[GRASS-SVN] r61584 - grass/branches/develbranch_6/locale/po
svn_grass at osgeo.org
Mon Aug 11 03:15:18 PDT 2014
Author: neteler
Date: 2014-08-11 03:15:18 -0700 (Mon, 11 Aug 2014)
New Revision: 61584
grass/branches/develbranch_6/locale/po/grasslibs_de.po
grass/branches/develbranch_6/locale/po/grassmods_de.po
grass/branches/develbranch_6/locale/po/grassnviz_de.po
grass/branches/develbranch_6/locale/po/grasswxpy_de.po
Robert Nuske: DE translation cont'ed)
Modified: grass/branches/develbranch_6/locale/po/grasslibs_de.po
--- grass/branches/develbranch_6/locale/po/grasslibs_de.po 2014-08-11 10:14:22 UTC (rev 61583)
+++ grass/branches/develbranch_6/locale/po/grasslibs_de.po 2014-08-11 10:15:18 UTC (rev 61584)
@@ -1,27 +1,27 @@
# translation of grasslibs_de.po to Deutsch
# This file is distributed under the same license as the GRASS package.
-# Copyright (C) 2004-2013 GRASS Development Team
+# Copyright (C) 2004-2014 GRASS Development Team
# Markus Neteler <neteler itc.it>, 2004.
# Stephan Holl <holl gdf-hannover.de>, 2004, 2005, 2006.
# Stephan Holl <stephan.holl intevation.de>, 2007.
# Markus Neteler <neteler osgeo.org>, 2008.
-# Robert Nuske <robert.nuske nw-fva.de>, 2009, 2010, 2011, 2012, 2013.
+# Robert Nuske <robert.nuske nw-fva.de>, 2009, 2010, 2011, 2012, 2013, 2014.
# Helmut Kudrnovsky <hellik web.de>, 2011.
msgid ""
msgstr ""
"Project-Id-Version: grasslibs_de\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2014-03-03 17:34+0100\n"
-"PO-Revision-Date: 2014-03-24 13:45+0100\n"
-"Last-Translator: Helmut Kudrnovsky <hellik at web.de>\n"
+"PO-Revision-Date: 2014-08-10 13:37+0200\n"
+"Last-Translator: Robert Nuske <robert.nuske at nw-fva.de>\n"
"Language-Team: German <grass-translations at lists.osgeo.org>\n"
"Language: de\n"
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=UTF-8\n"
"Content-Transfer-Encoding: 8bit\n"
"Plural-Forms: nplurals=2; plural=(n != 1);\n"
-"X-Generator: Poedit 1.6.4\n"
+"X-Generator: Lokalize 1.5\n"
#: ../lib/raster/rem_io.c:40
#, c-format
@@ -326,7 +326,7 @@
#: ../lib/ogsf/Gs3.c:133 ../lib/ogsf/Gs3.c:208 ../lib/ogsf/Gs3.c:366
#: ../lib/ogsf/Gs3.c:482 ../lib/ogsf/Gs3.c:587
msgid "Unable to allocate memory for a null buffer"
-msgstr "Kann keinen Speicher reservieren für einen NULL-Buffer."
+msgstr "Kann keinen Speicher reservieren für einen NULL-Puffer."
#: ../lib/ogsf/Gs3.c:137 ../lib/ogsf/Gs3.c:212 ../lib/ogsf/Gs3.c:370
#: ../lib/ogsf/Gs3.c:486 ../lib/ogsf/Gs3.c:577 ../lib/gpde/N_arrays_io.c:68
@@ -1880,7 +1880,7 @@
#: ../lib/gis/get_row.c:1115
msgid "Unable to realloc buffer"
-msgstr "Kann Buffer nicht wieder reservieren."
+msgstr "Kann Puffer nicht wieder reservieren."
#: ../lib/gis/gisinit.c:54 ../lib/gis/gisinit.c:90
msgid "Incompatible library version for module. You need to rebuild GRASS or untangle multiple installations."
@@ -5127,3 +5127,9 @@
#~ msgid "'%s' must be > 0 for '%s'"
#~ msgstr "'%s' muss > 0 für '%s' sein"
+#~ msgid "No temp files available: %s"
+#~ msgstr "Keine temp Dateien vorhanden: %s"
+#~ msgid "Module built against version %s but trying to use version %s. You need to rebuild GRASS GIS or untangle multiple installations."
+#~ msgstr "Das Module wurde mit Version %s gebaut, aber versucht Version %s zu verwenden. Sie müssen GRASS erneut bauen oder verschiedene Installationen entwirren."
Modified: grass/branches/develbranch_6/locale/po/grassmods_de.po
--- grass/branches/develbranch_6/locale/po/grassmods_de.po 2014-08-11 10:14:22 UTC (rev 61583)
+++ grass/branches/develbranch_6/locale/po/grassmods_de.po 2014-08-11 10:15:18 UTC (rev 61584)
@@ -1,24 +1,24 @@
# translation of grassmods_de.po to Deutsch
-# Robert Nuske <robert.nuske nw-fva.de>, 2006, 2007, 2008, 2009, 2010, 2011, 2012, 2013.
+# Robert Nuske <robert.nuske nw-fva.de>, 2006, 2007, 2008, 2009, 2010, 2011, 2012, 2013, 2014.
msgid ""
msgstr ""
"Project-Id-Version: grassmods_de\n"
-"PO-Revision-Date: 2014-03-24 15:17+0100\n"
+"PO-Revision-Date: 2014-08-10 14:59+0200\n"
"Language: de\n"
#: ../raster/r.out.pov/main.c:121 ../raster/r.out.ppm3/main.c:57
#: ../raster/r.out.arc/main.c:60 ../raster/r.out.ppm/main.c:54
@@ -2270,9 +2270,8 @@
msgstr ""
#: ../raster/r.watershed/front/main.c:86
-#, fuzzy
msgid "Name of input raster map blocking overland surface flow"
-msgstr "Eingabekarte mit Gelände, dass den Oberflächenabfluss blockiert, für USLE."
+msgstr "Eingabe-Rasterkarte: Flächen die Oberflächenabfluss blockieren"
#: ../raster/r.watershed/front/main.c:88
#, fuzzy
@@ -2280,9 +2279,8 @@
msgstr "Alle Zellen, die nicht NULL sind oder den Wert Null haben werden als echte Hindernis aufgefasst."
#: ../raster/r.watershed/front/main.c:94
-#, fuzzy
msgid "Name for output accumulation raster map"
-msgstr "Name der Ausgabe-Expositions-Rasterkarte."
+msgstr "Name der Ausgabe-Akkumulations-Rasterkarte."
#: ../raster/r.watershed/front/main.c:95
#, fuzzy
@@ -2346,9 +2344,8 @@
msgstr "Ausgabekarte die hilfreich für die visuelle Darstellung der Ergebnisse ist. VERALTET."
#: ../raster/r.watershed/front/main.c:135
-#, fuzzy
msgid "Name for output slope length raster map"
-msgstr "Name der Ausgabe-Neigungs-Rasterkarte."
+msgstr "Name der Ausgabe-Neigungslängen-Rasterkarte"
#: ../raster/r.watershed/front/main.c:137
#, fuzzy
@@ -2356,9 +2353,8 @@
msgstr "Ausgabekarte der Hanglängen und -Neigungsfaktoren (LS) für USLE."
#: ../raster/r.watershed/front/main.c:143
-#, fuzzy
msgid "Name for output slope steepness raster map"
+msgstr "Name der Ausgabe-Neigungs-Rasterkarte"
#: ../raster/r.watershed/front/main.c:144
#, fuzzy
@@ -2377,11 +2373,11 @@
#: ../raster/r.watershed/front/main.c:170
msgid "Convergence factor for MFD (1-10)"
-msgstr "Umrechnungsfaktor für MFD (1-10)."
+msgstr "Umrechnungsfaktor für MFD (1-10)"
#: ../raster/r.watershed/front/main.c:172
msgid "1 = most diverging flow, 10 = most converging flow. Recommended: 5"
-msgstr "1 = der am meisten divergierende Fluss, 10 = der am meisten konvergierende Fluss. Empfohlen: 5."
+msgstr "1 = am meisten divergierende Fluss, 10 = am meisten konvergierende Fluss. Empfohlen: 5"
#: ../raster/r.watershed/front/main.c:179
msgid "Maximum memory to be used with -m flag (in MB)"
@@ -2857,17 +2853,16 @@
msgstr "Raster, Geometrie"
#: ../raster/r.grow.distance/main.c:150
-#, fuzzy
msgid "Generates a raster map containing distances to nearest raster features."
-msgstr "Erzeugt eine Rasterkarte mit Distanzen zu Objekten in der Eingabekarte."
+msgstr "Erzeugt eine Rasterkarte mit Distanzen zu nächsten Raster-Objekten."
#: ../raster/r.grow.distance/main.c:157
msgid "Name for distance output map"
-msgstr "Name der Distanz-Ausgabekarte."
+msgstr "Name der Distanz-Ausgabekarte"
#: ../raster/r.grow.distance/main.c:162
msgid "Name for value output map"
-msgstr "Name der Wert-Ausgabekarte."
+msgstr "Name der Wert-Ausgabekarte"
#: ../raster/r.grow.distance/main.c:168 ../raster/r.grow2/main.c:148
msgid "Metric"
@@ -4583,11 +4578,11 @@
#: ../raster/r.buffer/main.c:69
msgid "raster, buffer"
-msgstr "Raster, Buffer"
+msgstr "Raster, Puffer"
#: ../raster/r.buffer/main.c:71
msgid "Creates a raster map layer showing buffer zones surrounding cells that contain non-NULL category values."
