ../general/g.proj/main.c:259
 msgid "Projection files missing"
@@ -6665,21 +6176,17 @@
 #: ../general/g.proj/main.c:279
 #, c-format
 msgid "Only one of -%c, -%c, -%c, -%c, -%c or -%c flags may be specified"
-msgstr ""
-"Nur ein Schalter von  -%c, -%c, -%c, -%c, -%c oder -%c kann angegeben werden"
+msgstr "Nur ein Schalter von  -%c, -%c, -%c, -%c, -%c oder -%c kann angegeben werden"
 #: ../general/g.proj/main.c:306
 #, c-format
 msgid "No output format specified, define one of flags -%c, -%c, -%c, or -%c"
-msgstr ""
-"Kein Ausgabeformat angegeben, verwende einen der Schalter -%c, -%c, -%c oder "
-"-%c"
+msgstr "Kein Ausgabeformat angegeben, verwende einen der Schalter -%c, -%c, -%c oder -%c"
 #: ../general/g.proj/main.c:310
 #, c-format
 msgid "No output format specified, define one of flags -%c, -%c, or -%c"
-msgstr ""
-"Kein Ausgabeformat angegeben, verwende einen der Schalter -%c, -%c oder -%c"
+msgstr "Kein Ausgabeformat angegeben, verwende einen der Schalter -%c, -%c oder -%c"
 #: ../general/g.proj/create.c:15 ../raster/r.in.gdal/main.c:331
 #, c-format
@@ -6711,22 +6218,12 @@
 #: ../general/g.proj/create.c:36
 #, c-format
-msgid ""
-"You must select the PERMANENT mapset before updating the current location's "
-"projection (current mapset is <%s>)."
-msgstr ""
-"Sie müssen das PERMANENT-Mapset selektieren, bevor Sie die Projektion der "
-"aktuelle Location aktualisieren (aktuelles Mapset: <%s>)."
+msgid "You must select the PERMANENT mapset before updating the current location's projection (current mapset is <%s>)."
+msgstr "Sie müssen das PERMANENT-Mapset selektieren, bevor Sie die Projektion der aktuelle Location aktualisieren (aktuelles Mapset: <%s>)."
 #: ../general/g.proj/create.c:63
-msgid ""
-"Default region was updated to the new projection, but if you have multiple "
-"mapsets `g.region -d` should be run in each to update the region from the "
-"default"
-msgstr ""
-"Die Standard Region wurde auf die neue Projektion aktualisiert. Wenn Sie "
-"aber mehrere Mapsets haben, sollten Sie  `g.region -d` in jedem ausführen, "
-"um die Einstellungen von der Standardregion zu übernehmen."
+msgid "Default region was updated to the new projection, but if you have multiple mapsets `g.region -d` should be run in each to update the region from the default"
+msgstr "Die Standard Region wurde auf die neue Projektion aktualisiert. Wenn Sie aber mehrere Mapsets haben, sollten Sie  `g.region -d` in jedem ausführen, um die Einstellungen von der Standardregion zu übernehmen."
 #: ../general/g.proj/create.c:67
 msgid "Projection information updated"
@@ -6768,13 +6265,8 @@
 #: ../general/g.proj/input.c:259
 #, c-format
-msgid ""
-"Read of file %s was successful, but it did not contain projection "
-"information. 'XY (unprojected)' will be used"
-msgstr ""
-"Einlesen der Datei %s war erfolgreich, aber die Datei enthielt keine "
-"Projektionsinformationen. Location-Definition 'XY (unprojiziert)' wird "
-"benutzt."
+msgid "Read of file %s was successful, but it did not contain projection information. 'XY (unprojected)' will be used"
+msgstr "Einlesen der Datei %s war erfolgreich, aber die Datei enthielt keine Projektionsinformationen. Location-Definition 'XY (unprojiziert)' wird benutzt."
 #: ../visualization/ximgview/color.c:90 ../visualization/ximgview/color.c:288
 #: ../visualization/xganim/Clr_table.c:94
@@ -6902,8 +6394,7 @@
 #: ../visualization/nviz/src/nviz_init.c:106
 msgid "Exit after completing script launched from the command line"
-msgstr ""
-"Beendet sich nachdem das, von der Kommandozeile gestartete, Skript fertig ist"
+msgstr "Beendet sich nachdem das, von der Kommandozeile gestartete, Skript fertig ist"
 #: ../visualization/nviz/src/nviz_init.c:111
 msgid "Start in Demo mode (skip the \"please wait\" message)"
@@ -6927,9 +6418,7 @@
 #: ../visualization/nviz/src/nviz_init.c:287
 msgid "Number of elevation files does not match number of colors files"
-msgstr ""
-"Die Anzahl der Dateien mit Höheninformationen stimmt nicht mit denen der "
-"Farbinformationen überein."
+msgstr "Die Anzahl der Dateien mit Höheninformationen stimmt nicht mit denen der Farbinformationen überein."
 #: ../visualization/nviz/src/nviz_init.c:298
 msgid "Loading data failed"
@@ -6940,18 +6429,12 @@
 msgstr "Betrete den Skriptmodus ..."
 #: ../locale/scriptstrings/d.split_to_translate.c:1
-msgid ""
-"Divides active display into two frames & displays maps/executes commands in "
-"each frame."
-msgstr ""
-"Teilt das aktive Grafikfenster in zwei Fenster & zeigt Karten und führt "
-"Befehle in beiden Fenstern aus."
+msgid "Divides active display into two frames & displays maps/executes commands in each frame."
+msgstr "Teilt das aktive Grafikfenster in zwei Fenster & zeigt Karten und führt Befehle in beiden Fenstern aus."
 #: ../locale/scriptstrings/d.split_to_translate.c:3
 msgid "Enter raster map to display in 1st frame"
-msgstr ""
-"Geben Sie den Name der Rasterkarte ein, die im 1. Fenster gezeigt werden "
-"soll."
+msgstr "Geben Sie den Name der Rasterkarte ein, die im 1. Fenster gezeigt werden soll."
 #: ../locale/scriptstrings/d.split_to_translate.c:4
 msgid "Enter command to execute in 1st frame"
@@ -6959,9 +6442,7 @@
 #: ../locale/scriptstrings/d.split_to_translate.c:5
 msgid "Enter raster map to display in 2nd frame"
-msgstr ""
-"Geben Sie den Name der Rasterkarte ein, die im 2. Fenster gezeigt werden "
-"soll."
+msgstr "Geben Sie den Name der Rasterkarte ein, die im 2. Fenster gezeigt werden soll."
 #: ../locale/scriptstrings/d.split_to_translate.c:6
 msgid "Enter command to execute in 2nd frame"
@@ -7003,9 +6484,7 @@
 #: ../locale/scriptstrings/d.out.file_to_translate.c:8
 msgid "Width and height of output image (overrides resolution setting)"
-msgstr ""
-"Breite und Höhe des auszugebenden Bildes (übersteuert die Einstellung der "
-"Auflösung)."
+msgstr "Breite und Höhe des auszugebenden Bildes (übersteuert die Einstellung der Auflösung)."
 #: ../locale/scriptstrings/d.out.file_to_translate.c:10
 msgid "Compression for PNG files"
@@ -7013,8 +6492,7 @@
 #: ../locale/scriptstrings/d.out.file_to_translate.c:11
 msgid "(0=none, 1=fastest, 9=most; lossless, only time vs. filesize)"
-msgstr ""
-"(0=keine, 1=schnellste, 9=am meisten; verlustfrei, nur Zeit vs. Dateigröße)."
+msgstr "(0=keine, 1=schnellste, 9=am meisten; verlustfrei, nur Zeit vs. Dateigröße)."
 #: ../locale/scriptstrings/d.out.file_to_translate.c:13
 msgid "File size/quality for JPEG files"
@@ -7058,11 +6536,8 @@
 msgstr "GeoTIFF Metadaten Schlüsselwort(e) und Wert(e)"
 #: ../locale/scriptstrings/d.out.file_to_translate.c:24
-msgid ""
-"In the form of \"META-TAG=VALUE\", separate multiple entries with a comma."
-msgstr ""
-"In der Form \"META-TAG=WERT\", trennen Sie mehrere Paare durch Kommas "
-"voneinander."
+msgid "In the form of \"META-TAG=VALUE\", separate multiple entries with a comma."
+msgstr "In der Form \"META-TAG=WERT\", trennen Sie mehrere Paare durch Kommas voneinander."
 #: ../locale/scriptstrings/d.out.file_to_translate.c:26
 msgid "Set background color to black (white default)"
@@ -7078,9 +6553,7 @@
 #: ../locale/scriptstrings/d.out.file_to_translate.c:31
 msgid "Set paper orientation to landscape (for PostScript output)"
-msgstr ""
-"Stelle die Orientierung der Seite auf Querformat (für die PostScript-"
-"Ausgabe)."
+msgstr "Stelle die Orientierung der Seite auf Querformat (für die PostScript-Ausgabe)."
 #: ../locale/scriptstrings/d.out.file_to_translate.c:33
 msgid "Do not crop away margins"
@@ -7097,9 +6570,7 @@
 #: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:3
 msgid "Also import quality map (SM status map layer) and filter NDVI map"
-msgstr ""
-"Importiere auch die Qualitätskarte (SM-Statuskarte) und filtere die NDVI-"
-"Karte."
+msgstr "Importiere auch die Qualitätskarte (SM-Statuskarte) und filtere die NDVI-Karte."
 #: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:4
 msgid "existing SPOT VGT NDVI HDF file (0001_NDV.HDF)"
@@ -7152,12 +6623,8 @@
 msgstr "Name der alten Datenbank."
 #: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:4
-msgid ""
-"The database must be in form printed by v.db.connect -g, i.e. with "
-"substituted variables"
-msgstr ""
-"Die Datenbank muß in der Form angegeben werden , wie sie von v.db.connect -g "
-"ausgegeben wird, z.B mit ersetzten Variablen."
+msgid "The database must be in form printed by v.db.connect -g, i.e. with substituted variables"
+msgstr "Die Datenbank muß in der Form angegeben werden , wie sie von v.db.connect -g ausgegeben wird, z.B mit ersetzten Variablen."
 #: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:5
 msgid "Name of new database"
@@ -7220,12 +6687,8 @@
 msgstr "Präfix für Ausgabe TC-Rasterkarten"
 #: ../locale/scriptstrings/r.tileset_to_translate.c:1
-msgid ""
-"Produces tilings of the source projection for use in the destination region "
-"and projection."
-msgstr ""
-"Erzeugt Kacheln der der Quell-Projektion zur Verwendung in der Ziel-Region "
-"und -Projektion."
+msgid "Produces tilings of the source projection for use in the destination region and projection."
+msgstr "Erzeugt Kacheln der der Quell-Projektion zur Verwendung in der Ziel-Region und -Projektion."
 #: ../locale/scriptstrings/r.tileset_to_translate.c:2
 msgid "raster, tiling"
@@ -7240,11 +6703,8 @@
 msgstr "Erzeugt ein Web Map Server Query-String."
 #: ../locale/scriptstrings/r.tileset_to_translate.c:5
-msgid ""
-"Name of region to use instead of current region for bounds and resolution"
-msgstr ""
-"Name der Region die anstelle der aktuellen Region für die Ausdehnung "
-"(bounding box) und Auflösung verwendet werden soll."
+msgid "Name of region to use instead of current region for bounds and resolution"
+msgstr "Name der Region die anstelle der aktuellen Region für die Ausdehnung (bounding box) und Auflösung verwendet werden soll."
 #: ../locale/scriptstrings/r.tileset_to_translate.c:6
 msgid "Source projection"
@@ -7277,11 +6737,8 @@
 msgstr "Gesprächigkeitsnievau"
 #: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:1
-msgid ""
-"Exports a vector map to a GPS receiver or file format supported by GpsBabel."
-msgstr ""
-"Exportiert eine Vektorkarte zu einem GPS Gerät oder in ein Dateiformat, das "
-"von GpsBabel unterstützt wird."
+msgid "Exports a vector map to a GPS receiver or file format supported by GpsBabel."
+msgstr "Exportiert eine Vektorkarte zu einem GPS Gerät oder in ein Dateiformat, das von GpsBabel unterstützt wird."
 #: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:2
 msgid "vector, export, GPS"
@@ -7331,12 +6788,8 @@
 #: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:11
 #: ../locale/scriptstrings/v.db.addcol_to_translate.c:5
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:6
-msgid ""
-"A single vector map can be connected to multiple database tables. This "
-"number determines which table to use."
-msgstr ""
-"Eine einzelne Vektorkarte kann mit mehreren Datenbanktabellen verbunden "
-"sein. Diese Zahl bestimmt welche Tabelle verwendet werden soll."
+msgid "A single vector map can be connected to multiple database tables. This number determines which table to use."
+msgstr "Eine einzelne Vektorkarte kann mit mehreren Datenbanktabellen verbunden sein. Diese Zahl bestimmt welche Tabelle verwendet werden soll."
 #: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:12
 #: ../locale/scriptstrings/v.out.gpsbabel_to_translate.c:15
@@ -7367,12 +6820,8 @@
 msgstr "Neue Fensterhöhe."
 #: ../locale/scriptstrings/v.in.gns_to_translate.c:1
-msgid ""
-"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
-"points map."
-msgstr ""
-"Importiert LÄnderdateien vom US-NGA GEOnet Names Server (GNS) in eine "
-"Vektorpunktkarte."
+msgid "Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector points map."
+msgstr "Importiert LÄnderdateien vom US-NGA GEOnet Names Server (GNS) in eine Vektorpunktkarte."
 #: ../locale/scriptstrings/v.in.gns_to_translate.c:2
 #: ../locale/scriptstrings/v.in.geonames_to_translate.c:2
@@ -7403,8 +6852,7 @@
 #: ../locale/scriptstrings/r.fillnulls_to_translate.c:1
 msgid "Fills no-data areas in raster maps using spline interpolation."
-msgstr ""
-"Fülle Flächen ohne Daten in Rasterkarten mit Hilfe von Spline-Interpolation."
+msgstr "Fülle Flächen ohne Daten in Rasterkarten mit Hilfe von Spline-Interpolation."
 #: ../locale/scriptstrings/r.fillnulls_to_translate.c:2
 msgid "raster, elevation, interpolation"
@@ -7463,26 +6911,19 @@
 #: ../locale/scriptstrings/r.shaded.relief_to_translate.c:8
 msgid "Scale factor for converting horizontal units to elevation units"
-msgstr ""
-"Skalierungsfaktor für die Umwandlung von horizontalen Einheiten zu "
-"Höheneinheiten"
+msgstr "Skalierungsfaktor für die Umwandlung von horizontalen Einheiten zu Höheneinheiten"
 #: ../locale/scriptstrings/r.shaded.relief_to_translate.c:9
-msgid ""
-"Set scaling factor (applies to lat./long. locations only, none: scale=1)"
-msgstr ""
-"Bestimmt den Skalierungsfaktor (nur für lat./long. Locations, kein Wert: "
-"scale=1)."
+msgid "Set scaling factor (applies to lat./long. locations only, none: scale=1)"
+msgstr "Bestimmt den Skalierungsfaktor (nur für lat./long. Locations, kein Wert: scale=1)."
 #: ../locale/scriptstrings/d.correlate_to_translate.c:1
-#, fuzzy
 msgid "Prints a graph of the correlation between raster maps (in pairs)."
-msgstr "Gibt eine Graphik der Korrelation zweier Karten (paarweise) aus."
+msgstr "Gibt eine Grafik der Korrelation zweier Rasterkarten (paarweise) aus."
 #: ../locale/scriptstrings/d.correlate_to_translate.c:2
-#, fuzzy
 msgid "display, correlation, scatterplot"
-msgstr "Darstellung, Raster"
+msgstr "Darstellung, Korrelation, Streudiagramm"
 #: ../locale/scriptstrings/d.correlate_to_translate.c:3
 #: ../locale/scriptstrings/d.correlate_to_translate.c:4
@@ -7493,12 +6934,11 @@
 #: ../locale/scriptstrings/d.correlate_to_translate.c:7
 msgid "Draw a trend line and calculate linear regression formula"
-msgstr ""
+msgstr "Zeichne Ausgleichsgerade und berechne lineare Regression"
 #: ../locale/scriptstrings/d.out.gpsdrive_to_translate.c:1
 msgid "Export display monitor to a GpsDrive compatible backdrop image"
-msgstr ""
-"Exportiert das Grafikfenster in ein GpsDrive-kompatibles Hintergrundbild."
+msgstr "Exportiert das Grafikfenster in ein GpsDrive-kompatibles Hintergrundbild."
 #: ../locale/scriptstrings/d.out.gpsdrive_to_translate.c:2
 msgid "display, export, GPS"
@@ -7525,11 +6965,8 @@
 msgstr "Erhalte keine individuellen Regionen beim Neuzeichnen aller Fenster."
 #: ../locale/scriptstrings/v.db.addcol_to_translate.c:1
-msgid ""
-"Adds one or more columns to the attribute table connected to a given vector "
-"map."
-msgstr ""
-"Fügt eine oder mehrere Spalten zu der Attributtabelle einer Vektorkarte."
+msgid "Adds one or more columns to the attribute table connected to a given vector map."
+msgstr "Fügt eine oder mehrere Spalten zu der Attributtabelle einer Vektorkarte."
 #: ../locale/scriptstrings/v.db.addcol_to_translate.c:3
 msgid "Name of vector map for which to edit attribute table"
@@ -7544,20 +6981,12 @@
 msgstr "Name and Typ der neuen Spalten ('name type [,name type, ...]')"
 #: ../locale/scriptstrings/v.db.addcol_to_translate.c:7
-msgid ""
-"Data types depend on database backend, but all support VARCHAR(), INT, "
-"DOUBLE PRECISION and DATE"
-msgstr ""
-"Datentyp hängt von der verwendeten Datenbank ab, aber alle unterstützen "
-"VARCHAR(), INT, DOUBLE PRECISION und DATE."
+msgid "Data types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE"
+msgstr "Datentyp hängt von der verwendeten Datenbank ab, aber alle unterstützen VARCHAR(), INT, DOUBLE PRECISION und DATE."
 #: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:1
-msgid ""
-"Import waypoints, routes, and tracks from a GPS receiver or GPS download "
-"file into a vector map."
-msgstr ""
-"Importiert Wegpunkte, Routen und Tracks von einem GPS-Gerät oder einer GPS-"
-"Download-Datei in eine Vektorkarte. "
+msgid "Import waypoints, routes, and tracks from a GPS receiver or GPS download file into a vector map."
+msgstr "Importiert Wegpunkte, Routen und Tracks von einem GPS-Gerät oder einer GPS-Download-Datei in eine Vektorkarte. "
 #: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:2
 #: ../locale/scriptstrings/v.in.garmin_to_translate.c:2
@@ -7601,20 +7030,15 @@
 #: ../locale/scriptstrings/v.in.mapgen_to_translate.c:6
 #: ../locale/scriptstrings/v.in.garmin_to_translate.c:11
 msgid "Name for output vector map (omit for display to stdout)"
-msgstr ""
-"Name der Ausgabe-Vektorausgabekarte (auslassen für Ausgabe auf stdout)."
+msgstr "Name der Ausgabe-Vektorausgabekarte (auslassen für Ausgabe auf stdout)."
 #: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:11
 msgid "Format of GPS input data (use gpsbabel supported formats)"
-msgstr ""
-"Format der GPS-Inputdaten (verwenden Sie von gpsbabel unterstützte Formate)."
+msgstr "Format der GPS-Inputdaten (verwenden Sie von gpsbabel unterstützte Formate)."
 #: ../locale/scriptstrings/v.in.gpsbabel_to_translate.c:12
-msgid ""
-"Projection of input data (PROJ.4 style), if not set Lat/Lon WGS84 is assumed"
-msgstr ""
-"Projektion der Inputdaten (PROJ.4 Stil). Wenn nicht angegeben, wird Lat/Lon "
-"WGS84 angenommen."
+msgid "Projection of input data (PROJ.4 style), if not set Lat/Lon WGS84 is assumed"
+msgstr "Projektion der Inputdaten (PROJ.4 Stil). Wenn nicht angegeben, wird Lat/Lon WGS84 angenommen."
 #: ../locale/scriptstrings/v.in.wfs_to_translate.c:1
 msgid "Import GetFeature from WFS"
@@ -7663,8 +7087,7 @@
 msgstr "Zu berechnendes Perzentil (erfordert den Schalter -e)."
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:1
-msgid ""
-"Export a raster map to a text file as x,y,z values based on cell centers."
+msgid "Export a raster map to a text file as x,y,z values based on cell centers."
 msgstr "."
 #: ../locale/scriptstrings/r.out.xyz_to_translate.c:2
@@ -7711,11 +7134,8 @@
 #: ../locale/scriptstrings/v.univar.sh_to_translate.c:1
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:1
-msgid ""
-"Calculates univariate statistics on selected table column for a GRASS vector "
-"map."
-msgstr ""
-"Berechnet univariate Statistiken von ausgewählten Spalten einer Vektorkarte."
+msgid "Calculates univariate statistics on selected table column for a GRASS vector map."
+msgstr "Berechnet univariate Statistiken von ausgewählten Spalten einer Vektorkarte."
 #: ../locale/scriptstrings/v.univar.sh_to_translate.c:2
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:2
@@ -7739,8 +7159,7 @@
 #: ../locale/scriptstrings/v.univar.sh_to_translate.c:5
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:5
 msgid "Column on which to calculate statistics (must be numeric)"
-msgstr ""
-"Spalte, für die Statistiken berechnet werden sollen (muss numerisch sein)."
+msgstr "Spalte, für die Statistiken berechnet werden sollen (muss numerisch sein)."
 #: ../locale/scriptstrings/v.univar.sh_to_translate.c:6
 #: ../locale/scriptstrings/v.db.univar_to_translate.c:6
@@ -7753,11 +7172,8 @@
 msgstr "Datenbanktreiber"
 #: ../locale/scriptstrings/v.db.renamecol_to_translate.c:1
-msgid ""
-"Renames a column in the attribute table connected to a given vector map."
-msgstr ""
-"Benennt eine Spalte einer Attributtabelle verbunden mit einer bestimmten "
-"Vektorkarte um."
+msgid "Renames a column in the attribute table connected to a given vector map."
+msgstr "Benennt eine Spalte einer Attributtabelle verbunden mit einer bestimmten Vektorkarte um."
 #: ../locale/scriptstrings/v.db.renamecol_to_translate.c:3
 msgid "Vector map for which to rename attribute column"
@@ -7772,11 +7188,8 @@
 msgstr "Alter und neuer Name der Spalte (alt,neu)."
 #: ../locale/scriptstrings/v.colors_to_translate.c:1
-msgid ""
-"Set color rules for features in a vector using a numeric attribute column."
-msgstr ""
-"Bestimme Farbregeln für die Objekte einer Vektorkarte unter Verwendung einer "
-"numerischen Spalte der Attributtabelle."
+msgid "Set color rules for features in a vector using a numeric attribute column."
+msgstr "Bestimme Farbregeln für die Objekte einer Vektorkarte unter Verwendung einer numerischen Spalte der Attributtabelle."
 #: ../locale/scriptstrings/v.colors_to_translate.c:2
 msgid "vector, color table"
@@ -7813,13 +7226,12 @@
 msgstr "Pfad zur Regel-Datei."
 #: ../locale/scriptstrings/v.colors_to_translate.c:15
-#, fuzzy
 msgid "Dummy raster map name containing color rules for use with d.legend"
-msgstr "Rasterkarte, die Werte für die Pfeillänge enthält."
+msgstr "Name für Dummy-Rasterkarte mit Farbregeln für d.legend"
 #: ../locale/scriptstrings/v.colors_to_translate.c:16
 msgid "Use with the -s flag (using this option implies -s)"
-msgstr ""
+msgstr "Verwende mit Schalter -s (Verwendung dieser Funktion impliziert -s)"
 #: ../locale/scriptstrings/v.colors_to_translate.c:18
 msgid "Save placeholder raster map for use with d.legend"
@@ -7846,9 +7258,7 @@
 #: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:6
 #: ../raster/r.out.gdal/main.c:154
 msgid "GIS format to write (case sensitive, see also -l flag)"
-msgstr ""
-"GIS Format, dass ausgegeben werden soll (Gross- und Kleinschreibung "
-"beachten, siehe auch den Schalter -l)."
+msgstr "GIS Format, dass ausgegeben werden soll (Gross- und Kleinschreibung beachten, siehe auch den Schalter -l)."
 #: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:7
 #: ../raster/r.out.gdal/main.c:175
@@ -7861,11 +7271,8 @@
 msgstr "Name der Ausgabedatei"
 #: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:9
-msgid ""
-"Creation option to the output format driver. Multiple options may be listed"
-msgstr ""
-"Erstellungs-Optionen für den Ausgabeformat-Treiber. Es können mehrere "
-"Optionen angegeben werden."
+msgid "Creation option to the output format driver. Multiple options may be listed"
+msgstr "Erstellungs-Optionen für den Ausgabeformat-Treiber. Es können mehrere Optionen angegeben werden."
 #: ../locale/scriptstrings/r.out.gdal.sh_to_translate.c:10
 msgid "Metadata key passed on the output dataset if possible"
@@ -7896,11 +7303,8 @@
 msgstr "Maximal zu ladende Anzahl Spalten."
 #: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:1
-msgid ""
-"Brovey transform to merge multispectral and high-res panchromatic channels"
-msgstr ""
-"Brovey-Transformation zum mischen multispektraler und hochaufgelöster "
-"panchromatischer Kanäle."
+msgid "Brovey transform to merge multispectral and high-res panchromatic channels"
+msgstr "Brovey-Transformation zum mischen multispektraler und hochaufgelöster panchromatischer Kanäle."
 #: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:2
 msgid "imagery, fusion, Brovey"
@@ -7967,9 +7371,7 @@
 #: ../locale/scriptstrings/d.polar_to_translate.c:1
 msgid "Draws polar diagram of angle map such as aspect or flow directions"
-msgstr ""
-"Zeichne ein Polardiagramm einer Karte mit Winkelangaben, so wie Expositionen "
-"oder Fließrichtungen."
+msgstr "Zeichne ein Polardiagramm einer Karte mit Winkelangaben, so wie Expositionen oder Fließrichtungen."
 #: ../locale/scriptstrings/d.polar_to_translate.c:2
 msgid "display, diagram"
@@ -7981,9 +7383,7 @@
 #: ../locale/scriptstrings/d.polar_to_translate.c:4
 msgid "Pixel value to be interpreted as undefined (different from NULL)"
-msgstr ""
-"Pixelwert der als undefiniert interpretiert werden soll (unterschiedlich von "
-"NULL)."
+msgstr "Pixelwert der als undefiniert interpretiert werden soll (unterschiedlich von NULL)."
 #: ../locale/scriptstrings/d.polar_to_translate.c:5
 msgid "Name of optional EPS output file"
@@ -8011,9 +7411,7 @@
 #: ../locale/scriptstrings/i.image.mosaic_to_translate.c:1
 msgid "Mosaics up to 4 images and extends colormap; creates map *.mosaic"
-msgstr ""
-"Mosaikiert bis zu 4 Bilder und erweitert die Farbtabelle. Erzeugt *.mosaic-"
-"Karten."
+msgstr "Mosaikiert bis zu 4 Bilder und erweitert die Farbtabelle. Erzeugt *.mosaic-Karten."
 #: ../locale/scriptstrings/i.image.mosaic_to_translate.c:2
 msgid "raster, imagery, mosaicking"
@@ -8036,12 +7434,8 @@
 msgstr "4. Bild für das Mosaik."
 #: ../locale/scriptstrings/r.plane_to_translate.c:1
-msgid ""
-"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
-"point."
-msgstr ""
-"Erzeugt eine Rasterkarte mit einer Ebene mit gegebener Neigung "
-"(inclination), Ausrichtung (azimuth) und einem Punkt."
+msgid "Creates raster plane map given dip (inclination), aspect (azimuth) and one point."
+msgstr "Erzeugt eine Rasterkarte mit einer Ebene mit gegebener Neigung (inclination), Ausrichtung (azimuth) und einem Punkt."
 #: ../locale/scriptstrings/r.plane_to_translate.c:3
 msgid "Name of raster plane to be created"
@@ -8080,12 +7474,8 @@
 msgstr "Raster, Landschaftsstruktur Analyse"
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:1
-msgid ""
-"Calculates univariate statistics from a raster map based on vector polygons "
-"and uploads statistics to new attribute columns."
-msgstr ""
-"Berechnet Kennzahlen univariater Statistik einer Rasterkarte für Polygone "
-"und fügt die Ergebnisse als neue Spalte der Attributtabelle an."
+msgid "Calculates univariate statistics from a raster map based on vector polygons and uploads statistics to new attribute columns."
+msgstr "Berechnet Kennzahlen univariater Statistik einer Rasterkarte für Polygone und fügt die Ergebnisse als neue Spalte der Attributtabelle an."
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:2
 msgid "vector, raster, statistics"
@@ -8106,12 +7496,8 @@
 msgstr "Name der Vektorkarte (Polygone)."
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:6
-msgid ""
-"number determines which table to use"
-msgstr ""
+msgid "A single vector map can be connected to multiple database tables. This number determines which table to use"
 #: ../locale/scriptstrings/v.rast.stats_to_translate.c:7
 msgid "Name of raster map to calculate statistics from"
@@ -8125,13 +7511,11 @@
 #: ../raster/r.univar2/r3.univar_main.c:53
 #: ../raster/r.univar2/r.univar_main.c:52 ../vector/v.univar/main.c:124
 msgid "Percentile to calculate (requires extended statistics flag)"
-msgstr ""
-"zu berechnende Perzentile (erfordert den Schalter 'erweiterte Statistiken')."
+msgstr "zu berechnende Perzentile (erfordert den Schalter 'erweiterte Statistiken')."
 #: ../locale/scriptstrings/d.monsize_to_translate.c:1
 msgid "Selects/starts specified monitor at specified size"
-msgstr ""
-"Selektiert/Startet das angegebene Grafikfenster in der angegebenen Größe."
+msgstr "Selektiert/Startet das angegebene Grafikfenster in der angegebenen Größe."
 #: ../locale/scriptstrings/d.monsize_to_translate.c:3
 msgid "Display monitor to start"
@@ -8146,14 +7530,12 @@
 msgstr "Höhe des neuen Grafikfensters in Pixel."
 #: ../locale/scriptstrings/v.db.dropcol_to_translate.c:1
-msgid ""
-"Drops a column from the attribute table connected to a given vector map."
+msgid "Drops a column from the attribute table connected to a given vector map."
 msgstr "Löscht eine Spalte der Attributtabelle einer Vektorkarte."
 #: ../locale/scriptstrings/v.db.dropcol_to_translate.c:3
 msgid "Vector map for which to drop attribute column"
-msgstr ""
-"Vektorkarte, in deren Attributtabelle eine Spalte gelsöcht werden soll."
+msgstr "Vektorkarte, in deren Attributtabelle eine Spalte gelsöcht werden soll."
 #: ../locale/scriptstrings/v.db.dropcol_to_translate.c:4
 msgid "Layer where to drop column"
@@ -8164,11 +7546,8 @@
 msgstr "Name der zu löschenden Spalte"
 #: ../locale/scriptstrings/d.shadedmap_to_translate.c:1
-#, fuzzy
 msgid "Drapes a color raster over a shaded relief map using d.his."
-msgstr ""
-"Drapiert eine Rasterkarte mit Farbwerten über Schummerungskarte unter "
-"Verwendung von d.his."
+msgstr "Drapiert eine Farb-Rasterkarte über eine Schummerungskarte mittels d.his."
 #: ../locale/scriptstrings/d.shadedmap_to_translate.c:2
 msgid "Name of shaded relief or aspect map"
@@ -8188,9 +7567,7 @@
 #: ../locale/scriptstrings/db.test_to_translate.c:1
 msgid "Test database driver, database must exist and set by db.connect."
-msgstr ""
-"Teste den Datenbank-Treiber. Die Datenbank muß existieren und mittels db."
-"connect verbunden sein."
+msgstr "Teste den Datenbank-Treiber. Die Datenbank muß existieren und mittels db.connect verbunden sein."
 #: ../locale/scriptstrings/db.test_to_translate.c:3
 msgid "Test name"
@@ -8198,9 +7575,7 @@
 #: ../locale/scriptstrings/d.out.png_to_translate.c:1
 msgid "Saves active display monitor to PNG file in home directory"
-msgstr ""
-"Speichert den Inhalt des aktiven Grafikfensters in einer PNG-Datei im Heimat-"
-"Verzeichnis."
+msgstr "Speichert den Inhalt des aktiven Grafikfensters in einer PNG-Datei im Heimat-Verzeichnis."
 #: ../locale/scriptstrings/d.out.png_to_translate.c:3
 msgid "Name of PNG file"
@@ -8256,12 +7631,8 @@
 msgstr "Name für automatisch erzeugte Schlüsselwert-Spalte."
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:1
-msgid ""
-"Georeference, rectify and import Terra-ASTER imagery and relative DEM's "
-"using gdalwarp."
-msgstr ""
-"Georeferenziere, rektifiziere und importiere Terra-ASTER-Bilder und relative "
-"DGMs mit Hilfe von gdalwarp."
+msgid "Georeference, rectify and import Terra-ASTER imagery and relative DEM's using gdalwarp."
+msgstr "Georeferenziere, rektifiziere und importiere Terra-ASTER-Bilder und relative DGMs mit Hilfe von gdalwarp."
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:3
 msgid "Input ASTER image to be georeferenced & rectified"
@@ -8272,12 +7643,8 @@
 msgstr "ASTER-Bild Processing Status (Level 1A, Level 1B, oder relatives DGM)."
 #: ../locale/scriptstrings/r.in.aster_to_translate.c:5
-msgid ""
-"L1A or L1B band to translate (1, 2, 3n, 3b, 4-14). Can only translate a "
-"single band"
-msgstr ""
-"L1A oder L1B Kanal zum Umrechnen (1, 2, 3n, 3b, 4-14). kann nur ein "
-"einzelnen Kanal umrechnen."
+msgid "L1A or L1B band to translate (1, 2, 3n, 3b, 4-14). Can only translate a single band"
+msgstr "L1A oder L1B Kanal zum Umrechnen (1, 2, 3n, 3b, 4-14). kann nur ein einzelnen Kanal umrechnen."
 #: ../locale/scriptstrings/v.in.e00_to_translate.c:1
 msgid "Import E00 file into a vector map."
@@ -8305,8 +7672,7 @@
 #: ../locale/scriptstrings/d.slide.show_to_translate.c:4
 msgid "Map prefix. Specify character(s) to view selected maps only"
-msgstr ""
-"Karten-Präfix. Bestimmen Sie Buchstaben um nur ausgewählte Karten anzusehen."
+msgstr "Karten-Präfix. Bestimmen Sie Buchstaben um nur ausgewählte Karten anzusehen."
 #: ../locale/scriptstrings/d.slide.show_to_translate.c:5
 msgid "Map number show across the monitor"
@@ -8318,20 +7684,15 @@
 #: ../locale/scriptstrings/d.slide.show_to_translate.c:7
 msgid "Mapsets to use. Specify multiple mapsets comma separated"
-msgstr ""
-"ZU verwendendes Mapset. Geben Sie mehrere Mapsets durch Kommas getrennt an."
+msgstr "ZU verwendendes Mapset. Geben Sie mehrere Mapsets durch Kommas getrennt an."
 #: ../locale/scriptstrings/d.slide.show_to_translate.c:8
 msgid "Number of seconds to pause between slides"
 msgstr "Pause zwischen den Bildern in Sekunden."
-msgid ""
-"Download waypoints, routes, and tracks from a Garmin GPS receiver into a "
-"vector map."
-msgstr ""
-"Lade Wegpunkte, Routen und Tracks von einem Garmin GPS Gerät in eine "
-"Vektorkarte."
+msgid "Download waypoints, routes, and tracks from a Garmin GPS receiver into a vector map."
+msgstr "Lade Wegpunkte, Routen und Tracks von einem Garmin GPS Gerät in eine Vektorkarte."
 #: ../locale/scriptstrings/v.in.garmin_to_translate.c:4
 msgid "Download Waypoints from GPS"
@@ -8379,8 +7740,7 @@
 #: ../locale/scriptstrings/v.db.droptable_to_translate.c:3
 msgid "Force removal (required for actual deletion of table)"
-msgstr ""
-"Erzwinge das Löschen (erforderlich um tatsächlich die Tabelle zu löschen)."
+msgstr "Erzwinge das Löschen (erforderlich um tatsächlich die Tabelle zu löschen)."
 #: ../locale/scriptstrings/v.db.droptable_to_translate.c:4
 msgid "Vector map from which to remove attribute table"
@@ -8388,8 +7748,7 @@
 #: ../locale/scriptstrings/v.db.droptable_to_translate.c:5
 msgid "Name of existing attribute table (default: vector map name)"
-msgstr ""
-"Name einer existierenden Attributtabelle (Standard Name der Vektorkarte)."
+msgstr "Name einer existierenden Attributtabelle (Standard Name der Vektorkarte)."
 #: ../locale/scriptstrings/v.db.droptable_to_translate.c:6
 msgid "Layer from which to drop linked attribute table"
@@ -8445,8 +7804,7 @@
 #: ../locale/scriptstrings/v.db.join_to_translate.c:5
 msgid "Join column in map table"
-msgstr ""
-"Spalte der Vektorkartentabelle, die für den Join verwendet werden soll."
+msgstr "Spalte der Vektorkartentabelle, die für den Join verwendet werden soll."
 #: ../locale/scriptstrings/v.db.join_to_translate.c:6
 msgid "Other table name"
@@ -8457,17 +7815,12 @@
 msgstr "Spalte in der anderen Tabelle, die für den Join verwendet werden soll."
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:1
-msgid ""
-"Creates and connects a new attribute table to a given layer of an existing "
-"vector map."
-msgstr ""
-"Erzeugt eine neue Attributtabelle und sie zu einem Layer einer existierenden "
-"Vektorkarte."
+msgid "Creates and connects a new attribute table to a given layer of an existing vector map."
+msgstr "Erzeugt eine neue Attributtabelle und sie zu einem Layer einer existierenden Vektorkarte."
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:3
 msgid "Vector map for which to add new attribute table"
-msgstr ""
-"Vektorkarte, zu der eine neue Attributtabelle hinzugefügt werden soll. "
+msgstr "Vektorkarte, zu der eine neue Attributtabelle hinzugefügt werden soll. "
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:4
 msgid "Name of new attribute table (default: vector map name)"
@@ -8478,12 +7831,8 @@
 msgstr "Layer in dem die neue Attributtabelle hinzugefügt werden soll."
 #: ../locale/scriptstrings/v.db.addtable_to_translate.c:6
-msgid ""
-"Name and type of the new column(s) (types depend on database backend, but "
-"all support VARCHAR(), INT, DOUBLE PRECISION and DATE)"
-msgstr ""
-"Name und Art der neuen Spalten (Art hängt von der verwendeten Datenbank ab, "
-"aber alle unterstützen VARCHAR(), INT, DOUBLE PRECISION and DATE)."
+msgid "Name and type of the new column(s) (types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE)"
+msgstr "Name und Art der neuen Spalten (Art hängt von der verwendeten Datenbank ab, aber alle unterstützen VARCHAR(), INT, DOUBLE PRECISION and DATE)."
 #: ../locale/scriptstrings/r.mapcalculator_to_translate.c:1
 msgid "Calculate new raster map from a r.mapcalc expression."
@@ -8616,8 +7965,7 @@
 #: ../locale/scriptstrings/r.blend_to_translate.c:1
 msgid "Blends color components of two raster maps by a given ratio."
-msgstr ""
-"Mischt die Farbkomponenten zweier Rasterkarten im angegebenen Verhältnis."
+msgstr "Mischt die Farbkomponenten zweier Rasterkarten im angegebenen Verhältnis."
 #: ../locale/scriptstrings/r.blend_to_translate.c:2
 #: ../raster/r.surf.fractal/main.c:37
@@ -8634,8 +7982,7 @@
 #: ../locale/scriptstrings/r.blend_to_translate.c:5
 msgid "Base name for red, green and blue output maps containing the blend"
-msgstr ""
-"Präfix für die rote, grüne und blaue Ausgabekarte der erstellten Mischung."
+msgstr "Präfix für die rote, grüne und blaue Ausgabekarte der erstellten Mischung."
 #: ../locale/scriptstrings/r.blend_to_translate.c:6
 msgid "Percentage weight of first map for color blending"
@@ -8659,37 +8006,27 @@
 #: ../locale/scriptstrings/v.db.update_to_translate.c:6
 msgid "Literal value to update the column with"
-msgstr ""
+msgstr "Wert mit dem die Spalte aktualisiert wird"
 #: ../locale/scriptstrings/v.db.update_to_translate.c:7
-#, fuzzy
 msgid "Varchar values must be in single quotes, e.g. 'grass'"
-msgstr ""
-"Wert mit dem die Spalte aktualisiert werden soll (varchar-Werte müssen in "
-"einfachen Anführungszeichen angegeben werden, z.B. 'grass')."
+msgstr "varchar-Werte müssen in einfachen Anführungszeichen angegeben werden, z.B. 'grass'."
 #: ../locale/scriptstrings/v.db.update_to_translate.c:8
-#, fuzzy
 msgid "Name of attribute column to query"
-msgstr "Name der Attributespalte verwendet mit der 'query'-Option."
+msgstr "Name der abzufragenden Attributspalte"
 #: ../locale/scriptstrings/v.db.update_to_translate.c:9
 msgid "Can be a combination of columns, e.g. col1+col2"
-msgstr ""
+msgstr "Kann eine Kombination von Spalten sein, z.B. col1+col2"
 #: ../locale/scriptstrings/v.db.update_to_translate.c:10
-msgid ""
-"WHERE conditions for update, without 'where' keyword (e.g. cat=1 or col1/"
-"col2>1)"
-msgstr ""
-"WHERE Bedingung für die Aktualisierung, ohne das Schlüsselwort 'where' (z.B. "
-"cat=1 or col1/col2>1)."
+msgid "WHERE conditions for update, without 'where' keyword (e.g. cat=1 or col1/col2>1)"
+msgstr "WHERE Bedingung für die Aktualisierung, ohne das Schlüsselwort 'where' (z.B. cat=1 or col1/col2>1)."
 #: ../locale/scriptstrings/m.proj_to_translate.c:1
 msgid "Convert coordinates from one projection to another (cs2cs frontend)."
-msgstr ""
-"Konvertiert Koordinaten von einer Projektion zu einer Anderen (cs2cs "
-"Frontend)."
+msgstr "Konvertiert Koordinaten von einer Projektion zu einer Anderen (cs2cs Frontend)."
 #: ../locale/scriptstrings/m.proj_to_translate.c:2
 msgid "miscellaneous, projection"
@@ -8709,9 +8046,7 @@
 #: ../locale/scriptstrings/m.proj_to_translate.c:5
 msgid "Output coordinate file (omit to send to stdout)"
-msgstr ""
-"Ausgabe-Koordinatendatei (leer lassen, wenn nach stdout geschrieben werden "
-"soll)."
+msgstr "Ausgabe-Koordinatendatei (leer lassen, wenn nach stdout geschrieben werden soll)."
 #: ../locale/scriptstrings/m.proj_to_translate.c:9
 msgid "Input projection parameters (PROJ.4 style)"
@@ -8730,33 +8065,23 @@
 #: ../locale/scriptstrings/m.proj_to_translate.c:13
 msgid "Use LL WGS84 as input and current location as output projection"
-msgstr ""
-"Verwende LL WGS84 als Eingabe-Projektion und aktuelle Loaction als Ausgabe-"
-"Projektion."
+msgstr "Verwende LL WGS84 als Eingabe-Projektion und aktuelle Loaction als Ausgabe-Projektion."
 #: ../locale/scriptstrings/m.proj_to_translate.c:15
 msgid "Use current location as input and LL WGS84 as output projection"
 msgstr "Verwende LL WGS84 als Eingabe-Projektion und Ausgabe-Projektion."
 #: ../locale/scriptstrings/m.proj_to_translate.c:17
-msgid ""
-"Output long/lat in decimal degrees, or other projections with many decimal "
-"places"
-msgstr ""
-"Gebe long/lat in Dezimalgrad oder anderen Projektionen mit vielen "
-"Dezimalstellen aus"
+msgid "Output long/lat in decimal degrees, or other projections with many decimal places"
+msgstr "Gebe long/lat in Dezimalgrad oder anderen Projektionen mit vielen Dezimalstellen aus"
 #: ../locale/scriptstrings/m.proj_to_translate.c:19
-msgid ""
-"Script style output in CSV format respecting the field separator settings"
-msgstr ""
-"Ausgabe im Skript-Style im CSV-Format unter Beachtung der Feldtrenner-"
-"Einstellungen."
+msgid "Script style output in CSV format respecting the field separator settings"
+msgstr "Ausgabe im Skript-Style im CSV-Format unter Beachtung der Feldtrenner-Einstellungen."
 #: ../locale/scriptstrings/m.proj_to_translate.c:21
 msgid "Verbose mode (print projection parameters and filenames to stderr)"
-msgstr ""
-"Gesprächiger Modus (Gebe Projektionsparameter und Dateinamen auf stderr aus)."
+msgstr "Gesprächiger Modus (Gebe Projektionsparameter und Dateinamen auf stderr aus)."
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:1
 msgid "Downloads and imports data from WMS servers."
@@ -8869,9 +8194,7 @@
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:37
 msgid "Named region to request data for. Current region used if omitted"
-msgstr ""
-"Benannte Region, für die Daten angefragt werden sollen. Wenn nicht angegeben "
-"wird die aktuelle Region verwendet."
+msgstr "Benannte Region, für die Daten angefragt werden sollen. Wenn nicht angegeben wird die aktuelle Region verwendet."
 #: ../locale/scriptstrings/r.in.wms_to_translate.c:39
 msgid "Folder to save downloaded data to"
@@ -8898,11 +8221,8 @@
 msgstr "Erfordert den Schalter 'Liste verfügbare Layer'."
 #: ../locale/scriptstrings/v.in.sites.all_to_translate.c:1
-msgid ""
-"Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps."
-msgstr ""
-"Konvertiert alle alten GRASS < Ver5.7 'Site'-karten im aktuellen Mapset zu "
-"Vektorkarten."
+msgid "Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps."
+msgstr "Konvertiert alle alten GRASS < Ver5.7 'Site'-karten im aktuellen Mapset zu Vektorkarten."
 #: ../locale/scriptstrings/v.in.sites.all_to_translate.c:2
 msgid "sites, vector, import"
@@ -8989,12 +8309,8 @@
 msgstr "Übersteuere die Projektionsprüfung (verwende Projektion der Location)"
 #: ../locale/scriptstrings/v.convert.all_to_translate.c:1
-msgid ""
-"Converts all older versions of GRASS vector maps in current mapset to "
-"current format."
-msgstr ""
-"Konvertiert alle alten GRASS Vektorkarten im aktuellen Mapset in das "
-"aktuelle Format."
+msgid "Converts all older versions of GRASS vector maps in current mapset to current format."
+msgstr "Konvertiert alle alten GRASS Vektorkarten im aktuellen Mapset in das aktuelle Format."
 #: ../locale/scriptstrings/v.convert.all_to_translate.c:3
 msgid "run non-interactively"
@@ -9002,17 +8318,11 @@
 #: ../locale/scriptstrings/g.extension_to_translate.c:1
 msgid "Tool to maintain GRASS extensions in local GRASS installation."
-msgstr ""
-"Werkzeug um GRASS-Erweiterungen in lokaler GRASS-Installation zu verwalten."
+msgstr "Werkzeug um GRASS-Erweiterungen in lokaler GRASS-Installation zu verwalten."
 #: ../locale/scriptstrings/g.extension_to_translate.c:2
-msgid ""
-"Downloads, installs extensions from GRASS Addons SVN repository into local "
-"GRASS installation or removes installed extensions."
-msgstr ""
-"Download und Installation von Erweiterungen aus dem 'GRASS Addons SVN "
-"Repository' in der lokalen GRASS Installation oder Entfernt installierte "
-"Erweiterungen. "
+msgid "Downloads, installs extensions from GRASS Addons SVN repository into local GRASS installation or removes installed extensions."
+msgstr "Download und Installation von Erweiterungen aus dem 'GRASS Addons SVN Repository' in der lokalen GRASS Installation oder Entfernt installierte Erweiterungen. "
 #: ../locale/scriptstrings/g.extension_to_translate.c:3
 msgid "general, extensions"
@@ -9041,8 +8351,7 @@
 #: ../locale/scriptstrings/g.extension_to_translate.c:10
 msgid "Install system-wide (may need system administrator rights)"
-msgstr ""
-"Systemweite Installation (eventuell Systemadministratorrechte erforderlich)."
+msgstr "Systemweite Installation (eventuell Systemadministratorrechte erforderlich)."
 #: ../locale/scriptstrings/g.extension_to_translate.c:11
 msgid "Install system-wide using sudo"
@@ -9100,9 +8409,7 @@
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:8
 msgid "Name of attribute column to use for thematic display (must be numeric)"
-msgstr ""
-"Name der Attribut-Spalte, die für die thematische Darstellung (muß umerisch "
-"sein)."
+msgstr "Name der Attribut-Spalte, die für die thematische Darstellung (muß umerisch sein)."
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:10
 msgid "Type of thematic display"
@@ -9144,15 +8451,11 @@
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:22
 msgid "Minimum icon size/line width for graduated points/lines)"
-msgstr ""
-"Kleinste Symbolgröße / Linienbreite für die gestufte Darstellung von Punkten/"
-"Linien."
+msgstr "Kleinste Symbolgröße / Linienbreite für die gestufte Darstellung von Punkten/Linien."
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:24
 msgid "Maximum icon size/line width for graduated points and lines"
-msgstr ""
-"Größste Symbolgröße / Linienbreite für die gestufte Darstellung von Punkten/"
-"Linien."
+msgstr "Größste Symbolgröße / Linienbreite für die gestufte Darstellung von Punkten/Linien."
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:26
 msgid "Number of classes for interval theme (integer)"
@@ -9172,8 +8475,7 @@
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:32
 msgid "GRASS named color or R:G:B triplet. Set color scheme to single color"
-msgstr ""
-"GRASS Farbnamen oder R:G:B Triplets. Setze das Farbschema auf eine Farbe."
+msgstr "GRASS Farbnamen oder R:G:B Triplets. Setze das Farbschema auf eine Farbe."
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:34
 msgid "Color for graduated lines or point/area outlines"
@@ -9181,8 +8483,7 @@
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:35
 msgid "GRASS named color or R:G:B triplet. Set color scheme to single color."
-msgstr ""
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:37
 msgid "Beginning color for custom color gradient"
@@ -9209,15 +8510,11 @@
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:45
 msgid "Save thematic map commands to group file for GIS Manager"
-msgstr ""
-"Speichere die Befehle zur Erstellung der thematischen Karte in die group-"
-"Datei für den GIS-Manager."
+msgstr "Speichere die Befehle zur Erstellung der thematischen Karte in die group-Datei für den GIS-Manager."
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:49
 msgid "Root for the name of psmap instruction files to be in current directory"
-msgstr ""
-"Dateiname (ohne Dateiendung) für die psmap-Datei. Die Datei wird im "
-"aktuellen Verzeichnis gespeichert."
+msgstr "Dateiname (ohne Dateiendung) für die psmap-Datei. Die Datei wird im aktuellen Verzeichnis gespeichert."
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:50
 msgid "If not set, no psmap instruction files will be created)"
@@ -9225,9 +8522,7 @@
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:52
 msgid "Name of group file where thematic map commands will be saved"
-msgstr ""
-"Name der group-Datei, in der die Befehle zur Erstellung der thematischen "
-"Karte gespeichert werden."
+msgstr "Name der group-Datei, in der die Befehle zur Erstellung der thematischen Karte gespeichert werden."
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:54
 msgid "Create graphic legend in x11 display monitor"
@@ -9243,9 +8538,7 @@
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:60
 msgid "Output legend for GIS Manager (for scripting use only)"
-msgstr ""
-"Gebe die Legende für den GIS-Maneger aus (nur für die Verwendung in "
-"Skripten)."
+msgstr "Gebe die Legende für den GIS-Maneger aus (nur für die Verwendung in Skripten)."
 #: ../locale/scriptstrings/d.vect.thematic_to_translate.c:62
 msgid "Use math notation brackets in legend"
@@ -9265,8 +8558,7 @@
 #: ../locale/scriptstrings/r.mask_to_translate.c:5
 msgid "Category values to use for MASK (format: 1 2 3 thru 7 *)"
-msgstr ""
-"Kategoriewerte, die für die Maske verwendet werden (Format: 1 2 3 thru 7 *)."
+msgstr "Kategoriewerte, die für die Maske verwendet werden (Format: 1 2 3 thru 7 *)."
 #: ../locale/scriptstrings/r.mask_to_translate.c:7
 msgid "Create inverse MASK from specified 'maskcats' list"
@@ -9306,11 +8598,8 @@
 msgstr "Handbuchseite die gezeigt werden soll."
 #: ../locale/scriptstrings/i.spectral_to_translate.c:1
-msgid ""
-"Displays spectral response at user specified locations in group or images."
-msgstr ""
-"Zeige die Farbempfindlichkeit an Benutzerdefinierten Stellen in der Gruppe "
-"oder in Bilderen."
+msgid "Displays spectral response at user specified locations in group or images."
+msgstr "Zeige die Farbempfindlichkeit an benutzerdefinierten Stellen in Gruppe oder Bildern."
 #: ../locale/scriptstrings/i.spectral_to_translate.c:2
 msgid "imagery, raster, multispectral"
@@ -9318,7 +8607,7 @@
 #: ../locale/scriptstrings/i.spectral_to_translate.c:3
 msgid "Group input"
-msgstr "Eingabe-Gruppe "
+msgstr "Eingabe-Gruppe"
 #: ../locale/scriptstrings/i.spectral_to_translate.c:4
 msgid "Raster input maps"
@@ -9326,52 +8615,47 @@
 #: ../locale/scriptstrings/i.spectral_to_translate.c:5
 msgid "Write output to PNG image"
-msgstr "Schreibe die Ausgabe in ein PNG-Bild."
+msgstr "Schreibe die Ausgabe in ein PNG-Bild"
 #: ../locale/scriptstrings/i.spectral_to_translate.c:6
 msgid "Use image list and not group"
-msgstr "Verwende eine Bild-Liste und keine Gruppe."
+msgstr "Verwende eine Bild-Liste und keine Gruppe"
 #: ../locale/scriptstrings/i.spectral_to_translate.c:7
 msgid "Select multiple points"
-msgstr "Selektiere mehrere Punkte."
+msgstr "Selektiere mehrere Punkte"
 #: ../locale/scriptstrings/i.spectral_to_translate.c:8
-#, fuzzy
 msgid "Show pick coordinates instead of numbering in the legend"
-msgstr "Beschrifte mit Koordinaten anstelle der Nummerierung."
+msgstr "Zeige gewählte Koordinaten anstelle der Nummerierung in der Legende"
 #: ../locale/scriptstrings/d.mvmon_to_translate.c:1
 msgid "Moves displayed maps to another monitor"
-msgstr "Verschiebt angezeigte Karten in ein anderes Grafikfenster."
+msgstr "Verschiebt angezeigte Karten in ein anderes Grafikfenster"
 #: ../locale/scriptstrings/d.mvmon_to_translate.c:3
 msgid "clear target monitor before moving"
-msgstr "Lösche das Ziel-Fenster vor dem Verschieben."
+msgstr "Lösche das Ziel-Fenster vor dem Verschieben"
 #: ../locale/scriptstrings/d.mvmon_to_translate.c:4
 msgid "stay with source monitor"
-msgstr "Bleib im Quell -Grafikfenster."
+msgstr "Bleib im Quell-Grafikfenster"
 #: ../locale/scriptstrings/d.mvmon_to_translate.c:5
 msgid "kill source monitor after moving"
-msgstr "Beende das Quell-Fenster nach dem Verschieben."
+msgstr "Beende das Quell-Fenster nach dem Verschieben"
 #: ../locale/scriptstrings/d.mvmon_to_translate.c:6
 msgid "Target monitor"
-msgstr "Ziel Grafikfenster."
+msgstr "Ziel Grafikfenster"
 #: ../locale/scriptstrings/d.mvmon_to_translate.c:7
 msgid "Source monitor"
-msgstr "Quell Grafikfenster."
+msgstr "Quell Grafikfenster"
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:1
-msgid ""
-"Reclasses a raster map greater or less than user specified area size (in "
-"hectares)."
-msgstr ""
-"Reklassifiziert eine Rasterkarte mit Flächen größer oder kleiner als eine "
-"benutzerspezifizierte Fläche (in Hektar)."
+msgid "Reclasses a raster map greater or less than user specified area size (in hectares)."
+msgstr "Reklassifiziert eine Rasterkarte mit Flächen größer oder kleiner als eine benutzerspezifizierte Fläche (in Hektar)."
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:2
 msgid "raster, statistics, aggregation"
@@ -9383,9 +8667,8 @@
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:6
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:8
-#, fuzzy
 msgid "Area"
-msgstr "Fläche:\n"
+msgstr "Fläche"
 #: ../locale/scriptstrings/r.reclass.area_to_translate.c:7
 msgid "Greater value option that sets the >= area size limit [hectares]"
@@ -9393,8 +8676,7 @@
 #: ../locale/scriptstrings/i.oif_to_translate.c:1
 msgid "Calculates Optimum-Index-Factor table for LANDSAT TM bands 1-5, & 7"
-msgstr ""
-"Berechne die Optimum-Index-Faktor Tabelle für die LANDSAT TM Kanäle 1-5, & 7."
+msgstr "Berechne die Optimum-Index-Faktor Tabelle für die LANDSAT TM Kanäle 1-5, & 7."
 #: ../locale/scriptstrings/i.oif_to_translate.c:2
 msgid "raster, imagery, statistics"
@@ -9425,12 +8707,8 @@
 msgstr "LANDSAT TM Kanal 7."
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:1
-msgid ""
-"Dissolves boundaries between adjacent areas sharing a common category number "
-"or attribute."
-msgstr ""
-"Löst Grenzen zwischen benachbarten Flächen mit gleicher Kategorienummer oder "
-"gleichem Attributwert auf."
+msgid "Dissolves boundaries between adjacent areas sharing a common category number or attribute."
+msgstr "Löst Grenzen zwischen benachbarten Flächen mit gleicher Kategorienummer oder gleichem Attributwert auf."
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:2
 msgid "vector, area, dissolve"
@@ -9442,9 +8720,7 @@
 #: ../locale/scriptstrings/v.dissolve_to_translate.c:7
 msgid "Name of column used to dissolve common boundaries"
-msgstr ""
-"Name der Spalte, die für das auflösen gemeinsamer Grenzen verwendet werden "
-"soll."
+msgstr "Name der Spalte, die für das auflösen gemeinsamer Grenzen verwendet werden soll."
 #: ../locale/scriptstrings/r3.mapcalculator_to_translate.c:1
 msgid "Calculates new grid3D volume from r3.mapcalc expression."
@@ -9741,18 +9017,12 @@
 #: ../imagery/i.landsat.acca/main.c:74
 #, c-format
-msgid ""
-"Input raster map <%s> is not floating point (process DN using i.landsat.toar "
-"to radiance first)"
-msgstr ""
-"Eingabe Rasterkarte <%s> enthält keine Fließkomma-Werte (verarbeiten Sie "
-"zunächst die DN mittels i.landsat.toar zu Strahlungswerten)."
+msgid "Input raster map <%s> is not floating point (process DN using i.landsat.toar to radiance first)"
+msgstr "Eingabe Rasterkarte <%s> enthält keine Fließkomma-Werte (verarbeiten Sie zunächst die DN mittels i.landsat.toar zu Strahlungswerten)."
 #: ../imagery/i.landsat.acca/main.c:106
 msgid "Performs Landsat TM/ETM+ Automatic Cloud Cover Assessment (ACCA)."
-msgstr ""
-"Führt automatische Landsat TM/ETM+ Einschätzung der Wolkenbedeckung (ACCA) "
-"durch."
+msgstr "Führt automatische Landsat TM/ETM+ Einschätzung der Wolkenbedeckung (ACCA) durch."
 #: ../imagery/i.landsat.acca/main.c:107
 msgid "imagery, landsat, acca"
@@ -9800,11 +9070,8 @@
 msgstr "Verwende immer die Wolkensignatur (Schritt 14)"
 #: ../imagery/i.landsat.acca/main.c:159
-msgid ""
-"Bypass second-pass processing, and merge warm (not ambiguous) and cold clouds"
-msgstr ""
-"Überspringe den zweiten Durchgang und fasse warme (nicht mehrdeutig) und "
-"kalte Wolken zusammen."
+msgid "Bypass second-pass processing, and merge warm (not ambiguous) and cold clouds"
+msgstr "Überspringe den zweiten Durchgang und fasse warme (nicht mehrdeutig) und kalte Wolken zusammen."
 #: ../imagery/i.landsat.acca/main.c:164
 msgid "Include a category for cloud shadows"
@@ -9812,7 +9079,7 @@
 #: ../imagery/i.cca/transform.c:18
 msgid "Unable to allocate cell buffers."
-msgstr "Kann keinen Speicher für Zellbuffer reservieren."
+msgstr "Kann keinen Speicher für Zellpuffer reservieren."
 #: ../imagery/i.cca/transform.c:24
 msgid "Error reading cell map during transform."
@@ -9832,8 +9099,7 @@
 #: ../imagery/i.cca/main.c:86
 msgid "Canonical components analysis (cca) program for image processing."
-msgstr ""
-"Kanonische Komponenten Analyse (cca) Programm für die Bildverarbeitung."
+msgstr "Kanonische Komponenten Analyse (cca) Programm für die Bildverarbeitung."
 #: ../imagery/i.cca/main.c:93 ../imagery/i.class/main.c:72
 msgid "Name of input imagery subgroup"
@@ -9986,12 +9252,8 @@
 msgstr "Bildverarbeitung, Klassifikation, überwacht, SMAP"
 #: ../imagery/i.smap/shapiro/main.c:40
-msgid ""
-"Performs contextual image classification using sequential maximum a "
-"posteriori (SMAP) estimation."
-msgstr ""
-"Führt eine nachbarschaftsbasierte Bildklassifikation unter Anwendung des "
-"'sequential maximum a posteriori (SMAP)' Ansatzes durch."
+msgid "Performs contextual image classification using sequential maximum a posteriori (SMAP) estimation."
+msgstr "Führt eine nachbarschaftsbasierte Bildklassifikation unter Anwendung des 'sequential maximum a posteriori (SMAP)' Ansatzes durch."
 #: ../imagery/i.smap/shapiro/parse.c:21 ../imagery/i.maxlik/main.c:79
 msgid "Name of file containing signatures"
@@ -10099,21 +9361,12 @@
 msgstr "Metadaten-Datei <%s> nicht gefunden"
 #: ../imagery/i.landsat.toar/main.c:67
-msgid ""
-"Calculates top-of-atmosphere radiance or reflectance and temperature for "
-"Landsat MSS/TM/ETM+/OLI"
-msgstr ""
-"Berechnet top-of-atmosphere Strahlung oder Reflexion und Temperatur für "
-"Landsat MSS/TM/ETM+/OLI."
+msgid "Calculates top-of-atmosphere radiance or reflectance and temperature for Landsat MSS/TM/ETM+/OLI"
+msgstr "Berechnet top-of-atmosphere Strahlung oder Reflexion und Temperatur für Landsat MSS/TM/ETM+/OLI."
 #: ../imagery/i.landsat.toar/main.c:69
-#, fuzzy
-msgid ""
-"imagery, Landsat, radiance, reflectance, brightness temperature, atmospheric "
-"correction"
-msgstr ""
-"Bildbearbeitung, Landsat, top-of-atmosphere Strahlung, dos-type einfache "
-"atmosphärische Korrektion"
+msgid "imagery, Landsat, radiance, reflectance, brightness temperature, atmospheric correction"
+msgstr "Bildbearbeitung, Landsat, Strahlung, Reflexion, Helligkeitstemperatur, atmosphärische Korrektion"
 #: ../imagery/i.landsat.toar/main.c:81
 msgid "Prefix for output raster maps"
@@ -10139,20 +9392,12 @@
 msgstr "Raumfahrzeug Sensor"
 #: ../imagery/i.landsat.toar/main.c:98
-#, fuzzy
 msgid "Required only if 'metfile' not given (recommended for sanity)"
 msgstr "Nur notwendig, wenn 'metfile' nicht angegeben (vernünftigerweise)"
 #: ../imagery/i.landsat.toar/main.c:101
-#, fuzzy
-msgid ""
-"mss1;Landsat_1 MSS;mss2;Landsat_2 MSS;mss3;Landsat_3 MSS;mss4;Landsat_4 MSS;"
-"mss5;Landsat_5 MSS;tm4;Landsat_4 TM;tm5;Landsat_5 TM;tm7;Landsat_7 ETM+;oli8;"
-"Landsat_8 OLI/TIRS"
-msgstr ""
-"mss5;Landsat_5 MSS;tm4;Landsat_4 TM;tm5;Landsat_5 TM;tm7;Landsat_7 ETM+;ot8;"
+msgid "mss1;Landsat_1 MSS;mss2;Landsat_2 MSS;mss3;Landsat_3 MSS;mss4;Landsat_4 MSS;mss5;Landsat_5 MSS;tm4;Landsat_4 TM;tm5;Landsat_5 TM;tm7;Landsat_7 ETM+;oli8;Landsat_8 OLI/TIRS"
+msgstr "mss1;Landsat_1 MSS;mss2;Landsat_2 MSS;mss3;Landsat_3 MSS;mss4;Landsat_4 MSS;mss5;Landsat_5 MSS;tm4;Landsat_4 TM;tm5;Landsat_5 TM;tm7;Landsat_7 ETM+;oli8;Landsat_8 OLI/TIRS"
 #: ../imagery/i.landsat.toar/main.c:118 ../imagery/i.landsat.toar/main.c:119
 msgid "Atmospheric correction method"
@@ -10189,8 +9434,7 @@
 #: ../imagery/i.landsat.toar/main.c:171
 msgid "Minimum pixels to consider digital number as dark object"
-msgstr ""
-"Minimum Pixel um die \"digital number\" als dunkles Objekt zu betrachten"
+msgstr "Minimum Pixel um die \"digital number\" als dunkles Objekt zu betrachten"
 #: ../imagery/i.landsat.toar/main.c:180
 msgid "Rayleigh atmosphere (diffuse sky irradiance)"
@@ -10201,18 +9445,16 @@
 msgstr "Nur notwendig, wenn 'method' ist DOS3"
 #: ../imagery/i.landsat.toar/main.c:189
-#, fuzzy
 msgid "Output at-sensor radiance instead of reflectance for all bands"
 msgstr "Ausgabe der Strahlung am Sensor anstatt der Reflexion für alle Kanäle"
 #: ../imagery/i.landsat.toar/main.c:194
-msgid ""
-"Input raster maps use as extension the number of the band instead the code"
+msgid "Input raster maps use as extension the number of the band instead the code"
 msgstr "Eingabe-Rasterkarten verwenden die Nummer des Kanals anstatt des Codes"
 #: ../imagery/i.landsat.toar/main.c:198
 msgid "Print output metadata info"
-msgstr ""
+msgstr "Gebe Ausgabe Metadaten aus"
 #: ../imagery/i.landsat.toar/main.c:221 ../imagery/i.landsat.toar/main.c:229
 #, c-format
@@ -10229,9 +9471,8 @@
 msgstr "Vermisse '%s' und/oder '%s' für diesen Satelliten"
 #: ../imagery/i.landsat.toar/main.c:280
-#, fuzzy
 msgid "Landsat-7 requires band gain with 9 (H/L) characters"
-msgstr "Landsat-7 benötigt Kanal gain mit 9 (H/L) Daten"
+msgstr "Landsat-7 benötigt Kanal gain mit 9 (H/L) Zeichen"
 #: ../imagery/i.landsat.toar/main.c:300
 #, c-format
@@ -10248,9 +9489,9 @@
 msgstr "Kann den Header der Rasterkarte <%s> nicht lesen."
 #: ../imagery/i.landsat.toar/main.c:354 ../imagery/i.landsat.toar/main.c:500
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read data type of raster map <%s>"
-msgstr "Kann den Wertebereich der Rasterkarte <%s> nicht lesen."
+msgstr "Kann den Datentyp der Rasterkarte <%s> nicht lesen."
 #: ../imagery/i.landsat.toar/main.c:479
 msgid "Calculating..."
@@ -10289,16 +9530,11 @@
 #: ../imagery/i.maxlik/main.c:65
 msgid "Classifies the cell spectral reflectances in imagery data."
-msgstr ""
-"Klassifiziert die spektrale Reflektion (spectral reflectance) in Bilddaten."
+msgstr "Klassifiziert die spektrale Reflektion (spectral reflectance) in Bilddaten."
 #: ../imagery/i.maxlik/main.c:67
-msgid ""
-"Classification is based on the spectral signature information generated by "
-"either i.cluster, i.class, or i.gensig."
-msgstr ""
-"Die Klassifikation basiert auf der Information der spektralen Signatur "
-"erzeugt von .cluster, i.class, oder i.gensig."
+msgid "Classification is based on the spectral signature information generated by either i.cluster, i.class, or i.gensig."
+msgstr "Die Klassifikation basiert auf der Information der spektralen Signatur erzeugt von .cluster, i.class, oder i.gensig."
 #: ../imagery/i.maxlik/main.c:80
 msgid "Generated by either i.cluster, i.class, or i.gensig"
@@ -10310,26 +9546,17 @@
 #: ../imagery/i.maxlik/main.c:91
 msgid "Name for raster map holding reject threshold results"
-msgstr ""
-"Rasterkarte mit den aufgrund des Schwellwertes ausgemusterten Resultaten."
+msgstr "Rasterkarte mit den aufgrund des Schwellwertes ausgemusterten Resultaten."
 #: ../imagery/i.maxlik/open.c:26
 #, c-format
-msgid ""
-"Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must "
-"have at least 2 raster maps."
-msgstr ""
-"Untergruppe <%s> der Gruppe <%s> beinhaltet keine Rasterkarten. Die "
-"Untergruppe muss mindestens 2 Rasterkarten haben."
+msgid "Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must have at least 2 raster maps."
+msgstr "Untergruppe <%s> der Gruppe <%s> beinhaltet keine Rasterkarten. Die Untergruppe muss mindestens 2 Rasterkarten haben."
 #: ../imagery/i.maxlik/open.c:29
 #, c-format
-msgid ""
-"Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at "
-"least 2 raster maps."
-msgstr ""
-"Untergruppe <%s> der Gruppe <%s> hat nur eine Rasterkarte. Die Untergruppe "
-"muss mindestens 2 Rasterkarten haben."
+msgid "Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at least 2 raster maps."
+msgstr "Untergruppe <%s> der Gruppe <%s> hat nur eine Rasterkarte. Die Untergruppe muss mindestens 2 Rasterkarten haben."
 #: ../imagery/i.maxlik/open.c:48
 #, c-format
@@ -10389,13 +9616,11 @@
 #: ../imagery/i.topo.corr/main.c:132
 msgid "Solar azimuth is necessary to calculate illumination terrain model"
-msgstr ""
-"Sonnenazimuth ist notwendig, um das beleuchtete Geländemodell zu berechnen."
+msgstr "Sonnenazimuth ist notwendig, um das beleuchtete Geländemodell zu berechnen."
 #: ../imagery/i.topo.corr/main.c:135
 msgid "Reflectance maps are necessary to make topographic correction"
-msgstr ""
-"Reflektionskarten sind notwendig, um topographische Korrekturen zu berechnen."
+msgstr "Reflektionskarten sind notwendig, um topographische Korrekturen zu berechnen."
 #: ../imagery/i.topo.corr/main.c:167
 msgid "Elevation raster map of unknown type"
@@ -10480,9 +9705,7 @@
 #: ../imagery/i.pca/main.c:218
 msgid "Scale range length should be > 0. Using default values: 0,255."
-msgstr ""
-"Die Länge des Skalierungsbereichs sollte > 0 sein. Verwende Standardwerte: "
-"0,255. "
+msgstr "Die Länge des Skalierungsbereichs sollte > 0 sein. Verwende Standardwerte: 0,255. "
 #: ../imagery/i.pca/main.c:264
 msgid "Computing covariance matrix..."
@@ -10502,7 +9725,6 @@
 msgstr "Bildverarbeitung, Kartenverwaltung"
 #: ../imagery/i.group/main.c:54
-#, fuzzy
 msgid "Creates, edits, and lists groups and subgroups of imagery data."
 msgstr "Erzeugt, editiert und listet Gruppen und Untergruppen von Bilddateien."
@@ -10608,12 +9830,8 @@
 msgstr "Bildverarbeitung, Farbtransformation, RGB, HIS"
 #: ../imagery/i.rgb.his/r2hmain.c:47
-msgid ""
-"Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-"
-"Intensity-Saturation) color space."
-msgstr ""
-"Transformiert Rasterkarten aus dem RGB (Rot-Grün-Blau) Farbraum in den HIS "
-"(Hue-Intensity-Saturation) Farbraum."
+msgid "Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-Intensity-Saturation) color space."
+msgstr "Transformiert Rasterkarten aus dem RGB (Rot-Grün-Blau) Farbraum in den HIS (Hue-Intensity-Saturation) Farbraum."
 #: ../imagery/i.rgb.his/r2hmain.c:53
 msgid "Name of input raster map (red)"
@@ -10653,7 +9871,7 @@
 #: ../imagery/i.rgb.his/openfiles.c:41 ../imagery/i.his.rgb/openfiles.c:23
 #: ../imagery/i.his.rgb/openfiles.c:25 ../imagery/i.his.rgb/openfiles.c:27
 msgid "Unable to allocate the input row buffer"
-msgstr "Kann keinen Speicher für Eingabe-Zeilenbuffer reservieren."
+msgstr "Kann keinen Speicher für Eingabe-Zeilenpuffer reservieren."
 #: ../imagery/i.gensig/means.c:24
 msgid "Calculating class means..."
@@ -10753,9 +9971,7 @@
 #: ../imagery/i.fft/fftmain.c:115
 msgid "Raster MASK found, consider to remove (see man-page). Will continue..."
-msgstr ""
-"Raster Maske (MASK) gefunden, denken Sie über das Löschen nach (siehe MAN "
-"Seiten). Fahre trotzdem fort..."
+msgstr "Raster Maske (MASK) gefunden, denken Sie über das Löschen nach (siehe MAN Seiten). Fahre trotzdem fort..."
 #: ../imagery/i.fft/fftmain.c:120
 msgid "Range less than or equal to zero not allowed"
@@ -10934,20 +10150,12 @@
 msgstr "Bildverarbeitung, Klassifikation, Signaturen"
 #: ../imagery/i.cluster/main.c:82
-msgid ""
-"Generates spectral signatures for land cover types in an image using a "
-"clustering algorithm."
-msgstr ""
-"Erzeugt spektrale Signaturen für Landbedeckungsklassen eines Bildes mittels "
-"eines Clusteralgorithmus."
+msgid "Generates spectral signatures for land cover types in an image using a clustering algorithm."
+msgstr "Erzeugt spektrale Signaturen für Landbedeckungsklassen eines Bildes mittels eines Clusteralgorithmus."
 #: ../imagery/i.cluster/main.c:85
-msgid ""
-"The resulting signature file is used as input for i.maxlik, to generate an "
-"unsupervised image classification."
-msgstr ""
-"Die resultierende Signaturdatei wird als Eingabe für i.maxlik verwendet, um "
-"eine unüberwachte Bildklassifikation zu erzeugen."
+msgid "The resulting signature file is used as input for i.maxlik, to generate an unsupervised image classification."
+msgstr "Die resultierende Signaturdatei wird als Eingabe für i.maxlik verwendet, um eine unüberwachte Bildklassifikation zu erzeugen."
 #: ../imagery/i.cluster/main.c:105
 msgid "Initial number of classes"
@@ -11148,9 +10356,7 @@
 #: ../imagery/i.cluster/main.c:298
 msgid "Out of Memory. Please run again and choose a smaller sample size."
-msgstr ""
-"Speicher voll! Bitte wiederholen Sie den Lauf mit einer kleineren "
-"Stichprobengröße."
+msgstr "Speicher voll! Bitte wiederholen Sie den Lauf mit einer kleineren Stichprobengröße."
 #: ../imagery/i.cluster/main.c:304
 #, c-format
@@ -11158,18 +10364,12 @@
 msgstr "Stichprobengröße: %d Punkte\n"
 #: ../imagery/i.cluster/main.c:307
-msgid ""
-"Not enough sample points. Please run again and choose a larger sample size."
-msgstr ""
-"Nicht genügend Stichprobenpunkte. Bitte wiederholen Sie den Lauf mit einer "
-"größeren Stichprobe."
+msgid "Not enough sample points. Please run again and choose a larger sample size."
+msgstr "Nicht genügend Stichprobenpunkte. Bitte wiederholen Sie den Lauf mit einer größeren Stichprobe."
 #: ../imagery/i.cluster/main.c:311
-msgid ""
-"Not enough non-zero sample data points. Check your current region (and mask)."
-msgstr ""
-"Nicht genug nicht-null Stichprobenpunkte. Bitte überprüfen Sie die aktuelle "
-"Region (und Maske)."
+msgid "Not enough non-zero sample data points. Check your current region (and mask)."
+msgstr "Nicht genug nicht-null Stichprobenpunkte. Bitte überprüfen Sie die aktuelle Region (und Maske)."
 #: ../imagery/i.cluster/main.c:324
 #, c-format
@@ -11188,9 +10388,7 @@
 #: ../imagery/i.cluster/main.c:336
 #, c-format
 msgid "Unable to create signature file <%s> for group <%s>, subsgroup <%s>"
-msgstr ""
-"Kann die Signaturdatei <%s> für die Gruppe <%s> Untergruppe <%s> nicht "
-"erzeugen."
+msgstr "Kann die Signaturdatei <%s> für die Gruppe <%s> Untergruppe <%s> nicht erzeugen."
 #: ../imagery/i.cluster/main.c:341
 #, c-format
@@ -11223,8 +10421,7 @@
 #: ../imagery/i.modis.qc/main.c:90
 msgid "QC, Quality Control, surface reflectance, Modis"
-msgstr ""
-"QC, Qualitätskontrolle, Oberflächenreflexion, surface reflectance, Modis"
+msgstr "QC, Qualitätskontrolle, Oberflächenreflexion, surface reflectance, Modis"
 #: ../imagery/i.modis.qc/main.c:92
 msgid "Extracts quality control parameters from Modis QC layers."
@@ -11243,76 +10440,24 @@
 msgstr "Name des MODIS Produkttyps"
 #: ../imagery/i.modis.qc/main.c:110
-msgid ""
-"mod09Q1;surf. refl. 250m 8-days;mod09A1;surf. refl. 500m 8-days;mod09A1s;"
-"surf. refl. 500m 8-days, State QA;mod11A1;LST 1Km daily (Day/Night);mod11A2;"
-"LST 1Km 8-days (Day/Night);"
-msgstr ""
+msgid "mod09Q1;surf. refl. 250m 8-days;mod09A1;surf. refl. 500m 8-days;mod09A1s;surf. refl. 500m 8-days, State QA;mod11A1;LST 1Km daily (Day/Night);mod11A2;LST 1Km 8-days (Day/Night);"
+msgstr "mod09Q1;surf. refl. 250m 8-days;mod09A1;surf. refl. 500m 8-days;mod09A1s;surf. refl. 500m 8-days, State QA;mod11A1;LST 1Km daily (Day/Night);mod11A2;LST 1Km 8-days (Day/Night);"
 #: ../imagery/i.modis.qc/main.c:122
 msgid "Name of QC type to extract"
 msgstr "Name des zu extrahierenden QC-Typs"
 #: ../imagery/i.modis.qc/main.c:123
-msgid ""
-"adjcorr;mod09: Adjacency Correction;atcorr;mod09: Atmospheric Correction;"
-"cloud;mod09: Cloud State;data_quality;mod09: Band-Wise Data Quality Flag;"
-"diff_orbit_from_500m;mod09: 250m Band is at Different Orbit than 500m;"
-"modland_qa_bits;mod09: MODIS Land General Quality Assessment;"
-"mandatory_qa_11A1;mod11A1: MODIS Land General Quality Assessment;"
-"data_quality_flag_11A1;mod11A1: Detailed Quality Indications;emis_error_11A1;"
-"mod11A1: Average Emissivity Error Classes;lst_error_11A1;mod11A1: Average "
-"LST Error Classes;data_quality_flag_11A2;mod11A2: Detailed Quality "
-"Indications;emis_error_11A2;mod11A2: Average Emissivity Error Classes;"
-"mandatory_qa_11A2;mod11A2: MODIS Land General Quality Assessment;"
-"lst_error_11A2;mod11A2: Average LST Error Classes;aerosol_quantity;mod09A1s: "
-"StateQA Internal Snow Mask;brdf_correction_performed;mod09A1s: StateQA "
-"Internal Snow Mask;cirrus_detected;mod09A1s: StateQA Internal Snow Mask;"
-"cloud_shadow;mod09A1s: StateQA Internal Snow Mask;cloud_state;mod09A1s: "
-"StateQA Internal Snow Mask;internal_clou_algorithm;mod09A1s: StateQA "
-"Internal Snow Mask;internal_fire_algorithm;mod09A1s: StateQA Internal Snow "
-"Mask;internal_snow_mask;mod09A1s: StateQA Internal Snow Mask;land_water;"
-"mod09A1s: StateQA Internal Snow Mask;mod35_snow_ice;mod09A1s: StateQA "
-"Internal Snow Mask;pixel_adjacent_to_cloud;mod09A1s: StateQA Internal Snow "
-"Mask;"
-msgstr ""
-"Mask;"
+msgid "adjcorr;mod09: Adjacency Correction;atcorr;mod09: Atmospheric Correction;cloud;mod09: Cloud State;data_quality;mod09: Band-Wise Data Quality Flag;diff_orbit_from_500m;mod09: 250m Band is at Different Orbit than 500m;modland_qa_bits;mod09: MODIS Land General Quality Assessment;mandatory_qa_11A1;mod11A1: MODIS Land General Quality Assessment;data_quality_flag_11A1;mod11A1: Detailed Quality Indications;emis_error_11A1;mod11A1: Average Emissivity Error Classes;lst_error_11A1;mod11A1: Average LST Error Classes;data_quality_flag_11A2;mod11A2: Detailed Quality Indications;emis_error_11A2;mod11A2: Average Emissivity Error Classes;mandatory_qa_11A2;mod11A2: MODIS Land General Quality Assessment;lst_error_11A2;mod11A2: Average LST Error Classes;aerosol_quantity;mod09A1s: StateQA Internal Snow Mask;brdf_correction_performed;mod09A1s: StateQA Internal Snow Mask;cirrus_detected;mod09A1s: StateQA Internal Snow Mask;cloud_shadow;mod09A1s: StateQA Internal Snow Mask;cloud_state;mod09
 A1s: StateQA Internal Snow Mask;internal_clou_algorithm;mod09A1s: StateQA Internal Snow Mask;internal_fire_algorithm;mod09A1s: StateQA Internal Snow Mask;internal_snow_mask;mod09A1s: StateQA Internal Snow Mask;land_water;mod09A1s: StateQA Internal Snow Mask;mod35_snow_ice;mod09A1s: StateQA Internal Snow Mask;pixel_adjacent_to_cloud;mod09A1s: StateQA Internal Snow Mask;"
+msgstr "adjcorr;mod09: Adjacency Correction;atcorr;mod09: Atmospheric Correction;cloud;mod09: Cloud State;data_quality;mod09: Band-Wise Data Quality Flag;diff_orbit_from_500m;mod09: 250m Band is at Different Orbit than 500m;modland_qa_bits;mod09: MODIS Land General Quality Assessment;mandatory_qa_11A1;mod11A1: MODIS Land General Quality Assessment;data_quality_flag_11A1;mod11A1: Detailed Quality Indications;emis_error_11A1;mod11A1: Average Emissivity Error Classes;lst_error_11A1;mod11A1: Average LST Error Classes;data_quality_flag_11A2;mod11A2: Detailed Quality Indications;emis_error_11A2;mod11A2: Average Emissivity Error Classes;mandatory_qa_11A2;mod11A2: MODIS Land General Quality Assessment;lst_error_11A2;mod11A2: Average LST Error Classes;aerosol_quantity;mod09A1s: StateQA Internal Snow Mask;brdf_correction_performed;mod09A1s: StateQA Internal Snow Mask;cirrus_detected;mod09A1s: StateQA Internal Snow Mask;cloud_shadow;mod09A1s: StateQA Internal Snow Mask;cloud_state;mod0
 9A1s: StateQA Internal Snow Mask;internal_clou_algorithm;mod09A1s: StateQA Internal Snow Mask;internal_fire_algorithm;mod09A1s: StateQA Internal Snow Mask;internal_snow_mask;mod09A1s: StateQA Internal Snow Mask;land_water;mod09A1s: StateQA Internal Snow Mask;mod35_snow_ice;mod09A1s: StateQA Internal Snow Mask;pixel_adjacent_to_cloud;mod09A1s: StateQA Internal Snow Mask;"
 #: ../imagery/i.modis.qc/main.c:157
 msgid "Band number of Modis product (mod09Q1=[1,2],mod09A1=[1-7])"
 msgstr "Kanalnummer des MODIS Produkts (mod09Q1=[1,2],mod09A1=[1-7])"
 #: ../imagery/i.modis.qc/main.c:158
-msgid ""
-"1;mod09Q1/A1 Band 1: Red;2;mod09Q1/A1 Band 2: NIR;3;mod09A1 Band 3: Blue;4;"
-"mod09A1 Band 4: Green;5;mod09A1 Band 5: SWIR 1;6;mod09A1 Band 6: SWIR 2;7;"
-"mod09A1 Band 7: SWIR 3;"
-msgstr ""
+msgid "1;mod09Q1/A1 Band 1: Red;2;mod09Q1/A1 Band 2: NIR;3;mod09A1 Band 3: Blue;4;mod09A1 Band 4: Green;5;mod09A1 Band 5: SWIR 1;6;mod09A1 Band 6: SWIR 2;7;mod09A1 Band 7: SWIR 3;"
+msgstr "1;mod09Q1/A1 Band 1: Red;2;mod09Q1/A1 Band 2: NIR;3;mod09A1 Band 3: Blue;4;mod09A1 Band 4: Green;5;mod09A1 Band 5: SWIR 1;6;mod09A1 Band 6: SWIR 2;7;mod09A1 Band 7: SWIR 3;"
 #: ../imagery/i.modis.qc/main.c:181
 msgid "This flag is only available for MOD09Q1 @ 250m products"
@@ -11358,8 +10503,7 @@
 #: ../imagery/i.ortho.photo/i.photo.rectify/rectify.c:131
 #, c-format
 msgid "Raster map <%s@%s>: projection don't match current settings"
-msgstr ""
-"Rasterkarte <%s@%s>: Projektion passt nicht zu den aktuellen Einstellungen."
+msgstr "Rasterkarte <%s@%s>: Projektion passt nicht zu den aktuellen Einstellungen."
 #: ../imagery/i.rectify/rectify.c:115
 #: ../imagery/i.ortho.photo/i.photo.rectify/rectify.c:137
@@ -11452,9 +10596,7 @@
 #: ../imagery/i.rectify/cp.c:21
 #, c-format
 msgid "Not enough active control points for current order, %d are required."
-msgstr ""
-"Nicht genügend aktive Kontrollpunkte für den momentanen Grad, %d werden "
-"benötigt."
+msgstr "Nicht genügend aktive Kontrollpunkte für den momentanen Grad, %d werden benötigt."
 #: ../imagery/i.rectify/cp.c:25
 msgid "Poorly placed control points."
@@ -11477,12 +10619,8 @@
 msgstr "Bildverarbeitung, Rektifikation"
 #: ../imagery/i.rectify/main.c:92
-msgid ""
-"Rectifies an image by computing a coordinate transformation for each pixel "
-"in the image based on the control points."
-msgstr ""
-"Rektifiziert ein Bild indem eine Koordinatentransformation für jedes Pixel "
-"des Bildes basierend auf den Kontrollpunkten durchgeführt wird."
+msgid "Rectifies an image by computing a coordinate transformation for each pixel in the image based on the control points."
+msgstr "Rektifiziert ein Bild indem eine Koordinatentransformation für jedes Pixel des Bildes basierend auf den Kontrollpunkten durchgeführt wird."
 #: ../imagery/i.rectify/main.c:106
 #: ../imagery/i.ortho.photo/i.photo.rectify/main.c:100
@@ -11511,11 +10649,8 @@
 #: ../imagery/i.rectify/main.c:141
 #: ../imagery/i.ortho.photo/i.photo.rectify/main.c:134
-msgid ""
-"Use current region settings in target location (def.=calculate smallest area)"
-msgstr ""
-"Verwende die Einstellungen der aktuelle Region für die Ziellocation "
-"(Standard: Berechne den kleinsten Bereich)."
+msgid "Use current region settings in target location (def.=calculate smallest area)"
+msgstr "Verwende die Einstellungen der aktuelle Region für die Ziellocation (Standard: Berechne den kleinsten Bereich)."
 #: ../imagery/i.rectify/main.c:145
 #: ../imagery/i.ortho.photo/i.photo.rectify/main.c:138
@@ -11719,16 +10854,12 @@
 #: ../imagery/i.gensigset/subcluster.c:547
 msgid "Unreliable clustering. Try a smaller initial number of clusters"
-msgstr ""
-"Unzuverlässiger Clusterprozess. Versuchen Sie es mit einer kleineren Anzahl "
-"von Anfangsclustern."
+msgstr "Unzuverlässiger Clusterprozess. Versuchen Sie es mit einer kleineren Anzahl von Anfangsclustern."
 #: ../imagery/i.gensigset/subcluster.c:556
 #, c-format
 msgid "Removed a singular subsignature number %d (%d remain)"
-msgstr ""
-"Habe eine singuläre Unter-Signatur mit der Nummer %d entfernt (%d "
-"verbleiben)."
+msgstr "Habe eine singuläre Unter-Signatur mit der Nummer %d entfernt (%d verbleiben)."
 #: ../imagery/i.points/main.c:96 ../imagery/i.vpoints/main.c:94
 msgid "imagery, geometry"
@@ -11768,20 +10899,12 @@
 msgstr "WARNUNG: %s (klicken Sie mit der Maus zum fortfahren)."
 #: ../imagery/i.vpoints/main.c:96
-msgid ""
-"Set registration points for an imagery group from a vector map or keyboard "
-"entry."
-msgstr ""
-"Setze Passpunkte für eine Bildgruppe basierend auf einer Vektorkarte oder "
-"durch Koordinateneingaben über die Tastatur."
+msgid "Set registration points for an imagery group from a vector map or keyboard entry."
+msgstr "Setze Passpunkte für eine Bildgruppe basierend auf einer Vektorkarte oder durch Koordinateneingaben über die Tastatur."
 #: ../imagery/i.his.rgb/h2rmain.c:47
-msgid ""
-"Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
-"RGB (Red-Green-Blue) color space."
-msgstr ""
-"Transformiert Rasterkarten aus dem HIS (Hue-Intensity-Saturation) Farbraum "
-"in den RGB (Rot-Grün-Blau) Farbraum."
+msgid "Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to RGB (Red-Green-Blue) color space."
+msgstr "Transformiert Rasterkarten aus dem HIS (Hue-Intensity-Saturation) Farbraum in den RGB (Rot-Grün-Blau) Farbraum."
 #: ../imagery/i.his.rgb/h2rmain.c:53
 msgid "Name of input raster map (hue)"
@@ -11810,8 +10933,7 @@
 #: ../imagery/i.class/add_point.c:22
 #, c-format
 msgid "Can't mark another point.  Only %d points allowed.  Sorry."
-msgstr ""
-"Kann keinen anderen Punkt markieren. Nur %d Punkte sind erlaubt. Sorry."
+msgstr "Kann keinen anderen Punkt markieren. Nur %d Punkte sind erlaubt. Sorry."
 #: ../imagery/i.class/redisplay.c:56
 msgid "No zoom window is defined."
@@ -11898,8 +11020,7 @@
 #: ../imagery/i.class/signature.c:278
 msgid "Unable to allocate the cell buffer in display_signature()."
-msgstr ""
-"Kann keinen Speicher für Zellbuffer in display_signature() reservieren."
+msgstr "Kann keinen Speicher für Zellpuffer in display_signature() reservieren."
 #: ../imagery/i.class/signature.c:310
 msgid "Did not find input cell map MASK."
@@ -11918,20 +11039,12 @@
 msgstr "Bildverarbeitung, Klassifikation"
 #: ../imagery/i.class/main.c:55
-msgid ""
-"Generates spectral signatures for an image by allowing the user to outline "
-"regions of interest."
-msgstr ""
-"Erzeugt spektrale Signaturen für ein Bild, in dem es dem Benutzer erlaubt "
-"Trainingsgebiete zu markieren."
+msgid "Generates spectral signatures for an image by allowing the user to outline regions of interest."
+msgstr "Erzeugt spektrale Signaturen für ein Bild, in dem es dem Benutzer erlaubt Trainingsgebiete zu markieren."
 #: ../imagery/i.class/main.c:58
-msgid ""
-"The resulting signature file can be used as input for i.maxlik or as a seed "
-"signature file for i.cluster."
-msgstr ""
-"Die resultierende Signatur-Datei kann als Eingabe für i.maxlik oder als "
-"Start-Signatur für i.cluster verwendet werden."
+msgid "The resulting signature file can be used as input for i.maxlik or as a seed signature file for i.cluster."
+msgstr "Die resultierende Signatur-Datei kann als Eingabe für i.maxlik oder als Start-Signatur für i.cluster verwendet werden."
 #: ../imagery/i.class/main.c:77
 msgid "File to contain result signatures"
@@ -11943,15 +11056,12 @@
 #: ../imagery/i.class/main.c:94
 msgid "You have a mask set. Unset mask and run again"
-msgstr ""
-"Es ist eine Maske gesetzt. Beseitigen Sie die Maske und versuchen Sie es "
-"erneut"
+msgstr "Es ist eine Maske gesetzt. Beseitigen Sie die Maske und versuchen Sie es erneut"
 #: ../imagery/i.class/main.c:213
 #, c-format
 msgid "** The following raster maps in subgroup [%s] do not exist:"
-msgstr ""
-"** Die folgenden Rasterkarten in der Untergruppe [%s] existieren nicht:"
+msgstr "** Die folgenden Rasterkarten in der Untergruppe [%s] existieren nicht:"
 #: ../imagery/i.class/main.c:222
 #, c-format
@@ -12045,20 +11155,12 @@
 msgstr "Name der Eingabe-Rasterkarte (fft Bild, imaginärer Teil)."
 #: ../imagery/i.ifft/ifftmain.c:101
-msgid ""
-"Unable to open real-image in the 'cell_misc' directory. Raster map probably "
-"wasn't created by i.fft"
-msgstr ""
-"Kann das Realteil-Bild im 'cell_misc' Ordner nicht öffnen. Rasterkarte wurde "
-"wahrscheinlich nicht mit i.fft erstellt."
+msgid "Unable to open real-image in the 'cell_misc' directory. Raster map probably wasn't created by i.fft"
+msgstr "Kann das Realteil-Bild im 'cell_misc' Ordner nicht öffnen. Rasterkarte wurde wahrscheinlich nicht mit i.fft erstellt."
 #: ../imagery/i.ifft/ifftmain.c:111
-msgid ""
-"Unable to open imaginary-image in the 'cell_misc' directory. Raster map "
-"probably wasn't created by i.fft"
-msgstr ""
-"Kann das Bild mit dem imaginären Teil im 'cell_misc' Ordner nicht öffnen. "
-"Eingabekarte wurde wahrscheinlich nicht mit i.fft erstellt."
+msgid "Unable to open imaginary-image in the 'cell_misc' directory. Raster map probably wasn't created by i.fft"
+msgstr "Kann das Bild mit dem imaginären Teil im 'cell_misc' Ordner nicht öffnen. Eingabekarte wurde wahrscheinlich nicht mit i.fft erstellt."
 #: ../imagery/i.ifft/ifftmain.c:129
 #, c-format
@@ -12178,12 +11280,8 @@
 msgstr "Bildverarbeitung, Orthorektifikation"
 #: ../imagery/i.ortho.photo/i.photo.rectify/main.c:88
-msgid ""
-"Orthorectifies an image by using the image to photo coordinate "
-"transformation matrix."
-msgstr ""
-"Orthorektifiziert ein Bild mittels der Foto zu Koordinaten "
-"Transformationsmatrix."
+msgid "Orthorectifies an image by using the image to photo coordinate transformation matrix."
+msgstr "Orthorektifiziert ein Bild mittels der Foto zu Koordinaten Transformationsmatrix."
 #: ../imagery/i.ortho.photo/i.photo.rectify/main.c:129
 msgid "Raster map with camera angle relative to ground surface"
@@ -12221,21 +11319,15 @@
 #: ../imagery/i.ortho.photo/i.photo.2target/main.c:54
 msgid "Creates control points on an image to be ortho-rectified."
-msgstr ""
-"Erzeuge Kontrollpunkte in einem Bild, welches orthorektifiziert werden soll."
+msgstr "Erzeuge Kontrollpunkte in einem Bild, welches orthorektifiziert werden soll."
 #: ../imagery/i.ortho.photo/i.photo.2target/main.c:66
 msgid "Name of image to be rectified which will be initially drawn on screen"
-msgstr ""
-"Name der Karte, die rektifiziert werden soll, diese wird anfänglich auf dem "
-"Bildschirm dargestellt."
+msgstr "Name der Karte, die rektifiziert werden soll, diese wird anfänglich auf dem Bildschirm dargestellt."
 #: ../imagery/i.ortho.photo/i.photo.2target/main.c:72
-msgid ""
-"Name of a map from target mapset which will be initially drawn on screen"
-msgstr ""
-"Name einer Karte im Zielmapset, welche anfänglich auf dem Bildschirm "
-"dargestellt wird."
+msgid "Name of a map from target mapset which will be initially drawn on screen"
+msgstr "Name einer Karte im Zielmapset, welche anfänglich auf dem Bildschirm dargestellt wird."
 #: ../imagery/i.ortho.photo/i.photo.2target/main.c:102
 #: ../imagery/i.ortho.photo/i.photo.init/main.c:64
@@ -12476,16 +11568,11 @@
 msgstr "Bitte wählen Sie ein Ziel für die Gruppe"
 #: ../imagery/i.ortho.photo/i.photo.init/main.c:46
-msgid ""
-"Interactively creates or modifies entries in a camera initial exposure "
-"station file for imagery group referenced by a sub-block."
-msgstr ""
-"Erzeugt oder ändert interaktiv Einträge in der Datei mit der Anfangsposition "
-"der Kamera für die Bildgruppe referenziert durch Unterblöcke."
+msgid "Interactively creates or modifies entries in a camera initial exposure station file for imagery group referenced by a sub-block."
+msgstr "Erzeugt oder ändert interaktiv Einträge in der Datei mit der Anfangsposition der Kamera für die Bildgruppe referenziert durch Unterblöcke."
 #: ../imagery/i.ortho.photo/i.photo.camera/main.c:57
-msgid ""
-"Interactively select and modify the imagery group camera reference file."
+msgid "Interactively select and modify the imagery group camera reference file."
 msgstr "Wähle und ändere die Kamerareferenzdatei der Bildgruppe interaktiv."
 #: ../imagery/i.ortho.photo/i.photo.camera/main.c:68
@@ -12494,16 +11581,12 @@
 #: ../imagery/i.ortho.photo/i.photo.camera/main.c:84
 msgid "Enter a camera reference file to be used with this imagery group"
-msgstr ""
-"Geben Sie eine Kamerareferenzdatei ein, die mit dieser Bildgruppe verwendet "
-"werden soll."
+msgstr "Geben Sie eine Kamerareferenzdatei ein, die mit dieser Bildgruppe verwendet werden soll."
 #: ../imagery/i.ortho.photo/i.photo.camera/main.c:101
 #, c-format
 msgid "Group [%s] in location [%s] mapset [%s] now has camera file [%s]"
-msgstr ""
-"Die Gruppe [%s] in der Location [%s] Mapset [%s] hat jetzt die Kameradatei "
-"[%s]."
+msgstr "Die Gruppe [%s] in der Location [%s] Mapset [%s] hat jetzt die Kameradatei [%s]."
 #: ../imagery/i.ortho.photo/i.photo.target/main.c:48
 msgid "Interactively select or modify the imagery group target."
@@ -12599,45 +11682,23 @@
 #: ../raster/r.out.gdal/export_band.c:187
 #, c-format
-msgid ""
-"Input raster map contains cells with NULL-value (no-data). The value %d will "
-"be used to represent no-data values in the input map. You can specify a "
-"nodata value with the %s option."
-msgstr ""
-"Die Eingabe-Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der Wert "
-"%d wurde verwendet um NoData-Werte in der Eingabekarte zu kennzeichnen. Sie "
-"können NoData-Wert mit dem Parameter %s bestimmen."
+msgid "Input raster map contains cells with NULL-value (no-data). The value %d will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
+msgstr "Die Eingabe-Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der Wert %d wurde verwendet um NoData-Werte in der Eingabekarte zu kennzeichnen. Sie können NoData-Wert mit dem Parameter %s bestimmen."
 #: ../raster/r.out.gdal/export_band.c:192
-#, fuzzy, c-format
-msgid ""
-"Input raster map contains cells with NULL-value (no-data). The value %g will "
-msgstr ""
+#, c-format
+msgid "Input raster map contains cells with NULL-value (no-data). The value %g will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
+msgstr "Die Eingabe-Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der Wert %g wird verwendet, um NoData-Werte in der Eingabekarte zu kennzeichnen. Sie können NoData-Wert mit dem Parameter %s bestimmen."
 #: ../raster/r.out.gdal/export_band.c:202
 #, c-format
-msgid ""
-"The default nodata value is present in rasterband <%s> and would lead to "
-"data loss. Please specify a custom nodata value with the %s parameter."
-msgstr ""
-"Der Standard-NoData-Wert ist im Rasterkanal <%s> vorhanden und würde zu "
-"Datenverlust führen. Bitte geben Sie einen eignen NoData-Wert mit dem "
-"Parameter %s an."
+msgid "The default nodata value is present in rasterband <%s> and would lead to data loss. Please specify a custom nodata value with the %s parameter."
+msgstr "Der Standard-NoData-Wert ist im Rasterkanal <%s> vorhanden und würde zu Datenverlust führen. Bitte geben Sie einen eignen NoData-Wert mit dem Parameter %s an."
 #: ../raster/r.out.gdal/export_band.c:209
 #, c-format
-msgid ""
-"The user given nodata value %g is present in rasterband <%s> and would lead "
-"to data loss. Please specify a different nodata value with the %s parameter."
-msgstr ""
-"Der gewählte NoData-Wert %g ist im Rasterkanal <%s> vorhanden und würde zu "
-"Datenverlust führen. Bitte geben Sie einen anderen NoData-Wert mit dem "
-"Parameter %s an."
+msgid "The user given nodata value %g is present in rasterband <%s> and would lead to data loss. Please specify a different nodata value with the %s parameter."
+msgstr "Der gewählte NoData-Wert %g ist im Rasterkanal <%s> vorhanden und würde zu Datenverlust führen. Bitte geben Sie einen anderen NoData-Wert mit dem Parameter %s an."
 #: ../raster/r.out.gdal/export_band.c:257
 msgid "Unable to get raster band"
@@ -12736,12 +11797,8 @@
 msgstr "Metadaten Schlüsselwort(e) und Wert(e), die eingefügt werden sollen."
 #: ../raster/r.out.gdal/main.c:201
-msgid ""
-"In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. "
-"Not supported by all output format drivers."
-msgstr ""
-"Im Format  \"META-TAG=WERT\". Trennen Sie mehrere Einträge durch Kommas. "
-"Wird nicht von allen Treibern unterstützt."
+msgid "In the form of \"META-TAG=VALUE\", separate multiple entries with a comma. Not supported by all output format drivers."
+msgstr "Im Format  \"META-TAG=WERT\". Trennen Sie mehrere Einträge durch Kommas. Wird nicht von allen Treibern unterstützt."
 #: ../raster/r.out.gdal/main.c:210
 msgid "Assign a specified nodata value to output bands"
@@ -12772,12 +11829,8 @@
 #: ../raster/r.out.gdal/main.c:267
 #, c-format
-msgid ""
-"Driver <%s> does not support direct writing. Using MEM driver for "
-"intermediate dataset."
-msgstr ""
-"Der Treiber <%s> unterstützt direktes Schreiben nicht. Verwende den MEM-"
-"Treiber für einen Zwischendatensatz."
+msgid "Driver <%s> does not support direct writing. Using MEM driver for intermediate dataset."
+msgstr "Der Treiber <%s> unterstützt direktes Schreiben nicht. Verwende den MEM-Treiber für einen Zwischendatensatz."
 #: ../raster/r.out.gdal/main.c:272
 msgid "Unable to get in-memory raster driver"
@@ -12800,36 +11853,22 @@
 #: ../raster/r.out.gdal/main.c:424
 msgid "Raster export would result in complete data loss, aborting."
-msgstr ""
-"Rasterexport würde kompletten Datenverlust bedeuten, breche die Aktion ab."
+msgstr "Rasterexport würde kompletten Datenverlust bedeuten, breche die Aktion ab."
 #: ../raster/r.out.gdal/main.c:435
 #, c-format
-msgid ""
-"Precision loss: Raster map <%s> of type %s to be exported as %s. This can be "
-"avoided by using %s."
-msgstr ""
-"Präzisionsverlust: Rasterkarte <%s> vom Typ %s soll als %s exportiert "
-"werden. Dies kann verhindert werden mit %s."
+msgid "Precision loss: Raster map <%s> of type %s to be exported as %s. This can be avoided by using %s."
+msgstr "Präzisionsverlust: Rasterkarte <%s> vom Typ %s soll als %s exportiert werden. Dies kann verhindert werden mit %s."
 #: ../raster/r.out.gdal/main.c:446
 #, c-format
-msgid ""
-"Precision loss: The range of <%s> can not be accurately preserved with GDAL "
-"datatype Float32. This can be avoided by exporting to Int32 or Float64."
-msgstr ""
-"Präzisionsverlust: Der Wertebereich von <%s> kann nicht korrekt erhalten "
-"werden mit dem GDAL Datentyp Float32. Dies kann verhindert werden durch "
-"Export nach Int32 oder Float64."
+msgid "Precision loss: The range of <%s> can not be accurately preserved with GDAL datatype Float32. This can be avoided by exporting to Int32 or Float64."
+msgstr "Präzisionsverlust: Der Wertebereich von <%s> kann nicht korrekt erhalten werden mit dem GDAL Datentyp Float32. Dies kann verhindert werden durch Export nach Int32 oder Float64."
 #: ../raster/r.out.gdal/main.c:454
 #, c-format
-msgid ""
-"Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. "
-"This can be avoided by using Float64"
-msgstr ""
-"Präzisionsverlust: Float32 kann die Präzision der DCELL Rasterkarte <%s> "
-"nicht erhalten. Dies kann verhindert werden mit Float64."
+msgid "Precision loss: Float32 can not preserve the DCELL precision of raster <%s>. This can be avoided by using Float64"
+msgstr "Präzisionsverlust: Float32 kann die Präzision der DCELL Rasterkarte <%s> nicht erhalten. Dies kann verhindert werden mit Float64."
 #: ../raster/r.out.gdal/main.c:482 ../raster/r.out.gdal/main.c:511
 #: ../raster/r.out.gdal/main.c:515
@@ -12905,14 +11944,8 @@
 #: ../raster/r.out.gdal/main.c:749 ../raster/r.out.gdal/main.c:762
 #: ../raster/r.out.gdal/main.c:777
 #, c-format
-msgid ""
-"Mismatch between metadata nodata value and actual nodata value in exported "
-"raster: specified nodata value %f gets converted to %d by selected GDAL "
-"datatype."
-msgstr ""
-"NoData-Wert der Metadaten und der tatsächlichen Werte in den exportierten "
-"Rasterdaten stimmen nicht überein: Der angegebene NoData-Wert %f wird von "
-"dem gewählten GDAL-Datentyp nach %d konvertiert."
+msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %f gets converted to %d by selected GDAL datatype."
