[GRASS-SVN] r63327 - in grass/trunk: lib/python/temporal lib/python/temporal/testsuite temporal/t.connect/testsuite temporal/t.info temporal/t.info/testsuite temporal/t.list temporal/t.rast.accdetect temporal/t.rast.aggregate/testsuite temporal/t.rast.algebra/testsuite temporal/t.rast.extract/testsuite temporal/t.rast.to.rast3/testsuite temporal/t.rast3d.algebra/testsuite temporal/t.rast3d.extract/testsuite temporal/t.remove temporal/t.sample/testsuite temporal/t.select temporal/t.unregister/testsuite temporal/t.vect.algebra/testsuite temporal/t.vect.db.select temporal/t.vect.export temporal/t.vect.extract temporal/t.vect.import/testsuite temporal/t.vect.list/testsuite temporal/t.vect.observe.strds/testsuite temporal/t.vect.univar/testsuite temporal/t.vect.what.strds
svn_grass at osgeo.org
Tue Dec 2 09:15:28 PST 2014
Author: huhabla
Date: 2014-12-02 09:15:28 -0800 (Tue, 02 Dec 2014)
New Revision: 63327
grass/trunk/lib/python/temporal/aggregation.py
grass/trunk/lib/python/temporal/extract.py
grass/trunk/lib/python/temporal/factory.py
grass/trunk/lib/python/temporal/mapcalc.py
grass/trunk/lib/python/temporal/open_stds.py
grass/trunk/lib/python/temporal/register.py
grass/trunk/lib/python/temporal/space_time_datasets.py
grass/trunk/lib/python/temporal/temporal_algebra.py
grass/trunk/lib/python/temporal/temporal_raster_algebra.py
grass/trunk/lib/python/temporal/temporal_vector_algebra.py
grass/trunk/lib/python/temporal/testsuite/test_register_function.py
grass/trunk/lib/python/temporal/testsuite/unittests_temporal_algebra.py
grass/trunk/lib/python/temporal/testsuite/unittests_temporal_algebra_grs.py
grass/trunk/lib/python/temporal/testsuite/unittests_temporal_conditionals.py
grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_algebra.py
grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_algebra_grs.py
grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_conditionals.py
grass/trunk/lib/python/temporal/testsuite/unittests_temporal_vector_algebra.py
grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster.py
grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster3d.py
grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_vector.py
grass/trunk/temporal/t.info/t.info.py
grass/trunk/temporal/t.info/testsuite/test.t.info.sh
grass/trunk/temporal/t.list/t.list.py
grass/trunk/temporal/t.rast.accdetect/t.rast.accdetect.py
grass/trunk/temporal/t.rast.aggregate/testsuite/test_aggregation_absolute.py
grass/trunk/temporal/t.rast.aggregate/testsuite/test_aggregation_absolute_parallel.py
grass/trunk/temporal/t.rast.aggregate/testsuite/test_aggregation_relative.py
grass/trunk/temporal/t.rast.algebra/testsuite/test_raster_algebra.py
grass/trunk/temporal/t.rast.algebra/testsuite/test_raster_algebra_granularity.py
grass/trunk/temporal/t.rast.algebra/testsuite/test_raster_algebra_granularity_fails.py
grass/trunk/temporal/t.rast.extract/testsuite/test_extract.py
grass/trunk/temporal/t.rast.to.rast3/testsuite/test_strds_to_rast3.py
grass/trunk/temporal/t.rast3d.algebra/testsuite/test_raster3d_algebra.py
grass/trunk/temporal/t.rast3d.extract/testsuite/test_extract.py
grass/trunk/temporal/t.remove/t.remove.py
grass/trunk/temporal/t.sample/testsuite/test.t.sample.sh
grass/trunk/temporal/t.select/test.t.select.sh
grass/trunk/temporal/t.unregister/testsuite/test_unregister.py
grass/trunk/temporal/t.vect.algebra/testsuite/test_vector_algebra.py
grass/trunk/temporal/t.vect.db.select/test.t.vect.db.select.sh
grass/trunk/temporal/t.vect.export/test.t.vect.export.sh
grass/trunk/temporal/t.vect.extract/test.t.vect.extract.layer.sh
grass/trunk/temporal/t.vect.extract/test.t.vect.extract.sh
grass/trunk/temporal/t.vect.import/testsuite/test.t.vect.import.sh
grass/trunk/temporal/t.vect.list/testsuite/test.t.vect.list.layer.sh
grass/trunk/temporal/t.vect.list/testsuite/test.t.vect.list.sh
grass/trunk/temporal/t.vect.observe.strds/testsuite/test.t.vect.observe.strds.layer_bug.sh
grass/trunk/temporal/t.vect.observe.strds/testsuite/test.t.vect.observe.strds.relative.sh
grass/trunk/temporal/t.vect.observe.strds/testsuite/test.t.vect.observe.strds.sh
grass/trunk/temporal/t.vect.univar/testsuite/test.t.vect.univar.sh
grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds.layer.sh
grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds.sh
grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds_relative.sh
temporal framework: Fixing the framework caused by option renaming
Modified: grass/trunk/lib/python/temporal/aggregation.py
--- grass/trunk/lib/python/temporal/aggregation.py 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/lib/python/temporal/aggregation.py 2014-12-02 17:15:28 UTC (rev 63327)
@@ -228,7 +228,7 @@
r_series = pymod.Module("r.series", output="spam", method=[method],
overwrite=overwrite, quiet=True, run_=False,
finish_=False)
- g_copy = pymod.Module("g.copy", rast=['spam', 'spamspam'],
+ g_copy = pymod.Module("g.copy", raster=['spam', 'spamspam'],
quiet=True, run_=False, finish_=False)
output_list = []
count = 0
@@ -308,7 +308,7 @@
process_queue.put(mod)
else:
mod = copy.deepcopy(g_copy)
- mod(rast=[aggregation_list[0], output_name])
+ mod(raster=[aggregation_list[0], output_name])
if connected:
Modified: grass/trunk/lib/python/temporal/extract.py
--- grass/trunk/lib/python/temporal/extract.py 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/lib/python/temporal/extract.py 2014-12-02 17:15:28 UTC (rev 63327)
@@ -234,13 +234,13 @@
names += ",%s" % (map.get_name())
count += 1
if type == "raster":
- gscript.run_command("g.remove", flags='f', type='rast',
+ gscript.run_command("g.remove", flags='f', type='raster',
name=names, quiet=True)
elif type == "raster3d":
gscript.run_command("g.remove", flags='f', type='3draster',
elif type == "vector":
- gscript.run_command("g.remove", flags='f', type='vect',
+ gscript.run_command("g.remove", flags='f', type='vector',
dbif.close()
Modified: grass/trunk/lib/python/temporal/factory.py
--- grass/trunk/lib/python/temporal/factory.py 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/lib/python/temporal/factory.py 2014-12-02 17:15:28 UTC (rev 63327)
@@ -26,8 +26,8 @@
def dataset_factory(type, id):
"""A factory functions to create space time or map datasets
- :param type: the dataset type: rast or raster, 3draster,
- vect or vector, strds, str3ds, stvds
+ :param type: the dataset type: rast or raster; rast3d, raster3d or 3draster;
+ vect or vector; strds; str3ds; stvds
:param id: The id of the dataset ("name at mapset")
if type == "strds":
@@ -38,7 +38,7 @@
sp = SpaceTimeVectorDataset(id)
elif type == "rast" or type == "raster":
sp = RasterDataset(id)
- elif type == "3draster":
+ elif type == "3draster" or type == "rast3d" or type == "raster3d":
sp = Raster3DDataset(id)
elif type == "vect" or type == "vector":
sp = VectorDataset(id)
Modified: grass/trunk/lib/python/temporal/mapcalc.py
--- grass/trunk/lib/python/temporal/mapcalc.py 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/lib/python/temporal/mapcalc.py 2014-12-02 17:15:28 UTC (rev 63327)
@@ -328,7 +328,7 @@
count += 1
Modified: grass/trunk/lib/python/temporal/open_stds.py
--- grass/trunk/lib/python/temporal/open_stds.py 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/lib/python/temporal/open_stds.py 2014-12-02 17:15:28 UTC (rev 63327)
@@ -52,7 +52,7 @@
if type == "strds" or type == "rast" or type == "raster":
sp = dataset_factory("strds", id)
- elif type == "str3ds" or type == "3draster" or type == "3draster":
+ elif type == "str3ds" or type == "raster3d" or type == "rast3d" or type == "3draster":
sp = dataset_factory("str3ds", id)
elif type == "stvds" or type == "vect" or type == "vector":
sp = dataset_factory("stvds", id)
@@ -108,7 +108,7 @@
+ elif type == "str3ds" or type == "raster3d" or type == "rast3d "or type == "3draster":
@@ -235,7 +235,7 @@
mapset = get_current_mapset()
dbif, connected = init_dbif(dbif)
- new_map = check_new_map_dataset(name, layer, "raster", overwrite, dbif)
+ new_map = check_new_map_dataset(name, layer, type, overwrite, dbif)
# Check if new map is in the temporal database
if new_map.is_in_db(dbif):
Modified: grass/trunk/lib/python/temporal/register.py
--- grass/trunk/lib/python/temporal/register.py 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/lib/python/temporal/register.py 2014-12-02 17:15:28 UTC (rev 63327)
@@ -35,17 +35,17 @@
It takes care of the correct update of the space time datasets from all
registered maps.