-msgstr "Erzeugt eine Rasterkarte mit Bufferzonen um Pixel, die keine NULL-Werte haben."
+msgstr "Erzeugt eine Rasterkarte mit Pufferzonen um Pixel, die keine NULL-Werte haben."
#: ../raster/r.buffer/main.c:83
msgid "Distance zone(s)"
@@ -4612,7 +4607,7 @@
#: ../raster/r.buffer/execute.c:34
msgid "Finding buffer zones..."
-msgstr "Berechne Buffer-Zonen..."
+msgstr "Berechne Puffer-Zonen..."
#: ../raster/r.buffer/read_map.c:53
#, c-format
@@ -5366,9 +5361,8 @@
msgstr "Rasterkarte <%s> nicht gefunden und manin_val undefiniert. Wählen Sie eine, welche prozessiert werden dürfen."
#: ../raster/simwe/simlib/input.c:541
-#, fuzzy
msgid "Zero value in Mannings n"
-msgstr "Nullwert in Manning's n."
+msgstr "Nullwert in Mannings n"
#: ../raster/simwe/simlib/input.c:592
msgid "Infiltration exceeds the rainfall rate everywhere! No overland flow."
@@ -5394,9 +5388,9 @@
msgstr "Mittlere Fließgeschwindigkeit \t= %f m/s\n"
#: ../raster/simwe/simlib/input.c:621
-#, fuzzy, c-format
+#, c-format
msgid "Mean Mannings \t= %f\n"
-msgstr "Mittlerer Manning's \t= %f\n"
+msgstr "Mittlerer Mannings \t= %f\n"
#: ../raster/simwe/simlib/input.c:625
#, c-format
@@ -5427,9 +5421,9 @@
msgstr "Kann die et Datei nicht schreiben."
#: ../raster/simwe/simlib/output.c:313 ../raster/simwe/simlib/output.c:321
-#, fuzzy, c-format
+#, c-format
msgid "FP raster map <%s> not found"
-msgstr "3D-Rasterkarte <%s> nicht gefunden."
+msgstr "FP-Rasterkarte <%s> nicht gefunden."
#: ../raster/r.region/main.c:56
msgid "Sets the boundary definitions for a raster map."
@@ -6641,9 +6635,9 @@
msgstr "Die Eingabe-Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der Wert %d wurde verwendet um NoData-Werte in der Eingabekarte zu kennzeichnen. Sie können NoData-Wert mit dem Parameter %s bestimmen."
#: ../raster/r.out.gdal/export_band.c:192
-#, fuzzy, c-format
+#, c-format
msgid "Input raster map contains cells with NULL-value (no-data). The value %g will be used to represent no-data values in the input map. You can specify a nodata value with the %s option."
-msgstr "Die Eingabe Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der Wert %d wurde verwendet um Nodata-Werte in der Eingabekarte zu kennzeichnen. Sie können Nodata-Wert mit dem Parameter %s bestimmen."
+msgstr "Die Eingabe-Rasterkarte enthält Zellen mit dem NULL-Wert (no-data). Der Wert %g wird verwendet, um NoData-Werte in der Eingabekarte zu kennzeichnen. Sie können NoData-Wert mit dem Parameter %s bestimmen."
#: ../raster/r.out.gdal/export_band.c:202
#, c-format
@@ -7474,7 +7468,6 @@
msgstr "Raster, Konvertieren, Vektorisieren"
#: ../raster/r.to.vect/main.c:52
-#, fuzzy
msgid "Converts a raster map into a vector map."
msgstr "Konvertiert eine Rasterkarte in eine Vektorkarte."
@@ -7734,7 +7727,7 @@
#: ../raster/r.grow2/main.c:141
msgid "Radius of buffer in raster cells"
-msgstr "Radius des Buffers in Rasterzellen."
+msgstr "Radius des Puffers in Rasterzellen"
#: ../raster/r.grow2/main.c:157
msgid "Value to write for input cells which are non-NULL (-1 => NULL)"
@@ -8803,9 +8796,8 @@
msgstr "Eingabe-Rasterkarte, die Höhenwerte enthält."
#: ../raster/r.carve/main.c:89
-#, fuzzy
msgid "Name of input vector map containing stream(s)"
-msgstr "Namde der Eingabe-Vektorkarte mit Linien."
+msgstr "Name der Eingabe-Vektorkarte mit Flüssen"
#: ../raster/r.carve/main.c:97
msgid "Name for output vector map for adjusted stream points"
@@ -9184,30 +9176,26 @@
msgstr "Kann Setup Datei nicht lesen."
#: ../raster/r.li/r.li.daemon/daemon.c:355
-#, fuzzy
msgid "Unable to parse configuration file (sampling frame)"
-msgstr "Kann die Konfigurationsdatei nicht interpretieren."
+msgstr "Kann die Konfigurationsdatei nicht interpretieren (Stichprobenrahmen)"
#: ../raster/r.li/r.li.daemon/daemon.c:367
msgid "Cannot read raster header file"
msgstr "Kann Header der Rasterkarte nicht lesen."
#: ../raster/r.li/r.li.daemon/daemon.c:529
-#, fuzzy
msgid "Irregular MASKEDOVERLAY areas definition"
-msgstr "Unregelmäßige maskedoverlay Flächen Definition."
+msgstr "Unregelmäßige MASKEDOVERLAY Flächen Definition."
#: ../raster/r.li/r.li.daemon/daemon.c:540
-#, fuzzy
msgid "Unable to parse configuration file (sample area)"
+msgstr "Kann die Konfigurationsdatei nicht interpretieren (Stichprobenfläche)."
#: ../raster/r.li/r.li.daemon/daemon.c:575
msgid "Too many units to place"
msgstr "Zu viele Einheiten zu platzieren."
#: ../raster/r.li/r.li.daemon/daemon.c:644
-#, fuzzy
msgid "Too many stratified random sample for raster map"
msgstr "Zu viele Straten für diese Rasterkarte."
@@ -9325,11 +9313,11 @@
#: ../raster/r.li/r.li.edgedensity/edgedensity.c:55
msgid "The value of the patch type"
-msgstr ""
+msgstr "Der Wert des Patch-Typs"
#: ../raster/r.li/r.li.edgedensity/edgedensity.c:56
msgid "It can be integer, double or float; it will be changed in function of map type"
-msgstr ""
+msgstr "Es kann Integer, Double oder Float sein. Es wird in Funktion des Kartentyps geändert."
#: ../raster/r.li/r.li.pielou/pielou.c:59
msgid "Calculates Pielou's diversity index on a raster map"
@@ -9361,7 +9349,7 @@
#: ../raster/r.li/r.li.cwed/cwed.c:59
msgid "Name of file that contains the weight to calculate the index"
-msgstr ""
+msgstr "Name der Datei mit den Gewichten zur Berechnung des Index"
#: ../raster/r.what/main.c:93
msgid "Queries raster map layers on their category values and category labels."
@@ -9482,23 +9470,23 @@
#: ../raster/r.horizon/main.c:251
msgid "For horizon rasters, read from the DEM an extra buffer around the present region"
-msgstr "Für Horizont-Rasterkarten: Lese vom DGM einen extra Bufferbereich um die aktuelle Region herum ein."
+msgstr "Für Horizont-Rasterkarten: Lese vom DGM einen extra Pufferbereich um die aktuelle Region herum ein."
#: ../raster/r.horizon/main.c:259
msgid "For horizon rasters, read from the DEM an extra buffer eastward the present region"
-msgstr "Für Horizont-Rasterkarten: Lese vom DGM einen extra Bufferbereich östlich der aktuellen Region ein."
+msgstr "Für Horizont-Rasterkarten: Lese vom DGM einen extra Pufferbereich östlich der aktuellen Region ein."
#: ../raster/r.horizon/main.c:267
msgid "For horizon rasters, read from the DEM an extra buffer westward the present region"
-msgstr "Für Horizont-Rasterkarten: Lese vom DGM einen extra Bufferbereich westlich der aktuellen Region ein."
+msgstr "Für Horizont-Rasterkarten: Lese vom DGM einen extra Pufferbereich westlich der aktuellen Region ein."
#: ../raster/r.horizon/main.c:275
msgid "For horizon rasters, read from the DEM an extra buffer northward the present region"
-msgstr "Für Horizont-Rasterkarten: Lese vom DGM einen extra Bufferbereich nördlich der aktuellen Region ein."
+msgstr "Für Horizont-Rasterkarten: Lese vom DGM einen extra Pufferbereich nördlich der aktuellen Region ein."
#: ../raster/r.horizon/main.c:283
msgid "For horizon rasters, read from the DEM an extra buffer southward the present region"
-msgstr "Für Horizont-Rasterkarten: Lese vom DGM einen extra Bufferbereichsüdlich der aktuellen Region ein."
+msgstr "Für Horizont-Rasterkarten: Lese vom DGM einen extra Pufferbereichsüdlich der aktuellen Region ein."
#: ../raster/r.horizon/main.c:291
msgid "The maximum distance to consider when finding the horizon height"
@@ -9534,7 +9522,7 @@
#: ../raster/r.horizon/main.c:389
msgid "Could not read bufferzone size. Aborting."
-msgstr "Konnte die Bufferzonengröße nicht lesen. Breche ab."
+msgstr "Konnte die Pufferzonengröße nicht lesen. Breche ab."
