[GRASS-SVN] r63325 - grass/branches/releasebranch_7_0/scripts/i.tasscap
svn_grass at osgeo.org
Tue Dec 2 08:06:50 PST 2014
Author: neteler
Date: 2014-12-02 08:06:50 -0800 (Tue, 02 Dec 2014)
New Revision: 63325
grass/branches/releasebranch_7_0/scripts/i.tasscap/i.tasscap.py
i.tasscap: added Landsat 8 (OLI) coefficients
Modified: grass/branches/releasebranch_7_0/scripts/i.tasscap/i.tasscap.py
--- grass/branches/releasebranch_7_0/scripts/i.tasscap/i.tasscap.py 2014-12-02 15:15:27 UTC (rev 63324)
+++ grass/branches/releasebranch_7_0/scripts/i.tasscap/i.tasscap.py 2014-12-02 16:06:50 UTC (rev 63325)
@@ -15,6 +15,7 @@
# TODO: Check if MODIS Tasseled Cap makes sense to be added
# http://ieeexplore.ieee.org/xpls/abs_all.jsp?arnumber=1025776
# Add other, e.g from here: http://www.sjsu.edu/faculty/watkins/tassel.htm
# References:
# LANDSAT-4/LANDSAT-5:
@@ -32,6 +33,11 @@
# This is published as well in INT. J. OF RS, 2002, VOL 23, NO. 8, 1741-1748.
# Compare discussion:
# http://adis.cesnet.cz/cgi-bin/lwgate/IMAGRS-L/archives/imagrs-l.log0211/date/article-14.html
+# Landsat8: Baig, M.H.A., Zhang, L., Shuai, T., Tong, Q., 2014. Derivation of a tasselled cap transformation
+# based on Landsat 8 at-satellite reflectance. Remote Sensing Letters 5, 423-431.
+# doi:10.1080/2150704X.2014.915434
#%Module
@@ -42,7 +48,7 @@
#% keywords: Tasseled Cap transformation
#%end
#%option G_OPT_R_INPUTS
-#% description: For Landsat4-7: bands 1, 2, 3, 4, 5, and 7
+#% description: For Landsat4-7: bands 1, 2, 3, 4, 5, and 7; for Landsat8: bands 2, 3, 4, 5, 6, and 7
#%end
#%option G_OPT_R_BASENAME_OUTPUT
#% label: Name for output basename raster map(s)
@@ -53,13 +59,13 @@
#% description: Satellite sensor
#% required: yes
#% multiple: no
-#% options: landsat4_tm,landsat5_tm,landsat7_etm
-#% descriptions: landsat4_tm;Use transformation rules for Landsat 4 TM;landsat5_tm;Use transformation rules for Landsat 5 TM;landsat7_etm;Use transformation rules for Landsat 7 ETM
+#% options: landsat4_tm,landsat5_tm,landsat7_etm,landsat8
+#% descriptions: landsat4_tm;Use transformation rules for Landsat 4 TM;landsat5_tm;Use transformation rules for Landsat 5 TM;landsat7_etm;Use transformation rules for Landsat 7 ETM;landsat8;Use transformation rules for Landsat 8
#%end
import grass.script as grass
-# weights for 6 Landsat bands: TM4, TM5, TM7
+# weights for 6 Landsat bands: TM4, TM5, TM7, OLI
parms = [[( 0.3037, 0.2793, 0.4743, 0.5585, 0.5082, 0.1863), # Landsat TM4
(-0.2848,-0.2435,-0.5435, 0.7243, 0.0840,-0.1800),
( 0.1509, 0.1973, 0.3279, 0.3406,-0.7112,-0.4572)],
@@ -70,7 +76,11 @@
[( 0.3561, 0.3972, 0.3904, 0.6966, 0.2286, 0.1596), # Landsat TM7
(-0.3344,-0.3544,-0.4556, 0.6966,-0.0242,-0.2630),
( 0.2626, 0.2141, 0.0926, 0.0656,-0.7629,-0.5388),
- ( 0.0805,-0.0498, 0.1950,-0.1327, 0.5752,-0.7775)]]
+ ( 0.0805,-0.0498, 0.1950,-0.1327, 0.5752,-0.7775)],
+ [( 0.3029, 0.2786, 0.4733, 0.5599, 0.5080, 0.1872), # Landsat TM8
+ (-0.2941,-0.2430,-0.5424, 0.7276, 0.0713,-0.1608),
+ ( 0.1511, 0.1973, 0.3283, 0.3407,-0.7117,-0.4559),
+ (-0.8239, 0.0849, 0.4396, -0.058, 0.2013,-0.2773)]]
ordinals = ["first", "second", "third", "fourth"]
names = ["Brightness", "Greenness", "Wetness", "Haze"]
@@ -118,6 +128,8 @@
calcN(output_basename, bands, 1, 5)
elif satellite == 'landsat7_etm':
calcN(output_basename, bands, 2, 7)
+ elif satellite == 'landsat8':
+ calcN(output_basename, bands, 2, 7)
else:
raise RuntimeError("Invalid satellite: " + satellite)