- :param type: The type of the maps rast, 3draster or vect
+ :param type: The type of the maps raster, 3draster or vector
:param name: The name of the space time dataset. Maps will be
registered in the temporal database if the name was set
to None
:param maps: A comma separated list of map names
:param file: Input file, one map per line map with start and optional
end time
- :param start: The start date and time of the first raster map
+ :param start: The start date and time of the first map
(format absolute: "yyyy-mm-dd HH:MM:SS" or "yyyy-mm-dd",
format relative is integer 5)
- :param end: The end date and time of the first raster map
+ :param end: The end date and time of the first map
:param unit: The unit of the relative time: years, months, days,
@@ -308,7 +308,7 @@
if name and map_object_list:
count = 0
num_maps = len(map_object_list)
- msgr.message(_("Registering maps in the space time raster dataset..."))
+ msgr.message(_("Registering maps in the space time dataset..."))
for map in map_object_list:
if count % 50 == 0:
msgr.percent(count, num_maps, 1)
@@ -317,7 +317,7 @@
# Update the space time tables
- msgr.message(_("Updating space time raster dataset..."))
+ msgr.message(_("Updating space time dataset..."))
sp.update_from_registered_maps(dbif)
if update_cmd_list is True:
sp.update_command_string(dbif=dbif)
@@ -327,7 +327,7 @@
for dataset in datatsets_to_modify:
ds = dataset_factory("strds", dataset)
ds = dataset_factory("str3ds", dataset)
ds = dataset_factory("stvds", dataset)
@@ -349,10 +349,10 @@
:param ttype: The temporal type which should be assigned
and which the time format is of
:param map: A map dataset object derived from abstract_map_dataset
@@ -434,7 +434,7 @@
"""Register a list of AbstractMapDataset objects in the temporal database
and optional in a space time dataset.
- :param type: The type of the map layer (rast, 3draster, vect)
+ :param type: The type of the map layer (raster, 3draster, vector)
:param map_list: List of AbstractMapDataset objects
:param output_stds: The output stds
:param delete_empty: Set True to delete empty map layer found in the map_list
@@ -452,7 +452,7 @@
empty_maps = []
for map_layer in map_list:
- # Read the raster map data
+ # Read the map data
map_layer.load()
# In case of a empty map continue, do not register empty maps
@@ -488,7 +488,12 @@
map.delete(dbif)
mod = copy.deepcopy(g_remove)
if map.get_name():
- mod(type='rast', name=map.get_name())
+ if map.get_type() == "raster":
+ mod(type='raster', name=map.get_name())
+ if map.get_type() == "raster3d":
+ mod(type='3draster', name=map.get_name())
+ if map.get_type() == "vector":
+ mod(type='vector', name=map.get_name())
mod.run()
if connected:
Modified: grass/trunk/lib/python/temporal/space_time_datasets.py
--- grass/trunk/lib/python/temporal/space_time_datasets.py 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/lib/python/temporal/space_time_datasets.py 2014-12-02 17:15:28 UTC (rev 63327)
@@ -100,7 +100,7 @@
>>> rmap.is_time_relative()
False
- >>> grass.run_command("g.remove", flags="f", type="rast", name=name, quiet=True)
+ >>> grass.run_command("g.remove", flags="f", type="raster", name=name, quiet=True)
0
>>> grass.del_temp_region()
@@ -746,7 +746,7 @@
True
>>> vmap.is_time_relative()
False
- >>> grass.run_command("g.remove", flags="f", type="vect", name=name, quiet=True)
+ >>> grass.run_command("g.remove", flags="f", type="vector", name=name, quiet=True)
0
Modified: grass/trunk/lib/python/temporal/temporal_algebra.py
--- grass/trunk/lib/python/temporal/temporal_algebra.py 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/lib/python/temporal/temporal_algebra.py 2014-12-02 17:15:28 UTC (rev 63327)
@@ -1070,14 +1070,6 @@
for chunk in chunklist:
stringlist = ",".join(chunk)
- # Transform the map type
- if map_type == "raster":
- map_type = "rast"
- if map_type == "raster3d":
- map_type = "3draster"
- if map_type == "vector":
- map_type = "vect"
if self.run:
m = copy.deepcopy(self.m_mremove)
m.inputs["type"].value = map_type
@@ -2068,7 +2060,7 @@
# Copy the map
if map_i.get_type() == 'raster':
m = copy.deepcopy(self.m_copy)
- m.inputs["rast"].value = map_i.get_id(), newident
+ m.inputs["raster"].value = map_i.get_id(), newident
m.flags["overwrite"].value = self.overwrite
process_queue.put(m)
elif map_i.get_type() == 'raster3d':
@@ -2078,7 +2070,7 @@
elif map_i.get_type() == 'vector':
- m.inputs["vect"].value = map_i.get_id(), newident
+ m.inputs["vector"].value = map_i.get_id(), newident
else:
Modified: grass/trunk/lib/python/temporal/temporal_raster_algebra.py
--- grass/trunk/lib/python/temporal/temporal_raster_algebra.py 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/lib/python/temporal/temporal_raster_algebra.py 2014-12-02 17:15:28 UTC (rev 63327)
@@ -85,7 +85,7 @@
self.overwrite = overwrite
self.count = 0
self.stdstype = "strds"
- self.maptype = "rast"
+ self.maptype = "raster"
self.mapclass = RasterDataset
self.basename = basename
self.expression = expression
Modified: grass/trunk/lib/python/temporal/temporal_vector_algebra.py
--- grass/trunk/lib/python/temporal/temporal_vector_algebra.py 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/lib/python/temporal/temporal_vector_algebra.py 2014-12-02 17:15:28 UTC (rev 63327)
@@ -140,7 +140,7 @@
self.count = 0
self.stdstype = "stvds"
- self.maptype = "vect"
+ self.maptype = "vector"
self.mapclass = VectorDataset
@@ -420,7 +420,7 @@
# Change map name to given basename.
newident = self.basename + "_" + str(count)
m = copy.deepcopy(self.m_rename)
- m.inputs["vect"].value = (map_i.get_name(),newident)
+ m.inputs["vector"].value = (map_i.get_name(),newident)
m.run()
map_i.set_id(newident + "@" + mapset)
@@ -451,7 +451,7 @@
# Copy the map
m.run()
else:
Modified: grass/trunk/lib/python/temporal/testsuite/test_register_function.py
--- grass/trunk/lib/python/temporal/testsuite/test_register_function.py 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/lib/python/temporal/testsuite/test_register_function.py 2014-12-02 17:15:28 UTC (rev 63327)
@@ -43,15 +43,17 @@
expression="register_map_2 = 2")
self.strds_abs = tgis.open_new_stds(name="register_test_abs", type="strds", temporaltype="absolute",
- title="Test strds", descr="Test strds", semantic="field")
+ title="Test strds", descr="Test strds", semantic="field",
+ overwrite=True)
self.strds_rel = tgis.open_new_stds(name="register_test_rel", type="strds", temporaltype="relative",
+ overwrite=True)
def tearDown(self):
"""Remove maps from temporal database
self.runModule("t.unregister", maps="register_map_1,register_map_2", quiet=True)
- self.runModule("g.remove", flags='f', type="rast", name="register_map_1,register_map_2", quiet=True)
+ self.runModule("g.remove", flags='f', type="raster", name="register_map_1,register_map_2", quiet=True)
self.strds_abs.delete()
self.strds_rel.delete()
@@ -59,7 +61,7 @@
"""Test the registration of maps with absolute time in a
- tgis.register_maps_in_space_time_dataset(type="rast", name=self.strds_abs.get_name(),
+ tgis.register_maps_in_space_time_dataset(type="raster", name=self.strds_abs.get_name(),
start="2001-01-01", increment="1 day", interval=True)
@@ -91,7 +93,7 @@
ciface.write_raster_timestamp("register_map_1", tgis.get_current_mapset(), "1 Jan 2001/2 Jan 2001")
ciface.write_raster_timestamp("register_map_2", tgis.get_current_mapset(), "2 Jan 2001/3 Jan 2001")
maps="register_map_1,register_map_2")
map = tgis.RasterDataset("register_map_1@" + tgis.get_current_mapset())
@@ -114,7 +116,7 @@
def test_absolute_time_1(self):
- tgis.register_maps_in_space_time_dataset(type="rast", name=None,
+ tgis.register_maps_in_space_time_dataset(type="raster", name=None,
@@ -133,7 +135,7 @@
def test_absolute_time_2(self):
start="2001-01-01 10:30:01", increment="8 hours", interval=False)
@@ -157,7 +159,7 @@
ciface.write_raster_timestamp("register_map_1", tgis.get_current_mapset(), "1 Jan 2001 10:30:01")
ciface.write_raster_timestamp("register_map_2", tgis.get_current_mapset(), "1 Jan 2001 18:30:01")
@@ -175,7 +177,7 @@
- tgis.register_maps_in_space_time_dataset(type="rast", name=self.strds_rel.get_name(),
+ tgis.register_maps_in_space_time_dataset(type="raster", name=self.strds_rel.get_name(),
maps="register_map_1,register_map_2", start=0,