#: ../raster/r.horizon/main.c:394 ../raster/r.horizon/main.c:400
#: ../raster/r.horizon/main.c:407 ../raster/r.horizon/main.c:414
@@ -11459,7 +11447,7 @@
#: ../raster/r.surf.fractal/process.c:53
msgid "Unable to allocate data buffer. Check current region with g.region."
-msgstr "Kann keinen Speicher für Datenbuffer reservieren. Überprüfen Sie die aktuelle Region mit g.region."
+msgstr "Kann keinen Speicher für Datenpuffer reservieren. Überprüfen Sie die aktuelle Region mit g.region."
#: ../raster/r.surf.fractal/spec_syn.c:61
msgid "Preliminary surface calculations..."
@@ -11536,9 +11524,8 @@
msgstr "Reklassifiziere Rasterkarte auf Basis des Kategoriewerte."
#: ../raster/r.reclass/main.c:52
-#, fuzzy
msgid "Creates a new raster map whose category values are based upon a reclassification of the categories in an existing raster map."
-msgstr "Erzeugt eine neue Karte, deren Kategoriewerte auf einer Reklassifikation der Kategorien einer existierenden Rasterkarte basieren."
+msgstr "Erzeugt eine neue Rasterkarte, deren Kategoriewerte auf einer Reklassifikation der Kategorien einer existierenden Rasterkarte basieren."
#: ../raster/r.reclass/main.c:57
msgid "Raster map to be reclassified"
@@ -13577,9 +13564,9 @@
#: ../db/base/columns.c:44 ../db/base/copy.c:100 ../db/base/select.c:53
#: ../db/base/describe.c:51
-#, fuzzy, c-format
+#, c-format
msgid "Table <%s> not found in database <%s> using driver <%s>"
-msgstr "Kann Datenbank <%s> nicht mit dem Treiber <%s> öffnen."
+msgstr "Tabelle <%s> in der Datenbank <%s> mit dem Treiber <%s> nicht gefunden."
#: ../db/base/columns.c:99
msgid "List all columns for a given table."
@@ -14048,7 +14035,7 @@
#: ../misc/m.cogo/main.c:248
msgid "Repeat the starting coordinate at the end to close a loop"
-msgstr ""
+msgstr "Anfangs-Koordinaten am Ende wiederholen, um den Ring zu schließen."
#: ../misc/m.cogo/main.c:263
msgid "Starting coordinate pair"
@@ -14660,27 +14647,27 @@
#: ../locale/scriptstrings/d.mvmon_to_translate.c:1
msgid "Moves displayed maps to another monitor"
-msgstr "Verschiebt angezeigte Karten in ein anderes Grafikfenster."
+msgstr "Verschiebt angezeigte Karten in ein anderes Grafikfenster"
#: ../locale/scriptstrings/d.mvmon_to_translate.c:3
msgid "clear target monitor before moving"
-msgstr "Lösche das Ziel-Fenster vor dem Verschieben."
+msgstr "Lösche das Ziel-Fenster vor dem Verschieben"
#: ../locale/scriptstrings/d.mvmon_to_translate.c:4
msgid "stay with source monitor"
-msgstr "Bleib im Quell -Grafikfenster."
+msgstr "Bleib im Quell-Grafikfenster"
#: ../locale/scriptstrings/d.mvmon_to_translate.c:5
msgid "kill source monitor after moving"
-msgstr "Beende das Quell-Fenster nach dem Verschieben."
+msgstr "Beende das Quell-Fenster nach dem Verschieben"
#: ../locale/scriptstrings/d.mvmon_to_translate.c:6
msgid "Target monitor"
-msgstr "Ziel Grafikfenster."
+msgstr "Ziel Grafikfenster"
#: ../locale/scriptstrings/d.mvmon_to_translate.c:7
msgid "Source monitor"
-msgstr "Quell Grafikfenster."
+msgstr "Quell Grafikfenster"
#: ../locale/scriptstrings/d.resize_to_translate.c:1
msgid "Resizes active display monitor"
@@ -14830,13 +14817,12 @@
msgstr "Pfad zur Regel-Datei."
#: ../locale/scriptstrings/v.colors_to_translate.c:15
-#, fuzzy
msgid "Dummy raster map name containing color rules for use with d.legend"
-msgstr "Rasterkarte, die Werte für die Pfeillänge enthält."
+msgstr "Name für Dummy-Rasterkarte mit Farbregeln für d.legend"
#: ../locale/scriptstrings/v.colors_to_translate.c:16
msgid "Use with the -s flag (using this option implies -s)"
-msgstr ""
+msgstr "Verwende mit Schalter -s (Verwendung dieser Funktion impliziert -s)"
#: ../locale/scriptstrings/v.colors_to_translate.c:18
msgid "Save placeholder raster map for use with d.legend"
@@ -14878,9 +14864,8 @@
msgstr "Layer aus dem die Attributtabelle gelöscht werden soll."
#: ../locale/scriptstrings/d.shadedmap_to_translate.c:1
-#, fuzzy
msgid "Drapes a color raster over a shaded relief map using d.his."
-msgstr "Drapiert eine Rasterkarte mit Farbwerten über Schummerungskarte unter Verwendung von d.his."
+msgstr "Drapiert eine Farb-Rasterkarte über eine Schummerungskarte mittels d.his."
#: ../locale/scriptstrings/d.shadedmap_to_translate.c:2
msgid "Name of shaded relief or aspect map"
@@ -15098,12 +15083,11 @@
#: ../locale/scriptstrings/i.spectral_to_translate.c:15
msgid "Select multiple points"
-msgstr "Selektiere mehrere Punkte."
+msgstr "Selektiere mehrere Punkte"
#: ../locale/scriptstrings/i.spectral_to_translate.c:16
-#, fuzzy
msgid "Show pick coordinates instead of numbering in the legend"
-msgstr "Beschrifte mit Koordinaten anstelle der Nummerierung."
+msgstr "Zeige gewählte Koordinaten anstelle der Nummerierung in der Legende"
#: ../locale/scriptstrings/d.redraw_to_translate.c:1
msgid "Redraws the current display frame in the GRASS monitor"
@@ -16122,21 +16106,19 @@
#: ../locale/scriptstrings/v.db.update_to_translate.c:6
msgid "Literal value to update the column with"
-msgstr ""
+msgstr "Wert mit dem die Spalte aktualisiert wird"
#: ../locale/scriptstrings/v.db.update_to_translate.c:7
-#, fuzzy
msgid "Varchar values must be in single quotes, e.g. 'grass'"
-msgstr "Wert mit dem die Spalte aktualisiert werden soll (varchar-Werte müssen in einfachen Anführungszeichen angegeben werden, z.B. 'grass')."
+msgstr "varchar-Werte müssen in einfachen Anführungszeichen angegeben werden, z.B. 'grass'."
#: ../locale/scriptstrings/v.db.update_to_translate.c:8
-#, fuzzy
msgid "Name of attribute column to query"
-msgstr "Name der Attributespalte verwendet mit der 'query'-Option."
+msgstr "Name der abzufragenden Attributspalte"
#: ../locale/scriptstrings/v.db.update_to_translate.c:9
msgid "Can be a combination of columns, e.g. col1+col2"
-msgstr ""
+msgstr "Kann eine Kombination von Spalten sein, z.B. col1+col2"
#: ../locale/scriptstrings/v.db.update_to_translate.c:10
msgid "WHERE conditions for update, without 'where' keyword (e.g. cat=1 or col1/col2>1)"
@@ -16359,9 +16341,8 @@
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:6
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:8
-#, fuzzy
msgid "Area"
-msgstr "Fläche:\n"
+msgstr "Fläche"
#: ../locale/scriptstrings/r.reclass.area_to_translate.c:7
msgid "Greater value option that sets the >= area size limit [hectares]"
@@ -16576,14 +16557,12 @@
msgstr "LANDSAT TM Kanal 7."
#: ../locale/scriptstrings/d.correlate_to_translate.c:1
-#, fuzzy
msgid "Prints a graph of the correlation between raster maps (in pairs)."
-msgstr "Gibt eine Graphik der Korrelation zweier Karten (paarweise) aus."
+msgstr "Gibt eine Grafik der Korrelation zweier Rasterkarten (paarweise) aus."
#: ../locale/scriptstrings/d.correlate_to_translate.c:2
-#, fuzzy
msgid "display, correlation, scatterplot"
-msgstr "Darstellung, Raster"
+msgstr "Darstellung, Korrelation, Streudiagramm"
#: ../locale/scriptstrings/d.correlate_to_translate.c:3
#: ../locale/scriptstrings/d.correlate_to_translate.c:4
@@ -16594,7 +16573,7 @@
#: ../locale/scriptstrings/d.correlate_to_translate.c:7
msgid "Draw a trend line and calculate linear regression formula"
-msgstr ""
+msgstr "Zeichne Ausgleichsgerade und berechne lineare Regression"
#: ../locale/scriptstrings/g.extension_to_translate.c:1
msgid "Tool to maintain GRASS extensions in local GRASS installation."
@@ -18950,13 +18929,12 @@
msgstr "Zeichne nur eine Maßstabsleiste."
#: ../display/d.barscale/main.c:96
-#, fuzzy
msgid "Screen coordinates of the rectangle's top-left corner"
-msgstr "Die Bildschirmkoordinaten für die linke obere Ecke des Labels ([0,0] ist oben links)."