+msgstr "NoData-Wert der Metadaten und der tatsächlichen Werte in den exportierten Rasterdaten stimmen nicht überein: Der angegebene NoData-Wert %f wird von dem gewählten GDAL-Datentyp nach %d konvertiert."
 #: ../raster/r.out.gdal/main.c:725 ../raster/r.out.gdal/main.c:752
 #: ../raster/r.out.gdal/main.c:780
@@ -12927,14 +11960,8 @@
 #: ../raster/r.out.gdal/main.c:791
 #, c-format
-msgid ""
-"raster: specified nodata value %g gets converted to %g by selected GDAL "
-"datatype."
-msgstr ""
-"Rasterdaten stimmen nicht überein: Der angegebene NoData-Wert %g wird von "
-"dem gewählten GDAL-Datentyp nach %g konvertiert."
+msgid "Mismatch between metadata nodata value and actual nodata value in exported raster: specified nodata value %g gets converted to %g by selected GDAL datatype."
+msgstr "NoData-Wert der Metadaten und der tatsächlichen Werte in den exportierten Rasterdaten stimmen nicht überein: Der angegebene NoData-Wert %g wird von dem gewählten GDAL-Datentyp nach %g konvertiert."
 #: ../raster/r.out.gdal/main.c:794
 #, c-format
@@ -12971,8 +11998,7 @@
 #: ../raster/r.los/main.c:150
 msgid "Lat/Long support is not (yet) implemented for this module."
-msgstr ""
-"Lat/Long-Unterstützung ist für dieses Modul (noch) nicht implementiert."
+msgstr "Lat/Long-Unterstützung ist für dieses Modul (noch) nicht implementiert."
 #: ../raster/r.los/main.c:155
 msgid "Specified observer coordinate is outside current region bounds."
@@ -12989,11 +12015,8 @@
 msgstr "Musterkarte sollte eine binäre 0/1 Rasterkarte sein."
 #: ../raster/r.los/main.c:241
-msgid ""
-"Problem to obtain current ellipsoid parameters, using sphere (6370997.0)"
-msgstr ""
-"Habe ein Problem die Parameter des aktuellen Ellipsoids zu ermitteln, "
-"verwende Kugel (6370997.0)."
+msgid "Problem to obtain current ellipsoid parameters, using sphere (6370997.0)"
+msgstr "Habe ein Problem die Parameter des aktuellen Ellipsoids zu ermitteln, verwende Kugel (6370997.0)."
 #: ../raster/r.los/main.c:246
 #, c-format
@@ -13032,13 +12055,8 @@
 msgstr "Raster, Geometrie"
 #: ../raster/r.patch/main.c:55
-msgid ""
-"Creates a composite raster map layer by using known category values from one "
-"(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
-msgstr ""
-"Erstellt eine Komposit-Karte, indem bekannte Kategorie-Werte einer (oder "
-"mehrerer) Rasterkarte(n) in \"NO DATA\"-Bereiche einer anderen Rasterkarte "
-"gefüllt werden."
+msgid "Creates a composite raster map layer by using known category values from one (or more) map layer(s) to fill in areas of \"no data\" in another map layer."
+msgstr "Erstellt eine Komposit-Karte, indem bekannte Kategorie-Werte einer (oder mehrerer) Rasterkarte(n) in \"NO DATA\"-Bereiche einer anderen Rasterkarte gefüllt werden."
 #: ../raster/r.patch/main.c:62
 msgid "Name of raster maps to be patched together"
@@ -13064,12 +12082,8 @@
 #: ../raster/r.rescale/main.c:103 ../raster/r.covar/main.c:75
 #: ../raster/r.carve/main.c:127 ../vector/v.qcount/main.c:117
 #: ../vector/v.mkgrid/main.c:141
-msgid ""
-"The '-q' flag is superseded and will be removed in future. Please use '--"
-"quiet' instead."
-msgstr ""
-"Der Schalter '-q' wurde ersetzt und wird in einer der kommenden Versionen "
-"ersatzlos gestrichen. Bitte verwenden Sie stattdessen '--quiet'."
+msgid "The '-q' flag is superseded and will be removed in future. Please use '--quiet' instead."
+msgstr "Der Schalter '-q' wurde ersetzt und wird in einer der kommenden Versionen ersatzlos gestrichen. Bitte verwenden Sie stattdessen '--quiet'."
 #: ../raster/r.patch/main.c:102
 msgid "The minimum number of input raster maps is two"
@@ -13238,7 +12252,6 @@
 msgstr "Raster, Konvertieren, Vektorisieren"
 #: ../raster/r.to.vect/main.c:52
-#, fuzzy
 msgid "Converts a raster map into a vector map."
 msgstr "Konvertiert eine Rasterkarte in eine Vektorkarte."
@@ -13248,9 +12261,7 @@
 #: ../raster/r.to.vect/main.c:74
 msgid "Use raster values as categories instead of unique sequence (CELL only)"
-msgstr ""
-"Benutze Rasterzellenwerte als Kategoriewerte anstelle von eindeutigen "
-"Sequenzen (nur bei CELL-Karten)."
+msgstr "Benutze Rasterzellenwerte als Kategoriewerte anstelle von eindeutigen Sequenzen (nur bei CELL-Karten)."
 #: ../raster/r.to.vect/main.c:75 ../raster/r.to.vect/main.c:82
 #: ../vector/v.to.rast/main.c:72 ../vector/v.to.rast/main.c:78
@@ -13263,18 +12274,12 @@
 msgstr "Attribute"
 #: ../raster/r.to.vect/main.c:80
-msgid ""
-"Write raster values as z coordinate. Table is not created. Currently "
-"supported only for points."
-msgstr ""
-"Schreibe Rasterwerte als Z-Koordinate. Attributtabelle wird nicht erzeugt. "
-"Derzeit werden nur Punkte unterstützt."
+msgid "Write raster values as z coordinate. Table is not created. Currently supported only for points."
+msgstr "Schreibe Rasterwerte als Z-Koordinate. Attributtabelle wird nicht erzeugt. Derzeit werden nur Punkte unterstützt."
 #: ../raster/r.to.vect/main.c:87
 msgid "Do not build vector topology (use with care for massive point export)"
-msgstr ""
-"Erzeuge keine Vektor-Topologie (Vorsichtig einsetzen für den Export von "
-"extrem großen Punktmengen)."
+msgstr "Erzeuge keine Vektor-Topologie (Vorsichtig einsetzen für den Export von extrem großen Punktmengen)."
 #: ../raster/r.to.vect/main.c:92
 msgid "Quiet - Do not show progress"
@@ -13285,12 +12290,8 @@
 msgstr "Der Schalter '-z' wird nur für Punkte unterstützt."
 #: ../raster/r.to.vect/main.c:124
-msgid ""
-"Raster is not CELL, '-v' flag ignored, raster values will be written to the "
-"table."
-msgstr ""
-"Die Rasterkarte hat nicht den Typ integer (CELL) daher wird der Schalter '-"
-"v' ignoriert. Rasterwerte werden in die Tabelle geschrieben."
+msgid "Raster is not CELL, '-v' flag ignored, raster values will be written to the table."
+msgstr "Die Rasterkarte hat nicht den Typ integer (CELL) daher wird der Schalter '-v' ignoriert. Rasterwerte werden in die Tabelle geschrieben."
 #: ../raster/r.to.vect/main.c:195 ../vector/v.in.ascii/in.c:386
 #: ../vector/v.random/main.c:193 ../vector/v.lrs/v.lrs.create/main.c:326
@@ -13341,8 +12342,7 @@
 #: ../raster/r.proj/main.c:132 ../raster/r.proj.seg/main.c:141
 msgid "Re-projects a raster map from one location to the current location."
-msgstr ""
-"Reprojiziert eine Rasterkarte von einer Location in die aktuelle Location."
+msgstr "Reprojiziert eine Rasterkarte von einer Location in die aktuelle Location."
 #: ../raster/r.proj/main.c:135 ../raster/r.proj.seg/main.c:144
 msgid "Name of input raster map to re-project"
@@ -13407,8 +12407,7 @@
 #: ../raster/r.proj/main.c:228 ../raster/r.proj.seg/main.c:263
 msgid "Unable to get projection info of output raster map"
-msgstr ""
-"Kann die Projektionsinformation der Ausgabe-Rasterkarte nicht ermitteln."
+msgstr "Kann die Projektionsinformation der Ausgabe-Rasterkarte nicht ermitteln."
 #: ../raster/r.proj/main.c:231 ../raster/r.proj.seg/main.c:266
 msgid "Unable to get projection units of output raster map"
@@ -13416,8 +12415,7 @@
 #: ../raster/r.proj/main.c:234 ../raster/r.proj.seg/main.c:269
 msgid "Unable to get projection key values of output raster map"
-msgstr ""
-"Kann die Kennzahlen der Projektion der Ausgabe-Rasterkarte nicht ermitteln."
+msgstr "Kann die Kennzahlen der Projektion der Ausgabe-Rasterkarte nicht ermitteln."
 #: ../raster/r.proj/main.c:243 ../raster/r.proj.seg/main.c:278
 #, c-format
@@ -13516,12 +12514,8 @@
 msgstr "Lese 'r.stats'-Ausgabe."
 #: ../raster/r.mode/main.c:52
-msgid ""
-"Finds the mode of values in a cover map within areas assigned the same "
-"category value in a user-specified base map."
-msgstr ""
-"Findet den Modalwert der Werte einer Bedeckungskarte innerhalb der Flächen "
-"mit gleichen Werten in einer benutzerdefinierten Basiskarte."
+msgid "Finds the mode of values in a cover map within areas assigned the same category value in a user-specified base map."
+msgstr "Findet den Modalwert der Werte einer Bedeckungskarte innerhalb der Flächen mit gleichen Werten in einer benutzerdefinierten Basiskarte."
 #: ../raster/r.mode/main.c:58
 msgid "Base map to be reclassified"
@@ -13556,11 +12550,8 @@
 msgstr "%s: Nicht in der Lage Kategorie-Typen zu lesen."
 #: ../raster/r.li/r.li.edgedensity/edgedensity.c:43
-msgid ""
-"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
-msgstr ""
-"Berechnet Kanten-Dichte-Index einer Rasterkarte, unter Verwendung eines 4-"
-"Nachbarn-Algorithmus."
+msgid "Calculates edge density index on a raster map, using a 4 neighbour algorithm"
+msgstr "Berechnet Kanten-Dichte-Index einer Rasterkarte, unter Verwendung eines 4-Nachbarn-Algorithmus."
 #: ../raster/r.li/r.li.edgedensity/edgedensity.c:44
 #: ../raster/r.li/r.li.padrange/padrange.c:52
@@ -13592,13 +12583,11 @@
 #: ../raster/r.li/r.li.edgedensity/edgedensity.c:62
 msgid "The value of the patch type"
-msgstr ""
+msgstr "Der Wert des Patch-Typs"
 #: ../raster/r.li/r.li.edgedensity/edgedensity.c:63
-msgid ""
-"It can be integer, double or float; it will be changed in function of map "
-"type"
-msgstr ""
+msgid "It can be integer, double or float; it will be changed in function of map type"
+msgstr "Es kann Integer, Double oder Float sein. Es wird in Funktion des Kartentyps geändert."
 #: ../raster/r.li/r.li.simpson/simpson.c:44
 msgid "Calculates Simpson's diversity index on a raster map"
@@ -13650,26 +12639,22 @@
 msgstr "Kann Setup Datei nicht lesen."
 #: ../raster/r.li/r.li.daemon/daemon.c:218
-#, fuzzy
 msgid "Unable to parse configuration file (sampling frame)"
-msgstr "Kann die Konfigurationsdatei nicht interpretieren."
+msgstr "Kann die Konfigurationsdatei nicht interpretieren (Stichprobenrahmen)"
 #: ../raster/r.li/r.li.daemon/daemon.c:481
-#, fuzzy
 msgid "Irregular MASKEDOVERLAY areas definition"
-msgstr "Unregelmäßige maskedoverlay Flächen Definition."
+msgstr "Unregelmäßige MASKEDOVERLAY Flächen Definition."
 #: ../raster/r.li/r.li.daemon/daemon.c:492
-#, fuzzy
 msgid "Unable to parse configuration file (sample area)"
+msgstr "Kann die Konfigurationsdatei nicht interpretieren (Stichprobenfläche)."
 #: ../raster/r.li/r.li.daemon/daemon.c:527
 msgid "Too many units to place"
 msgstr "Zu viele Einheiten zu platzieren."
 #: ../raster/r.li/r.li.daemon/daemon.c:596
-#, fuzzy
 msgid "Too many stratified random sample for raster map"
 msgstr "Zu viele Straten für diese Rasterkarte."
@@ -13682,18 +12667,17 @@
 msgstr "Kann lseek nicht ausführen."
 #: ../raster/r.li/r.li.daemon/worker.c:140
-#, fuzzy, c-format
+#, c-format
 msgid "unable to open <%s> mask ... continuing without!"
-msgstr "CHILD[pid = %i]: kann %s Maske nicht öffnen ... mache ohne weiter !"
+msgstr "Kann Maske <%s> nicht öffnen ... mache ohne weiter !"
 #: ../raster/r.li/r.li.padcv/padcv.c:51
 msgid "Calculates coefficient of variation of patch area on a raster map"
 msgstr "Berechnet Variationskoeffizient der Patch-Größen einer Rasterkarte."
 #: ../raster/r.li/r.li.richness/richness.c:41
-#, fuzzy
 msgid "Calculates richness index on a raster map"
-msgstr "Berechnet den Form-Index einer Rasterkarte."
+msgstr "Berechnet den Richness-Index einer Rasterkarte"
 #: ../raster/r.li/r.li.shannon/shannon.c:44
 msgid "Calculates Shannon's diversity index on a raster map"
@@ -13713,19 +12697,16 @@
 #: ../raster/r.li/r.li.cwed/cwed.c:67
 msgid "Name of file that contains the weight to calculate the index"
-msgstr ""
+msgstr "Name der Datei mit den Gewichten zur Berechnung des Index"
 #: ../raster/r.li/r.li.cwed/cwed.c:303 ../raster/r.li/r.li.cwed/cwed.c:451
 #: ../raster/r.li/r.li.cwed/cwed.c:598
-#, fuzzy
 msgid "Row cache is too small"
-msgstr "Seitenbreite ist zu schmal."
+msgstr "Zeilen-Cache ist zu klein"
 #: ../raster/r.li/r.li.mpa/mpa.c:42
 msgid "Calculates mean pixel attribute index on a raster map"
-msgstr ""
-"Berechnet den Mittelwert der Attribute (Rasterwerte) -Index einer "
-"Rasterkarte."
+msgstr "Berechnet den Mittelwert der Attribute (Rasterwerte) -Index einer Rasterkarte."
 #: ../raster/r.li/r.li.padsd/padsd.c:51
 msgid "Calculates standard deviation of patch area a raster map"
@@ -13736,11 +12717,8 @@
 msgstr "Berechnet Pielou-Diversitäts-Index einer Rasterkarte."
 #: ../raster/r.li/r.li.patchdensity/main.c:49
-msgid ""
-"Calculates patch density index on a raster map, using a 4 neighbour algorithm"
-msgstr ""
-"Berechnet Patch-Dichte-Index einer Rasterkarte, unter Verwendung eines 4-"
+msgid "Calculates patch density index on a raster map, using a 4 neighbour algorithm"
+msgstr "Berechnet Patch-Dichte-Index einer Rasterkarte, unter Verwendung eines 4-Nachbarn-Algorithmus."
 #: ../raster/r.li/r.li.shape/main.c:49
 msgid "Calculates shape index on a raster map"
@@ -13751,19 +12729,12 @@
 msgstr "Berechnet Dominanz-Diversitäts-Index einer Rasterkarte."
 #: ../raster/r.li/r.li.mps/mps.c:50
-msgid ""
-"Calculates mean patch size index on a raster map, using a 4 neighbour "
-"algorithm"
-msgstr ""
-"Berechnet mittleren Patch-Größen-Index einer Rasterkarte, unter Verwendung "
-"eines 4-Nachbarn-Algorithmus."
+msgid "Calculates mean patch size index on a raster map, using a 4 neighbour algorithm"
+msgstr "Berechnet mittleren Patch-Größen-Index einer Rasterkarte, unter Verwendung eines 4-Nachbarn-Algorithmus."
 #: ../raster/r.li/r.li.patchnum/main.c:48
-msgid ""
-"Calculates patch number index on a raster map, using a 4 neighbour algorithm."
-msgstr ""
-"Berechnet Patch-Anzahl-Index einer Rasterkarte, unter Verwendung eines 4-"
+msgid "Calculates patch number index on a raster map, using a 4 neighbour algorithm."
+msgstr "Berechnet Patch-Anzahl-Index einer Rasterkarte, unter Verwendung eines 4-Nachbarn-Algorithmus."
 #: ../raster/simwe/r.sim.water/main.c:118
 msgid "raster, flow, hydrology"
@@ -13771,9 +12742,7 @@
 #: ../raster/simwe/r.sim.water/main.c:120
 msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)."
-msgstr ""
-"Hydrologische Simulation des Oberflächenabfluß mittels der \"path sampling\" "
-"Methode (SIMWE)."
+msgstr "Hydrologische Simulation des Oberflächenabfluß mittels der \"path sampling\" Methode (SIMWE)."
 #: ../raster/simwe/r.sim.water/main.c:125
 #: ../raster/simwe/r.sim.sediment/main.c:118
@@ -13818,8 +12787,7 @@
 #: ../raster/simwe/r.sim.water/main.c:142
 msgid "Name of the rainfall excess rate (rain-infilt) raster map [mm/hr]"
-msgstr ""
-"Name der Rasterkarte der Niederschlagsüberschussrate (rain-infilt) [mm/hr]."
+msgstr "Name der Rasterkarte der Niederschlagsüberschussrate (rain-infilt) [mm/hr]."
 #: ../raster/simwe/r.sim.water/main.c:151
 msgid "Rainfall excess rate unique value [mm/hr]"
@@ -13911,12 +12879,8 @@
 msgstr "Wasserdiffusionskoeffizienten"
 #: ../raster/simwe/r.sim.water/main.c:276
-msgid ""
-"Threshold water depth [m] (diffusion increases after this water depth is "
-"reached)"
-msgstr ""
-"Schwellwert der Wassertiefe [m] (Diffusion steigt, nachdem diese Wassertiefe "
-"erreicht wurde)."
+msgid "Threshold water depth [m] (diffusion increases after this water depth is reached)"
+msgstr "Schwellwert der Wassertiefe [m] (Diffusion steigt, nachdem diese Wassertiefe erreicht wurde)."
 #: ../raster/simwe/r.sim.water/main.c:284
 msgid "Diffusion increase constant"
@@ -13972,28 +12936,22 @@
 msgstr "Kann Rasterkarten nicht schreiben."
 #: ../raster/simwe/simlib/output.c:313 ../raster/simwe/simlib/output.c:321
-#, fuzzy, c-format
+#, c-format
 msgid "FP raster map <%s> not found"
-msgstr "3D-Rasterkarte <%s> nicht gefunden."
+msgstr "FP-Rasterkarte <%s> nicht gefunden."
 #: ../raster/simwe/simlib/input.c:409
 #, c-format
-msgid ""
-"Raster map <%s> not found, and manin_val undefined, choose one to be allowed "
-"to process"
-msgstr ""
-"Rasterkarte <%s> nicht gefunden und manin_val undefiniert. Wählen Sie eine, "
-"welche prozessiert werden dürfen."
+msgid "Raster map <%s> not found, and manin_val undefined, choose one to be allowed to process"
+msgstr "Rasterkarte <%s> nicht gefunden und manin_val undefiniert. Wählen Sie eine, welche prozessiert werden dürfen."
 #: ../raster/simwe/simlib/input.c:541
-#, fuzzy
 msgid "Zero value in Mannings n"
-msgstr "Nullwert in Manning's n."
+msgstr "Nullwert in Mannings n"
 #: ../raster/simwe/simlib/input.c:592
 msgid "Infiltration exceeds the rainfall rate everywhere! No overland flow."
-msgstr ""
-"Die Infiltration übersteigt den Niederschlag überall! Kein Oberflächenabfluß."
+msgstr "Die Infiltration übersteigt den Niederschlag überall! Kein Oberflächenabfluß."
 #: ../raster/simwe/simlib/input.c:616
 #, c-format
@@ -14007,9 +12965,7 @@
 #: ../raster/simwe/simlib/input.c:618
 #, c-format
 msgid "Mean Source Rate (rainf. excess or sediment) \t= %f m/s or kg/m2s \n"
-msgstr ""
-"Mittlere Quellgeschwindigkeit (Regenüberschuss oder Sediment) \t= %f m/s or "
-"kg/m2s \n"
+msgstr "Mittlere Quellgeschwindigkeit (Regenüberschuss oder Sediment) \t= %f m/s or kg/m2s \n"
 #: ../raster/simwe/simlib/input.c:620
 #, c-format
@@ -14017,9 +12973,9 @@
 msgstr "Mittlere Fließgeschwindigkeit \t= %f m/s\n"
 #: ../raster/simwe/simlib/input.c:621
-#, fuzzy, c-format
+#, c-format
 msgid "Mean Mannings \t= %f\n"
-msgstr "Mittlerer Manning's \t= %f\n"
+msgstr "Mittlerer Mannings \t= %f\n"
 #: ../raster/simwe/simlib/input.c:625
 #, c-format
@@ -14054,12 +13010,8 @@
 msgstr "Raster, Sedimenttransport, Erosion, Deposition"
 #: ../raster/simwe/r.sim.sediment/main.c:113
-msgid ""
-"Sediment transport and erosion/deposition simulation using path sampling "
-"method (SIMWE)."
-msgstr ""
-"Sedimenttransport und Erosions/Depositions Simulation unter Verwendung der "
-"\"path sampling\" Methode (SIMWE)."
+msgid "Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)."
+msgstr "Sedimenttransport und Erosions/Depositions Simulation unter Verwendung der \"path sampling\" Methode (SIMWE)."
 #: ../raster/simwe/r.sim.sediment/main.c:123
 msgid "Name of the water depth raster map [m]"
@@ -14083,8 +13035,7 @@
 #: ../raster/simwe/r.sim.sediment/main.c:187
 msgid "Output transp.limited erosion-deposition raster map [kg/m2s]"
-msgstr ""
-"Ausgabe der \"transp.limited\" Erosions-Depositions Rasterkarte [kg/m2s]."
+msgstr "Ausgabe der \"transp.limited\" Erosions-Depositions Rasterkarte [kg/m2s]."
 #: ../raster/simwe/r.sim.sediment/main.c:194
 msgid "Output sediment concentration raster map [particle/m3]"
@@ -14126,9 +13077,7 @@
 msgstr "Raster, Kategorie"
 #: ../raster/r.cats/main.c:53
-msgid ""
-"Manages category values and labels associated with user-specified raster map "
-"layers."
+msgid "Manages category values and labels associated with user-specified raster map layers."
 msgstr "Verwaltet die Kategoriewerte und Label von Rasterkarten."
 #: ../raster/r.cats/main.c:66
@@ -14145,13 +13094,11 @@
 #: ../raster/r.cats/main.c:84
 msgid "File containing category label rules (or \"-\" to read from stdin)"
-msgstr ""
-"Datei mit Kategorie-Beschriftungsregeln (oder \"-\" um von stdin zu lesen)."
+msgstr "Datei mit Kategorie-Beschriftungsregeln (oder \"-\" um von stdin zu lesen)."
 #: ../raster/r.cats/main.c:91
 msgid "Default label or format string for dynamic labeling"
-msgstr ""
-"Standard-Beschriftung oder eine Formatanweisung für dynamische Beschriftung."
+msgstr "Standard-Beschriftung oder eine Formatanweisung für dynamische Beschriftung."
 #: ../raster/r.cats/main.c:93
 msgid "Used when no explicit label exists for the category"
@@ -14187,9 +13134,7 @@
 #: ../raster/r.cats/main.c:268
 msgid "The map is floating point! Ignoring cats list, using vals list"
-msgstr ""
-"Die Karte ist eine Fließkommazahl-Karte. Ignoriere Kategorieliste, nehme "
-"stattdessen Vals-Liste."
+msgstr "Die Karte ist eine Fließkommazahl-Karte. Ignoriere Kategorieliste, nehme stattdessen Vals-Liste."
 #: ../raster/r.cats/main.c:285
 msgid "vals argument is required for floating point map!"
@@ -14204,23 +13149,8 @@
 msgstr "Modell der Sonnen-Strahlungsdichte und -Strahlungssumme."
 #: ../raster/r.sun/main.c:176 ../raster/r.sun2/main.c:230
-msgid ""
-"Computes direct (beam), diffuse and reflected solar irradiation raster maps "
-"for given day, latitude, surface and atmospheric conditions. Solar "
-"parameters (e.g. sunrise, sunset times, declination, extraterrestrial "
-"irradiance, daylight length) are saved in the map history file. "
-"Alternatively, a local time can be specified to compute solar incidence "
-"angle and/or irradiance raster maps. The shadowing effect of the topography "
-"is optionally incorporated."
-msgstr ""
-"Berechnet direkte (beam), diffuse und reflektierte Sonneneinstrahlung für "
-"einen angegebenen Tag, geographische Breite, Oberfläche und atmosphärische "
-"Kondition. Parameter (z.B. Sonnenauf- und -untergangszeiten, Sonnenwinkel, "
-"extraterrestrische Strahlung und Tageslänge) werden in der History-Datei der "
-"Rasterkarte abgespeichert. Alternativ kann die lokale Zeit angegeben werden, "
-"daraus wird der Einfallswinkel der Strahlung und/oder die "
-"Strahlungsintensität berechnet. Ein Schatteneffekt der Topographie kann "
-"eingebunden werden."
+msgid "Computes direct (beam), diffuse and reflected solar irradiation raster maps for given day, latitude, surface and atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, declination, extraterrestrial irradiance, daylight length) are saved in the map history file. Alternatively, a local time can be specified to compute solar incidence angle and/or irradiance raster maps. The shadowing effect of the topography is optionally incorporated."
+msgstr "Berechnet direkte (beam), diffuse und reflektierte Sonneneinstrahlung für einen angegebenen Tag, geographische Breite, Oberfläche und atmosphärische Kondition. Parameter (z.B. Sonnenauf- und -untergangszeiten, Sonnenwinkel, extraterrestrische Strahlung und Tageslänge) werden in der History-Datei der Rasterkarte abgespeichert. Alternativ kann die lokale Zeit angegeben werden, daraus wird der Einfallswinkel der Strahlung und/oder die Strahlungsintensität berechnet. Ein Schatteneffekt der Topographie kann eingebunden werden."
 #: ../raster/r.sun/main.c:206 ../raster/r.horizon/main.c:226
 #: ../raster/r.sun2/main.c:244
@@ -14253,26 +13183,16 @@
 msgstr "Eingabe Optionen"
 #: ../raster/r.sun/main.c:215 ../raster/r.sun2/main.c:253
-msgid ""
-"Name of the input aspect map (terrain aspect or azimuth of the solar panel) "
-"[decimal degrees]"
-msgstr ""
-"Name der Eingabe-Expositionskarte (Geländeexposition oder Azimuth des "
-"Sonnenstandes) [in Dezimalgrad]."
+msgid "Name of the input aspect map (terrain aspect or azimuth of the solar panel) [decimal degrees]"
+msgstr "Name der Eingabe-Expositionskarte (Geländeexposition oder Azimuth des Sonnenstandes) [in Dezimalgrad]."
 #: ../raster/r.sun/main.c:225 ../raster/r.sun2/main.c:271
-msgid ""
-"Name of the input slope raster map (terrain slope or solar panel "
-"inclination) [decimal degrees]"
-msgstr ""
-"Eingabe-Rasterkarte der Hangneigung (Geländeneigung oder "
-"Sonnenstandsinklination) [in Grad]."
+msgid "Name of the input slope raster map (terrain slope or solar panel inclination) [decimal degrees]"
+msgstr "Eingabe-Rasterkarte der Hangneigung (Geländeneigung oder Sonnenstandsinklination) [in Grad]."
 #: ../raster/r.sun/main.c:234 ../raster/r.sun2/main.c:288
-msgid ""
-"Name of the Linke atmospheric turbidity coefficient input raster map [-]"
-msgstr ""
-"Eingabe-Rasterkarte des Linke-Trübungskoeffizienten der Atmosphäre [-]."
+msgid "Name of the Linke atmospheric turbidity coefficient input raster map [-]"
+msgstr "Eingabe-Rasterkarte des Linke-Trübungskoeffizienten der Atmosphäre [-]."
 #: ../raster/r.sun/main.c:245 ../raster/r.sun2/main.c:298
 msgid "A single value of the Linke atmospheric turbidity coefficient [-]"
@@ -14296,13 +13216,11 @@
 #: ../raster/r.sun/main.c:293
 msgid "Name of real-sky beam radiation coefficient raster map [-]"
-msgstr ""
-"Name der Rasterkarte mit dem Koeffizient der direkten Sonneneinstrahlung [-]."
+msgstr "Name der Rasterkarte mit dem Koeffizient der direkten Sonneneinstrahlung [-]."
 #: ../raster/r.sun/main.c:302
 msgid "Name of real-sky diffuse radiation coefficient raster map [-]"
-msgstr ""
-"Name der Rasterkarte mit dem Koeffizient der diffusen Sonneneinstrahlung [-]."
+msgstr "Name der Rasterkarte mit dem Koeffizient der diffusen Sonneneinstrahlung [-]."
 #: ../raster/r.sun/main.c:311 ../raster/r.sun2/main.c:380
 msgid "Output incidence angle raster map (mode 1 only)"
@@ -14334,32 +13252,20 @@
 msgstr "Ausgabe Optionen"
 #: ../raster/r.sun/main.c:320 ../raster/r.sun2/main.c:389
-msgid ""
-"Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
-"day-1] (mode 2)"
-msgstr ""
-"Ausgabe der gerichteten [W.m-2] (Modus 1) Strahlung oder der Abstrahlung [Wh."
-"m-2.day-1] (Modus 2)."
+msgid "Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr "Ausgabe der gerichteten [W.m-2] (Modus 1) Strahlung oder der Abstrahlung [Wh.m-2.day-1] (Modus 2)."
 #: ../raster/r.sun/main.c:329 ../raster/r.sun2/main.c:398
 msgid "Output insolation time raster map [h] (mode 2 only)"
 msgstr "Ausgabe-Rasterkarte der Sonneneinstrahlungszeit [in h] (nur Modus 2)."
 #: ../raster/r.sun/main.c:338 ../raster/r.sun2/main.c:407
-msgid ""
-"Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
-"day-1] (mode 2)"
-msgstr ""
-"Ausgabe-Rasterkarte der diffusen Sonneneinstrahlung [W.m-2] (Modus 1) oder "
-"der Abstrahlung [Wh.m-2.day-1] (Modus 2)."
+msgid "Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr "Ausgabe-Rasterkarte der diffusen Sonneneinstrahlung [W.m-2] (Modus 1) oder der Abstrahlung [Wh.m-2.day-1] (Modus 2)."
 #: ../raster/r.sun/main.c:347 ../raster/r.sun2/main.c:416
-msgid ""
-"Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster "
-"map [Wh.m-2.day-1] (mode 2)"
-msgstr ""
-"Ausgabekarte der Grund-Ausstrahlung [W.m-2] (Modus 1) oder Intensität [Wh."
-"m-2.day1] (Modus 2)."
+msgid "Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr "Ausgabekarte der Grund-Ausstrahlung [W.m-2] (Modus 1) oder Intensität [Wh.m-2.day1] (Modus 2)."
 #: ../raster/r.sun/main.c:354 ../raster/r.sun2/main.c:432
 msgid "No. of day of the year (1-365)"
@@ -14367,20 +13273,15 @@
 #: ../raster/r.sun/main.c:362 ../raster/r.sun2/main.c:441
 msgid "Time step when computing all-day radiation sums [decimal hours]"
-msgstr ""
-"Zeitschritt für die Berechnung der ganztägigen Strahlung [in Dezimal-"
-"Stunden]."
+msgstr "Zeitschritt für die Berechnung der ganztägigen Strahlung [in Dezimal-Stunden]."
 #: ../raster/r.sun/main.c:369 ../raster/r.sun2/main.c:448
 msgid "Declination value (overriding the internally computed value) [radians]"
-msgstr ""
-"Deklinationswert (überschreibt den intern berechneten Wert) [Bogenmaß]."
+msgstr "Deklinationswert (überschreibt den intern berechneten Wert) [Bogenmaß]."
 #: ../raster/r.sun/main.c:377 ../raster/r.sun2/main.c:456
 msgid "Local (solar) time (to be set for mode 1 only) [decimal hours]"
-msgstr ""
-"Lokale (Sonnen-)Zeit (muss nur für Modus 1 angegeben werden) [Dezimal-"
-"Stunden]"
+msgstr "Lokale (Sonnen-)Zeit (muss nur für Modus 1 angegeben werden) [Dezimal-Stunden]"
 #: ../raster/r.sun/main.c:382 ../raster/r.sun2/main.c:509
 msgid "Incorporate the shadowing effect of terrain"
@@ -14395,12 +13296,8 @@
 msgstr "time und insol_time sind nicht kompatible Optionen."
 #: ../raster/r.sun/main.c:417
-msgid ""
-"Mode 1: instantaneous solar incidence angle & irradiance given a set local "
-"time"
-msgstr ""
-"Modus 1: momentaner Sonneneinfallswinkel & Strahlungsintensität bei "
-"bekannter lokaler Zeit"
+msgid "Mode 1: instantaneous solar incidence angle & irradiance given a set local time"
+msgstr "Modus 1: momentaner Sonneneinfallswinkel & Strahlungsintensität bei bekannter lokaler Zeit"
 #: ../raster/r.sun/main.c:422 ../raster/r.sun2/main.c:623
 msgid "incidout requires time parameter to be set"
@@ -14411,12 +13308,8 @@
 msgstr "Modus 2: integrierte tägliche Strahlung für einen Tag des Jahres"
 #: ../raster/r.sun/main.c:472
-msgid ""
-"Can't get projection info of current location: please set latitude via 'lat' "
-"or 'latin' option!"
-msgstr ""
-"Kann die Projektionsinformationen der aktuellen Location nicht finden: Bitte "
-"setzen Sie geog. Länge via 'lat' oder 'latin'!"
+msgid "Can't get projection info of current location: please set latitude via 'lat' or 'latin' option!"
+msgstr "Kann die Projektionsinformationen der aktuellen Location nicht finden: Bitte setzen Sie geog. Länge via 'lat' oder 'latin'!"
 #: ../raster/r.sun/main.c:527
 #, c-format
@@ -14482,9 +13375,7 @@
 #: ../raster/r.surf.contour/main.c:54
 msgid "Surface generation program from rasterized contours."
-msgstr ""
-"Erzeugt eine Rasteroberfläche aus gerasterten Konturlinien mit "
-"Höheninformationen."
+msgstr "Erzeugt eine Rasteroberfläche aus gerasterten Konturlinien mit Höheninformationen."
 #: ../raster/r.surf.contour/main.c:61
 msgid "Name of existing raster map containing contours"
@@ -14496,17 +13387,11 @@
 #: ../raster/r.surf.contour/main.c:72
 msgid "Unused; retained for compatibility purposes, will be removed in future"
-msgstr ""
-"Unbenutzt; nur noch zu Kompatibilitätszwecken vorhanden. Dieses Feature wird "
-"in der Zukunft entfernt."
+msgstr "Unbenutzt; nur noch zu Kompatibilitätszwecken vorhanden. Dieses Feature wird in der Zukunft entfernt."
 #: ../raster/r.surf.contour/main.c:77
-msgid ""
-"Invoke slow, but memory frugal operation (generally not needed, will be "
-"removed in future)"
-msgstr ""
-"Rufe langsame aber speicherschonende Operation auf (im Allgemeinen nicht "
-"benötigt, wird in Zukunft entfernt)."
+msgid "Invoke slow, but memory frugal operation (generally not needed, will be removed in future)"
+msgstr "Rufe langsame aber speicherschonende Operation auf (im Allgemeinen nicht benötigt, wird in Zukunft entfernt)."
 #: ../raster/r.describe/main.c:59 ../raster/r.region/main.c:54
 #: ../raster/r.support/front/front.c:54 ../raster/r.info/main.c:69
@@ -14557,13 +13442,11 @@
 #: ../raster/r.grow2/main.c:129
 msgid "Generates a raster map layer with contiguous areas grown by one cell."
-msgstr ""
-"Erzeugt eine Rasterkarte mit kontinuierlich um eine Zelle gewachsenen "
-"Flächen."
+msgstr "Erzeugt eine Rasterkarte mit kontinuierlich um eine Zelle gewachsenen Flächen."
 #: ../raster/r.grow2/main.c:140
 msgid "Radius of buffer in raster cells"
-msgstr "Radius des Buffers in Rasterzellen."
+msgstr "Radius des Puffers in Rasterzellen"
 #: ../raster/r.grow2/main.c:147 ../raster/r.grow.distance/main.c:168
 msgid "Metric"
@@ -14571,9 +13454,7 @@
 #: ../raster/r.grow2/main.c:156
 msgid "Value to write for input cells which are non-NULL (-1 => NULL)"
-msgstr ""
-"Wert die für Eingabezellen, die nicht-NULL sind (-1 => NULL) geschrieben "
-"werden."
+msgstr "Wert die für Eingabezellen, die nicht-NULL sind (-1 => NULL) geschrieben werden."
 #: ../raster/r.grow2/main.c:162
 msgid "Value to write for \"grown\" cells"
@@ -14612,17 +13493,12 @@
 msgstr "Name der Ausgabe ASCII-Grid Datei (verwende out=- für stdout)."
 #: ../raster/r.out.ascii/main.c:92
-msgid ""
-"Number of values printed before wrapping a line (only SURFER or MODFLOW "
-"format)"
-msgstr ""
-"Anzahl der ausgegebenen Werte, bevor ein Zeilenumbruch eingefügt wird (nur "
-"beim SURFER oder MODFLOW-Format)"
+msgid "Number of values printed before wrapping a line (only SURFER or MODFLOW format)"
+msgstr "Anzahl der ausgegebenen Werte, bevor ein Zeilenumbruch eingefügt wird (nur beim SURFER oder MODFLOW-Format)"
 #: ../raster/r.out.ascii/main.c:100
 msgid "String to represent null cell (GRASS grid only)"
-msgstr ""
-"Zeichenkette, der NULL-Werte repräsentiert (nur bei GRASS Rasterkarten)."
+msgstr "Zeichenkette, der NULL-Werte repräsentiert (nur bei GRASS Rasterkarten)."
 #: ../raster/r.out.ascii/main.c:104 ../raster/r.out.arc/main.c:80
 #: ../raster3d/r3.out.ascii/main.c:103
@@ -14676,19 +13552,12 @@
 msgstr "Raster, Kostenfläche, kumulative Kosten"
 #: ../raster/r.cost/main.c:130
-msgid ""
-"Creates a raster map showing the cumulative cost of moving between different "
-"geographic locations on an input raster map whose cell category values "
-"represent cost."
-msgstr ""
-"Erzeugt eine Rasterkarte, die die kumulativen Kosten, die beim Bewegen "
-"zwischen unterschiedlichen geographischen Orten entstehen, zeigt. Die "
-"Kategoriewerte der Eingabekarte repräsentieren die Kosten."
+msgid "Creates a raster map showing the cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
+msgstr "Erzeugt eine Rasterkarte, die die kumulativen Kosten, die beim Bewegen zwischen unterschiedlichen geographischen Orten entstehen, zeigt. Die Kategoriewerte der Eingabekarte repräsentieren die Kosten."
 #: ../raster/r.cost/main.c:137
 msgid "Name of raster map containing grid cell cost information"
-msgstr ""
-"Name der Rasterkarte, deren Kategoriewerte Kosteninformationen enthalten."
+msgstr "Name der Rasterkarte, deren Kategoriewerte Kosteninformationen enthalten."
 #: ../raster/r.cost/main.c:147 ../raster/r.walk/main.c:214
 msgid "Name of output raster map to contain movement directions"
@@ -14730,9 +13599,7 @@
 #: ../raster/r.cost/main.c:201 ../raster/r.walk/main.c:260
 msgid "Cost assigned to null cells. By default, null cells are excluded"
-msgstr ""
-"Kosten werden NULL-Zellen zugewiesen. Standardmäßig werden NULL-Zellen "
-"ignoriert."
+msgstr "Kosten werden NULL-Zellen zugewiesen. Standardmäßig werden NULL-Zellen ignoriert."
 #: ../raster/r.cost/main.c:210 ../raster/r.walk/main.c:268
 #: ../raster/r.in.xyz/main.c:235
@@ -14741,9 +13608,7 @@
 #: ../raster/r.cost/main.c:215 ../raster/r.walk/main.c:310
 msgid "Use the 'Knight's move'; slower, but more accurate"
-msgstr ""
-"Gehe wie ein Pferd im Schach (Knight's move); ist etwas langsamer, aber "
-"genauer."
+msgstr "Gehe wie ein Pferd im Schach (Knight's move); ist etwas langsamer, aber genauer."
 #: ../raster/r.cost/main.c:219
 msgid "Keep null values in output raster map"
@@ -14760,9 +13625,7 @@
 #: ../raster/r.cost/main.c:290
 msgid "Must specify exactly one of start_points, start_rast or coordinate"
-msgstr ""
-"Es muss exakt entweder start_points, start_rast oder coordinate angegeben "
-"werden."
+msgstr "Es muss exakt entweder start_points, start_rast oder coordinate angegeben werden."
 #: ../raster/r.cost/main.c:295 ../raster/r.cost/main.c:604
 #: ../raster/r.cost/main.c:710
@@ -14781,8 +13644,7 @@
 #: ../raster/r.cost/main.c:324
 msgid "Assigning negative cost to null cell. Null cells excluded."
-msgstr ""
-"Weise NULL-Zellen negative Kosten zu. NULL-Zellen werden ausgeschlossen."
+msgstr "Weise NULL-Zellen negative Kosten zu. NULL-Zellen werden ausgeschlossen."
 #: ../raster/r.cost/main.c:392 ../raster/r.walk/main.c:672
 msgid "Creating some temporary files..."
@@ -14799,12 +13661,8 @@
 #: ../raster/r.cost/main.c:451 ../raster/r.cost/main.c:469
 #: ../raster/r.cost/main.c:488
 #, c-format
-msgid ""
-"Negative cell value found at row %d, col %d. Setting negative value to "
-"null_cost value"
-msgstr ""
-"Negative Werte in Zeile %d, Spalte %d gefunden. Setze die negativen Werte "
-"auf den null_cost-Wert."
+msgid "Negative cell value found at row %d, col %d. Setting negative value to null_cost value"
+msgstr "Negative Werte in Zeile %d, Spalte %d gefunden. Setze die negativen Werte auf den null_cost-Wert."
 #: ../raster/r.cost/main.c:507
 msgid "Initializing output..."
@@ -14935,12 +13793,8 @@
 msgstr "\"%s\" Feld fehlt im Header."
 #: ../raster/r.in.arc/main.c:61
-msgid ""
-"Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster "
-"map layer."
-msgstr ""
-"Konvertiert ein ESRI ARC/INFO ascii Raster-Datei (GRID) in eine (binäre) "
-"GRASS Rasterkarte."
+msgid "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster map layer."
+msgstr "Konvertiert ein ESRI ARC/INFO ascii Raster-Datei (GRID) in eine (binäre) GRASS Rasterkarte."
 #: ../raster/r.in.arc/main.c:69
 msgid "ARC/INFO ASCII raster file (GRID) to be imported"
@@ -14985,14 +13839,8 @@
 msgstr "Konnte Datei nicht kopieren."
 #: ../raster/r.resamp.rst/main.c:158
-msgid ""
-"Reinterpolates and optionally computes topographic analysis from input "
-"raster map to a new raster map (possibly with different resolution) using "
-"regularized spline with tension and smoothing."
-msgstr ""
-"Reinterpoliert und berechnet ggf. topographische Analysen basierend auf "
-"einer Eingabe-Rasterkarte in eine neue Rasterkarte unter Verwendung von "
-"regularized splines with tension and smoothing (RST)."
+msgid "Reinterpolates and optionally computes topographic analysis from input raster map to a new raster map (possibly with different resolution) using regularized spline with tension and smoothing."
+msgstr "Reinterpoliert und berechnet ggf. topographische Analysen basierend auf einer Eingabe-Rasterkarte in eine neue Rasterkarte unter Verwendung von regularized splines with tension and smoothing (RST)."
 #: ../raster/r.resamp.rst/main.c:169
 msgid "Desired east-west resolution"
@@ -15064,8 +13912,7 @@
 #: ../raster/r.resamp.rst/main.c:286 ../vector/v.surf.rst/main.c:209
 msgid "Output partial derivatives instead of topographic parameters"
-msgstr ""
-"Gebe partielle Ableitungen an Stelle von topographischen Parametern aus."
+msgstr "Gebe partielle Ableitungen an Stelle von topographischen Parametern aus."
 #: ../raster/r.resamp.rst/main.c:321
 msgid "Cannot read ew_res value"
@@ -15134,9 +13981,7 @@
 #: ../raster/r.resamp.rst/main.c:431
 msgid "Input map resolution differs from current region resolution!"
-msgstr ""
-"Auflösung der Eingabekarte unterscheidet sich von der aktuellen "
-"Regionsauflösung!"
+msgstr "Auflösung der Eingabekarte unterscheidet sich von der aktuellen Regionsauflösung!"
 #: ../raster/r.resamp.rst/main.c:451
 msgid "Processing all selected output files will require"
@@ -15189,9 +14034,7 @@
 #: ../vector/v.surf.rst/main.c:668 ../vector/v.surf.rst/main.c:678
 #: ../vector/v.surf.rst/main.c:687 ../vector/v.surf.rst/main.c:696
 msgid "Not enough disk space -- cannot write files"
-msgstr ""
-"Nicht genügend Speicher auf der Festplatte frei - kann die Dateien nicht "
-"schreiben."
+msgstr "Nicht genügend Speicher auf der Festplatte frei - kann die Dateien nicht schreiben."
 #: ../raster/r.texture/main.c:76
 msgid "Generate images with textural features from a raster map."
@@ -15285,22 +14128,13 @@
 msgstr "Habe die Kenngröße #%d <%s> berechnet (56 Kenngrößen verfügbar)."
 #: ../raster/r.texture/h_measure.c:84
-msgid ""
-"Negative or no data pixel found. This module is not yet able to process no "
-"data holes in a map, please fill with r.fillnulls or other algorithms"
-msgstr ""
-"Negative oder NODATA-Pixel gefunden. Dieses Modul kann NODATA-Werte in "
-"Rasterkarten noch nicht verarbeiten. Bitte füllen Sie die Löcher z.B. mit "
-"dem Modul r.fillnulls oder anderen Füllalgorithmen."
+msgid "Negative or no data pixel found. This module is not yet able to process no data holes in a map, please fill with r.fillnulls or other algorithms"
+msgstr "Negative oder NODATA-Pixel gefunden. Dieses Modul kann NODATA-Werte in Rasterkarten noch nicht verarbeiten. Bitte füllen Sie die Löcher z.B. mit dem Modul r.fillnulls oder anderen Füllalgorithmen."
 #: ../raster/r.texture/h_measure.c:88
 #, c-format
-msgid ""
-"Too many categories (found: %i, max: %i). Try to rescale or reclassify the "
-"map"
-msgstr ""
-"Zu viele Kategorien (gefunden %i, Max: %i). Versuchen Sie die Karte zu "
-"reklassifizieren oder zu reskalieren."
+msgid "Too many categories (found: %i, max: %i). Try to rescale or reclassify the map"
+msgstr "Zu viele Kategorien (gefunden %i, Max: %i). Versuchen Sie die Karte zu reklassifizieren oder zu reskalieren."
 #: ../raster/r.texture/h_measure.c:937
 #, c-format
@@ -15341,8 +14175,7 @@
 #: ../raster/r.out.pov/main.c:193
 #, c-format
 msgid "Raster map is too big! Exceeds %d columns or %d rows"
-msgstr ""
-"Die Rasterkarte ist zu groß! Sie hat mehr als %d Spalten oder %d Zeilen."
+msgstr "Die Rasterkarte ist zu groß! Sie hat mehr als %d Spalten oder %d Zeilen."
 #: ../raster/r.out.pov/main.c:214
 msgid "Negative elevation values in input"
@@ -15417,16 +14250,8 @@
 msgstr "Vertikaler Maßstab."
 #: ../raster/r.walk/main.c:179
-msgid ""
-"Outputs a raster map layer showing the anisotropic cumulative cost of moving "
-"between different geographic locations on an input elevation raster map "
-"layer whose cell category values represent elevation combined with an input "
-"raster map layer whose cell values represent friction cost."
-msgstr ""
-"Erzeugt eine Rasterkarte, die die anisotrophen kumulierten Kosten zeigt, die "
-"beim Bewegen zwischen unterschiedlichen geographischen Orten entstehen. "
-"Dabei werden als Eingabekarten einmal ein Höhenmodell und eine Rasterkarte "
-"mit Reibungs-Kosten kombiniert."
+msgid "Outputs a raster map layer showing the anisotropic cumulative cost of moving between different geographic locations on an input elevation raster map layer whose cell category values represent elevation combined with an input raster map layer whose cell values represent friction cost."
+msgstr "Erzeugt eine Rasterkarte, die die anisotrophen kumulierten Kosten zeigt, die beim Bewegen zwischen unterschiedlichen geographischen Orten entstehen. Dabei werden als Eingabekarten einmal ein Höhenmodell und eine Rasterkarte mit Reibungs-Kosten kombiniert."
 #: ../raster/r.walk/main.c:191
 msgid "Name of elevation input raster map"
@@ -15462,18 +14287,15 @@
 #: ../raster/r.walk/main.c:287
 msgid "Coefficients for walking energy formula parameters a,b,c,d"
-msgstr ""
-"Koeffizienten für die Formel zum Berechnen der Geh-Energie: a, b, c, d."
+msgstr "Koeffizienten für die Formel zum Berechnen der Geh-Energie: a, b, c, d."
 #: ../raster/r.walk/main.c:296
 msgid "Lambda coefficients for combining walking energy and friction cost"
-msgstr ""
-"Lambda Koeffizient zur Kombination der Geh-Energie und den Reibungskosten."
+msgstr "Lambda Koeffizient zur Kombination der Geh-Energie und den Reibungskosten."
 #: ../raster/r.walk/main.c:305
 msgid "Slope factor determines travel energy cost per height step"
-msgstr ""
-"Hangneigungsfaktor, der die Reiseenergiekosten pro Höhenstufe ermittelt."
+msgstr "Hangneigungsfaktor, der die Reiseenergiekosten pro Höhenstufe ermittelt."
 #: ../raster/r.walk/main.c:314
 msgid "Keep null values in output map"
@@ -15530,9 +14352,7 @@
 #: ../raster/r.walk/main.c:512
 msgid "Warning: assigning negative cost to null cell. Null cells excluded."
-msgstr ""
-"Warnung: Weise NULL-Zellen negative Kosten zu. NULL-Zellen werden "
-"ausgeschlossen."
+msgstr "Warnung: Weise NULL-Zellen negative Kosten zu. NULL-Zellen werden ausgeschlossen."
 #: ../raster/r.walk/main.c:574 ../raster/r.walk/main.c:576
 #, c-format
@@ -15611,9 +14431,7 @@
 #: ../raster/r.walk/main.c:922
 #, c-format
 msgid "Memory allocation error on reading start points from raster map %s"
-msgstr ""
-"Fehler beim allozieren von Speicher während des Lesens der Startpunktes der "
-"Rasterkarte %s."
+msgstr "Fehler beim allozieren von Speicher während des Lesens der Startpunktes der Rasterkarte %s."
 #: ../raster/r.walk/main.c:925
 #, c-format
@@ -15671,12 +14489,8 @@
 msgstr "Lese r.stats Ausgabe."
 #: ../raster/r.median/main.c:48
-msgid ""
-"Finds the median of values in a cover map within areas assigned the same "
-msgstr ""
-"Findet den Median der Werte einer Coverkarte innerhalb der Flächen mit "
-"gleichen Werten in einer benutzerdefinierten Basiskarte."
+msgid "Finds the median of values in a cover map within areas assigned the same category value in a user-specified base map."
+msgstr "Findet den Median der Werte einer Coverkarte innerhalb der Flächen mit gleichen Werten in einer benutzerdefinierten Basiskarte."
 #: ../raster/r.median/main.c:54
 msgid "Name of base raster map"
@@ -15730,12 +14544,8 @@
 msgstr "Unterstützte Formate:\n"
 #: ../raster/r.external/main.c:83 ../raster/r.in.gdal/main.c:338
-msgid ""
-"Unable to convert input raster map projection information to GRASS format "
-"for checking"
-msgstr ""
-"Kann die Projektion der Eingabe-Rasterkarte nicht ins GRASS-Format "
-"konvertieren, zwecks Überprüfung."
+msgid "Unable to convert input raster map projection information to GRASS format for checking"
+msgstr "Kann die Projektion der Eingabe-Rasterkarte nicht ins GRASS-Format konvertieren, zwecks Überprüfung."
 #: ../raster/r.external/main.c:99 ../raster/r.in.gdal/main.c:354
 #: ../vector/v.in.ogr/main.c:515
@@ -15748,8 +14558,7 @@
 "Projection of dataset does not appear to match current location.\n"
 "\n"
 msgstr ""
-"Die Projektion des Datensatzes scheint nicht mit der aktuellen Location "
-"übereinzustimmen.\n"
+"Die Projektion des Datensatzes scheint nicht mit der aktuellen Location übereinzustimmen.\n"
 "\n"
 #: ../raster/r.external/main.c:112 ../raster/r.in.gdal/main.c:369
@@ -15768,37 +14577,23 @@
 #: ../raster/r.external/main.c:172
 msgid ""
 "\n"
-"You can use the -o flag to r.external to override this check and use the "
-"location definition for the dataset.\n"
+"You can use the -o flag to r.external to override this check and use the location definition for the dataset.\n"
 msgstr ""
 "\n"
-"Sie können den Schalter '-o' von r.exernal, um diese Prüfung zu übersteuern "
-"und die Einstellungen der Location für diesen Datensatz zu verwenden.\n"
+"Sie können den Schalter '-o' von r.exernal, um diese Prüfung zu übersteuern und die Einstellungen der Location für diesen Datensatz zu verwenden.\n"
 #: ../raster/r.external/main.c:175 ../raster/r.in.gdal/main.c:441
-msgid ""
-"Consider generating a new location from the input dataset using the "
-"'location' parameter.\n"
-msgstr ""
-"Bedenken Sie, dass es besser sein könnte eine neue Location mit den Werten "
-"des zu importierenden Datensatzes mit Hilfe des 'location'-Parameters zu "
-"erzeugen.\n"
+msgid "Consider generating a new location from the input dataset using the 'location' parameter.\n"
+msgstr "Bedenken Sie, dass es besser sein könnte eine neue Location mit den Werten des zu importierenden Datensatzes mit Hilfe des 'location'-Parameters zu erzeugen.\n"
 #: ../raster/r.external/main.c:180 ../raster/r.in.gdal/main.c:446
 #: ../vector/v.in.ogr/main.c:598
 msgid "Projection of input dataset and current location appear to match"
-msgstr ""
-"Die Projektionsinformationen des Eingabedatensatzes und der aktuellen "
-"Location scheinen übereinzustimmen."
+msgstr "Die Projektionsinformationen des Eingabedatensatzes und der aktuellen Location scheinen übereinzustimmen."
 #: ../raster/r.external/main.c:202
-msgid ""
-"Input raster map is rotated - cannot import. You may use 'gdalwarp' to "
-"transform the map to North-up."
-msgstr ""
-"Die Eingabekarte wurde rotiert und kann daher nicht eingelesen werden. Sie "
-"können 'gdalwarp' verwenden, um die Karte so zu transformieren, dass Norden "
-"nach oben zeigt."
+msgid "Input raster map is rotated - cannot import. You may use 'gdalwarp' to transform the map to North-up."
+msgstr "Die Eingabekarte wurde rotiert und kann daher nicht eingelesen werden. Sie können 'gdalwarp' verwenden, um die Karte so zu transformieren, dass Norden nach oben zeigt."
 #: ../raster/r.external/main.c:264 ../raster/r.in.gdal/main.c:630
 #: ../vector/v.in.ogr/main.c:1260
@@ -15949,9 +14744,7 @@
 #: ../raster/r.topidx/main.c:39
 msgid "Creates topographic index map from elevation raster map."
-msgstr ""
-"Erstellt Karte mit topographischem Index [(ln(a/tan(beta)))] auf Basis eines "
-"digitalen Höhenmodells."
+msgstr "Erstellt Karte mit topographischem Index [(ln(a/tan(beta)))] auf Basis eines digitalen Höhenmodells."
 #: ../raster/r.topidx/main.c:46
 msgid "Output topographic index map"
@@ -15960,20 +14753,12 @@
 #: ../raster/r.topidx/main.c:53 ../raster/r.gwflow/main.c:201
 #, c-format
 msgid "Lat/Long location is not supported by %s. Please reproject map first."
-msgstr ""
-"Lat/Long Location wird nicht unterstützt von %s. Bitte, projezieren Sie die "
-"Karte zuerst."
+msgstr "Lat/Long Location wird nicht unterstützt von %s. Bitte, projezieren Sie die Karte zuerst."
 #: ../raster/r.topidx/file_io.c:37
 #, c-format
-msgid ""
-"The current region resolution [%s x %s] is finer than the input map's "
-"resolution [%s x %s]. The current region resolution must be identical to, or "
-"coarser than, the input map's resolution."
-msgstr ""
-"Die Auflösung der aktuellen Region [%s x %s] ist feiner als die Auflösung "
-"der Eingabekarte [%s x %s]. Die Auflösungen der aktuellen Region muss "
-"identisch oder gröber sein als die der Eingabekarte."
+msgid "The current region resolution [%s x %s] is finer than the input map's resolution [%s x %s]. The current region resolution must be identical to, or coarser than, the input map's resolution."
+msgstr "Die Auflösung der aktuellen Region [%s x %s] ist feiner als die Auflösung der Eingabekarte [%s x %s]. Die Auflösungen der aktuellen Region muss identisch oder gröber sein als die der Eingabekarte."
 #: ../raster/r.topidx/file_io.c:44
 msgid "Reading elevation map..."
@@ -15992,12 +14777,8 @@
 msgstr "Name der Bewegungsrichtungskarte verbunden mit der Kostenkarte."
 #: ../raster/r.drain/main.c:131
-msgid ""
-"Output drain vector map (recommended for cost surface made using knight's "
-"move)"
-msgstr ""
-"Ausgabe Abflußvektorkarte (empfohlen für Kostenkarten erstellt mittels "
-"Rösselsprung)."
+msgid "Output drain vector map (recommended for cost surface made using knight's move)"
+msgstr "Ausgabe Abflußvektorkarte (empfohlen für Kostenkarten erstellt mittels Rösselsprung)."
 #: ../raster/r.drain/main.c:139
 msgid "Map coordinates of starting point(s) (E,N)"
@@ -16020,12 +14801,8 @@
 msgstr "Zähle Zellenanzahl entlang des Pfades."
 #: ../raster/r.drain/main.c:163
-msgid ""
-"The input surface is a cost surface (if checked, a direction surface must "
-"also be specified"
-msgstr ""
-"Die Eingabe-Oberfläche ist eine Kostenkarte (wenn aktiviert, muß auch eine "
-"Richtungskarte angegeben werden)."
+msgid "The input surface is a cost surface (if checked, a direction surface must also be specified"
+msgstr "Die Eingabe-Oberfläche ist eine Kostenkarte (wenn aktiviert, muß auch eine Richtungskarte angegeben werden)."
 #: ../raster/r.drain/main.c:175
 msgid "Directional drain selected... checking for direction raster"
@@ -16036,12 +14813,8 @@
 msgstr "Oberflächen-/Hydrologischer-Abfluß ausgewählt"
 #: ../raster/r.drain/main.c:184
-msgid ""
-"Direction raster not specified, if direction flag is on, a direction raster "
-"must be given"
-msgstr ""
-"Richtungskarte nicht angegeben. Wenn der Richtungsschalter aktiviert ist, "
-"muß eine Richtungskarte angegeben werden."
+msgid "Direction raster not specified, if direction flag is on, a direction raster must be given"
+msgstr "Richtungskarte nicht angegeben. Wenn der Richtungsschalter aktiviert ist, muß eine Richtungskarte angegeben werden."
 #: ../raster/r.drain/main.c:191
 #, c-format
@@ -16051,9 +14824,7 @@
 #: ../raster/r.drain/main.c:198
 #, c-format
 msgid "Direction map <%s> should not be specified for Surface/Hydrology drains"
-msgstr ""
-"Richtungskarte <%s> sollte bei Oberflächen-/Hydrologischem-Abfluß nicht "
-"angegeben werden."
+msgstr "Richtungskarte <%s> sollte bei Oberflächen-/Hydrologischem-Abfluß nicht angegeben werden."
 #: ../raster/r.drain/main.c:204
 msgid "Outputting a vector path"
@@ -16099,12 +14870,8 @@
 msgstr "Raster, Terrain"
 #: ../raster/r.slope.aspect/main.c:156
-msgid ""
-"Generates raster maps of slope, aspect, curvatures and partial derivatives "
-"from a elevation raster map."
-msgstr ""
-"Erzeugt Rasterkarten mit Hangneigung, Exposition, Wölbung und partiellen "
-"Ableitungen aus einer Rasterkarte mit Höheninformationen."
+msgid "Generates raster maps of slope, aspect, curvatures and partial derivatives from a elevation raster map."
+msgstr "Erzeugt Rasterkarten mit Hangneigung, Exposition, Wölbung und partiellen Ableitungen aus einer Rasterkarte mit Höheninformationen."
 #: ../raster/r.slope.aspect/main.c:158
 msgid "Aspect is calculated counterclockwise from east."
@@ -16148,18 +14915,12 @@
 msgstr "Name der Ausgabe-Rasterkarte mit horizontaler Wölbung."
 #: ../raster/r.slope.aspect/main.c:211
-msgid ""
-"Name for output first order partial derivative dx (E-W slope) raster map"
-msgstr ""
-"Name der Ausgabe-Rasterkarte der ersten partiellen Ableitung dx (Ost-West "
-"Hangneigung)."
+msgid "Name for output first order partial derivative dx (E-W slope) raster map"
+msgstr "Name der Ausgabe-Rasterkarte der ersten partiellen Ableitung dx (Ost-West Hangneigung)."
 #: ../raster/r.slope.aspect/main.c:218
-msgid ""
-"Name for output first order partial derivative dy (N-S slope) raster map"
-msgstr ""
-"Name der Ausgabe-Rasterkarte der ersten partiellen Ableitung dy (Nord-Süd "
-"Hangneigung)."
+msgid "Name for output first order partial derivative dy (N-S slope) raster map"
+msgstr "Name der Ausgabe-Rasterkarte der ersten partiellen Ableitung dy (Nord-Süd Hangneigung)."
 #: ../raster/r.slope.aspect/main.c:225
 msgid "Name for output second order partial derivative dxx raster map"
@@ -16179,15 +14940,11 @@
 #: ../raster/r.slope.aspect/main.c:254
 msgid "Minimum slope val. (in percent) for which aspect is computed"
-msgstr ""
-"Minimale Hangneigung (in Prozent), für die eine Hangexposition berechnet "
-"werden soll."
+msgstr "Minimale Hangneigung (in Prozent), für die eine Hangexposition berechnet werden soll."
 #: ../raster/r.slope.aspect/main.c:268
 msgid "Do not align the current region to the elevation layer"
-msgstr ""
-"Die aktuelle Region nicht an die Rasterkarte mit den Höheninformationen "
-"anpassen."
+msgstr "Die aktuelle Region nicht an die Rasterkarte mit den Höheninformationen anpassen."
 #: ../raster/r.slope.aspect/main.c:329
 #, c-format
@@ -16201,12 +14958,8 @@
 #: ../raster/r.slope.aspect/main.c:350
 #, c-format
-msgid ""
-"You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <"
-"%s>, <%s>, <%s>, <%s> or <%s>"
-msgstr ""
-"Sie müssen mindestens einen der Parameter wählen: <%s>, <%s>, <%s>, <%s>, <"
-"%s>, <%s>, <%s>, <%s> oder <%s>"
+msgid "You must specify at least one of the parameters: <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s> or <%s>"
+msgstr "Sie müssen mindestens einen der Parameter wählen: <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s>, <%s> oder <%s>"
 #: ../raster/r.slope.aspect/main.c:380
 #, c-format
@@ -16231,8 +14984,7 @@
 #: ../raster/r.slope.aspect/main.c:1119
 #, c-format
 msgid "Min computed slope %.4f, max computed slope %.4f"
-msgstr ""
-"minimale berechnete Hangneigung %.4f, maximale berechnete Hangneigung %.4f."
+msgstr "minimale berechnete Hangneigung %.4f, maximale berechnete Hangneigung %.4f."
 #: ../raster/r.slope.aspect/main.c:1174
 #, c-format
@@ -16379,9 +15131,7 @@
 #: ../raster/r.in.bin/main.c:426
 msgid "Either all or none of north=, south=, east= and west= must be given"
-msgstr ""
-"Entweder alle oder keine Angabe von north=, south=, east= and west= müssen "
-"angegeben werden"
+msgstr "Entweder alle oder keine Angabe von north=, south=, east= and west= müssen angegeben werden"
 #: ../raster/r.in.bin/main.c:435
 #, c-format
@@ -16400,12 +15150,8 @@
 #: ../raster/r.in.bin/main.c:464
 #, c-format
-msgid ""
-"East-West (ewres: %f) and North-South (nwres: %f) resolution differ "
-"significantly. Did you assign east= and west= correctly?"
-msgstr ""
-"Ost-West (ewres: %f) und Nord-Süd (nwres: %f) Auflösung unterscheiden sich "
-"wesentlich. Haben Sie east= and west= korrekt gesetzt?"
+msgid "East-West (ewres: %f) and North-South (nwres: %f) resolution differ significantly. Did you assign east= and west= correctly?"
+msgstr "Ost-West (ewres: %f) und Nord-Süd (nwres: %f) Auflösung unterscheiden sich wesentlich. Haben Sie east= and west= korrekt gesetzt?"
 #: ../raster/r.in.bin/main.c:487
 msgid "File Size %"
@@ -16416,15 +15162,8 @@
 msgstr "Bytes passen nicht zur Dateigröße"
 #: ../raster/r.surf.gauss/main.c:48
-msgid ""
-"GRASS module to produce a raster map layer of gaussian deviates whose mean "
-"and standard deviation can be expressed by the user. It uses a gaussian "
-"random number generator."
-msgstr ""
-"GRASS Modul zum Erstellen einer Rasterkarte mit Werten einer Gauß'schen "
-"Verteilung, wobei der Mittelwert und die Standardabweichung vom Benutzer "
-"angegeben werden können. Ein Gauß'scher Zufallszahlengenerator wird "
-"verwendet."
+msgid "GRASS module to produce a raster map layer of gaussian deviates whose mean and standard deviation can be expressed by the user. It uses a gaussian random number generator."
+msgstr "GRASS Modul zum Erstellen einer Rasterkarte mit Werten einer Gauß'schen Verteilung, wobei der Mittelwert und die Standardabweichung vom Benutzer angegeben werden können. Ein Gauß'scher Zufallszahlengenerator wird verwendet."
 #: ../raster/r.surf.gauss/main.c:55
 msgid "Name of the output random surface"
@@ -16440,8 +15179,7 @@
 #: ../raster/r.topmodel/main.c:57
 msgid "Simulates TOPMODEL which is a physically based hydrologic model."
-msgstr ""
-"Modul zur TOPMODEL Simulation (physikalisch basiertes hydrologisches Modell)."
+msgstr "Modul zur TOPMODEL Simulation (physikalisch basiertes hydrologisches Modell)."
 #: ../raster/r.topmodel/main.c:63
 msgid "(i)   Basin map created by r.water.outlet (MASK)"
@@ -16465,9 +15203,7 @@
 #: ../raster/r.topmodel/main.c:100
 msgid "(o)   Topographic index ln(a/tanB) map (MASK applied)"
-msgstr ""
-"(o)   Karte des Topographischen Index ln(a/tanB) (mit angewandter Maske "
-"(MASK))."
+msgstr "(o)   Karte des Topographischen Index ln(a/tanB) (mit angewandter Maske (MASK))."
 #: ../raster/r.topmodel/main.c:108
 msgid "(i)   Number of topographic index classes"
@@ -16499,8 +15235,7 @@
 #: ../raster/r.topmodel/main.c:155
 msgid "(i)   OPTIONAL Output for given topographic index class"
-msgstr ""
-"(i)   OPTIONAL: Ausgabe für die angegebene Klasse des topgraphischen Index."
+msgstr "(i)   OPTIONAL: Ausgabe für die angegebene Klasse des topgraphischen Index."
 #: ../raster/r.topmodel/main.c:163
 msgid "Input data given for (o/i)"
@@ -16520,8 +15255,7 @@
 #: ../raster/r.out.vrml/main.c:49
 msgid "Export a raster map to the Virtual Reality Modeling Language (VRML)"
-msgstr ""
-"Exportiere eine Rasterkarte in die Virtual Reality Modeling Language (VRML)."
+msgstr "Exportiere eine Rasterkarte in die Virtual Reality Modeling Language (VRML)."
 #: ../raster/r.out.vrml/main.c:56
 msgid "Name of elevation map"
@@ -16550,12 +15284,8 @@
 msgstr "Raster, Serien"
 #: ../raster/r.series/main.c:135
-msgid ""
-"Makes each output cell value a function of the values assigned to the "
-"corresponding cells in the input raster map layers."
-msgstr ""
-"Macht aus jeder Ausgabezelle eine Funktion der Werte, die einer "
-"korrespondierenden Zelle einer Eingabekarte zugewiesen ist."
+msgid "Makes each output cell value a function of the values assigned to the corresponding cells in the input raster map layers."
+msgstr "Macht aus jeder Ausgabezelle eine Funktion der Werte, die einer korrespondierenden Zelle einer Eingabekarte zugewiesen ist."
 #: ../raster/r.series/main.c:149
 msgid "Aggregate operation"
@@ -16592,11 +15322,8 @@
 msgstr "Raster, Transekt"
 #: ../raster/r.transect/main.c:56
-msgid ""
-"Outputs raster map layer values lying along user defined transect line(s)."
-msgstr ""
-"Gibt die Werte einer Rasterkarte aus, die entlang einer/mehrerer durch den "
-"Benutzer festgelegten Linie(n) liegen."
+msgid "Outputs raster map layer values lying along user defined transect line(s)."
+msgstr "Gibt die Werte einer Rasterkarte aus, die entlang einer/mehrerer durch den Benutzer festgelegten Linie(n) liegen."
 #: ../raster/r.transect/main.c:60
 msgid "Raster map to be queried"
@@ -16642,20 +15369,15 @@
 #: ../raster/r.to.rast3/main.c:196
 msgid "Converts 2D raster map slices to one 3D raster volume map."
-msgstr ""
-"Konvertiert Schnitte von 2D Rasterkarten in eine 3D-Rastervolumenkarte."
+msgstr "Konvertiert Schnitte von 2D Rasterkarten in eine 3D-Rastervolumenkarte."
 #: ../raster/r.to.rast3/main.c:208
 msgid "No output map"
 msgstr "Keine Ausgabekarte angegeben."
 #: ../raster/r.to.rast3/main.c:222 ../raster/r.to.rast3elev/main.c:462
-msgid ""
-"The 2D and 3D region settings are different. I will use the 3D region "
-"settings to adjust the 2D region."
-msgstr ""
-"Die 2D- und 3D-Regionsparameter sind unterschiedlich. Werde die Parameter "
-"der 3D-Region verwenden, um die 2D-Region anzupassen."
+msgid "The 2D and 3D region settings are different. I will use the 3D region settings to adjust the 2D region."
+msgstr "Die 2D- und 3D-Regionsparameter sind unterschiedlich. Werde die Parameter der 3D-Region verwenden, um die 2D-Region anzupassen."
 #: ../raster/r.to.rast3/main.c:256
 msgid "Cell file not found"
@@ -16668,8 +15390,7 @@
 #: ../raster/r.to.rast3/main.c:277
 msgid "Input maps have to be from the same type. CELL, FCELL or DCELL!"
-msgstr ""
-"Eingabekarten müssen vom gleichen Datentyp sein. CELL FCELL oder DCELL!"
+msgstr "Eingabekarten müssen vom gleichen Datentyp sein. CELL FCELL oder DCELL!"
 #: ../raster/r.to.rast3/main.c:281 ../raster/r.to.rast3elev/main.c:494
 msgid "Creating 3D raster map"
@@ -16688,36 +15409,25 @@
 msgstr "Kann die Eingabekarte nicht schließen."
 #: ../raster/r.sunmask/g_solposition.c:66
-msgid ""
-"Unable to calculate sun position in un-projected locations. Specify "
-"sunposition directly."
-msgstr ""
-"Die Sonnenposition kann in unprojezierten Locations nicht berechnet werden. "
-"Sonnenposition muss direkt eingegeben werden."
+msgid "Unable to calculate sun position in un-projected locations. Specify sunposition directly."
+msgstr "Die Sonnenposition kann in unprojezierten Locations nicht berechnet werden. Sonnenposition muss direkt eingegeben werden."
 #: ../raster/r.sunmask/g_solposition.c:88
 #, c-format
-msgid ""
-"Specified point %f, %f outside of current region, is that intended? Anyway, "
-"it will be used."
-msgstr ""
-"Angegebener Punkt %f, %f ist außerhalb der aktuellen Gebietsausdehnung, ist "
-"dies beabsichtigt? Trotzdem, die Einstellungen werden verwendet."
+msgid "Specified point %f, %f outside of current region, is that intended? Anyway, it will be used."
+msgstr "Angegebener Punkt %f, %f ist außerhalb der aktuellen Gebietsausdehnung, ist dies beabsichtigt? Trotzdem, die Einstellungen werden verwendet."
 #: ../raster/r.sunmask/g_solposition.c:98
 msgid "Unable to get projection info of current location"
-msgstr ""
-"Kann die Projektionsinformation der aktuellen Location nicht ermitteln."
+msgstr "Kann die Projektionsinformation der aktuellen Location nicht ermitteln."
 #: ../raster/r.sunmask/g_solposition.c:101
 msgid "Unable to get projection units of current location"
-msgstr ""
-"Kann die Einheiten der Projektion der aktuellen Location nicht ermitteln."
+msgstr "Kann die Einheiten der Projektion der aktuellen Location nicht ermitteln."
 #: ../raster/r.sunmask/g_solposition.c:104
 msgid "Unable to get projection key values of current location"
-msgstr ""
-"Kann die Kennzahlen der Projektion der aktuellen Location nicht ermitteln."
+msgstr "Kann die Kennzahlen der Projektion der aktuellen Location nicht ermitteln."
 #: ../raster/r.sunmask/solpos00.c:949
 #, c-format
@@ -16807,26 +15517,19 @@
 #: ../raster/r.sunmask/solpos00.c:993
 #, c-format
 msgid "S_decode ==> Please fix the shadowband sky factor: %f"
-msgstr ""
-"S_decode ==> Bitte berichtigen Sie den 'sky factor' des Schattenbandes: %f"
+msgstr "S_decode ==> Bitte berichtigen Sie den 'sky factor' des Schattenbandes: %f"
 #: ../raster/r.sunmask/main.c:115 ../raster/r.horizon/main.c:178
 msgid "raster, sun position"
 msgstr "Raster, Sonnenposition"
 #: ../raster/r.sunmask/main.c:116
-msgid ""
-"Calculates cast shadow areas from sun position and elevation raster map."
-msgstr ""
-"Berechnet Schattenbereiche aus der Sonnenposition und einer Höhenkarte."
+msgid "Calculates cast shadow areas from sun position and elevation raster map."
+msgstr "Berechnet Schattenbereiche aus der Sonnenposition und einer Höhenkarte."
 #: ../raster/r.sunmask/main.c:117
-msgid ""
-"Either exact sun position (A) is specified, or date/time to calculate the "
-"sun position (B) by r.sunmask itself."
-msgstr ""
-"Entweder wird die exakte Sonnenposition (A) oder Datum/Uhrzeit zur "
-"Berechnung der Sonnenposition durch r.sunmask (B) angegeben."
+msgid "Either exact sun position (A) is specified, or date/time to calculate the sun position (B) by r.sunmask itself."
+msgstr "Entweder wird die exakte Sonnenposition (A) oder Datum/Uhrzeit zur Berechnung der Sonnenposition durch r.sunmask (B) angegeben."
 #: ../raster/r.sunmask/main.c:131
 msgid "Altitude of the sun above horizon, degrees (A)"
@@ -16878,9 +15581,7 @@
 #: ../raster/r.sunmask/main.c:197
 msgid "East positive, offset from GMT, also use to adjust daylight savings"
-msgstr ""
-"Ost positiv, Abstand von GMT; wird auch zur Anpassung an die Winterzeit "
-"genutzt"
+msgstr "Ost positiv, Abstand von GMT; wird auch zur Anpassung an die Winterzeit genutzt"
 #: ../raster/r.sunmask/main.c:206
 msgid "Easting coordinate (point of interest)"
@@ -16928,12 +15629,8 @@
 msgstr "Definiere Sie entweder die Sonnenposition oder Ort/Datum/Zeit."
 #: ../raster/r.sunmask/main.c:282
-msgid ""
-"Neither sun position nor east/north, date/time/timezone definition are "
-"complete"
-msgstr ""
-"Weder die Sonnenposition noch Ost/Nord, Datum/Uhrzeit/Zeitzone sind "
-"vollständig angegeben."
+msgid "Neither sun position nor east/north, date/time/timezone definition are complete"
+msgstr "Weder die Sonnenposition noch Ost/Nord, Datum/Uhrzeit/Zeitzone sind vollständig angegeben."
 #: ../raster/r.sunmask/main.c:286
 #, c-format
@@ -16941,12 +15638,8 @@
 msgstr "Berechne Sonnenposition... (verwende solpos (V. %s) vom NREL)"
 #: ../raster/r.sunmask/main.c:291
-msgid ""
-"Using user defined sun azimuth, altitude settings (ignoring eventual other "
-"values)"
-msgstr ""
-"Verwende benutzerdefinierten Sonnenazimuth und Höhe (ignoriere eventuell "
-"anderen Werte)"
+msgid "Using user defined sun azimuth, altitude settings (ignoring eventual other values)"
+msgstr "Verwende benutzerdefinierten Sonnenazimuth und Höhe (ignoriere eventuell anderen Werte)"
 #: ../raster/r.sunmask/main.c:397
 msgid "Please correct settings"
@@ -16988,8 +15681,7 @@
 #: ../raster/r.sunmask/main.c:459
 #, c-format
 msgid "Unable to open range file for raster map <%s>"
-msgstr ""
-"Kann die Datei mit dem Wertebereich für die Rasterkarte <%s> nicht lesen."
+msgstr "Kann die Datei mit dem Wertebereich für die Rasterkarte <%s> nicht lesen."
 #: ../raster/r.sunmask/main.c:475
 msgid "Calculating shadows from DEM..."
@@ -17012,23 +15704,16 @@
 msgstr "Höhe (wenn keine Rasterkarte mit Höhenwerten bestimmt wurde)."
 #: ../raster/r.out.vtk/parameters.c:66
-msgid ""
-"Create VTK point data instead of VTK cell data (if no elevation map is given)"
-msgstr ""
-"Erzeuge VTK Punktdaten anstelle von VTK Cell-Daten (wenn keine Höhenkarte "
-"angegeben wurde)."
+msgid "Create VTK point data instead of VTK cell data (if no elevation map is given)"
+msgstr "Erzeuge VTK Punktdaten anstelle von VTK Cell-Daten (wenn keine Höhenkarte angegeben wurde)."
 #: ../raster/r.out.vtk/parameters.c:76
-msgid ""
-"Three (r,g,b) raster maps to create rgb values [redmap,greenmap,bluemap]"
-msgstr ""
-"Drei (R,G,B) Rasterkarten um RGB-Werte zu erzeugen [rote Karte,grüne Karte,"
-"blaue Karte]."
+msgid "Three (r,g,b) raster maps to create rgb values [redmap,greenmap,bluemap]"
+msgstr "Drei (R,G,B) Rasterkarten um RGB-Werte zu erzeugen [rote Karte,grüne Karte,blaue Karte]."
 #: ../raster/r.out.vtk/parameters.c:86
 msgid "Three (x,y,z) raster maps to create vector values [xmap,ymap,zmap]"
-msgstr ""
-"Drei (x,y,z) Rasterkarten um Vektor-Werte zu erzeugen [xmap,ymap,zmap]."
+msgstr "Drei (x,y,z) Rasterkarten um Vektor-Werte zu erzeugen [xmap,ymap,zmap]."
 #: ../raster/r.out.vtk/parameters.c:93 ../raster3d/r3.out.vtk/parameters.c:99
 #: ../vector/v.out.vtk/main.c:75
@@ -17044,17 +15729,12 @@
 msgstr "Benutze Polydata-Dreiecksstreifen für die Erzeugung des Höhengitters."
 #: ../raster/r.out.vtk/parameters.c:123
-msgid ""
-"Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
-msgstr ""
-"Benutze Polydata-Stützpunkte für die Höhenmodellerstellung (für "
-"vtkDelauny2D)."
+msgid "Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
+msgstr "Benutze Polydata-Stützpunkte für die Höhenmodellerstellung (für vtkDelauny2D)."
 #: ../raster/r.out.vtk/parameters.c:129
 msgid "Scale factor effects the origin (if no elevation map is given)"
-msgstr ""
-"Skalierungsfaktor beeinflusst den Ursprung (wenn keine Höhenkarte angegeben "
-"wurde)."
+msgstr "Skalierungsfaktor beeinflusst den Ursprung (wenn keine Höhenkarte angegeben wurde)."
 #: ../raster/r.out.vtk/parameters.c:135
 #: ../raster3d/r3.out.vtk/parameters.c:128 ../vector/v.out.vtk/main.c:88
@@ -17121,9 +15801,7 @@
 #: ../raster/r.out.vtk/main.c:86
 msgid "Cannot create RGB data, please provide three maps [r,g,b]"
-msgstr ""
-"Kann RGB-Daten nicht erzeugen, bitte stellen Sie drei Karten zur Verfügung "
-"[r,g,b]"
+msgstr "Kann RGB-Daten nicht erzeugen, bitte stellen Sie drei Karten zur Verfügung [r,g,b]"
 #: ../raster/r.out.vtk/main.c:102
 #, c-format
@@ -17132,8 +15810,7 @@
 #: ../raster/r.out.vtk/main.c:109
 msgid "Cannot create vector data, please provide three maps [x,y,z]"
-msgstr ""
-"Kann Vektor-Daten nicht erzeugen, bitte geben Sie drei Karten an [x,y,z]"
+msgstr "Kann Vektor-Daten nicht erzeugen, bitte geben Sie drei Karten an [x,y,z]"
 #: ../raster/r.out.vtk/main.c:149
 msgid "Converts raster maps into the VTK-Ascii format"
@@ -17151,20 +15828,15 @@
 #: ../raster/r.out.vtk/main.c:334
 msgid "Wrong RGB maps. Maps should have the same type! RGB output not added!"
-msgstr ""
-"Falsche RGB Karten. Karten sollten den selben Typ haben! RGB Ausgabe wurde "
-"nicht hinzugefügt!"
+msgstr "Falsche RGB Karten. Karten sollten den selben Typ haben! RGB Ausgabe wurde nicht hinzugefügt!"
 #: ../raster/r.out.vtk/main.c:371
 msgid "Writing VTK Vector Data\n"
 msgstr "Schreibe VTK Vektordaten.\n"
 #: ../raster/r.out.vtk/main.c:381
-msgid ""
-"Wrong vector maps. Maps should have the same type! Vector output not added!"
-msgstr ""
-"FalscheVektorkarten. Karten sollten den selben Typ haben! Vektor-Ausgabe "
-"wurde nicht hinzugefügt!"
+msgid "Wrong vector maps. Maps should have the same type! Vector output not added!"
+msgstr "FalscheVektorkarten. Karten sollten den selben Typ haben! Vektor-Ausgabe wurde nicht hinzugefügt!"
 #: ../raster/r.out.vtk/main.c:393
 msgid "Error closing VTK-ASCII file"
@@ -17206,9 +15878,7 @@
 #: ../raster/r.circle/dist.c:53
 msgid "Creates a raster map containing concentric rings around a given point."
-msgstr ""
-"Erzeugt eine Rasterkarte, die konzentrische Kreise um einen angegebenen "
-"Punkt ziehen."
+msgstr "Erzeugt eine Rasterkarte, die konzentrische Kreise um einen angegebenen Punkt ziehen."
 #: ../raster/r.circle/dist.c:63
 msgid "The coordinate of the center (east,north)"
@@ -17236,9 +15906,7 @@
 #: ../raster/r.circle/dist.c:116
 msgid "Please specify min and/or max radius when using the binary flag"
-msgstr ""
-"Bitte geben Sie einen min und/oder max Radius an, wenn Sie den Binären "
-"Schalter verwenden."
+msgstr "Bitte geben Sie einen min und/oder max Radius an, wenn Sie den Binären Schalter verwenden."
 #: ../raster/r.lake/main.c:79
 #, c-format
@@ -17275,20 +15943,15 @@
 #: ../raster/r.lake/main.c:200
 msgid "Overwrite seed map with result (lake) map"
-msgstr ""
-"Überschreibe die Karte mit Startpunkten mit der resultierenden Seekarte."
+msgstr "Überschreibe die Karte mit Startpunkten mit der resultierenden Seekarte."
 #: ../raster/r.lake/main.c:206
 msgid "Both seed map and coordinates cannot be specified"
-msgstr ""
-"Eine Karte mit Startpunkten und Koordinaten können nicht gleichzeitig "
-"verwendet werden."
+msgstr "Eine Karte mit Startpunkten und Koordinaten können nicht gleichzeitig verwendet werden."
 #: ../raster/r.lake/main.c:209
 msgid "Seed map or seed coordinates must be set!"
-msgstr ""
-"Entweder eine Karte mit Startpunkten oder Startkoordinaten müssen angegeben "
-"werden."
+msgstr "Entweder eine Karte mit Startpunkten oder Startkoordinaten müssen angegeben werden."
 # Einige Daten können u.U. verloren sein.er/r.lake/main.c:212
 #: ../raster/r.lake/main.c:212
@@ -17297,15 +15960,11 @@
 #: ../raster/r.lake/main.c:215
 msgid "Both lake and overwrite cannot be specified"
-msgstr ""
-"Die Einstellungen 'lake' und 'overwrite' können nicht zugleich verwendet "
-"werden."
+msgstr "Die Einstellungen 'lake' und 'overwrite' können nicht zugleich verwendet werden."
 #: ../raster/r.lake/main.c:218
 msgid "Output lake map or overwrite flag must be set!"
-msgstr ""
-"Entweder eine Ausgabe-Seekarte oder das Überschreiben-'flag' muss angegeben "
-"werden."
+msgstr "Entweder eine Ausgabe-Seekarte oder das Überschreiben-'flag' muss angegeben werden."
 #: ../raster/r.lake/main.c:248
 msgid "Seed point outside the current region"
@@ -17316,13 +15975,8 @@
 msgstr "G_malloc: Kein Speicher mehr da."
 #: ../raster/r.lake/main.c:303
-msgid ""
-"Given water level at seed point is below earth surface. Increase water level "
-"or move seed point."
-msgstr ""
-"Der angegebene Wasserstand am Startpunkt befindet sich unter der "
-"Erdoberfläche. Erhöhen Sie den Wasserstand oder verschieben Sie den "
-"Startpunkt."
+msgid "Given water level at seed point is below earth surface. Increase water level or move seed point."
+msgstr "Der angegebene Wasserstand am Startpunkt befindet sich unter der Erdoberfläche. Erhöhen Sie den Wasserstand oder verschieben Sie den Startpunkt."
 #: ../raster/r.lake/main.c:386
 #, c-format
@@ -17341,9 +15995,7 @@
 #: ../raster/r.lake/main.c:389
 msgid "Volume is correct only if lake depth (terrain raster map) is in meters"
-msgstr ""
-"Das Volumen ist nur korrekt, wenn die Seetiefe (Terrain-Rasterkarte) in "
-"Metern angegeben wurde."
+msgstr "Das Volumen ist nur korrekt, wenn die Seetiefe (Terrain-Rasterkarte) in Metern angegeben wurde."
 #: ../raster/r.lake/main.c:407 ../raster/r.composite/main.c:167
 #, c-format
@@ -17479,12 +16131,8 @@
 msgstr "Raster, Statistik, Reklassifizieren"
 #: ../raster/r.clump/main.c:51
-msgid ""
-"Recategorizes data in a raster map by grouping cells that form physically "
-"discrete areas into unique categories."
-msgstr ""
-"Re-Kategorisiert Daten einer Rasterkarte, indem Zellen physikalisch "
-"diskreter Areale zu eindeutigen Kategorie gruppiert werden."
+msgid "Recategorizes data in a raster map by grouping cells that form physically discrete areas into unique categories."
+msgstr "Re-Kategorisiert Daten einer Rasterkarte, indem Zellen physikalisch diskreter Areale zu eindeutigen Kategorie gruppiert werden."
 #: ../raster/r.clump/main.c:117
 #, c-format
@@ -17493,9 +16141,7 @@
 #: ../raster/r.surf.fractal/process.c:53
 msgid "Unable to allocate data buffer. Check current region with g.region."
-msgstr ""
-"Kann keinen Speicher für Datenbuffer reservieren. Überprüfen Sie die "
-"aktuelle Region mit g.region."
+msgstr "Kann keinen Speicher für Datenpuffer reservieren. Überprüfen Sie die aktuelle Region mit g.region."
 #: ../raster/r.surf.fractal/spec_syn.c:61
 msgid "Preliminary surface calculations..."
@@ -17508,8 +16154,7 @@
 #: ../raster/r.surf.fractal/main.c:39
 msgid "Creates a fractal surface of a given fractal dimension."
-msgstr ""
-"Erzeugt eine fraktale Oberfläche mit einer gegebenen Fraktalendimension."
+msgstr "Erzeugt eine fraktale Oberfläche mit einer gegebenen Fraktalendimension."
 #: ../raster/r.surf.fractal/main.c:49
 msgid "Fractal dimension of surface (2 < D < 3)"
@@ -17522,17 +16167,16 @@
 #: ../raster/r.surf.fractal/main.c:69
 #, c-format
 msgid "Steps=%d"
-msgstr ""
+msgstr "Schritte=%d"
 #: ../raster/r.surf.fractal/main.c:80
-#, fuzzy, c-format
+#, c-format
 msgid "Fractal dimension of [%.2lf] must be between 2 and 3."
 msgstr "Fraktale Dimension von [%.2lf] muss zwischen 2 und 3 liegen."
 #: ../raster/r.to.rast3elev/main.c:138
 msgid "The number of input and elevation maps is not equal"
-msgstr ""
-"Die Anzahl der Eingabe-Karten ist nicht gleich der Anzahl der Höhen-Karten."
+msgstr "Die Anzahl der Eingabe-Karten ist nicht gleich der Anzahl der Höhen-Karten."
 #: ../raster/r.to.rast3elev/main.c:211
 msgid "The value to fill the upper cells, default is null"
@@ -17540,8 +16184,7 @@
 #: ../raster/r.to.rast3elev/main.c:218
 msgid "The value to fill the lower cells, default is null"
-msgstr ""
-"Der Wert mit dem die unteren Zellen gefüllt werden (Standrad ist null)."
+msgstr "Der Wert mit dem die unteren Zellen gefüllt werden (Standrad ist null)."
 #: ../raster/r.to.rast3elev/main.c:223
 msgid "Use the input map values to fill the upper cells"
@@ -17574,9 +16217,7 @@
 #: ../raster/r.to.rast3elev/main.c:402
 msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
-msgstr ""
-"Erzeugt eine 3D Volumenkarte basierend auf einer 2D Höhenkarte und weiteren "
-"Rasterkarten."
+msgstr "Erzeugt eine 3D Volumenkarte basierend auf einer 2D Höhenkarte und weiteren Rasterkarten."
 #: ../raster/r.to.rast3elev/main.c:433
 msgid "The upper value is not valid"
@@ -17619,36 +16260,27 @@
 #: ../raster/r.watershed/shed/com_line.c:28
 #, c-format
 msgid "in its fast mode or its slow mode.  If you run %s"
-msgstr ""
-"im schnellen Modus oder im langsamen Modus ausführen wollen. Wenn Sie %s "
+msgstr "im schnellen Modus oder im langsamen Modus ausführen wollen. Wenn Sie %s "
 #: ../raster/r.watershed/shed/com_line.c:30
 msgid "in the fast mode, the computer will finish about 10 times faster"
-msgstr ""
-"im schnellen Modus ausführen, wird der Computer ca. 10mal schneller fertig "
-"sein "
+msgstr "im schnellen Modus ausführen, wird der Computer ca. 10mal schneller fertig sein "
 #: ../raster/r.watershed/shed/com_line.c:31
 msgid "than in the slow mode, but will not allow other programs to run"
-msgstr ""
-"als im langsamen Modus. Aber dies wird nicht zulassen andere Programme "
+msgstr "als im langsamen Modus. Aber dies wird nicht zulassen andere Programme "
 #: ../raster/r.watershed/shed/com_line.c:32
 msgid "at the same time.  The fast mode also places all of the data into"
-msgstr ""
-"zur gleichen Zeit auszuführen. Der schnelle Modus schreibt ausßerdem alle "
-"Daten"
+msgstr "zur gleichen Zeit auszuführen. Der schnelle Modus schreibt ausßerdem alle Daten"
 #: ../raster/r.watershed/shed/com_line.c:33
 msgid "RAM, which limits the size of window that can be run.  The slow"
-msgstr ""
-"in das RAM, was die maximal zu berechnende Region begrenzt. Der langsame"
+msgstr "in das RAM, was die maximal zu berechnende Region begrenzt. Der langsame"
 #: ../raster/r.watershed/shed/com_line.c:34
 msgid "mode uses disk space in the same hard disk partition as where GRASS is"
-msgstr ""
-"Modus verwendet Speicher auf der selben Festplatte auf der sich GRASS "
-"befindet. "
+msgstr "Modus verwendet Speicher auf der selben Festplatte auf der sich GRASS befindet. "
 #: ../raster/r.watershed/shed/com_line.c:35
 msgid "stored.  Thus, if the program does not work in the slow mode, you will"
@@ -17656,14 +16288,12 @@
 #: ../raster/r.watershed/shed/com_line.c:36
 msgid "need to remove unnecessary files from that partition.  The slow mode"
-msgstr ""
-"das Programm im langsamen Modus nicht funktioniert. Andere Prozesse können "
+msgstr "das Programm im langsamen Modus nicht funktioniert. Andere Prozesse können "
 #: ../raster/r.watershed/shed/com_line.c:37
 #, c-format
 msgid "will allow other processes to run concurrently with %s.\n"
-msgstr ""
-"gleichzeitig mit %s ausgeführt werden, wenn es im langsamen Modus ist.\n"
+msgstr "gleichzeitig mit %s ausgeführt werden, wenn es im langsamen Modus ist.\n"
 #: ../raster/r.watershed/shed/com_line.c:69
 #: ../raster/r.watershed/shed/com_line.c:182
@@ -17689,38 +16319,28 @@
 "Eine der Optionen für %s ist eine `Senkungskarte'. Eine "
 #: ../raster/r.watershed/shed/com_line.c:83
-msgid ""
-"depression map indicates all the locations in the current map window where"
+msgid "depression map indicates all the locations in the current map window where"
 msgstr "Senkungskarte zeigt alle Orte im aktuellen Fenster an wo "
 #: ../raster/r.watershed/shed/com_line.c:84
-msgid ""
-"water accumulates and does not leave by the edge of the map. Lakes without"
+msgid "water accumulates and does not leave by the edge of the map. Lakes without"
 msgstr "sich Wasser sammelt und nicht am Kartenrand austritt. Seen ohne "
 #: ../raster/r.watershed/shed/com_line.c:85
-msgid ""
-"outlet streams and sinkholes are examples of `depressions'.  If you wish to"
-msgstr ""
-"Auslassströmungen und Senklöcher sind Beispiele von 'Bodensenken'. Wenn Sie "
-"eine "
+msgid "outlet streams and sinkholes are examples of `depressions'.  If you wish to"
+msgstr "Auslassströmungen und Senklöcher sind Beispiele von 'Bodensenken'. Wenn Sie eine "
 #: ../raster/r.watershed/shed/com_line.c:86
 msgid "have a depression map, prepare a map where non-zero values indicate the"
-msgstr ""
-"Karte der Bodensenken wünschen, müssen Sie eine Karte vorbereiten, in der "
-"die Nicht-Null Zellen "
+msgstr "Karte der Bodensenken wünschen, müssen Sie eine Karte vorbereiten, in der die Nicht-Null Zellen "
 #: ../raster/r.watershed/shed/com_line.c:87
 msgid "locations where depressions occur.\n"
 msgstr "Orte anzeigen an denen Senken vorkommen.\n"
 #: ../raster/r.watershed/shed/com_line.c:88
-msgid ""
-"Hit <return> by itself for the next question if there is no depression map."
-msgstr ""
-"Drücke <return> für die nächste Frage, wenn es keine Karte der Bodensenken "
-"gibt."
+msgid "Hit <return> by itself for the next question if there is no depression map."
+msgstr "Drücke <return> für die nächste Frage, wenn es keine Karte der Bodensenken gibt."
 #: ../raster/r.watershed/shed/com_line.c:99
 #, c-format
@@ -17732,79 +16352,50 @@
 "Das %s Programm wird die Höhenkarte in ein Anzahl von "
 #: ../raster/r.watershed/shed/com_line.c:101
-msgid ""
-"watershed basins.  The number of watershed basins is indirectly determined"
-msgstr ""
-"Einzugsgebiete unterteilen. Die Anzahl von Einzugsgebieten wird indirekt "
+msgid "watershed basins.  The number of watershed basins is indirectly determined"
+msgstr "Einzugsgebiete unterteilen. Die Anzahl von Einzugsgebieten wird indirekt "
 #: ../raster/r.watershed/shed/com_line.c:102
-msgid ""
-"by the `basin threshold' value.  The basin threshold is the area necessary "
-"for"
-msgstr ""
-"vom 'basin threshold' Wert festgelegt. Der 'basin threshold' ist die "
-"notwendige Fläche für "
+msgid "by the `basin threshold' value.  The basin threshold is the area necessary for"
+msgstr "vom 'basin threshold' Wert festgelegt. Der 'basin threshold' ist die notwendige Fläche für "
 #: ../raster/r.watershed/shed/com_line.c:103
 #, c-format
 msgid "%s to define a unique watershed basin.  This area only applies to"
-msgstr ""
-"%s um einzelne Einzugsgebiete zu definieren. Diese Fläche gilt nur für "
+msgstr "%s um einzelne Einzugsgebiete zu definieren. Diese Fläche gilt nur für "
 #: ../raster/r.watershed/shed/com_line.c:105
-msgid ""
-"`exterior drainage basins'.  An exterior drainage basin does not have any"
-msgstr ""
-"außenliegende Einzugsgebiete. Ein außenliegendes Einzugsgebiet hat keine "
-"anderen "
+msgid "`exterior drainage basins'.  An exterior drainage basin does not have any"
+msgstr "außenliegende Einzugsgebiete. Ein außenliegendes Einzugsgebiet hat keine anderen "
 #: ../raster/r.watershed/shed/com_line.c:106
-msgid ""
-"drainage basins flowing into it.  Interior drainage basin size is determined"
-msgstr ""
-"Einzugsgebiete die mit einfließen. Die Größe von Binneneinzugsgebieten ist "
-"festgelegt "
+msgid "drainage basins flowing into it.  Interior drainage basin size is determined"
+msgstr "Einzugsgebiete die mit einfließen. Die Größe von Binneneinzugsgebieten ist festgelegt "
 #: ../raster/r.watershed/shed/com_line.c:107
-msgid ""
-"by the surface flow going into stream segments between stream interceptions."
-msgstr ""
-"durch den Oberflächenabfluss, der in Flussabschnitten zwischen "
-"Stromunterbrechungen fließt. "
+msgid "by the surface flow going into stream segments between stream interceptions."
+msgstr "durch den Oberflächenabfluss, der in Flussabschnitten zwischen Stromunterbrechungen fließt. "
 #: ../raster/r.watershed/shed/com_line.c:108
 #, c-format
 msgid "Thus interior drainage basins can be of any size.  The %s program"
-msgstr ""
-"Daher können Binneneinzugsgebiete eine beliebige Größe haben. Das Programm "
-"%s "
+msgstr "Daher können Binneneinzugsgebiete eine beliebige Größe haben. Das Programm %s "
 #: ../raster/r.watershed/shed/com_line.c:110
 msgid "also allows the user to relate basin size to potential overland flow"
-msgstr ""
-"ermöglicht es dem Benutzer sogar die Behältergröße in Beziehung zum "
-"Oberflächenabfluss zu setzen "
+msgstr "ermöglicht es dem Benutzer sogar die Behältergröße in Beziehung zum Oberflächenabfluss zu setzen "
 #: ../raster/r.watershed/shed/com_line.c:111
-msgid ""
-"(i.e., areas with low infiltration capacities will need smaller areas to"
-msgstr ""
-"(z.B. Flächen mit niedriger Infiltrationskapazität brauchen kleinere Flächen "
-"um "
+msgid "(i.e., areas with low infiltration capacities will need smaller areas to"
+msgstr "(z.B. Flächen mit niedriger Infiltrationskapazität brauchen kleinere Flächen um "
 #: ../raster/r.watershed/shed/com_line.c:112
-msgid ""
-"develop stream channels than neighboring areas with high infiltration rates)."
-msgstr ""
-"Strömungskanäle zu entwickeln als benachbarte Flächen mit hohen "
-"Infiltrationsraten). "
+msgid "develop stream channels than neighboring areas with high infiltration rates)."
+msgstr "Strömungskanäle zu entwickeln als benachbarte Flächen mit hohen Infiltrationsraten). "
 #: ../raster/r.watershed/shed/com_line.c:113
-msgid ""
-"The user can create a map layer with potential overland flow values, and"
-msgstr ""
-"Der Benutzer kann eine Karte mit potentiellen Oerflächenabflusswerten "
-"generieren, und "
+msgid "The user can create a map layer with potential overland flow values, and"
+msgstr "Der Benutzer kann eine Karte mit potentiellen Oerflächenabflusswerten generieren, und "
 #: ../raster/r.watershed/shed/com_line.c:114
 #, c-format
@@ -17834,8 +16425,7 @@
 "How large an area (or how many overland flow units) must a drainage basin"
 msgstr ""
 "\n"
-"Welche Fläche (oder wie viele Oberflächenabfluss-Einheiten) muss ein "
-"Einzugsgebiet "
+"Welche Fläche (oder wie viele Oberflächenabfluss-Einheiten) muss ein Einzugsgebiet "
 #: ../raster/r.watershed/shed/com_line.c:132
 #, c-format
@@ -17916,9 +16506,7 @@
 #: ../raster/r.watershed/shed/com_line.c:292
 #, c-format
 msgid "%s to function (stream channels, overland flow aspect, and"
-msgstr ""
-"%s nicht unbedingt funktionieren müssen (Strömungskanäle, Oberflächenabfluss-"
-"Aspekt und "
+msgstr "%s nicht unbedingt funktionieren müssen (Strömungskanäle, Oberflächenabfluss-Aspekt und "
 #: ../raster/r.watershed/shed/com_line.c:294
 #, c-format
@@ -17926,11 +16514,8 @@
 msgstr "Bildschirmversion der Akkumulationskarte). %s hat auch die "
 #: ../raster/r.watershed/shed/com_line.c:296
-msgid ""
-"ability to generate several variables in the Revised Universal Soil Loss"
-msgstr ""
-"Möglichkeit in der verbesserten allgemeinen Bodenverlust Formel (Revised "
-"Universal Soil Loss Equation; Rusle) "
+msgid "ability to generate several variables in the Revised Universal Soil Loss"
+msgstr "Möglichkeit in der verbesserten allgemeinen Bodenverlust Formel (Revised Universal Soil Loss Equation; Rusle) "
 #: ../raster/r.watershed/shed/com_line.c:297
 msgid "Equation (Rusle): Slope Length (LS), and Slope Steepness (S).\n"
@@ -17947,17 +16532,11 @@
 #: ../raster/r.watershed/shed/com_line.c:349
 #, c-format
 msgid "disturbed land.  %s reflects this with an optional map layer or value"
-msgstr ""
-"gestörtem Boden. %s reflektiert das mit einer optionalen Karte oder einem "
-"Wert "
+msgstr "gestörtem Boden. %s reflektiert das mit einer optionalen Karte oder einem Wert "
 #: ../raster/r.watershed/shed/com_line.c:351
-msgid ""
-"where the value indicates the percent of disturbed (barren) land in that "
-"cell."
-msgstr ""
-"wobei der Wert den Prozentanteil von gestörtem (unfruchtbarem) Boden in der "
-"Zelle angibt. "
+msgid "where the value indicates the percent of disturbed (barren) land in that cell."
+msgstr "wobei der Wert den Prozentanteil von gestörtem (unfruchtbarem) Boden in der Zelle angibt. "
 #: ../raster/r.watershed/shed/com_line.c:352
 msgid "Type <return> if you do not have a disturbed land map layer."
@@ -17969,8 +16548,7 @@
 "Type the value indicating the percent of disturbed land.  This value will"
 msgstr ""
 "\n"
-"Geben Sie den Wert der den Prozentansatz von gestörtem Boden indiziert ein. "
-"Dieser Wert "
+"Geben Sie den Wert der den Prozentansatz von gestörtem Boden indiziert ein. Dieser Wert "
 #: ../raster/r.watershed/shed/com_line.c:365
 msgid "be used for every cell in the current region."
@@ -17991,8 +16569,7 @@
 "Overland surface flow only occurs for a set distance before swales form."
 msgstr ""
 "\n"
-"Oberflächenabfluss tritt nur für eine bestimmte Distanz auf bevor eine Senke "
-"entsteht. "
+"Oberflächenabfluss tritt nur für eine bestimmte Distanz auf bevor eine Senke entsteht. "
 #: ../raster/r.watershed/shed/com_line.c:380
 #, c-format
@@ -18002,12 +16579,10 @@
 #: ../raster/r.watershed/shed/com_line.c:382
 #, c-format
 msgid "these swales.  %s allows for an input (warning: kludge factor)"
-msgstr ""
-"Senken nicht aufnehmen. %s erlaubt eine Eingabe (Warnung: Kludge Faktor) "
+msgstr "Senken nicht aufnehmen. %s erlaubt eine Eingabe (Warnung: Kludge Faktor) "
 #: ../raster/r.watershed/shed/com_line.c:384
-msgid ""
-"that prevents the surface flow distance from getting too long.  Normally,"
+msgid "that prevents the surface flow distance from getting too long.  Normally,"
 msgstr "das verhindert dass die Distanz des Oberflächenabfluss zu lang wird. "
 #: ../raster/r.watershed/shed/com_line.c:385
@@ -18023,8 +16598,7 @@
 "Straßen, Gräben, Änderung in der Oberflächenabdeckung und andere Faktoren "
 #: ../raster/r.watershed/shed/com_line.c:401
-msgid ""
-"slope length.  You may input a raster map indicating the locations of these"
+msgid "slope length.  You may input a raster map indicating the locations of these"
 msgstr "begrenzen die Hanglänge. Eine Rasterkarte mit den Standorten dieser "
 #: ../raster/r.watershed/shed/com_line.c:402
@@ -18032,11 +16606,8 @@
 msgstr "blockierenden Faktoren sollte angegeben werden.\n"
 #: ../raster/r.watershed/shed/com_line.c:403
-msgid ""
-"Hit <return> by itself for the next question if there is no blocking map."
-msgstr ""
-"Drücke <return> für die nächste Frage wenn es keine Karte der Blockierungen "
-"gibt. "
+msgid "Hit <return> by itself for the next question if there is no blocking map."
+msgstr "Drücke <return> für die nächste Frage wenn es keine Karte der Blockierungen gibt. "
 #: ../raster/r.watershed/shed/read.c:23
 msgid "unable to open basin/half basin map"
@@ -18045,8 +16616,7 @@
 #: ../raster/r.watershed/shed/intro.c:8
 #, c-format
 msgid "%s provides a text-based user-interface to the %s program."
