[GRASS-SVN] r61674 - grass/branches/develbranch_6/vector/v.mkgrid
svn_grass at osgeo.org
Mon Aug 18 07:25:04 PDT 2014
Author: neteler
Date: 2014-08-18 07:25:03 -0700 (Mon, 18 Aug 2014)
New Revision: 61674
grass/branches/develbranch_6/vector/v.mkgrid/description.html
grass/branches/develbranch_6/vector/v.mkgrid/local_proto.h
grass/branches/develbranch_6/vector/v.mkgrid/main.c
grass/branches/develbranch_6/vector/v.mkgrid/write_grid.c
v.mkgrid: added support for line output through -l flag (trunk, r61519)
Modified: grass/branches/develbranch_6/vector/v.mkgrid/description.html
--- grass/branches/develbranch_6/vector/v.mkgrid/description.html 2014-08-17 22:38:06 UTC (rev 61673)
+++ grass/branches/develbranch_6/vector/v.mkgrid/description.html 2014-08-18 14:25:03 UTC (rev 61674)
@@ -15,8 +15,32 @@
<h2>EXAMPLES</h2>
-Make a 4x3 grid, cells 20km a side, with lower left corner at 2716500,6447000:
+1) Create a grid in a latitude-longitude location (WGS84):
<div class="code"><pre>
+# use g.region to easily calculate rows and column for 'grid':
+g.region n=90 s=-90 w=-180 e=180 res=10 -p
+projection: 3 (Latitude-Longitude)
+zone: 0
+datum: wgs84
+ellipsoid: wgs84
+north: 90N
+south: 90S
+west: 180W
+east: 180E
+nsres: 10
+ewres: 10
+rows: 18
+cols: 36
+cells: 648
+# create 10 degree size grid:
+v.mkgrid map=grid_10deg grid=18,36
+</pre></div>
+<p>
+2) Make a 4x3 grid, cells 20km a side, with lower left corner at 2716500,6447000:
+<div class="code"><pre>
v.mkgrid map=coro_grid grid=4,3 position=coor coor=2716500,6447000 box=20000,20000
</pre></div>
Modified: grass/branches/develbranch_6/vector/v.mkgrid/local_proto.h
--- grass/branches/develbranch_6/vector/v.mkgrid/local_proto.h 2014-08-17 22:38:06 UTC (rev 61673)
+++ grass/branches/develbranch_6/vector/v.mkgrid/local_proto.h 2014-08-18 14:25:03 UTC (rev 61674)
@@ -2,6 +2,6 @@
void rotate(double *, double *, double, double, double);
/* write_grid.c */
-int write_grid(struct grid_description *, struct Map_info *, int);
+int write_grid(struct grid_description *, struct Map_info *, int, int);
int write_vect(double, double, double, double, struct Map_info *,
- struct line_pnts *);
+ struct line_pnts *, int);
Modified: grass/branches/develbranch_6/vector/v.mkgrid/main.c
--- grass/branches/develbranch_6/vector/v.mkgrid/main.c 2014-08-17 22:38:06 UTC (rev 61673)
+++ grass/branches/develbranch_6/vector/v.mkgrid/main.c 2014-08-18 14:25:03 UTC (rev 61674)
@@ -6,12 +6,14 @@
* Upgrade to 5.7 Radim Blazek 10/2004
* Hamish Bowman <hamish_b yahoo.com>,
* Jachym Cepicky <jachym les-ejk.cz>, Markus Neteler <neteler itc.it>
- * PURPOSE:
- * COPYRIGHT: (C) 1999-2007 by the GRASS Development Team
+ * Ivan Shevlakov: points support -p
+ * Luca Delucchi: lines support -l, vertical breaks
+ * PURPOSE:
+ * COPYRIGHT: (C) 1999-2014 by the GRASS Development Team
- * This program is free software under the GNU General Public
- * License (>=v2). Read the file COPYING that comes with GRASS
- * for details.
+ * This program is free software under the GNU General
+ * Public License (>=v2). Read the file COPYING that
+ * comes with GRASS for details.