increment=1, unit="day", interval=True)
@@ -208,7 +210,7 @@
ciface.write_raster_timestamp("register_map_1", tgis.get_current_mapset(), "1000000 seconds/1500000 seconds")
ciface.write_raster_timestamp("register_map_2", tgis.get_current_mapset(), "1500000 seconds/2000000 seconds")
@@ -234,7 +236,7 @@
def test_relative_time_1(self):
"""Test the registration of maps with relative time
start=0, increment=1, unit="day", interval=True)
@@ -255,7 +257,7 @@
def test_relative_time_2(self):
start=1000000, increment=500000, unit="seconds", interval=True)
@@ -281,7 +283,7 @@
Modified: grass/trunk/lib/python/temporal/testsuite/unittests_temporal_algebra.py
--- grass/trunk/lib/python/temporal/testsuite/unittests_temporal_algebra.py 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/lib/python/temporal/testsuite/unittests_temporal_algebra.py 2014-12-02 17:15:28 UTC (rev 63327)
@@ -46,15 +46,15 @@
tgis.open_new_stds(name="D", type="strds", temporaltype="absolute",
title="D", descr="D", semantic="field", overwrite=True)
- tgis.register_maps_in_space_time_dataset(type="rast", name="A", maps="a1,a2,a3,a4",
+ tgis.register_maps_in_space_time_dataset(type="raster", name="A", maps="a1,a2,a3,a4",
- tgis.register_maps_in_space_time_dataset(type="rast", name="B", maps="b1,b2",
+ tgis.register_maps_in_space_time_dataset(type="raster", name="B", maps="b1,b2",
start="2001-01-01", increment="2 day", interval=True)
- tgis.register_maps_in_space_time_dataset(type="rast", name="C", maps="c1",
+ tgis.register_maps_in_space_time_dataset(type="raster", name="C", maps="c1",
start="2001-01-02", increment="2 day", interval=True)
- tgis.register_maps_in_space_time_dataset(type="rast", name="D", maps="d1,d2,d3",
+ tgis.register_maps_in_space_time_dataset(type="raster", name="D", maps="d1,d2,d3",
start="2001-01-03", increment="1 day", interval=True)
- tgis.register_maps_in_space_time_dataset(type="rast", name=None, maps="singletmap",
+ tgis.register_maps_in_space_time_dataset(type="raster", name=None, maps="singletmap",
start="2001-01-03", end="2001-01-04", interval=True)
def tearDown(self):
Modified: grass/trunk/lib/python/temporal/testsuite/unittests_temporal_algebra_grs.py
--- grass/trunk/lib/python/temporal/testsuite/unittests_temporal_algebra_grs.py 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/lib/python/temporal/testsuite/unittests_temporal_algebra_grs.py 2014-12-02 17:15:28 UTC (rev 63327)
@@ -48,19 +48,19 @@
- tgis.register_maps_in_space_time_dataset(type="rast", name="A", maps="a1,a2,a3,a4,a5,a6",
+ tgis.register_maps_in_space_time_dataset(type="raster", name="A", maps="a1,a2,a3,a4,a5,a6",
start="2001-01-01", increment="1 month", interval=True)
start="2001-01-01", increment="3 months", interval=True)
start="2001-01-01", increment="1 year", interval=True)
- tgis.register_maps_in_space_time_dataset(type="rast", name="D", maps="d1",
+ tgis.register_maps_in_space_time_dataset(type="raster", name="D", maps="d1",
start="2001-01-01", increment="31 days", interval=True)
- tgis.register_maps_in_space_time_dataset(type="rast", name="D", maps="d2",
+ tgis.register_maps_in_space_time_dataset(type="raster", name="D", maps="d2",
start="2001-03-01", increment="31 days", interval=True)
- tgis.register_maps_in_space_time_dataset(type="rast", name="D", maps="d3",
+ tgis.register_maps_in_space_time_dataset(type="raster", name="D", maps="d3",
start="2001-05-01", increment="31 days", interval=True)
def tearDown(self):
@@ -85,7 +85,7 @@
ta.count = 0
ta.stdstype = "strds"
- ta.maptype = "rast"
+ ta.maptype = "raster"
ta.mapclass = tgis.RasterDataset
maplist = ta.check_stds("A")
Modified: grass/trunk/lib/python/temporal/testsuite/unittests_temporal_conditionals.py
--- grass/trunk/lib/python/temporal/testsuite/unittests_temporal_conditionals.py 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/lib/python/temporal/testsuite/unittests_temporal_conditionals.py 2014-12-02 17:15:28 UTC (rev 63327)
@@ -51,17 +51,17 @@
tgis.open_new_stds(name="E", type="strds", temporaltype="absolute",
title="E", descr="E", semantic="field", overwrite=True)
- tgis.register_maps_in_space_time_dataset(type="rast", name="E", maps="e1,e2,e3",
+ tgis.register_maps_in_space_time_dataset(type="raster", name="E", maps="e1,e2,e3",
start="2000-12-31", increment="2 day", interval=True)
def tearDown(self):
Modified: grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_algebra.py
--- grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_algebra.py 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_algebra.py 2014-12-02 17:15:28 UTC (rev 63327)
@@ -46,15 +46,15 @@
def tearDown(self):
Modified: grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_algebra_grs.py
--- grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_algebra_grs.py 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_algebra_grs.py 2014-12-02 17:15:28 UTC (rev 63327)
@@ -47,19 +47,19 @@
start="2001-01-01", increment="5 days", interval=True)
start="2001-03-01", increment="5 days", interval=True)
start="2001-05-01", increment="5 days", interval=True)
start="2001-03-01", end="2001-04-01", interval=True)
def tearDown(self):
Modified: grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_conditionals.py
--- grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_conditionals.py 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_conditionals.py 2014-12-02 17:15:28 UTC (rev 63327)
@@ -45,13 +45,13 @@
- tgis.register_maps_in_space_time_dataset(type="rast", name="D", maps="d1,d2,d3,d4",
+ tgis.register_maps_in_space_time_dataset(type="raster", name="D", maps="d1,d2,d3,d4",
def tearDown(self):
Modified: grass/trunk/lib/python/temporal/testsuite/unittests_temporal_vector_algebra.py
--- grass/trunk/lib/python/temporal/testsuite/unittests_temporal_vector_algebra.py 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/lib/python/temporal/testsuite/unittests_temporal_vector_algebra.py 2014-12-02 17:15:28 UTC (rev 63327)
@@ -24,18 +24,18 @@
cls.runModule("g.region", n=80.0, s=0.0, e=120.0,
w=0.0, t=1.0, b=0.0, res=10.0)
- cls.runModule("v.random", overwrite=True, quiet=True, n=20, seed=1, output='a1')
- cls.runModule("v.random", overwrite=True, quiet=True, n=20, seed=1, output='a2')
- cls.runModule("v.random", overwrite=True, quiet=True, n=20, seed=1, output='a3')
- cls.runModule("v.random", overwrite=True, quiet=True, n=20, seed=1, output='a4')
- cls.runModule("v.random", overwrite=True, quiet=True, n=20, seed=2, output='b1')
- cls.runModule("v.random", overwrite=True, quiet=True, n=20, seed=2, output='b2')
- cls.runModule("v.random", overwrite=True, quiet=True, n=20, seed=3, output='c1')
- cls.runModule("v.random", overwrite=True, quiet=True, n=20, seed=4, output='d1')
- cls.runModule("v.random", overwrite=True, quiet=True, n=20, seed=4, output='d2')
- cls.runModule("v.random", overwrite=True, quiet=True, n=20, seed=4, output='d3')
- cls.runModule("v.random", overwrite=True, quiet=True, n=20, seed=5, output='singletmap')
- cls.runModule("v.random", overwrite=True, quiet=True, n=20, seed=6, output='singlemap')
+ cls.runModule("v.random", overwrite=True, quiet=True, npoints=20, seed=1, output='a1')
+ cls.runModule("v.random", overwrite=True, quiet=True, npoints=20, seed=1, output='a2')
+ cls.runModule("v.random", overwrite=True, quiet=True, npoints=20, seed=1, output='a3')
+ cls.runModule("v.random", overwrite=True, quiet=True, npoints=20, seed=1, output='a4')
+ cls.runModule("v.random", overwrite=True, quiet=True, npoints=20, seed=2, output='b1')
+ cls.runModule("v.random", overwrite=True, quiet=True, npoints=20, seed=2, output='b2')
+ cls.runModule("v.random", overwrite=True, quiet=True, npoints=20, seed=3, output='c1')
+ cls.runModule("v.random", overwrite=True, quiet=True, npoints=20, seed=4, output='d1')
+ cls.runModule("v.random", overwrite=True, quiet=True, npoints=20, seed=4, output='d2')
+ cls.runModule("v.random", overwrite=True, quiet=True, npoints=20, seed=4, output='d3')
+ cls.runModule("v.random", overwrite=True, quiet=True, npoints=20, seed=5, output='singletmap')
+ cls.runModule("v.random", overwrite=True, quiet=True, npoints=20, seed=6, output='singlemap')
tgis.open_new_stds(name="A", type="stvds", temporaltype="absolute",