-msgstr ""
-"%s erstellt eine textbasierte Benutzerschnittstelle für das %s Programm. "
+msgstr "%s erstellt eine textbasierte Benutzerschnittstelle für das %s Programm. "
 #: ../raster/r.watershed/shed/intro.c:10
 #, c-format
@@ -18071,9 +16641,7 @@
 #: ../raster/r.watershed/shed/intro.c:18
 #, c-format
 msgid "divided by basin. %s will then run %s and create the report."
-msgstr ""
-"von Behältern getrennt werden. %s wird dann %s starten und einen Bericht "
-"erstellen. "
+msgstr "von Behältern getrennt werden. %s wird dann %s starten und einen Bericht erstellen. "
 #: ../raster/r.watershed/shed/basin_maps.c:12
 msgid ""
@@ -18083,8 +16651,7 @@
 msgstr ""
 "\n"
 "\n"
-"Bitte geben Sie an welche Karten verwendet werden sollen in dem "
-"konzentrierten "
+"Bitte geben Sie an welche Karten verwendet werden sollen in dem konzentrierten "
 #: ../raster/r.watershed/shed/basin_maps.c:13
 msgid "parameter hydrologic/soil erosion model.  Continue inputing cell map"
@@ -18123,15 +16690,11 @@
 #: ../raster/r.watershed/shed/basin_maps.c:39
 msgid "1) by only including data pertaining to the basin itself, or 2) using"
-msgstr ""
-"1) es werden nur die Daten beigefügt die nur das Gebiet selbst betreffen, "
-"oder 2) "
+msgstr "1) es werden nur die Daten beigefügt die nur das Gebiet selbst betreffen, oder 2) "
 #: ../raster/r.watershed/shed/basin_maps.c:40
 msgid "data from the basin, and all basins upstream of it."
-msgstr ""
-"es werden die Daten zum jeweiligen Gebiet und allen stromaufwärts gelegenen "
-"verwendet. "
+msgstr "es werden die Daten zum jeweiligen Gebiet und allen stromaufwärts gelegenen verwendet. "
 #: ../raster/r.watershed/shed/basin_maps.c:43
 msgid ""
@@ -18206,9 +16769,7 @@
 #: ../raster/r.watershed/seg/do_cum.c:385
 #, c-format
 msgid "MFD: A * path already processed when distributing flow: %d of %d cells"
-msgstr ""
-"MFD: A * Pfad schon verarbeitet bei der Verteilung der Flüsse: %d von %d "
-"Zellen"
+msgstr "MFD: A * Pfad schon verarbeitet bei der Verteilung der Flüsse: %d von %d Zellen"
 #: ../raster/r.watershed/ram/sg_factor.c:13
 #: ../raster/r.watershed/seg/sg_factor.c:12
@@ -18251,38 +16812,22 @@
 #, c-format
 msgid ""
 "USAGE for basin delineation:\n"
-"%s -4 el=elevation_map t=swale_threshold [ov=overland_flow_map] "
-"[dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] "
-"[di=display_map] ba=watershed_basin_map [se=stream_segment_map]\n"
+"%s -4 el=elevation_map t=swale_threshold [ov=overland_flow_map] [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] ba=watershed_basin_map [se=stream_segment_map]\n"
 "\n"
 "USAGE for ARMSED FILE creation:\n"
-"%s [-4] el=elevation_map t=swale_threshold [ov=overland_flow_map] "
-"[di=display_map] [ba=watershed_basin_map] [se=stream_segment_map] "
-"ha=half_basin_map ar=ARMSED_file_name\n"
+"%s [-4] el=elevation_map t=swale_threshold [ov=overland_flow_map] [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] [ba=watershed_basin_map] [se=stream_segment_map] ha=half_basin_map ar=ARMSED_file_name\n"
 "\n"
 "USAGE for slope length determination:\n"
-"%s [-4] el=elevation_map t=swale_threshold [dr=drain_direction_map] "
-"[de=depression_map] [ac=accumulation_map] [di=display_map] "
-"[ms=max_slope_length] [ob=overland_blocking_map] [S=slope_steepness_map] "
-"LS=length_slope_map [r=rill_erosion_map] [sd=slope_deposition value or map]"
+"%s [-4] el=elevation_map t=swale_threshold [dr=drain_direction_map] [de=depression_map] [ac=accumulation_map] [di=display_map] [ms=max_slope_length] [ob=overland_blocking_map] [S=slope_steepness_map] LS=length_slope_map [r=rill_erosion_map] [sd=slope_deposition value or map]"
 msgstr ""
 "VERWENDUNG für Einzugsgebietskartierung:\n"
 "\n"
 "VERWENDUNG für ARMSED-Datei Erzeugung:\n"
 "\n"
 "VERWENDUNG für Hanglängenberechnung:\n"
 #: ../raster/r.watershed/ram/do_astar.c:26
 #: ../raster/r.watershed/seg/do_astar.c:30
@@ -18349,11 +16894,8 @@
 msgstr "ABSCHNITT 1 Beginne: Initialisiere Variablen. %d Abschnitte insgesamt."
 #: ../raster/r.watershed/seg/init_vars.c:150
-msgid ""
-"Maximum memory to be used was smaller than 3 MB, set to default = 300 MB."
-msgstr ""
-"Maximal verwendbarer Speicher war kleiner als 3 MB; Setze es auf den "
-"Standardwert 300 MB."
+msgid "Maximum memory to be used was smaller than 3 MB, set to default = 300 MB."
+msgstr "Maximal verwendbarer Speicher war kleiner als 3 MB; Setze es auf den Standardwert 300 MB."
 #: ../raster/r.watershed/front/main.c:57
 msgid "Watershed basin analysis program."
@@ -18361,105 +16903,91 @@
 #: ../raster/r.watershed/front/main.c:61
 msgid "Input map: elevation on which entire analysis is based"
-msgstr ""
-"Eingabekarte mit Höheninformationen, welche die Grundlage der gesamten "
-"Analyse ist."
+msgstr "Eingabekarte: Höheninformationen für die Analyse"
 #: ../raster/r.watershed/front/main.c:66
 msgid "Input map: locations of real depressions"
-msgstr "Eingabekarte mit Orten realer Senken im Gebiet."
+msgstr "Eingabekarte: Orte realer Senken"
 #: ../raster/r.watershed/front/main.c:72
 msgid "Input map: amount of overland flow per cell"
-msgstr "Eingabekarte mit der Größe des Oberflächenabfluss pro Zelle."
+msgstr "Eingabekarte: Größe des Oberflächenabfluss pro Zelle"
 #: ../raster/r.watershed/front/main.c:79
 msgid "Input map or value: percent of disturbed land, for USLE"
-msgstr "Eingabekarte oder Wert: Prozent von gestörtem Land, (für ABAG/USLE)."
+msgstr "Eingabekarte oder Wert: Prozent von gestörtem Land, für USLE"
 #: ../raster/r.watershed/front/main.c:88
-#, fuzzy
 msgid "Name of input raster map blocking overland surface flow"
-msgstr ""
-"Eingabekarte mit Gelände, dass den Oberflächenabfluss blockiert, für USLE."
+msgstr "Eingabe-Rasterkarte: Flächen die Oberflächenabfluss blockieren"
 #: ../raster/r.watershed/front/main.c:90
 msgid "Input map: terrain blocking overland surface flow, for USLE"
-msgstr ""
+msgstr "Eingabekarte: Gelände, dass den Oberflächenabfluss blockiert, für USLE"
 #: ../raster/r.watershed/front/main.c:96
-#, fuzzy
 msgid "Name for output accumulation raster map"
-msgstr "Name der Ausgabe-Expositions-Rasterkarte."
+msgstr "Name der Ausgabe-Akkumulations-Rasterkarte."
 #: ../raster/r.watershed/front/main.c:98
 msgid "Output map: number of cells that drain through each cell"
-msgstr "Ausgabekarte mit Anzahl der Zellen, die durch jede Zelle abfließt."
+msgstr "Ausgabekarte: Anzahl der Zellen, die durch jede Zelle abfließt"
 #: ../raster/r.watershed/front/main.c:104
 msgid "Output map: drainage direction"
-msgstr "Ausgabekarte mit Abflussrichtung."
+msgstr "Ausgabekarte: Abflussrichtung"
 #: ../raster/r.watershed/front/main.c:111
-#, fuzzy
 msgid "Output map: basins raster map"
-msgstr "Ausgabe-Expositionskarte."
+msgstr "Ausgabe-Rasterkarte: Einzugsgebiete"
 #: ../raster/r.watershed/front/main.c:117
 msgid "Output map: stream segments"
-msgstr "Ausgabekarte der Flußsegmente. "
+msgstr "Ausgabekarte: Flusssegmente"
 #: ../raster/r.watershed/front/main.c:124
-#, fuzzy
 msgid "Output map: half basins raster map"
-msgstr "Name der Ausgabe-Rasterkarte, die Höheninformationen enthält."
+msgstr "Ausgabe-Rasterkarte: Halbe Einzugsgebiete"
 #: ../raster/r.watershed/front/main.c:131
 msgid "Output map: useful for visual display of results"
-msgstr "Ausgabekarte: hilfreich für die visuelle Darstellung der Ergebnisse."
+msgstr "Ausgabekarte: Hilfreich für visuelle Darstellung der Ergebnisse"
 #: ../raster/r.watershed/front/main.c:137
-#, fuzzy
 msgid "Name for output slope length raster map"
-msgstr "Name der Ausgabe-Neigungs-Rasterkarte."
+msgstr "Name der Ausgabe-Neigungslängen-Rasterkarte"
 #: ../raster/r.watershed/front/main.c:139
 msgid "Output map: slope length and steepness (LS) factor for USLE"
-msgstr "Ausgabekarte der Hanglängen und -Neigungsfaktoren (LS) für USLE."
+msgstr "Ausgabekarte: Hanglängen und -Neigungsfaktoren (LS) für USLE."
 #: ../raster/r.watershed/front/main.c:145
-#, fuzzy
 msgid "Name for output slope steepness raster map"
+msgstr "Name der Ausgabe-Neigungs-Rasterkarte"
 #: ../raster/r.watershed/front/main.c:146
-#, fuzzy
 msgid "Output map: Slope steepness (S) factor for USLE"
-msgstr "Ausgabekarte der Hangneigungsfaktoren (S) für USLE."
+msgstr "Ausgabekarte: Hangneigungsfaktoren (S) für USLE"
 #: ../raster/r.watershed/front/main.c:153
 msgid "Input value: minimum size of exterior watershed basin"
-msgstr "Eingabewert: kleinste Größe des äußeren Wassereinzugsgebiets."
+msgstr "Eingabewert: Minimale Größe des äußeren Wassereinzugsgebiets"
 #: ../raster/r.watershed/front/main.c:161
 msgid "Input value: maximum length of surface flow, for USLE"
-msgstr "Eingabewert: maximale Länge des Oberflächenabflusses für USLE."
+msgstr "Eingabewert: Maximale Länge des Oberflächenabflusses für USLE"
 #: ../raster/r.watershed/front/main.c:171
 msgid "Convergence factor for MFD (1-10)"
-msgstr "Umrechnungsfaktor für MFD (1-10)."
+msgstr "Umrechnungsfaktor für MFD (1-10)"
 #: ../raster/r.watershed/front/main.c:173
 msgid "1 = most diverging flow, 10 = most converging flow. Recommended: 5"
-msgstr ""
-"1 = der am meisten divergierende Fluss, 10 = der am meisten konvergierende "
-"Fluss. Empfohlen: 5."
+msgstr "1 = am meisten divergierende Fluss, 10 = am meisten konvergierende Fluss. Empfohlen: 5"
 #: ../raster/r.watershed/front/main.c:180
 msgid "Maximum memory to be used with -m flag (in MB)"
-msgstr ""
-"Maximal zu verwendender Speicher in Verbindung mit dem Schalter -m (in MB)."
+msgstr "Maximal zu verwendender Speicher in Verbindung mit dem Schalter -m (in MB)."
 #: ../raster/r.watershed/front/main.c:184
 msgid "Enable MFD flow (default is SFD (D8))"
@@ -18478,25 +17006,16 @@
 msgstr "Schalte Auslagerung auf Festplatte an: Operation ist langsam."
 #: ../raster/r.watershed/front/main.c:198
-msgid ""
-"Only needed if memory requirements exceed available RAM; see manual on how "
-"to calculate memory requirements"
-msgstr ""
-"Nur benötigt wenn die Speicheranforderungen den vorhandenen Arbeitsspeicher "
-"überschreiten. Schlagen Sie im Handbuch nach wie die Speicheranforderungen "
-"berechnet werden."
+msgid "Only needed if memory requirements exceed available RAM; see manual on how to calculate memory requirements"
+msgstr "Nur benötigt wenn die Speicheranforderungen den vorhandenen Arbeitsspeicher überschreiten. Schlagen Sie im Handbuch nach wie die Speicheranforderungen berechnet werden."
 #: ../raster/r.watershed/front/main.c:203
 msgid "Use positive flow accumulation even for likely underestimates"
-msgstr ""
-"Verwende positive Flussakkumulation, auch für vorraussichtliche "
-"Unterschätzungen."
+msgstr "Verwende positive Flussakkumulation, auch für vorraussichtliche Unterschätzungen."
 #: ../raster/r.watershed/front/main.c:205
 msgid "See manual for a detailed description of flow accumulation output"
-msgstr ""
-"Siehe Handbuch für detaillierte Beschreibung der Ausgabe der "
-"Flussakkumulation."
+msgstr "Siehe Handbuch für detaillierte Beschreibung der Ausgabe der Flussakkumulation."
 #: ../raster/r.watershed/front/main.c:222
 msgid "Sorry, you must choose an output map."
@@ -18519,26 +17038,11 @@
 #: ../raster/r.horizon/main.c:180
 msgid "Horizon angle computation from a digital elevation model."
-msgstr ""
-"Berechnung des Horizontwinkel auf Grundlage eines digitalen Höhenmodells."
+msgstr "Berechnung des Horizontwinkel auf Grundlage eines digitalen Höhenmodells."
 #: ../raster/r.horizon/main.c:182
-msgid ""
-"Computes horizon angle height from a digital elevation model. The module has "
-"two different modes of operation:  1. Computes the entire horizon around a "
-"single point whose coordinates are given with the 'coord' option. The "
-"horizon height (in radians). 2. Computes one or more raster maps of the "
-"horizon height in a single direction.  The input for this is the angle (in "
-"degrees), which is measured  counterclockwise with east=0, north=90 etc. The "
-"output is the horizon height in radians."
-msgstr ""
-"Berechnet Horizontwinkelhöhe auf Grundlage eines digitalen Höhenmodells. "
-"Dies Modul hat zwei verschiedende Betriebsarten:  1. Berechnet den gesamten "
-"Horizont um einen Punkt, dessen Koordinaten mit der Option 'coord' angegeben "
-"wurden. Die Horizonthöhe wird im Bogenmaß ausgegeben.  2. Berechnet eine "
-"oder mehr Rasterkarten der Horizonthöhe in einer Richtung. Eingabe dafür ist "
-"der Winkel [Grad] gemessen gegen den Uhrzeigersinn mit Osten=0, Norden=90 "
-"etc. Die Ausgabe ist die Horizonthöhe im Bogenmaß. "
+msgid "Computes horizon angle height from a digital elevation model. The module has two different modes of operation:  1. Computes the entire horizon around a single point whose coordinates are given with the 'coord' option. The horizon height (in radians). 2. Computes one or more raster maps of the horizon height in a single direction.  The input for this is the angle (in degrees), which is measured  counterclockwise with east=0, north=90 etc. The output is the horizon height in radians."
+msgstr "Berechnet Horizontwinkelhöhe auf Grundlage eines digitalen Höhenmodells. Dies Modul hat zwei verschiedende Betriebsarten:  1. Berechnet den gesamten Horizont um einen Punkt, dessen Koordinaten mit der Option 'coord' angegeben wurden. Die Horizonthöhe wird im Bogenmaß ausgegeben.  2. Berechnet eine oder mehr Rasterkarten der Horizonthöhe in einer Richtung. Eingabe dafür ist der Winkel [Grad] gemessen gegen den Uhrzeigersinn mit Osten=0, Norden=90 etc. Die Ausgabe ist die Horizonthöhe im Bogenmaß. "
 #: ../raster/r.horizon/main.c:235
 msgid "Direction in which you want to know the horizon height"
@@ -18549,50 +17053,28 @@
 msgstr "Schrittgröße des Winkels für multidirektionalen Horizont [Grad]."
 #: ../raster/r.horizon/main.c:251
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer around the present "
-"region"
-msgstr ""
-"Für Horizont-Rasterkarten: Lese vom DGM einen extra Bufferbereich um die "
-"aktuelle Region herum ein."
+msgid "For horizon rasters, read from the DEM an extra buffer around the present region"
+msgstr "Für Horizont-Rasterkarten: Lese vom DGM einen extra Pufferbereich um die aktuelle Region herum ein."
 #: ../raster/r.horizon/main.c:259
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer eastward the present "
-"region"
-msgstr ""
-"Für Horizont-Rasterkarten: Lese vom DGM einen extra Bufferbereich östlich "
-"der aktuellen Region ein."
+msgid "For horizon rasters, read from the DEM an extra buffer eastward the present region"
+msgstr "Für Horizont-Rasterkarten: Lese vom DGM einen extra Pufferbereich östlich der aktuellen Region ein."
 #: ../raster/r.horizon/main.c:267
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer westward the present "
-"region"
-msgstr ""
-"Für Horizont-Rasterkarten: Lese vom DGM einen extra Bufferbereich westlich "
+msgid "For horizon rasters, read from the DEM an extra buffer westward the present region"
+msgstr "Für Horizont-Rasterkarten: Lese vom DGM einen extra Pufferbereich westlich der aktuellen Region ein."
 #: ../raster/r.horizon/main.c:275
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer northward the present "
-"region"
-msgstr ""
-"Für Horizont-Rasterkarten: Lese vom DGM einen extra Bufferbereich nördlich "
+msgid "For horizon rasters, read from the DEM an extra buffer northward the present region"
+msgstr "Für Horizont-Rasterkarten: Lese vom DGM einen extra Pufferbereich nördlich der aktuellen Region ein."
 #: ../raster/r.horizon/main.c:283
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer southward the present "
-"region"
-msgstr ""
-"Für Horizont-Rasterkarten: Lese vom DGM einen extra Bufferbereichsüdlich der "
-"aktuellen Region ein."
+msgid "For horizon rasters, read from the DEM an extra buffer southward the present region"
+msgstr "Für Horizont-Rasterkarten: Lese vom DGM einen extra Pufferbereichsüdlich der aktuellen Region ein."
 #: ../raster/r.horizon/main.c:291
 msgid "The maximum distance to consider when finding the horizon height"
-msgstr ""
-"Die maximale bei der Suche nach der Horizonthöhe zu berücksichtigende "
-"Distanz."
+msgstr "Die maximale bei der Suche nach der Horizonthöhe zu berücksichtigende Distanz."
 #: ../raster/r.horizon/main.c:300
 msgid "Prefix of the horizon raster output maps"
@@ -18616,8 +17098,7 @@
 #: ../raster/r.horizon/main.c:361
 msgid "You didn't specify a direction value or step size. Aborting."
-msgstr ""
-"Sie haben keine Wert für die Richtung oder Schrittgröße angegeben. Breche ab."
+msgstr "Sie haben keine Wert für die Richtung oder Schrittgröße angegeben. Breche ab."
 #: ../raster/r.horizon/main.c:366
 msgid "You didn't specify a horizon raster name. Aborting."
@@ -18629,23 +17110,23 @@
 #: ../raster/r.horizon/main.c:389
 msgid "Could not read bufferzone size. Aborting."
-msgstr "Konnte die Bufferzonengröße nicht lesen. Breche ab."
+msgstr "Konnte die Pufferzonengröße nicht lesen. Breche ab."
 #: ../raster/r.horizon/main.c:395
 msgid "Could not read east bufferzone size. Aborting."
-msgstr "Konnte die Ost-Bufferzonengröße nicht lesen. Breche ab."
+msgstr "Konnte die Ost-Pufferzonengröße nicht lesen. Breche ab."
 #: ../raster/r.horizon/main.c:401
 msgid "Could not read west bufferzone size. Aborting."
-msgstr "Konnte die West-Bufferzonengröße nicht lesen. Breche ab."
+msgstr "Konnte die West-Pufferzonengröße nicht lesen. Breche ab."
 #: ../raster/r.horizon/main.c:408
 msgid "Could not read south bufferzone size. Aborting."
-msgstr "Konnte die Süd-Bufferzonengröße nicht lesen. Breche ab."
+msgstr "Konnte die Süd-Pufferzonengröße nicht lesen. Breche ab."
 #: ../raster/r.horizon/main.c:417
 msgid "Could not read north bufferzone size. Aborting."
-msgstr "Konnte die Nord-Bufferzonengröße nicht lesen. Breche ab."
+msgstr "Konnte die Nord-Pufferzonengröße nicht lesen. Breche ab."
 #: ../raster/r.horizon/main.c:423
 msgid "Could not read maximum distance. Aborting."
@@ -18677,31 +17158,20 @@
 msgstr "Name der Eingabe-Rasterkarte mit Längengraden [Dezimalgrad]."
 #: ../raster/r.sun2/main.c:346
-msgid ""
-"Name of real-sky beam radiation coefficient (thick cloud) input raster map "
-"[0-1]"
-msgstr ""
-"Eingabe-Rasterkarte mit Koeffizient der direkten 'real-sky' "
-"Sonneneinstrahlung (dicke Wolken) [0-1]"
+msgid "Name of real-sky beam radiation coefficient (thick cloud) input raster map [0-1]"
+msgstr "Eingabe-Rasterkarte mit Koeffizient der direkten 'real-sky' Sonneneinstrahlung (dicke Wolken) [0-1]"
 #: ../raster/r.sun2/main.c:355
-msgid ""
-"Name of real-sky diffuse radiation coefficient (haze) input raster map [0-1]"
-msgstr ""
-"Eingabe-Rasterkarte mit dem Koeffizient der diffusen 'real-sky' "
-"Sonneneinstrahlung (Dunst) [0-1]."
+msgid "Name of real-sky diffuse radiation coefficient (haze) input raster map [0-1]"
+msgstr "Eingabe-Rasterkarte mit dem Koeffizient der diffusen 'real-sky' Sonneneinstrahlung (Dunst) [0-1]."
 #: ../raster/r.sun2/main.c:363
 msgid "The horizon information input map prefix"
 msgstr "Der Präfix, der Horizont-Informations-Eingabekarte."
 #: ../raster/r.sun2/main.c:425
-msgid ""
-"Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/"
-"irradiation raster map [Wh.m-2.day-1] (mode 2)"
-msgstr ""
-"Ausgabe der globalen (Gesamt-) Strahlungsintensität/-summe [W.m-2] (Modus 1) "
-"oder Rasterkarten der Strahlungsintensität/-summe [Wh.m-2.day-1] (Modus 2)."
+msgid "Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/irradiation raster map [Wh.m-2.day-1] (mode 2)"
+msgstr "Ausgabe der globalen (Gesamt-) Strahlungsintensität/-summe [W.m-2] (Modus 1) oder Rasterkarten der Strahlungsintensität/-summe [Wh.m-2.day-1] (Modus 2)."
 #: ../raster/r.sun2/main.c:487
 msgid "Read the input files in this number of chunks"
@@ -18709,9 +17179,7 @@
 #: ../raster/r.sun2/main.c:494
 msgid "Civil time zone value, if none, the time will be local solar time"
-msgstr ""
-"Wert der zivilen Zeitzone. Wennnicht angegeben wird die lokale Sonnenzeit "
-"verwendet."
+msgstr "Wert der zivilen Zeitzone. Wennnicht angegeben wird die lokale Sonnenzeit verwendet."
 #: ../raster/r.sun2/main.c:502 ../raster/r.regression.line/main.c:68
 #: ../vector/v.generalize/main.c:209
@@ -18729,9 +17197,7 @@
 #: ../raster/r.sun2/main.c:561
 msgid "You must give the longitude raster if you use civil time"
-msgstr ""
-"Sie müssen eine Rasterkarte mit Breitengraden angeben, wenn Sie zivile Zeit "
-"verwenden."
+msgstr "Sie müssen eine Rasterkarte mit Breitengraden angeben, wenn Sie zivile Zeit verwenden."
 #: ../raster/r.sun2/main.c:564
 msgid "Error reading civil time zone value"
@@ -18758,49 +17224,32 @@
 msgstr "Die Horizont-Schrittgröße muss größer sein als 0."
 #: ../raster/r.sun2/main.c:610
-msgid ""
-"If you use the horizon option you must also set the 'horizonstep' parameter."
-msgstr ""
-"Wenn Sie die Option 'horizon' verwenden, müssen Sie auch den 'horizonstep'-"
-"Parameter angeben."
+msgid "If you use the horizon option you must also set the 'horizonstep' parameter."
+msgstr "Wenn Sie die Option 'horizon' verwenden, müssen Sie auch den 'horizonstep'-Parameter angeben."
 #: ../raster/r.sun2/main.c:616
 msgid "Time and insol_time are incompatible options"
 msgstr "Time und insol_time sind nicht kompatible Optionen."
 #: ../raster/r.sun2/main.c:618
-msgid ""
-"Mode 1: instantaneous solar incidence angle & irradiance using a set local "
-"time"
-msgstr ""
-"Modus 1: momentaner Sonneneinfallswinkel & Strahlungsintensität bei "
-"bekannter lokaler Zeit"
+msgid "Mode 1: instantaneous solar incidence angle & irradiance using a set local time"
+msgstr "Modus 1: momentaner Sonneneinfallswinkel & Strahlungsintensität bei bekannter lokaler Zeit"
 #: ../raster/r.sun2/main.c:671
 msgid "If you use -s and no horizon rasters, numpartitions must be =1"
-msgstr ""
-"Wenn sie -s und keine Horizont-Rasterkarte verwenden, muss numpartitions=1 "
-"sein."
+msgstr "Wenn sie -s und keine Horizont-Rasterkarte verwenden, muss numpartitions=1 sein."
 #: ../raster/r.sun2/main.c:683
-msgid ""
-"If you want to save memory and to use shadows, you must use pre-calculated "
-"horizons."
-msgstr ""
-"Wenn Sie Speicher sparen und Schatten verwenden wollen, müssen Sie einen "
-"vorher berechneten Horizont verwenden."
+msgid "If you want to save memory and to use shadows, you must use pre-calculated horizons."
+msgstr "Wenn Sie Speicher sparen und Schatten verwenden wollen, müssen Sie einen vorher berechneten Horizont verwenden."
 #: ../raster/r.sun2/main.c:750
 msgid "latin and longin raster maps have no effect when in a Lat/Lon location"
-msgstr ""
-"Die Rasterkarten latin und longin haben kein Effekt in einer Lat/Lon "
-"Location."
+msgstr "Die Rasterkarten latin und longin haben kein Effekt in einer Lat/Lon Location."
 #: ../raster/r.sun2/main.c:755
 msgid "Both latin and longin raster maps must be given, or neither"
-msgstr ""
-"Entweder müssen die beiden Rasterkarten latin und longin oder keine von "
-"beiden angegeben werden."
+msgstr "Entweder müssen die beiden Rasterkarten latin und longin oder keine von beiden angegeben werden."
 #: ../raster/r.sun2/main.c:949
 #, c-format
@@ -18813,16 +17262,8 @@
 msgstr "Raster, Feuer"
 #: ../raster/wildfire/r.ros/main.c:214
-msgid ""
-"Generates three, or four raster map layers showing 1) the base "
-"(perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the "
-"direction of the maximum ROS, and optionally 4) the maximum potential "
-"spotting distance."
-msgstr ""
-"Erstellt drei oder vier Rasterkarten, die 1) die Basisrate der "
-"(rechtwinkligen) Ausbreitungsgeschwindigkeit, 2) die maximale (Vorwärts-) "
-"Geschwindigkeit, 3) die Richtung der größten Ausbreitungsgeschwindigkeit und "
-"optional 4) die maximale Entdeckungsentfernung."
+msgid "Generates three, or four raster map layers showing 1) the base (perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the direction of the maximum ROS, and optionally 4) the maximum potential spotting distance."
+msgstr "Erstellt drei oder vier Rasterkarten, die 1) die Basisrate der (rechtwinkligen) Ausbreitungsgeschwindigkeit, 2) die maximale (Vorwärts-) Geschwindigkeit, 3) die Richtung der größten Ausbreitungsgeschwindigkeit und optional 4) die maximale Entdeckungsentfernung."
 #: ../raster/wildfire/r.ros/main.c:224
 msgid "Name of raster map containing fuel MODELs"
@@ -18830,29 +17271,23 @@
 #: ../raster/wildfire/r.ros/main.c:231
 msgid "Name of raster map containing the 1-HOUR fuel MOISTURE (%)"
-msgstr ""
-"Name der Rasterkarte mit den 1-Stunden-Brennmaterialfeuchtigkeiten [%]."
+msgstr "Name der Rasterkarte mit den 1-Stunden-Brennmaterialfeuchtigkeiten [%]."
 #: ../raster/wildfire/r.ros/main.c:238
 msgid "Name of raster map containing the 10-HOUR fuel MOISTURE (%)"
-msgstr ""
-"Name der Rasterkarte mit den 10-Stunden-Brennmaterialfeuchtigkeiten [%]."
+msgstr "Name der Rasterkarte mit den 10-Stunden-Brennmaterialfeuchtigkeiten [%]."
 #: ../raster/wildfire/r.ros/main.c:245
 msgid "Name of raster map containing the 100-HOUR fuel MOISTURE (%)"
-msgstr ""
-"Name der Rasterkarte mit den 100-Stunden-Brennmaterialfeuchtigkeiten [%]."
+msgstr "Name der Rasterkarte mit den 100-Stunden-Brennmaterialfeuchtigkeiten [%]."
 #: ../raster/wildfire/r.ros/main.c:253
 msgid "Name of raster map containing LIVE fuel MOISTURE (%)"
-msgstr ""
-"Name der Rasterkarte mit den aktuellen Brennmaterialfeuchtigkeiten [%]."
+msgstr "Name der Rasterkarte mit den aktuellen Brennmaterialfeuchtigkeiten [%]."
 #: ../raster/wildfire/r.ros/main.c:260
 msgid "Name of raster map containing midflame wind VELOCITYs (ft/min)"
-msgstr ""
-"Name der Rasterkarte mit Windgeschwindigkeiten auf mittlerer Flamenhöhe [ft/"
-"min]."
+msgstr "Name der Rasterkarte mit Windgeschwindigkeiten auf mittlerer Flamenhöhe [ft/min]."
 #: ../raster/wildfire/r.ros/main.c:267
 msgid "Name of raster map containing wind DIRECTIONs (degree)"
@@ -18864,15 +17299,11 @@
 #: ../raster/wildfire/r.ros/main.c:281
 msgid "Name of raster map containing ASPECT (degree, anti-clockwise from E)"
-msgstr ""
-"Name der Rasterkarte mit Expositionen [Grad, gegen den Uhrzeigersinn vom "
-"Osten]."
+msgstr "Name der Rasterkarte mit Expositionen [Grad, gegen den Uhrzeigersinn vom Osten]."
 #: ../raster/wildfire/r.ros/main.c:288
 msgid "Name of raster map containing ELEVATION (m) (required w/ -s)"
-msgstr ""
-"Name der Rasterkarte mit den Höheninformationen [m] (gefordert von dem "
-"Schalter -s)."
+msgstr "Name der Rasterkarte mit den Höheninformationen [m] (gefordert von dem Schalter -s)."
 #: ../raster/wildfire/r.ros/main.c:296
 msgid "Name of raster map to contain results (several new layers)"
@@ -18886,32 +17317,19 @@
 #: ../raster/wildfire/r.ros/main.c:428 ../raster/wildfire/r.ros/main.c:435
 #, c-format
 msgid "Raster map <%s> already exists in mapset <%s>, select another name"
-msgstr ""
-"Rasterkarte <%s> existiert bereits im Mapset <%s>, wählen Sie einen anderen "
-"Namen."
+msgstr "Rasterkarte <%s> existiert bereits im Mapset <%s>, wählen Sie einen anderen Namen."
 #: ../raster/wildfire/r.ros/main.c:636
 msgid "Percent Completed ... "
 msgstr "Prozent fertig..."
 #: ../raster/wildfire/r.spread/main.c:103
-msgid ""
-"Simulates elliptically anisotropic spread on a graphics window and generates "
-"a raster map of the cumulative time of spread, given raster maps containing "
-"the rates of spread (ROS), the ROS directions and the spread origins."
-msgstr ""
-"Simuliert elliptische anisotrophe Ausbreitung in einem Grafikfenster und "
-"erzeugt eine Rasterkarte mit der kumulativen Ausbreitungszeit. Als "
-"Ausgangskarten dienen die Ausbreitungsgeschwindigkeit, Ausbreitungsrichtung "
-"und der Ursprung."
+msgid "Simulates elliptically anisotropic spread on a graphics window and generates a raster map of the cumulative time of spread, given raster maps containing the rates of spread (ROS), the ROS directions and the spread origins."
+msgstr "Simuliert elliptische anisotrophe Ausbreitung in einem Grafikfenster und erzeugt eine Rasterkarte mit der kumulativen Ausbreitungszeit. Als Ausgangskarten dienen die Ausbreitungsgeschwindigkeit, Ausbreitungsrichtung und der Ursprung."
 #: ../raster/wildfire/r.spread/main.c:108
-msgid ""
-"It optionally produces raster maps to contain backlink UTM coordinates for "
-"tracing spread paths."
-msgstr ""
-"Dies erzeugt optional Rasterkarten mit 'backlink'-UTM-Koordinaten, um "
-"Ausbreitungspfade nachzuzeichnen."
+msgid "It optionally produces raster maps to contain backlink UTM coordinates for tracing spread paths."
+msgstr "Dies erzeugt optional Rasterkarten mit 'backlink'-UTM-Koordinaten, um Ausbreitungspfade nachzuzeichnen."
 #: ../raster/wildfire/r.spread/main.c:116
 #: ../raster/wildfire/r.spread/main.c:125
@@ -18925,56 +17343,39 @@
 #: ../raster/wildfire/r.spread/main.c:118
 msgid "Name of raster map containing MAX rate of spread (ROS) (cm/min)"
-msgstr ""
-"Name der Rasterkarte mit den maximalen Ausbreitungsgeschwindigkeiten [cm/"
-"min]."
+msgstr "Name der Rasterkarte mit den maximalen Ausbreitungsgeschwindigkeiten [cm/min]."
 #: ../raster/wildfire/r.spread/main.c:127
 msgid "Name of raster map containing DIRections of max ROS (degree)"
-msgstr ""
-"Name der Rasterkarte mit den Richtungen der Maximalen "
-"Ausbreitungsgeschwindigkeit [Grad]."
+msgstr "Name der Rasterkarte mit den Richtungen der Maximalen Ausbreitungsgeschwindigkeit [Grad]."
 #: ../raster/wildfire/r.spread/main.c:136
 msgid "Name of raster map containing BASE ROS (cm/min)"
-msgstr ""
-"Name der Rasterkarte mit der Grund-Ausbreitungsgeschwindigkeit [cm/min]."
+msgstr "Name der Rasterkarte mit der Grund-Ausbreitungsgeschwindigkeit [cm/min]."
 #: ../raster/wildfire/r.spread/main.c:145
 msgid "Name of raster map containing STARTing sources"
 msgstr "Name der Rasterkarte mit Startpunkten."
 #: ../raster/wildfire/r.spread/main.c:153
-msgid ""
-"Name of raster map containing max SPOTting DISTance (m) (required w/ -s)"
-msgstr ""
-"Name der Rasterkarte mit den maximalen Entdeckungsentfernungen [m] "
-"(gefordert von dem Schalter -s)."
+msgid "Name of raster map containing max SPOTting DISTance (m) (required w/ -s)"
+msgstr "Name der Rasterkarte mit den maximalen Entdeckungsentfernungen [m] (gefordert von dem Schalter -s)."
 #: ../raster/wildfire/r.spread/main.c:161
-msgid ""
-"Name of raster map containing midflame Wind SPEED (ft/min) (required w/ -s)"
-msgstr ""
-"min] (gefordert von dem Schalter -s)."
+msgid "Name of raster map containing midflame Wind SPEED (ft/min) (required w/ -s)"
+msgstr "Name der Rasterkarte mit Windgeschwindigkeiten auf mittlerer Flamenhöhe [ft/min] (gefordert von dem Schalter -s)."
 #: ../raster/wildfire/r.spread/main.c:169
-msgid ""
-"Name of raster map containing fine Fuel MOISture of the cell receiving a "
-"spotting firebrand (%) (required w/ -s)"
-msgstr ""
-"Name der Rasterkarte,mit den genauen Brennmaterialfeuchtigkeiten einer "
-"Zelle, die von einem Brand erreicht wird [%] (gefordert von dem Schalter -s)."
+msgid "Name of raster map containing fine Fuel MOISture of the cell receiving a spotting firebrand (%) (required w/ -s)"
+msgstr "Name der Rasterkarte,mit den genauen Brennmaterialfeuchtigkeiten einer Zelle, die von einem Brand erreicht wird [%] (gefordert von dem Schalter -s)."
 #: ../raster/wildfire/r.spread/main.c:177
 msgid "Basic sampling window SIZE needed to meet certain accuracy (3)"
-msgstr ""
-"Stichprobenrahmengröße, die für eine bestimmte Genauigkeit benötigt wird (3)."
+msgstr "Stichprobenrahmengröße, die für eine bestimmte Genauigkeit benötigt wird (3)."
 #: ../raster/wildfire/r.spread/main.c:184
 msgid "Sampling DENSity for additional COMPutin (range: 0.0 - 1.0 (0.5))"
-msgstr ""
-"Stichprobendichte für zusätzliche Berechnungen (Spanne: 0.0 - 1.0 (0.5))."
+msgstr "Stichprobendichte für zusätzliche Berechnungen (Spanne: 0.0 - 1.0 (0.5))."
 #: ../raster/wildfire/r.spread/main.c:191
 msgid "INITial TIME for current simulation (0) (min)"
@@ -18986,9 +17387,7 @@
 #: ../raster/wildfire/r.spread/main.c:205
 msgid "Name of raster map as a display backdrop"
-msgstr ""
-"Name der Rasterkarte, die als Hintergrundkarte im Grafikfenster benutzt "
-"werden soll."
+msgstr "Name der Rasterkarte, die als Hintergrundkarte im Grafikfenster benutzt werden soll."
 #: ../raster/wildfire/r.spread/main.c:212
 #: ../raster/wildfire/r.spread/main.c:220
@@ -19018,31 +17417,23 @@
 #: ../raster/wildfire/r.spread/main.c:243
 msgid "For wildfires: consider SPOTTING effect"
-msgstr ""
-"Bei nicht zu kontrollierenden Bränden (wildfire): beachte den Effekt der "
-"Entdeckung (Spotting-Effect)."
+msgstr "Bei nicht zu kontrollierenden Bränden (wildfire): beachte den Effekt der Entdeckung (Spotting-Effect)."
 #: ../raster/wildfire/r.spread/main.c:434
 msgid "Reading inputs..."
 msgstr "Lese Eingaben..."
 #: ../raster/wildfire/r.spreadpath/main.c:74
-msgid ""
-"Recursively traces the least cost path backwards to cells from which the "
-"cumulative cost was determined."
-msgstr ""
-"Das Modul verfolgt den kürzesten Weg rekursiv zurück zu den Zellen, von "
-"denen der kumulative Weg bestimmt wurde."
+msgid "Recursively traces the least cost path backwards to cells from which the cumulative cost was determined."
+msgstr "Das Modul verfolgt den kürzesten Weg rekursiv zurück zu den Zellen, von denen der kumulative Weg bestimmt wurde."
 #: ../raster/wildfire/r.spreadpath/main.c:83
 msgid "Name of raster map containing back-path easting information"
-msgstr ""
-"Name der Rasterkarte, die die Ost Informationen zu den Rückwegen enthält."
+msgstr "Name der Rasterkarte, die die Ost Informationen zu den Rückwegen enthält."
 #: ../raster/wildfire/r.spreadpath/main.c:91
 msgid "Name of raster map containing back-path northing information"
-msgstr ""
-"Name der Rasterkarte, die die Nord Informationen zu den Rückwegen enthält."
+msgstr "Name der Rasterkarte, die die Nord Informationen zu den Rückwegen enthält."
 #: ../raster/wildfire/r.spreadpath/main.c:99
 msgid "The map E and N grid coordinates of starting points"
@@ -19057,11 +17448,8 @@
 msgstr "Raster, Komposite"
 #: ../raster/r.composite/main.c:74
-msgid ""
-"Combines red, green and blue raster maps into a single composite raster map."
-msgstr ""
-"Kombiniert rote, grüne und blaue Rasterkarten zu einer zusammengesetzten "
-"Rasterkarte."
+msgid "Combines red, green and blue raster maps into a single composite raster map."
+msgstr "Kombiniert rote, grüne und blaue Rasterkarten zu einer zusammengesetzten Rasterkarte."
 #: ../raster/r.composite/main.c:88 ../raster/r.out.ppm3/main.c:65
 #, c-format
@@ -19118,22 +17506,17 @@
 #: ../raster/r.compress/main.c:123
 #, c-format
 msgid "[%s] is a reclass file of map <%s> in mapset <%s> - can't uncompress"
-msgstr ""
-"[%s] ist eine Reklassifikations-Datei von <%s> im Mapset <%s> - kann nicht "
-"dekomprimieren."
+msgstr "[%s] ist eine Reklassifikations-Datei von <%s> im Mapset <%s> - kann nicht dekomprimieren."
 #: ../raster/r.compress/main.c:125
 #, c-format
 msgid "[%s] is a reclass file of map <%s> in mapset <%s> - can't compress"
-msgstr ""
-"<%s> ist eine Reklassifikations-Datei von <%s> im Mapset <%s> - kann nicht "
-"komprimieren."
+msgstr "<%s> ist eine Reklassifikations-Datei von <%s> im Mapset <%s> - kann nicht komprimieren."
 #: ../raster/r.compress/main.c:130
 #, c-format
 msgid "[%s] is a GDAL-linked map - can't (un)compress"
-msgstr ""
-"[%s] ist eine per GDAL verknüpfte Karte  - kann nicht (de)komprimieren."
+msgstr "[%s] ist eine per GDAL verknüpfte Karte  - kann nicht (de)komprimieren."
 #: ../raster/r.compress/main.c:172
 #, c-format
@@ -19192,8 +17575,7 @@
 #: ../raster/r.out.png/r.out.png.c:128
 msgid "(0 = none, 1 = fastest, 9 = best)"
-msgstr ""
-"(0 = keine Kompression, 1 = schnellste Kompression, 9 = beste Kompression)"
+msgstr "(0 = keine Kompression, 1 = schnellste Kompression, 9 = beste Kompression)"
 #: ../raster/r.out.png/r.out.png.c:140
 msgid "Make NULL cells transparent"
@@ -19271,26 +17653,20 @@
 msgstr "Karte mit Werten für Y-Koeffizienten."
 #: ../raster/r.regression.line/main.c:59
-msgid ""
-"ASCII file for storing regression coefficients (output to screen if file not "
-"specified)."
-msgstr ""
-"ASCII-Datei n der die Regressionskoeffizienten gespeichert werden sollen "
-"(wenn keine angegeben wird erfolgt die Ausgabe auf dem Bildschirm)."
+msgid "ASCII file for storing regression coefficients (output to screen if file not specified)."
+msgstr "ASCII-Datei n der die Regressionskoeffizienten gespeichert werden sollen (wenn keine angegeben wird erfolgt die Ausgabe auf dem Bildschirm)."
 #: ../raster/r.grow.distance/main.c:150
-#, fuzzy
 msgid "Generates a raster map containing distances to nearest raster features."
-msgstr ""
-"Erzeugt eine Rasterkarte mit Distanzen zu Objekten in der Eingabekarte."
+msgstr "Erzeugt eine Rasterkarte mit Distanzen zu nächsten Raster-Objekten."
 #: ../raster/r.grow.distance/main.c:157
 msgid "Name for distance output map"
-msgstr "Name der Distanz-Ausgabekarte."
+msgstr "Name der Distanz-Ausgabekarte"
 #: ../raster/r.grow.distance/main.c:162
 msgid "Name for value output map"
-msgstr "Name der Wert-Ausgabekarte."
+msgstr "Name der Wert-Ausgabekarte"
 #: ../raster/r.grow.distance/main.c:174
 msgid "Output distances in meters instead of map units"
@@ -19358,15 +17734,11 @@
 #: ../raster/r.null/null.c:94
 msgid "Only do the work if the map doesn't have a NULL-value bitmap file"
-msgstr ""
-"Nur ausführen, wenn für die Karte noch keine NULL-Wert Bitmap Datei "
-"existiert."
+msgstr "Nur ausführen, wenn für die Karte noch keine NULL-Wert Bitmap Datei existiert."
 #: ../raster/r.null/null.c:100
 msgid "Create NULL-value bitmap file validating all data cells"
-msgstr ""
-"Erzeuge eine NULL-Wert Bitmap Datei, die alle Daten-Zellen für gültig "
-"erklärt."
+msgstr "Erzeuge eine NULL-Wert Bitmap Datei, die alle Daten-Zellen für gültig erklärt."
 #: ../raster/r.null/null.c:104
 msgid "Remove NULL-value bitmap file"
@@ -19374,13 +17746,8 @@
 #: ../raster/r.null/null.c:123
 #, c-format
-msgid ""
-"Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy "
-"with r.mapcalc. Exiting."
-msgstr ""
-"Die Rasterkarte <%s> ist eine reklassifizierte Version der Karte <%s@%s>. "
-"Bedenken Sie, dass es sinnvoll sein könnte eine Kopie mit r.mapcalc zu "
-"erzeugen. Beende mich."
+msgid "Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy with r.mapcalc. Exiting."
+msgstr "Die Rasterkarte <%s> ist eine reklassifizierte Version der Karte <%s@%s>. Bedenken Sie, dass es sinnvoll sein könnte eine Kopie mit r.mapcalc zu erzeugen. Beende mich."
 #: ../raster/r.null/null.c:129
 #, c-format
@@ -19465,8 +17832,7 @@
 #: ../raster/r.out.arc/main.c:92
 msgid "Use cell center reference in header instead of cell corner"
-msgstr ""
-"Verwende als Referenz im Header den Zellmittelpunkt anstelle der Zellecke."
+msgstr "Verwende als Referenz im Header den Zellmittelpunkt anstelle der Zellecke."
 #: ../raster/r.mapcalc/map3.c:124 ../raster/r.mapcalc/map3.c:138
 #: ../raster/r.mapcalc/map3.c:152 ../raster/r.out.bin/main.c:53
@@ -19650,9 +18016,7 @@
 #: ../raster/r.in.gdal/main.c:81
 msgid "Import GDAL supported raster file into a binary raster map layer."
-msgstr ""
-"Importiert Rasterdaten (aus Formaten die GDAL unterstützt) in eine GRASS "
-"Rasterkarte."
+msgstr "Importiert Rasterdaten (aus Formaten die GDAL unterstützt) in eine GRASS Rasterkarte."
 #: ../raster/r.in.gdal/main.c:87
 msgid "Raster file to be imported"
@@ -19668,9 +18032,7 @@
 #: ../raster/r.in.gdal/main.c:113
 msgid "Name of location to read projection from for GCPs transformation"
-msgstr ""
-"Name der Location, von der Projektionsinformationen für eine GCP-"
-"Transformation gelesen werden soll."
+msgstr "Name der Location, von der Projektionsinformationen für eine GCP-Transformation gelesen werden soll."
 #: ../raster/r.in.gdal/main.c:128 ../vector/v.in.ogr/main.c:186
 msgid "Name for new location to create"
@@ -19682,9 +18044,7 @@
 #: ../raster/r.in.gdal/main.c:176
 msgid "You have to specify a target location different from output location"
-msgstr ""
-"Sie müssen eine Ziel-Location angeben, die verschieden ist von der Ausgabe-"
-"Location."
+msgstr "Sie müssen eine Ziel-Location angeben, die verschieden ist von der Ausgabe-Location."
 #: ../raster/r.in.gdal/main.c:180
 msgid "The '-l' flag only works in Lat/Lon locations"
@@ -19700,52 +18060,28 @@
 msgstr "Die Rasterkarte <%s> existiert bereits und wird überschrieben"
 #: ../raster/r.in.gdal/main.c:247
-msgid ""
-"The polynomial rectification used in i.rectify does not work well with NOAA/"
-"AVHRR data. Try using gdalwarp with thin plate spline rectification instead. "
-"(-tps)"
-msgstr ""
-"Die polynomiale Rektifikation die von i.rectify verwendet wird funktioniert "
-"nicht gut für NOAA/AVHRR Daten. Versuchen Sie stattdessen gdalwarp mit der "
-"'thin plate spline rectification' (-tps)."
+msgid "The polynomial rectification used in i.rectify does not work well with NOAA/AVHRR data. Try using gdalwarp with thin plate spline rectification instead. (-tps)"
+msgstr "Die polynomiale Rektifikation die von i.rectify verwendet wird funktioniert nicht gut für NOAA/AVHRR Daten. Versuchen Sie stattdessen gdalwarp mit der 'thin plate spline rectification' (-tps)."
 #: ../raster/r.in.gdal/main.c:263
-msgid ""
-"Input raster map is flipped or rotated - cannot import. You may use "
-"'gdalwarp' to transform the map to North-up."
-msgstr ""
-"Die Eingabe-Rasterkarte wurde rotiert und kann daher nicht eingelesen "
-"werden. Sie können 'gdalwarp' verwenden, um die Karte zu transformieren, so "
-"dass Norden oben ist."
+msgid "Input raster map is flipped or rotated - cannot import. You may use 'gdalwarp' to transform the map to North-up."
+msgstr "Die Eingabe-Rasterkarte wurde rotiert und kann daher nicht eingelesen werden. Sie können 'gdalwarp' verwenden, um die Karte zu transformieren, so dass Norden oben ist."
 #: ../raster/r.in.gdal/main.c:305
-msgid ""
-"Map bounds have been constrained to geographic coordinates. You will almost "
-"certainly want to check map bounds and resolution with r.info and reset them "
-"with r.region before going any further."
-msgstr ""
-"Die Begrenzung ist an geographische Koordinaten gebunden. Eine Überprüfung "
-"der Begrenzung und Auflösung mit r.info und eine Anpassung mit r.region "
-"dieser Parameter ist für die weitere Berechnung empfehlenswert."
+msgid "Map bounds have been constrained to geographic coordinates. You will almost certainly want to check map bounds and resolution with r.info and reset them with r.region before going any further."
+msgstr "Die Begrenzung ist an geographische Koordinaten gebunden. Eine Überprüfung der Begrenzung und Auflösung mit r.info und eine Anpassung mit r.region dieser Parameter ist für die weitere Berechnung empfehlenswert."
 #: ../raster/r.in.gdal/main.c:325
-msgid ""
-"Unable to convert input map projection to GRASS format; cannot create new "
-"location."
-msgstr ""
-"Kann die Projektion der Eingabekarte nicht in das GRASS-Format konvertieren; "
-"erstelle daher keine neue Location."
+msgid "Unable to convert input map projection to GRASS format; cannot create new location."
+msgstr "Kann die Projektion der Eingabekarte nicht in das GRASS-Format konvertieren; erstelle daher keine neue Location."
 #: ../raster/r.in.gdal/main.c:438
 msgid ""
 "\n"
-"You can use the -o flag to r.in.gdal to override this check and use the "
-"location definition for the dataset.\n"
+"You can use the -o flag to r.in.gdal to override this check and use the location definition for the dataset.\n"
 msgstr ""
 "\n"
-"Sie können den Schalter '-o' von r.in.gdal verwenden, um die Prüfung der "
-"Projektion zu übersteuern und die Projektionsinformation der Location für "
-"diesen Datensatz zu verwenden.\n"
+"Sie können den Schalter '-o' von r.in.gdal verwenden, um die Prüfung der Projektion zu übersteuern und die Projektionsinformation der Location für diesen Datensatz zu verwenden.\n"
 #: ../raster/r.in.gdal/main.c:557
 #, c-format
@@ -19831,9 +18167,7 @@
 #: ../raster/r.in.ascii/gethead.c:169
 msgid "ignoring type filed in header, type is set on command line"
-msgstr ""
-"Ignoriere Feldtypen des Headers, da der Typ auf der Kommandozeile gesetzt "
-"wurde."
+msgstr "Ignoriere Feldtypen des Headers, da der Typ auf der Kommandozeile gesetzt wurde."
 #: ../raster/r.in.ascii/gethead.c:176
 msgid "illegal multiplier field: using 1.0"
@@ -19841,15 +18175,11 @@
 #: ../raster/r.in.ascii/gethead.c:181
 msgid "ignoring multiplier filed in header, multiplier is set on command line"
-msgstr ""
-"Ignoriere Multiplikator-Feld im Header, da der Multiplikator auf der "
-"Kommandozeile gesetzt wurde."
+msgstr "Ignoriere Multiplikator-Feld im Header, da der Multiplikator auf der Kommandozeile gesetzt wurde."
 #: ../raster/r.in.ascii/gethead.c:189
 msgid "ignoring null filed in header, null string is set on command line"
-msgstr ""
-"Ignoriere NULL-Feld im Header, da der NULL-Wert auf der Kommandozeile "
-"gesetzt wurde."
+msgstr "Ignoriere NULL-Feld im Header, da der NULL-Wert auf der Kommandozeile gesetzt wurde."
 #: ../raster/r.in.ascii/gethead.c:218
 msgid "error in ascii data format"
@@ -19869,11 +18199,8 @@
 msgstr "Konvertiert eine ASCII-Rasterdatei in eine (binäre) GRASS Rasterkarte."
 #: ../raster/r.in.ascii/main.c:74
-msgid ""
-"ASCII raster file to be imported. If not given reads from standard input"
-msgstr ""
-"ASCII-Datei, die importiert werden soll. Wenn nichts angegeben ist, wird von "
-"der Standardeingabe gelesen."
+msgid "ASCII raster file to be imported. If not given reads from standard input"
+msgstr "ASCII-Datei, die importiert werden soll. Wenn nichts angegeben ist, wird von der Standardeingabe gelesen."
 #: ../raster/r.in.ascii/main.c:100
 msgid "String representing NULL value data cell"
@@ -19914,12 +18241,8 @@
 msgstr "Kann nicht in die Datei schreiben."
 #: ../raster/r.average/main.c:53
-msgid ""
-"Finds the average of values in a cover map within areas assigned the same "
-"category value in a user-specified base map."
-msgstr ""
-"Findet den Durchschnitt der Werte in einer Überlagerungskarte innerhalb "
-"gleicher Kategorien in einer benutzer-angegebenen Ausgangskarte."
+msgid "Finds the average of values in a cover map within areas assigned the same category value in a user-specified base map."
+msgstr "Findet den Durchschnitt der Werte in einer Überlagerungskarte innerhalb gleicher Kategorien in einer benutzer-angegebenen Ausgangskarte."
 #: ../raster/r.average/main.c:66 ../raster/r.statistics/main.c:73
 msgid "Cover values extracted from the category labels of the cover map"
@@ -19959,12 +18282,8 @@
 msgstr "Raster, Zufall"
 #: ../raster/r.random/main.c:53
-msgid ""
-"Creates a raster map layer and vector point map containing randomly located "
-"points."
-msgstr ""
-"Erstellt eine Rasterkarte und eine Vektorkarte, die zufällig angeordnete "
-"Punkte enthalten."
+msgid "Creates a raster map layer and vector point map containing randomly located points."
+msgstr "Erstellt eine Rasterkarte und eine Vektorkarte, die zufällig angeordnete Punkte enthalten."
 #: ../raster/r.random/main.c:69
 msgid "The number of points to allocate"
@@ -20079,12 +18398,8 @@
 msgstr "Kann Vektor nicht lesen."
 #: ../raster/r.le/r.le.setup/main.c:63
-msgid ""
-"Interactive tool used to setup the sampling and analysis framework that will "
-"be used by the other r.le programs."
-msgstr ""
-"Interaktives Werkzeug zur Erzeugung eine Stichproben- und Analyse-Rahmens, "
-"der von den anderen r.le-Progammen verwendet wird. "
+msgid "Interactive tool used to setup the sampling and analysis framework that will be used by the other r.le programs."
+msgstr "Interaktives Werkzeug zur Erzeugung eine Stichproben- und Analyse-Rahmens, der von den anderen r.le-Progammen verwendet wird. "
 #: ../raster/r.le/r.le.setup/main.c:67
 msgid "Raster map to use to setup sampling"
@@ -20095,30 +18410,16 @@
 msgstr "Einzublendende Vektorkarte."
 #: ../raster/r.le/r.le.patch/main.c:49
-msgid ""
-"Calculates attribute, patch size, core (interior) size, shape, fractal "
-"dimension, and perimeter measures for sets of patches in a landscape."
-msgstr ""
-"Berechnet Attribute, Patch-Größe, Kerngebiets-Größe, Form, Fraktale "
-"Dimension und Umfang für ein Satz von Patches in einer Landschaft."
+msgid "Calculates attribute, patch size, core (interior) size, shape, fractal dimension, and perimeter measures for sets of patches in a landscape."
+msgstr "Berechnet Attribute, Patch-Größe, Kerngebiets-Größe, Form, Fraktale Dimension und Umfang für ein Satz von Patches in einer Landschaft."
 #: ../raster/r.le/r.le.trace/main.c:59
-msgid ""
-"Displays the boundary of each r.le patch and shows how the boundary is "
-"traced, displays the attribute, size, perimeter and shape indices for each "
-"patch and saves the data in an output file."
-msgstr ""
-"Zeigt die Grenzen aller r.le-Patches und wie die Grenze verfolgt wird. Zeigt "
-"außerdem die Attribute, Größe, Umfang und Form Indices jedes Patches und "
-"speichert die Daten in eine Ausgabedatei."
+msgid "Displays the boundary of each r.le patch and shows how the boundary is traced, displays the attribute, size, perimeter and shape indices for each patch and saves the data in an output file."
+msgstr "Zeigt die Grenzen aller r.le-Patches und wie die Grenze verfolgt wird. Zeigt außerdem die Attribute, Größe, Umfang und Form Indices jedes Patches und speichert die Daten in eine Ausgabedatei."
 #: ../raster/r.le/r.le.pixel/main.c:47
-msgid ""
-"Contains a set of measures for attributes, diversity, texture, "
-"juxtaposition, and edge."
-msgstr ""
-"Beinhaltet ein Satz von Maßen für Attribute, Diversität, Textur, "
-"Nebeneinanderstellung und Kanten"
+msgid "Contains a set of measures for attributes, diversity, texture, juxtaposition, and edge."
+msgstr "Beinhaltet ein Satz von Maßen für Attribute, Diversität, Textur, Nebeneinanderstellung und Kanten"
 #: ../raster/r.region/main.c:56
 msgid "Sets the boundary definitions for a raster map."
@@ -20177,13 +18478,8 @@
 msgstr "Reklassifiziere Rasterkarte auf Basis des Kategoriewerte."
 #: ../raster/r.reclass/main.c:52
-#, fuzzy
-msgid ""
-"Creates a new raster map whose category values are based upon a "
-"reclassification of the categories in an existing raster map."
-msgstr ""
-"Erzeugt eine neue Karte, deren Kategoriewerte auf einer Reklassifikation der "
-"Kategorien einer existierenden Rasterkarte basieren."
+msgid "Creates a new raster map whose category values are based upon a reclassification of the categories in an existing raster map."
+msgstr "Erzeugt eine neue Rasterkarte, deren Kategoriewerte auf einer Reklassifikation der Kategorien einer existierenden Rasterkarte basieren."
 #: ../raster/r.reclass/main.c:57
 msgid "Raster map to be reclassified"
@@ -20205,8 +18501,7 @@
 #: ../raster/r.reclass/main.c:103
 #, c-format
 msgid "Enter rule(s), \"end\" when done, \"help\" if you need it\n"
-msgstr ""
-"Eingabe der Regeln, mit \"end\" beenden, \"help\" liefert eine Hilfe.\n"
+msgstr "Eingabe der Regeln, mit \"end\" beenden, \"help\" liefert eine Hilfe.\n"
 #: ../raster/r.reclass/main.c:105
 #, c-format
@@ -20294,9 +18589,7 @@
 msgstr "Einheiten"
 #: ../raster/r.report/parse.c:46
-msgid ""
-"mi;miles;me;meters;k;kilometers;a;acres;h;hectares;c;cell counts;p;percent "
-"cover"
+msgid "mi;miles;me;meters;k;kilometers;a;acres;h;hectares;c;cell counts;p;percent cover"
 msgstr "mi;Meilen;me;Meter;k;Kilometer;a;Acres;h;Hektar;c;Zellanzahl;p;Prozent"
 #: ../raster/r.report/parse.c:56
@@ -20325,8 +18618,7 @@
 #: ../raster/r.report/parse.c:91 ../raster/r.stats/main.c:136
 msgid "Number of fp subranges to collect stats from"
-msgstr ""
-"Anzahl der Kategoriewerte, für die Statistiken eingeholt werden sollen."
+msgstr "Anzahl der Kategoriewerte, für die Statistiken eingeholt werden sollen."
 #: ../raster/r.report/parse.c:99
 msgid "Suppress page headers"
@@ -20354,9 +18646,7 @@
 #: ../raster/r.report/parse.c:127 ../raster/r.stats/main.c:200
 msgid "Read fp map as integer (use map's quant rules)"
-msgstr ""
-"Lese Fließkommakarte als Integerkarte (benutze Quantisierungsregeln der "
-"Karte)."
+msgstr "Lese Fließkommakarte als Integerkarte (benutze Quantisierungsregeln der Karte)."
 #: ../raster/r.report/parse.c:170
 msgid "nsteps has to be > 0; using nsteps=255"
@@ -20386,8 +18676,7 @@
 #: ../raster/r.random.cells/init.c:40
 msgid "Random seed (SEED_MIN >= value >= SEED_MAX) (default [random])"
-msgstr ""
-"Zufälliger Startwert (SEED_MIN >= Wert >= SEED_MAX) (Standard [zufällig])."
+msgstr "Zufälliger Startwert (SEED_MIN >= Wert >= SEED_MAX) (Standard [zufällig])."
 #: ../raster/r.random.cells/init.c:93
 msgid "Distance must be >= 0.0"
@@ -20417,16 +18706,11 @@
 #: ../raster/r.proj.seg/main.c:214
 msgid "Print input map's bounds in the current projection and exit"
-msgstr ""
-"Gibt die Grenzen der Eingabekarte in der aktuellen Projektion aus und "
-"beendet sich."
+msgstr "Gibt die Grenzen der Eingabekarte in der aktuellen Projektion aus und beendet sich."
 #: ../raster/r.proj.seg/main.c:220
-msgid ""
-"Print input map's bounds in the current projection and exit (shell style)"
-msgstr ""
-"Gibt die Grenzen der Eingabekarte in der aktuellen Projektion im Shellskript-"
-"Format aus und beendet sich."
+msgid "Print input map's bounds in the current projection and exit (shell style)"
+msgstr "Gibt die Grenzen der Eingabekarte in der aktuellen Projektion im Shellskript-Format aus und beendet sich."
 #: ../raster/r.proj.seg/main.c:253
 msgid "Input and output locations are the same"
@@ -20438,14 +18722,8 @@
 msgstr "Eingabekarte <%s@%s> in Location <%s>:"
 #: ../raster/r.neighbors/main.c:110
-msgid ""
-"Makes each cell category value a function of the category values assigned to "
-"the cells around it, and stores new cell values in an output raster map "
-"layer."
-msgstr ""
-"Weist für jeden Zellenkategoriewert eine Funktion der umgebenden "
-"Kategoriewerte basierend auf einer Fenstergröße zu und erstellt neue "
-"Zellenwerte in einer Ausgabe-Rasterkarte."
+msgid "Makes each cell category value a function of the category values assigned to the cells around it, and stores new cell values in an output raster map layer."
+msgstr "Weist für jeden Zellenkategoriewert eine Funktion der umgebenden Kategoriewerte basierend auf einer Fenstergröße zu und erstellt neue Zellenwerte in einer Ausgabe-Rasterkarte."
 #: ../raster/r.neighbors/main.c:133
 msgid "Neighborhood operation"
@@ -20525,12 +18803,8 @@
 msgstr "Kann die aktuelle Region nicht bekommen."
 #: ../raster/r.flow/calc.c:413
-msgid ""
-"Construction of slope curves (flowlines), flowpath lengths, and flowline "
-"densities (upslope areas) from a raster digital elevation model (DEM)."
-msgstr ""
-"Erzeugt Hangkurven (flowlines), Fließlängen und Flussdichte (upslope areas) "
-"aus einem angegebenen digitalen Höhenmodell (DEM)."
+msgid "Construction of slope curves (flowlines), flowpath lengths, and flowline densities (upslope areas) from a raster digital elevation model (DEM)."
+msgstr "Erzeugt Hangkurven (flowlines), Fließlängen und Flussdichte (upslope areas) aus einem angegebenen digitalen Höhenmodell (DEM)."
 #: ../raster/r.flow/calc.c:451
 msgid "Input elevation raster map"
@@ -20578,17 +18852,11 @@
 #: ../raster/r.flow/calc.c:533
 msgid "You must select one or more output maps (flout, lgout, dsout)"
-msgstr ""
-"Es müssen eine oder mehrere Ausgabekarten ausgewählt werden (flout, lgout, "
-"dsout)."
+msgstr "Es müssen eine oder mehrere Ausgabekarten ausgewählt werden (flout, lgout, dsout)."
 #: ../raster/r.flow/calc.c:549
-msgid ""
-"lat/long projection not supported by r.flow. Please use 'r.watershed' for "
-"calculating flow accumulation."
-msgstr ""
-"Lat/Long Projection wird von r.flow nicht unterstützt. Bitte verwenden Sie "
-"'r.watershed' für die Berechnung der Fussakkumulation."
+msgid "lat/long projection not supported by r.flow. Please use 'r.watershed' for calculating flow accumulation."
+msgstr "Lat/Long Projection wird von r.flow nicht unterstützt. Bitte verwenden Sie 'r.watershed' für die Berechnung der Fussakkumulation."
 #: ../raster/r.flow/io.c:68
 #, c-format
@@ -20601,9 +18869,7 @@
 #: ../raster/r.flow/io.c:89
 msgid "Elevation file's resolution differs from current region resolution"
-msgstr ""
-"Auflösung der Höhenkarte unterscheidet sich von der Auflösung der aktuellen "
-"Region."
+msgstr "Auflösung der Höhenkarte unterscheidet sich von der Auflösung der aktuellen Region."
 #: ../raster/r.flow/io.c:101
 msgid "Reading input files: aspect"
@@ -20611,9 +18877,7 @@
 #: ../raster/r.flow/io.c:104
 msgid "Resolution of aspect file differs from current region resolution"
-msgstr ""
-"Auflösung der Expositionsdatei unterscheidet sich von der Auflösung der "
-"aktuellen Region"
+msgstr "Auflösung der Expositionsdatei unterscheidet sich von der Auflösung der aktuellen Region"
 #: ../raster/r.flow/io.c:118
 msgid "Reading input files: barrier"
@@ -20685,9 +18949,7 @@
 #: ../raster/r.flow/precomp.c:115
 #, c-format
 msgid "Resolution too unbalanced (%f x %f); please resample input map"
-msgstr ""
-"Auflösung ist zu unausgewogen (%f x %f); Bitte resamplen Sie die "
-"Eingabekarte."
+msgstr "Auflösung ist zu unausgewogen (%f x %f); Bitte resamplen Sie die Eingabekarte."
 #: ../raster/r.univar2/r3.univar_main.c:38
 msgid "3D Raster map used for zoning, must be of type CELL"
@@ -20714,12 +18976,8 @@
 msgstr "3D-Raster, Voxel, Statistik"
 #: ../raster/r.univar2/r3.univar_main.c:102
-msgid ""
-"Calculates univariate statistics from the non-null 3d cells of a raster3d "
-"map."
-msgstr ""
-"Berechnet univariate Statistiken der nicht-NULL 3D-Zellen einer 3D-"
-"Rasterkarte."
+msgid "Calculates univariate statistics from the non-null 3d cells of a raster3d map."
+msgstr "Berechnet univariate Statistiken der nicht-NULL 3D-Zellen einer 3D-Rasterkarte."
 #: ../raster/r.univar2/r3.univar_main.c:154
 #: ../raster/r.univar2/r3.univar_main.c:193 ../raster3d/r3.stats/main.c:618
@@ -20741,10 +18999,8 @@
 msgstr "Rasterkarte für Zonenbildung, muss vom Typ CELL sein"
 #: ../raster/r.univar2/r.univar_main.c:99
-msgid ""
-"Calculates univariate statistics from the non-null cells of a raster map."
-msgstr ""
-"Berechnet univariate Statistiken der nicht-NULL Zellen einer Rasterkarte."
+msgid "Calculates univariate statistics from the non-null cells of a raster map."
+msgstr "Berechnet univariate Statistiken der nicht-NULL Zellen einer Rasterkarte."
 #: ../raster/r.univar2/r.univar_main.c:274
 #: ../raster/r.univar2/r.univar_main.c:277
@@ -20785,12 +19041,8 @@
 msgstr "Raster, Farbtransformation"
 #: ../raster/r.his/main.c:65
-msgid ""
-"Generates red, green and blue raster map layers combining hue, intensity and "
-"saturation (HIS) values from user-specified input raster map layers."
-msgstr ""
-"Erzeugt rot, grün und blaue Rasterkarten durch Kombination des Farbtons, der "
-"Intensität und Sättigung (HIS) aus Eingabe-Rasterkarten."
+msgid "Generates red, green and blue raster map layers combining hue, intensity and saturation (HIS) values from user-specified input raster map layers."
+msgstr "Erzeugt rot, grün und blaue Rasterkarten durch Kombination des Farbtons, der Intensität und Sättigung (HIS) aus Eingabe-Rasterkarten."
 #: ../raster/r.his/main.c:95
 msgid "Name of output layer to be used for RED"
@@ -20853,9 +19105,7 @@
 #: ../raster/r.thin/main.c:57
 msgid "Thins non-zero cells that denote linear features in a raster map."
-msgstr ""
-"Dünnt Zellen die nicht null sind und linienhafte Strukturen in einer "
-"Rasterkarte abbilden."
+msgstr "Dünnt Zellen die nicht null sind und linienhafte Strukturen in einer Rasterkarte abbilden."
 #: ../raster/r.thin/main.c:69
 msgid "Maximal number of iterations"
@@ -20887,17 +19137,11 @@
 #: ../raster/r.thin/thin_lines.c:176
 msgid "Thinning not completed, consider to increase 'iterations' parameter."
-msgstr ""
-"Ausdünnung nicht vollständig. Es könnte sinnvoll sein den Wert des Parameter "
-"'iterations' zu erhöhen."
+msgstr "Ausdünnung nicht vollständig. Es könnte sinnvoll sein den Wert des Parameter 'iterations' zu erhöhen."
 #: ../raster/r.out.ppm3/main.c:59
-msgid ""
-"Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel "
-"resolution of the CURRENTLY DEFINED REGION."
-msgstr ""
-"Exportiert 3 GRASS Rasterkarten (R,G,B) als PPM-Bild mit der Pixel-Auflösung "
-"der DERZEITIG EINGESTELLTEN REGION."
+msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel resolution of the CURRENTLY DEFINED REGION."
+msgstr "Exportiert 3 GRASS Rasterkarten (R,G,B) als PPM-Bild mit der Pixel-Auflösung der DERZEITIG EINGESTELLTEN REGION."
 #: ../raster/r.out.ppm3/main.c:85
 msgid "Name for new PPM file. (use out=- for stdout)"
@@ -20932,12 +19176,8 @@
 msgstr "aufwärts Durchgang %d"
 #: ../raster/r.fill.dir/main.c:86
-msgid ""
-"Filters and generates a depressionless elevation map and a flow direction "
-"map from a given elevation raster map."
-msgstr ""
-"Filtert und generiert ein depressionsloses Höhenmodell und eine "
-"Fließrichtungskarte auf Basis eines gegebenen Höhenmodells."
+msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation raster map."
+msgstr "Filtert und generiert ein depressionsloses Höhenmodell und eine Fließrichtungskarte auf Basis eines gegebenen Höhenmodells."
 #: ../raster/r.fill.dir/main.c:91
 msgid "Name of existing raster map containing elevation surface"
@@ -20985,12 +19225,8 @@
 msgstr "Habe %d unaufgelöste Flächen gefunden."
 #: ../raster/r.surf.random/main.c:46
-msgid ""
-"Produces a raster map of uniform random deviates whose range can be "
-"expressed by the user."
-msgstr ""
-"Erzeugt eine Rasterkarte mit zufälligen Werten einer Gleichverteilung, deren "
-"Spanne vom Benutzer angegeben werden kann."
+msgid "Produces a raster map of uniform random deviates whose range can be expressed by the user."
+msgstr "Erzeugt eine Rasterkarte mit zufälligen Werten einer Gleichverteilung, deren Spanne vom Benutzer angegeben werden kann."
 #: ../raster/r.surf.random/main.c:53
 msgid "Minimum random value"
@@ -21009,17 +19245,12 @@
 msgstr "Bilineares Interpolationswerkzeug für Rasterkarten."
 #: ../raster/r.bilinear/main.c:54 ../raster/r.bilinear/main.c:61
-msgid ""
-"Specific input value to be assigned to the north and/or south poles for "
-"longitude-latitude grids"
-msgstr ""
-"Spezieller Eingabewert, der dem Nord- und/oder Südpol in Längen- und "
-"Breitengrad-Gittern zugewiesen wird."
+msgid "Specific input value to be assigned to the north and/or south poles for longitude-latitude grids"
+msgstr "Spezieller Eingabewert, der dem Nord- und/oder Südpol in Längen- und Breitengrad-Gittern zugewiesen wird."
 #: ../raster/r.bilinear/main.c:67
 msgid "This module is deprecated. Please use 'r.resamp.interp' instead."
-msgstr ""
-"Dies Moduls ist veraltet. Bitte verwenden Sie stattdessen 'r.resamp.interp'."
+msgstr "Dies Moduls ist veraltet. Bitte verwenden Sie stattdessen 'r.resamp.interp'."
 #: ../raster/r.quant/main.c:41
 msgid "raster, quantization"
@@ -21100,15 +19331,12 @@
 #: ../raster/r.colors/stats.c:79
 msgid "Unable to use logarithmic scaling if range includes zero"
-msgstr ""
-"Kann keine logarithmische Skala verwenden, wenn der Wertebereich Null "
-"enthält."
+msgstr "Kann keine logarithmische Skala verwenden, wenn der Wertebereich Null enthält."
 #: ../raster/r.colors/rules.c:42
 #, c-format
 msgid "Enter rules, \"end\" when done, \"help\" if you need it.\n"
-msgstr ""
 #: ../raster/r.colors/rules.c:51
 #, c-format
@@ -21126,8 +19354,7 @@
 "Your color rules do not cover the whole range of data!\n"
 " (rules %f to %f but data %f to %f)"
 msgstr ""
-"Die ausgewählten Farbregeln erstrecken sich nicht über den gesamten "
-"Wertebereich!\n"
+"Die ausgewählten Farbregeln erstrecken sich nicht über den gesamten Wertebereich!\n"
 "(Regelsatz: %f - %f aber Daten: %f - %f)"
 #: ../raster/r.colors/rules.c:107
@@ -21211,26 +19438,16 @@
 msgstr "Keine Rasterkarte angegeben."
 #: ../raster/r.colors/main.c:281
-msgid ""
-"One of \"-i\" or \"-r\" or options \"color\", \"rast\" or \"rules\" must be "
-"specified!"
-msgstr ""
-"Entweder \"-i\" oder \"-r\" oder eine der Optionen \"color\", \"rast\" oder "
-"\"rules\" muss angegeben werden!"
+msgid "One of \"-i\" or \"-r\" or options \"color\", \"rast\" or \"rules\" must be specified!"
+msgstr "Entweder \"-i\" oder \"-r\" oder eine der Optionen \"color\", \"rast\" oder \"rules\" muss angegeben werden!"
 #: ../raster/r.colors/main.c:284
-msgid ""
-"Interactive mode is incompatible with \"color\", \"rules\", and \"raster\" "
-"options"
-msgstr ""
-"Der interaktive Modus ist inkompatibel mit den Optionen \"color\", \"rules\" "
-"und \"raster\"."
+msgid "Interactive mode is incompatible with \"color\", \"rules\", and \"raster\" options"
+msgstr "Der interaktive Modus ist inkompatibel mit den Optionen \"color\", \"rules\" und \"raster\"."
 #: ../raster/r.colors/main.c:291
 msgid "\"color\", \"rules\", and \"raster\" options are mutually exclusive"
-msgstr ""
-"Die Optionen \"color\", \"rules\" und \"raster\" schliessen sich gegenseitig "
-"aus."
+msgstr "Die Optionen \"color\", \"rules\" und \"raster\" schliessen sich gegenseitig aus."
 #: ../raster/r.colors/main.c:302
 msgid "-g and -a flags are mutually exclusive"
@@ -21282,18 +19499,12 @@
 msgstr "Raster, Volumen"
 #: ../raster/r.volume/main.c:59
-msgid ""
-"Calculates the volume of data \"clumps\", and (optionally) produces a GRASS "
-"vector points map containing the calculated centroids of these clumps."
-msgstr ""
-"Berechnet das Volumen Daten-\"Klumpen\". Optional kann eine GRASS-"
-"Vektorkarte (Punkte) mit den Zentroiden der Datenklumpen erzeugt werden."
+msgid "Calculates the volume of data \"clumps\", and (optionally) produces a GRASS vector points map containing the calculated centroids of these clumps."
+msgstr "Berechnet das Volumen Daten-\"Klumpen\". Optional kann eine GRASS-Vektorkarte (Punkte) mit den Zentroiden der Datenklumpen erzeugt werden."
 #: ../raster/r.volume/main.c:69
 msgid "Existing raster map representing data that will be summed within clumps"
-msgstr ""
-"Existierende Rasterkarte repräsentiert Daten, die in sog. Klumpen "
-"aufsummiert werden."
+msgstr "Existierende Rasterkarte repräsentiert Daten, die in sog. Klumpen aufsummiert werden."
 #: ../raster/r.volume/main.c:77
 msgid "Existing raster map, preferably the output of r.clump"
@@ -21313,8 +19524,7 @@
 #: ../raster/r.volume/main.c:128
 msgid "No clump map specified and MASK not set."
-msgstr ""
-"Keine Klumpen-Karte angegeben. Außerdem ist die Maske (MASK) nicht gesetzt."
+msgstr "Keine Klumpen-Karte angegeben. Außerdem ist die Maske (MASK) nicht gesetzt."
 #: ../raster/r.volume/main.c:133
 msgid "Unable to find data map"
@@ -21349,15 +19559,11 @@
 #: ../raster/r.buffer/main.c:69
 msgid "raster, buffer"
-msgstr "Raster, Buffer"
+msgstr "Raster, Puffer"
 #: ../raster/r.buffer/main.c:71
-msgid ""
-"Creates a raster map layer showing buffer zones surrounding cells that "
-"contain non-NULL category values."
-msgstr ""
-"Erzeugt eine Rasterkarte mit Bufferzonen um Pixel, die keine NULL-Werte "
-"haben."
+msgid "Creates a raster map layer showing buffer zones surrounding cells that contain non-NULL category values."
+msgstr "Erzeugt eine Rasterkarte mit Pufferzonen um Pixel, die keine NULL-Werte haben."
 #: ../raster/r.buffer/main.c:83
 msgid "Distance zone(s)"
@@ -21382,7 +19588,7 @@
 #: ../raster/r.buffer/execute.c:34
 msgid "Finding buffer zones..."
-msgstr "Berechne Buffer-Zonen..."
+msgstr "Berechne Puffer-Zonen..."
 #: ../raster/r.resamp.stats/main.c:261
 msgid "Resamples raster map layers to a coarser grid using aggregation."
@@ -21433,8 +19639,7 @@
 #: ../raster/r.stats/main.c:162
 msgid "Print APPROXIMATE percents (total percent may not be 100%)"
-msgstr ""
-"Gebe ungefähre Prozente aus (Gesamtprozente müssen nicht 100% ergeben)."
+msgstr "Gebe ungefähre Prozente aus (Gesamtprozente müssen nicht 100% ergeben)."
 #: ../raster/r.stats/main.c:167
 msgid "Print category labels"
@@ -21467,30 +19672,18 @@
 #: ../raster/r.stats/main.c:287
 #, c-format
-msgid ""
-"Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option "
-"will be ignored."
-msgstr ""
-"Rasterkarte <%s> wird als Integer-Karte gelesen! Schalter '-%c' und/oder die "
-"Option '%s' werden ignoriert."
+msgid "Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option will be ignored."
+msgstr "Rasterkarte <%s> wird als Integer-Karte gelesen! Schalter '-%c' und/oder die Option '%s' werden ignoriert."
 #: ../raster/r.stats/main.c:304
 #, c-format
-msgid ""
-"Cats for raster map <%s> are either missing or have no explicit labels. "
-"Using %s=%d."
-msgstr ""
-"Kategorien der Rasterkarte <%s> fehlen oder haben keine expliziten "
-"Beschriftungen. Verwende %s=%d."
+msgid "Cats for raster map <%s> are either missing or have no explicit labels. Using %s=%d."
+msgstr "Kategorien der Rasterkarte <%s> fehlen oder haben keine expliziten Beschriftungen. Verwende %s=%d."
 #: ../raster/r.stats/main.c:311
 #, c-format
-msgid ""
-"Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' "
-"option"
-msgstr ""
-"Der Schalter '-%c' wurde gesetzt. Verwende die fp-Kategoriespanne der "
-"Rasterkarte <%s> und ignoriere die Option '%s'."
+msgid "Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' option"
+msgstr "Der Schalter '-%c' wurde gesetzt. Verwende die fp-Kategoriespanne der Rasterkarte <%s> und ignoriere die Option '%s'."
 #: ../raster/r.stats/main.c:345
 #, c-format
@@ -21535,8 +19728,7 @@
 #: ../raster/r.quantile/main.c:282
 msgid "Generate recode rules based on quantile-defined intervals."
-msgstr ""
-"Erzeuge Rekodierungs-Regeln auf Grundlage quantildefinierter Intervalle."
+msgstr "Erzeuge Rekodierungs-Regeln auf Grundlage quantildefinierter Intervalle."
 #: ../raster/r.out.mat/main.c:65
 msgid "Exports a GRASS raster to a binary MAT-File."
@@ -21627,9 +19819,7 @@
 #: ../raster/r.param.scale/process.c:73
 msgid "E-W and N-S grid resolutions are different. Taking average."
-msgstr ""
-"Zellengröße in Ost-West- und Nord-Süd-Richtung ist unterschiedlich. Verwende "
-"den Mittelwert."
+msgstr "Zellengröße in Ost-West- und Nord-Süd-Richtung ist unterschiedlich. Verwende den Mittelwert."
 #: ../raster/r.param.scale/interface.c:54
 msgid "raster, geomorphology"
@@ -21640,12 +19830,8 @@
 msgstr "Extrahiert Terrainparameter aus einem DGM."
 #: ../raster/r.param.scale/interface.c:56
-msgid ""
-"Uses a multi-scale approach by taking fitting quadratic parameters to any "
-"size window (via least squares)."
-msgstr ""
-"Verwendet einen multi-skalaren Ansatz, in dem quadratische Parameter auf "
-"jede Fenstergröße angepasst werden (über die Methode der kleinsten Quadrate)."
+msgid "Uses a multi-scale approach by taking fitting quadratic parameters to any size window (via least squares)."
+msgstr "Verwendet einen multi-skalaren Ansatz, in dem quadratische Parameter auf jede Fenstergröße angepasst werden (über die Methode der kleinsten Quadrate)."
 #: ../raster/r.param.scale/interface.c:74
 msgid "Output raster layer containing morphometric parameter"
@@ -21653,8 +19839,7 @@
 #: ../raster/r.param.scale/interface.c:78
 msgid "Slope tolerance that defines a 'flat' surface (degrees)"
-msgstr ""
-"Hangneigungstoleranz, die eine 'flache' Oberfläche definiert (in Grad)."
+msgstr "Hangneigungstoleranz, die eine 'flache' Oberfläche definiert (in Grad)."
 #: ../raster/r.param.scale/interface.c:85
 msgid "Curvature tolerance that defines 'planar' surface"
@@ -21667,9 +19852,7 @@
 #: ../raster/r.param.scale/interface.c:100
 msgid "Morphometric parameter in 'size' window to calculate"
-msgstr ""
-"Morphometrische Parameter, die innerhalb der Fenstergröße berechnet werden "
-"sollen."
+msgstr "Morphometrische Parameter, die innerhalb der Fenstergröße berechnet werden sollen."
 #: ../raster/r.param.scale/interface.c:108
 msgid "Exponent for distance weighting (0.0-4.0)"
@@ -21701,11 +19884,8 @@
 msgstr "Raster, Rescale"
 #: ../raster/r.rescale.eq/main.c:54
-msgid ""
-"Rescales histogram equalized the range of category values in a raster map "
-"layer."
-msgstr ""
-"Reskaliert mit Histogrammnormalisierung die Kategoriewerte einer Rasterkarte."
+msgid "Rescales histogram equalized the range of category values in a raster map layer."
+msgstr "Reskaliert mit Histogrammnormalisierung die Kategoriewerte einer Rasterkarte."
 #: ../raster/r.rescale.eq/main.c:64 ../raster/r.rescale/main.c:61
 msgid "The name of the raster map to be rescaled"
@@ -21713,9 +19893,7 @@
 #: ../raster/r.rescale.eq/main.c:72 ../raster/r.rescale/main.c:69
 msgid "The input data range to be rescaled (default: full range of input map)"
-msgstr ""
-"Wertebereich der Eingangsdaten, der reskaliert werden soll (Standard: "
-"gesamter Wertebereich der Eingabekarte)"
+msgstr "Wertebereich der Eingangsdaten, der reskaliert werden soll (Standard: gesamter Wertebereich der Eingabekarte)"
 #: ../raster/r.rescale.eq/main.c:79 ../raster/r.rescale/main.c:76
 msgid "The resulting raster map name"
@@ -21880,8 +20058,7 @@
 #: ../raster/r.random.surface/init.c:80
 msgid "Random seed (SEED_MIN >= value >= SEED_MAX) (default: random)"
-msgstr ""
-"Zufälliger Startwert (SEED_MIN >= Wert >= SEED_MAX) (Standard: zufällig)."
+msgstr "Zufälliger Startwert (SEED_MIN >= Wert >= SEED_MAX) (Standard: zufällig)."
 #: ../raster/r.random.surface/init.c:87
 msgid "Maximum cell value of distribution"
@@ -21970,11 +20147,8 @@
 msgstr "%s: SCHRITT 1 ... "
 #: ../raster/r.cross/main.c:77
-msgid ""
-"Creates a cross product of the category values from multiple raster map "
-"layers."
-msgstr ""
-"Erzeugt ein Kreuzprodukt von Kategoriewerten auf Basis mehrerer Rasterkarten."
+msgid "Creates a cross product of the category values from multiple raster map layers."
+msgstr "Erzeugt ein Kreuzprodukt von Kategoriewerten auf Basis mehrerer Rasterkarten."
 #: ../raster/r.cross/main.c:86
 #, c-format
@@ -22129,8 +20303,7 @@
 #: ../raster/r.timestamp/main.c:37
 msgid "Print/add/remove a timestamp for a raster map."
-msgstr ""
-"Ausgeben/hinzufügen/entfernen eines Zeitstempels von einer Rasterkarte."
+msgstr "Ausgeben/hinzufügen/entfernen eines Zeitstempels von einer Rasterkarte."
 #: ../raster/r.timestamp/main.c:46
 msgid "Datetime, datetime1/datetime2, or 'none' to remove"
@@ -22223,12 +20396,8 @@
 #: ../raster/r.mfilter.fp/main.c:109 ../raster/r.mfilter/main.c:104
 #: ../raster/r.out.ppm/main.c:81 ../raster/r.kappa/main.c:125
-msgid ""
-"The '-q' flag is superseded and will be removed in future. Please use '--"
-"quiet' instead"
-msgstr ""
-"Der Schalter '-q' wurde überflüssig gemacht und wird in der Zukunft "
-"entfernt-- Bitte verwenden Sie '--quiet' stattdessen ."
+msgid "The '-q' flag is superseded and will be removed in future. Please use '--quiet' instead"
+msgstr "Der Schalter '-q' wurde überflüssig gemacht und wird in der Zukunft entfernt-- Bitte verwenden Sie '--quiet' stattdessen ."
 #: ../raster/r.mfilter.fp/main.c:138 ../raster/r.mfilter/main.c:133
 msgid "Raster map too small for the size of the filter"
@@ -22364,17 +20533,11 @@
 #: ../raster/r.gwflow/main.c:159
 msgid "Use a sparse matrix, only available with iterative solvers"
-msgstr ""
-"Verwende eine dünnbesetzte Matrix, nur für iterative Lösungsverfahren "
-"verfügbar."
+msgstr "Verwende eine dünnbesetzte Matrix, nur für iterative Lösungsverfahren verfügbar."
 #: ../raster/r.gwflow/main.c:191
-msgid ""
-"Numerical calculation program for transient, confined and unconfined "
-"groundwater flow in two dimensions."
-msgstr ""
-"Programm zur numerischen Berechnung von transienten, beschränkten und "
-"unbeschränkten Grundwasserfluss in zwei Dimensionen."
+msgid "Numerical calculation program for transient, confined and unconfined groundwater flow in two dimensions."
+msgstr "Programm zur numerischen Berechnung von transienten, beschränkten und unbeschränkten Grundwasserfluss in zwei Dimensionen."
 #: ../raster/r.gwflow/main.c:216
 msgid "Please provide river_head, river_leak and river_bed maps"
@@ -22390,13 +20553,11 @@
 #: ../raster/r.gwflow/main.c:242 ../raster3d/r3.gwflow/main.c:191
 msgid "The direct Gauss solver do not work with sparse matrices"
-msgstr ""
-"Der direkte Gauss'sche Löser funktioniert nicht mit dünnbesetzten Matrizen."
+msgstr "Der direkte Gauss'sche Löser funktioniert nicht mit dünnbesetzten Matrizen."
 #: ../raster/r.gwflow/main.c:244
 msgid "The direct cholesky solver do not work with sparse matrices"
-msgstr ""
-"Der direkte Cholesky Löser funktioniert nicht mit dünnbesetzten Matrizen."
+msgstr "Der direkte Cholesky Löser funktioniert nicht mit dünnbesetzten Matrizen."
 #: ../raster/r.gwflow/main.c:360
 #, c-format
@@ -22417,12 +20578,8 @@
 msgstr "Raster, Import, LIDAR"
 #: ../raster/r.in.xyz/main.c:161
-msgid ""
-"Create a raster map from an assemblage of many coordinates using univariate "
-"statistics."
-msgstr ""
-"Erzeugt eine Rasterkarte aus einer Vielzahl von Koordinaten unter Verwendung "
-"univariater Statistik."
+msgid "Create a raster map from an assemblage of many coordinates using univariate statistics."
+msgstr "Erzeugt eine Rasterkarte aus einer Vielzahl von Koordinaten unter Verwendung univariater Statistik."
 #: ../raster/r.in.xyz/main.c:165
 msgid "ASCII file containing input data (or \"-\" to read from stdin)"
@@ -22439,8 +20596,7 @@
 #: ../raster/r.in.xyz/main.c:196
 msgid "Column number of x coordinates in input file (first column is 1)"
-msgstr ""
-"Spaltenummer der X-Koordinate in der Eingabedatei (erste Spalte ist 1)."
+msgstr "Spaltenummer der X-Koordinate in der Eingabedatei (erste Spalte ist 1)."
 #: ../raster/r.in.xyz/main.c:204
 msgid "Column number of y coordinates in input file"
@@ -22463,17 +20619,12 @@
 msgstr "Perzentil der Werte"
 #: ../raster/r.in.xyz/main.c:251
-msgid ""
-"Discard <trim> percent of the smallest and <trim> percent of the largest "
-"observations"
-msgstr ""
-"Verwerfe <trim> Prozent der kleinsten und <trim> Prozent der größsten "
-"Beobachtungen."
+msgid "Discard <trim> percent of the smallest and <trim> percent of the largest observations"
+msgstr "Verwerfe <trim> Prozent der kleinsten und <trim> Prozent der größsten Beobachtungen."
 #: ../raster/r.in.xyz/main.c:256
 msgid "Scan data file for extent then exit"
-msgstr ""
-"Lese Eingabedatei um die räumliche Ausdehnung zu bestimmen und beendet sich."
+msgstr "Lese Eingabedatei um die räumliche Ausdehnung zu bestimmen und beendet sich."
 #: ../raster/r.in.xyz/main.c:261
 msgid "In scan mode, print using shell script style"
@@ -22500,11 +20651,8 @@
 msgstr "Kann keinen getrimmten Mittelwert (trimmean) ohne Angabe von trim!"
 #: ../raster/r.in.xyz/main.c:477
-msgid ""
-"If input is not from a file it is only possible to perform a single pass."
-msgstr ""
-"Wenn die Eingabe nicht aus einer Datei kommt kann nur ein Durchgang "
-"ausgeführt werden."
+msgid "If input is not from a file it is only possible to perform a single pass."
+msgstr "Wenn die Eingabe nicht aus einer Datei kommt kann nur ein Durchgang ausgeführt werden."
 #: ../raster/r.in.xyz/main.c:483
 msgid "zrange will not be taken into account during scan"
@@ -22518,12 +20666,10 @@
 #: ../raster/r.in.xyz/main.c:1103 ../raster/r.in.xyz/main.c:1111
 #, c-format
 msgid ""
-"Not enough data columns. Incorrect delimiter or column number? Found the "
-"following character(s) in row %lu:\n"
+"Not enough data columns. Incorrect delimiter or column number? Found the following character(s) in row %lu:\n"
 "[%s]"
 msgstr ""
-"Nicht genügend Datenspalten. Falsches Trennzeichen oder Spaltenanzahl? Habe "
-"die folgenden Zeichen in Zeile %lu gefunden:\n"
+"Nicht genügend Datenspalten. Falsches Trennzeichen oder Spaltenanzahl? Habe die folgenden Zeichen in Zeile %lu gefunden:\n"
 "[%s]"
 #: ../raster/r.in.xyz/main.c:603 ../raster/r.in.xyz/main.c:1107
@@ -22601,9 +20747,7 @@
 #: ../raster/r.profile/main.c:55
 msgid "Outputs the raster map layer values lying on user-defined line(s)."
-msgstr ""
-"Gibt eine Rasterkarte aus, deren Werte entlang einer (oder mehrerer) "
-"benutzerdefinierter Linien liegt."
+msgstr "Gibt eine Rasterkarte aus, deren Werte entlang einer (oder mehrerer) benutzerdefinierter Linien liegt."
 #: ../raster/r.profile/main.c:66
 msgid "Name of file for output (use output=- for stdout)"
@@ -22646,8 +20790,7 @@
 #: ../raster/r.profile/main.c:179
 #, c-format
 msgid "[Easting] [Northing] [Along Track Dist.(m)] [Elevation]"
-msgstr ""
-"[Ost-Koordinate] [Nord-Koordinate] [Dist. entlang des Tracks(m)] [Höhe]"
+msgstr "[Ost-Koordinate] [Nord-Koordinate] [Dist. entlang des Tracks(m)] [Höhe]"
 #: ../raster/r.profile/main.c:181
 #, c-format
@@ -22720,11 +20863,8 @@
 msgstr "Programm zur Erzeugung von Oberflächen."
 #: ../raster/r.surf.idw2/main.c:80
-msgid ""
-"Lat/long databases not supported by r.surf.idw2. Use r.surf.idw instead!"
-msgstr ""
-"Lat/Long-Datenbank wird nicht von r.surf.idw2 unterstützt. Verwenden Sie "
-"stattdessen r.surf.idw."
+msgid "Lat/long databases not supported by r.surf.idw2. Use r.surf.idw instead!"
+msgstr "Lat/Long-Datenbank wird nicht von r.surf.idw2 unterstützt. Verwenden Sie stattdessen r.surf.idw."
 #: ../raster/r.surf.idw2/main.c:84 ../vector/v.surf.idw/main.c:138
 #, c-format
@@ -22746,12 +20886,8 @@
 msgstr "Kann Zeile nicht bekommen."
 #: ../raster/r.covar/main.c:55
-msgid ""
-"Outputs a covariance/correlation matrix for user-specified raster map "
-"layer(s)."
-msgstr ""
-"Gibt eine Kovarianz/Korrelations-Matrix für (eine) benutzerdefiniert "
-"Rasterkarte(n) aus."
+msgid "Outputs a covariance/correlation matrix for user-specified raster map layer(s)."
+msgstr "Gibt eine Kovarianz/Korrelations-Matrix für (eine) benutzerdefiniert Rasterkarte(n) aus."
 #: ../raster/r.covar/main.c:62
 msgid "Print correlation matrix"
@@ -22784,37 +20920,28 @@
 msgstr "Verarbeite Zeilen... "
 #: ../raster/r.carve/enforce_ds.c:173
-msgid ""
-"Vect runs out of region and re-enters - this case is not yet implemented."
-msgstr ""
-"Vect läuft aus der Region und kommt wieder hinein. Diese Situation ist "
-"leider noch nicht implementiert!"
+msgid "Vect runs out of region and re-enters - this case is not yet implemented."
+msgstr "Vect läuft aus der Region und kommt wieder hinein. Diese Situation ist leider noch nicht implementiert!"
 #: ../raster/r.carve/lobf.c:74
 msgid "trying to divide by zero...no unique solution for system...skipping..."
-msgstr ""
-"Versuche durch 0 zu teilen... Keine eindeutige Lösung...Übergehe das..."
+msgstr "Versuche durch 0 zu teilen... Keine eindeutige Lösung...Übergehe das..."
 #: ../raster/r.carve/main.c:78
 msgid "Generates stream channels."
 msgstr "Erzeugt Flussbettlinien."
 #: ../raster/r.carve/main.c:79
-msgid ""
-"Takes vector stream data, transforms it to raster and subtracts depth from "
-"the output DEM."
-msgstr ""
-"Wandelt eine Vektorkarte mit Flüssen, transformiert sie in das Rasterformat "
-"und subtrahiert die Tiefe vom Ausgabe-DEM."
+msgid "Takes vector stream data, transforms it to raster and subtracts depth from the output DEM."
+msgstr "Wandelt eine Vektorkarte mit Flüssen, transformiert sie in das Rasterformat und subtrahiert die Tiefe vom Ausgabe-DEM."
 #: ../raster/r.carve/main.c:84
 msgid "Name of input raster elevation map"
 msgstr "Eingabe-Rasterkarte, die Höhenwerte enthält."
 #: ../raster/r.carve/main.c:89
-#, fuzzy
 msgid "Name of input vector map containing stream(s)"
-msgstr "Namde der Eingabe-Vektorkarte mit Linien."
+msgstr "Name der Eingabe-Vektorkarte mit Flüssen"
 #: ../raster/r.carve/main.c:97
 msgid "Name for output vector map for adjusted stream points"
@@ -22874,9 +21001,7 @@
 #: ../raster/r.statistics/main.c:67
 msgid "Resultant raster map (not used with 'distribution')"
-msgstr ""
-"Resultierende Rasterkarte (wird nicht benutzt, wenn Methode 'Verteilung' "
-"gewählt wurde)."
+msgstr "Resultierende Rasterkarte (wird nicht benutzt, wenn Methode 'Verteilung' gewählt wurde)."
 #: ../raster/r.statistics/main.c:82 ../raster/r.statistics/main.c:88
 msgid "This module currently only works for integer (CELL) maps"
@@ -22921,16 +21046,12 @@
 #: ../raster/r.support/modhead/modhead.c:86
 #, c-format
 msgid "[%s] is a reclass of [%s] - cannot edit header! Run support on [%s]."
-msgstr ""
-"[%s] ist eine reklassifizierte Karte von [%s] - kann den Header nicht "
-"editieren! Führen Sie support für [%s] aus."
+msgstr "[%s] ist eine reklassifizierte Karte von [%s] - kann den Header nicht editieren! Führen Sie support für [%s] aus."
 #: ../raster/r.support/modhead/modhead.c:90
 #, c-format
 msgid "[%s] is a reclass of [%s in %s] - cannot edit header!"
-msgstr ""
-"[%s] ist eine reklassifizierte Karte von [%s in %s] - kann den Header nicht "
-"editieren!"
+msgstr "[%s] ist eine reklassifizierte Karte von [%s in %s] - kann den Header nicht editieren!"
 #: ../raster/r.support/modhead/modhead.c:96
 #, c-format
@@ -22991,9 +21112,7 @@
 #: ../raster/r.support/modhead/modhead.c:248
 #: ../raster/r.support/modhead/modhead.c:257
 msgid "Most likely the header is wrong, but I want you to decide.\n"
-msgstr ""
-"Höchstwahrscheinlich ist die Information aus dem Header falsch, aber ich "
-"möchte, dass Sie entscheiden.\n"
+msgstr "Höchstwahrscheinlich ist die Information aus dem Header falsch, aber ich möchte, dass Sie entscheiden.\n"
 #: ../raster/r.support/modhead/modhead.c:254
 #, c-format
@@ -23006,12 +21125,8 @@
 #: ../raster/r.support/modhead/modhead.c:271
 #, c-format
-msgid ""
-"Header indicates %d row%s in the raster map, but the actual file format "
-"indicates %d row%s"
-msgstr ""
-"Header gibt an, dass %d Zeile%s in der Rasterkarte enthalten sind, aber die "
-"aktuelle Datei hat %d Zeile%s."
+msgid "Header indicates %d row%s in the raster map, but the actual file format indicates %d row%s"
+msgstr "Header gibt an, dass %d Zeile%s in der Rasterkarte enthalten sind, aber die aktuelle Datei hat %d Zeile%s."
 #: ../raster/r.support/modhead/modhead.c:303
 #, c-format
@@ -23055,9 +21170,7 @@
 #: ../raster/r.support/modhead/ask_format.c:51
 #, c-format
 msgid "rows * cols * bytes per cell must be same as file size (%lu)"
-msgstr ""
-"Zeilen * Spalten * Bytes* pro Zelle musse genauso groß sein wie die Datei "
-"(%lu)."
+msgstr "Zeilen * Spalten * Bytes* pro Zelle musse genauso groß sein wie die Datei (%lu)."
 #: ../raster/r.support/modhead/ask_format.c:55
 msgid "If you need help figuring them out, just hit ESC"
@@ -23126,9 +21239,7 @@
 #: ../raster/r.support/front/front.c:55
 msgid "Allows creation and/or modification of raster map layer support files."
-msgstr ""
-"Erlaubt das Erzeugen und/oder das Modifizieren von Rasterkarten-Support-"
-"Dateien."
+msgstr "Erlaubt das Erzeugen und/oder das Modifizieren von Rasterkarten-Support-Dateien."
 #: ../raster/r.support/front/front.c:65
 msgid "Text to use for map title"
@@ -23217,12 +21328,10 @@
 #, c-format
 msgid ""
 "\n"
-"Do you want to create/reset the null file for [%s] so that null cell values "
-"are considered valid data? "
+"Do you want to create/reset the null file for [%s] so that null cell values are considered valid data? "
 msgstr ""
 "\n"
-"Wollen Sie eine NULL-Datei für [%s] erzeugen/zurücksetzen, so dass Zellen "
-"mit NULL-Werten als gültige Daten angesehen werden?"
+"Wollen Sie eine NULL-Datei für [%s] erzeugen/zurücksetzen, so dass Zellen mit NULL-Werten als gültige Daten angesehen werden?"
 #: ../raster/r.support/front/front.c:317 ../raster/r.support/front/front.c:354
 #, c-format
@@ -23266,8 +21375,7 @@
 #: ../raster/r.support/front/check.c:29
 #, c-format
 msgid "Update the statistics (histogram, range) for [%s]? "
-msgstr ""
-"Wollen Sie die Statistik (Histogramm, Spannweite) für [%s] aktualisieren?"
+msgstr "Wollen Sie die Statistik (Histogramm, Spannweite) für [%s] aktualisieren?"
 #: ../raster/r.support/front/check.c:35
 #, c-format
@@ -23336,18 +21444,12 @@
 msgstr "Schließen ohne eine Karte zu erzeugen?"
 #: ../raster/r.digit/main.c:47
-msgid ""
-"Interactive tool used to draw and save vector features on a graphics monitor "
-"using a pointing device (mouse) and save to a raster map."
-msgstr ""
-"Interaktives Werkzeug, welches Vektorobjekte in einem Grafikfenster mit der "
-"Maus zeichnet und als Rasterkarte speichert."
+msgid "Interactive tool used to draw and save vector features on a graphics monitor using a pointing device (mouse) and save to a raster map."
+msgstr "Interaktives Werkzeug, welches Vektorobjekte in einem Grafikfenster mit der Maus zeichnet und als Rasterkarte speichert."
 #: ../raster/r.digit/main.c:56 ../vector/v.digit/main.c:120
 msgid "Display commands to be used for canvas backdrop (separated by ';')"
-msgstr ""
-"Display-Befehle die für den Hintergrund verwendet werden sollen (getrennt "
-"durch ';')."
+msgstr "Display-Befehle die für den Hintergrund verwendet werden sollen (getrennt durch ';')."
 #: ../raster/r.digit/main.c:79
 msgid "No graphics device selected!"
@@ -23381,8 +21483,7 @@
 #: ../raster/r.contour/main.c:92
 msgid "Produces a vector map of specified contours from a raster map."
-msgstr ""
-"Erzeugt eine Vektorkarte mit bestimmten Kontourlinien aus einer Rasterkarte."
+msgstr "Erzeugt eine Vektorkarte mit bestimmten Kontourlinien aus einer Rasterkarte."
 #: ../raster/r.contour/main.c:104
 msgid "List of contour levels"
@@ -23409,12 +21510,8 @@
 msgstr "Unterdrücke Fehlermeldungen für 'single crossing'."
 #: ../raster/r.contour/main.c:147
-msgid ""
-"The '-q' and '-n' flag is superseded and will be removed in future. Please "
-"use '--quiet' instead."
-msgstr ""
-"Die Schalter '-q' und '-n' wurden ersetzt und werden in einer der kommenden "
-"Versionen ersatzlos gestrichen. Bitte verwenden Sie stattdessen '--quiet'."
+msgid "The '-q' and '-n' flag is superseded and will be removed in future. Please use '--quiet' instead."
+msgstr "Die Schalter '-q' und '-n' wurden ersetzt und werden in einer der kommenden Versionen ersatzlos gestrichen. Bitte verwenden Sie stattdessen '--quiet'."
 #: ../raster/r.contour/main.c:152
 msgid "Neither \"levels\" nor \"step\" parameter specified."
@@ -23500,11 +21597,8 @@
 msgstr "GIS Koinzidenz-Tabellierungsanlage\n"
 #: ../raster/r.coin/inter.c:35
-msgid ""
-"This utility will allow you to compare the coincidence of two map layers\n"
-msgstr ""
-"Dieses Dienstprogramm ermöglicht Ihnen die Koinzidenz zweier Karten zu "
-"vergleichen\n"
+msgid "This utility will allow you to compare the coincidence of two map layers\n"
+msgstr "Dieses Dienstprogramm ermöglicht Ihnen die Koinzidenz zweier Karten zu vergleichen\n"
 #: ../raster/r.coin/inter.c:52
 msgid "The report can be made in one of 8 units."
