[GRASS-SVN] r61678 - in grass/branches/releasebranch_7_0: . include	include/Make include/defs lib/nviz lib/ogsf
    svn_grass at osgeo.org
    Mon Aug 18 10:25:46 PDT 2014
Author: wenzeslaus
Date: 2014-08-18 10:25:46 -0700 (Mon, 18 Aug 2014)
New Revision: 61678
Removed:
   grass/branches/releasebranch_7_0/lib/ogsf/gsd_img_mpeg.c
   grass/branches/releasebranch_7_0/REQUIREMENTS.html
   grass/branches/releasebranch_7_0/configure
   grass/branches/releasebranch_7_0/configure.in
   grass/branches/releasebranch_7_0/include/Make/Grass.make
   grass/branches/releasebranch_7_0/include/Make/Platform.make.in
   grass/branches/releasebranch_7_0/include/config.h.in
   grass/branches/releasebranch_7_0/include/defs/ogsf.h
   grass/branches/releasebranch_7_0/lib/nviz/Makefile
   grass/branches/releasebranch_7_0/lib/ogsf/Makefile
remove unused ffmpeg (libavutil) dependency (ticket #2017, backport r61305)
Modified: grass/branches/releasebranch_7_0/REQUIREMENTS.html
--- grass/branches/releasebranch_7_0/REQUIREMENTS.html	2014-08-18 16:57:22 UTC (rev 61677)
+++ grass/branches/releasebranch_7_0/REQUIREMENTS.html	2014-08-18 17:25:46 UTC (rev 61678)
@@ -154,11 +154,15 @@
 a newer version is "python-pillow"
 </li>
-<li><b>FFMPEG</b> (for direct rendering of animations from wxNVIZ),
-    including libavcodec, libavformat, libswscale <br>
+<li><b>FFMPEG or alternative</b> (for wxGUI Animation tool - g.gui.module),
+    specifically ffmpeg tool<br>
 <a href="http://ffmpeg.org">http://ffmpeg.org</a>
 </li>
+<li><b>mpeg_encode or ppmtompeg tool</b> (for r.out.mpeg module)<br>
+<a href="http://ffmpeg.org">http://ffmpeg.org</a>
+</li>
 <li><b>Cairo >= 1.5.8</b> (for Cairo driver)<br>
 <a href="http://cairographics.org">http://cairographics.org</a>
 </li>
Modified: grass/branches/releasebranch_7_0/configure
--- grass/branches/releasebranch_7_0/configure	2014-08-18 16:57:22 UTC (rev 61677)
+++ grass/branches/releasebranch_7_0/configure	2014-08-18 17:25:46 UTC (rev 61678)
@@ -39,8 +39,6 @@
 ac_help="$ac_help
   --with-sqlite           support SQLite functionality (default: no)"
 ac_help="$ac_help
-  --with-ffmpeg           support FFMPEG functionality (default: no)"
-ac_help="$ac_help
   --with-opengl           support OpenGL functionality (default: yes)"
 ac_help="$ac_help
   --with-odbc             support ODBC functionality (default: no)"
@@ -134,11 +132,6 @@
 ac_help="$ac_help
   --with-sqlite-libs=DIRS SQLite library files are in DIRS"
 ac_help="$ac_help
-  --with-ffmpeg-includes=DIRS
-                          FFMPEG include files are in DIRS"
-ac_help="$ac_help
-  --with-ffmpeg-libs=DIRS FFMPEG library files are in DIRS"
-ac_help="$ac_help
   --with-opengl-includes=DIRS
                           OpenGL include files are in DIRS"
 ac_help="$ac_help
@@ -750,7 +743,7 @@
 fi
 echo $ac_n "checking host system type""... $ac_c" 1>&6
-echo "configure:754: checking host system type" >&5
+echo "configure:747: checking host system type" >&5
 host_alias=$host
 case "$host_alias" in
@@ -773,7 +766,7 @@
 # Extract the first word of "gcc", so it can be a program name with args.
 set dummy gcc; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:777: checking for $ac_word" >&5
+echo "configure:770: checking for $ac_word" >&5
 if test -n "$CC"; then
   ac_cv_prog_CC="$CC" # Let the user override the test.
@@ -800,7 +793,7 @@
   # Extract the first word of "cc", so it can be a program name with args.
 set dummy cc; ac_word=$2
-echo "configure:804: checking for $ac_word" >&5
+echo "configure:797: checking for $ac_word" >&5
@@ -848,7 +841,7 @@
       # Extract the first word of "cl", so it can be a program name with args.
 set dummy cl; ac_word=$2
-echo "configure:852: checking for $ac_word" >&5
+echo "configure:845: checking for $ac_word" >&5
@@ -877,7 +870,7 @@
 fi
 echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:881: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
+echo "configure:874: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) works" >&5
 ac_ext=c
 # CFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -888,12 +881,12 @@
 cat > conftest.$ac_ext << EOF
-#line 892 "configure"
+#line 885 "configure"
 #include "confdefs.h"
 main(){return(0);}
 EOF
-if { (eval echo configure:897: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:890: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cc_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -919,19 +912,19 @@
   { echo "configure: error: installation or configuration problem: C compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:923: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:916: checking whether the C compiler ($CC $CFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cc_cross" 1>&6
 cross_compiling=$ac_cv_prog_cc_cross
 echo $ac_n "checking whether we are using GNU C""... $ac_c" 1>&6
-echo "configure:928: checking whether we are using GNU C" >&5
+echo "configure:921: checking whether we are using GNU C" >&5
 cat > conftest.c <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:935: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CC-cc} -E conftest.c'; { (eval echo configure:928: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gcc=yes
 else
   ac_cv_prog_gcc=no
@@ -949,7 +942,7 @@
 ac_save_CFLAGS="$CFLAGS"
 CFLAGS=
 echo $ac_n "checking whether ${CC-cc} accepts -g""... $ac_c" 1>&6
-echo "configure:953: checking whether ${CC-cc} accepts -g" >&5
+echo "configure:946: checking whether ${CC-cc} accepts -g" >&5
 echo 'void f(){}' > conftest.c
 if test -z "`${CC-cc} -g -c conftest.c 2>&1`"; then
@@ -978,10 +971,10 @@
 fi
 echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:982: checking for Cygwin environment" >&5
+echo "configure:975: checking for Cygwin environment" >&5
 cat > conftest.$ac_ext <<EOF
-#line 985 "configure"
+#line 978 "configure"
 int main() {
@@ -992,7 +985,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:996: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:989: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -1008,17 +1001,17 @@
 CYGWIN=
 test "$ac_cv_cygwin" = yes && CYGWIN=yes
 echo $ac_n "checking for mingw32 environment""... $ac_c" 1>&6
-echo "configure:1012: checking for mingw32 environment" >&5
+echo "configure:1005: checking for mingw32 environment" >&5
-#line 1015 "configure"
+#line 1008 "configure"
 int main() {
 return __MINGW32__;
 ; return 0; }
 EOF
-if { (eval echo configure:1022: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1015: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_mingw32=yes
 else
@@ -1036,7 +1029,7 @@
 echo $ac_n "checking for executable suffix""... $ac_c" 1>&6
-echo "configure:1040: checking for executable suffix" >&5
+echo "configure:1033: checking for executable suffix" >&5
 if test "$CYGWIN" = yes || test "$MINGW32" = yes; then
   ac_cv_exeext=.exe
@@ -1055,23 +1048,23 @@
 IEEEFLAG=
 echo $ac_n "checking for full floating-point support""... $ac_c" 1>&6
-echo "configure:1059: checking for full floating-point support" >&5
+echo "configure:1052: checking for full floating-point support" >&5
 if test "$cross_compiling" = yes; then
      echo "$ac_t""unknown (cross-compiling)" 1>&6
 echo $ac_n "checking whether "cc -mieee" works""... $ac_c" 1>&6
-echo "configure:1064: checking whether "cc -mieee" works" >&5
+echo "configure:1057: checking whether "cc -mieee" works" >&5
 ac_save_cflags=${CFLAGS}
 CFLAGS="$CFLAGS -mieee"
-#line 1068 "configure"
+#line 1061 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:1075: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:1068: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
      echo "$ac_t""yes" 1>&6
         IEEEFLAG="-mieee"
@@ -1087,7 +1080,7 @@
 else
-#line 1091 "configure"
+#line 1084 "configure"
 #include <float.h>
@@ -1101,7 +1094,7 @@
 EOF
-if { (eval echo configure:1105: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1098: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
@@ -1114,14 +1107,14 @@
   CFLAGS=-mieee
 echo $ac_n "checking for full floating-point support with -mieee""... $ac_c" 1>&6
-echo "configure:1118: checking for full floating-point support with -mieee" >&5
+echo "configure:1111: checking for full floating-point support with -mieee" >&5
     { echo "configure: error: *** INTERNAL CONFIGURE ERROR" 1>&2; exit 1; }
 else
-#line 1125 "configure"
+#line 1118 "configure"
 #include <float.h>
@@ -1135,7 +1128,7 @@
 EOF
-if { (eval echo configure:1139: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:1132: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
     IEEEFLAG="-mieee"
@@ -1172,7 +1165,7 @@
 # Extract the first word of "pwd", so it can be a program name with args.
 set dummy pwd; ac_word=$2
-echo "configure:1176: checking for $ac_word" >&5
+echo "configure:1169: checking for $ac_word" >&5
 case "$pwd" in
@@ -1210,7 +1203,7 @@
 fi
 echo $ac_n "checking for source directory""... $ac_c" 1>&6
-echo "configure:1214: checking for source directory" >&5
+echo "configure:1207: checking for source directory" >&5
 if test -z "$srcdir" ; then
   SRCDIR=`$pwd`
@@ -1221,7 +1214,7 @@
 echo "$ac_t"""$SRCDIR"" 1>&6
 echo $ac_n "checking for build directory""... $ac_c" 1>&6
-echo "configure:1225: checking for build directory" >&5
+echo "configure:1218: checking for build directory" >&5
 DSTDIR=`$pwd`
 WINDSTDIR=`$winpwd`
@@ -1289,7 +1282,7 @@
 # Extract the first word of "svnversion", so it can be a program name with args.
 set dummy svnversion; ac_word=$2
-echo "configure:1293: checking for $ac_word" >&5
+echo "configure:1286: checking for $ac_word" >&5
 case "$SVN_VERSION" in
@@ -1348,7 +1341,7 @@
 echo $ac_n "checking for MacOSX App""... $ac_c" 1>&6
-echo "configure:1352: checking for MacOSX App" >&5
+echo "configure:1345: checking for MacOSX App" >&5
 case "$enable_macosx_app" in
 	yes)	MACOSX_APP=1	;;
 	no)	MACOSX_APP=	;;
@@ -1360,7 +1353,7 @@
 # Check for MacOSX archs
 echo $ac_n "checking for MacOSX architectures""... $ac_c" 1>&6
-echo "configure:1364: checking for MacOSX architectures" >&5
+echo "configure:1357: checking for MacOSX architectures" >&5
 MACOSX_ARCHS=
@@ -1389,7 +1382,7 @@
 # Check for MacOSX SDK
 echo $ac_n "checking for MacOSX SDK""... $ac_c" 1>&6
-echo "configure:1393: checking for MacOSX SDK" >&5
+echo "configure:1386: checking for MacOSX SDK" >&5
 MACOSX_SDK=
@@ -1399,7 +1392,7 @@
 ac_safe=`echo "$with_macosx_sdk/SDKSettings.plist" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $with_macosx_sdk/SDKSettings.plist""... $ac_c" 1>&6
-echo "configure:1403: checking for $with_macosx_sdk/SDKSettings.plist" >&5
+echo "configure:1396: checking for $with_macosx_sdk/SDKSettings.plist" >&5
     { echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -1443,7 +1436,7 @@
     echo $ac_n "checking how to build libraries""... $ac_c" 1>&6
-echo "configure:1447: checking how to build libraries" >&5
+echo "configure:1440: checking how to build libraries" >&5
     # Check whether --enable-shared or --disable-shared was given.
 if test "${enable_shared+set}" = set; then
   enableval="$enable_shared"
@@ -1740,16 +1733,6 @@
-# Check whether --with-ffmpeg or --without-ffmpeg was given.
-if test "${with_ffmpeg+set}" = set; then
-  withval="$with_ffmpeg"
-else
-  with_ffmpeg=no
-fi
 # Check whether --with-opengl or --without-opengl was given.
 if test "${with_opengl+set}" = set; then
   withval="$with_opengl"
@@ -2069,23 +2052,6 @@
-# Check whether --with-ffmpeg-includes or --without-ffmpeg-includes was given.
-if test "${with_ffmpeg_includes+set}" = set; then
-  withval="$with_ffmpeg_includes"
-fi
-# Check whether --with-ffmpeg-libs or --without-ffmpeg-libs was given.