title="A", descr="A", semantic="field", overwrite=True)
@@ -46,15 +46,15 @@
tgis.open_new_stds(name="D", type="stvds", temporaltype="absolute",
- tgis.register_maps_in_space_time_dataset(type="vect", name="A", maps="a1,a2,a3,a4",
+ tgis.register_maps_in_space_time_dataset(type="vector", name="A", maps="a1,a2,a3,a4",
- tgis.register_maps_in_space_time_dataset(type="vect", name="B", maps="b1,b2",
+ tgis.register_maps_in_space_time_dataset(type="vector", name="B", maps="b1,b2",
- tgis.register_maps_in_space_time_dataset(type="vect", name="C", maps="c1",
+ tgis.register_maps_in_space_time_dataset(type="vector", name="C", maps="c1",
- tgis.register_maps_in_space_time_dataset(type="vect", name="D", maps="d1,d2,d3",
+ tgis.register_maps_in_space_time_dataset(type="vector", name="D", maps="d1,d2,d3",
- tgis.register_maps_in_space_time_dataset(type="vect", name=None, maps="singletmap",
+ tgis.register_maps_in_space_time_dataset(type="vector", name=None, maps="singletmap",
def tearDown(self):
Modified: grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster.py
--- grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster.py 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster.py 2014-12-02 17:15:28 UTC (rev 63327)
@@ -31,7 +31,7 @@
cls.runModule("t.create", type="strds", temporaltype="absolute",
output="A", title="A test", description="A test")
- cls.runModule("t.register", flags="i", type="rast", input="A",
+ cls.runModule("t.register", flags="i", type="raster", input="A",
maps="a1,a2,a3",
start="2001-01-01", increment="%i months"%i)
@@ -56,7 +56,7 @@
maps="a1,a2,a3",
@@ -219,7 +219,7 @@
start_time=2001-01-01 00:00:00
end_time=2001-02-01 00:00:00 """
- info = SimpleModule("t.info", flags="g", type="rast", input="a1 at test1")
+ info = SimpleModule("t.info", flags="g", type="raster", input="a1 at test1")
self.assertModuleKeyValue(module=info, reference=tinfo_string, precision=2, sep="=")
tinfo_string="""id=a1 at test2
@@ -229,7 +229,7 @@
end_time=2001-03-01 00:00:00 """
- info = SimpleModule("t.info", flags="g", type="rast", input="a1 at test2")
+ info = SimpleModule("t.info", flags="g", type="raster", input="a1 at test2")
tinfo_string="""id=a1 at test3
@@ -239,7 +239,7 @@
end_time=2001-04-01 00:00:00 """
- info = SimpleModule("t.info", flags="g", type="rast", input="a1 at test3")
+ info = SimpleModule("t.info", flags="g", type="raster", input="a1 at test3")
tinfo_string="""id=a1 at test4
@@ -249,7 +249,7 @@
end_time=2001-05-01 00:00:00 """
- info = SimpleModule("t.info", flags="g", type="rast", input="a1 at test4")
+ info = SimpleModule("t.info", flags="g", type="raster", input="a1 at test4")
tinfo_string="""id=a1 at test5
@@ -259,7 +259,7 @@
end_time=2001-06-01 00:00:00 """
- info = SimpleModule("t.info", flags="g", type="rast", input="a1 at test5")
+ info = SimpleModule("t.info", flags="g", type="raster", input="a1 at test5")
if __name__ == '__main__':
Modified: grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster3d.py
--- grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster3d.py 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster3d.py 2014-12-02 17:15:28 UTC (rev 63327)
@@ -28,7 +28,7 @@
cls.runModule("t.create", type="str3ds", temporaltype="absolute",
output="A", title="A test3d", description="A test3d")
- cls.runModule("t.register", flags="i", type="rast3d", input="A",
+ cls.runModule("t.register", flags="i", type="3draster", input="A",
maps="a1,a2,a3",
@@ -165,7 +165,7 @@
- info = SimpleModule("t.info", flags="g", type="rast3d", input="a1 at test3d1")
+ info = SimpleModule("t.info", flags="g", type="3draster", input="a1 at test3d1")
tinfo_string="""id=a1 at test3d2
@@ -175,7 +175,7 @@
- info = SimpleModule("t.info", flags="g", type="rast3d", input="a1 at test3d2")
+ info = SimpleModule("t.info", flags="g", type="3draster", input="a1 at test3d2")
tinfo_string="""id=a1 at test3d3
@@ -185,7 +185,7 @@
- info = SimpleModule("t.info", flags="g", type="rast3d", input="a1 at test3d3")
+ info = SimpleModule("t.info", flags="g", type="3draster", input="a1 at test3d3")
tinfo_string="""id=a1 at test3d4
@@ -195,7 +195,7 @@
- info = SimpleModule("t.info", flags="g", type="rast3d", input="a1 at test3d4")
+ info = SimpleModule("t.info", flags="g", type="3draster", input="a1 at test3d4")
Modified: grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_vector.py
--- grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_vector.py 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_vector.py 2014-12-02 17:15:28 UTC (rev 63327)
@@ -14,7 +14,6 @@
from grass.gunittest.gmodules import SimpleModule
import os
mapset_count = 0
class TestRasterExtraction(TestCase):
@@ -25,13 +24,13 @@
cls.runModule("g.mapset", flags="c", mapset="testvect%i"%i)
cls.runModule("g.region", s=0, n=80, w=0, e=120, b=0, t=50, res=10, res3=10)
# Use always the current mapset as temporal database
- cls.runModule("v.random", output="a1", n=20)
- cls.runModule("v.random", output="a2", n=20)
- cls.runModule("v.random", output="a3", n=20)
+ cls.runModule("v.random", output="a1", npoints=20)
+ cls.runModule("v.random", output="a2", npoints=20)
+ cls.runModule("v.random", output="a3", npoints=20)
cls.runModule("t.create", type="stvds", temporaltype="absolute",
output="A", title="A testvect", description="A testvect")
- cls.runModule("t.register", flags="i", type="vect", input="A",
+ cls.runModule("t.register", flags="i", type="vector", input="A",
maps="a1,a2,a3",
@@ -176,7 +175,7 @@
- info = SimpleModule("t.info", flags="g", type="vect", input="a1 at testvect1")
+ info = SimpleModule("t.info", flags="g", type="vector", input="a1 at testvect1")
tinfo_string="""id=a1 at testvect2
@@ -186,7 +185,7 @@
- info = SimpleModule("t.info", flags="g", type="vect", input="a1 at testvect2")
+ info = SimpleModule("t.info", flags="g", type="vector", input="a1 at testvect2")
tinfo_string="""id=a1 at testvect3
@@ -196,7 +195,7 @@
- info = SimpleModule("t.info", flags="g", type="vect", input="a1 at testvect3")
+ info = SimpleModule("t.info", flags="g", type="vector", input="a1 at testvect3")
tinfo_string="""id=a1 at testvect4
@@ -206,7 +205,7 @@
- info = SimpleModule("t.info", flags="g", type="vect", input="a1 at testvect4")
+ info = SimpleModule("t.info", flags="g", type="vector", input="a1 at testvect4")
Modified: grass/trunk/temporal/t.info/t.info.py
--- grass/trunk/temporal/t.info/t.info.py 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/temporal/t.info/t.info.py 2014-12-02 17:15:28 UTC (rev 63327)
@@ -27,7 +27,7 @@
#%option G_OPT_STDS_TYPE
#% guidependency: input
#% guisection: Required
-#% options: strds, str3ds, stvds, rast, 3draster, vect
+#% options: strds, str3ds, stvds, raster, 3draster, vector
#%end
#%flag
Modified: grass/trunk/temporal/t.info/testsuite/test.t.info.sh
--- grass/trunk/temporal/t.info/testsuite/test.t.info.sh 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/temporal/t.info/testsuite/test.t.info.sh 2014-12-02 17:15:28 UTC (rev 63327)
@@ -29,18 +29,18 @@
t.create type=stvds temporaltype=absolute output=lidar_abs_ds1 title="A test" descr="A test"
t.create type=stvds temporaltype=absolute output=lidar_abs_ds2 title="A test" descr="A test"
-t.register type=rast -i input=precip_abs1 maps=prec_1,prec_2 start="2001-01-01" increment="20 years"
+t.register type=raster -i input=precip_abs1 maps=prec_1,prec_2 start="2001-01-01" increment="20 years"
t.info type=strds input=precip_abs1
t.info -g type=strds input=precip_abs1
-t.register type=rast -i input=precip_abs2 maps=prec_1,prec_2 start="2001-01-01" increment="20 years"
+t.register type=raster -i input=precip_abs2 maps=prec_1,prec_2 start="2001-01-01" increment="20 years"
t.info type=strds input=precip_abs2
t.info -g type=strds input=precip_abs2
t.info -h type=strds input=precip_abs2
-t.info type=rast input=prec_1
-t.info -g type=rast input=prec_1
-t.info type=rast input=prec_2
-t.info -g type=rast input=prec_2
+t.info type=raster input=prec_1
+t.info -g type=raster input=prec_1
+t.info type=raster input=prec_2
+t.info -g type=raster input=prec_2
t.register type=3draster -i input=precip_abs1 maps=prec_1,prec_2 start="2001-01-01" increment="20 years"
@@ -51,29 +51,29 @@
t.info type=str3ds input=precip_abs2
t.info -g type=str3ds input=precip_abs2