@@ -23512,8 +21606,7 @@
 #: ../raster/r.coin/inter.c:53
 msgid "Please choose a unit by entering one of the following letter codes:"
-msgstr ""
-"Bitte wählen Sie eine Einheit durch Eingabe eines der folgenden Buchstaben:"
+msgstr "Bitte wählen Sie eine Einheit durch Eingabe eines der folgenden Buchstaben:"
 #: ../raster/r.coin/inter.c:55
 msgid "     'c': cells"
@@ -23574,10 +21667,8 @@
 #: ../raster/r.coin/inter.c:117
 #, c-format
-msgid ""
-"Do you wish to print this report (requires Unix lpr command)? (y/n) [n] "
-msgstr ""
-"Möchten Sie diesen Bericht drucken (benötigt den Unix lpr-Befehl)? (y/n) [n] "
+msgid "Do you wish to print this report (requires Unix lpr command)? (y/n) [n] "
+msgstr "Möchten Sie diesen Bericht drucken (benötigt den Unix lpr-Befehl)? (y/n) [n] "
 #: ../raster/r.coin/inter.c:126
 #, c-format
@@ -23590,17 +21681,12 @@
 #: ../raster/r.coin/inter.c:142
 #, c-format
-msgid ""
-"Do you wish to run this report with a different unit of measure? (y/n) [y] "
+msgid "Do you wish to run this report with a different unit of measure? (y/n) [y] "
 msgstr "Möchten Sie diesen Bericht mit einer anderen Maßeinheit? (y/n) [y] "
 #: ../raster/r.coin/main.c:68
-msgid ""
-"Tabulates the mutual occurrence (coincidence) of categories for two raster "
-"map layers."
-msgstr ""
-"Tabelliert das gemeinsame Auftreten von Kategorien (Koinzidenz) von zwei "
-"Rasterkarten."
+msgid "Tabulates the mutual occurrence (coincidence) of categories for two raster map layers."
+msgstr "Tabelliert das gemeinsame Auftreten von Kategorien (Koinzidenz) von zwei Rasterkarten."
 #: ../raster/r.coin/main.c:76
 msgid "Name of first raster map"
@@ -23615,13 +21701,8 @@
 msgstr "Maßeinheit"
 #: ../raster/r.coin/main.c:91
-msgid ""
-"c(ells), p(ercent), x(percent of category [column]), y(percent of category "
-"[row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
-msgstr ""
-"c(ells), p(rozent), x(Prozent der Kategorien [Spalte]), y(Prozent der "
-"Kategorien [Zeile]), a(cres), h(ektar), k(Quadrat-Kilometer), m(Quadrat-"
-"Meilen)"
+msgid "c(ells), p(ercent), x(percent of category [column]), y(percent of category [row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
+msgstr "c(ells), p(rozent), x(Prozent der Kategorien [Spalte]), y(Prozent der Kategorien [Zeile]), a(cres), h(ektar), k(Quadrat-Kilometer), m(Quadrat-Meilen)"
 #: ../raster/r.coin/main.c:98
 msgid "Wide report, 132 columns (default: 80)"
@@ -23654,12 +21735,8 @@
 msgstr "Erstelle den Bericht ..."
 #: ../raster/r.out.ppm/main.c:56
-msgid ""
-"Converts a GRASS raster map to a PPM image file at the pixel resolution of "
-"the currently defined region."
-msgstr ""
-"Konvertiert eine GRASS-Rasterkarte in eine PPM Bilddatei mit der Auflösung "
-"der aktuellen Region."
+msgid "Converts a GRASS raster map to a PPM image file at the pixel resolution of the currently defined region."
+msgstr "Konvertiert eine GRASS-Rasterkarte in eine PPM Bilddatei mit der Auflösung der aktuellen Region."
 #: ../raster/r.out.ppm/main.c:64
 msgid "Name for new PPM file (use '-' for stdout)"
@@ -23765,8 +21842,7 @@
 #: ../raster/r.info/main.c:111
 msgid "Print raster map timestamp (day.month.year hour:minute:seconds) only"
-msgstr ""
-"Gebe Zeitstempel der Rasterkarte aus (Tag.Monat.Jahr Stunde:Minute:Sekunde)"
+msgstr "Gebe Zeitstempel der Rasterkarte aus (Tag.Monat.Jahr Stunde:Minute:Sekunde)"
 #: ../raster/r.info/main.c:142
 msgid "Unable to read range file"
@@ -23795,24 +21871,16 @@
 #: ../raster/r.kappa/calc_kappa.c:32
 #, c-format
 msgid "Cannot open file <%s> to write kappa and relevant parameters"
-msgstr ""
-"Kann die Datei <%s> nicht öffnen, um die Kappawerte und relevante Parameter "
-"zu schreiben."
+msgstr "Kann die Datei <%s> nicht öffnen, um die Kappawerte und relevante Parameter zu schreiben."
 #: ../raster/r.kappa/prt_mat.c:39
 #, c-format
 msgid "Cannot open file <%s> to write cats and counts (error matrix)"
-msgstr ""
-"Kann die Datei <%s> nicht öffnen, um Kategorien und Anzahlen (Fehlermatrix) "
-"zu schreiben."
+msgstr "Kann die Datei <%s> nicht öffnen, um Kategorien und Anzahlen (Fehlermatrix) zu schreiben."
 #: ../raster/r.kappa/main.c:69
-msgid ""
-"Calculate error matrix and kappa parameter for accuracy assessment of "
-"classification result."
-msgstr ""
-"Berechnet Fehlermatrix und Kappa-Parameter für die Genauigkeitsabschätzung "
-"(accuracy assessment) der Klassifikationsergebnisse."
+msgid "Calculate error matrix and kappa parameter for accuracy assessment of classification result."
+msgstr "Berechnet Fehlermatrix und Kappa-Parameter für die Genauigkeitsabschätzung (accuracy assessment) der Klassifikationsergebnisse."
 #: ../raster/r.kappa/main.c:75
 msgid "Name of raster map containing classification result"
@@ -23848,12 +21916,8 @@
 msgstr "Kann die Datei <%s> nicht zum Schreiben des Headers öffnen."
 #: ../raster/r.out.tiff/r.out.tiff.c:101
-msgid ""
-"Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel "
-"resolution of the currently defined region."
-msgstr ""
-"Exportiere GRASS Rasterkarte in ein 8/24 bit TIFF-Bild. Die Pixelauflösung "
-"wird aus der aktuellen Region-Einstellung übernommen."
+msgid "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel resolution of the currently defined region."
+msgstr "Exportiere GRASS Rasterkarte in ein 8/24 bit TIFF-Bild. Die Pixelauflösung wird aus der aktuellen Region-Einstellung übernommen."
 #: ../raster/r.out.tiff/r.out.tiff.c:111
 msgid "Name for new TIFF file"
@@ -23877,19 +21941,12 @@
 #: ../raster/r.out.tiff/r.out.tiff.c:177
 #, c-format
-msgid ""
-"Raster map <%s> in mapset <%s> is a floating point map. Decimal values will "
-"be rounded to integer!"
-msgstr ""
-"Die Rasterkarte <%s> im Mapset <%s> ist eine Fließkommakarte. "
-"Nachkommastellen werden auf ganze Zahlen gerundet!"
+msgid "Raster map <%s> in mapset <%s> is a floating point map. Decimal values will be rounded to integer!"
+msgstr "Die Rasterkarte <%s> im Mapset <%s> ist eine Fließkommakarte. Nachkommastellen werden auf ganze Zahlen gerundet!"
 #: ../raster/r.out.tiff/r.out.tiff.c:183
-msgid ""
-"Color map for palette must have less than 256 colors for the available range "
-"of data"
-msgstr ""
-"Farbtabelle muss weniger als 256 Farben für die vorhandene Datenspanne haben."
+msgid "Color map for palette must have less than 256 colors for the available range of data"
+msgstr "Farbtabelle muss weniger als 256 Farben für die vorhandene Datenspanne haben."
 #: ../raster/r.out.tiff/r.out.tiff.c:198
 #, c-format
@@ -23947,8 +22004,7 @@
 #: ../raster/r.resamp.interp/main.c:74
 msgid "Resamples raster map layers to a finer grid using interpolation."
-msgstr ""
-"Erzeugt eine neue Rasterkarte mit feinerer Auflösung mittels Interpolation."
+msgstr "Erzeugt eine neue Rasterkarte mit feinerer Auflösung mittels Interpolation."
 #: ../ps/ps.map/r_vlegend.c:49 ../ps/ps.map/r_info.c:48
 #: ../ps/ps.map/r_colortable.c:61
@@ -23987,29 +22043,18 @@
 msgstr "Kann die Farbe für den Farbstreifen nicht lesen."
 #: ../ps/ps.map/ps_clrtbl.c:54
-msgid ""
-"Your cats/ file is invalid. A cats/ file with categories and labels is "
-"required for 'colortable' when using categorical legends; see the r.category "
-"help page. Colortable creation has been skipped."
-msgstr ""
-"Ihre cats/-Datei ist ungültig. Eine cats/-Datei mit Kategorien und Labeln "
-"ist für 'colortable' notwendig für eine kategorische Legende. Werfen Sie "
-"einen Blick in die Handbuchseite von r.category. Die Erzeugung der Farbteile "
-"wurde nicht ausgeführt."
+msgid "Your cats/ file is invalid. A cats/ file with categories and labels is required for 'colortable' when using categorical legends; see the r.category help page. Colortable creation has been skipped."
+msgstr "Ihre cats/-Datei ist ungültig. Eine cats/-Datei mit Kategorien und Labeln ist für 'colortable' notwendig für eine kategorische Legende. Werfen Sie einen Blick in die Handbuchseite von r.category. Die Erzeugung der Farbteile wurde nicht ausgeführt."
 #: ../ps/ps.map/ps_clrtbl.c:69 ../ps/ps.map/ps_fclrtbl.c:92
 #: ../ps/ps.map/ps_fclrtbl.c:97
 msgid "Colorbar y location beyond page margins. Adjusting."
-msgstr ""
-"Die Y-Position der Farbtabelle liegt außerhalb der Seitenränder. Korrigiere "
-"dies."
+msgstr "Die Y-Position der Farbtabelle liegt außerhalb der Seitenränder. Korrigiere dies."
 #: ../ps/ps.map/ps_clrtbl.c:75 ../ps/ps.map/ps_fclrtbl.c:103
 #: ../ps/ps.map/ps_fclrtbl.c:108
 msgid "Colorbar x location beyond page margins. Adjusting."
-msgstr ""
-"Die X-Position der Farbtabelle liegt außerhalb der Seitenränder. Korrigiere "
-"dies."
+msgstr "Die X-Position der Farbtabelle liegt außerhalb der Seitenränder. Korrigiere dies."
 #: ../ps/ps.map/ps_fclrtbl.c:51
 msgid "Range information not available (run r.support)"
@@ -24167,12 +22212,8 @@
 #: ../ps/ps.map/r_vpoints.c:244
 #, c-format
-msgid ""
-"The mapping instruction <%s> will be renamed to <%s> in future versions of "
-"GRASS. Please use <%s> instead."
-msgstr ""
-"Die Kartierungsanweisung <%s> wird umbenannt in <%s> in zukünftigen "
-"Versionen von GRASS. Bitte verwenden Sie sattdessen <%s>."
+msgid "The mapping instruction <%s> will be renamed to <%s> in future versions of GRASS. Please use <%s> instead."
+msgstr "Die Kartierungsanweisung <%s> wird umbenannt in <%s> in zukünftigen Versionen von GRASS. Bitte verwenden Sie sattdessen <%s>."
 #: ../ps/ps.map/r_header.c:77
 msgid "illegal header sub-request"
@@ -24201,9 +22242,7 @@
 #: ../ps/ps.map/main.c:111
 msgid "List paper formats ( name width height left right top bottom(margin) )"
-msgstr ""
-"Gebe Liste der Papierformate aus (Name Breite Höhe links rechts oben "
-"unten(Rand) )."
+msgstr "Gebe Liste der Papierformate aus (Name Breite Höhe links rechts oben unten(Rand) )."
 #: ../ps/ps.map/main.c:112 ../ps/ps.map/main.c:124
 msgid "Utility"
@@ -24214,12 +22253,8 @@
 msgstr "Erzeugt EPS (Encapsulated PostScript) anstatt PostScript-Dateien."
 #: ../ps/ps.map/main.c:123
-msgid ""
-"Describe map-box's position on the page and exit (inches from top-left of "
-"paper)"
-msgstr ""
-"Beschreibe die Position der Kartenrechtecks auf dem Papier und beendet sich "
-"(Inch von der linken-oberen Ecke). "
+msgid "Describe map-box's position on the page and exit (inches from top-left of paper)"
+msgstr "Beschreibe die Position der Kartenrechtecks auf dem Papier und beendet sich (Inch von der linken-oberen Ecke). "
 #: ../ps/ps.map/main.c:129
 msgid "File containing mapping instructions"
@@ -24235,9 +22270,7 @@
 #: ../ps/ps.map/main.c:147
 msgid "Scale of the output map, e.g. 1:25000 (default: Auto-sized to fit page)"
-msgstr ""
-"Maßstab der Ausgabekarte, z.B. 1:25000 (standardmäßig: Anpassung an die "
-"Seite)"
+msgstr "Maßstab der Ausgabekarte, z.B. 1:25000 (standardmäßig: Anpassung an die Seite)"
 #: ../ps/ps.map/main.c:154
 msgid "Number of copies to print"
@@ -24245,14 +22278,8 @@
 #: ../ps/ps.map/main.c:247
 #, c-format
-msgid ""
-"Using <%s> from the command line is depreciated. Please use the <%s> mapping "
-"instruction instead. The parameter <%s> will be removed in future versions "
-"of GRASS."
-msgstr ""
-"Die Verwendung von <%s> auf der Kommandozeile ist veraltet. Bitte verwenden "
-"Sie stattdessen die Kartierungsanweisung <%s>. Der Parameter <%s> wird in "
-"zukünftigen GRASS-Versionen nicht mehr vorhanden sein."
+msgid "Using <%s> from the command line is depreciated. Please use the <%s> mapping instruction instead. The parameter <%s> will be removed in future versions of GRASS."
+msgstr "Die Verwendung von <%s> auf der Kommandozeile ist veraltet. Bitte verwenden Sie stattdessen die Kartierungsanweisung <%s>. Der Parameter <%s> wird in zukünftigen GRASS-Versionen nicht mehr vorhanden sein."
 #: ../ps/ps.map/main.c:255 ../ps/ps.map/main.c:559
 msgid "illegal scale request"
@@ -24280,29 +22307,20 @@
 msgstr "Weitere Daten existieren nach der beendenden 'end'-Instruktion!"
 #: ../ps/ps.map/main.c:330
-msgid ""
-"GRASS environment variable GRASS_VERBOSE is overwritten by VERBOSE mapping "
-"instruction. This mapping instruction is superseded and will be removed in "
-"future versions of GRASS. Please use --verbose instead."
-msgstr ""
-"Die GRASS Umgebungsvariable GRASS_VERBOSE wird überschrieben von der "
-"Kartierungsanweisung VERBOSE. Diese Kartierungsanweisung wurde ersetzt und "
-"wird in zukünftigen GRASS_Versionen nicht mehr enthalten sein. Bitte "
-"verwenden Sie stattdessen '--verbose'."
+msgid "GRASS environment variable GRASS_VERBOSE is overwritten by VERBOSE mapping instruction. This mapping instruction is superseded and will be removed in future versions of GRASS. Please use --verbose instead."
+msgstr "Die GRASS Umgebungsvariable GRASS_VERBOSE wird überschrieben von der Kartierungsanweisung VERBOSE. Diese Kartierungsanweisung wurde ersetzt und wird in zukünftigen GRASS_Versionen nicht mehr enthalten sein. Bitte verwenden Sie stattdessen '--verbose'."
 #: ../ps/ps.map/main.c:337
 msgid "Cannot set GRASS_VERBOSE variable."
 msgstr "Kann die GRASS_VERBOSE Variable nicht setzen."
 #: ../ps/ps.map/main.c:394
-#, fuzzy
 msgid "no raster map selected yet"
-msgstr "Keine Rasterkarte angegeben."
+msgstr "Keine Rasterkarte ausgewählt"
 #: ../ps/ps.map/main.c:410
-#, fuzzy
 msgid "illegal value list"
-msgstr "%s: ungültiger Wert."
+msgstr "Liste ungültiger Werte"
 #: ../ps/ps.map/main.c:738
 #, c-format
@@ -24376,9 +22394,8 @@
 msgstr "Ungültige Farb-Anfrage (Farbtabelle)."
 #: ../ps/ps.map/r_colortable.c:158
-#, fuzzy
 msgid "illegal colortable sub-request"
-msgstr "Ungültige colortabe sub-request"
+msgstr "Ungültiger colortable sub-request"
 #: ../ps/ps.map/r_colortable.c:169
 msgid "No raster selected for colortable!"
@@ -24389,12 +22406,8 @@
 msgstr "3D-Raster, Voxel, Import"
 #: ../raster3d/r3.in.v5d/main.c:193
-msgid ""
-"Imports 3-dimensional Vis5D files (i.e. the V5D file with 1 variable and 1 "
-"time step)."
-msgstr ""
-"Importiert dreidimensionale Vis5D Dateien (z.B. V5D Datei mit 1 Variablen "
-"und 1 Zeitschritt)."
+msgid "Imports 3-dimensional Vis5D files (i.e. the V5D file with 1 variable and 1 time step)."
+msgstr "Importiert dreidimensionale Vis5D Dateien (z.B. V5D Datei mit 1 Variablen und 1 Zeitschritt)."
 #: ../raster3d/r3.in.v5d/main.c:213 ../raster3d/r3.in.ascii/main.c:281
 msgid "Unable to open 3D raster map"
@@ -24442,12 +22455,8 @@
 msgstr "Grundwasserneubildungskarte in m^3/s"
 #: ../raster3d/r3.gwflow/main.c:116
-msgid ""
-"The piezometric head result of the numerical calculation will be written to "
-"this map"
-msgstr ""
-"Das resultierende piezometrisches Niveau der numerischen Berechnung wird in "
-"diese Karte geschrieben."
+msgid "The piezometric head result of the numerical calculation will be written to this map"
+msgstr "Das resultierende piezometrisches Niveau der numerischen Berechnung wird in diese Karte geschrieben."
 #: ../raster3d/r3.gwflow/main.c:123
 msgid ""
@@ -24464,11 +22473,8 @@
 msgstr "Verwende 3D Maske (falls existent) mit den Eingabekarten."
 #: ../raster3d/r3.gwflow/main.c:141
-msgid ""
-"Use a sparse linear equation system, only available with iterative solvers"
-msgstr ""
-"Verwende ein dünnbesetztes lineares Gleichungssystem, nur für iterative "
-"Lösungsverfahren verfügbar."
+msgid "Use a sparse linear equation system, only available with iterative solvers"
+msgstr "Verwende ein dünnbesetztes lineares Gleichungssystem, nur für iterative Lösungsverfahren verfügbar."
 #: ../raster3d/r3.gwflow/main.c:169 ../raster3d/r3.mkdspf/main.c:75
 #: ../raster3d/r3.to.rast/main.c:215 ../raster3d/base/r3.timestamp.main.c:43
@@ -24478,16 +22484,12 @@
 msgstr "3D-Raster, Voxel"
 #: ../raster3d/r3.gwflow/main.c:171
-msgid ""
-"Calculates numerically transient, confined groundwater flow in three "
-"dimensions."
-msgstr ""
-"Berechnet transienten, beschränkten Grundwasserflusses in drei Dimensionen."
+msgid "Calculates numerically transient, confined groundwater flow in three dimensions."
+msgstr "Berechnet transienten, beschränkten Grundwasserflusses in drei Dimensionen."
 #: ../raster3d/r3.gwflow/main.c:193
 msgid "The direct Cholesky solver do not work with sparse matrices"
-msgstr ""
 #: ../raster3d/r3.gwflow/main.c:371
 #, c-format
@@ -24501,12 +22503,8 @@
 msgstr "Kann die 3D-Rasterkarte <%s> nicht schließen."
 #: ../raster3d/r3.mkdspf/main.c:77
-msgid ""
-"Creates a display file from an existing grid3 file according to specified "
-"threshold levels."
-msgstr ""
-"Erzeugt eine Datei aus einer existierenden grid3-Datei basierend auf einem "
-"gegebenen Threshold."
+msgid "Creates a display file from an existing grid3 file according to specified threshold levels."
+msgstr "Erzeugt eine Datei aus einer existierenden grid3-Datei basierend auf einem gegebenen Threshold."
 #: ../raster3d/r3.mkdspf/main.c:85
 msgid "Name of an existing 3d raster map"
@@ -24603,12 +22601,8 @@
 msgstr "Basisname für die resultierenden Rasterscheiben."
 #: ../raster3d/r3.to.rast/main.c:95
-msgid ""
-"Use the same resolution as the input 3D raster map for the 2D outputmaps, "
-"independent of the current region settings"
-msgstr ""
-"Verwende dieselbe Auflösung wie die 3D-Rasterkarte für die 2D-Ausgabekarten "
-"(unabhängig von der Auflösung der aktuellen Region). "
+msgid "Use the same resolution as the input 3D raster map for the 2D outputmaps, independent of the current region settings"
+msgstr "Verwende dieselbe Auflösung wie die 3D-Rasterkarte für die 2D-Ausgabekarten (unabhängig von der Auflösung der aktuellen Region). "
 #: ../raster3d/r3.to.rast/main.c:152 ../raster3d/r3.to.rast/main.c:159
 #: ../raster3d/r3.cross.rast/main.c:230 ../raster3d/r3.cross.rast/main.c:237
@@ -24635,12 +22629,8 @@
 msgstr "Fehler beim Öffnen der 3D-Rasterkarte <%s>."
 #: ../raster3d/r3.to.rast/main.c:267 ../raster3d/r3.out.vtk/main.c:451
-msgid ""
-"The 2D and 3D region settings are different. Using the 2D window settings to "
-"adjust the 2D part of the 3D region."
-msgstr ""
-"Die 2D und 3D Regionsparameter sind unterschiedlich. Verwende die 2D-"
-"Fenstereinstellungen, um den 2D-Teil der 3D-Region anzupassen."
+msgid "The 2D and 3D region settings are different. Using the 2D window settings to adjust the 2D part of the 3D region."
+msgstr "Die 2D und 3D Regionsparameter sind unterschiedlich. Verwende die 2D-Fenstereinstellungen, um den 2D-Teil der 3D-Region anzupassen."
 #: ../raster3d/r3.to.rast/main.c:301
 #, c-format
@@ -24655,8 +22645,7 @@
 #: ../raster3d/r3.to.rast/main.c:310
 #, c-format
 msgid "Raster map %d Filename: %s already exists. Will be overwritten!"
-msgstr ""
-"Rasterkarte %i Dateiname: %s existiert bereits. Sie wird überschrieben!"
+msgstr "Rasterkarte %i Dateiname: %s existiert bereits. Sie wird überschrieben!"
 #: ../raster3d/r3.out.vtk/errorHandling.c:52
 msgid "Unable to close input raster map"
@@ -24676,8 +22665,7 @@
 #: ../raster3d/r3.out.vtk/parameters.c:47
 msgid "Create VTK pointdata instead of VTK celldata (celldata is default)"
-msgstr ""
-"Erzeugt VTK Punktedaten anstelle von VTK Zelldaten (Standard ist Zelldaten)."
+msgstr "Erzeugt VTK Punktedaten anstelle von VTK Zelldaten (Standard ist Zelldaten)."
 #: ../raster3d/r3.out.vtk/parameters.c:56
 msgid "top surface 2D raster map"
@@ -24688,24 +22676,16 @@
 msgstr "2D Rasterkarte für den Boden."
 #: ../raster3d/r3.out.vtk/parameters.c:71
-msgid ""
-"Create 3d elevation output with a top and a bottom surface, both raster maps "
-"are required."
-msgstr ""
-"Erzeugt 3D Höhenausgabe mit einer Ober- und einer Unterfläche. Beide "
-"Rasterkarten werden benötigt."
+msgid "Create 3d elevation output with a top and a bottom surface, both raster maps are required."
+msgstr "Erzeugt 3D Höhenausgabe mit einer Ober- und einer Unterfläche. Beide Rasterkarten werden benötigt."
 #: ../raster3d/r3.out.vtk/parameters.c:82
-msgid ""
-"Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
-msgstr ""
-"Drei (R,G,B) 3D-Rasterkarten, um RGB-Werte zu erzeugen [redmap,greenmap,"
-"bluemap]"
+msgid "Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
+msgstr "Drei (R,G,B) 3D-Rasterkarten, um RGB-Werte zu erzeugen [redmap,greenmap,bluemap]"
 #: ../raster3d/r3.out.vtk/parameters.c:92
 msgid "Three (x,y,z) 3D raster maps to create vector values [xmap,ymap,zmap]"
-msgstr ""
-"Drei (x,y,z) 3D-Rasterkarten zum Erzeugen von Vektorwerten [xmap,ymap,zmap]"
+msgstr "Drei (x,y,z) 3D-Rasterkarten zum Erzeugen von Vektorwerten [xmap,ymap,zmap]"
 #: ../raster3d/r3.out.vtk/parameters.c:122
 msgid "Scale factor effects the origin"
@@ -24730,8 +22710,7 @@
 #: ../raster3d/r3.out.vtk/writeVTKData.c:429
 #: ../raster3d/r3.out.vtk/writeVTKData.c:462
 msgid "Wrong 3D raster map values: Values should in between 0 and 255\n"
-msgstr ""
-"Falsche Werte in 3D-Rasterkarte: Werte sollten zwischen 0 und 255 liegen!\n"
+msgstr "Falsche Werte in 3D-Rasterkarte: Werte sollten zwischen 0 und 255 liegen!\n"
 #: ../raster3d/r3.out.vtk/writeVTKHead.c:39
 msgid "write_vtk_structured_point_header: Writing VTKStructuredPoint-Header"
@@ -24743,8 +22722,7 @@
 #: ../raster3d/r3.out.vtk/writeVTKHead.c:116
 msgid "write_vtk_unstructured_grid_header: Writing VTKUnstructuredGrid-Header"
-msgstr ""
-"write_vtk_unstructured_grid_header: Schreibe VTKUnstructuredGrid-Header"
+msgstr "write_vtk_unstructured_grid_header: Schreibe VTKUnstructuredGrid-Header"
 #: ../raster3d/r3.out.vtk/main.c:99
 #, c-format
@@ -24776,16 +22754,11 @@
 #: ../raster3d/r3.out.vtk/main.c:171
 msgid "Please provide three 3D raster maps for the xyz-vector maps [x,y,z]"
-msgstr ""
-"Bitte geben Sie drei 3D-Rasterkarten für die xyz-Vektorkarten an [x,y,z]."
+msgstr "Bitte geben Sie drei 3D-Rasterkarten für die xyz-Vektorkarten an [x,y,z]."
 #: ../raster3d/r3.out.vtk/main.c:178
-msgid ""
-"No 3D raster data, RGB or xyz-vector maps are provided. Will only write the "
-"geometry"
-msgstr ""
-"Keine 3D-Daten, RGB oder xyz-Vektorkarten wurden angegeben! Werde nur die "
-"Geometrien schreiben."
+msgid "No 3D raster data, RGB or xyz-vector maps are provided. Will only write the geometry"
+msgstr "Keine 3D-Daten, RGB oder xyz-Vektorkarten wurden angegeben! Werde nur die Geometrien schreiben."
 #: ../raster3d/r3.out.vtk/main.c:211
 msgid "No RGB Data will be created"
@@ -24818,9 +22791,7 @@
 #: ../raster3d/r3.out.vtk/main.c:546
 msgid "Unable to close 3D raster map, the VTK file may be incomplete"
-msgstr ""
-"Kann die 3D-Rasterkarte nicht schließen. Die VTK-Datei könnte unvollständig "
-"sein."
+msgstr "Kann die 3D-Rasterkarte nicht schließen. Die VTK-Datei könnte unvollständig sein."
 #: ../raster3d/r3.out.vtk/main.c:561
 msgid "Unable to close VTK-ASCII file"
@@ -24832,9 +22803,7 @@
 #: ../raster3d/r3.in.ascii/main.c:90
 msgid "String representing NULL value data cell (use 'none' if no such value)"
-msgstr ""
-"Zeichenkette, die NULL-Werte repräsentiert (verwenden Sie 'none' wenn keiner "
-"existiert)"
+msgstr "Zeichenkette, die NULL-Werte repräsentiert (verwenden Sie 'none' wenn keiner existiert)"
 #: ../raster3d/r3.in.ascii/main.c:175
 #, c-format
@@ -24851,17 +22820,12 @@
 #: ../raster3d/r3.in.ascii/main.c:222
 #, c-format
-msgid ""
-"Data exists in input file after fully importing expected data.  [%.4f ...]"
-msgstr ""
-"Nach vollständigem Import der erwarteten Daten befinden sie sich in der "
-"Input-Datei.  [%.4f ...]"
+msgid "Data exists in input file after fully importing expected data.  [%.4f ...]"
+msgstr "Nach vollständigem Import der erwarteten Daten befinden sie sich in der Input-Datei.  [%.4f ...]"
 #: ../raster3d/r3.in.ascii/main.c:255
-msgid ""
-"Converts a 3D ASCII raster text file into a (binary) 3D raster map layer."
-msgstr ""
-"Konvertiert eine 3D ASCII Raster Textdatei in eine (binäre) 3D-Rasterkarte. "
+msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map layer."
+msgstr "Konvertiert eine 3D ASCII Raster Textdatei in eine (binäre) 3D-Rasterkarte. "
 #: ../raster3d/r3.in.ascii/main.c:297
 msgid "Unable to close ASCII file"
@@ -24976,8 +22940,7 @@
 " Use 'g.remove rast3d=G3D_MASK' to remove the existing mask."
 msgstr ""
 "Kann keine Maskendatei erzeugen: G3D_MASK existiert bereits.\n"
-"Verwenden Sie 'g.remove rast3d=G3D_MASK', um die existierende Maske zu "
-"löschen."
+"Verwenden Sie 'g.remove rast3d=G3D_MASK', um die existierende Maske zu löschen."
 #: ../raster3d/base/r3.info.main.c:80
 msgid "Outputs basic information about a user-specified 3D raster map layer."
@@ -25005,9 +22968,7 @@
 #: ../raster3d/base/r3.info.main.c:113
 msgid "Print 3D raster map timestamp (day.month.year hour:minute:seconds) only"
-msgstr ""
-"Gebe nur den Zeitstempel der 3D-Rasterkarte aus (Tag.Monat.Jahr Stunde:"
-"Minute:Sekunde)"
+msgstr "Gebe nur den Zeitstempel der 3D-Rasterkarte aus (Tag.Monat.Jahr Stunde:Minute:Sekunde)"
 #: ../raster3d/base/r3.info.main.c:121
 #, c-format
@@ -25040,20 +23001,12 @@
 msgstr "Kann Zeile der Höhenrasterkarte nicht bekommen."
 #: ../raster3d/r3.cross.rast/main.c:272
-msgid ""
-"Creates cross section 2D raster map from 3D raster map based on 2D elevation "
-"map."
-msgstr ""
-"Erzeugt einen Querschnitt in Form einer 2D-Rasterkarte aus einer 3D-"
-"Rasterkarte basierend auf 2D-Höhenkarte."
+msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map."
+msgstr "Erzeugt einen Querschnitt in Form einer 2D-Rasterkarte aus einer 3D-Rasterkarte basierend auf 2D-Höhenkarte."
 #: ../raster3d/r3.cross.rast/main.c:298
-msgid ""
-"The 2D and 3D region settings are different. Using the 3D raster map "
-"settings to adjust the 2D region."
-msgstr ""
-"Die 2D- und 3D-Regionsparameter sind unterschiedlich. Verwende die 3D-"
-"Rasterkarteneinstellungen, um die 2D-Region anzupassen."
+msgid "The 2D and 3D region settings are different. Using the 3D raster map settings to adjust the 2D region."
+msgstr "Die 2D- und 3D-Regionsparameter sind unterschiedlich. Verwende die 3D-Rasterkarteneinstellungen, um die 2D-Region anzupassen."
 #: ../raster3d/r3.cross.rast/main.c:333
 msgid "Elevation map not found"
@@ -25077,8 +23030,7 @@
 #: ../raster3d/r3.cross.rast/main.c:395
 msgid "Wrong 3D raster map datatype! Unable to create raster map."
-msgstr ""
-"Falscher Datentyp der 3D-Rasterkarte! Kann die Rasterkarte nicht erzeugen."
+msgstr "Falscher Datentyp der 3D-Rasterkarte! Kann die Rasterkarte nicht erzeugen."
 #: ../raster3d/r3.out.v5d/main.c:72
 msgid "3D raster map to be converted to Vis5D (V5D) file"
@@ -25109,8 +23061,7 @@
 #: ../raster3d/r3.out.v5d/main.c:288
 msgid "Exports GRASS 3D raster map to 3-dimensional Vis5D file."
-msgstr ""
-"Exportiert eine GRASS 3D-Rasterkarte in eine dreidimensionale Vis5D-Datei"
+msgstr "Exportiert eine GRASS 3D-Rasterkarte in eine dreidimensionale Vis5D-Datei"
 #: ../raster3d/r3.out.v5d/main.c:295
 msgid "Use map coordinates instead of xyz coordinates"
@@ -25130,8 +23081,7 @@
 #: ../vector/v.support/main.c:61
 msgid "Date of vector map digitization (e.g., \"15 Mar 2007\")"
-msgstr ""
-"Datum, an dem die Vektorkarte digitalisiert wurde (z.B., \"15 Mar 2007\")."
+msgstr "Datum, an dem die Vektorkarte digitalisiert wurde (z.B., \"15 Mar 2007\")."
 #: ../vector/v.support/main.c:68
 msgid "Person who created vector map"
@@ -25162,11 +23112,8 @@
 msgstr "Text, der an den Kommentar Metadatendatei der Karte angehängt wird"
 #: ../vector/v.support/main.c:118
-msgid ""
-"Command line to store into vector map history file (used for vector scripts)"
-msgstr ""
-"Kommentarzeile die in der History-Datei der Vektorkarte gespeichert wird "
-"(verwendet für Vektor-Skripts)"
+msgid "Command line to store into vector map history file (used for vector scripts)"
+msgstr "Kommentarzeile die in der History-Datei der Vektorkarte gespeichert wird (verwendet für Vektor-Skripts)"
 #: ../vector/v.support/main.c:122
 msgid "Replace comment instead of appending it"
@@ -25190,15 +23137,12 @@
 "%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"
 msgstr ""
 "\n"
-"%d Vertices aus der Eingabe %d (Vertices des angegebenen Typs) entfernt, z."
-"B. %.2f %%"
+"%d Vertices aus der Eingabe %d (Vertices des angegebenen Typs) entfernt, z.B. %.2f %%"
 #: ../vector/v.clean/prune.c:221
 #, c-format
 msgid "%d boundaries not pruned because pruning would damage topology"
-msgstr ""
-"%d Grenzen wurden nicht geputzt, weil das Putzen die Topologie beschädigt "
-"hätte."
+msgstr "%d Grenzen wurden nicht geputzt, weil das Putzen die Topologie beschädigt hätte."
 #: ../vector/v.clean/rmdac.c:61
 #, c-format
@@ -25227,52 +23171,12 @@
 msgstr "Säuberungswerkzeug"
 #: ../vector/v.clean/main.c:66
-#, fuzzy
-msgid ""
-"break;break lines at each intersection;rmdupl;remove duplicate geometry "
-"features (pay attention to categories!);rmdangle;remove dangles, threshold "
-"ignored if < 0;chdangle;change the type of boundary dangle to line, "
-"threshold ignored if < 0, input line type is ignored;rmbridge;remove bridges "
-"connecting area and island or 2 islands;chbridge;change the type of bridges "
-"connecting area and island or 2 islands from boundary to line;snap;snap "
-"lines to vertex in threshold;rmdac;remove duplicate area centroids ('type' "
-"option ignored);bpol;break (topologically clean) polygons (imported from non "
-"topological format, like ShapeFile). Boundaries are broken on each point "
-"shared between 2 and more polygons where angles of segments are different;"
-"prune;remove vertices in threshold from lines and boundaries, boundary is "
-"pruned only if topology is not damaged (new intersection, changed attachment "
-"of centroid), first and last segment of the boundary is never changed;rmarea;"
-"remove small areas, the longest boundary with adjacent area is removed;"
-"rmline;remove all lines or boundaries of zero length, threshold is ignored;"
-"rmsa;remove small angles between lines at nodes"
-msgstr ""
-"break;Teilt Linien an jeder Überschneidung;rmdupl;Entfernt doppelte "
-"Geometrie-Feature (Achten Sie auf die Kategorien!);rmdangle;Entfernt "
-"Überstände (dangles), Schwellwert wird ignoriert, wenn <0;chdangle;Ändert "
-"den Typ eines Überstands (dangle) zu einer Linie, Schwellwert wird "
-"ignoriert, wenn <0, Eingabe-Linien-Typ wird ignoriert;rmbridge;Entfernt "
-"Brücken, die eine Fläche und eine Insel oder 2 Inseln verbindet;chbridge;"
-"Ändert den Typ einer Brücke, die eine Fläche und eine Insel oder 2 Inseln "
-"verbindet von Grenze zu Linie;snap;Richtet Linien an Vertices innerhalb des "
-"Schwellwertes aus;rmdac;Entfernt doppelte Zentroide (Option 'type' wird "
-"ignoriert);bpol;Teilt (topologisch sauber) Polygone (importiert aus nicht "
-"topologischen Formaten, wie z.B. ShapeFile). Grenzen werden an jedem Punkt "
-"geteilt, der 2 oder mehr Polygonen gemeinsam ist und die Winkel der Segmente "
-"verschieden sind.;prune;Entfernt Vertices innerhalb des Schwellwertes von "
-"Linien und Grenzen. Grenzen werden nur gesäubert, wenn die Topologie nicht "
-"beschädigt wird (neue Überschneidungen, veränderte Zuordnung von "
-"Zentroiden), das erste und letzte Segment einer Grenze wird nie geändert;"
-"rmarea;Entfernt kleine Flächen, die längste Grenze mit einer benachbarten "
-"Fläche wird entfernt;rmline;Entfernt alle Linien und Grenzen mit der Länge "
-"null, Schwellwert wird ignoriert;rmsa;Entfernt spitze Winkel zwischen Linien "
-"an einem Knoten"
+msgid "break;break lines at each intersection;rmdupl;remove duplicate geometry features (pay attention to categories!);rmdangle;remove dangles, threshold ignored if < 0;chdangle;change the type of boundary dangle to line, threshold ignored if < 0, input line type is ignored;rmbridge;remove bridges connecting area and island or 2 islands;chbridge;change the type of bridges connecting area and island or 2 islands from boundary to line;snap;snap lines to vertex in threshold;rmdac;remove duplicate area centroids ('type' option ignored);bpol;break (topologically clean) polygons (imported from non topological format, like ShapeFile). Boundaries are broken on each point shared between 2 and more polygons where angles of segments are different;prune;remove vertices in threshold from lines and boundaries, boundary is pruned only if topology is not damaged (new intersection, changed attachment of centroid), first and last segment of the boundary is never changed;rmarea;remove small ar
 eas, the longest boundary with adjacent area is removed;rmline;remove all lines or boundaries of zero length, threshold is ignored;rmsa;remove small angles between lines at nodes"
+msgstr "break;Teilt Linien an jeder Überschneidung;rmdupl;Entfernt doppelte Geometrie-Feature (Achten Sie auf die Kategorien!);rmdangle;Entfernt Überstände (dangles), Schwellwert wird ignoriert, wenn <0;chdangle;Ändert den Typ eines Überstands (dangle) zu einer Linie, Schwellwert wird ignoriert, wenn <0, Eingabe-Linien-Typ wird ignoriert;rmbridge;Entfernt Brücken, die eine Fläche und eine Insel oder 2 Inseln verbindet;chbridge;Ändert den Typ einer Brücke, die eine Fläche und eine Insel oder 2 Inseln verbindet von Grenze zu Linie;snap;Richtet Linien an Vertices innerhalb des Schwellwertes aus;rmdac;Entfernt doppelte Zentroide (Option 'type' wird ignoriert);bpol;Teilt (topologisch sauber) Polygone (importiert aus nicht topologischen Formaten, wie z.B. ShapeFile). Grenzen werden an jedem Punkt geteilt, der 2 oder mehr Polygonen gemeinsam ist und die Winkel der Segmente verschieden sind.;prune;Entfernt Vertices innerhalb des Schwellwertes von Linien und Grenzen. Grenze
 n werden nur gesäubert, wenn die Topologie nicht beschädigt wird (neue Überschneidungen, veränderte Zuordnung von Zentroiden), das erste und letzte Segment einer Grenze wird nie geändert;rmarea;Entfernt kleine Flächen, die längste Grenze mit einer benachbarten Fläche wird entfernt;rmline;Entfernt alle Linien und Grenzen mit der Länge null, Schwellwert wird ignoriert;rmsa;Entfernt spitze Winkel zwischen Linien an einem Knoten"
 #: ../vector/v.clean/main.c:94
-msgid ""
-"Threshold in map units, one value for each tool (default: 0.0[,0.0,...])"
-msgstr ""
-"Schwellenwert in Karteneinheiten, einen Wert für jedes Werkzeug (Standard: "
-"0.0[,0.0,...])."
+msgid "Threshold in map units, one value for each tool (default: 0.0[,0.0,...])"
+msgstr "Schwellenwert in Karteneinheiten, einen Wert für jedes Werkzeug (Standard: 0.0[,0.0,...])."
 #: ../vector/v.clean/main.c:100
 msgid "Don't build topology for the output vector"
@@ -25459,24 +23363,12 @@
 msgstr "Benötigt für die Operation 'connect'."
 #: ../vector/v.net/main.c:71
-msgid ""
-"nodes;new point is placed on each node (line end) if doesn't exist;connect;"
-"connect still unconnected points to vector network by inserting new line(s);"
-"report;print to standard output {line_category start_point_category "
-"end_point_category};nreport;print to standard output {point_category "
-"line_category[,line_category...]}"
-msgstr ""
-"nodes;Neue Punkte werden auf jeden Knoten (Linienendpunkte) platziert, wenn "
-"sie nicht existieren;connect;Verbinde noch unverbundene Punkte des Netzwerks "
-"durch einfügen neuer Linien;report;Gebe auf der Standardausgabe "
-"{line_category start_point_category end_point_category} aus;nreport;Gebe auf "
-"der Standardausgabe {point_category line_category [line_category...]}aus"
+msgid "nodes;new point is placed on each node (line end) if doesn't exist;connect;connect still unconnected points to vector network by inserting new line(s);report;print to standard output {line_category start_point_category end_point_category};nreport;print to standard output {point_category line_category[,line_category...]}"
+msgstr "nodes;Neue Punkte werden auf jeden Knoten (Linienendpunkte) platziert, wenn sie nicht existieren;connect;Verbinde noch unverbundene Punkte des Netzwerks durch einfügen neuer Linien;report;Gebe auf der Standardausgabe {line_category start_point_category end_point_category} aus;nreport;Gebe auf der Standardausgabe {point_category line_category [line_category...]}aus"
 #: ../vector/v.net/main.c:97
 msgid "Required for operation 'connect'. Connect points in given threshold."
-msgstr ""
-"Erforderlich für die Operation 'connect'. Verbindet Punkte innerhalb des "
-"gegebenen Schwellenwertes."
+msgstr "Erforderlich für die Operation 'connect'. Verbindet Punkte innerhalb des gegebenen Schwellenwertes."
 #: ../vector/v.net/main.c:101
 msgid "Assign unique categories to new points"
@@ -25536,11 +23428,8 @@
 msgstr "Vektor, Import, Datenbank, Punkte"
 #: ../vector/v.in.db/main.c:54
-msgid ""
-"Creates new vector (points) map from database table containing coordinates."
-msgstr ""
-"Erzeugt neue Vektorkarte (Punkte) aus einer Datenbanktabelle, die "
-"Koordinaten beinhaltet."
+msgid "Creates new vector (points) map from database table containing coordinates."
+msgstr "Erzeugt neue Vektorkarte (Punkte) aus einer Datenbanktabelle, die Koordinaten beinhaltet."
 #: ../vector/v.in.db/main.c:58
 msgid "Input table name"
@@ -25568,11 +23457,8 @@
 #: ../vector/v.in.db/main.c:130
 #, c-format
-msgid ""
-"Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
-msgstr ""
-"Ausgabe-Vektorkarte, Tabelle <%s> (Treiber: <%s>, Datenbank: <%s>) existiert "
-"bereits."
+msgid "Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
+msgstr "Ausgabe-Vektorkarte, Tabelle <%s> (Treiber: <%s>, Datenbank: <%s>) existiert bereits."
 #: ../vector/v.in.db/main.c:138 ../vector/v.transform/trans_digit.c:114
 #: ../vector/v.db.connect/main.c:284
@@ -25620,13 +23506,8 @@
 msgstr "Vektor, Kerndichte"
 #: ../vector/v.kernel/main.c:108
-msgid ""
-"Generates a raster density map from vector point data using a moving kernel "
-"or optionally generates a vector density map on a vector network."
-msgstr ""
-"Erzeugt eine Raster-Dichtekarte aus Vektorpunkten unter Verwendung eines "
-"gleitenden Kerns. Optional kann eine Vektor-Dichtekarte basierend auf einem "
-"Vektornetzwerk erstellt werden."
+msgid "Generates a raster density map from vector point data using a moving kernel or optionally generates a vector density map on a vector network."
+msgstr "Erzeugt eine Raster-Dichtekarte aus Vektorpunkten unter Verwendung eines gleitenden Kerns. Optional kann eine Vektor-Dichtekarte basierend auf einem Vektornetzwerk erstellt werden."
 #: ../vector/v.kernel/main.c:112
 msgid "Input vector with training points"
@@ -25665,45 +23546,28 @@
 msgstr "Knoten Methode"
 #: ../vector/v.kernel/main.c:168
-msgid ""
-"none;No method applied at nodes with more than 2 arcs;split;Equal split "
-"(Okabe 2009) applied at nodes;"
-msgstr ""
-"nichts;Keine Methode wird bei Knoten mit mehr als 2 Arcs angewendet;split;"
-"Equal split (Okabe 2009) angewendet bei Knoten;"
+msgid "none;No method applied at nodes with more than 2 arcs;split;Equal split (Okabe 2009) applied at nodes;"
+msgstr "nichts;Keine Methode wird bei Knoten mit mehr als 2 Arcs angewendet;split;Equal split (Okabe 2009) angewendet bei Knoten;"
 #: ../vector/v.kernel/main.c:175
 msgid "Kernel function"
 msgstr "Kernel Funktion"
 #: ../vector/v.kernel/main.c:183
-msgid ""
-"Try to calculate an optimal standard deviation with 'stddeviation' taken as "
-"maximum (experimental)"
-msgstr ""
-"Versuche eine optimale Standardabweichung mit 'stddeviation' als Maximum zu "
-"berechnen (experimentell)."
+msgid "Try to calculate an optimal standard deviation with 'stddeviation' taken as maximum (experimental)"
+msgstr "Versuche eine optimale Standardabweichung mit 'stddeviation' als Maximum zu berechnen (experimentell)."
 #: ../vector/v.kernel/main.c:188
 msgid "Only calculate optimal standard deviation and exit (no map is written)"
-msgstr ""
-"Berechnet nur die optimale Standardabweichung und beendet sich (keine Karte "
-"wird geschrieben)."
+msgstr "Berechnet nur die optimale Standardabweichung und beendet sich (keine Karte wird geschrieben)."
 #: ../vector/v.kernel/main.c:193
-msgid ""
-"In network mode, normalize values by sum of density multiplied by length of "
-"each segment. Integral over the output map then gives 1.0 * mult"
-msgstr ""
-"Im Netzwerk-Modus: normalisiere Werte durch die Summe der Dichte "
-"multipliziert mit der Länge der Segmente. Integral über die Ausgabekarte "
-"ergibt 1.0 * mult."
+msgid "In network mode, normalize values by sum of density multiplied by length of each segment. Integral over the output map then gives 1.0 * mult"
+msgstr "Im Netzwerk-Modus: normalisiere Werte durch die Summe der Dichte multipliziert mit der Länge der Segmente. Integral über die Ausgabekarte ergibt 1.0 * mult."
 #: ../vector/v.kernel/main.c:198
 msgid "In network mode, multiply the result by number of input points."
-msgstr ""
-"Im Netzwerk-Modus: multipliziere das Ergebnis mit der Anzahl der Eingabe-"
-"Punkte."
+msgstr "Im Netzwerk-Modus: multipliziere das Ergebnis mit der Anzahl der Eingabe-Punkte."
 #: ../vector/v.kernel/main.c:203
 msgid "Verbose module output (retained for backwards compatibility)"
@@ -25718,20 +23582,12 @@
 msgstr "Unbekannte Kernelfunktion"
 #: ../vector/v.kernel/main.c:249
-msgid ""
-"Optimal standard deviation calculation is supported only for node method "
-"'none' and kernel function 'gaussian'."
-msgstr ""
-"Optimale Berechnung der Standardabweichung wird nur durch die Knoten-Methode "
-"'none' und die Kernelfunktion 'gaussian' unterstützt."
+msgid "Optimal standard deviation calculation is supported only for node method 'none' and kernel function 'gaussian'."
+msgstr "Optimale Berechnung der Standardabweichung wird nur durch die Knoten-Methode 'none' und die Kernelfunktion 'gaussian' unterstützt."
 #: ../vector/v.kernel/main.c:253
-msgid ""
-"Optimal standard deviation calculation is supported only for kernel function "
-"'gaussian'."
-msgstr ""
-"Optimale Berechnung der Standardabweichung wird nur durch die Kernel-"
-"Funktion 'gaussian' unterstützt."
+msgid "Optimal standard deviation calculation is supported only for kernel function 'gaussian'."
+msgstr "Optimale Berechnung der Standardabweichung wird nur durch die Kernel-Funktion 'gaussian' unterstützt."
 #: ../vector/v.kernel/main.c:290
 #, c-format
@@ -25745,12 +23601,8 @@
 #: ../vector/v.kernel/main.c:341
 #, c-format
-msgid ""
-"Automatic choice of smoothing parameter (standard deviation), maximum "
-"possible value of standard deviation is set to %f"
-msgstr ""
-"Automatisches Auswählen der Glättungsparameter (Standardabweichung). Der "
-"Maximalwert der möglichen Werte der Standardabweichung ist auf %f gesetzt"
+msgid "Automatic choice of smoothing parameter (standard deviation), maximum possible value of standard deviation is set to %f"
+msgstr "Automatisches Auswählen der Glättungsparameter (Standardabweichung). Der Maximalwert der möglichen Werte der Standardabweichung ist auf %f gesetzt"
 #: ../vector/v.kernel/main.c:348
 #, c-format
@@ -25769,12 +23621,8 @@
 #: ../vector/v.kernel/main.c:366
 #, c-format
-msgid ""
-"Distances between all points are beyond %e (4 * standard deviation), unable "
-"to calculate optimal value."
-msgstr ""
-"Entfernungen zwischen allen Punkten liegt über %e (4 * Standardabweichung), "
-"daher kann kein optimaler Wert berechnet werden."
+msgid "Distances between all points are beyond %e (4 * standard deviation), unable to calculate optimal value."
+msgstr "Entfernungen zwischen allen Punkten liegt über %e (4 * Standardabweichung), daher kann kein optimaler Wert berechnet werden."
 #: ../vector/v.kernel/main.c:377
 #, c-format
@@ -25831,46 +23679,32 @@
 msgstr "Vektor, Geometrie, Puffer"
 #: ../vector/v.buffer/main.c:256
-msgid ""
-"Creates a buffer around features of given type (areas must contain centroid)."
-msgstr ""
-"Erzeugt einen Buffer um die Objekte mit gegebenen Typ (Flächen müssen "
-"Zentroide enthalten)."
+msgid "Creates a buffer around features of given type (areas must contain centroid)."
+msgstr "Erzeugt einen Puffer um die Objekte mit gegebenen Typ (Flächen müssen Zentroide enthalten)."
 #: ../vector/v.buffer/main.c:271
 msgid "Buffer distance in map units"
-msgstr "Bufferdistanz in Karteneinheiten"
+msgstr "Pufferdistanz in Karteneinheiten"
 #: ../vector/v.buffer/main.c:278
 msgid "Attribute column to use for buffer distances"
-msgstr "Attributspalte mit den Bufferdistanzen."
+msgstr "Attributspalte mit den Pufferdistanzen."
 #: ../vector/v.buffer/main.c:286 ../vector/v.buffer2/main.c:407
 msgid "Scaling factor for attribute column values"
 msgstr "Skalierfaktor für die Werte der Attributspalte"
 #: ../vector/v.buffer/main.c:296 ../vector/v.buffer2/main.c:416
-msgid ""
-"Maximum distance between theoretical arc and polygon segments as multiple of "
-"buffer"
-msgstr ""
-"Maximale Distanz zwischen theoretischen Linien und Polygonsegmenten als "
-"Vielfaches des Buffers"
+msgid "Maximum distance between theoretical arc and polygon segments as multiple of buffer"
+msgstr "Maximale Distanz zwischen theoretischen Linien und Polygonsegmenten als Vielfaches des Puffers"
 #: ../vector/v.buffer/main.c:305
 msgid "Stop the process at a certain stage"
 msgstr "Stoppt den Prozess bei einer bestimmten Stufe."
 #: ../vector/v.buffer/main.c:319
-msgid ""
-"The bufcol option may contain bugs during the cleaning step. If you "
-"encounter problems, use the debug option or clean manually with v.clean "
-"tool=break; v.category step=0; v.extract -d type=area"
-msgstr ""
-"Die Option 'bufcol' kann Fehler enthalten während des Säuberungsschrittes. "
-"Wenn Sie auf Probleme stoßen, verwenden Sie die die Option 'debug' oder "
-"säubern Sie manuell mit v.clean tool=break; v.category step=0; v.extract -d "
-"type=area."
+msgid "The bufcol option may contain bugs during the cleaning step. If you encounter problems, use the debug option or clean manually with v.clean tool=break; v.category step=0; v.extract -d type=area"
+msgstr "Die Option 'bufcol' kann Fehler enthalten während des Säuberungsschrittes. Wenn Sie auf Probleme stoßen, verwenden Sie die die Option 'debug' oder säubern Sie manuell mit v.clean tool=break; v.category step=0; v.extract -d type=area."
 #: ../vector/v.buffer/main.c:335 ../vector/v.buffer/main.c:485
 #: ../vector/v.buffer/main.c:562 ../vector/v.buffer2/main.c:657
@@ -25895,7 +23729,7 @@
 #: ../vector/v.buffer/main.c:432
 msgid "Lines buffers... "
-msgstr "Linien-Buffer... "
+msgstr "Linien-Puffer... "
 #: ../vector/v.buffer/main.c:454 ../vector/v.buffer/main.c:466
 #: ../vector/v.buffer/main.c:531 ../vector/v.buffer/main.c:543
@@ -25916,12 +23750,11 @@
 #: ../vector/v.buffer/main.c:492 ../vector/v.buffer/main.c:569
 #, c-format
 msgid "The tolerance was reset to %g (map units). [category %d]"
-msgstr ""
-"Die Toleranz wurde auf %g (Karteneinheiten) zurückgesetzt [Kategorie %d]."
+msgstr "Die Toleranz wurde auf %g (Karteneinheiten) zurückgesetzt [Kategorie %d]."
 #: ../vector/v.buffer/main.c:509
 msgid "Areas buffers... "
-msgstr "Flächen-Buffer ..."
+msgstr "Flächen-Puffer ..."
 #: ../vector/v.buffer/main.c:607 ../vector/v.buffer2/main.c:770
 msgid "Building parts of topology..."
@@ -25974,12 +23807,8 @@
 msgstr "Vektor, Interpolation"
 #: ../vector/v.vol.rst/main.c:204
-msgid ""
-"Interpolates point data to a 3D raster map using regularized spline with "
-"tension (RST) algorithm."
-msgstr ""
-"Interpoliert Punkte zu einer 3D Rasterkarte unter Verwendung des regularized "
-"spline with tension (RST) Algorithmus."
+msgid "Interpolates point data to a 3D raster map using regularized spline with tension (RST) algorithm."
+msgstr "Interpoliert Punkte zu einer 3D Rasterkarte unter Verwendung des regularized spline with tension (RST) Algorithmus."
 #: ../vector/v.vol.rst/main.c:237
 msgid "Name of the vector map with input x,y,z,w"
@@ -26035,8 +23864,7 @@
 #: ../vector/v.vol.rst/main.c:336 ../vector/v.surf.rst/main.c:349
 msgid "Minimum distance between points (to remove almost identical points)"
-msgstr ""
-"Minimale Distanz zwischen Punkten (um fast identische Punkte zu entfernen)"
+msgstr "Minimale Distanz zwischen Punkten (um fast identische Punkte zu entfernen)"
 #: ../vector/v.vol.rst/main.c:345
 msgid "Conversion factor for w-values used for interpolation"
@@ -26110,15 +23938,11 @@
 #: ../vector/v.vol.rst/user1.c:107
 msgid "Column type of wcolumn is not supported (must be integer or double)"
-msgstr ""
-"Spaltentyp der wcolumn wird nicht unterstützt (muss integer oder double sein)"
+msgstr "Spaltentyp der wcolumn wird nicht unterstützt (muss integer oder double sein)"
 #: ../vector/v.vol.rst/user1.c:126
-msgid ""
-"Column type of smooth column is not supported (must be integer or double)"
-msgstr ""
-"Spaltentyp der 'smooth'-Spalte wird nicht unterstützt (muss integer oder "
-"double sein)"
+msgid "Column type of smooth column is not supported (must be integer or double)"
+msgstr "Spaltentyp der 'smooth'-Spalte wird nicht unterstützt (muss integer oder double sein)"
 #: ../vector/v.qcount/main.c:70
 msgid "Indices for quadrat counts of sites lists."
@@ -26130,9 +23954,7 @@
 #: ../vector/v.qcount/main.c:84
 msgid "Output quadrant centres, number of points is written as category"
-msgstr ""
-"Gebe die Zentren der Quadrate aus, Anzahl der Punkte wird als Kategorie "
-"ausgegeben."
+msgstr "Gebe die Zentren der Quadrate aus, Anzahl der Punkte wird als Kategorie ausgegeben."
 #: ../vector/v.qcount/main.c:91
 msgid "Number of quadrats"
@@ -26175,12 +23997,8 @@
 msgstr "Sammle Teilnetze für nächste Zentren (Richtung: vom Zentrum)."
 #: ../vector/v.net.alloc/main.c:65
-msgid ""
-"Centre node must be opened (costs >= 0). Costs of centre node are used in "
-"calculation"
-msgstr ""
-"Zentraler Knoten muss geöffnet sein (Kosten >= 0). Kosten des zentralen "
-"Knoten gehen im die Berechnung mit ein."
+msgid "Centre node must be opened (costs >= 0). Costs of centre node are used in calculation"
+msgstr "Zentraler Knoten muss geöffnet sein (Kosten >= 0). Kosten des zentralen Knoten gehen im die Berechnung mit ein."
 #: ../vector/v.net.alloc/main.c:92 ../vector/v.net.iso/main.c:99
 msgid "Arc forward/both direction(s) cost column (number)"
@@ -26195,12 +24013,8 @@
 msgstr "Spalte mit Kosten für Knoten (Zahl)."
 #: ../vector/v.net.alloc/main.c:110
-msgid ""
-"Categories of centres (points on nodes) to which net will be allocated, "
-"layer for this categories is given by nlayer option"
-msgstr ""
-"Kategorien der Zentren (Punkte auf Knoten) zu welchen das Netz zugewiesen "
-"wird. Der Layer für diese Kategorien wird mit der 'nlayer'-Option angegeben."
+msgid "Categories of centres (points on nodes) to which net will be allocated, layer for this categories is given by nlayer option"
+msgstr "Kategorien der Zentren (Punkte auf Knoten) zu welchen das Netz zugewiesen wird. Der Layer für diese Kategorien wird mit der 'nlayer'-Option angegeben."
 #: ../vector/v.net.alloc/main.c:186
 #, c-format
@@ -26209,8 +24023,7 @@
 #: ../vector/v.net.alloc/main.c:189 ../vector/v.net.iso/main.c:227
 msgid "Not enough centres for selected nlayer. Nothing will be allocated."
-msgstr ""
-"Nicht genügend Zentren für den gewählten nlayer. Nichts wird zugewiesen."
+msgstr "Nicht genügend Zentren für den gewählten nlayer. Nichts wird zugewiesen."
 #: ../vector/v.net.alloc/main.c:200
 msgid "Calculating costs from centres ..."
@@ -26219,8 +24032,7 @@
 #: ../vector/v.net.alloc/main.c:340 ../vector/v.net.alloc/main.c:351
 #: ../vector/v.net.iso/main.c:508
 msgid "Cannot get line segment, segment out of line"
-msgstr ""
-"Kann das Liniensegment nicht bekommen, Segment ist außerhalb der Linie."
+msgstr "Kann das Liniensegment nicht bekommen, Segment ist außerhalb der Linie."
 #: ../vector/v.net.flow/main.c:58
 msgid "vector, network, flow"
@@ -26228,8 +24040,7 @@
 #: ../vector/v.net.flow/main.c:60
 msgid "Computes the maximum flow between two sets of nodes in the network."
-msgstr ""
-"Berechnet den maximalen Fluss zwischen zwei Auswahlen von Knoten im Netzwerk."
+msgstr "Berechnet den maximalen Fluss zwischen zwei Auswahlen von Knoten im Netzwerk."
 #: ../vector/v.net.flow/main.c:71
 msgid "Name for output vector map containing a minimum cut"
@@ -26253,8 +24064,7 @@
 #: ../vector/v.net.flow/main.c:97
 msgid "Source WHERE conditions of SQL statement without 'where' keyword"
-msgstr ""
-"Source WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
+msgstr "Source WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
 #: ../vector/v.net.flow/main.c:102
 msgid "Sink layer number or name"
@@ -26271,8 +24081,7 @@
 #: ../vector/v.net.flow/main.c:113
 msgid "Sink WHERE conditions of SQL statement without 'where' keyword"
-msgstr ""
-"Sink WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
+msgstr "Sink WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
 #: ../vector/v.net.flow/main.c:172 ../vector/v.net.centrality/main.c:244
 #: ../vector/v.net.distance/main.c:212 ../vector/v.sample/main.c:219
@@ -26336,13 +24145,8 @@
 msgstr "Eingabedatei ist portabel."
 #: ../vector/v.convert/read.c:99
-msgid ""
-"Input file is not portable. We will attempt to convert anyway but conversion "
-"may fail. Please read manual for detail information."
-msgstr ""
-"Eingabedatei ist nicht portabel. Wir versuchen sie trotzdem zu konvertieren; "
-"dies kann aber schiefgehen. Bitte lesen Sie die Hilfeseiten für weitere "
-"Informationen."
+msgid "Input file is not portable. We will attempt to convert anyway but conversion may fail. Please read manual for detail information."
+msgstr "Eingabedatei ist nicht portabel. Wir versuchen sie trotzdem zu konvertieren; dies kann aber schiefgehen. Bitte lesen Sie die Hilfeseiten für weitere Informationen."
 #: ../vector/v.convert/read.c:185
 #, c-format
@@ -26367,8 +24171,7 @@
 #: ../vector/v.convert/read.c:192
 #, c-format
 msgid "[%d] area boundaries read and written to output"
-msgstr ""
-"[%d] Grenzen (boundaries) wurden gelesen und in die Ausgabe geschrieben"
+msgstr "[%d] Grenzen (boundaries) wurden gelesen und in die Ausgabe geschrieben"
 #: ../vector/v.convert/read.c:193
 #, c-format
@@ -26451,8 +24254,7 @@
 #: ../vector/v.convert/att.c:36
 msgid "No category labels (dig_cats) found, no table created"
-msgstr ""
-"Keine Kategoriebeschriftungen (dig_cats) gefunden; keine Tabelle erstellt."
+msgstr "Keine Kategoriebeschriftungen (dig_cats) gefunden; keine Tabelle erstellt."
 #: ../vector/v.convert/att.c:41
 msgid "Unable to open dig_cats file"
@@ -26482,9 +24284,7 @@
 #: ../vector/v.convert/old2new.c:89
 #, c-format
 msgid "Failed to attach an attribute (category %d) to a line."
-msgstr ""
-"Das Anfügen von einem Attribut (Kategorie %d) an eine Linie ist "
-"fehlgeschlagen."
+msgstr "Das Anfügen von einem Attribut (Kategorie %d) an eine Linie ist fehlgeschlagen."
 #: ../vector/v.convert/old2new.c:94
 #, c-format
@@ -26600,14 +24400,11 @@
 #: ../vector/v.in.ascii/in.c:50
 msgid "Creates a vector map from ASCII points file or ASCII vector file."
-msgstr ""
-"Erzeugt eine Vektorkarte aus einer ASCII-Punktdatei oder ASCII-Vektordatei."
+msgstr "Erzeugt eine Vektorkarte aus einer ASCII-Punktdatei oder ASCII-Vektordatei."
 #: ../vector/v.in.ascii/in.c:56
 msgid "ASCII file to be imported, if not given reads from standard input"
-msgstr ""
-"ASCII-Datei, die importiert werden soll. Wenn nichts angegeben wird von der "
-"Standardeingabe gelesen."
+msgstr "ASCII-Datei, die importiert werden soll. Wenn nichts angegeben wird von der Standardeingabe gelesen."
 #: ../vector/v.in.ascii/in.c:67
 msgid "point;simple x,y[,z] list;standard;GRASS vector ASCII format"
@@ -26624,21 +24421,15 @@
 #: ../vector/v.in.ascii/in.c:83
 msgid "Number of header lines to skip at top of input file (points mode)"
-msgstr ""
-"Anzahl der Kopfzeilen, die am Anfang der Eingabedatei übersprungen werden "
-"soll (Punktmodus)."
+msgstr "Anzahl der Kopfzeilen, die am Anfang der Eingabedatei übersprungen werden soll (Punktmodus)."
 #: ../vector/v.in.ascii/in.c:92
 msgid "Column definition in SQL style (points mode)"
 msgstr "Spaltendefinition im SQL-Stil (Punkt-Modus)."
 #: ../vector/v.in.ascii/in.c:93
-msgid ""
-"For example: 'x double precision, y double precision, cat int, name "
-"varchar(10)'"
-msgstr ""
-"Zum Beispiel: 'x double precision, y double precision, cat int, name "
-"varchar(10)'"
+msgid "For example: 'x double precision, y double precision, cat int, name varchar(10)'"
+msgstr "Zum Beispiel: 'x double precision, y double precision, cat int, name varchar(10)'"
 #: ../vector/v.in.ascii/in.c:105 ../vector/v.in.ascii/in.c:115
 msgid "First column is 1"
@@ -26654,20 +24445,15 @@
 #: ../vector/v.in.ascii/in.c:125
 msgid "First column is 1. If 0, z coordinate is not used"
-msgstr ""
-"Erste Spalte ist 1. Wenn 0, dann wird die Z-Koordinate nicht verwendet."
+msgstr "Erste Spalte ist 1. Wenn 0, dann wird die Z-Koordinate nicht verwendet."
 #: ../vector/v.in.ascii/in.c:135
 msgid "Number of column used as category (points mode)"
 msgstr "Nummer der Spalte, die als Kategorie genutzt wird (Punkt-Modus)."
 #: ../vector/v.in.ascii/in.c:137
-msgid ""
-"First column is 1. If 0, unique category is assigned to each row and written "
-"to new column 'cat'"
-msgstr ""
-"Erste Spalte ist 1. Wenn 0, dann wird jeder Zeile eine eindeutige Kategorie "
-"zugeweisen und in die neue Spalte 'cat' geschrieben."
+msgid "First column is 1. If 0, unique category is assigned to each row and written to new column 'cat'"
+msgstr "Erste Spalte ist 1. Wenn 0, dann wird jeder Zeile eine eindeutige Kategorie zugeweisen und in die neue Spalte 'cat' geschrieben."
 #: ../vector/v.in.ascii/in.c:141 ../vector/v.in.dwg/main.c:88
 msgid "Create 3D vector map"
@@ -26675,9 +24461,7 @@
 #: ../vector/v.in.ascii/in.c:146
 msgid "Create a new empty vector map and exit. Nothing is read from input."
-msgstr ""
-"Erstellt eine neue, leere Vektorkarte und beendet sich. Nichts wird "
-"eingelesen."
+msgstr "Erstellt eine neue, leere Vektorkarte und beendet sich. Nichts wird eingelesen."
 #: ../vector/v.in.ascii/in.c:151
 msgid "Don't expect a header when reading in standard format"
@@ -26689,14 +24473,11 @@
 #: ../vector/v.in.ascii/in.c:167
 msgid "Only import points falling within current region (points mode)"
-msgstr ""
-"Importiere nur Punkte die sich innerhalb der aktuellen Region befinden."
+msgstr "Importiere nur Punkte die sich innerhalb der aktuellen Region befinden."
 #: ../vector/v.in.ascii/in.c:181
 msgid "Please specify reasonable number of lines to skip"
-msgstr ""
-"Bitte geben Sie eine angemessene Zahl von Zeilen an, die übersprungen werden "
-"sollen."
+msgstr "Bitte geben Sie eine angemessene Zahl von Zeilen an, die übersprungen werden sollen."
 #: ../vector/v.in.ascii/in.c:184
 msgid "Please specify z column"
@@ -26747,15 +24528,13 @@
 "(falsches Trennzeichen?)"
 #: ../vector/v.in.ascii/in.c:271
-msgid ""
-"z column number > minimum last column number (incorrect field separator?)"
+msgid "z column number > minimum last column number (incorrect field separator?)"
 msgstr ""
 "Z-Spaltennummer > letzte Spaltennummer\n"
 #: ../vector/v.in.ascii/in.c:276
-msgid ""
-"cat column number > minimum last column number (incorrect field separator?)"
+msgid "cat column number > minimum last column number (incorrect field separator?)"
 msgstr "cat-Spaltennummer > letzte Spaltennummer (falsches Trennzeichen?)"
 #: ../vector/v.in.ascii/in.c:282
@@ -26780,66 +24559,51 @@
 #: ../vector/v.in.ascii/in.c:417
 #, c-format
-msgid ""
-"Number of columns defined (%d) does not match number of columns (%d) in input"
-msgstr ""
-"Die Anzahl der definierten Spalten (%d) stimmt nicht mit der Anzahl der "
-"Spalten (%d) in der Eingabe überein."
+msgid "Number of columns defined (%d) does not match number of columns (%d) in input"
+msgstr "Die Anzahl der definierten Spalten (%d) stimmt nicht mit der Anzahl der Spalten (%d) in der Eingabe überein."
 #: ../vector/v.in.ascii/in.c:445
 #, c-format
 msgid "Column number %d <%s> defined as double has only integer values"
-msgstr ""
-"Spalte Nummer %d <%s> ist als double definiert und hat nur Integer-Werte."
+msgstr "Spalte Nummer %d <%s> ist als double definiert und hat nur Integer-Werte."
 #: ../vector/v.in.ascii/in.c:450
 #, c-format
 msgid "Column number %d <%s> defined as string has only integer values"
-msgstr ""
-"Spalte Nummer %d <%s> ist als string definiert und hat nur Integer-Werte."
+msgstr "Spalte Nummer %d <%s> ist als string definiert und hat nur Integer-Werte."
 #: ../vector/v.in.ascii/in.c:458
 #, c-format
 msgid "Column number %d <%s> defined as integer has double values"
-msgstr ""
-"Spalte Nummer %d <%s> ist als integer definiert und hat nur Double-Werte."
+msgstr "Spalte Nummer %d <%s> ist als integer definiert und hat nur Double-Werte."
 #: ../vector/v.in.ascii/in.c:463
 #, c-format
 msgid "Column number %d <%s> defined as string has double values"
-msgstr ""
-"Spalte Nummer %d <%s> ist als string definiert und hat nur Double-Werte."
+msgstr "Spalte Nummer %d <%s> ist als string definiert und hat nur Double-Werte."
 #: ../vector/v.in.ascii/in.c:471
 #, c-format
 msgid "Column number %d <%s> defined as integer has string values"
-msgstr ""
-"Spalte Nummer %d <%s> ist als integer definiert und hat nur String-Werte."
+msgstr "Spalte Nummer %d <%s> ist als integer definiert und hat nur String-Werte."
 #: ../vector/v.in.ascii/in.c:477
 #, c-format
 msgid "Column number %d <%s> defined as double has string values"
-msgstr ""
-"Spalte Nummer %d <%s> ist als double definiert und hat nur String-Werte."
+msgstr "Spalte Nummer %d <%s> ist als double definiert und hat nur String-Werte."
 #: ../vector/v.in.ascii/in.c:483
 #, c-format
 msgid "Length of column %d <%s> (%d) is less than maximum value length (%d)"
-msgstr ""
-"Länge der Spalte %d <%s> (%d) ist geringer als die maximale Länge der Werte "
-"(%d)."
+msgstr "Länge der Spalte %d <%s> (%d) ist geringer als die maximale Länge der Werte (%d)."
 #: ../vector/v.in.ascii/in.c:523
 msgid "Populating table..."
 msgstr "Fülle Tabelle..."
 #: ../vector/v.in.ascii/in.c:530
-msgid ""
-"Could not close attribute table. The DBMI driver did not accept all "
-"attributes"
-msgstr ""
-"Konnte Attributetabelle nicht schliessen. Der DBMI-Treiber hat nicht alle "
-"Attribute akzeptiert."
+msgid "Could not close attribute table. The DBMI driver did not accept all attributes"
+msgstr "Konnte Attributetabelle nicht schliessen. Der DBMI-Treiber hat nicht alle Attribute akzeptiert."
 #: ../vector/v.random/main.c:85
 msgid "Randomly generate a 2D/3D vector points map."
@@ -26867,12 +24631,8 @@
 msgstr "Spaltenname und -typ (z.B. INTEGER, DOUBLE PRECISION) für z Werte."
 #: ../vector/v.random/main.c:121
-msgid ""
-"If type is not given then DOUBLE PRECISION is used. Writes Z data to column "
-"instead of 3D vector."
-msgstr ""
-"Wenn kein Typ angegeben wurde, wird DOUBLE PRECISION verwendet. Schreibe Z "
-"Werte in eine Spalte an Stelle einer 3D Vektorkarte."
+msgid "If type is not given then DOUBLE PRECISION is used. Writes Z data to column instead of 3D vector."
+msgstr "Wenn kein Typ angegeben wurde, wird DOUBLE PRECISION verwendet. Schreibe Z Werte in eine Spalte an Stelle einer 3D Vektorkarte."
 #: ../vector/v.random/main.c:127 ../vector/v.in.ogr/main.c:214
 msgid "Create 3D output"
@@ -26889,9 +24649,7 @@
 #: ../vector/v.random/main.c:142
 msgid "v.random can't create 3D vector and attribute table at same time"
-msgstr ""
-"v.random kann 3D Vektorkarten und Attributtabellen nicht zu selben Zeit "
-"erstellen."
+msgstr "v.random kann 3D Vektorkarten und Attributtabellen nicht zu selben Zeit erstellen."
 #: ../vector/v.random/main.c:150
 #, c-format
@@ -26908,12 +24666,8 @@
 msgstr "Tabelle sollte nur zwei Spalten haben."
 #: ../vector/v.random/main.c:234
-msgid ""
-"You have created unsupported column type. This module supports only INTEGER "
-"and DOUBLE PRECISION column types."
-msgstr ""
-"Sie haben nicht unterstützte Spaltentypen erzeugt. Dieses Modul unterstützt "
-"nur die Spaltentypen INTEGER und DOUBLE PRECISION."
+msgid "You have created unsupported column type. This module supports only INTEGER and DOUBLE PRECISION column types."
+msgstr "Sie haben nicht unterstützte Spaltentypen erzeugt. Dieses Modul unterstützt nur die Spaltentypen INTEGER und DOUBLE PRECISION."
 #: ../vector/v.random/main.c:264
 msgid "Generating points..."
@@ -27016,8 +24770,7 @@
 #: ../vector/v.label/main.c:138
 msgid "Space between letters for curled labels (in map-units)"
-msgstr ""
-"Zwischenraum zwischen den Buchstaben für gewellte Label (in Karteneinheiten)."
+msgstr "Zwischenraum zwischen den Buchstaben für gewellte Label (in Karteneinheiten)."
 #: ../vector/v.label/main.c:145
 msgid "Label size (in points)"
@@ -27042,16 +24795,11 @@
 #: ../vector/v.label/main.c:201 ../vector/v.label.sa/main.c:181
 msgid "Opaque to vector (only relevant if background color is selected)"
-msgstr ""
-"Undurchsichtig für Vektoren (nur relevant, wenn eine Hintergrundfarbe "
-"ausgewählt wurde)."
+msgstr "Undurchsichtig für Vektoren (nur relevant, wenn eine Hintergrundfarbe ausgewählt wurde)."
 #: ../vector/v.label/main.c:252
-msgid ""
-"size and space options vary significantly which may lead to crummy output"
-msgstr ""
-"Größen- und Abstandsoptionen differieren signifikant, was zu einer komischen "
-"Ausgabe führen kann."
+msgid "size and space options vary significantly which may lead to crummy output"
+msgstr "Größen- und Abstandsoptionen differieren signifikant, was zu einer komischen Ausgabe führen kann."
 #: ../vector/v.label/main.c:260
 msgid "Too many parameters for <reference>"
@@ -27092,8 +24840,7 @@
 #: ../vector/v.info/main.c:80
 msgid "Print types/names of table columns for specified layer instead of info"
-msgstr ""
-"Gebe Typ/Name der Tabellenspalten bestimmter Layer anstatt der Info aus."
+msgstr "Gebe Typ/Name der Tabellenspalten bestimmter Layer anstatt der Info aus."
 #: ../vector/v.info/main.c:95
 msgid "Print topology information only"
@@ -27102,9 +24849,7 @@
 #: ../vector/v.info/main.c:199 ../vector/v.db.connect/main.c:161
 #, c-format
 msgid "Database connection for map <%s> is not defined in DB file"
-msgstr ""
-"Die Datenbankverbindung für die Karte <%s> ist nicht definiert in der DB-"
-"Datei."
+msgstr "Die Datenbankverbindung für die Karte <%s> ist nicht definiert in der DB-Datei."
 #: ../vector/v.info/main.c:205
 #, c-format
@@ -27270,14 +25015,12 @@
 #: ../vector/v.to.rast/vect2rast.c:164
 #, c-format
 msgid "Problem processing areas from vector map <%s>, continuing..."
-msgstr ""
-"Probleme beim Verarbeiten der Flächen der Vektorkarte <%s>, mache weiter..."
+msgstr "Probleme beim Verarbeiten der Flächen der Vektorkarte <%s>, mache weiter..."
 #: ../vector/v.to.rast/vect2rast.c:175
 #, c-format
 msgid "Problem processing lines from vector map <%s>, continuing..."
-msgstr ""
-"Probleme beim Verarbeiten der Linien der Vektorkarte <%s>, mache weiter..."
+msgstr "Probleme beim Verarbeiten der Linien der Vektorkarte <%s>, mache weiter..."
 #: ../vector/v.to.rast/vect2rast.c:200
 msgid "Creating support files for raster map..."
@@ -27337,8 +25080,7 @@
 #: ../vector/v.to.rast/do_lines.c:125
 #, c-format
 msgid "%d lines with varying height were not written to raster"
-msgstr ""
-"%d Linien mit wechselnden Höhen wurden nicht in das Raster geschrieben."
+msgstr "%d Linien mit wechselnden Höhen wurden nicht in das Raster geschrieben."
 #: ../vector/v.to.rast/support.c:139 ../vector/v.to.rast/support.c:300
 #: ../vector/v.to.rast/support.c:450
@@ -27353,8 +25095,7 @@
 #: ../vector/v.to.rast/support.c:173
 #, c-format
 msgid "Error in color definition column (%s) with cat %d: colorstring [%s]"
-msgstr ""
-"Fehler in der Spalte mit den Farbwerten (%s),mit cat %d: Farbstring [%s]."
+msgstr "Fehler in der Spalte mit den Farbwerten (%s),mit cat %d: Farbstring [%s]."
 #: ../vector/v.to.rast/support.c:176
 msgid "Color set to [200:200:200]"
@@ -27367,9 +25108,7 @@
 #: ../vector/v.to.rast/support.c:273
 msgid "Label column was not specified, no labels will be written"
-msgstr ""
-"Spalte mit Beschriftungen wurde nicht angegeben. Es werden keine "
-"Beschriftungen ausgegeben."
+msgstr "Spalte mit Beschriftungen wurde nicht angegeben. Es werden keine Beschriftungen ausgegeben."
 #: ../vector/v.to.rast/support.c:349 ../vector/v.to.rast/support.c:496
 #, c-format
@@ -27378,7 +25117,7 @@
 #: ../vector/v.to.rast/support.c:514
 msgid "Cannot allocate memory for row buffer"
-msgstr "Kann keinen Speicher für Zeilenbuffer reservieren."
+msgstr "Kann keinen Speicher für Zeilenpuffer reservieren."
 #: ../vector/v.to.rast/support.c:584
 #, c-format
@@ -27398,20 +25137,12 @@
 msgstr "Quelle der Rasterwerte"
 #: ../vector/v.to.rast/main.c:62
-msgid ""
-"attr;read values from attribute table;cat;use category values;val;use value "
-"specified by value option;z;use z coordinate (points or contours only);dir;"
-"output as flow direction (lines only)"
-msgstr ""
-"attr;Lese Werte aus der Attributtabelle;cat;Verwende Kategoriewerte;val;"
-"Verwende Werte angegeben durch die Option 'value';z;Verwende die Z-"
-"Koordinate (nur Punkte oder Konturen);dir;Ausgabe als Flussrichtung (nur "
-"Linien)"
+msgid "attr;read values from attribute table;cat;use category values;val;use value specified by value option;z;use z coordinate (points or contours only);dir;output as flow direction (lines only)"
+msgstr "attr;Lese Werte aus der Attributtabelle;cat;Verwende Kategoriewerte;val;Verwende Werte angegeben durch die Option 'value';z;Verwende die Z-Koordinate (nur Punkte oder Konturen);dir;Ausgabe als Flussrichtung (nur Linien)"
 #: ../vector/v.to.rast/main.c:71
 msgid "Name of column for 'attr' parameter (data type must be numeric)"
-msgstr ""
-"Name der Spalte für den Parameter 'attr' (Datentyp muss numerisch sein)."
+msgstr "Name der Spalte für den Parameter 'attr' (Datentyp muss numerisch sein)."
 #: ../vector/v.to.rast/main.c:77
 msgid "Name of color definition column (with RRR:GGG:BBB entries)"
@@ -27431,21 +25162,15 @@
 #: ../vector/v.to.rast/main.c:118
 msgid "Column parameter cannot be combined with use of category values option"
-msgstr ""
-"Der Parameter Spalte kann nicht mit der Benutzung des Kategoriewertes "
-"kombiniert werden."
+msgstr "Der Parameter Spalte kann nicht mit der Benutzung des Kategoriewertes kombiniert werden."
 #: ../vector/v.to.rast/main.c:123
 msgid "Column parameter cannot be combined with use of value option"
-msgstr ""
-"Der Parameter Spalte kann nicht mit der Benutzung der Wert-Option kombiniert "
-"werden."
+msgstr "Der Parameter Spalte kann nicht mit der Benutzung der Wert-Option kombiniert werden."
 #: ../vector/v.to.rast/main.c:128
 msgid "Column parameter cannot be combined with use of z coordinate"
-msgstr ""
-"Der Parameter Spalte kann nicht mit der Benutzung von Z-Koordinaten "
+msgstr "Der Parameter Spalte kann nicht mit der Benutzung von Z-Koordinaten kombiniert werden."
 #: ../vector/v.to.rast/main.c:134
 #, c-format
@@ -27458,17 +25183,11 @@
 #: ../vector/v.net.salesman/main.c:99
 msgid "Creates a cycle connecting given nodes (Traveling salesman problem)."
-msgstr ""
-"Erzeugt einen Ring der die gegebenen Knoten verbindet (Handelsreisenden-"
-"Problem)."
+msgstr "Erzeugt einen Ring der die gegebenen Knoten verbindet (Handelsreisenden-Problem)."
 #: ../vector/v.net.salesman/main.c:101
-msgid ""
-"Note that TSP is NP-hard, heuristic algorithm is used by this module and "
-"created cycle may be sub optimal"
-msgstr ""
-"Bedenken Sie das: Das Handelsreisenden-Problem ist NP-hart. Dies Modul setzt "
-"ein heuristischen Algorithmus ein und erzeugte Ringen können suboptimal sein."
+msgid "Note that TSP is NP-hard, heuristic algorithm is used by this module and created cycle may be sub optimal"
+msgstr "Bedenken Sie das: Das Handelsreisenden-Problem ist NP-hart. Dies Modul setzt ein heuristischen Algorithmus ein und erzeugte Ringen können suboptimal sein."
 #: ../vector/v.net.salesman/main.c:119
 msgid "Node layer (used for cities)"
@@ -27480,9 +25199,7 @@
 #: ../vector/v.net.salesman/main.c:130
 msgid "Categories of points ('cities') on nodes (layer is specified by nlayer)"
-msgstr ""
-"Kategorien der Punkte ('Städte') auf den Knoten (Layer wird mit nlayer "
-"bestimmt)."
+msgstr "Kategorien der Punkte ('Städte') auf den Knoten (Layer wird mit nlayer bestimmt)."
 #: ../vector/v.net.salesman/main.c:193
 #, c-format
@@ -27570,8 +25287,7 @@
 #: ../vector/v.net.connectivity/main.c:55
 msgid "Computes vertex connectivity between two sets of nodes in the network."
-msgstr ""
-"Berechnet Vertex connectivity zwischen zwei Gruppen von Knoten im Netzwerk."
+msgstr "Berechnet Vertex connectivity zwischen zwei Gruppen von Knoten im Netzwerk."
 #: ../vector/v.net.connectivity/main.c:66
 msgid "Name of node capacity column"
@@ -27593,8 +25309,7 @@
 #: ../vector/v.net.connectivity/main.c:81
 msgid "Set1 WHERE conditions of SQL statement without 'where' keyword"
-msgstr ""
-"Set1 WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
+msgstr "Set1 WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
 #: ../vector/v.net.connectivity/main.c:86
 msgid "Set2 layer number or name"
@@ -27612,8 +25327,7 @@
 #: ../vector/v.net.connectivity/main.c:97
 msgid "Set2 WHERE conditions of SQL statement without 'where' keyword"
-msgstr ""
-"Set2 WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
+msgstr "Set2 WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
 #: ../vector/v.net.connectivity/main.c:148
 #: ../vector/v.net.connectivity/main.c:151
@@ -27663,29 +25377,15 @@
 #: ../vector/v.category/main.c:70
 msgid "Attach, delete or report vector categories to map geometry."
-msgstr ""
-"Füge hinzu, Lösche oder Berichte Vektorkategorien einer Kartengeometrie."
+msgstr "Füge hinzu, Lösche oder Berichte Vektorkategorien einer Kartengeometrie."
 #: ../vector/v.category/main.c:84
 msgid "Action to be done"
 msgstr "Aktion die ausgeführt werden soll."
 #: ../vector/v.category/main.c:85
-msgid ""
-"add;add a new category;del;delete all categories of given layer;chlayer;"
-"change layer number (e.g. layer=3,1 changes layer 3 to layer 1);sum;add the "
-"value specified by cat option to the current category value;report;print "
-"report (statistics), in shell style: layer type count min max;print;print "
-"category values, more cats in the same layer are separated by '/';layers;"
-"print only layer numbers"
-msgstr ""
-"add;Füge eine neue Kategorie hinzu;del;Lösche alle Kategorien eines "
-"gegebenen Layers;chlayer;Ändere die Layer-Nummer (z.B. layer=3,1 ändert von "
-"Layer 3 auf Layer 1);sum;Addiert den in 'cat' angegeben Wert zu dem "
-"aktuellen Kategoriewert;report;Gebe einen Bericht  im Shellskript-Stil aus "
-"(Statistiken ): Layer Typ Anzahl Min Max;print;Gebe Kategoriewerte aus, "
-"mehrere cats im selben Layer werden durch '/' getrennt;layers;gebe nur Layer "
-"Nummern aus"
+msgid "add;add a new category;del;delete all categories of given layer;chlayer;change layer number (e.g. layer=3,1 changes layer 3 to layer 1);sum;add the value specified by cat option to the current category value;report;print report (statistics), in shell style: layer type count min max;print;print category values, more cats in the same layer are separated by '/';layers;print only layer numbers"
+msgstr "add;Füge eine neue Kategorie hinzu;del;Lösche alle Kategorien eines gegebenen Layers;chlayer;Ändere die Layer-Nummer (z.B. layer=3,1 ändert von Layer 3 auf Layer 1);sum;Addiert den in 'cat' angegeben Wert zu dem aktuellen Kategoriewert;report;Gebe einen Bericht  im Shellskript-Stil aus (Statistiken ): Layer Typ Anzahl Min Max;print;Gebe Kategoriewerte aus, mehrere cats im selben Layer werden durch '/' getrennt;layers;gebe nur Layer Nummern aus"
 #: ../vector/v.category/main.c:102
 msgid "Feature ids (by default all features are processed)"
@@ -27700,11 +25400,8 @@
 msgstr "Format: Layer Typ Anzahl Min Max"
 #: ../vector/v.category/main.c:137
-msgid ""
-"Database connection and attribute tables for concerned layers are not changed"
-msgstr ""
-"Die Datenbankverbindung und die Attributtabellen der betroffenen Layer "
-"werden nicht geändert."
+msgid "Database connection and attribute tables for concerned layers are not changed"
+msgstr "Die Datenbankverbindung und die Attributtabellen der betroffenen Layer werden nicht geändert."
 #: ../vector/v.category/main.c:160 ../vector/v.kcv/main.c:137
 #: ../vector/v.edit/main.c:126
@@ -27713,12 +25410,8 @@
 msgstr "Kann Vektorkarte <%s> auf der topologischen Ebene %d nicht öffnen"
 #: ../vector/v.category/main.c:182
-msgid ""
-"Invalid category number (must be equal to or greater than 0). Normally "
-"category number starts at 1."
-msgstr ""
-"Ungültige Kategorie (muss größer oder gleich 0 sein). Normalerweise beginnen "
-"die Kategorien bei 1."
+msgid "Invalid category number (must be equal to or greater than 0). Normally category number starts at 1."
+msgstr "Ungültige Kategorie (muss größer oder gleich 0 sein). Normalerweise beginnen die Kategorien bei 1."
 #: ../vector/v.category/main.c:191
 #, c-format
@@ -27810,13 +25503,8 @@
 msgstr "Erzeuge 'Steiner Tree' für das Netzwerk und die gegebenen Stationen"
 #: ../vector/v.net.steiner/main.c:349
-msgid ""
-"Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm "
-"is used in this module so the result may be sub optimal"
-msgstr ""
-"Bedenken Sie das 'Minimum Steiner Tree'-Problem ist NP-hart und in diesem "
-"Modul wird ein heuristischer Algorithmus verwenden, so kann das Ergebnis "
-"suboptimal sein."
+msgid "Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm is used in this module so the result may be sub optimal"
+msgstr "Bedenken Sie das 'Minimum Steiner Tree'-Problem ist NP-hart und in diesem Modul wird ein heuristischer Algorithmus verwenden, so kann das Ergebnis suboptimal sein."
 #: ../vector/v.net.steiner/main.c:369
 msgid "Node layer (used for terminals)"
@@ -27824,8 +25512,7 @@
 #: ../vector/v.net.steiner/main.c:381
 msgid "Categories of points on terminals (layer is specified by nlayer)"
-msgstr ""
-"Kategorien der Punkte auf den Stationen (Layer wird mit nlayer angegeben)"
+msgstr "Kategorien der Punkte auf den Stationen (Layer wird mit nlayer angegeben)"
 #: ../vector/v.net.steiner/main.c:389
 msgid "Number of steiner points (-1 for all possible)"
@@ -27842,17 +25529,12 @@
 #: ../vector/v.net.steiner/main.c:511
 #, c-format
 msgid "Terminal at node [%d] cannot be connected to terminal at node [%d]"
-msgstr ""
-"Station am Knoten [%d] kann nicht mit der Station am Knoten [%d] verbunden "
-"werden"
+msgstr "Station am Knoten [%d] kann nicht mit der Station am Knoten [%d] verbunden werden"
 #: ../vector/v.net.steiner/main.c:527
 #, c-format
-msgid ""
-"[%d] (not reachable) nodes removed from list of Steiner point candidates"
-msgstr ""
-"[%d] (nicht erreichbare) Knoten wurden aus der Liste der Steiner-"
-"Punktkandidaten entfernt"
+msgid "[%d] (not reachable) nodes removed from list of Steiner point candidates"
+msgstr "[%d] (nicht erreichbare) Knoten wurden aus der Liste der Steiner-Punktkandidaten entfernt"
 #: ../vector/v.net.steiner/main.c:532
 #, c-format
@@ -27867,9 +25549,7 @@
 #: ../vector/v.net.steiner/main.c:559
 #, c-format
 msgid "Steiner point at node [%d] was added to terminals (MST costs = %f)"
-msgstr ""
-"Steiner-Punkt am Knoten [%d] wurde zu den Stationen hinzugefügt (MST Kosten "
-"= %f)."
+msgstr "Steiner-Punkt am Knoten [%d] wurde zu den Stationen hinzugefügt (MST Kosten = %f)."
 #: ../vector/v.net.steiner/main.c:571
 msgid "No Steiner point found -> leaving cycle"
@@ -27901,9 +25581,7 @@
 #: ../vector/v.vect.stats/main.c:177
 msgid "Column name of points map to use for statistics"
-msgstr ""
-"Name der Spalte der Punkt-Karte, welche für die Statistik verwendet werden "
-"soll"
+msgstr "Name der Spalte der Punkt-Karte, welche für die Statistik verwendet werden soll"
 #: ../vector/v.vect.stats/main.c:178
 msgid "Column of points map must be numeric"
@@ -27914,29 +25592,20 @@
 msgstr "name der Spalte, in die Punktsummen gespeichert werden sollen"
 #: ../vector/v.vect.stats/main.c:187
-msgid ""
-"Column to hold points count, must be of type integer, will be created if not "
-"existing"
-msgstr ""
-"Spalte, in die die Punktsummen geschrieben werden sollen, muss vom Typ "
-"'integer' sein. Spalte wird angelegt, wenn sie noch nicht existiert."
+msgid "Column to hold points count, must be of type integer, will be created if not existing"
+msgstr "Spalte, in die die Punktsummen geschrieben werden sollen, muss vom Typ 'integer' sein. Spalte wird angelegt, wenn sie noch nicht existiert."
 #: ../vector/v.vect.stats/main.c:194
 msgid "Column name to upload statistics"
 msgstr "Name der Spalte, in die die Statistiken geschrieben werden"
 #: ../vector/v.vect.stats/main.c:196
-msgid ""
-"Column to hold statistics, must be of type double, will be created if not "
-"existing"
-msgstr ""
-"Spalte, in die die Statistiken geschrieben werden sollen, muss vom Typ "
-"'double' sein. Spalte wird angelegt, wenn sie noch nicht existiert."
+msgid "Column to hold statistics, must be of type double, will be created if not existing"
+msgstr "Spalte, in die die Statistiken geschrieben werden sollen, muss vom Typ 'double' sein. Spalte wird angelegt, wenn sie noch nicht existiert."
 #: ../vector/v.vect.stats/main.c:206
 msgid "Print output to stdout, do not update attribute table"
-msgstr ""
-"Gebe die Ausgabe auf stdout aus und verändere die Attributtabelle nicht."
+msgstr "Gebe die Ausgabe auf stdout aus und verändere die Attributtabelle nicht."
 #: ../vector/v.vect.stats/main.c:207
 msgid "First column is always area category"
@@ -27945,9 +25614,7 @@
 #: ../vector/v.vect.stats/main.c:261 ../vector/v.distance/main.c:306
 #, c-format
 msgid "Vector map <%s> is not in user mapset and cannot be updated"
-msgstr ""
-"Vektorkarte <%s> ist nicht im Mapset des Benutzers und kann nicht "
-"aktualisiert werden."
+msgstr "Vektorkarte <%s> ist nicht im Mapset des Benutzers und kann nicht aktualisiert werden."
 #: ../vector/v.vect.stats/main.c:308 ../vector/v.vect.stats/main.c:384
 #, c-format
@@ -28058,13 +25725,8 @@
 #: ../vector/v.transform/trans_digit.c:125
 #, c-format
-msgid ""
-"Unable to select value for category %d from table <%s>, column <%s>. For "
-"category %d using default transformation parameter %.3f."
-msgstr ""
-"Kann den Wert der Kategorie %d aus der Tabelle <%s>, Spalte <%s> nicht "
-"selektieren. Verwende für die Kategorie %d den "
-"Standardtransformationsparameter %.3f."
+msgid "Unable to select value for category %d from table <%s>, column <%s>. For category %d using default transformation parameter %.3f."
+msgstr "Kann den Wert der Kategorie %d aus der Tabelle <%s>, Spalte <%s> nicht selektieren. Verwende für die Kategorie %d den Standardtransformationsparameter %.3f."
 #: ../vector/v.transform/trans_digit.c:136
 msgid "No category number defined. Using default transformation parameters."
@@ -28075,12 +25737,8 @@
 msgstr "Vektor, Transformation"
 #: ../vector/v.transform/main.c:75
-msgid ""
-"Performs an affine transformation (shift, scale and rotate, or GPCs) on "
-"vector map."
-msgstr ""
-"Führt eine affine Transformation (schieben, skalieren und rotieren oder "
-"GPCs) von Vektorkarten durch."
+msgid "Performs an affine transformation (shift, scale and rotate, or GPCs) on vector map."
+msgstr "Führt eine affine Transformation (schieben, skalieren und rotieren oder GPCs) von Vektorkarten durch."
 #: ../vector/v.transform/main.c:82
 msgid "Suppress display of residuals or other information"
@@ -28100,31 +25758,23 @@
 #: ../vector/v.transform/main.c:92
 msgid "Swap coordinates x, y and then apply other parameters"
-msgstr ""
+msgstr "Tausche die Koordinaten x,y und wende weitere Parameter an"
 #: ../vector/v.transform/main.c:98
 msgid "Print the transformation matrix to stdout"
 msgstr "Gebe Transformations-Matrix auf stdout aus."
 #: ../vector/v.transform/main.c:103
-msgid ""
-"Instead of points use transformation parameters (xshift, yshift, zshift, "
-"xscale, yscale, zscale, zrot)"
-msgstr ""
-"Anstelle von Punkten verwende Transformationsparameter (xshift, yshift, "
-"zshift, xscale, yscale, zscale, zrot)."
+msgid "Instead of points use transformation parameters (xshift, yshift, zshift, xscale, yscale, zscale, zrot)"
+msgstr "Anstelle von Punkten verwende Transformationsparameter (xshift, yshift, zshift, xscale, yscale, zscale, zrot)."
 #: ../vector/v.transform/main.c:117
 msgid "ASCII file holding transform coordinates"
 msgstr "ASCII-Datei mit den Transformationskoordinaten"
 #: ../vector/v.transform/main.c:118
-msgid ""
-"If not given, transformation parameters (xshift, yshift, zshift, xscale, "
-"yscale, zscale, zrot) are used instead"
-msgstr ""
-"Wenn nicht gegeben, verwende verwende stattdessen Transformationsparameter "
-"(xshift, yshift, zshift, xscale, yscale, zscale, zrot)."
+msgid "If not given, transformation parameters (xshift, yshift, zshift, xscale, yscale, zscale, zrot) are used instead"
+msgstr "Wenn nicht gegeben, verwende verwende stattdessen Transformationsparameter (xshift, yshift, zshift, xscale, yscale, zscale, zrot)."
 #: ../vector/v.transform/main.c:129
 msgid "Shifting value for x coordinates"
@@ -28168,28 +25818,18 @@
 #: ../vector/v.transform/main.c:217
 #, c-format
-msgid ""
-"The '%c' flag is deprecated and will be removed in future. Transformation "
-"parameters are used automatically when no pointsfile is given."
-msgstr ""
-"Der Schalter '%c' ist veraltet und wird in Zukunft nicht mehr vorhanden "
-"sein. Transformationsparameter werden automatisch verwendet wenn kein "
-"pointsfile angegeben wurde."
+msgid "The '%c' flag is deprecated and will be removed in future. Transformation parameters are used automatically when no pointsfile is given."
+msgstr "Der Schalter '%c' ist veraltet und wird in Zukunft nicht mehr vorhanden sein. Transformationsparameter werden automatisch verwendet wenn kein pointsfile angegeben wurde."
 #: ../vector/v.transform/main.c:223
 #, c-format
-msgid ""
-"The '%c' flag is deprecated and will be removed in future. Please use '--"
-"quiet' instead."
-msgstr ""
-"sein. Bitte verwenden Sie stattdessen '--quiet'."
+msgid "The '%c' flag is deprecated and will be removed in future. Please use '--quiet' instead."
+msgstr "Der Schalter '%c' ist veraltet und wird in Zukunft nicht mehr vorhanden sein. Bitte verwenden Sie stattdessen '--quiet'."
 #: ../vector/v.transform/main.c:232
 #, c-format
 msgid "Column names are not defined. Please use '%s' parameter."
-msgstr ""
-"Spaltennamen sind nicht definiert. Bitte verwenden Sie den Parameter '%s'."
+msgstr "Spaltennamen sind nicht definiert. Bitte verwenden Sie den Parameter '%s'."
 #: ../vector/v.transform/main.c:237
 #, c-format
@@ -28197,12 +25837,8 @@
 msgstr "Bitte geben Sie mit dem Parameter '%s' einen gültigen Layer an."
 #: ../vector/v.transform/main.c:242
-msgid ""
-"Name of table and name for output vector map must be different. Otherwise "
-"the table is overwritten."
-msgstr ""
-"Name der Tabelle und Name der Ausgabe-Vektorkarte müssenunterschiedlich "
-"sein. Sonst wird die Tabelle überschrieben."
+msgid "Name of table and name for output vector map must be different. Otherwise the table is overwritten."
+msgstr "Name der Tabelle und Name der Ausgabe-Vektorkarte müssenunterschiedlich sein. Sonst wird die Tabelle überschrieben."
 #: ../vector/v.transform/main.c:259
 #, c-format
@@ -28267,14 +25903,8 @@
 msgstr "Verteilung der Störung"
 #: ../vector/v.perturb/main.c:96
-msgid ""
-"Parameter(s) of distribution. If the distribution is uniform, only one "
-"parameter, the maximum, is needed. For a normal distribution, two "
-"parameters, the mean and standard deviation, are required."
-msgstr ""
-"Parameter der Verteilung. Wenn es eine gleichförmige Verteilung ist, wird "
-"nur ein Parameter, das Maximum, benötigt. Für eine Normalverteilung sind "
-"zwei Parameter, der Mittelwert und die Standardabweichung, erforderlich."
+msgid "Parameter(s) of distribution. If the distribution is uniform, only one parameter, the maximum, is needed. For a normal distribution, two parameters, the mean and standard deviation, are required."
+msgstr "Parameter der Verteilung. Wenn es eine gleichförmige Verteilung ist, wird nur ein Parameter, das Maximum, benötigt. Für eine Normalverteilung sind zwei Parameter, der Mittelwert und die Standardabweichung, erforderlich."
 #: ../vector/v.perturb/main.c:106
 msgid "Minimum deviation in map units"
@@ -28474,9 +26104,7 @@
 #: ../vector/v.parallel/main.c:52
 msgid "Offset in map units, positive for right side, negative for left side."
-msgstr ""
-"Versatz in Karteneinheiten, positiv für die rechte und negativ für die linke "
-"Seite."
+msgstr "Versatz in Karteneinheiten, positiv für die rechte und negativ für die linke Seite."
 #: ../vector/lidar/v.lidar.correction/main.c:73
 #: ../vector/lidar/v.lidar.growing/main.c:79
@@ -28484,12 +26112,8 @@
 msgstr "Vektor, LIDAR"
 #: ../vector/lidar/v.lidar.correction/main.c:75
-msgid ""
-"Correction of the v.lidar.growing output. It is the last of the three "
-"algorithms for LIDAR filtering."
-msgstr ""
-"Korrektur der v.lidar.growing Ausgabe. Das ist der letzte von 3 Algorithmen "
-"um LIDAR zu filtern."
+msgid "Correction of the v.lidar.growing output. It is the last of the three algorithms for LIDAR filtering."
+msgstr "Korrektur der v.lidar.growing Ausgabe. Das ist der letzte von 3 Algorithmen um LIDAR zu filtern."
 #: ../vector/lidar/v.lidar.correction/main.c:79
 #: ../vector/lidar/v.lidar.edgedetection/main.c:84
@@ -28502,17 +26126,12 @@
 #: ../vector/lidar/v.lidar.edgedetection/main.c:86
 #: ../vector/lidar/v.outlier/main.c:80
 #: ../vector/lidar/v.surf.bspline/main.c:96
-msgid ""
-"Estimate point density and distance for the input vector points within the "
-"current region extends and quit"
-msgstr ""
-"Schätze die Punktedichte und Distanz der Eingabe-Vektorkarte innerhalb der "
-"aktuellen Region und beende mich."
+msgid "Estimate point density and distance for the input vector points within the current region extends and quit"
+msgstr "Schätze die Punktedichte und Distanz der Eingabe-Vektorkarte innerhalb der aktuellen Region und beende mich."
 #: ../vector/lidar/v.lidar.correction/main.c:85
 msgid "Input observation vector map name (v.lidar.growing output)"
-msgstr ""
-"Eingabeüberwachung des Vektorkarten-Namens (Ausgabe von v.lidar.growing)"
+msgstr "Eingabeüberwachung des Vektorkarten-Namens (Ausgabe von v.lidar.growing)"
 #: ../vector/lidar/v.lidar.correction/main.c:88
 msgid "Output classified vector map name"
@@ -28571,9 +26190,7 @@
 #: ../vector/lidar/v.surf.bspline/main.c:362
 #, c-format
 msgid "No database connection for driver <%s> is defined. Run db.connect."
-msgstr ""
-"Keine Datenbankverbindung für Treiber <%s> definiert. Bitte db.connect "
-"benutzen"
+msgstr "Keine Datenbankverbindung für Treiber <%s> definiert. Bitte db.connect benutzen"
 #: ../vector/lidar/v.lidar.correction/main.c:172
 #: ../vector/lidar/v.lidar.edgedetection/main.c:196
@@ -28663,9 +26280,7 @@
 #: ../vector/lidar/v.lidar.edgedetection/main.c:460
 #: ../vector/lidar/v.outlier/main.c:423
 msgid "No data within this subregion. Consider changing the spline step."
-msgstr ""
-"Keine Daten in dieser Unterregion. Erwägen Sie die Splineschrittweite zu "
-"ändern."
+msgstr "Keine Daten in dieser Unterregion. Erwägen Sie die Splineschrittweite zu ändern."
 #: ../vector/lidar/v.lidar.correction/main.c:438
 #: ../vector/lidar/v.lidar.edgedetection/main.c:468
@@ -28745,9 +26360,7 @@
 #: ../vector/lidar/v.lidar.edgedetection/main.c:263
 #, c-format
 msgid "It was impossible to create <%s> interpolation table in database."
-msgstr ""
-"Es war nicht möglich die <%s> Interpolations-Tabelle in der Datenbank zu "
-"erstellen."
+msgstr "Es war nicht möglich die <%s> Interpolations-Tabelle in der Datenbank zu erstellen."
 #: ../vector/lidar/v.lidar.edgedetection/main.c:396
 msgid "Allocating memory for bilinear interpolation"
@@ -28807,12 +26420,8 @@
 msgstr "Kann nicht auf die Tabelle <%s> zugreifen."
 #: ../vector/lidar/v.lidar.growing/main.c:81
-msgid ""
-"Building contour determination and Region Growing algorithm for determining "
-"the building inside"
-msgstr ""
-"Bestimmung des Gebäude Umriss und Anwendung des 'Region Growing' Verfahrens "
-"zu Ermittelung des Gebäude Inneren."
+msgid "Building contour determination and Region Growing algorithm for determining the building inside"
+msgstr "Bestimmung des Gebäude Umriss und Anwendung des 'Region Growing' Verfahrens zu Ermittelung des Gebäude Inneren."
 #: ../vector/lidar/v.lidar.growing/main.c:86
 msgid "Input vector (v.lidar.edgedetection output"
@@ -28908,12 +26517,8 @@
 msgstr "%d Punkte in der Region gelesen"
 #: ../vector/lidar/v.surf.bspline/crosscorr.c:93
-msgid ""
-"Maybe, it takes too long. It will depend on how many points you are "
-"considering."
-msgstr ""
-"Vielleicht dauert es zu lange. Es hängt davon ab wieviel Punkte Sie erwägen "
-"zu verwenden."
+msgid "Maybe, it takes too long. It will depend on how many points you are considering."
+msgstr "Vielleicht dauert es zu lange. Es hängt davon ab wieviel Punkte Sie erwägen zu verwenden."
