[GRASS-SVN] r63470 - grass/trunk/lib/display
svn_grass at osgeo.org
Wed Dec 10 02:46:07 PST 2014
Author: martinl
Date: 2014-12-10 02:46:07 -0800 (Wed, 10 Dec 2014)
New Revision: 63470
grass/trunk/lib/display/r_raster.c
partialy revert r63469
Modified: grass/trunk/lib/display/r_raster.c
--- grass/trunk/lib/display/r_raster.c 2014-12-10 10:44:36 UTC (rev 63469)
+++ grass/trunk/lib/display/r_raster.c 2014-12-10 10:46:07 UTC (rev 63470)
@@ -111,35 +111,32 @@
p = getenv("GRASS_RENDER_IMMEDIATE");
m = G__getenv("MONITOR");
- if (m) {
- char *env;
- const char *v;
- char *u_m;
- /* GRASS variable names should be upper case. */
- u_m = G_store_upper(m);
+ if (m && G_strncasecmp(m, "wx", 2) == 0) {
+ /* wx monitors always use GRASS_RENDER_IMMEDIATE. */
+ p = NULL; /* use default display driver */
+ } else if (m) {
+ char *env;
+ const char *v;
+ char *u_m;
+ if (p)
+ G_warning(_("%s variable defined, %s ignored"),
+ "MONITOR", "GRASS_RENDER_IMMEDIATE");
+ /* GRASS variable names should be upper case. */
+ u_m = G_store_upper(m);
- env = NULL;
- G_asprintf(&env, "MONITOR_%s_MAPFILE", u_m);
- v = G__getenv(env);
- if (v)
+ env = NULL;
+ G_asprintf(&env, "MONITOR_%s_MAPFILE", u_m);
+ v = G__getenv(env);
+ p = m;
+ if (v)
G_putenv("GRASS_RENDER_FILE", v);
- if (G_strncasecmp(m, "wx", 2) == 0) {
- /* wx monitors always use GRASS_RENDER_IMMEDIATE. */
- p = NULL; /* use default display driver */
- } else {
- if (p)
- G_warning(_("%s variable defined, %s ignored"),
- "MONITOR", "GRASS_RENDER_IMMEDIATE");
- p = m;
- G_asprintf(&env, "MONITOR_%s_ENVFILE", u_m);
- if (v)
- read_env_file(v);
+ G_asprintf(&env, "MONITOR_%s_ENVFILE", u_m);
+ if (v)
+ read_env_file(v);
const struct driver *drv =