t.info -h type=str3ds input=precip_abs2
-t.info type=rast3 input=prec_1
-t.info -g type=rast3 input=prec_1
-t.info type=rast3 input=prec_2
-t.info -g type=rast3 input=prec_2
+t.info type=3draster input=prec_1
+t.info -g type=3draster input=prec_1
+t.info type=3draster input=prec_2
+t.info -g type=3draster input=prec_2
-t.register type=vect --v -i input=lidar_abs_ds1 maps=lidar_abs_1,lidar_abs_2 start="2001-01-01" increment="20 years"
+t.register type=vector --v -i input=lidar_abs_ds1 maps=lidar_abs_1,lidar_abs_2 start="2001-01-01" increment="20 years"
t.info type=stvds input=lidar_abs_ds1
t.info -g type=stvds input=lidar_abs_ds1
-t.register type=vect --v -i input=lidar_abs_ds2 maps=lidar_abs_1,lidar_abs_2 start="2001-01-01" increment="20 years"
+t.register type=vector --v -i input=lidar_abs_ds2 maps=lidar_abs_1,lidar_abs_2 start="2001-01-01" increment="20 years"
t.info type=stvds input=lidar_abs_ds2
t.info -g type=stvds input=lidar_abs_ds2
-t.info type=vect input=lidar_abs_1
-t.info -g type=vect input=lidar_abs_1
-t.info type=vect input=lidar_abs_2
-t.info -g type=vect input=lidar_abs_2
+t.info type=vector input=lidar_abs_1
+t.info -g type=vector input=lidar_abs_1
+t.info type=vector input=lidar_abs_2
+t.info -g type=vector input=lidar_abs_2
-t.unregister type=vect maps=lidar_abs_1,lidar_abs_2
+t.unregister type=vector maps=lidar_abs_1,lidar_abs_2
t.remove type=stvds input=lidar_abs_ds1,lidar_abs_ds2
-t.unregister type=rast maps=prec_1,prec_2
+t.unregister type=raster maps=prec_1,prec_2
t.remove type=strds input=precip_abs1,precip_abs2
-t.unregister type=rast3 maps=prec_1,prec_2
+t.unregister type=3draster maps=prec_1,prec_2
t.remove type=str3ds input=precip_abs1,precip_abs2
Modified: grass/trunk/temporal/t.list/t.list.py
--- grass/trunk/temporal/t.list/t.list.py 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/temporal/t.list/t.list.py 2014-12-02 17:15:28 UTC (rev 63327)
@@ -27,7 +27,7 @@
#% description: Type of the space time dataset or map, default is strds
#% guisection: Selection
#% required: no
#% answer: strds
#%end
Modified: grass/trunk/temporal/t.rast.accdetect/t.rast.accdetect.py
--- grass/trunk/temporal/t.rast.accdetect/t.rast.accdetect.py 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/temporal/t.rast.accdetect/t.rast.accdetect.py 2014-12-02 17:15:28 UTC (rev 63327)
@@ -418,7 +418,7 @@
# Remove empty maps
if len(empty_maps) > 0:
for map in empty_maps:
- grass.run_command("g.remove", flags='f', type="rast", name=map.get_name(), quiet=True)
+ grass.run_command("g.remove", flags='f', type="raster", name=map.get_name(), quiet=True)
Modified: grass/trunk/temporal/t.rast.aggregate/testsuite/test_aggregation_absolute.py
--- grass/trunk/temporal/t.rast.aggregate/testsuite/test_aggregation_absolute.py 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/temporal/t.rast.aggregate/testsuite/test_aggregation_absolute.py 2014-12-02 17:15:28 UTC (rev 63327)
@@ -36,7 +36,7 @@
description="A test", overwrite=True)
maps="a1,a2,a3,a4,a5,a6,a7",
start="2001-01-15 12:05:45",
increment="14 days",
Modified: grass/trunk/temporal/t.rast.aggregate/testsuite/test_aggregation_absolute_parallel.py
--- grass/trunk/temporal/t.rast.aggregate/testsuite/test_aggregation_absolute_parallel.py 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/temporal/t.rast.aggregate/testsuite/test_aggregation_absolute_parallel.py 2014-12-02 17:15:28 UTC (rev 63327)
@@ -35,7 +35,7 @@
maps=name_list,
start="2001-01-01",
increment="4 hours",
Modified: grass/trunk/temporal/t.rast.aggregate/testsuite/test_aggregation_relative.py
--- grass/trunk/temporal/t.rast.aggregate/testsuite/test_aggregation_relative.py 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/temporal/t.rast.aggregate/testsuite/test_aggregation_relative.py 2014-12-02 17:15:28 UTC (rev 63327)
@@ -36,7 +36,7 @@
start=0, unit="days", increment=3,
overwrite=True)
Modified: grass/trunk/temporal/t.rast.algebra/testsuite/test_raster_algebra.py
--- grass/trunk/temporal/t.rast.algebra/testsuite/test_raster_algebra.py 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/temporal/t.rast.algebra/testsuite/test_raster_algebra.py 2014-12-02 17:15:28 UTC (rev 63327)
@@ -47,15 +47,15 @@
title="D", descr="D", semantic="field")
def tearDown(self):
Modified: grass/trunk/temporal/t.rast.algebra/testsuite/test_raster_algebra_granularity.py
--- grass/trunk/temporal/t.rast.algebra/testsuite/test_raster_algebra_granularity.py 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/temporal/t.rast.algebra/testsuite/test_raster_algebra_granularity.py 2014-12-02 17:15:28 UTC (rev 63327)
@@ -48,19 +48,19 @@
def tearDown(self):
Modified: grass/trunk/temporal/t.rast.algebra/testsuite/test_raster_algebra_granularity_fails.py
--- grass/trunk/temporal/t.rast.algebra/testsuite/test_raster_algebra_granularity_fails.py 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/temporal/t.rast.algebra/testsuite/test_raster_algebra_granularity_fails.py 2014-12-02 17:15:28 UTC (rev 63327)
@@ -32,9 +32,9 @@
tgis.open_new_stds(name="A", type="strds", temporaltype="absolute",
- tgis.register_maps_in_space_time_dataset(type="rast", name="A", maps="a1",
+ tgis.register_maps_in_space_time_dataset(type="raster", name="A", maps="a1",
start="2001-02-01", end="2001-04-01", interval=True)
- tgis.register_maps_in_space_time_dataset(type="rast", name="A", maps="a2",
+ tgis.register_maps_in_space_time_dataset(type="raster", name="A", maps="a2",
start="2001-03-01", end="2001-05-01", interval=True)
@classmethod
Modified: grass/trunk/temporal/t.rast.extract/testsuite/test_extract.py
--- grass/trunk/temporal/t.rast.extract/testsuite/test_extract.py 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/temporal/t.rast.extract/testsuite/test_extract.py 2014-12-02 17:15:28 UTC (rev 63327)
@@ -42,7 +42,7 @@
self.runModule("t.create", type="strds", temporaltype="absolute",
output="precip_abs1", title="A test", description="A test", overwrite=True)
- self.runModule("t.register", flags="i", type="rast", input="precip_abs1",
+ self.runModule("t.register", flags="i", type="raster", input="precip_abs1",
maps="prec_1,prec_2,prec_3,prec_4,prec_5,prec_6",
start="2001-01-01", increment="3 months", overwrite=True)
Modified: grass/trunk/temporal/t.rast.to.rast3/testsuite/test_strds_to_rast3.py
--- grass/trunk/temporal/t.rast.to.rast3/testsuite/test_strds_to_rast3.py 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/temporal/t.rast.to.rast3/testsuite/test_strds_to_rast3.py 2014-12-02 17:15:28 UTC (rev 63327)
@@ -46,21 +46,21 @@
output="precip_i", title="A test integer",
description="A test integer values")
- self.runModule("t.register", flags="i", type="rast", input="precip_i",
+ self.runModule("t.register", flags="i", type="raster", input="precip_i",
maps="prec_1i,prec_2i,prec_3i,prec_4i,prec_5i,prec_6i",
start="2001-01-01", increment="3 months")
output="precip_f", title="A test float",
description="A test float values")
- self.runModule("t.register", flags="i", type="rast", input="precip_f",
+ self.runModule("t.register", flags="i", type="raster", input="precip_f",
maps="prec_1f,prec_2f,prec_3f,prec_4f,prec_5f,prec_6f",
output="precip_d", title="A test float",
- self.runModule("t.register", flags="i", type="rast", input="precip_d",
+ self.runModule("t.register", flags="i", type="raster", input="precip_d",
maps="prec_1d,prec_2d,prec_3d,prec_4d,prec_5d,prec_6d",
Modified: grass/trunk/temporal/t.rast3d.algebra/testsuite/test_raster3d_algebra.py
--- grass/trunk/temporal/t.rast3d.algebra/testsuite/test_raster3d_algebra.py 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/temporal/t.rast3d.algebra/testsuite/test_raster3d_algebra.py 2014-12-02 17:15:28 UTC (rev 63327)
@@ -34,7 +34,7 @@
tgis.open_new_stds(name="A", type="str3ds", temporaltype="absolute",
- tgis.register_maps_in_space_time_dataset(type="rast3d", name="A", maps="a1,a2,a3,a4",
+ tgis.register_maps_in_space_time_dataset(type="3draster", name="A", maps="a1,a2,a3,a4",
def tearDown(self):
Modified: grass/trunk/temporal/t.rast3d.extract/testsuite/test_extract.py
--- grass/trunk/temporal/t.rast3d.extract/testsuite/test_extract.py 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/temporal/t.rast3d.extract/testsuite/test_extract.py 2014-12-02 17:15:28 UTC (rev 63327)