+msgstr "Bildschirmkoordinaten der linken oberen Ecke des Rechtecks"
#: ../display/d.barscale/main.c:97
msgid "(0,0) is top-left of the display frame"
-msgstr ""
+msgstr "(0,0) ist links oben im Fenster"
#: ../display/d.barscale/main.c:105
msgid "Font size"
@@ -20785,14 +20763,12 @@
msgstr "Ungültige Löschanfrage."
#: ../ps/ps.map/r_instructions.c:139 ../ps/ps.map/r_instructions.c:335
-#, fuzzy
msgid "no raster map selected yet"
-msgstr "Keine Rasterkarte angegeben."
+msgstr "Keine Rasterkarte ausgewählt"
#: ../ps/ps.map/r_instructions.c:155
-#, fuzzy
msgid "illegal value list"
-msgstr "%s: ungültiger Wert."
+msgstr "Liste ungültiger Werte"
#: ../ps/ps.map/r_instructions.c:191
#, fuzzy
@@ -20907,9 +20883,8 @@
msgstr "Ungültige Farb-Anfrage (Farbtabelle)."
#: ../ps/ps.map/r_colortable.c:157
-#, fuzzy
msgid "illegal colortable sub-request"
-msgstr "Ungültige colortabe sub-request"
+msgstr "Ungültiger colortable sub-request"
#: ../ps/ps.map/r_colortable.c:168
msgid "No raster selected for colortable!"
@@ -22388,7 +22363,7 @@
#: ../imagery/i.class/signature.c:278
msgid "Unable to allocate the cell buffer in display_signature()."
-msgstr "Kann keinen Speicher für Zellbuffer in display_signature() reservieren."
+msgstr "Kann keinen Speicher für Zellpuffer in display_signature() reservieren."
#: ../imagery/i.class/signature.c:310
msgid "Did not find input cell map MASK."
@@ -22609,7 +22584,7 @@
#: ../imagery/i.his.rgb/openfiles.c:27 ../imagery/i.rgb.his/openfiles.c:37
#: ../imagery/i.rgb.his/openfiles.c:39 ../imagery/i.rgb.his/openfiles.c:41
msgid "Unable to allocate the input row buffer"
-msgstr "Kann keinen Speicher für Eingabe-Zeilenbuffer reservieren."
+msgstr "Kann keinen Speicher für Eingabe-Zeilenpuffer reservieren."
#: ../imagery/i.smap/bouman/interp.c:38
msgid "pyramid constructed."
@@ -22844,7 +22819,6 @@
msgstr "Bildverarbeitung, Kartenverwaltung"
#: ../imagery/i.group/main.c:54
-#, fuzzy
msgid "Creates, edits, and lists groups and subgroups of imagery data."
msgstr "Erzeugt, editiert und listet Gruppen und Untergruppen von Bilddateien."
@@ -23255,9 +23229,8 @@
msgstr "Berechnet top-of-atmosphere Strahlung oder Reflexion und Temperatur für Landsat MSS/TM/ETM+/OLI."
#: ../imagery/i.landsat.toar/main.c:69
-#, fuzzy
msgid "imagery, Landsat, radiance, reflectance, brightness temperature, atmospheric correction"
-msgstr "Bildbearbeitung, Landsat, top-of-atmosphere Strahlung, dos-type einfache atmosphärische Korrektion"
+msgstr "Bildbearbeitung, Landsat, Strahlung, Reflexion, Helligkeitstemperatur, atmosphärische Korrektion"
#: ../imagery/i.landsat.toar/main.c:81
msgid "Prefix for output raster maps"
@@ -23276,14 +23249,12 @@
msgstr "Raumfahrzeug Sensor"
#: ../imagery/i.landsat.toar/main.c:98
-#, fuzzy
msgid "Required only if 'metfile' not given (recommended for sanity)"
msgstr "Nur notwendig, wenn 'metfile' nicht angegeben (vernünftigerweise)"
#: ../imagery/i.landsat.toar/main.c:101
-#, fuzzy
msgid "mss1;Landsat_1 MSS;mss2;Landsat_2 MSS;mss3;Landsat_3 MSS;mss4;Landsat_4 MSS;mss5;Landsat_5 MSS;tm4;Landsat_4 TM;tm5;Landsat_5 TM;tm7;Landsat_7 ETM+;oli8;Landsat_8 OLI/TIRS"
-msgstr "mss1;Landsat_1 MSS;mss2;Landsat_2 MSS;mss3;Landsat_3 MSS;mss4;Landsat_4 MSS;mss5;Landsat_5 MSS;tm4;Landsat_4 TM;tm5;Landsat_5 TM;tm7;Landsat_7 ETM+;ot8;Landsat_8 OLI/TIRS"
+msgstr "mss1;Landsat_1 MSS;mss2;Landsat_2 MSS;mss3;Landsat_3 MSS;mss4;Landsat_4 MSS;mss5;Landsat_5 MSS;tm4;Landsat_4 TM;tm5;Landsat_5 TM;tm7;Landsat_7 ETM+;oli8;Landsat_8 OLI/TIRS"
#: ../imagery/i.landsat.toar/main.c:118 ../imagery/i.landsat.toar/main.c:119
msgid "Atmospheric correction method"
@@ -23331,7 +23302,6 @@
msgstr "Nur notwendig, wenn 'method' ist DOS3"
#: ../imagery/i.landsat.toar/main.c:189
-#, fuzzy
msgid "Output at-sensor radiance instead of reflectance for all bands"
msgstr "Ausgabe der Strahlung am Sensor anstatt der Reflexion für alle Kanäle"
@@ -23341,7 +23311,7 @@
#: ../imagery/i.landsat.toar/main.c:198
msgid "Print output metadata info"
-msgstr ""
+msgstr "Gebe Ausgabe Metadaten aus"
#: ../imagery/i.landsat.toar/main.c:221 ../imagery/i.landsat.toar/main.c:229
#, c-format
@@ -23358,9 +23328,8 @@
msgstr "Vermisse '%s' und/oder '%s' für diesen Satelliten"
#: ../imagery/i.landsat.toar/main.c:280
-#, fuzzy
msgid "Landsat-7 requires band gain with 9 (H/L) characters"
-msgstr "Landsat-7 benötigt Kanal gain mit 9 (H/L) Daten"
+msgstr "Landsat-7 benötigt Kanal gain mit 9 (H/L) Zeichen"
#: ../imagery/i.landsat.toar/main.c:300
#, c-format
@@ -23368,9 +23337,9 @@
msgstr "Unbekannter Satellitentyp (definiert von '%s')"
#: ../imagery/i.landsat.toar/main.c:354 ../imagery/i.landsat.toar/main.c:500
-#, fuzzy, c-format
+#, c-format
msgid "Unable to read data type of raster map <%s>"
-msgstr "Kann den Wertebereich der Rasterkarte <%s> nicht lesen."
+msgstr "Kann den Datentyp der Rasterkarte <%s> nicht lesen."
#: ../imagery/i.landsat.toar/main.c:479
msgid "Calculating..."
@@ -23441,7 +23410,7 @@
#: ../imagery/i.cca/transform.c:24
msgid "Unable to allocate cell buffers."
-msgstr "Kann keinen Speicher für Zellbuffer reservieren."
+msgstr "Kann keinen Speicher für Zellpuffer reservieren."
#: ../imagery/i.cca/transform.c:30
msgid "Error reading cell map during transform."
@@ -24759,7 +24728,7 @@
#: ../vector/v.transform/main.c:92
msgid "Swap coordinates x, y and then apply other parameters"
-msgstr ""
+msgstr "Tausche die Koordinaten x,y und wende weitere Parameter an"
#: ../vector/v.transform/main.c:98
msgid "Print the transformation matrix to stdout"
@@ -26211,9 +26180,9 @@
msgstr "Keine Flächen gefunden, überspringe %."
#: ../vector/v.out.svg/main.c:262
-#, fuzzy, c-format
+#, c-format
msgid "%d areas extracted"
-msgstr "Typen die extrahiert werden."
+msgstr "%d Flächen extrahiert"
#: ../vector/v.out.svg/main.c:269
#, c-format
@@ -26221,9 +26190,9 @@
msgstr "Keine Punkte gefunden, überspringe %s."
#: ../vector/v.out.svg/main.c:295
-#, fuzzy, c-format
+#, c-format
msgid "%d points extracted"
-msgstr "%d Punkte geladen."
+msgstr "%d Punkte extrahiert"
#: ../vector/v.out.svg/main.c:302
#, c-format
@@ -26231,9 +26200,9 @@
msgstr "Keine Linien gefunden, überspringe %s."
#: ../vector/v.out.svg/main.c:326
-#, fuzzy, c-format
+#, c-format
msgid "%d lines extracted"
-msgstr "%d Linien zusammengefasst"
+msgstr "%d Linien extrahiert"
#: ../vector/v.out.svg/main.c:393
#, c-format
@@ -26839,15 +26808,15 @@
#: ../vector/v.buffer2/main.c:150
msgid "vector, buffer"
-msgstr "Vektor, Buffer"
+msgstr "Vektor, Puffer"
#: ../vector/v.buffer2/main.c:152 ../vector/v.buffer/main.c:153
msgid "Creates a buffer around features of given type (areas must contain centroid)."
-msgstr "Erzeugt einen Buffer um die Objekte mit gegebenen Typ (Flächen müssen Zentroide enthalten)."
+msgstr "Erzeugt einen Puffer um die Objekte mit gegebenen Typ (Flächen müssen Zentroide enthalten)."
