[GRASS-SVN] r61679 - grass/trunk/raster3d/r3.flow
svn_grass at osgeo.org
Mon Aug 18 11:43:42 PDT 2014
Author: annakrat
Date: 2014-08-18 11:43:42 -0700 (Mon, 18 Aug 2014)
New Revision: 61679
grass/trunk/raster3d/r3.flow/flowline.c
grass/trunk/raster3d/r3.flow/flowline.h
grass/trunk/raster3d/r3.flow/main.c
grass/trunk/raster3d/r3.flow/r3.flow.html
r3.flow: added option to sample a 3D raster by flowlines
Modified: grass/trunk/raster3d/r3.flow/flowline.c
--- grass/trunk/raster3d/r3.flow/flowline.c 2014-08-18 17:25:46 UTC (rev 61678)
+++ grass/trunk/raster3d/r3.flow/flowline.c 2014-08-18 18:43:42 UTC (rev 61679)
@@ -37,35 +37,39 @@
static void write_segment_db(struct field_info *finfo, dbDriver * driver,
dbString * sql, const double velocity,
- double scalar_value, int write_scalar,
+ double scalar_value, double sampled_map_value,
+ int write_scalar, int use_sampled_map,
const int cat)
char buf[200];
- if (write_scalar)
- sprintf(buf, "insert into %s values ( %d, %e, %e )", finfo->table,
- cat, scalar_value, velocity);
- else
- sprintf(buf, "insert into %s values ( %d, %e)", finfo->table, cat,
- velocity);
+ sprintf(buf, "insert into %s values (%d, %e", finfo->table, cat, velocity);
db_set_string(sql, buf);
+ if (write_scalar) {
+ sprintf(buf, ", %e", scalar_value);
+ db_append_string(sql, buf);
+ if (use_sampled_map) {
+ sprintf(buf, ", %e", sampled_map_value);
+ db_append_string(sql, ")");
if (db_execute_immediate(driver, sql) != DB_OK) {
G_fatal_error(_("Unable to insert new record: '%s'"),
db_get_string(sql));
-static double get_scalar_value(RASTER3D_Region * region,
- struct Gradient_info *gradient_info,
- double north, double east, double top)
+static double get_map_value(RASTER3D_Region * region, RASTER3D_Map *map,
+ double north, double east, double top)
int col, row, depth;
double val;
Rast3d_location2coord(region, north, east, top, &col, &row, &depth);
- Rast3d_get_value(gradient_info->scalar_map, col, row, depth, &val,
+ Rast3d_get_value(map, col, row, depth, &val,
DCELL_TYPE);
return val;
@@ -86,7 +90,8 @@
void compute_flowline(RASTER3D_Region * region, const struct Seed *seed,
- RASTER3D_Map * flowacc, struct Integration *integration,
+ RASTER3D_Map * flowacc, RASTER3D_Map * sampled_map,
+ struct Integration *integration,
struct Map_info *flowline_vec, struct line_cats *cats,
struct line_pnts *points, int *cat, int if_table,
struct field_info *finfo, dbDriver * driver)
@@ -100,8 +105,9 @@
int last_col, last_row, last_depth;
int coor_diff;
+ DCELL scalar_value;
+ DCELL sampled_map_value;
FCELL value;
- double scalar_value;
int *trav_coords;
int size, trav_count;
dbString sql;
@@ -114,7 +120,7 @@
last_col = last_row = last_depth = -1;
size = 5;
- scalar_value = 0;
+ value = 0;
trav_coords = G_malloc(3 * size * sizeof(int));
if (seed->flowline) {
@@ -152,11 +158,14 @@
if (if_table) {
write_segment(flowline_vec, points, cats, new_point, cat);
if (gradient_info->compute_gradient)
- scalar_value = get_scalar_value(region, gradient_info,
- point[1], point[0],
- point[2]);
+ scalar_value = get_map_value(region, gradient_info->scalar_map,
+ point[1], point[0], point[2]);
+ if (sampled_map)
+ sampled_map_value = get_map_value(region, sampled_map,
write_segment_db(finfo, driver, &sql, velocity, scalar_value,
- gradient_info->compute_gradient, *cat - 1);
+ sampled_map_value, gradient_info->compute_gradient,
+ sampled_map ? 1 : 0, *cat - 1);
else
Vect_append_point(points, point[0], point[1], point[2]);
Modified: grass/trunk/raster3d/r3.flow/flowline.h
--- grass/trunk/raster3d/r3.flow/flowline.h 2014-08-18 17:25:46 UTC (rev 61678)
+++ grass/trunk/raster3d/r3.flow/flowline.h 2014-08-18 18:43:42 UTC (rev 61679)
@@ -10,7 +10,7 @@
+ RASTER3D_Map * flowacc, RASTER3D_Map *sampled_map,
Modified: grass/trunk/raster3d/r3.flow/main.c
--- grass/trunk/raster3d/r3.flow/main.c 2014-08-18 17:25:46 UTC (rev 61678)
+++ grass/trunk/raster3d/r3.flow/main.c 2014-08-18 18:43:42 UTC (rev 61679)
@@ -27,7 +27,7 @@
static void create_table(struct Map_info *flowline_vec,
struct field_info **f_info, dbDriver ** driver,
- int write_scalar)
+ int write_scalar, int use_sampled_map)
dbString sql;
char buf[200];
@@ -47,14 +47,14 @@
Vect_subst_var(fi->database, flowline_vec), fi->driver);