 #: ../vector/lidar/v.surf.bspline/crosscorr.c:124
 #, c-format
@@ -28927,11 +26532,8 @@
 #: ../vector/lidar/v.surf.bspline/crosscorr.c:156
 #, c-format
-msgid ""
-"Too many splines (%d x %d). Consider changing spline steps \"sie=\" \"sin=\"."
-msgstr ""
-"Zu viele Splines (%d x %d). Erwägen Sie die Splineschrittweite (\"sie=\" "
-"\"sin=\") zu ändern."
+msgid "Too many splines (%d x %d). Consider changing spline steps \"sie=\" \"sin=\"."
+msgstr "Zu viele Splines (%d x %d). Erwägen Sie die Splineschrittweite (\"sie=\" \"sin=\") zu ändern."
 #: ../vector/lidar/v.surf.bspline/crosscorr.c:174
 #, c-format
@@ -28955,19 +26557,13 @@
 msgstr "Root Mean Square (RMS) = %.5lf"
 #: ../vector/lidar/v.surf.bspline/crosscorr.c:318
-msgid ""
-"Different number of splines and lambda_i values have been taken for the "
-"cross correlation"
-msgstr ""
-"Eine unterschiedliche Anzahl von Splines und lambda_i-Werten wurde für die "
-"Kreuzvalidierung angegeben."
+msgid "Different number of splines and lambda_i values have been taken for the cross correlation"
+msgstr "Eine unterschiedliche Anzahl von Splines und lambda_i-Werten wurde für die Kreuzvalidierung angegeben."
 #: ../vector/lidar/v.surf.bspline/crosscorr.c:320
 #, c-format
-msgid ""
-"The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
-msgstr ""
-"Der Minimalwert für den Test (rms=%lf) wurde erreicht mit: lambda_i = %.3f"
+msgid "The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
+msgstr "Der Minimalwert für den Test (rms=%lf) wurde erreicht mit: lambda_i = %.3f"
 #: ../vector/lidar/v.surf.bspline/crosscorr.c:328
 msgid "Table of results:"
@@ -28984,16 +26580,11 @@
 #: ../vector/lidar/v.surf.bspline/main.c:85
 msgid "Bicubic or bilinear spline interpolation with Tykhonov regularization."
-msgstr ""
-"Bikubische oder bilineare Spline-Interpolation mit Tykhonov-Regularisierung."
+msgstr "Bikubische oder bilineare Spline-Interpolation mit Tykhonov-Regularisierung."
 #: ../vector/lidar/v.surf.bspline/main.c:90
-msgid ""
-"Find the best Tykhonov regularizing parameter using a \"leave-one-out\" "
-"cross validation method"
-msgstr ""
-"Finde die beste Tykhonov Regularisierung mittels der \"leave-one-out\" "
-"Kreuzvalidierung."
+msgid "Find the best Tykhonov regularizing parameter using a \"leave-one-out\" cross validation method"
+msgstr "Finde die beste Tykhonov Regularisierung mittels der \"leave-one-out\" Kreuzvalidierung."
 #: ../vector/lidar/v.surf.bspline/main.c:104
 msgid "Name of input vector map of sparse points"
@@ -29021,15 +26612,11 @@
 #: ../vector/lidar/v.surf.bspline/main.c:159
 msgid "Attribute table column with values to interpolate (if layer>0)"
-msgstr ""
-"Spalte der Attributtabelle, die zu interpolierende Werte enthält (wenn layer "
-"> 0)."
+msgstr "Spalte der Attributtabelle, die zu interpolierende Werte enthält (wenn layer > 0)."
 #: ../vector/lidar/v.surf.bspline/main.c:172
 msgid "Choose either vector or raster output, not both"
-msgstr ""
-"Wählen Sie entweder die Ausgabe im Raster- oder Vektor-Format, aber nicht "
-"beides."
+msgstr "Wählen Sie entweder die Ausgabe im Raster- oder Vektor-Format, aber nicht beides."
 #: ../vector/lidar/v.surf.bspline/main.c:175
 msgid "No raster or vector or cross-validation output"
@@ -29037,8 +26624,7 @@
 #: ../vector/lidar/v.surf.bspline/main.c:229
 msgid "Need either 3D vector or layer and column with z values"
-msgstr ""
-"Brauche entweder ein 3D Vektor oder ein Layer und Spalte mit Z-Werten. "
+msgstr "Brauche entweder ein 3D Vektor oder ein Layer und Spalte mit Z-Werten. "
 #: ../vector/lidar/v.surf.bspline/main.c:231
 msgid "Layer but not column with z values given"
@@ -29060,12 +26646,8 @@
 #: ../vector/lidar/v.surf.bspline/main.c:285
 #, c-format
-msgid ""
-"Sorry, <%s> driver is not allowed for vector output in this module. Try with "
-"a raster output or other driver."
-msgstr ""
-"Der Treiber <%s> ist leider nicht für die Vektorausgabe in diesem Modul "
-"erlaubt. Versuchen Sie die Rasterausgabe oder einen anderen Treiber."
+msgid "Sorry, <%s> driver is not allowed for vector output in this module. Try with a raster output or other driver."
+msgstr "Der Treiber <%s> ist leider nicht für die Vektorausgabe in diesem Modul erlaubt. Versuchen Sie die Rasterausgabe oder einen anderen Treiber."
 #: ../vector/lidar/v.surf.bspline/main.c:307
 #, c-format
@@ -29089,17 +26671,11 @@
 #: ../vector/lidar/v.surf.bspline/main.c:369
 #, c-format
 msgid "Interpolation: Creating table: It was impossible to create table <%s>."
-msgstr ""
-"Interpolation: Tabellenerzeugung: Es war nicht möglich die Tabelle <%s> zu "
-"erstellen."
+msgstr "Interpolation: Tabellenerzeugung: Es war nicht möglich die Tabelle <%s> zu erstellen."
 #: ../vector/lidar/v.surf.bspline/main.c:392
-msgid ""
-"Cannot allocate memory for auxiliar matrix.Consider changing region "
-"resolution"
-msgstr ""
-"Kann keinen Speicher für Hilfsmatrix reservieren. Erwägen Sie die Auflösung "
-"der Region zu ändern."
+msgid "Cannot allocate memory for auxiliar matrix.Consider changing region resolution"
+msgstr "Kann keinen Speicher für Hilfsmatrix reservieren. Erwägen Sie die Auflösung der Region zu ändern."
 #: ../vector/lidar/v.surf.bspline/main.c:590
 #, c-format
@@ -29108,9 +26684,7 @@
 #: ../vector/lidar/v.surf.bspline/main.c:709
 msgid "No data within this subregion. Consider increasing spline step values."
-msgstr ""
-"Keine Daten in dieser Unterregion. Überlegen Sie die Splineschrittweite zu "
-"vergrößern."
+msgstr "Keine Daten in dieser Unterregion. Überlegen Sie die Splineschrittweite zu vergrößern."
 #: ../vector/lidar/v.surf.bspline/main.c:715
 msgid "Writing output..."
@@ -29121,12 +26695,8 @@
 msgstr "Vektor, Netzwerk, Zentralitätsmaß"
 #: ../vector/v.net.centrality/main.c:97
-msgid ""
-"Computes degree, centrality, betweeness, closeness and eigenvector "
-"centrality measures in the network."
-msgstr ""
-"Berechnet Degree, Centrality, Betweeness, Closeness and Eigenvektor "
-"centrality Werte im Netzwerk."
+msgid "Computes degree, centrality, betweeness, closeness and eigenvector centrality measures in the network."
+msgstr "Berechnet Degree, Centrality, Betweeness, Closeness and Eigenvektor centrality Werte im Netzwerk."
 #: ../vector/v.net.centrality/main.c:115 ../vector/v.net.allpairs/main.c:77
 msgid "Name of arc forward/both direction(s) cost column"
@@ -29164,8 +26734,7 @@
 #: ../vector/v.net.centrality/main.c:154
 msgid "Maximum number of iterations to compute eigenvector centrality"
-msgstr ""
-"Maximale Zahl der Iterationen zur Berechnung der Eigenvektor-Zentralität"
+msgstr "Maximale Zahl der Iterationen zur Berechnung der Eigenvektor-Zentralität"
 #: ../vector/v.net.centrality/main.c:162
 msgid "Cummulative error tolerance for eigenvector centrality"
@@ -29197,14 +26766,11 @@
 #: ../vector/v.what.rast/main.c:83
 msgid "Uploads raster values at positions of vector points to the table."
-msgstr ""
-"Übernimmt die Rasterwerte an den Positinen der Vektor-Punkte in die "
-"Attributtabelle."
+msgstr "Übernimmt die Rasterwerte an den Positinen der Vektor-Punkte in die Attributtabelle."
 #: ../vector/v.what.rast/main.c:88
 msgid "Name of input vector points map for which to edit attribute table"
-msgstr ""
-"Name der Vektorpunktekarte, dessen Attributtabelle editiert werden soll. "
+msgstr "Name der Vektorpunktekarte, dessen Attributtabelle editiert werden soll. "
 #: ../vector/v.what.rast/main.c:92
 msgid "Name of existing raster map to be queried"
@@ -29220,9 +26786,7 @@
 #: ../vector/v.what.rast/main.c:169
 msgid "Raster type is float and column type is integer, some data lost!!"
-msgstr ""
-"Rastertyp ist Fließkomma und der Spaltentyp ist Integer. Etwas "
-"Informationsgehalt der Daten geht verloren!!"
+msgstr "Rastertyp ist Fließkomma und der Spaltentyp ist Integer. Etwas Informationsgehalt der Daten geht verloren!!"
 #: ../vector/v.what.rast/main.c:249
 #, c-format
@@ -29267,8 +26831,7 @@
 #: ../vector/v.out.ascii/b2a.c:202
 #, c-format
 msgid "Feature has more categories. Only first category (%d) is exported."
-msgstr ""
-"Objekt hat mehrere Kategorien. Nur die erste Kategorie (%d) wurde exportiert."
+msgstr "Objekt hat mehrere Kategorien. Nur die erste Kategorie (%d) wurde exportiert."
 #: ../vector/v.out.ascii/b2a.c:212
 #, c-format
@@ -29282,14 +26845,11 @@
 #: ../vector/v.out.ascii/out.c:47
 msgid "Converts a GRASS binary vector map to a GRASS ASCII vector map."
-msgstr ""
-"Konvertiere eine binäre GRASS-Vektordatei in eine GRASS ASCII-Vektorkarte."
+msgstr "Konvertiere eine binäre GRASS-Vektordatei in eine GRASS ASCII-Vektorkarte."
 #: ../vector/v.out.ascii/out.c:54
 msgid "Path to resulting ASCII file or ASCII vector name if '-o' is defined"
-msgstr ""
-"Pfad zur resultiertenden ASCII-Datei oder ASCII-Kartenname, wenn der "
-"Schalter '-o' angegeben ist."
+msgstr "Pfad zur resultiertenden ASCII-Datei oder ASCII-Kartenname, wenn der Schalter '-o' angegeben ist."
 #: ../vector/v.out.ascii/out.c:66
 msgid "Field separator (points mode)"
@@ -29297,8 +26857,7 @@
 #: ../vector/v.out.ascii/out.c:83
 msgid "Name of attribute column(s) to be exported (point mode)"
-msgstr ""
-"Name der Attribut-Spalte(n) die exportiert werden sollen (Punkt-Modus)."
+msgstr "Name der Attribut-Spalte(n) die exportiert werden sollen (Punkt-Modus)."
 #: ../vector/v.out.ascii/out.c:91
 msgid "Create old (version 4) ASCII file"
@@ -29306,9 +26865,7 @@
 #: ../vector/v.out.ascii/out.c:96
 msgid "Only export points falling within current 3D region (points mode)"
-msgstr ""
-"Exportiere nur Punkte, die sich in der aktuellen 3D-Region befinden (Punkt-"
-"Modus)."
+msgstr "Exportiere nur Punkte, die sich in der aktuellen 3D-Region befinden (Punkt-Modus)."
 #: ../vector/v.out.ascii/out.c:111
 #, c-format
@@ -29329,12 +26886,8 @@
 #: ../vector/v.out.ascii/out.c:147
 #, c-format
-msgid ""
-"Unable to open vector map <%s> at topology level. Areas will not be "
-"processed."
-msgstr ""
-"Kann die Vektorkarte <%s> topologisch nicht öffnen. Flächen werden nicht "
-"verarbeitet."
+msgid "Unable to open vector map <%s> at topology level. Areas will not be processed."
+msgstr "Kann die Vektorkarte <%s> topologisch nicht öffnen. Flächen werden nicht verarbeitet."
 #: ../vector/v.out.ascii/out.c:185
 msgid "dig_att file already exist"
@@ -29351,21 +26904,12 @@
 msgstr "Vektor, Netzwerk, kürzester Pfad"
 #: ../vector/v.net.distance/main.c:61
-msgid ""
-"Computes shortest distance via the network between the given sets of "
-"features."
-msgstr ""
-"Berechne die kürzeste Distanz zwischen einer Auswahl an Objekten über das "
-"Netzwerk."
+msgid "Computes shortest distance via the network between the given sets of features."
+msgstr "Berechne die kürzeste Distanz zwischen einer Auswahl an Objekten über das Netzwerk."
 #: ../vector/v.net.distance/main.c:64
-msgid ""
-"Finds the shortest paths from a feature 'to' to every feature 'from' and "
-"various information about this realtion are uploaded to the attribute table."
-msgstr ""
-"Findet den kürzesten Pfad von einem Objekt 'to' zu allen Objekten 'from' und "
-"zahlreiche Informationen über diese Beziehung wird in der Attributtabelle "
-"abgespeichert"
+msgid "Finds the shortest paths from a feature 'to' to every feature 'from' and various information about this realtion are uploaded to the attribute table."
+msgstr "Findet den kürzesten Pfad von einem Objekt 'to' zu allen Objekten 'from' und zahlreiche Informationen über diese Beziehung wird in der Attributtabelle abgespeichert"
 #: ../vector/v.net.distance/main.c:73
 msgid "From layer number or name"
@@ -29383,8 +26927,7 @@
 #: ../vector/v.net.distance/main.c:84
 msgid "From WHERE conditions of SQL statement without 'where' keyword"
-msgstr ""
-"From WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
+msgstr "From WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
 #: ../vector/v.net.distance/main.c:89
 msgid "To layer number or name"
@@ -29403,8 +26946,7 @@
 #: ../vector/v.net.distance/main.c:100
 msgid "To WHERE conditions of SQL statement without 'where' keyword"
-msgstr ""
-"Ziel-WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
+msgstr "Ziel-WHERE Bedingungen des SQL-Ausdrucks ohne das Schlüsselwort 'where'"
 #: ../vector/v.net.distance/main.c:107
 msgid "To feature type"
@@ -29420,8 +26962,7 @@
 #: ../vector/v.net.allpairs/main.c:209
 msgid "New points are excluded from shortest path calculations."
-msgstr ""
-"Neue Punkte werden aus der Berechnung der kürzesten Pfade ausgeschlossen."
+msgstr "Neue Punkte werden aus der Berechnung der kürzesten Pfade ausgeschlossen."
 #: ../vector/v.lrs/v.lrs.where/main.c:58
 #: ../vector/v.lrs/v.lrs.label/main.c:102
@@ -29431,12 +26972,8 @@
 msgstr "Vektor, LRS, Netzwerk"
 #: ../vector/v.lrs/v.lrs.where/main.c:60
-msgid ""
-"Finds line id and real km+offset for given points in vector map using linear "
-"reference system."
-msgstr ""
-"Findet die ID der Linie und tatsächliche km+Versatz für gegebene Punkte "
-"einer Vektorkarte mit Hilfe eines Linearenreferenzsystems."
+msgid "Finds line id and real km+offset for given points in vector map using linear reference system."
+msgstr "Findet die ID der Linie und tatsächliche km+Versatz für gegebene Punkte einer Vektorkarte mit Hilfe eines Linearenreferenzsystems."
 #: ../vector/v.lrs/v.lrs.where/main.c:65
 #: ../vector/v.lrs/v.lrs.label/main.c:107
@@ -29520,8 +27057,7 @@
 #: ../vector/v.lrs/v.lrs.label/main.c:103
 msgid "Creates stationing from input lines, and linear reference system"
-msgstr ""
-"Erzeuge Stationen auf Basis der Eingabelinien und dem Linearenreferenzsystem."
+msgstr "Erzeuge Stationen auf Basis der Eingabelinien und dem Linearenreferenzsystem."
 #: ../vector/v.lrs/v.lrs.label/main.c:111
 msgid "Output vector map where stationing will be written"
@@ -29590,8 +27126,7 @@
 #: ../vector/v.lrs/v.lrs.create/main.c:131
 msgid "Output vector map where oriented lines are written"
-msgstr ""
-"Ausgabe-Vektorkarte in die die ausgerichteten Linien geschrieben werden."
+msgstr "Ausgabe-Vektorkarte in die die ausgerichteten Linien geschrieben werden."
 #: ../vector/v.lrs/v.lrs.create/main.c:136
 msgid "Output vector map of errors"
@@ -29611,28 +27146,19 @@
 #: ../vector/v.lrs/v.lrs.create/main.c:171
 msgid "Column containing milepost position for the beginning of next segment"
-msgstr ""
-"Spalte mit den Meilensteinpositionen, die den Beginn des nächsten Segmentes "
-"kennzeichnen."
+msgstr "Spalte mit den Meilensteinpositionen, die den Beginn des nächsten Segmentes kennzeichnen."
 #: ../vector/v.lrs/v.lrs.create/main.c:180
-msgid ""
-"Column containing offset from milepost for the beginning of next segment"
-msgstr ""
-"Spalte mit dem Versatz vom Meilenstein, um den Beginn des nächsten Segmentes "
-"zu kennzeichnen."
+msgid "Column containing offset from milepost for the beginning of next segment"
+msgstr "Spalte mit dem Versatz vom Meilenstein, um den Beginn des nächsten Segmentes zu kennzeichnen."
 #: ../vector/v.lrs/v.lrs.create/main.c:189
 msgid "Column containing milepost position for the end of previous segment"
-msgstr ""
-"Spalte mit den Meilensteinpositionen, die das Ende des vorherigen Segmentes "
-"kennzeichnen."
+msgstr "Spalte mit den Meilensteinpositionen, die das Ende des vorherigen Segmentes kennzeichnen."
 #: ../vector/v.lrs/v.lrs.create/main.c:198
 msgid "Column containing offset from milepost for the end of previous segment"
-msgstr ""
-"Spalte mit dem Versatz vom Meilenstein, um das Ende des vorherigen Segmentes "
-"zu kennzeichnen."
+msgstr "Spalte mit dem Versatz vom Meilenstein, um das Ende des vorherigen Segmentes zu kennzeichnen."
 #: ../vector/v.lrs/v.lrs.create/main.c:222
 msgid "Name of table where the reference system will be written"
@@ -29691,8 +27217,7 @@
 #: ../vector/v.lrs/v.lrs.create/main.c:478
 #, c-format
 msgid "Milepost (start) %f+%f used as %f+%f (change MP to integer)"
-msgstr ""
-"Meilenstein (Start) %f+%f verwendet als %f+%f (ändere MP nach Integer)."
+msgstr "Meilenstein (Start) %f+%f verwendet als %f+%f (ändere MP nach Integer)."
 #: ../vector/v.lrs/v.lrs.create/main.c:500
 #, c-format
@@ -29726,21 +27251,17 @@
 #: ../vector/v.lrs/v.lrs.create/main.c:749
 #, c-format
 msgid "Distance along line identical for points' cats [%d], [%d]"
-msgstr ""
-"Distanz entlang der Linie ist identisch für die Punkte der cats [%d], [%d]."
+msgstr "Distanz entlang der Linie ist identisch für die Punkte der cats [%d], [%d]."
 #: ../vector/v.lrs/v.lrs.create/main.c:763
 #, c-format
 msgid "Not enough points (%d) attached to the line (cat %d), line skip."
-msgstr ""
-"Nicht genügend Punkte (%d) der Linie (cat %d) zugeordnet, überspringe die "
-"Linie."
+msgstr "Nicht genügend Punkte (%d) der Linie (cat %d) zugeordnet, überspringe die Linie."
 #: ../vector/v.lrs/v.lrs.create/main.c:768
 #, c-format
 msgid "Unable to guess direction for the line (cat %d), line skip."
-msgstr ""
-"Kann die Richtung der Linie (cat %d) nicht erraten, überspringe die Linie."
+msgstr "Kann die Richtung der Linie (cat %d) nicht erraten, überspringe die Linie."
 #: ../vector/v.lrs/v.lrs.create/main.c:772
 #, c-format
@@ -29761,12 +27282,8 @@
 msgstr "Erstelle Topologie für Fehlerkarte (err)..."
 #: ../vector/v.lrs/v.lrs.segment/main.c:72
-msgid ""
-"Creates points/segments from input lines, linear reference system and "
-"positions read from stdin or a file."
-msgstr ""
-"Erzeuge Punkte/Segmente auf Basis der Eingabelinien, des "
-"Linearenreferenzsystems und Positionen von stdin oder einer Datei."
+msgid "Creates points/segments from input lines, linear reference system and positions read from stdin or a file."
+msgstr "Erzeuge Punkte/Segmente auf Basis der Eingabelinien, des Linearenreferenzsystems und Positionen von stdin oder einer Datei."
 #: ../vector/v.lrs/v.lrs.segment/main.c:80
 msgid "Output vector map where segments will be written"
@@ -29774,9 +27291,7 @@
 #: ../vector/v.lrs/v.lrs.segment/main.c:112 ../vector/v.segment/main.c:71
 msgid "Name of file containing segment rules. If not given, read from stdin."
-msgstr ""
-"Name der Datei, die Segment-Regeln enthält. Falls nicht angegeben, wird von "
-"stdin gelesen."
+msgstr "Name der Datei, die Segment-Regeln enthält. Falls nicht angegeben, wird von stdin gelesen."
 #: ../vector/v.lrs/v.lrs.segment/main.c:179
 #: ../vector/v.lrs/v.lrs.segment/main.c:233
@@ -29806,8 +27321,7 @@
 "Cannot get point on line: cat = [%d] distance = [%f] (line length = %f)\n"
 "%s"
 msgstr ""
-"Kann den Punkt auf der Linie nicht bekommen: cat = [%d] Distanz = [%f] "
-"(Linienlänge = %f)\n"
+"Kann den Punkt auf der Linie nicht bekommen: cat = [%d] Distanz = [%f] (Linienlänge = %f)\n"
 "%s"
 #: ../vector/v.lrs/v.lrs.segment/main.c:248
@@ -29834,8 +27348,7 @@
 "Requested offset for the 1. point not found, using nearest found:\n"
 "  %s"
 msgstr ""
-"Angeforderten Versatz für den 1. Punkt nicht gefunden, verwende den "
-"Nächsten:\n"
+"Angeforderten Versatz für den 1. Punkt nicht gefunden, verwende den Nächsten:\n"
 "  %s"
 #: ../vector/v.lrs/v.lrs.segment/main.c:268
@@ -29853,8 +27366,7 @@
 "Requested offset for the 2. point not found, using nearest found:\n"
 "  %s"
 msgstr ""
-"Angeforderten Versatz für den 2. Punkt nicht gefunden, verwende den "
-"Nächsten:\n"
+"Angeforderten Versatz für den 2. Punkt nicht gefunden, verwende den Nächsten:\n"
 "  %s"
 #: ../vector/v.lrs/v.lrs.segment/main.c:277
@@ -29881,8 +27393,7 @@
 "Cannot make line segment: cat = %d : %f - %f (line length = %f)\n"
 "%s"
 msgstr ""
-"Kann das Linien-Segment nicht erzeugen: cat = %d : %f - %f (Länge der Linie "
-"= %f)\n"
+"Kann das Linien-Segment nicht erzeugen: cat = %d : %f - %f (Länge der Linie = %f)\n"
 "%s"
 #: ../vector/v.lrs/v.lrs.segment/main.c:331 ../vector/v.segment/main.c:222
@@ -29910,20 +27421,13 @@
 msgstr "Gebe Vektorattribute aus."
 #: ../vector/v.db.select/main.c:89
-msgid ""
-"Print minimal region extent of selected vector features instead of attributes"
-msgstr ""
-"Gebe anstelle der Attribute die minimale Ausdehnung der Region der "
-"selektierten Vektorobjekte aus."
+msgid "Print minimal region extent of selected vector features instead of attributes"
+msgstr "Gebe anstelle der Attribute die minimale Ausdehnung der Region der selektierten Vektorobjekte aus."
 #: ../vector/v.db.select/main.c:152
 #, c-format
-msgid ""
-"Unable to open vector map <%s> at topology level. Flag '%c' requires "
-"topology level."
-msgstr ""
-"Kann die Vektorkarte <%s> nicht im topologischen Modus öffnen. Schalter '%c' "
-"benötigt aber den topologischen Modus."
+msgid "Unable to open vector map <%s> at topology level. Flag '%c' requires topology level."
+msgstr "Kann die Vektorkarte <%s> nicht im topologischen Modus öffnen. Schalter '%c' benötigt aber den topologischen Modus."
 #: ../vector/v.db.select/main.c:187
 msgid "Unable to open select cursor"
@@ -29954,8 +27458,7 @@
 #: ../vector/v.mkgrid/main.c:65
 msgid "Creates a GRASS vector map of a user-defined grid."
-msgstr ""
-"Erzeugt eine GRASS Vektorkarte mit einem benutzerdefinierten Gitternetz."
+msgstr "Erzeugt eine GRASS Vektorkarte mit einem benutzerdefinierten Gitternetz."
 #: ../vector/v.mkgrid/main.c:76
 msgid "Number of rows and columns in grid"
@@ -30056,8 +27559,7 @@
 #: ../vector/v.sample/main.c:98
 msgid "Vector map attribute column to use for comparison"
-msgstr ""
-"Attributspalte der Vektorkarte, die zum Vergleich verwendet werden soll."
+msgstr "Attributspalte der Vektorkarte, die zum Vergleich verwendet werden soll."
 #: ../vector/v.sample/main.c:101
 msgid "Vector map to store differences"
@@ -30068,12 +27570,8 @@
 msgstr "Rasterkarte, die abgefragt wird."
 #: ../vector/v.sample/main.c:113
-msgid ""
-"Option scaling factor for values read from raster map. Sampled values will "
-"be multiplied by this factor"
-msgstr ""
-"Skalierungsfaktor für Werte der Rasterkarte. Abgefragte Werte werden mit "
-"diesem Faktor multipliziert."
+msgid "Option scaling factor for values read from raster map. Sampled values will be multiplied by this factor"
+msgstr "Skalierungsfaktor für Werte der Rasterkarte. Abgefragte Werte werden mit diesem Faktor multipliziert."
 #: ../vector/v.sample/main.c:119
 msgid "Bilinear interpolation (default is nearest neighbor)"
@@ -30085,15 +27583,12 @@
 #: ../vector/v.sample/main.c:142
 msgid "Flags -b & -c are mutually exclusive. Choose only one."
-msgstr ""
-"Die Schalter -b und -c schließen sich gegenseitig aus. Bitte wählen Sie nur "
-"Einen."
+msgstr "Die Schalter -b und -c schließen sich gegenseitig aus. Bitte wählen Sie nur Einen."
 #: ../vector/v.sample/main.c:181
 #, c-format
 msgid "Column type <%s> not supported (must be integer or double precision)"
-msgstr ""
-"Spaltentyp <%s> wird nicht unterstützt (muss integer oder double sein)."
+msgstr "Spaltentyp <%s> wird nicht unterstützt (muss integer oder double sein)."
 #: ../vector/v.sample/main.c:187 ../vector/v.normal/main.c:155
 #: ../vector/v.surf.idw/read_sites.c:54
@@ -30119,9 +27614,7 @@
 #: ../vector/v.to.db/update.c:28 ../vector/v.to.db/update.c:32
 #, c-format
 msgid "Database connection not defined for layer %d. Use v.db.connect first."
-msgstr ""
-"Datenbankverbindung für Layer %d nicht definiert. Verwenden Sie zuerst v.db."
-"connect."
+msgstr "Datenbankverbindung für Layer %d nicht definiert. Verwenden Sie zuerst v.db.connect."
 #: ../vector/v.to.db/query.c:93
 msgid "Querying database... "
@@ -30129,19 +27622,13 @@
 #: ../vector/v.to.db/query.c:108
 #, c-format
-msgid ""
-"Query for category '0' (no category) was not executed because of too many "
-"(%d) query categories. All later reported values for cat 0 are not valid."
-msgstr ""
-"Abfrage für Kategorie '0' (keine Kategorie) wurde nicht ausgeführt, weil zu "
-"viele (%d) Kategorien in der Abfrage sind. Alle im Folgenden berichteten "
-"Werte für cat 0 sind nicht korrekt. "
+msgid "Query for category '0' (no category) was not executed because of too many (%d) query categories. All later reported values for cat 0 are not valid."
+msgstr "Abfrage für Kategorie '0' (keine Kategorie) wurde nicht ausgeführt, weil zu viele (%d) Kategorien in der Abfrage sind. Alle im Folgenden berichteten Werte für cat 0 sind nicht korrekt. "
 #: ../vector/v.to.db/query.c:145
 #, c-format
 msgid "Multiple query results, output value set to NULL (category [%d])"
-msgstr ""
-"Mehrere Abfrage-Ergebnisse, Ausgabewert auf NULL gesetzt (Kategorie [%d])."
+msgstr "Mehrere Abfrage-Ergebnisse, Ausgabewert auf NULL gesetzt (Kategorie [%d])."
 #: ../vector/v.to.db/query.c:152
 msgid "Unable to fetch record"
@@ -30183,16 +27670,12 @@
 #: ../vector/v.to.db/report.c:194
 #, c-format
 msgid "%d categories read from vector map exist in selection from table"
-msgstr ""
-"%d Kategorien gelesen von der Vektorkarte existieren in der Selektion der "
-"Tabelle."
+msgstr "%d Kategorien gelesen von der Vektorkarte existieren in der Selektion der Tabelle."
 #: ../vector/v.to.db/report.c:197
 #, c-format
 msgid "%d categories read from vector map don't exist in selection from table"
-msgstr ""
-"%d Kategorien gelesen von der Vektorkarte existieren nicht in der Selektion "
-"der Tabelle."
+msgstr "%d Kategorien gelesen von der Vektorkarte existieren nicht in der Selektion der Tabelle."
 #: ../vector/v.to.db/report.c:199
 #, c-format
@@ -30211,8 +27694,7 @@
 #: ../vector/v.to.db/parse.c:38
 msgid "For coor valid point/centroid, for length valid line/boundary"
-msgstr ""
-"Für coor sind Punkt/Zentroid erlaubt; für length sind Linie/Grenze erlaubt."
+msgstr "Für coor sind Punkt/Zentroid erlaubt; für length sind Linie/Grenze erlaubt."
 #: ../vector/v.to.db/parse.c:42
 msgid "Layer number (write to)"
@@ -30227,8 +27709,7 @@
 msgstr "Wert zum Laden in die Attributtabelle."
 #: ../vector/v.to.db/parse.c:87
-msgid ""
-"mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),r(adians),d(egrees)"
+msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectares),r(adians),d(egrees)"
 msgstr "mi(len),f(uß),me(ter),k(ilometer),a(cres),h(ektar),r(adians),d(egrees)"
 #: ../vector/v.to.db/parse.c:93
@@ -30249,8 +27730,7 @@
 #: ../vector/v.to.db/parse.c:114
 msgid "In print mode prints totals for options: length,area,count"
-msgstr ""
-"Im Print-Modus werden die Optionen Länge, Fläche und Anzahl ausgegeben."
+msgstr "Im Print-Modus werden die Optionen Länge, Fläche und Anzahl ausgegeben."
 #: ../vector/v.to.db/parse.c:153
 msgid "This option requires one column"
@@ -30281,12 +27761,8 @@
 msgstr "Die 'azimuth' -Option macht nur Sinn für Linien."
 #: ../vector/v.univar/main.c:95
-msgid ""
-"Calculates univariate statistics for attribute. Variance and standard "
-"deviation is calculated only for points if specified."
-msgstr ""
-"Berechnet univariate Statistiken für die Attribute. Die Varianz und "
-"Standardabweichung wird nur für Punkte berechnet wenn explizit angefragt."
+msgid "Calculates univariate statistics for attribute. Variance and standard deviation is calculated only for points if specified."
+msgstr "Berechnet univariate Statistiken für die Attribute. Die Varianz und Standardabweichung wird nur für Punkte berechnet wenn explizit angefragt."
 #: ../vector/v.univar/main.c:111
 msgid "Column name"
@@ -30299,9 +27775,7 @@
 #: ../vector/v.univar/main.c:144
 #, c-format
 msgid "The '-%c' flag is currently broken, please use v.distance instead."
-msgstr ""
-"Der Schalter '-%c' ist momentan kaputt. Bitte verwenden Sie stattdessen v."
-"distance."
+msgstr "Der Schalter '-%c' ist momentan kaputt. Bitte verwenden Sie stattdessen v.distance."
 #: ../vector/v.univar/main.c:149
 #, c-format
@@ -30313,17 +27787,12 @@
 "\t(%s)"
 #: ../vector/v.univar/main.c:175
-msgid ""
-"Incompatible vector type(s) specified, only number of features, minimum, "
-"maximum and range can be calculated"
-msgstr ""
-"Inkompatible Vektortypen angeben. Es kann nur die Anzahl der Objekte, das "
-"Minimum, das Maximum und der Wertebereich berechnet werden."
+msgid "Incompatible vector type(s) specified, only number of features, minimum, maximum and range can be calculated"
+msgstr "Inkompatible Vektortypen angeben. Es kann nur die Anzahl der Objekte, das Minimum, das Maximum und der Wertebereich berechnet werden."
 #: ../vector/v.univar/main.c:180
 msgid "Extended statistics is currently supported only for points/centroids"
-msgstr ""
-"Erweiterte Statistiken werden zur Zeit nur für Punkte/Zentroide unterstützt."
+msgstr "Erweiterte Statistiken werden zur Zeit nur für Punkte/Zentroide unterstützt."
 #: ../vector/v.univar/main.c:220
 #, c-format
@@ -30357,9 +27826,7 @@
 #: ../vector/v.net.path/path.c:205
 #, c-format
 msgid "Point with category [%d] is not reachable from point with category [%d]"
-msgstr ""
-"Punkt mit der Kategorie [%d] ist nicht erreichbar von dem Punkt mit der "
-"Kategorie [%d]."
+msgstr "Punkt mit der Kategorie [%d] ist nicht erreichbar von dem Punkt mit der Kategorie [%d]."
 #: ../vector/v.net.path/path.c:262
 #, c-format
@@ -30379,41 +27846,27 @@
 #: ../vector/v.net.path/path.c:331
 #, c-format
 msgid "%d destination(s) unreachable (including points out of threshold)"
-msgstr ""
-"%d Ziele sind unerreichbar (inklusive der Punkte außerhalb des "
-"Schwellwertes)."
+msgstr "%d Ziele sind unerreichbar (inklusive der Punkte außerhalb des Schwellwertes)."
 #: ../vector/v.net.path/main.c:42
 msgid "Finds shortest path on vector network."
 msgstr "Findet den kürzesten Weg in einem Vektor-Netzwerk."
 #: ../vector/v.net.path/main.c:65
-msgid ""
-"Name of file containing start and end points. If not given, read from stdin"
-msgstr ""
-"Name der Datei mit Start- und Endpunkten. Falls nicht angegeben, wird von "
-"stdin gelesen."
+msgid "Name of file containing start and end points. If not given, read from stdin"
+msgstr "Name der Datei mit Start- und Endpunkten. Falls nicht angegeben, wird von stdin gelesen."
 #: ../vector/v.net.path/main.c:92
 msgid "Maximum distance to the network"
 msgstr "Maximale Distanz zum Netzwerk."
 #: ../vector/v.net.path/main.c:93
-msgid ""
-"If start/end are given as coordinates. If start/end point is outside this "
-"threshold, the path is not found and error message is printed. To speed up "
-"the process, keep this value as low as possible."
-msgstr ""
-"Wenn der Start-/Endpunkt als Koordinaten angegeben wurden. Wenn der Start-/"
-"Endpunkt außerhalb des Schwellwertes sind, wird der kürzeste Weg nicht "
-"gefunden und eine Fehlermeldung ausgegeben. Um die Verarbeitung zu "
-"beschleunigen, wählen Sie den Wert so gering wie möglich."
+msgid "If start/end are given as coordinates. If start/end point is outside this threshold, the path is not found and error message is printed. To speed up the process, keep this value as low as possible."
+msgstr "Wenn der Start-/Endpunkt als Koordinaten angegeben wurden. Wenn der Start-/Endpunkt außerhalb des Schwellwertes sind, wird der kürzeste Weg nicht gefunden und eine Fehlermeldung ausgegeben. Um die Verarbeitung zu beschleunigen, wählen Sie den Wert so gering wie möglich."
 #: ../vector/v.net.path/main.c:106
 msgid "Write output as original input segments, not each path as one line."
-msgstr ""
-"Schreibe die Ausgabe in Form der originalen Eingabesegmente und nicht jeden "
-"Weg als eine Linie."
+msgstr "Schreibe die Ausgabe in Form der originalen Eingabesegmente und nicht jeden Weg als eine Linie."
 #: ../vector/v.kcv/main.c:78
 msgid "Randomly partition points into test/train sets."
@@ -30452,9 +27905,9 @@
 msgstr "%s: Keine Font Definitionsdatei."
 #: ../vector/v.label.sa/labels.c:74
-#, fuzzy, c-format
+#, c-format
 msgid "Cannot allocate %lu bytes of memory"
-msgstr "Kann nicht %d Byte Speicher reservieren."
+msgstr "Kann nicht %lu Byte Speicher reservieren."
 #: ../vector/v.label.sa/labels.c:96
 #, c-format
@@ -30484,11 +27937,8 @@
 #: ../vector/v.label.sa/labels.c:229
 #, c-format
-msgid ""
-"Cannot load overlap weights. Column %s is not of numeric type in table <%s>"
-msgstr ""
-"Kann die Überlappungsgewichte nicht laden. Die Spalte %s in der Tabelle <%s> "
-"ist nicht numerisch."
+msgid "Cannot load overlap weights. Column %s is not of numeric type in table <%s>"
+msgstr "Kann die Überlappungsgewichte nicht laden. Die Spalte %s in der Tabelle <%s> ist nicht numerisch."
 #: ../vector/v.label.sa/labels.c:287
 #, c-format
@@ -30512,24 +27962,12 @@
 msgstr "Rand-Breite (nur für die Ausgabe von ps.map)."
 #: ../vector/v.label.sa/main.c:207
-msgid ""
-"Numeric column to give precedence in case of overlapping labels. The label "
-"with a smaller weight is hidden."
-msgstr ""
-"Numerische Spalte mit Werten, um den Vorrang bei überlappenden "
-"Beschriftungen zu kären. Die Beschriftung mit dem geringeren Gewicht wird "
-"verdeckt."
+msgid "Numeric column to give precedence in case of overlapping labels. The label with a smaller weight is hidden."
+msgstr "Numerische Spalte mit Werten, um den Vorrang bei überlappenden Beschriftungen zu kären. Die Beschriftung mit dem geringeren Gewicht wird verdeckt."
 #: ../vector/v.surf.rst/main.c:166
-msgid ""
-"Spatial approximation and topographic analysis from given point or isoline "
-"data in vector format to floating point raster format using regularized "
-"spline with tension."
-msgstr ""
-"Räumliche Approximation und topographische Analyse auf Basis gegebener "
-"Punkte oder Isolinien im Vektorformat unter Verwendung regularisierten "
-"Splinefunktion mit Spannung. Das Ergebnis wird in eine Fließkomma-"
-"Rasterkarte geschrieben."
+msgid "Spatial approximation and topographic analysis from given point or isoline data in vector format to floating point raster format using regularized spline with tension."
+msgstr "Räumliche Approximation und topographische Analyse auf Basis gegebener Punkte oder Isolinien im Vektorformat unter Verwendung regularisierten Splinefunktion mit Spannung. Das Ergebnis wird in eine Fließkomma-Rasterkarte geschrieben."
 #: ../vector/v.surf.rst/main.c:192
 msgid "Use z-coordinates (3D vector only)"
@@ -30580,29 +28018,20 @@
 msgstr "Ausgabe-Vektordatei, die die überlappenden Segmente beinhaltet."
 #: ../vector/v.surf.rst/main.c:300
-msgid ""
-"Name of the attribute column with values to be used for approximation (if "
-"layer>0)"
-msgstr ""
-"Name der Attributspalte mit Werten, die für die Approximation verwendet "
-"werden (wen der Layer >0)."
+msgid "Name of the attribute column with values to be used for approximation (if layer>0)"
+msgstr "Name der Attributspalte mit Werten, die für die Approximation verwendet werden (wen der Layer >0)."
 #: ../vector/v.surf.rst/main.c:323
 msgid "Name of the attribute column with smoothing parameters"
 msgstr "Name der Attributspalte mit Glättungsparametern (smoothing)."
 #: ../vector/v.surf.rst/main.c:358
-msgid ""
-"Maximum distance between points on isoline (to insert additional points)"
-msgstr ""
-"Maximale Distanz zwischen den Punkten auf einer Isolinie (zum Einfügen "
-"weiterer Punkte)."
+msgid "Maximum distance between points on isoline (to insert additional points)"
+msgstr "Maximale Distanz zwischen den Punkten auf einer Isolinie (zum Einfügen weiterer Punkte)."
 #: ../vector/v.surf.rst/main.c:367
 msgid "Conversion factor for values used for approximation"
-msgstr ""
-"Konvertierungsfaktor für die Werte, die für die Annährung genutzt werden "
-"sollen."
+msgstr "Konvertierungsfaktor für die Werte, die für die Annährung genutzt werden sollen."
 #: ../vector/v.surf.rst/main.c:375
 msgid "Anisotropy angle (in degrees counterclockwise from East)"
@@ -30616,40 +28045,27 @@
 #: ../vector/v.surf.rst/main.c:436
 msgid "You are not outputting any raster or vector maps"
-msgstr ""
-"Sie haben weder die Ausgabe von Vektor- noch von Rasterkarten veranlasst."
+msgstr "Sie haben weder die Ausgabe von Vektor- noch von Rasterkarten veranlasst."
 #: ../vector/v.surf.rst/main.c:456
-msgid ""
-"Both cross-validation options (-c flag and cvdev vector output) must be "
-"specified"
-msgstr ""
-"Beide Kreuzvalidierungsoptionen (Schalter '-c' und die 'cvdev'-Vektorkarte) "
-"müssen angegeben werden."
+msgid "Both cross-validation options (-c flag and cvdev vector output) must be specified"
+msgstr "Beide Kreuzvalidierungsoptionen (Schalter '-c' und die 'cvdev'-Vektorkarte) müssen angegeben werden."
 #: ../vector/v.surf.rst/main.c:459
-msgid ""
-"The cross-validation cannot be computed simultaneously with output raster or "
-"devi file"
-msgstr ""
-"Die Kreuzvalidierung kann nicht gleichzeitig mit Ausgabe-Rasterkarten oder "
-"der 'devi'-Datei berechnet werden."
+msgid "The cross-validation cannot be computed simultaneously with output raster or devi file"
+msgstr "Die Kreuzvalidierung kann nicht gleichzeitig mit Ausgabe-Rasterkarten oder der 'devi'-Datei berechnet werden."
 #: ../vector/v.surf.rst/main.c:462
 msgid "Both z-coordinate and zcol attribute defined, only one is allowed"
-msgstr ""
-"z-Koordinate und 'zcol' wurden angegeben, aber nur eine Angabe ist erlaubt."
+msgstr "z-Koordinate und 'zcol' wurden angegeben, aber nur eine Angabe ist erlaubt."
 #: ../vector/v.surf.rst/main.c:464
 msgid "Only smoothing column defined, zcol or -z flag is missing"
-msgstr ""
-"Nur die Spalte mit dem Glättungsfaktor wurde definiert, zcol oder -z fehlt."
+msgstr "Nur die Spalte mit dem Glättungsfaktor wurde definiert, zcol oder -z fehlt."
 #: ../vector/v.surf.rst/main.c:484
 msgid "Using anisotropy - both theta and scalex have to be specified"
-msgstr ""
-"Benutze Anisotropie - beide Parameter theta und scalex müssen angegeben "
-"werden."
+msgstr "Benutze Anisotropie - beide Parameter theta und scalex müssen angegeben werden."
 #: ../vector/v.surf.rst/main.c:492
 msgid "Both smatt and smooth options specified - using constant"
@@ -30657,8 +28073,7 @@
 #: ../vector/v.surf.rst/main.c:502
 msgid "The computation will last too long - lower npmin is suggested"
-msgstr ""
-"Die Berechnung dauert zu lange - es wird vorgeschlagen, npmin zu reduzieren."
+msgstr "Die Berechnung dauert zu lange - es wird vorgeschlagen, npmin zu reduzieren."
 #: ../vector/v.surf.rst/main.c:549
 msgid "Cannot create quaddata"
@@ -30691,31 +28106,23 @@
 #: ../vector/v.surf.rst/main.c:796
 msgid "Cannot write raster maps -- try to increase resolution"
-msgstr ""
-"Kann Rasterkarte nicht schreiben -- Versuchen Sie die Auflösung zu erhöhen."
+msgstr "Kann Rasterkarte nicht schreiben -- Versuchen Sie die Auflösung zu erhöhen."
 #: ../vector/v.reclass/main.c:64
 msgid "vector, reclass, attributes"
 msgstr "Vektor, Re-Klassifizierung, Attribute"
 #: ../vector/v.reclass/main.c:66
-msgid ""
-"Changes vector category values for an existing vector map according to "
-"results of SQL queries or a value in attribute table column."
-msgstr ""
-"Ändert die Kategorien einer existierenden Vektorkarte entsprechend den "
-"Ergebnissen der SQL-Abfragen oder der Werte einer Spalte der Attributtabelle."
+msgid "Changes vector category values for an existing vector map according to results of SQL queries or a value in attribute table column."
+msgstr "Ändert die Kategorien einer existierenden Vektorkarte entsprechend den Ergebnissen der SQL-Abfragen oder der Werte einer Spalte der Attributtabelle."
 #: ../vector/v.reclass/main.c:83
 msgid "The name of the column whose values are to be used as new categories"
-msgstr ""
-"Name der Spalte, deren Werte als neue Kategorien verwendet werden sollen."
+msgstr "Name der Spalte, deren Werte als neue Kategorien verwendet werden sollen."
 #: ../vector/v.reclass/main.c:84
 msgid "The source for the new key column must be type integer or string"
-msgstr ""
-"Die Quelle für die neue Schlüsselspalte muss vom Typ integer oder string "
-"sein."
+msgstr "Die Quelle für die neue Schlüsselspalte muss vom Typ integer oder string sein."
 #: ../vector/v.reclass/main.c:89
 msgid "Full path to the reclass rule file"
@@ -30815,14 +28222,12 @@
 msgstr "Trenne Linien in kleinere Abschnitte."
 #: ../vector/v.split/main.c:54
-#, fuzzy
 msgid "Maximum segment length"
-msgstr "Maximale Länge der Inputzeile: %d"
+msgstr "Maximale Segmentlänge"
 #: ../vector/v.split/main.c:61
-#, fuzzy
 msgid "Maximum number of vertices in segment"
-msgstr "Maximale Anzahl der Punkte auf einem Segment"
+msgstr "Maximale Anzahl der Vertices auf einem Segment"
 #: ../vector/v.surf.idw/read_sites.c:102
 #, c-format
@@ -30830,18 +28235,12 @@
 msgstr "%d Punkte geladen."
 #: ../vector/v.surf.idw/main.c:86
-msgid ""
-"Surface interpolation from vector point data by Inverse Distance Squared "
-"Weighting."
-msgstr ""
-"Oberflächeninterpolation aus Vektor-Punktdaten durch Inverse Distance "
-"Squared Weighting."
+msgid "Surface interpolation from vector point data by Inverse Distance Squared Weighting."
+msgstr "Oberflächeninterpolation aus Vektor-Punktdaten durch Inverse Distance Squared Weighting."
 #: ../vector/v.surf.idw/main.c:95
 msgid "If set to 0, z coordinates are used (3D vector only)"
-msgstr ""
-"Wenn auf 0 gesetzt, dann werden die Z-Koordinate genutzt (nur bei 3D-"
-"Vektoren)."
+msgstr "Wenn auf 0 gesetzt, dann werden die Z-Koordinate genutzt (nur bei 3D-Vektoren)."
 #: ../vector/v.surf.idw/main.c:98 ../vector/v.surf.idw/main.c:106
 msgid "Values"
@@ -30856,23 +28255,16 @@
 msgstr "Erfordert wenn Layer >0"
 #: ../vector/v.surf.idw/main.c:122
-msgid ""
-"Power parameter; greater values assign greater influence to closer points"
-msgstr ""
-"Power-Parameter; größere Werte geben ein näheren Punkten ein stärkeres "
-"Gewicht."
+msgid "Power parameter; greater values assign greater influence to closer points"
+msgstr "Power-Parameter; größere Werte geben ein näheren Punkten ein stärkeres Gewicht."
 #: ../vector/v.surf.idw/main.c:127
 msgid "Don't index points by raster cell"
 msgstr "Indiziere die Punkte nicht mittels der Rasterzellen."
 #: ../vector/v.surf.idw/main.c:128
-msgid ""
-"Slower but uses less memory and includes points from outside region in the "
-"interpolation"
-msgstr ""
-"Langsamer, aber braucht weniger Speicher und integriert auch Punkte "
-"außerhalb der Region in die Interpolation."
+msgid "Slower but uses less memory and includes points from outside region in the interpolation"
+msgstr "Langsamer, aber braucht weniger Speicher und integriert auch Punkte außerhalb der Region in die Interpolation."
 #: ../vector/v.surf.idw/main.c:144
 msgid "No attribute column specified"
@@ -30924,9 +28316,7 @@
 #: ../vector/v.to.3d/args.c:39
 msgid "Can be used for reverse transformation, to store height of points"
-msgstr ""
-"Kann verwendet werden, um, bei umgekehrter Transformation, die Höhen der "
-"Punkte zu speichern. "
+msgstr "Kann verwendet werden, um, bei umgekehrter Transformation, die Höhen der Punkte zu speichern. "
 #: ../vector/v.to.3d/main.c:37
 msgid "vector, transformation, 3D"
@@ -31001,8 +28391,7 @@
 #: ../vector/v.out.vtk/main.c:93
 msgid "Export numeric attribute table fields as VTK scalar variables"
-msgstr ""
-"Exportiere numerische Felder der Attributtabelle als VTK-Skalar-Variablen."
+msgstr "Exportiere numerische Felder der Attributtabelle als VTK-Skalar-Variablen."
 #: ../vector/v.out.vtk/main.c:188
 msgid "dp has to be from 0 to 8"
@@ -31013,11 +28402,8 @@
 msgstr "Interpretation des 'Layer'-Parameters als Integer fehlgeschlagen."
 #: ../vector/v.out.vtk/writeVTK.c:188
-msgid ""
-"No coordinates to generate the output! Maybe an empty vector type chosen?"
-msgstr ""
-"Keine Koordinaten um Ausgabe zu erzeugen. Vielleicht wurde ein leerer Vektor-"
-"Typ ausgewählt."
+msgid "No coordinates to generate the output! Maybe an empty vector type chosen?"
+msgstr "Keine Koordinaten um Ausgabe zu erzeugen. Vielleicht wurde ein leerer Vektor-Typ ausgewählt."
 #: ../vector/v.out.vtk/writeVTK.c:576 ../vector/v.out.ogr/main.c:1067
 #, c-format
@@ -31026,9 +28412,7 @@
 #: ../vector/v.out.vtk/writeVTK.c:623
 msgid "Cannot export attribute table fields for layer < 1. Skipping export"
-msgstr ""
-"Kann Felder der Attributtabelle für Layer < 1 nicht exportieren. Überspringe "
-"den Export."
+msgstr "Kann Felder der Attributtabelle für Layer < 1 nicht exportieren. Überspringe den Export."
 #: ../vector/v.out.vtk/writeVTK.c:631
 msgid "No attribute table found"
@@ -31046,9 +28430,7 @@
 #: ../vector/v.to.points/main.c:175
 msgid "Create points along input lines in new vector with 2 layers."
-msgstr ""
-"Erzeuge Punkte entlang der Eingabelinie in eine neue Vektorkarte mit zwei "
-"Layern."
+msgstr "Erzeuge Punkte entlang der Eingabelinie in eine neue Vektorkarte mit zwei Layern."
 #: ../vector/v.to.points/main.c:182
 msgid "Output vector map where points will be written"
@@ -31093,7 +28475,7 @@
 #: ../vector/v.voronoi/sw_main.c:140
 #, c-format
 msgid "Found %d points/centroids in <%s>, but at least 2 are needed"
-msgstr ""
+msgstr "%d Punkte/Zentroide in <%s> gefunden, aber mindestens 2 werden benötigt"
 #: ../vector/v.voronoi/dt_main.c:46 ../vector/v.voronoi/vo_main.c:123
 #: ../vector/v.delaunay2/main.c:86
@@ -31101,12 +28483,8 @@
 msgstr "Vektor, Geometrie, Triangulation"
 #: ../vector/v.voronoi/dt_main.c:47 ../vector/v.delaunay2/main.c:87
-msgid ""
-"Creates a Delaunay triangulation from an input vector map containing points "
-"or centroids."
-msgstr ""
-"Erzeugt eine Delaunay-Triangulation auf Basis einer Eingabe-Vektorkarte mit "
-"Punkten oder Zentroiden."
+msgid "Creates a Delaunay triangulation from an input vector map containing points or centroids."
+msgstr "Erzeugt eine Delaunay-Triangulation auf Basis einer Eingabe-Vektorkarte mit Punkten oder Zentroiden."
 #: ../vector/v.voronoi/dt_main.c:55 ../vector/v.delaunay2/main.c:95
 msgid "Use only points in current region"
@@ -31114,21 +28492,15 @@
 #: ../vector/v.voronoi/dt_main.c:60 ../vector/v.delaunay2/main.c:100
 msgid "Output triangulation as a graph (lines), not areas"
-msgstr ""
-"Gebe das Ergebnis der Triangulation als Graph (Linien) und nicht als Flächen "
-"aus."
+msgstr "Gebe das Ergebnis der Triangulation als Graph (Linien) und nicht als Flächen aus."
 #: ../vector/v.voronoi/dt_main.c:149
 msgid "Cannot calculate area centroid z coordinate"
 msgstr "Kann die Z-Koordinate des Zentroids nicht berechnen."
 #: ../vector/v.voronoi/vo_main.c:124
-msgid ""
-"Creates a Voronoi diagram from an input vector map containing points or "
-"centroids."
-msgstr ""
-"Erstellt ein Voronoi Diagramm auf Basis einer Vektorkarte mit Punkten oder "
-"Zentroiden."
+msgid "Creates a Voronoi diagram from an input vector map containing points or centroids."
+msgstr "Erstellt ein Voronoi Diagramm auf Basis einer Vektorkarte mit Punkten oder Zentroiden."
 #: ../vector/v.voronoi/vo_main.c:139
 msgid "Output tessellation as a graph (lines), not areas"
@@ -31175,13 +28547,8 @@
 msgstr "Kategorienummer-Modus"
 #: ../vector/v.build.polylines/main.c:123
-msgid ""
-"no;Do not assign any category number to polyline;first;Assign category "
-"number of first line to polyline;multi;Assign multiple category numbers to "
-"polyline"
-msgstr ""
-"no;Weise Polyline keine Kategorie zu;first;Weise der Polyline die Kategorie "
-"der ersten Linie zu;multi;Weise der Polylinie mehrere Kategorien zu"
+msgid "no;Do not assign any category number to polyline;first;Assign category number of first line to polyline;multi;Assign multiple category numbers to polyline"
+msgstr "no;Weise Polyline keine Kategorie zu;first;Weise der Polyline die Kategorie der ersten Linie zu;multi;Weise der Polylinie mehrere Kategorien zu"
 #: ../vector/v.build.polylines/main.c:225
 #, c-format
@@ -31195,9 +28562,7 @@
 #: ../vector/v.db.connect/main.c:52
 msgid "Prints/sets DB connection for a vector map to attribute table."
-msgstr ""
-"Gibt oder setzt Datenbankverbindung für eine Vektorkarte zu einer "
-"Attributtabelle."
+msgstr "Gibt oder setzt Datenbankverbindung für eine Vektorkarte zu einer Attributtabelle."
 #: ../vector/v.db.connect/main.c:72
 msgid "Key column name"
@@ -31213,13 +28578,11 @@
 #: ../vector/v.db.connect/main.c:90
 msgid "Print all map connection parameters and exit in shell script style"
-msgstr ""
-"Gibt alle Verbindungsparameter im Shellskript-Stil aus und beendet sich."
+msgstr "Gibt alle Verbindungsparameter im Shellskript-Stil aus und beendet sich."
 #: ../vector/v.db.connect/main.c:93
 msgid "Format: layer[/layer name] table key database driver"
-msgstr ""
-"Format: Layer[/Name des Layers] Tabelle Schlüsselspalte Datenbanktreiber"
+msgstr "Format: Layer[/Name des Layers] Tabelle Schlüsselspalte Datenbanktreiber"
 #: ../vector/v.db.connect/main.c:103
 msgid "When printing, limit to layer specified by the layer option"
@@ -31227,9 +28590,7 @@
 #: ../vector/v.db.connect/main.c:108
 msgid "Print types/names of table columns for specified layer and exit"
-msgstr ""
-"Gebe die Typen/Namen der Tabellenspalten der angegebenen Layer aus und "
-"beendet sich. "
+msgstr "Gebe die Typen/Namen der Tabellenspalten der angegebenen Layer aus und beendet sich. "
 #: ../vector/v.db.connect/main.c:115
 msgid "Overwrite connection parameter for certain layer"
@@ -31250,18 +28611,13 @@
 #: ../vector/v.db.connect/main.c:198
 #, c-format
-msgid ""
-"layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
-msgstr ""
-"Layer <%d> Tabelle <%s> in der Datenbank <%s> mit dem Treiber <%s> und der "
-"Schlüsselspalte <%s>\n"
+msgid "layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
+msgstr "Layer <%d> Tabelle <%s> in der Datenbank <%s> mit dem Treiber <%s> und der Schlüsselspalte <%s>\n"
 #: ../vector/v.db.connect/main.c:261
 #, c-format
 msgid "Use -o to overwrite existing link for layer <%d>"
-msgstr ""
-"Verwenden Sie -o, um den existierenden Link für den Layer <%d> zu "
-"überschreiben."
+msgstr "Verwenden Sie -o, um den existierenden Link für den Layer <%d> zu überschreiben."
 #: ../vector/v.db.connect/main.c:269 ../vector/v.db.connect/main.c:309
 #, c-format
@@ -31270,12 +28626,8 @@
 #: ../vector/v.db.connect/main.c:297 ../vector/v.db.connect/main.c:315
 #, c-format
-msgid ""
-"The table <%s> is now part of vector map <%s> and may be deleted or "
-"overwritten by GRASS modules"
-msgstr ""
-"Die Tabelle <%s> ist jetzt Teil der Vektorkarte <%s> und kann mit GRASS "
-"Modulen gelöscht und überschrieben werden."
+msgid "The table <%s> is now part of vector map <%s> and may be deleted or overwritten by GRASS modules"
+msgstr "Die Tabelle <%s> ist jetzt Teil der Vektorkarte <%s> und kann mit GRASS Modulen gelöscht und überschrieben werden."
 #: ../vector/v.db.connect/main.c:336 ../vector/v.digit/c_face.c:294
 #, c-format
@@ -31287,61 +28639,52 @@
 msgstr "Select-Privilegien wurden für die Tabelle gewährt."
 #: ../vector/v.db.connect/main.c:346
-msgid ""
-"For defining a new connection you have to specify these parameters: driver, "
-"database, table [, key [, layer]]"
-msgstr ""
-"Um eine neue Verbindung zu definieren müssen Sie die folgenden Parameter "
-"angeben: Treiber, Datenbank, Tabelle [, Schlüsselspalte [, Layer]]."
+msgid "For defining a new connection you have to specify these parameters: driver, database, table [, key [, layer]]"
+msgstr "Um eine neue Verbindung zu definieren müssen Sie die folgenden Parameter angeben: Treiber, Datenbank, Tabelle [, Schlüsselspalte [, Layer]]."
 #: ../vector/v.buffer2/geos.c:19
-#, fuzzy
 msgid "Invalid GEOS geometry!"
-msgstr "Ungültiger Grad."
+msgstr "Ungültige GEOS Geometrie!"
 #: ../vector/v.buffer2/geos.c:25
 msgid "No coordinates in GEOS geometry (can be ok for negative distance)!"
-msgstr ""
+msgstr "Keine Koordinaten in der GEIS Geometrie (kann bei negativer Distanz okay sein)!"
 #: ../vector/v.buffer2/geos.c:33
-#, fuzzy, c-format
+#, c-format
 msgid "Invalid x coordinate %f"
-msgstr "Ungültige Koordinaten."
+msgstr "Ungültige X-Koordinate %f"
 #: ../vector/v.buffer2/geos.c:35
-#, fuzzy, c-format
+#, c-format
 msgid "Invalid y coordinate %f"
+msgstr "Ungültige Y-Koordinate %f"
 #: ../vector/v.buffer2/geos.c:107
-#, fuzzy
 msgid "Corrupt GEOS geometry"
-msgstr "Kann Teil der Geometrie nicht lesen."
+msgstr "Kaputte GEOS Geometrie"
 #: ../vector/v.buffer2/geos.c:135
-#, fuzzy
 msgid "Unknown GEOS geometry type"
-msgstr "Unbekannter Geometrie-Typ."
+msgstr "Unbekannter GEOS Geometrie-Typ"
 #: ../vector/v.buffer2/geos.c:164
-#, fuzzy
 msgid "Buffering failed"
-msgstr "Buffere Linien..."
+msgstr "Puffern fehlgeschlagen"
 #: ../vector/v.buffer2/main.c:203 ../vector/v.buffer2/main.c:289
-#, fuzzy
 msgid "Layer number must be > 0 for category constraints"
-msgstr "'Layer' muss > 0 sein für den Parameter 'cats'."
+msgstr "Layer Nummer muss > 0 sein für Kategorie-Bedingungen"
 #: ../vector/v.buffer2/main.c:216
-#, fuzzy, c-format
+#, c-format
 msgid "'%s' and '%s' parameters were supplied, cats will be ignored"
-msgstr "'where' und 'cats' Parameter wurden angegeben, cat wird ignoriert."
+msgstr "'%s' und '%s' Parameter wurden angegeben, cats wird ignoriert"
 #: ../vector/v.buffer2/main.c:224
-#, fuzzy, c-format
+#, c-format
 msgid "Loading categories from table <%s>..."
-msgstr "%d Kategorien von der Tabelle <%s> geladen."
+msgstr "Lade Kategorien aus Tabelle <%s> ..."
 #: ../vector/v.buffer2/main.c:234 ../vector/v.extract/main.c:297
 #, c-format
@@ -31349,35 +28692,31 @@
 msgstr "Kann keine Datensätze Tabelle <%s> selektieren."
 #: ../vector/v.buffer2/main.c:236
-#, fuzzy, c-format
+#, c-format
 msgid "%d categories loaded"
-msgstr "%d Kategorien aus der Tabelle geladen."
+msgstr "%d Kategorien geladen"
 #: ../vector/v.buffer2/main.c:258
-#, fuzzy, c-format
+#, c-format
 msgid "No categories selected with '%s' option"
-msgstr "Kann 'select' und 'where'-Optionen nicht miteinander kombinieren."
+msgstr "Keine Kategorien mit der Option '%s' selektiert"
 #: ../vector/v.buffer2/main.c:268
-#, fuzzy, c-format
+#, c-format
 msgid "%d errors in '%s' option"
-msgstr "%d Fehler in id Option."
+msgstr "%d Fehler in '%s' Option"
 #: ../vector/v.buffer2/main.c:350
-#, fuzzy
 msgid "vector, buffer, geometry"
-msgstr "Vektor, Geometrie"
+msgstr "Vektor, Puffer, Geometrie"
 #: ../vector/v.buffer2/main.c:352
-#, fuzzy
 msgid "Creates a buffer around vector features of given type."
-msgstr ""
-"Erzeugt einen Buffer um die Objekte mit gegebenen Typ (Flächen müssen "
-"Zentroide enthalten)."
+msgstr "Erzeugt einen Puffer um Objekte mit gegebenen Typ."
 #: ../vector/v.buffer2/main.c:377
 msgid "Buffer distance along major axis in map units"
-msgstr "Bufferdistanz entlang der Hauptachse in Karteneinheiten."
+msgstr "Pufferdistanz entlang der Hauptachse in Karteneinheiten."
 #: ../vector/v.buffer2/main.c:378 ../vector/v.buffer2/main.c:386
 #: ../vector/v.buffer2/main.c:394 ../vector/v.buffer2/main.c:400
@@ -31387,7 +28726,7 @@
 #: ../vector/v.buffer2/main.c:385
 msgid "Buffer distance along minor axis in map units"
-msgstr "Bufferdistanz entlang der Nebenachse in Karteneinheiten."
+msgstr "Pufferdistanz entlang der Nebenachse in Karteneinheiten."
 #: ../vector/v.buffer2/main.c:393 ../vector/v.parallel2/main.c:74
 msgid "Angle of major axis in degrees"
@@ -31395,7 +28734,7 @@
 #: ../vector/v.buffer2/main.c:399
 msgid "Name of column to use for buffer distances"
-msgstr "Name der Spalte mit den Bufferdistanzen"
+msgstr "Name der Spalte mit den Pufferdistanzen"
 #: ../vector/v.buffer2/main.c:421
 msgid "Make outside corners straight"
@@ -31406,27 +28745,21 @@
 msgstr "Erzeuge keine Kappen an den Enden von Polylinien"
 #: ../vector/v.buffer2/main.c:429
-#, fuzzy
 msgid "Transfer categories and attributes"
-msgstr "Gebe Vektorattribute aus."
+msgstr "Übertrage Kategorien und Attribute"
 #: ../vector/v.buffer2/main.c:443
-msgid ""
-"Note: In latitude-longitude coordinate system distances are in degree units"
-msgstr ""
+msgid "Note: In latitude-longitude coordinate system distances are in degree units"
+msgstr "Beachte: In geographischen Koordinatensystem sind Distanzen in Grad"
 #: ../vector/v.buffer2/main.c:447
 msgid "Select a buffer distance/minordistance/angle or column, but not both."
-msgstr ""
-"Wählen Sie entweder die Buffer distance/minordistance/angle oder eine "
-"Spalte, aber nicht beides"
+msgstr "Wählen Sie entweder die Puffer distance/minordistance/angle oder eine Spalte, aber nicht beides"
 #: ../vector/v.buffer2/main.c:465
 #, c-format
-msgid ""
-"Invalid layer number (%d). Parameter '%s' or '%s' specified, assuming layer "
-"'1'."
-msgstr ""
+msgid "Invalid layer number (%d). Parameter '%s' or '%s' specified, assuming layer '1'."
+msgstr "Ungültige Layer-Nummer (%d). Parameter '%s' oder '%s' angegeben, vermute Layer '1'."
 #: ../vector/v.buffer2/main.c:476
 msgid "The bufcol option requires a valid layer."
@@ -31442,9 +28775,8 @@
 msgstr "Die Toleranz wurde auf %g zurückgesetzt"
 #: ../vector/v.buffer2/main.c:487
-#, fuzzy
 msgid "Illegal scale value"
-msgstr "Ungültige Anfrage Maßstab"
+msgstr "Ungültiger Maßstabswert"
 #: ../vector/v.buffer2/main.c:504
 #, c-format
@@ -31452,9 +28784,8 @@
 msgstr "Toleranz in Karteneinheiten = %g"
 #: ../vector/v.buffer2/main.c:517
-#, fuzzy
 msgid "Unable to create vector map"
-msgstr "Kann die Vektorkarte nicht lesen."
+msgstr "Kann die Vektorkarte nicht erzeugen"
 #: ../vector/v.buffer2/main.c:544
 #, c-format
@@ -31462,36 +28793,28 @@
 msgstr "Kann keine Daten der Tabelle <%s> selektieren"
 #: ../vector/v.buffer2/main.c:580
-msgid ""
-"No features available for buffering. Check type option and features "
-"available in the input vector."
-msgstr ""
-"Keine Objekte zum Buffern vorhanden. Überprüfen Sie die Option type und die "
-"Objekte in der Eingabe-Vektorkarte."
+msgid "No features available for buffering. Check type option and features available in the input vector."
+msgstr "Keine Objekte zum Puffern vorhanden. Überprüfen Sie die Option type und die Objekte in der Eingabe-Vektorkarte."
 #: ../vector/v.buffer2/main.c:596
-msgid ""
-"Negative distances for internal buffers are not supported and converted to "
-"positive values."
-msgstr ""
+msgid "Negative distances for internal buffers are not supported and converted to positive values."
+msgstr "Negative Distanzen für interne Puffer sind nicht erlaubt und werden in positive Werte umgewandelt."
 #: ../vector/v.buffer2/main.c:607
 msgid "Buffering areas..."
-msgstr "Buffere Flächen..."
+msgstr "Puffere Flächen..."
 #: ../vector/v.buffer2/main.c:672
-#, fuzzy
 msgid "Buffering features..."
+msgstr "Puffere Objekte..."
 #: ../vector/v.buffer2/main.c:675 ../vector/v.buffer2/main.c:724
 msgid "Negative distances are only supported for areas"
-msgstr ""
+msgstr "Negative Distanzen sind nur für Flächen erlaubt"
 #: ../vector/v.buffer2/main.c:767
-#, fuzzy
 msgid "Cleaning buffers..."
-msgstr "Schreibe Buffer..."
+msgstr "Säubere Puffer..."
 #: ../vector/v.buffer2/main.c:787
 msgid "Breaking polygons..."
@@ -31502,19 +28825,16 @@
 msgstr "Säubere Grenzen an den Knoten"
 #: ../vector/v.buffer2/main.c:808
-#, fuzzy
 msgid "Removing dangles..."
-msgstr "Entferne Überstände (dangles)"
+msgstr "Entferne Überstände (dangles)..."
 #: ../vector/v.buffer2/main.c:811
-#, fuzzy
 msgid "Removing bridges..."
-msgstr "Entferne Brücken"
+msgstr "Entferne Brücken..."
 #: ../vector/v.buffer2/main.c:821
-#, fuzzy
 msgid "Calculating centroids for all areas..."
-msgstr "Berechne Zentroide der Flächen..."
+msgstr "Berechne Zentroide für alle Flächen..."
 #: ../vector/v.buffer2/main.c:930
 #, c-format
@@ -31527,8 +28847,7 @@
 #: ../vector/v.proj/main.c:64
 msgid "Re-projects a vector map from one location to the current location."
-msgstr ""
-"Reprojiziert eine Vektorkarte von einer Location in die aktuelle Location."
+msgstr "Reprojiziert eine Vektorkarte von einer Location in die aktuelle Location."
 #: ../vector/v.proj/main.c:76
 msgid "Location containing input vector map"
@@ -31552,9 +28871,7 @@
 #: ../vector/v.proj/main.c:111
 msgid "Assume z co-ordinate is ellipsoidal height and transform if possible"
-msgstr ""
-"Nehme an das die Z-Koordinate die ellipsoidale Höhe enthält und "
-"transformiere, wenn möglich."
+msgstr "Nehme an das die Z-Koordinate die ellipsoidale Höhe enthält und transformiere, wenn möglich."
 #: ../vector/v.proj/main.c:188
 #, c-format
@@ -31589,19 +28906,12 @@
 msgstr "Erzeugt eine neue Vektorkarte durch Kombination anderer Vektorkarten"
 #: ../vector/v.patch/main.c:80
-msgid ""
-"Name for output vector map where bounding boxes of input vector maps are "
-"written to"
-msgstr ""
-"Ausgabe-Vektorkarte, in die die Boundig Boxes der Eingabe-Vektorkarten "
-"geschrieben werden"
+msgid "Name for output vector map where bounding boxes of input vector maps are written to"
+msgstr "Ausgabe-Vektorkarte, in die die Boundig Boxes der Eingabe-Vektorkarten geschrieben werden"
 #: ../vector/v.patch/main.c:84
-msgid ""
-"Append files to existing file (overwriting existing files must be activated)"
-msgstr ""
-"Hänge Dateien an eine existierende Datei an. Das Überschreiben von "
-"existierenden Dateien muss aktiviert sein"
+msgid "Append files to existing file (overwriting existing files must be activated)"
+msgstr "Hänge Dateien an eine existierende Datei an. Das Überschreiben von existierenden Dateien muss aktiviert sein"
 #: ../vector/v.patch/main.c:89
 msgid "Copy also attribute table"
@@ -31651,9 +28961,7 @@
 #: ../vector/v.patch/main.c:333
 #, c-format
 msgid "Error reading vector map <%s> - some data may not be correct"
-msgstr ""
-"Fehler beim Lesen der Vektorkarte <%s> - Einige Daten könnten nicht korrekt "
-"sein"
+msgstr "Fehler beim Lesen der Vektorkarte <%s> - Einige Daten könnten nicht korrekt sein"
 #: ../vector/v.patch/main.c:375
 #, c-format
@@ -31779,15 +29087,11 @@
 #: ../vector/v.in.sites/main.c:98
 msgid "Floating point category values, using sequential integer for category"
-msgstr ""
-"Fließkomma Kategoriewerte -> verwende einen fortlaufenden Integer für die "
-"Kategorien."
+msgstr "Fließkomma Kategoriewerte -> verwende einen fortlaufenden Integer für die Kategorien."
 #: ../vector/v.in.sites/main.c:101
 msgid "No category values, using sequential integer for category"
-msgstr ""
-"Keine Kategoriewerte -> verwende einen fortlaufenden Integer für die "
-"Kategorien."
+msgstr "Keine Kategoriewerte -> verwende einen fortlaufenden Integer für die Kategorien."
 #: ../vector/v.in.sites/main.c:183
 msgid "Transferring sites to vector point map..."
@@ -32007,11 +29311,8 @@
 #: ../vector/v.digit/generate.c:110
 #, c-format
-msgid ""
-"Cannot open select cursor:<BR>'%s'<BR>on database '%s' by driver '%s'<BR>"
-msgstr ""
-"kann den Select-Cursor nicht öffnen:<BR>'%s'<BR>der Datenbank '%s' mit "
-"Treiber '%s'<BR>"
+msgid "Cannot open select cursor:<BR>'%s'<BR>on database '%s' by driver '%s'<BR>"
+msgstr "kann den Select-Cursor nicht öffnen:<BR>'%s'<BR>der Datenbank '%s' mit Treiber '%s'<BR>"
 #: ../vector/v.digit/generate.c:121
 msgid "Cannot fetch next record"
@@ -32024,8 +29325,7 @@
 #: ../vector/v.digit/generate.c:223
 #, c-format
 msgid "<HR>   Assume data encoding as:<BR><BR><SELECT NAME=%s SIZE=4><HR><BR>"
-msgstr ""
-"<HR>   Angenommene Datenkodierung:<BR><BR><SELECT NAME=%s SIZE=4><HR><BR>"
+msgstr "<HR>   Angenommene Datenkodierung:<BR><BR><SELECT NAME=%s SIZE=4><HR><BR>"
 #: ../vector/v.digit/attr.c:94
 msgid "Cannot create new record."
@@ -32113,13 +29413,8 @@
 #: ../vector/v.digit/attr.c:668
 #, c-format
-msgid ""
-"There are no more features with category %d (layer %d) in the map, but there "
-"is record in the table. Delete this record?"
-msgstr ""
-"Es gibt keine weiteren Objekte mit der Kategorie %d (Layer %d) in der Karte, "
-"aber es existieren Einträge in der Tabelle. Sollen diese Tabellen-Einträge "
-"gelöscht werden?"
+msgid "There are no more features with category %d (layer %d) in the map, but there is record in the table. Delete this record?"
+msgstr "Es gibt keine weiteren Objekte mit der Kategorie %d (Layer %d) in der Karte, aber es existieren Einträge in der Tabelle. Sollen diese Tabellen-Einträge gelöscht werden?"
 #: ../vector/v.digit/attr.c:680
 #, c-format
@@ -32144,11 +29439,8 @@
 #: ../vector/v.digit/main.c:165
 #, c-format
-msgid ""
-"Map <%s> does not exist in current mapset. Add flag -n to create a new map."
-msgstr ""
-"Karte <%s> existiert noch nicht im aktuellen Mapset. verwenden Sie den "
-"Schalter -n, um eine neue Karte zu erzeugen."
+msgid "Map <%s> does not exist in current mapset. Add flag -n to create a new map."
+msgstr "Karte <%s> existiert noch nicht im aktuellen Mapset. verwenden Sie den Schalter -n, um eine neue Karte zu erzeugen."
 #: ../vector/v.digit/c_face.c:183 ../vector/v.digit/c_face.c:241
 #, c-format
@@ -32177,12 +29469,8 @@
 msgstr "Kann Privilegien für die Tabelle nicht zuweisen:\n"
 #: ../vector/v.digit/c_face.c:312
-msgid ""
-"Cannot add database link to vector, link for given field probably already "
-"exists."
-msgstr ""
-"Kann Datenbankverknüpfung nicht zum Vektor hinzufügen. Vermutlich besteht "
-"schon eine Verknüpfung für das Feld."
+msgid "Cannot add database link to vector, link for given field probably already exists."
+msgstr "Kann Datenbankverknüpfung nicht zum Vektor hinzufügen. Vermutlich besteht schon eine Verknüpfung für das Feld."
 #: ../vector/v.digit/vertex.c:35
 msgid "Split line:"
@@ -32252,8 +29540,7 @@
 #: ../vector/v.in.dxf/main.c:89 ../vector/v.in.dwg/main.c:84
 msgid "Invert selection by layers (don't import layers in list)"
-msgstr ""
-"Invertiere die Selektion der Layer (importiere nicht die angegebenen Layer)."
+msgstr "Invertiere die Selektion der Layer (importiere nicht die angegebenen Layer)."
 #: ../vector/v.in.dxf/main.c:94
 msgid "Import all objects into one layer"
@@ -32326,9 +29613,7 @@
 #: ../vector/v.hull/main.c:291
 msgid "Create a 'flat' 2D hull even if the input is 3D points"
-msgstr ""
-"Erzeuge eine 'flache' 2D Hülle, selbst wenn die Eingabe aus 3D Punkten "
-"besteht."
+msgstr "Erzeuge eine 'flache' 2D Hülle, selbst wenn die Eingabe aus 3D Punkten besteht."
 #: ../vector/v.hull/main.c:314
 #, c-format
@@ -32337,9 +29622,7 @@
 #: ../vector/v.hull/main.c:318
 msgid "Convex hull calculation requires at least three points. Exiting."
-msgstr ""
-"Die Berechnung der konvexen Hülle erfordert mindestens drei Punkte. Beende "
-"mich."
+msgstr "Die Berechnung der konvexen Hülle erfordert mindestens drei Punkte. Beende mich."
 #: ../vector/v.hull/main.c:320
 #, c-format
@@ -32408,34 +29691,8 @@
 msgstr "Werkzeug"
 #: ../vector/v.edit/args.c:55
-msgid ""
-"create;Create new (empty) vector map;add;Add new features to existing vector "
-"map;delete;Delete selected features from vector map;move;Move selected "
-"features in vector map;vertexmove;Move vertex of selected vector lines;"
-"vertexdel;Remove vertex from selected vector lines;vertexadd;Add new vertex "
-"to selected vector lines;merge;Merge selected vector lines;break;Break/split "
-"vector lines;select;Select lines and print their ID's;catadd;Set new "
-"categories to selected vector features for defined layer;catdel;Delete "
-"categories from selected vector features for defined layer;copy;Copy "
-"selected features;snap;Snap vector features in given threshold;flip;Flip "
-"direction of selected vector lines;connect;Connect two lines;zbulk;Z bulk-"
-"labeling (automated assignment of z coordinate to vector lines);chtype;"
-"Change feature type (point<->centroid, line<->boundary)"
-msgstr ""
-"create;Erzeuge ein neue (leere) Vektorkarte;add;Fügt neue Objekte zu einer "
-"existierenden Vektorkarte hinzu;delete;Entfernt selektierte Objekte von "
-"einer Vektorkarte;move;Verschiebt selektierte Objekte in einer Vektorkarte;"
-"vertexmove;Verschiebt einen Vertex selektierter Vektorlinien;vertexdel;"
-"Entfernt einen Vertex aus selektierten Vektorlinien;vertexadd;Fügt einen "
-"neuen Vertex zu selektierten Vektorlinien hinzu;merge;Vereinigt selektierte "
-"Vektorlinien;break;Teilt Vektorlinien;select;Selektiert Linien und gibt ihre "
-"ID aus;catadd;Vergibt neue Kategorien für selektierte Vektorobjekte eines "
-"bestimmten Layers;catdel;Löscht Kategorien von selektierten Vektorobjekten "
-"eines bestimmten Layers;copy;Kopiert selektierte Feature;snap;Fange "
-"Vektorobjekt innerhalb des angegebenen Toleranz;flip;Drehe die Richtung "
-"selektierter Vektorlinien um;connect;Verbinde zwei Linien;zbulk;Z-Massen-"
-"Beschriftung (automatisierte Zuweisung der Z Koordinate zu Vektorlinien);"
-"chtype;Ändere den Typ des Features(Punkt<->Zentroid, Linie<->Grenze)"
+msgid "create;Create new (empty) vector map;add;Add new features to existing vector map;delete;Delete selected features from vector map;move;Move selected features in vector map;vertexmove;Move vertex of selected vector lines;vertexdel;Remove vertex from selected vector lines;vertexadd;Add new vertex to selected vector lines;merge;Merge selected vector lines;break;Break/split vector lines;select;Select lines and print their ID's;catadd;Set new categories to selected vector features for defined layer;catdel;Delete categories from selected vector features for defined layer;copy;Copy selected features;snap;Snap vector features in given threshold;flip;Flip direction of selected vector lines;connect;Connect two lines;zbulk;Z bulk-labeling (automated assignment of z coordinate to vector lines);chtype;Change feature type (point<->centroid, line<->boundary)"
+msgstr "create;Erzeuge ein neue (leere) Vektorkarte;add;Fügt neue Objekte zu einer existierenden Vektorkarte hinzu;delete;Entfernt selektierte Objekte von einer Vektorkarte;move;Verschiebt selektierte Objekte in einer Vektorkarte;vertexmove;Verschiebt einen Vertex selektierter Vektorlinien;vertexdel;Entfernt einen Vertex aus selektierten Vektorlinien;vertexadd;Fügt einen neuen Vertex zu selektierten Vektorlinien hinzu;merge;Vereinigt selektierte Vektorlinien;break;Teilt Vektorlinien;select;Selektiert Linien und gibt ihre ID aus;catadd;Vergibt neue Kategorien für selektierte Vektorobjekte eines bestimmten Layers;catdel;Löscht Kategorien von selektierten Vektorobjekten eines bestimmten Layers;copy;Kopiert selektierte Feature;snap;Fange Vektorobjekt innerhalb des angegebenen Toleranz;flip;Drehe die Richtung selektierter Vektorlinien um;connect;Verbinde zwei Linien;zbulk;Z-Massen-Beschriftung (automatisierte Zuweisung der Z Koordinate zu Vektorlinien);chtype;Ändere den Typ
 #: ../vector/v.edit/args.c:100
 msgid "ASCII file to be converted to binary vector map"
@@ -32447,8 +29704,7 @@
 #: ../vector/v.edit/args.c:112
 msgid "Difference in x,y direction for moving feature or vertex"
-msgstr ""
-"Differenz in x,y Richtung für das Verschieben eines Objektes oder Vertex."
+msgstr "Differenz in x,y Richtung für das Verschieben eines Objektes oder Vertex."
 #: ../vector/v.edit/args.c:119
 msgid "Threshold distance (coords,snap,query)"
@@ -32456,8 +29712,7 @@
 #: ../vector/v.edit/args.c:121
 msgid "'-1' for threshold based on the current resolution settings"
-msgstr ""
-"'-1' um den Schwellwert auf Basis der aktuellen Auflösung zu bestimmen."
+msgstr "'-1' um den Schwellwert auf Basis der aktuellen Auflösung zu bestimmen."
 #: ../vector/v.edit/args.c:137
 msgid "List of point coordinates"
@@ -32477,38 +29732,23 @@
 #: ../vector/v.edit/args.c:167
 msgid "For 'shorter' use negative threshold value, positive value for 'longer'"
-msgstr ""
-"Für 'Kürzere' verwenden Sie einen negativen Schwellwert und positive Werte "
-"für 'Längere'."
+msgstr "Für 'Kürzere' verwenden Sie einen negativen Schwellwert und positive Werte für 'Längere'."
 #: ../vector/v.edit/args.c:170
-msgid ""
-"length;Select only lines or boundaries shorter/longer than threshold "
-"distance;dangle;Select dangles shorter/longer than threshold distance"
-msgstr ""
-"length; Selektiere nur Linien oder Grenzen kürzer/länger als der "
-"Schwellwert; dangle; Selektiere Überstände (dangles) kürzer/länger als der "
-"Schwellwert"
+msgid "length;Select only lines or boundaries shorter/longer than threshold distance;dangle;Select dangles shorter/longer than threshold distance"
+msgstr "length; Selektiere nur Linien oder Grenzen kürzer/länger als der Schwellwert; dangle; Selektiere Überstände (dangles) kürzer/länger als der Schwellwert"
 #: ../vector/v.edit/args.c:178
 msgid "Name of background vector map(s)"
 msgstr "Name der Hintergrund-Vektorkarte(n)."
 #: ../vector/v.edit/args.c:185
-msgid ""
-"Snap added or modified features in the given threshold to the nearest "
-"existing feature"
-msgstr ""
-"Hinzugefügte oder veränderte Objekte, innerhalb der Toleranz, am nächsten "
-"Objekt fangen"
+msgid "Snap added or modified features in the given threshold to the nearest existing feature"
+msgstr "Hinzugefügte oder veränderte Objekte, innerhalb der Toleranz, am nächsten Objekt fangen"
 #: ../vector/v.edit/args.c:187
-msgid ""
-"no;Not apply snapping;node;Snap only to node;vertex;Allow snapping also to "
-"vertex"
-msgstr ""
-"no; Kein Fangen; node; Nur an Knoten Fangen; vertex; Erlaube Fangen auch an "
-"Vertices"
+msgid "no;Not apply snapping;node;Snap only to node;vertex;Allow snapping also to vertex"
+msgstr "no; Kein Fangen; node; Nur an Knoten Fangen; vertex; Erlaube Fangen auch an Vertices"
 #: ../vector/v.edit/args.c:195
 msgid "Starting value and step for z bulk-labeling"
@@ -32525,8 +29765,7 @@
 #: ../vector/v.edit/args.c:207
 msgid "Close added boundaries (using threshold distance)"
-msgstr ""
-"Schließe hinzugefügte Grenzlinien (unter Verwendung der Schwellwert Distanz)."
+msgstr "Schließe hinzugefügte Grenzlinien (unter Verwendung der Schwellwert Distanz)."
 #: ../vector/v.edit/args.c:211
 msgid "Do not expect header of input data"
@@ -32562,12 +29801,8 @@
 msgstr "Vektor, Editieren, Geometrie"
 #: ../vector/v.edit/main.c:57
-msgid ""
-"Edits a vector map, allows adding, deleting and modifying selected vector "
-"features."
-msgstr ""
-"Editiert eine Vektorkarte, ermöglicht das Hinzufügen, Löschen und Ändern "
-"ausgewählter Vektorobjekte."
+msgid "Edits a vector map, allows adding, deleting and modifying selected vector features."
+msgstr "Editiert eine Vektorkarte, ermöglicht das Hinzufügen, Löschen und Ändern ausgewählter Vektorobjekte."
 #: ../vector/v.edit/main.c:66
 #, c-format
@@ -32585,12 +29820,8 @@
 #: ../vector/v.edit/main.c:149
 #, c-format
-msgid ""
-"Unable to open vector map <%s> as the background map. It is given as vector "
-"map to be edited."
-msgstr ""
-"Kann Vektorkarte <%s> nicht als Hintergrundkarte öffnen, da sie als zu "
-"editierende Karte ausgewählte wurde."
+msgid "Unable to open vector map <%s> as the background map. It is given as vector map to be edited."
+msgstr "Kann Vektorkarte <%s> nicht als Hintergrundkarte öffnen, da sie als zu editierende Karte ausgewählte wurde."
 #: ../vector/v.edit/main.c:164
 #, c-format
@@ -32607,13 +29838,8 @@
 #: ../vector/v.edit/main.c:224
 #, c-format
-msgid ""
-"Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert "
-"the vector map to 3D using e.g. %s."
-msgstr ""
-"Die Vektorkarte <%s> ist nicht 3D. Das Werkzeug '%s' benötigt eine 3D-"
-"Vektorkarte. Bitte konvertieren Sie die Vektorkarte nach 3D z.B. mit Hilfe "
-"von %s."
+msgid "Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert the vector map to 3D using e.g. %s."
+msgstr "Die Vektorkarte <%s> ist nicht 3D. Das Werkzeug '%s' benötigt eine 3D-Vektorkarte. Bitte konvertieren Sie die Vektorkarte nach 3D z.B. mit Hilfe von %s."
 #: ../vector/v.edit/main.c:262
 #, c-format
@@ -32679,12 +29905,8 @@
 #: ../vector/v.edit/main.c:342
 #, c-format
-msgid ""
-"Multiple background maps were given. Selected features will be copied only "
-"from vector map <%s>."
-msgstr ""
-"Mehrere Hintergrundkarten wurden angegeben. Selektierte Objekte werden nur "
-"von der Vektorkarte <%s> kopiert."
+msgid "Multiple background maps were given. Selected features will be copied only from vector map <%s>."
+msgstr "Mehrere Hintergrundkarten wurden angegeben. Selektierte Objekte werden nur von der Vektorkarte <%s> kopiert."
 #: ../vector/v.edit/main.c:352
 #, c-format
@@ -32734,9 +29956,7 @@
 #: ../vector/v.in.ogr/main.c:131
 msgid "OGR layer name. If not given, all available layers are imported"
-msgstr ""
-"Name des OGR-Layers. Wenn nicht spezifiziert, werden alle verfügbaren Layer "
-"importiert."
+msgstr "Name des OGR-Layers. Wenn nicht spezifiziert, werden alle verfügbaren Layer importiert."
 #: ../vector/v.in.ogr/main.c:133
 msgid ""
@@ -32770,21 +29990,15 @@
 #: ../vector/v.in.ogr/main.c:159
 msgid "Smaller areas and islands are ignored. Should be greater than snap^2"
-msgstr ""
-"Kleinere Flächen und Inseln werden ignoriert. Sollte größer sein als snap^2."
+msgstr "Kleinere Flächen und Inseln werden ignoriert. Sollte größer sein als snap^2."
 #: ../vector/v.in.ogr/main.c:165
 msgid "Optionally change default input type"
 msgstr "Optionalerweise: Ändere den Standard Input-Typ."
 #: ../vector/v.in.ogr/main.c:167
-msgid ""
-"point;import area centroids as points;line;import area boundaries as lines;"
-"boundary;import lines as area boundaries;centroid;import points as centroids"
-msgstr ""
-"point;Importiere Zentroide als Punkte;line;Importiere Grenzen als Linien;"
-"boundary;Importiere Linien als Grenzen;centroid;Importiere Punkte als "
-"Zentroide"
+msgid "point;import area centroids as points;line;import area boundaries as lines;boundary;import lines as area boundaries;centroid;import points as centroids"
+msgstr "point;Importiere Zentroide als Punkte;line;Importiere Grenzen als Linien;boundary;Importiere Linien als Grenzen;centroid;Importiere Punkte als Zentroide"
 #: ../vector/v.in.ogr/main.c:178 ../vector/v.overlay/main.c:125
 msgid "Snapping threshold for boundaries"
@@ -32795,12 +30009,8 @@
 msgstr "'-1' für kein Fangen"
 #: ../vector/v.in.ogr/main.c:194
-msgid ""
-"List of column names to be used instead of original names, first is used for "
-"category column"
-msgstr ""
-"Zeige sie Spaltennamen die anstatt der Originalnamen verwendet werden. Der "
-"Erste entspricht der Kategoriespalte."
+msgid "List of column names to be used instead of original names, first is used for category column"
+msgstr "Zeige sie Spaltennamen die anstatt der Originalnamen verwendet werden. Der Erste entspricht der Kategoriespalte."
 #: ../vector/v.in.ogr/main.c:201
 msgid "List available layers in data source and exit"
@@ -32812,9 +30022,7 @@
 #: ../vector/v.in.ogr/main.c:224
 msgid "Override dataset projection (use location's projection)"
-msgstr ""
-"Übersteuere die Projektion des Datensatzes (verwende Projektion der "
-"Location)."
+msgstr "Übersteuere die Projektion des Datensatzes (verwende Projektion der Location)."
 #: ../vector/v.in.ogr/main.c:229
 msgid "Limit import to the current region"
@@ -32850,29 +30058,19 @@
 #: ../vector/v.in.ogr/main.c:383
 msgid "Select either the current region flag or the spatial option, not both"
-msgstr ""
-"Wählen Sie entweder den Schalter \"aktuelle Region\" oder die Option "
-"'spatial' aber nicht beide."
+msgstr "Wählen Sie entweder den Schalter \"aktuelle Region\" oder die Option 'spatial' aber nicht beide."
 #: ../vector/v.in.ogr/main.c:411
 msgid "4 parameters required for 'spatial' parameter"
 msgstr "4 Werte sind für den Parameter 'spatial' nötig."
 #: ../vector/v.in.ogr/main.c:488
-msgid ""
-"Unable to convert input map projection to GRASS format; cannot create new "
-"location"
-msgstr ""
-"Kann die Projektion der Eingabekarte nicht in das GRASS-Format konvertieren; "
-"kann daher keine neue Location erstellen."
+msgid "Unable to convert input map projection to GRASS format; cannot create new location"
+msgstr "Kann die Projektion der Eingabekarte nicht in das GRASS-Format konvertieren; kann daher keine neue Location erstellen."
 #: ../vector/v.in.ogr/main.c:500
-msgid ""
-"Unable to convert input map projection information to GRASS format for "
-"checking"
-msgstr ""
-"Kann die Projektionsinformationen der Eingabekarte nicht ins GRASS-Format "
-"konvertieren, zwecks Überprüfung."
+msgid "Unable to convert input map projection information to GRASS format for checking"
+msgstr "Kann die Projektionsinformationen der Eingabekarte nicht ins GRASS-Format konvertieren, zwecks Überprüfung."
 #: ../vector/v.in.ogr/main.c:530
 msgid "GRASS LOCATION PROJ_INFO is:\n"
@@ -32885,16 +30083,11 @@
 "You can use the -o flag to %s to override this projection check.\n"
 msgstr ""
 "\n"
-"Sie können den Schalter '-o' verwenden, um den Projektions-Check %s zu "
-"übersteuern.\n"
+"Sie können den Schalter '-o' verwenden, um den Projektions-Check %s zu übersteuern.\n"
 #: ../vector/v.in.ogr/main.c:593
-msgid ""
-"Consider generating a new location with 'location' parameter from input data "
-"set.\n"
-msgstr ""
-"Bedenken Sie, dass die Erzeugung einer neuen Location auf Grundlage der "
-"Eingabedaten mit dem Parameter 'location=' geeigneter sein könnte.\n"
+msgid "Consider generating a new location with 'location' parameter from input data set.\n"
+msgstr "Bedenken Sie, dass die Erzeugung einer neuen Location auf Grundlage der Eingabedaten mit dem Parameter 'location=' geeigneter sein könnte.\n"
 #: ../vector/v.in.ogr/main.c:616
 #, c-format
@@ -32914,25 +30107,17 @@
 #: ../vector/v.in.ogr/main.c:732
 #, c-format
 msgid "Writing column <%s> with fixed length %d chars (may be truncated)"
-msgstr ""
-"Schreibe Spalte <%s> mit einer festen Länge von %d Zeichen (Es könnte etwas "
-"abgeschnitten worden sein). "
+msgstr "Schreibe Spalte <%s> mit einer festen Länge von %d Zeichen (Es könnte etwas abgeschnitten worden sein). "
 #: ../vector/v.in.ogr/main.c:755
 #, c-format
-msgid ""
-"Width for column %s set to 255 (was not specified by OGR), some strings may "
-"be truncated!"
-msgstr ""
-"Breite für die Spalte %s wird auf 255 gesetzt (wurde nicht von OGR "
-"bestimmt). Einige Texte können abgeschnitten worden sein!"
+msgid "Width for column %s set to 255 (was not specified by OGR), some strings may be truncated!"
+msgstr "Breite für die Spalte %s wird auf 255 gesetzt (wurde nicht von OGR bestimmt). Einige Texte können abgeschnitten worden sein!"
 #: ../vector/v.in.ogr/main.c:767
 #, c-format
 msgid "Writing column %s with fixed length %d chars (may be truncated)"
-msgstr ""
-"Schreibe Spalte %s mit einer festen Länge von %d Zeichen (Es könnte etwas "
+msgstr "Schreibe Spalte %s mit einer festen Länge von %d Zeichen (Es könnte etwas abgeschnitten worden sein). "
 #: ../vector/v.in.ogr/main.c:771
 #, c-format
@@ -33020,15 +30205,8 @@
 #: ../vector/v.in.ogr/main.c:1149
 #, c-format
-msgid ""
-"%d areas represent more (overlapping) features, because polygons overlap in "
-"input layer(s). Such areas are linked to more than 1 row in attribute table. "
-"The number of features for those areas is stored as category in layer %d"
-msgstr ""
-"%d Flächen repräsentieren mehrere Objekte, da sich die Polygone in dem "
-"Eingabedatensatz überlappen. Solche Flächen sind mit mehr als einer Zeile in "
-"der Attributtabelle verlinkt. Die Anzahl der Objekte für diese Flächen ist "
-"als Kategoriewert im Layer %d abgelegt."
+msgid "%d areas represent more (overlapping) features, because polygons overlap in input layer(s). Such areas are linked to more than 1 row in attribute table. The number of features for those areas is stored as category in layer %d"
+msgstr "%d Flächen repräsentieren mehrere Objekte, da sich die Polygone in dem Eingabedatensatz überlappen. Solche Flächen sind mit mehr als einer Zeile in der Attributtabelle verlinkt. Die Anzahl der Objekte für diese Flächen ist als Kategoriewert im Layer %d abgelegt."
 #: ../vector/v.in.ogr/main.c:1159
 #, c-format
@@ -33077,16 +30255,11 @@
 #: ../vector/v.in.ogr/main.c:1226
 #, c-format
 msgid "Try to import again, snapping with at least %g: 'snap=%g'"
-msgstr ""
-"Versuchen Sie den Import nochmals, Fangtoleranz mindestens %g: 'snap=%g'"
+msgstr "Versuchen Sie den Import nochmals, Fangtoleranz mindestens %g: 'snap=%g'"
 #: ../vector/v.in.ogr/main.c:1267
-msgid ""
-"Input data contains 3D features. Created vector is 2D only, use -z flag to "
-"import 3D vector"
-msgstr ""
-"Eingabekarte enthält 3D-Objekte. Erstellte Vektorkarte ist allerdings nur "
-"2D, verwenden Sie den Schalter '-z', um 3D-Vektordaten zu importieren."
+msgid "Input data contains 3D features. Created vector is 2D only, use -z flag to import 3D vector"
+msgstr "Eingabekarte enthält 3D-Objekte. Erstellte Vektorkarte ist allerdings nur 2D, verwenden Sie den Schalter '-z', um 3D-Vektordaten zu importieren."
 #: ../vector/v.in.ogr/geom.c:195
 msgid "Cannot read part of geometry"
@@ -33129,15 +30302,11 @@
 #: ../vector/v.external/main.c:53
 msgid "Creates a new vector as a read-only link to OGR layer."
-msgstr ""
-"Erzeugt eine neue Vektorkarte als einen ausschließlich lesbaren Link zu "
-"einem OGR-Layer."
+msgstr "Erzeugt eine neue Vektorkarte als einen ausschließlich lesbaren Link zu einem OGR-Layer."
 #: ../vector/v.external/main.c:66
 msgid "Output vector. If not given, available layers are printed only."
-msgstr ""
-"Ausgabevektor. Wenn nicht benannt, werden alle verfügbaren Layer "
-"lediglichangezeigt."
+msgstr "Ausgabevektor. Wenn nicht benannt, werden alle verfügbaren Layer lediglichangezeigt."
 #: ../vector/v.external/main.c:74
 msgid ""
@@ -33145,15 +30314,13 @@
 "\t\tESRI Shapefile: shapefile name\n"
 "\t\tMapInfo File: mapinfo file name"
 msgstr ""
-"OGR Layer-Name. Falls nicht angegeben, werden alle vorhandenen Layernamen "
-"lediglich angezeigt. Beispiele:\n"
+"OGR Layer-Name. Falls nicht angegeben, werden alle vorhandenen Layernamen lediglich angezeigt. Beispiele:\n"
 "\t\tESRI Shapefile: Name des Shapefiles\n"
 "\t\tMapInfo File: Name der MapInfo-Datei"
 #: ../vector/v.external/main.c:95
-#, fuzzy
 msgid "Name of OGR data source not specified"
-msgstr "Name der Eingabe-Qulle nicht angegeben."
+msgstr "Name der OGR-Quelle nicht angegeben"
 #: ../vector/v.external/main.c:98
 msgid "Output vector name was not specified"
@@ -33164,9 +30331,8 @@
 msgstr "Kann die Datenquelle nicht öffnen."
 #: ../vector/v.external/main.c:179
-#, fuzzy
 msgid "List of supported formats:"
-msgstr "Zeige unterstützte Dateiformate."
+msgstr "Liste der unterstützten Dateiformate:"
 #: ../vector/v.extrude/main.c:69
 msgid "vector, geometry, 3D"
@@ -33238,11 +30404,8 @@
 msgstr "Vektor, Volumen, Konvertierung"
 #: ../vector/v.to.rast3/main.c:46
-msgid ""
-"Converts a binary GRASS vector map (only points) layer into a 3D GRASS "
-"raster map layer."
-msgstr ""
-"Konvertiert eine binäre Vektorkarte (nur Punkte) in eine 3D-Rasterkarte. "
+msgid "Converts a binary GRASS vector map (only points) layer into a 3D GRASS raster map layer."
+msgstr "Konvertiert eine binäre Vektorkarte (nur Punkte) in eine 3D-Rasterkarte. "
 #: ../vector/v.to.rast3/main.c:59
 msgid "Column name (type must be numeric)"
@@ -33265,22 +30428,12 @@
 msgstr "Vektor, Netzwerk, Isolinien"
 #: ../vector/v.net.iso/main.c:75
-msgid ""
-"Splits net to bands between cost isolines (direction from centre). Centre "
-"node must be opened (costs >= 0). Costs of centre node are used in "
-"calculation."
-msgstr ""
-"Teilt das Netz in Bänder zwischen Isokostenlinien (Richtung vom Zentrum). "
-"Zentraler Knoten muss geöffnet sein (Kosten >= 0). Kosten des zentralen "
-"Knotens gehen in die Berechnung ein."
+msgid "Splits net to bands between cost isolines (direction from centre). Centre node must be opened (costs >= 0). Costs of centre node are used in calculation."
+msgstr "Teilt das Netz in Bänder zwischen Isokostenlinien (Richtung vom Zentrum). Zentraler Knoten muss geöffnet sein (Kosten >= 0). Kosten des zentralen Knotens gehen in die Berechnung ein."
 #: ../vector/v.net.iso/main.c:113
-msgid ""
-"Categories of centres (points on nodes) to which net will be allocated. "
-"Layer for this categories is given by nlayer option."
-msgstr ""
-"Kategorie der Zentren (Punkte auf Knoten), denen das Netz zugeteilt wird. "
-"Layer für diese Kategorien wird mit der Option nlayer angegeben. "
+msgid "Categories of centres (points on nodes) to which net will be allocated. Layer for this categories is given by nlayer option."
+msgstr "Kategorie der Zentren (Punkte auf Knoten), denen das Netz zugeteilt wird. Layer für diese Kategorien wird mit der Option nlayer angegeben. "
 #: ../vector/v.net.iso/main.c:122
 msgid "Costs for isolines"
@@ -33303,8 +30456,7 @@
 #: ../vector/v.net.iso/main.c:171
 msgid "Not enough costs, everything reachable falls to first band"
-msgstr ""
-"Kosten sind nicht hoch genug. Alles in Reichweit fällt in das erste Band."
+msgstr "Kosten sind nicht hoch genug. Alles in Reichweit fällt in das erste Band."
 #: ../vector/v.net.iso/main.c:205
 msgid "Centre at closed node (costs = -1) ignored"
@@ -33348,8 +30500,7 @@
 "Unable to get point on line: cat = %d offset = %f (line length = %.15g)\n"
 "%s"
 msgstr ""
-"Kann den Punkt auf der Linie nicht bekommen: cat = %d offset = %f (Länge der "
-"Linie = %.15g)\n"
+"Kann den Punkt auf der Linie nicht bekommen: cat = %d offset = %f (Länge der Linie = %.15g)\n"
 "%s"
 #: ../vector/v.segment/main.c:194
@@ -33362,8 +30513,7 @@
 "Unable to make line segment: cat = %d : %f - %f (line length = %.15g)\n"
 "%s"
 msgstr ""
-"Kann das Liniensegment nicht machen: cat = %d : %f - %f (Länge der Linie = "
-"%.15g)\n"
+"Kann das Liniensegment nicht machen: cat = %d : %f - %f (Länge der Linie = %.15g)\n"
 "%s"
 #: ../vector/v.segment/main.c:227
@@ -33392,9 +30542,7 @@
 #: ../vector/v.drape/main.c:168
 msgid "Converts vector map to 3D by sampling of elevation raster map."
-msgstr ""
-"Konvertiert eine Vektorkarte nach 3D durch Abtasten einer Karte mit "
-"Höheninformationen."
+msgstr "Konvertiert eine Vektorkarte nach 3D durch Abtasten einer Karte mit Höheninformationen."
 #: ../vector/v.drape/main.c:180
 msgid "Elevation raster map for height extraction"
@@ -33418,9 +30566,7 @@
 #: ../vector/v.drape/main.c:213
 msgid "Will set Z to this value, if value from raster map can not be read"
-msgstr ""
-"Werde Z auf diesen Wert setzen, wenn der Wert der Rasterkarte nicht gelesen "
-"werden kann."
+msgstr "Werde Z auf diesen Wert setzen, wenn der Wert der Rasterkarte nicht gelesen werden kann."
 #: ../vector/v.drape/main.c:220 ../vector/v.extract/main.c:204
 msgid "Layer 0 not supported"
@@ -33432,16 +30578,11 @@
 #: ../vector/v.drape/main.c:407 ../vector/v.drape/main.c:417
 msgid "Due to error attribute data to new map are not transferred"
-msgstr ""
-"Auf Grund eines Fehlers werden die Attributdaten nicht in die neue Karte "
-"übetragen."
+msgstr "Auf Grund eines Fehlers werden die Attributdaten nicht in die neue Karte übetragen."
 #: ../vector/v.drape/main.c:425
-msgid ""
-"No features drapped. Check Your computational region and input raster map."
-msgstr ""
-"Keine Objekte wurden drapiert. Überprüfen Sie die aktuelle Region und die "
-"Eingabe-Rasterkarte."
+msgid "No features drapped. Check Your computational region and input raster map."
+msgstr "Keine Objekte wurden drapiert. Überprüfen Sie die aktuelle Region und die Eingabe-Rasterkarte."
 #: ../vector/v.class/main.c:47
 msgid "Classifies attribute data, e.g. for thematic mapping"
@@ -33456,14 +30597,8 @@
 msgstr "Gebe nur die Klassengrenzen aus (ohne Min und Max)"
 #: ../vector/v.class/main.c:166
-msgid ""
-"The discontinuities algorithm indicates that some class breaks are not "
-"statistically significant at alpha=0.05. You are advised to reduce the "
-"number of classes."
-msgstr ""
-"Der Diskontinuitätsalgorithmus weist daraufhin, dass einige Klassengrenzen "
-"nicht statistisch signifikant (alpha = 0.05) sind. Es wird Ihnen geraten, "
-"die Anzahl der Klassen zu reduzieren."