@@ -19,10 +21,12 @@
#include <stdlib.h>
#include <string.h>
#include <math.h>
#include <grass/gis.h>
#include <grass/dbmi.h>
#include <grass/Vect.h>
#include <grass/glocale.h>
#include "grid_structs.h"
#include "local_proto.h"
@@ -43,10 +47,10 @@
struct Cell_head window;
struct Map_info Map;
struct Option *vectname, *grid, *coord, *box, *angle, *position_opt, *breaks;
+ struct GModule *module;
struct Flag *q;
- struct Flag *points_fl;
- int points_p;
- struct GModule *module;
+ struct Flag *points_fl, *line_fl;
+ int points_p, line_p, output_type;
struct line_pnts *Points;
struct line_cats *Cats;
@@ -69,7 +73,7 @@
grid = G_define_option();
grid->key = "grid";
- grid->key_desc = "rows,columns";
+ grid->key_desc = _("rows,columns");
grid->type = TYPE_INTEGER;
grid->required = YES;
grid->multiple = NO;
@@ -97,7 +101,7 @@
box = G_define_option();
box->key = "box";
- box->key_desc = "width,height";
+ box->key_desc = _("width,height");
box->type = TYPE_DOUBLE;
box->required = NO;
box->multiple = NO;
@@ -116,16 +120,20 @@
breaks->type = TYPE_INTEGER;
breaks->required = NO;
breaks->description =
- _("Number of horizontal vertex points per grid cell");
- breaks->options = "3-30";
+ _("Number of vertex points per grid cell");
+ breaks->options = "0-60";
breaks->answer = "3";
- points_fl = G_define_flag ();
+ points_fl = G_define_flag();
points_fl->key = 'p';
points_fl->description =
_("Create grid of points instead of areas and centroids");
- /* please, remove before GRASS 7 released */
+ line_fl = G_define_flag();
+ line_fl->key = 'l';
+ line_fl->description =
+ _("Create grid as lines, instead of areas");
q = G_define_flag();
q->key = 'q';
q->description = _("Quiet; No chatter");
@@ -135,13 +143,18 @@
exit(EXIT_FAILURE);
if (q->answer) {
putenv("GRASS_VERBOSE=0");
G_warning(_("The '-q' flag is superseded and will be removed "
"in future. Please use '--quiet' instead."));
+ line_p = line_fl->answer;
+ if (line_p) {
+ output_type = GV_LINE;
+ } else {
+ output_type = GV_BOUNDARY;
points_p = points_fl->answer;
@@ -165,11 +178,14 @@
/* Position */
if (position_opt->answer[0] == 'r') { /* region */
if (coord->answer)
- G_warning("'coor' option ignored with 'position=region'");
+ G_fatal_error(_("'coor' and 'position=region' are exclusive options"));
if (box->answer)
- G_warning("'box' option ignored with 'position=region'");
+ G_fatal_error(_("'box' and 'position=region' are exclusive options"));
+ if (grid_info.angle != 0.0)
+ G_fatal_error(_("'angle' and 'position=region' are exclusive options"));
grid_info.origin_x = window.west;
grid_info.origin_y = window.south;
@@ -178,11 +194,6 @@
G_debug(2, "x = %e y = %e l = %e w = %e", grid_info.origin_x,
grid_info.origin_y, grid_info.length, grid_info.width);
- if (grid_info.angle != 0.0) {
- G_warning("'angle' ignored ");
- grid_info.angle = 0.0;
else {
if (!coord->answer)
@@ -263,55 +274,67 @@
G_fatal_error(_("Unable to grant privileges on table <%s>"),
Fi->table);
- if (! points_p) {
+ if (!points_p) {
/* create areas */
- write_grid(&grid_info, &Map, nbreaks);
