[GRASS-SVN] r61681 - in grass/trunk/raster/r.li: . r.li.cwed r.li.dominance r.li.edgedensity r.li.mpa r.li.mps r.li.padcv r.li.padrange r.li.padsd r.li.patchdensity r.li.patchnum r.li.pielou r.li.renyi r.li.richness r.li.shannon r.li.shape r.li.simpson
svn_grass at osgeo.org
Mon Aug 18 12:59:49 PDT 2014
Author: hellik
Date: 2014-08-18 12:59:48 -0700 (Mon, 18 Aug 2014)
New Revision: 61681
grass/trunk/raster/r.li/r.li.cwed/r.li.cwed.html
grass/trunk/raster/r.li/r.li.dominance/r.li.dominance.html
grass/trunk/raster/r.li/r.li.edgedensity/r.li.edgedensity.html
grass/trunk/raster/r.li/r.li.html
grass/trunk/raster/r.li/r.li.mpa/r.li.mpa.html
grass/trunk/raster/r.li/r.li.mps/r.li.mps.html
grass/trunk/raster/r.li/r.li.padcv/r.li.padcv.html
grass/trunk/raster/r.li/r.li.padrange/r.li.padrange.html
grass/trunk/raster/r.li/r.li.padsd/r.li.padsd.html
grass/trunk/raster/r.li/r.li.patchdensity/r.li.patchdensity.html
grass/trunk/raster/r.li/r.li.patchnum/r.li.patchnum.html
grass/trunk/raster/r.li/r.li.pielou/r.li.pielou.html
grass/trunk/raster/r.li/r.li.renyi/r.li.renyi.html
grass/trunk/raster/r.li/r.li.richness/r.li.richness.html
grass/trunk/raster/r.li/r.li.shannon/r.li.shannon.html
grass/trunk/raster/r.li/r.li.shape/r.li.shape.html
grass/trunk/raster/r.li/r.li.simpson/r.li.simpson.html
r.li.*: better wording in manual for folder where conf file is stored in windows platform
Modified: grass/trunk/raster/r.li/r.li.cwed/r.li.cwed.html
--- grass/trunk/raster/r.li/r.li.cwed/r.li.cwed.html 2014-08-18 19:04:44 UTC (rev 61680)
+++ grass/trunk/raster/r.li/r.li.cwed/r.li.cwed.html 2014-08-18 19:59:48 UTC (rev 61681)
@@ -27,7 +27,7 @@
If the "moving window" method was selected in <b>g.gui.rlisetup</b>, then the
output will be a raster map, otherwise an ASCII file will be generated in
-the folder <tt>C:\Users\normal\AppData\Roaming\GRASS7\r.li\output\</tt>
+the folder <tt>C:\Users\userxy\AppData\Roaming\GRASS7\r.li\output\</tt>
(MS-Windows) or <tt>$HOME/.grass7/r.li/output/</tt> (GNU/Linux).
<p>
<!-- TODO: verify next: -->
Modified: grass/trunk/raster/r.li/r.li.dominance/r.li.dominance.html
--- grass/trunk/raster/r.li/r.li.dominance/r.li.dominance.html 2014-08-18 19:04:44 UTC (rev 61680)
+++ grass/trunk/raster/r.li/r.li.dominance/r.li.dominance.html 2014-08-18 19:59:48 UTC (rev 61681)
@@ -17,7 +17,7 @@
<p>
Modified: grass/trunk/raster/r.li/r.li.edgedensity/r.li.edgedensity.html
--- grass/trunk/raster/r.li/r.li.edgedensity/r.li.edgedensity.html 2014-08-18 19:04:44 UTC (rev 61680)
+++ grass/trunk/raster/r.li/r.li.edgedensity/r.li.edgedensity.html 2014-08-18 19:59:48 UTC (rev 61681)
@@ -29,7 +29,7 @@
<p>
Modified: grass/trunk/raster/r.li/r.li.html
--- grass/trunk/raster/r.li/r.li.html 2014-08-18 19:04:44 UTC (rev 61680)
+++ grass/trunk/raster/r.li/r.li.html 2014-08-18 19:59:48 UTC (rev 61681)
@@ -36,7 +36,7 @@
<ol>
<li>run <em>g.gui.rlisetup</em>: create a configuration file selecting
the parts of raster map to be analyzed. This file allows to re-run
- an analysis easily. It is stored on Windows in the directory <tt>C:\Users\normal\AppData\Roaming\GRASS7\r.li\</tt>, on GNU/Linux in
+ an analysis easily. It is stored on Windows in the directory <tt>C:\Users\userxy\AppData\Roaming\GRASS7\r.li\</tt>, on GNU/Linux in
<tt>$HOME/.grass7/r.li/</tt>. <!-- TODO: and Mac OSX? -->
<li>run one or more of the <em>r.li.<b>[index]</b></em> modules (e.g.,
Modified: grass/trunk/raster/r.li/r.li.mpa/r.li.mpa.html
--- grass/trunk/raster/r.li/r.li.mpa/r.li.mpa.html 2014-08-18 19:04:44 UTC (rev 61680)
+++ grass/trunk/raster/r.li/r.li.mpa/r.li.mpa.html 2014-08-18 19:59:48 UTC (rev 61681)
@@ -18,7 +18,7 @@
<p>
Modified: grass/trunk/raster/r.li/r.li.mps/r.li.mps.html
--- grass/trunk/raster/r.li/r.li.mps/r.li.mps.html 2014-08-18 19:04:44 UTC (rev 61680)
+++ grass/trunk/raster/r.li/r.li.mps/r.li.mps.html 2014-08-18 19:59:48 UTC (rev 61681)
@@ -28,7 +28,7 @@
<p>
If the sample area contains only NULL value cells, <em>r.li.mps</em>
Modified: grass/trunk/raster/r.li/r.li.padcv/r.li.padcv.html
--- grass/trunk/raster/r.li/r.li.padcv/r.li.padcv.html 2014-08-18 19:04:44 UTC (rev 61680)
+++ grass/trunk/raster/r.li/r.li.padcv/r.li.padcv.html 2014-08-18 19:59:48 UTC (rev 61681)
@@ -19,7 +19,7 @@
<p>
The result is NULL if the sample area contains only NULL values.