#: ../vector/v.buffer2/main.c:170
msgid "Buffer distance along major axis in map units"
-msgstr "Bufferdistanz entlang der Hauptachse in Karteneinheiten."
+msgstr "Pufferdistanz entlang der Hauptachse in Karteneinheiten."
#: ../vector/v.buffer2/main.c:171 ../vector/v.buffer2/main.c:179
#: ../vector/v.buffer2/main.c:187 ../vector/v.buffer2/main.c:193
@@ -26857,7 +26826,7 @@
#: ../vector/v.buffer2/main.c:178
msgid "Buffer distance along minor axis in map units"
-msgstr "Bufferdistanz entlang der Nebenachse in Karteneinheiten."
+msgstr "Pufferdistanz entlang der Nebenachse in Karteneinheiten."
#: ../vector/v.buffer2/main.c:186 ../vector/v.parallel2/main.c:74
msgid "Angle of major axis in degrees"
@@ -26865,7 +26834,7 @@
#: ../vector/v.buffer2/main.c:192
msgid "Name of column to use for buffer distances"
-msgstr "Name der Spalte mit den Bufferdistanzen"
+msgstr "Name der Spalte mit den Pufferdistanzen"
#: ../vector/v.buffer2/main.c:200 ../vector/v.buffer/main.c:190
msgid "Scaling factor for attribute column values"
@@ -26874,7 +26843,7 @@
#: ../vector/v.buffer2/main.c:209 ../vector/v.buffer/main.c:200
#: ../vector/v.parallel/main.c:64
msgid "Maximum distance between theoretical arc and polygon segments as multiple of buffer"
-msgstr "Maximale Distanz zwischen theoretischen Linien und Polygonsegmenten als Vielfaches des Buffers"
+msgstr "Maximale Distanz zwischen theoretischen Linien und Polygonsegmenten als Vielfaches des Puffers"
#: ../vector/v.buffer2/main.c:225
msgid "This is an alias to the distance option. It is retained for backwards compatibility"
@@ -26882,7 +26851,7 @@
#: ../vector/v.buffer2/main.c:227 ../vector/v.buffer/main.c:175
msgid "Buffer distance in map units"
-msgstr "Bufferdistanz in Karteneinheiten"
+msgstr "Pufferdistanz in Karteneinheiten"
#: ../vector/v.buffer2/main.c:232
msgid "Make outside corners straight"
@@ -26894,7 +26863,7 @@
#: ../vector/v.buffer2/main.c:247
msgid "Select a buffer distance/minordistance/angle or column, but not both."
-msgstr "Wählen Sie entweder die Buffer distance/minordistance/angle oder eine Spalte, aber nicht beides"
+msgstr "Wählen Sie entweder die Puffer distance/minordistance/angle oder eine Spalte, aber nicht beides"
#: ../vector/v.buffer2/main.c:251
msgid "The bufcol option may contain bugs during the cleaning step. If you encounter problems, use the debug option or clean manually with v.clean tool=break; v.category step=0; v.extract -d type=area"
@@ -26906,11 +26875,11 @@
#: ../vector/v.buffer2/main.c:265
msgid "The buffer option has been replaced by the distance option and will be removed in future."
-msgstr "Die Buffer-Option wurde durch die Distanz-Option ersetzt und wird in Zukunft entfernt."
+msgstr "Die Puffer-Option wurde durch die Distanz-Option ersetzt und wird in Zukunft entfernt."
#: ../vector/v.buffer2/main.c:268
msgid "Use the distance option instead of the buffer option."
-msgstr "Verwende die Distanz-Option anstelle der Buffer-Option."
+msgstr "Verwende die Distanz-Option anstelle der Puffer-Option."
#: ../vector/v.buffer2/main.c:272
msgid "The tolerance must be > 0."
@@ -26933,7 +26902,7 @@
#: ../vector/v.buffer2/main.c:380 ../vector/v.buffer/main.c:292
msgid "No features available for buffering. Check type option and features available in the input vector."
-msgstr "Keine Objekte zum Buffern vorhanden. Überprüfen Sie die Option type und die Objekte in der Eingabe-Vektorkarte."
+msgstr "Keine Objekte zum Puffern vorhanden. Überprüfen Sie die Option type und die Objekte in der Eingabe-Vektorkarte."
#: ../vector/v.buffer2/main.c:394
msgid "Buffering lines..."
@@ -26954,7 +26923,7 @@
#: ../vector/v.buffer2/main.c:468
msgid "Buffering areas..."
-msgstr "Buffere Flächen..."
+msgstr "Puffere Flächen..."
#: ../vector/v.buffer2/main.c:523
msgid "Writing buffers..."
@@ -27403,9 +27372,9 @@
msgstr "Numerische Spalte mit Werten, um den Vorrang bei überlappenden Beschriftungen zu kären. Die Beschriftung mit dem geringeren Gewicht wird verdeckt."
#: ../vector/v.label.sa/labels.c:74
-#, fuzzy, c-format
+#, c-format
msgid "Cannot allocate %lu bytes of memory"
-msgstr "Kann nicht %d Byte Speicher reservieren."
+msgstr "Kann nicht %lu Byte Speicher reservieren."
#: ../vector/v.label.sa/labels.c:96
#, c-format
@@ -27466,7 +27435,6 @@
msgstr "Säuberungswerkzeug"
#: ../vector/v.clean/main.c:66
-#, fuzzy
msgid "break;break lines at each intersection;rmdupl;remove duplicate geometry features (pay attention to categories!);rmdangle;remove dangles, threshold ignored if < 0;chdangle;change the type of boundary dangle to line, threshold ignored if < 0, input line type is ignored;rmbridge;remove bridges connecting area and island or 2 islands;chbridge;change the type of bridges connecting area and island or 2 islands from boundary to line;snap;snap lines to vertex in threshold;rmdac;remove duplicate area centroids ('type' option ignored);bpol;break (topologically clean) polygons (imported from non topological format, like ShapeFile). Boundaries are broken on each point shared between 2 and more polygons where angles of segments are different;prune;remove vertices in threshold from lines and boundaries, boundary is pruned only if topology is not damaged (new intersection, changed attachment of centroid), first and last segment of the boundary is never changed;rmarea;remove small ar
eas, the longest boundary with adjacent area is removed;rmline;remove all lines or boundaries of zero length, threshold is ignored;rmsa;remove small angles between lines at nodes"
msgstr "break;Teilt Linien an jeder Überschneidung;rmdupl;Entfernt doppelte Geometrie-Feature (Achten Sie auf die Kategorien!);rmdangle;Entfernt Überstände (dangles), Schwellwert wird ignoriert, wenn <0;chdangle;Ändert den Typ eines Überstands (dangle) zu einer Linie, Schwellwert wird ignoriert, wenn <0, Eingabe-Linien-Typ wird ignoriert;rmbridge;Entfernt Brücken, die eine Fläche und eine Insel oder 2 Inseln verbindet;chbridge;Ändert den Typ einer Brücke, die eine Fläche und eine Insel oder 2 Inseln verbindet von Grenze zu Linie;snap;Richtet Linien an Vertices innerhalb des Schwellwertes aus;rmdac;Entfernt doppelte Zentroide (Option 'type' wird ignoriert);bpol;Teilt (topologisch sauber) Polygone (importiert aus nicht topologischen Formaten, wie z.B. ShapeFile). Grenzen werden an jedem Punkt geteilt, der 2 oder mehr Polygonen gemeinsam ist und die Winkel der Segmente verschieden sind.;prune;Entfernt Vertices innerhalb des Schwellwertes von Linien und Grenzen. Grenze
n werden nur gesäubert, wenn die Topologie nicht beschädigt wird (neue Überschneidungen, veränderte Zuordnung von Zentroiden), das erste und letzte Segment einer Grenze wird nie geändert;rmarea;Entfernt kleine Flächen, die längste Grenze mit einer benachbarten Fläche wird entfernt;rmline;Entfernt alle Linien und Grenzen mit der Länge null, Schwellwert wird ignoriert;rmsa;Entfernt spitze Winkel zwischen Linien an einem Knoten"
@@ -27715,7 +27683,7 @@
#: ../vector/v.voronoi/sw_main.c:140
#, c-format
msgid "Found %d points/centroids in <%s>, but at least 2 are needed"
-msgstr ""
+msgstr "%d Punkte/Zentroide in <%s> gefunden, aber mindestens 2 werden benötigt"
#: ../vector/v.voronoi/dt_main.c:149
msgid "Cannot calculate area centroid z coordinate"
@@ -28144,7 +28112,7 @@
#: ../vector/v.buffer/main.c:182
msgid "Attribute column to use for buffer distances"
-msgstr "Attributspalte mit den Bufferdistanzen."
+msgstr "Attributspalte mit den Pufferdistanzen."
#: ../vector/v.buffer/main.c:209
msgid "Stop the process at a certain stage"
@@ -28577,14 +28545,12 @@
msgstr "Trenne Linien in kleinere Abschnitte."
#: ../vector/v.split/main.c:54
-#, fuzzy
msgid "Maximum segment length"
-msgstr "Maximale Länge der Inputzeile: %d"
+msgstr "Maximale Segmentlänge"
#: ../vector/v.split/main.c:61
-#, fuzzy
msgid "Maximum number of vertices in segment"
-msgstr "Maximale Anzahl der Punkte auf einem Segment"
+msgstr "Maximale Anzahl der Vertices auf einem Segment"
#: ../vector/v.distance/main.c:116
msgid "Finds the nearest element in vector map 'to' for elements in vector map 'from'."