+ write_grid(&grid_info, &Map, nbreaks, output_type);
/* Create a grid of label points at the centres of the grid cells */
G_verbose_message(_("Creating centroids..."));
/* Write out centroids and attributes */
- attCount = 0;
- for (i = 0; i < grid_info.num_rows; ++i) {
- for (j = 0; j < grid_info.num_cols; ++j) {
- double x, y;
- const int point_type = points_p ? GV_POINT : GV_CENTROID;
+ /* If the output id is lines it skips to add centroids and attributes
+ TODO decide what to write in the attribute table
+ if (!line_p) {
+ db_begin_transaction(Driver);
+ attCount = 0;
+ for (i = 0; i < grid_info.num_rows; ++i) {
+ for (j = 0; j < grid_info.num_cols; ++j) {
+ double x, y;
+ const int point_type = points_p ? GV_POINT : GV_CENTROID;
- x = grid_info.origin_x + (0.5 + j) * grid_info.length;
- y = grid_info.origin_y + (0.5 + i) * grid_info.width;
+ x = grid_info.origin_x + (0.5 + j) * grid_info.length;
+ y = grid_info.origin_y + (0.5 + i) * grid_info.width;
- rotate(&x, &y, grid_info.origin_x, grid_info.origin_y,
- grid_info.angle);
+ rotate(&x, &y, grid_info.origin_x, grid_info.origin_y,
+ grid_info.angle);
- Vect_reset_line(Points);
- Vect_reset_cats(Cats);
+ Vect_reset_line(Points);
+ Vect_reset_cats(Cats);
- Vect_append_point(Points, x, y, 0.0);
- Vect_cat_set(Cats, 1, attCount + 1);
- Vect_write_line(&Map, point_type, Points, Cats);
+ Vect_append_point(Points, x, y, 0.0);
+ Vect_cat_set(Cats, 1, attCount + 1);
+ Vect_write_line(&Map, point_type, Points, Cats);
- if (grid_info.num_rows < 27 && grid_info.num_cols < 27) {
- sprintf(buf,
- "insert into %s values ( %d, %d, %d, '%c', '%c' )",
- Fi->table, attCount + 1, grid_info.num_rows - i,
- j + 1, 'A' + grid_info.num_rows - i - 1, 'A' + j);
- else {
- sprintf(buf, "insert into %s values ( %d, %d, %d )",
- Fi->table, attCount + 1, i + 1, j + 1);
- db_set_string(&sql, buf);
+ sprintf(buf, "insert into %s values ", Fi->table);
+ if (db_set_string(&sql, buf) != DB_OK)
+ G_fatal_error(_("Unable to fill attribute table"));
- G_debug(3, "SQL: %s", db_get_string(&sql));
+ if (grid_info.num_rows < 27 && grid_info.num_cols < 27) {
+ sprintf(buf,
+ "( %d, %d, %d, '%c', '%c' )",
+ attCount + 1, grid_info.num_rows - i,
+ j + 1, 'A' + grid_info.num_rows - i - 1, 'A' + j);
+ else {
+ sprintf(buf, "( %d, %d, %d )",
+ attCount + 1, i + 1, j + 1);
+ if (db_append_string(&sql, buf) != DB_OK)
- if (db_execute_immediate(Driver, &sql) != DB_OK) {
- G_fatal_error(_("Unable to insert new record: %s"),
+ G_debug(3, "SQL: %s", db_get_string(&sql));
+ if (db_execute_immediate(Driver, &sql) != DB_OK) {
+ G_fatal_error(_("Unable to insert new record: %s"),
- attCount++;
+ attCount++;
+ db_commit_transaction(Driver);
db_close_database_shutdown_driver(Driver);
Modified: grass/branches/develbranch_6/vector/v.mkgrid/write_grid.c
--- grass/branches/develbranch_6/vector/v.mkgrid/write_grid.c 2014-08-17 22:38:06 UTC (rev 61673)
+++ grass/branches/develbranch_6/vector/v.mkgrid/write_grid.c 2014-08-18 14:25:03 UTC (rev 61674)
@@ -5,13 +5,13 @@
-int write_grid(struct grid_description *grid_info, struct Map_info *Map, int nbreaks)