-if test "${with_ffmpeg_libs+set}" = set; then
-  withval="$with_ffmpeg_libs"
-fi
 # Check whether --with-opengl-includes or --without-opengl-includes was given.
 if test "${with_opengl_includes+set}" = set; then
   withval="$with_opengl_includes"
@@ -2340,7 +2306,7 @@
 # Done checking fortran
 echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:2344: checking for additional include dirs" >&5
+echo "configure:2310: checking for additional include dirs" >&5
 case "$with_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -2363,7 +2329,7 @@
 # With libs option
 echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:2367: checking for additional library dirs" >&5
+echo "configure:2333: checking for additional library dirs" >&5
 case "$with_libs" in
 	{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -2397,7 +2363,7 @@
 # SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
 # ./install, which can be erroneously created by make from ./install.sh.
 echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:2401: checking for a BSD compatible install" >&5
+echo "configure:2367: checking for a BSD compatible install" >&5
 if test -z "$INSTALL"; then
   IFS="${IFS= 	}"; ac_save_IFS="$IFS"; IFS=":"
@@ -2450,7 +2416,7 @@
 # Extract the first word of "flex", so it can be a program name with args.
 set dummy flex; ac_word=$2
-echo "configure:2454: checking for $ac_word" >&5
+echo "configure:2420: checking for $ac_word" >&5
 if test -n "$LEX"; then
   ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -2481,13 +2447,13 @@
   *) ac_lib=l ;;
   esac
   echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:2485: checking for yywrap in -l$ac_lib" >&5
+echo "configure:2451: checking for yywrap in -l$ac_lib" >&5
 ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-l$ac_lib  $LIBS"
-#line 2491 "configure"
+#line 2457 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -2498,7 +2464,7 @@
 yywrap()
 ; return 0; }
 EOF
-if { (eval echo configure:2502: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2468: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -2523,7 +2489,7 @@
     # Extract the first word of "lex", so it can be a program name with args.
 set dummy lex; ac_word=$2
-echo "configure:2527: checking for $ac_word" >&5
+echo "configure:2493: checking for $ac_word" >&5
 case "$LEXPATH" in
@@ -2563,7 +2529,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
-echo "configure:2567: checking for $ac_word" >&5
+echo "configure:2533: checking for $ac_word" >&5
 if test -n "$YACC"; then
   ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -2594,7 +2560,7 @@
     # Extract the first word of "yacc", so it can be a program name with args.
 set dummy yacc; ac_word=$2
-echo "configure:2598: checking for $ac_word" >&5
+echo "configure:2564: checking for $ac_word" >&5
 case "$YACCPATH" in
@@ -2632,7 +2598,7 @@
 # Extract the first word of "ranlib", so it can be a program name with args.
 set dummy ranlib; ac_word=$2
-echo "configure:2636: checking for $ac_word" >&5
+echo "configure:2602: checking for $ac_word" >&5
 if test -n "$RANLIB"; then
   ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -2661,7 +2627,7 @@
-echo "configure:2665: checking for $ac_word" >&5
+echo "configure:2631: checking for $ac_word" >&5
 if test -n "$AR"; then
   ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -2692,7 +2658,7 @@
-echo "configure:2696: checking for $ac_word" >&5
+echo "configure:2662: checking for $ac_word" >&5
 if test -n "$ENV"; then
   ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -2721,7 +2687,7 @@
 # Extract the first word of "perl", so it can be a program name with args.
 set dummy perl; ac_word=$2
-echo "configure:2725: checking for $ac_word" >&5
+echo "configure:2691: checking for $ac_word" >&5
 case "$PERL" in
@@ -2752,7 +2718,7 @@
 fi
 echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:2756: checking how to run the C preprocessor" >&5
+echo "configure:2722: checking how to run the C preprocessor" >&5
 # On Suns, sometimes $CPP names a directory.
 if test -n "$CPP" && test -d "$CPP"; then
   CPP=
@@ -2765,13 +2731,13 @@
   # On the NeXT, cc -E runs the code through the compiler's parser,
   # not just through cpp.
-#line 2769 "configure"
+#line 2735 "configure"
 #include <assert.h>
 Syntax Error
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:2775: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2741: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
@@ -2782,13 +2748,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -E -traditional-cpp"
-#line 2786 "configure"
+#line 2752 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:2792: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2758: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2799,13 +2765,13 @@
   rm -rf conftest*
   CPP="${CC-cc} -nologo -E"
-#line 2803 "configure"
+#line 2769 "configure"
 #include <assert.h>
 Syntax Error
 EOF
-{ (eval echo configure:2809: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2775: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2829,10 +2795,10 @@
 echo "$ac_t""$CPP" 1>&6
 echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:2833: checking for ANSI C header files" >&5
+echo "configure:2799: checking for ANSI C header files" >&5
-#line 2836 "configure"
+#line 2802 "configure"
 #include <stdlib.h>
 #include <stdarg.h>
@@ -2840,7 +2806,7 @@
 #include <float.h>
 EOF
-{ (eval echo configure:2844: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2810: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2857,7 +2823,7 @@
 if test $ac_cv_header_stdc = yes; then
   # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 2861 "configure"
+#line 2827 "configure"
 #include <string.h>
 EOF
@@ -2875,7 +2841,7 @@
   # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 2879 "configure"
+#line 2845 "configure"
 #include <stdlib.h>
 EOF
@@ -2896,7 +2862,7 @@
 else
-#line 2900 "configure"
+#line 2866 "configure"
 #include <ctype.h>
 #define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -2907,7 +2873,7 @@
 exit (0); }
 EOF
-if { (eval echo configure:2911: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:2877: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
 else
@@ -2934,15 +2900,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:2938: checking for $ac_hdr" >&5
+echo "configure:2904: checking for $ac_hdr" >&5
-#line 2941 "configure"
+#line 2907 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:2946: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2912: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -2971,15 +2937,15 @@
 do
-echo "configure:2975: checking for $ac_hdr" >&5
+echo "configure:2941: checking for $ac_hdr" >&5
-#line 2978 "configure"
+#line 2944 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:2983: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2949: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3008,15 +2974,15 @@
 do
-echo "configure:3012: checking for $ac_hdr" >&5
+echo "configure:2978: checking for $ac_hdr" >&5
-#line 3015 "configure"
+#line 2981 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3020: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2986: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3045,15 +3011,15 @@
 do
-echo "configure:3049: checking for $ac_hdr" >&5
+echo "configure:3015: checking for $ac_hdr" >&5
-#line 3052 "configure"
+#line 3018 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3057: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3023: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3082,15 +3048,15 @@
 do
-echo "configure:3086: checking for $ac_hdr" >&5
+echo "configure:3052: checking for $ac_hdr" >&5
-#line 3089 "configure"
+#line 3055 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:3094: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3060: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3116,10 +3082,10 @@
 done
 echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:3120: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:3086: checking whether time.h and sys/time.h may both be included" >&5
-#line 3123 "configure"
+#line 3089 "configure"
 #include <sys/types.h>
 #include <sys/time.h>
@@ -3128,7 +3094,7 @@
 struct tm *tp;
 ; return 0; }
 EOF
-if { (eval echo configure:3132: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3098: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_header_time=yes
 else
@@ -3148,10 +3114,10 @@
 fi
 echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:3152: checking for off_t" >&5
+echo "configure:3118: checking for off_t" >&5
-#line 3155 "configure"
+#line 3121 "configure"
 #if STDC_HEADERS
@@ -3178,10 +3144,10 @@
 fi
 echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:3182: checking for uid_t in sys/types.h" >&5
+echo "configure:3148: checking for uid_t in sys/types.h" >&5
-#line 3185 "configure"
+#line 3151 "configure"
 EOF
@@ -3209,10 +3175,10 @@
 fi
 echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:3213: checking return type of signal handlers" >&5
+echo "configure:3179: checking return type of signal handlers" >&5
-#line 3216 "configure"
+#line 3182 "configure"
 #include <signal.h>
@@ -3229,7 +3195,7 @@
 int i;
 ; return 0; }
 EOF
-if { (eval echo configure:3233: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3199: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_type_signal=void
 else
@@ -3247,10 +3213,10 @@
-echo "configure:3251: checking for Cygwin environment" >&5
+echo "configure:3217: checking for Cygwin environment" >&5
-#line 3254 "configure"
+#line 3220 "configure"
 int main() {
@@ -3261,7 +3227,7 @@
 return __CYGWIN__;
 ; return 0; }
 EOF
-if { (eval echo configure:3265: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3231: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_cygwin=yes
 else
@@ -3279,10 +3245,10 @@
 for ac_func in ftime gethostname gettimeofday lseek nice time uname
 do
 echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:3283: checking for $ac_func" >&5
+echo "configure:3249: checking for $ac_func" >&5
-#line 3286 "configure"
+#line 3252 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char $ac_func(); below.  */
@@ -3305,7 +3271,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3309: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3275: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_$ac_func=yes"
 else
@@ -3331,10 +3297,10 @@
 for ac_func in seteuid setpriority setreuid setruid
 do
-echo "configure:3335: checking for $ac_func" >&5
+echo "configure:3301: checking for $ac_func" >&5
-#line 3338 "configure"
+#line 3304 "configure"
@@ -3357,7 +3323,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3361: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3327: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3383,10 +3349,10 @@
 for ac_func in drand48
 do
-echo "configure:3387: checking for $ac_func" >&5
+echo "configure:3353: checking for $ac_func" >&5
-#line 3390 "configure"
+#line 3356 "configure"
@@ -3409,7 +3375,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3413: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3379: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3435,10 +3401,10 @@
 for ac_func in putenv setenv
 do
-echo "configure:3439: checking for $ac_func" >&5
+echo "configure:3405: checking for $ac_func" >&5
-#line 3442 "configure"
+#line 3408 "configure"
@@ -3461,7 +3427,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3465: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3431: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3487,10 +3453,10 @@
 for ac_func in nanosleep
 do
-echo "configure:3491: checking for $ac_func" >&5
+echo "configure:3457: checking for $ac_func" >&5
-#line 3494 "configure"
+#line 3460 "configure"
@@ -3513,7 +3479,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:3517: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3483: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3538,13 +3504,13 @@
 if test "$cross_compiling" != "yes" ; then
 echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:3542: checking whether setpgrp takes no argument" >&5
+echo "configure:3508: checking whether setpgrp takes no argument" >&5
   { echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
 else
-#line 3548 "configure"
+#line 3514 "configure"
 #ifdef HAVE_UNISTD_H
@@ -3564,7 +3530,7 @@
 EOF
-if { (eval echo configure:3568: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3534: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
   ac_cv_func_setpgrp_void=no
 else
@@ -3592,16 +3558,16 @@
 fi
 echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:3596: checking for long long int" >&5
+echo "configure:3562: checking for long long int" >&5
-#line 3598 "configure"
+#line 3564 "configure"
 int main() {
 long long int x;
 ; return 0; }
 EOF
-if { (eval echo configure:3605: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3571: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
@@ -3621,7 +3587,7 @@
 rm -f conftest*
 echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:3625: checking for W11" >&5
+echo "configure:3591: checking for W11" >&5
 case "$enable_w11" in
 	yes|no)	echo "$ac_t"""$enable_w11"" 1>&6	;;
 	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
@@ -3649,7 +3615,7 @@
 # Uses ac_ vars as temps to allow command line to override cache and checks.
 # --without-x overrides everything else, but does not touch the cache.
 echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:3653: checking for X" >&5
+echo "configure:3619: checking for X" >&5
 # Check whether --with-x or --without-x was given.
 if test "${with_x+set}" = set; then
@@ -3709,12 +3675,12 @@
   # First, try using that file with no special directory specified.
-#line 3713 "configure"
+#line 3679 "configure"
 #include <$x_direct_test_include>
 EOF
-{ (eval echo configure:3718: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3684: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -3783,14 +3749,14 @@
   LIBS="-l$x_direct_test_library $LIBS"
-#line 3787 "configure"
+#line 3753 "configure"
 int main() {
 ${x_direct_test_function}()
 ; return 0; }
 EOF
-if { (eval echo configure:3794: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3760: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LIBS="$ac_save_LIBS"
 # We can link X programs with no special library path.
@@ -3895,17 +3861,17 @@
     case "`(uname -sr) 2>/dev/null`" in
     "SunOS 5"*)
       echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:3899: checking whether -R must be followed by a space" >&5
+echo "configure:3865: checking whether -R must be followed by a space" >&5
       ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 3902 "configure"
+#line 3868 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:3909: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3875: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_nospace=yes
 else
@@ -3921,14 +3887,14 @@
       else
 	LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 3925 "configure"
+#line 3891 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:3932: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3898: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_R_space=yes
 else
@@ -3960,13 +3926,13 @@
     # libraries were built with DECnet support.  And karl at cs.umb.edu says
     # the Alpha needs dnet_stub (dnet does not exist).
     echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:3964: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:3930: checking for dnet_ntoa in -ldnet" >&5
 ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet  $LIBS"
-#line 3970 "configure"
+#line 3936 "configure"
@@ -3977,7 +3943,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:3981: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3947: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -3998,13 +3964,13 @@
     if test $ac_cv_lib_dnet_dnet_ntoa = no; then
       echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:4002: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:3968: checking for dnet_ntoa in -ldnet_stub" >&5
 ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
 LIBS="-ldnet_stub  $LIBS"
-#line 4008 "configure"
+#line 3974 "configure"
@@ -4015,7 +3981,7 @@
 dnet_ntoa()
 ; return 0; }
 EOF
-if { (eval echo configure:4019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3985: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4043,10 +4009,10 @@
     # The nsl library prevents programs from opening the X display
     # on Irix 5.2, according to dickey at clark.net.
     echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:4047: checking for gethostbyname" >&5
+echo "configure:4013: checking for gethostbyname" >&5
-#line 4050 "configure"
+#line 4016 "configure"
     which can conflict with char gethostbyname(); below.  */
@@ -4069,7 +4035,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4073: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4039: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gethostbyname=yes"
 else
@@ -4089,13 +4055,13 @@
     if test $ac_cv_func_gethostbyname = no; then
       echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:4093: checking for gethostbyname in -lnsl" >&5
+echo "configure:4059: checking for gethostbyname in -lnsl" >&5
 ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
 LIBS="-lnsl  $LIBS"
-#line 4099 "configure"
+#line 4065 "configure"
@@ -4106,7 +4072,7 @@
 gethostbyname()
 ; return 0; }
 EOF
-if { (eval echo configure:4110: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4076: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4135,10 +4101,10 @@
     # -lsocket must be given before -lnsl if both are needed.
     # We assume that if connect needs -lnsl, so does gethostbyname.
     echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:4139: checking for connect" >&5
+echo "configure:4105: checking for connect" >&5
-#line 4142 "configure"
+#line 4108 "configure"
     which can conflict with char connect(); below.  */
@@ -4161,7 +4127,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4165: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4131: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_connect=yes"
 else
@@ -4181,13 +4147,13 @@
     if test $ac_cv_func_connect = no; then
       echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:4185: checking for connect in -lsocket" >&5
+echo "configure:4151: checking for connect in -lsocket" >&5
 ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
 LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 4191 "configure"
+#line 4157 "configure"
@@ -4198,7 +4164,7 @@
 connect()
 ; return 0; }
 EOF
-if { (eval echo configure:4202: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4168: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4221,10 +4187,10 @@
     # gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
     echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:4225: checking for remove" >&5
+echo "configure:4191: checking for remove" >&5
-#line 4228 "configure"
+#line 4194 "configure"
     which can conflict with char remove(); below.  */
@@ -4247,7 +4213,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4251: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4217: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_remove=yes"
 else
@@ -4267,13 +4233,13 @@
     if test $ac_cv_func_remove = no; then
       echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:4271: checking for remove in -lposix" >&5
+echo "configure:4237: checking for remove in -lposix" >&5
 ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
 LIBS="-lposix  $LIBS"
-#line 4277 "configure"
+#line 4243 "configure"
@@ -4284,7 +4250,7 @@
 remove()
 ; return 0; }
 EOF
-if { (eval echo configure:4288: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4254: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4307,10 +4273,10 @@
     # BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
     echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:4311: checking for shmat" >&5
+echo "configure:4277: checking for shmat" >&5
-#line 4314 "configure"
+#line 4280 "configure"
     which can conflict with char shmat(); below.  */
@@ -4333,7 +4299,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4337: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4303: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_shmat=yes"
 else
@@ -4353,13 +4319,13 @@
     if test $ac_cv_func_shmat = no; then
       echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:4357: checking for shmat in -lipc" >&5
+echo "configure:4323: checking for shmat in -lipc" >&5
 ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
 LIBS="-lipc  $LIBS"
-#line 4363 "configure"
+#line 4329 "configure"
@@ -4370,7 +4336,7 @@
 shmat()
 ; return 0; }
 EOF
-if { (eval echo configure:4374: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4340: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4402,13 +4368,13 @@