@@ -41,7 +41,7 @@
self.runModule("t.create", type="str3ds", temporaltype="absolute",
output="A", title="A test", description="A test", overwrite=True)
- self.runModule("t.register", flags="i", type="rast3d", input="A",
+ self.runModule("t.register", flags="i", type="3draster", input="A",
Modified: grass/trunk/temporal/t.remove/t.remove.py
--- grass/trunk/temporal/t.remove/t.remove.py 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/temporal/t.remove/t.remove.py 2014-12-02 17:15:28 UTC (rev 63327)
@@ -132,7 +132,12 @@
# Delete every 100 maps
if count%100 == 0:
dbif.execute_transaction(map_statement)
- remove(type="rast", name=name_list, run_=True)
+ if type == "strds":
+ remove(type="raster", name=name_list, run_=True)
+ if type == "stvds":
+ remove(type="vector", name=name_list, run_=True)
+ if type == "str3ds":
+ remove(type="3draster", name=name_list, run_=True)
map_statement = ""
name_list = []
@@ -140,11 +145,11 @@
if name_list:
if type == "strds":
- remove(type="rast", name=",".join(name_list), run_=True)
if type == "stvds":
- remove(type="vect", name=",".join(name_list), run_=True)
- remove(type="3draster", name=",".join(name_list), run_=True)
statement += sp.delete(dbif=dbif, execute=False)
Modified: grass/trunk/temporal/t.sample/testsuite/test.t.sample.sh
--- grass/trunk/temporal/t.sample/testsuite/test.t.sample.sh 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/temporal/t.sample/testsuite/test.t.sample.sh 2014-12-02 17:15:28 UTC (rev 63327)
@@ -16,15 +16,15 @@
r.mapcalc expr="prec_5 = rand(0, 300)" -s
r.mapcalc expr="prec_6 = rand(0, 650)" -s
-v.random -z output=pnts1 n=20 zmin=0 zmax=100 column=height
-v.random -z output=pnts2 n=20 zmin=0 zmax=100 column=height
+v.random -z output=pnts1 npoints=20 zmin=0 zmax=100 column=height
+v.random -z output=pnts2 npoints=20 zmin=0 zmax=100 column=height
-v.random -z output=pnts3 n=20 zmin=0 zmax=100 column=height
-v.random -z output=pnts4 n=20 zmin=0 zmax=100 column=height
-v.random -z output=pnts5 n=20 zmin=0 zmax=100 column=height
-v.random -z output=pnts6 n=20 zmin=0 zmax=100 column=height
-v.random -z output=pnts7 n=20 zmin=0 zmax=100 column=height
-v.random -z output=pnts8 n=20 zmin=0 zmax=100 column=height
+v.random -z output=pnts3 npoints=20 zmin=0 zmax=100 column=height
+v.random -z output=pnts4 npoints=20 zmin=0 zmax=100 column=height
+v.random -z output=pnts5 npoints=20 zmin=0 zmax=100 column=height
+v.random -z output=pnts6 npoints=20 zmin=0 zmax=100 column=height
+v.random -z output=pnts7 npoints=20 zmin=0 zmax=100 column=height
+v.random -z output=pnts8 npoints=20 zmin=0 zmax=100 column=height
n1=`g.tempfile pid=1 -d`
n2=`g.tempfile pid=2 -d`
Modified: grass/trunk/temporal/t.select/test.t.select.sh
--- grass/trunk/temporal/t.select/test.t.select.sh 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/temporal/t.select/test.t.select.sh 2014-12-02 17:15:28 UTC (rev 63327)
@@ -13,15 +13,15 @@
do
if [ "$i" -le 20 ]; then
echo testpoint1_$i >> ${n1}
- v.random -z output=testpoint1_$i n=3 seed=$i
+ v.random -z output=testpoint1_$i npoints=3 seed=$i
elif [ "$i" -gt 20 ] && [ "$i" -le 40 ]; then
echo testpoint2_$i >> ${n2}
- v.random -z output=testpoint2_$i n=3 seed=$i
+ v.random -z output=testpoint2_$i npoints=3 seed=$i
else
echo testpoint3_$i >> ${n3}
echo testpoint4_$i >> ${n4}
- v.random -z output=testpoint3_$i n=3 seed=$i
- v.random -z output=testpoint4_$i n=3 seed=$i
+ v.random -z output=testpoint3_$i npoints=3 seed=$i
+ v.random -z output=testpoint4_$i npoints=3 seed=$i
fi
done
Modified: grass/trunk/temporal/t.unregister/testsuite/test_unregister.py
--- grass/trunk/temporal/t.unregister/testsuite/test_unregister.py 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/temporal/t.unregister/testsuite/test_unregister.py 2014-12-02 17:15:28 UTC (rev 63327)
@@ -44,7 +44,7 @@
- self.runModule("t.register", flags="i", type="rast", input="A",
+ self.runModule("t.register", flags="i", type="raster", input="A",
overwrite=True)
@@ -52,14 +52,14 @@
output="B", title="B test",
description="B test", overwrite=True)
- self.runModule("t.register", flags="i", type="rast", input="B",
+ self.runModule("t.register", flags="i", type="raster", input="B",
overwrite=True)
def tearDown(self):
"""Remove generated data"""
- self.runModule("g.remove", type="rast",
+ self.runModule("g.remove", type="raster",
name="a1,a2,a3,a4,a5,a6")
def test_1(self):
@@ -95,7 +95,7 @@
# Check if maps a1, a2 and a3 are still present in the temporal database
- lister = SimpleModule("t.list", type="rast", columns="name",
+ lister = SimpleModule("t.list", type="raster", columns="name",
where='mapset = "%s" AND (name = "a1" OR name = "a2" OR name = "a3")'%(tgis.get_current_mapset()))
self.runModule(lister)
self.assertEqual(a123, lister.outputs.stdout)
@@ -104,7 +104,7 @@
# Unregister maps a1, a2 and a3 from the temporal database
self.assertModule("t.unregister", maps="a1,a2,a3")
self.assertEqual("", lister.outputs.stdout)
@@ -120,7 +120,7 @@
# Remove STRDS A and B and chceck if maps a4, a5 and a6 are still in the temporal database
self.assertModule("t.remove", type="strds", inputs="A,B")
where='mapset = "%s" AND (name = "a4" OR name = "a5" OR name = "a6")'%(tgis.get_current_mapset()))
self.assertEqual(a456, lister.outputs.stdout)
@@ -129,7 +129,7 @@
# Unregister maps a4, a5 and a6 from the temporal database
self.assertModule("t.unregister", maps="a4,a5,a6")
Modified: grass/trunk/temporal/t.vect.algebra/testsuite/test_vector_algebra.py
--- grass/trunk/temporal/t.vect.algebra/testsuite/test_vector_algebra.py 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/temporal/t.vect.algebra/testsuite/test_vector_algebra.py 2014-12-02 17:15:28 UTC (rev 63327)
@@ -25,18 +25,18 @@
- cls.runModule("v.random", quiet=True, n=20, seed=1, output='a1')
- cls.runModule("v.random", quiet=True, n=20, seed=1, output='a2')
- cls.runModule("v.random", quiet=True, n=20, seed=1, output='a3')
- cls.runModule("v.random", quiet=True, n=20, seed=1, output='a4')
- cls.runModule("v.random", quiet=True, n=20, seed=2, output='b1')
- cls.runModule("v.random", quiet=True, n=20, seed=2, output='b2')
- cls.runModule("v.random", quiet=True, n=20, seed=3, output='c1')
- cls.runModule("v.random", quiet=True, n=20, seed=4, output='d1')
- cls.runModule("v.random", quiet=True, n=20, seed=4, output='d2')
- cls.runModule("v.random", quiet=True, n=20, seed=4, output='d3')
- cls.runModule("v.random", quiet=True, n=20, seed=5, output='singletmap')
- cls.runModule("v.random", quiet=True, n=20, seed=6, output='singlemap')
+ cls.runModule("v.random", quiet=True, npoints=20, seed=1, output='a1')
+ cls.runModule("v.random", quiet=True, npoints=20, seed=1, output='a2')
+ cls.runModule("v.random", quiet=True, npoints=20, seed=1, output='a3')
+ cls.runModule("v.random", quiet=True, npoints=20, seed=1, output='a4')
+ cls.runModule("v.random", quiet=True, npoints=20, seed=2, output='b1')
+ cls.runModule("v.random", quiet=True, npoints=20, seed=2, output='b2')
+ cls.runModule("v.random", quiet=True, npoints=20, seed=3, output='c1')
+ cls.runModule("v.random", quiet=True, npoints=20, seed=4, output='d1')
+ cls.runModule("v.random", quiet=True, npoints=20, seed=4, output='d2')
+ cls.runModule("v.random", quiet=True, npoints=20, seed=4, output='d3')
+ cls.runModule("v.random", quiet=True, npoints=20, seed=5, output='singletmap')
+ cls.runModule("v.random", quiet=True, npoints=20, seed=6, output='singlemap')
title="A", descr="A", semantic="field")
@@ -47,15 +47,15 @@
def tearDown(self):
Modified: grass/trunk/temporal/t.vect.db.select/test.t.vect.db.select.sh
--- grass/trunk/temporal/t.vect.db.select/test.t.vect.db.select.sh 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/temporal/t.vect.db.select/test.t.vect.db.select.sh 2014-12-02 17:15:28 UTC (rev 63327)
@@ -37,8 +37,8 @@
t.unregister type=rast maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
t.remove type=stvds input=prec_observer
-t.unregister type=vect maps=prec_observer:1,prec_observer:2,prec_observer:3,prec_observer:4,prec_observer:5,prec_observer:6
+t.unregister type=vector maps=prec_observer:1,prec_observer:2,prec_observer:3,prec_observer:4,prec_observer:5,prec_observer:6