+int write_grid(struct grid_description *grid_info, struct Map_info *Map, int nbreaks, int out_type)
int i, k, j;
- int rows, cols, x_cols;
+ int rows, cols;
int num_v_rows, num_v_cols;
- double x, y, x_len;
+ double x, y, x_len, y_len;
double sx, sy;
double width, length;
double next_x, next_y;
@@ -35,12 +35,11 @@
* to make sure that each section of the grid
* line is less than half way around the globe
- x_len = length / (1. * nbreaks);
- x_cols = cols * (1. * nbreaks);
+ x_len = length / (1. * nbreaks + 1);
+ y_len = width / (1. * nbreaks + 1);
/* write out all the vector lengths (x vectors) of the entire grid */
G_verbose_message(_("Writing out vector rows..."));
y = grid_info->origin_y;
for (i = 0; i < num_v_rows; ++i) {
double startx;
@@ -50,8 +49,9 @@
for (k = 0; k < cols; k++) {
x = startx;
- for (j = 0; j < nbreaks; j++) {
- if (j < nbreaks -1)
+ j = 0;
+ do {
+ if (j < nbreaks)
next_x = x + x_len;
else
next_x = startx + length;
@@ -65,11 +65,12 @@
angle);
rotate(&next_x, &dum, grid_info->origin_x,
grid_info->origin_y, angle);
- write_vect(x, y, next_x, dum, Map, Points);
+ write_vect(x, y, next_x, dum, Map, Points, out_type);
y = sy;
x = next_x = snext_x;
+ j++;
+ } while (j <= nbreaks);
startx += length;
y += width;
@@ -78,27 +79,37 @@
/* write out all the vector widths (y vectors) of the entire grid */
G_verbose_message(_("Writing out vector columns..."));
x = grid_info->origin_x;
- for (k = 0; k < num_v_cols; ++k) {
- y = grid_info->origin_y;
- G_percent(k, num_v_cols, 2);
+ for (i = 0; i < num_v_cols; ++i) {
+ double starty;
+ starty = grid_info->origin_y;
+ G_percent(i, num_v_cols, 2);
- for (i = 0; i < rows; ++i) {
- next_y = y + width;
+ for (k = 0; k < rows; k++) {
+ y = starty;
+ j = 0;
+ do {
+ if (j < nbreaks)
+ next_y = y + y_len;
+ else
+ next_y = starty + width;
- sx = x;
- sy = y;
- snext_y = next_y;
- dum = x;
- rotate(&x, &y, grid_info->origin_x, grid_info->origin_y, angle);
- rotate(&dum, &next_y, grid_info->origin_x, grid_info->origin_y,
- angle);
+ sx = x;
+ sy = y;
+ snext_y = next_y;
+ dum = x;
+ rotate(&x, &y, grid_info->origin_x, grid_info->origin_y, angle);
+ rotate(&dum, &next_y, grid_info->origin_x, grid_info->origin_y,
+ angle);
- write_vect(x, y, dum, next_y, Map, Points);
+ write_vect(x, y, dum, next_y, Map, Points, out_type);
- x = sx;
- y = next_y = snext_y;
+ x = sx;
+ y = next_y = snext_y;
+ j++;
+ /* To get exactly the same coordinates as above, y+=width is wrong */
+ starty += width;
- /* To get exactly the same coordinates as above, x+=length is wrong */
x += length;
@@ -114,7 +125,7 @@
#define NUM_POINTS 2
int write_vect(double x1, double y1, double x2, double y2,
- struct Map_info *Map, struct line_pnts *Points) /* new with Vlib */
+ struct Map_info *Map, struct line_pnts *Points, int out_type)
static struct line_cats *Cats = NULL;
@@ -129,8 +140,7 @@
if (0 > Vect_copy_xyz_to_pnts(Points, xarray, yarray, NULL, NUM_POINTS))
G_fatal_error(_("Out of memory"));
+ Vect_write_line(Map, out_type, Points, Cats);
- Vect_write_line(Map, GV_BOUNDARY, Points, Cats);
return 0;