   # libraries we check for below, so use a different variable.
   #  --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
   echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:4406: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:4372: checking for IceConnectionNumber in -lICE" >&5
 ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
 LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 4412 "configure"
+#line 4378 "configure"
@@ -4419,7 +4385,7 @@
 IceConnectionNumber()
 ; return 0; }
 EOF
-if { (eval echo configure:4423: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4389: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4459,12 +4425,12 @@
 LIBS=""
 echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:4463: checking for library containing cuserid" >&5
+echo "configure:4429: checking for library containing cuserid" >&5
 ac_func_search_save_LIBS="$LIBS"
 ac_cv_search_cuserid="no"
-#line 4468 "configure"
+#line 4434 "configure"
@@ -4475,7 +4441,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:4479: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4445: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="none required"
 else
@@ -4486,7 +4452,7 @@
 test "$ac_cv_search_cuserid" = "no" && for i in compat; do
 LIBS="-l$i  $ac_func_search_save_LIBS"
-#line 4490 "configure"
+#line 4456 "configure"
@@ -4497,7 +4463,7 @@
 cuserid()
 ; return 0; }
 EOF
-if { (eval echo configure:4501: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4467: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_search_cuserid="-l$i"
 break
@@ -4523,10 +4489,10 @@
 for ac_func in asprintf
 do
-echo "configure:4527: checking for $ac_func" >&5
+echo "configure:4493: checking for $ac_func" >&5
-#line 4530 "configure"
+#line 4496 "configure"
@@ -4549,7 +4515,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4553: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4519: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4576,10 +4542,10 @@
 # Test if mathlib needs -lm flag or is included with libc
 echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:4580: checking for atan" >&5
+echo "configure:4546: checking for atan" >&5
-#line 4583 "configure"
+#line 4549 "configure"
     which can conflict with char atan(); below.  */
@@ -4602,7 +4568,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4606: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4572: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_atan=yes"
 else
@@ -4620,13 +4586,13 @@
   echo "$ac_t""no" 1>&6
 echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:4624: checking for atan in -lm" >&5
+echo "configure:4590: checking for atan in -lm" >&5
 ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
 LIBS="-lm  $LIBS"
-#line 4630 "configure"
+#line 4596 "configure"
@@ -4637,7 +4603,7 @@
 atan()
 ; return 0; }
 EOF
-if { (eval echo configure:4641: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4607: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4664,10 +4630,10 @@
 echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:4668: checking for dlsym" >&5
+echo "configure:4634: checking for dlsym" >&5
-#line 4671 "configure"
+#line 4637 "configure"
     which can conflict with char dlsym(); below.  */
@@ -4690,7 +4656,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4694: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4660: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dlsym=yes"
 else
@@ -4708,13 +4674,13 @@
 echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:4712: checking for dlsym in -ldl" >&5
+echo "configure:4678: checking for dlsym in -ldl" >&5
 ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
 LIBS="-ldl  $LIBS"
-#line 4718 "configure"
+#line 4684 "configure"
@@ -4725,7 +4691,7 @@
 dlsym()
 ; return 0; }
 EOF
-if { (eval echo configure:4729: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4695: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4752,10 +4718,10 @@
 echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:4756: checking for iconv" >&5
+echo "configure:4722: checking for iconv" >&5
-#line 4759 "configure"
+#line 4725 "configure"
     which can conflict with char iconv(); below.  */
@@ -4778,7 +4744,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4782: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4748: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_iconv=yes"
 else
@@ -4796,13 +4762,13 @@
 echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:4800: checking for iconv in -liconv" >&5
+echo "configure:4766: checking for iconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-liconv  $LIBS"
-#line 4806 "configure"
+#line 4772 "configure"
@@ -4813,7 +4779,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:4817: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4783: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4832,13 +4798,13 @@
 echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4836: checking for iconv in -lgiconv" >&5
+echo "configure:4802: checking for iconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
 LIBS="-lgiconv  $LIBS"
-#line 4842 "configure"
+#line 4808 "configure"
@@ -4849,7 +4815,7 @@
 iconv()
 ; return 0; }
 EOF
-if { (eval echo configure:4853: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4819: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4868,10 +4834,10 @@
 echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:4872: checking for libiconv" >&5
+echo "configure:4838: checking for libiconv" >&5
-#line 4875 "configure"
+#line 4841 "configure"
     which can conflict with char libiconv(); below.  */
@@ -4894,7 +4860,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:4898: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4864: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_libiconv=yes"
 else
@@ -4912,13 +4878,13 @@
 echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:4916: checking for libiconv in -liconv" >&5
+echo "configure:4882: checking for libiconv in -liconv" >&5
 ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 4922 "configure"
+#line 4888 "configure"
@@ -4929,7 +4895,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:4933: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4899: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -4948,13 +4914,13 @@
 echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4952: checking for libiconv in -lgiconv" >&5
+echo "configure:4918: checking for libiconv in -lgiconv" >&5
 ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 4958 "configure"
+#line 4924 "configure"
@@ -4965,7 +4931,7 @@
 libiconv()
 ; return 0; }
 EOF
-if { (eval echo configure:4969: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4935: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5002,10 +4968,10 @@
 have_socket=1
 echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:5006: checking for socket" >&5
+echo "configure:4972: checking for socket" >&5
-#line 5009 "configure"
+#line 4975 "configure"
     which can conflict with char socket(); below.  */
@@ -5028,7 +4994,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5032: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4998: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_socket=yes"
 else
@@ -5046,13 +5012,13 @@
 echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:5050: checking for socket in -lsocket" >&5
+echo "configure:5016: checking for socket in -lsocket" >&5
 ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
 LIBS="-lsocket  $LIBS"
-#line 5056 "configure"
+#line 5022 "configure"
@@ -5063,7 +5029,7 @@
 socket()
 ; return 0; }
 EOF
-if { (eval echo configure:5067: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5111,7 +5077,7 @@
 echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:5115: checking for location of zlib includes" >&5
+echo "configure:5081: checking for location of zlib includes" >&5
 case "$with_zlib_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -5137,15 +5103,15 @@
 do
-echo "configure:5141: checking for $ac_hdr" >&5
+echo "configure:5107: checking for $ac_hdr" >&5
-#line 5144 "configure"
+#line 5110 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5149: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5115: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5179,7 +5145,7 @@
 echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:5183: checking for location of zlib library" >&5
+echo "configure:5149: checking for location of zlib library" >&5
 case "$with_zlib_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -5204,13 +5170,13 @@
 echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:5208: checking for deflate in -lz" >&5
+echo "configure:5174: checking for deflate in -lz" >&5
 ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
 LIBS="-lz  $LIBS"
-#line 5214 "configure"
+#line 5180 "configure"
@@ -5221,7 +5187,7 @@
 deflate()
 ; return 0; }
 EOF
-if { (eval echo configure:5225: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5191: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5269,7 +5235,7 @@
 echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:5273: checking for location of External PROJ.4 includes" >&5
+echo "configure:5239: checking for location of External PROJ.4 includes" >&5
 case "$with_proj_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -5295,15 +5261,15 @@
 do
-echo "configure:5299: checking for $ac_hdr" >&5
+echo "configure:5265: checking for $ac_hdr" >&5
-#line 5302 "configure"
+#line 5268 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5307: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5273: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5340,7 +5306,7 @@
 else
 echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:5344: checking External PROJ.4 version" >&5
+echo "configure:5310: checking External PROJ.4 version" >&5
 ac_save_cppflags="$CPPFLAGS"
 CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -5348,7 +5314,7 @@
 else
-#line 5352 "configure"
+#line 5318 "configure"
 #include <stdio.h>
@@ -5360,7 +5326,7 @@
 EOF
-if { (eval echo configure:5364: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:5330: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      proj_ver=`cat conftestdata`
         echo "$ac_t""$proj_ver" 1>&6
@@ -5385,7 +5351,7 @@
 echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:5389: checking for location of External PROJ.4 library" >&5
+echo "configure:5355: checking for location of External PROJ.4 library" >&5
 case "$with_proj_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -5410,13 +5376,13 @@
 echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:5414: checking for pj_get_def in -lproj" >&5
+echo "configure:5380: checking for pj_get_def in -lproj" >&5
 ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
 LIBS="-lproj  $LIBS"
-#line 5420 "configure"
+#line 5386 "configure"
@@ -5427,7 +5393,7 @@
 pj_get_def()
 ; return 0; }
 EOF
-if { (eval echo configure:5431: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5397: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5461,7 +5427,7 @@
 echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:5465: checking for location of External PROJ.4 data files" >&5
+echo "configure:5431: checking for location of External PROJ.4 data files" >&5
 case "$with_proj_share" in
         { echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -5485,14 +5451,14 @@
 # LOC_CHECK_SHARE does not work when cross compiling
 if test "$cross_compiling" = "yes" ; then
     echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:5489: checking for epsg" >&5
+echo "configure:5455: checking for epsg" >&5
 else
 ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:5496: checking for $PROJSHARE/epsg" >&5
+echo "configure:5462: checking for $PROJSHARE/epsg" >&5
@@ -5524,7 +5490,7 @@
 # Extract the first word of "nad2bin", so it can be a program name with args.
 set dummy nad2bin; ac_word=$2
-echo "configure:5528: checking for $ac_word" >&5
+echo "configure:5494: checking for $ac_word" >&5
 case "$NAD2BIN" in
@@ -5564,7 +5530,7 @@
 echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:5568: checking whether to use regex" >&5
+echo "configure:5534: checking whether to use regex" >&5
 echo "$ac_t"""$with_regex"" 1>&6
 case "$with_regex" in
 	"no")	USE_REGEX=	;;
@@ -5584,7 +5550,7 @@
 echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:5588: checking for location of regex includes" >&5
+echo "configure:5554: checking for location of regex includes" >&5
 case "$with_regex_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -5610,15 +5576,15 @@
 do
-echo "configure:5614: checking for $ac_hdr" >&5
+echo "configure:5580: checking for $ac_hdr" >&5
-#line 5617 "configure"
+#line 5583 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5622: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5588: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5652,7 +5618,7 @@
 echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:5656: checking for location of regex library" >&5
+echo "configure:5622: checking for location of regex library" >&5
 case "$with_regex_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -5677,10 +5643,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:5681: checking for regcomp" >&5
+echo "configure:5647: checking for regcomp" >&5
-#line 5684 "configure"
+#line 5650 "configure"
     which can conflict with char regcomp(); below.  */
@@ -5703,7 +5669,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:5707: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5673: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_regcomp=yes"
 else
@@ -5730,13 +5696,13 @@
 echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:5734: checking for regcomp in -lregex" >&5
+echo "configure:5700: checking for regcomp in -lregex" >&5
 ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
 LIBS="-lregex  $LIBS"
-#line 5740 "configure"
+#line 5706 "configure"
@@ -5747,7 +5713,7 @@
 regcomp()
 ; return 0; }
 EOF
-if { (eval echo configure:5751: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5717: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -5797,7 +5763,7 @@
 echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:5801: checking whether to use Readline" >&5
+echo "configure:5767: checking whether to use Readline" >&5
 echo "$ac_t"""$with_readline"" 1>&6
 case "$with_readline" in
 	"no")	USE_READLINE=	;;
@@ -5818,7 +5784,7 @@
 echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:5822: checking for location of Readline includes" >&5
+echo "configure:5788: checking for location of Readline includes" >&5
 case "$with_readline_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -5844,15 +5810,15 @@
 do
-echo "configure:5848: checking for $ac_hdr" >&5
+echo "configure:5814: checking for $ac_hdr" >&5
-#line 5851 "configure"
+#line 5817 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5856: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5822: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5888,15 +5854,15 @@
 do
-echo "configure:5892: checking for $ac_hdr" >&5
+echo "configure:5858: checking for $ac_hdr" >&5
-#line 5895 "configure"
+#line 5861 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:5900: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5866: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -5930,7 +5896,7 @@
 echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:5934: checking for location of Readline library" >&5
+echo "configure:5900: checking for location of Readline library" >&5
 case "$with_readline_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -5955,13 +5921,13 @@
 echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:5959: checking for readline in -lreadline" >&5
+echo "configure:5925: checking for readline in -lreadline" >&5
 ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
 LIBS="-lreadline  $LIBS"
-#line 5965 "configure"
+#line 5931 "configure"
@@ -5972,7 +5938,7 @@
 readline()
 ; return 0; }
 EOF
-if { (eval echo configure:5976: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5942: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6007,13 +5973,13 @@
 echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:6011: checking for add_history in -lhistory" >&5
+echo "configure:5977: checking for add_history in -lhistory" >&5
 ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
 LIBS="-lhistory  $LIBS"
-#line 6017 "configure"
+#line 5983 "configure"
@@ -6024,7 +5990,7 @@
 add_history()
 ; return 0; }
 EOF
-if { (eval echo configure:6028: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5994: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6066,7 +6032,7 @@
 # GDAL option
 echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:6070: checking whether to use GDAL" >&5
+echo "configure:6036: checking whether to use GDAL" >&5
 GDAL_LIBS=
 GDAL_CFLAGS=
@@ -6084,7 +6050,7 @@
   # Extract the first word of "gdal-config", so it can be a program name with args.
 set dummy gdal-config; ac_word=$2
-echo "configure:6088: checking for $ac_word" >&5
+echo "configure:6054: checking for $ac_word" >&5
 case "$GDAL_CONFIG" in
@@ -6139,14 +6105,14 @@
   LIBS="$LIBS $GDAL_LIBS"
   CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 6143 "configure"
+#line 6109 "configure"
 #include <gdal.h>
 int main() {
 GDALOpen("foo", GA_ReadOnly);
 ; return 0; }
 EOF
-if { (eval echo configure:6150: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6116: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
   echo "configure: failed program was:" >&5
@@ -6155,14 +6121,14 @@
   LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 6159 "configure"
+#line 6125 "configure"
 #include <gdal.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:6166: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6132: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
