[GRASS-SVN] r61672 - grass/trunk/raster/r.viewshed
svn_grass at osgeo.org
Sun Aug 17 14:52:45 PDT 2014
Author: neteler
Date: 2014-08-17 14:52:44 -0700 (Sun, 17 Aug 2014)
New Revision: 61672
grass/trunk/raster/r.viewshed/r.viewshed.html
r.viewshed manual: better explain view angle
Modified: grass/trunk/raster/r.viewshed/r.viewshed.html
--- grass/trunk/raster/r.viewshed/r.viewshed.html 2014-08-17 21:52:30 UTC (rev 61671)
+++ grass/trunk/raster/r.viewshed/r.viewshed.html 2014-08-17 21:52:44 UTC (rev 61672)
@@ -29,8 +29,9 @@
Otherwise, a value in [0, 180] representing the vertical angle with
regard to the viewpoint, in degrees, if the point is visible.
-0 degrees: directly above the observer,
-180 degrees: directly below the observer
+A value of 0 is directly below the specified viewing position,
+90 is due horizontal. The angle to the cell containing the viewing
+position is undefined and set to 180.
<p>
If the <b>-b</b> flag is set, the output is in boolean-mode, and each point
@@ -71,7 +72,7 @@
elevation.
<p>
-By default the target is assumed to have height 0 map units above the
+By default the target is assumed to have height of 0 map units above the
terrain. The user can change this using option
<b>tgt_elev</b> to determine if objects of a given height would be
visible. The value entered is in the same units as the elevation.