@@ -28647,9 +28613,8 @@
msgstr "Spaltenname der nächstgelegenen Objekte (verwendet mit upload=to_attr)."
#: ../vector/v.distance/main.c:214
-#, fuzzy
msgid "Name of table created when the 'distance to all' flag is used"
-msgstr "Name der auszugebenden Tabelle, erzeugt wenn der Schalter 'Distanz zu Allen' gesetzt wurde."
+msgstr "Name der Tabelle, erzeugt wenn der Schalter 'Distanz zu Allen' gesetzt wurde."
#: ../vector/v.distance/main.c:219
msgid "Print output to stdout, don't update attribute table"
@@ -29270,7 +29235,7 @@
#: ../vector/v.parallel2/main.c:103
msgid "Create buffer-like parallel lines"
-msgstr "Erzeuge Bufferähnliche parallele Linien."
+msgstr "Erzeuge Pufferähnliche parallele Linien."
#: ../vector/v.net.flow/main.c:58
msgid "vector, network, flow"
@@ -31625,7 +31590,7 @@
#: ../vector/v.to.rast/support.c:514
msgid "Cannot allocate memory for row buffer"
-msgstr "Kann keinen Speicher für Zeilenbuffer reservieren."
+msgstr "Kann keinen Speicher für Zeilenpuffer reservieren."
#: ../vector/v.to.rast/support.c:584
#, c-format
@@ -32925,6 +32890,9 @@
msgid "Data range is %.15g to %.15g\n"
msgstr "Wertebereich ist %.15g bis %.15g\n"
+msgid "Output map: slope steepness (S) factor for USLE"
+msgstr "Ausgabekarte der Hangneigungsfaktoren (S) für USLE."
#~ msgid "The configuration file can be used only with \t\t\t%s rasterfile"
#~ msgstr "Die Konfigurationsdatei kann nur verwendet werden mit \t\t\t%s Rasterkarte."
@@ -32932,10 +32900,10 @@
#~ msgstr "Ungültige Konfigurationsdatei (Stichprobenfläche)."
#~ msgid "Group input"
-#~ msgstr "Eingabe-Gruppe "
+#~ msgstr "Eingabe-Gruppe"
#~ msgid "Use image list and not group"
-#~ msgstr "Verwende eine Bild-Liste und keine Gruppe."
+#~ msgstr "Verwende eine Bild-Liste und keine Gruppe"
#~ msgid "Subgroup <%s> not found"
#~ msgstr "Untergruppe <%s> nicht gefunden."
@@ -33025,7 +32993,7 @@
#~ msgstr "Transformiere <%s>..."
#~ msgid "Unable allocate memory for row buffer"
-#~ msgstr "Kann keinen Speicher für Zeilenbuffer reservieren."
+#~ msgstr "Kann keinen Speicher für Zeilenpuffer reservieren."
#~ msgid "Current window size:"
#~ msgstr "Aktuelle Fenstergröße:"
@@ -33076,7 +33044,7 @@
#~ msgstr "Berechne Zeile %d (von %d) der Kovarianz-Matrix..."
#~ msgid "Unable to allocate memory for row buffer"
#~ msgid "Threshold to calculate for method=threshold"
#~ msgstr "Schwellenwert für method=threshold"
@@ -33640,19 +33608,19 @@
#~ msgstr "Lese Karte..."
#~ msgid "Input map: elevation on which entire analysis is based"
-#~ msgstr "Eingabekarte mit Höheninformationen, welche die Grundlage der gesamten Analyse ist."
+#~ msgstr "Eingabekarte: Höheninformationen für die Analyse"
#~ msgid "Input map: locations of real depressions"
-#~ msgstr "Eingabekarte mit Orten realer Senken im Gebiet."
+#~ msgstr "Eingabekarte: Orte realer Senken"
#~ msgid "Input map or value: percent of disturbed land, for USLE"
-#~ msgstr "Eingabekarte oder Wert: Prozent von gestörtem Land, (für ABAG/USLE)."
+#~ msgstr "Eingabekarte oder Wert: Prozent von gestörtem Land, für USLE"
#~ msgid "Output map: drainage direction"
-#~ msgstr "Ausgabekarte mit Abflussrichtung."
+#~ msgstr "Ausgabekarte: Abflussrichtung"
#~ msgid "Output map: stream segments"
-#~ msgstr "Ausgabekarte der Flußsegmente. "
+#~ msgstr "Ausgabekarte: Flusssegmente"
#~ msgid "Watershed basin creation program."
#~ msgstr "Modul zur Berechnung von Wassereinzugsgebieten."
@@ -33716,13 +33684,13 @@
#~ msgstr "Gib mehr Kommentare aus (Standard=schweigsam)."
#~ msgid "Could not read east bufferzone size. Aborting."
-#~ msgstr "Konnte die Ost-Bufferzonengröße nicht lesen. Breche ab."
+#~ msgstr "Konnte die Ost-Pufferzonengröße nicht lesen. Breche ab."
#~ msgid "Could not read west bufferzone size. Aborting."
-#~ msgstr "Konnte die West-Bufferzonengröße nicht lesen. Breche ab."
+#~ msgstr "Konnte die West-Pufferzonengröße nicht lesen. Breche ab."
#~ msgid "Could not read north bufferzone size. Aborting."
-#~ msgstr "Konnte die Nord-Bufferzonengröße nicht lesen. Breche ab."
+#~ msgstr "Konnte die Nord-Pufferzonengröße nicht lesen. Breche ab."
#~ msgid "Name of the longitude input raster map [decimal degrees]"
#~ msgstr "Eingabe-Rasterkarte mit Längengraden [in Dezimal-Grad]."
@@ -33748,10 +33716,10 @@
#~ msgstr "Berechnung der unbeschränkten Grundwasserfluss Schleife %i\n"
#~ msgid "Input value: maximum length of surface flow, for USLE"
-#~ msgstr "Eingabewert: maximale Länge des Oberflächenabflusses für USLE."
+#~ msgstr "Eingabewert: Maximale Länge des Oberflächenabflusses für USLE"
#~ msgid "Output map: useful for visual display of results"
-#~ msgstr "Ausgabekarte: hilfreich für die visuelle Darstellung der Ergebnisse."
+#~ msgstr "Ausgabekarte: Hilfreich für visuelle Darstellung der Ergebnisse"
#~ msgid "unable to open new L map layer."
#~ msgstr "Kann neue L-Karte nicht öffnen."
@@ -33851,13 +33819,13 @@
#~ msgstr "Schwellwert der Wassertiefe [m] (Diffusion steigt, nachdem diese Wassertiefe erreicht wurde)."
#~ msgid "Input map: amount of overland flow per cell"
-#~ msgstr "Eingabekarte mit der Größe des Oberflächenabfluss pro Zelle."
+#~ msgstr "Eingabekarte: Größe des Oberflächenabfluss pro Zelle"
#~ msgid "Input map: terrain blocking overland surface flow, for USLE"
-#~ msgstr "Eingabekarte mit Gelände, dass den Oberflächenabfluss blockiert, für USLE."
+#~ msgstr "Eingabekarte: Gelände, dass den Oberflächenabfluss blockiert, für USLE"
#~ msgid "Output map: number of cells that drain through each cell"
-#~ msgstr "Ausgabekarte mit Anzahl der Zellen, die durch jede Zelle abfließt."
+#~ msgstr "Ausgabekarte: Anzahl der Zellen, die durch jede Zelle abfließt"
#~ msgid "Output map: unique label for each watershed basin"
#~ msgstr "Ausgabekarte mit eindeutiger Kennzeichnung jedes Einzugsgebietes."
@@ -33866,13 +33834,10 @@
#~ msgstr "Ausgabekarte mit Einzugsgebietshälften mit eindeutigen Wert."
#~ msgid "Output map: slope length and steepness (LS) factor for USLE"
-#~ msgstr "Ausgabekarte der Hanglängen und -Neigungsfaktoren (LS) für USLE."
+#~ msgstr "Ausgabekarte: Hanglängen und -Neigungsfaktoren (LS) für USLE."
-#~ msgid "Output map: slope steepness (S) factor for USLE"
-#~ msgstr "Ausgabekarte der Hangneigungsfaktoren (S) für USLE."
#~ msgid "Input value: minimum size of exterior watershed basin"
-#~ msgstr "Eingabewert: kleinste Größe des äußeren Wassereinzugsgebiets."
+#~ msgstr "Eingabewert: Minimale Größe des äußeren Wassereinzugsgebiets"
#~ msgid "Output elevation raster map after filling"
#~ msgstr "Ausgabehöhenkarte nach dem Füllen"
@@ -33946,7 +33911,7 @@
#~ " Versuche:\n"
#~ msgid "Could not read south bufferzone size. Aborting."
-#~ msgstr "Konnte die Süd-Bufferzonengröße nicht lesen. Breche ab."
+#~ msgstr "Konnte die Süd-Pufferzonengröße nicht lesen. Breche ab."
#~ msgid "Slower but accurate (applies to FP maps only"
#~ msgstr "Langsamer aber genau (gilt nur für Fließkomma-Karten)"
@@ -33955,10 +33920,10 @@
#~ msgstr "Konvertiert eine GRASS Vektorkarte in ein OGR unterstütztes Vektorformat."
#~ msgid "Lines buffers... "
-#~ msgstr "Linien-Buffer... "
+#~ msgstr "Linien-Puffer... "
#~ msgid "Areas buffers... "
-#~ msgstr "Flächen-Buffer ..."