 else
@@ -6194,7 +6160,7 @@
 # libLAS option
 echo $ac_n "checking whether to use libLAS""... $ac_c" 1>&6
-echo "configure:6198: checking whether to use libLAS" >&5
+echo "configure:6164: checking whether to use libLAS" >&5
 LIBLAS_LIBS=
 LIBLAS_CFLAGS=
@@ -6211,7 +6177,7 @@
   # Extract the first word of "liblas-config", so it can be a program name with args.
 set dummy liblas-config; ac_word=$2
-echo "configure:6215: checking for $ac_word" >&5
+echo "configure:6181: checking for $ac_word" >&5
 case "$LIBLAS_CONFIG" in
@@ -6261,14 +6227,14 @@
   CFLAGS="$CFLAGS $LIBLAS_CFLAGS"
   CPPFLAGS="$CPPFLAGS $LIBLAS_INC"
-#line 6265 "configure"
+#line 6231 "configure"
 #include <liblas/capi/liblas.h>
 int main() {
 LASReader_Create("foo");
 ; return 0; }
 EOF
-if { (eval echo configure:6272: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6238: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
@@ -6276,14 +6242,14 @@
   rm -rf conftest*
-#line 6280 "configure"
+#line 6246 "configure"
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:6287: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6253: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   LAS_LIBS="$LAS_LIBS"
 else
@@ -6316,7 +6282,7 @@
 # NetCDF option
 echo $ac_n "checking whether to use NetCDF""... $ac_c" 1>&6
-echo "configure:6320: checking whether to use NetCDF" >&5
+echo "configure:6286: checking whether to use NetCDF" >&5
 NETCDF_LIBS=
 NETCDF_CFLAGS=
@@ -6333,7 +6299,7 @@
   # Extract the first word of "nc-config", so it can be a program name with args.
 set dummy nc-config; ac_word=$2
-echo "configure:6337: checking for $ac_word" >&5
+echo "configure:6303: checking for $ac_word" >&5
 case "$NETCDF_CONFIG" in
@@ -6380,14 +6346,14 @@
   LIBS="$LIBS $NETCDF_LIBS"
   CFLAGS="$CFLAGS $NETCDF_CFLAGS"
-#line 6384 "configure"
+#line 6350 "configure"
 #include <netcdf.h>
 int main() {
 nc_create("foo", NC_CLOBBER, NULL);
 ; return 0; }
 EOF
-if { (eval echo configure:6391: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6357: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
 else
@@ -6395,14 +6361,14 @@
   rm -rf conftest*
-#line 6399 "configure"
+#line 6365 "configure"
 #include <netcdf.h>
 int main() {
 ; return 0; }
 EOF
-if { (eval echo configure:6406: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6372: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   NETCDF_LIBS="$NETCDF_LIBS"
 else
@@ -6433,7 +6399,7 @@
 # GEOS option
 echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:6437: checking whether to use GEOS" >&5
+echo "configure:6403: checking whether to use GEOS" >&5
 GEOS_LIBS=
 GEOS_CFLAGS=
@@ -6451,7 +6417,7 @@
   # Extract the first word of "geos-config", so it can be a program name with args.
 set dummy geos-config; ac_word=$2
-echo "configure:6455: checking for $ac_word" >&5
+echo "configure:6421: checking for $ac_word" >&5
 case "$GEOS_CONFIG" in
@@ -6499,15 +6465,15 @@
 do
-echo "configure:6503: checking for $ac_hdr" >&5
+echo "configure:6469: checking for $ac_hdr" >&5
-#line 6506 "configure"
+#line 6472 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6511: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6477: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6546,13 +6512,13 @@
 echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:6550: checking for initGEOS in -lgeos_c" >&5
+echo "configure:6516: checking for initGEOS in -lgeos_c" >&5
 ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
 LIBS="-lgeos_c  $LIBS"
-#line 6556 "configure"
+#line 6522 "configure"
@@ -6563,7 +6529,7 @@
 initGEOS()
 ; return 0; }
 EOF
-if { (eval echo configure:6567: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6533: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6607,7 +6573,7 @@
 echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:6611: checking whether to use TIFF" >&5
+echo "configure:6577: checking whether to use TIFF" >&5
 echo "$ac_t"""$with_tiff"" 1>&6
 case "$with_tiff" in
 	"no")	USE_TIFF=	;;
@@ -6627,7 +6593,7 @@
 echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:6631: checking for location of TIFF includes" >&5
+echo "configure:6597: checking for location of TIFF includes" >&5
 case "$with_tiff_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -6653,15 +6619,15 @@
 do
-echo "configure:6657: checking for $ac_hdr" >&5
+echo "configure:6623: checking for $ac_hdr" >&5
-#line 6660 "configure"
+#line 6626 "configure"
 #include "confdefs.h"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:6665: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6631: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -6695,7 +6661,7 @@
 echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:6699: checking for location of TIFF library" >&5
+echo "configure:6665: checking for location of TIFF library" >&5
 case "$with_tiff_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -6726,13 +6692,13 @@
 echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:6730: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6696: checking for TIFFOpen in -ltiff" >&5
 ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
 LIBS="-ltiff  $LIBS"
-#line 6736 "configure"
+#line 6702 "configure"
@@ -6743,7 +6709,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6747: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6713: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6762,13 +6728,13 @@
-echo "configure:6766: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6732: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $MATHLIB $LIBS"
-#line 6772 "configure"
+#line 6738 "configure"
@@ -6779,7 +6745,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6783: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6749: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6798,13 +6764,13 @@
-echo "configure:6802: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6768: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $LIBS"
 cat > conftest.$ac_ext <<EOF
-#line 6808 "configure"
+#line 6774 "configure"
@@ -6815,7 +6781,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6819: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6785: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6834,13 +6800,13 @@
-echo "configure:6838: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6804: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 6844 "configure"
+#line 6810 "configure"
@@ -6851,7 +6817,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6855: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6870,13 +6836,13 @@
-echo "configure:6874: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6840: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $LIBS"
-#line 6880 "configure"
+#line 6846 "configure"
@@ -6887,7 +6853,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6891: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6857: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6906,13 +6872,13 @@
-echo "configure:6910: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6876: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $MATHLIB $LIBS"
-#line 6916 "configure"
+#line 6882 "configure"
@@ -6923,7 +6889,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6927: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6893: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6942,13 +6908,13 @@
-echo "configure:6946: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6912: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $ZLIB $LIBS"
-#line 6952 "configure"
+#line 6918 "configure"
@@ -6959,7 +6925,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6963: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6929: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -6978,13 +6944,13 @@
-echo "configure:6982: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6948: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff -ljpeg $ZLIB $MATHLIB $LIBS"
-#line 6988 "configure"
+#line 6954 "configure"
@@ -6995,7 +6961,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:6999: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6965: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7093,7 +7059,7 @@
 echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:7097: checking whether to use PNG" >&5
+echo "configure:7063: checking whether to use PNG" >&5
 echo "$ac_t"""$with_png"" 1>&6
 case "$with_png" in
 	"no")	USE_PNG=	;;
@@ -7112,7 +7078,7 @@
 echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:7116: checking for location of PNG includes" >&5
+echo "configure:7082: checking for location of PNG includes" >&5
 case "$with_png_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -7138,15 +7104,15 @@
 do
-echo "configure:7142: checking for $ac_hdr" >&5
+echo "configure:7108: checking for $ac_hdr" >&5
-#line 7145 "configure"
+#line 7111 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7150: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7116: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7180,7 +7146,7 @@
 echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:7184: checking for location of PNG library" >&5
+echo "configure:7150: checking for location of PNG library" >&5
 case "$with_png_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -7205,13 +7171,13 @@
 echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:7209: checking for png_read_image in -lpng" >&5
+echo "configure:7175: checking for png_read_image in -lpng" >&5
 ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
 LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 7215 "configure"
+#line 7181 "configure"
@@ -7222,7 +7188,7 @@
 png_read_image()
 ; return 0; }
 EOF
-if { (eval echo configure:7226: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7192: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7264,7 +7230,7 @@
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:7268: checking whether to use PostgreSQL" >&5
+echo "configure:7234: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -7291,7 +7257,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:7295: checking for location of PostgreSQL includes" >&5
+echo "configure:7261: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -7317,15 +7283,15 @@
 do
-echo "configure:7321: checking for $ac_hdr" >&5
+echo "configure:7287: checking for $ac_hdr" >&5
-#line 7324 "configure"
+#line 7290 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7329: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7295: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7363,7 +7329,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:7367: checking for location of PostgreSQL library" >&5
+echo "configure:7333: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -7392,13 +7358,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:7396: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7362: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 7402 "configure"
+#line 7368 "configure"
@@ -7409,7 +7375,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7413: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7379: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7428,13 +7394,13 @@
-echo "configure:7432: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7398: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 7438 "configure"
+#line 7404 "configure"
@@ -7445,7 +7411,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7449: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7415: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7464,13 +7430,13 @@
-echo "configure:7468: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7434: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
-#line 7474 "configure"
+#line 7440 "configure"
@@ -7481,7 +7447,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7485: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7451: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7500,13 +7466,13 @@
-echo "configure:7504: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7470: checking for PQsetdbLogin in -lpq" >&5
 ac_save_LIBS="$LIBS"
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 7510 "configure"
+#line 7476 "configure"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -7517,7 +7483,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:7521: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7487: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -7574,13 +7540,13 @@
 ac_save_ldflags="$LDFLAGS"
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:7578: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7544: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 7584 "configure"
+#line 7550 "configure"
@@ -7591,7 +7557,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:7595: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7561: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7613,13 +7579,13 @@
-echo "configure:7617: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7583: checking for PQcmdTuples in -lpq" >&5
-#line 7623 "configure"
+#line 7589 "configure"
@@ -7630,7 +7596,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:7634: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7600: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7673,7 +7639,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:7677: checking whether to use MySQL" >&5
+echo "configure:7643: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -7693,7 +7659,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:7697: checking for location of MySQL includes" >&5
+echo "configure:7663: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -7719,15 +7685,15 @@
 do
-echo "configure:7723: checking for $ac_hdr" >&5
+echo "configure:7689: checking for $ac_hdr" >&5
-#line 7726 "configure"
+#line 7692 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:7731: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7697: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -7764,7 +7730,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:7768: checking for location of MySQL library" >&5
+echo "configure:7734: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -7795,13 +7761,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:7799: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7765: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 7805 "configure"
+#line 7771 "configure"
@@ -7812,7 +7778,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7816: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7782: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7831,13 +7797,13 @@
-echo "configure:7835: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7801: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 7841 "configure"
+#line 7807 "configure"
@@ -7848,7 +7814,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7852: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7818: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7867,13 +7833,13 @@
-echo "configure:7871: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7837: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 7877 "configure"
+#line 7843 "configure"
@@ -7884,7 +7850,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7888: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7854: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7903,13 +7869,13 @@
-echo "configure:7907: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7873: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 7913 "configure"
+#line 7879 "configure"
@@ -7920,7 +7886,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7924: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7890: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7939,13 +7905,13 @@
-echo "configure:7943: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7909: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 7949 "configure"
+#line 7915 "configure"
@@ -7956,7 +7922,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7960: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -7975,13 +7941,13 @@
-echo "configure:7979: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7945: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 7985 "configure"
+#line 7951 "configure"
@@ -7992,7 +7958,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:7996: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7962: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8011,13 +7977,13 @@
-echo "configure:8015: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7981: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 8021 "configure"
+#line 7987 "configure"
@@ -8028,7 +7994,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8032: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7998: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8047,13 +8013,13 @@
-echo "configure:8051: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:8017: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 8057 "configure"
+#line 8023 "configure"
@@ -8064,7 +8030,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:8068: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8034: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8154,7 +8120,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:8158: checking for $ac_word" >&5
+echo "configure:8124: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -8203,10 +8169,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:8207: checking for mysql_server_init" >&5
+echo "configure:8173: checking for mysql_server_init" >&5
-#line 8210 "configure"
+#line 8176 "configure"
     which can conflict with char mysql_server_init(); below.  */
@@ -8232,7 +8198,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:8236: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8202: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -8284,7 +8250,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:8288: checking whether to use SQLite" >&5
+echo "configure:8254: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -8304,7 +8270,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:8308: checking for location of SQLite includes" >&5
+echo "configure:8274: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -8330,15 +8296,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:8334: checking for $ac_hdr" >&5
+echo "configure:8300: checking for $ac_hdr" >&5
-#line 8337 "configure"
+#line 8303 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:8342: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8308: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -8381,7 +8347,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:8385: checking for location of SQLite library" >&5
+echo "configure:8351: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -8410,13 +8376,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:8414: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8380: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 8420 "configure"
+#line 8386 "configure"