+msgid "The discontinuities algorithm indicates that some class breaks are not statistically significant at alpha=0.05. You are advised to reduce the number of classes."
+msgstr "Der Diskontinuitätsalgorithmus weist daraufhin, dass einige Klassengrenzen nicht statistisch signifikant (alpha = 0.05) sind. Es wird Ihnen geraten, die Anzahl der Klassen zu reduzieren."
 #: ../vector/v.class/main.c:193
 #, c-format
@@ -33578,31 +30713,15 @@
 #: ../vector/v.overlay/main.c:100
 msgid "Operator defines features written to output vector map"
-msgstr ""
-"Operator bestimmt, welche Objekte in die Ausgabe-Vektorkarte geschrieben "
-"werden."
+msgstr "Operator bestimmt, welche Objekte in die Ausgabe-Vektorkarte geschrieben werden."
 #: ../vector/v.overlay/main.c:103
-msgid ""
-"Feature is written to output if the result of operation 'ainput operator "
-"binput' is true. Input feature is considered to be true, if category of "
-"given layer is defined."
-msgstr ""
-"Ein Objekt wird in die Ausgabekarte geschrieben, wenn das Ergebnis der "
-"Operation 'ainput operator binput' wahr ist. Ein Eingabe-Objekt wird als "
-"wahr erachtet, wenn die Kategorie des gegebenen Layers definiert ist."
+msgid "Feature is written to output if the result of operation 'ainput operator binput' is true. Input feature is considered to be true, if category of given layer is defined."
+msgstr "Ein Objekt wird in die Ausgabekarte geschrieben, wenn das Ergebnis der Operation 'ainput operator binput' wahr ist. Ein Eingabe-Objekt wird als wahr erachtet, wenn die Kategorie des gegebenen Layers definiert ist."
 #: ../vector/v.overlay/main.c:108
-msgid ""
-"and;also known as 'intersection' in GIS;or;also known as 'union' in GIS "
-"(only for atype=area);not;features from ainput not overlayed by features "
-"from binput;xor;features from either ainput or binput but not those from "
-"ainput overlayed by binput (only for atype=area)"
-msgstr ""
-"and;auch als 'intersection' im GIS bekannt;or;auch als 'union' im GIS "
-"bekannt (nur für atype=area);not;Objekt von ainput nicht überlagert von "
-"Objekten von binput;xor;Objekt von ainput oder binput, aber nicht solche von "
-"ainput die von binput überlagert werden(nur für atype=area)"
+msgid "and;also known as 'intersection' in GIS;or;also known as 'union' in GIS (only for atype=area);not;features from ainput not overlayed by features from binput;xor;features from either ainput or binput but not those from ainput overlayed by binput (only for atype=area)"
+msgstr "and;auch als 'intersection' im GIS bekannt;or;auch als 'union' im GIS bekannt (nur für atype=area);not;Objekt von ainput nicht überlagert von Objekten von binput;xor;Objekt von ainput oder binput, aber nicht solche von ainput die von binput überlagert werden(nur für atype=area)"
 #: ../vector/v.overlay/main.c:119
 msgid "Output layer for new category, ainput and binput"
@@ -33655,12 +30774,8 @@
 msgstr "Selektiere Linien..."
 #: ../vector/v.distance/main.c:116
-msgid ""
-"Finds the nearest element in vector map 'to' for elements in vector map "
-"'from'."
-msgstr ""
-"Findet das nächstgelegene Element der Vektorkarte 'to' für Elemente in der "
-"Vektorkarte 'from'. "
+msgid "Finds the nearest element in vector map 'to' for elements in vector map 'from'."
+msgstr "Findet das nächstgelegene Element der Vektorkarte 'to' für Elemente in der Vektorkarte 'from'. "
 #: ../vector/v.distance/main.c:120
 msgid "Name of existing vector map (from)"
@@ -33688,9 +30803,7 @@
 #: ../vector/v.distance/main.c:155
 msgid "Name for output vector map containing lines connecting nearest elements"
-msgstr ""
-"Ausgabe-Vektorkarte mit Verbindungslinien zwischen den nächstgelgenen "
-"Elementen."
+msgstr "Ausgabe-Vektorkarte mit Verbindungslinien zwischen den nächstgelgenen Elementen."
 #: ../vector/v.distance/main.c:163
 msgid "Maximum distance or -1 for no limit"
@@ -33702,33 +30815,15 @@
 #: ../vector/v.distance/main.c:179
 msgid "Values describing the relation between two nearest features"
-msgstr ""
-"Werte, die die Verbindung zwischen zwei nächstgelegenen Objekte beschreiben"
+msgstr "Werte, die die Verbindung zwischen zwei nächstgelegenen Objekte beschreiben"
 #: ../vector/v.distance/main.c:181
-msgid ""
-"cat;category of the nearest feature;dist;minimum distance to nearest feature;"
-"to_x;x coordinate of the nearest point on the 'to' feature;to_y;y coordinate "
-"of the nearest point on the 'to' feature;to_along;distance to the nearest "
-"point on the 'to' feature along that linear feature;to_angle;angle along the "
-"nearest linear feature in the 'to' map, measured CCW from the +x axis, in "
-"radians, between -Pi and Pi inclusive;to_attr;attribute of nearest feature "
-"given by to_column option"
-msgstr ""
-"cat;Kategorie des nächsten Objektes;dist;Minimumdistanz zum nächsten Objekt;"
-"to_x;X Koordinate des nächsten Punkts des 'to'-Objektes;to_y;Y Koordinate "
-"des nächsten Punktes des 'to'-Objektes;to_along;Distanz zum nächsten Punkt "
-"des 'to'-Objektes entlang des linearen Objektes;to_angle;Winkel entlang des "
-"nächsten linearen Objektes der 'to'-Karte, gemessen gegen den Uhrzeigersinn "
-"von der positiven X-Achse im Bogenmaß (zwischen -Pi und Pi);to_attr;Attribut "
-"des nächsten Objektes gegeben durch die Option to_column"
+msgid "cat;category of the nearest feature;dist;minimum distance to nearest feature;to_x;x coordinate of the nearest point on the 'to' feature;to_y;y coordinate of the nearest point on the 'to' feature;to_along;distance to the nearest point on the 'to' feature along that linear feature;to_angle;angle along the nearest linear feature in the 'to' map, measured CCW from the +x axis, in radians, between -Pi and Pi inclusive;to_attr;attribute of nearest feature given by to_column option"
+msgstr "cat;Kategorie des nächsten Objektes;dist;Minimumdistanz zum nächsten Objekt;to_x;X Koordinate des nächsten Punkts des 'to'-Objektes;to_y;Y Koordinate des nächsten Punktes des 'to'-Objektes;to_along;Distanz zum nächsten Punkt des 'to'-Objektes entlang des linearen Objektes;to_angle;Winkel entlang des nächsten linearen Objektes der 'to'-Karte, gemessen gegen den Uhrzeigersinn von der positiven X-Achse im Bogenmaß (zwischen -Pi und Pi);to_attr;Attribut des nächsten Objektes gegeben durch die Option to_column"
 #: ../vector/v.distance/main.c:202
-msgid ""
-"Column name(s) where values specified by 'upload' option will be uploaded"
-msgstr ""
-"Name(n) der Spalte(n) in denen, durch die 'upload'-Option bestimmte, Werte "
-"gespeichert werden."
+msgid "Column name(s) where values specified by 'upload' option will be uploaded"
+msgstr "Name(n) der Spalte(n) in denen, durch die 'upload'-Option bestimmte, Werte gespeichert werden."
 #: ../vector/v.distance/main.c:203
 msgid "From_map"
@@ -33736,39 +30831,27 @@
 #: ../vector/v.distance/main.c:208
 msgid "Column name of nearest feature (used with upload=to_attr)"
-msgstr ""
-"Spaltenname der nächstgelegenen Objekte (verwendet mit upload=to_attr)."
+msgstr "Spaltenname der nächstgelegenen Objekte (verwendet mit upload=to_attr)."
 #: ../vector/v.distance/main.c:214
-#, fuzzy
 msgid "Name of table created when the 'distance to all' flag is used"
-msgstr ""
-"Name der auszugebenden Tabelle, erzeugt wenn der Schalter 'Distanz zu Allen' "
-"gesetzt wurde."
+msgstr "Name der Tabelle, erzeugt wenn der Schalter 'Distanz zu Allen' gesetzt wurde."
 #: ../vector/v.distance/main.c:219
 msgid "Print output to stdout, don't update attribute table"
-msgstr ""
-"Gebe die Ausgabe auf stdout aus und verändere die Attributtabelle nicht."
+msgstr "Gebe die Ausgabe auf stdout aus und verändere die Attributtabelle nicht."
 #: ../vector/v.distance/main.c:221
 msgid "First column is always category of 'from' feature called from_cat"
-msgstr ""
-"Die erste Spalte ist immer die Kategorie der 'from'-Objekte und 'from_cat' "
-"benannt."
+msgstr "Die erste Spalte ist immer die Kategorie der 'from'-Objekte und 'from_cat' benannt."
 #: ../vector/v.distance/main.c:226
 msgid "Calculate distances to all features within the threshold"
 msgstr "Berechne Distanzen zu allen Objekten innerhalb des Schwellwertes."
 #: ../vector/v.distance/main.c:228
-msgid ""
-"Output is written to stdout but may be uploaded to a new table created by "
-"this module; multiple 'upload' options may be used."
-msgstr ""
-"Die Ausgabe wird nach stdout geschrieben und kann auch in eine neue Tabelle "
-"geschrieben werden, die von diesem Modul erzeugt wird. Es können mehrere "
-"'upload' Optionen verwendet werden."
+msgid "Output is written to stdout but may be uploaded to a new table created by this module; multiple 'upload' options may be used."
+msgstr "Die Ausgabe wird nach stdout geschrieben und kann auch in eine neue Tabelle geschrieben werden, die von diesem Modul erzeugt wird. Es können mehrere 'upload' Optionen verwendet werden."
 #: ../vector/v.distance/main.c:280
 msgid "to_column option missing"
@@ -33805,9 +30888,7 @@
 #: ../vector/v.distance/main.c:872
 msgid "DATETIME type not yet supported, no attributes will be uploaded"
-msgstr ""
-"Datentyp DATETIME wird noch nicht unterstützt. Es werden keine Attribute "
-"geschrieben."
+msgstr "Datentyp DATETIME wird noch nicht unterstützt. Es werden keine Attribute geschrieben."
 #: ../vector/v.distance/main.c:1123
 #, c-format
@@ -33847,8 +30928,7 @@
 #: ../vector/v.distance/main.c:1146
 #, c-format
 msgid "%d categories read from the map exist in the table"
-msgstr ""
-"%d aus der Karte gelesene Kategorien existieren bereits in der Tabelle."
+msgstr "%d aus der Karte gelesene Kategorien existieren bereits in der Tabelle."
 #: ../vector/v.distance/main.c:1149
 #, c-format
@@ -33872,12 +30952,8 @@
 msgstr "Seite"
 #: ../vector/v.parallel2/main.c:85
-msgid ""
-"left;Parallel line is on the left;right;Parallel line is on the right;both;"
-"Parallel lines on both sides"
-msgstr ""
-"left;Parallele Linie ist links;right;Parallele Linie ist rechts;both;"
-"Parallele Linien auf beiden Seiten"
+msgid "left;Parallel line is on the left;right;Parallel line is on the right;both;Parallel lines on both sides"
+msgstr "left;Parallele Linie ist links;right;Parallele Linie ist rechts;both;Parallele Linien auf beiden Seiten"
 #: ../vector/v.parallel2/main.c:95
 msgid "Tolerance of arc polylines in map units"
@@ -33889,7 +30965,7 @@
 #: ../vector/v.parallel2/main.c:103
 msgid "Create buffer-like parallel lines"
-msgstr "Erzeuge Bufferähnliche parallele Linien."
+msgstr "Erzeuge Pufferähnliche parallele Linien."
 #: ../vector/v.delaunay2/main.c:141
 msgid "no points to triangulate"
@@ -33928,37 +31004,23 @@
 #: ../vector/v.build/main.c:42
 msgid "Name for vector map where erroneous vector features are written to"
-msgstr ""
-"Name der Vektorkarte, in die fehlerhafte Vektor-Objekte geschrieben werden "
-"sollen."
+msgstr "Name der Vektorkarte, in die fehlerhafte Vektor-Objekte geschrieben werden sollen."
 #: ../vector/v.build/main.c:53
 msgid "Build topology or dump topology or spatial index to stdout"
-msgstr ""
-"Erzeuge Topologie oder schreibe die Topologie oder den räumlichen Index nach "
-"stdout."
+msgstr "Erzeuge Topologie oder schreibe die Topologie oder den räumlichen Index nach stdout."
 #: ../vector/v.build/main.c:55
-msgid ""
-"build;build topology;dump;write topology to stdout;sdump;write spatial index "
-"to stdout;cdump;write category index to stdout"
-msgstr ""
-"build;Erzeuge Topologie;dump;Schreibe Topologie nach stdout;sdump;Schreibe "
-"den räumlichen Index nach stdout;cdump;Schreibe den Kategorie-Index nach "
-"stdout"
+msgid "build;build topology;dump;write topology to stdout;sdump;write spatial index to stdout;cdump;write category index to stdout"
+msgstr "build;Erzeuge Topologie;dump;Schreibe Topologie nach stdout;sdump;Schreibe den räumlichen Index nach stdout;cdump;Schreibe den Kategorie-Index nach stdout"
 #: ../vector/v.out.ogr/main.c:98
 msgid "Converts GRASS vector map to one of the supported OGR vector formats."
-msgstr ""
-"Konvertiert eine GRASS Vektorkarte in ein OGR unterstütztes Vektorformat."
+msgstr "Konvertiert eine GRASS Vektorkarte in ein OGR unterstütztes Vektorformat."
 #: ../vector/v.out.ogr/main.c:106
-msgid ""
-"Feature type(s). Combinations not supported by all output formats. Default: "
-"first type found in input."
-msgstr ""
-"Objekt-Typ(en): Kombinationen der Typen wird nicht von allen Formaten "
-"unterstützt. Standard: der erste in der Eingabe gefundene Typ."
+msgid "Feature type(s). Combinations not supported by all output formats. Default: first type found in input."
+msgstr "Objekt-Typ(en): Kombinationen der Typen wird nicht von allen Formaten unterstützt. Standard: der erste in der Eingabe gefundene Typ."
 #: ../vector/v.out.ogr/main.c:114
 msgid "OGR output datasource name"
@@ -33966,13 +31028,11 @@
 #: ../vector/v.out.ogr/main.c:116
 msgid "For example: ESRI Shapefile: filename or directory for storage"
-msgstr ""
-"Zum Beispiel: ESRI Shapefile: Dateiname oder Verzeichnis für die Speicherung."
+msgstr "Zum Beispiel: ESRI Shapefile: Dateiname oder Verzeichnis für die Speicherung."
 #: ../vector/v.out.ogr/main.c:123
 msgid "OGR layer name. If not specified, input name is used."
-msgstr ""
-"Name des OGR-Layers. Wenn nicht spezifiziert, wird der Eingabename verwendet."
+msgstr "Name des OGR-Layers. Wenn nicht spezifiziert, wird der Eingabename verwendet."
 #: ../vector/v.out.ogr/main.c:124
 msgid "For example: ESRI Shapefile: shapefile name"
@@ -33989,8 +31049,7 @@
 #: ../vector/v.out.ogr/main.c:147
 msgid "OGR dataset creation option (format specific, NAME=VALUE)"
-msgstr ""
-"Optionen zum Erzeugen des OGR-Datensatzes (formatspezifisch, NAME=WERT)."
+msgstr "Optionen zum Erzeugen des OGR-Datensatzes (formatspezifisch, NAME=WERT)."
 #: ../vector/v.out.ogr/main.c:157
 msgid "OGR layer creation option (format specific, NAME=VALUE)"
@@ -34005,22 +31064,16 @@
 msgstr "Überspringe den Export der GRASS-Kategorie-ID ('cat')-Spalte"
 #: ../vector/v.out.ogr/main.c:171
-msgid ""
-"Export features with category (labeled) only. Otherwise all features are "
-"exported"
-msgstr ""
-"Exportiert Vektorobjekte nur mit Kategoriewerten (Labeln). Ansonsten werden "
-"alle Objekte exportiert."
+msgid "Export features with category (labeled) only. Otherwise all features are exported"
+msgstr "Exportiert Vektorobjekte nur mit Kategoriewerten (Labeln). Ansonsten werden alle Objekte exportiert."
 #: ../vector/v.out.ogr/main.c:176
 msgid "Use ESRI-style .prj file format (applies to Shapefile output only)"
-msgstr ""
-"Verwende .prj-Dateiformat im ESRI-Stil (nur bei Ausgabe von Shapefiles)."
+msgstr "Verwende .prj-Dateiformat im ESRI-Stil (nur bei Ausgabe von Shapefiles)."
 #: ../vector/v.out.ogr/main.c:181
 msgid "Create 3D output if input is 3D (applies to Shapefile output only)"
-msgstr ""
-"Erzeuge 3D Ausgabe wenn Eingabe 3D ist (nur bei Ausgabe von Shapefiles)"
+msgstr "Erzeuge 3D Ausgabe wenn Eingabe 3D ist (nur bei Ausgabe von Shapefiles)"
 #: ../vector/v.out.ogr/main.c:186
 msgid "Export lines as polygons"
@@ -34043,137 +31096,80 @@
 msgstr "Die Kombination von Typen wird nicht von allen Formaten unterstützt."
 #: ../vector/v.out.ogr/main.c:326
-msgid ""
-"The map contains islands. To preserve them in the output map, use the -c flag"
-msgstr ""
-"Die Karte enthält Inseln. Verwenden Sie den Schalter -c, um Inseln in der "
-"Ausgabe-Karte zu erhalten."
+msgid "The map contains islands. To preserve them in the output map, use the -c flag"
+msgstr "Die Karte enthält Inseln. Verwenden Sie den Schalter -c, um Inseln in der Ausgabe-Karte zu erhalten."
 #: ../vector/v.out.ogr/main.c:331
 #, c-format
-msgid ""
-"%d point(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr ""
-"%d Punkt(e) gefunden, die allerdings nicht zum Export angegeben wurden. "
-"Überprüfen Sie bitte den 'type'-Parameter."
+msgid "%d point(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d Punkt(e) gefunden, die allerdings nicht zum Export angegeben wurden. Überprüfen Sie bitte den 'type'-Parameter."
 #: ../vector/v.out.ogr/main.c:336
 #, c-format
-msgid ""
-"%d line(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr ""
-"%d Linie(n) gefunden, die allerdings nicht zum Export angegeben wurden. "
+msgid "%d line(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d Linie(n) gefunden, die allerdings nicht zum Export angegeben wurden. Überprüfen Sie bitte den 'type'-Parameter."
 #: ../vector/v.out.ogr/main.c:342
 #, c-format
-msgid ""
-"%d boundary(ies) found, but not requested to be exported. Verify 'type' "
-"parameter."
-msgstr ""
-"%d Grenzlinie(n) gefunden, die allerdings nicht zum Export angegeben wurden. "
+msgid "%d boundary(ies) found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d Grenzlinie(n) gefunden, die allerdings nicht zum Export angegeben wurden. Überprüfen Sie bitte den 'type'-Parameter."
 #: ../vector/v.out.ogr/main.c:348
 #, c-format
-msgid ""
-"%d centroid(s) found, but not requested to be exported. Verify 'type' "
-"parameter."
-msgstr ""
-"%d Zentroid(e) gefunden, die allerdings nicht zum Export angegeben wurden. "
+msgid "%d centroid(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d Zentroid(e) gefunden, die allerdings nicht zum Export angegeben wurden. Überprüfen Sie bitte den 'type'-Parameter."
 #: ../vector/v.out.ogr/main.c:353
 #, c-format
-msgid ""
-"%d areas found, but not requested to be exported. Verify 'type' parameter."
-msgstr ""
-"%d Fläche(n) gefunden, die allerdings nicht zum Export angegeben wurden. "
+msgid "%d areas found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d Fläche(n) gefunden, die allerdings nicht zum Export angegeben wurden. Überprüfen Sie bitte den 'type'-Parameter."
 #: ../vector/v.out.ogr/main.c:357
 #, c-format
-msgid ""
-"%d face(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr ""
-"%d 3D-Fläche(n) gefunden, die allerdings nicht zum Export angegeben wurden. "
+msgid "%d face(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d 3D-Fläche(n) gefunden, die allerdings nicht zum Export angegeben wurden. Überprüfen Sie bitte den 'type'-Parameter."
 #: ../vector/v.out.ogr/main.c:363
 #, c-format
-msgid ""
-"%d kernel(s) found, but not requested to be exported. Verify 'type' "
-"parameter."
-msgstr ""
-"%d Kern(en) gefunden, die allerdings nicht zum Export angegeben wurden. "
-"Überprüfen Sie den Parameter 'type'."
+msgid "%d kernel(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d Kern(en) gefunden, die allerdings nicht zum Export angegeben wurden. Überprüfen Sie den Parameter 'type'."
 #: ../vector/v.out.ogr/main.c:368
 #, c-format
-msgid ""
-"%d volume(s) found, but not requested to be exported. Verify 'type' "
-"parameter."
-msgstr ""
-"%d Volumen gefunden, die allerdings nicht zum Export angegeben wurden. "
+msgid "%d volume(s) found, but not requested to be exported. Verify 'type' parameter."
+msgstr "%d Volumen gefunden, die allerdings nicht zum Export angegeben wurden. Überprüfen Sie bitte den 'type'-Parameter."
 #: ../vector/v.out.ogr/main.c:374
-msgid ""
-"No points found, but requested to be exported. Will skip this geometry type."
-msgstr ""
-"Keine Punkte gefunden, die allerdings exportiert werden sollen. Überspringe "
-"diesen Geometrie-Typ."
+msgid "No points found, but requested to be exported. Will skip this geometry type."
+msgstr "Keine Punkte gefunden, die allerdings exportiert werden sollen. Überspringe diesen Geometrie-Typ."
 #: ../vector/v.out.ogr/main.c:383
-msgid ""
-"No lines found, but requested to be exported. Will skip this geometry type."
-msgstr ""
-"Keine Linien gefunden, die allerdings exportiert werden sollen. Überspringe "
-"diesen Geometry-Typ."
+msgid "No lines found, but requested to be exported. Will skip this geometry type."
+msgstr "Keine Linien gefunden, die allerdings exportiert werden sollen. Überspringe diesen Geometry-Typ."
 #: ../vector/v.out.ogr/main.c:393
-msgid ""
-"No boundaries found, but requested to be exported. Will skip this geometry "
-"type."
-msgstr ""
-"Keine Grenzen gefunden, die allerdings exportiert werden sollen. Überspringe "
+msgid "No boundaries found, but requested to be exported. Will skip this geometry type."
+msgstr "Keine Grenzen gefunden, die allerdings exportiert werden sollen. Überspringe diesen Geometry-Typ."
 #: ../vector/v.out.ogr/main.c:402
-msgid ""
-"No areas found, but requested to be exported. Will skip this geometry type."
-msgstr ""
-"Keine Flächen gefunden, die allerdings exportiert werden sollen. Überspringe "
+msgid "No areas found, but requested to be exported. Will skip this geometry type."
+msgstr "Keine Flächen gefunden, die allerdings exportiert werden sollen. Überspringe diesen Geometry-Typ."
 #: ../vector/v.out.ogr/main.c:412
-msgid ""
-"No centroids found, but requested to be exported. Will skip this geometry "
-"type."
-msgstr ""
-"Keine Zentroide gefunden, die allerdings exportiert werden sollen. "
-"Überspringe diesen Geometry-Typ."
+msgid "No centroids found, but requested to be exported. Will skip this geometry type."
+msgstr "Keine Zentroide gefunden, die allerdings exportiert werden sollen. Überspringe diesen Geometry-Typ."
 #: ../vector/v.out.ogr/main.c:421
-msgid ""
-"No faces found, but requested to be exported. Will skip this geometry type."
-msgstr ""
-"Keine Faces gefunden, die allerdings exportiert werden sollen. Überspringe "
+msgid "No faces found, but requested to be exported. Will skip this geometry type."
+msgstr "Keine Faces gefunden, die allerdings exportiert werden sollen. Überspringe diesen Geometry-Typ."
 #: ../vector/v.out.ogr/main.c:430
-msgid ""
-"No kernels found, but requested to be exported. Will skip this geometry type."
-msgstr ""
-"Keine Kerne gefunden, die allerdings exportiert werden sollen. Überspringe "
+msgid "No kernels found, but requested to be exported. Will skip this geometry type."
+msgstr "Keine Kerne gefunden, die allerdings exportiert werden sollen. Überspringe diesen Geometry-Typ."
 #: ../vector/v.out.ogr/main.c:439
-msgid ""
-"No volumes found, but requested to be exported. Will skip this geometry type."
-msgstr ""
-"Keine Volumen gefunden, obwohl sie exportiert werden sollen. Überspringe "
+msgid "No volumes found, but requested to be exported. Will skip this geometry type."
+msgstr "Keine Volumen gefunden, obwohl sie exportiert werden sollen. Überspringe diesen Geometry-Typ."
 #: ../vector/v.out.ogr/main.c:450
 msgid "Nothing to export"
@@ -34205,23 +31201,13 @@
 #: ../vector/v.out.ogr/main.c:583
 #, c-format
-msgid ""
-"Vector map <%s> is 3D. Use format specific layer creation options (parameter "
-"'lco') or '-z' flag to export in 3D rather than 2D (default)"
-msgstr ""
-"Vektorkarte <%s> ist 3D. Verwenden Sie formatspezifische "
-"Layererzeugungsoptionen (Parameter 'lco') oder '-z' Flag um nach 3D und "
-"nicht 2D (Standard) zu exportieren"
+msgid "Vector map <%s> is 3D. Use format specific layer creation options (parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
+msgstr "Vektorkarte <%s> ist 3D. Verwenden Sie formatspezifische Layererzeugungsoptionen (Parameter 'lco') oder '-z' Flag um nach 3D und nicht 2D (Standard) zu exportieren"
 #: ../vector/v.out.ogr/main.c:590
 #, c-format
-msgid ""
-"'lco') to export in 3D rather than 2D (default)"
-msgstr ""
-"Layererzeugungsoptionen (Parameter 'lco') um nach 3D und nicht 2D (Standard) "
-"zu exportieren."
+msgid "Vector map <%s> is 3D. Use format specific layer creation options (parameter 'lco') to export in 3D rather than 2D (default)"
+msgstr "Vektorkarte <%s> ist 3D. Verwenden Sie formatspezifische Layererzeugungsoptionen (Parameter 'lco') um nach 3D und nicht 2D (Standard) zu exportieren."
 #: ../vector/v.out.ogr/main.c:603
 msgid "Unable to create OGR layer"
@@ -34229,9 +31215,7 @@
 #: ../vector/v.out.ogr/main.c:613
 msgid "No attribute table found -> using only category numbers as attributes"
-msgstr ""
-"Keine Attributtabelle gefunden -> benutze nur Kategorienummern als "
-"Attributes."
+msgstr "Keine Attributtabelle gefunden -> benutze nur Kategorienummern als Attributes."
 #: ../vector/v.out.ogr/main.c:617
 msgid "Exporting 'cat' anyway, as it is the only attribute table field"
@@ -34294,9 +31278,7 @@
 #: ../vector/v.out.ogr/main.c:1083
 #, c-format
 msgid "No database record for cat = %d and export of 'cat' disabled"
-msgstr ""
-"Kein Datenbankeintrag für cat = %d und der Export von 'cat' wurde "
-"deaktiviert."
+msgstr "Kein Datenbankeintrag für cat = %d und der Export von 'cat' wurde deaktiviert."
 #: ../vector/v.out.svg/main.c:76
 msgid "Exports a GRASS vector map to SVG."
@@ -34336,14 +31318,14 @@
 msgstr "Kann die SVG-Datei <%s> nicht öffnen."
 #: ../vector/v.out.svg/main.c:221
-#, fuzzy, c-format
+#, c-format
 msgid "No areas found, skipping %s"
-msgstr "Keine Flächen gefunden, überspringe %."
+msgstr "Keine Flächen gefunden, überspringe %s"
 #: ../vector/v.out.svg/main.c:262
-#, fuzzy, c-format
+#, c-format
 msgid "%d areas extracted"
-msgstr "Typen die extrahiert werden."
+msgstr "%d Flächen extrahiert"
 #: ../vector/v.out.svg/main.c:269
 #, c-format
@@ -34351,9 +31333,9 @@
 msgstr "Keine Punkte gefunden, überspringe %s."
 #: ../vector/v.out.svg/main.c:295
-#, fuzzy, c-format
+#, c-format
 msgid "%d points extracted"
-msgstr "%d Punkte geladen."
+msgstr "%d Punkte extrahiert"
 #: ../vector/v.out.svg/main.c:302
 #, c-format
@@ -34361,9 +31343,9 @@
 msgstr "Keine Linien gefunden, überspringe %s."
 #: ../vector/v.out.svg/main.c:326
-#, fuzzy, c-format
+#, c-format
 msgid "%d lines extracted"
-msgstr "%d Linien zusammengefasst"
+msgstr "%d Linien extrahiert"
 #: ../vector/v.out.svg/main.c:393
 #, c-format
@@ -34375,12 +31357,8 @@
 msgstr "Vektor, extrahieren"
 #: ../vector/v.extract/main.c:93
-msgid ""
-"Selects vector objects from an existing vector map and creates a new map "
-"containing only the selected objects."
-msgstr ""
-"Selektiert Vektorobjekte einer existierenden Vektorkarte und erzeugt eine "
-"neue Karte nur mit den selektierten Objekten."
+msgid "Selects vector objects from an existing vector map and creates a new map containing only the selected objects."
+msgstr "Selektiert Vektorobjekte einer existierenden Vektorkarte und erzeugt eine neue Karte nur mit den selektierten Objekten."
 #: ../vector/v.extract/main.c:98
 msgid "Dissolve common boundaries (default is no)"
@@ -34388,25 +31366,19 @@
 #: ../vector/v.extract/main.c:102
 msgid "Do not copy table (see also 'new' parameter)"
-msgstr ""
-"Kopiere die Attributtabelle nicht mit (bitte Parameter 'new' beachten)."
+msgstr "Kopiere die Attributtabelle nicht mit (bitte Parameter 'new' beachten)."
 #: ../vector/v.extract/main.c:116
 msgid "Types to be extracted"
 #: ../vector/v.extract/main.c:122
-msgid ""
-"Layer number (if -1, all features in all layers of given type are extracted)"
-msgstr ""
-"Layernummer (wenn -1, dann werden alle Objekte in allen Layern des "
-"angegebenen Typs extrahiert)."
+msgid "Layer number (if -1, all features in all layers of given type are extracted)"
+msgstr "Layernummer (wenn -1, dann werden alle Objekte in allen Layern des angegebenen Typs extrahiert)."
 #: ../vector/v.extract/main.c:136
 msgid "Input text file with category numbers/number ranges to be extracted"
-msgstr ""
-"Eingabe-Textdatei mit Kategorienummern/-wertebereichen, die extrahiert "
-"werden sollen."
+msgstr "Eingabe-Textdatei mit Kategorienummern/-wertebereichen, die extrahiert werden sollen."
 #: ../vector/v.extract/main.c:137
 msgid "If '-' given reads from standard input"
@@ -34414,32 +31386,23 @@
 #: ../vector/v.extract/main.c:145
 msgid "Number of random categories matching vector objects to extract"
-msgstr ""
-"Zahl der zu zufälligen Kategorien passenden Vektorobjekten, die extrahiert "
-"werden."
+msgstr "Zahl der zu zufälligen Kategorien passenden Vektorobjekten, die extrahiert werden."
 #: ../vector/v.extract/main.c:147
 msgid "Number must be smaller than unique cat count in layer"
-msgstr ""
-"Zahl muss kleiner sein als die Anzahl der eindeutigen cat in dem Layer."
+msgstr "Zahl muss kleiner sein als die Anzahl der eindeutigen cat in dem Layer."
 #: ../vector/v.extract/main.c:156
 msgid "Enter -1 to keep original categories or the desired NEW category value"
-msgstr ""
-"Geben Sie -1 ein, um die originalen Kategorien beizubehalten oder der "
-"erwünschte NEUE Kategoriewert."
+msgstr "Geben Sie -1 ein, um die originalen Kategorien beizubehalten oder der erwünschte NEUE Kategoriewert."
 #: ../vector/v.extract/main.c:157
 msgid "If new >= 0, table is not copied"
 msgstr "Wenn neu >= 0, wird die Tabelle nicht kopiert."
 #: ../vector/v.extract/main.c:175
-msgid ""
-"List, file, where and random options are exclusive. Please specify only one "
-"of them"
-msgstr ""
-"Die Optionen list, file, where und random schließen sich gegenseitig aus. "
-"Bitte geben Sie nur eine von diesen an."
+msgid "List, file, where and random options are exclusive. Please specify only one of them"
+msgstr "Die Optionen list, file, where und random schließen sich gegenseitig aus. Bitte geben Sie nur eine von diesen an."
 #: ../vector/v.extract/main.c:228
 #, c-format
@@ -34467,12 +31430,8 @@
 msgstr "%d Kategorien von der Tabelle <%s> geladen."
 #: ../vector/v.extract/main.c:313
-msgid ""
-"This map has no categories attached. Use v.category to attach categories to "
-"this vector map."
-msgstr ""
-"Diese Karte hat keine Kategorien beigefügt. Verwenden Sie v.category, um "
-"dieser Karte Kategorien zuzuordnen."
+msgid "This map has no categories attached. Use v.category to attach categories to this vector map."
+msgstr "Diese Karte hat keine Kategorien beigefügt. Verwenden Sie v.category, um dieser Karte Kategorien zuzuordnen."
 #: ../vector/v.extract/main.c:319
 msgid "Please specify random number larger than 0"
@@ -34480,21 +31439,13 @@
 #: ../vector/v.extract/main.c:323
 #, c-format
-msgid ""
-"Random category count must be smaller than feature count. There are only %d "
-"features of type(s): %s"
-msgstr ""
-"Die Zahl der zufälligen Kategorien muss kleiner sein, als die Zahl der "
-"Objekte. Es gibt nur %d Objekte des Typs: %s"
+msgid "Random category count must be smaller than feature count. There are only %d features of type(s): %s"
+msgstr "Die Zahl der zufälligen Kategorien muss kleiner sein, als die Zahl der Objekte. Es gibt nur %d Objekte des Typs: %s"
 #: ../vector/v.extract/main.c:346
 #, c-format
-msgid ""
-"Random category count is larger or equal to uniq \"%s\" feature category "
-"count %d"
-msgstr ""
-"Die Zahl der zufälligen Kategorien ist größer oder gleich der Zahl der "
-"eindeutigen \"%s\" Objekt-Kategorien %d."
+msgid "Random category count is larger or equal to uniq \"%s\" feature category count %d"
+msgstr "Die Zahl der zufälligen Kategorien ist größer oder gleich der Zahl der eindeutigen \"%s\" Objekt-Kategorien %d."
 #: ../vector/v.extract/main.c:383
 msgid "Extracting features..."
@@ -34550,38 +31501,16 @@
 msgstr "Operator bestimmt das erforderte Verhältnis zwischen den Objekten"
 #: ../vector/v.select/args.c:47
-msgid ""
-"A feature is written to output if the result of operation 'ainput operator "
-"binput' is true. An input feature is considered to be true, if category of "
-msgstr ""
-"Ein Objekt wird in die Ausgabe geschrieben, wenn das Ergebnis der Operation "
-"'ainput operator binput' wahr ist. Ein Eingabe-Objekt wird als wahr "
-"aufgefasst, wenn die Kategorie des gegebenen Layers definiert ist."
+msgid "A feature is written to output if the result of operation 'ainput operator binput' is true. An input feature is considered to be true, if category of given layer is defined."
+msgstr "Ein Objekt wird in die Ausgabe geschrieben, wenn das Ergebnis der Operation 'ainput operator binput' wahr ist. Ein Eingabe-Objekt wird als wahr aufgefasst, wenn die Kategorie des gegebenen Layers definiert ist."
 #: ../vector/v.select/args.c:53
 msgid "overlap;features partially or completely overlap"
 msgstr "overlap; Objekte überlappen sich teilweise oder vollständig"
 #: ../vector/v.select/args.c:58
-msgid ""
-"overlap;features partially or completely overlap;equals;features are "
-"spatially equals (using GEOS);disjoint;features do not spatially intersect "
-"(using GEOS);intersects;features spatially intersect (using GEOS);touches;"
-"features spatially touches (using GEOS);crosses;features spatially crosses "
-"(using GEOS);within;feature A is completely inside feature B (using GEOS);"
-"contains;feature B is completely inside feature A (using GEOS);overlaps;"
-"features spatially overlap (using GEOS);relate;feature A is spatially "
-"related to feature B (using GEOS, requires 'relate' option);"
-msgstr ""
-"overlap;Objekte überlappen sich ganz oder teilweise;equals;Objekte sind im "
-"Raum gleich (mit GEOS);disjoint;Objekte überschneiden sich räumlich nicht "
-"(mit GEOS);intersects;Objekte überschneiden sich räumlich (mit GEOS);touches;"
-"Objekte berühren sich räumlich (mit  GEOS);crosses;Objekte kreuzen sich "
-"räumlich (mit GEOS);within;Objekt A ist komplett innerhalb von Objekt B (mit "
-"GEOS);contains;Objekt B ist komplett innerhalb von Objekt A (mit GEOS);"
-"overlaps;Objekte überlappen sich räumlich (mit GEOS);relate;Objekt A besitzt "
-"einen räumlichen Bezug zu Objekt B (mit GEOS, Option 'relate' erforderlich);"
+msgid "overlap;features partially or completely overlap;equals;features are spatially equals (using GEOS);disjoint;features do not spatially intersect (using GEOS);intersects;features spatially intersect (using GEOS);touches;features spatially touches (using GEOS);crosses;features spatially crosses (using GEOS);within;feature A is completely inside feature B (using GEOS);contains;feature B is completely inside feature A (using GEOS);overlaps;features spatially overlap (using GEOS);relate;feature A is spatially related to feature B (using GEOS, requires 'relate' option);"
+msgstr "overlap;Objekte überlappen sich ganz oder teilweise;equals;Objekte sind im Raum gleich (mit GEOS);disjoint;Objekte überschneiden sich räumlich nicht (mit GEOS);intersects;Objekte überschneiden sich räumlich (mit GEOS);touches;Objekte berühren sich räumlich (mit  GEOS);crosses;Objekte kreuzen sich räumlich (mit GEOS);within;Objekt A ist komplett innerhalb von Objekt B (mit GEOS);contains;Objekt B ist komplett innerhalb von Objekt A (mit GEOS);overlaps;Objekte überlappen sich räumlich (mit GEOS);relate;Objekt A besitzt einen räumlichen Bezug zu Objekt B (mit GEOS, Option 'relate' erforderlich);"
 #: ../vector/v.select/args.c:75
 msgid "Intersection Matrix Pattern used for 'relate' operator"
@@ -34596,11 +31525,8 @@
 msgstr "Vektor, räumliche Abfrage"
 #: ../vector/v.select/main.c:54
-msgid ""
-"Selects features from vector map (A) by features from other vector map (B)."
-msgstr ""
-"Selektiert Objekte der Vektorkarte (A) durch Objekte einer anderen "
-"Vektorkarte (B)."
+msgid "Selects features from vector map (A) by features from other vector map (B)."
+msgstr "Selektiert Objekte der Vektorkarte (A) durch Objekte einer anderen Vektorkarte (B)."
 #: ../vector/v.select/main.c:87
 msgid "Unknown operator"
@@ -34678,39 +31604,16 @@
 msgstr "Löse Konflikte..."
 #: ../vector/v.generalize/main.c:77
-msgid ""
-"vector, generalization, simplification, smoothing, displacement, network "
-"generalization"
-msgstr ""
-"Vektor, Generalisierung, Vereinfachung, Glättung, Verschiebung, Netzwerk-"
-"Generalisierung"
+msgid "vector, generalization, simplification, smoothing, displacement, network generalization"
+msgstr "Vektor, Generalisierung, Vereinfachung, Glättung, Verschiebung, Netzwerk-Generalisierung"
 #: ../vector/v.generalize/main.c:78
 msgid "Vector based generalization."
 msgstr "Vektorbasierte Generalisierung."
 #: ../vector/v.generalize/main.c:95
-msgid ""
-"douglas;Douglas-Peucker Algorithm;douglas_reduction;Douglas-Peucker "
-"Algorithm with reduction parameter;lang;Lang Simplification Algorithm;"
-"reduction;Vertex Reduction Algorithm eliminates points close to each other;"
-"reumann;Reumann-Witkam Algorithm;boyle;Boyle's Forward-Looking Algorithm;"
-"sliding_averaging;McMaster's Sliding Averaging Algorithm;distance_weighting;"
-"McMaster's Distance-Weighting Algorithm;chaiken;Chaiken's Algorithm;hermite;"
-"Interpolation by Cubic Hermite Splines;snakes;Snakes method for line "
-"smoothing;network;Network generalization;displacement;Displacement of lines "
-"close to each other;"
-msgstr ""
-"douglas;Douglas-Peucker Algorithmus;douglas_reduction;Douglas-Peucker "
-"Algorithmus mit Reduktionsparameter;lang;Lang's Vereinfachungsalgorithmus;"
-"reduction;Vertex Reduktionsalgorithmus eliminiert Punkte, die dicht "
-"beieinander liegen;reumann;Reumann-Witkam Algorithmus;boyle;Boyle's "
-"vorausschauender Algorithmus;sliding_averaging;McMaster's gleitender "
-"Mittelwert-Algorithmus;distance_weighting;McMaster's Distanzgewichtetungs-"
-"Algorithmus;chaiken;Chaiken's Algorithmus;hermite;Interpolation mit "
-"kubischen Hermite-Splines;snakes;Snake-Methoden zum Glätten von Linien;"
-"network;Netzwerk Generalisierung;displacement;Verschieben von Linien, die "
-"dicht beieinander liegen;"
+msgid "douglas;Douglas-Peucker Algorithm;douglas_reduction;Douglas-Peucker Algorithm with reduction parameter;lang;Lang Simplification Algorithm;reduction;Vertex Reduction Algorithm eliminates points close to each other;reumann;Reumann-Witkam Algorithm;boyle;Boyle's Forward-Looking Algorithm;sliding_averaging;McMaster's Sliding Averaging Algorithm;distance_weighting;McMaster's Distance-Weighting Algorithm;chaiken;Chaiken's Algorithm;hermite;Interpolation by Cubic Hermite Splines;snakes;Snakes method for line smoothing;network;Network generalization;displacement;Displacement of lines close to each other;"
+msgstr "douglas;Douglas-Peucker Algorithmus;douglas_reduction;Douglas-Peucker Algorithmus mit Reduktionsparameter;lang;Lang's Vereinfachungsalgorithmus;reduction;Vertex Reduktionsalgorithmus eliminiert Punkte, die dicht beieinander liegen;reumann;Reumann-Witkam Algorithmus;boyle;Boyle's vorausschauender Algorithmus;sliding_averaging;McMaster's gleitender Mittelwert-Algorithmus;distance_weighting;McMaster's Distanzgewichtetungs-Algorithmus;chaiken;Chaiken's Algorithmus;hermite;Interpolation mit kubischen Hermite-Splines;snakes;Snake-Methoden zum Glätten von Linien;network;Netzwerk Generalisierung;displacement;Verschieben von Linien, die dicht beieinander liegen;"
 #: ../vector/v.generalize/main.c:109
 msgid "Generalization algorithm"
@@ -34726,20 +31629,15 @@
 #: ../vector/v.generalize/main.c:132
 msgid "Percentage of the points in the output of 'douglas_reduction' algorithm"
-msgstr ""
-"Prozentsatz der Punkte im Ergebnis des 'douglas_reduction' Algorithmus."
+msgstr "Prozentsatz der Punkte im Ergebnis des 'douglas_reduction' Algorithmus."
 #: ../vector/v.generalize/main.c:141
 msgid "Slide of computed point toward the original point"
-msgstr ""
-"Verschieben von berechneten Punkten in Richtung seiner ursprünglichen "
-"Position."
+msgstr "Verschieben von berechneten Punkten in Richtung seiner ursprünglichen Position."
 #: ../vector/v.generalize/main.c:150
 msgid "Minimum angle between two consecutive segments in Hermite method"
-msgstr ""
-"Minimaler Winkel zwischen zwei aufeinanderfolgenden Segmenten in der Hermite-"
-"Methode."
+msgstr "Minimaler Winkel zwischen zwei aufeinanderfolgenden Segmenten in der Hermite-Methode."
 #: ../vector/v.generalize/main.c:158
 msgid "Degree threshold in network generalization"
@@ -34747,8 +31645,7 @@
 #: ../vector/v.generalize/main.c:167
 msgid "Closeness threshold in network generalization"
-msgstr ""
-"Geschlossenheits(closeness)-Schwellenwert für die Netzwerk Generalisierung."
+msgstr "Geschlossenheits(closeness)-Schwellenwert für die Netzwerk Generalisierung."
 #: ../vector/v.generalize/main.c:175
 msgid "Betweeness threshold in network generalization"
@@ -34803,17 +31700,13 @@
 #: ../vector/v.generalize/main.c:495
 #, c-format
-msgid ""
-"%d boundaries were not modified because modification would damage topology"
-msgstr ""
-"%d Grenzen wurden nicht geändert, weil Änderungen die Topologie beschädigen "
-"würden."
+msgid "%d boundaries were not modified because modification would damage topology"
+msgstr "%d Grenzen wurden nicht geändert, weil Änderungen die Topologie beschädigen würden."
 #: ../vector/v.generalize/main.c:498
 #, c-format
 msgid "%d lines/boundaries were not modified due to over-simplification"
-msgstr ""
-"%d Linien/Grenzen wurden nicht geändert wegen übertriebener Vereinfachung."
+msgstr "%d Linien/Grenzen wurden nicht geändert wegen übertriebener Vereinfachung."
 #: ../vector/v.generalize/main.c:513
 #, c-format
@@ -34851,14 +31744,8 @@
 #~ msgid "Output map: each half-basin is given a unique value"
 #~ msgstr "Ausgabekarte mit Einzugsgebietshälften mit eindeutigen Wert."
-#~ msgid ""
-#~ "Input raster map contains cells with NULL-value (no-data). The value %f "
-#~ "will be used to represent no-data values in the input map. You can "
-#~ "specify a nodata value with the %s option."
-#~ msgstr ""
-#~ "Die Eingabe Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der "
-#~ "Wert %f wurde verwendet um Nodata-Werte in der Eingabekarte zu "
-#~ "kennzeichnen. Sie können Nodata-Wert mit dem Parameter %s bestimmen."
+#~ msgid "Input raster map contains cells with NULL-value (no-data). The value %f will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
+#~ msgstr "Die Eingabe Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der Wert %f wurde verwendet um Nodata-Werte in der Eingabekarte zu kennzeichnen. Sie können Nodata-Wert mit dem Parameter %s bestimmen."
 #~ msgid "Illegal output file name"
 #~ msgstr "Ungültiger Ausgabedateiname."
@@ -35008,29 +31895,19 @@
 #~ msgstr "Nichts zu tun."
 #~ msgid "vector, buffer"
-#~ msgstr "Vektor, Buffer"
+#~ msgstr "Vektor, Puffer"
-#~ msgid ""
-#~ "This is an alias to the distance option. It is retained for backwards "
-#~ "compatibility"
-#~ msgstr ""
-#~ "Dies ist ein Alias für die Distanz-Option. Es wurde nur für rückwärts "
-#~ "Kompatibilität erhalten"
+#~ msgid "This is an alias to the distance option. It is retained for backwards compatibility"
+#~ msgstr "Dies ist ein Alias für die Distanz-Option. Es wurde nur für rückwärts Kompatibilität erhalten"
-#~ msgid ""
-#~ "The buffer option has been replaced by the distance option and will be "
-#~ "removed in future."
-#~ msgstr ""
-#~ "Die Buffer-Option wurde durch die Distanz-Option ersetzt und wird in "
-#~ "Zukunft entfernt."
+#~ msgid "The buffer option has been replaced by the distance option and will be removed in future."
+#~ msgstr "Die Puffer-Option wurde durch die Distanz-Option ersetzt und wird in Zukunft entfernt."
 #~ msgid "Use the distance option instead of the buffer option."
-#~ msgstr "Verwende die Distanz-Option anstelle der Buffer-Option."
+#~ msgstr "Verwende die Distanz-Option anstelle der Puffer-Option."
 #~ msgid "The configuration file can be used only with \t\t\t%s rasterfile"
-#~ msgstr ""
-#~ "Die Konfigurationsdatei kann nur verwendet werden mit \t\t\t%s "
-#~ "Rasterkarte."
+#~ msgstr "Die Konfigurationsdatei kann nur verwendet werden mit \t\t\t%s Rasterkarte."
 #~ msgid "Illegal configuration file (sample area)"
 #~ msgstr "Ungültige Konfigurationsdatei (Stichprobenfläche)."
@@ -35072,26 +31949,14 @@
 #~ msgid "Sets the legend's text color"
 #~ msgstr "Setzt die Texfarbe für die Legende."
-#~ msgid ""
-#~ "File containing mapping instructions (or use input=- to enter from "
-#~ "keyboard)"
-#~ msgstr ""
-#~ "Datei die Instruktionen zum Kartenzeichnen enthält (Oder benutzen Sie "
-#~ "input=- für eine interaktive Eingabe über die Tastatur)."
+#~ msgid "File containing mapping instructions (or use input=- to enter from keyboard)"
+#~ msgstr "Datei die Instruktionen zum Kartenzeichnen enthält (Oder benutzen Sie input=- für eine interaktive Eingabe über die Tastatur)."
-#~ msgid ""
-#~ "Product creation date not in metadata file <%s>, input this data in the "
-#~ "command line parameters"
-#~ msgstr ""
-#~ "Erzeugungsdatum des Produkts nicht in der Metadaten-Datei <%s>. Geben Sie "
-#~ "die Daten in der Kommandozeile ein."
+#~ msgid "Product creation date not in metadata file <%s>, input this data in the command line parameters"
+#~ msgstr "Erzeugungsdatum des Produkts nicht in der Metadaten-Datei <%s>. Geben Sie die Daten in der Kommandozeile ein."
-#~ msgid ""
-#~ "Unable to read solar elevation from metadata file in metadata file <%s>, "
-#~ "input this data in the command line parameters"
-#~ msgstr ""
-#~ "Kann die Sonnenhöhe nicht aus der Metadaten-Datei <%s> lesen. Geben Sie "
-#~ "diese Daten auf der Kommandozeile ein."
+#~ msgid "Unable to read solar elevation from metadata file in metadata file <%s>, input this data in the command line parameters"
+#~ msgstr "Kann die Sonnenhöhe nicht aus der Metadaten-Datei <%s> lesen. Geben Sie diese Daten auf der Kommandozeile ein."
 #~ msgid "Unknown column type '%s'"
 #~ msgstr "Unbekannter Spalten-Typ '%s'"
@@ -35099,29 +31964,17 @@
 #~ msgid "Building partial topology..."
 #~ msgstr "Erzeuge partielle Topologie..."
-#~ msgid ""
-#~ "Converts co-ordinate system descriptions (i.e. projection information) "
-#~ "between various formats (including GRASS format)."
-#~ msgstr ""
-#~ "Konvertiert Beschreibungen von Koordinatensystemen (z.B. "
-#~ "Projektinosinformationen) in verschiedene Formate (inklusive des GRASS-"
-#~ "Formats)."
+#~ msgid "Converts co-ordinate system descriptions (i.e. projection information) between various formats (including GRASS format)."
+#~ msgstr "Konvertiert Beschreibungen von Koordinatensystemen (z.B. Projektinosinformationen) in verschiedene Formate (inklusive des GRASS-Formats)."
 #~ msgid "Create/Edit"
 #~ msgstr "Erzeuge/Editiere"
-#~ msgid ""
-#~ "Create new projection files (modifies current location unless 'location' "
-#~ "option specified)"
-#~ msgstr ""
-#~ "Erzeuge neue Projektionsdateien. Dies modifiziert die "
-#~ "Projektionsinformationen der aktuellen Location, solange nicht der "
-#~ "Parameter 'location' angegeben ist."
+#~ msgid "Create new projection files (modifies current location unless 'location' option specified)"
+#~ msgstr "Erzeuge neue Projektionsdateien. Dies modifiziert die Projektionsinformationen der aktuellen Location, solange nicht der Parameter 'location' angegeben ist."
 #~ msgid "Enable interactive prompting (for command-line use only)"
-#~ msgstr ""
-#~ "Aktivieren Sie die interaktive Nachfrage (nur bei Verwendung der "
-#~ "Befehlszeile)."
+#~ msgstr "Aktivieren Sie die interaktive Nachfrage (nur bei Verwendung der Befehlszeile)."
 #~ msgid "Location %s created!"
 #~ msgstr "Location '%s' erstellt!"
@@ -35133,13 +31986,10 @@
 #~ msgstr ""
 #~ "\n"
 #~ "\n"
-#~ "WARNUNG! Eine Projektionsinformation für diese Location existiert "
-#~ "bereits!\n"
+#~ "WARNUNG! Eine Projektionsinformation für diese Location existiert bereits!\n"
-#~ msgid ""
-#~ "Would you still like to overwrite the current projection information "
-#~ msgstr ""
-#~ "Wollen sie wirklich die aktuelle Projektionsinformation überschreiben?"
+#~ msgid "Would you still like to overwrite the current projection information "
+#~ msgstr "Wollen sie wirklich die aktuelle Projektionsinformation überschreiben?"
 #~ msgid "Error writing PROJ_INFO"
 #~ msgstr "Fehler beim Schreiben der Datei PROJ_INFO."
@@ -35156,12 +32006,8 @@
 #~ msgid "Use G3D mask (if exists) with input map"
 #~ msgstr "Benutzt G3D Maske (falls existent) mit der Eingabekarte"
-#~ msgid ""
-#~ "No vector map of sparse points to interpolate was specified. "
-#~ "Interpolation will be done with <%s> vector map"
-#~ msgstr ""
-#~ "Keine Vektorkarte mit wenigen zu interpolierenden Punkten angegeben. Die "
-#~ "Interpolation erfolgt mit der <%s> Vektorkarte"
+#~ msgid "No vector map of sparse points to interpolate was specified. Interpolation will be done with <%s> vector map"
+#~ msgstr "Keine Vektorkarte mit wenigen zu interpolierenden Punkten angegeben. Die Interpolation erfolgt mit der <%s> Vektorkarte"
 #~ msgid "Results into a table:"
 #~ msgstr "Nun, -husch husch- die Ergebnisse in eine Tabelle:"
@@ -35179,7 +32025,7 @@
 #~ msgstr "Titel, in Gänsefüßchen"
 #~ msgid "Unable allocate memory for row buffer"
-#~ msgstr "Kann keinen Speicher für Zeilenbuffer reservieren."
+#~ msgstr "Kann keinen Speicher für Zeilenpuffer reservieren."
 #~ msgid "Computing means for band %d..."
 #~ msgstr "Berechne Mittelwerte für Kanal %d..."
@@ -35188,7 +32034,7 @@
 #~ msgstr "Berechne Zeile %d (von %d) der Kovarianz-Matrix..."
 #~ msgid "Unable to allocate memory for row buffer"
 #~ msgid "Unable to allocate memory for raster row"
 #~ msgstr "Kann keinen Speicher für Rasterzeilen reservieren."
@@ -35262,12 +32108,8 @@
 #~ msgid "Converts 3D raster maps (G3D) into the VTK-Ascii format"
 #~ msgstr "Konvertiert eine 3D-Rasterkarte (G3D) in das VTK-ASCII-Format."
-#~ msgid ""
-#~ "The 2d and 3d region settings are different. The g3d settings are used to "
-#~ "adjust the 2d region."
-#~ msgstr ""
-#~ "Die 2D und 3D Regions Parameter sind unterschiedlich. Die G3D-Parameter "
-#~ "werden verwendet, um die 2D Region anzupassen."
+#~ msgid "The 2d and 3d region settings are different. The g3d settings are used to adjust the 2d region."
+#~ msgstr "Die 2D und 3D Regions Parameter sind unterschiedlich. Die G3D-Parameter werden verwendet, um die 2D Region anzupassen."
 #~ msgid "unable to close input 3d raster map"
 #~ msgstr "Kann die Eingabe-3D-Rasterkarte nicht schließen."
@@ -35281,12 +32123,8 @@
 #~ msgid "Could not get bottom raster row \n"
 #~ msgstr "Kann die untereste Zeile des Rasters nicht bekommen.\n"
-#~ msgid ""
-#~ "write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-"
-#~ "ascii file"
-#~ msgstr ""
-#~ "write_vtk_data: Schreibe Zelldaten %s mit %i Zeilen, %i Spalten und einer "
-#~ "Tiefe von %i in eine VTK-ASCII-Datei."
+#~ msgid "write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-ascii file"
+#~ msgstr "write_vtk_data: Schreibe Zelldaten %s mit %i Zeilen, %i Spalten und einer Tiefe von %i in eine VTK-ASCII-Datei."
 #~ msgid "write_vtk_rgb_data: writing rgb data"
 #~ msgstr "write_vtk_rgb_data: Schreibe RGB-Daten"
@@ -35349,16 +32187,10 @@
 #~ msgstr "%d Grenzen wurden gelöscht, Flächen werden nicht erhalten."
 #~ msgid "New centroids were calculated, attribute attachment may be changed"
-#~ msgstr ""
-#~ "Neue Zentroide wurden berechnet. Attributzuordnung kann sich geändert "
-#~ "haben."
+#~ msgstr "Neue Zentroide wurden berechnet. Attributzuordnung kann sich geändert haben."
-#~ msgid ""
-#~ "Areas may have disappeared and/or area attribute attachment may have "
-#~ "changed"
-#~ msgstr ""
-#~ "Flächen können verschwunden sein und/oder die Zuordnung der Attribute "
-#~ "kann sich geändert haben."
+#~ msgid "Areas may have disappeared and/or area attribute attachment may have changed"
+#~ msgstr "Flächen können verschwunden sein und/oder die Zuordnung der Attribute kann sich geändert haben."
 #~ msgid "Try v.clean tool=prune thresh=%f"
 #~ msgstr "Versuchen Sie v.clean tool=prune thresh=%f"
@@ -35379,9 +32211,7 @@
 #~ msgstr " %.1f Zellen pro Minute\n"
 #~ msgid "Rectified input raster map <%s> will be saved as <%s>"
-#~ msgstr ""
-#~ "Habe die Eingabe-Rasterkarte <%s> rektifiziert. Sie wird als <%s> "
-#~ "gespeichert."
+#~ msgstr "Habe die Eingabe-Rasterkarte <%s> rektifiziert. Sie wird als <%s> gespeichert."
 #, fuzzy
 #~ msgid "Cannot open file [%s] in mapset [%s]"
@@ -35474,8 +32304,7 @@
 #~ "Sie müssen zumindest [north= south= east= west=] OR [r=\tc=] angeben."
 #~ msgid "You have to provide all limits of geographic region (n,s,e,w)"
-#~ msgstr ""
-#~ "Sie müssen alle Grenzen der geographischen Region (n,s,e,w) angeben."
+#~ msgstr "Sie müssen alle Grenzen der geographischen Region (n,s,e,w) angeben."
 #~ msgid "Illegal number of rows <%s>"
 #~ msgstr "Ungültiger Zeilenanzahl <%s>."
@@ -35522,18 +32351,11 @@
 #~ msgid "Unable to write row %d"
 #~ msgstr "Kann die Zeile %d nicht schreiben."
-#~ msgid ""
-#~ "Unable to write raster map. You might want to check available disk space "
-#~ "and write permissions."
-#~ msgstr ""
-#~ "Kann die Rasterkarte nicht schreiben. Sie sollten den verfügbaren "
-#~ "Plattenplatz und die Schreibberechtigungen überprüfen."
+#~ msgid "Unable to write raster map. You might want to check available disk space and write permissions."
+#~ msgstr "Kann die Rasterkarte nicht schreiben. Sie sollten den verfügbaren Plattenplatz und die Schreibberechtigungen überprüfen."
-#~ msgid ""
-#~ "Please select the file(s) you wish to rectify by naming an output file"
-#~ msgstr ""
-#~ "Bitte wählen Sie die Dateie(n), die Sie rektifizieren möchten, in dem Sie "
-#~ "eine Ausgabedatei benennen."
+#~ msgid "Please select the file(s) you wish to rectify by naming an output file"
+#~ msgstr "Bitte wählen Sie die Dateie(n), die Sie rektifizieren möchten, in dem Sie eine Ausgabedatei benennen."
 #~ msgid "%s@%s: projection doesn't match current settings"
 #~ msgstr "%s@%s: Projektion passt nicht zu den aktuellen Einstellungen."
@@ -35557,8 +32379,7 @@
 #~ msgstr "Mapset der Eingabe-Rasterkarte."
 #~ msgid "You have to use a different location for input than the current"
-#~ msgstr ""
-#~ "Sie müssen eine andere Location als Input verwenden als die Aktuelle."
+#~ msgstr "Sie müssen eine andere Location als Input verwenden als die Aktuelle."
 #~ msgid "Checking location <%s>, mapset <%s>..."
 #~ msgstr "Prüfe Location <%s>, Mapset <%s>..."
@@ -35597,8 +32418,7 @@
 #~ msgstr "Zero (0) ist eine reale Höhenangabe"
 #~ msgid " %d.%02d.%02d, daynum %d, time: %02i:%02i:%02i (decimal time: %f)\n"
-#~ msgstr ""
-#~ " %d.%02d.%02d, Tagnummer %d, Zeit: %02i:%02i:%02i (dezimale Zeit: %f)\n"
+#~ msgstr " %d.%02d.%02d, Tagnummer %d, Zeit: %02i:%02i:%02i (dezimale Zeit: %f)\n"
 #~ msgid " long: %f, lat: %f, timezone: %f\n"
 #~ msgstr "geogr. Länge: %f, geogr. Breite: %f, Zeitzone: %f\n"
@@ -35665,12 +32485,8 @@
 #~ msgid "New MAPSET name"
 #~ msgstr "Neuer Mapset Name."
-#~ msgid ""
-#~ "Displays and overlays raster map layers in the active display frame on "
-#~ "the graphics monitor."
-#~ msgstr ""
-#~ "Stellt Rasterkarten im aktiven Grafikfenster dar. Überlagerung ist auch "
-#~ "möglich."
+#~ msgid "Displays and overlays raster map layers in the active display frame on the graphics monitor."
+#~ msgstr "Stellt Rasterkarten im aktiven Grafikfenster dar. Überlagerung ist auch möglich."
 #~ msgid "Displays vector data in the active frame on the graphics monitor."
 #~ msgstr "Stellt GRASS Vektorkarten im aktiven Grafikfenster dar."
@@ -35684,11 +32500,8 @@
 #~ msgid "Island size [%.1e], island not imported"
 #~ msgstr "Inselgröße [%.1e], Insel nicht importiert."
-#~ msgid ""
-#~ "Number of column used as x coordinate (first column is 1) for points mode"
-#~ msgstr ""
-#~ "Nummer der Spalte, die als X-Koordinate (erste Spalte ist 1)  für den "
-#~ "Punkt-Modus genutzt wird."
+#~ msgid "Number of column used as x coordinate (first column is 1) for points mode"
+#~ msgstr "Nummer der Spalte, die als X-Koordinate (erste Spalte ist 1)  für den Punkt-Modus genutzt wird."
 #~ msgid "Duplicate area centroids"
 #~ msgstr "Doppelte Zentroide"
@@ -35699,14 +32512,8 @@
 #~ msgid "Failed in attempt to open %s"
 #~ msgstr "Fehlschlag beim Versuch '%s' zu öffnen."
-#~ msgid ""
-#~ "Generates raster map layers of slope, aspect, curvatures and partial "
-#~ "derivatives from a raster map layer of true elevation values. Aspect is "
-#~ "calculated counterclockwise from east."
-#~ msgstr ""
-#~ "Erzeugt Rasterkarten mit Hangneigung, Exposition, Wölbung und partiellen "
-#~ "Ableitungen aus einer Rasterkarte mit Höheninformationen.Die Exposition "
-#~ "werden vom Osten gegen den Uhrzeigersinn berechnet."
+#~ msgid "Generates raster map layers of slope, aspect, curvatures and partial derivatives from a raster map layer of true elevation values. Aspect is calculated counterclockwise from east."
+#~ msgstr "Erzeugt Rasterkarten mit Hangneigung, Exposition, Wölbung und partiellen Ableitungen aus einer Rasterkarte mit Höheninformationen.Die Exposition werden vom Osten gegen den Uhrzeigersinn berechnet."
 #~ msgid "Raster elevation file name"
 #~ msgstr "Rasterkarte mit Höheninformationen."
@@ -35721,12 +32528,10 @@
 #~ msgstr "Dateiname für Ausgabekarte mit horizontaler Wölbung."
 #~ msgid "Output first order partial derivative dx (E-W slope) filename"
-#~ msgstr ""
-#~ "Ausgabekarte der ersten partiellen Ableitung dx (Ost-West Hangneigung)."
+#~ msgstr "Ausgabekarte der ersten partiellen Ableitung dx (Ost-West Hangneigung)."
 #~ msgid "Output first order partial derivative dy (N-S slope) filename"
-#~ msgstr ""
-#~ "Ausgabekarte der ersten partiellen Ableitung dy (Nord-Süd Hangneigung)."
+#~ msgstr "Ausgabekarte der ersten partiellen Ableitung dy (Nord-Süd Hangneigung)."
 #~ msgid "Output second order partial derivative dxx filename"
 #~ msgstr "Ausgabekarte der zweiten partiellen Ableitung dxx."
@@ -35773,14 +32578,8 @@
 #~ msgid "DXY [%s] COMPLETE"
 #~ msgstr "DXY [%s] KOMPLETT"
-#~ msgid ""
-#~ "Input raster map contains cells with NULL-value (no-data). The value %g "
-#~ "was used to represent no-data values in the input map. You can specify "
-#~ "nodata value by %s parameter."
-#~ msgstr ""
-#~ "Wert %g wurde verwendet um Nodata-Werte in der Eingabekarte zu "
+#~ msgid "Input raster map contains cells with NULL-value (no-data). The value %g was used to represent no-data values in the input map. You can specify nodata value by %s parameter."
+#~ msgstr "Die Eingabe Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der Wert %g wurde verwendet um Nodata-Werte in der Eingabekarte zu kennzeichnen. Sie können Nodata-Wert mit dem Parameter %s bestimmen."
 #~ msgid "raster, terrain analysis"
 #~ msgstr "Raster, Geländeanalyse"
@@ -35804,9 +32603,7 @@
 #~ msgstr "Kann die Maske (MASK) nicht öffnen."
 #~ msgid "Uses a GRASS vector points map to produce a convex hull vector map."
-#~ msgstr ""
-#~ "Verwendet eine GRASS Vektor-Punktkarte, um eine Vektorkarte mit konvexer "
-#~ "Hülle zu erzeugen."
+#~ msgstr "Verwendet eine GRASS Vektor-Punktkarte, um eine Vektorkarte mit konvexer Hülle zu erzeugen."
 #~ msgid "Name of input vector points map"
 #~ msgstr "Name der Eingabe-Vektorkarte mit Punkten."
@@ -35820,22 +32617,14 @@
 #~ msgid "It was impossible to create <Auxiliar_outlier_table>."
 #~ msgstr "Kann <Auxiliar_outlier_table> nicht erzeugen"
-#~ msgid ""
-#~ "It was not possible to drop <%s> table. Nothing will be done. Try to drop "
-#~ "it manually."
-#~ msgstr ""
-#~ "Es war nicht möglich die Tabelle <%s> zu löschen. Nichts wird "
-#~ "unternommen. Versuchen Sie die Tabelle manuell zu löschen."
+#~ msgid "It was not possible to drop <%s> table. Nothing will be done. Try to drop it manually."
+#~ msgstr "Es war nicht möglich die Tabelle <%s> zu löschen. Nichts wird unternommen. Versuchen Sie die Tabelle manuell zu löschen."
 #~ msgid "Cross Validation was success!"
 #~ msgstr "Die Kreuzvalidierung war erfolgreich."
-#~ msgid ""
-#~ "Interpolation: The region resolution is too high: %d cells. Consider to "
-#~ "change it."
-#~ msgstr ""
-#~ "Interpolation: Die Auflösung der Region ist zu hoch: %d Zellen. Überlegen "
-#~ "Sie die Auflösung zu ändern."
+#~ msgid "Interpolation: The region resolution is too high: %d cells. Consider to change it."
+#~ msgstr "Interpolation: Die Auflösung der Region ist zu hoch: %d Zellen. Überlegen Sie die Auflösung zu ändern."
 #~ msgid "Creating auxiliar table for archiving overlapping zones"
 #~ msgstr "Erstelle Hilfstabelle um überlappende Zonen zu archivieren"
@@ -35863,14 +32652,10 @@
 #~ msgstr "Gib mehr Kommentare aus (Standard=schweigsam)."
 #~ msgid "All non-NULL and non-zero cells are considered as real depressions"
-#~ msgstr ""
-#~ "Alle Zellen, die nicht NULL sind oder den Wert Null haben werden als "
-#~ "echte Bodensenke aufgefasst."
+#~ msgstr "Alle Zellen, die nicht NULL sind oder den Wert Null haben werden als echte Bodensenke aufgefasst."
 #~ msgid "All non-NULL and non-zero cells are considered as blocking terrain"
-#~ msgstr ""
-#~ "echte Hindernis aufgefasst."
+#~ msgstr "Alle Zellen, die nicht NULL sind oder den Wert Null haben werden als echte Hindernis aufgefasst."
 #~ msgid "It was impossible to open table"
 #~ msgstr "Es war unmöglich die Tabelle zu öffnen."
Modified: grass/branches/releasebranch_6_4/locale/po/grassnviz_de.po
--- grass/branches/releasebranch_6_4/locale/po/grassnviz_de.po	2014-08-11 09:44:09 UTC (rev 61582)
+++ grass/branches/releasebranch_6_4/locale/po/grassnviz_de.po	2014-08-11 10:14:22 UTC (rev 61583)
@@ -1,22 +1,22 @@
 # translation of grassnviz_de.po to deutsch
 # This file is distributed under the same license as the GRASS package.
-# Copyright (C) 2011-2013 GRASS Development Team
+# Copyright (C) 2011-2014 GRASS Development Team
-# Robert Nuske <robert.nuske nw-fva.de>, 2011, 2012, 2013.
+# Robert Nuske <robert.nuske nw-fva.de>, 2011, 2012, 2013, 2014.
 msgid ""
 msgstr ""
 "Project-Id-Version: grassnviz_de\n"
 "Report-Msgid-Bugs-To: \n"
 "POT-Creation-Date: 2014-05-20 18:01+0200\n"
-"PO-Revision-Date: 2014-03-24 15:19+0100\n"
-"Last-Translator: Helmut Kudrnovsky <hellik at web.de>\n"
+"PO-Revision-Date: 2014-08-10 15:19+0200\n"
+"Last-Translator: Robert Nuske <robert.nuske at nw-fva.de>\n"
 "Language-Team: German <grass-translations at lists.osgeo.org>\n"
 "Language: de\n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
 "Plural-Forms: nplurals=2; plural=(n != 1);\n"
-"X-Generator: Poedit 1.6.4\n"
+"X-Generator: Lokalize 1.5\n"
 #: ../visualization/nviz/scripts/attPopup.tcl:45
 #: ../visualization/nviz/scripts/attPopup.tcl:46
@@ -128,12 +128,12 @@
 #: ../visualization/nviz/scripts/attPopup.tcl:516
 msgid "Use slider to set value"
-msgstr "Benutze Slider, um Wert einzustellen"
+msgstr "Benutze Schieber, um Wert einzustellen"
 #: ../visualization/nviz/scripts/filemapBrowser.tcl:98
 #: ../visualization/nviz/scripts/multimapBrowser.tcl:99
 msgid "Remove"
-msgstr "Entferne"
+msgstr "Entfernen"
 #: ../visualization/nviz/scripts/filemapBrowser.tcl:104
 #: ../visualization/nviz/scripts/mapBrowser.tcl:150
@@ -187,7 +187,7 @@
 #: ../visualization/nviz/scripts/mapBrowser.tcl:220
 #: ../visualization/nviz/scripts/multimapBrowser.tcl:163
 msgid "Regions"
-msgstr "Region"
+msgstr "Regionen"
 #: ../visualization/nviz/scripts/filemapBrowser.tcl:164
 #: ../visualization/nviz/scripts/mapBrowser.tcl:222
@@ -235,7 +235,7 @@
 #: ../visualization/nviz/scripts/panel_legend.tcl:71
 msgid "reverse legend"
-msgstr "Drehe Legende"
+msgstr "Legende umdrehen"
 #: ../visualization/nviz/scripts/panel_legend.tcl:73
 msgid "show values"
@@ -261,7 +261,7 @@
 #: ../visualization/nviz/scripts/panel_legend.tcl:91
 msgid "min "
-msgstr "min"
+msgstr "min "
 #: ../visualization/nviz/scripts/panel_legend.tcl:94
 msgid " max "
@@ -276,12 +276,8 @@
 msgstr "Platziere Legende"
 #: ../visualization/nviz/scripts/panel_legend.tcl:133
-msgid ""
-"Use mouse to place legend; left button defines first corner,  right button "
-"defines opposite corner."
-msgstr ""
-"Bewege Maus um Legende zu platzieren; Linker Button legt erste Ecke fest, "
-"rechter Button legt gegenüberliegende Ecke fest."
+msgid "Use mouse to place legend; left button defines first corner,  right button defines opposite corner."
+msgstr "Bewege Maus um Legende zu platzieren; Linker Button legt erste Ecke fest, rechter Button legt gegenüberliegende Ecke fest."
 #: ../visualization/nviz/scripts/panel_legend.tcl:135
 msgid "Erase legend"
@@ -441,7 +437,7 @@
 #: ../visualization/nviz/scripts/flythrough.tcl:114
 msgid "Interactively set view position"
-msgstr "Interaktives setzen der Blickposition"
+msgstr "Interaktives Setzen der Blickposition"
 #: ../visualization/nviz/scripts/flythrough.tcl:135
 msgid "flythrough help"
@@ -453,7 +449,7 @@
 #: ../visualization/nviz/scripts/flythrough.tcl:196
 msgid "turn"
-msgstr "Drehe"
+msgstr "drehe"
 #: ../visualization/nviz/scripts/mapBrowser.tcl:204
 msgid "Map type:"
@@ -850,7 +846,7 @@
 #: ../visualization/nviz/scripts/nviz2.2_script:439
 msgid "Script Tools"
-msgstr "Script Tools"
+msgstr "Skript Werkzeuge"
 #: ../visualization/nviz/scripts/nviz2.2_script:484
 msgid "PPM Image"
@@ -882,7 +878,7 @@
 #: ../visualization/nviz/scripts/nviz2.2_script:811
 msgid "Unconstrained"
-msgstr "Zwanglos"
+msgstr "Unbeschränkt"
 #: ../visualization/nviz/scripts/nviz2.2_script:873
 #: ../visualization/nviz/scripts/nviz2.2_script:1027
@@ -1129,14 +1125,12 @@
 #: ../visualization/nviz/scripts/panel_animation.tcl:602
 #: ../visualization/nviz/scripts/panel_kanimator.tcl:872
 msgid "Internal Error - Failed to delete keyframe in GK key list"
-msgstr ""
-"Interner Fehler - Löschen des Key-Frames in GK-Key-Liste fehlgeschlagen."
+msgstr "Interner Fehler - Löschen des Key-Frames in GK-Key-Liste fehlgeschlagen."
 #: ../visualization/nviz/scripts/panel_animation.tcl:643
 #: ../visualization/nviz/scripts/panel_kanimator.tcl:1006
 msgid "Internal Error - Failed to move keyframe in GK key list"
-msgstr ""
-"Interner Fehler - Verschieben des Key-Frames in GK-Key-Liste fehlgeschlagen."
+msgstr "Interner Fehler - Verschieben des Key-Frames in GK-Key-Liste fehlgeschlagen."
 #: ../visualization/nviz/scripts/panel_animation.tcl:753
 #: ../visualization/nviz/scripts/panel_kanimator.tcl:1124
@@ -1161,8 +1155,7 @@
 #: ../visualization/nviz/scripts/panel_animation.tcl:935
 msgid "Enter a prefix name for images to be created from animation frames"
-msgstr ""
-"Gebe ein Prefix für die von den Animation-Frames erzeugten  Bildernamen an"
+msgstr "Gebe ein Prefix für die von den Animation-Frames erzeugten  Bildernamen an"
 #: ../visualization/nviz/scripts/panel_animation.tcl:940
 msgid "Output format: "
@@ -1254,7 +1247,7 @@
 #: ../visualization/nviz/scripts/panel_vol.tcl:443
 msgid "Y-axis"
-msgstr "X-Achse"
+msgstr "Y-Achse"
 #: ../visualization/nviz/scripts/panel_vol.tcl:445
 msgid "Z-axis"
@@ -1367,7 +1360,7 @@
 #: ../visualization/nviz/scripts/panel_fringe.tcl:43
 #: ../visualization/nviz/scripts/panel_main.tcl:164
 msgid "Fringe"
-msgstr "Fringe"
+msgstr "Rand"
 #: ../visualization/nviz/scripts/panel_fringe.tcl:45
 msgid "Fringe Panel"
@@ -1437,21 +1430,12 @@
 msgstr "Aster"
 #: ../visualization/nviz/scripts/site_attr.tcl:411
-msgid ""
-"Fill 2 or more entry fields with  desired min and max values, then press "
-"[Apply].  Or press [Auto] to automatically  generate a range of symbol sizes."
-msgstr ""
-"Fülle 2 oder mehrere Eingabefelder mit den gewünschten min- und max-Werten, "
-"dann drücke [Apply].  Oder drücke [Auto] für einen automatisch erzeugten "
-"Wertebereich der Symbolgröße."
+msgid "Fill 2 or more entry fields with  desired min and max values, then press [Apply].  Or press [Auto] to automatically  generate a range of symbol sizes."
+msgstr "Fülle 2 oder mehrere Eingabefelder mit den gewünschten min- und max-Werten, dann drücke [Apply].  Oder drücke [Auto] für einen automatisch erzeugten Wertebereich der Symbolgröße."
 #: ../visualization/nviz/scripts/site_attr.tcl:422
-msgid ""
-"Fill 2 or more entry fields with desired colors, then press [Apply]. Or "
-"press [Auto] to automatically generate a color table."
-msgstr ""
-"Fülle 2 oder mehrere Eingabefelder mit der gewünschten Farbe, dann drücke "
-"[Apply]. Oder drücke [Auto] für eine automatisch erzeugte Farbtabelle."
+msgid "Fill 2 or more entry fields with desired colors, then press [Apply]. Or press [Auto] to automatically generate a color table."
+msgstr "Fülle 2 oder mehrere Eingabefelder mit der gewünschten Farbe, dann drücke [Apply]. Oder drücke [Auto] für eine automatisch erzeugte Farbtabelle."
 #: ../visualization/nviz/scripts/site_attr.tcl:428
 #, tcl-format
@@ -1482,12 +1466,8 @@
 msgstr "Auto"
 #: ../visualization/nviz/scripts/site_attr.tcl:479
-msgid ""
-"Automatically generate a color  table distributed across range of attribute "
-"values"
-msgstr ""
-"Generiere automatisch eine über den Wertebereich der Attribute verteilte "
-"Farbtabelle"
+msgid "Automatically generate a color  table distributed across range of attribute values"
+msgstr "Generiere automatisch eine über den Wertebereich der Attribute verteilte Farbtabelle"
 #: ../visualization/nviz/scripts/site_attr.tcl:485
 msgid "Clear all thematic settings"
@@ -1557,13 +1537,11 @@
 #: ../visualization/nviz/scripts/site_attr.tcl:1146
 msgid "Thematic prefs and attribute have different types"
-msgstr ""
-"Thematische Einstellung und Attribute besitzen unterschiedliche Eigenschaft"
+msgstr "Thematische Einstellung und Attribute besitzen unterschiedliche Eigenschaft"
 #: ../visualization/nviz/scripts/site_attr.tcl:1207
 msgid "Thematic prefs and attributes have different types"
-msgstr ""
-"Thematische Einstellungen und Attribute besitzen unterschiedliche Eigenschaft"
+msgstr "Thematische Einstellungen und Attribute besitzen unterschiedliche Eigenschaft"
 #: ../visualization/nviz/scripts/site_attr.tcl:1408
 #, tcl-format
@@ -1632,8 +1610,7 @@
 #: ../visualization/nviz/scripts/site_attr.tcl:1627
 #, tcl-format
 msgid "*** ERROR *** Some thematic pref component are missing in file \"%s\""
-msgstr ""
-"*** FEHLER *** Einige thematische Einstellungen fehlen in der Datei \"%s\""
+msgstr "*** FEHLER *** Einige thematische Einstellungen fehlen in der Datei \"%s\""
 #: ../visualization/nviz/scripts/site_attr.tcl:1700
 #, tcl-format
@@ -1694,9 +1671,7 @@
 #: ../visualization/nviz/scripts/script_file_tools:111
 msgid "Current fields have not been saved, really load new fields?"
-msgstr ""
-"Aktuelle Felder wurden noch nicht gespeichert,  wollen sie wirklich neue "
-"Felder laden?"
+msgstr "Aktuelle Felder wurden noch nicht gespeichert,  wollen sie wirklich neue Felder laden?"
 #: ../visualization/nviz/scripts/script_file_tools:135
 #, tcl-format
@@ -1800,9 +1775,7 @@
 #: ../visualization/nviz/scripts/panel_vquery.tcl:130
 msgid "Choose size in multiples of default to indicate point queried"
-msgstr ""
-"Wähle Größe ein Vielfaches der Grundeinstellung, um abgefragten Punkt "
-"anzuzeigen"
+msgstr "Wähle Größe ein Vielfaches der Grundeinstellung, um abgefragten Punkt anzuzeigen"
 #: ../visualization/nviz/scripts/panel_vquery.tcl:137
 msgid "specific icon"
Modified: grass/branches/releasebranch_6_4/locale/po/grasswxpy_de.po
--- grass/branches/releasebranch_6_4/locale/po/grasswxpy_de.po	2014-08-11 09:44:09 UTC (rev 61582)
+++ grass/branches/releasebranch_6_4/locale/po/grasswxpy_de.po	2014-08-11 10:14:22 UTC (rev 61583)
@@ -1,26 +1,26 @@
 # translation of grasswxpy_de.po to Deutsch
-# Copyright (C) 2008-2013 GRASS Development Team
+# Copyright (C) 2008-2014 GRASS Development Team
 # Markus Neteler <neteler cealp it>, 2008.
 # Georg Lösel <georg*de-schorsch.de>, 2008.
 # Markus Neteler <neteler osgeo.org>, 2008, 2009, 2010.
 # Robert Nuske <rnuske gwdg.de>, 2009, 2010.
 msgid ""
 msgstr ""
 "Project-Id-Version: grasswxpy_de\n"
-"PO-Revision-Date: 2014-03-24 16:24+0100\n"
+"PO-Revision-Date: 2014-08-10 14:04+0200\n"
 "Language: de\n"
 #: ../gui/wxpython/gmodeler/dialogs.py:47
 msgid "Data properties"
@@ -175,8 +175,7 @@
 #: ../gui/wxpython/gmodeler/dialogs.py:654
 #, python-format
 msgid "Variable <%s> already exists in the model. Adding variable failed."
-msgstr ""
-"Variable <%s> ist im Modell bereits vorhanden. Hinzufügen nicht erfolgreich."
+msgstr "Variable <%s> ist im Modell bereits vorhanden. Hinzufügen nicht erfolgreich."
 #: ../gui/wxpython/gmodeler/dialogs.py:683
 msgid "Do you want to delete all variables from the model?"
@@ -207,12 +206,8 @@
 #: ../gui/wxpython/gmodeler/dialogs.py:848
 #, python-format
-msgid ""
-"Selected data records (%d) will permanently deleted from table. Do you want "
-"to delete them?"
-msgstr ""
-"Selektierte Datensätze (%d) werden unwiderruflich aus der Tabelle gelöscht. "
-"Wollen Sie diese Datensätze löschen?"
+msgid "Selected data records (%d) will permanently deleted from table. Do you want to delete them?"
+msgstr "Selektierte Datensätze (%d) werden unwiderruflich aus der Tabelle gelöscht. Wollen Sie diese Datensätze löschen?"
 #: ../gui/wxpython/gmodeler/dialogs.py:851
 #: ../gui/wxpython/dbmgr/manager.py:1191 ../gui/wxpython/dbmgr/manager.py:1237
@@ -538,12 +533,8 @@
 msgstr "%d Karte aus dem aktuellen Mapset gelöscht"
 #: ../gui/wxpython/gmodeler/frame.py:341 ../gui/wxpython/gmodeler/frame.py:456
-msgid ""
-"Current model is not empty. Do you want to store current settings to model "
-"file?"
-msgstr ""
-"Aktuelles Modell ist nicht leer. Wollen sie die aktuellen Einstellungen in "
-"eine Modell-Datei speichern?"
+msgid "Current model is not empty. Do you want to store current settings to model file?"
+msgstr "Aktuelles Modell ist nicht leer. Wollen sie die aktuellen Einstellungen in eine Modell-Datei speichern?"
 #: ../gui/wxpython/gmodeler/frame.py:344 ../gui/wxpython/gmodeler/frame.py:459
 msgid "Create new model?"
@@ -566,8 +557,7 @@
 #: ../gui/wxpython/gmodeler/frame.py:396 ../gui/wxpython/gmodeler/frame.py:433
 #, python-format
 msgid "Model file <%s> already exists. Do you want to overwrite this file?"
-msgstr ""
-"Modell-Datei <%s> existiert bereits. Wollen Sie diese Datei überschreiben?"
+msgstr "Modell-Datei <%s> existiert bereits. Wollen Sie diese Datei überschreiben?"
 #: ../gui/wxpython/gmodeler/frame.py:399 ../gui/wxpython/menustrings.py:863
 msgid "Save model"
@@ -609,9 +599,7 @@
 #: ../gui/wxpython/modules/histogram.py:416
 #: ../gui/wxpython/gcp/mapdisplay.py:456
 msgid "Choose a file name to save the image (no need to add extension)"
-msgstr ""
-"Wähle einen Dateinamen, um Bild zu speichern (Anfügen einer Extension nicht "
-"erforderlich)"
+msgstr "Wähle einen Dateinamen, um Bild zu speichern (Anfügen einer Extension nicht erforderlich)"
 #: ../gui/wxpython/gmodeler/frame.py:578 ../gui/wxpython/gmodeler/frame.py:585
 #, python-format
@@ -632,13 +620,8 @@
 "\n"
 #: ../gui/wxpython/gmodeler/frame.py:717 ../gui/wxpython/psmap/frame.py:1058
-msgid ""
-"This program is free software under the GNU General Public License(>=v2). "
-"Read the file COPYING that comes with GRASS for details."
-msgstr ""
-"Dieses Programm ist freie Software unter der GNU General Public "
-"License(>=v2). Lesen Sie für Details die Datei COPYING, die mit GRASS "
-"ausgeliefert wird."
+msgid "This program is free software under the GNU General Public License(>=v2). Read the file COPYING that comes with GRASS for details."
+msgstr "Dieses Programm ist freie Software unter der GNU General Public License(>=v2). Lesen Sie für Details die Datei COPYING, die mit GRASS ausgeliefert wird."
 #: ../gui/wxpython/gmodeler/frame.py:815
 #, python-format
@@ -655,9 +638,7 @@
 #: ../gui/wxpython/gmodeler/frame.py:881
 msgid "Writing current settings to model file failed."
-msgstr ""
-"Das Schreiben der aktuellen Einstellungen in die Modell-Datei nicht "
-"erfolgreich."
+msgstr "Das Schreiben der aktuellen Einstellungen in die Modell-Datei nicht erfolgreich."
 #: ../gui/wxpython/gmodeler/frame.py:891 ../gui/wxpython/lmgr/frame.py:1123
 #, python-format
@@ -836,12 +817,8 @@
 msgstr "Speichere Datei"
 #: ../gui/wxpython/gmodeler/frame.py:1620
-msgid ""
-"Python script is locally modificated. Refresh will discard all changes. Do "
-"you really want to continue?"
-msgstr ""
-"Python-Skript wurde lokal geändert. Aktualisierung wird die Änderungen "
-"überschreiben. Wollen Sie wirklich fortfahren?"
+msgid "Python script is locally modificated. Refresh will discard all changes. Do you really want to continue?"
+msgstr "Python-Skript wurde lokal geändert. Aktualisierung wird die Änderungen überschreiben. Wollen Sie wirklich fortfahren?"
 #: ../gui/wxpython/gmodeler/frame.py:1623
 msgid "Update"
@@ -929,11 +906,8 @@
 #: ../gui/wxpython/wxplot/dialogs.py:380 ../gui/wxpython/wxplot/dialogs.py:764
 #: ../gui/wxpython/gcp/manager.py:2372
 #: ../gui/wxpython/gui_core/preferences.py:90
-msgid ""
-"Apply and save changes to user settings file (default for next sessions)"
-msgstr ""
-"Wende Änderungen an und speichere sie in den Benutzereinstellungen (Standard "
-"für die nächste Sitzung)"
+msgid "Apply and save changes to user settings file (default for next sessions)"
+msgstr "Wende Änderungen an und speichere sie in den Benutzereinstellungen (Standard für die nächste Sitzung)"
 #: ../gui/wxpython/wxplot/dialogs.py:433
 #, python-format
@@ -1017,11 +991,8 @@
 msgstr "Maßstab"
 #: ../gui/wxpython/wxplot/dialogs.py:661
-msgid ""
-"Automatic axis scaling, custom max and min, or scale matches data range (min)"
-msgstr ""
-"Automatische Achsenskalierung, benutzerdefiniertes max und min oder Maßstab "
-"nach Wertebereich der Daten (min)"
+msgid "Automatic axis scaling, custom max and min, or scale matches data range (min)"
+msgstr "Automatische Achsenskalierung, benutzerdefiniertes max und min oder Maßstab nach Wertebereich der Daten (min)"
 #: ../gui/wxpython/wxplot/dialogs.py:666
 msgid "Custom min"
@@ -1061,16 +1032,8 @@
 msgstr "Plot-Einstellungen in der Datei '%s' gespeichert."
 #: ../gui/wxpython/wxplot/profile.py:30 ../gui/wxpython/nviz/wxnviz.py:32
-msgid ""
-"This module requires the NumPy module, which could not be imported. It "
-"probably is not installed (it's not part of the standard Python "
-"distribution). See the Numeric Python site (http://numpy.scipy.org) for "
-"information on downloading source or binaries."
-msgstr ""
-"Dieses erfordert NumPy, das nicht importiert werden konnte. Es ist eventuell "
-"nicht installiert (es ist nicht Bestandteil der Standard-Python-"
-"Distribution). Gehe zur Numeric Python Website (http://numpy.scipy.org), um "
-"den Quellcode oder Binaries zu erhalten."
+msgid "This module requires the NumPy module, which could not be imported. It probably is not installed (it's not part of the standard Python distribution). See the Numeric Python site (http://numpy.scipy.org) for information on downloading source or binaries."
+msgstr "Dieses erfordert NumPy, das nicht importiert werden konnte. Es ist eventuell nicht installiert (es ist nicht Bestandteil der Standard-Python-Distribution). Gehe zur Numeric Python Website (http://numpy.scipy.org), um den Quellcode oder Binaries zu erhalten."
 #: ../gui/wxpython/wxplot/profile.py:52
 msgid "GRASS Profile Analysis Tool"
@@ -1103,8 +1066,7 @@
 #: ../gui/wxpython/wxplot/profile.py:264
 msgid "You must draw a transect to profile in the map display window."
-msgstr ""
-"Sie müssen ein Transekt im Kartenfenster zeichnen, um ein Profil zu erhalten."
+msgstr "Sie müssen ein Transekt im Kartenfenster zeichnen, um ein Profil zu erhalten."
 #: ../gui/wxpython/wxplot/profile.py:265
 msgid "Nothing to profile"
@@ -1123,13 +1085,13 @@
 msgstr "Datei überschreiben?"
 #: ../gui/wxpython/wxplot/profile.py:356
-#, fuzzy, python-format
+#, python-format
 msgid ""
 "Unable to open file <%(file)s> for writing.\n"
 "Reason: %(e)s"
 msgstr ""
-"Kann die Datei <%s> nicht zum Schreiben öffnen.\n"
-"Grund: %s"
+"Kann die Datei <%(file)s> nicht zum Schreiben öffnen.\n"
+"Grund: %(e)s"
 #: ../gui/wxpython/wxplot/profile.py:369
 #, python-format
@@ -1154,8 +1116,7 @@
 #: ../gui/wxpython/wxplot/base.py:37
 msgid "Draw transect in map display window to profile"
-msgstr ""
-"Zeichne ein Transekt in das Kartenfenster, für das ein Profil erstellt wird"
+msgstr "Zeichne ein Transekt in das Kartenfenster, für das ein Profil erstellt wird"
 #: ../gui/wxpython/wxplot/base.py:39
 msgid "Plot options"
@@ -1356,12 +1317,8 @@
 #: ../gui/wxpython/location_wizard/wizard.py:159
 #, python-format
-msgid ""
-"Name <%(name)s> is not a valid name for location. Please use only ASCII "
-"characters excluding %(chars)s and space."
-msgstr ""
-"Der Name <%(name)s> ist kein gültiger Name für Locations. Bitte verwenden "
-"Sie nur ASCII-Zeichen ohne %(chars)s und Leerzeichen."
+msgid "Name <%(name)s> is not a valid name for location. Please use only ASCII characters excluding %(chars)s and space."
+msgstr "Der Name <%(name)s> ist kein gültiger Name für Locations. Bitte verwenden Sie nur ASCII-Zeichen ohne %(chars)s und Leerzeichen."
 #: ../gui/wxpython/location_wizard/wizard.py:162
 msgid "Invalid location name"
@@ -1381,12 +1338,8 @@
 msgstr "Kann die Location nicht erzeugen"
 #: ../gui/wxpython/location_wizard/wizard.py:205
-msgid ""
-"Title of the location is limited only to one line and 256 characters. The "
-"rest of the text will be ignored."
-msgstr ""
-"Der Titel der Location ist auf eine Zeile und 256 Zeichen beschränkt. Der "
-"Rest des Textes wird ignoriert."
+msgid "Title of the location is limited only to one line and 256 characters. The rest of the text will be ignored."
+msgstr "Der Titel der Location ist auf eine Zeile und 256 Zeichen beschränkt. Der Rest des Textes wird ignoriert."
 #: ../gui/wxpython/location_wizard/wizard.py:212
 msgid "Choose method for creating a new location"
@@ -1402,20 +1355,15 @@
 #: ../gui/wxpython/location_wizard/wizard.py:224
 msgid "Read projection and datum terms from a georeferenced data file"
-msgstr ""
-"Einlesen von Projektions- und Datumsinformationen aus georeferenzierter Datei"
+msgstr "Einlesen von Projektions- und Datumsinformationen aus georeferenzierter Datei"
 #: ../gui/wxpython/location_wizard/wizard.py:227
-#, fuzzy
 msgid "Read projection and datum terms from a Well Known Text (WKT) .prj file"
-msgstr ""
-"Einlesen von Projektions- und Datumsinformationen aus WKT oder PRJ Datei"
+msgstr "Lese Projektions- und Datumsinformationen aus Well Known Text (WKT) .prj-Datei"
 #: ../gui/wxpython/location_wizard/wizard.py:230
 msgid "Specify projection and datum terms using custom PROJ.4 parameters"
-msgstr ""
-"Angabe von Projektions- und Datumsinformationen über anwendungsspezifische "
-"PROJ.4 Parameter"
+msgstr "Angabe von Projektions- und Datumsinformationen über anwendungsspezifische PROJ.4 Parameter"
 #: ../gui/wxpython/location_wizard/wizard.py:233
 msgid "Create a generic Cartesian coordinate system (XY)"
@@ -1548,8 +1496,7 @@
 #: ../gui/wxpython/location_wizard/wizard.py:1468
 msgid "Choose method of specifying georeferencing parameters"
-msgstr ""
-"Wählen Sie eine Methode, um die Parameter der Georeferenzierung zuwählen"
+msgstr "Wählen Sie eine Methode, um die Parameter der Georeferenzierung zuwählen"
 #: ../gui/wxpython/location_wizard/wizard.py:1476
 msgid "Enter PROJ.4 parameters string:"
@@ -1619,8 +1566,7 @@
 #: ../gui/wxpython/location_wizard/wizard.py:1884
 msgid "Location wizard canceled. Location not created."
-msgstr ""
-"Location-Assistent wurde abgebrochen. Die Location wurde nicht erzeugt."
+msgstr "Location-Assistent wurde abgebrochen. Die Location wurde nicht erzeugt."
 #: ../gui/wxpython/location_wizard/wizard.py:1991
 msgid "Unable to create new location"
@@ -1628,12 +1574,8 @@
 #: ../gui/wxpython/location_wizard/wizard.py:2010
 #, python-format
-msgid ""
-"Location <%(loc)s> will be created in GIS data directory <%(dir)s>. You will "
-"need to change the default GIS data directory in the GRASS startup screen."
-msgstr ""
-"Die Location <%(loc)s> wird im GIS-Verzeichnis <%(dir)s> angelegt. Sie "
-"müssen das Standard GIS-Verzeichnis auf dem GRASS Startbildschirm anpassen."
+msgid "Location <%(loc)s> will be created in GIS data directory <%(dir)s>. You will need to change the default GIS data directory in the GRASS startup screen."
+msgstr "Die Location <%(loc)s> wird im GIS-Verzeichnis <%(dir)s> angelegt. Sie müssen das Standard GIS-Verzeichnis auf dem GRASS Startbildschirm anpassen."
 #: ../gui/wxpython/location_wizard/wizard.py:2015
 msgid "New GIS data directory"
@@ -1671,9 +1613,7 @@
 #: ../gui/wxpython/core/render.py:421
 msgid "GISBASE not set. You must be in GRASS GIS to run this program."
-msgstr ""
-"GISBASE wurde nicht gesetzt. Sie müssen in GRASS GIS sein, um dieses "
-"Programm auszuführen."
+msgstr "GISBASE wurde nicht gesetzt. Sie müssen in GRASS GIS sein, um dieses Programm auszuführen."
 #: ../gui/wxpython/core/render.py:434 ../gui/wxpython/gui_core/mapdisp.py:84
 #, python-format
@@ -1683,8 +1623,7 @@
 #: ../gui/wxpython/core/render.py:466
 #, python-format
 msgid "Error: Unable to open '%(file)s'. Reason: %(ret)s. wxGUI exited.\n"
-msgstr ""
-"Fehler: Unable to open '%(file)s'. Begründung: %(ret)s. wxGUI exited.\n"
+msgstr "Fehler: Unable to open '%(file)s'. Begründung: %(ret)s. wxGUI exited.\n"
 #: ../gui/wxpython/core/render.py:566
 #, python-format
@@ -1707,13 +1646,8 @@
 msgstr "Kann nicht auf die Vektorkarte <%s> zoomen."
 #: ../gui/wxpython/core/render.py:647
-msgid ""
-"Unable to get current geographic extent. Force quiting wxGUI. Please "
-"manually run g.region to fix the problem."
-msgstr ""
-"Kann die aktuelle geographische Ausdehnung nicht ermitteln. Erzwinge das "
-"Schließen von wxGUI. Führen Sie bitte g.region manuell aus, um das Problem "
-"zu beheben."
+msgid "Unable to get current geographic extent. Force quiting wxGUI. Please manually run g.region to fix the problem."
+msgstr "Kann die aktuelle geographische Ausdehnung nicht ermitteln. Erzwinge das Schließen von wxGUI. Führen Sie bitte g.region manuell aus, um das Problem zu beheben."
 #: ../gui/wxpython/core/render.py:930
 #, python-format
@@ -1771,8 +1705,7 @@
 "\n"
 "Number of skipped lines: %(line)d"
 msgstr ""
-"Einige Zeilen wurden beim Lesen der Einstellungen aus Datei <%(file)s> "
-"übersprungen.\n"
+"Einige Zeilen wurden beim Lesen der Einstellungen aus Datei <%(file)s> übersprungen.\n"
 "Siehe 'Befehlsausgabe' Fenster für Einzelheiten.\n"
 "\n"
 "Anzahl übersprungener Zeilen: %(line)d"
@@ -1890,8 +1823,7 @@
 "\t\tDetails: %(detail)s\n"
 "\t\tLine: '%(line)s'\n"
 msgstr ""
-"Fehler: Das Lesen der Einstellungen aus Datei <%(file)s> ist "
-"fehlgeschlagen.\n"
+"Fehler: Das Lesen der Einstellungen aus Datei <%(file)s> ist fehlgeschlagen.\n"
 "\t\tEinzelheiten: %(detail)s\n"
 "\t\tZeile: '%(line)s'\n"
@@ -1940,11 +1872,9 @@
 msgstr "Kann Datei '%s' nicht öffnen.\n"
 #: ../gui/wxpython/core/utils.py:852
+#, python-format
 msgid "%(env)s: line skipped - unable to parse Reason: %(e)s\n"
-msgstr ""
-"%s: Zeilen übersprungen - kann '%s' nicht interpretieren\n"
-"Grund: %s\n"
+msgstr "%(env)s: Zeilen übersprungen - Grund für Interpretationsfehler: %(e)s\n"
 #: ../gui/wxpython/core/utils.py:858
 #, python-format
@@ -1985,9 +1915,8 @@
 msgstr "Position ist angegeben:"
 #: ../gui/wxpython/psmap/dialogs.py:221
-#, fuzzy
 msgid "relative to paper"
-msgstr "in Bezug auf Papier"
+msgstr "bezogen auf Papier"
 #: ../gui/wxpython/psmap/dialogs.py:222
 msgid "by map coordinates"
@@ -2855,9 +2784,7 @@
 #: ../gui/wxpython/psmap/frame.py:232
 msgid "Program ps2pdf is not available. Please install it first to create PDF."
-msgstr ""
-"Das Programm ps2pdf ist nicht vorhanden. Bitte installieren Sie es um PDFs "
-"zu erzeugen."
+msgstr "Das Programm ps2pdf ist nicht vorhanden. Bitte installieren Sie es um PDFs zu erzeugen."
 #: ../gui/wxpython/psmap/frame.py:276
 msgid "Generating PDF..."
@@ -2877,9 +2804,9 @@
 msgstr "Ps.map beendet mit Rückgabewert %s"
 #: ../gui/wxpython/psmap/frame.py:320
+#, python-format
 msgid "%(prg)s exited with return code %(code)s"
-msgstr "ps2pdf beendet mit Rückgabewert %s"
+msgstr "%(prg)s beendet mit Rückgabewert %(code)s"
 #: ../gui/wxpython/psmap/frame.py:323
 msgid "PDF generated"
@@ -2892,8 +2819,7 @@
 "\n"
 " %s"
 msgstr ""
-"zu erzeugen.\n"
+"Das Programm ps2pdf ist nicht vorhanden. Bitte installieren Sie es um PDFs zu erzeugen.\n"
 "\n"
 " %s"
@@ -2936,9 +2862,7 @@
 #: ../gui/wxpython/psmap/frame.py:1028
 msgid "Press button with green triangle icon to generate preview."
-msgstr ""
-"Bitte klicken Sie auf den Button mit dem grünen Dreieck um Vorschau zu "
-"erzeugen."
+msgstr "Bitte klicken Sie auf den Button mit dem grünen Dreieck um Vorschau zu erzeugen."
 #: ../gui/wxpython/psmap/frame.py:1055
 msgid "wxGUI Cartographic Composer"
@@ -3018,8 +2942,7 @@
 "Map frame position changed, old value: %(old1)s %(old2)s\n"
 "new value: %(new1)s %(new2)s"
 msgstr ""
-"Position des Kartenausschnitts hat sich geändert, alter Wert: %(old1)s "
-"%(old2)s\n"
+"Position des Kartenausschnitts hat sich geändert, alter Wert: %(old1)s %(old2)s\n"
 "neuer Wert: %(new1)s %(new2)s"
 #: ../gui/wxpython/psmap/instructions.py:637
@@ -3028,8 +2951,7 @@
 "Map frame size changed, old value: %(old1)s %(old2)s\n"
 msgstr ""
-"Größe des Kartenausschnitts hat sich geändert, alter Wert: %(old1)s "
-"%(old2)s\n"
+"Größe des Kartenausschnitts hat sich geändert, alter Wert: %(old1)s %(old2)s\n"
 #: ../gui/wxpython/psmap/instructions.py:684
@@ -3049,27 +2971,18 @@
 #: ../gui/wxpython/psmap/instructions.py:811
 #: ../gui/wxpython/psmap/instructions.py:1693
 #, python-format
-msgid ""
-"Characters on position %s are not supported by ISO-8859-1 (Latin 1) encoding "
-"which is required by module ps.map."
-msgstr ""
-"Zeichen in der Position %s werden nicht von der Zeichenkodierung ISO-8859-1 "
-"(Latin 1), welche vom Modul benötigt wird, unterstützt."
+msgid "Characters on position %s are not supported by ISO-8859-1 (Latin 1) encoding which is required by module ps.map."
+msgstr "Zeichen in der Position %s werden nicht von der Zeichenkodierung ISO-8859-1 (Latin 1), welche vom Modul benötigt wird, unterstützt."
 #: ../gui/wxpython/psmap/instructions.py:815
 #: ../gui/wxpython/psmap/instructions.py:1697
-msgid ""
-"Not all characters are supported by ISO-8859-1 (Latin 1) encoding which is "
-"required by module ps.map."
-msgstr ""
-"Nicht alle Zeichen werden von der Zeichenkodierung ISO-8859-1 (Latin 1), "
-"welche von dem Modul ps.map benötigt wird."
+msgid "Not all characters are supported by ISO-8859-1 (Latin 1) encoding which is required by module ps.map."
+msgstr "Nicht alle Zeichen werden von der Zeichenkodierung ISO-8859-1 (Latin 1), welche von dem Modul ps.map benötigt wird."
 #: ../gui/wxpython/psmap/instructions.py:931
 #, python-format
 msgid "Failed to read instruction %(inst)s: file %(file)s not found."
-msgstr ""
-"Lesen der Anweisungen %(inst)s fehlgeschlagen: Datei %(file)s nicht gefunden."
+msgstr "Lesen der Anweisungen %(inst)s fehlgeschlagen: Datei %(file)s nicht gefunden."
 #: ../gui/wxpython/psmap/utils.py:92
 msgid "inch"
@@ -3207,9 +3120,9 @@
 msgstr "Starte Kartenfenster <%s>..."
 #: ../gui/wxpython/mapdisp/main.py:124
+#, python-format
 msgid "GRASS GIS %(version)s Map Display: %(name)s - Location: %(location)s"
-msgstr "GRASS GIS Kartenfenster: %(name)s  - Location: %(loc)s"
+msgstr "GRASS GIS %(version)s Kartenfenster: %(name)s  - Location: %(location)s"
 #: ../gui/wxpython/mapdisp/main.py:131
 #, python-format
@@ -3224,8 +3137,7 @@
 #: ../gui/wxpython/mapdisp/mapwindow.py:1123
 #: ../gui/wxpython/nviz/mapwindow.py:805
 msgid "Querying is not implemented in standalone mode of Map Display"
-msgstr ""
-"Abfragen sind in der 'stand alone' Version des Kartenfensters nicht umgesetzt"
+msgstr "Abfragen sind in der 'stand alone' Version des Kartenfensters nicht umgesetzt"
 #: ../gui/wxpython/mapdisp/mapwindow.py:1613
 msgid "Zoom to saved region extents"
@@ -3286,8 +3198,7 @@
 "Details: %s"
 msgstr ""
 "Kann nicht in 3D Modus wechseln.\n"
-"Die Nviz Python Erweiterung wurde nicht gefunden oder nicht korrekt "
-"geladen.\n"
+"Die Nviz Python Erweiterung wurde nicht gefunden oder nicht korrekt geladen.\n"
 "Schalte zurück auf 2D Modus.\n"
 "\n"
 "Einzelheiten: %s"
@@ -3420,14 +3331,8 @@
 msgstr "Zeige den Arbeitsbereich"
 #: ../gui/wxpython/mapdisp/statusbar.py:392
-msgid ""
-"Show/hide computational region extent (set with g.region). Display region "
-"drawn as a blue box inside the computational region, computational region "
-"inside a display region as a red box)."