-g.remove -f type=vect name=prec_observer,test_extract
+g.remove -f type=vector name=prec_observer,test_extract
g.remove -f type=rast name=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
Modified: grass/trunk/temporal/t.vect.export/test.t.vect.export.sh
--- grass/trunk/temporal/t.vect.export/test.t.vect.export.sh 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/temporal/t.vect.export/test.t.vect.export.sh 2014-12-02 17:15:28 UTC (rev 63327)
@@ -19,7 +19,7 @@
EOF
t.create --o type=stvds temporaltype=absolute output=soil_abs1 title="A test" descr="A test"
-t.register -i type=vect input=soil_abs1 file="${n1}" start='2001-01-01' increment="1 months"
+t.register -i type=vector input=soil_abs1 file="${n1}" start='2001-01-01' increment="1 months"
# The first @test
t.vect.export format=GML input=soil_abs1 output=stvds_export_gml.tar.bz2 compression=bzip2 workdir=/tmp
@@ -30,7 +30,7 @@
t.vect.export format=pack input=soil_abs1 output=stvds_export_pack.tar.gz compression=gzip workdir=/tmp
t.vect.export format=pack input=soil_abs1 output=stvds_export_pack.tar compression=no workdir=/tmp
-t.unregister type=vect file="${n1}"
+t.unregister type=vector file="${n1}"
t.remove type=stvds input=soil_abs1
rm stvds_export_gml.tar.bz2
rm stvds_export_gml.tar.gz
Modified: grass/trunk/temporal/t.vect.extract/test.t.vect.extract.layer.sh
--- grass/trunk/temporal/t.vect.extract/test.t.vect.extract.layer.sh 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/temporal/t.vect.extract/test.t.vect.extract.layer.sh 2014-12-02 17:15:28 UTC (rev 63327)
@@ -37,11 +37,11 @@
# @postprocess
-t.unregister type=rast maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+t.unregister type=raster maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
t.remove type=stvds input=prec_observer,test_extract_1,test_extract_2,test_extract_3
-g.remove -f type=vect pattern=test_*
-g.remove -f type=rast name=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+g.remove -f type=vector pattern=test_*
+g.remove -f type=raster name=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
Modified: grass/trunk/temporal/t.vect.extract/test.t.vect.extract.sh
--- grass/trunk/temporal/t.vect.extract/test.t.vect.extract.sh 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/temporal/t.vect.extract/test.t.vect.extract.sh 2014-12-02 17:15:28 UTC (rev 63327)
@@ -27,7 +27,7 @@
EOF
t.info type=stvds input=soil_abs1
t.vect.list input=soil_abs1
@@ -42,7 +42,7 @@
t.vect.list input=soil_abs3 columns=name,start_time,end_time,primitives
# @postprocess
-t.unregister type=vect maps=soil_1,soil_2,soil_3,soil_4,soil_5,soil_6,soil_7,soil_8
+t.unregister type=vector maps=soil_1,soil_2,soil_3,soil_4,soil_5,soil_6,soil_7,soil_8
t.remove type=stvds input=soil_abs1,soil_abs2,soil_abs3
-g.remove -f type=vect name=soil_1,soil_2,soil_3,soil_4,soil_5,soil_6,soil_7,soil_8
-g.remove -f type=vect name=new_vect_1,new_vect_2,new_vect_3,new_vect_4,new_vect_5,new_vect_6
+g.remove -f type=vector name=soil_1,soil_2,soil_3,soil_4,soil_5,soil_6,soil_7,soil_8
+g.remove -f type=vector name=new_vect_1,new_vect_2,new_vect_3,new_vect_4,new_vect_5,new_vect_6
Modified: grass/trunk/temporal/t.vect.import/testsuite/test.t.vect.import.sh
--- grass/trunk/temporal/t.vect.import/testsuite/test.t.vect.import.sh 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/temporal/t.vect.import/testsuite/test.t.vect.import.sh 2014-12-02 17:15:28 UTC (rev 63327)
@@ -21,7 +21,7 @@
EOF
# The first @test
@@ -59,8 +59,8 @@
# Cleaning up
rm -rf test
Modified: grass/trunk/temporal/t.vect.list/testsuite/test.t.vect.list.layer.sh
--- grass/trunk/temporal/t.vect.list/testsuite/test.t.vect.list.layer.sh 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/temporal/t.vect.list/testsuite/test.t.vect.list.layer.sh 2014-12-02 17:15:28 UTC (rev 63327)
@@ -87,38 +87,38 @@
t.create type=stvds temporaltype=absolute output=soils_abs5 title="A test with input files" descr="A test with input files"
# The first @test
-t.register type=vect input=soils_abs1 file="${n1}" start="2001-01-01" increment="1 months"
+t.register type=vector input=soils_abs1 file="${n1}" start="2001-01-01" increment="1 months"
t.vect.list separator=" | " method=comma input=soils_abs1
t.vect.list input=soils_abs1
t.vect.list separator=" | " method=cols input=soils_abs1
t.vect.list separator=" | " method=delta input=soils_abs1
t.vect.list separator=" | " method=deltagaps input=soils_abs1
-t.register type=vect -i input=soils_abs2 file="${n2}"
+t.register type=vector -i input=soils_abs2 file="${n2}"
t.vect.list separator=" | " method=comma input=soils_abs2
t.vect.list input=soils_abs2
t.vect.list separator=" | " method=cols input=soils_abs2
t.vect.list separator=" | " method=delta input=soils_abs2
t.vect.list separator=" | " method=deltagaps input=soils_abs2
-t.register type=vect -i input=soils_abs3 file="${n3}"
+t.register type=vector -i input=soils_abs3 file="${n3}"
t.vect.list separator=" | " method=comma input=soils_abs3
t.vect.list separator=" | " method=delta input=soils_abs3
t.vect.list separator=" | " method=deltagaps input=soils_abs3
-t.register type=vect -i input=soils_abs4 file="${n4}"
+t.register type=vector -i input=soils_abs4 file="${n4}"
t.vect.list separator=" | " method=comma input=soils_abs4
t.vect.list separator=" | " method=delta input=soils_abs4
t.vect.list separator=" | " method=deltagaps input=soils_abs4
-t.register type=vect -i input=soils_abs5 file="${n5}"
+t.register type=vector -i input=soils_abs5 file="${n5}"
t.vect.list separator=" | " method=comma input=soils_abs5
t.vect.list input=soils_abs5
t.vect.list separator=" | " method=cols input=soils_abs5
t.vect.list separator=" | " method=delta input=soils_abs5
t.vect.list separator=" | " method=deltagaps input=soils_abs5
-t.unregister type=vect maps=soils:1,soils:2,soils:3,soils:4,soils:5,soils:6
+t.unregister type=vector maps=soils:1,soils:2,soils:3,soils:4,soils:5,soils:6
t.remove type=stvds input=soils_abs1,soils_abs2,soils_abs3,soils_abs4,soils_abs5
-g.remove -f type=vect name=soil_orig,soils
+g.remove -f type=vector name=soil_orig,soils
Modified: grass/trunk/temporal/t.vect.list/testsuite/test.t.vect.list.sh
--- grass/trunk/temporal/t.vect.list/testsuite/test.t.vect.list.sh 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/temporal/t.vect.list/testsuite/test.t.vect.list.sh 2014-12-02 17:15:28 UTC (rev 63327)
@@ -73,37 +73,37 @@
t.create type=stvds temporaltype=absolute output=lidar_abs5 title="A test with input files" descr="A test with input files"
# The first @test
-t.register type=vect input=lidar_abs1 file="${n1}" start="2001-01-01" increment="1 months"
+t.register type=vector input=lidar_abs1 file="${n1}" start="2001-01-01" increment="1 months"
t.vect.list separator=" | " method=comma input=lidar_abs1
t.vect.list input=lidar_abs1
t.vect.list separator=" | " method=cols input=lidar_abs1
t.vect.list separator=" | " method=delta input=lidar_abs1
t.vect.list separator=" | " method=deltagaps input=lidar_abs1
-t.register type=vect -i input=lidar_abs2 file="${n2}"
+t.register type=vector -i input=lidar_abs2 file="${n2}"
t.vect.list separator=" | " method=comma input=lidar_abs2
t.vect.list input=lidar_abs2
t.vect.list separator=" | " method=cols input=lidar_abs2
t.vect.list separator=" | " method=delta input=lidar_abs2
t.vect.list separator=" | " method=deltagaps input=lidar_abs2
-t.register type=vect -i input=lidar_abs3 file="${n3}"
+t.register type=vector -i input=lidar_abs3 file="${n3}"
t.vect.list separator=" | " method=comma input=lidar_abs3
t.vect.list separator=" | " method=delta input=lidar_abs3
t.vect.list separator=" | " method=deltagaps input=lidar_abs3
-t.register type=vect -i input=lidar_abs4 file="${n4}"
+t.register type=vector -i input=lidar_abs4 file="${n4}"
t.vect.list separator=" | " method=comma input=lidar_abs4
t.vect.list separator=" | " method=delta input=lidar_abs4
t.vect.list separator=" | " method=deltagaps input=lidar_abs4
-t.register type=vect -i input=lidar_abs5 file="${n5}"
+t.register type=vector -i input=lidar_abs5 file="${n5}"
t.vect.list separator=" | " method=comma input=lidar_abs5
t.vect.list input=lidar_abs5
t.vect.list separator=" | " method=cols input=lidar_abs5