@@ -8427,7 +8393,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8431: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8397: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8446,13 +8412,13 @@
-echo "configure:8450: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8416: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 8456 "configure"
+#line 8422 "configure"
@@ -8463,7 +8429,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8467: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8433: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8482,13 +8448,13 @@
-echo "configure:8486: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8452: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 8492 "configure"
+#line 8458 "configure"
@@ -8499,7 +8465,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8503: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8469: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8518,13 +8484,13 @@
-echo "configure:8522: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8488: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 8528 "configure"
+#line 8494 "configure"
@@ -8535,7 +8501,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:8539: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8505: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8599,520 +8565,6 @@
 # Done checking SQLite
-# Enable FFMPEG option
-echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:8608: checking whether to use FFMPEG" >&5
-echo "$ac_t"""$with_ffmpeg"" 1>&6
-case "$with_ffmpeg" in
-	"no")	USE_FFMPEG=	;;
-	"yes")	USE_FFMPEG="1"	;;
-	*)	{ echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; }	;;
-esac
-FFMPEGINCPATH=
-FFMPEGLIBPATH=
-FFMPEGLIB=
-if test -n "$USE_FFMPEG"; then
-# With FFMPEG includes directory
-echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:8628: checking for location of FFMPEG includes" >&5
-case "$with_ffmpeg_includes" in
-y | ye | yes | n | no)
-	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
-esac
-echo "$ac_t""$with_ffmpeg_includes" 1>&6
-if test -n "$with_ffmpeg_includes" ; then
-    for dir in $with_ffmpeg_includes; do
-        if test -d "$dir"; then
-            FFMPEGINCPATH="$FFMPEGINCPATH -I$dir"
-        else
-            { echo "configure: error: *** FFMPEG includes directory $dir does not exist." 1>&2; exit 1; }
-        fi
-    done
-fi
-ac_save_cppflags="$CPPFLAGS"
-CPPFLAGS="$FFMPEGINCPATH $CPPFLAGS"
-for ac_hdr in avcodec.h
-do
-ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
-echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:8654: checking for $ac_hdr" >&5
-cat > conftest.$ac_ext <<EOF
-#line 8657 "configure"
-#include "confdefs.h"
-#include <$ac_hdr>
-EOF
-ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:8662: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
-ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
-if test -z "$ac_err"; then
-  rm -rf conftest*
-  eval "ac_cv_header_$ac_safe=yes"
-else
-  echo "$ac_err" >&5
-  echo "configure: failed program was:" >&5
-  cat conftest.$ac_ext >&5
-  rm -rf conftest*
-  eval "ac_cv_header_$ac_safe=no"
-fi
-rm -f conftest*
-if eval "test \"`echo '$ac_cv_header_'$ac_safe`\" = yes"; then
-  echo "$ac_t""yes" 1>&6
-    ac_tr_hdr=HAVE_`echo $ac_hdr | sed 'y%abcdefghijklmnopqrstuvwxyz./-%ABCDEFGHIJKLMNOPQRSTUVWXYZ___%'`
-  cat >> confdefs.h <<EOF
-#define $ac_tr_hdr 1
-EOF
-else
-  echo "$ac_t""no" 1>&6
-{ echo "configure: error: *** Unable to locate FFMPEG includes." 1>&2; exit 1; }
-fi
-done
-CPPFLAGS=$ac_save_cppflags
-for ac_hdr in avformat.h
-do
-echo "configure:8698: checking for $ac_hdr" >&5
-#line 8701 "configure"
-#include <$ac_hdr>
-EOF
-{ (eval echo configure:8706: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-EOF
-else
-fi
-done
-for ac_hdr in swscale.h
-do
-echo "configure:8742: checking for $ac_hdr" >&5
-#line 8745 "configure"
-#include <$ac_hdr>
-EOF
-{ (eval echo configure:8750: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-EOF
-else
-fi
-done
-cat >> confdefs.h <<\EOF
-#define HAVE_FFMPEG 1
-EOF
-fi # $USE_FFMPEG
-# With FFMPEG library directory
-echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:8793: checking for location of FFMPEG library" >&5
-case "$with_ffmpeg_libs" in
-	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
-esac
-echo "$ac_t""$with_ffmpeg_libs" 1>&6
-if test -n "$with_ffmpeg_libs"; then
-    for dir in $with_ffmpeg_libs; do
-            FFMPEGLIBPATH="$FFMPEGLIBPATH -L$dir"
-        else
-            { echo "configure: error: *** FFMPEG library directory $dir does not exist." 1>&2; exit 1; }
-        fi
-    done
-fi
-ac_save_ldflags="$LDFLAGS"
-LDFLAGS="$FFMPEGLIBPATH $LDFLAGS"
-echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:8820: checking for av_free in -lavutil" >&5
-ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
-ac_save_LIBS="$LIBS"
-LIBS="-lavutil  $LIBS"
-#line 8826 "configure"
-/* Override any gcc2 internal prototype to avoid an error.  */
-/* We use char because int might match the return type of a gcc2
-    builtin and then its argument prototype would still apply.  */
-char av_free();
-int main() {
-av_free()
-; return 0; }
-EOF
-if { (eval echo configure:8837: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-  eval "ac_cv_lib_$ac_lib_var=yes"
-else
-  rm -rf conftest*
-  eval "ac_cv_lib_$ac_lib_var=no"
-fi
-rm -f conftest*
-LIBS="$ac_save_LIBS"
-if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
-  FFMPEGLIB="$FFMPEGLIB -lavutil "
-else
-echo "configure:8856: checking for av_free in -lavutil" >&5
-LIBS="-lavutil $MATHLIB $LIBS"
-#line 8862 "configure"
-char av_free();
-int main() {
-av_free()
-; return 0; }
-EOF
-if { (eval echo configure:8873: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-  FFMPEGLIB="$FFMPEGLIB -lavutil $MATHLIB"
-else
-LDFLAGS=${ac_save_ldflags}
-    { echo "configure: error: *** Unable to locate FFMPEG library." 1>&2; exit 1; }
-fi
-fi
-echo $ac_n "checking for avcodec_register in -lavcodec""... $ac_c" 1>&6
-echo "configure:8918: checking for avcodec_register in -lavcodec" >&5
-ac_lib_var=`echo avcodec'_'avcodec_register | sed 'y%./+-%__p_%'`
-LIBS="-lavcodec $FFMPEGLIB  $LIBS"
-#line 8924 "configure"
-char avcodec_register();
-int main() {
-avcodec_register()
-; return 0; }
-EOF
-if { (eval echo configure:8935: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-  FFMPEGLIB="$FFMPEGLIB -lavcodec "
-else
-echo "configure:8954: checking for avcodec_register in -lavcodec" >&5
-LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 8960 "configure"
-int main() {
-avcodec_register()
-; return 0; }
-EOF
-if { (eval echo configure:8971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-  FFMPEGLIB="$FFMPEGLIB -lavcodec $MATHLIB"
-else
-fi
-fi
-echo $ac_n "checking for avformat_alloc_context in -lavformat""... $ac_c" 1>&6
-echo "configure:9016: checking for avformat_alloc_context in -lavformat" >&5
-ac_lib_var=`echo avformat'_'avformat_alloc_context | sed 'y%./+-%__p_%'`
-LIBS="-lavformat $FFMPEGLIB  $LIBS"
-#line 9022 "configure"
-char avformat_alloc_context();
-int main() {
-avformat_alloc_context()
-; return 0; }
-EOF
-if { (eval echo configure:9033: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-  FFMPEGLIB="$FFMPEGLIB -lavformat "
-else
-echo "configure:9052: checking for avformat_alloc_context in -lavformat" >&5
-LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 9058 "configure"
-int main() {
-; return 0; }
-EOF
-if { (eval echo configure:9069: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
-  rm -rf conftest*
-else
-  rm -rf conftest*
-fi
-rm -f conftest*
-  FFMPEGLIB="$FFMPEGLIB -lavformat $MATHLIB"
-else
-fi
-fi
-fi # $USE_FFMPEG
-# Done checking FFMPEG
 # Enable OpenGL option
 OPENGLINC=
@@ -9124,7 +8576,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:9128: checking whether to use OpenGL" >&5
+echo "configure:8580: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -9158,7 +8610,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:9162: checking for location of OpenGL includes" >&5
+echo "configure:8614: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -9184,15 +8636,15 @@
 do
-echo "configure:9188: checking for $ac_hdr" >&5
+echo "configure:8640: checking for $ac_hdr" >&5
-#line 9191 "configure"
+#line 8643 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9196: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8648: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9226,7 +8678,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:9230: checking for location of OpenGL library" >&5
+echo "configure:8682: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -9255,13 +8707,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:9259: checking for glBegin in -lGL" >&5
+echo "configure:8711: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 9265 "configure"
+#line 8717 "configure"
@@ -9272,7 +8724,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9276: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8728: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9291,13 +8743,13 @@
-echo "configure:9295: checking for glBegin in -lGL" >&5
+echo "configure:8747: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 9301 "configure"
+#line 8753 "configure"
@@ -9308,7 +8760,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9312: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8764: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9327,13 +8779,13 @@
-echo "configure:9331: checking for glBegin in -lGL" >&5
+echo "configure:8783: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 9337 "configure"
+#line 8789 "configure"
@@ -9344,7 +8796,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9348: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8800: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9363,13 +8815,13 @@
-echo "configure:9367: checking for glBegin in -lGL" >&5
+echo "configure:8819: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 9373 "configure"
+#line 8825 "configure"
@@ -9380,7 +8832,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:9384: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8836: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9442,13 +8894,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:9446: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:8898: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 9452 "configure"
+#line 8904 "configure"
@@ -9459,7 +8911,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:9463: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8915: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9478,13 +8930,13 @@
-echo "configure:9482: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:8934: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 9488 "configure"
+#line 8940 "configure"
@@ -9495,7 +8947,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:9499: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8951: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9542,10 +8994,10 @@
 LIBS=" $OPENGLLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:9546: checking for glXCreatePbuffer" >&5
+echo "configure:8998: checking for glXCreatePbuffer" >&5
-#line 9549 "configure"
+#line 9001 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -9568,7 +9020,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9572: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9024: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -9605,10 +9057,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:9609: checking for glXCreateGLXPixmap" >&5
+echo "configure:9061: checking for glXCreateGLXPixmap" >&5
-#line 9612 "configure"
+#line 9064 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -9631,7 +9083,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9635: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9087: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -9674,7 +9126,7 @@
 echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:9678: checking for location of OpenGL framework" >&5
+echo "configure:9130: checking for location of OpenGL framework" >&5
 case "$with_opengl_framework" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -9698,15 +9150,15 @@
 do
-echo "configure:9702: checking for $ac_hdr" >&5
+echo "configure:9154: checking for $ac_hdr" >&5
-#line 9705 "configure"
+#line 9157 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9710: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9162: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9742,10 +9194,10 @@
 LIBS="-framework OpenGL -framework AGL -framework ApplicationServices  $LIBS"
 LDFLAGS="$OPENGLPATH $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:9746: checking for glBegin" >&5
+echo "configure:9198: checking for glBegin" >&5
-#line 9749 "configure"
+#line 9201 "configure"
     which can conflict with char glBegin(); below.  */
@@ -9768,7 +9220,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9772: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9224: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -9805,10 +9257,10 @@
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:9809: checking for gluBeginCurve" >&5
+echo "configure:9261: checking for gluBeginCurve" >&5
-#line 9812 "configure"
+#line 9264 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -9831,7 +9283,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9835: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9287: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -9879,7 +9331,7 @@
-echo "configure:9883: checking for location of OpenGL includes" >&5
+echo "configure:9335: checking for location of OpenGL includes" >&5
@@ -9905,15 +9357,15 @@
 do
-echo "configure:9909: checking for $ac_hdr" >&5
+echo "configure:9361: checking for $ac_hdr" >&5
-#line 9912 "configure"
+#line 9364 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9917: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9369: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9947,7 +9399,7 @@
-echo "configure:9951: checking for location of OpenGL library" >&5
+echo "configure:9403: checking for location of OpenGL library" >&5
@@ -9972,18 +9424,18 @@
 ac_save_libs="$LIBS"
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:9976: checking for OpenGL library" >&5
+echo "configure:9428: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 9980 "configure"
+#line 9432 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:9987: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9439: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -10007,18 +9459,18 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:10011: checking for GLU library" >&5
+echo "configure:9463: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
-#line 10015 "configure"
+#line 9467 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:10022: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9474: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -10067,7 +9519,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:10071: checking whether to use ODBC" >&5
+echo "configure:9523: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -10086,7 +9538,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:10090: checking for location of ODBC includes" >&5
+echo "configure:9542: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -10112,15 +9564,15 @@
 do
-echo "configure:10116: checking for $ac_hdr" >&5
+echo "configure:9568: checking for $ac_hdr" >&5
-#line 10119 "configure"
+#line 9571 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10124: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9576: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10154,7 +9606,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:10158: checking for location of ODBC library" >&5
+echo "configure:9610: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -10179,13 +9631,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:10183: checking for SQLConnect in -lodbc" >&5
+echo "configure:9635: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 10189 "configure"
+#line 9641 "configure"
@@ -10196,7 +9648,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:10200: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9652: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10221,13 +9673,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:10225: checking for SQLConnect in -liodbc" >&5
+echo "configure:9677: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 10231 "configure"
+#line 9683 "configure"
@@ -10238,7 +9690,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:10242: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9694: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10263,11 +9715,11 @@
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:10267: checking for ODBC library" >&5
+echo "configure:9719: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 10271 "configure"
+#line 9723 "configure"
 #include <windows.h>
 #include <sql.h>
@@ -10275,7 +9727,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:10279: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9731: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -10324,7 +9776,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:10328: checking whether to use FFTW" >&5
+echo "configure:9780: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -10343,7 +9795,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:10347: checking for location of FFTW includes" >&5
+echo "configure:9799: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -10369,15 +9821,15 @@
 do
-echo "configure:10373: checking for $ac_hdr" >&5
+echo "configure:9825: checking for $ac_hdr" >&5
-#line 10376 "configure"
+#line 9828 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10381: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9833: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10405,15 +9857,15 @@
 do
-echo "configure:10409: checking for $ac_hdr" >&5
+echo "configure:9861: checking for $ac_hdr" >&5
-#line 10412 "configure"
+#line 9864 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10417: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9869: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10441,15 +9893,15 @@
 do
-echo "configure:10445: checking for $ac_hdr" >&5
+echo "configure:9897: checking for $ac_hdr" >&5
-#line 10448 "configure"
+#line 9900 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10453: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9905: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10495,7 +9947,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:10499: checking for location of FFTW library" >&5
+echo "configure:9951: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -10520,13 +9972,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:10524: checking for fftw_execute in -lfftw3" >&5
+echo "configure:9976: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 10530 "configure"
+#line 9982 "configure"