-msgstr ""
-"Zeige/verberge den Arbeitsbereich (mit g.region definiert). Zeige die Region "
-"als blaues Rechteck im Arbeitsbereich und den Arbeitsbereich als rotes "
-"Rechteck im Kartenfenster."
+msgid "Show/hide computational region extent (set with g.region). Display region drawn as a blue box inside the computational region, computational region inside a display region as a red box)."
+msgstr "Zeige/verberge den Arbeitsbereich (mit g.region definiert). Zeige die Region als blaues Rechteck im Arbeitsbereich und den Arbeitsbereich als rotes Rechteck im Kartenfenster."
 #: ../gui/wxpython/mapdisp/statusbar.py:432
 msgid "Display mode"
@@ -3439,12 +3344,8 @@
 msgstr "Richte Ausdehnung der Region an Fenstergröße aus"
 #: ../gui/wxpython/mapdisp/statusbar.py:439
-msgid ""
-"Align region extent based on display size from center point. Default value "
-"for new map displays can be set up in 'User GUI settings' dialog."
-msgstr ""
-"Richte Arbeitsbereich am Kartenfenster aus. Standardwert für neue "
-"Kartenfenster kann in 'GUI Einstellungen' definiert werden."
+msgid "Align region extent based on display size from center point. Default value for new map displays can be set up in 'User GUI settings' dialog."
+msgstr "Richte Arbeitsbereich am Kartenfenster aus. Standardwert für neue Kartenfenster kann in 'GUI Einstellungen' definiert werden."
 #: ../gui/wxpython/mapdisp/statusbar.py:452
 msgid "Display resolution"
@@ -3453,30 +3354,19 @@
 #: ../gui/wxpython/mapdisp/statusbar.py:455
 #: ../gui/wxpython/gui_core/preferences.py:700
 msgid "Constrain display resolution to computational settings"
-msgstr ""
-"Beschränke die Auflösung des Kartenfensters auf die Einstellungen des "
-"Arbeitsbereichs."
+msgstr "Beschränke die Auflösung des Kartenfensters auf die Einstellungen des Arbeitsbereichs."
 #: ../gui/wxpython/mapdisp/statusbar.py:459
-msgid ""
-"Constrain display resolution to computational region settings. Default value "
-msgstr ""
-"Arbeitsbereichs. Standardwert für neue Kartenfenster kann in 'GUI "
-"Einstellungen' definiert werden. "
+msgid "Constrain display resolution to computational region settings. Default value for new map displays can be set up in 'User GUI settings' dialog."
+msgstr "Beschränke die Auflösung des Kartenfensters auf die Einstellungen des Arbeitsbereichs. Standardwert für neue Kartenfenster kann in 'GUI Einstellungen' definiert werden. "
 #: ../gui/wxpython/mapdisp/statusbar.py:483
 msgid "Map scale"
 msgstr "Kartenmaßstab"
 #: ../gui/wxpython/mapdisp/statusbar.py:497
-msgid ""
-"As everyone's monitors and resolutions are set differently these values are "
-"not true map scales, but should get you into the right neighborhood."
-msgstr ""
-"Da die Bildschirmauflösungen an jedem Arbeitsplatz unterschiedlich sind, "
-"können die Maßstabsangaben nicht exakt sein. Die Größenordnung wird stimmen."
+msgid "As everyone's monitors and resolutions are set differently these values are not true map scales, but should get you into the right neighborhood."
+msgstr "Da die Bildschirmauflösungen an jedem Arbeitsplatz unterschiedlich sind, können die Maßstabsangaben nicht exakt sein. Die Größenordnung wird stimmen."
 #: ../gui/wxpython/mapdisp/statusbar.py:550
 msgid "Go to"
@@ -3505,12 +3395,8 @@
 msgstr "Verwende definierte Projektion"
 #: ../gui/wxpython/mapdisp/statusbar.py:695
-msgid ""
-"Reproject coordinates displayed in the statusbar. Projection can be defined "
-"in GUI preferences dialog (tab 'Projection')"
-msgstr ""
-"Umprojezierte Koordinaten in der Statusleiste angezeigt. Die Projektion kann "
-"in GUI Einstellungen (Reiter 'Projektion') definiert werden."
+msgid "Reproject coordinates displayed in the statusbar. Projection can be defined in GUI preferences dialog (tab 'Projection')"
+msgstr "Umprojezierte Koordinaten in der Statusleiste angezeigt. Die Projektion kann in GUI Einstellungen (Reiter 'Projektion') definiert werden."
 #: ../gui/wxpython/mapdisp/statusbar.py:720
 msgid "MASK"
@@ -3603,11 +3489,8 @@
 msgstr "Fly-through Modus"
 #: ../gui/wxpython/mapdisp/toolbars.py:57
-msgid ""
-"Drag with mouse, hold Ctrl down for different mode or Shift to accelerate"
-msgstr ""
-"Mit der Maus verschieben. Strg-Taste ändert den Modus und Umschalttaste "
-"beschleunigt."
+msgid "Drag with mouse, hold Ctrl down for different mode or Shift to accelerate"
+msgstr "Mit der Maus verschieben. Strg-Taste ändert den Modus und Umschalttaste beschleunigt."
 #: ../gui/wxpython/mapdisp/toolbars.py:59
 msgid "Click mouse to zoom"
@@ -3632,15 +3515,8 @@
 msgstr "Grund: %s"
 #: ../gui/wxpython/mapdisp/toolbars.py:90
-msgid ""
-"Note that the wxGUI's 3D view mode is currently disabled on MS Windows "
-"(hopefully this will be fixed soon). Please keep an eye out for updated "
-"versions of GRASS. In the meantime you can use \"NVIZ\" from the File menu."
-msgstr ""
-"3D-Ansicht-Modus derzeit unter MS Windows nicht aktiviert (dies wird "
-"hoffentlich bald behoben sein). Bitte achten Sie auf aktualisierte Versionen "
-"von GRASS. In der Zwischenzeit können Sie \"NVIZ\" unter File menue "
-"verwenden."
+msgid "Note that the wxGUI's 3D view mode is currently disabled on MS Windows (hopefully this will be fixed soon). Please keep an eye out for updated versions of GRASS. In the meantime you can use \"NVIZ\" from the File menu."
+msgstr "3D-Ansicht-Modus derzeit unter MS Windows nicht aktiviert (dies wird hoffentlich bald behoben sein). Bitte achten Sie auf aktualisierte Versionen von GRASS. In der Zwischenzeit können Sie \"NVIZ\" unter File menue verwenden."
 #: ../gui/wxpython/mapdisp/toolbars.py:98
 #: ../gui/wxpython/vdigit/toolbars.py:695
@@ -3652,15 +3528,8 @@
 msgstr "Vektordigitalisierer nicht vorhanden"
 #: ../gui/wxpython/mapdisp/toolbars.py:107
-msgid ""
-"Note that the wxGUI's vector digitizer is currently disabled (hopefully this "
-"will be fixed soon). Please keep an eye out for updated versions of GRASS. "
-"In the meantime you can use \"v.digit\" from the Develop Vector menu."
-msgstr ""
-"Beachten Sie, dass der Vektordigitalisierer derzeit unter MS Windows nicht "
-"funktioniert (dieses wird hoffentlich bald behoben sein). Bitte achten Sie "
-"auf aktualisierte Versionen von GRASS. In der Zwischenzeit können Sie \"v."
-"digit\" aus dem Menü \"Vektor\" - \"Vektorkarten pflegen\" verwenden."
+msgid "Note that the wxGUI's vector digitizer is currently disabled (hopefully this will be fixed soon). Please keep an eye out for updated versions of GRASS. In the meantime you can use \"v.digit\" from the Develop Vector menu."
+msgstr "Beachten Sie, dass der Vektordigitalisierer derzeit unter MS Windows nicht funktioniert (dieses wird hoffentlich bald behoben sein). Bitte achten Sie auf aktualisierte Versionen von GRASS. In der Zwischenzeit können Sie \"v.digit\" aus dem Menü \"Vektor\" - \"Vektorkarten pflegen\" verwenden."
 #: ../gui/wxpython/nviz/tools.py:83 ../gui/wxpython/nviz/preferences.py:55
 #: ../gui/wxpython/nviz/preferences.py:60
@@ -3701,12 +3570,8 @@
 msgstr "Neigung:"
 #: ../gui/wxpython/nviz/tools.py:263
-msgid ""
-"Adjusts the viewing height above the surface (angle of view automatically "
-"adjusts to maintain the same center of view)"
-msgstr ""
-"Passt die Höhe des Blickpunktes über der Oberfläche an (der Blickwinkel wird "
-"automatisch adjustiert, um das Bildzentrum zu erhalten) "
+msgid "Adjusts the viewing height above the surface (angle of view automatically adjusts to maintain the same center of view)"
+msgstr "Passt die Höhe des Blickpunktes über der Oberfläche an (der Blickwinkel wird automatisch adjustiert, um das Bildzentrum zu erhalten) "
 #: ../gui/wxpython/nviz/tools.py:268
 msgid "Adjusts the relative height of features above the plane of the surface"
@@ -3725,12 +3590,8 @@
 msgstr "hier"
 #: ../gui/wxpython/nviz/tools.py:301
-msgid ""
-"Allows you to select a point on the surface that becomes the new center of "
-"view. Click on the button and then on the surface."
-msgstr ""
-"Erlaubt Ihnen ein neues Zentrum der Ansicht zu wählen. Klicken Sie zunächst "
-"auf den Button und dann auf die Oberfläche."
+msgid "Allows you to select a point on the surface that becomes the new center of view. Click on the button and then on the surface."
+msgstr "Erlaubt Ihnen ein neues Zentrum der Ansicht zu wählen. Klicken Sie zunächst auf den Button und dann auf die Oberfläche."
 #: ../gui/wxpython/nviz/tools.py:307
 msgid "center"
@@ -3745,12 +3606,8 @@
 msgstr "oben"
 #: ../gui/wxpython/nviz/tools.py:317
-msgid ""
-"Sets the viewer directly over the scene's center position. This top view "
-"orients approximately north south."
-msgstr ""
-"Ansicht direkt von oben über dem Zentrum. Die Ansicht ist ungefähr in Nord-"
-"Süd-Richtung."
+msgid "Sets the viewer directly over the scene's center position. This top view orients approximately north south."
+msgstr "Ansicht direkt von oben über dem Zentrum. Die Ansicht ist ungefähr in Nord-Süd-Richtung."
 #: ../gui/wxpython/nviz/tools.py:321
 msgid "reset"
@@ -3770,13 +3627,8 @@
 msgstr "Hintergrundfarbe: "
 #: ../gui/wxpython/nviz/tools.py:384
-msgid ""
-"Press 'Record' button and start changing the view. It is recommended to use "
-"fly-through mode (Map Display toolbar) to achieve smooth motion."
-msgstr ""
-"Klicken Sie auf den 'Aufnehmen' Button und beginnen Sie die Ansicht zu "
-"verändern. Es ist empfehlenswert den fly-through Modus zu verwenden um "
-"flüssige Bewegungen zu erhalten."
+msgid "Press 'Record' button and start changing the view. It is recommended to use fly-through mode (Map Display toolbar) to achieve smooth motion."
+msgstr "Klicken Sie auf den 'Aufnehmen' Button und beginnen Sie die Ansicht zu verändern. Es ist empfehlenswert den fly-through Modus zu verwenden um flüssige Bewegungen zu erhalten."
 #: ../gui/wxpython/nviz/tools.py:395
 msgid "Record"
@@ -3819,10 +3671,8 @@
 msgstr "Datei-Präfix:"
 #: ../gui/wxpython/nviz/tools.py:482
-msgid ""
-"Generated files names will look like this: prefix_1.ppm, prefix_2.ppm, ..."
-msgstr ""
-"Erzeugte Dateinamen haben folgendes Muster: prefix_1.ppm, prefix_2.ppm, ..."
+msgid "Generated files names will look like this: prefix_1.ppm, prefix_2.ppm, ..."
+msgstr "Erzeugte Dateinamen haben folgendes Muster: prefix_1.ppm, prefix_2.ppm, ..."
 #: ../gui/wxpython/nviz/tools.py:483
 msgid "File format:"
@@ -4025,12 +3875,8 @@
 msgstr "Rotiert die aktuelle Schnittfläche um die horizontale Achse"
 #: ../gui/wxpython/nviz/tools.py:1037
-msgid ""
-"Sets the Z coordinate of the current cutting plane (only meaningful when "
-"tilt is not 0)"
-msgstr ""
-"Bestimmt die Z-Koordinate der aktuellen Schnittfläche (nur sinnvoll wenn die "
-"Neigung nicht 0 ist)"
+msgid "Sets the Z coordinate of the current cutting plane (only meaningful when tilt is not 0)"
+msgstr "Bestimmt die Z-Koordinate der aktuellen Schnittfläche (nur sinnvoll wenn die Neigung nicht 0 ist)"
 #: ../gui/wxpython/nviz/tools.py:1089 ../gui/wxpython/menustrings.py:4
 #: ../gui/wxpython/menustrings.py:858
@@ -4205,8 +4051,7 @@
 #: ../gui/wxpython/nviz/tools.py:1963
 msgid "Do you want to record new animation without saving the previous one?"
-msgstr ""
-"Wollen Sie eine neue Animation aufzeichnen ohne die vorherige zu speichern?"
+msgstr "Wollen Sie eine neue Animation aufzeichnen ohne die vorherige zu speichern?"
 #: ../gui/wxpython/nviz/tools.py:1966
 msgid "Animation already axists"
@@ -4372,12 +4217,8 @@
 msgstr "Passt Entfernung und Richtung des Betrachters an"
 #: ../gui/wxpython/nviz/tools.py:4902
-msgid ""
-"Adjusts the light direction. Click and drag the puck to change the light "
-"direction."
-msgstr ""
-"Passt die Richtung der Beleuchtung an. Verschieben Sie die Scheibe um die "
-"Richtung zu ändern."
+msgid "Adjusts the light direction. Click and drag the puck to change the light direction."
+msgstr "Passt die Richtung der Beleuchtung an. Verschieben Sie die Scheibe um die Richtung zu ändern."
 #: ../gui/wxpython/nviz/preferences.py:31
 msgid "3D view settings"
@@ -4385,8 +4226,7 @@
 #: ../gui/wxpython/nviz/preferences.py:48
 msgid "Revert settings to default, changes are not applied"
-msgstr ""
-"Kehre zu den Standardeinstellungen zurück und wende die Änderungen nicht an"
+msgstr "Kehre zu den Standardeinstellungen zurück und wende die Änderungen nicht an"
 #: ../gui/wxpython/nviz/preferences.py:71
 #: ../gui/wxpython/nviz/preferences.py:134
@@ -4450,21 +4290,13 @@
 msgstr "Einstellungen für 3D-Ansicht gespeichert in Datei <%s>."
 #: ../gui/wxpython/nviz/mapwindow.py:207
-msgid ""
-"Opening 3D view was not successful. Please try to change the value of depth "
-"buffer in GUI Settings dialog > tab Map Display > Advanced and restart GUI."
-msgstr ""
-"Öffnen der 3D-Ansicht war nicht erfolgreich. Ändere den Wert des "
-"Tiefenbuffers in den GUI-Einstellungen > Map Display > Fortgeschritten und "
-"erneuter GUI-Start."
+msgid "Opening 3D view was not successful. Please try to change the value of depth buffer in GUI Settings dialog > tab Map Display > Advanced and restart GUI."
+msgstr "Öffnen der 3D-Ansicht war nicht erfolgreich. Ändere den Wert des Tiefenpuffers in den GUI-Einstellungen > Map Display > Fortgeschritten und erneuter GUI-Start."
 #: ../gui/wxpython/nviz/mapwindow.py:543
 #, python-format
-msgid ""
-"Image is too large, your OpenGL implementation supports maximum texture size "
-"%d px."
-msgstr ""
-"Bild ist zu groß. Ihr OpenGL unterstützt maximal Texturen der Größe %d px."
+msgid "Image is too large, your OpenGL implementation supports maximum texture size %d px."
+msgstr "Bild ist zu groß. Ihr OpenGL unterstützt maximal Texturen der Größe %d px."
 #: ../gui/wxpython/nviz/mapwindow.py:1039
 msgid "Easting"
@@ -4699,9 +4531,9 @@
 msgstr "Einstellungen vornehmen"
 #: ../gui/wxpython/lmgr/layertree.py:161
+#, python-format
 msgid "GRASS GIS %(version)s Map Display: %(id)d  - Location: %(loc)s"
-msgstr "GRASS GIS Kartenfenster: %(id)d  - Location: %(loc)s"
+msgstr "GRASS GIS %(version)s Kartenfenster: %(id)d  - Location: %(loc)s"
 #: ../gui/wxpython/lmgr/layertree.py:172
 msgid "Map Layers"
@@ -4761,8 +4593,7 @@
 #: ../gui/wxpython/lmgr/layertree.py:446
 msgid "Set computational region from selected map(s) (ignore NULLs)"
-msgstr ""
-"Arbeitsbereich auf Grundlage selektierter Karte setzen (ignoriere NULLwerte)"
+msgstr "Arbeitsbereich auf Grundlage selektierter Karte setzen (ignoriere NULLwerte)"
 #: ../gui/wxpython/lmgr/layertree.py:458 ../gui/wxpython/menustrings.py:717
 msgid "Histogram"
@@ -4782,9 +4613,7 @@
 #: ../gui/wxpython/lmgr/layertree.py:590
 msgid "Unable to display histogram of raster map. No map name defined."
-msgstr ""
-"Kann das Histogramm der Rasterkarte nicht anzeigen. Kein Kartenname "
-"angegeben."
+msgstr "Kann das Histogramm der Rasterkarte nicht anzeigen. Kein Kartenname angegeben."
 #: ../gui/wxpython/lmgr/layertree.py:670
 #, python-format
@@ -4868,9 +4697,9 @@
 msgstr "Karte <%s> nicht gefunden."
 #: ../gui/wxpython/lmgr/frame.py:83
+#, python-format
 msgid "GRASS GIS %s Layer Manager"
-msgstr "GRASS GIS Ebenen-Manager"
+msgstr "GRASS GIS %s Ebenen-Manager"
 #: ../gui/wxpython/lmgr/frame.py:121
 msgid "Workspace Toolbar"
@@ -4944,8 +4773,7 @@
 #: ../gui/wxpython/lmgr/frame.py:362 ../gui/wxpython/gis_set.py:442
 msgid "Do you want to set the default region extents and resolution now?"
-msgstr ""
-"Möchten Sie nun die Ausdehnung und Auflösung der Standardregion eingeben?"
+msgstr "Möchten Sie nun die Ausdehnung und Auflösung der Standardregion eingeben?"
 #: ../gui/wxpython/lmgr/frame.py:364 ../gui/wxpython/gis_set.py:444
 #, python-format
@@ -4962,8 +4790,7 @@
 #: ../gui/wxpython/lmgr/frame.py:474 ../gui/wxpython/lmgr/frame.py:1795
 msgid "Do you want to store current settings to workspace file?"
-msgstr ""
-"Wollen Sie die aktuellen Einstellungen in einer Projektdatei speichern?"
+msgstr "Wollen Sie die aktuellen Einstellungen in einer Projektdatei speichern?"
 #: ../gui/wxpython/lmgr/frame.py:482
 #, python-format
@@ -4993,12 +4820,8 @@
 #: ../gui/wxpython/lmgr/frame.py:623
 #, python-format
-msgid ""
-"Script <%s> is not executable. Do you want to set the permissions that "
-"allows you to run this script (note that you must be the owner of the file)?"
-msgstr ""
-"Skript <%s> ist nicht ausführbar. Wollen Sie die Berechtigung der Datei "
-"ändern (Sie müssen dafür Eigentümer der Datei sein)?"
+msgid "Script <%s> is not executable. Do you want to set the permissions that allows you to run this script (note that you must be the owner of the file)?"
+msgstr "Skript <%s> ist nicht ausführbar. Wollen Sie die Berechtigung der Datei ändern (Sie müssen dafür Eigentümer der Datei sein)?"
 #: ../gui/wxpython/lmgr/frame.py:628
 msgid "Set permission?"
@@ -5010,12 +4833,8 @@
 #: ../gui/wxpython/lmgr/frame.py:648
 #, python-format
-msgid ""
-"Directory '%s' is not defined in GRASS_ADDON_PATH. Do you want add this "
-"directory to GRASS_ADDON_PATH?"
-msgstr ""
-"Verzeichnis '%s' ist nicht im GRASS_ADDON_PATH. Möchten Sie das Verzeichnis "
-"zum GRASS_ADDON_PATH hinzufügen?"
+msgid "Directory '%s' is not defined in GRASS_ADDON_PATH. Do you want add this directory to GRASS_ADDON_PATH?"
+msgstr "Verzeichnis '%s' ist nicht im GRASS_ADDON_PATH. Möchten Sie das Verzeichnis zum GRASS_ADDON_PATH hinzufügen?"
 #: ../gui/wxpython/lmgr/frame.py:651
 msgid "Update Addons path?"
@@ -5065,12 +4884,8 @@
 msgstr "Platform"
 #: ../gui/wxpython/lmgr/frame.py:836
-msgid ""
-"Current workspace is not empty. Do you want to store current settings to "
-"workspace file?"
-msgstr ""
-"Aktuelles Projekt ist nicht leer. Wollen Sie die aktuellen Einstellungen in "
-"einer Projektdatei speichern?"
+msgid "Current workspace is not empty. Do you want to store current settings to workspace file?"
+msgstr "Aktuelles Projekt ist nicht leer. Wollen Sie die aktuellen Einstellungen in einer Projektdatei speichern?"
 #: ../gui/wxpython/lmgr/frame.py:839
 msgid "Create new workspace?"
@@ -5112,8 +4927,7 @@
 #: ../gui/wxpython/lmgr/frame.py:1072 ../gui/wxpython/lmgr/frame.py:1088
 #, python-format
 msgid "Workspace file <%s> already exists. Do you want to overwrite this file?"
-msgstr ""
-"Projektdatei <%s> existiert bereits. Wollen Sie die Datei überschreiben?"
+msgstr "Projektdatei <%s> existiert bereits. Wollen Sie die Datei überschreiben?"
 #: ../gui/wxpython/lmgr/frame.py:1074 ../gui/wxpython/lmgr/frame.py:1091
 #: ../gui/wxpython/menustrings.py:9
@@ -5122,17 +4936,15 @@
 #: ../gui/wxpython/lmgr/frame.py:1112
 msgid "Writing current settings to workspace file failed."
-msgstr ""
-"Schreiben der aktuellen Einstellungen in die Workspace-Datei fehlgeschlagen."
+msgstr "Schreiben der aktuellen Einstellungen in die Workspace-Datei fehlgeschlagen."
 #: ../gui/wxpython/lmgr/frame.py:1163
 msgid "Enter new name:"
 msgstr "Geben Sie neuen Namen ein:"
 #: ../gui/wxpython/lmgr/frame.py:1169
-#, fuzzy
 msgid "GRASS GIS %(version) Map Display: %(name)s - Location: %(loc)s"
+msgstr "GRASS GIS %(version) Kartenfenster: %(name)s  - Location: %(loc)s"
 #: ../gui/wxpython/lmgr/frame.py:1383
 msgid "Nothing to import. No WMS layer selected."
@@ -5152,12 +4964,8 @@
 msgstr "Nicht unterstützter Kartenebenentyp <%s>."
 #: ../gui/wxpython/lmgr/frame.py:1648
-msgid ""
-"Note that cell values can only be displayed for regions of less than 10,000 "
-"cells."
-msgstr ""
-"Zellwerte können nur für Regionen mit weniger als 10000 Zellen angezeigt "
-"werden."
+msgid "Note that cell values can only be displayed for regions of less than 10,000 cells."
+msgstr "Zellwerte können nur für Regionen mit weniger als 10000 Zellen angezeigt werden."
 #: ../gui/wxpython/lmgr/frame.py:1730
 #, python-format
@@ -5172,8 +4980,7 @@
 #: ../gui/wxpython/lmgr/frame.py:1733
 msgid "Do you want to remove selected map layer(s) from layer tree?"
-msgstr ""
-"Wollen Sie die selektierten Kartenebene(n) aus der Baumstruktur entfernen?"
+msgstr "Wollen Sie die selektierten Kartenebene(n) aus der Baumstruktur entfernen?"
 #: ../gui/wxpython/lmgr/frame.py:1737
 msgid "Remove map layer"
@@ -5188,14 +4995,8 @@
 msgstr "Keine Kartenebene selektiert. Breche die Operation ab."
 #: ../gui/wxpython/lmgr/frame.py:1843
-msgid ""
-"Display resolution is currently not constrained to computational settings. "
-"It's suggested to constrain map to region geometry. Do you want to constrain "
-"the resolution?"
-msgstr ""
-"Die Auflösung des Kartenfensters stimmt nicht mit dem Arbeitsbereich "
-"überein. Wir schlagen vor, dass Sie das Kartenfenster auf den Arbeitsbereich "
-"beschränken. Wollen Sie die Auflösung beschränken?"
+msgid "Display resolution is currently not constrained to computational settings. It's suggested to constrain map to region geometry. Do you want to constrain the resolution?"
+msgstr "Die Auflösung des Kartenfensters stimmt nicht mit dem Arbeitsbereich überein. Wir schlagen vor, dass Sie das Kartenfenster auf den Arbeitsbereich beschränken. Wollen Sie die Auflösung beschränken?"
 #: ../gui/wxpython/lmgr/frame.py:1852
 msgid "Constrain map to region geometry?"
@@ -5325,9 +5126,7 @@
 #: ../gui/wxpython/lmgr/toolbars.py:231
 msgid "Generate command for m.nviz.image based on current state"
-msgstr ""
-"Erzeugt den Befehl für m.nviz.image auf der Grundlage der aktuellen "
-"Einstellungen"
+msgstr "Erzeugt den Befehl für m.nviz.image auf der Grundlage der aktuellen Einstellungen"
 #: ../gui/wxpython/lmgr/toolbars.py:233
 msgid "3D view mode settings"
@@ -5425,9 +5224,7 @@
 #: ../gui/wxpython/vdigit/preferences.py:56
 msgid "Close dialog and save changes to user settings file"
-msgstr ""
-"Beende den Dialog und speichere die Änderungen in Datei mit "
-"Benutzereinstellungen"
+msgstr "Beende den Dialog und speichere die Änderungen in Datei mit Benutzereinstellungen"
 #: ../gui/wxpython/vdigit/preferences.py:148
 msgid "Snapping"
@@ -5470,11 +5267,8 @@
 msgstr "Selektiere nur Objekte innerhalb der Auswahlbox"
 #: ../gui/wxpython/vdigit/preferences.py:220
-msgid ""
-"By default are selected all features overlapping selection bounding box "
-msgstr ""
-"Standardmäßig sind alle Objekte selektiert die von der Auswahlbox "
-"geschnitten werden "
+msgid "By default are selected all features overlapping selection bounding box "
+msgstr "Standardmäßig sind alle Objekte selektiert die von der Auswahlbox geschnitten werden "
 #: ../gui/wxpython/vdigit/preferences.py:223
 msgid "Check for duplicates"
@@ -5595,12 +5389,8 @@
 msgstr "Umfang"
 #: ../gui/wxpython/vdigit/preferences.py:484
-msgid ""
-"Note: These settings are stored in the workspace not in the vector digitizer "
-"preferences."
-msgstr ""
-"Beachte: Diese Einstellungen werden im Workspace und nicht in den "
-"Einstellungen für die Vektordigitalisierung gespeichert."
+msgid "Note: These settings are stored in the workspace not in the vector digitizer preferences."
+msgstr "Beachte: Diese Einstellungen werden im Workspace und nicht in den Einstellungen für die Vektordigitalisierung gespeichert."
 #: ../gui/wxpython/vdigit/preferences.py:512
 msgid "Digitize new line segment"
@@ -5669,9 +5459,7 @@
 #: ../gui/wxpython/vdigit/preferences.py:598
 #, python-format
 msgid "Snapping threshold is %(value).1f %(units)s (based on comp. resolution)"
-msgstr ""
-"Fangtoleranz ist %(value).1f %(units)s (basiert auf Auflösung des "
-"Arbeitsbereichs)"
+msgstr "Fangtoleranz ist %(value).1f %(units)s (basiert auf Auflösung des Arbeitsbereichs)"
 #: ../gui/wxpython/vdigit/preferences.py:654
 #, python-format
@@ -5697,14 +5485,8 @@
 #: ../gui/wxpython/vdigit/wxdisplay.py:869
 #, python-format
-msgid ""
-"Topology for vector map <%s> is not available. Topology is required by "
-"digitizer. Do you want to rebuild topology (takes some time) and open the "
-"vector map for editing?"
-msgstr ""
-"Die Topologie der Vektorkarte <%s> ist nicht vorhanden. Topologie ist für "
-"den Digitizer erforderlich. Wollen Sie die Topologie erneuern (benötigt "
-"einige Zeit) und die Vektorkarte dann zum Bearbeiten öffnen?"
+msgid "Topology for vector map <%s> is not available. Topology is required by digitizer. Do you want to rebuild topology (takes some time) and open the vector map for editing?"
+msgstr "Die Topologie der Vektorkarte <%s> ist nicht vorhanden. Topologie ist für den Digitizer erforderlich. Wollen Sie die Topologie erneuern (benötigt einige Zeit) und die Vektorkarte dann zum Bearbeiten öffnen?"
 #: ../gui/wxpython/vdigit/wxdisplay.py:873
 msgid "Topology missing"
@@ -5748,11 +5530,8 @@
 #: ../gui/wxpython/vdigit/wxdigit.py:97
 #, python-format
-msgid ""
-"Unable to open database <%(db)s> by driver <%(driver)s>. Operation canceled."
-msgstr ""
-"Kann Datenbank <%(db)s> nicht mit Treiber <%(driver)s> öffnen. Operation "
-"abgebrochen."
+msgid "Unable to open database <%(db)s> by driver <%(driver)s>. Operation canceled."
+msgstr "Kann Datenbank <%(db)s> nicht mit Treiber <%(driver)s> öffnen. Operation abgebrochen."
 #: ../gui/wxpython/vdigit/wxdigit.py:105
 #, python-format
@@ -5794,9 +5573,7 @@
 #: ../gui/wxpython/vdigit/toolbars.py:88 ../gui/wxpython/vdigit/toolbars.py:91
 #: ../gui/wxpython/vdigit/toolbars.py:112
 msgid "Left: new point; Ctrl+Left: undo last point; Right: close line"
-msgstr ""
-"Links: neuer Punkt; Ctrl+Links: letzten Punkt zurücknehmen; Rechts: Linie "
-"beenden"
+msgstr "Links: neuer Punkt; Ctrl+Links: letzten Punkt zurücknehmen; Rechts: Linie beenden"
 #: ../gui/wxpython/vdigit/toolbars.py:90
 msgid "Digitize new boundary"
@@ -5807,12 +5584,8 @@
 msgstr "neues Zentroid digitalisieren"
 #: ../gui/wxpython/vdigit/toolbars.py:96
-msgid ""
-"Digitize new area (composition of boundaries without category and one "
-"centroid with category)"
-msgstr ""
-"Neue Fläche digitalisieren (Flächengrenzen ohne Kategorie und einem Zentroid "
-"mit Kategorie)"
+msgid "Digitize new area (composition of boundaries without category and one centroid with category)"
+msgstr "Neue Fläche digitalisieren (Flächengrenzen ohne Kategorie und einem Zentroid mit Kategorie)"
 #: ../gui/wxpython/vdigit/toolbars.py:99
 msgid "Add new vertex"
@@ -5968,8 +5741,7 @@
 #: ../gui/wxpython/vdigit/toolbars.py:740
 #, python-format
 msgid "Please wait, closing and rebuilding topology of vector map <%s>..."
-msgstr ""
-"Bitte warten Sie, ich erneuere die Topologie schließe die Vektorkarte <%s>..."
+msgstr "Bitte warten Sie, ich erneuere die Topologie schließe die Vektorkarte <%s>..."
 #: ../gui/wxpython/vdigit/toolbars.py:750
 #, python-format
@@ -6059,12 +5831,8 @@
 msgstr "&Location-Assistent"
 #: ../gui/wxpython/gis_set.py:143
-msgid ""
-"Start location wizard. After location is created successfully, GRASS session "
-"is started."
-msgstr ""
-"Starte den Location-Assistenten. Nach der erfolgreichen Einrichtung der "
-"Location wird GRASS gestartet."
+msgid "Start location wizard. After location is created successfully, GRASS session is started."
+msgstr "Starte den Location-Assistenten. Nach der erfolgreichen Einrichtung der Location wird GRASS gestartet."
 #: ../gui/wxpython/gis_set.py:147
 msgid "Rename mapset"
@@ -6092,9 +5860,7 @@
 #: ../gui/wxpython/gis_set.py:214 ../gui/wxpython/gis_set.py:655
 msgid "Unable to set GRASS database. Check your locale settings."
-msgstr ""
-"Kann die GRASS Datenbank nicht setzten. Bitte überprüfen Sie ihre lokalen "
-"Einstellungen."
+msgstr "Kann die GRASS Datenbank nicht setzten. Bitte überprüfen Sie ihre lokalen Einstellungen."
 #: ../gui/wxpython/gis_set.py:232
 #, python-format
@@ -6107,18 +5873,14 @@
 msgstr "FEHLER: Mapset <%s> nicht gefunden."
 #: ../gui/wxpython/gis_set.py:383
+#, python-format
 msgid "Invalid line in GISRC file (%(e)s):%(l)s\n"
-msgstr "Fehlerhafte Zeile in GISRC Datei (%s):%s\n"
+msgstr "Fehlerhafte Zeile in GISRC Datei (%(e)s):%(l)s\n"
 #: ../gui/wxpython/gis_set.py:412
 #, python-format
-msgid ""
-"Do you want to import data source <%(name)s> to created location? Default "
-"region will be set to match imported map."
-msgstr ""
-"Möchten Sie die Location anhand der Datenquelle <%(name)s> erzeugen? Die "
-"Standardregion wird auf Grundlage der importierten Karte erstellt."
+msgid "Do you want to import data source <%(name)s> to created location? Default region will be set to match imported map."
+msgstr "Möchten Sie die Location anhand der Datenquelle <%(name)s> erzeugen? Die Standardregion wird auf Grundlage der importierten Karte erstellt."
 #: ../gui/wxpython/gis_set.py:416
 msgid "Import data"
@@ -6141,9 +5903,7 @@
 #: ../gui/wxpython/gis_set.py:490
 #, python-format
 msgid "Attempt to import data source <%(name)s> as raster or vector failed. "
-msgstr ""
-"Der Versuch die Datei <%(name)s> als raster oder Vektor zu importieren ist "
-"fehlgeschlagen."
+msgstr "Der Versuch die Datei <%(name)s> als raster oder Vektor zu importieren ist fehlgeschlagen."
 #: ../gui/wxpython/gis_set.py:494
 #, python-format
@@ -6156,8 +5916,7 @@
 "\n"
 "This mapset cannot be renamed."
 msgstr ""
-"Das Mapset <PERMANENT> muss in jeder gültigen GRASS Location vorhanden "
-"sein.\n"
+"Das Mapset <PERMANENT> muss in jeder gültigen GRASS Location vorhanden sein.\n"
 "\n"
 "Dieses Mapset kann nicht umbenannt werden."
@@ -6230,21 +5989,18 @@
 "\n"
 "This mapset cannot be deleted."
 msgstr ""
-"sein.\n"
 "\n"
 "Dieses Mapset kann nicht gelöscht werden."
 #: ../gui/wxpython/gis_set.py:605
 #, python-format
 msgid ""
-"Do you want to continue with deleting mapset <%(mapset)s> from location <"
-"%(location)s>?\n"
+"Do you want to continue with deleting mapset <%(mapset)s> from location <%(location)s>?\n"
 "\n"
 "ALL MAPS included in this mapset will be PERMANENTLY DELETED!"
 msgstr ""
-"Wollen Sie mit dem Löschen des Mapsets <%(mapset)s> der Location <"
-"%(location)s> fortfahren?\n"
+"Wollen Sie mit dem Löschen des Mapsets <%(mapset)s> der Location <%(location)s> fortfahren?\n"
 "\n"
 "ALLE KARTEN in diesem Mapset werden UNWIDERRUFLICH GELÖSCHT!"
@@ -6297,16 +6053,14 @@
 "\n"
 "Concurrent use not allowed.\n"
 "\n"
-"Do you want to try to remove .gislock (note that you need permission for "
-"this operation) and continue?"
+"Do you want to try to remove .gislock (note that you need permission for this operation) and continue?"
 msgstr ""
 "GRASS läuft bereits in dem gewählten Mapset <%(mapset)s>\n"
 "(datei %(lock)s gefunden).\n"
 "\n"
 "Gleichzeitiger Betrieb ist nicht erlaubt..\n"
 "\n"
-"Wollen Sie versuchen .gislock zu löschen (Sie brauchen entsprechende Rechte "
-"für diese Operation) und Fortzufahren?"
+"Wollen Sie versuchen .gislock zu löschen (Sie brauchen entsprechende Rechte für diese Operation) und Fortzufahren?"
 #: ../gui/wxpython/gis_set.py:845 ../gui/wxpython/gis_set.py:857
 msgid "Lock file found"
@@ -6316,14 +6070,11 @@
 msgid ""
 "ARE YOU REALLY SURE?\n"
 "\n"
-"If you really are running another GRASS session doing this could corrupt "
-"your data. Have another look in the processor manager just to be sure..."
+"If you really are running another GRASS session doing this could corrupt your data. Have another look in the processor manager just to be sure..."
 msgstr ""
 "SIND SIE WIRKLICH SICHER?\n"
 "\n"
-"Wenn Sie schon eine andere GRASS-Sitzung geöffnet haben, könnte das "
-"Weitermachen hier Ihre Daten beschädigen. Überprüfen Sie sicherheitshalber "
-"die Prozesstabelle..."
+"Wenn Sie schon eine andere GRASS-Sitzung geöffnet haben, könnte das Weitermachen hier Ihre Daten beschädigen. Überprüfen Sie sicherheitshalber die Prozesstabelle..."
 #: ../gui/wxpython/gis_set.py:868
 #, python-format
@@ -6338,12 +6089,8 @@
 #: ../gui/wxpython/gis_set.py:918
 #, python-format
-msgid ""
-"Name <%(name)s> is not a valid name for location or mapset. Please use only "
-"ASCII characters excluding %(chars)s and space."
-msgstr ""
-"Der Name <%(name)s> ist kein gültiger Name für Locations oder Mapsets. Bitte "
-"verwenden Sie nur ASCII-Zeichen ohne %(chars)s und Leerzeichen."
+msgid "Name <%(name)s> is not a valid name for location or mapset. Please use only ASCII characters excluding %(chars)s and space."
+msgstr "Der Name <%(name)s> ist kein gültiger Name für Locations oder Mapsets. Bitte verwenden Sie nur ASCII-Zeichen ohne %(chars)s und Leerzeichen."
 #: ../gui/wxpython/gis_set.py:921
 msgid "Invalid name"
@@ -6354,14 +6101,8 @@
 msgstr "Starte GRASS zum ersten Mal"
 #: ../gui/wxpython/gis_set.py:986
-msgid ""
-"GRASS needs a directory in which to store its data. Create one now if you "
-"have not already done so. A popular choice is \"grassdata\", located in your "
-"home directory."
-msgstr ""
-"GRASS braucht eine Verzeichnis, in dem es seine Daten speichern kann. "
-"Erstellen Sie jetzt eins, wenn Sie es noch nicht getan haben. Eine beliebte "
-"Wahl ist \"grassdata\" im eigenen Heimatverzeichnis."
+msgid "GRASS needs a directory in which to store its data. Create one now if you have not already done so. A popular choice is \"grassdata\", located in your home directory."
+msgstr "GRASS braucht eine Verzeichnis, in dem es seine Daten speichern kann. Erstellen Sie jetzt eins, wenn Sie es noch nicht getan haben. Eine beliebte Wahl ist \"grassdata\" im eigenen Heimatverzeichnis."
 #: ../gui/wxpython/menustrings.py:2 ../gui/wxpython/menustrings.py:857
 msgid "&File"
@@ -6438,8 +6179,7 @@
 #: ../gui/wxpython/menustrings.py:22
 msgid "Add multiple raster or vector map layers to current display"
-msgstr ""
-"Mehrere Raster- oder Vektorkarten zum aktuellen Kartenfenster hinzufügen"
+msgstr "Mehrere Raster- oder Vektorkarten zum aktuellen Kartenfenster hinzufügen"
 #: ../gui/wxpython/menustrings.py:23
 msgid "New map display window"
@@ -6470,12 +6210,8 @@
 msgstr "ASCII x,y,z-Punkt Import und Gridding"
 #: ../gui/wxpython/menustrings.py:33
-msgid ""
-"Create a raster map from an assemblage of many coordinates using univariate "
-"statistics."
-msgstr ""
-"Erstellen einer Rasterkarte unter Verwendung einer Sammlung von vielen "
-"Koordinaten mit univariater Statistik."
+msgid "Create a raster map from an assemblage of many coordinates using univariate statistics."
+msgstr "Erstellen einer Rasterkarte unter Verwendung einer Sammlung von vielen Koordinaten mit univariater Statistik."
 #: ../gui/wxpython/menustrings.py:34
 msgid "ASCII grid import"
@@ -6506,12 +6242,8 @@
 msgstr "ESRI ASCII Rasterimport"
 #: ../gui/wxpython/menustrings.py:41
-msgid ""
-"Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster "
-"map layer."
-msgstr ""
-"Konvertiert ein ESRI ARC/INFO ASCII-Raster (GRID) in eine (binäre) GRASS "
-"Rasterkarte."
+msgid "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster map layer."
+msgstr "Konvertiert ein ESRI ARC/INFO ASCII-Raster (GRID) in eine (binäre) GRASS Rasterkarte."
 #: ../gui/wxpython/menustrings.py:42
 msgid "GRIDATB.FOR import"
@@ -6519,8 +6251,7 @@
 #: ../gui/wxpython/menustrings.py:43
 msgid "Imports GRIDATB.FOR map file (TOPMODEL) into GRASS raster map"
-msgstr ""
-"Importiert GRIDATB.FOR Kartendatei (TOPMODEL) in eine GRASS Rasterkarte."
+msgstr "Importiert GRIDATB.FOR Kartendatei (TOPMODEL) in eine GRASS Rasterkarte."
 #: ../gui/wxpython/menustrings.py:44
 msgid "Matlab 2D array import"
@@ -6551,12 +6282,8 @@
 msgstr "Terra ASTER HDF Import"
 #: ../gui/wxpython/menustrings.py:51
-msgid ""
-"Georeference, rectify and import Terra-ASTER imagery and relative DEM's "
-"using gdalwarp."
-msgstr ""
-"Georeferenzieren, entzerren und Importieren von Terra-ASTER Bildern und "
-"entsprechende DHM mit gdalwarp."
+msgid "Georeference, rectify and import Terra-ASTER imagery and relative DEM's using gdalwarp."
+msgstr "Georeferenzieren, entzerren und Importieren von Terra-ASTER Bildern und entsprechende DHM mit gdalwarp."
 #: ../gui/wxpython/menustrings.py:52
 msgid "WMS import"
@@ -6611,12 +6338,8 @@
 msgstr "Import alter GRASS Vektordaten (alle Karten)"
 #: ../gui/wxpython/menustrings.py:66
-msgid ""
-"Converts all older versions of GRASS vector maps in current mapset to "
-"current format."
-msgstr ""
-"Konvertiere alle alten GRASS Vektorkarten des aktuellen Mapsets in aktuelles "
-"Format."
+msgid "Converts all older versions of GRASS vector maps in current mapset to current format."
+msgstr "Konvertiere alle alten GRASS Vektorkarten des aktuellen Mapsets in aktuelles Format."
 #: ../gui/wxpython/menustrings.py:67
 msgid "DXF import"
@@ -6647,24 +6370,16 @@
 msgstr "Garmin GPS Import"
 #: ../gui/wxpython/menustrings.py:74
-msgid ""
-"Download waypoints, routes, and tracks from a Garmin GPS receiver into a "
-"vector map."
-msgstr ""
-"Lade Wegpunkte, Routen und Tracks von einem Garmin GPS Empfänger in eine "
-"Verktorkarte."
+msgid "Download waypoints, routes, and tracks from a Garmin GPS receiver into a vector map."
+msgstr "Lade Wegpunkte, Routen und Tracks von einem Garmin GPS Empfänger in eine Verktorkarte."
 #: ../gui/wxpython/menustrings.py:75
 msgid "GPSBabel GPS import"
 msgstr "GPSBabel GPS Import"
 #: ../gui/wxpython/menustrings.py:76
-msgid ""
-"Import waypoints, routes, and tracks from a GPS receiver or GPS download "
-"file into a vector map."
-msgstr ""
-"Lade Wegpunkte, Routen und Tracks von einem Garmin GPS Empfänger oder direkt "
-"GPS Daten in eine Verktorkarte."
+msgid "Import waypoints, routes, and tracks from a GPS receiver or GPS download file into a vector map."
+msgstr "Lade Wegpunkte, Routen und Tracks von einem Garmin GPS Empfänger oder direkt GPS Daten in eine Verktorkarte."
 #: ../gui/wxpython/menustrings.py:77
 msgid "Geonames import"
@@ -6679,12 +6394,8 @@
 msgstr "GEOnet Import"
 #: ../gui/wxpython/menustrings.py:80
-msgid ""
-"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
-"points map."
-msgstr ""
-"Importiere US-NGA GEOnet Names Server (GNS) Länderdaten in eine GRASS "
-"Vektorpunkte Karte."
+msgid "Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector points map."
+msgstr "Importiere US-NGA GEOnet Names Server (GNS) Länderdaten in eine GRASS Vektorpunkte Karte."
 #: ../gui/wxpython/menustrings.py:81
 msgid "Matlab array or Mapgen format import"
@@ -6703,22 +6414,16 @@
 msgstr "ASCII 3D Import"
-msgid ""
-"Converts a 3D ASCII raster text file into a (binary) 3D raster map layer."
-msgstr ""
-"Konvertiert eine 3D ASCII-Raster Textdatei in eine (binäre) 3D-Rasterkarte."
+msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map layer."
+msgstr "Konvertiert eine 3D ASCII-Raster Textdatei in eine (binäre) 3D-Rasterkarte."
 #: ../gui/wxpython/menustrings.py:86
 msgid "Vis5D import"
 msgstr "Vis5D Datei Import"
 #: ../gui/wxpython/menustrings.py:87
-msgid ""
-"Imports 3-dimensional Vis5D files (i.e. the V5D file with 1 variable and 1 "
-"time step)."
-msgstr ""
-"Importiere 3-dimensionale Vis5D Daten (z.B. die v5d-Daten mit einer "
-"Variablen und einem Zeitstempel)."
+msgid "Imports 3-dimensional Vis5D files (i.e. the V5D file with 1 variable and 1 time step)."
+msgstr "Importiere 3-dimensionale Vis5D Daten (z.B. die v5d-Daten mit einer Variablen und einem Zeitstempel)."
 #: ../gui/wxpython/menustrings.py:88
 msgid "Import database table"
@@ -6757,11 +6462,8 @@
 msgstr "ASCII x,y,z Punkte-Export"
 #: ../gui/wxpython/menustrings.py:97
-msgid ""
-"Export a raster map to a text file as x,y,z values based on cell centers."
-msgstr ""
-"Exportiert eine Rasterkarte in eine Textdatei (x,y,z-werte; Zentrum der "
-"Zellen)"
+msgid "Export a raster map to a text file as x,y,z values based on cell centers."
+msgstr "Exportiert eine Rasterkarte in eine Textdatei (x,y,z-werte; Zentrum der Zellen)"
 #: ../gui/wxpython/menustrings.py:98
 msgid "ESRI ASCII grid export"
@@ -6816,24 +6518,16 @@
 msgstr "PPM Export"
 #: ../gui/wxpython/menustrings.py:111
-msgid ""
-"Converts a GRASS raster map to a PPM image file at the pixel resolution of "
-"the currently defined region."
-msgstr ""
-"Exportiere GRASS Rasterkarte in ein PPM-Bild. Die Pixelauflösung wird aus "
-"der aktuellen Regions-Einstellung übernommen."
+msgid "Converts a GRASS raster map to a PPM image file at the pixel resolution of the currently defined region."
+msgstr "Exportiere GRASS Rasterkarte in ein PPM-Bild. Die Pixelauflösung wird aus der aktuellen Regions-Einstellung übernommen."
 #: ../gui/wxpython/menustrings.py:112
 msgid "PPM from RGB export"
 msgstr "PPM aus RGB Export"
 #: ../gui/wxpython/menustrings.py:113
-msgid ""
-"Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel "
-"resolution of the CURRENTLY DEFINED REGION."
-msgstr ""
-"Exportiert 3 GRASS Rasterkarten (R,G,B) als PPM-Bild mit der Pixel-Auflösung "
-"der DERZEITIG EINGESTELLTEN REGION."
+msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel resolution of the CURRENTLY DEFINED REGION."
+msgstr "Exportiert 3 GRASS Rasterkarten (R,G,B) als PPM-Bild mit der Pixel-Auflösung der DERZEITIG EINGESTELLTEN REGION."
 #: ../gui/wxpython/menustrings.py:114 ../gui/wxpython/menustrings.py:133
 msgid "POV-Ray export"
@@ -6848,12 +6542,8 @@
 msgstr "TIFF Export"
 #: ../gui/wxpython/menustrings.py:117
-msgid ""
-"Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel "
-"resolution of the currently defined region."
-msgstr ""
-"Exportiere GRASS Rasterkarte in ein 8/24 bit TIFF-Bild. Die Pixelauflösung "
-"wird aus der aktuellen Regions-Einstellung übernommen."
+msgid "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel resolution of the currently defined region."
+msgstr "Exportiere GRASS Rasterkarte in ein 8/24 bit TIFF-Bild. Die Pixelauflösung wird aus der aktuellen Regions-Einstellung übernommen."
 #: ../gui/wxpython/menustrings.py:118
 msgid "VRML export"
@@ -6894,8 +6584,7 @@
 #: ../gui/wxpython/menustrings.py:128
 msgid "Converts a GRASS binary vector map to a GRASS ASCII vector map."
-msgstr ""
-"Konvertiert eine binäre GRASS Vektor Karte in eine GRASS ASCII Vektor Karte"
+msgstr "Konvertiert eine binäre GRASS Vektor Karte in eine GRASS ASCII Vektor Karte"
 #: ../gui/wxpython/menustrings.py:129
 msgid "DXF export"
@@ -6910,11 +6599,8 @@
 msgstr "Exportiere in verschiedene GPS-Formate mit GPSBabel"
 #: ../gui/wxpython/menustrings.py:132
-msgid ""
-"Exports a vector map to a GPS receiver or file format supported by GpsBabel."
-msgstr ""
-"Exportiert eine Vektorkarte in ein GPS-Gerät oder als von GPSBabel "
-"unterstütztes Datenformat."
+msgid "Exports a vector map to a GPS receiver or file format supported by GpsBabel."
+msgstr "Exportiert eine Vektorkarte in ein GPS-Gerät oder als von GPSBabel unterstütztes Datenformat."
 #: ../gui/wxpython/menustrings.py:134
 msgid "Converts to POV-Ray format, GRASS x,y,z -> POV-Ray x,z,y"
@@ -6950,8 +6636,7 @@
 #: ../gui/wxpython/menustrings.py:143
 msgid "Exports GRASS 3D raster map to 3-dimensional Vis5D file."
-msgstr ""
-"Exportiert eine GRASS 3D Rasterkarte in eine 3-dimensionale Vis5D Datei."
+msgstr "Exportiert eine GRASS 3D Rasterkarte in eine 3-dimensionale Vis5D Datei."
 #: ../gui/wxpython/menustrings.py:145
 msgid "Converts 3D raster maps into the VTK-ASCII format."
@@ -6979,8 +6664,7 @@
 #: ../gui/wxpython/menustrings.py:153
 msgid "Creates a new pseudo-vector map as a link to an OGR-supported layer."
-msgstr ""
-"Erzeugt eine neue Pseudo-Vektorkarte als Verknüpfung zu einem OGR-Layer."
+msgstr "Erzeugt eine neue Pseudo-Vektorkarte als Verknüpfung zu einem OGR-Layer."
 #: ../gui/wxpython/menustrings.py:154
 msgid "Manage maps and volumes"
@@ -6991,14 +6675,8 @@
 msgstr "Kopieren"
 #: ../gui/wxpython/menustrings.py:156
-msgid ""
-"Copies available data files in the user's current mapset search path and "
-"location to the appropriate element directories under the user's current "
-"mapset."
-msgstr ""
-"Kopiert verfügbare Daten aus dem aktuellen Suchpfad des Mapsets und der "
-"Location des Benutzers in die entsprechenden Verzeichnisse im aktuellen "
-"Mapset."
+msgid "Copies available data files in the user's current mapset search path and location to the appropriate element directories under the user's current mapset."
+msgstr "Kopiert verfügbare Daten aus dem aktuellen Suchpfad des Mapsets und der Location des Benutzers in die entsprechenden Verzeichnisse im aktuellen Mapset."
 #: ../gui/wxpython/menustrings.py:157
 msgid "List"
@@ -7006,20 +6684,15 @@
 #: ../gui/wxpython/menustrings.py:158
 msgid "Lists available GRASS data base files of the user-specified data type."
-msgstr ""
-"Listet alle verfügbaren GRASS Datenbankdateien im spezifizierten Typ auf."
+msgstr "Listet alle verfügbaren GRASS Datenbankdateien im spezifizierten Typ auf."
 #: ../gui/wxpython/menustrings.py:159
 msgid "List filtered"
 msgstr "Gefilterte Liste"
 #: ../gui/wxpython/menustrings.py:160
-msgid ""
-"Lists available GRASS data base files of the user-specified data type "
-"optionally using the search pattern."
-msgstr ""
-"Listet alle verfügbaren GRASS Datenbankdateien im spezifizierten Typ mit "
-"optionalem Suchmuster auf."
+msgid "Lists available GRASS data base files of the user-specified data type optionally using the search pattern."
+msgstr "Listet alle verfügbaren GRASS Datenbankdateien im spezifizierten Typ mit optionalem Suchmuster auf."
 #: ../gui/wxpython/menustrings.py:162
 msgid "Renames data base element files in the user's current mapset."
@@ -7052,8 +6725,7 @@
 #: ../gui/wxpython/menustrings.py:171 ../gui/wxpython/menustrings.py:303
 msgid "Converts 2D raster map slices to one 3D raster volume map."
-msgstr ""
-"Konvertiert Schnitte von 2D Rasterkarten in eine 3D Rastervolumenkarte."
+msgstr "Konvertiert Schnitte von 2D Rasterkarten in eine 3D Rastervolumenkarte."
 #: ../gui/wxpython/menustrings.py:172 ../gui/wxpython/menustrings.py:304
 msgid "Raster 2.5D to volume"
@@ -7061,8 +6733,7 @@
 #: ../gui/wxpython/menustrings.py:173 ../gui/wxpython/menustrings.py:305
 msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
-msgstr ""
-"Erzeugt eine 3D Volumenkarte aus 2D Höheninformationen und einer Wertekarte"
+msgstr "Erzeugt eine 3D Volumenkarte aus 2D Höheninformationen und einer Wertekarte"
 #: ../gui/wxpython/menustrings.py:174 ../gui/wxpython/menustrings.py:579
 msgid "Vector to raster"
@@ -7077,11 +6748,8 @@
 msgstr "Vektor zu Volumen"
 #: ../gui/wxpython/menustrings.py:177 ../gui/wxpython/menustrings.py:582
-msgid ""
-"Converts a binary GRASS vector map (only points) layer into a 3D GRASS "
-"raster map layer."
-msgstr ""
-"Konvertiert eine GRASS Vektorkarte (nur Punkte) in eine 3D GRASS Rasterkarte."
+msgid "Converts a binary GRASS vector map (only points) layer into a 3D GRASS raster map layer."
+msgstr "Konvertiert eine GRASS Vektorkarte (nur Punkte) in eine 3D GRASS Rasterkarte."
 #: ../gui/wxpython/menustrings.py:178 ../gui/wxpython/menustrings.py:583
 msgid "2D vector to 3D vector"
@@ -7152,12 +6820,8 @@
 msgstr "Richtung/Distanz zu Koordinaten"
 #: ../gui/wxpython/menustrings.py:195
-msgid ""
-"A simple utility for converting bearing and distance measurements to "
-"coordinates and vice versa."
-msgstr ""
-"Eine einfache Anwendung zur Konvertierung von Richtung und Entfernung in "
-"Koordinaten und umgekehrt."
+msgid "A simple utility for converting bearing and distance measurements to coordinates and vice versa."
+msgstr "Eine einfache Anwendung zur Konvertierung von Richtung und Entfernung in Koordinaten und umgekehrt."
 #: ../gui/wxpython/menustrings.py:197
 msgid "Launch Cartographic Composer"
@@ -7209,8 +6873,7 @@
 #: ../gui/wxpython/menustrings.py:210
 msgid "Set/unset access to other mapsets in current location"
-msgstr ""
-"Zugriff auf andere Mapsets der aktuellen Location ermöglichen/verwehren"
+msgstr "Zugriff auf andere Mapsets der aktuellen Location ermöglichen/verwehren"
 #: ../gui/wxpython/menustrings.py:211
 msgid "User access"
@@ -7262,9 +6925,7 @@
 #: ../gui/wxpython/menustrings.py:224
 msgid "Changes the default GRASS graphical user interface (GUI) setting."
-msgstr ""
-"Ändert die Standardeinstellung für die graphische Benutzeroberfläche (GUI) "
-"von GRASS."
+msgstr "Ändert die Standardeinstellung für die graphische Benutzeroberfläche (GUI) von GRASS."
 #: ../gui/wxpython/menustrings.py:225
 msgid "Create new location"
@@ -7276,8 +6937,7 @@
 #: ../gui/wxpython/menustrings.py:228
 msgid "Creates new mapset in the current location, changes current mapset."
-msgstr ""
-"Erzeugt neues Mapset in der aktuellen Location, ändert aktuelles Mapset."
+msgstr "Erzeugt neues Mapset in der aktuellen Location, ändert aktuelles Mapset."
 #: ../gui/wxpython/menustrings.py:229
 msgid "Version"
@@ -7304,9 +6964,7 @@
 msgstr "Projektionen verwalten"
 #: ../gui/wxpython/menustrings.py:235
-msgid ""
-"Prints and manipulates GRASS projection information files (in various co-"
-"ordinate system descriptions)."
+msgid "Prints and manipulates GRASS projection information files (in various co-ordinate system descriptions)."
 msgstr "Anzeigen und ändern der GRASS Projektionsdateien (in verschiedenen"
 #: ../gui/wxpython/menustrings.py:236
@@ -7323,8 +6981,7 @@
 #: ../gui/wxpython/menustrings.py:239
 msgid "Convert coordinates from one projection to another (cs2cs frontend)."
-msgstr ""
-"Konvertiert Koordinaten zwischen versch. Projektionen (Frontend für cs2cs)."
+msgstr "Konvertiert Koordinaten zwischen versch. Projektionen (Frontend für cs2cs)."
 #: ../gui/wxpython/menustrings.py:240
 msgid "Addons extensions"
@@ -7376,12 +7033,8 @@
 msgstr "Raster digitalisieren (erfordert XTerm)"
 #: ../gui/wxpython/menustrings.py:252
-msgid ""
-"Interactive tool used to draw and save vector features on a graphics monitor "
-"using a pointing device (mouse) and save to a raster map."
-msgstr ""
-"Interaktives Werkzeug, um Vektorobjekte in einem Kartenfenster mit der Maus "
-"zu zeichnen und als Rasterkarte zu speichern."
+msgid "Interactive tool used to draw and save vector features on a graphics monitor using a pointing device (mouse) and save to a raster map."
+msgstr "Interaktives Werkzeug, um Vektorobjekte in einem Kartenfenster mit der Maus zu zeichnen und als Rasterkarte zu speichern."
 #: ../gui/wxpython/menustrings.py:253
 msgid "Compress/decompress"
@@ -7437,8 +7090,7 @@
 #: ../gui/wxpython/menustrings.py:266
 msgid "Resamples raster map layers to a finer grid using interpolation."
-msgstr ""
-"Resamplen einer Rasterkarte zu feinerer Auflösung mittels Interpolation."
+msgstr "Resamplen einer Rasterkarte zu feinerer Auflösung mittels Interpolation."
 #: ../gui/wxpython/menustrings.py:267
 msgid "Resample using nearest neighbor"
@@ -7453,14 +7105,8 @@
 msgstr "Resampeln mittels Spline mit Tension"
 #: ../gui/wxpython/menustrings.py:270
-msgid ""
-"Reinterpolates and optionally computes topographic analysis from input "
-"raster map to a new raster map (possibly with different resolution) using "
-"regularized spline with tension and smoothing."
-msgstr ""
-"Reinterpoliert und berechnet ggf. topographische Analysen basierend auf "
-"einer Eingabe-Rasterkarte in eine neue Rasterkarte unter Verwendung von "
-"regularized splines with tension and smoothing (RST)."
+msgid "Reinterpolates and optionally computes topographic analysis from input raster map to a new raster map (possibly with different resolution) using regularized spline with tension and smoothing."
+msgstr "Reinterpoliert und berechnet ggf. topographische Analysen basierend auf einer Eingabe-Rasterkarte in eine neue Rasterkarte unter Verwendung von regularized splines with tension and smoothing (RST)."
 #: ../gui/wxpython/menustrings.py:271 ../gui/wxpython/menustrings.py:544
 msgid "Support file maintenance"
@@ -7484,20 +7130,15 @@
 #: ../gui/wxpython/menustrings.py:276
 msgid "Re-projects a raster map from one location to the current location."
-msgstr ""
-"Reprojiziert eine Rasterkarte von einer Location in die aktuelle Location."
+msgstr "Reprojiziert eine Rasterkarte von einer Location in die aktuelle Location."
 #: ../gui/wxpython/menustrings.py:277
 msgid "Tiling"
 msgstr "Kacheln erzeugen"
 #: ../gui/wxpython/menustrings.py:278
-msgid ""
-"Produces tilings of the source projection for use in the destination region "
-"and projection."
-msgstr ""
-"Erzeugt Kacheln der Quelloprojection um sie in der Zielprojektion und -"
-"location zu nutzen"
+msgid "Produces tilings of the source projection for use in the destination region and projection."
+msgstr "Erzeugt Kacheln der Quelloprojection um sie in der Zielprojektion und -location zu nutzen"
 #: ../gui/wxpython/menustrings.py:279 ../gui/wxpython/menustrings.py:563
 msgid "Manage colors"
@@ -7548,8 +7189,7 @@
 msgstr "Erzeuge RGB"
 #: ../gui/wxpython/menustrings.py:291
-msgid ""
-"Combines red, green and blue raster maps into a single composite raster map."
+msgid "Combines red, green and blue raster maps into a single composite raster map."
 msgstr "Kombiniert die Farbkanäle rot, grün und blau zu einer Komposit-Karte."
 #: ../gui/wxpython/menustrings.py:292 ../gui/wxpython/menustrings.py:713
@@ -7557,12 +7197,8 @@
 msgstr "RGB zu HIS"
 #: ../gui/wxpython/menustrings.py:293
-msgid ""
-"Generates red, green and blue raster map layers combining hue, intensity and "
-"saturation (HIS) values from user-specified input raster map layers."
-msgstr ""
-"Erzeugt rot, grün und blaue (RGB) Karten aus einer benutzerspezifizierten "
-"Kombination von Wert-, Intensitäts- und Sättigungs-Karten (HIS)."
+msgid "Generates red, green and blue raster map layers combining hue, intensity and saturation (HIS) values from user-specified input raster map layers."
+msgstr "Erzeugt rot, grün und blaue (RGB) Karten aus einer benutzerspezifizierten Kombination von Wert-, Intensitäts- und Sättigungs-Karten (HIS)."
 #: ../gui/wxpython/menustrings.py:294
 msgid "Query raster maps"
@@ -7586,15 +7222,11 @@
 #: ../gui/wxpython/menustrings.py:306
 msgid "Buffer rasters"
-msgstr "Rasterzellen buffern"
+msgstr "Rasterzellen puffern"
 #: ../gui/wxpython/menustrings.py:307
-msgid ""
-"Creates a raster map layer showing buffer zones surrounding cells that "
-"contain non-NULL category values."
-msgstr ""
-"Erzeugt eine Rasterkarte mit Pufferzonen um Pixel, die keine NULL-Werte "
-"haben."
+msgid "Creates a raster map layer showing buffer zones surrounding cells that contain non-NULL category values."
+msgstr "Erzeugt eine Rasterkarte mit Pufferzonen um Pixel, die keine NULL-Werte haben."
 #: ../gui/wxpython/menustrings.py:308
 msgid "Concentric circles"
@@ -7602,9 +7234,7 @@
 #: ../gui/wxpython/menustrings.py:309
 msgid "Creates a raster map containing concentric rings around a given point."
-msgstr ""
-"Erzeugt eine Rasterkarte, die konzentrische Kreise um einen angegebenen "
-"Punkt ziehen."
+msgstr "Erzeugt eine Rasterkarte, die konzentrische Kreise um einen angegebenen Punkt ziehen."
 #: ../gui/wxpython/menustrings.py:310
 msgid "Closest points"
@@ -7616,8 +7246,7 @@
 #: ../gui/wxpython/menustrings.py:313
 msgid "Creates a MASK for limiting raster operation."
-msgstr ""
-"Erzeugt eine MASK für räumlich eingeschränkte Rasterkartenberechnungen."
+msgstr "Erzeugt eine MASK für räumlich eingeschränkte Rasterkartenberechnungen."
 #: ../gui/wxpython/menustrings.py:314
 msgid "Raster map calculator"
@@ -7636,28 +7265,16 @@
 msgstr "Moving window"
 #: ../gui/wxpython/menustrings.py:318
-msgid ""
-"Makes each cell category value a function of the category values assigned to "
-"the cells around it, and stores new cell values in an output raster map "
-"layer."
-msgstr ""
-"Weist für jeden Zellenkategoriewert eine Funktion der umgebenden "
-"Kategoriewerte basierend auf einer Fenstergrösse zu und erstellt neue "
-"Zellenwerte in einer Ausgabe-Rasterkarte."
+msgid "Makes each cell category value a function of the category values assigned to the cells around it, and stores new cell values in an output raster map layer."
+msgstr "Weist für jeden Zellenkategoriewert eine Funktion der umgebenden Kategoriewerte basierend auf einer Fenstergrösse zu und erstellt neue Zellenwerte in einer Ausgabe-Rasterkarte."
 #: ../gui/wxpython/menustrings.py:319
 msgid "Neighborhood points"
 msgstr "Benachbarte Punkte"
 #: ../gui/wxpython/menustrings.py:320
-msgid ""
-"Makes each cell value a function of the attribute values assigned to the "
-"vector points or centroids around it, and stores new cell values in an "
-"output raster map layer."
-msgstr ""
-"Vektorpunkte oder Zentroide und erstellt neue Zellenwerte in einer Ausgabe-"
-"Rasterkarte."
+msgid "Makes each cell value a function of the attribute values assigned to the vector points or centroids around it, and stores new cell values in an output raster map layer."
+msgstr "Weist für jeden Zellenkategoriewert eine Funktion der umgebenden Vektorpunkte oder Zentroide und erstellt neue Zellenwerte in einer Ausgabe-Rasterkarte."
 #: ../gui/wxpython/menustrings.py:321
 msgid "Overlay rasters"
@@ -7668,9 +7285,7 @@
 msgstr "Kreuzprodukt"
 #: ../gui/wxpython/menustrings.py:323
-msgid ""
-"Creates a cross product of the category values from multiple raster map "
-"layers."
+msgid "Creates a cross product of the category values from multiple raster map layers."
 msgstr "Erzeugt ein Kreuzprodukt der Kategriewerte verschiedener Rasterkarten"
 #: ../gui/wxpython/menustrings.py:324
@@ -7678,24 +7293,16 @@
 msgstr "Raster-Serie"
 #: ../gui/wxpython/menustrings.py:325
-msgid ""
-"Makes each output cell value a function of the values assigned to the "
-"corresponding cells in the input raster map layers."
-msgstr ""
-"Macht aus jeder Ausgabezelle eine Funktion der Werte, die einer "
-"korrespondierenden Zelle einer Eingabekarte zugewiesen ist."
+msgid "Makes each output cell value a function of the values assigned to the corresponding cells in the input raster map layers."
+msgstr "Macht aus jeder Ausgabezelle eine Funktion der Werte, die einer korrespondierenden Zelle einer Eingabekarte zugewiesen ist."
 #: ../gui/wxpython/menustrings.py:326
 msgid "Patch raster maps"
 msgstr "Rasterkarten patchen"
 #: ../gui/wxpython/menustrings.py:327
-msgid ""
-"Creates a composite raster map layer by using known category values from one "
-"(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
-msgstr ""
-"Erzeugt eine Komposit-Rasterkarte unter Nutzung von Werten aus einer (oder "
-"mehrerer) Karte, um NULL-Werte einer anderen Karte zu füllen."
+msgid "Creates a composite raster map layer by using known category values from one (or more) map layer(s) to fill in areas of \"no data\" in another map layer."
+msgstr "Erzeugt eine Komposit-Rasterkarte unter Nutzung von Werten aus einer (oder mehrerer) Karte, um NULL-Werte einer anderen Karte zu füllen."
 #: ../gui/wxpython/menustrings.py:328
 msgid "Statistical overlay"
@@ -7722,8 +7329,7 @@
 msgstr "Schattenkarten"
 #: ../gui/wxpython/menustrings.py:334
-msgid ""
-"Calculates cast shadow areas from sun position and elevation raster map."
+msgid "Calculates cast shadow areas from sun position and elevation raster map."
 msgstr "Berechnet Schlagschatten aus der Sonnenposition und einer Höhenkarte."
 #: ../gui/wxpython/menustrings.py:335
@@ -7743,30 +7349,16 @@
 msgstr "Kostenoberfläche"
 #: ../gui/wxpython/menustrings.py:339
-msgid ""
-"Creates a raster map showing the cumulative cost of moving between different "
-"geographic locations on an input raster map whose cell category values "
-"represent cost."
-msgstr ""
-"Erzeugt eine Rasterkarte, die die kumulativen Kosten, die beim Bewegen "
-"zwischen unterschiedlichen geographischen Orten entstehen, zeigt. Die "
-"Kategoriewerte der Eingabekarte repräsentieren die Kosten."
+msgid "Creates a raster map showing the cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
+msgstr "Erzeugt eine Rasterkarte, die die kumulativen Kosten, die beim Bewegen zwischen unterschiedlichen geographischen Orten entstehen, zeigt. Die Kategoriewerte der Eingabekarte repräsentieren die Kosten."
 #: ../gui/wxpython/menustrings.py:340
 msgid "Cumulative movement costs"
 msgstr "Kumulierte Bewegungskosten"
 #: ../gui/wxpython/menustrings.py:341
-msgid ""
-"Outputs a raster map layer showing the anisotropic cumulative cost of moving "
-"between different geographic locations on an input elevation raster map "
-"layer whose cell category values represent elevation combined with an input "
-"raster map layer whose cell values represent friction cost."
-msgstr ""
-"Erzeugt eine Rasterkarte, die die anisotrophen kumulierten Kosten zeigt, die "
-"beim Bewegen zwischen unterschiedlichen geographischen Orten entstehen. "
-"Dabei werden als Eingabekarten einmal ein Höhenmodell und eine Rasterkarte "
-"mit Reibungs-Kosten kombiniert."
+msgid "Outputs a raster map layer showing the anisotropic cumulative cost of moving between different geographic locations on an input elevation raster map layer whose cell category values represent elevation combined with an input raster map layer whose cell values represent friction cost."
+msgstr "Erzeugt eine Rasterkarte, die die anisotrophen kumulierten Kosten zeigt, die beim Bewegen zwischen unterschiedlichen geographischen Orten entstehen. Dabei werden als Eingabekarten einmal ein Höhenmodell und eine Rasterkarte mit Reibungs-Kosten kombiniert."
 #: ../gui/wxpython/menustrings.py:342
 msgid "Least cost route or flow"
@@ -7782,20 +7374,15 @@
 #: ../gui/wxpython/menustrings.py:345
 msgid "Creates shaded relief map from an elevation map (DEM)."
-msgstr ""
-"Erstellt eine geschummerte Reliefkarte auf Basis einer Höhenkarte (DHM)."
+msgstr "Erstellt eine geschummerte Reliefkarte auf Basis einer Höhenkarte (DHM)."
 #: ../gui/wxpython/menustrings.py:346
 msgid "Slope and aspect"
 msgstr "Hangneigung und -exposition"
 #: ../gui/wxpython/menustrings.py:347
-msgid ""
-"Generates raster maps of slope, aspect, curvatures and partial derivatives "
-"from a elevation raster map."
-msgstr ""
-"Erzeugt Karten der Hangneigung, Exposition, Krümmung und partiellen "
-"Ableitungen aus einer Höhenkarte."
+msgid "Generates raster maps of slope, aspect, curvatures and partial derivatives from a elevation raster map."
+msgstr "Erzeugt Karten der Hangneigung, Exposition, Krümmung und partiellen Ableitungen aus einer Höhenkarte."
 #: ../gui/wxpython/menustrings.py:348
 msgid "Terrain parameters"
@@ -7827,8 +7414,7 @@
 #: ../gui/wxpython/menustrings.py:355
 msgid "Generates a raster map layer of distance to features in input layer."
-msgstr ""
-"Erzeugt eine Rasterkarte mit Distanzen zu Objekten in der Eingabekarte."
+msgstr "Erzeugt eine Rasterkarte mit Distanzen zu Objekten in der Eingabekarte."
 #: ../gui/wxpython/menustrings.py:356
 msgid "Horizon angle"
@@ -7836,8 +7422,7 @@
 #: ../gui/wxpython/menustrings.py:357
 msgid "Horizon angle computation from a digital elevation model."
-msgstr ""
-"Berechnung des Horizontwinkel auf Grundlage eines digitalen Höhenmodells."
+msgstr "Berechnung des Horizontwinkel auf Grundlage eines digitalen Höhenmodells."
 #: ../gui/wxpython/menustrings.py:358
 msgid "Transform features"
@@ -7848,12 +7433,8 @@
 msgstr "Klumpen"
 #: ../gui/wxpython/menustrings.py:360
-msgid ""
-"Recategorizes data in a raster map by grouping cells that form physically "
-"discrete areas into unique categories."
-msgstr ""
-"Rekategoriziert Daten aus Rasterkarten durch Zusammenfassen von räumlich "
-"getrennten, aber gleichartigen Zellen zu eigenständigen Kategorien."
+msgid "Recategorizes data in a raster map by grouping cells that form physically discrete areas into unique categories."
+msgstr "Rekategoriziert Daten aus Rasterkarten durch Zusammenfassen von räumlich getrennten, aber gleichartigen Zellen zu eigenständigen Kategorien."
 #: ../gui/wxpython/menustrings.py:361
 msgid "Grow"
@@ -7861,9 +7442,7 @@
 #: ../gui/wxpython/menustrings.py:362
 msgid "Generates a raster map layer with contiguous areas grown by one cell."
-msgstr ""
-"Erstellt eine Rasterkarte mit Flächen, die um jeweils eine Zelle erweitert "
-"wurde"
+msgstr "Erstellt eine Rasterkarte mit Flächen, die um jeweils eine Zelle erweitert wurde"
 #: ../gui/wxpython/menustrings.py:363
 msgid "Thin"
@@ -7871,9 +7450,7 @@
 #: ../gui/wxpython/menustrings.py:364
 msgid "Thins non-zero cells that denote linear features in a raster map."
-msgstr ""
-"Dünnt Non-Zero-Zellen aus, die in einer Rasterkarte Linienstrukturen "
-"darstellen."
+msgstr "Dünnt Non-Zero-Zellen aus, die in einer Rasterkarte Linienstrukturen darstellen."
 #: ../gui/wxpython/menustrings.py:365
 msgid "Hydrologic modeling"
@@ -7884,12 +7461,8 @@
 msgstr "Abflusslinien graben"
 #: ../gui/wxpython/menustrings.py:367
-msgid ""
-"Takes vector stream data, transforms it to raster and subtracts depth from "
-"the output DEM."
-msgstr ""
-"Erzeugt aus Abflusslinien (Vektor) Resterdaten und substrahiert die Tiefe "
-"vom ausgegebenen DHM "
+msgid "Takes vector stream data, transforms it to raster and subtracts depth from the output DEM."
+msgstr "Erzeugt aus Abflusslinien (Vektor) Resterdaten und substrahiert die Tiefe vom ausgegebenen DHM "
 #: ../gui/wxpython/menustrings.py:368
 msgid "Fill lake"
@@ -7904,12 +7477,8 @@
 msgstr "Senkenloses Höhenmodell und Abflusslinienkarte"
 #: ../gui/wxpython/menustrings.py:371
-msgid ""
-"Filters and generates a depressionless elevation map and a flow direction "
-"map from a given elevation raster map."
-msgstr ""
-"Filtert und erzeugt aus einem Höhenmodell sowohl eine depressionslose "
-"Höhenkarte als auch eine Karte mit Fließrichtungen."
+msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation raster map."
+msgstr "Filtert und erzeugt aus einem Höhenmodell sowohl eine depressionslose Höhenkarte als auch eine Karte mit Fließrichtungen."
 #: ../gui/wxpython/menustrings.py:372
 msgid "Flow accumulation"
@@ -7917,21 +7486,15 @@
 #: ../gui/wxpython/menustrings.py:373
 msgid "Flow computation for massive grids (float version)."
-msgstr ""
-"Berechnung der Fließrichtung und -mengen für sehr großen Rastern (Float-"
-"Version)."
+msgstr "Berechnung der Fließrichtung und -mengen für sehr großen Rastern (Float-Version)."
 #: ../gui/wxpython/menustrings.py:374
 msgid "Flow lines"
 msgstr "Flußlinien"
 #: ../gui/wxpython/menustrings.py:375
-msgid ""
-"Construction of slope curves (flowlines), flowpath lengths, and flowline "
-"densities (upslope areas) from a raster digital elevation model (DEM)."
-msgstr ""
-"Berechnung von Abflusslinien, Länge der Fliesswege und Flussdichte aus einem "
-"digitalen Höhenmodell."
+msgid "Construction of slope curves (flowlines), flowpath lengths, and flowline densities (upslope areas) from a raster digital elevation model (DEM)."
+msgstr "Berechnung von Abflusslinien, Länge der Fliesswege und Flussdichte aus einem digitalen Höhenmodell."
 #: ../gui/wxpython/menustrings.py:376
 msgid "Watershed analysis"
@@ -7962,12 +7525,8 @@
 msgstr "Grundwassermodellierung"
 #: ../gui/wxpython/menustrings.py:383
-msgid ""
-"Numerical calculation program for transient, confined and unconfined "
-"groundwater flow in two dimensions."
-msgstr ""
-"Numerische Berechnung von transientem, beschränktem und unbeschränktem "
-"Grundwasserfluss in zwei Dimensionen."
+msgid "Numerical calculation program for transient, confined and unconfined groundwater flow in two dimensions."
+msgstr "Numerische Berechnung von transientem, beschränktem und unbeschränktem Grundwasserfluss in zwei Dimensionen."
 #: ../gui/wxpython/menustrings.py:384
 msgid "SIMWE Overland flow modeling"
@@ -7975,21 +7534,15 @@
 #: ../gui/wxpython/menustrings.py:385
 msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)."
-msgstr ""
-"Hydrologische Simulation des Oberflächenabfluss mittels \"path sampling"
-"\" (SIMWE)."
+msgstr "Hydrologische Simulation des Oberflächenabfluss mittels \"path sampling\" (SIMWE)."
 #: ../gui/wxpython/menustrings.py:386
 msgid "SIMWE Sediment flux modeling"
 msgstr "SIMWE Sedimentbewegungsmodellierung"
 #: ../gui/wxpython/menustrings.py:387
-msgid ""
-"Sediment transport and erosion/deposition simulation using path sampling "
-"method (SIMWE)."
-msgstr ""
-"Sedimenttransport und Erosions-/Deposition-Simulation mittels \"path sampling"
-"\" (SIMWE)."
+msgid "Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)."
+msgstr "Sedimenttransport und Erosions-/Deposition-Simulation mittels \"path sampling\" (SIMWE)."
 #: ../gui/wxpython/menustrings.py:388
 msgid "Topographic index map"
@@ -8016,50 +7569,32 @@
 msgstr "Setup (erfordert XTerm)"
 #: ../gui/wxpython/menustrings.py:394
-msgid ""
-"Interactive tool used to setup the sampling and analysis framework that will "
-"be used by the other r.le programs."
-msgstr ""
-"Interaktives Werkzeug zur Erzeugung eine Stichprobe- und Analyse-Rahmens, "
-"welche von den anderen r.le-Progammen verwendet werden. "
+msgid "Interactive tool used to setup the sampling and analysis framework that will be used by the other r.le programs."
+msgstr "Interaktives Werkzeug zur Erzeugung eine Stichprobe- und Analyse-Rahmens, welche von den anderen r.le-Progammen verwendet werden. "
 #: ../gui/wxpython/menustrings.py:395
 msgid "Analyze landscape"
 msgstr "Landschaftsanalyse"
 #: ../gui/wxpython/menustrings.py:396
-msgid ""
-"Contains a set of measures for attributes, diversity, texture, "
-"juxtaposition, and edge."
-msgstr ""
-"Beinhaltet ein Satz von Maßen für Attribute, Diversität, Textur, "
-"Nebeneinanderstellung und Kanten"
+msgid "Contains a set of measures for attributes, diversity, texture, juxtaposition, and edge."
+msgstr "Beinhaltet ein Satz von Maßen für Attribute, Diversität, Textur, Nebeneinanderstellung und Kanten"
 #: ../gui/wxpython/menustrings.py:397
 msgid "Analyze patches"
 msgstr "Analysiere Patches"
 #: ../gui/wxpython/menustrings.py:398
-msgid ""
-"Calculates attribute, patch size, core (interior) size, shape, fractal "
-"dimension, and perimeter measures for sets of patches in a landscape."
-msgstr ""
-"Berechnet Attribute, Patch-Grösse, Kerngebiets-Grösse, Form, Fraktale "
-"Dimension und Umfang für ein Satz von Patches in einer Landschaft."
+msgid "Calculates attribute, patch size, core (interior) size, shape, fractal dimension, and perimeter measures for sets of patches in a landscape."
+msgstr "Berechnet Attribute, Patch-Grösse, Kerngebiets-Grösse, Form, Fraktale Dimension und Umfang für ein Satz von Patches in einer Landschaft."
 #: ../gui/wxpython/menustrings.py:399
 msgid "Summary and display (requires XTerm)"
 msgstr "Zusammenfassung und Darstellung  (erfordert XTerm)"
 #: ../gui/wxpython/menustrings.py:400
-msgid ""
-"Displays the boundary of each r.le patch and shows how the boundary is "
-"traced, displays the attribute, size, perimeter and shape indices for each "
-"patch and saves the data in an output file."
-msgstr ""
-"Zeigt die Grenze von jedem r.le patch und deren Verlauf, zeigt das Attribut, "
-"Größe, Umfang und Flächenindizes jedes Patches und speichert die Daten in "
-"einer Ergebnisdatei "
+msgid "Displays the boundary of each r.le patch and shows how the boundary is traced, displays the attribute, size, perimeter and shape indices for each patch and saves the data in an output file."
+msgstr "Zeigt die Grenze von jedem r.le patch und deren Verlauf, zeigt das Attribut, Größe, Umfang und Flächenindizes jedes Patches und speichert die Daten in einer Ergebnisdatei "
 #: ../gui/wxpython/menustrings.py:401
 msgid "Landscape patch analysis"
@@ -8078,11 +7613,8 @@
 msgstr "Kantendichte"
 #: ../gui/wxpython/menustrings.py:405
-msgid ""
-"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
-msgstr ""
-"Berechnet die Kanten-Dichte-Index einer Rasterkarte, unter Verwendung eines "
-"4-Nachbarn-Algorithmus."
+msgid "Calculates edge density index on a raster map, using a 4 neighbour algorithm"
+msgstr "Berechnet die Kanten-Dichte-Index einer Rasterkarte, unter Verwendung eines 4-Nachbarn-Algorithmus."
 #: ../gui/wxpython/menustrings.py:406
 msgid "Contrast weighted edge density"
@@ -8090,21 +7622,15 @@
 #: ../gui/wxpython/menustrings.py:407
 msgid "Calculates contrast weighted edge density index on a raster map"
-msgstr ""
-"Berechnet den Kanten-Dichte-Index einer Rasterkarte gewichtet nach dem "
-"Kontrast"
+msgstr "Berechnet den Kanten-Dichte-Index einer Rasterkarte gewichtet nach dem Kontrast"
 #: ../gui/wxpython/menustrings.py:408
 msgid "Patch area mean"
 msgstr "Mittlere Patchgröße"
 #: ../gui/wxpython/menustrings.py:409
-msgid ""
-"Calculates mean patch size index on a raster map, using a 4 neighbour "
-"algorithm"
-msgstr ""
-"Berechnet die mittlere Patchgrößein einer Rasterkarte, unter Verwendung "
-"eines 4-Nachbarn-Algorithmus."
+msgid "Calculates mean patch size index on a raster map, using a 4 neighbour algorithm"
+msgstr "Berechnet die mittlere Patchgrößein einer Rasterkarte, unter Verwendung eines 4-Nachbarn-Algorithmus."
 #: ../gui/wxpython/menustrings.py:410
 msgid "Patch area range"
@@ -8135,22 +7661,16 @@
 msgstr "Patchdichte"
 #: ../gui/wxpython/menustrings.py:417
-msgid ""
-"Calculates patch density index on a raster map, using a 4 neighbour algorithm"
-msgstr ""
-"Berechnet Patch-Dichte-Index einer Rasterkarte, unter Verwendung eines 4-"
-"Nachbarn-Algorithmus."
+msgid "Calculates patch density index on a raster map, using a 4 neighbour algorithm"
+msgstr "Berechnet Patch-Dichte-Index einer Rasterkarte, unter Verwendung eines 4-Nachbarn-Algorithmus."
 #: ../gui/wxpython/menustrings.py:418
 msgid "Patch number"
 msgstr "Patchanzahl"
 #: ../gui/wxpython/menustrings.py:419
-msgid ""
-"Calculates patch number index on a raster map, using a 4 neighbour algorithm."
-msgstr ""
-"Berechnet Patch-Anzahl-Index einer Rasterkarte, unter Verwendung eines 4-"
+msgid "Calculates patch number index on a raster map, using a 4 neighbour algorithm."
+msgstr "Berechnet Patch-Anzahl-Index einer Rasterkarte, unter Verwendung eines 4-Nachbarn-Algorithmus."
 #: ../gui/wxpython/menustrings.py:420
 msgid "Dominance's diversity"
@@ -8197,43 +7717,24 @@
 msgstr "Ausbreitungsgeschwindigkeit"
 #: ../gui/wxpython/menustrings.py:432
-msgid ""
-"Generates three, or four raster map layers showing 1) the base "
-"(perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the "
-"direction of the maximum ROS, and optionally 4) the maximum potential "
-"spotting distance."
-msgstr ""
-"Erstellt drei oder optional vier Rasterkarten, die 1) die Basisrate der "
-"(lotrechten) Ausbreitung (ROS), 2) die maximale (Vorwärts-) Ausbreitung, 3) "
-"die Richtung der größten Ausbreitung, und optional 4) die maximal zu "
-"erkennende potentielle Ausbreitung, zeigen."
+msgid "Generates three, or four raster map layers showing 1) the base (perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the direction of the maximum ROS, and optionally 4) the maximum potential spotting distance."
+msgstr "Erstellt drei oder optional vier Rasterkarten, die 1) die Basisrate der (lotrechten) Ausbreitung (ROS), 2) die maximale (Vorwärts-) Ausbreitung, 3) die Richtung der größten Ausbreitung, und optional 4) die maximal zu erkennende potentielle Ausbreitung, zeigen."
 #: ../gui/wxpython/menustrings.py:433
 msgid "Least-cost spread paths"
 msgstr "Geringsten-Kosten-Ausbreitungspfade"
 #: ../gui/wxpython/menustrings.py:434
-msgid ""
-"Recursively traces the least cost path backwards to cells from which the "
-"cumulative cost was determined."
-msgstr ""
-"Das Modul verfolgt den kürzesten Weg rekursiv zurück zu den Zellen, von "
-"denen der kumulative Weg bestimmt wurde."
+msgid "Recursively traces the least cost path backwards to cells from which the cumulative cost was determined."
+msgstr "Das Modul verfolgt den kürzesten Weg rekursiv zurück zu den Zellen, von denen der kumulative Weg bestimmt wurde."
 #: ../gui/wxpython/menustrings.py:435
 msgid "Anisotropic spread simulation"
 msgstr "Anisotropische Ausbreitungssimulation"
 #: ../gui/wxpython/menustrings.py:436
-msgid ""
-"Simulates elliptically anisotropic spread on a graphics window and generates "
-"a raster map of the cumulative time of spread, given raster maps containing "
-"the rates of spread (ROS), the ROS directions and the spread origins."
-msgstr ""
-"Simuliert elliptische anisotrophe Ausbreitung in einem Kartenfenster und "
-"erzeugt eine Rasterkarte mit der kumulativen Ausbreitungszeit. Als "
-"Ausgangskarten dienen die Ausbreitungsgeschwindigkeit, Ausbreitungsrichtung "
-"und der Ursprung."
+msgid "Simulates elliptically anisotropic spread on a graphics window and generates a raster map of the cumulative time of spread, given raster maps containing the rates of spread (ROS), the ROS directions and the spread origins."
+msgstr "Simuliert elliptische anisotrophe Ausbreitung in einem Kartenfenster und erzeugt eine Rasterkarte mit der kumulativen Ausbreitungszeit. Als Ausgangskarten dienen die Ausbreitungsgeschwindigkeit, Ausbreitungsrichtung und der Ursprung."
 #: ../gui/wxpython/menustrings.py:437
 msgid "Change category values and labels"
@@ -8252,24 +7753,16 @@
 msgstr "Klassifizieren nach Größe"
 #: ../gui/wxpython/menustrings.py:441
-msgid ""
-"Reclasses a raster map greater or less than user specified area size (in "
-"hectares)."
-msgstr ""
-"Reklassifiziert Bereiche eine Rasterkarte (größer oder kleiner) nach einer "
-"benutzerspezifischen Größe (in ha)."
+msgid "Reclasses a raster map greater or less than user specified area size (in hectares)."
+msgstr "Reklassifiziert Bereiche eine Rasterkarte (größer oder kleiner) nach einer benutzerspezifischen Größe (in ha)."
 #: ../gui/wxpython/menustrings.py:442 ../gui/wxpython/menustrings.py:648
 msgid "Reclassify"
 msgstr "Reklassifiziere"
 #: ../gui/wxpython/menustrings.py:443
-msgid ""
-"Creates a new map layer whose category values are based upon a "
-"reclassification of the categories in an existing raster map layer."
-msgstr ""
-"Erzeugt eine neue Karte, deren Kategoriewerte auf einer Reklassifikation der "
-"Kategorien einer existierenden Rasterkarte basieren."
+msgid "Creates a new map layer whose category values are based upon a reclassification of the categories in an existing raster map layer."
+msgstr "Erzeugt eine neue Karte, deren Kategoriewerte auf einer Reklassifikation der Kategorien einer existierenden Rasterkarte basieren."
 #: ../gui/wxpython/menustrings.py:444
 msgid "Recode"
@@ -8292,12 +7785,8 @@
 msgstr "Neuskalierung mit Histogramm"
 #: ../gui/wxpython/menustrings.py:449
-msgid ""
-"Rescales histogram equalized the range of category values in a raster map "
-"layer."
-msgstr ""
-"Reskaliert ein normalisiertes Histogram basierend auf der Spanne der "
-"Kategoriewerte einer Rasterkarte."
+msgid "Rescales histogram equalized the range of category values in a raster map layer."
+msgstr "Reskaliert ein normalisiertes Histogram basierend auf der Spanne der Kategoriewerte einer Rasterkarte."
 #: ../gui/wxpython/menustrings.py:450
 msgid "Generate random cells"
@@ -8316,12 +7805,8 @@
 msgstr "Zufällige Zellen und Vektorpunkte"
 #: ../gui/wxpython/menustrings.py:454
-msgid ""
-"Creates a raster map layer and vector point map containing randomly located "
-"points."
-msgstr ""
-"Erzeugt eine Rasterkarte und eine Vektorkarte (Punkte) deren Inhalte "
-"räumlich zufällig verteilt sind."
+msgid "Creates a raster map layer and vector point map containing randomly located points."
+msgstr "Erzeugt eine Rasterkarte und eine Vektorkarte (Punkte) deren Inhalte räumlich zufällig verteilt sind."
 #: ../gui/wxpython/menustrings.py:455
 msgid "Generate surfaces"
@@ -8333,55 +7818,35 @@
 #: ../gui/wxpython/menustrings.py:457
 msgid "Creates a fractal surface of a given fractal dimension."
-msgstr ""
-"Erzeugt fraktale Oberflächen nach einer definierten fraktalen Dimension "
+msgstr "Erzeugt fraktale Oberflächen nach einer definierten fraktalen Dimension "
 #: ../gui/wxpython/menustrings.py:458
 msgid "Gaussian kernel density surface"
 msgstr "Gauß'sche Kerndichte Oberfläche"
 #: ../gui/wxpython/menustrings.py:459
-msgid ""
-"Generates a raster density map from vector point data using a moving kernel "
-"or optionally generates a vector density map on a vector network."
-msgstr ""
-"Erzeugt eine Dichte-Rasterkarte aus Vektorpunkten mittels eines \"moving "
-"Kernels\" oder erzeugt optional eine Dichte-Vektorkarte aus einem Netzwerk."
+msgid "Generates a raster density map from vector point data using a moving kernel or optionally generates a vector density map on a vector network."
+msgstr "Erzeugt eine Dichte-Rasterkarte aus Vektorpunkten mittels eines \"moving Kernels\" oder erzeugt optional eine Dichte-Vektorkarte aus einem Netzwerk."
 #: ../gui/wxpython/menustrings.py:460
 msgid "Gaussian deviates surface"
 msgstr "Oberflächen (Gauß'sche Deviate)"
 #: ../gui/wxpython/menustrings.py:461
-msgid ""
-"GRASS module to produce a raster map layer of gaussian deviates whose mean "
-"and standard deviation can be expressed by the user. It uses a gaussian "
-"random number generator."
-msgstr ""
-"GRASS Modul zum Erstellen einer Rasterkarte mit Werten einer Gauß'schen "
-"Verteilung, wobei der Mittelwert und die Standardabweichung vom Benutzer "
-"angegeben werden können. Ein Gauß'scher Zufallszahlengenerator wird "
-"verwendet."
+msgid "GRASS module to produce a raster map layer of gaussian deviates whose mean and standard deviation can be expressed by the user. It uses a gaussian random number generator."
+msgstr "GRASS Modul zum Erstellen einer Rasterkarte mit Werten einer Gauß'schen Verteilung, wobei der Mittelwert und die Standardabweichung vom Benutzer angegeben werden können. Ein Gauß'scher Zufallszahlengenerator wird verwendet."
 #: ../gui/wxpython/menustrings.py:463
-msgid ""
-"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
-"point."
-msgstr ""
-"Erzeugt eine Rasterkarte mit einer Ebene mit gegebener Neigung "
-"(inclination), Ausrichtung (azimuth) und einem Punkt."
+msgid "Creates raster plane map given dip (inclination), aspect (azimuth) and one point."
+msgstr "Erzeugt eine Rasterkarte mit einer Ebene mit gegebener Neigung (inclination), Ausrichtung (azimuth) und einem Punkt."
 #: ../gui/wxpython/menustrings.py:464
 msgid "Random deviates surface"
 msgstr "Oberfläche zufälliger Abweichungen"
 #: ../gui/wxpython/menustrings.py:465
-msgid ""
-"Produces a raster map of uniform random deviates whose range can be "
-"expressed by the user."
-msgstr ""
-"Erzeugt eine Rasterkarte mit gleichverteilten zufälligen Abweichungen, deren "
-"Wertebereiche vom Benutzer festgelegt werden können."
+msgid "Produces a raster map of uniform random deviates whose range can be expressed by the user."
+msgstr "Erzeugt eine Rasterkarte mit gleichverteilten zufälligen Abweichungen, deren Wertebereiche vom Benutzer festgelegt werden können."
 #: ../gui/wxpython/menustrings.py:466
 msgid "Random surface with spatial dependence"
@@ -8409,8 +7874,7 @@
 #: ../gui/wxpython/menustrings.py:472
 msgid "Bicubic or bilinear spline interpolation with Tykhonov regularization."
-msgstr ""
-"Bikubische oder bilineare Spline-Interpolation mit Tykhonov Regularisierung."
+msgstr "Bikubische oder bilineare Spline-Interpolation mit Tykhonov Regularisierung."
 #: ../gui/wxpython/menustrings.py:473
 msgid "IDW from raster points"
@@ -8433,12 +7897,8 @@
 msgstr "IDW aus Vektorpunkten"
 #: ../gui/wxpython/menustrings.py:478
-msgid ""
-"Surface interpolation from vector point data by Inverse Distance Squared "
-"Weighting."
-msgstr ""
-"Oberflächeninterpolation aus Vektor-Punktdaten durch Inverse Distance "
-"Squared Weighting."
+msgid "Surface interpolation from vector point data by Inverse Distance Squared Weighting."
+msgstr "Oberflächeninterpolation aus Vektor-Punktdaten durch Inverse Distance Squared Weighting."
 #: ../gui/wxpython/menustrings.py:479
 msgid "Raster contours"
@@ -8453,15 +7913,8 @@
 msgstr "Regularized spline tension"
 #: ../gui/wxpython/menustrings.py:482
-msgid ""
-"Spatial approximation and topographic analysis from given point or isoline "
-"data in vector format to floating point raster format using regularized "
-"spline with tension."
-msgstr ""
-"Räumliche Approximation und topographische Analyse auf Basis gegebener "
-"Punkte oder Isolinien im Vektorformat unter Verwendung regularisierten "
-"Splinefunktion mit Spannung. Das Ergebnis wird in eine Fließkomma-"
-"Rasterkarte geschrieben."
+msgid "Spatial approximation and topographic analysis from given point or isoline data in vector format to floating point raster format using regularized spline with tension."
+msgstr "Räumliche Approximation und topographische Analyse auf Basis gegebener Punkte oder Isolinien im Vektorformat unter Verwendung regularisierten Splinefunktion mit Spannung. Das Ergebnis wird in eine Fließkomma-Rasterkarte geschrieben."
 #: ../gui/wxpython/menustrings.py:483
 msgid "Ordinary or block kriging"
@@ -8477,8 +7930,7 @@
 #: ../gui/wxpython/menustrings.py:486
 msgid "Fills no-data areas in raster maps using spline interpolation."
-msgstr ""
-"Füllt Flächen ohne Daten in Rasterkarten mit Hilfe der Spline-Interpolation."
+msgstr "Füllt Flächen ohne Daten in Rasterkarten mit Hilfe der Spline-Interpolation."
 #: ../gui/wxpython/menustrings.py:487 ../gui/wxpython/menustrings.py:764
 msgid "Report and statistics"
@@ -8497,12 +7949,8 @@
 msgstr "Verwalte Kategorieinformationen"
 #: ../gui/wxpython/menustrings.py:491
-msgid ""
-"Manages category values and labels associated with user-specified raster map "
-"layers."
-msgstr ""
-"Verwaltet die Kategoriewerte und Beschriftungen von benutzerdefinierten "
-"Rasterkarten."
+msgid "Manages category values and labels associated with user-specified raster map layers."
+msgstr "Verwaltet die Kategoriewerte und Beschriftungen von benutzerdefinierten Rasterkarten."
 #: ../gui/wxpython/menustrings.py:492
 msgid "General statistics"
@@ -8549,12 +7997,8 @@
 msgstr "Statistiken für geklumpte Zellen"
 #: ../gui/wxpython/menustrings.py:503
-msgid ""
-"Calculates the volume of data \"clumps\", and (optionally) produces a GRASS "
-"vector points map containing the calculated centroids of these clumps."
-msgstr ""
-"Berechnet das Volumen von Daten-\"Klumpen\". Optional kann eine GRASS-"
-"Vektorkarte (Punkte) mit den Zentroiden der Datenklumpen erzeugt werden."
+msgid "Calculates the volume of data \"clumps\", and (optionally) produces a GRASS vector points map containing the calculated centroids of these clumps."
+msgstr "Berechnet das Volumen von Daten-\"Klumpen\". Optional kann eine GRASS-Vektorkarte (Punkte) mit den Zentroiden der Datenklumpen erzeugt werden."
 #: ../gui/wxpython/menustrings.py:504
 msgid "Total corrected area"
@@ -8565,10 +8009,8 @@
 msgstr "Abschätzung der Größe der Rasteroberflächen."
 #: ../gui/wxpython/menustrings.py:507
-msgid ""
-"Calculates univariate statistics from the non-null cells of a raster map."
-msgstr ""
-"Berechnet univariate Statistiken der nicht-NULL Zellen einer Rasterkarte."
+msgid "Calculates univariate statistics from the non-null cells of a raster map."
+msgstr "Berechnet univariate Statistiken der nicht-NULL Zellen einer Rasterkarte."
 #: ../gui/wxpython/menustrings.py:508
 msgid "Sample transects"
@@ -8576,32 +8018,23 @@
 #: ../gui/wxpython/menustrings.py:509
 msgid "Outputs the raster map layer values lying on user-defined line(s)."
-msgstr ""
-"Gibt Werte einer Rasterkarte aus, die entlang einer/mehrerer "
-"benutzerdefinierter Linien liegen."
+msgstr "Gibt Werte einer Rasterkarte aus, die entlang einer/mehrerer benutzerdefinierter Linien liegen."
 #: ../gui/wxpython/menustrings.py:510
 msgid "Sample transects (bearing/distance)"
 msgstr "Transekt-Stichprobe (Azimuth, Distanz)"
 #: ../gui/wxpython/menustrings.py:511
-msgid ""
-"Outputs raster map layer values lying along user defined transect line(s)."
-msgstr ""
-"Gibt die Werte einer Rasterkarte aus, die entlang einer/mehrerer "
-"benutzerdefinierter Transekte liegen."
+msgid "Outputs raster map layer values lying along user defined transect line(s)."
+msgstr "Gibt die Werte einer Rasterkarte aus, die entlang einer/mehrerer benutzerdefinierter Transekte liegen."
 #: ../gui/wxpython/menustrings.py:512
 msgid "Covariance/correlation"
 msgstr "Kovarianz/Korrelation"
 #: ../gui/wxpython/menustrings.py:513
-msgid ""
-"Outputs a covariance/correlation matrix for user-specified raster map "
-"layer(s)."
-msgstr ""
-"Gibt eine Kovarianz-/Korrelations-Matrix für benutzerdefiniert Rasterkarten "
-"aus."
+msgid "Outputs a covariance/correlation matrix for user-specified raster map layer(s)."
+msgstr "Gibt eine Kovarianz-/Korrelations-Matrix für benutzerdefiniert Rasterkarten aus."
 #: ../gui/wxpython/menustrings.py:514
 msgid "Linear regression"
@@ -8616,12 +8049,8 @@
 msgstr "gemeinsame Auftreten von Kategorien"
 #: ../gui/wxpython/menustrings.py:517
-msgid ""
-"Tabulates the mutual occurrence (coincidence) of categories for two raster "
-"map layers."
-msgstr ""
-"Tabelliert das gemeinsame Auftreten von Kategorien (Koinzidenz) von zwei "
-"Rasterkarten."
+msgid "Tabulates the mutual occurrence (coincidence) of categories for two raster map layers."
+msgstr "Tabelliert das gemeinsame Auftreten von Kategorien (Koinzidenz) von zwei Rasterkarten."
 #: ../gui/wxpython/menustrings.py:518
 msgid "&Vector"
@@ -8653,12 +8082,8 @@
 msgstr "Editiere Vektorkarte (nicht interaktiv)"
 #: ../gui/wxpython/menustrings.py:525
-msgid ""
-"Edits a vector map, allows adding, deleting and modifying selected vector "
-"features."
-msgstr ""
-"Editiert eine Vektorkarte, ermöglicht das Hinzufügen, Löschen und Ändern "
-"ausgewählter Vektorobjekte."
+msgid "Edits a vector map, allows adding, deleting and modifying selected vector features."
+msgstr "Editiert eine Vektorkarte, ermöglicht das Hinzufügen, Löschen und Ändern ausgewählter Vektorobjekte."
 #: ../gui/wxpython/menustrings.py:526
 msgid "Convert object types"
@@ -8681,12 +8106,8 @@
 msgstr "Grenzen auflösen"
 #: ../gui/wxpython/menustrings.py:531
-msgid ""
-"Dissolves boundaries between adjacent areas sharing a common category number "
-"or attribute."
-msgstr ""
-"Löst Grenzen zwischen benachbarten Flächen mit gleicher Kategorienummer oder "
-"gleichem Attributwert auf."
+msgid "Dissolves boundaries between adjacent areas sharing a common category number or attribute."
+msgstr "Löst Grenzen zwischen benachbarten Flächen mit gleicher Kategorienummer oder gleichem Attributwert auf."
 #: ../gui/wxpython/menustrings.py:532
 msgid "Create 3D vector over raster"
@@ -8694,9 +8115,7 @@
 #: ../gui/wxpython/menustrings.py:533
 msgid "Converts vector map to 3D by sampling of elevation raster map."
-msgstr ""
-"Konvertiert eine Vektorkarte nach 3D durch Abtasten einer Karte mit "
-"Höheninformationen."
+msgstr "Konvertiert eine Vektorkarte nach 3D durch Abtasten einer Karte mit Höheninformationen."
 #: ../gui/wxpython/menustrings.py:534
 msgid "Extrude 3D vector map"
@@ -8727,12 +8146,8 @@
 msgstr "Vektorkarte repositionieren"
 #: ../gui/wxpython/menustrings.py:541
-msgid ""
-"Performs an affine transformation (shift, scale and rotate, or GPCs) on "
-"vector map."
-msgstr ""
-"Führt eine affine Transformation (schieben, skalieren und rotieren oder "
-"GPCs) von Vektorkarten durch."
+msgid "Performs an affine transformation (shift, scale and rotate, or GPCs) on vector map."
+msgstr "Führt eine affine Transformation (schieben, skalieren und rotieren oder GPCs) von Vektorkarten durch."
 #: ../gui/wxpython/menustrings.py:542
 msgid "Reproject vector map"
@@ -8740,8 +8155,7 @@
 #: ../gui/wxpython/menustrings.py:543
 msgid "Re-projects a vector map from one location to the current location."
-msgstr ""
-"Re-Projektion einer Vektorkarte von einer Location zur aktuellen Location."
+msgstr "Re-Projektion einer Vektorkarte von einer Location zur aktuellen Location."
 #: ../gui/wxpython/menustrings.py:545
 msgid "Updates vector map metadata."
@@ -8816,11 +8230,8 @@
 msgstr "Fügt fehlende Zentroide zu geschlossenen Grenzen hinzu."
 #: ../gui/wxpython/menustrings.py:565
-msgid ""
-"Set color rules for features in a vector using a numeric attribute column."
-msgstr ""
-"Bestimme Farbregeln für Objekte einer Vektorkarte unter Verwendung einer "
-"numerischen Spalte der Attributtabelle."
+msgid "Set color rules for features in a vector using a numeric attribute column."
+msgstr "Bestimme Farbregeln für Objekte einer Vektorkarte unter Verwendung einer numerischen Spalte der Attributtabelle."
 #: ../gui/wxpython/menustrings.py:567
 msgid "Interactive management of vector color tables."
@@ -8855,34 +8266,24 @@
 msgstr "Attributabfrage"
 #: ../gui/wxpython/menustrings.py:575
-msgid ""
-"Selects vector objects from an existing vector map and creates a new map "
-"containing only the selected objects."