*driver = drvr;
+ sprintf(buf, "create table %s (cat integer, velocity double precision",
+ fi->table);
+ db_set_string(&sql, buf);
if (write_scalar)
- sprintf(buf, "create table %s (cat integer, input double precision, "
- "velocity double precision)", fi->table);
- else
- sprintf(buf,
- "create table %s (cat integer, velocity double precision)",
- fi->table);
- db_set_string(&sql, buf);
+ db_append_string(&sql, ", input double precision");
+ db_append_string(&sql, ", sampled double precision");
+ db_append_string(&sql, ")");
db_begin_transaction(drvr);
/* Create table */
@@ -147,13 +147,13 @@
int main(int argc, char *argv[])
- struct Option *vector_opt, *seed_opt, *flowlines_opt, *flowacc_opt,
+ struct Option *vector_opt, *seed_opt, *flowlines_opt, *flowacc_opt, *sampled_opt,
*scalar_opt, *unit_opt, *step_opt, *limit_opt, *skip_opt, *dir_opt,
*error_opt;
struct Flag *table_fl;
struct GModule *module;
RASTER3D_Region region;
- RASTER3D_Map *flowacc;
+ RASTER3D_Map *flowacc, *sampled;
struct Integration integration;
struct Seed seed;
struct Gradient_info gradient_info;
@@ -215,6 +215,15 @@
_("Name for output flowaccumulation 3D raster");
flowacc_opt->guisection = _("Output");
+ sampled_opt = G_define_standard_option(G_OPT_R3_INPUT);
+ sampled_opt->key = "sampled";
+ sampled_opt->required = NO;
+ sampled_opt->label =
+ _("Name for 3D raster sampled by flowlines");
+ sampled_opt->description =
+ _("Values of this 3D raster will be stored "
+ "as attributes of flowlines segments");
unit_opt = G_define_option();
unit_opt->key = "unit";
unit_opt->type = TYPE_STRING;
@@ -287,6 +296,7 @@
G_option_required(flowlines_opt, flowacc_opt, NULL);
G_option_requires(seed_opt, flowlines_opt, NULL);
G_option_requires(table_fl, flowlines_opt);
+ G_option_requires(sampled_opt, table_fl);
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -363,6 +373,19 @@
init_flowaccum(®ion, flowacc);
+ /* open 3D raster map used for sampling */
+ if (sampled_opt->answer) {
+ sampled = Rast3d_open_cell_old(sampled_opt->answer,
+ G_find_raster3d(sampled_opt->answer, ""),
+ ®ion, RASTER3D_TILE_SAME_AS_FILE,
+ RASTER3D_USE_CACHE_DEFAULT);
+ if (!sampled)
+ Rast3d_fatal_error(_("Unable to open 3D raster map <%s>"),
+ sampled_opt->answer);
+ else
+ sampled = NULL;
/* open new vector map of flowlines */
if (flowlines_opt->answer) {
fl_cats = Vect_new_cats_struct();
@@ -375,7 +398,7 @@
if (if_table) {
create_table(&fl_map, &finfo, &driver,
- gradient_info.compute_gradient);
+ gradient_info.compute_gradient, sampled ? 1 : 0);
@@ -429,14 +452,14 @@
if (integration.direction_type == FLOWDIR_UP ||
integration.direction_type == FLOWDIR_BOTH) {
integration.actual_direction = FLOWDIR_UP;
- compute_flowline(®ion, &seed, &gradient_info, flowacc,
+ compute_flowline(®ion, &seed, &gradient_info, flowacc, sampled,
&integration, &fl_map, fl_cats, fl_points,
&cat, if_table, finfo, driver);
if (integration.direction_type == FLOWDIR_DOWN ||
integration.actual_direction = FLOWDIR_DOWN;
@@ -474,7 +497,7 @@
- flowacc, &integration, &fl_map,
+ flowacc, sampled, &integration, &fl_map,
fl_cats, fl_points, &cat,
@@ -482,7 +505,7 @@
Modified: grass/trunk/raster3d/r3.flow/r3.flow.html
--- grass/trunk/raster3d/r3.flow/r3.flow.html 2014-08-18 17:25:46 UTC (rev 61678)
+++ grass/trunk/raster3d/r3.flow/r3.flow.html 2014-08-18 18:43:42 UTC (rev 61679)
@@ -33,6 +33,8 @@
and each category (record) represents one segment of a flowline, so that attributes
specific for segments can be written. In case of <b>vector_field</b> input, only velocity is written,
in case of <b>input</b> option, also values of the input 3D raster are written.
+Option <b>sampled</b> allows to sample (query) given 3D raster by flow lines (computed from different 3D raster) and
+write the values of the given 3D raster as attributes of the flow line segments.
Note that using <b>a</b> flag results in longer computation time, so consider increasing
<b>step</b> and <b>max_error</b> parameter.
@@ -87,6 +89,7 @@
<h2>SEE ALSO</h2>
<em>
<a href="http://grass.osgeo.org/grass71/manuals/r.flow.html">r.flow</a>,
+<a href="http://grass.osgeo.org/grass71/manuals/r3.gradient.html">r3.gradient</a>,
<a href="http://grass.osgeo.org/grass71/manuals/r3.gwflow.html">r3.gwflow</a>
</em>
