[GRASS-SVN] r63471 - grass/trunk/lib/python/pygrass/vector
svn_grass at osgeo.org
Wed Dec 10 03:21:38 PST 2014
Author: zarch
Date: 2014-12-10 03:21:38 -0800 (Wed, 10 Dec 2014)
New Revision: 63471
grass/trunk/lib/python/pygrass/vector/geometry.py
pygrass: Fix a bug in the lines method of the class Node and improve documentation of the distance method of the Line class and change the returned value from tuple to namedtuple
Modified: grass/trunk/lib/python/pygrass/vector/geometry.py
--- grass/trunk/lib/python/pygrass/vector/geometry.py 2014-12-10 10:46:07 UTC (rev 63470)
+++ grass/trunk/lib/python/pygrass/vector/geometry.py 2014-12-10 11:21:38 UTC (rev 63471)
@@ -7,6 +7,7 @@
import ctypes
import re
+from collections import namedtuple
import numpy as np
@@ -19,6 +20,8 @@
from grass.pygrass.vector import sql
+LineDist = namedtuple('LineDist', 'point dist spdist sldist')
WKT = {'POINT\((.*)\)': 'point', # 'POINT\(\s*([+-]*\d+\.*\d*)+\s*\)'
'LINESTRING\((.*)\)': 'line'}
@@ -763,19 +766,20 @@
:param pnt: the point to calculate distance
:type pnt: a Point object or a tuple with the coordinates
- Return a tuple with:
+ Return a namedtuple with:
- * the closest point on the line,
- * the distance between these two points,
- * distance of point from segment beginning
- * distance of point from line
+ * point: the closest point on the line,
+ * dist: the distance between these two points,
+ * spdist: distance to point on line from segment beginning
+ * sldist: distance to point on line form line beginning along line
The distance is compute using the ``Vect_line_distance`` C function.
- >>> line = Line([(0, 0), (0, 2)])
- >>> line.distance(Point(1, 1))
- (Point(0.000000, 1.000000), 1.0, 1.0, 1.0)
+ >>> point = Point(2.3, 0.5)
+ >>> line = Line([(0, 0), (2, 0), (3, 0)])
+ >>> line.distance(point) #doctest: +NORMALIZE_WHITESPACE
+ LineDist(point=Point(2.300000, 0.000000),
+ dist=0.5, spdist=0.2999999999999998, sldist=2.3)
# instantite outputs
cx = ctypes.c_double(0)
@@ -795,7 +799,7 @@
# instantiate the Point class
point = Point(cx.value, cy.value, cz.value)
point.is2D = self.is2D
- return point, dist.value, sp_dist.value, lp_dist.value
+ return LineDist(point, dist.value, sp_dist.value, lp_dist.value)
def get_first_cat(self):
"""Fetches FIRST category number for given vector line and field, using
@@ -1142,7 +1146,7 @@
:type only_out: bool
for iline in self.ilines(only_in, only_out):
- yield Line(id=abs(iline), c_mapinfo=self.c_mapinfo)
+ yield Line(v_id=abs(iline), c_mapinfo=self.c_mapinfo)
def angles(self):
"""Return a generator with all lines angles in a node."""