-msgstr ""
-"Selektiert Vektorobjekte einer existierenden Vektorkarte und erzeugt eine "
-"neue Karte nur mit den selektierten Objekten."
+msgid "Selects vector objects from an existing vector map and creates a new map containing only the selected objects."
+msgstr "Selektiert Vektorobjekte einer existierenden Vektorkarte und erzeugt eine neue Karte nur mit den selektierten Objekten."
 #: ../gui/wxpython/menustrings.py:576
 msgid "Spatial query"
 msgstr "Räumliche Abfrage"
 #: ../gui/wxpython/menustrings.py:577
-msgid ""
-"Selects features from vector map (A) by features from other vector map (B)."
-msgstr ""
-"Selektiert Objekte einer Vektorkarte (A) durch Objekte einer anderen "
-"Vektorkarte (B). "
+msgid "Selects features from vector map (A) by features from other vector map (B)."
+msgstr "Selektiert Objekte einer Vektorkarte (A) durch Objekte einer anderen Vektorkarte (B). "
 #: ../gui/wxpython/menustrings.py:587
 msgid "Buffer vectors"
-msgstr "Vektor buffern"
+msgstr "Vektor puffern"
 #: ../gui/wxpython/menustrings.py:588
-msgid ""
-"Creates a buffer around features of given type (areas must contain centroid)."
-msgstr ""
-"Erzeugt einen Buffer um Objekte bestimmten Typs (Flächen müssen Zentroide "
-"enthalten)."
+msgid "Creates a buffer around features of given type (areas must contain centroid)."
+msgstr "Erzeugt einen Puffer um Objekte bestimmten Typs (Flächen müssen Zentroide enthalten)."
 #: ../gui/wxpython/menustrings.py:589
 msgid "Lidar analysis"
@@ -8901,24 +8302,16 @@
 msgstr "Innenräume erkennen"
 #: ../gui/wxpython/menustrings.py:593
-msgid ""
-"Building contour determination and Region Growing algorithm for determining "
-"the building inside"
-msgstr ""
-"Bestimmung der Gebäudeumrisse und Ermittelung des Gebäudeinneren mittels des "
-"'Region Growing' Verfahrens"
+msgid "Building contour determination and Region Growing algorithm for determining the building inside"
+msgstr "Bestimmung der Gebäudeumrisse und Ermittelung des Gebäudeinneren mittels des 'Region Growing' Verfahrens"
 #: ../gui/wxpython/menustrings.py:594
 msgid "Correct and reclassify objects"
 msgstr "Korrigiere und Reklassifiziere Objekte"
 #: ../gui/wxpython/menustrings.py:595
-msgid ""
-"Correction of the v.lidar.growing output. It is the last of the three "
-"algorithms for LIDAR filtering."
-msgstr ""
-"Korrektur der v.lidar.growing Ausgabe. Dies ist der letzte von drei LiDAR "
-"Filter-Algorithmen."
+msgid "Correction of the v.lidar.growing output. It is the last of the three algorithms for LIDAR filtering."
+msgstr "Korrektur der v.lidar.growing Ausgabe. Dies ist der letzte von drei LiDAR Filter-Algorithmen."
 #: ../gui/wxpython/menustrings.py:596
 msgid "Linear referencing"
@@ -8938,45 +8331,31 @@
 #: ../gui/wxpython/menustrings.py:600
 msgid "Creates stationing from input lines, and linear reference system"
-msgstr ""
-"Erzeuge Stationen auf Basis der Eingabe-Linien und dem linearen "
-"Referenzsystem."
+msgstr "Erzeuge Stationen auf Basis der Eingabe-Linien und dem linearen Referenzsystem."
 #: ../gui/wxpython/menustrings.py:601
 msgid "Create points/segments"
 msgstr "Erzeuge Punkte/Segmente"
 #: ../gui/wxpython/menustrings.py:602
-msgid ""
-"Creates points/segments from input lines, linear reference system and "
-"positions read from stdin or a file."
-msgstr ""
-"Erzeuge Punkte/Segmente auf Basis der Eingabelinien, des "
-"Linearenreferenzsystems und Positionen von stdin oder einer Datei."
+msgid "Creates points/segments from input lines, linear reference system and positions read from stdin or a file."
+msgstr "Erzeuge Punkte/Segmente auf Basis der Eingabelinien, des Linearenreferenzsystems und Positionen von stdin oder einer Datei."
 #: ../gui/wxpython/menustrings.py:603
 msgid "Find line id and offset"
 msgstr "Finde Linien ID und Versatz"
 #: ../gui/wxpython/menustrings.py:604
-msgid ""
-"Finds line id and real km+offset for given points in vector map using linear "
-"reference system."
-msgstr ""
-"Findet die ID der Linie und tatsächliche km+Versatz für gegebene Punkte "
-"einer Vektorkarte mit Hilfe eines Linearenreferenzsystems."
+msgid "Finds line id and real km+offset for given points in vector map using linear reference system."
+msgstr "Findet die ID der Linie und tatsächliche km+Versatz für gegebene Punkte einer Vektorkarte mit Hilfe eines Linearenreferenzsystems."
 #: ../gui/wxpython/menustrings.py:605
 msgid "Nearest features"
 msgstr "Nächstliegendes Objekt"
 #: ../gui/wxpython/menustrings.py:606
-msgid ""
-"Finds the nearest element in vector map 'to' for elements in vector map "
-"'from'."
-msgstr ""
-"Findet das nächstgelegene Element der Vektorkarte 'to' für Elemente in der "
-"Vektorkarte 'from'. "
+msgid "Finds the nearest element in vector map 'to' for elements in vector map 'from'."
+msgstr "Findet das nächstgelegene Element der Vektorkarte 'to' für Elemente in der Vektorkarte 'from'. "
 #: ../gui/wxpython/menustrings.py:607
 msgid "Network analysis"
@@ -9019,11 +8398,8 @@
 msgstr "Kürzester Pfad für eine Gruppen von Objekten"
 #: ../gui/wxpython/menustrings.py:617
-msgid ""
-"Computes shortest distance via the network between the given sets of "
-"features."
-msgstr ""
-"Berechnet kürzeste Distanzen im Netzwerk zwischen Gruppen von Objekten."
+msgid "Computes shortest distance via the network between the given sets of features."
+msgstr "Berechnet kürzeste Distanzen im Netzwerk zwischen Gruppen von Objekten."
 #: ../gui/wxpython/menustrings.py:618
 msgid "Shortest path using timetables"
@@ -9039,8 +8415,7 @@
 #: ../gui/wxpython/menustrings.py:621
 msgid "Computes the shortest path between all pairs of nodes in the network."
-msgstr ""
-"Berechnet den kürzesten Pfad zwischen allen Paaren von Knoten des Netzwerks."
+msgstr "Berechnet den kürzesten Pfad zwischen allen Paaren von Knoten des Netzwerks."
 #: ../gui/wxpython/menustrings.py:622
 msgid "Visibility network"
@@ -9064,8 +8439,7 @@
 #: ../gui/wxpython/menustrings.py:627
 msgid "Computes the maximum flow between two sets of nodes in the network."
-msgstr ""
-"Berechnet den maximalen Fluss zwischen zwei Gruppen von Knoten im Netzwerk."
+msgstr "Berechnet den maximalen Fluss zwischen zwei Gruppen von Knoten im Netzwerk."
 #: ../gui/wxpython/menustrings.py:628
 msgid "Vertex connectivity"
@@ -9073,8 +8447,7 @@
 #: ../gui/wxpython/menustrings.py:629
 msgid "Computes vertex connectivity between two sets of nodes in the network."
-msgstr ""
-"Berechnet Vertex Konnektivität zwischen zwei Gruppen von Knoten im Netzwerk."
+msgstr "Berechnet Vertex Konnektivität zwischen zwei Gruppen von Knoten im Netzwerk."
 #: ../gui/wxpython/menustrings.py:630
 msgid "Components"
@@ -9089,12 +8462,8 @@
 msgstr "Zentralheit"
 #: ../gui/wxpython/menustrings.py:633
-msgid ""
-"Computes degree, centrality, betweeness, closeness and eigenvector "
-"centrality measures in the network."
-msgstr ""
-"Berechnet Grad, Zentralität, Betweenness, Closeness und "
-"Eigenvektorzentralitätsmaße im Netzwerk."
+msgid "Computes degree, centrality, betweeness, closeness and eigenvector centrality measures in the network."
+msgstr "Berechnet Grad, Zentralität, Betweenness, Closeness und Eigenvektorzentralitätsmaße im Netzwerk."
 #: ../gui/wxpython/menustrings.py:634
 msgid "Steiner tree"
@@ -9118,9 +8487,7 @@
 #: ../gui/wxpython/menustrings.py:639
 msgid "Creates a cycle connecting given nodes (Traveling salesman problem)."
-msgstr ""
-"Erzeugt einen Ring, der die gegebenen Knoten verbindet (Handelsreisenden-"
-"Problem)."
+msgstr "Erzeugt einen Ring, der die gegebenen Knoten verbindet (Handelsreisenden-Problem)."
 #: ../gui/wxpython/menustrings.py:640 ../gui/wxpython/menustrings.py:641
 msgid "Overlay vector maps"
@@ -9148,16 +8515,11 @@
 #: ../gui/wxpython/menustrings.py:647
 msgid "Attach, delete or report vector categories to map geometry."
-msgstr ""
-"Füge hinzu, Lösche oder Berichte Vektorkategorien einer Kartengeometrie."
+msgstr "Füge hinzu, Lösche oder Berichte Vektorkategorien einer Kartengeometrie."
 #: ../gui/wxpython/menustrings.py:649
-msgid ""
-"Changes vector category values for an existing vector map according to "
-"results of SQL queries or a value in attribute table column."
-msgstr ""
-"Ändert die Kategorien einer existierenden Vektorkarte entsprechend den "
-"Ergebnissen der SQL-Abfragen oder der Werte einer Spalte der Attributtabelle."
+msgid "Changes vector category values for an existing vector map according to results of SQL queries or a value in attribute table column."
+msgstr "Ändert die Kategorien einer existierenden Vektorkarte entsprechend den Ergebnissen der SQL-Abfragen oder der Werte einer Spalte der Attributtabelle."
 #: ../gui/wxpython/menustrings.py:650 ../gui/wxpython/dbmgr/dialogs.py:112
 msgid "Update attributes"
@@ -9168,12 +8530,8 @@
 msgstr "Aktualisiere Flächenattribute aus Raster"
 #: ../gui/wxpython/menustrings.py:652
-msgid ""
-"Calculates univariate statistics from a raster map based on vector polygons "
-"and uploads statistics to new attribute columns."
-msgstr ""
-"Berechnet univariate Statistik einer Rasterkarte, basierend auf Polygone und "
-"ergänzt die Ergebnisse als neue Spalte der Attributtabelle."
+msgid "Calculates univariate statistics from a raster map based on vector polygons and uploads statistics to new attribute columns."
+msgstr "Berechnet univariate Statistik einer Rasterkarte, basierend auf Polygone und ergänzt die Ergebnisse als neue Spalte der Attributtabelle."
 #: ../gui/wxpython/menustrings.py:653
 msgid "Update point attributes from areas"
@@ -9197,9 +8555,7 @@
 #: ../gui/wxpython/menustrings.py:658
 msgid "Uploads raster values at positions of vector points to the table."
-msgstr ""
-"Übernimmt die Rasterwerte an den Positionen der Vektorpunkte in die "
-"Attributtabelle."
+msgstr "Übernimmt die Rasterwerte an den Positionen der Vektorpunkte in die Attributtabelle."
 #: ../gui/wxpython/menustrings.py:659
 msgid "Sample raster neighborhood around points"
@@ -9234,24 +8590,16 @@
 msgstr "Delaunay-Dreiecke"
 #: ../gui/wxpython/menustrings.py:667
-msgid ""
-"Creates a Delaunay triangulation from an input vector map containing points "
-"or centroids."
-msgstr ""
-"Erzeugt eine Delaunay-Triangulation auf Basis einer Eingabe-Vektorkarte mit "
-"Punkten oder Zentroiden."
+msgid "Creates a Delaunay triangulation from an input vector map containing points or centroids."
+msgstr "Erzeugt eine Delaunay-Triangulation auf Basis einer Eingabe-Vektorkarte mit Punkten oder Zentroiden."
 #: ../gui/wxpython/menustrings.py:668
 msgid "Voronoi diagram/Thiessen polygons"
 msgstr "Voronoi Diagramm / Thiessen Polygone"
 #: ../gui/wxpython/menustrings.py:669
-msgid ""
-"Creates a Voronoi diagram from an input vector map containing points or "
-"centroids."
-msgstr ""
-"Erstellt ein Voronoi Diagramm auf Basis einer Vektorkarte mit Punkten oder "
-"Zentroiden."
+msgid "Creates a Voronoi diagram from an input vector map containing points or centroids."
+msgstr "Erstellt ein Voronoi Diagramm auf Basis einer Vektorkarte mit Punkten oder Zentroiden."
 #: ../gui/wxpython/menustrings.py:670
 msgid "Generate grid"
@@ -9259,8 +8607,7 @@
 #: ../gui/wxpython/menustrings.py:671
 msgid "Creates a GRASS vector map of a user-defined grid."
-msgstr ""
-"Erzeugt eine GRASS Vektorkarte mit einem benutzerdefinierten Gitternetz."
+msgstr "Erzeugt eine GRASS Vektorkarte mit einem benutzerdefinierten Gitternetz."
 #: ../gui/wxpython/menustrings.py:672
 msgid "Generate points"
@@ -9271,11 +8618,8 @@
 msgstr "Erzeuge aus Datenbank"
 #: ../gui/wxpython/menustrings.py:674
-msgid ""
-"Creates new vector (points) map from database table containing coordinates."
-msgstr ""
-"Erzeugt neue Vektorkarte (Punkte) aus einer Datenbanktabelle, die "
-"Koordinaten beinhaltet."
+msgid "Creates new vector (points) map from database table containing coordinates."
+msgstr "Erzeugt neue Vektorkarte (Punkte) aus einer Datenbanktabelle, die Koordinaten beinhaltet."
 #: ../gui/wxpython/menustrings.py:675
 msgid "Generate points along lines"
@@ -9283,8 +8627,7 @@
 #: ../gui/wxpython/menustrings.py:676
 msgid "Create points along input lines in new vector with 2 layers."
-msgstr ""
-"Erzeuge Punkte entlang der Eingabelinien in neue Vektorkarte mit zwei Layern."
+msgstr "Erzeuge Punkte entlang der Eingabelinien in neue Vektorkarte mit zwei Layern."
 #: ../gui/wxpython/menustrings.py:677
 msgid "Generate random points"
@@ -9328,8 +8671,7 @@
 #: ../gui/wxpython/menustrings.py:687
 msgid "Outputs basic information about a user-specified vector map."
-msgstr ""
-"Gibt grundlegende Informationen über eine benutzerdefinierte Vektorkarte aus."
+msgstr "Gibt grundlegende Informationen über eine benutzerdefinierte Vektorkarte aus."
 #: ../gui/wxpython/menustrings.py:688
 msgid "Classify attribute data"
@@ -9352,24 +8694,16 @@
 msgstr "Univariate Statistik für Punktattribute"
 #: ../gui/wxpython/menustrings.py:693
-msgid ""
-"Calculates univariate statistics for attribute. Variance and standard "
-"deviation is calculated only for points if specified."
-msgstr ""
-"Berechnet univariate Statistiken für die Attribute. Die Varianz und "
-"Standardabweichung wird nur für Punkte berechnet wenn explizit angefragt."
+msgid "Calculates univariate statistics for attribute. Variance and standard deviation is calculated only for points if specified."
+msgstr "Berechnet univariate Statistiken für die Attribute. Die Varianz und Standardabweichung wird nur für Punkte berechnet wenn explizit angefragt."
 #: ../gui/wxpython/menustrings.py:694
 msgid "Univariate statistics for attribute columns"
 msgstr "Univariate Statistik für Attributspalten"
 #: ../gui/wxpython/menustrings.py:695
-msgid ""
-"Calculates univariate statistics on selected table column for a GRASS vector "
-"map."
-msgstr ""
-"Berechnet univariate Statistiken in ausgewählten Tabellenspalten einer GRASS "
-"Vektorkarte."
+msgid "Calculates univariate statistics on selected table column for a GRASS vector map."
+msgstr "Berechnet univariate Statistiken in ausgewählten Tabellenspalten einer GRASS Vektorkarte."
 #: ../gui/wxpython/menustrings.py:696
 msgid "Quadrat indices"
@@ -9417,9 +8751,7 @@
 #: ../gui/wxpython/menustrings.py:707
 msgid "Mosaics up to 4 images and extends colormap; creates map *.mosaic"
-msgstr ""
-"Mosaikiert bis zu 4 Bilder und erweitert die Farbtabelle. Erzeugt *.mosaic-"
-"Karten."
+msgstr "Mosaikiert bis zu 4 Bilder und erweitert die Farbtabelle. Erzeugt *.mosaic-Karten."
 #: ../gui/wxpython/menustrings.py:708
 msgid "Manage image colors"
@@ -9438,32 +8770,20 @@
 msgstr "HIS zu RGB"
 #: ../gui/wxpython/menustrings.py:712
-msgid ""
-"Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
-"RGB (Red-Green-Blue) color space."
-msgstr ""
-"Transformiert Rasterkarten aus dem HIS (Hue-Intensity-Saturation) Farbraum "
-"in den RGB (Rot-Grün-Blau) Farbraum."
+msgid "Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to RGB (Red-Green-Blue) color space."
+msgstr "Transformiert Rasterkarten aus dem HIS (Hue-Intensity-Saturation) Farbraum in den RGB (Rot-Grün-Blau) Farbraum."
 #: ../gui/wxpython/menustrings.py:714
-msgid ""
-"Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-"
-"Intensity-Saturation) color space."
-msgstr ""
-"Transformiert Rasterkarten aus dem RGB (Rot-Grün-Blau) Farbraum in den HIS "
-"(Hue-Intensity-Saturation) Farbraum."
+msgid "Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-Intensity-Saturation) color space."
+msgstr "Transformiert Rasterkarten aus dem RGB (Rot-Grün-Blau) Farbraum in den HIS (Hue-Intensity-Saturation) Farbraum."
 #: ../gui/wxpython/menustrings.py:715
 msgid "Rectify image or raster"
 msgstr "Rektifiziere Bild oder Raster"
 #: ../gui/wxpython/menustrings.py:716
-msgid ""
-"Rectifies an image by computing a coordinate transformation for each pixel "
-"in the image based on the control points."
-msgstr ""
-"Rektifiziert ein Bild durch Berechnung einer Koordinatentransformation für "
-"jedes Pixel des Bildes basierend auf den Kontrollpunkten."
+msgid "Rectifies an image by computing a coordinate transformation for each pixel in the image based on the control points."
+msgstr "Rektifiziert ein Bild durch Berechnung einer Koordinatentransformation für jedes Pixel des Bildes basierend auf den Kontrollpunkten."
 #: ../gui/wxpython/menustrings.py:718
 msgid "Generate histogram of image"
@@ -9474,22 +8794,16 @@
 msgstr "Spektralwert"
 #: ../gui/wxpython/menustrings.py:720
-msgid ""
-"Displays spectral response at user specified locations in group or images."
-msgstr ""
-"Zeigt die Spektralwerte von Gruppen oder Bildern an einem ausgewählten Ort "
-"an."
+msgid "Displays spectral response at user specified locations in group or images."
+msgstr "Zeigt die Spektralwerte von Gruppen oder Bildern an einem ausgewählten Ort an."
 #: ../gui/wxpython/menustrings.py:721
 msgid "Brovey sharpening"
 msgstr "Brovey-Schärfen"
 #: ../gui/wxpython/menustrings.py:722
-msgid ""
-"Brovey transform to merge multispectral and high-res panchromatic channels"
-msgstr ""
-"Brovey-Transformation zum mischen multispektraler und hochaufgelöster "
-"panchromatischer Kanäle."
+msgid "Brovey transform to merge multispectral and high-res panchromatic channels"
+msgstr "Brovey-Transformation zum mischen multispektraler und hochaufgelöster panchromatischer Kanäle."
 #: ../gui/wxpython/menustrings.py:723
 msgid "Classify image"
@@ -9500,12 +8814,8 @@
 msgstr "Clustert die Eingabe für eine unüberwachte Klassifikation."
 #: ../gui/wxpython/menustrings.py:725
-msgid ""
-"Generates spectral signatures for land cover types in an image using a "
-"clustering algorithm."
-msgstr ""
-"Erzeugt spektrale Signaturen für Landbedeckungsklassen eines Bildes mittels "
-"eines Clusteralgorithmus."
+msgid "Generates spectral signatures for land cover types in an image using a clustering algorithm."
+msgstr "Erzeugt spektrale Signaturen für Landbedeckungsklassen eines Bildes mittels eines Clusteralgorithmus."
 #: ../gui/wxpython/menustrings.py:726
 msgid "Input for supervised MLC"
@@ -9521,21 +8831,15 @@
 #: ../gui/wxpython/menustrings.py:729
 msgid "Classifies the cell spectral reflectances in imagery data."
-msgstr ""
-"Klassifiziert die spektrale Reflektion (spectral reflectance) in Bilddaten."
+msgstr "Klassifiziert die spektrale Reflektion (spectral reflectance) in Bilddaten."
 #: ../gui/wxpython/menustrings.py:730
 msgid "Interactive input for supervised classification (requires Xterm)"
-msgstr ""
-"Interaktive Eingabe für eine überwachte Klassifikation (benötigt Xterm)."
+msgstr "Interaktive Eingabe für eine überwachte Klassifikation (benötigt Xterm)."
 #: ../gui/wxpython/menustrings.py:731
-msgid ""
-"Generates spectral signatures for an image by allowing the user to outline "
-"regions of interest."
-msgstr ""
-"Erzeugt spektrale Signaturen für ein Bild, in dem es dem Benutzer erlaubt "
-"Trainingsgebiete zu markieren."
+msgid "Generates spectral signatures for an image by allowing the user to outline regions of interest."
+msgstr "Erzeugt spektrale Signaturen für ein Bild, in dem es dem Benutzer erlaubt Trainingsgebiete zu markieren."
 #: ../gui/wxpython/menustrings.py:732
 msgid "Input for supervised SMAP"
@@ -9550,12 +8854,8 @@
 msgstr "Sequential maximum a posteriori classification (SMAP)"
 #: ../gui/wxpython/menustrings.py:735
-msgid ""
-"Performs contextual image classification using sequential maximum a "
-"posteriori (SMAP) estimation."
-msgstr ""
-"Führt eine nachbarschaftsbasierte Bildklassifikation unter Anwendung des "
-"'sequential maximum a posteriori (SMAP)' Ansatzes durch."
+msgid "Performs contextual image classification using sequential maximum a posteriori (SMAP) estimation."
+msgstr "Führt eine nachbarschaftsbasierte Bildklassifikation unter Anwendung des 'sequential maximum a posteriori (SMAP)' Ansatzes durch."
 #: ../gui/wxpython/menustrings.py:736
 msgid "Filter image"
@@ -9587,8 +8887,7 @@
 #: ../gui/wxpython/menustrings.py:743
 msgid "Canonical components analysis (cca) program for image processing."
-msgstr ""
-"Kanonische Komponenten Analyse (cca) Programm für die Bildverarbeitung."
+msgstr "Kanonische Komponenten Analyse (cca) Programm für die Bildverarbeitung."
 #: ../gui/wxpython/menustrings.py:744
 msgid "Principal components"
@@ -9623,12 +8922,8 @@
 msgstr "Landsat Zahlen zu Strahlung/Reflexion"
 #: ../gui/wxpython/menustrings.py:752
-msgid ""
-"Calculates top-of-atmosphere radiance or reflectance and temperature for "
-"Landsat MSS/TM/ETM+."
-msgstr ""
-"Berechnet top-of-atmosphere Strahlung oder Reflexion und Temperatur für "
+msgid "Calculates top-of-atmosphere radiance or reflectance and temperature for Landsat MSS/TM/ETM+."
+msgstr "Berechnet top-of-atmosphere Strahlung oder Reflexion und Temperatur für Landsat MSS/TM/ETM+."
 #: ../gui/wxpython/menustrings.py:753
 msgid "Landsat cloud cover assessment"
@@ -9636,9 +8931,7 @@
 #: ../gui/wxpython/menustrings.py:754
 msgid "Performs Landsat TM/ETM+ Automatic Cloud Cover Assessment (ACCA)."
-msgstr ""
-"Führt Landsat TM/ETM+ automatische Einschätzung der Wolkenbedeckung (ACCA) "
-"durch."
+msgstr "Führt Landsat TM/ETM+ automatische Einschätzung der Wolkenbedeckung (ACCA) durch."
 #: ../gui/wxpython/menustrings.py:755
 msgid "Modis quality control"
@@ -9689,12 +8982,8 @@
 msgstr "Kappa Analyse"
 #: ../gui/wxpython/menustrings.py:768
-msgid ""
-"Calculate error matrix and kappa parameter for accuracy assessment of "
-"classification result."
-msgstr ""
-"Berechnet Fehlermatrix und Kappa-Parameter für die Genauigkeitsabschätzung "
-"(accuracy assessment) der Klassifikationsergebnisse."
+msgid "Calculate error matrix and kappa parameter for accuracy assessment of classification result."
+msgstr "Berechnet Fehlermatrix und Kappa-Parameter für die Genauigkeitsabschätzung (accuracy assessment) der Klassifikationsergebnisse."
 #: ../gui/wxpython/menustrings.py:769
 msgid "OIF for LandSat TM"
@@ -9702,8 +8991,7 @@
 #: ../gui/wxpython/menustrings.py:770
 msgid "Calculates Optimum-Index-Factor table for LANDSAT TM bands 1-5, & 7"
-msgstr ""
-"Berechne die Optimum-Index-Faktor Tabelle für die LANDSAT TM Kanäle 1-5, & 7."
+msgstr "Berechne die Optimum-Index-Faktor Tabelle für die LANDSAT TM Kanäle 1-5, & 7."
 #: ../gui/wxpython/menustrings.py:771
 msgid "V&olumes"
@@ -9727,8 +9015,7 @@
 #: ../gui/wxpython/menustrings.py:776
 msgid "Print/add/remove a timestamp for a 3D raster map"
-msgstr ""
-"Ausgeben/Hinzufügen/Entfernen eines Zeitstempels für eine 3D-Rasterkarte"
+msgstr "Ausgeben/Hinzufügen/Entfernen eines Zeitstempels für eine 3D-Rasterkarte"
 #: ../gui/wxpython/menustrings.py:780
 msgid "3D Mask"
@@ -9751,32 +9038,20 @@
 msgstr "Querschnitt"
 #: ../gui/wxpython/menustrings.py:785
-msgid ""
-"Creates cross section 2D raster map from 3D raster map based on 2D elevation "
-"map."
-msgstr ""
-"Erzeugt einen Querschnitt in Form einer 2D-Rasterkarte aus einer 3D-"
-"Rasterkarte basierend auf 2D-Höhenkarte."
+msgid "Creates cross section 2D raster map from 3D raster map based on 2D elevation map."
+msgstr "Erzeugt einen Querschnitt in Form einer 2D-Rasterkarte aus einer 3D-Rasterkarte basierend auf 2D-Höhenkarte."
 #: ../gui/wxpython/menustrings.py:787
-msgid ""
-"Calculates numerically transient, confined groundwater flow in three "
-"dimensions."
-msgstr ""
-"Programm zur numerischen Berechnung des transienten, beschränkten "
-"Grundwasserflusses in drei Dimensionen."
+msgid "Calculates numerically transient, confined groundwater flow in three dimensions."
+msgstr "Programm zur numerischen Berechnung des transienten, beschränkten Grundwasserflusses in drei Dimensionen."
 #: ../gui/wxpython/menustrings.py:788
 msgid "Interpolate volume from points"
 msgstr "Interpoliere Volumen aus Punkten"
 #: ../gui/wxpython/menustrings.py:789
-msgid ""
-"Interpolates point data to a 3D raster map using regularized spline with "
-"tension (RST) algorithm."
-msgstr ""
-"Interpoliert Punkte zu einem G3D Grid Volumen unter Verwendung des "
-"regularized spline with tension (RST) Algorithmus."
+msgid "Interpolates point data to a 3D raster map using regularized spline with tension (RST) algorithm."
+msgstr "Interpoliert Punkte zu einem G3D Grid Volumen unter Verwendung des regularized spline with tension (RST) Algorithmus."
 #: ../gui/wxpython/menustrings.py:790
 msgid "Report and Statistics"
@@ -9803,11 +9078,8 @@
 msgstr "Univariate Statistiken für Volumen"
 #: ../gui/wxpython/menustrings.py:796
-msgid ""
-"Calculates univariate statistics from the non-null 3d cells of a raster3d "
-"map."
-msgstr ""
-"Berechnet univariate Statistiken der nicht-NULL Zellen einer 3D-Rasterkarte."
+msgid "Calculates univariate statistics from the non-null 3d cells of a raster3d map."
+msgstr "Berechnet univariate Statistiken der nicht-NULL Zellen einer 3D-Rasterkarte."
 #: ../gui/wxpython/menustrings.py:797
 msgid "&Database"
@@ -9859,9 +9131,7 @@
 #: ../gui/wxpython/menustrings.py:809
 msgid "Prints/sets general DB connection for current mapset and exits."
-msgstr ""
-"Gibt oder setzt allgemeine Datenbankverbindung für das aktuelle Mapset und "
-"beendet sich."
+msgstr "Gibt oder setzt allgemeine Datenbankverbindung für das aktuelle Mapset und beendet sich."
 #: ../gui/wxpython/menustrings.py:810
 msgid "Login"
@@ -9901,9 +9171,7 @@
 #: ../gui/wxpython/menustrings.py:819
 msgid "Test database driver, database must exist and set by db.connect."
-msgstr ""
-"Teste den Datenbank-Treiber. Die Datenbank muß existieren und mittels db."
-"connect verbunden sein."
+msgstr "Teste den Datenbank-Treiber. Die Datenbank muß existieren und mittels db.connect verbunden sein."
 #: ../gui/wxpython/menustrings.py:820 ../gui/wxpython/dbmgr/sqlbuilder.py:99
 msgid "Query"
@@ -9934,12 +9202,8 @@
 msgstr "Neue Tabelle"
 #: ../gui/wxpython/menustrings.py:829
-msgid ""
-"Creates and connects a new attribute table to a given layer of an existing "
-"vector map."
-msgstr ""
-"Erzeugt und verbindet eine neue Attributtabelle für einen Layer einer "
-"existierenden Vektorkarte."
+msgid "Creates and connects a new attribute table to a given layer of an existing vector map."
+msgstr "Erzeugt und verbindet eine neue Attributtabelle für einen Layer einer existierenden Vektorkarte."
 #: ../gui/wxpython/menustrings.py:830
 msgid "Remove table"
@@ -9962,38 +9226,27 @@
 msgstr "Spalte hinzufügen"
 #: ../gui/wxpython/menustrings.py:835
-msgid ""
-"Adds one or more columns to the attribute table connected to a given vector "
-"map."
-msgstr ""
-"Fügt eine oder mehrere Spalten zu der Attributtabelle einer Vektorkarte "
-"hinzu."
+msgid "Adds one or more columns to the attribute table connected to a given vector map."
+msgstr "Fügt eine oder mehrere Spalten zu der Attributtabelle einer Vektorkarte hinzu."
 #: ../gui/wxpython/menustrings.py:837
-msgid ""
-"Drops a column from the attribute table connected to a given vector map."
-msgstr ""
-"Löscht eine Spalte in einer Attributtabelle die mit einer bestimmten "
-"Vektorkarte verbunden ist."
+msgid "Drops a column from the attribute table connected to a given vector map."
+msgstr "Löscht eine Spalte in einer Attributtabelle die mit einer bestimmten Vektorkarte verbunden ist."
 #: ../gui/wxpython/menustrings.py:838 ../gui/wxpython/dbmgr/manager.py:931
 msgid "Rename column"
 msgstr "Spalte umbenennen"
 #: ../gui/wxpython/menustrings.py:839
-msgid ""
-"Renames a column in the attribute table connected to a given vector map."
-msgstr ""
-"Benennt eine Spalte einer Attributtabelle verbunden mit einer bestimmten "
-"Vektorkarte um."
+msgid "Renames a column in the attribute table connected to a given vector map."
+msgstr "Benennt eine Spalte einer Attributtabelle verbunden mit einer bestimmten Vektorkarte um."
 #: ../gui/wxpython/menustrings.py:840
 msgid "Change values"
 msgstr "Werte ändern"
 #: ../gui/wxpython/menustrings.py:841
-msgid ""
-"Allows to update a column in the attribute table connected to a vector map."
+msgid "Allows to update a column in the attribute table connected to a vector map."
 msgstr "Aktualisiert eine Spalte einer Attributtabelle einer Vektorkarte."
 #: ../gui/wxpython/menustrings.py:842
@@ -10010,9 +9263,7 @@
 #: ../gui/wxpython/menustrings.py:845
 msgid "Prints/sets DB connection for a vector map to attribute table."
-msgstr ""
-"Gibt oder setzt Datenbankverbindung für eine Vektorkarte zu einer "
-"Attributtabelle."
+msgstr "Gibt oder setzt Datenbankverbindung für eine Vektorkarte zu einer Attributtabelle."
 #: ../gui/wxpython/menustrings.py:846 ../gui/wxpython/menustrings.py:898
 msgid "&Help"
@@ -10180,13 +9431,11 @@
 msgid ""
 "No attribute table found.\n"
 "\n"
-"Do you want to create a new attribute table and defined a link to vector map "
-"<%s>?"
+"Do you want to create a new attribute table and defined a link to vector map <%s>?"
 msgstr ""
 "Keine Attributtabelle gefunden.\n"
 "\n"
-"Möchten Sie eine neue Attributtabelle und einen Link zur Vektorkarte <%s>  "
-"erzeugen?"
+"Möchten Sie eine neue Attributtabelle und einen Link zur Vektorkarte <%s>  erzeugen?"
 #: ../gui/wxpython/dbmgr/dialogs.py:74
 msgid "Create table?"
@@ -10219,8 +9468,7 @@
 #: ../gui/wxpython/dbmgr/dialogs.py:227
 #, python-format
 msgid "Column <%(col)s>: Value '%(value)s' needs to be entered as %(type)s."
-msgstr ""
-"Spalte <%(col)s>: Wert '%(value)s' muss als %(type)s eingegeben werden."
+msgstr "Spalte <%(col)s>: Wert '%(value)s' muss als %(type)s eingegeben werden."
 #: ../gui/wxpython/dbmgr/dialogs.py:427
 msgid "Unknown"
@@ -10327,12 +9575,8 @@
 #: ../gui/wxpython/dbmgr/manager.py:152
 #, python-format
-msgid ""
-"Attribute table <%s> not found. For creating the table switch to 'Manage "
-"layers' tab."
-msgstr ""
-"Attributtabelle <%s> nicht gefunden. Um die Tabelle zu erstellen wechseln "
-"Sie in das Register 'Layer verwalten'."
+msgid "Attribute table <%s> not found. For creating the table switch to 'Manage layers' tab."
+msgstr "Attributtabelle <%s> nicht gefunden. Um die Tabelle zu erstellen wechseln Sie in das Register 'Layer verwalten'."
 #: ../gui/wxpython/dbmgr/manager.py:163
 #, python-format
@@ -10365,21 +9609,16 @@
 #: ../gui/wxpython/dbmgr/manager.py:304
 msgid "Unable to decode value. Set encoding in GUI preferences ('Attributes')."
-msgstr ""
-"Kann den Wert nicht dekodieren. Stellen Sie die Kodierung in den GUI "
-"Einstellungen ('Attribute') ein."
+msgstr "Kann den Wert nicht dekodieren. Stellen Sie die Kodierung in den GUI Einstellungen ('Attribute') ein."
 #: ../gui/wxpython/dbmgr/manager.py:313
 #, python-format
 msgid ""
-"Error loading attribute data. Record number: %(rec)d. Unable to convert "
-"value '%(val)s' in key column (%(key)s) to integer.\n"
+"Error loading attribute data. Record number: %(rec)d. Unable to convert value '%(val)s' in key column (%(key)s) to integer.\n"
 "\n"
 "Details: %(detail)s"
 msgstr ""
-"Fehler beim Laden der Attributdaten. Datensatz Nummer: %(rec)d. Kann den "
-"Wert '%(val)s' in der Schlüsselspalte (%(key)s) nicht nach integer "
-"umwandeln.\n"
+"Fehler beim Laden der Attributdaten. Datensatz Nummer: %(rec)d. Kann den Wert '%(val)s' in der Schlüsselspalte (%(key)s) nicht nach integer umwandeln.\n"
 "\n"
 "Einzelheiten: %(detail)s"
@@ -10437,13 +9676,8 @@
 #: ../gui/wxpython/dbmgr/manager.py:602
 #, python-format
-msgid ""
-"Database connection for vector map <%s> is not defined in DB file. You can "
-"define new connection in 'Manage layers' tab."
-msgstr ""
-"Die Datenbankverbindung der Vektorkarte <%s> ist nicht in der DB-Datei "
-"definiert. Sie können eine neue Verbindung in dem Register 'Layer verwalten' "
-"definieren."
+msgid "Database connection for vector map <%s> is not defined in DB file. You can define new connection in 'Manage layers' tab."
+msgstr "Die Datenbankverbindung der Vektorkarte <%s> ist nicht in der DB-Datei definiert. Sie können eine neue Verbindung in dem Register 'Layer verwalten' definieren."
 #: ../gui/wxpython/dbmgr/manager.py:628
 msgid "Browse data"
@@ -10568,21 +9802,13 @@
 #: ../gui/wxpython/dbmgr/manager.py:1188
 #, python-format
-msgid ""
-"Selected data records (%d) will be permanently deleted from table. Do you "
-"want to delete them?"
-msgstr ""
-"Selektierte Datensätze (%d) werden unwiderruflich aus der Tabelle gelöscht. "
-"Wollen Sie diese Datensätze löschen?"
+msgid "Selected data records (%d) will be permanently deleted from table. Do you want to delete them?"
+msgstr "Selektierte Datensätze (%d) werden unwiderruflich aus der Tabelle gelöscht. Wollen Sie diese Datensätze löschen?"
 #: ../gui/wxpython/dbmgr/manager.py:1234
 #, python-format
-msgid ""
-"All data records (%d) will be permanently deleted from table. Do you want to "
-"delete them?"
-msgstr ""
-"Alle Datensätze (%d) werden unwiderruflich aus der Tabelle gelöscht. Wollen "
-"Sie diese Datensätze löschen?"
+msgid "All data records (%d) will be permanently deleted from table. Do you want to delete them?"
+msgstr "Alle Datensätze (%d) werden unwiderruflich aus der Tabelle gelöscht. Wollen Sie diese Datensätze löschen?"
 #: ../gui/wxpython/dbmgr/manager.py:1392
 #, python-format
@@ -10627,21 +9853,13 @@
 #: ../gui/wxpython/dbmgr/manager.py:1632
 #, python-format
-msgid ""
-"Unable to rename column <%(column)s> to <%(columnTo)s>. Column already "
-"exists in the table <%(table)s>."
-msgstr ""
-"Kann die Spalte <%(column)s> nicht in <%(columnTo)s> umbenennen. Spalte "
-"existiert bereits in der Tabelle <%(table)s>."
+msgid "Unable to rename column <%(column)s> to <%(columnTo)s>. Column already exists in the table <%(table)s>."
+msgstr "Kann die Spalte <%(column)s> nicht in <%(columnTo)s> umbenennen. Spalte existiert bereits in der Tabelle <%(table)s>."
 #: ../gui/wxpython/dbmgr/manager.py:1648
 #, python-format
-msgid ""
-"Unable to rename column. Column <%(column)s> doesn't exist in the table <"
-"%(table)s>."
-msgstr ""
-"Kann die Spalte nicht umbenennen. Die Spalte <%(column)s> existiert nicht in "
-"der Tabelle <%(table)s>."
+msgid "Unable to rename column. Column <%(column)s> doesn't exist in the table <%(table)s>."
+msgstr "Kann die Spalte nicht umbenennen. Die Spalte <%(column)s> existiert nicht in der Tabelle <%(table)s>."
 #: ../gui/wxpython/dbmgr/manager.py:1675
 msgid "Drop selected column"
@@ -10653,12 +9871,8 @@
 #: ../gui/wxpython/dbmgr/manager.py:1693
 #, python-format
-msgid ""
-"Selected column '%s' will PERMANENTLY removed from table. Do you want to "
-"drop the column?"
-msgstr ""
-"Selektierte Spalte '%s' wird unwiderruflich aus der Tabelle gelöscht. Wollen "
-"Sie diese Spalte löschen?"
+msgid "Selected column '%s' will PERMANENTLY removed from table. Do you want to drop the column?"
+msgstr "Selektierte Spalte '%s' wird unwiderruflich aus der Tabelle gelöscht. Wollen Sie diese Spalte löschen?"
 #: ../gui/wxpython/dbmgr/manager.py:1696 ../gui/wxpython/dbmgr/manager.py:1733
 msgid "Drop column(s)"
@@ -10673,14 +9887,11 @@
 msgstr ""
 "Selektierte Spalten\n"
 "%s\n"
-"werden unwiderruflich aus der Tabelle gelöscht. Wollen Sie diese Spalten "
-"löschen?"
+"werden unwiderruflich aus der Tabelle gelöscht. Wollen Sie diese Spalten löschen?"
 #: ../gui/wxpython/dbmgr/manager.py:1768
 msgid "Unable to add column to the table. No column name defined."
-msgstr ""
-"Kann Die Spalte der Tabelle nicht hinzufügen. Es wurde kein Spaltenname "
-"definiert."
+msgstr "Kann Die Spalte der Tabelle nicht hinzufügen. Es wurde kein Spaltenname definiert."
 #: ../gui/wxpython/dbmgr/manager.py:1789
 #, python-format
@@ -10749,12 +9960,8 @@
 msgstr "Schlüsselspalte"
 #: ../gui/wxpython/dbmgr/manager.py:2397
-msgid ""
-"Unknown default DB connection. Please define DB connection using db.connect "
-"module."
-msgstr ""
-"Unbekannte Standard Datenbankverbindung. Bitte definieren Sie eine "
-"Datenbankverbindung mit dem Modul db.connect."
+msgid "Unknown default DB connection. Please define DB connection using db.connect module."
+msgstr "Unbekannte Standard Datenbankverbindung. Bitte definieren Sie eine Datenbankverbindung mit dem Modul db.connect."
 #: ../gui/wxpython/dbmgr/manager.py:2416
 msgid "Add layer"
@@ -10827,25 +10034,17 @@
 #: ../gui/wxpython/dbmgr/manager.py:2895
 msgid "Unable to create new table. Table name or key column name is missing."
-msgstr ""
-"Kann keine neue Tabelle anlegen. Tabellenname oder Name der Schlüsselspalte "
-"fehlen."
+msgstr "Kann keine neue Tabelle anlegen. Tabellenname oder Name der Schlüsselspalte fehlen."
 #: ../gui/wxpython/dbmgr/manager.py:2901
 #, python-format
 msgid "Unable to create new table. Table <%s> already exists in the database."
-msgstr ""
-"Kann neue Tabelle nicht anlegen. Die Tabelle <%s> existiert bereits in der "
-"Datenbank."
+msgstr "Kann neue Tabelle nicht anlegen. Die Tabelle <%s> existiert bereits in der Datenbank."
 #: ../gui/wxpython/dbmgr/manager.py:2938
 #, python-format
-msgid ""
-"Unable to add new layer to vector map <%(vector)s>. Layer %(layer)d already "
-"exists."
-msgstr ""
-"Kann der Vektorkarte <%(vector)s> keinen neuen Layer hinzufügen. Der Layer "
-"%(layer)d existiert bereits."
+msgid "Unable to add new layer to vector map <%(vector)s>. Layer %(layer)d already exists."
+msgstr "Kann der Vektorkarte <%(vector)s> keinen neuen Layer hinzufügen. Der Layer %(layer)d existiert bereits."
 #: ../gui/wxpython/modules/colorrules.py:71
 msgid "Check all"
@@ -10948,8 +10147,7 @@
 #: ../gui/wxpython/modules/colorrules.py:837
 #, python-format
 msgid "Enter raster category values or percents (%(range)s = %(min)d-%(max)d)"
-msgstr ""
-"Gib Rasterkategoriewerte oder Prozent (%(range)s = %(min)d-%(max)d) ein"
+msgstr "Gib Rasterkategoriewerte oder Prozent (%(range)s = %(min)d-%(max)d) ein"
 #: ../gui/wxpython/modules/colorrules.py:926
 msgid "Create new color rules for vector map"
@@ -11016,12 +10214,8 @@
 #: ../gui/wxpython/modules/colorrules.py:1096
 #, python-format
-msgid ""
-"Database connection for vector map <%s> is not defined in DB file.  Do you "
-"want to create and connect new attribute table?"
-msgstr ""
-"definiert. Möchten Sie eine neue Verbindung anlegen?"
+msgid "Database connection for vector map <%s> is not defined in DB file.  Do you want to create and connect new attribute table?"
+msgstr "Die Datenbankverbindung der Vektorkarte <%s> ist nicht in der DB-Datei definiert. Möchten Sie eine neue Verbindung anlegen?"
 #: ../gui/wxpython/modules/colorrules.py:1099
 msgid "No database connection defined"
@@ -11029,21 +10223,13 @@
 #: ../gui/wxpython/modules/colorrules.py:1171
 #, python-format
-msgid ""
-"Selected map <%(map)s> is not in current mapset <%(mapset)s>. Color rules "
-"cannot be edited."
-msgstr ""
-"Die selektierte Karte <%(map)s> ist nicht im aktuellen Mapset <%(mapset)s>. "
-"Farbregeln können nicht geändert werden."
+msgid "Selected map <%(map)s> is not in current mapset <%(mapset)s>. Color rules cannot be edited."
+msgstr "Die selektierte Karte <%(map)s> ist nicht im aktuellen Mapset <%(mapset)s>. Farbregeln können nicht geändert werden."
 #: ../gui/wxpython/modules/colorrules.py:1176
 #, python-format
-msgid ""
-"Selected map <%(map)s> is not in current mapset <%(mapset)s>. Attribute "
-"table cannot be edited."
-msgstr ""
-"Attributtabelle kann nicht geändert werden."
+msgid "Selected map <%(map)s> is not in current mapset <%(mapset)s>. Attribute table cannot be edited."
+msgstr "Die selektierte Karte <%(map)s> ist nicht im aktuellen Mapset <%(mapset)s>. Attributtabelle kann nicht geändert werden."
 #: ../gui/wxpython/modules/colorrules.py:1318
 #, python-format
@@ -11056,13 +10242,8 @@
 #: ../gui/wxpython/modules/colorrules.py:1411
 #, python-format
-msgid ""
-"Number of loaded records reached %d, displaying all the records will be time-"
-"consuming and may lead to computer freezing, do you still want to continue?"
-msgstr ""
-"Anzahl der geladenen Zeilen erreicht %d. Alle Zeilen anzuzeigen wird sehr "
-"lange dauern und könnte dazu führen, dass der Computer einfriert. Wollen Sie "
-"fortfahren?"
+msgid "Number of loaded records reached %d, displaying all the records will be time-consuming and may lead to computer freezing, do you still want to continue?"
+msgstr "Anzahl der geladenen Zeilen erreicht %d. Alle Zeilen anzuzeigen wird sehr lange dauern und könnte dazu führen, dass der Computer einfriert. Wollen Sie fortfahren?"
 #: ../gui/wxpython/modules/colorrules.py:1415
 msgid "Too many records"
@@ -11198,8 +10379,7 @@
 #: ../gui/wxpython/modules/vclean.py:382
 msgid "Please select a cleaning tool to move up"
-msgstr ""
-"Wählen sie ein Vektor-Cleaning-Tool aus, um es weiter nach oben zu reihen"
+msgstr "Wählen sie ein Vektor-Cleaning-Tool aus, um es weiter nach oben zu reihen"
 #: ../gui/wxpython/modules/vclean.py:405
 #, python-format
@@ -11212,8 +10392,7 @@
 #: ../gui/wxpython/modules/vclean.py:409
 msgid "Please select a cleaning tool to move down"
-msgstr ""
-"Bitte wählen Sie ein Cleaning-Werkzeug aus, um es nach unten zu verschieben"
+msgstr "Bitte wählen Sie ein Cleaning-Werkzeug aus, um es nach unten zu verschieben"
 #: ../gui/wxpython/modules/vclean.py:420
 #, python-format
@@ -11263,8 +10442,7 @@
 #: ../gui/wxpython/modules/vclean.py:524
 msgid "Vector cleaning command copied to clipboard"
-msgstr ""
-"Befehl zum Säubern von Vektordaten wurden in die Zwischenablage kopiert"
+msgstr "Befehl zum Säubern von Vektordaten wurden in die Zwischenablage kopiert"
 #: ../gui/wxpython/modules/ogc_services.py:38
 msgid "Import data from WMS server"
@@ -11315,12 +10493,8 @@
 msgstr "Importiere ausgewählte Ebenen"
 #: ../gui/wxpython/modules/ogc_services.py:167
-msgid ""
-"The 'xml2' parser is required, please install it first. You may also try "
-"running r.in.wms directly from the command line."
-msgstr ""
-"Ein 'xml2'-Parser wird benötigt, installiere diesen zuerst. Probiere auch r."
-"in.wms in der Kommandozeile."
+msgid "The 'xml2' parser is required, please install it first. You may also try running r.in.wms directly from the command line."
+msgstr "Ein 'xml2'-Parser wird benötigt, installiere diesen zuerst. Probiere auch r.in.wms in der Kommandozeile."
 #: ../gui/wxpython/modules/ogc_services.py:251
 msgid "Layer / Style"
@@ -11497,8 +10671,7 @@
 #: ../gui/wxpython/modules/mcalc_builder.py:476
 msgid "You must enter an expression to create a new raster map."
-msgstr ""
-"Sie müssen ein Ausdruck eingeben, um eine neue Rasterkarte zu erzeugen."
+msgstr "Sie müssen ein Ausdruck eingeben, um eine neue Rasterkarte zu erzeugen."
 #: ../gui/wxpython/modules/mcalc_builder.py:516
 msgid "Choose a file name to save the expression"
@@ -11527,8 +10700,7 @@
 #: ../gui/wxpython/modules/extensions.py:59
 msgid "Fetch full info including description and keywords"
-msgstr ""
-"Abruf der gesamten Information inklusive Beschreibung und Schlüsselworte"
+msgstr "Abruf der gesamten Information inklusive Beschreibung und Schlüsselworte"
 #: ../gui/wxpython/modules/extensions.py:68
 #: ../gui/wxpython/gui_core/dialogs.py:1438
@@ -11688,14 +10860,11 @@
 #: ../gui/wxpython/gcp/manager.py:383
 msgid "You must select a valid location before selecting a mapset"
-msgstr ""
-"Sie müssen zuerst eine gültige Location wählen, bevor Sie ein Mapset wählen "
-"können."
+msgstr "Sie müssen zuerst eine gültige Location wählen, bevor Sie ein Mapset wählen können."
 #: ../gui/wxpython/gcp/manager.py:396
 msgid "You must select a valid location and mapset in order to continue"
-msgstr ""
-"Sie müssen zuerst eine gültige Location und Mapset wählen, um fortzufahren."
+msgstr "Sie müssen zuerst eine gültige Location und Mapset wählen, um fortzufahren."
 #: ../gui/wxpython/gcp/manager.py:415
 msgid "Select image/map group to georectify"
@@ -11723,8 +10892,7 @@
 #: ../gui/wxpython/gcp/manager.py:521
 msgid "You must select a valid image/map group in order to continue"
-msgstr ""
-"Sie müssen eine gültige Gruppe von Bildern/Karten wählen, um fortzufahren."
+msgstr "Sie müssen eine gültige Gruppe von Bildern/Karten wählen, um fortzufahren."
 #: ../gui/wxpython/gcp/manager.py:528
 msgid "You must enter an map name extension in order to continue"
@@ -11732,8 +10900,7 @@
 #: ../gui/wxpython/gcp/manager.py:594
 msgid "Select maps to display for ground control point (GCP) creation"
-msgstr ""
-"Wählen Sie eine darzustellende Karte für Erzeugung von Passpunkten (GCP)."
+msgstr "Wählen Sie eine darzustellende Karte für Erzeugung von Passpunkten (GCP)."
 #: ../gui/wxpython/gcp/manager.py:602 ../gui/wxpython/gcp/manager.py:2560
 msgid "Select source map to display:"
@@ -11817,14 +10984,12 @@
 #: ../gui/wxpython/gcp/manager.py:1305
 msgid ""
-"Insufficient points defined and active (checked) for selected rectification "
-"method.\n"
+"Insufficient points defined and active (checked) for selected rectification method.\n"
 "3+ points needed for 1st order,\n"
 "6+ points for 2nd order, and\n"
 "10+ points for 3rd order."
 msgstr ""
-"Nicht ausreichend Punkte gesetzt und aktiv (checked) für die gewählte "
-"Rektifizierungsmethode.\n"
+"Nicht ausreichend Punkte gesetzt und aktiv (checked) für die gewählte Rektifizierungsmethode.\n"
 "3+ Punkte benötigt für 1. Ordnung,\n"
 "7+ Punkte für 2. Ordnung und\n"
 "10+ Punkte für 3. Ordnung."
@@ -11845,11 +11010,8 @@
 #: ../gui/wxpython/gcp/manager.py:1443
 #, python-format
-msgid ""
-"Vector map <%s> already exists. Change extension name and georectify again."
-msgstr ""
-"Die Vektorkarte <%s> existiert bereits. Ändern Sie die Namenserweiterung und "
-"georektifizieren Sie erneut."
+msgid "Vector map <%s> already exists. Change extension name and georectify again."
+msgstr "Die Vektorkarte <%s> existiert bereits. Ändern Sie die Namenserweiterung und georektifizieren Sie erneut."
 #: ../gui/wxpython/gcp/manager.py:1453
 msgid "For all vector maps georectified successfully,"
@@ -12182,12 +11344,8 @@
 #: ../gui/wxpython/gui_core/dialogs.py:384
 #, python-format
-msgid ""
-"Vector map <%s> already exists in the current mapset. Do you want to "
-"overwrite it?"
-msgstr ""
-"Die Vektorkarte <%s> existiert bereits im aktuellen Mapset. Wollen Sie diese "
-"überschreiben?"
+msgid "Vector map <%s> already exists in the current mapset. Do you want to overwrite it?"
+msgstr "Die Vektorkarte <%s> existiert bereits im aktuellen Mapset. Wollen Sie diese überschreiben?"
 #: ../gui/wxpython/gui_core/dialogs.py:387
 msgid "Overwrite?"
@@ -12211,12 +11369,8 @@
 msgstr "Definiere Größe und Position"
 #: ../gui/wxpython/gui_core/dialogs.py:534
-msgid ""
-"Click and drag on the map display to set legend size and position and then "
-"press OK"
-msgstr ""
-"Klicken und Verschieben im Kartenfenster, um Größe und Position der Legende "
-"zu bestimmen. Mit klick auf OK beenden."
+msgid "Click and drag on the map display to set legend size and position and then press OK"
+msgstr "Klicken und Verschieben im Kartenfenster, um Größe und Position der Legende zu bestimmen. Mit klick auf OK beenden."
 #: ../gui/wxpython/gui_core/dialogs.py:544
 msgid ""
@@ -12224,19 +11378,16 @@
 "Double-click to change options.\n"
 "Define raster map name for legend in properties dialog."
 msgstr ""
-"Ziehen Sie das Legenden-Objekt mit Maus im Zeiger-Modus in die gewünschte "
-"Position.\n"
+"Ziehen Sie das Legenden-Objekt mit Maus im Zeiger-Modus in die gewünschte Position.\n"
 "Doppelklick ändert die Einstellung.\n"
-"Geben Sie den Namen der Rasterkarte für die Legende im Eigenschaften-Dialog "
-"an."
+"Geben Sie den Namen der Rasterkarte für die Legende im Eigenschaften-Dialog an."
 #: ../gui/wxpython/gui_core/dialogs.py:548
 msgid ""
 "Drag scale object with mouse in pointer mode to position.\n"
 "Double-click to change options."
 msgstr ""
-"Ziehen Sie das Maßstabs-Objekt mit der Maus im Zeiger-Modus in die "
-"gewünschte Position.\n"
+"Ziehen Sie das Maßstabs-Objekt mit der Maus im Zeiger-Modus in die gewünschte Position.\n"
 "Doppelklick ändert die Einstellung."
 #: ../gui/wxpython/gui_core/dialogs.py:596
@@ -12280,9 +11431,7 @@
 #: ../gui/wxpython/gui_core/dialogs.py:882
 msgid "Select the group you want to edit or enter name of new group:"
-msgstr ""
-"Selektieren Sie zu editierenden die Gruppe oder geben Sie einen Namen für "
-"eine neue Gruppe ein:"
+msgstr "Selektieren Sie zu editierenden die Gruppe oder geben Sie einen Namen für eine neue Gruppe ein:"
 #: ../gui/wxpython/gui_core/dialogs.py:893
 msgid "Layers in selected group:"
@@ -12594,9 +11743,7 @@
 #: ../gui/wxpython/gui_core/gselect.py:1400
 #, python-format
 msgid "Settings <%s> already exists. Do you want to overwrite the settings?"
-msgstr ""
-"Einstellung <%s> existiert bereits. Wollen Sie die Einstellungen "
-"überschreiben?"
+msgstr "Einstellung <%s> existiert bereits. Wollen Sie die Einstellungen überschreiben?"
 #: ../gui/wxpython/gui_core/gselect.py:1422
 msgid "No settings is defined. Operation canceled."
@@ -12660,9 +11807,7 @@
 #: ../gui/wxpython/gui_core/preferences.py:328
 msgid "Automatically copy selected text to clipboard (in Command console)"
-msgstr ""
-"Kopiere selektierten Text automatisch in die Zwischenablage (in der "
-"Kommandozeile)"
+msgstr "Kopiere selektierten Text automatisch in die Zwischenablage (in der Kommandozeile)"
 #: ../gui/wxpython/gui_core/preferences.py:343
 msgid "Workspace settings"
@@ -12681,12 +11826,8 @@
 msgstr "Speichere das aktuelle Fensterlayout als Standard"
 #: ../gui/wxpython/gui_core/preferences.py:376
-msgid ""
-"Save current position and size of Layer Manager window and opened Map "
-"Display window(s) and use as default for next sessions."
-msgstr ""
-"Speichere die aktuelle Position und Größe des 'Layer Manager'-Fensters und "
-"der geöffneten Kartenfenster als Standardwerte für die nächste Sitzung."
+msgid "Save current position and size of Layer Manager window and opened Map Display window(s) and use as default for next sessions."
+msgstr "Speichere die aktuelle Position und Größe des 'Layer Manager'-Fensters und der geöffneten Kartenfenster als Standardwerte für die nächste Sitzung."
 #: ../gui/wxpython/gui_core/preferences.py:417
 msgid "Font for command output:"
@@ -12835,20 +11976,15 @@
 #: ../gui/wxpython/gui_core/preferences.py:1114
 msgid ""
 "\n"
-"Note: This only controls the coordinates displayed in the lower-left of the "
-"Map Display\n"
-"window's status bar. It is purely cosmetic and does not affect the working "
-"location's\n"
-"projection in any way. You will need to enable the Projection check box in "
-"the drop-down\n"
+"Note: This only controls the coordinates displayed in the lower-left of the Map Display\n"
+"window's status bar. It is purely cosmetic and does not affect the working location's\n"
+"projection in any way. You will need to enable the Projection check box in the drop-down\n"
 "menu located at the bottom of the Map Display window.\n"
 msgstr ""
 "\n"
 "Beachte: Dies beeinflusst nur die Koordinaten angezeigt in der Map Display-\n"
-"Statusleiste. Dies ist nur kosmetisch und beeinflusst nicht die Projektion "
-"der aktuellen\n"
-"Location. Aktiviere die Projektion-Checkbox im Drop down-Menue am unteren "
-"Ende des Map Display-Fensters.\n"
+"Statusleiste. Dies ist nur kosmetisch und beeinflusst nicht die Projektion der aktuellen\n"
+"Location. Aktiviere die Projektion-Checkbox im Drop down-Menue am unteren Ende des Map Display-Fensters.\n"
 #: ../gui/wxpython/gui_core/preferences.py:1146
 msgid "Proj.4 string (required):"
@@ -12859,12 +11995,8 @@
 msgstr "EPSG Datei:"
 #: ../gui/wxpython/gui_core/preferences.py:1177
-msgid ""
-"Load EPSG codes (be patient), enter EPSG code or insert Proj.4 string "
-"directly."
-msgstr ""
-"Lade EPSG-Codes. Eingabe des EPSG-Code oder direkte Eingabe des Proj.4-"
-"String."
+msgid "Load EPSG codes (be patient), enter EPSG code or insert Proj.4 string directly."
+msgstr "Lade EPSG-Codes. Eingabe des EPSG-Code oder direkte Eingabe des Proj.4-String."
 #: ../gui/wxpython/gui_core/preferences.py:1185
 msgid "&Load EPSG codes"
@@ -12922,8 +12054,7 @@
 "    - You may only write to the current mapset.\n"
 "    - You may only write to mapsets which you own."
 msgstr ""
-"Selektiere ein Mapset, um es zugänglich zu machen und deselektiere es, um es "
-"zu verbergen. \n"
+"Selektiere ein Mapset, um es zugänglich zu machen und deselektiere es, um es zu verbergen. \n"
 "  Bemerkungen:\n"
 "    - Das aktuelle Mapset ist immer zugänglich.\n"
 "    - Sie können nur in der selektierten Mapset speichern.\n"
@@ -12970,12 +12101,8 @@
 msgstr "log. Datei"
 #: ../gui/wxpython/gui_core/goutput.py:270
-msgid ""
-"Toggle to save list of executed commands into a file; content saved when "
-"switching off."
-msgstr ""
-"Umschalten, um ausgeführte Befehle in Datei zu speichern. Inhalt wird beim "
-"Ausschalten gespeichert."
+msgid "Toggle to save list of executed commands into a file; content saved when switching off."
+msgstr "Umschalten, um ausgeführte Befehle in Datei zu speichern. Inhalt wird beim Ausschalten gespeichert."
 #: ../gui/wxpython/gui_core/goutput.py:486
 #: ../gui/wxpython/gui_core/goutput.py:793
@@ -12991,12 +12118,8 @@
 #: ../gui/wxpython/gui_core/goutput.py:524
 #, python-format
-msgid ""
-"Command '%s' not yet implemented in the WxGUI. Try adding it as a command "
-"layer instead."
-msgstr ""
-"Befehl '%s' wurde noch nicht im wxGUI implementiert. Versuchen Sie es als "
-"Befehlsebene hinzuzufügen."
+msgid "Command '%s' not yet implemented in the WxGUI. Try adding it as a command layer instead."
+msgstr "Befehl '%s' wurde noch nicht im wxGUI implementiert. Versuchen Sie es als Befehlsebene hinzuzufügen."
 #: ../gui/wxpython/gui_core/goutput.py:571
 #, python-format
@@ -13009,8 +12132,7 @@
 "Kann den Befehl nicht ausführen:\n"
 "%(cmd)s\n"
 "\n"
-"Option <%(opt)s>: Das Lesen von der Standardeingabe wird vom wxGUI nicht "
-"unterstützt"
+"Option <%(opt)s>: Das Lesen von der Standardeingabe wird vom wxGUI nicht unterstützt"
 #: ../gui/wxpython/gui_core/goutput.py:661
 #: ../gui/wxpython/gui_core/goutput.py:811
@@ -13045,9 +12167,9 @@
 "Einzelheiten: %(error)s"
 #: ../gui/wxpython/gui_core/goutput.py:679
-#, fuzzy, python-format
+#, python-format
 msgid "Command output saved into '%s'"
-msgstr "Befehlsausgabe in '%s' gespeichert"
+msgstr "Befehlsausgabe gespeichert in '%s'"
 #: ../gui/wxpython/gui_core/goutput.py:708
 #: ../gui/wxpython/gui_core/ghelp.py:328
@@ -13056,9 +12178,9 @@
 msgstr "%d Module stimmen überein"
 #: ../gui/wxpython/gui_core/goutput.py:798
+#, python-format
 msgid "Command log saved to '%s'"
+msgstr "Befehlslog gespeichert in '%s'"
 #: ../gui/wxpython/gui_core/goutput.py:853
 #, python-format
@@ -13071,11 +12193,8 @@
 msgstr "%(min)d Min %(sec)d Sek"
 #: ../gui/wxpython/gui_core/goutput.py:864
-msgid ""
-"Please note that the data are left in inconsistent state and may be corrupted"
-msgstr ""
-"Daten wurden in einem inkonsistenten Zustand zurückgelassen und können "
-"beschädigt sein"
+msgid "Please note that the data are left in inconsistent state and may be corrupted"
+msgstr "Daten wurden in einem inkonsistenten Zustand zurückgelassen und können beschädigt sein"
 #: ../gui/wxpython/gui_core/goutput.py:866
 msgid "Command aborted"
@@ -13225,12 +12344,8 @@
 msgstr "Erzeugte Karte(n) der Baumstruktur hinzufügen"
 #: ../gui/wxpython/gui_core/forms.py:514
-msgid ""
-"Close dialog when command is successfully finished. Change this settings in "
-"Preferences dialog ('Command' tab)."
-msgstr ""
-"Schließe Dialog, wenn Befehl erfolgreich ausgeführt. Ändere dies in den "
-"Einstellungen (Reiter 'Befehle')."
+msgid "Close dialog when command is successfully finished. Change this settings in Preferences dialog ('Command' tab)."
+msgstr "Schließe Dialog, wenn Befehl erfolgreich ausgeführt. Ändere dies in den Einstellungen (Reiter 'Befehle')."
 #: ../gui/wxpython/gui_core/forms.py:685
 #, python-format
@@ -13403,1175 +12518,1086 @@
 msgid "Create histogram with d.histogram"
 msgstr "Erzeuge Histogramm mit d.histogram"
-#~ msgid "GRASS GIS Map Display: "
-#~ msgstr "GRASS GIS Kartenfenster: "
+msgid "GRASS GIS Map Display: "
+msgstr "GRASS GIS Kartenfenster: "
-#~ msgid "Display on surface(s):"
-#~ msgstr "Auf Oberfläche(n) darstellen:"
+msgid "Display on surface(s):"
+msgstr "Auf Oberfläche(n) darstellen:"
 #, fuzzy
-#~ msgid "Select WKT or PRJ file"
-#~ msgstr "Wählen Sie eine WKT-Datei"
+msgid "Select WKT or PRJ file"
+msgstr "Wählen Sie eine WKT-Datei"
-#~ msgid ""
-#~ "Field separator must be ASCII character not <%s> (use e.g. ';', '&', '#')"
-#~ msgstr ""
-#~ "Feldtrenner muss ein ASCII-Zeichen sein, nicht <%s> (z.B. ';', '&', '#')"
+msgid "Field separator must be ASCII character not <%s> (use e.g. ';', '&', '#')"
+msgstr "Feldtrenner muss ein ASCII-Zeichen sein, nicht <%s> (z.B. ';', '&', '#')"
-#~ msgid "Field separator:"
-#~ msgstr "Feldtrenner:"
+msgid "Field separator:"
+msgstr "Feldtrenner:"
-#~ msgid ""
-#~ "Inconsistent number of columns in the table <%(table)s>. Try to change "
-#~ "field separator in GUI Settings, Attributes tab, Data browser section."
-#~ msgstr ""
-#~ "Inkonsistente Spaltenanzahl in der Tabelle <%(table)s>. Versuchen Sie den "
-#~ "Spaltentrenner in den GUI-Einstellungen/Attribute/Daten-Browser zu ändern."
+msgid "Inconsistent number of columns in the table <%(table)s>. Try to change field separator in GUI Settings, Attributes tab, Data browser section."
+msgstr "Inkonsistente Spaltenanzahl in der Tabelle <%(table)s>. Versuchen Sie den Spaltentrenner in den GUI-Einstellungen/Attribute/Daten-Browser zu ändern."
-#~ msgid "&Protocol"
-#~ msgstr "&Protokoll"
+msgid "&Protocol"
+msgstr "&Protokoll"
-#~ msgid "Commands protocol saved into '%s'"
-#~ msgstr "Protokoll der Befehle in '%s' gespeichert"
+msgid "Commands protocol saved into '%s'"
+msgstr "Protokoll der Befehle in '%s' gespeichert"
-#~ msgid "deg"
-#~ msgstr "deg"
+msgid "deg"
+msgstr "deg"
-#~ msgid "Unable to generate preview. %s"
-#~ msgstr "Kann Vorschau nicht erzeugen. %s"
+msgid "Unable to generate preview. %s"
+msgstr "Kann Vorschau nicht erzeugen. %s"
-#~ msgid "Delete selected map layer"
-#~ msgstr "Selektierte Ebenen löschen"
+msgid "Delete selected map layer"
+msgstr "Selektierte Ebenen löschen"
-#~ msgid ""
-#~ "\n"
-#~ "Define raster map name for legend in properties dialog."
-#~ msgstr ""
-#~ "\n"
-#~ "Definieren Sie den Rasterkartennamen für die Legende im Eigenschaften-"
-#~ "Dialog."
+msgid ""
+"\n"
+"Define raster map name for legend in properties dialog."
+msgstr ""
+"\n"
+"Definieren Sie den Rasterkartennamen für die Legende im Eigenschaften-Dialog."
-#~ msgid ""
-#~ "Converts co-ordinate system descriptions (i.e. projection information) "
-#~ "between various formats (including GRASS format)."
-#~ msgstr ""
-#~ "Konvertiert die Beschreibung von Koordinatesystemen (z.B. "
-#~ "Projektionsinformationen) zwischen verschiedenen Formaten "
-#~ "(einschliesslich GRASS)."
+msgid "Converts co-ordinate system descriptions (i.e. projection information) between various formats (including GRASS format)."
+msgstr "Konvertiert die Beschreibung von Koordinatesystemen (z.B. Projektionsinformationen) zwischen verschiedenen Formaten (einschliesslich GRASS)."
 #, fuzzy
-#~ msgid "Histogram text settings"
-#~ msgstr "Profiltexteinstellungen"
+msgid "Histogram text settings"
+msgstr "Profiltexteinstellungen"
-#~ msgid "Show/hide scale and North arrow"
-#~ msgstr "Maßstab und Nordpfeil anzeigen/verbergen"
+msgid "Show/hide scale and North arrow"
+msgstr "Maßstab und Nordpfeil anzeigen/verbergen"
-#~ msgid "scale object"
-#~ msgstr "Maßstabsobjekt"
+msgid "scale object"
+msgstr "Maßstabsobjekt"
-#~ msgid "Show/hide legend"
-#~ msgstr "Legende anzeigen/verbergen"
+msgid "Show/hide legend"
+msgstr "Legende anzeigen/verbergen"
-#~ msgid "legend object"
-#~ msgstr "Legendenobjekt"
+msgid "legend object"
+msgstr "Legendenobjekt"
 #, fuzzy
-#~ msgid "Python:"
-#~ msgstr "Python Shell"
+msgid "Python:"
+msgstr "Python Shell"
 #, fuzzy
-#~ msgid "Language:"
-#~ msgstr "Sprache"
+msgid "Language:"
+msgstr "Sprache"
-#~ msgid "dtree"
-#~ msgstr "dtree"
+msgid "dtree"
+msgstr "dtree"
-#~ msgid "ctree"
-#~ msgstr "ctree"
+msgid "ctree"
+msgstr "ctree"
-#~ msgid "Profile line settings"
-#~ msgstr "Profillinien-Einstellungen"
+msgid "Profile line settings"
+msgstr "Profillinien-Einstellungen"
-#~ msgid "'%(cmd)s' failed. Details: %(det)s"
-#~ msgstr "'%(cmd)s' fehlgeschlagen. Einzelheiten: %(det)s"
+msgid "'%(cmd)s' failed. Details: %(det)s"
+msgstr "'%(cmd)s' fehlgeschlagen. Einzelheiten: %(det)s"
-#~ msgid "Profile of %s"
-#~ msgstr "Profil von %s"
+msgid "Profile of %s"
+msgstr "Profil von %s"
-#~ msgid "Profile settings"
-#~ msgstr "Profileinstellungen"
+msgid "Profile settings"
+msgstr "Profileinstellungen"
-#~ msgid "Select raster map 2 (optional):"
-#~ msgstr "Wähle Rasterkarte 2 (optional):"
+msgid "Select raster map 2 (optional):"
+msgstr "Wähle Rasterkarte 2 (optional):"
-#~ msgid "Select raster map 3 (optional):"
-#~ msgstr "Wähle Rasterkarte 3 (optional):"
+msgid "Select raster map 3 (optional):"
+msgstr "Wähle Rasterkarte 3 (optional):"
-#~ msgid ""
-#~ "No attribute table linked to vector map <%(vector)s> found. %(msg)s\n"
-#~ "\n"
-#~ "New attribute table can be created by Attribute Table Manager."
-#~ msgstr ""
-#~ "Es ist keine Attributtabelle mit der Vektorkarte <%(vector)s> verlinkt. "
-#~ "%(msg)s\n"
-#~ "\n"
-#~ "Eine neue Attributtabelle kann mit dem Attributtabellenmanager erzeugt "
-#~ "werden."
+msgid ""
+"No attribute table linked to vector map <%(vector)s> found. %(msg)s\n"
+"\n"
+"New attribute table can be created by Attribute Table Manager."
+msgstr ""
+"Es ist keine Attributtabelle mit der Vektorkarte <%(vector)s> verlinkt. %(msg)s\n"
+"\n"
+"Eine neue Attributtabelle kann mit dem Attributtabellenmanager erzeugt werden."
-#~ msgid ""
-#~ "Module r.mapcalc cannot be used in the model. Use r.mapcalculator instead."
-#~ msgstr ""
-#~ "Modul r.mapcalc kann im Modell nicht benützt werden. Verwenden sie "
-#~ "stattdessen r.mapcalculator."
+msgid "Module r.mapcalc cannot be used in the model. Use r.mapcalculator instead."
+msgstr "Modul r.mapcalc kann im Modell nicht benützt werden. Verwenden sie stattdessen r.mapcalculator."
-#~ msgid "Change ID"
-#~ msgstr "Ändere ID"
+msgid "Change ID"
+msgstr "Ändere ID"
-#~ msgid "&Add"
-#~ msgstr "&Hinzufügen"
+msgid "&Add"
+msgstr "&Hinzufügen"
-#~ msgid "Add selected map layers to current display"
-#~ msgstr "Rasterkarten zum aktuellen Kartenfenster hinzufügen"
+msgid "Add selected map layers to current display"
+msgstr "Rasterkarten zum aktuellen Kartenfenster hinzufügen"
-#~ msgid "Filter:"
-#~ msgstr "Filter:"
+msgid "Filter:"
+msgstr "Filter:"
 #, fuzzy
-#~ msgid ""
-#~ "No layers marked for import.\n"
-#~ "Operation canceled."
-#~ msgstr ""
-#~ "Keine Erweiterung zum Entfernen ausgewählt. Breche die Operation ab."
+msgid ""
+"No layers marked for import.\n"
+"Operation canceled."
+msgstr "Keine Erweiterung zum Entfernen ausgewählt. Breche die Operation ab."
-#~ msgid "Source"
-#~ msgstr "Quelle"
+msgid "Source"
+msgstr "Quelle"
-#~ msgid "Directory:"
-#~ msgstr "Verzeichnis:"
+msgid "Directory:"
+msgstr "Verzeichnis:"
-#~ msgid "Database:"
-#~ msgstr "Datenbank:"
+msgid "Database:"
+msgstr "Datenbank:"
-#~ msgid "north"
-#~ msgstr "Norden"
+msgid "north"
+msgstr "Norden"
-#~ msgid "south"
-#~ msgstr "Süden"
+msgid "south"
+msgstr "Süden"
-#~ msgid "east"
-#~ msgstr "Osten"
+msgid "east"
+msgstr "Osten"
-#~ msgid "west"
-#~ msgstr "Westen"
+msgid "west"
+msgstr "Westen"
-#~ msgid "north-west"
-#~ msgstr "Nordwesten"
+msgid "north-west"
+msgstr "Nordwesten"
-#~ msgid "north-east"
-#~ msgstr "Nordosten"
+msgid "north-east"
+msgstr "Nordosten"
-#~ msgid "south-east"
-#~ msgstr "Südosten"
+msgid "south-east"
+msgstr "Südosten"
-#~ msgid "south-west"
-#~ msgstr "Südwesten"
+msgid "south-west"
+msgstr "Südwesten"
-#~ msgid "Topography"
-#~ msgstr "Topographie"
+msgid "Topography"
+msgstr "Topographie"
-#~ msgid "res."
-#~ msgstr "res."
+msgid "res."
+msgstr "res."
-#~ msgid "Mask zeros:"
-#~ msgstr "Nullen maskieren:"
+msgid "Mask zeros:"
+msgstr "Nullen maskieren:"
-#~ msgid "by elevation"
-#~ msgstr "nach Höhenlage"
+msgid "by elevation"
+msgstr "nach Höhenlage"
-#~ msgid "display"
-#~ msgstr "Fenster"
+msgid "display"
+msgstr "Fenster"
-#~ msgid "size"
-#~ msgstr "Größe"
+msgid "size"
+msgstr "Größe"
-#~ msgid "slides"
-#~ msgstr "Folien"
+msgid "slides"
+msgstr "Folien"
-#~ msgid "Topography level"
-#~ msgstr "Topographisches Level"
+msgid "Topography level"
+msgstr "Topographisches Level"
-#~ msgid "Follow source viewpoint"
-#~ msgstr "Folge Quell-Blickposition"
+msgid "Follow source viewpoint"
+msgstr "Folge Quell-Blickposition"
-#~ msgid "(value)"
-#~ msgstr "(Wert)"
+msgid "(value)"
+msgstr "(Wert)"
-#~ msgid "(step)"
-#~ msgstr "(Schrittweite)"
+msgid "(step)"
+msgstr "(Schrittweite)"
-#~ msgid "(x)"
-#~ msgstr "(x)"
+msgid "(x)"
+msgstr "(x)"
-#~ msgid "Show lines"
-#~ msgstr "Linien anzeigen"
+msgid "Show lines"
+msgstr "Linien anzeigen"
-#~ msgid "Show points"
-#~ msgstr "Punkte anzeigen"
+msgid "Show points"
+msgstr "Punkte anzeigen"
-#~ msgid "Nviz settings saved to file <%s>."
-#~ msgstr "Nviz-Einstellungen in der Datei <%s> gespeichert."
+msgid "Nviz settings saved to file <%s>."
+msgstr "Nviz-Einstellungen in der Datei <%s> gespeichert."
-#~ msgid "Set map canvas for "
-#~ msgstr "Bestimme Kartenfenster für "
+msgid "Set map canvas for "
+msgstr "Bestimme Kartenfenster für "
-#~ msgid " / Zoom to map"
-#~ msgstr " / Zoom zu Karte"
+msgid " / Zoom to map"
+msgstr " / Zoom zu Karte"
-#~ msgid "Cl&ear"
-#~ msgstr "&Säubere"
+msgid "Cl&ear"
+msgstr "&Säubere"
-#~ msgid "replace existing color table"
-#~ msgstr "ersetze existierende Farbtabelle"
+msgid "replace existing color table"
+msgstr "ersetze existierende Farbtabelle"
-#~ msgid "Please select attribute column and RGB color column first"
-#~ msgstr "Bitte wählen Sie zuerst die Attributspalte und die RGB-Farbspalte."
+msgid "Please select attribute column and RGB color column first"
+msgstr "Bitte wählen Sie zuerst die Attributspalte und die RGB-Farbspalte."
-#~ msgid ""
-#~ "Color table already exists. Check out 'replace existing color table' to "
-#~ "overwrite it."
-#~ msgstr ""
-#~ "Farbtabelle existiert bereits. Wählen Sie 'replace existing color table', "
-#~ "um diese zu überschreiben."
+msgid "Color table already exists. Check out 'replace existing color table' to overwrite it."
+msgstr "Farbtabelle existiert bereits. Wählen Sie 'replace existing color table', um diese zu überschreiben."
-#~ msgid "Function not implemented yet"
-#~ msgstr "Funktion  noch nicht implementiert"
+msgid "Function not implemented yet"
+msgstr "Funktion  noch nicht implementiert"
-#~ msgid "C&lear cmd"
-#~ msgstr "&Lösche Befehl"
+msgid "C&lear cmd"
+msgstr "&Lösche Befehl"
-#~ msgid "&Save output"
-#~ msgstr "&Speichere Ergebnis"
+msgid "&Save output"
+msgstr "&Speichere Ergebnis"
-#~ msgid "&Abort cmd"
-#~ msgstr "&Breche Befehl ab"
+msgid "&Abort cmd"
+msgstr "&Breche Befehl ab"
-#~ msgid "3d raster"
-#~ msgstr "3D Raster"
+msgid "3d raster"
+msgstr "3D Raster"
-#~ msgid "Georectification Toolbar"
-#~ msgstr "Werkzeugleiste Georektifizierung"
+msgid "Georectification Toolbar"
+msgstr "Werkzeugleiste Georektifizierung"
-#~ msgid "No map layer selected for querying."
-#~ msgstr "Keine Vektorkarte für die Abfrage ausgewählt."
+msgid "No map layer selected for querying."
+msgstr "Keine Vektorkarte für die Abfrage ausgewählt."
-#~ msgid "Query surface (raster map)"
-#~ msgstr "Oberfläche (Rasterkarte) abfragen"
+msgid "Query surface (raster map)"
+msgstr "Oberfläche (Rasterkarte) abfragen"
-#~ msgid "set up vector cleaning tools"
-#~ msgstr "Einstellung der Vektor-Cleaning-Werkzeuge"
+msgid "set up vector cleaning tools"
+msgstr "Einstellung der Vektor-Cleaning-Werkzeuge"
-#~ msgid "Invalid GCP Number"
-#~ msgstr "Ungültige GCP-Nummer"
+msgid "Invalid GCP Number"
+msgstr "Ungültige GCP-Nummer"
 #, fuzzy
-#~ msgid ""
-#~ "Unable to add new layer/category <%(layer)s/%(category)s>.\n"
-#~ "Layer and category number must be integer.\n"
-#~ "Layer number must be greater then zero."
-#~ msgstr ""
-#~ "Kann den neuen Layer/Kategorie <%(layer)s/%(category)s> nicht "
-#~ "hinzufügen.\n"
-#~ "Layer und Kategorie Nummern müssen integer sein.\n"
-#~ "Layer Nummern müssen größer als Null sein."
+msgid ""
+"Unable to add new layer/category <%(layer)s/%(category)s>.\n"
+"Layer and category number must be integer.\n"
+"Layer number must be greater then zero."
+msgstr ""
+"Kann den neuen Layer/Kategorie <%(layer)s/%(category)s> nicht hinzufügen.\n"
+"Layer und Kategorie Nummern müssen integer sein.\n"
+"Layer Nummern müssen größer als Null sein."
-#~ msgid "Attribute Table Manager"
-#~ msgstr "Attributtabellen Manager"
+msgid "Attribute Table Manager"
+msgstr "Attributtabellen Manager"
-#~ msgid "Choose GIS Data Directory:"
-#~ msgstr "Wählen Sie das GIS-Datenverzeichnis:"
+msgid "Choose GIS Data Directory:"
+msgstr "Wählen Sie das GIS-Datenverzeichnis:"
-#~ msgid "GRASS Quickstart"
-#~ msgstr "GRASS Schnellstart"
+msgid "GRASS Quickstart"
+msgstr "GRASS Schnellstart"
-#~ msgid ""
-#~ "Hardcopy Map Output Utility is not available. You can install it by %s"
-#~ msgstr ""
-#~ "Hardcopy Map Output Utility ist nicht verfügbar. Sie können es mit %s "
-#~ "installieren"
+msgid "Hardcopy Map Output Utility is not available. You can install it by %s"
+msgstr "Hardcopy Map Output Utility ist nicht verfügbar. Sie können es mit %s installieren"
-#~ msgid "Unable to switch to location <%(loc)s> mapset <%(mapset)s>."
-#~ msgstr "Kann nicht in Location <%(loc)s>  und Mapset <%(mapset)s> wechseln."
+msgid "Unable to switch to location <%(loc)s> mapset <%(mapset)s>."
+msgstr "Kann nicht in Location <%(loc)s>  und Mapset <%(mapset)s> wechseln."
-#~ msgid "Starting GRASS GUI..."
-#~ msgstr "Starte GRASS GUI..."
+msgid "Starting GRASS GUI..."
+msgstr "Starte GRASS GUI..."
-#~ msgid "Query with attributes"
-#~ msgstr "Abfrage mittels Attribut"
+msgid "Query with attributes"
+msgstr "Abfrage mittels Attribut"
-#~ msgid "Query with another vector map"
-#~ msgstr "Abfrage mittels andererVektorkarte"
+msgid "Query with another vector map"
+msgstr "Abfrage mittels andererVektorkarte"
-#~ msgid "Update point attributes from raster"
-#~ msgstr "Aktualisiere Punktattribute aus Raster"
+msgid "Update point attributes from raster"
+msgstr "Aktualisiere Punktattribute aus Raster"
-#~ msgid "Ortho photo rectification (requires Xterm)"
-#~ msgstr "Orthophoto Rektifizierung (erfordert Xterm)"
+msgid "Ortho photo rectification (requires Xterm)"
+msgstr "Orthophoto Rektifizierung (erfordert Xterm)"
-#~ msgid "Menu driver for the photo imagery programs."
-#~ msgstr "Menü-Treiber für die Photo-/Bildverarbeitungs-Programme."
+msgid "Menu driver for the photo imagery programs."
+msgstr "Menü-Treiber für die Photo-/Bildverarbeitungs-Programme."
-#~ msgid "Add action"
-#~ msgstr "Aktion hinzufügen"
+msgid "Add action"
+msgstr "Aktion hinzufügen"
-#~ msgid "Show GUI settings"
-#~ msgstr "Zeige GUI-Einstellungen"
+msgid "Show GUI settings"
+msgstr "Zeige GUI-Einstellungen"
-#~ msgid "Profile options"
+msgid "Profile options"
-#~ msgid "Quit Profile Analysis Tool"
-#~ msgstr "Beende Profil-Analyse"
+msgid "Quit Profile Analysis Tool"
+msgstr "Beende Profil-Analyse"
-#~ msgid "Set GCP"
-#~ msgstr "GCPs setzten"
+msgid "Set GCP"
+msgstr "GCPs setzten"
-#~ msgid "Define GCP (Ground Control Points)"
-#~ msgstr "Definiere GCPs (Ground Control Points)"
+msgid "Define GCP (Ground Control Points)"
+msgstr "Definiere GCPs (Ground Control Points)"
-#~ msgid "Recalculate RMS error"
-#~ msgstr "Berechne den RMS-Fehler"
+msgid "Recalculate RMS error"
+msgstr "Berechne den RMS-Fehler"
-#~ msgid "Save GCPs to POINTS file"
-#~ msgstr "Speichere GCPs in POINTS Datei"
+msgid "Save GCPs to POINTS file"
+msgstr "Speichere GCPs in POINTS Datei"
-#~ msgid "Add new GCP"
-#~ msgstr "Neuen GCP hinzufügen"
+msgid "Add new GCP"
+msgstr "Neuen GCP hinzufügen"
-#~ msgid "Delete selected GCP"
-#~ msgstr "Selektierten GCP löschen"
+msgid "Delete selected GCP"
+msgstr "Selektierten GCP löschen"
-#~ msgid "Clear selected GCP"
-#~ msgstr "Selektierten GCP reinigen"
+msgid "Clear selected GCP"
+msgstr "Selektierten GCP reinigen"
-#~ msgid "Reload GCPs from POINTS file"
-#~ msgstr "Lade erneut GCPs aus POINTS-Datei"
+msgid "Reload GCPs from POINTS file"
+msgstr "Lade erneut GCPs aus POINTS-Datei"
-#~ msgid "Quit georectification"
-#~ msgstr "Beende Georektifikationsmodul"
+msgid "Quit georectification"
+msgstr "Beende Georektifikationsmodul"
-#~ msgid "Settings dialog for georectification tool"
-#~ msgstr "Einstellungsdialog für Georektifikationswerkzeug"
+msgid "Settings dialog for georectification tool"
+msgstr "Einstellungsdialog für Georektifikationswerkzeug"
-#~ msgid "Switch to view control page"
-#~ msgstr "Wechsle zu Einstellungen für Ansicht"
+msgid "Switch to view control page"
+msgstr "Wechsle zu Einstellungen für Ansicht"
-#~ msgid "Change view settings"
-#~ msgstr "Ändere Einstellungen für Darstellung"
+msgid "Change view settings"
+msgstr "Ändere Einstellungen für Darstellung"
-#~ msgid "Switch to surface (raster) control page"
-#~ msgstr "Wechsle zu Einstellungen für Oberflächen (Raster)"
+msgid "Switch to surface (raster) control page"
+msgstr "Wechsle zu Einstellungen für Oberflächen (Raster)"
-#~ msgid "Change surface (loaded raster maps) settings"
-#~ msgstr "Ändere Oberflächen-Eigenschaften (geladene Rasterkarte)"
+msgid "Change surface (loaded raster maps) settings"
+msgstr "Ändere Oberflächen-Eigenschaften (geladene Rasterkarte)"
-#~ msgid "Switch to vector (2D/3D) control page"
-#~ msgstr "Wechsle zu Einstellungen für Vektoren (2D/3D) "
+msgid "Switch to vector (2D/3D) control page"
+msgstr "Wechsle zu Einstellungen für Vektoren (2D/3D) "
-#~ msgid "Change 2D/3D vector settings"
-#~ msgstr "Ändere 2D/3D Vektoreinstellungen"
+msgid "Change 2D/3D vector settings"
+msgstr "Ändere 2D/3D Vektoreinstellungen"
-#~ msgid "Switch to volume (3D raster) control page"
-#~ msgstr "Wechsle zu Einstellungen für Volumen (3D-Raster)"
+msgid "Switch to volume (3D raster) control page"
+msgstr "Wechsle zu Einstellungen für Volumen (3D-Raster)"
-#~ msgid "Change volume (loaded 3D raster maps) settings"
-#~ msgstr "Ändere Volumen-Einstellungen (geladene 3D-Rasterkarte)"
+msgid "Change volume (loaded 3D raster maps) settings"
+msgstr "Ändere Volumen-Einstellungen (geladene 3D-Rasterkarte)"
-#~ msgid "Switch to lighting control page"
-#~ msgstr "Wechsle zu Einstellungen für die Lichtverhältnisse"
+msgid "Switch to lighting control page"
+msgstr "Wechsle zu Einstellungen für die Lichtverhältnisse"
-#~ msgid "Change lighting settings"
-#~ msgstr "Ändere Beleuchtungseinstellung"
+msgid "Change lighting settings"
+msgstr "Ändere Beleuchtungseinstellung"
-#~ msgid "Switch to fringe control page"
-#~ msgstr "Wechsle zu Einstellungen der Randzone"
+msgid "Switch to fringe control page"
+msgstr "Wechsle zu Einstellungen der Randzone"
-#~ msgid "Switch on/off fringes"
-#~ msgstr "Randzonen ein-/ausblenden"
+msgid "Switch on/off fringes"
+msgstr "Randzonen ein-/ausblenden"
-#~ msgid "3D view mode tools"
-#~ msgstr "3D Ansicht-Werkszeugsleiste"
+msgid "3D view mode tools"
+msgstr "3D Ansicht-Werkszeugsleiste"
-#~ msgid "Quit 3D view mode"
-#~ msgstr "Verlasse den 3D-Ansicht-Modus"
+msgid "Quit 3D view mode"
+msgstr "Verlasse den 3D-Ansicht-Modus"
-#~ msgid "Create new model (Ctrl+N)"
-#~ msgstr "Erstelle neues Modell (Ctrl+N)"
+msgid "Create new model (Ctrl+N)"
+msgstr "Erstelle neues Modell (Ctrl+N)"
-#~ msgid "Load model from file (Ctrl+O)"
-#~ msgstr "Lade Modell aus Datei (Ctrl+O)"
+msgid "Load model from file (Ctrl+O)"
+msgstr "Lade Modell aus Datei (Ctrl+O)"
-#~ msgid "Save current model to file (Ctrl+S)"
-#~ msgstr "Speichere aktuelles Modell in Datei (Ctrl+S)"
+msgid "Save current model to file (Ctrl+S)"
+msgstr "Speichere aktuelles Modell in Datei (Ctrl+S)"
-#~ msgid "Show modeler settings"
-#~ msgstr "Zeige Modeler-Einstellungen"
+msgid "Show modeler settings"
+msgstr "Zeige Modeler-Einstellungen"
-#~ msgid "Show model properties"
-#~ msgstr "Zeige Modell-Eigenschaften"
+msgid "Show model properties"
+msgstr "Zeige Modell-Eigenschaften"
-#~ msgid "Manage model variables"
-#~ msgstr "Verwalte Modell-Variablen"
+msgid "Manage model variables"
+msgstr "Verwalte Modell-Variablen"
-#~ msgid "Redraw model canvas"
-#~ msgstr "Neuzeichnen des Modell-Kartenfensters"
+msgid "Redraw model canvas"
+msgstr "Neuzeichnen des Modell-Kartenfensters"
-#~ msgid "Add raster map"
-#~ msgstr "Rasterkarte hinzufügen"
+msgid "Add raster map"
+msgstr "Rasterkarte hinzufügen"
-#~ msgid "Add text"
-#~ msgstr "Text hinzufügen"
+msgid "Add text"
+msgstr "Text hinzufügen"
-#~ msgid "Unable to render overlay <%s>"
-#~ msgstr "Kann die Überlagerung <%s> nicht rendern"
+msgid "Unable to render overlay <%s>"
+msgstr "Kann die Überlagerung <%s> nicht rendern"
-#~ msgid "Converts 3D raster maps (G3D) into the VTK-Ascii format"
-#~ msgstr "Konvertiert eine 3D-Rasterkarte (G3D) in das VTK-ASCII-Format."
+msgid "Converts 3D raster maps (G3D) into the VTK-Ascii format"
+msgstr "Konvertiert eine 3D-Rasterkarte (G3D) in das VTK-ASCII-Format."
-#~ msgid "NVIZ (non-interactive)"
-#~ msgstr "NVIZ (nicht interaktiv)"
+msgid "NVIZ (non-interactive)"
+msgstr "NVIZ (nicht interaktiv)"
-#~ msgid "Allows rendering GIS data is a 3D space."
-#~ msgstr "Erlaubt Rendern von GIS data im 3D-Raum."
+msgid "Allows rendering GIS data is a 3D space."
+msgstr "Erlaubt Rendern von GIS data im 3D-Raum."
-#~ msgid "Upload or report topology"
-#~ msgstr "Lade oder berichte Topologie"
+msgid "Upload or report topology"
+msgstr "Lade oder berichte Topologie"
-#~ msgid "Validity"
-#~ msgstr "Gültigkeit"
+msgid "Validity"
+msgstr "Gültigkeit"
-#~ msgid "Manage columns"
-#~ msgstr "Spalten verwalten"
+msgid "Manage columns"
+msgstr "Spalten verwalten"
-#~ msgid "Hardcopy Map Output Utility"
-#~ msgstr "Werkzeug zur Erstellung von Ausgabekarten"
+msgid "Hardcopy Map Output Utility"
+msgstr "Werkzeug zur Erstellung von Ausgabekarten"
-#~ msgid "Quit Hardcopy Map Utility"
-#~ msgstr "Verlasse Werkzeug zur Erstellung von Ausgabekarten"
+msgid "Quit Hardcopy Map Utility"
+msgstr "Verlasse Werkzeug zur Erstellung von Ausgabekarten"
 #, fuzzy
-#~ msgid "Launch Hardcopy Map Output Utility"
-#~ msgstr "Werkzeug zur Erstellung von Ausgabekarten im PostScript-Format."
+msgid "Launch Hardcopy Map Output Utility"
+msgstr "Werkzeug zur Erstellung von Ausgabekarten im PostScript-Format."
 #, fuzzy
-#~ msgid "GRASS GIS Hardcopy Map Output Utility (experimental prototype)"
+msgid "GRASS GIS Hardcopy Map Output Utility (experimental prototype)"
 #, fuzzy
-#~ msgid "wxGUI Hardcopy Map Utility"
+msgid "wxGUI Hardcopy Map Utility"
-#~ msgid "Close current"
-#~ msgstr "Aktuelles einklappen "
+msgid "Close current"
+msgstr "Aktuelles einklappen "
-#~ msgid "Postscript plot"
-#~ msgstr "Postscript Plot"
+msgid "Postscript plot"
+msgstr "Postscript Plot"
 #, fuzzy
-#~ msgid "Produces hardcopy PostScript map output."
+msgid "Produces hardcopy PostScript map output."
-#~ msgid "Tool to maintain GRASS extensions in local GRASS installation."
-#~ msgstr ""
-#~ "Werkzeug zur Verwaltung von GRASS-Erweiterungen in der lokalen GRASS-"
-#~ "Installation."
+msgid "Tool to maintain GRASS extensions in local GRASS installation."
+msgstr "Werkzeug zur Verwaltung von GRASS-Erweiterungen in der lokalen GRASS-Installation."
-#~ msgid "Submit"
-#~ msgstr "Senden"
+msgid "Submit"
+msgstr "Senden"
-#~ msgid "Vector digitizer"
-#~ msgstr "Vektor-Digitalisierung"
+msgid "Vector digitizer"
+msgstr "Vektor-Digitalisierung"
-#~ msgid "Vector querying"
-#~ msgstr "Vektorabfrage"
+msgid "Vector querying"
+msgstr "Vektorabfrage"
-#~ msgid "Only vector map from the current mapset can be modified."
-#~ msgstr "Es können nur Vektorkarten des aktuellen Mapsets geändert werden."
+msgid "Only vector map from the current mapset can be modified."
+msgstr "Es können nur Vektorkarten des aktuellen Mapsets geändert werden."
-#~ msgid "Query raster/vector map(s) (display mode)"
-#~ msgstr "Frage Raster-/Vektorkarte(n) ab (Anzeige-Modus)"
+msgid "Query raster/vector map(s) (display mode)"
+msgstr "Frage Raster-/Vektorkarte(n) ab (Anzeige-Modus)"
-#~ msgid "Query vector map (edit mode)"
-#~ msgstr "Frage Vektorkarte ab (Editier-Modus)"
+msgid "Query vector map (edit mode)"
+msgstr "Frage Vektorkarte ab (Editier-Modus)"
-#~ msgid "Parameter element '%(element)s' not found: '%(value)s'"
-#~ msgstr "Parameter-Element '%(element)s' nicht gefunden: '%(value)s'"
+msgid "Parameter element '%(element)s' not found: '%(value)s'"
+msgstr "Parameter-Element '%(element)s' nicht gefunden: '%(value)s'"
-#~ msgid "Flag not found: %s"
-#~ msgstr "Schalter nicht gefunden: %s"
+msgid "Flag not found: %s"
+msgstr "Schalter nicht gefunden: %s"
-#~ msgid "Parameter '%(name)s' (%(desc)s) is missing."
-#~ msgstr "Parameter %(name)s (%(desc)s) fehlt."
+msgid "Parameter '%(name)s' (%(desc)s) is missing."
+msgstr "Parameter %(name)s (%(desc)s) fehlt."
-#~ msgid "<required>"
-#~ msgstr "<erfordert>"
+msgid "<required>"
+msgstr "<erfordert>"
 #, fuzzy
-#~ msgid "Unable to fetch interface description for command '%s'."
-#~ msgstr ""
-#~ "Kann die Interface-Beschreibung für den Befehl '%s' nicht ermitteln. "
-#~ "Details: %s"
+msgid "Unable to fetch interface description for command '%s'."
+msgstr "Kann die Interface-Beschreibung für den Befehl '%s' nicht ermitteln. Details: %s"
 #, fuzzy
-#~ msgid "Menu style:"
-#~ msgstr "Menue-Baum"
+msgid "Menu style:"
+msgstr "Menue-Baum"
-#~ msgid "Icon theme:"
-#~ msgstr "Symbol-Design:"
+msgid "Icon theme:"
+msgstr "Symbol-Design:"
-#~ msgid ""
-#~ "Note: For changing the icon theme, you must save the settings and restart "
-#~ "this GUI."
-#~ msgstr ""
-#~ "Hinweis: Um das Symbol-Design zu ändern müssen die Einstellungen "
-#~ "gespeichert werden und das GUI erneut gestartet werden."
+msgid "Note: For changing the icon theme, you must save the settings and restart this GUI."
+msgstr "Hinweis: Um das Symbol-Design zu ändern müssen die Einstellungen gespeichert werden und das GUI erneut gestartet werden."
 #, fuzzy
-#~ msgid "No mapsets available in location <%s>"
-#~ msgstr "Keine Mapsets in Location <%s> vorhanden"
+msgid "No mapsets available in location <%s>"
+msgstr "Keine Mapsets in Location <%s> vorhanden"
-#~ msgid "Load map layers into layer tree"
-#~ msgstr "Kartenebenen in Baumstruktur laden"
+msgid "Load map layers into layer tree"
+msgstr "Kartenebenen in Baumstruktur laden"
-#~ msgid "Load map layers into workspace (Ctrl+L)"
-#~ msgstr "Lade Kartenlayer in Workspace (Ctrl+L)"
+msgid "Load map layers into workspace (Ctrl+L)"
+msgstr "Lade Kartenlayer in Workspace (Ctrl+L)"
 #, fuzzy
-#~ msgid "Hardcopy Map Ouput Utility"
+msgid "Hardcopy Map Ouput Utility"
-#~ msgid "Load map layers"
-#~ msgstr "Lade Kartenebenen"
+msgid "Load map layers"
+msgstr "Lade Kartenebenen"
-#~ msgid "General settings"
-#~ msgstr "Allgemeine Einstellungen"
+msgid "General settings"
+msgstr "Allgemeine Einstellungen"
-#~ msgid "Loading workspace"
-#~ msgstr "Lade Projekt"
+msgid "Loading workspace"
+msgstr "Lade Projekt"
-#~ msgid "Start Graphical Modeler"
-#~ msgstr "Starte Graphical Modeler"
+msgid "Start Graphical Modeler"
+msgstr "Starte Graphical Modeler"
-#~ msgid "Show help page"
-#~ msgstr "Zeige Hilfe an"
+msgid "Show help page"
+msgstr "Zeige Hilfe an"
-#~ msgid "Select maps to display"
-#~ msgstr "Wähle Karten für Darstellung"
+msgid "Select maps to display"
+msgstr "Wähle Karten für Darstellung"
-#~ msgid "Delete GCP"
-#~ msgstr "Löschen GCP"
+msgid "Delete GCP"
+msgstr "Löschen GCP"
-#~ msgid "RMS Error"
-#~ msgstr "RMS-Fehler"
+msgid "RMS Error"
+msgstr "RMS-Fehler"
-#~ msgid "Adjust GCP Displays "
-#~ msgstr "Passe GCP Anzeige an"
+msgid "Adjust GCP Displays "
+msgstr "Passe GCP Anzeige an"
-#~ msgid "Map toolbar"
-#~ msgstr "Karten-Werkzeugleiste"
+msgid "Map toolbar"
+msgstr "Karten-Werkzeugleiste"
-#~ msgid "Uknown settings file location."
-#~ msgstr "Unbekannter Ort der Datei mit den Einstellungen"
+msgid "Uknown settings file location."
+msgstr "Unbekannter Ort der Datei mit den Einstellungen"
-#~ msgid "Place where to store settings:"
-#~ msgstr "Ort, an dem Einstellungen gespeichert werden:"
+msgid "Place where to store settings:"
+msgstr "Ort, an dem Einstellungen gespeichert werden:"
-#~ msgid "Import Mapgen or Matlab vector maps into GRASS."
-#~ msgstr "Importiere Mapgen oder Matlab Vektordaten in GRASS."
+msgid "Import Mapgen or Matlab vector maps into GRASS."
+msgstr "Importiere Mapgen oder Matlab Vektordaten in GRASS."
 #, fuzzy
-#~ msgid "Lists available GIS elements of the user-specified data type."
-#~ msgstr ""
-#~ "Listet alle verfügbaren GRASS Datenbankdateien im spezifiezierten Typ im "
-#~ "Standard Output auf"
+msgid "Lists available GIS elements of the user-specified data type."
+msgstr "Listet alle verfügbaren GRASS Datenbankdateien im spezifiezierten Typ im Standard Output auf"
 #, fuzzy
-#~ msgid "Generates stream channels."
-#~ msgstr "Abflusslinien graben"
+msgid "Generates stream channels."
+msgstr "Abflusslinien graben"
 #, fuzzy
-#~ msgid "Creates watershed basins."
-#~ msgstr "Einzugsgebietsunterflächen"
+msgid "Creates watershed basins."
+msgstr "Einzugsgebietsunterflächen"
 #, fuzzy
-#~ msgid "Reclassify raster map based on category values."
-#~ msgstr "Reklassifiziere Rasterkarte mittels Regeln"
+msgid "Reclassify raster map based on category values."
+msgstr "Reklassifiziere Rasterkarte mittels Regeln"
-#~ msgid "Attribute management is available only for vector maps."
-#~ msgstr "Attributverwaltung ist nur für Vektorkarten möglich"
+msgid "Attribute management is available only for vector maps."
+msgstr "Attributverwaltung ist nur für Vektorkarten möglich"
-#~ msgid "Display zoom management"
-#~ msgstr "Zeige Zoom-Management"
+msgid "Display zoom management"
+msgstr "Zeige Zoom-Management"
-#~ msgid "Add thematic layer"
-#~ msgstr "Thematische Ebene hinzufügen"
+msgid "Add thematic layer"
+msgstr "Thematische Ebene hinzufügen"
-#~ msgid "Settings dialog for digitization tool"
-#~ msgstr "Einstellungsdialog des Digitalisierungswerkzeugs"
+msgid "Settings dialog for digitization tool"
+msgstr "Einstellungsdialog des Digitalisierungswerkzeugs"
-#~ msgid "Select color"
-#~ msgstr "Farbe auswählen"
+msgid "Select color"
+msgstr "Farbe auswählen"
-#~ msgid "Display Graphical Modeler manual page"
-#~ msgstr "Zeige Graphical Modeler-Handbuch an "
+msgid "Display Graphical Modeler manual page"
+msgstr "Zeige Graphical Modeler-Handbuch an "
-#~ msgid "Aggregate ASCII xyz import"
-#~ msgstr "Aggregierter ASCII XYZ Import"
+msgid "Aggregate ASCII xyz import"
+msgstr "Aggregierter ASCII XYZ Import"
-#~ msgid "Binary export"
-#~ msgstr "Export in Binärdatei"
+msgid "Binary export"
+msgstr "Export in Binärdatei"
-#~ msgid "Multiple export formats using OGR"
-#~ msgstr "Vektorexport über OGR"
+msgid "Multiple export formats using OGR"
+msgstr "Vektorexport über OGR"
-#~ msgid "Selects data from table."
-#~ msgstr "Selektiert Daten einer Tabelle."
+msgid "Selects data from table."
+msgstr "Selektiert Daten einer Tabelle."
-#~ msgid "Add attributes"
-#~ msgstr "Attribute hinzufügen"
+msgid "Add attributes"
+msgstr "Attribute hinzufügen"
-#~ msgid ""
-#~ "Unable to initialize display driver of vector digitizer. See 'Command "
-#~ "output' for details.\n"
-#~ "\n"
-#~ "Details: "
-#~ msgstr ""
-#~ "Kann die Anzeige für die Vektordigitalisierung nicht initialisieren. "
-#~ "Siehe 'Command output' für Details.\n"
-#~ "\n"
-#~ "Details:"
+msgid ""
+"Unable to initialize display driver of vector digitizer. See 'Command output' for details.\n"
+"\n"
+"Details: "
+msgstr ""
+"Kann die Anzeige für die Vektordigitalisierung nicht initialisieren. Siehe 'Command output' für Details.\n"
+"\n"
+"Details:"
-#~ msgid ""
-#~ "Unable to open vector map <%s> for editing.\n"
-#~ "\n"
-#~ "Data are probably corrupted, try to run v.build to rebuild the topology "
-#~ "(Vector->Develop vector map->Create/rebuild topology)."
-#~ msgstr ""
-#~ "Kann die Vektorkarte <%s> nicht zum Editieren öff
