[GRASS-SVN] r61682 - in grass/branches/releasebranch_6_4/raster/r.li: . r.li.cwed r.li.dominance r.li.edgedensity r.li.mpa r.li.mps r.li.padcv r.li.padrange r.li.padsd r.li.patchdensity r.li.patchnum r.li.pielou r.li.renyi r.li.richness r.li.setup r.li.shannon r.li.shape r.li.simpson
Mon Aug 18 13:13:41 PDT 2014
Author: hellik
Date: 2014-08-18 13:13:41 -0700 (Mon, 18 Aug 2014)
New Revision: 61682
   grass/branches/releasebranch_6_4/raster/r.li/description.html
   grass/branches/releasebranch_6_4/raster/r.li/r.li.cwed/description.html
   grass/branches/releasebranch_6_4/raster/r.li/r.li.dominance/description.html
   grass/branches/releasebranch_6_4/raster/r.li/r.li.edgedensity/description.html
   grass/branches/releasebranch_6_4/raster/r.li/r.li.mpa/description.html
   grass/branches/releasebranch_6_4/raster/r.li/r.li.mps/description.html
   grass/branches/releasebranch_6_4/raster/r.li/r.li.padcv/description.html
   grass/branches/releasebranch_6_4/raster/r.li/r.li.padrange/description.html
   grass/branches/releasebranch_6_4/raster/r.li/r.li.padsd/description.html
   grass/branches/releasebranch_6_4/raster/r.li/r.li.patchdensity/description.html
   grass/branches/releasebranch_6_4/raster/r.li/r.li.patchnum/description.html
   grass/branches/releasebranch_6_4/raster/r.li/r.li.pielou/description.html
   grass/branches/releasebranch_6_4/raster/r.li/r.li.renyi/description.html
   grass/branches/releasebranch_6_4/raster/r.li/r.li.richness/description.html
   grass/branches/releasebranch_6_4/raster/r.li/r.li.setup/description.html
   grass/branches/releasebranch_6_4/raster/r.li/r.li.shannon/description.html
   grass/branches/releasebranch_6_4/raster/r.li/r.li.shape/description.html
   grass/branches/releasebranch_6_4/raster/r.li/r.li.simpson/description.html
r.li.*: better wording in manual for folder where conf file is stored in windows platform
Modified: grass/branches/releasebranch_6_4/raster/r.li/description.html
--- grass/branches/releasebranch_6_4/raster/r.li/description.html	2014-08-18 19:59:48 UTC (rev 61681)
+++ grass/branches/releasebranch_6_4/raster/r.li/description.html	2014-08-18 20:13:41 UTC (rev 61682)
@@ -57,7 +57,7 @@
 <li>run <em>r.li.setup</em>: create a configuration file selecting
     the parts of raster map to be analyzed. This file allows to re-run
     an analysis easily. It is stored on MS-Windows in the directory
-    <tt>C:\Users\normal\.r.li\history\</tt>, on GNU/Linux in
+    <tt>C:\Users\userxy\.r.li\history\</tt>, on GNU/Linux in
     <tt>$HOME/.r.li/history/</tt>. <!-- TODO: and Mac OSX? -->
 <li>run one or more of the <em>r.li.<b>[index]</b></em> modules (e.g.,
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.cwed/description.html
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.cwed/description.html	2014-08-18 19:59:48 UTC (rev 61681)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.cwed/description.html	2014-08-18 20:13:41 UTC (rev 61682)
@@ -27,7 +27,7 @@
 If the "moving window" method was selected in <b>r.li.setup</b>, then the
 output will be a raster map, otherwise an ASCII file will be generated in
-the folder <tt>C:\Users\normal\.r.li\output\</tt>
+the folder <tt>C:\Users\userxy\.r.li\output\</tt>
 (MS-Windows) or <tt>$HOME/.r.li/output/</tt> (GNU/Linux).
 <p>
 <!-- TODO: verify next: -->
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.dominance/description.html
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.dominance/description.html	2014-08-18 19:59:48 UTC (rev 61681)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.dominance/description.html	2014-08-18 20:13:41 UTC (rev 61682)
@@ -16,7 +16,7 @@
 file/map parameters.