+#~ msgstr "Flächen-Puffer ..."
#~ msgid "List paper formats ( name width height left right top bottom(margin) )"
#~ msgstr "Gebe Liste der Papierformate aus (Name Breite Höhe links rechts oben unten(Rand) )."
@@ -34027,15 +33992,14 @@
#~ msgid "Use '-' to enter instructions from keyboard"
#~ msgstr "Verwenden Sie '-' für eine Eingabe über die Tastatur"
-#, fuzzy
#~ msgid "The password was stored in file (%s/.grasslogin64)"
-#~ msgstr "Das Passwort wurde in einer Datei gespeichert."
+#~ msgstr "Das Passwort wurde in der Datei (%s/.grasslogin64) gespeichert."
#~ msgid "Displays spectral response at user specified locations in group or images."
-#~ msgstr "Zeige die Farbempfindlichkeit an Benutzerdefinierten Stellen in der Gruppe oder in Bilderen."
+#~ msgstr "Zeige die Farbempfindlichkeit an benutzerdefinierten Stellen in Gruppe oder Bildern."
#~ msgid "Write output to PNG image"
-#~ msgstr "Schreibe die Ausgabe in ein PNG-Bild."
+#~ msgstr "Schreibe die Ausgabe in ein PNG-Bild"
#~ msgid "Category values to use for MASK (format: 1 2 3 thru 7 *)"
#~ msgstr "Kategoriewerte, die für die Maske verwendet werden (Format: 1 2 3 thru 7 *)."
@@ -34052,3 +34016,117 @@
#, fuzzy
#~ msgid "Subgroup <%s> not found in current mapset"
#~ msgstr "Rasterkarte <%s> im aktuellen Mapset nicht gefunden."
+#~ msgid "unable to open <%s> mask ... continuing without!"
+#~ msgstr "Kann Maske <%s> nicht öffnen ... mache ohne weiter !"
+#~ msgid "Calculates richness index on a raster map"
+#~ msgstr "Berechnet den Richness-Index einer Rasterkarte"
+#~ msgid "Row cache is too small"
+#~ msgstr "Zeilen-Cache ist zu klein"
+#~ msgid "Steps=%d"
+#~ msgstr "Schritte=%d"
+#~ msgid "Fractal dimension of [%.2lf] must be between 2 and 3."
+#~ msgstr "Fraktale Dimension von [%.2lf] muss zwischen 2 und 3 liegen."
+#~ msgid "Output map: basins raster map"
+#~ msgstr "Ausgabe-Rasterkarte: Einzugsgebiete"
+#~ msgid "Output map: half basins raster map"
+#~ msgstr "Ausgabe-Rasterkarte: Halbe Einzugsgebiete"
+#~ msgid "Output map: Slope steepness (S) factor for USLE"
+#~ msgstr "Ausgabekarte: Hangneigungsfaktoren (S) für USLE"
+#~ msgid "Invalid GEOS geometry!"
+#~ msgstr "Ungültige GEOS Geometrie!"
+#~ msgid "No coordinates in GEOS geometry (can be ok for negative distance)!"
+#~ msgstr "Keine Koordinaten in der GEIS Geometrie (kann bei negativer Distanz okay sein)!"
+#~ msgid "Invalid x coordinate %f"
+#~ msgstr "Ungültige X-Koordinate %f"
+#~ msgid "Invalid y coordinate %f"
+#~ msgstr "Ungültige Y-Koordinate %f"
+#~ msgid "Corrupt GEOS geometry"
+#~ msgstr "Kaputte GEOS Geometrie"
+#~ msgid "Unknown GEOS geometry type"
+#~ msgstr "Unbekannter GEOS Geometrie-Typ"
+#~ msgid "Buffering failed"
+#~ msgstr "Puffern fehlgeschlagen"
+#~ msgid "Layer number must be > 0 for category constraints"
+#~ msgstr "Layer Nummer muss > 0 sein für Kategorie-Bedingungen"
+#~ msgid "'%s' and '%s' parameters were supplied, cats will be ignored"
+#~ msgstr "'%s' und '%s' Parameter wurden angegeben, cats wird ignoriert"
+#~ msgid "Loading categories from table <%s>..."
+#~ msgstr "Lade Kategorien aus Tabelle <%s> ..."
+#~ msgid "%d categories loaded"
+#~ msgstr "%d Kategorien geladen"
+#~ msgid "No categories selected with '%s' option"
+#~ msgstr "Keine Kategorien mit der Option '%s' selektiert"
+#~ msgid "%d errors in '%s' option"
+#~ msgstr "%d Fehler in '%s' Option"
+#~ msgid "vector, buffer, geometry"
+#~ msgstr "Vektor, Puffer, Geometrie"
+#~ msgid "Creates a buffer around vector features of given type."
+#~ msgstr "Erzeugt einen Puffer um Objekte mit gegebenen Typ."
+#~ msgid "Transfer categories and attributes"
+#~ msgstr "Übertrage Kategorien und Attribute"
+#~ msgid "Note: In latitude-longitude coordinate system distances are in degree units"
+#~ msgstr "Beachte: In geographischen Koordinatensystem sind Distanzen in Grad"
+#~ msgid "Invalid layer number (%d). Parameter '%s' or '%s' specified, assuming layer '1'."
+#~ msgstr "Ungültige Layer-Nummer (%d). Parameter '%s' oder '%s' angegeben, vermute Layer '1'."
+#~ msgid "Illegal scale value"
+#~ msgstr "Ungültiger Maßstabswert"
+#~ msgid "Unable to create vector map"
+#~ msgstr "Kann die Vektorkarte nicht erzeugen"
+#~ msgid "Negative distances for internal buffers are not supported and converted to positive values."
+#~ msgstr "Negative Distanzen für interne Puffer sind nicht erlaubt und werden in positive Werte umgewandelt."
+#~ msgid "Buffering features..."
+#~ msgstr "Puffere Objekte..."
+#~ msgid "Negative distances are only supported for areas"
+#~ msgstr "Negative Distanzen sind nur für Flächen erlaubt"
+#~ msgid "Cleaning buffers..."
+#~ msgstr "Säubere Puffer..."
+#~ msgid "Removing dangles..."
+#~ msgstr "Entferne Überstände (dangles)..."
+#~ msgid "Removing bridges..."
+#~ msgstr "Entferne Brücken..."
+#~ msgid "Calculating centroids for all areas..."
+#~ msgstr "Berechne Zentroide für alle Flächen..."
+#~ msgid "Name of OGR data source not specified"
+#~ msgstr "Name der OGR-Quelle nicht angegeben"
+#~ msgid "List of supported formats:"
+#~ msgstr "Liste der unterstützten Dateiformate:"
+#~ msgid "No areas found, skipping %s"
+#~ msgstr "Keine Flächen gefunden, überspringe %s"
Modified: grass/branches/develbranch_6/locale/po/grassnviz_de.po
--- grass/branches/develbranch_6/locale/po/grassnviz_de.po 2014-08-11 10:14:22 UTC (rev 61583)
+++ grass/branches/develbranch_6/locale/po/grassnviz_de.po 2014-08-11 10:15:18 UTC (rev 61584)
@@ -1,22 +1,22 @@
# translation of grassnviz_de.po to deutsch
-# Copyright (C) 2011-2013 GRASS Development Team
+# Copyright (C) 2011-2014 GRASS Development Team
-# Robert Nuske <robert.nuske nw-fva.de>, 2011, 2012, 2013.
+# Robert Nuske <robert.nuske nw-fva.de>, 2011, 2012, 2013, 2014.