Modified: grass/trunk/raster/r.li/r.li.padrange/r.li.padrange.html
--- grass/trunk/raster/r.li/r.li.padrange/r.li.padrange.html 2014-08-18 19:04:44 UTC (rev 61680)
+++ grass/trunk/raster/r.li/r.li.padrange/r.li.padrange.html 2014-08-18 19:59:48 UTC (rev 61681)
@@ -20,7 +20,7 @@
<p>
If the sample area contains only NULL values then <em>r.li.padrange</em>
Modified: grass/trunk/raster/r.li/r.li.padsd/r.li.padsd.html
--- grass/trunk/raster/r.li/r.li.padsd/r.li.padsd.html 2014-08-18 19:04:44 UTC (rev 61680)
+++ grass/trunk/raster/r.li/r.li.padsd/r.li.padsd.html 2014-08-18 19:59:48 UTC (rev 61681)
@@ -21,7 +21,7 @@
<p>
Modified: grass/trunk/raster/r.li/r.li.patchdensity/r.li.patchdensity.html
--- grass/trunk/raster/r.li/r.li.patchdensity/r.li.patchdensity.html 2014-08-18 19:04:44 UTC (rev 61680)
+++ grass/trunk/raster/r.li/r.li.patchdensity/r.li.patchdensity.html 2014-08-18 19:59:48 UTC (rev 61681)
@@ -23,7 +23,7 @@
<p>
A sample area of only NULL values is considered to have zero patches,
Modified: grass/trunk/raster/r.li/r.li.patchnum/r.li.patchnum.html
--- grass/trunk/raster/r.li/r.li.patchnum/r.li.patchnum.html 2014-08-18 19:04:44 UTC (rev 61680)
+++ grass/trunk/raster/r.li/r.li.patchnum/r.li.patchnum.html 2014-08-18 19:59:48 UTC (rev 61681)
@@ -14,7 +14,7 @@
<p>
If the sample area contains only NULL values then it is considered to
Modified: grass/trunk/raster/r.li/r.li.pielou/r.li.pielou.html
--- grass/trunk/raster/r.li/r.li.pielou/r.li.pielou.html 2014-08-18 19:04:44 UTC (rev 61680)
+++ grass/trunk/raster/r.li/r.li.pielou/r.li.pielou.html 2014-08-18 19:59:48 UTC (rev 61681)
@@ -16,7 +16,7 @@
<p>
Modified: grass/trunk/raster/r.li/r.li.renyi/r.li.renyi.html
--- grass/trunk/raster/r.li/r.li.renyi/r.li.renyi.html 2014-08-18 19:04:44 UTC (rev 61680)
+++ grass/trunk/raster/r.li/r.li.renyi/r.li.renyi.html 2014-08-18 19:59:48 UTC (rev 61681)
@@ -19,7 +19,7 @@
<p>
Modified: grass/trunk/raster/r.li/r.li.richness/r.li.richness.html
--- grass/trunk/raster/r.li/r.li.richness/r.li.richness.html 2014-08-18 19:04:44 UTC (rev 61680)
+++ grass/trunk/raster/r.li/r.li.richness/r.li.richness.html 2014-08-18 19:59:48 UTC (rev 61681)
@@ -17,7 +17,7 @@
<p>
Modified: grass/trunk/raster/r.li/r.li.shannon/r.li.shannon.html
--- grass/trunk/raster/r.li/r.li.shannon/r.li.shannon.html 2014-08-18 19:04:44 UTC (rev 61680)
+++ grass/trunk/raster/r.li/r.li.shannon/r.li.shannon.html 2014-08-18 19:59:48 UTC (rev 61681)
@@ -17,7 +17,7 @@
<p>
Modified: grass/trunk/raster/r.li/r.li.shape/r.li.shape.html
--- grass/trunk/raster/r.li/r.li.shape/r.li.shape.html 2014-08-18 19:04:44 UTC (rev 61680)
+++ grass/trunk/raster/r.li/r.li.shape/r.li.shape.html 2014-08-18 19:59:48 UTC (rev 61681)
@@ -18,7 +18,7 @@
<p>
Modified: grass/trunk/raster/r.li/r.li.simpson/r.li.simpson.html
--- grass/trunk/raster/r.li/r.li.simpson/r.li.simpson.html 2014-08-18 19:04:44 UTC (rev 61680)
+++ grass/trunk/raster/r.li/r.li.simpson/r.li.simpson.html 2014-08-18 19:59:48 UTC (rev 61681)
@@ -16,7 +16,7 @@
file/map parameters.
<p>