@@ -10537,7 +9989,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:10541: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9993: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10562,13 +10014,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:10566: checking for fftwnd_one in -lfftw" >&5
+echo "configure:10018: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 10572 "configure"
+#line 10024 "configure"
@@ -10579,7 +10031,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:10583: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10035: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10604,13 +10056,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:10608: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:10060: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 10614 "configure"
+#line 10066 "configure"
@@ -10621,7 +10073,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:10625: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10077: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10678,7 +10130,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:10682: checking whether to use BLAS" >&5
+echo "configure:10134: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -10699,7 +10151,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:10703: checking for location of BLAS includes" >&5
+echo "configure:10155: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -10719,7 +10171,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:10723: checking for location of BLAS library" >&5
+echo "configure:10175: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -10745,15 +10197,15 @@
 do
-echo "configure:10749: checking for $ac_hdr" >&5
+echo "configure:10201: checking for $ac_hdr" >&5
-#line 10752 "configure"
+#line 10204 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10757: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10209: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10788,13 +10240,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:10792: checking for dnrm2_ in -lblas" >&5
+echo "configure:10244: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 10798 "configure"
+#line 10250 "configure"
@@ -10805,7 +10257,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:10809: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10261: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10824,13 +10276,13 @@
-echo "configure:10828: checking for dnrm2_ in -lblas" >&5
+echo "configure:10280: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 10834 "configure"
+#line 10286 "configure"
@@ -10841,7 +10293,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:10845: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10297: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10885,13 +10337,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:10889: checking for ATL_xerbla in -latlas" >&5
+echo "configure:10341: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 LIBS="-latlas  $LIBS"
-#line 10895 "configure"
+#line 10347 "configure"
@@ -10902,7 +10354,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:10906: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10358: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10917,13 +10369,13 @@
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:10921: checking for sgemm_ in -lf77blas" >&5
+echo "configure:10373: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 10927 "configure"
+#line 10379 "configure"
@@ -10934,7 +10386,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:10938: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10390: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10949,13 +10401,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:10953: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:10405: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 10959 "configure"
+#line 10411 "configure"
@@ -10966,7 +10418,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:10970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10422: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11012,16 +10464,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:11016: checking for sgemm in $vlib_flags" >&5
+echo "configure:10468: checking for sgemm in $vlib_flags" >&5
-#line 11018 "configure"
+#line 10470 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:11025: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10477: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -11039,13 +10491,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:11043: checking for sgemm_ in -lblas" >&5
+echo "configure:10495: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas  $LIBS"
-#line 11049 "configure"
+#line 10501 "configure"
@@ -11056,7 +10508,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:11060: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10512: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11071,13 +10523,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:11075: checking for dgemm_ in -ldgemm" >&5
+echo "configure:10527: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 11081 "configure"
+#line 10533 "configure"
@@ -11088,7 +10540,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:11092: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10544: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11103,13 +10555,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:11107: checking for sgemm_ in -lsgemm" >&5
+echo "configure:10559: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 11113 "configure"
+#line 10565 "configure"
@@ -11120,7 +10572,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:11124: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10576: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11154,13 +10606,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:11158: checking for acosp in -lsunmath" >&5
+echo "configure:10610: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 11164 "configure"
+#line 10616 "configure"
@@ -11171,7 +10623,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:11175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10627: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11186,13 +10638,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:11190: checking for sgemm_ in -lsunperf" >&5
+echo "configure:10642: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 11196 "configure"
+#line 10648 "configure"
@@ -11203,7 +10655,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:11207: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10659: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11233,13 +10685,13 @@
 # Generic BLAS library
-echo "configure:11237: checking for sgemm_ in -lblas" >&5
+echo "configure:10689: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 11243 "configure"
+#line 10695 "configure"
@@ -11250,7 +10702,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:11254: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10706: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11289,7 +10741,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:11293: checking whether to use LAPACK" >&5
+echo "configure:10745: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -11314,7 +10766,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:11318: checking for location of LAPACK includes" >&5
+echo "configure:10770: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -11334,7 +10786,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:11338: checking for location of LAPACK library" >&5
+echo "configure:10790: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -11360,15 +10812,15 @@
 do
-echo "configure:11364: checking for $ac_hdr" >&5
+echo "configure:10816: checking for $ac_hdr" >&5
-#line 11367 "configure"
+#line 10819 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11372: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10824: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11400,10 +10852,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:11404: checking for dsegv_" >&5
+echo "configure:10856: checking for dsegv_" >&5
-#line 11407 "configure"
+#line 10859 "configure"
     which can conflict with char dsegv_(); below.  */
@@ -11426,7 +10878,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11430: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10882: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -11453,13 +10905,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:11457: checking for desgv_ in -llapack" >&5
+echo "configure:10909: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 11463 "configure"
+#line 10915 "configure"
@@ -11470,7 +10922,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:11474: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10926: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11502,13 +10954,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:11506: checking for dgesv_ in -llapack" >&5
+echo "configure:10958: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 11512 "configure"
+#line 10964 "configure"
@@ -11519,7 +10971,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:11523: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10975: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11538,13 +10990,13 @@
-echo "configure:11542: checking for dgesv_ in -llapack" >&5
+echo "configure:10994: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 11548 "configure"
+#line 11000 "configure"
@@ -11555,7 +11007,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:11559: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11011: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11611,7 +11063,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:11615: checking whether to use Cairo" >&5
+echo "configure:11067: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -11643,7 +11095,7 @@
 echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:11647: checking for location of cairo includes" >&5
+echo "configure:11099: checking for location of cairo includes" >&5
 case "$with_cairo_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -11669,15 +11121,15 @@
 do
-echo "configure:11673: checking for $ac_hdr" >&5
+echo "configure:11125: checking for $ac_hdr" >&5
-#line 11676 "configure"
+#line 11128 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11681: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11133: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11713,7 +11165,7 @@
 echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:11717: checking for location of cairo library" >&5
+echo "configure:11169: checking for location of cairo library" >&5
 case "$with_cairo_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -11733,7 +11185,7 @@
 echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:11737: checking for cairo linking flags" >&5
+echo "configure:11189: checking for cairo linking flags" >&5
 case "$with_cairo_ldflags" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -11749,10 +11201,10 @@
 LIBS=" $CAIROLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:11753: checking for cairo_create" >&5
+echo "configure:11205: checking for cairo_create" >&5
-#line 11756 "configure"
+#line 11208 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -11775,7 +11227,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11779: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11231: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -11809,10 +11261,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:11813: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:11265: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 11816 "configure"
+#line 11268 "configure"
     which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below.  */
@@ -11835,7 +11287,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11839: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11291: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
 else
@@ -11868,10 +11320,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:11872: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:11324: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 11875 "configure"
+#line 11327 "configure"
     which can conflict with char cairo_xlib_surface_get_xrender_format(); below.  */
@@ -11894,7 +11346,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11898: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11350: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
 else
@@ -11936,7 +11388,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:11940: checking whether to use FreeType" >&5
+echo "configure:11392: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -11955,7 +11407,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:11959: checking for location of FreeType includes" >&5
+echo "configure:11411: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -11981,15 +11433,15 @@
 do
-echo "configure:11985: checking for $ac_hdr" >&5
+echo "configure:11437: checking for $ac_hdr" >&5
-#line 11988 "configure"
+#line 11440 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11993: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11445: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12023,7 +11475,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:12027: checking for location of FreeType library" >&5
+echo "configure:11479: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -12048,13 +11500,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:12052: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:11504: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 12058 "configure"
+#line 11510 "configure"
@@ -12065,7 +11517,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:12069: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11521: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12106,7 +11558,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:12110: checking whether to use NLS" >&5
+echo "configure:11562: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -12126,10 +11578,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:12130: checking for gettext" >&5
+echo "configure:11582: checking for gettext" >&5
-#line 12133 "configure"
+#line 11585 "configure"
     which can conflict with char gettext(); below.  */
@@ -12152,7 +11604,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12156: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11608: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -12170,13 +11622,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:12174: checking for gettext in -lintl" >&5
+echo "configure:11626: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 12180 "configure"
+#line 11632 "configure"
@@ -12187,7 +11639,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:12191: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11643: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12222,7 +11674,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:12226: checking whether to use C++" >&5
+echo "configure:11678: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -12238,7 +11690,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
-echo "configure:12242: checking for $ac_word" >&5
+echo "configure:11694: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -12267,7 +11719,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:12271: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:11723: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -12278,12 +11730,12 @@
 cat > conftest.$ac_ext << EOF
-#line 12282 "configure"
+#line 11734 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:12287: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11739: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -12309,19 +11761,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:12313: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:11765: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:12318: checking whether we are using GNU C++" >&5
+echo "configure:11770: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:12325: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:11777: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -12339,7 +11791,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:12343: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:11795: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -12367,58 +11819,7 @@
   fi
 fi
-for ac_declaration in \
-   '#include <stdlib.h>' \
-   'extern "C" void std::exit (int) throw (); using std::exit;' \
-   'extern "C" void std::exit (int); using std::exit;' \
-   'extern "C" void exit (int) throw ();' \
-   'extern "C" void exit (int);' \
-   'void exit (int);'
-do
-  cat > conftest.$ac_ext <<EOF
-#line 12381 "configure"
-#include <stdlib.h>
-$ac_declaration
-int main() {
-exit (42);
-; return 0; }
-EOF
-if { (eval echo configure:12389: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
-  rm -rf conftest*
-  continue
-fi
-rm -f conftest*
-#line 12399 "configure"
-$ac_declaration
-int main() {
-exit (42);
-; return 0; }
-EOF
-if { (eval echo configure:12406: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
-  rm -rf conftest*
-  break
-else
-fi
-rm -f conftest*
-done
-if test -n "$ac_declaration"; then
-  echo '#ifdef __cplusplus' >>confdefs.h
-  echo $ac_declaration      >>confdefs.h
-  echo '#endif'             >>confdefs.h
-fi
-else
 	CXX=
 	CXXFLAGS=
@@ -12431,7 +11832,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:12435: checking whether to use openDWG" >&5
+echo "configure:11836: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -12451,7 +11852,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:12455: checking for location of openDGW includes" >&5
+echo "configure:11856: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -12477,15 +11878,15 @@
 do
-echo "configure:12481: checking for $ac_hdr" >&5
+echo "configure:11882: checking for $ac_hdr" >&5
-#line 12484 "configure"
+#line 11885 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12489: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11890: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12519,7 +11920,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:12523: checking for location of openDWG library" >&5
+echo "configure:11924: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -12560,7 +11961,7 @@
 echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:12564: checking whether to use POSIX threads" >&5
+echo "configure:11965: checking whether to use POSIX threads" >&5
 echo "$ac_t"""$with_pthread"" 1>&6
 case "$with_pthread" in
 	"no")	USE_PTHREAD=	;;
@@ -12580,7 +11981,7 @@
 echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:12584: checking for location of POSIX threads includes" >&5
+echo "configure:11985: checking for location of POSIX threads includes" >&5
 case "$with_pthread_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -12606,15 +12007,15 @@
 do
-echo "configure:12610: checking for $ac_hdr" >&5
+echo "configure:12011: checking for $ac_hdr" >&5
-#line 12613 "configure"
+#line 12014 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12618: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12019: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12648,7 +12049,7 @@
 echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:12652: checking for location of POSIX threads library" >&5
+echo "configure:12053: checking for location of POSIX threads library" >&5
 case "$with_pthread_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -12673,10 +12074,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:12677: checking for pthread_create" >&5
+echo "configure:12078: checking for pthread_create" >&5
-#line 12680 "configure"
+#line 12081 "configure"
     which can conflict with char pthread_create(); below.  */
@@ -12699,7 +12100,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12703: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12104: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_pthread_create=yes"
 else
@@ -12726,13 +12127,13 @@
 echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:12730: checking for pthread_create in -lpthread" >&5
+echo "configure:12131: checking for pthread_create in -lpthread" >&5
 ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
 LIBS="-lpthread  $LIBS"
-#line 12736 "configure"
+#line 12137 "configure"
@@ -12743,7 +12144,7 @@
 pthread_create()
 ; return 0; }
 EOF
-if { (eval echo configure:12747: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12148: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12793,7 +12194,7 @@
 echo $ac_n "checking whether to use OpenMP""... $ac_c" 1>&6
-echo "configure:12797: checking whether to use OpenMP" >&5
+echo "configure:12198: checking whether to use OpenMP" >&5
 echo "$ac_t"""$with_openmp"" 1>&6
 case "$with_openmp" in
 	"no")	USE_OPENMP=	;;
@@ -12814,7 +12215,7 @@
 echo $ac_n "checking for location of OpenMP includes""... $ac_c" 1>&6
-echo "configure:12818: checking for location of OpenMP includes" >&5
+echo "configure:12219: checking for location of OpenMP includes" >&5
 case "$with_openmp_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-openmp-includes." 1>&2; exit 1; }
@@ -12840,15 +12241,15 @@
 do
-echo "configure:12844: checking for $ac_hdr" >&5
+echo "configure:12245: checking for $ac_hdr" >&5
-#line 12847 "configure"
+#line 12248 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12852: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12253: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12886,7 +12287,7 @@
 echo $ac_n "checking for location of OpenMP library""... $ac_c" 1>&6
-echo "configure:12890: checking for location of OpenMP library" >&5
+echo "configure:12291: checking for location of OpenMP library" >&5
 case "$with_openmp_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-openmp-libs." 1>&2; exit 1; }
@@ -12911,10 +12312,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for GOMP_parallel_start""... $ac_c" 1>&6
-echo "configure:12915: checking for GOMP_parallel_start" >&5
+echo "configure:12316: checking for GOMP_parallel_start" >&5
-#line 12918 "configure"
+#line 12319 "configure"
     which can conflict with char GOMP_parallel_start(); below.  */
@@ -12937,7 +12338,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12941: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12342: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_GOMP_parallel_start=yes"
 else
@@ -12964,13 +12365,13 @@
 echo $ac_n "checking for GOMP_parallel_start in -lgomp""... $ac_c" 1>&6
-echo "configure:12968: checking for GOMP_parallel_start in -lgomp" >&5
+echo "configure:12369: checking for GOMP_parallel_start in -lgomp" >&5
 ac_lib_var=`echo gomp'_'GOMP_parallel_start | sed 'y%./+-%__p_%'`
 LIBS="-lgomp  $LIBS"
-#line 12974 "configure"
+#line 12375 "configure"
@@ -12981,7 +12382,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:12985: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12386: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13054,7 +12455,7 @@
 echo $ac_n "checking whether to use OpenCL""... $ac_c" 1>&6
-echo "configure:13058: checking whether to use OpenCL" >&5
+echo "configure:12459: checking whether to use OpenCL" >&5
 echo "$ac_t"""$with_opencl"" 1>&6
 case "$with_opencl" in
 	"no")	USE_OPENCL=	;;
@@ -13074,7 +12475,7 @@
 echo $ac_n "checking for location of OpenCL includes""... $ac_c" 1>&6
-echo "configure:13078: checking for location of OpenCL includes" >&5
+echo "configure:12479: checking for location of OpenCL includes" >&5
 case "$with_opencl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opencl-includes." 1>&2; exit 1; }
@@ -13101,15 +12502,15 @@
 do
-echo "configure:13105: checking for $ac_hdr" >&5
+echo "configure:12506: checking for $ac_hdr" >&5
-#line 13108 "configure"
+#line 12509 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13113: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12514: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13149,10 +12550,10 @@
 LIBS="-framework OpenCL  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for clGetPlatformInfo""... $ac_c" 1>&6
-echo "configure:13153: checking for clGetPlatformInfo" >&5
+echo "configure:12554: checking for clGetPlatformInfo" >&5
-#line 13156 "configure"
+#line 12557 "configure"
     which can conflict with char clGetPlatformInfo(); below.  */
@@ -13175,7 +12576,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12580: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_clGetPlatformInfo=yes"
 else
@@ -13214,15 +12615,15 @@
 do
-echo "configure:13218: checking for $ac_hdr" >&5
+echo "configure:12619: checking for $ac_hdr" >&5
-#line 13221 "configure"
+#line 12622 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13226: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12627: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13255,7 +12656,7 @@
     # With OpenCL library directory
 echo $ac_n "checking for location of OpenCL library""... $ac_c" 1>&6
-echo "configure:13259: checking for location of OpenCL library" >&5
+echo "configure:12660: checking for location of OpenCL library" >&5
 case "$with_opencl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opencl-libs." 1>&2; exit 1; }
@@ -13279,13 +12680,13 @@
 echo $ac_n "checking for clGetPlatformInfo in -lOpenCL""... $ac_c" 1>&6
-echo "configure:13283: checking for clGetPlatformInfo in -lOpenCL" >&5
+echo "configure:12684: checking for clGetPlatformInfo in -lOpenCL" >&5
 ac_lib_var=`echo OpenCL'_'clGetPlatformInfo | sed 'y%./+-%__p_%'`
 LIBS="-lOpenCL  $LIBS"
-#line 13289 "configure"
+#line 12690 "configure"
@@ -13296,7 +12697,7 @@
 clGetPlatformInfo()
 ; return 0; }
 EOF
-if { (eval echo configure:13300: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12701: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13356,7 +12757,7 @@
      fi
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:13360: checking for special C compiler options needed for large files" >&5
+echo "configure:12761: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -13364,7 +12765,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 13368 "configure"
+#line 12769 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -13380,7 +12781,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13384: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12785: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
@@ -13389,7 +12790,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 13393 "configure"
+#line 12794 "configure"
@@ -13405,7 +12806,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13409: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12810: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -13432,11 +12833,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:13436: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:12837: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 13440 "configure"
+#line 12841 "configure"
@@ -13452,14 +12853,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13456: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12857: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13463 "configure"
+#line 12864 "configure"
 #include "confdefs.h"
 #define _FILE_OFFSET_BITS 64
@@ -13477,7 +12878,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13481: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12882: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -13503,11 +12904,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:13507: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:12908: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 13511 "configure"
+#line 12912 "configure"
@@ -13523,14 +12924,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13527: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12928: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   echo "configure: failed program was:" >&5
   cat conftest.$ac_ext >&5
   rm -rf conftest*
-#line 13534 "configure"
+#line 12935 "configure"
 #define _LARGE_FILES 1
@@ -13548,7 +12949,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13552: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12953: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -13574,25 +12975,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:13578: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:12979: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 13582 "configure"
+#line 12983 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13589: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12990: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13596 "configure"
+#line 12997 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -13601,7 +13002,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13605: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13006: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -13633,25 +13034,25 @@
 ac_save_cflags=${CFLAGS}
 CFLAGS="$LFS_CFLAGS ${ac_save_cflags}"
-echo "configure:13637: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13038: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 13641 "configure"
+#line 13042 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13648: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13049: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 13655 "configure"
+#line 13056 "configure"
 #include <stdio.h>
@@ -13660,7 +13061,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:13664: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13065: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
 else
@@ -13690,18 +13091,18 @@
    # If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
    echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:13694: checking for fseeko" >&5
+echo "configure:13095: checking for fseeko" >&5
 ac_cv_func_fseeko=no
-#line 13698 "configure"
+#line 13099 "configure"
 #include <stdio.h>
 int main() {
 return fseeko && fseeko (stdin, 0, 0);
 ; return 0; }
 EOF
-if { (eval echo configure:13705: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13106: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   ac_cv_func_fseeko=yes
 else
@@ -13718,10 +13119,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:13722: checking if system supports Large Files at all" >&5
+echo "configure:13123: checking if system supports Large Files at all" >&5
-#line 13725 "configure"
+#line 13126 "configure"
 #include <stdio.h>
@@ -13753,7 +13154,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:13757: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13158: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -13784,7 +13185,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:13788: checking whether to use wxWidgets" >&5
+echo "configure:13189: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -13805,7 +13206,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:13809: checking for $ac_word" >&5
+echo "configure:13210: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -13853,7 +13254,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:13857: checking wxWidgets version" >&5
+echo "configure:13258: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -13876,15 +13277,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13880: checking for $ac_hdr" >&5
+echo "configure:13281: checking for $ac_hdr" >&5
-#line 13883 "configure"
+#line 13284 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13888: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13289: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -14169,10 +13570,6 @@
 s%@SQLITEINCPATH@%$SQLITEINCPATH%g
 s%@SQLITELIBPATH@%$SQLITELIBPATH%g
 s%@SQLITELIB@%$SQLITELIB%g
-s%@USE_FFMPEG@%$USE_FFMPEG%g
-s%@FFMPEGINCPATH@%$FFMPEGINCPATH%g
-s%@FFMPEGLIBPATH@%$FFMPEGLIBPATH%g
-s%@FFMPEGLIB@%$FFMPEGLIB%g
 s%@USE_OPENGL@%$USE_OPENGL%g
 s%@OPENGL_X11@%$OPENGL_X11%g
 s%@OPENGL_AQUA@%$OPENGL_AQUA%g
@@ -14510,8 +13907,6 @@
 echo "  DWG support:                `if test -n "${USE_OPENDWG}" ; then echo yes ; else echo no ; fi`"
-echo "  FFMPEG support:             `if test -n "${USE_FFMPEG}" ; then echo yes ; else echo no ; fi`"
 echo "  FFTW support:               `if test -n "${USE_FFTW}" ; then echo yes ; else echo no ; fi`"
 echo "  FreeType support:           `if test -n "${USE_FREETYPE}" ; then echo yes ; else echo no ; fi`"
Modified: grass/branches/releasebranch_7_0/configure.in
--- grass/branches/releasebranch_7_0/configure.in	2014-08-18 16:57:22 UTC (rev 61677)
+++ grass/branches/releasebranch_7_0/configure.in	2014-08-18 17:25:46 UTC (rev 61678)
@@ -251,7 +251,6 @@
 LOC_ARG_WITH(postgres, PostgreSQL, no)
 LOC_ARG_WITH(mysql, MySQL, no)
 LOC_ARG_WITH(sqlite, SQLite, no)
-LOC_ARG_WITH(ffmpeg, FFMPEG, no)
 LOC_ARG_WITH(opengl, OpenGL)
 LOC_ARG_WITH(odbc, ODBC, no)
 LOC_ARG_WITH(fftw, FFTW)
@@ -325,9 +324,6 @@
 LOC_ARG_WITH_INC(sqlite, SQLite)
 LOC_ARG_WITH_LIB(sqlite, SQLite)
-LOC_ARG_WITH_INC(ffmpeg, FFMPEG)
-LOC_ARG_WITH_LIB(ffmpeg, FFMPEG)
 LOC_ARG_WITH_INC(opengl, OpenGL)
 LOC_ARG_WITH_LIB(opengl, OpenGL)
 LOC_ARG_WITH_FRAMEWORK(opengl, OpenGL)
@@ -1120,49 +1116,6 @@
 # Done checking SQLite
-# Enable FFMPEG option
-LOC_CHECK_USE(ffmpeg, FFMPEG, USE_FFMPEG)
-FFMPEGINCPATH=
-FFMPEGLIBPATH=
-FFMPEGLIB=
-if test -n "$USE_FFMPEG"; then
-# With FFMPEG includes directory
-LOC_CHECK_INC_PATH(ffmpeg, FFMPEG, FFMPEGINCPATH)
-LOC_CHECK_INCLUDES(avcodec.h,FFMPEG,$FFMPEGINCPATH)
-LOC_CHECK_INCLUDES(avformat.h,FFMPEG,$FFMPEGINCPATH)
-LOC_CHECK_INCLUDES(swscale.h,FFMPEG,$FFMPEGINCPATH)
-AC_DEFINE(HAVE_FFMPEG)
-fi # $USE_FFMPEG
-# With FFMPEG library directory
-LOC_CHECK_LIB_PATH(ffmpeg, FFMPEG, FFMPEGLIBPATH)
-LOC_CHECK_LIBS(avutil, av_free, FFMPEG, $FFMPEGLIBPATH, FFMPEGLIB,,,,$MATHLIB)
-LOC_CHECK_LIBS(avcodec, avcodec_register, FFMPEG, $FFMPEGLIBPATH, FFMPEGLIB, $FFMPEGLIB,,,$MATHLIB)
-LOC_CHECK_LIBS(avformat, avformat_alloc_context, FFMPEG, $FFMPEGLIBPATH, FFMPEGLIB, $FFMPEGLIB,,,$MATHLIB)
-fi # $USE_FFMPEG
-AC_SUBST(USE_FFMPEG)
-AC_SUBST(FFMPEGINCPATH)
-AC_SUBST(FFMPEGLIBPATH)
-AC_SUBST(FFMPEGLIB)
-# Done checking FFMPEG
 # Enable OpenGL option
 OPENGLINC=
@@ -1945,7 +1898,6 @@
 LOC_MSG_USE(C++ support,USE_CXX)
 LOC_MSG_USE(Cairo support,USE_CAIRO)
 LOC_MSG_USE(DWG support,USE_OPENDWG)
-LOC_MSG_USE(FFMPEG support,USE_FFMPEG)
 LOC_MSG_USE(FFTW support,USE_FFTW)
 LOC_MSG_USE(FreeType support,USE_FREETYPE)
 LOC_MSG_USE(GDAL support,USE_GDAL)
Modified: grass/branches/releasebranch_7_0/include/Make/Grass.make
--- grass/branches/releasebranch_7_0/include/Make/Grass.make	2014-08-18 16:57:22 UTC (rev 61677)
+++ grass/branches/releasebranch_7_0/include/Make/Grass.make	2014-08-18 17:25:46 UTC (rev 61678)
@@ -206,7 +206,7 @@
 LRSDEPS          = $(DBMILIB) $(GISLIB)
 MANAGEDEPS       = $(VECTORLIB) $(GISLIB)
 NVIZDEPS         = $(OGSFLIB) $(GISLIB) $(OPENGLLIB)
-OGSFDEPS         = $(BITMAPLIB) $(RASTER3DLIB) $(VECTORLIB) $(DBMILIB) $(RASTERLIB) $(GISLIB) $(FFMPEGLIBPATH) $(FFMPEGLIB) $(TIFFLIBPATH) $(TIFFLIB) $(OPENGLLIB) $(OPENGLULIB) $(MATHLIB)
+OGSFDEPS         = $(BITMAPLIB) $(RASTER3DLIB) $(VECTORLIB) $(DBMILIB) $(RASTERLIB) $(GISLIB) $(TIFFLIBPATH) $(TIFFLIB) $(OPENGLLIB) $(OPENGLULIB) $(MATHLIB)
 PNGDRIVERDEPS    = $(DRIVERLIB) $(GISLIB) $(PNGLIB) $(MATHLIB)
 PSDRIVERDEPS     = $(DRIVERLIB) $(GISLIB) $(MATHLIB)
 RASTERDEPS       = $(GISLIB) $(MATHLIB)
Modified: grass/branches/releasebranch_7_0/include/Make/Platform.make.in
--- grass/branches/releasebranch_7_0/include/Make/Platform.make.in	2014-08-18 16:57:22 UTC (rev 61677)
+++ grass/branches/releasebranch_7_0/include/Make/Platform.make.in	2014-08-18 17:25:46 UTC (rev 61678)
@@ -119,11 +119,6 @@
 SQLITELIBPATH       = @SQLITELIBPATH@
 SQLITELIB           = @SQLITELIB@
-#FFMPEG
-FFMPEGINCPATH       = @FFMPEGINCPATH@
-FFMPEGLIBPATH       = @FFMPEGLIBPATH@
-FFMPEGLIB           = @FFMPEGLIB@
 #ODBC:
 ODBCINC             = @ODBCINC@
 ODBCLIB             = @ODBCLIB@
Modified: grass/branches/releasebranch_7_0/include/config.h.in
--- grass/branches/releasebranch_7_0/include/config.h.in	2014-08-18 16:57:22 UTC (rev 61677)
+++ grass/branches/releasebranch_7_0/include/config.h.in	2014-08-18 17:25:46 UTC (rev 61678)
@@ -221,9 +221,6 @@
 /* define if glXCreateGLXPixmap exists */
 #undef HAVE_PIXMAPS
-/* define if FFMPEG library exists */
-#undef HAVE_FFMPEG
 /* define if OpenGL uses X11 */
 #undef OPENGL_X11
Modified: grass/branches/releasebranch_7_0/include/defs/ogsf.h
--- grass/branches/releasebranch_7_0/include/defs/ogsf.h	2014-08-18 16:57:22 UTC (rev 61677)
+++ grass/branches/releasebranch_7_0/include/defs/ogsf.h	2014-08-18 17:25:46 UTC (rev 61678)
@@ -451,9 +451,6 @@
 /* gsd_img_ppm.c */
 int GS_write_ppm(const char *);
-int gsd_init_mpeg(const char *);
-int gsd_write_mpegframe(void);
-int gsd_close_mpeg(void);
 /* gsd_img_tif.c */
 int GS_write_tif(const char *);
Modified: grass/branches/releasebranch_7_0/lib/nviz/Makefile
--- grass/branches/releasebranch_7_0/lib/nviz/Makefile	2014-08-18 16:57:22 UTC (rev 61677)
+++ grass/branches/releasebranch_7_0/lib/nviz/Makefile	2014-08-18 17:25:46 UTC (rev 61678)
@@ -9,7 +9,7 @@
 EXTRA_CFLAGS += $(XCFLAGS)
 endif
-EXTRA_INC = $(VECT_INC) $(OPENGLINC) $(TIFFINCPATH) $(FFMPEGINCPATH)
+EXTRA_INC = $(VECT_INC) $(OPENGLINC) $(TIFFINCPATH)
 EXTRA_CFLAGS = $(VECT_CFLAGS)
Modified: grass/branches/releasebranch_7_0/lib/ogsf/Makefile
--- grass/branches/releasebranch_7_0/lib/ogsf/Makefile	2014-08-18 16:57:22 UTC (rev 61677)
+++ grass/branches/releasebranch_7_0/lib/ogsf/Makefile	2014-08-18 17:25:46 UTC (rev 61678)
@@ -6,7 +6,7 @@
 include $(MODULE_TOPDIR)/include/Make/Lib.make
 include $(MODULE_TOPDIR)/include/Make/Doxygen.make
 EXTRA_CFLAGS = $(VECT_CFLAGS) $(XCFLAGS)
 ifneq ($(USE_OPENGL),)
Deleted: grass/branches/releasebranch_7_0/lib/ogsf/gsd_img_mpeg.c
--- grass/branches/releasebranch_7_0/lib/ogsf/gsd_img_mpeg.c	2014-08-18 16:57:22 UTC (rev 61677)
+++ grass/branches/releasebranch_7_0/lib/ogsf/gsd_img_mpeg.c	2014-08-18 17:25:46 UTC (rev 61678)
@@ -1,509 +0,0 @@
-   \file gsd_img_mpeg.c
-   \brief OGSF library - FFMPEG stuff
-   GRASS OpenGL gsurf OGSF Library
-   (C) 1999-2008, 2012 by the GRASS Development Team
-   This program is free software under the GNU General Public License
-   (>=v2).  Read the file COPYING that comes with GRASS for details.