 <p>
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.edgedensity/description.html
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.edgedensity/description.html	2014-08-18 19:59:48 UTC (rev 61681)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.edgedensity/description.html	2014-08-18 20:13:41 UTC (rev 61682)
@@ -28,7 +28,7 @@
 <p>
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.mpa/description.html
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.mpa/description.html	2014-08-18 19:59:48 UTC (rev 61681)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.mpa/description.html	2014-08-18 20:13:41 UTC (rev 61682)
@@ -17,7 +17,7 @@
 <p>
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.mps/description.html
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.mps/description.html	2014-08-18 19:59:48 UTC (rev 61681)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.mps/description.html	2014-08-18 20:13:41 UTC (rev 61682)
@@ -27,7 +27,7 @@
 <p>
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.padcv/description.html
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.padcv/description.html	2014-08-18 19:59:48 UTC (rev 61681)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.padcv/description.html	2014-08-18 20:13:41 UTC (rev 61682)
@@ -18,7 +18,7 @@
 <p>
 If input raster is not full of null values <em>r.li.padcv</em> returns a value >=0 that is PADcv. <br>
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.padrange/description.html
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.padrange/description.html	2014-08-18 19:59:48 UTC (rev 61681)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.padrange/description.html	2014-08-18 20:13:41 UTC (rev 61682)
@@ -19,7 +19,7 @@
 <p>
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.padsd/description.html
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.padsd/description.html	2014-08-18 19:59:48 UTC (rev 61681)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.padsd/description.html	2014-08-18 20:13:41 UTC (rev 61682)
@@ -20,7 +20,7 @@
 <p>
 If input raster is not full of null values <em>r.li.padsd</em> returns a
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.patchdensity/description.html
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.patchdensity/description.html	2014-08-18 19:59:48 UTC (rev 61681)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.patchdensity/description.html	2014-08-18 20:13:41 UTC (rev 61682)
@@ -22,7 +22,7 @@
 <p>
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.patchnum/description.html
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.patchnum/description.html	2014-08-18 19:59:48 UTC (rev 61681)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.patchnum/description.html	2014-08-18 20:13:41 UTC (rev 61682)
@@ -13,7 +13,7 @@
 <p>
 <!-- TODO verify: -->
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.pielou/description.html
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.pielou/description.html	2014-08-18 19:59:48 UTC (rev 61681)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.pielou/description.html	2014-08-18 20:13:41 UTC (rev 61682)
@@ -15,7 +15,7 @@
 <p>
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.renyi/description.html
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.renyi/description.html	2014-08-18 19:59:48 UTC (rev 61681)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.renyi/description.html	2014-08-18 20:13:41 UTC (rev 61682)
@@ -18,7 +18,7 @@
 <p>
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.richness/description.html
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.richness/description.html	2014-08-18 19:59:48 UTC (rev 61681)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.richness/description.html	2014-08-18 20:13:41 UTC (rev 61682)
@@ -16,7 +16,7 @@
 <p>
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.setup/description.html
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.setup/description.html	2014-08-18 19:59:48 UTC (rev 61681)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.setup/description.html	2014-08-18 20:13:41 UTC (rev 61682)
@@ -49,13 +49,13 @@
  rectangles with differents colors (green for the raster map, red for
  the sample frame and blue for the sample areas), and other notes
  (disposition of sample areas etc). The configuration file is saved in
- the folder <tt>C:\Users\normal\.r.li\history\my_conf</tt> (MS-Windows) or
+ the folder <tt>C:\Users\userxy\.r.li\history\my_conf</tt> (MS-Windows) or
  <tt>$HOME/.r.li/history/my_conf</tt> (GNU/Linux) (the file name can
  be defined by the user).
  The output can either be a new raster map (in case of
  using a "moving window" analysis) or be an ASCII text file (when not
  performing a "moving window" analysis) containing the result which
- is then saved to the folder <tt>C:\Users\normal\.r.li\output\</tt>
+ is then saved to the folder <tt>C:\Users\userxy\.r.li\output\</tt>
  <br>
  <!-- TODO: applies to all output or only ASCII output?? -->
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.shannon/description.html
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.shannon/description.html	2014-08-18 19:59:48 UTC (rev 61681)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.shannon/description.html	2014-08-18 20:13:41 UTC (rev 61682)
@@ -16,7 +16,7 @@
 <p>
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.shape/description.html
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.shape/description.html	2014-08-18 19:59:48 UTC (rev 61681)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.shape/description.html	2014-08-18 20:13:41 UTC (rev 61682)
@@ -17,7 +17,7 @@
 <p>
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.simpson/description.html
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.simpson/description.html	2014-08-18 19:59:48 UTC (rev 61681)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.simpson/description.html	2014-08-18 20:13:41 UTC (rev 61682)
@@ -16,7 +16,7 @@
 <p>