msgid ""
msgstr ""
"Project-Id-Version: grassnviz_de\n"
-"PO-Revision-Date: 2014-03-24 15:19+0100\n"
+"PO-Revision-Date: 2014-08-10 15:19+0200\n"
"Language: de\n"
#: ../visualization/nviz/scripts/nviz2.2_script:197
msgid "Show Panels"
@@ -135,7 +135,7 @@
#: ../visualization/nviz/scripts/nviz2.2_script:439
msgid "Script Tools"
-msgstr "Script Tools"
+msgstr "Skript Werkzeuge"
#: ../visualization/nviz/scripts/nviz2.2_script:484
msgid "PPM Image"
@@ -164,7 +164,7 @@
#: ../visualization/nviz/scripts/nviz2.2_script:809
msgid "Unconstrained"
-msgstr "Zwanglos"
+msgstr "Unbeschränkt"
#: ../visualization/nviz/scripts/nviz2.2_script:819
#: ../visualization/nviz/scripts/panel_animation.tcl:203
@@ -474,7 +474,7 @@
#: ../visualization/nviz/scripts/multimapBrowser.tcl:99
#: ../visualization/nviz/scripts/filemapBrowser.tcl:98
msgid "Remove"
-msgstr "Entferne"
+msgstr "Entfernen"
#: ../visualization/nviz/scripts/multimapBrowser.tcl:105
#: ../visualization/nviz/scripts/filemapBrowser.tcl:104
@@ -528,7 +528,7 @@
#: ../visualization/nviz/scripts/filemapBrowser.tcl:162
#: ../visualization/nviz/scripts/mapBrowser.tcl:220
msgid "Regions"
-msgstr "Region"
+msgstr "Regionen"
#: ../visualization/nviz/scripts/multimapBrowser.tcl:165
#: ../visualization/nviz/scripts/panel_main.tcl:158
@@ -593,7 +593,7 @@
#: ../visualization/nviz/scripts/flythrough.tcl:115
msgid "Interactively set view position"
-msgstr "Interaktives setzen der Blickposition"
+msgstr "Interaktives Setzen der Blickposition"
#: ../visualization/nviz/scripts/flythrough.tcl:136
msgid "flythrough help"
@@ -605,7 +605,7 @@
#: ../visualization/nviz/scripts/flythrough.tcl:197
msgid "turn"
-msgstr "Drehe"
+msgstr "drehe"
#: ../visualization/nviz/scripts/panel_main.tcl:86
msgid "Main"
@@ -689,7 +689,7 @@
#: ../visualization/nviz/scripts/panel_main.tcl:164
#: ../visualization/nviz/scripts/panel_fringe.tcl:43
msgid "Fringe"
-msgstr "Fringe"
+msgstr "Rand"
#: ../visualization/nviz/scripts/panel_main.tcl:175
msgid "View method:"
@@ -859,7 +859,7 @@
#: ../visualization/nviz/scripts/attPopup.tcl:516
msgid "Use slider to set value"
-msgstr "Benutze Slider, um Wert einzustellen"
+msgstr "Benutze Schieber, um Wert einzustellen"
#: ../visualization/nviz/scripts/panel_kanimator.tcl:79
msgid "Keyframe Animation"
@@ -1161,7 +1161,7 @@
#: ../visualization/nviz/scripts/panel_vol.tcl:443
msgid "Y-axis"
-msgstr "X-Achse"
+msgstr "Y-Achse"
#: ../visualization/nviz/scripts/panel_vol.tcl:445
msgid "Z-axis"
@@ -1420,7 +1420,7 @@
#: ../visualization/nviz/scripts/panel_legend.tcl:71
msgid "reverse legend"
-msgstr "Drehe Legende"
+msgstr "Legende umdrehen"
#: ../visualization/nviz/scripts/panel_legend.tcl:73
msgid "show values"
@@ -1440,7 +1440,7 @@
#: ../visualization/nviz/scripts/panel_legend.tcl:91
msgid "min "
-msgstr "min"
+msgstr "min "
#: ../visualization/nviz/scripts/panel_legend.tcl:94
msgid " max "
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_de.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_de.po 2014-08-11 10:14:22 UTC (rev 61583)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_de.po 2014-08-11 10:15:18 UTC (rev 61584)
@@ -1,26 +1,26 @@
# translation of grasswxpy_de.po to Deutsch
-# Copyright (C) 2008-2013 GRASS Development Team
+# Copyright (C) 2008-2014 GRASS Development Team
# Markus Neteler <neteler cealp it>, 2008.
# Georg Lösel <georg*de-schorsch.de>, 2008.
# Markus Neteler <neteler osgeo.org>, 2008, 2009, 2010.
# Robert Nuske <rnuske gwdg.de>, 2009, 2010.
msgid ""
msgstr ""
"Project-Id-Version: grasswxpy_de\n"
-"PO-Revision-Date: 2014-03-24 16:24+0100\n"
+"PO-Revision-Date: 2014-08-10 14:04+0200\n"
"Language: de\n"
#: ../gui/wxpython/gui_core/prompt.py:393
#, python-format
@@ -1484,14 +1484,14 @@
"Einzelheiten: %(error)s"
#: ../gui/wxpython/gui_core/goutput.py:676
-#, fuzzy, python-format
+#, python-format
msgid "Command output saved into '%s'"
-msgstr "Befehlsausgabe in '%s' gespeichert"
+msgstr "Befehlsausgabe gespeichert in '%s'"
#: ../gui/wxpython/gui_core/goutput.py:795
+#, python-format
msgid "Command log saved to '%s'"
+msgstr "Befehlslog gespeichert in '%s'"
#: ../gui/wxpython/gui_core/goutput.py:850
#, python-format
@@ -2483,9 +2483,8 @@
msgstr "Einlesen von Projektions- und Datumsinformationen aus georeferenzierter Datei"
#: ../gui/wxpython/location_wizard/wizard.py:227
-#, fuzzy
msgid "Read projection and datum terms from a Well Known Text (WKT) .prj file"
-msgstr "Einlesen von Projektions- und Datumsinformationen aus WKT oder PRJ Datei"
+msgstr "Lese Projektions- und Datumsinformationen aus Well Known Text (WKT) .prj-Datei"
#: ../gui/wxpython/location_wizard/wizard.py:230
msgid "Specify projection and datum terms using custom PROJ.4 parameters"
@@ -2952,9 +2951,8 @@
msgstr "Position ist angegeben:"
#: ../gui/wxpython/psmap/dialogs.py:221
-#, fuzzy
msgid "relative to paper"
-msgstr "in Bezug auf Papier"
+msgstr "bezogen auf Papier"
#: ../gui/wxpython/psmap/dialogs.py:222
msgid "by map coordinates"
@@ -3822,9 +3820,9 @@
msgstr "Ps.map beendet mit Rückgabewert %s"
#: ../gui/wxpython/psmap/frame.py:320
+#, python-format
msgid "%(prg)s exited with return code %(code)s"
-msgstr "ps2pdf beendet mit Rückgabewert %s"
+msgstr "%(prg)s beendet mit Rückgabewert %(code)s"
#: ../gui/wxpython/psmap/frame.py:323
msgid "PDF generated"
@@ -6013,7 +6011,7 @@
#: ../gui/wxpython/menustrings.py:306
msgid "Buffer rasters"
-msgstr "Rasterzellen buffern"
+msgstr "Rasterzellen puffern"
#: ../gui/wxpython/menustrings.py:307
@@ -7080,11 +7078,11 @@
#: ../gui/wxpython/menustrings.py:587
msgid "Buffer vectors"
-msgstr "Vektor buffern"
+msgstr "Vektor puffern"
#: ../gui/wxpython/menustrings.py:588
-msgstr "Erzeugt einen Buffer um Objekte bestimmten Typs (Flächen müssen Zentroide enthalten)."
+msgstr "Erzeugt einen Puffer um Objekte bestimmten Typs (Flächen müssen Zentroide enthalten)."
#: ../gui/wxpython/menustrings.py:589
msgid "Lidar analysis"
@@ -10116,7 +10114,7 @@
#: ../gui/wxpython/nviz/mapwindow.py:207
msgid "Opening 3D view was not successful. Please try to change the value of depth buffer in GUI Settings dialog > tab Map Display > Advanced and restart GUI."
-msgstr "Öffnen der 3D-Ansicht war nicht erfolgreich. Ändere den Wert des Tiefenbuffers in den GUI-Einstellungen > Map Display > Fortgeschritten und erneuter GUI-Start."
+msgstr "Öffnen der 3D-Ansicht war nicht erfolgreich. Ändere den Wert des Tiefenpuffers in den GUI-Einstellungen > Map Display > Fortgeschritten und erneuter GUI-Start."
#: ../gui/wxpython/nviz/mapwindow.py:544
#, python-format
@@ -14276,19 +14274,15 @@
#~ msgid "Attempt to import data source <%(name)s> as raster or vector failed. "
#~ msgstr "Der Versuch die Datei <%(name)s> als raster oder Vektor zu importieren ist fehlgeschlagen."
-#, fuzzy
#~ msgid "%(env)s: line skipped - unable to parse Reason: %(e)s\n"
-#~ msgstr ""
-#~ "%s: Zeilen übersprungen - kann '%s' nicht interpretieren\n"
-#~ "Grund: %s\n"
+#~ msgstr "%(env)s: Zeilen übersprungen - Grund für Interpretationsfehler: %(e)s\n"
-#, fuzzy
#~ msgid ""
#~ "Unable to open file <%(file)s> for writing.\n"
#~ "Reason: %(e)s"
#~ msgstr ""
-#~ "Kann die Datei <%s> nicht zum Schreiben öffnen.\n"
-#~ "Grund: %s"
+#~ "Kann die Datei <%(file)s> nicht zum Schreiben öffnen.\n"
+#~ "Grund: %(e)s"
#~ msgid ""
#~ "%(l)d files created:\n"
@@ -14297,9 +14291,20 @@
#~ "%(l)d Dateien erzeugt:\n"
#~ "%(p)s"
-#, fuzzy
#~ msgid "Invalid line in GISRC file (%(e)s):%(l)s\n"
-#~ msgstr "Fehlerhafte Zeile in GISRC Datei (%s):%s\n"
+#~ msgstr "Fehlerhafte Zeile in GISRC Datei (%(e)s):%(l)s\n"
#~ msgid "Do you want to import data source <%(name)s> to created location? Default region will be set to match imported map."
#~ msgstr "Möchten Sie die Location anhand der Datenquelle <%(name)s> erzeugen? Die Standardregion wird auf Grundlage der importierten Karte erstellt."
+#~ msgid "GRASS GIS %(version)s Map Display: %(name)s - Location: %(location)s"
+#~ msgstr "GRASS GIS %(version)s Kartenfenster: %(name)s - Location: %(location)s"
+#~ msgid "GRASS GIS %(version)s Map Display: %(id)d - Location: %(loc)s"
+#~ msgstr "GRASS GIS %(version)s Kartenfenster: %(id)d - Location: %(loc)s"
+#~ msgid "GRASS GIS %s Layer Manager"
+#~ msgstr "GRASS GIS %s Ebenen-Manager"
+#~ msgid "GRASS GIS %(version) Map Display: %(name)s - Location: %(loc)s"
+#~ msgstr "GRASS GIS %(version) Kartenfenster: %(name)s - Location: %(loc)s"