-   \author Bill Brown USACERL, GMSL/University of Illinois
-   \author Doxygenized (May 2008) and update for FFMPEG >= 0.7
-   (November 2012) by Martin Landa <landa.martin gmail.com>
-#include <string.h>
-#include <grass/gis.h>
-#include <grass/glocale.h>
-#include <grass/ogsf.h>
-/* FFMPEG stuff */
-#ifdef HAVE_FFMPEG
-#include <avformat.h>
-#include <avio.h>
-#if LIBAVUTIL_VERSION_MAJOR < 51
-#include <avutil.h>
-#else
-/* libavutil 51.22.1's avutil.h doesn't include libavutil/mathematics.h */
-#include <mathematics.h>
-#endif
-/* 5 seconds stream duration */
-#define STREAM_DURATION   5.0
-#define STREAM_FRAME_RATE 25	/* 25 images/s */
-#define STREAM_NB_FRAMES  ((int)(STREAM_DURATION * STREAM_FRAME_RATE))
-#define STREAM_PIX_FMT PIX_FMT_YUV420P	/* default pix_fmt */
-AVFrame *picture, *tmp_picture;
-uint8_t *video_outbuf;
-int frame_count, video_outbuf_size;
-AVOutputFormat *fmt;
-AVFormatContext *oc;
-AVStream *video_st;
-   \brief Add a video output stream
-   \param oc
-   \param codec_id
-   \param w
-   \param h
-   \return
-static AVStream *add_video_stream(AVFormatContext * oc, int codec_id, int w,
-				  int h)
-    AVCodecContext *c;
-    AVStream *st;
-#if LIBAVFORMAT_VERSION_INT < AV_VERSION_INT(52, 112, 0)
-    st = av_new_stream(oc, 0);
-#else
-    st = avformat_new_stream(oc, NULL);
-#endif
-    if (!st) {
-	G_warning(_("Unable to allocate stream"));
-	return NULL;
-    c = st->codec;
-    c->codec_id = codec_id;
-#if LIBAVCODEC_VERSION_INT < AV_VERSION_INT(52, 123, 0)
-    c->codec_type = CODEC_TYPE_VIDEO;
-#else
-    c->codec_type = AVMEDIA_TYPE_VIDEO;
-#endif
-    /* put sample parameters */
-    c->bit_rate = 400000;
-    /* resolution must be a multiple of two */
-    c->width = w;
-    c->height = h;
-    /* time base: this is the fundamental unit of time (in seconds) in terms
-       of which frame timestamps are represented. for fixed-fps content,
-       timebase should be 1/framerate and timestamp increments should be
-       identically 1. */
-    c->time_base.den = STREAM_FRAME_RATE;
-    c->time_base.num = 1;
-    c->gop_size = 12;		/* emit one intra frame every twelve frames at most */
-    c->pix_fmt = STREAM_PIX_FMT;
-    if (c->codec_id == CODEC_ID_MPEG2VIDEO) {
-	/* just for testing, we also add B frames */
-	c->max_b_frames = 2;
-    if (c->codec_id == CODEC_ID_MPEG1VIDEO) {
-	/* Needed to avoid using macroblocks in which some coeffs overflow.
-	   This does not happen with normal video, it just happens here as
-	   the motion of the chroma plane does not match the luma plane. */
-	c->mb_decision = 2;
-    /* some formats want stream headers to be separate */
-    if (!strcmp(oc->oformat->name, "mp4") || !strcmp(oc->oformat->name, "mov")
-	|| !strcmp(oc->oformat->name, "3gp"))
-	c->flags |= CODEC_FLAG_GLOBAL_HEADER;
-    c->flags |= CODEC_FLAG_QSCALE;
-    /* Quality, as it has been removed from AVCodecContext and put in AVVideoFrame. */
-#if LIBAVFORMAT_VERSION_INT < AV_VERSION_INT(52, 100, 0)
-    c->global_quality = st->quality = FF_QP2LAMBDA * 10;
-#else
-    c->global_quality = FF_QP2LAMBDA * 10;
-#endif
-    return st;
-   \brief Allocate picture
-   \param pix_fmt
-   \param width picture width
-   \param height picture height
-   \return pointer to AVFrame struct
-   \return NULL on failure
-static AVFrame *alloc_picture(int pix_fmt, int width, int height)
-    AVFrame *picture;
-    uint8_t *picture_buf;
-    int size;
-    picture = avcodec_alloc_frame();
-    if (!picture)
-	return NULL;
-    size = avpicture_get_size(pix_fmt, width, height);
-    picture_buf = av_malloc(size);
-    if (!picture_buf) {
-	av_free(picture);
-	return NULL;
-    avpicture_fill((AVPicture *) picture, picture_buf,
-		   pix_fmt, width, height);
-    return picture;
-   \brief Open video
-   \param oc
-   \param st
-static void open_video(AVFormatContext * oc, AVStream * st)
-    AVCodec *codec;
-    c = st->codec;
-    /* find the video encoder */
-    codec = avcodec_find_encoder(c->codec_id);
-    if (!codec) {
-	G_warning(_("Video codec not found"));
-	return;
-    /* open the codec */
-    if (avcodec_open(c, codec) < 0) {
-#else
-    if (avcodec_open2(c, codec, NULL) < 0) {
-#endif
-	G_warning(_("Unable to open codec"));
-	return;
-    video_outbuf = NULL;
-    if (!(oc->oformat->flags & AVFMT_RAWPICTURE)) {
-	/* allocate output buffer */
-	/* XXX: API change will be done */
-	/* buffers passed into lav* can be allocated any way you prefer,
-	   as long as they're aligned enough for the architecture, and
-	   they're freed appropriately (such as using av_free for buffers
-	   allocated with av_malloc) */
-	video_outbuf_size = 200000;
-	video_outbuf = av_malloc(video_outbuf_size);
-    /* allocate the encoded raw picture */
-    picture = alloc_picture(c->pix_fmt, c->width, c->height);
-    if (!picture) {
-	G_warning(_("Unable to allocate picture"));
-	return;
-    /* if the output format is not YUV420P, then a temporary YUV420P
-       picture is needed too. It is then converted to the required
-       output format */
-    tmp_picture = NULL;
-    if (c->pix_fmt != PIX_FMT_YUV420P) {
-	tmp_picture = alloc_picture(PIX_FMT_YUV420P, c->width, c->height);
-	if (!tmp_picture) {
-	    G_warning(_("Unable to allocate temporary picture"));
-	    return;
-   \brief Write video frame
-   \param oc
-   \param st
-static void write_video_frame(AVFormatContext * oc, AVStream * st)
-    int out_size, ret;
-    c = st->codec;
-    if (oc->oformat->flags & AVFMT_RAWPICTURE) {
-	/* raw video case. The API will change slightly in the near
-	   future for that */
-	AVPacket pkt;
-	av_init_packet(&pkt);
-#if LIBAVFORMAT_VERSION_INT < AV_VERSION_INT(52, 32, 0)
-	pkt.flags |= PKT_FLAG_KEY;
-#else
-	pkt.flags |= AV_PKT_FLAG_KEY;
-#endif
-	pkt.stream_index = st->index;
-	pkt.data = (uint8_t *) picture;
-	pkt.size = sizeof(AVPicture);
-	ret = av_write_frame(oc, &pkt);
-    else {
-	/* encode the image */
-	out_size =
-	    avcodec_encode_video(c, video_outbuf, video_outbuf_size, picture);
-	/* if zero size, it means the image was buffered */
-	if (out_size > 0) {
-	    AVPacket pkt;
-	    pkt.pts =
-		av_rescale_q(c->coded_frame->pts, c->time_base,
-			     st->time_base);
-	    if (c->coded_frame->key_frame)
-#else
-#endif
-	    pkt.data = video_outbuf;
-	    pkt.size = out_size;
-	    /* write the compressed frame in the media file */
-	else {
-	    ret = 0;
-    if (ret != 0) {
-	G_warning(_("Error while writing video frame"));
-	return;
-    frame_count++;
-   \brief Close video
-   \param oc [unused]
-   \param st
-static void close_video(AVStream * st)
-    avcodec_close(st->codec);
-    av_free(picture->data[0]);
-    av_free(picture);
-    if (tmp_picture) {
-	av_free(tmp_picture->data[0]);
-	av_free(tmp_picture);
-    av_free(video_outbuf);
-#endif
-   \brief Initialize FAME setup mpeg defaults and open file for writing
-   \param filename file name
-   \return -1 on failure
-   \return 0 on success
-int gsd_init_mpeg(const char *filename)
-#ifdef HAVE_FFMPEG
-    GLuint l, r, b, t;
-    GLint tmp[4];
-    glGetIntegerv(GL_VIEWPORT, tmp);
-    l = tmp[0];
-    r = tmp[0] + tmp[2] - 1;
-    b = tmp[1];
-    t = tmp[1] + tmp[3] - 1;
-    G_verbose_message(_("Opening MPEG stream <%s>..."), filename);
-    /* initialize libavcodec, and register all codecs and formats */
-    av_register_all();
-    /* auto detect the output format from the name. default is mpeg. */
-    fmt = guess_format(NULL, filename, NULL);
-#else
-    fmt = av_guess_format(NULL, filename, NULL);
-#endif
-    if (!fmt) {
-	G_warning(_("Unable to deduce output format from file extension: using MPEG"));
-	fmt = guess_format("mpeg", NULL, NULL);
-#else
-	fmt = av_guess_format("mpeg", NULL, NULL);
-#endif
-    if (!fmt) {
-	G_warning(_("Unable to find suitable output format"));
-	return (-1);
-    /* allocate the output media context */
-    oc = avformat_alloc_context();
-    if (!oc) {
-	G_warning(_("Out of memory"));
-	return (-1);
-    oc->oformat = fmt;
-    snprintf(oc->filename, sizeof(oc->filename), "%s", filename);
-    /* if you want to hardcode the codec (eg #ifdef USE_XVID)
-       this may be the place to do it (?????) */
-#ifdef USE_XVID
-    fmt->video_codec = CODEC_ID_XVID;
-#endif
-    video_st = NULL;
-    if (fmt->video_codec != CODEC_ID_NONE) {
-	video_st =
-	    add_video_stream(oc, fmt->video_codec, (r - l + 1), (t - b + 1));
-    /* set the output parameters (must be done even if no parameters). */
-    if (av_set_parameters(oc, NULL) < 0) {
-#else
-    if (avformat_write_header(oc, NULL) < 0) {
-#endif
-	G_warning(_("Invalid output format parameters"));
-	return -1;
-    dump_format(oc, 0, filename, 1);
-#else
-    av_dump_format(oc, 0, filename, 1);
-#endif
-    /* now that all the parameters are set, we can open the audio and
-       video codecs and allocate the necessary encode buffers */
-    if (video_st)
-	open_video(oc, video_st);
-    /* open the output file, if needed */
-    if (!(fmt->flags & AVFMT_NOFILE)) {
-        if (url_fopen(&oc->pb, filename, URL_WRONLY) < 0) {
-#else
-	if (avio_open(&oc->pb, filename, AVIO_FLAG_WRITE) < 0) {
-#endif
-	    G_warning(_("Unable to open <%s>"), filename);
-	    return (-1);
-    /* write the stream header, if any */
-    av_write_header(oc);
-#else
-    avformat_write_header(oc, NULL);
-#endif
-#else
-    G_warning(_("OGSF library has not been built with MPEG output support"));
-    return -1;
-#endif
-    return 0;
-   \brief Get RGB pixbuf and convert to YUV 4:2:0
-   Image and write to mpeg stream
-   \return 0
-#ifdef HAVE_FFMPEG
-    unsigned int xsize, ysize, x;
-    int y, xy, xy_uv;
-    int yy, uu, vv;
-    unsigned char *pixbuf;
-    gsd_getimage(&pixbuf, &xsize, &ysize);
-    xy = xy_uv = 0;
-    for (y = ysize - 1; y >= 0; y--) {
-	for (x = 0; x < xsize; x++) {
-	    unsigned char r = pixbuf[(y * xsize + x) * 4 + 0];
-	    unsigned char g = pixbuf[(y * xsize + x) * 4 + 1];
-	    unsigned char b = pixbuf[(y * xsize + x) * 4 + 2];
-	    yy = (0.257 * r) + (0.504 * g) + (0.098 * b) + 16;;
-	    vv = (0.439 * r) - (0.368 * g) - (0.071 * b) + 128;
-	    uu = -(0.148 * r) - (0.291 * g) + (0.439 * b) + 128;
-	    fflush(stdout);
-	    picture->data[0][xy] = yy;
-	    if ((x % 2) && (y % 2)) {
-		picture->data[1][xy_uv] = uu;
-		picture->data[2][xy_uv] = vv;
-		xy_uv++;
-	    xy++;
-    G_free(pixbuf);
-    write_video_frame(oc, video_st);
-#endif
-    return (0);
-   \brief Close the mpeg, free buffer, and close file
-   \return 0
-#ifdef HAVE_FFMPEG
-    unsigned int i;
-    close_video(video_st);
-    /* write the trailer, if any */
-    av_write_trailer(oc);
-    /* free the streams */
-    for (i = 0; i < oc->nb_streams; i++) {
-	av_freep(&oc->streams[i]->codec);
-	av_freep(&oc->streams[i]);
-	/* close the output file */
-#if (LIBAVFORMAT_VERSION_INT>>16) < 52
-      url_fclose(&oc->pb);
-#elif LIBAVFORMAT_VERSION_INT < AV_VERSION_INT(52, 100, 0)
-      url_fclose(oc->pb);
-#else
-      avio_close(oc->pb);
-#endif
-    /* free the stream */
-    av_free(oc);
-    G_debug(3, "Closed MPEG stream");
-#endif
-    return 0;