t.vect.list separator=" | " method=delta input=lidar_abs5
t.vect.list separator=" | " method=deltagaps input=lidar_abs5
-#t.unregister type=vect maps=lidar_1,lidar_2,lidar_3,lidar_4,lidar_5,lidar_6
+#t.unregister type=vector maps=lidar_1,lidar_2,lidar_3,lidar_4,lidar_5,lidar_6
#t.remove type=stvds input=lidar_abs1,lidar_abs2,lidar_abs3,lidar_abs4,lidar_abs5
-#g.remove -f type=vect name=lidar_1,lidar_2,lidar_3,lidar_4,lidar_5,lidar_6
+#g.remove -f type=vector name=lidar_1,lidar_2,lidar_3,lidar_4,lidar_5,lidar_6
Modified: grass/trunk/temporal/t.vect.observe.strds/testsuite/test.t.vect.observe.strds.layer_bug.sh
--- grass/trunk/temporal/t.vect.observe.strds/testsuite/test.t.vect.observe.strds.layer_bug.sh 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/temporal/t.vect.observe.strds/testsuite/test.t.vect.observe.strds.layer_bug.sh 2014-12-02 17:15:28 UTC (rev 63327)
@@ -32,9 +32,9 @@
t.vect.db.select input=prec_observer
# @postprocess
-t.unregister type=rast file=${MAP_LIST}
+t.unregister type=raster file=${MAP_LIST}
-#g.remove -f type=vect name=prec_observer
-#g.remove -f type=rast pattern="test_prec_*"
+#g.remove -f type=vector name=prec_observer
+#g.remove -f type=raster pattern="test_prec_*"
Modified: grass/trunk/temporal/t.vect.observe.strds/testsuite/test.t.vect.observe.strds.relative.sh
--- grass/trunk/temporal/t.vect.observe.strds/testsuite/test.t.vect.observe.strds.relative.sh 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/temporal/t.vect.observe.strds/testsuite/test.t.vect.observe.strds.relative.sh 2014-12-02 17:15:28 UTC (rev 63327)
@@ -26,10 +26,10 @@
# @postprocess
-#g.remove -f type=vect name=prec_observer,test_extract
-#g.remove -f type=rast name=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+#g.remove -f type=vector name=prec_observer,test_extract
+#g.remove -f type=raster name=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
Modified: grass/trunk/temporal/t.vect.observe.strds/testsuite/test.t.vect.observe.strds.sh
--- grass/trunk/temporal/t.vect.observe.strds/testsuite/test.t.vect.observe.strds.sh 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/temporal/t.vect.observe.strds/testsuite/test.t.vect.observe.strds.sh 2014-12-02 17:15:28 UTC (rev 63327)
@@ -19,7 +19,7 @@
r.mapcalc expr="prec_9 = 600.0"
-v.random output=prec n=5 seed=1
+v.random output=prec npoints=5 seed=1
v.random -z output=test_1 column=test n=5 seed=1
t.create type=strds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
Modified: grass/trunk/temporal/t.vect.univar/testsuite/test.t.vect.univar.sh
--- grass/trunk/temporal/t.vect.univar/testsuite/test.t.vect.univar.sh 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/temporal/t.vect.univar/testsuite/test.t.vect.univar.sh 2014-12-02 17:15:28 UTC (rev 63327)
@@ -15,7 +15,7 @@
v.voronoi input=rpoints2 output=rvoronoi2
t.create type=stvds temporaltype=absolute output=random_data title="A test" descr="A test"
-t.register type=vect --v -i input=random_data maps=rpoints1,rpoints2,rvoronoi1,rvoronoi2 start="2001-01-15 12:05:45" increment="14 days"
+t.register type=vector --v -i input=random_data maps=rpoints1,rpoints2,rvoronoi1,rvoronoi2 start="2001-01-15 12:05:45" increment="14 days"
# The first @test
t.vect.univar input=random_data column=height where='height > 50' twhere="start_time > '2000-01-01'" layer=1
@@ -25,7 +25,7 @@
t.vect.univar type=line input=random_data column=height where='height > 20' twhere="start_time > '2000-01-01'" layer=1
# @postprocess
-t.unregister type=vect maps=rpoints1,rpoints2,rvoronoi1,rvoronoi2
+t.unregister type=vector maps=rpoints1,rpoints2,rvoronoi1,rvoronoi2
t.remove type=stvds input=random_data
-g.remove -f type=vect name=rpoints1,rpoints2,rvoronoi1,rvoronoi2
+g.remove -f type=vector name=rpoints1,rpoints2,rvoronoi1,rvoronoi2
Modified: grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds.layer.sh
--- grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds.layer.sh 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds.layer.sh 2014-12-02 17:15:28 UTC (rev 63327)
@@ -41,15 +41,15 @@
EOF
t.create --o type=stvds temporaltype=absolute output=soil_abs title="A test" descr="A test"
-t.register -i type=vect input=soil_abs file="${n1}" start="2001-03-01 00:00:00" increment="1 months"
+t.register -i type=vector input=soil_abs file="${n1}" start="2001-03-01 00:00:00" increment="1 months"
t.vect.list input=soil_abs columns=name,layer,start_time,end_time
t.create --o type=strds temporaltype=absolute output=sand_frac_abs_1 title="A test" descr="A test"
-t.register -i type=rast input=sand_frac_abs_1 maps=sand_frac start="2001-01-01 00:00:00" increment="12 months"
+t.register -i type=raster input=sand_frac_abs_1 maps=sand_frac start="2001-01-01 00:00:00" increment="12 months"
t.rast.list input=sand_frac_abs_1 columns=name,start_time,end_time
t.create --o type=strds temporaltype=absolute output=sand_frac_abs_2 title="A test" descr="A test"
-t.register -i type=rast input=sand_frac_abs_2 maps=sand_frac_1,sand_frac_2,sand_frac_3,sand_frac_4,sand_frac_5,sand_frac_6 \
+t.register -i type=raster input=sand_frac_abs_2 maps=sand_frac_1,sand_frac_2,sand_frac_3,sand_frac_4,sand_frac_5,sand_frac_6 \
t.rast.list input=sand_frac_abs_2 columns=name,start_time,end_time
@@ -71,11 +71,11 @@
v.db.select map=soils layer=6
# @postprocess
-t.unregister type=rast maps=sand_frac,sand_frac_1,sand_frac_2,sand_frac_3,sand_frac_4,sand_frac_5,sand_frac_6
+t.unregister type=raster maps=sand_frac,sand_frac_1,sand_frac_2,sand_frac_3,sand_frac_4,sand_frac_5,sand_frac_6
t.remove type=strds input=sand_frac_abs_1,sand_frac_abs_2
-g.remove -f type=rast name=sand_frac,sand_frac_1,sand_frac_2,sand_frac_3,sand_frac_4,sand_frac_5,sand_frac_6
-g.remove -f type=vect name=soils,soil_orig
+g.remove -f type=raster name=sand_frac,sand_frac_1,sand_frac_2,sand_frac_3,sand_frac_4,sand_frac_5,sand_frac_6
+g.remove -f type=vector name=soils,soil_orig
Modified: grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds.sh
--- grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds.sh 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds.sh 2014-12-02 17:15:28 UTC (rev 63327)
@@ -25,10 +25,10 @@
EOF
-t.register type=vect input=soil_abs1 file="${n1}"
+t.register type=vector input=soil_abs1 file="${n1}"
t.create --o type=strds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
-t.register -i type=rast input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-03-01 00:00:00" increment="1 months"
+t.register -i type=raster input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-03-01 00:00:00" increment="1 months"
# The @test
@@ -48,11 +48,11 @@
v.db.select map=soil_3
# @postprocess
Modified: grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds_relative.sh
--- grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds_relative.sh 2014-12-02 16:33:08 UTC (rev 63326)
+++ grass/trunk/temporal/t.vect.what.strds/test.t.vect.what.strds_relative.sh 2014-12-02 17:15:28 UTC (rev 63327)
@@ -12,9 +12,9 @@
r.mapcalc --o expr="prec_5 = 500.0"
r.mapcalc --o expr="prec_6 = 600.0"
-v.random --o -z output=soil_1 n=5 zmin=0 zmax=100 column=heigh seed=1
-v.random --o -z output=soil_2 n=5 zmin=0 zmax=100 column=height seed=2
-v.random --o -z output=soil_3 n=5 zmin=0 zmax=100 column=height seed=3
+v.random --o -z output=soil_1 npoints=5 zmin=0 zmax=100 column=heigh seed=1
+v.random --o -z output=soil_2 npoints=5 zmin=0 zmax=100 column=height seed=2
+v.random --o -z output=soil_3 npoints=5 zmin=0 zmax=100 column=height seed=3
@@ -25,11 +25,11 @@
EOF
t.create --o type=stvds temporaltype=relative output=soil_rel1 title="A test" descr="A test"
-t.register type=vect input=soil_rel1 file="${n1}" unit=minutes
+t.register type=vector input=soil_rel1 file="${n1}" unit=minutes
t.info type=stvds input=soil_rel1
t.create --o type=strds temporaltype=relative output=precip_rel1 title="A test" descr="A test"
-t.register type=rast input=precip_rel1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start=0 increment=5 unit=minutes
+t.register type=raster input=precip_rel1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start=0 increment=5 unit=minutes
# The @test
@@ -49,11 +49,11 @@
# @postprocess
t.remove type=stvds input=soil_rel1
t.remove type=strds input=precip_rel1
